[GRASS-SVN] r30833 - grass/trunk/gui/wxpython
svn_grass at osgeo.org
Tue Apr 1 11:39:28 EDT 2008
Author: martinl
Date: 2008-04-01 11:39:28 -0400 (Tue, 01 Apr 2008)
New Revision: 30833
grass/trunk/gui/wxpython/wxgui.py
wxGUI (wxgui): open map display on add layer, etc. if no map display is available, trac #113
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-04-01 12:12:36 UTC (rev 30832)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-04-01 15:39:28 UTC (rev 30833)
@@ -493,6 +493,10 @@
Erase current workspace settings first"""
Debug.msg(4, "GMFrame.OnWorkspaceNew():")
+ # start new map display if no display is available
+ if not self.curr_page:
+ self.NewDisplay()
maptree = self.curr_page.maptree
@@ -528,6 +532,10 @@
Debug.msg(4, "GMFrame.OnWorkspaceOpen(): filename=%s" % filename)
+ self.NewDisplay()
self.LoadWorkspaceFile(filename)
self.workspaceFile = filename
@@ -591,9 +599,10 @@
parent=self)
wx.Yield()
+ maptree = None
for layer in gxwXml.layers:
if layer['display'] >= self.disp_idx:
- # create new map display window if needed
self.NewDisplay()
maptree = self.gm_cb.GetPage(layer['display']).maptree
newItem = maptree.AddLayer(ltype=layer['type'],
@@ -606,8 +615,9 @@
busy.Destroy()
- # reverse list of map layers
- maptree.Map.ReverseListOfLayers()
+ if maptree:
+ # reverse list of map layers
+ maptree.Map.ReverseListOfLayers()
file.close()
except IOError, err:
@@ -627,6 +637,10 @@
dialog = wxgui_utils.LoadMapLayersDialog(parent=self, title=_("Load map layers into layer tree"))
if dialog.ShowModal() == wx.ID_OK:
+ self.NewDisplay()
busy = wx.BusyInfo(message=_("Please wait, loading map layers into layer tree..."),
parent=self)
@@ -941,28 +955,32 @@
Icons["workspaceSave"].GetLabel(), self.OnWorkspaceSave),
('addrast', Icons["addrast"].GetBitmap(),
- Icons["addrast"].GetLabel(), self.OnRaster),
+ Icons["addrast"].GetLabel(), self.OnAddRaster),
('addvect', Icons["addvect"].GetBitmap(),
- Icons["addvect"].GetLabel(), self.OnVector),
+ Icons["addvect"].GetLabel(), self.OnAddVector),
('addcmd', Icons["addcmd"].GetBitmap(),
- Icons["addcmd"].GetLabel(), self.AddCommand),
+ Icons["addcmd"].GetLabel(), self.OnAddCommand),
('addgrp', Icons["addgrp"].GetBitmap(),
- Icons["addgrp"].GetLabel(), self.AddGroup),
+ Icons["addgrp"].GetLabel(), self.OnAddGroup),
('addovl', Icons["addovl"].GetBitmap(),
- Icons["addovl"].GetLabel(), self.OnOverlay),
+ Icons["addovl"].GetLabel(), self.OnAddOverlay),
('addlabels', Icons["addlabels"].GetBitmap(),
- Icons["addlabels"].GetLabel(), self.AddLabels),
+ Icons["addlabels"].GetLabel(), self.OnAddLabels),
('delcmd', Icons["delcmd"].GetBitmap(),
- Icons["delcmd"].GetLabel(), self.DeleteLayer),
+ Icons["delcmd"].GetLabel(), self.OnDeleteLayer),
('attrtable', Icons["attrtable"].GetBitmap(),
- Icons["attrtable"].GetLabel(), self.ShowAttributeTable)
+ Icons["attrtable"].GetLabel(), self.OnShowAttributeTable)
- def ShowAttributeTable(self, event):
+ def OnShowAttributeTable(self, event):
Show attribute table of the given vector map layer
+ self.MsgNoLayerSelected()
+ return
layer = self.curr_page.maptree.layer_selected
# no map layer selected
if not layer:
@@ -1051,11 +1069,16 @@
# self._auimgr.Update()
# toolBar button handlers
- def OnRaster(self, event):
+ def OnAddRaster(self, event):
"""Add raster menu"""
+ self.NewDisplay(show=False)
point = wx.GetMousePosition()
rastmenu = wx.Menu()
- # Add items to the menu
+ # add items to the menu
addrast = wx.MenuItem(rastmenu, -1, Icons["addrast"].GetLabel())
addrast.SetBitmap(Icons["addrast"].GetBitmap(self.iconsize))
rastmenu.AppendItem(addrast)
@@ -1090,9 +1113,16 @@
# will be called before PopupMenu returns.
self.PopupMenu(rastmenu)
rastmenu.Destroy()
+ # show map display
+ self.curr_page.maptree.mapdisplay.Show()
- def OnVector(self, event):
+ def OnAddVector(self, event):
"""Add vector menu"""
vectmenu = wx.Menu()
@@ -1110,13 +1140,21 @@
addchart.SetBitmap(Icons["addchart"].GetBitmap(self.iconsize))
vectmenu.AppendItem(addchart)
self.Bind(wx.EVT_MENU, self.addThemeChart, addchart)
# Popup the menu. If an item is selected then its handler
self.PopupMenu(vectmenu)
vectmenu.Destroy()
- def OnOverlay(self, event):
- """Add overlay menu"""
+ def OnAddOverlay(self, event):
+ """Add overlay menu"""
ovlmenu = wx.Menu()
@@ -1140,6 +1178,9 @@
self.PopupMenu(ovlmenu)
ovlmenu.Destroy()
def AddRaster(self, event):
self.notebook.SetSelection(0)
self.curr_page.maptree.AddLayer('raster')
@@ -1184,16 +1225,30 @@
self.curr_page.maptree.AddLayer('themechart')
- def AddCommand(self, event):
+ def OnAddCommand(self, event):
"""Add command line layer"""
self.curr_page.maptree.AddLayer('command')
- def AddGroup(self, event):
+ def OnAddGroup(self, event):
"""Add layer group"""
self.curr_page.maptree.AddLayer('group')
def AddGrid(self, event):
"""Add layer grid"""
@@ -1209,19 +1264,26 @@
self.curr_page.maptree.AddLayer('rhumb')
- def AddLabels(self, event):
+ def OnAddLabels(self, event):
"""Add layer vector labels"""
self.curr_page.maptree.AddLayer('labels')
def GetSelectedDisplay(self):
return self.notebook.GetSelection()
- def DeleteLayer(self, event):
+ def OnDeleteLayer(self, event):
Delete selected map display layer in GIS Manager tree widget
- if not self.curr_page.maptree.layer_selected:
+ if not self.curr_page or not self.curr_page.maptree.layer_selected:
return
