[GRASS-SVN] r30840 - in grass-addons/gipe: . i.dn2full.l5
Tue Apr 1 23:59:42 EDT 2008
Author: ychemin
Date: 2008-04-01 23:59:42 -0400 (Tue, 01 Apr 2008)
New Revision: 30840
Added:
   grass-addons/gipe/i.dn2full.l5/
   grass-addons/gipe/i.dn2full.l5/Makefile
   grass-addons/gipe/i.dn2full.l5/date2doy.c
   grass-addons/gipe/i.dn2full.l5/description.html
   grass-addons/gipe/i.dn2full.l5/dn2rad_landsat5.c
   grass-addons/gipe/i.dn2full.l5/l5inread.c
   grass-addons/gipe/i.dn2full.l5/main.c
   grass-addons/gipe/i.dn2full.l5/rad2ref_landsat5.c
   grass-addons/gipe/i.dn2full.l5/science_L5gain9a.txt
   grass-addons/gipe/i.dn2full.l5/tempk_landsat5.c
resbmutting i.dn2full.l5
Added: grass-addons/gipe/i.dn2full.l5/Makefile
--- grass-addons/gipe/i.dn2full.l5/Makefile	                        (rev 0)
+++ grass-addons/gipe/i.dn2full.l5/Makefile	2008-04-02 03:59:42 UTC (rev 30840)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR = ../..
+PGM = i.dn2full.l5
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LARGEFILES),)
+	EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
+endif
+default: cmd
Added: grass-addons/gipe/i.dn2full.l5/date2doy.c
--- grass-addons/gipe/i.dn2full.l5/date2doy.c	                        (rev 0)
+++ grass-addons/gipe/i.dn2full.l5/date2doy.c	2008-04-02 03:59:42 UTC (rev 30840)
@@ -0,0 +1,66 @@
+/*This program converts day/month/year to doy*/
+int date2doy(int day, int month, int year)
+	int leap=0;
+	int day_month_tot=0;
+	int doy;
+	doy=0;
+/*printf("Date is %i/%i/%i\n", day, month, year);*/
+	if (month == 1) {
+		day_month_tot = 0;
+	else if (month == 2) {
+		day_month_tot = 31;
+	else if (month == 3) {
+		day_month_tot = 59;
+	else if (month == 4) {
+		day_month_tot = 90;
+	else if (month == 5) {
+		day_month_tot = 120;
+	else if (month == 6) {
+		day_month_tot = 151;
+	else if (month == 7) {
+		day_month_tot = 181;
+	else if (month == 8) {
+		day_month_tot = 212;
+	else if (month == 9) {
+		day_month_tot = 243;
+	else if (month == 10) {
+		day_month_tot = 273;
+	else if (month == 11) {
+		day_month_tot = 304;
+	else if (month == 12) {
+		day_month_tot = 334;
+	/* Leap year if dividing by 4 leads % 0.0*/
+	if (year/4*4 == year) {
+		leap = 1;
+	doy=day_month_tot+day;
+	if(doy>59){
+		doy=day_month_tot+day+leap;
+	return(doy);
Added: grass-addons/gipe/i.dn2full.l5/description.html
--- grass-addons/gipe/i.dn2full.l5/description.html	                        (rev 0)
+++ grass-addons/gipe/i.dn2full.l5/description.html	2008-04-02 03:59:42 UTC (rev 30840)
@@ -0,0 +1,28 @@
+<H2>DESCRIPTION</H2>
+<EM>i.dn2full.l5</EM> This module is a full import module for Landsat 5. It corrects every band (1,2,3,4,5,6,7) from DN to either reflectance at top of Atmosphere or Kinetic Temperature.
+It is useful after importing your Landsat 5TM imagery from GeoTiff NLAPS processed format that is generally in standard DN values range.
+<H2>NOTES</H2>
+then run this GRASS module: "for file in *.tif; do r.in.gdal input=$file output=$file title=Landsat5TM$file ; done"
+Finally run this GRASS module: "i.dn2full.l5 NLAPS_report_file.txt output=base_ouput_name"
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="r.in.gdal.html">r.in.gdal</A><br>
+<A HREF="i.dn2ref.l7.html">i.dn2ref.l7</A><br>
+<A HREF="i.dn2ref.l7.html">i.dn2full.l7</A><br>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin, AIT, Thailand<BR>
+<p>
+<i>Last changed: $Date: 2006/10/08 11:41:43 $</i>
Added: grass-addons/gipe/i.dn2full.l5/dn2rad_landsat5.c
--- grass-addons/gipe/i.dn2full.l5/dn2rad_landsat5.c	                        (rev 0)
+++ grass-addons/gipe/i.dn2full.l5/dn2rad_landsat5.c	2008-04-02 03:59:42 UTC (rev 30840)
@@ -0,0 +1,163 @@
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+// Conversion of DN to Radiance for Landsat 5TM
+// yann.chemin at gmail.com - Yann Chemin - GPL>=2, 2008.
+double dn2rad_landsat5(int c_year, int c_month, int c_day, int year, int month, int day, int band, int DN )
+	double	result, gain, bias;
+	int	gain_mode;
+	if(c_year<2003){
+		gain_mode=1;
+	} else if (c_year==2003){
+		if(c_month<5){
+			gain_mode=1;
+		} else if(c_month==5){
+			if(c_day<5){
+				gain_mode=1;
+			}else{
+				gain_mode=2;
+		} else {
+			gain_mode=2;
+	} else if (c_year>2003&&c_year<2007){
+		gain_mode=2;
+	} else if (c_year==2007){
+		if(c_month<5){
+			gain_mode=2;
+		} else if(year<1992){
+			gain_mode=3;
+		} else {
+			gain_mode=4;
+	if (gain_mode==1){
+		if (band==1){
+			gain = 0.602431;
+			bias = -1.52;
+		if (band==2){
+			gain = 1.175100;
+			bias = -2.84;
+		if (band==3){
+			gain = 0.805765;
+			bias = -1.17;
+		if (band==4){
+			gain = 0.814549;
+			bias = -1.51;
+		if (band==5){
+			gain = 0.108078;
+			bias = -0.37;
+		if (band==6){
+			gain = 0.055158;
+			bias = 1.2378;
+		if (band==7){
+			gain = 0.056980;
+			bias = -0.15;
+	if (gain_mode==2){
+		if (band==1){
+			gain = 0.762824;
+			bias = -1.52;
+		if (band==2){
+			gain = 1.442510;
+			bias = -2.84;
+		if (band==3){
+			gain = 1.039880;
+			bias = -1.17;
+		if (band==4){
+			gain = 0.872588;
+			bias = -1.51;
+		if (band==5){
+			gain = 0.119882;
+			bias = -0.37;
+		if (band==6){
+			gain = 0.055158;
+			bias = 1.2378;
+		if (band==7){
+			gain = 0.065294;
+			bias = -0.15;
+	if (gain_mode==3){
+		if (band==1){
+			gain = 0.668706;
+			bias = -1.52;
+		if (band==2){
+			gain = 1.317020;
+			bias = -2.84;
+		if (band==3){
+			gain = 1.039880;
+			bias = -1.17;
+		if (band==4){
+			gain = 0.872588;
+			bias = -1.51;
+		if (band==5){
+			gain = 0.119882;
+			bias = -0.37;
+		if (band==6){
+			gain = 0.055158;
+			bias = 1.2378;
+		if (band==7){
+			gain = 0.065294;
+			bias = -0.15;
+	if (gain_mode==4){
+		if (band==1){
+			gain = 0.762824;
+			bias = -1.52;
+		if (band==2){
+			gain = 1.442510;
+			bias = -2.84;
+		if (band==3){
+			gain = 1.039880;
+			bias = -1.17;
+		if (band==4){
+			gain = 0.872588;
+			bias = -1.51;
+		if (band==5){
+			gain = 0.119882;
+			bias = -0.37;
+		if (band==6){
+			gain = 0.055158;
+			bias = 1.2378;
+		if (band==7){
+			gain = 0.065294;
+			bias = -0.15;
+	result 	= gain * (double) DN + bias ;
+	return result;
Added: grass-addons/gipe/i.dn2full.l5/l5inread.c
--- grass-addons/gipe/i.dn2full.l5/l5inread.c	                        (rev 0)
+++ grass-addons/gipe/i.dn2full.l5/l5inread.c	2008-04-02 03:59:42 UTC (rev 30840)
@@ -0,0 +1,94 @@
+#include<stdio.h>
+#include<stdlib.h>
+#include<string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+int l5_in_read(char *metfName,int *path, int *row, double *latitude,double *longitude,double *sun_elevation, double *sun_azimuth,int *c_year, int *c_month, int *c_day,int *day, int *month, int *year,double *decimal_hour)
+	FILE 		*f;
+	char 		s[1000], *ptr;
+	int 		i=0;
+	char 		*p;
+	int 		hour, minute;
+	float		second;
+	if((f=fopen(metfName,"r"))==NULL){
+		G_fatal_error (_("NLAPS report file [%s] not found, are you in the proper directory?"), metfName);
+	while (fgets(s,1000,f)!=NULL)
+		ptr = strstr(s, "Strip no.");
+		if (ptr != NULL)
+			p = strtok(ptr, ":");
+			p = strtok(NULL, " ");
+			*path = atoi(p);
+			p = strtok(NULL, "Start Row no.:");
+			*row = atoi(p);
+		ptr = strstr(s, "center lat");
+		if (ptr != NULL)
+			*latitude = atof(p);
+			p = strtok(NULL, " deg");
+			p = strtok(NULL, " Scene center long:");
+			*longitude = atof(p);
+		ptr = strstr(s, "Sun Elevation");
+		if (ptr != NULL)
+			*sun_elevation = atof(p);
+			p = strtok(NULL, "Sun Azimuth:");
+			*sun_azimuth = atof(p);
+		ptr = strstr(s, "center date");
+		if (ptr != NULL)
+			*year = atoi(p);
+			*month = atoi(p);
+			*day = atoi(p);
+			p = strtok(NULL, " Scene center time:");
+			hour = atoi(p);
+			p = strtok(NULL, ":");
+			minute = atoi(p);
+			second = atof(p);
+		ptr = strstr(s, "Completion date");
+		if (ptr != NULL)
+			*c_year = atoi(p);
+			*c_month = atoi(p);
+			*c_day = atoi(p);
+//	printf("year = %i\n", year);
+//	printf("month = %i\n", month);
+//	printf("day = %i\n", day);
+//	printf("sun azimuth = %f\n", sun_azimuth);
+//	printf("sun elevation = %f\n", sun_elevation);
+//	printf("latitude = %f\n", latitude);
+//	printf("longitude = %f\n", longitude);
+	(void)fclose(f);
+	return;
Added: grass-addons/gipe/i.dn2full.l5/main.c
--- grass-addons/gipe/i.dn2full.l5/main.c	                        (rev 0)
+++ grass-addons/gipe/i.dn2full.l5/main.c	2008-04-02 03:59:42 UTC (rev 30840)
@@ -0,0 +1,433 @@
+ * MODULE:       i.dn2full.l5
+ * AUTHOR(S):    Yann Chemin - ychemin at gmail.com
+ * PURPOSE:      Calculate TOA Reflectance&Temperature for Landsat5 from DN.
+ * COPYRIGHT:    (C) 2002 by the GRASS Development Team
+ *               This program is free software under the GNU Lesser General Public
+ *   	    	 License. Read the file COPYING that comes with GRASS for details.
+ * THANKS:	 Brad Douglas helped fixing the filename fetching
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#define MAXFILES 7
+//sun exo-atmospheric irradiance
+#define KEXO1 1969.0
+#define KEXO2 1840.0
+#define KEXO3 1551.0
+#define KEXO4 1044.0
+#define KEXO5 225.7
+#define KEXO6 00.0//filling only
+#define KEXO7 82.07
+#define PI 3.1415926
+int l5_in_read(char *metfName, int *path, int *row, double *latitude,double *longitude,double *sun_elevation, double *sun_azimuth,int *c_year, int *c_month, int *c_day, int *day, int *month, int *year,double *decimal_hour);
+int date2doy(int day, int month, int year);
+double dn2rad_landsat5(int c_year, int c_month, int c_day, int year, int month, int day, int band, int DN );
+double rad2ref_landsat5( double radiance, double doy,double sun_elevation, double k_exo );
+double tempk_landsat5( double l6 );
+int
+main(int argc, char *argv[])
+	struct Cell_head cellhd;//region+header info
+	char *mapset; //mapset name
+	int nrows, ncols;
+	int row,col;
+	struct GModule *module;
+	struct Option *input,*output;
+	struct Flag *flag1;
+	struct History history; //metadata
+	/* FMEO Declarations*****************/
+	char history_buf[200];
+	char *name; //input raster name
+	char *result; //output raster name
+	//Prepare new names for output files
+	char result1[80], result2[80], result3[80], result4[80];
+	char result5[80], result6[80], result7[80];
+	//File Descriptors
+	int infd[MAXFILES];
+	int outfd[MAXFILES];
+	char **names;
+	char **ptr;
+	int i=0,j=0;
+	void *inrast[MAXFILES];
+	unsigned char *outrast[MAXFILES];
+	RASTER_MAP_TYPE in_data_type[MAXFILES];
+	RASTER_MAP_TYPE out_data_type = DCELL_TYPE; /* 0=numbers  1=text */
+	double		kexo[MAXFILES];
+	//Metfile
+	char		*metfName; //NLAPS report file, header in text format
+	double 		sun_elevation;
+	double 		sun_azimuth;//not useful here, only for parser()
+	int 		c_day,c_month,c_year;//NLAPS processing date
+	int 		day,month,year;
+	double 		decimal_hour;
+	double 		latitude;
+	double 		longitude;
+	int		l5path, l5row;
+	//EndofMetfile
+	int 		doy;
+	char		b1[80],b2[80],b3[80];
+	char		b4[80],b5[80];
+	char		b6[80],b7[80];//Load .tif names
+	int		temp;
+	G_gisinit(argv[0]);
+	module = G_define_module();
+	module->keywords = _("DN, reflectance, temperature, import");
+	module->description =
+		_("Calculates Top of Atmosphere Reflectance/Temperature from Landsat 5 DN.\n");
+	/* Define the different options */
+	input = G_define_option() ;
+	input->key        = _("file");
+	input->type       = TYPE_STRING;
+	input->required   = YES;
+	input->gisprompt  = _("old_file,file,file");
+	input->description= _("Landsat 5TM NLAPS processing report File (.txt)");
+	output = G_define_standard_option(G_OPT_R_OUTPUT) ;
+	output->key        = _("output");
+	output->description= _("Base name of the output layers (will add .x)");
+	if (G_parser(argc, argv))
+		exit (-1);
+	metfName	= input->answer;
+	result		= output->answer;
+	//Fetch parameters for DN2Rad2Ref correction
+	l5_in_read(metfName,&l5path,&l5row,&latitude,&longitude,&sun_elevation,&sun_azimuth,&c_year,&c_month,&c_day,&day,&month,&year,&decimal_hour);
+	//Prepare the input file names
+	doy = date2doy(day,month,year);
+	//printf("doy=%i\n",doy);
+	if(year<2000){
+		temp = year - 1900;
+	} else {
+		temp = year - 2000;
+	if (temp >=10){
+		sprintf(b1, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B1.tif");
+		sprintf(b2, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B2.tif");
+		sprintf(b3, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B3.tif");
+		sprintf(b4, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B4.tif");
+		sprintf(b5, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B5.tif");
+		sprintf(b6, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B6.tif");
+		sprintf(b7, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B7.tif");
+	} else {
+		sprintf(b1, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B1.tif");
+		sprintf(b2, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B2.tif");
+		sprintf(b3, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B3.tif");
+		sprintf(b4, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B4.tif");
+		sprintf(b5, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B5.tif");
+		sprintf(b6, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B6.tif");
+		sprintf(b7, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B7.tif");
+	//printf("%f/%f/%i-%i-%i\n",sun_elevation,sun_azimuth,day,month,year);
+//	exit(1);
+	//Prepare the ouput file names
+//	printf("result=%s\n",result);
+	snprintf(result1, 80, "%s%s",result,".1");
+//	printf("%s\n",result1);
+	snprintf(result2, 80, "%s%s",result,".2");
+//	printf("%s\n",result2);
+	snprintf(result3, 80, "%s%s",result,".3");
+//	printf("%s\n",result3);
+	snprintf(result4, 80, "%s%s",result,".4");
+//	printf("%s\n",result4);
+	snprintf(result5, 80, "%s%s",result,".5");
+//	printf("%s\n",result5);
+	snprintf(result6, 80, "%s%s",result,".6");
+//	printf("%s\n",result6);
+	snprintf(result7, 80, "%s%s",result,".7");
+//	printf("%s\n",result7);
+	//Prepare sun exo-atm irradiance
+	kexo[0]=KEXO1;
+	kexo[1]=KEXO2;
+	kexo[2]=KEXO3;
+	kexo[3]=KEXO4;
+	kexo[4]=KEXO5;
+	kexo[5]=KEXO6;//filling only
+	kexo[6]=KEXO7;
+	//Band1
+	/* find map in mapset */
+	mapset = G_find_cell2 (b1, "");
+        if (mapset == NULL){
+		G_fatal_error (_("cell file [%s] not found"), b1);
+	if (G_legal_filename (b1) < 0){
+		G_fatal_error (_("[%s] is an illegal name"), b1);
+	infd[0] = G_open_cell_old (b1, mapset);
+	/* Allocate input buffer */
+	in_data_type[0] = G_raster_map_type(b1, mapset);
+	if( (infd[0] = G_open_cell_old(b1,mapset)) < 0){
+		G_fatal_error(_("Cannot open cell file [%s]"), b1);
+	if( (G_get_cellhd(b1,mapset,&cellhd)) < 0){
+		G_fatal_error(_("Cannot read file header of [%s]"), b1);
+	inrast[0] = G_allocate_raster_buf(in_data_type[0]);
+	//Band2
+	mapset = G_find_cell2 (b2, "");
+		G_fatal_error (_("cell file [%s] not found"), b2);
+	if (G_legal_filename (b2) < 0){
+		G_fatal_error (_("[%s] is an illegal name"), b2);
+	infd[1] = G_open_cell_old (b2, mapset);
+	in_data_type[1] = G_raster_map_type(b2, mapset);
+	if( (infd[1] = G_open_cell_old(b2,mapset)) < 0){
+		G_fatal_error(_("Cannot open cell file [%s]"), b2);
+	if( (G_get_cellhd(b2,mapset,&cellhd)) < 0){
+		G_fatal_error(_("Cannot read file header of [%s]"), b2);
+	inrast[1] = G_allocate_raster_buf(in_data_type[1]);
+	//Band3
+	mapset = G_find_cell2 (b3, "");
+		G_fatal_error (_("cell file [%s] not found"), b3);
+	if (G_legal_filename (b3) < 0){
+		G_fatal_error (_("[%s] is an illegal name"), b3);
+	infd[2] = G_open_cell_old (b3, mapset);
+	in_data_type[2] = G_raster_map_type(b3, mapset);
+	if( (infd[2] = G_open_cell_old(b3,mapset)) < 0){
+		G_fatal_error(_("Cannot open cell file [%s]"), b3);
+	if( (G_get_cellhd(b3,mapset,&cellhd)) < 0){
+		G_fatal_error(_("Cannot read file header of [%s]"), b3);
+	inrast[2] = G_allocate_raster_buf(in_data_type[2]);
+	//Band4
+	mapset = G_find_cell2 (b4, "");
+		G_fatal_error (_("cell file [%s] not found"), b4);
+	if (G_legal_filename (b4) < 0){
+		G_fatal_error (_("[%s] is an illegal name"), b4);
+	infd[3] = G_open_cell_old (b4, mapset);
+	in_data_type[3] = G_raster_map_type(b4, mapset);
+	if( (infd[3] = G_open_cell_old(b4,mapset)) < 0){
+		G_fatal_error(_("Cannot open cell file [%s]"), b4);
+	if( (G_get_cellhd(b4,mapset,&cellhd)) < 0){
+		G_fatal_error(_("Cannot read file header of [%s]"), b4);
+	inrast[3] = G_allocate_raster_buf(in_data_type[3]);
+	//Band5
+	mapset = G_find_cell2 (b5, "");
+		G_fatal_error (_("cell file [%s] not found"), b5);
+	if (G_legal_filename (b5) < 0){
+		G_fatal_error (_("[%s] is an illegal name"), b5);
+	infd[4] = G_open_cell_old (b5, mapset);
+	in_data_type[4] = G_raster_map_type(b5, mapset);
+	if( (infd[4] = G_open_cell_old(b5,mapset)) < 0){
+		G_fatal_error(_("Cannot open cell file [%s]"), b5);
+	if( (G_get_cellhd(b5,mapset,&cellhd)) < 0){
+		G_fatal_error(_("Cannot read file header of [%s]"), b5);
+	inrast[4] = G_allocate_raster_buf(in_data_type[4]);
+	//Band6
+	mapset = G_find_cell2 (b6, "");
+		G_fatal_error (_("cell file [%s] not found"), b6);
+	if (G_legal_filename (b6) < 0){
+		G_fatal_error (_("[%s] is an illegal name"), b6);
+	infd[5] = G_open_cell_old (b6, mapset);
+	in_data_type[5] = G_raster_map_type(b6, mapset);
+	if( (infd[5] = G_open_cell_old(b6,mapset)) < 0){
+		G_fatal_error(_("Cannot open cell file [%s]"), b6);
+	if( (G_get_cellhd(b6,mapset,&cellhd)) < 0){
+		G_fatal_error(_("Cannot read file header of [%s]"), b6);
+	inrast[5] = G_allocate_raster_buf(in_data_type[5]);
+	//Band7
+	mapset = G_find_cell2 (b7, "");
+		G_fatal_error (_("cell file [%s] not found"), b7);
+	if (G_legal_filename (b7) < 0){
+		G_fatal_error (_("[%s] is an illegal name"), b7);
+	infd[6] = G_open_cell_old (b7, mapset);
+	in_data_type[6] = G_raster_map_type(b7, mapset);
+	if( (infd[6] = G_open_cell_old(b7,mapset)) < 0){
+		G_fatal_error(_("Cannot open cell file [%s]"), b7);
+	if( (G_get_cellhd(b7,mapset,&cellhd)) < 0){
+		G_fatal_error(_("Cannot read file header of [%s]"), b7);
+	inrast[6] = G_allocate_raster_buf(in_data_type[6]);
+	/* Allocate output buffer, use input map data_type */
+	nrows = G_window_rows();
+	ncols = G_window_cols();
+	out_data_type=DCELL_TYPE;
+	for(i=0;i<MAXFILES;i++){
+		outrast[i] = G_allocate_raster_buf(out_data_type);
+	if ( (outfd[0] = G_open_raster_new (result1,1)) < 0)
+		G_fatal_error (_("Could not open <%s>"),result1);
+	if ( (outfd[1] = G_open_raster_new (result2,1)) < 0)
+		G_fatal_error (_("Could not open <%s>"),result2);
+	if ( (outfd[2] = G_open_raster_new (result3,1)) < 0)
+		G_fatal_error (_("Could not open <%s>"),result3);
+	if ( (outfd[3] = G_open_raster_new (result4,1)) < 0)
+		G_fatal_error (_("Could not open <%s>"),result4);
+	if ( (outfd[4] = G_open_raster_new (result5,1)) < 0)
+		G_fatal_error (_("Could not open <%s>"),result5);
+	if ( (outfd[5] = G_open_raster_new (result6,1)) < 0)
+		G_fatal_error (_("Could not open <%s>"),result6);
+	if ( (outfd[6] = G_open_raster_new (result7,1)) < 0)
+		G_fatal_error (_("Could not open <%s>"),result7);
+	/* Process pixels */
+	DCELL dout[MAXFILES];
+	DCELL d[MAXFILES];
+	for (row = 0; row < nrows; row++)
+		G_percent (row, nrows, 2);
+		/* read input map */
+		for (i=0;i<MAXFILES;i++)
+			if((G_get_raster_row(infd[i],inrast[i],row,in_data_type[i])) < 0){
+				G_fatal_error (_("Could not read from <%s>"),i);
+		/*process the data */
+		for (col=0; col < ncols; col++)
+				d[i] = (double) ((CELL *) inrast[i])[col];
+				dout[i]=dn2rad_landsat5(c_year,c_month,c_day,year,month,day,i+1,d[i]);
+				if(i==5){//if band 6, process brightness temperature
+					if(dout[i]<=0.0){
+						dout[i]=-999.990;
+					}else{
+						dout[i]=tempk_landsat5(dout[i]);
+				}else{//process reflectance
+					dout[i]=rad2ref_landsat5(dout[i],doy,sun_elevation,kexo[i]);
+			((DCELL *) outrast[i])[col] = dout[i];
+			if (G_put_raster_row (outfd[i], outrast[i], out_data_type) < 0)
+				G_fatal_error (_("Cannot write to <%s.%i>"),result,i+1);
+		G_free (inrast[i]);
+		G_close_cell (infd[i]);
+		G_free (outrast[i]);
+		G_close_cell (outfd[i]);
+	printf("Make Metadata\n");
+//	G_short_history(result, "raster", &history);
+//	G_command_history(&history);
+//	G_write_history(result,&history);
+//	//fill in data source line
+//		printf("1\t");
+//	strncpy(history.datsrc_1,metfName,RECORD_LEN);
+//	sprintf(history_buf,"year=%d",year);
+//		printf("1\t");
+//	strncpy(history.datsrc_1,history_buf,RECORD_LEN);
+//	sprintf(history_buf,"month=%d",month);
+//		printf("1\t");
+//	sprintf(history_buf,"day=%d",day);
+//		printf("1\t");
+//	sprintf(history_buf,"doy=%d",doy);
+//		printf("1\t");
+//	sprintf(history_buf,"sun_elevation=%f",sun_elevation);
+//		printf("1\t");
+//	sprintf(history_buf,"sun_azimuth=%f",sun_azimuth);
+//		printf("1\t");
+//		printf("1\t");
+//	history.datsrc_1[RECORD_LEN-1]='\0';//strncpy() doesn't null terminate if maxfill
+//		printf("1\t");
+	return 0;
Added: grass-addons/gipe/i.dn2full.l5/rad2ref_landsat5.c
--- grass-addons/gipe/i.dn2full.l5/rad2ref_landsat5.c	                        (rev 0)
+++ grass-addons/gipe/i.dn2full.l5/rad2ref_landsat5.c	2008-04-02 03:59:42 UTC (rev 30840)
@@ -0,0 +1,19 @@
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+// Conversion of Radiance to Reflectance for Landsat 5TM
+// ychemin at gmail.com - Yann Chemin - GPL>=2, 2008.
+	double	result, ds;
+	ds = (1+0.01672*sin(2*PI*(doy-93.5)/365));
+	result = (radiance/((cos((90-sun_elevation)*PI/180)/(PI*ds*ds))*k_exo));
+	return result;
Added: grass-addons/gipe/i.dn2full.l5/science_L5gain9a.txt
--- grass-addons/gipe/i.dn2full.l5/science_L5gain9a.txt	                        (rev 0)
+++ grass-addons/gipe/i.dn2full.l5/science_L5gain9a.txt	2008-04-02 03:59:42 UTC (rev 30840)
@@ -0,0 +1,9437 @@
+1	1984.1667	61	1.5008	0.7556	0.9875	1.0820	8.2090	14.6950	8.1915	14.6941
+2	1984.1694	62	1.5007	0.7556	0.9875	1.0820	8.2090	14.6950	8.1724	14.6918
+3	1984.1721	63	1.5006	0.7556	0.9874	1.0820	8.2090	14.6950	8.1521	14.6880
+4	1984.1749	64	1.5005	0.7555	0.9874	1.0820	8.2090	14.6950	8.1310	14.6828
+5	1984.1776	65	1.5003	0.7555	0.9873	1.0820	8.2090	14.6950	8.1094	14.6761
+6	1984.1803	66	1.5002	0.7555	0.9873	1.0820	8.2090	14.6950	8.0878	14.6681
+7	1984.1831	67	1.5001	0.7554	0.9872	1.0820	8.2090	14.6950	8.0665	14.6587
+8	1984.1858	68	1.5000	0.7554	0.9871	1.0820	8.2090	14.6950	8.0459	14.6481
+9	1984.1885	69	1.4999	0.7554	0.9871	1.0820	8.2090	14.6950	8.0265	14.6362
+10	1984.1913	70	1.4998	0.7553	0.9870	1.0820	8.2090	14.6950	8.0084	14.6232
+11	1984.1940	71	1.4997	0.7553	0.9870	1.0820	8.2090	14.6950	7.9922	14.6092
+12	1984.1967	72	1.4996	0.7552	0.9869	1.0820	8.2090	14.6950	7.9779	14.5943
+13	1984.1995	73	1.4995	0.7552	0.9869	1.0820	8.2090	14.6950	7.9658	14.5786
+14	1984.2022	74	1.4993	0.7552	0.9868	1.0820	8.2090	14.6950	7.9563	14.5621
+15	1984.2049	75	1.4992	0.7551	0.9868	1.0820	8.2090	14.6950	7.9493	14.5451
+16	1984.2077	76	1.4991	0.7551	0.9867	1.0820	8.2090	14.6950	7.9450	14.5276
+17	1984.2104	77	1.4990	0.7551	0.9867	1.0820	8.2090	14.6950	7.9434	14.5098
+18	1984.2131	78	1.4989	0.7550	0.9866	1.0820	8.2090	14.6950	7.9447	14.4918
+19	1984.2158	79	1.4988	0.7550	0.9865	1.0820	8.2090	14.6950	7.9486	14.4737
+20	1984.2186	80	1.4987	0.7550	0.9865	1.0820	8.2090	14.6950	7.9553	14.4556
+21	1984.2213	81	1.4986	0.7549	0.9864	1.0820	8.2090	14.6950	7.9645	14.4378
+22	1984.2240	82	1.4985	0.7549	0.9864	1.0820	8.2090	14.6950	7.9760	14.4203
+23	1984.2268	83	1.4983	0.7549	0.9863	1.0820	8.2090	14.6950	7.9897	14.4032
+24	1984.2295	84	1.4982	0.7548	0.9863	1.0820	8.2090	14.6950	8.0053	14.3867
+25	1984.2322	85	1.4981	0.7548	0.9862	1.0820	8.2090	14.6950	8.0226	14.3708
+26	1984.2350	86	1.4980	0.7548	0.9862	1.0820	8.2090	14.6950	8.0412	14.3558
+27	1984.2377	87	1.4979	0.7547	0.9861	1.0820	8.2090	14.6950	8.0607	14.3416
+28	1984.2404	88	1.4978	0.7547	0.9861	1.0820	8.2090	14.6950	8.0808	14.3283
+29	1984.2432	89	1.4977	0.7546	0.9860	1.0820	8.2090	14.6950	8.1011	14.3161
+30	1984.2459	90	1.4976	0.7546	0.9859	1.0820	8.2090	14.6950	8.1213	14.3051
+31	1984.2486	91	1.4975	0.7546	0.9859	1.0820	8.2090	14.6950	8.1409	14.2952
+32	1984.2514	92	1.4974	0.7545	0.9858	1.0820	8.2090	14.6950	8.1594	14.2866
+33	1984.2541	93	1.4972	0.7545	0.9858	1.0820	8.2090	14.6950	8.1767	14.2793
+34	1984.2568	94	1.4971	0.7545	0.9857	1.0820	8.2090	14.6950	8.1922	14.2734
+35	1984.2596	95	1.4970	0.7544	0.9857	1.0820	8.2090	14.6950	8.2057	14.2688
+36	1984.2623	96	1.4969	0.7544	0.9856	1.0820	8.2090	14.6950	8.2169	14.2655
+37	1984.2650	97	1.4968	0.7544	0.9856	1.0820	8.2090	14.6950	8.2254	14.2637
+38	1984.2678	98	1.4967	0.7543	0.9855	1.0820	8.2090	14.6950	8.2313	14.2632
+39	1984.2705	99	1.4966	0.7543	0.9855	1.0820	8.2090	14.6950	8.2342	14.2641
+40	1984.2732	100	1.4965	0.7543	0.9854	1.0820	8.2090	14.6950	8.2342	14.2662
+41	1984.2760	101	1.4964	0.7542	0.9854	1.0820	8.2090	14.6950	8.2312	14.2697
+42	1984.2787	102	1.4963	0.7542	0.9853	1.0820	8.2090	14.6950	8.2253	14.2744
+43	1984.2814	103	1.4961	0.7542	0.9852	1.0820	8.2090	14.6950	8.2166	14.2803
+44	1984.2842	104	1.4960	0.7541	0.9852	1.0820	8.2090	14.6950	8.2052	14.2873
+45	1984.2869	105	1.4959	0.7541	0.9851	1.0820	8.2090	14.6950	8.1914	14.2954
+46	1984.2896	106	1.4958	0.7540	0.9851	1.0820	8.2090	14.6950	8.1754	14.3044
+47	1984.2923	107	1.4957	0.7540	0.9850	1.0820	8.2090	14.6950	8.1576	14.3142
+48	1984.2951	108	1.4956	0.7540	0.9850	1.0820	8.2090	14.6950	8.1384	14.3248
+49	1984.2978	109	1.4955	0.7539	0.9849	1.0820	8.2090	14.6950	8.1179	14.3361
+50	1984.3005	110	1.4954	0.7539	0.9849	1.0820	8.2090	14.6950	8.0968	14.3479
+51	1984.3033	111	1.4953	0.7539	0.9848	1.0820	8.2090	14.6950	8.0753	14.3601
+52	1984.3060	112	1.4952	0.7538	0.9848	1.0820	8.2090	14.6950	8.0539	14.3726
+53	1984.3087	113	1.4950	0.7538	0.9847	1.0820	8.2090	14.6950	8.0329	14.3852
+54	1984.3115	114	1.4949	0.7538	0.9847	1.0820	8.2090	14.6950	8.0127	14.3979
+55	1984.3142	115	1.4948	0.7537	0.9846	1.0820	8.2090	14.6950	7.9937	14.4105
+56	1984.3169	116	1.4947	0.7537	0.9846	1.0820	8.2090	14.6950	7.9762	14.4229
+57	1984.3197	117	1.4946	0.7537	0.9845	1.0820	8.2090	14.6950	7.9605	14.4350
+58	1984.3224	118	1.4945	0.7536	0.9844	1.0820	8.2090	14.6950	7.9469	14.4466
+59	1984.3251	119	1.4944	0.7536	0.9844	1.0820	8.2090	14.6950	7.9355	14.4576
+60	1984.3279	120	1.4943	0.7536	0.9843	1.0820	8.2090	14.6950	7.9266	14.4678
+61	1984.3306	121	1.4942	0.7535	0.9843	1.0820	8.2090	14.6950	7.9203	14.4773
+62	1984.3333	122	1.4941	0.7535	0.9842	1.0820	8.2090	14.6950	7.9168	14.4859
+63	1984.3361	123	1.4940	0.7534	0.9842	1.0820	8.2090	14.6950	7.9159	14.4934
+64	1984.3388	124	1.4938	0.7534	0.9841	1.0820	8.2090	14.6950	7.9178	14.4998
+65	1984.3415	125	1.4937	0.7534	0.9841	1.0820	8.2090	14.6950	7.9224	14.5050
+66	1984.3443	126	1.4936	0.7533	0.9840	1.0820	8.2090	14.6950	7.9297	14.5089
+67	1984.3470	127	1.4935	0.7533	0.9840	1.0820	8.2090	14.6950	7.9394	14.5116
+68	1984.3497	128	1.4934	0.7533	0.9839	1.0820	8.2090	14.6950	7.9514	14.5129
+69	1984.3525	129	1.4933	0.7532	0.9839	1.0820	8.2090	14.6950	7.9655	14.5128
+70	1984.3552	130	1.4932	0.7532	0.9838	1.0820	8.2090	14.6950	7.9815	14.5112
+71	1984.3579	131	1.4931	0.7532	0.9838	1.0820	8.2090	14.6950	7.9990	14.5083
+72	1984.3607	132	1.4930	0.7531	0.9837	1.0820	8.2090	14.6950	8.0177	14.5039
+73	1984.3634	133	1.4929	0.7531	0.9836	1.0820	8.2090	14.6950	8.0372	14.4981
+74	1984.3661	134	1.4928	0.7531	0.9836	1.0820	8.2090	14.6950	8.0573	14.4910
+75	1984.3689	135	1.4927	0.7530	0.9835	1.0820	8.2090	14.6950	8.0775	14.4825
+76	1984.3716	136	1.4925	0.7530	0.9835	1.0820	8.2090	14.6950	8.0974	14.4727
+77	1984.3743	137	1.4924	0.7530	0.9834	1.0820	8.2090	14.6950	8.1166	14.4618
+78	1984.3770	138	1.4923	0.7529	0.9834	1.0820	8.2090	14.6950	8.1347	14.4497
+79	1984.3798	139	1.4922	0.7529	0.9833	1.0820	8.2090	14.6950	8.1515	14.4365
+80	1984.3825	140	1.4921	0.7529	0.9833	1.0820	8.2090	14.6950	8.1664	14.4224
+81	1984.3852	141	1.4920	0.7528	0.9832	1.0820	8.2090	14.6950	8.1792	14.4074
+82	1984.3880	142	1.4919	0.7528	0.9832	1.0820	8.2090	14.6950	8.1897	14.3917
+83	1984.3907	143	1.4918	0.7527	0.9831	1.0820	8.2090	14.6950	8.1976	14.3753
+84	1984.3934	144	1.4917	0.7527	0.9831	1.0820	8.2090	14.6950	8.2026	14.3585
+85	1984.3962	145	1.4916	0.7527	0.9830	1.0820	8.2090	14.6950	8.2048	14.3412
+86	1984.3989	146	1.4915	0.7526	0.9830	1.0820	8.2090	14.6950	8.2041	14.3237
+87	1984.4016	147	1.4914	0.7526	0.9829	1.0820	8.2090	14.6950	8.2004	14.3060
+88	1984.4044	148	1.4912	0.7526	0.9829	1.0820	8.2090	14.6950	8.1938	14.2883
+89	1984.4071	149	1.4911	0.7525	0.9828	1.0820	8.2090	14.6950	8.1844	14.2708
+90	1984.4098	150	1.4910	0.7525	0.9828	1.0820	8.2090	14.6950	8.1725	14.2535
+91	1984.4126	151	1.4909	0.7525	0.9827	1.0820	8.2090	14.6950	8.1582	14.2365
+92	1984.4153	152	1.4908	0.7524	0.9827	1.0820	8.2090	14.6950	8.1419	14.2201
+93	1984.4180	153	1.4907	0.7524	0.9826	1.0820	8.2090	14.6950	8.1238	14.2042
+94	1984.4208	154	1.4906	0.7524	0.9826	1.0820	8.2090	14.6950	8.1044	14.1891
+95	1984.4235	155	1.4905	0.7523	0.9825	1.0820	8.2090	14.6950	8.0839	14.1747
+96	1984.4262	156	1.4904	0.7523	0.9824	1.0820	8.2090	14.6950	8.0628	14.1612
+97	1984.4290	157	1.4903	0.7523	0.9824	1.0820	8.2090	14.6950	8.0414	14.1488
+98	1984.4317	158	1.4902	0.7522	0.9823	1.0820	8.2090	14.6950	8.0202	14.1373
+99	1984.4344	159	1.4901	0.7522	0.9823	1.0820	8.2090	14.6950	7.9995	14.1271
+100	1984.4372	160	1.4900	0.7522	0.9822	1.0820	8.2090	14.6950	7.9798	14.1180
+101	1984.4399	161	1.4898	0.7521	0.9822	1.0820	8.2090	14.6950	7.9612	14.1101
+102	1984.4426	162	1.4897	0.7521	0.9821	1.0820	8.2090	14.6950	7.9443	14.1036
+103	1984.4454	163	1.4896	0.7520	0.9821	1.0820	8.2090	14.6950	7.9292	14.0983
+104	1984.4481	164	1.4895	0.7520	0.9820	1.0820	8.2090	14.6950	7.9162	14.0944
+105	1984.4508	165	1.4894	0.7520	0.9820	1.0820	8.2090	14.6950	7.9055	14.0918
+106	1984.4536	166	1.4893	0.7519	0.9819	1.0820	8.2090	14.6950	7.8973	14.0906
+107	1984.4563	167	1.4892	0.7519	0.9819	1.0820	8.2090	14.6950	7.8917	14.0907
+108	1984.4590	168	1.4891	0.7519	0.9818	1.0820	8.2090	14.6950	7.8888	14.0921
+109	1984.4617	169	1.4890	0.7518	0.9818	1.0820	8.2090	14.6950	7.8887	14.0948
+110	1984.4645	170	1.4889	0.7518	0.9817	1.0820	8.2090	14.6950	7.8912	14.0987
+111	1984.4672	171	1.4888	0.7518	0.9817	1.0820	8.2090	14.6950	7.8965	14.1038
+112	1984.4699	172	1.4887	0.7517	0.9816	1.0820	8.2090	14.6950	7.9043	14.1101
+113	1984.4727	173	1.4886	0.7517	0.9816	1.0820	8.2090	14.6950	7.9145	14.1174
+114	1984.4754	174	1.4885	0.7517	0.9815	1.0820	8.2090	14.6950	7.9270	14.1256
+115	1984.4781	175	1.4884	0.7516	0.9815	1.0820	8.2090	14.6950	7.9415	14.1348
+116	1984.4809	176	1.4882	0.7516	0.9814	1.0820	8.2090	14.6950	7.9577	14.1447
+117	1984.4836	177	1.4881	0.7516	0.9814	1.0820	8.2090	14.6950	7.9754	14.1553
+118	1984.4863	178	1.4880	0.7515	0.9813	1.0820	8.2090	14.6950	7.9943	14.1665
+119	1984.4891	179	1.4879	0.7515	0.9813	1.0820	8.2090	14.6950	8.0139	14.1782
+120	1984.4918	180	1.4878	0.7515	0.9812	1.0820	8.2090	14.6950	8.0338	14.1902
+121	1984.4945	181	1.4877	0.7514	0.9812	1.0820	8.2090	14.6950	8.0538	14.2024
+122	1984.4973	182	1.4876	0.7514	0.9811	1.0820	8.2090	14.6950	8.0735	14.2148
+123	1984.5000	183	1.4875	0.7514	0.9811	1.0820	8.2090	14.6950	8.0923	14.2271
+124	1984.5027	184	1.4874	0.7513	0.9810	1.0820	8.2090	14.6950	8.1100	14.2393
+125	1984.5055	185	1.4873	0.7513	0.9810	1.0820	8.2090	14.6950	8.1262	14.2513
+126	1984.5082	186	1.4872	0.7513	0.9809	1.0820	8.2090	14.6950	8.1405	14.2628
+127	1984.5109	187	1.4871	0.7512	0.9809	1.0820	8.2090	14.6950	8.1527	14.2738
+128	1984.5137	188	1.4870	0.7512	0.9808	1.0820	8.2090	14.6950	8.1625	14.2842
+129	1984.5164	189	1.4869	0.7512	0.9808	1.0820	8.2090	14.6950	8.1696	14.2938
+130	1984.5191	190	1.4868	0.7511	0.9807	1.0820	8.2090	14.6950	8.1739	14.3026
+131	1984.5219	191	1.4866	0.7511	0.9806	1.0820	8.2090	14.6950	8.1754	14.3105
+132	1984.5246	192	1.4865	0.7510	0.9806	1.0820	8.2090	14.6950	8.1739	14.3173
+133	1984.5273	193	1.4864	0.7510	0.9805	1.0820	8.2090	14.6950	8.1695	14.3230
+134	1984.5301	194	1.4863	0.7510	0.9805	1.0820	8.2090	14.6950	8.2090	14.6950
+135	1984.5328	195	1.4862	0.7509	0.9804	1.0820	8.2090	14.6950	8.1915	14.6941
+136	1984.5355	196	1.4861	0.7509	0.9804	1.0820	8.2090	14.6950	8.1724	14.6918
+137	1984.5383	197	1.4860	0.7509	0.9803	1.0820	8.2090	14.6950	8.1521	14.6880
+138	1984.5410	198	1.4859	0.7508	0.9803	1.0820	8.2090	14.6950	8.1310	14.6828
+139	1984.5437	199	1.4858	0.7508	0.9802	1.0820	8.2090	14.6950	8.1094	14.6761
+140	1984.5464	200	1.4857	0.7508	0.9802	1.0820	8.2090	14.6950	8.0878	14.6681
+141	1984.5492	201	1.4856	0.7507	0.9801	1.0820	8.2090	14.6950	8.0665	14.6587
+142	1984.5519	202	1.4855	0.7507	0.9801	1.0820	8.2090	14.6950	8.0459	14.6481
+143	1984.5546	203	1.4854	0.7507	0.9800	1.0820	8.2090	14.6950	8.0265	14.6362
+144	1984.5574	204	1.4853	0.7506	0.9800	1.0820	8.2090	14.6950	8.0084	14.6232
+145	1984.5601	205	1.4852	0.7506	0.9799	1.0820	8.2090	14.6950	7.9922	14.6092
+146	1984.5628	206	1.4851	0.7506	0.9799	1.0820	8.2090	14.6950	7.9779	14.5943
+147	1984.5656	207	1.4850	0.7505	0.9798	1.0820	8.2090	14.6950	7.9658	14.5786
+148	1984.5683	208	1.4848	0.7505	0.9798	1.0820	8.2090	14.6950	7.9563	14.5621
+149	1984.5710	209	1.4847	0.7505	0.9797	1.0820	8.2090	14.6950	7.9493	14.5451
+150	1984.5738	210	1.4846	0.7504	0.9797	1.0820	8.2090	14.6950	7.9450	14.5276
+151	1984.5765	211	1.4845	0.7504	0.9796	1.0820	8.2090	14.6950	7.9434	14.5098
+152	1984.5792	212	1.4844	0.7504	0.9796	1.0820	8.2090	14.6950	7.9447	14.4918
+153	1984.5820	213	1.4843	0.7503	0.9795	1.0820	8.2090	14.6950	7.9486	14.4737
+154	1984.5847	214	1.4842	0.7503	0.9795	1.0820	8.2090	14.6950	7.9553	14.4556
+155	1984.5874	215	1.4841	0.7503	0.9794	1.0820	8.2090	14.6950	7.9645	14.4378
+156	1984.5902	216	1.4840	0.7502	0.9794	1.0820	8.2090	14.6950	7.9760	14.4203
+157	1984.5929	217	1.4839	0.7502	0.9793	1.0820	8.2090	14.6950	7.9897	14.4032
+158	1984.5956	218	1.4838	0.7502	0.9793	1.0820	8.2090	14.6950	8.0053	14.3867
+159	1984.5984	219	1.4837	0.7501	0.9792	1.0820	8.2090	14.6950	8.0226	14.3708
+160	1984.6011	220	1.4836	0.7501	0.9792	1.0820	8.2090	14.6950	8.0412	14.3558
+161	1984.6038	221	1.4835	0.7501	0.9791	1.0820	8.2090	14.6950	8.0607	14.3416
+162	1984.6066	222	1.4834	0.7500	0.9791	1.0820	8.2090	14.6950	8.0808	14.3283
+163	1984.6093	223	1.4833	0.7500	0.9790	1.0820	8.2090	14.6950	8.1011	14.3161
+164	1984.6120	224	1.4832	0.7500	0.9790	1.0820	8.2090	14.6950	8.1213	14.3051
+165	1984.6148	225	1.4831	0.7499	0.9789	1.0820	8.2090	14.6950	8.1409	14.2952
+166	1984.6175	226	1.4830	0.7499	0.9789	1.0820	8.2090	14.6950	8.1594	14.2866
+167	1984.6202	227	1.4829	0.7498	0.9788	1.0820	8.2090	14.6950	8.1767	14.2793
+168	1984.6230	228	1.4827	0.7498	0.9788	1.0820	8.2090	14.6950	8.1922	14.2734
+169	1984.6257	229	1.4826	0.7498	0.9787	1.0820	8.2090	14.6950	8.2057	14.2688
+170	1984.6284	230	1.4825	0.7497	0.9787	1.0820	8.2090	14.6950	8.2169	14.2655
+171	1984.6311	231	1.4824	0.7497	0.9786	1.0820	8.2090	14.6950	8.2254	14.2637
+172	1984.6339	232	1.4823	0.7497	0.9786	1.0820	8.2090	14.6950	8.2313	14.2632
+173	1984.6366	233	1.4822	0.7496	0.9785	1.0820	8.2090	14.6950	8.2342	14.2641
+174	1984.6393	234	1.4821	0.7496	0.9785	1.0820	8.2090	14.6950	8.2342	14.2662
+175	1984.6421	235	1.4820	0.7496	0.9784	1.0820	8.2090	14.6950	8.2312	14.2697
+176	1984.6448	236	1.4819	0.7495	0.9784	1.0820	8.2090	14.6950	8.2090	14.6950
+177	1984.6475	237	1.4818	0.7495	0.9784	1.0820	8.2090	14.6950	8.1915	14.6941
+178	1984.6503	238	1.4817	0.7495	0.9783	1.0820	8.2090	14.6950	8.1724	14.6918
+179	1984.6530	239	1.4816	0.7494	0.9783	1.0820	8.2090	14.6950	8.1521	14.6880
+180	1984.6557	240	1.4815	0.7494	0.9782	1.0820	8.2090	14.6950	8.1310	14.6828
+181	1984.6585	241	1.4814	0.7494	0.9782	1.0820	8.2090	14.6950	8.1094	14.6761
+182	1984.6612	242	1.4813	0.7493	0.9781	1.0820	8.2090	14.6950	8.0878	14.6681
+183	1984.6639	243	1.4812	0.7493	0.9781	1.0820	8.2090	14.6950	8.0665	14.6587
+184	1984.6667	244	1.4811	0.7493	0.9780	1.0820	8.2090	14.6950	8.0459	14.6481
+185	1984.6694	245	1.4810	0.7492	0.9780	1.0820	8.2090	14.6950	8.0265	14.6362
+186	1984.6721	246	1.4809	0.7492	0.9779	1.0820	8.2090	14.6950	8.0084	14.6232
+187	1984.6749	247	1.4808	0.7492	0.9779	1.0820	8.2090	14.6950	7.9922	14.6092
+188	1984.6776	248	1.4807	0.7491	0.9778	1.0820	8.2090	14.6950	7.9779	14.5943
+189	1984.6803	249	1.4806	0.7491	0.9778	1.0820	8.2090	14.6950	7.9658	14.5786
+190	1984.6831	250	1.4805	0.7491	0.9777	1.0820	8.2090	14.6950	7.9563	14.5621
+191	1984.6858	251	1.4803	0.7490	0.9777	1.0820	8.2090	14.6950	7.9493	14.5451
+192	1984.6885	252	1.4802	0.7490	0.9776	1.0820	8.2090	14.6950	7.9450	14.5276
+193	1984.6913	253	1.4801	0.7490	0.9776	1.0820	8.2090	14.6950	7.9434	14.5098
+194	1984.6940	254	1.4800	0.7489	0.9775	1.0820	8.2090	14.6950	7.9447	14.4918
+195	1984.6967	255	1.4799	0.7489	0.9775	1.0820	8.2090	14.6950	7.9486	14.4737
+196	1984.6995	256	1.4798	0.7489	0.9774	1.0820	8.2090	14.6950	7.9553	14.4556
+197	1984.7022	257	1.4797	0.7488	0.9774	1.0820	8.2090	14.6950	7.9645	14.4378
+198	1984.7049	258	1.4796	0.7488	0.9773	1.0820	8.2090	14.6950	7.9760	14.4203
+199	1984.7077	259	1.4795	0.7488	0.9773	1.0820	8.2090	14.6950	7.9897	14.4032
+200	1984.7104	260	1.4794	0.7487	0.9772	1.0820	8.2090	14.6950	8.0053	14.3867
+201	1984.7131	261	1.4793	0.7487	0.9772	1.0820	8.2090	14.6950	8.0226	14.3708
+202	1984.7158	262	1.4792	0.7487	0.9771	1.0820	8.2090	14.6950	8.0412	14.3558
+203	1984.7186	263	1.4791	0.7486	0.9771	1.0820	8.2090	14.6950	8.0607	14.3416
+204	1984.7213	264	1.4790	0.7486	0.9770	1.0820	8.2090	14.6950	8.0808	14.3283
+205	1984.7240	265	1.4789	0.7486	0.9770	1.0820	8.2090	14.6950	8.1011	14.3161
+206	1984.7268	266	1.4788	0.7485	0.9769	1.0820	8.2090	14.6950	8.1213	14.3051
+207	1984.7295	267	1.4787	0.7485	0.9769	1.0820	8.2090	14.6950	8.1409	14.2952
+208	1984.7322	268	1.4786	0.7485	0.9768	1.0820	8.2090	14.6950	8.1594	14.2866
+209	1984.7350	269	1.4785	0.7484	0.9768	1.0820	8.2090	14.6950	8.1767	14.2793
+210	1984.7377	270	1.4784	0.7484	0.9767	1.0820	8.2090	14.6950	8.1922	14.2734
+211	1984.7404	271	1.4783	0.7484	0.9767	1.0820	8.2090	14.6950	8.2057	14.2688
+212	1984.7432	272	1.4782	0.7483	0.9766	1.0820	8.2090	14.6950	8.2169	14.2655
+213	1984.7459	273	1.4781	0.7483	0.9766	1.0820	8.2090	14.6950	8.2254	14.2637
+214	1984.7486	274	1.4780	0.7483	0.9766	1.0820	8.2090	14.6950	8.2313	14.2632
+215	1984.7514	275	1.4779	0.7482	0.9765	1.0820	8.2090	14.6950	8.2342	14.2641
+216	1984.7541	276	1.4778	0.7482	0.9765	1.0820	8.2090	14.6950	8.2342	14.2662
+217	1984.7568	277	1.4777	0.7482	0.9764	1.0820	8.2090	14.6950	8.2312	14.2697
+218	1984.7596	278	1.4776	0.7481	0.9764	1.0820	8.2090	14.6950	8.2253	14.2744
+219	1984.7623	279	1.4775	0.7481	0.9763	1.0820	8.2090	14.6950	8.2166	14.2803
+220	1984.7650	280	1.4774	0.7481	0.9763	1.0820	8.2090	14.6950	8.2052	14.2873
+221	1984.7678	281	1.4773	0.7480	0.9762	1.0820	8.2090	14.6950	8.1914	14.2954
+222	1984.7705	282	1.4772	0.7480	0.9762	1.0820	8.2090	14.6950	8.1754	14.3044
+223	1984.7732	283	1.4771	0.7480	0.9761	1.0820	8.2090	14.6950	8.1576	14.3142
+224	1984.7760	284	1.4769	0.7479	0.9761	1.0820	8.2090	14.6950	8.1384	14.3248
+225	1984.7787	285	1.4768	0.7479	0.9760	1.0820	8.2090	14.6950	8.1179	14.3361
+226	1984.7814	286	1.4767	0.7479	0.9760	1.0820	8.2090	14.6950	8.0968	14.3479
+227	1984.7842	287	1.4766	0.7478	0.9759	1.0820	8.2090	14.6950	8.0753	14.3601
+228	1984.7869	288	1.4765	0.7478	0.9759	1.0820	8.2090	14.6950	8.0539	14.3726
+229	1984.7896	289	1.4764	0.7478	0.9758	1.0820	8.2090	14.6950	8.0329	14.3852
+230	1984.7923	290	1.4763	0.7477	0.9758	1.0820	8.2090	14.6950	8.0127	14.3979
+231	1984.7951	291	1.4762	0.7477	0.9757	1.0820	8.2090	14.6950	7.9937	14.4105
+232	1984.7978	292	1.4761	0.7477	0.9757	1.0820	8.2090	14.6950	7.9762	14.4229
+233	1984.8005	293	1.4760	0.7476	0.9756	1.0820	8.2090	14.6950	7.9605	14.4350
+234	1984.8033	294	1.4759	0.7476	0.9756	1.0820	8.2090	14.6950	7.9469	14.4466
+235	1984.8060	295	1.4758	0.7476	0.9755	1.0820	8.2090	14.6950	7.9355	14.4576
+236	1984.8087	296	1.4757	0.7475	0.9755	1.0820	8.2090	14.6950	7.9266	14.4678
+237	1984.8115	297	1.4756	0.7475	0.9755	1.0820	8.2090	14.6950	7.9203	14.4773
+238	1984.8142	298	1.4755	0.7475	0.9754	1.0820	8.2090	14.6950	7.9168	14.4859
+239	1984.8169	299	1.4754	0.7474	0.9754	1.0820	8.2090	14.6950	7.9159	14.4934
+240	1984.8197	300	1.4753	0.7474	0.9753	1.0820	8.2090	14.6950	7.9178	14.4998
+241	1984.8224	301	1.4752	0.7474	0.9753	1.0820	8.2090	14.6950	7.9224	14.5050
+242	1984.8251	302	1.4751	0.7473	0.9752	1.0820	8.2090	14.6950	7.9297	14.5089
+243	1984.8279	303	1.4750	0.7473	0.9752	1.0820	8.2090	14.6950	7.9394	14.5116
+244	1984.8306	304	1.4749	0.7473	0.9751	1.0820	8.2090	14.6950	7.9514	14.5129
+245	1984.8333	305	1.4748	0.7472	0.9751	1.0820	8.2090	14.6950	7.9655	14.5128
+246	1984.8361	306	1.4747	0.7472	0.9750	1.0820	8.2090	14.6950	7.9815	14.5112
+247	1984.8388	307	1.4746	0.7472	0.9750	1.0820	8.2090	14.6950	7.9990	14.5083
+248	1984.8415	308	1.4745	0.7471	0.9749	1.0820	8.2090	14.6950	8.0177	14.5039
+249	1984.8443	309	1.4744	0.7471	0.9749	1.0820	8.2090	14.6950	8.0372	14.4981
+250	1984.8470	310	1.4743	0.7471	0.9748	1.0820	8.2090	14.6950	8.0573	14.4910
+251	1984.8497	311	1.4742	0.7470	0.9748	1.0820	8.2090	14.6950	8.0775	14.4825
+252	1984.8525	312	1.4741	0.7470	0.9747	1.0820	8.2090	14.6950	8.0974	14.4727
+253	1984.8552	313	1.4740	0.7470	0.9747	1.0820	8.2090	14.6950	8.1166	14.4618
+254	1984.8579	314	1.4739	0.7469	0.9747	1.0820	8.2090	14.6950	8.1347	14.4497
+255	1984.8607	315	1.4738	0.7469	0.9746	1.0820	8.2090	14.6950	8.1515	14.4365
+256	1984.8634	316	1.4737	0.7469	0.9746	1.0820	8.2090	14.6950	8.1664	14.4224
+257	1984.8661	317	1.4736	0.7468	0.9745	1.0820	8.2090	14.6950	8.1792	14.4074
+258	1984.8689	318	1.4735	0.7468	0.9745	1.0820	8.2090	14.6950	8.1897	14.3917
+259	1984.8716	319	1.4734	0.7468	0.9744	1.0820	8.2090	14.6950	8.1976	14.3753
+260	1984.8743	320	1.4733	0.7467	0.9744	1.0820	8.2090	14.6950	8.2026	14.3585
+261	1984.8770	321	1.4732	0.7467	0.9743	1.0820	8.2090	14.6950	8.2090	14.6950
+262	1984.8798	322	1.4731	0.7467	0.9743	1.0820	8.2090	14.6950	8.1915	14.6941
+263	1984.8825	323	1.4730	0.7466	0.9742	1.0820	8.2090	14.6950	8.1724	14.6918
+264	1984.8852	324	1.4729	0.7466	0.9742	1.0820	8.2090	14.6950	8.1521	14.6880
+265	1984.8880	325	1.4728	0.7466	0.9741	1.0820	8.2090	14.6950	8.1310	14.6828
+266	1984.8907	326	1.4727	0.7465	0.9741	1.0820	8.2090	14.6950	8.1094	14.6761
+267	1984.8934	327	1.4726	0.7465	0.9740	1.0820	8.2090	14.6950	8.0878	14.6681
+268	1984.8962	328	1.4725	0.7465	0.9740	1.0820	8.2090	14.6950	8.0665	14.6587
+269	1984.8989	329	1.4724	0.7464	0.9740	1.0820	8.2090	14.6950	8.0459	14.6481
+270	1984.9016	330	1.4723	0.7464	0.9739	1.0820	8.2090	14.6950	8.0265	14.6362
+271	1984.9044	331	1.4722	0.7464	0.9739	1.0820	8.2090	14.6950	8.0084	14.6232
+272	1984.9071	332	1.4721	0.7463	0.9738	1.0820	8.2090	14.6950	7.9922	14.6092
+273	1984.9098	333	1.4720	0.7463	0.9738	1.0820	8.2090	14.6950	7.9779	14.5943
+274	1984.9126	334	1.4719	0.7463	0.9737	1.0820	8.2090	14.6950	7.9658	14.5786
+275	1984.9153	335	1.4718	0.7462	0.9737	1.0820	8.2090	14.6950	7.9563	14.5621
+276	1984.9180	336	1.4717	0.7462	0.9736	1.0820	8.2090	14.6950	7.9493	14.5451
+277	1984.9208	337	1.4716	0.7462	0.9736	1.0820	8.2090	14.6950	7.9450	14.5276
+278	1984.9235	338	1.4715	0.7461	0.9735	1.0820	8.2090	14.6950	7.9434	14.5098
+279	1984.9262	339	1.4714	0.7461	0.9735	1.0820	8.2090	14.6950	7.9447	14.4918
+280	1984.9290	340	1.4713	0.7461	0.9734	1.0820	8.2090	14.6950	7.9486	14.4737
+281	1984.9317	341	1.4712	0.7460	0.9734	1.0820	8.2090	14.6950	7.9553	14.4556
+282	1984.9344	342	1.4711	0.7460	0.9734	1.0820	8.2090	14.6950	7.9645	14.4378
+283	1984.9372	343	1.4710	0.7460	0.9733	1.0820	8.2090	14.6950	7.9760	14.4203
+284	1984.9399	344	1.4709	0.7459	0.9733	1.0820	8.2090	14.6950	7.9897	14.4032
+285	1984.9426	345	1.4708	0.7459	0.9732	1.0820	8.2090	14.6950	8.0053	14.3867
+286	1984.9454	346	1.4707	0.7459	0.9732	1.0820	8.2090	14.6950	8.0226	14.3708
+287	1984.9481	347	1.4706	0.7458	0.9731	1.0820	8.2090	14.6950	8.0412	14.3558
+288	1984.9508	348	1.4705	0.7458	0.9731	1.0820	8.2090	14.6950	8.0607	14.3416
+289	1984.9536	349	1.4704	0.7458	0.9730	1.0820	8.2090	14.6950	8.0808	14.3283
+290	1984.9563	350	1.4703	0.7457	0.9730	1.0820	8.2090	14.6950	8.1011	14.3161
+291	1984.9590	351	1.4702	0.7457	0.9729	1.0820	8.2090	14.6950	8.1213	14.3051
+292	1984.9617	352	1.4701	0.7457	0.9729	1.0820	8.2090	14.6950	8.1409	14.2952
+293	1984.9645	353	1.4700	0.7456	0.9728	1.0820	8.2090	14.6950	8.1594	14.2866
+294	1984.9672	354	1.4699	0.7456	0.9728	1.0820	8.2090	14.6950	8.1767	14.2793
+295	1984.9699	355	1.4698	0.7456	0.9728	1.0820	8.2090	14.6950	8.1922	14.2734
+296	1984.9727	356	1.4697	0.7455	0.9727	1.0820	8.2090	14.6950	8.2057	14.2688
+297	1984.9754	357	1.4696	0.7455	0.9727	1.0820	8.2090	14.6950	8.2169	14.2655
+298	1984.9781	358	1.4695	0.7455	0.9726	1.0820	8.2090	14.6950	8.2254	14.2637
+299	1984.9809	359	1.4694	0.7454	0.9726	1.0820	8.2090	14.6950	8.2313	14.2632
+300	1984.9836	360	1.4693	0.7454	0.9725	1.0820	8.2090	14.6950	8.2342	14.2641
+301	1984.9863	361	1.4692	0.7454	0.9725	1.0820	8.2090	14.6950	8.2342	14.2662
+302	1984.9891	362	1.4691	0.7453	0.9724	1.0820	8.2090	14.6950	8.2312	14.2697
+303	1984.9918	363	1.4690	0.7453	0.9724	1.0820	8.2090	14.6950	8.2253	14.2744
+304	1984.9945	364	1.4689	0.7453	0.9723	1.0820	8.2090	14.6950	8.2166	14.2803
+305	1984.9973	365	1.4688	0.7452	0.9723	1.0820	8.2090	14.6950	8.2052	14.2873
+306	1984.9999	366	1.4687	0.7452	0.9723	1.0820	8.2090	14.6950	8.1914	14.2954
+307	1985.0027	1	1.4686	0.7452	0.9722	1.0820	8.2090	14.6950	8.1754	14.3044
+308	1985.0055	2	1.4685	0.7451	0.9722	1.0820	8.2090	14.6950	8.1576	14.3142
+309	1985.0082	3	1.4684	0.7451	0.9721	1.0820	8.2090	14.6950	8.1384	14.3248
+310	1985.0110	4	1.4683	0.7451	0.9721	1.0820	8.2090	14.6950	8.1179	14.3361
+311	1985.0137	5	1.4682	0.7450	0.9720	1.0820	8.2090	14.6950	8.0968	14.3479
+312	1985.0164	6	1.4681	0.7450	0.9720	1.0820	8.2090	14.6950	8.0753	14.3601
+313	1985.0192	7	1.4680	0.7450	0.9719	1.0820	8.2090	14.6950	8.0539	14.3726
+314	1985.0219	8	1.4679	0.7449	0.9719	1.0820	8.2090	14.6950	8.0329	14.3852
+315	1985.0247	9	1.4678	0.7449	0.9718	1.0820	8.2090	14.6950	8.0127	14.3979
+316	1985.0274	10	1.4677	0.7449	0.9718	1.0820	8.2090	14.6950	7.9937	14.4105
+317	1985.0301	11	1.4676	0.7448	0.9718	1.0820	8.2090	14.6950	7.9762	14.4229
+318	1985.0329	12	1.4675	0.7448	0.9717	1.0820	8.2090	14.6950	7.9605	14.4350
+319	1985.0356	13	1.4674	0.7448	0.9717	1.0820	8.2090	14.6950	7.9469	14.4466
+320	1985.0384	14	1.4673	0.7447	0.9716	1.0820	8.2090	14.6950	7.9355	14.4576
+321	1985.0411	15	1.4672	0.7447	0.9716	1.0820	8.2090	14.6950	7.9266	14.4678
+322	1985.0438	16	1.4671	0.7447	0.9715	1.0820	8.2090	14.6950	7.9203	14.4773
+323	1985.0466	17	1.4670	0.7446	0.9715	1.0820	8.2090	14.6950	7.9168	14.4859
+324	1985.0493	18	1.4669	0.7446	0.9714	1.0820	8.2090	14.6950	7.9159	14.4934
+325	1985.0521	19	1.4668	0.7446	0.9714	1.0820	8.2090	14.6950	7.9178	14.4998
+326	1985.0548	20	1.4667	0.7446	0.9714	1.0820	8.2090	14.6950	7.9224	14.5050
+327	1985.0575	21	1.4666	0.7445	0.9713	1.0820	8.2090	14.6950	7.9297	14.5089
+328	1985.0603	22	1.4665	0.7445	0.9713	1.0820	8.2090	14.6950	7.9394	14.5116
+329	1985.0630	23	1.4664	0.7445	0.9712	1.0820	8.2090	14.6950	7.9514	14.5129
+330	1985.0658	24	1.4663	0.7444	0.9712	1.0820	8.2090	14.6950	7.9655	14.5128
+331	1985.0685	25	1.4662	0.7444	0.9711	1.0820	8.2090	14.6950	7.9815	14.5112
+332	1985.0712	26	1.4661	0.7444	0.9711	1.0820	8.2090	14.6950	7.9990	14.5083
+333	1985.0740	27	1.4660	0.7443	0.9710	1.0820	8.2090	14.6950	8.0177	14.5039
+334	1985.0767	28	1.4659	0.7443	0.9710	1.0820	8.2090	14.6950	8.0372	14.4981
+335	1985.0795	29	1.4658	0.7443	0.9710	1.0820	8.2090	14.6950	8.0573	14.4910
+336	1985.0822	30	1.4657	0.7442	0.9709	1.0820	8.2090	14.6950	8.0775	14.4825
+337	1985.0849	31	1.4656	0.7442	0.9709	1.0820	8.2090	14.6950	8.0974	14.4727
+338	1985.0877	32	1.4655	0.7442	0.9708	1.0820	8.2090	14.6950	8.1166	14.4618
+339	1985.0904	33	1.4654	0.7441	0.9708	1.0820	8.2090	14.6950	8.1347	14.4497
+340	1985.0932	34	1.4653	0.7441	0.9707	1.0820	8.2090	14.6950	8.1515	14.4365
+341	1985.0959	35	1.4652	0.7441	0.9707	1.0820	8.2090	14.6950	8.1664	14.4224
+342	1985.0986	36	1.4651	0.7440	0.9706	1.0820	8.2090	14.6950	8.1792	14.4074
+343	1985.1014	37	1.4650	0.7440	0.9706	1.0820	8.2090	14.6950	8.1897	14.3917
+344	1985.1041	38	1.4649	0.7440	0.9706	1.0820	8.2090	14.6950	8.1976	14.3753
+345	1985.1068	39	1.4648	0.7439	0.9705	1.0820	8.2090	14.6950	8.2026	14.3585
+346	1985.1096	40	1.4647	0.7439	0.9705	1.0820	8.2090	14.6950	8.2048	14.3412
+347	1985.1123	41	1.4646	0.7439	0.9704	1.0820	8.2090	14.6950	8.2041	14.3237
+348	1985.1151	42	1.4645	0.7438	0.9704	1.0820	8.2090	14.6950	8.2004	14.3060
+349	1985.1178	43	1.4644	0.7438	0.9703	1.0820	8.2090	14.6950	8.1938	14.2883
+350	1985.1205	44	1.4643	0.7438	0.9703	1.0820	8.2090	14.6950	8.2090	14.6950
+351	1985.1233	45	1.4642	0.7437	0.9702	1.0820	8.2090	14.6950	8.1915	14.6941
+352	1985.1260	46	1.4641	0.7437	0.9702	1.0820	8.2090	14.6950	8.1724	14.6918
+353	1985.1288	47	1.4640	0.7437	0.9702	1.0820	8.2090	14.6950	8.1521	14.6880
+354	1985.1315	48	1.4639	0.7436	0.9701	1.0820	8.2090	14.6950	8.1310	14.6828
+355	1985.1342	49	1.4639	0.7436	0.9701	1.0820	8.2090	14.6950	8.1094	14.6761
+356	1985.1370	50	1.4638	0.7436	0.9700	1.0820	8.2090	14.6950	8.0878	14.6681
+357	1985.1397	51	1.4637	0.7435	0.9700	1.0820	8.2090	14.6950	8.0665	14.6587
+358	1985.1425	52	1.4636	0.7435	0.9699	1.0820	8.2090	14.6950	8.0459	14.6481
+359	1985.1452	53	1.4635	0.7435	0.9699	1.0820	8.2090	14.6950	8.0265	14.6362
+360	1985.1479	54	1.4634	0.7434	0.9698	1.0820	8.2090	14.6950	8.0084	14.6232
+361	1985.1507	55	1.4633	0.7434	0.9698	1.0820	8.2090	14.6950	7.9922	14.6092
+362	1985.1534	56	1.4632	0.7434	0.9698	1.0820	8.2090	14.6950	7.9779	14.5943
+363	1985.1562	57	1.4631	0.7433	0.9697	1.0820	8.2090	14.6950	7.9658	14.5786
+364	1985.1589	58	1.4630	0.7433	0.9697	1.0820	8.2090	14.6950	7.9563	14.5621
+365	1985.1616	59	1.4629	0.7433	0.9696	1.0820	8.2090	14.6950	7.9493	14.5451
+366	1985.1644	60	1.4628	0.7433	0.9696	1.0820	8.2090	14.6950	7.9450	14.5276
+367	1985.1671	61	1.4627	0.7432	0.9695	1.0820	8.2090	14.6950	7.9434	14.5098
+368	1985.1699	62	1.4626	0.7432	0.9695	1.0820	8.2090	14.6950	7.9447	14.4918
+369	1985.1726	63	1.4625	0.7432	0.9695	1.0820	8.2090	14.6950	7.9486	14.4737
+370	1985.1753	64	1.4624	0.7431	0.9694	1.0820	8.2090	14.6950	7.9553	14.4556
+371	1985.1781	65	1.4623	0.7431	0.9694	1.0820	8.2090	14.6950	7.9645	14.4378
+372	1985.1808	66	1.4622	0.7431	0.9693	1.0820	8.2090	14.6950	7.9760	14.4203
+373	1985.1836	67	1.4621	0.7430	0.9693	1.0820	8.2090	14.6950	7.9897	14.4032
+374	1985.1863	68	1.4620	0.7430	0.9692	1.0820	8.2090	14.6950	8.0053	14.3867
+375	1985.1890	69	1.4619	0.7430	0.9692	1.0820	8.2090	14.6950	8.0226	14.3708
+376	1985.1918	70	1.4618	0.7429	0.9691	1.0820	8.2090	14.6950	8.0412	14.3558
+377	1985.1945	71	1.4617	0.7429	0.9691	1.0820	8.2090	14.6950	8.0607	14.3416
+378	1985.1973	72	1.4616	0.7429	0.9691	1.0820	8.2090	14.6950	8.0808	14.3283
+379	1985.2000	73	1.4615	0.7428	0.9690	1.0820	8.2090	14.6950	8.1011	14.3161
+380	1985.2027	74	1.4614	0.7428	0.9690	1.0820	8.2090	14.6950	8.1213	14.3051
+381	1985.2055	75	1.4613	0.7428	0.9689	1.0820	8.2090	14.6950	8.1409	14.2952
+382	1985.2082	76	1.4612	0.7427	0.9689	1.0820	8.2090	14.6950	8.1594	14.2866
+383	1985.2110	77	1.4611	0.7427	0.9688	1.0820	8.2090	14.6950	8.1767	14.2793
+384	1985.2137	78	1.4610	0.7427	0.9688	1.0820	8.2090	14.6950	8.1922	14.2734
+385	1985.2164	79	1.4609	0.7426	0.9688	1.0820	8.2090	14.6950	8.2057	14.2688
+386	1985.2192	80	1.4608	0.7426	0.9687	1.0820	8.2090	14.6950	8.2169	14.2655
+387	1985.2219	81	1.4607	0.7426	0.9687	1.0820	8.2090	14.6950	8.2254	14.2637
+388	1985.2247	82	1.4606	0.7425	0.9686	1.0820	8.2090	14.6950	8.2313	14.2632
+389	1985.2274	83	1.4605	0.7425	0.9686	1.0820	8.2090	14.6950	8.2342	14.2641
+390	1985.2301	84	1.4605	0.7425	0.9685	1.0820	8.2090	14.6950	8.2342	14.2662
+391	1985.2329	85	1.4604	0.7424	0.9685	1.0820	8.2090	14.6950	8.2312	14.2697
+392	1985.2356	86	1.4603	0.7424	0.9685	1.0820	8.2090	14.6950	8.2253	14.2744
+393	1985.2384	87	1.4602	0.7424	0.9684	1.0820	8.2090	14.6950	8.2166	14.2803
+394	1985.2411	88	1.4601	0.7424	0.9684	1.0820	8.2090	14.6950	8.2052	14.2873
+395	1985.2438	89	1.4600	0.7423	0.9683	1.0820	8.2090	14.6950	8.1914	14.2954
+396	1985.2466	90	1.4599	0.7423	0.9683	1.0820	8.2090	14.6950	8.1754	14.3044
+397	1985.2493	91	1.4598	0.7423	0.9682	1.0820	8.2090	14.6950	8.1576	14.3142
+398	1985.2521	92	1.4597	0.7422	0.9682	1.0820	8.2090	14.6950	8.1384	14.3248
+399	1985.2548	93	1.4596	0.7422	0.9682	1.0820	8.2090	14.6950	8.1179	14.3361
+400	1985.2575	94	1.4595	0.7422	0.9681	1.0820	8.2090	14.6950	8.0968	14.3479
+401	1985.2603	95	1.4594	0.7421	0.9681	1.0820	8.2090	14.6950	8.0753	14.3601
+402	1985.2630	96	1.4593	0.7421	0.9680	1.0820	8.2090	14.6950	8.0539	14.3726
+403	1985.2658	97	1.4592	0.7421	0.9680	1.0820	8.2090	14.6950	8.0329	14.3852
+404	1985.2685	98	1.4591	0.7420	0.9679	1.0820	8.2090	14.6950	8.0127	14.3979
+405	1985.2712	99	1.4590	0.7420	0.9679	1.0820	8.2090	14.6950	7.9937	14.4105
+406	1985.2740	100	1.4589	0.7420	0.9679	1.0820	8.2090	14.6950	7.9762	14.4229
+407	1985.2767	101	1.4588	0.7419	0.9678	1.0820	8.2090	14.6950	7.9605	14.4350
+408	1985.2795	102	1.4587	0.7419	0.9678	1.0820	8.2090	14.6950	7.9469	14.4466
+409	1985.2822	103	1.4586	0.7419	0.9677	1.0820	8.2090	14.6950	7.9355	14.4576
+410	1985.2849	104	1.4585	0.7418	0.9677	1.0820	8.2090	14.6950	7.9266	14.4678
+411	1985.2877	105	1.4584	0.7418	0.9676	1.0820	8.2090	14.6950	7.9203	14.4773
+412	1985.2904	106	1.4583	0.7418	0.9676	1.0820	8.2090	14.6950	7.9168	14.4859
+413	1985.2932	107	1.4582	0.7417	0.9676	1.0820	8.2090	14.6950	7.9159	14.4934
+414	1985.2959	108	1.4582	0.7417	0.9675	1.0820	8.2090	14.6950	7.9178	14.4998
+415	1985.2986	109	1.4581	0.7417	0.9675	1.0820	8.2090	14.6950	7.9224	14.5050
+416	1985.3014	110	1.4580	0.7416	0.9674	1.0820	8.2090	14.6950	7.9297	14.5089
+417	1985.3041	111	1.4579	0.7416	0.9674	1.0820	8.2090	14.6950	7.9394	14.5116
+418	1985.3068	112	1.4578	0.7416	0.9674	1.0820	8.2090	14.6950	7.9514	14.5129
+419	1985.3096	113	1.4577	0.7416	0.9673	1.0820	8.2090	14.6950	7.9655	14.5128
+420	1985.3123	114	1.4576	0.7415	0.9673	1.0820	8.2090	14.6950	7.9815	14.5112
+421	1985.3151	115	1.4575	0.7415	0.9672	1.0820	8.2090	14.6950	7.9990	14.5083
+422	1985.3178	116	1.4574	0.7415	0.9672	1.0820	8.2090	14.6950	8.0177	14.5039
+423	1985.3205	117	1.4573	0.7414	0.9671	1.0820	8.2090	14.6950	8.0372	14.4981
+424	1985.3233	118	1.4572	0.7414	0.9671	1.0820	8.2090	14.6950	8.0573	14.4910
+425	1985.3260	119	1.4571	0.7414	0.9671	1.0820	8.2090	14.6950	8.0775	14.4825
+426	1985.3288	120	1.4570	0.7413	0.9670	1.0820	8.2090	14.6950	8.0974	14.4727
+427	1985.3315	121	1.4569	0.7413	0.9670	1.0820	8.2090	14.6950	8.1166	14.4618
+428	1985.3342	122	1.4568	0.7413	0.9669	1.0820	8.2090	14.6950	8.1347	14.4497
+429	1985.3370	123	1.4567	0.7412	0.9669	1.0820	8.2090	14.6950	8.1515	14.4365
+430	1985.3397	124	1.4566	0.7412	0.9668	1.0820	8.2090	14.6950	8.1664	14.4224
+431	1985.3425	125	1.4565	0.7412	0.9668	1.0820	8.2090	14.6950	8.1792	14.4074
+432	1985.3452	126	1.4564	0.7411	0.9668	1.0820	8.2090	14.6950	8.1897	14.3917
+433	1985.3479	127	1.4563	0.7411	0.9667	1.0820	8.2090	14.6950	8.1976	14.3753
+434	1985.3507	128	1.4562	0.7411	0.9667	1.0820	8.2090	14.6950	8.2026	14.3585
+435	1985.3534	129	1.4562	0.7410	0.9666	1.0820	8.2090	14.6950	8.2048	14.3412
+436	1985.3562	130	1.4561	0.7410	0.9666	1.0820	8.2090	14.6950	8.2090	14.6950
+437	1985.3589	131	1.4560	0.7410	0.9666	1.0820	8.2090	14.6950	8.1915	14.6941
+438	1985.3616	132	1.4559	0.7410	0.9665	1.0820	8.2090	14.6950	8.1724	14.6918
+439	1985.3644	133	1.4558	0.7409	0.9665	1.0820	8.2090	14.6950	8.1521	14.6880
+440	1985.3671	134	1.4557	0.7409	0.9664	1.0820	8.2090	14.6950	8.1310	14.6828
+441	1985.3699	135	1.4556	0.7409	0.9664	1.0820	8.2090	14.6950	8.1094	14.6761
+442	1985.3726	136	1.4555	0.7408	0.9663	1.0820	8.2090	14.6950	8.0878	14.6681
+443	1985.3753	137	1.4554	0.7408	0.9663	1.0820	8.2090	14.6950	8.0665	14.6587
+444	1985.3781	138	1.4553	0.7408	0.9663	1.0820	8.2090	14.6950	8.0459	14.6481
+445	1985.3808	139	1.4552	0.7407	0.9662	1.0820	8.2090	14.6950	8.0265	14.6362
+446	1985.3836	140	1.4551	0.7407	0.9662	1.0820	8.2090	14.6950	8.0084	14.6232
+447	1985.3863	141	1.4550	0.7407	0.9661	1.0820	8.2090	14.6950	7.9922	14.6092
+448	1985.3890	142	1.4549	0.7406	0.9661	1.0820	8.2090	14.6950	7.9779	14.5943
+449	1985.3918	143	1.4548	0.7406	0.9661	1.0820	8.2090	14.6950	7.9658	14.5786
+450	1985.3945	144	1.4547	0.7406	0.9660	1.0820	8.2090	14.6950	7.9563	14.5621
+451	1985.3973	145	1.4546	0.7405	0.9660	1.0820	8.2090	14.6950	7.9493	14.5451
+452	1985.4000	146	1.4545	0.7405	0.9659	1.0820	8.2090	14.6950	7.9450	14.5276
+453	1985.4027	147	1.4545	0.7405	0.9659	1.0820	8.2090	14.6950	7.9434	14.5098
+454	1985.4055	148	1.4544	0.7404	0.9659	1.0820	8.2090	14.6950	7.9447	14.4918
+455	1985.4082	149	1.4543	0.7404	0.9658	1.0820	8.2090	14.6950	7.9486	14.4737
+456	1985.4110	150	1.4542	0.7404	0.9658	1.0820	8.2090	14.6950	7.9553	14.4556
+457	1985.4137	151	1.4541	0.7404	0.9657	1.0820	8.2090	14.6950	7.9645	14.4378
+458	1985.4164	152	1.4540	0.7403	0.9657	1.0820	8.2090	14.6950	7.9760	14.4203
+459	1985.4192	153	1.4539	0.7403	0.9656	1.0820	8.2090	14.6950	7.9897	14.4032
+460	1985.4219	154	1.4538	0.7403	0.9656	1.0820	8.2090	14.6950	8.0053	14.3867
+461	1985.4247	155	1.4537	0.7402	0.9656	1.0820	8.2090	14.6950	8.0226	14.3708
+462	1985.4274	156	1.4536	0.7402	0.9655	1.0820	8.2090	14.6950	8.0412	14.3558
+463	1985.4301	157	1.4535	0.7402	0.9655	1.0820	8.2090	14.6950	8.0607	14.3416
+464	1985.4329	158	1.4534	0.7401	0.9654	1.0820	8.2090	14.6950	8.0808	14.3283
+465	1985.4356	159	1.4533	0.7401	0.9654	1.0820	8.2090	14.6950	8.1011	14.3161
+466	1985.4384	160	1.4532	0.7401	0.9654	1.0820	8.2090	14.6950	8.1213	14.3051
+467	1985.4411	161	1.4531	0.7400	0.9653	1.0820	8.2090	14.6950	8.1409	14.2952
+468	1985.4438	162	1.4530	0.7400	0.9653	1.0820	8.2090	14.6950	8.1594	14.2866
+469	1985.4466	163	1.4530	0.7400	0.9652	1.0820	8.2090	14.6950	8.1767	14.2793
+470	1985.4493	164	1.4529	0.7399	0.9652	1.0820	8.2090	14.6950	8.1922	14.2734
+471	1985.4521	165	1.4528	0.7399	0.9652	1.0820	8.2090	14.6950	8.2057	14.2688
+472	1985.4548	166	1.4527	0.7399	0.9651	1.0820	8.2090	14.6950	8.2169	14.2655
+473	1985.4575	167	1.4526	0.7399	0.9651	1.0820	8.2090	14.6950	8.2254	14.2637
+474	1985.4603	168	1.4525	0.7398	0.9650	1.0820	8.2090	14.6950	8.2313	14.2632
+475	1985.4630	169	1.4524	0.7398	0.9650	1.0820	8.2090	14.6950	8.2342	14.2641
+476	1985.4658	170	1.4523	0.7398	0.9650	1.0820	8.2090	14.6950	8.2342	14.2662
+477	1985.4685	171	1.4522	0.7397	0.9649	1.0820	8.2090	14.6950	8.2312	14.2697
+478	1985.4712	172	1.4521	0.7397	0.9649	1.0820	8.2090	14.6950	8.2253	14.2744
+479	1985.4740	173	1.4520	0.7397	0.9648	1.0820	8.2090	14.6950	8.2166	14.2803
+480	1985.4767	174	1.4519	0.7396	0.9648	1.0820	8.2090	14.6950	8.2052	14.2873
+481	1985.4795	175	1.4518	0.7396	0.9647	1.0820	8.2090	14.6950	8.1914	14.2954
+482	1985.4822	176	1.4517	0.7396	0.9647	1.0820	8.2090	14.6950	8.1754	14.3044
+483	1985.4849	177	1.4516	0.7395	0.9647	1.0820	8.2090	14.6950	8.1576	14.3142
+484	1985.4877	178	1.4516	0.7395	0.9646	1.0820	8.2090	14.6950	8.1384	14.3248
+485	1985.4904	179	1.4515	0.7395	0.9646	1.0820	8.2090	14.6950	8.1179	14.3361
+486	1985.4932	180	1.4514	0.7394	0.9645	1.0820	8.2090	14.6950	8.0968	14.3479
+487	1985.4959	181	1.4513	0.7394	0.9645	1.0820	8.2090	14.6950	8.0753	14.3601
+488	1985.4986	182	1.4512	0.7394	0.9645	1.0820	8.2090	14.6950	8.0539	14.3726
+489	1985.5014	183	1.4511	0.7393	0.9644	1.0820	8.2090	14.6950	8.0329	14.3852
+490	1985.5041	184	1.4510	0.7393	0.9644	1.0820	8.2090	14.6950	8.0127	14.3979
+491	1985.5068	185	1.4509	0.7393	0.9643	1.0820	8.2090	14.6950	7.9937	14.4105
+492	1985.5096	186	1.4508	0.7393	0.9643	1.0820	8.2090	14.6950	7.9762	14.4229
+493	1985.5123	187	1.4507	0.7392	0.9643	1.0820	8.2090	14.6950	7.9605	14.4350
+494	1985.5151	188	1.4506	0.7392	0.9642	1.0820	8.2090	14.6950	7.9469	14.4466
+495	1985.5178	189	1.4505	0.7392	0.9642	1.0820	8.2090	14.6950	7.9355	14.4576
+496	1985.5205	190	1.4504	0.7391	0.9641	1.0820	8.2090	14.6950	7.9266	14.4678
+497	1985.5233	191	1.4503	0.7391	0.9641	1.0820	8.2090	14.6950	7.9203	14.4773
+498	1985.5260	192	1.4503	0.7391	0.9641	1.0820	8.2090	14.6950	8.2090	14.6950
+499	1985.5288	193	1.4502	0.7390	0.9640	1.0820	8.2090	14.6950	8.1915	14.6941
+500	1985.5315	194	1.4501	0.7390	0.9640	1.0820	8.2090	14.6950	8.1724	14.6918
+501	1985.5342	195	1.4500	0.7390	0.9639	1.0820	8.2090	14.6950	8.1521	14.6880
+502	1985.5370	196	1.4499	0.7389	0.9639	1.0820	8.2090	14.6950	8.1310	14.6828
+503	1985.5397	197	1.4498	0.7389	0.9639	1.0820	8.2090	14.6950	8.1094	14.6761
+504	1985.5425	198	1.4497	0.7389	0.9638	1.0820	8.2090	14.6950	8.0878	14.6681
+505	1985.5452	199	1.4496	0.7389	0.9638	1.0820	8.2090	14.6950	8.0665	14.6587
+506	1985.5479	200	1.4495	0.7388	0.9637	1.0820	8.2090	14.6950	8.0459	14.6481
+507	1985.5507	201	1.4494	0.7388	0.9637	1.0820	8.2090	14.6950	8.0265	14.6362
+508	1985.5534	202	1.4493	0.7388	0.9637	1.0820	8.2090	14.6950	8.0084	14.6232
+509	1985.5562	203	1.4492	0.7387	0.9636	1.0820	8.2090	14.6950	7.9922	14.6092
+510	1985.5589	204	1.4491	0.7387	0.9636	1.0820	8.2090	14.6950	7.9779	14.5943
+511	1985.5616	205	1.4491	0.7387	0.9635	1.0820	8.2090	14.6950	7.9658	14.5786
+512	1985.5644	206	1.4490	0.7386	0.9635	1.0820	8.2090	14.6950	7.9563	14.5621
+513	1985.5671	207	1.4489	0.7386	0.9635	1.0820	8.2090	14.6950	7.9493	14.5451
+514	1985.5699	208	1.4488	0.7386	0.9634	1.0820	8.2090	14.6950	7.9450	14.5276
+515	1985.5726	209	1.4487	0.7385	0.9634	1.0820	8.2090	14.6950	7.9434	14.5098
+516	1985.5753	210	1.4486	0.7385	0.9633	1.0820	8.2090	14.6950	7.9447	14.4918
+517	1985.5781	211	1.4485	0.7385	0.9633	1.0820	8.2090	14.6950	7.9486	14.4737
+518	1985.5808	212	1.4484	0.7385	0.9633	1.0820	8.2090	14.6950	7.9553	14.4556
+519	1985.5836	213	1.4483	0.7384	0.9632	1.0820	8.2090	14.6950	7.9645	14.4378
+520	1985.5863	214	1.4482	0.7384	0.9632	1.0820	8.2090	14.6950	7.9760	14.4203
+521	1985.5890	215	1.4481	0.7384	0.9632	1.0820	8.2090	14.6950	7.9897	14.4032
+522	1985.5918	216	1.4480	0.7383	0.9631	1.0820	8.2090	14.6950	8.0053	14.3867
+523	1985.5945	217	1.4480	0.7383	0.9631	1.0820	8.2090	14.6950	8.0226	14.3708
+524	1985.5973	218	1.4479	0.7383	0.9630	1.0820	8.2090	14.6950	8.0412	14.3558
+525	1985.6000	219	1.4478	0.7382	0.9630	1.0820	8.2090	14.6950	8.0607	14.3416
+526	1985.6027	220	1.4477	0.7382	0.9630	1.0820	8.2090	14.6950	8.0808	14.3283
+527	1985.6055	221	1.4476	0.7382	0.9629	1.0820	8.2090	14.6950	8.1011	14.3161
+528	1985.6082	222	1.4475	0.7381	0.9629	1.0820	8.2090	14.6950	8.1213	14.3051
+529	1985.6110	223	1.4474	0.7381	0.9628	1.0820	8.2090	14.6950	8.1409	14.2952
+530	1985.6137	224	1.4473	0.7381	0.9628	1.0820	8.2090	14.6950	8.1594	14.2866
+531	1985.6164	225	1.4472	0.7380	0.9628	1.0820	8.2090	14.6950	8.1767	14.2793
+532	1985.6192	226	1.4471	0.7380	0.9627	1.0820	8.2090	14.6950	8.1922	14.2734
+533	1985.6219	227	1.4470	0.7380	0.9627	1.0820	8.2090	14.6950	8.2057	14.2688
+534	1985.6247	228	1.4469	0.7380	0.9626	1.0820	8.2090	14.6950	8.2169	14.2655
+535	1985.6274	229	1.4469	0.7379	0.9626	1.0820	8.2090	14.6950	8.2254	14.2637
+536	1985.6301	230	1.4468	0.7379	0.9626	1.0820	8.2090	14.6950	8.2313	14.2632
+537	1985.6329	231	1.4467	0.7379	0.9625	1.0820	8.2090	14.6950	8.2342	14.2641
+538	1985.6356	232	1.4466	0.7378	0.9625	1.0820	8.2090	14.6950	8.2342	14.2662
+539	1985.6384	233	1.4465	0.7378	0.9624	1.0820	8.2090	14.6950	8.2312	14.2697
+540	1985.6411	234	1.4464	0.7378	0.9624	1.0820	8.2090	14.6950	8.2253	14.2744
+541	1985.6438	235	1.4463	0.7377	0.9624	1.0820	8.2090	14.6950	8.2166	14.2803
+542	1985.6466	236	1.4462	0.7377	0.9623	1.0820	8.2090	14.6950	8.2052	14.2873
+543	1985.6493	237	1.4461	0.7377	0.9623	1.0820	8.2090	14.6950	8.1914	14.2954
+544	1985.6521	238	1.4460	0.7376	0.9622	1.0820	8.2090	14.6950	8.1754	14.3044
+545	1985.6548	239	1.4459	0.7376	0.9622	1.0820	8.2090	14.6950	8.1576	14.3142
+546	1985.6575	240	1.4459	0.7376	0.9622	1.0820	8.2090	14.6950	8.1384	14.3248
+547	1985.6603	241	1.4458	0.7376	0.9621	1.0820	8.2090	14.6950	8.1179	14.3361
+548	1985.6630	242	1.4457	0.7375	0.9621	1.0820	8.2090	14.6950	8.0968	14.3479
+549	1985.6658	243	1.4456	0.7375	0.9621	1.0820	8.2090	14.6950	8.0753	14.3601
+550	1985.6685	244	1.4455	0.7375	0.9620	1.0820	8.2090	14.6950	8.0539	14.3726
+551	1985.6712	245	1.4454	0.7374	0.9620	1.0820	8.2090	14.6950	8.0329	14.3852
+552	1985.6740	246	1.4453	0.7374	0.9619	1.0820	8.2090	14.6950	8.0127	14.3979
+553	1985.6767	247	1.4452	0.7374	0.9619	1.0820	8.2090	14.6950	7.9937	14.4105
+554	1985.6795	248	1.4451	0.7373	0.9619	1.0820	8.2090	14.6950	7.9762	14.4229
+555	1985.6822	249	1.4450	0.7373	0.9618	1.0820	8.2090	14.6950	7.9605	14.4350
+556	1985.6849	250	1.4450	0.7373	0.9618	1.0820	8.2090	14.6950	7.9469	14.4466
+557	1985.6877	251	1.4449	0.7373	0.9617	1.0820	8.2090	14.6950	7.9355	14.4576
+558	1985.6904	252	1.4448	0.7372	0.9617	1.0820	8.2090	14.6950	7.9266	14.4678
+559	1985.6932	253	1.4447	0.7372	0.9617	1.0820	8.2090	14.6950	7.9203	14.4773
+560	1985.6959	254	1.4446	0.7372	0.9616	1.0820	8.2090	14.6950	7.9168	14.4859
+561	1985.6986	255	1.4445	0.7371	0.9616	1.0820	8.2090	14.6950	7.9159	14.4934
+562	1985.7014	256	1.4444	0.7371	0.9616	1.0820	8.2090	14.6950	7.9178	14.4998
+563	1985.7041	257	1.4443	0.7371	0.9615	1.0820	8.2090	14.6950	7.9224	14.5050
+564	1985.7068	258	1.4442	0.7370	0.9615	1.0820	8.2090	14.6950	7.9297	14.5089
+565	1985.7096	259	1.4441	0.7370	0.9614	1.0820	8.2090	14.6950	7.9394	14.5116
+566	1985.7123	260	1.4441	0.7370	0.9614	1.0820	8.2090	14.6950	7.9514	14.5129
+567	1985.7151	261	1.4440	0.7369	0.9614	1.0820	8.2090	14.6950	7.9655	14.5128
+568	1985.7178	262	1.4439	0.7369	0.9613	1.0820	8.2090	14.6950	8.2090	14.6950
+569	1985.7205	263	1.4438	0.7369	0.9613	1.0820	8.2090	14.6950	8.1915	14.6941
+570	1985.7233	264	1.4437	0.7369	0.9612	1.0820	8.2090	14.6950	8.1724	14.6918
+571	1985.7260	265	1.4436	0.7368	0.9612	1.0820	8.2090	14.6950	8.1521	14.6880
+572	1985.7288	266	1.4435	0.7368	0.9612	1.0820	8.2090	14.6950	8.1310	14.6828
+573	1985.7315	267	1.4434	0.7368	0.9611	1.0820	8.2090	14.6950	8.1094	14.6761
+574	1985.7342	268	1.4433	0.7367	0.9611	1.0820	8.2090	14.6950	8.0878	14.6681
+575	1985.7370	269	1.4432	0.7367	0.9611	1.0820	8.2090	14.6950	8.0665	14.6587
+576	1985.7397	270	1.4432	0.7367	0.9610	1.0820	8.2090	14.6950	8.0459	14.6481
+577	1985.7425	271	1.4431	0.7366	0.9610	1.0820	8.2090	14.6950	8.0265	14.6362
+578	1985.7452	272	1.4430	0.7366	0.9609	1.0820	8.2090	14.6950	8.0084	14.6232
+579	1985.7479	273	1.4429	0.7366	0.9609	1.0820	8.2090	14.6950	7.9922	14.6092
+580	1985.7507	274	1.4428	0.7366	0.9609	1.0820	8.2090	14.6950	7.9779	14.5943
+581	1985.7534	275	1.4427	0.7365	0.9608	1.0820	8.2090	14.6950	7.9658	14.5786
+582	1985.7562	276	1.4426	0.7365	0.9608	1.0820	8.2090	14.6950	7.9563	14.5621
+583	1985.7589	277	1.4425	0.7365	0.9608	1.0820	8.2090	14.6950	7.9493	14.5451
+584	1985.7616	278	1.4424	0.7364	0.9607	1.0820	8.2090	14.6950	7.9450	14.5276
+585	1985.7644	279	1.4423	0.7364	0.9607	1.0820	8.2090	14.6950	7.9434	14.5098
+586	1985.7671	280	1.4423	0.7364	0.9606	1.0820	8.2090	14.6950	7.9447	14.4918
+587	1985.7699	281	1.4422	0.7363	0.9606	1.0820	8.2090	14.6950	7.9486	14.4737
+588	1985.7726	282	1.4421	0.7363	0.9606	1.0820	8.2090	14.6950	7.9553	14.4556
+589	1985.7753	283	1.4420	0.7363	0.9605	1.0820	8.2090	14.6950	7.9645	14.4378
+590	1985.7781	284	1.4419	0.7362	0.9605	1.0820	8.2090	14.6950	7.9760	14.4203
+591	1985.7808	285	1.4418	0.7362	0.9605	1.0820	8.2090	14.6950	7.9897	14.4032
+592	1985.7836	286	1.4417	0.7362	0.9604	1.0820	8.2090	14.6950	8.0053	14.3867
+593	1985.7863	287	1.4416	0.7362	0.9604	1.0820	8.2090	14.6950	8.0226	14.3708
+594	1985.7890	288	1.4415	0.7361	0.9603	1.0820	8.2090	14.6950	8.0412	14.3558
+595	1985.7918	289	1.4415	0.7361	0.9603	1.0820	8.2090	14.6950	8.0607	14.3416
+596	1985.7945	290	1.4414	0.7361	0.9603	1.0820	8.2090	14.6950	8.0808	14.3283
+597	1985.7973	291	1.4413	0.7360	0.9602	1.0820	8.2090	14.6950	8.1011	14.3161
+598	1985.8000	292	1.4412	0.7360	0.9602	1.0820	8.2090	14.6950	8.1213	14.3051
+599	1985.8027	293	1.4411	0.7360	0.9602	1.0820	8.2090	14.6950	8.1409	14.2952
+600	1985.8055	294	1.4410	0.7359	0.9601	1.0820	8.2090	14.6950	8.1594	14.2866
+601	1985.8082	295	1.4409	0.7359	0.9601	1.0820	8.2090	14.6950	8.1767	14.2793
+602	1985.8110	296	1.4408	0.7359	0.9600	1.0820	8.2090	14.6950	8.1922	14.2734
+603	1985.8137	297	1.4407	0.7359	0.9600	1.0820	8.2090	14.6950	8.2057	14.2688
+604	1985.8164	298	1.4407	0.7358	0.9600	1.0820	8.2090	14.6950	8.2169	14.2655
+605	1985.8192	299	1.4406	0.7358	0.9599	1.0820	8.2090	14.6950	8.2254	14.2637
+606	1985.8219	300	1.4405	0.7358	0.9599	1.0820	8.2090	14.6950	8.2313	14.2632
+607	1985.8247	301	1.4404	0.7357	0.9599	1.0820	8.2090	14.6950	8.2342	14.2641
+608	1985.8274	302	1.4403	0.7357	0.9598	1.0820	8.2090	14.6950	8.2342	14.2662
+609	1985.8301	303	1.4402	0.7357	0.9598	1.0820	8.2090	14.6950	8.2312	14.2697
+610	1985.8329	304	1.4401	0.7356	0.9597	1.0820	8.2090	14.6950	8.2253	14.2744
+611	1985.8356	305	1.4400	0.7356	0.9597	1.0820	8.2090	14.6950	8.2166	14.2803
+612	1985.8384	306	1.4399	0.7356	0.9597	1.0820	8.2090	14.6950	8.2052	14.2873
+613	1985.8411	307	1.4399	0.7356	0.9596	1.0820	8.2090	14.6950	8.1914	14.2954
+614	1985.8438	308	1.4398	0.7355	0.9596	1.0820	8.2090	14.6950	8.1754	14.3044
+615	1985.8466	309	1.4397	0.7355	0.9596	1.0820	8.2090	14.6950	8.1576	14.3142
+616	1985.8493	310	1.4396	0.7355	0.9595	1.0820	8.2090	14.6950	8.1384	14.3248
+617	1985.8521	311	1.4395	0.7354	0.9595	1.0820	8.2090	14.6950	8.1179	14.3361
+618	1985.8548	312	1.4394	0.7354	0.9594	1.0820	8.2090	14.6950	8.0968	14.3479
+619	1985.8575	313	1.4393	0.7354	0.9594	1.0820	8.2090	14.6950	8.0753	14.3601
+620	1985.8603	314	1.4392	0.7353	0.9594	1.0820	8.2090	14.6950	8.0539	14.3726
+621	1985.8630	315	1.4391	0.7353	0.9593	1.0820	8.2090	14.6950	8.0329	14.3852
+622	1985.8658	316	1.4391	0.7353	0.9593	1.0820	8.2090	14.6950	8.0127	14.3979
+623	1985.8685	317	1.4390	0.7353	0.9593	1.0820	8.2090	14.6950	7.9937	14.4105
+624	1985.8712	318	1.4389	0.7352	0.9592	1.0820	8.2090	14.6950	7.9762	14.4229
+625	1985.8740	319	1.4388	0.7352	0.9592	1.0820	8.2090	14.6950	7.9605	14.4350
+626	1985.8767	320	1.4387	0.7352	0.9591	1.0820	8.2090	14.6950	7.9469	14.4466
+627	1985.8795	321	1.4386	0.7351	0.9591	1.0820	8.2090	14.6950	7.9355	14.4576
+628	1985.8822	322	1.4385	0.7351	0.9591	1.0820	8.2090	14.6950	7.9266	14.4678
+629	1985.8849	323	1.4384	0.7351	0.9590	1.0820	8.2090	14.6950	7.9203	14.4773
+630	1985.8877	324	1.4384	0.7350	0.9590	1.0820	8.2090	14.6950	7.9168	14.4859
+631	1985.8904	325	1.4383	0.7350	0.9590	1.0820	8.2090	14.6950	7.9159	14.4934
+632	1985.8932	326	1.4382	0.7350	0.9589	1.0820	8.2090	14.6950	7.9178	14.4998
+633	1985.8959	327	1.4381	0.7350	0.9589	1.0820	8.2090	14.6950	7.9224	14.5050
+634	1985.8986	328	1.4380	0.7349	0.9589	1.0820	8.2090	14.6950	7.9297	14.5089
+635	1985.9014	329	1.4379	0.7349	0.9588	1.0820	8.2090	14.6950	7.9394	14.5116
+636	1985.9041	330	1.4378	0.7349	0.9588	1.0820	8.2090	14.6950	7.9514	14.5129
+637	1985.9068	331	1.4377	0.7348	0.9587	1.0820	8.2090	14.6950	7.9655	14.5128
+638	1985.9096	332	1.4377	0.7348	0.9587	1.0820	8.2090	14.6950	7.9815	14.5112
+639	1985.9123	333	1.4376	0.7348	0.9587	1.0820	8.2090	14.6950	7.9990	14.5083
+640	1985.9151	334	1.4375	0.7347	0.9586	1.0820	8.2090	14.6950	8.0177	14.5039
+641	1985.9178	335	1.4374	0.7347	0.9586	1.0820	8.2090	14.6950	8.0372	14.4981
+642	1985.9205	336	1.4373	0.7347	0.9586	1.0820	8.2090	14.6950	8.0573	14.4910
+643	1985.9233	337	1.4372	0.7347	0.9585	1.0820	8.2090	14.6950	8.0775	14.4825
+644	1985.9260	338	1.4371	0.7346	0.9585	1.0820	8.2090	14.6950	8.0974	14.4727
+645	1985.9288	339	1.4370	0.7346	0.9585	1.0820	8.2090	14.6950	8.1166	14.4618
+646	1985.9315	340	1.4370	0.7346	0.9584	1.0820	8.2090	14.6950	8.1347	14.4497
+647	1985.9342	341	1.4369	0.7345	0.9584	1.0820	8.2090	14.6950	8.1515	14.4365
+648	1985.9370	342	1.4368	0.7345	0.9583	1.0820	8.2090	14.6950	8.1664	14.4224
+649	1985.9397	343	1.4367	0.7345	0.9583	1.0820	8.2090	14.6950	8.1792	14.4074
+650	1985.9425	344	1.4366	0.7344	0.9583	1.0820	8.2090	14.6950	8.1897	14.3917
+651	1985.9452	345	1.4365	0.7344	0.9582	1.0820	8.2090	14.6950	8.1976	14.3753
+652	1985.9479	346	1.4364	0.7344	0.9582	1.0820	8.2090	14.6950	8.2026	14.3585
+653	1985.9507	347	1.4363	0.7344	0.9582	1.0820	8.2090	14.6950	8.2048	14.3412
+654	1985.9534	348	1.4363	0.7343	0.9581	1.0820	8.2090	14.6950	8.2041	14.3237
+655	1985.9562	349	1.4362	0.7343	0.9581	1.0820	8.2090	14.6950	8.2004	14.3060
+656	1985.9589	350	1.4361	0.7343	0.9581	1.0820	8.2090	14.6950	8.1938	14.2883
+657	1985.9616	351	1.4360	0.7342	0.9580	1.0820	8.2090	14.6950	8.1844	14.2708
+658	1985.9644	352	1.4359	0.7342	0.9580	1.0820	8.2090	14.6950	8.1725	14.2535
+659	1985.9671	353	1.4358	0.7342	0.9579	1.0820	8.2090	14.6950	8.1582	14.2365
+660	1985.9699	354	1.4357	0.7341	0.9579	1.0820	8.2090	14.6950	8.1419	14.2201
+661	1985.9726	355	1.4356	0.7341	0.9579	1.0820	8.2090	14.6950	8.1238	14.2042
+662	1985.9753	356	1.4356	0.7341	0.9578	1.0820	8.2090	14.6950	8.1044	14.1891
+663	1985.9781	357	1.4355	0.7341	0.9578	1.0820	8.2090	14.6950	8.0839	14.1747
+664	1985.9808	358	1.4354	0.7340	0.9578	1.0820	8.2090	14.6950	8.0628	14.1612
+665	1985.9836	359	1.4353	0.7340	0.9577	1.0820	8.2090	14.6950	8.0414	14.1488
+666	1985.9863	360	1.4352	0.7340	0.9577	1.0820	8.2090	14.6950	8.0202	14.1373
+667	1985.9890	361	1.4351	0.7339	0.9577	1.0820	8.2090	14.6950	7.9995	14.1271
+668	1985.9918	362	1.4350	0.7339	0.9576	1.0820	8.2090	14.6950	7.9798	14.1180
+669	1985.9945	363	1.4350	0.7339	0.9576	1.0820	8.2090	14.6950	7.9612	14.1101
+670	1985.9973	364	1.4349	0.7339	0.9575	1.0820	8.2090	14.6950	7.9443	14.1036
+671	1985.9999	365	1.4348	0.7338	0.9575	1.0820	8.2090	14.6950	7.9292	14.0983
+672	1986.0027	1	1.4347	0.7338	0.9575	1.0820	8.2090	14.6950	7.9162	14.0944
+673	1986.0055	2	1.4346	0.7338	0.9574	1.0820	8.2090	14.6950	8.2090	14.6950
+674	1986.0082	3	1.4345	0.7337	0.9574	1.0820	8.2090	14.6950	8.1915	14.6941
+675	1986.0110	4	1.4344	0.7337	0.9574	1.0820	8.2090	14.6950	8.1724	14.6918
+676	1986.0137	5	1.4343	0.7337	0.9573	1.0820	8.2090	14.6950	8.1521	14.6880
+677	1986.0164	6	1.4343	0.7336	0.9573	1.0820	8.2090	14.6950	8.1310	14.6828
+678	1986.0192	7	1.4342	0.7336	0.9573	1.0820	8.2090	14.6950	8.1094	14.6761
+679	1986.0219	8	1.4341	0.7336	0.9572	1.0820	8.2090	14.6950	8.0878	14.6681
+680	1986.0247	9	1.4340	0.7336	0.9572	1.0820	8.2090	14.6950	8.0665	14.6587
+681	1986.0274	10	1.4339	0.7335	0.9572	1.0820	8.2090	14.6950	8.0459	14.6481
+682	1986.0301	11	1.4338	0.7335	0.9571	1.0820	8.2090	14.6950	8.0265	14.6362
+683	1986.0329	12	1.4337	0.7335	0.9571	1.0820	8.2090	14.6950	8.0084	14.6232
+684	1986.0356	13	1.4337	0.7334	0.9571	1.0820	8.2090	14.6950	7.9922	14.6092
+685	1986.0384	14	1.4336	0.7334	0.9570	1.0820	8.2090	14.6950	7.9779	14.5943
+686	1986.0411	15	1.4335	0.7334	0.9570	1.0820	8.2090	14.6950	7.9658	14.5786
+687	1986.0438	16	1.4334	0.7334	0.9569	1.0820	8.2090	14.6950	7.9563	14.5621
+688	1986.0466	17	1.4333	0.7333	0.9569	1.0820	8.2090	14.6950	7.9493	14.5451
+689	1986.0493	18	1.4332	0.7333	0.9569	1.0820	8.2090	14.6950	7.9450	14.5276
+690	1986.0521	19	1.4331	0.7333	0.9568	1.0820	8.2090	14.6950	7.9434	14.5098
+691	1986.0548	20	1.4331	0.7332	0.9568	1.0820	8.2090	14.6950	7.9447	14.4918
+692	1986.0575	21	1.4330	0.7332	0.9568	1.0820	8.2090	14.6950	7.9486	14.4737
+693	1986.0603	22	1.4329	0.7332	0.9567	1.0820	8.2090	14.6950	7.9553	14.4556
+694	1986.0630	23	1.4328	0.7331	0.9567	1.0820	8.2090	14.6950	7.9645	14.4378
+695	1986.0658	24	1.4327	0.7331	0.9567	1.0820	8.2090	14.6950	7.9760	14.4203
+696	1986.0685	25	1.4326	0.7331	0.9566	1.0820	8.2090	14.6950	7.9897	14.4032
+697	1986.0712	26	1.4325	0.7331	0.9566	1.0820	8.2090	14.6950	8.0053	14.3867
+698	1986.0740	27	1.4325	0.7330	0.9566	1.0820	8.2090	14.6950	8.0226	14.3708
+699	1986.0767	28	1.4324	0.7330	0.9565	1.0820	8.2090	14.6950	8.0412	14.3558
+700	1986.0795	29	1.4323	0.7330	0.9565	1.0820	8.2090	14.6950	8.0607	14.3416
+701	1986.0822	30	1.4322	0.7329	0.9565	1.0820	8.2090	14.6950	8.0808	14.3283
+702	1986.0849	31	1.4321	0.7329	0.9564	1.0820	8.2090	14.6950	8.1011	14.3161
+703	1986.0877	32	1.4320	0.7329	0.9564	1.0820	8.2090	14.6950	8.1213	14.3051
+704	1986.0904	33	1.4319	0.7329	0.9563	1.0820	8.2090	14.6950	8.1409	14.2952
+705	1986.0932	34	1.4319	0.7328	0.9563	1.0820	8.2090	14.6950	8.1594	14.2866
+706	1986.0959	35	1.4318	0.7328	0.9563	1.0820	8.2090	14.6950	8.1767	14.2793
+707	1986.0986	36	1.4317	0.7328	0.9562	1.0820	8.2090	14.6950	8.1922	14.2734
+708	1986.1014	37	1.4316	0.7327	0.9562	1.0820	8.2090	14.6950	8.2057	14.2688
+709	1986.1041	38	1.4315	0.7327	0.9562	1.0820	8.2090	14.6950	8.2169	14.2655
+710	1986.1068	39	1.4314	0.7327	0.9561	1.0820	8.2090	14.6950	8.2254	14.2637
+711	1986.1096	40	1.4313	0.7326	0.9561	1.0820	8.2090	14.6950	8.2313	14.2632
+712	1986.1123	41	1.4313	0.7326	0.9561	1.0820	8.2090	14.6950	8.2342	14.2641
+713	1986.1151	42	1.4312	0.7326	0.9560	1.0820	8.2090	14.6950	8.2342	14.2662
+714	1986.1178	43	1.4311	0.7326	0.9560	1.0820	8.2090	14.6950	8.2312	14.2697
+715	1986.1205	44	1.4310	0.7325	0.9560	1.0820	8.2090	14.6950	8.2253	14.2744
+716	1986.1233	45	1.4309	0.7325	0.9559	1.0820	8.2090	14.6950	8.2166	14.2803
+717	1986.1260	46	1.4308	0.7325	0.9559	1.0820	8.2090	14.6950	8.2052	14.2873
+718	1986.1288	47	1.4307	0.7324	0.9559	1.0820	8.2090	14.6950	8.1914	14.2954
+719	1986.1315	48	1.4307	0.7324	0.9558	1.0820	8.2090	14.6950	8.1754	14.3044
+720	1986.1342	49	1.4306	0.7324	0.9558	1.0820	8.2090	14.6950	8.1576	14.3142
+721	1986.1370	50	1.4305	0.7324	0.9558	1.0820	8.2090	14.6950	8.1384	14.3248
+722	1986.1397	51	1.4304	0.7323	0.9557	1.0820	8.2090	14.6950	8.1179	14.3361
+723	1986.1425	52	1.4303	0.7323	0.9557	1.0820	8.2090	14.6950	8.0968	14.3479
+724	1986.1452	53	1.4302	0.7323	0.9556	1.0820	8.2090	14.6950	8.0753	14.3601
+725	1986.1479	54	1.4302	0.7322	0.9556	1.0820	8.2090	14.6950	8.0539	14.3726
+726	1986.1507	55	1.4301	0.7322	0.9556	1.0820	8.2090	14.6950	8.0329	14.3852
+727	1986.1534	56	1.4300	0.7322	0.9555	1.0820	8.2090	14.6950	8.0127	14.3979
+728	1986.1562	57	1.4299	0.7322	0.9555	1.0820	8.2090	14.6950	7.9937	14.4105
+729	1986.1589	58	1.4298	0.7321	0.9555	1.0820	8.2090	14.6950	7.9762	14.4229
+730	1986.1616	59	1.4297	0.7321	0.9554	1.0820	8.2090	14.6950	7.9605	14.4350
+731	1986.1644	60	1.4296	0.7321	0.9554	1.0820	8.2090	14.6950	7.9469	14.4466
+732	1986.1671	61	1.4296	0.7320	0.9554	1.0820	8.2090	14.6950	7.9355	14.4576
+733	1986.1699	62	1.4295	0.7320	0.9553	1.0820	8.2090	14.6950	7.9266	14.4678
+734	1986.1726	63	1.4294	0.7320	0.9553	1.0820	8.2090	14.6950	7.9203	14.4773
+735	1986.1753	64	1.4293	0.7319	0.9553	1.0820	8.2090	14.6950	8.2090	14.6950
+736	1986.1781	65	1.4292	0.7319	0.9552	1.0820	8.2090	14.6950	8.1915	14.6941
+737	1986.1808	66	1.4291	0.7319	0.9552	1.0820	8.2090	14.6950	8.1724	14.6918
+738	1986.1836	67	1.4291	0.7319	0.9552	1.0820	8.2090	14.6950	8.1521	14.6880
+739	1986.1863	68	1.4290	0.7318	0.9551	1.0820	8.2090	14.6950	8.1310	14.6828
+740	1986.1890	69	1.4289	0.7318	0.9551	1.0820	8.2090	14.6950	8.1094	14.6761
+741	1986.1918	70	1.4288	0.7318	0.9551	1.0820	8.2090	14.6950	8.0878	14.6681
+742	1986.1945	71	1.4287	0.7317	0.9550	1.0820	8.2090	14.6950	8.0665	14.6587
+743	1986.1973	72	1.4286	0.7317	0.9550	1.0820	8.2090	14.6950	8.0459	14.6481
+744	1986.2000	73	1.4285	0.7317	0.9550	1.0820	8.2090	14.6950	8.0265	14.6362
+745	1986.2027	74	1.4285	0.7317	0.9549	1.0820	8.2090	14.6950	8.0084	14.6232
+746	1986.2055	75	1.4284	0.7316	0.9549	1.0820	8.2090	14.6950	7.9922	14.6092
+747	1986.2082	76	1.4283	0.7316	0.9549	1.0820	8.2090	14.6950	7.9779	14.5943
+748	1986.2110	77	1.4282	0.7316	0.9548	1.0820	8.2090	14.6950	7.9658	14.5786
+749	1986.2137	78	1.4281	0.7315	0.9548	1.0820	8.2090	14.6950	7.9563	14.5621
+750	1986.2164	79	1.4280	0.7315	0.9548	1.0820	8.2090	14.6950	7.9493	14.5451
+751	1986.2192	80	1.4280	0.7315	0.9547	1.0820	8.2090	14.6950	7.9450	14.5276
+752	1986.2219	81	1.4279	0.7315	0.9547	1.0820	8.2090	14.6950	7.9434	14.5098
+753	1986.2247	82	1.4278	0.7314	0.9547	1.0820	8.2090	14.6950	7.9447	14.4918
+754	1986.2274	83	1.4277	0.7314	0.9546	1.0820	8.2090	14.6950	7.9486	14.4737
+755	1986.2301	84	1.4276	0.7314	0.9546	1.0820	8.2090	14.6950	7.9553	14.4556
+756	1986.2329	85	1.4275	0.7313	0.9546	1.0820	8.2090	14.6950	7.9645	14.4378
+757	1986.2356	86	1.4275	0.7313	0.9545	1.0820	8.2090	14.6950	7.9760	14.4203
+758	1986.2384	87	1.4274	0.7313	0.9545	1.0820	8.2090	14.6950	7.9897	14.4032
+759	1986.2411	88	1.4273	0.7313	0.9545	1.0820	8.2090	14.6950	8.0053	14.3867
+760	1986.2438	89	1.4272	0.7312	0.9544	1.0820	8.2090	14.6950	8.0226	14.3708
+761	1986.2466	90	1.4271	0.7312	0.9544	1.0820	8.2090	14.6950	8.0412	14.3558
+762	1986.2493	91	1.4270	0.7312	0.9544	1.0820	8.2090	14.6950	8.0607	14.3416
+763	1986.2521	92	1.4270	0.7311	0.9543	1.0820	8.2090	14.6950	8.0808	14.3283
+764	1986.2548	93	1.4269	0.7311	0.9543	1.0820	8.2090	14.6950	8.1011	14.3161
+765	1986.2575	94	1.4268	0.7311	0.9543	1.0820	8.2090	14.6950	8.1213	14.3051
+766	1986.2603	95	1.4267	0.7311	0.9542	1.0820	8.2090	14.6950	8.1409	14.2952
+767	1986.2630	96	1.4266	0.7310	0.9542	1.0820	8.2090	14.6950	8.1594	14.2866
+768	1986.2658	97	1.4265	0.7310	0.9542	1.0820	8.2090	14.6950	8.1767	14.2793
+769	1986.2685	98	1.4265	0.7310	0.9541	1.0820	8.2090	14.6950	8.1922	14.2734
+770	1986.2712	99	1.4264	0.7309	0.9541	1.0820	8.2090	14.6950	8.2057	14.2688
+771	1986.2740	100	1.4263	0.7309	0.9541	1.0820	8.2090	14.6950	8.2169	14.2655
+772	1986.2767	101	1.4262	0.7309	0.9540	1.0820	8.2090	14.6950	8.2254	14.2637
+773	1986.2795	102	1.4261	0.7308	0.9540	1.0820	8.2090	14.6950	8.2313	14.2632
+774	1986.2822	103	1.4260	0.7308	0.9540	1.0820	8.2090	14.6950	8.2342	14.2641
+775	1986.2849	104	1.4260	0.7308	0.9539	1.0820	8.2090	14.6950	8.2342	14.2662
+776	1986.2877	105	1.4259	0.7308	0.9539	1.0820	8.2090	14.6950	8.2312	14.2697
+777	1986.2904	106	1.4258	0.7307	0.9539	1.0820	8.2090	14.6950	8.2253	14.2744
+778	1986.2932	107	1.4257	0.7307	0.9538	1.0820	8.2090	14.6950	8.2166	14.2803
+779	1986.2959	108	1.4256	0.7307	0.9538	1.0820	8.2090	14.6950	8.2052	14.2873
+780	1986.2986	109	1.4255	0.7306	0.9538	1.0820	8.2090	14.6950	8.1914	14.2954
+781	1986.3014	110	1.4255	0.7306	0.9537	1.0820	8.2090	14.6950	8.1754	14.3044
+782	1986.3041	111	1.4254	0.7306	0.9537	1.0820	8.2090	14.6950	8.1576	14.3142
+783	1986.3068	112	1.4253	0.7306	0.9537	1.0820	8.2090	14.6950	8.1384	14.3248
+784	1986.3096	113	1.4252	0.7305	0.9536	1.0820	8.2090	14.6950	8.1179	14.3361
+785	1986.3123	114	1.4251	0.7305	0.9536	1.0820	8.2090	14.6950	8.0968	14.3479
+786	1986.3151	115	1.4250	0.7305	0.9536	1.0820	8.2090	14.6950	8.0753	14.3601
+787	1986.3178	116	1.4250	0.7304	0.9535	1.0820	8.2090	14.6950	8.0539	14.3726
+788	1986.3205	117	1.4249	0.7304	0.9535	1.0820	8.2090	14.6950	8.0329	14.3852
+789	1986.3233	118	1.4248	0.7304	0.9535	1.0820	8.2090	14.6950	8.0127	14.3979
+790	1986.3260	119	1.4247	0.7304	0.9534	1.0820	8.2090	14.6950	7.9937	14.4105
+791	1986.3288	120	1.4246	0.7303	0.9534	1.0820	8.2090	14.6950	7.9762	14.4229
+792	1986.3315	121	1.4245	0.7303	0.9534	1.0820	8.2090	14.6950	7.9605	14.4350
+793	1986.3342	122	1.4245	0.7303	0.9533	1.0820	8.2090	14.6950	7.9469	14.4466
+794	1986.3370	123	1.4244	0.7302	0.9533	1.0820	8.2090	14.6950	7.9355	14.4576
+795	1986.3397	124	1.4243	0.7302	0.9533	1.0820	8.2090	14.6950	7.9266	14.4678
+796	1986.3425	125	1.4242	0.7302	0.9532	1.0820	8.2090	14.6950	7.9203	14.4773
+797	1986.3452	126	1.4241	0.7302	0.9532	1.0820	8.2090	14.6950	7.9168	14.4859
+798	1986.3479	127	1.4241	0.7301	0.9532	1.0820	8.2090	14.6950	7.9159	14.4934
+799	1986.3507	128	1.4240	0.7301	0.9531	1.0820	8.2090	14.6950	7.9178	14.4998
+800	1986.3534	129	1.4239	0.7301	0.9531	1.0820	8.2090	14.6950	8.2090	14.6950
+801	1986.3562	130	1.4238	0.7300	0.9531	1.0820	8.2090	14.6950	8.1915	14.6941
+802	1986.3589	131	1.4237	0.7300	0.9530	1.0820	8.2090	14.6950	8.1724	14.6918
+803	1986.3616	132	1.4236	0.7300	0.9530	1.0820	8.2090	14.6950	8.1521	14.6880
+804	1986.3644	133	1.4236	0.7300	0.9530	1.0820	8.2090	14.6950	8.1310	14.6828
+805	1986.3671	134	1.4235	0.7299	0.9529	1.0820	8.2090	14.6950	8.1094	14.6761
+806	1986.3699	135	1.4234	0.7299	0.9529	1.0820	8.2090	14.6950	8.0878	14.6681
+807	1986.3726	136	1.4233	0.7299	0.9529	1.0820	8.2090	14.6950	8.0665	14.6587
+808	1986.3753	137	1.4232	0.7298	0.9528	1.0820	8.2090	14.6950	8.0459	14.6481
+809	1986.3781	138	1.4231	0.7298	0.9528	1.0820	8.2090	14.6950	8.0265	14.6362
+810	1986.3808	139	1.4231	0.7298	0.9528	1.0820	8.2090	14.6950	8.0084	14.6232
+811	1986.3836	140	1.4230	0.7298	0.9527	1.0820	8.2090	14.6950	7.9922	14.6092
+812	1986.3863	141	1.4229	0.7297	0.9527	1.0820	8.2090	14.6950	7.9779	14.5943
+813	1986.3890	142	1.4228	0.7297	0.9527	1.0820	8.2090	14.6950	7.9658	14.5786
+814	1986.3918	143	1.4227	0.7297	0.9526	1.0820	8.2090	14.6950	7.9563	14.5621
+815	1986.3945	144	1.4227	0.7297	0.9526	1.0820	8.2090	14.6950	7.9493	14.5451
+816	1986.3973	145	1.4226	0.7296	0.9526	1.0820	8.2090	14.6950	7.9450	14.5276
+817	1986.4000	146	1.4225	0.7296	0.9525	1.0820	8.2090	14.6950	7.9434	14.5098
+818	1986.4027	147	1.4224	0.7296	0.9525	1.0820	8.2090	14.6950	7.9447	14.4918
+819	1986.4055	148	1.4223	0.7295	0.9525	1.0820	8.2090	14.6950	7.9486	14.4737
+820	1986.4082	149	1.4222	0.7295	0.9524	1.0820	8.2090	14.6950	7.9553	14.4556
+821	1986.4110	150	1.4222	0.7295	0.9524	1.0820	8.2090	14.6950	7.9645	14.4378
+822	1986.4137	151	1.4221	0.7295	0.9524	1.0820	8.2090	14.6950	7.9760	14.4203
+823	1986.4164	152	1.4220	0.7294	0.9523	1.0820	8.2090	14.6950	7.9897	14.4032
+824	1986.4192	153	1.4219	0.7294	0.9523	1.0820	8.2090	14.6950	8.0053	14.3867
+825	1986.4219	154	1.4218	0.7294	0.9523	1.0820	8.2090	14.6950	8.0226	14.3708
+826	1986.4247	155	1.4218	0.7293	0.9522	1.0820	8.2090	14.6950	8.0412	14.3558
+827	1986.4274	156	1.4217	0.7293	0.9522	1.0820	8.2090	14.6950	8.0607	14.3416
+828	1986.4301	157	1.4216	0.7293	0.9522	1.0820	8.2090	14.6950	8.0808	14.3283
+829	1986.4329	158	1.4215	0.7293	0.9521	1.0820	8.2090	14.6950	8.1011	14.3161
+830	1986.4356	159	1.4214	0.7292	0.9521	1.0820	8.2090	14.6950	8.1213	14.3051
+831	1986.4384	160	1.4213	0.7292	0.9521	1.0820	8.2090	14.6950	8.1409	14.2952
+832	1986.4411	161	1.4213	0.7292	0.9520	1.0820	8.2090	14.6950	8.1594	14.2866
+833	1986.4438	162	1.4212	0.7291	0.9520	1.0820	8.2090	14.6950	8.1767	14.2793
+834	1986.4466	163	1.4211	0.7291	0.9520	1.0820	8.2090	14.6950	8.1922	14.2734
+835	1986.4493	164	1.4210	0.7291	0.9520	1.0820	8.2090	14.6950	8.2057	14.2688
+836	1986.4521	165	1.4209	0.7291	0.9519	1.0820	8.2090	14.6950	8.2169	14.2655
+837	1986.4548	166	1.4209	0.7290	0.9519	1.0820	8.2090	14.6950	8.2254	14.2637
+838	1986.4575	167	1.4208	0.7290	0.9519	1.0820	8.2090	14.6950	8.2313	14.2632
+839	1986.4603	168	1.4207	0.7290	0.9518	1.0820	8.2090	14.6950	8.2342	14.2641
+840	1986.4630	169	1.4206	0.7289	0.9518	1.0820	8.2090	14.6950	8.2342	14.2662
+841	1986.4658	170	1.4205	0.7289	0.9518	1.0820	8.2090	14.6950	8.2312	14.2697
+842	1986.4685	171	1.4205	0.7289	0.9517	1.0820	8.2090	14.6950	8.2253	14.2744
+843	1986.4712	172	1.4204	0.7289	0.9517	1.0820	8.2090	14.6950	8.2166	14.2803
+844	1986.4740	173	1.4203	0.7288	0.9517	1.0820	8.2090	14.6950	8.2052	14.2873
+845	1986.4767	174	1.4202	0.7288	0.9516	1.0820	8.2090	14.6950	8.1914	14.2954
+846	1986.4795	175	1.4201	0.7288	0.9516	1.0820	8.2090	14.6950	8.1754	14.3044
+847	1986.4822	176	1.4200	0.7287	0.9516	1.0820	8.2090	14.6950	8.1576	14.3142
+848	1986.4849	177	1.4200	0.7287	0.9515	1.0820	8.2090	14.6950	8.1384	14.3248
+849	1986.4877	178	1.4199	0.7287	0.9515	1.0820	8.2090	14.6950	8.1179	14.3361
+850	1986.4904	179	1.4198	0.7287	0.9515	1.0820	8.2090	14.6950	8.0968	14.3479
+851	1986.4932	180	1.4197	0.7286	0.9514	1.0820	8.2090	14.6950	8.0753	14.3601
+852	1986.4959	181	1.4196	0.7286	0.9514	1.0820	8.2090	14.6950	8.0539	14.3726
+853	1986.4986	182	1.4196	0.7286	0.9514	1.0820	8.2090	14.6950	8.0329	14.3852
+854	1986.5014	183	1.4195	0.7285	0.9513	1.0820	8.2090	14.6950	8.0127	14.3979
+855	1986.5041	184	1.4194	0.7285	0.9513	1.0820	8.2090	14.6950	7.9937	14.4105
+856	1986.5068	185	1.4193	0.7285	0.9513	1.0820	8.2090	14.6950	7.9762	14.4229
+857	1986.5096	186	1.4192	0.7285	0.9512	1.0820	8.2090	14.6950	7.9605	14.4350
+858	1986.5123	187	1.4192	0.7284	0.9512	1.0820	8.2090	14.6950	7.9469	14.4466
+859	1986.5151	188	1.4191	0.7284	0.9512	1.0820	8.2090	14.6950	7.9355	14.4576
+860	1986.5178	189	1.4190	0.7284	0.9512	1.0820	8.2090	14.6950	7.9266	14.4678
+861	1986.5205	190	1.4189	0.7284	0.9511	1.0820	8.2090	14.6950	8.2090	14.6950
+862	1986.5233	191	1.4188	0.7283	0.9511	1.0820	8.2090	14.6950	8.1915	14.6941
+863	1986.5260	192	1.4188	0.7283	0.9511	1.0820	8.2090	14.6950	8.1724	14.6918
+864	1986.5288	193	1.4187	0.7283	0.9510	1.0820	8.2090	14.6950	8.1521	14.6880
+865	1986.5315	194	1.4186	0.7282	0.9510	1.0820	8.2090	14.6950	8.1310	14.6828
+866	1986.5342	195	1.4185	0.7282	0.9510	1.0820	8.2090	14.6950	8.1094	14.6761
+867	1986.5370	196	1.4184	0.7282	0.9509	1.0820	8.2090	14.6950	8.0878	14.6681
+868	1986.5397	197	1.4184	0.7282	0.9509	1.0820	8.2090	14.6950	8.0665	14.6587
+869	1986.5425	198	1.4183	0.7281	0.9509	1.0820	8.2090	14.6950	8.0459	14.6481
+870	1986.5452	199	1.4182	0.7281	0.9508	1.0820	8.2090	14.6950	8.0265	14.6362
+871	1986.5479	200	1.4181	0.7281	0.9508	1.0820	8.2090	14.6950	8.0084	14.6232
+872	1986.5507	201	1.4180	0.7280	0.9508	1.0820	8.2090	14.6950	7.9922	14.6092
+873	1986.5534	202	1.4180	0.7280	0.9507	1.0820	8.2090	14.6950	7.9779	14.5943
+874	1986.5562	203	1.4179	0.7280	0.9507	1.0820	8.2090	14.6950	7.9658	14.5786
+875	1986.5589	204	1.4178	0.7280	0.9507	1.0820	8.2090	14.6950	7.9563	14.5621
+876	1986.5616	205	1.4177	0.7279	0.9507	1.0820	8.2090	14.6950	7.9493	14.5451
+877	1986.5644	206	1.4176	0.7279	0.9506	1.0820	8.2090	14.6950	7.9450	14.5276
+878	1986.5671	207	1.4176	0.7279	0.9506	1.0820	8.2090	14.6950	7.9434	14.5098
+879	1986.5699	208	1.4175	0.7278	0.9506	1.0820	8.2090	14.6950	7.9447	14.4918
+880	1986.5726	209	1.4174	0.7278	0.9505	1.0820	8.2090	14.6950	7.9486	14.4737
+881	1986.5753	210	1.4173	0.7278	0.9505	1.0820	8.2090	14.6950	7.9553	14.4556
+882	1986.5781	211	1.4172	0.7278	0.9505	1.0820	8.2090	14.6950	7.9645	14.4378
+883	1986.5808	212	1.4172	0.7277	0.9504	1.0820	8.2090	14.6950	7.9760	14.4203
+884	1986.5836	213	1.4171	0.7277	0.9504	1.0820	8.2090	14.6950	7.9897	14.4032
+885	1986.5863	214	1.4170	0.7277	0.9504	1.0820	8.2090	14.6950	8.0053	14.3867
+886	1986.5890	215	1.4169	0.7277	0.9503	1.0820	8.2090	14.6950	8.0226	14.3708
+887	1986.5918	216	1.4168	0.7276	0.9503	1.0820	8.2090	14.6950	8.0412	14.3558
+888	1986.5945	217	1.4168	0.7276	0.9503	1.0820	8.2090	14.6950	8.0607	14.3416
+889	1986.5973	218	1.4167	0.7276	0.9502	1.0820	8.2090	14.6950	8.0808	14.3283
+890	1986.6000	219	1.4166	0.7275	0.9502	1.0820	8.2090	14.6950	8.1011	14.3161
+891	1986.6027	220	1.4165	0.7275	0.9502	1.0820	8.2090	14.6950	8.1213	14.3051
+892	1986.6055	221	1.4164	0.7275	0.9502	1.0820	8.2090	14.6950	8.1409	14.2952
+893	1986.6082	222	1.4164	0.7275	0.9501	1.0820	8.2090	14.6950	8.1594	14.2866
+894	1986.6110	223	1.4163	0.7274	0.9501	1.0820	8.2090	14.6950	8.1767	14.2793
+895	1986.6137	224	1.4162	0.7274	0.9501	1.0820	8.2090	14.6950	8.1922	14.2734
+896	1986.6164	225	1.4161	0.7274	0.9500	1.0820	8.2090	14.6950	8.2057	14.2688
+897	1986.6192	226	1.4160	0.7273	0.9500	1.0820	8.2090	14.6950	8.2169	14.2655
+898	1986.6219	227	1.4160	0.7273	0.9500	1.0820	8.2090	14.6950	8.2254	14.2637
+899	1986.6247	228	1.4159	0.7273	0.9499	1.0820	8.2090	14.6950	8.2313	14.2632
+900	1986.6274	229	1.4158	0.7273	0.9499	1.0820	8.2090	14.6950	8.2342	14.2641
+901	1986.6301	230	1.4157	0.7272	0.9499	1.0820	8.2090	14.6950	8.2342	14.2662
+902	1986.6329	231	1.4156	0.7272	0.9498	1.0820	8.2090	14.6950	8.2312	14.2697
+903	1986.6356	232	1.4156	0.7272	0.9498	1.0820	8.2090	14.6950	8.2253	14.2744
+904	1986.6384	233	1.4155	0.7272	0.9498	1.0820	8.2090	14.6950	8.2166	14.2803
+905	1986.6411	234	1.4154	0.7271	0.9498	1.0820	8.2090	14.6950	8.2052	14.2873
+906	1986.6438	235	1.4153	0.7271	0.9497	1.0820	8.2090	14.6950	8.1914	14.2954
+907	1986.6466	236	1.4153	0.7271	0.9497	1.0820	8.2090	14.6950	8.1754	14.3044
+908	1986.6493	237	1.4152	0.7270	0.9497	1.0820	8.2090	14.6950	8.1576	14.3142
+909	1986.6521	238	1.4151	0.7270	0.9496	1.0820	8.2090	14.6950	8.1384	14.3248
+910	1986.6548	239	1.4150	0.7270	0.9496	1.0820	8.2090	14.6950	8.1179	14.3361
+911	1986.6575	240	1.4149	0.7270	0.9496	1.0820	8.2090	14.6950	8.0968	14.3479
+912	1986.6603	241	1.4149	0.7269	0.9495	1.0820	8.2090	14.6950	8.0753	14.3601
+913	1986.6630	242	1.4148	0.7269	0.9495	1.0820	8.2090	14.6950	8.0539	14.3726
+914	1986.6658	243	1.4147	0.7269	0.9495	1.0820	8.2090	14.6950	8.0329	14.3852
+915	1986.6685	244	1.4146	0.7269	0.9494	1.0820	8.2090	14.6950	8.0127	14.3979
+916	1986.6712	245	1.4145	0.7268	0.9494	1.0820	8.2090	14.6950	7.9937	14.4105
+917	1986.6740	246	1.4145	0.7268	0.9494	1.0820	8.2090	14.6950	7.9762	14.4229
+918	1986.6767	247	1.4144	0.7268	0.9494	1.0820	8.2090	14.6950	7.9605	14.4350
+919	1986.6795	248	1.4143	0.7267	0.9493	1.0820	8.2090	14.6950	8.2090	14.6950
+920	1986.6822	249	1.4142	0.7267	0.9493	1.0820	8.2090	14.6950	8.1915	14.6941
+921	1986.6849	250	1.4141	0.7267	0.9493	1.0820	8.2090	14.6950	8.1724	14.6918
+922	1986.6877	251	1.4141	0.7267	0.9492	1.0820	8.2090	14.6950	8.1521	14.6880
+923	1986.6904	252	1.4140	0.7266	0.9492	1.0820	8.2090	14.6950	8.1310	14.6828
+924	1986.6932	253	1.4139	0.7266	0.9492	1.0820	8.2090	14.6950	8.1094	14.6761
+925	1986.6959	254	1.4138	0.7266	0.9491	1.0820	8.2090	14.6950	8.0878	14.6681
+926	1986.6986	255	1.4138	0.7265	0.9491	1.0820	8.2090	14.6950	8.0665	14.6587
+927	1986.7014	256	1.4137	0.7265	0.9491	1.0820	8.2090	14.6950	8.0459	14.6481
+928	1986.7041	257	1.4136	0.7265	0.9491	1.0820	8.2090	14.6950	8.0265	14.6362
+929	1986.7068	258	1.4135	0.7265	0.9490	1.0820	8.2090	14.6950	8.0084	14.6232
+930	1986.7096	259	1.4134	0.7264	0.9490	1.0820	8.2090	14.6950	7.9922	14.6092
+931	1986.7123	260	1.4134	0.7264	0.9490	1.0820	8.2090	14.6950	7.9779	14.5943
+932	1986.7151	261	1.4133	0.7264	0.9489	1.0820	8.2090	14.6950	7.9658	14.5786
+933	1986.7178	262	1.4132	0.7264	0.9489	1.0820	8.2090	14.6950	7.9563	14.5621
+934	1986.7205	263	1.4131	0.7263	0.9489	1.0820	8.2090	14.6950	7.9493	14.5451
+935	1986.7233	264	1.4130	0.7263	0.9488	1.0820	8.2090	14.6950	7.9450	14.5276
+936	1986.7260	265	1.4130	0.7263	0.9488	1.0820	8.2090	14.6950	7.9434	14.5098
+937	1986.7288	266	1.4129	0.7262	0.9488	1.0820	8.2090	14.6950	7.9447	14.4918
+938	1986.7315	267	1.4128	0.7262	0.9488	1.0820	8.2090	14.6950	7.9486	14.4737
+939	1986.7342	268	1.4127	0.7262	0.9487	1.0820	8.2090	14.6950	7.9553	14.4556
+940	1986.7370	269	1.4127	0.7262	0.9487	1.0820	8.2090	14.6950	7.9645	14.4378
+941	1986.7397	270	1.4126	0.7261	0.9487	1.0820	8.2090	14.6950	7.9760	14.4203
+942	1986.7425	271	1.4125	0.7261	0.9486	1.0820	8.2090	14.6950	7.9897	14.4032
+943	1986.7452	272	1.4124	0.7261	0.9486	1.0820	8.2090	14.6950	8.0053	14.3867
+944	1986.7479	273	1.4123	0.7261	0.9486	1.0820	8.2090	14.6950	8.0226	14.3708
+945	1986.7507	274	1.4123	0.7260	0.9485	1.0820	8.2090	14.6950	8.0412	14.3558
+946	1986.7534	275	1.4122	0.7260	0.9485	1.0820	8.2090	14.6950	8.0607	14.3416
+947	1986.7562	276	1.4121	0.7260	0.9485	1.0820	8.2090	14.6950	8.0808	14.3283
+948	1986.7589	277	1.4120	0.7259	0.9485	1.0820	8.2090	14.6950	8.1011	14.3161
+949	1986.7616	278	1.4120	0.7259	0.9484	1.0820	8.2090	14.6950	8.1213	14.3051
+950	1986.7644	279	1.4119	0.7259	0.9484	1.0820	8.2090	14.6950	8.1409	14.2952
+951	1986.7671	280	1.4118	0.7259	0.9484	1.0820	8.2090	14.6950	8.1594	14.2866
+952	1986.7699	281	1.4117	0.7258	0.9483	1.0820	8.2090	14.6950	8.1767	14.2793
+953	1986.7726	282	1.4116	0.7258	0.9483	1.0820	8.2090	14.6950	8.1922	14.2734
+954	1986.7753	283	1.4116	0.7258	0.9483	1.0820	8.2090	14.6950	8.2057	14.2688
+955	1986.7781	284	1.4115	0.7258	0.9482	1.0820	8.2090	14.6950	8.2169	14.2655
+956	1986.7808	285	1.4114	0.7257	0.9482	1.0820	8.2090	14.6950	8.2254	14.2637
+957	1986.7836	286	1.4113	0.7257	0.9482	1.0820	8.2090	14.6950	8.2313	14.2632
+958	1986.7863	287	1.4113	0.7257	0.9482	1.0820	8.2090	14.6950	8.2342	14.2641
+959	1986.7890	288	1.4112	0.7256	0.9481	1.0820	8.2090	14.6950	8.2342	14.2662
+960	1986.7918	289	1.4111	0.7256	0.9481	1.0820	8.2090	14.6950	8.2312	14.2697
+961	1986.7945	290	1.4110	0.7256	0.9481	1.0820	8.2090	14.6950	8.2253	14.2744
+962	1986.7973	291	1.4109	0.7256	0.9480	1.0820	8.2090	14.6950	8.2166	14.2803
+963	1986.8000	292	1.4109	0.7255	0.9480	1.0820	8.2090	14.6950	8.2052	14.2873
+964	1986.8027	293	1.4108	0.7255	0.9480	1.0820	8.2090	14.6950	8.1914	14.2954
+965	1986.8055	294	1.4107	0.7255	0.9479	1.0820	8.2090	14.6950	8.1754	14.3044
+966	1986.8082	295	1.4106	0.7255	0.9479	1.0820	8.2090	14.6950	8.1576	14.3142
+967	1986.8110	296	1.4106	0.7254	0.9479	1.0820	8.2090	14.6950	8.1384	14.3248
+968	1986.8137	297	1.4105	0.7254	0.9479	1.0820	8.2090	14.6950	8.1179	14.3361
+969	1986.8164	298	1.4104	0.7254	0.9478	1.0820	8.2090	14.6950	8.0968	14.3479
+970	1986.8192	299	1.4103	0.7253	0.9478	1.0820	8.2090	14.6950	8.0753	14.3601
+971	1986.8219	300	1.4103	0.7253	0.9478	1.0820	8.2090	14.6950	8.0539	14.3726
+972	1986.8247	301	1.4102	0.7253	0.9477	1.0820	8.2090	14.6950	8.0329	14.3852
+973	1986.8274	302	1.4101	0.7253	0.9477	1.0820	8.2090	14.6950	8.0127	14.3979
+974	1986.8301	303	1.4100	0.7252	0.9477	1.0820	8.2090	14.6950	7.9937	14.4105
+975	1986.8329	304	1.4099	0.7252	0.9477	1.0820	8.2090	14.6950	7.9762	14.4229
+976	1986.8356	305	1.4099	0.7252	0.9476	1.0820	8.2090	14.6950	7.9605	14.4350
+977	1986.8384	306	1.4098	0.7252	0.9476	1.0820	8.2090	14.6950	7.9469	14.4466
+978	1986.8411	307	1.4097	0.7251	0.9476	1.0820	8.2090	14.6950	7.9355	14.4576
+979	1986.8438	308	1.4096	0.7251	0.9475	1.0820	8.2090	14.6950	7.9266	14.4678
+980	1986.8466	309	1.4096	0.7251	0.9475	1.0820	8.2090	14.6950	7.9203	14.4773
+981	1986.8493	310	1.4095	0.7250	0.9475	1.0820	8.2090	14.6950	7.9168	14.4859
+982	1986.8521	311	1.4094	0.7250	0.9474	1.0820	8.2090	14.6950	7.9159	14.4934
+983	1986.8548	312	1.4093	0.7250	0.9474	1.0820	8.2090	14.6950	7.9178	14.4998
+984	1986.8575	313	1.4093	0.7250	0.9474	1.0820	8.2090	14.6950	7.9224	14.5050
+985	1986.8603	314	1.4092	0.7249	0.9474	1.0820	8.2090	14.6950	7.9297	14.5089
+986	1986.8630	315	1.4091	0.7249	0.9473	1.0820	8.2090	14.6950	7.9394	14.5116
+987	1986.8658	316	1.4090	0.7249	0.9473	1.0820	8.2090	14.6950	7.9514	14.5129
+988	1986.8685	317	1.4089	0.7249	0.9473	1.0820	8.2090	14.6950	7.9655	14.5128
+989	1986.8712	318	1.4089	0.7248	0.9472	1.0820	8.2090	14.6950	7.9815	14.5112
+990	1986.8740	319	1.4088	0.7248	0.9472	1.0820	8.2090	14.6950	7.9990	14.5083
+991	1986.8767	320	1.4087	0.7248	0.9472	1.0820	8.2090	14.6950	8.0177	14.5039
+992	1986.8795	321	1.4086	0.7248	0.9472	1.0820	8.2090	14.6950	8.0372	14.4981
+993	1986.8822	322	1.4086	0.7247	0.9471	1.0820	8.2090	14.6950	8.0573	14.4910
+994	1986.8849	323	1.4085	0.7247	0.9471	1.0820	8.2090	14.6950	8.0775	14.4825
+995	1986.8877	324	1.4084	0.7247	0.9471	1.0820	8.2090	14.6950	8.2090	14.6950
+996	1986.8904	325	1.4083	0.7246	0.9470	1.0820	8.2090	14.6950	8.1915	14.6941
+997	1986.8932	326	1.4083	0.7246	0.9470	1.0820	8.2090	14.6950	8.1724	14.6918
+998	1986.8959	327	1.4082	0.7246	0.9470	1.0820	8.2090	14.6950	8.1521	14.6880
+999	1986.8986	328	1.4081	0.7246	0.9470	1.0820	8.2090	14.6950	8.1310	14.6828
+1000	1986.9014	329	1.4080	0.7245	0.9469	1.0820	8.2090	14.6950	8.1094	14.6761
+1001	1986.9041	330	1.4080	0.7245	0.9469	1.0820	8.2090	14.6950	8.0878	14.6681
+1002	1986.9068	331	1.4079	0.7245	0.9469	1.0820	8.2090	14.6950	8.0665	14.6587
+1003	1986.9096	332	1.4078	0.7245	0.9468	1.0820	8.2090	14.6950	8.0459	14.6481
+1004	1986.9123	333	1.4077	0.7244	0.9468	1.0820	8.2090	14.6950	8.0265	14.6362
+1005	1986.9151	334	1.4076	0.7244	0.9468	1.0820	8.2090	14.6950	8.0084	14.6232
+1006	1986.9178	335	1.4076	0.7244	0.9468	1.0820	8.2090	14.6950	7.9922	14.6092
+1007	1986.9205	336	1.4075	0.7243	0.9467	1.0820	8.2090	14.6950	7.9779	14.5943
+1008	1986.9233	337	1.4074	0.7243	0.9467	1.0820	8.2090	14.6950	7.9658	14.5786
+1009	1986.9260	338	1.4073	0.7243	0.9467	1.0820	8.2090	14.6950	7.9563	14.5621
+1010	1986.9288	339	1.4073	0.7243	0.9466	1.0820	8.2090	14.6950	7.9493	14.5451
+1011	1986.9315	340	1.4072	0.7242	0.9466	1.0820	8.2090	14.6950	7.9450	14.5276
+1012	1986.9342	341	1.4071	0.7242	0.9466	1.0820	8.2090	14.6950	7.9434	14.5098
+1013	1986.9370	342	1.4070	0.7242	0.9466	1.0820	8.2090	14.6950	7.9447	14.4918
+1014	1986.9397	343	1.4070	0.7242	0.9465	1.0820	8.2090	14.6950	7.9486	14.4737
+1015	1986.9425	344	1.4069	0.7241	0.9465	1.0820	8.2090	14.6950	7.9553	14.4556
+1016	1986.9452	345	1.4068	0.7241	0.9465	1.0820	8.2090	14.6950	7.9645	14.4378
+1017	1986.9479	346	1.4067	0.7241	0.9464	1.0820	8.2090	14.6950	7.9760	14.4203
+1018	1986.9507	347	1.4067	0.7241	0.9464	1.0820	8.2090	14.6950	7.9897	14.4032
+1019	1986.9534	348	1.4066	0.7240	0.9464	1.0820	8.2090	14.6950	8.0053	14.3867
+1020	1986.9562	349	1.4065	0.7240	0.9464	1.0820	8.2090	14.6950	8.0226	14.3708
+1021	1986.9589	350	1.4064	0.7240	0.9463	1.0820	8.2090	14.6950	8.0412	14.3558
+1022	1986.9616	351	1.4064	0.7239	0.9463	1.0820	8.2090	14.6950	8.0607	14.3416
+1023	1986.9644	352	1.4063	0.7239	0.9463	1.0820	8.2090	14.6950	8.0808	14.3283
+1024	1986.9671	353	1.4062	0.7239	0.9462	1.0820	8.2090	14.6950	8.1011	14.3161
+1025	1986.9699	354	1.4061	0.7239	0.9462	1.0820	8.2090	14.6950	8.1213	14.3051
+1026	1986.9726	355	1.4061	0.7238	0.9462	1.0820	8.2090	14.6950	8.1409	14.2952
+1027	1986.9753	356	1.4060	0.7238	0.9462	1.0820	8.2090	14.6950	8.1594	14.2866
+1028	1986.9781	357	1.4059	0.7238	0.9461	1.0820	8.2090	14.6950	8.1767	14.2793
+1029	1986.9808	358	1.4058	0.7238	0.9461	1.0820	8.2090	14.6950	8.1922	14.2734
+1030	1986.9836	359	1.4058	0.7237	0.9461	1.0820	8.2090	14.6950	8.2057	14.2688
+1031	1986.9863	360	1.4057	0.7237	0.9460	1.0820	8.2090	14.6950	8.2169	14.2655
+1032	1986.9890	361	1.4056	0.7237	0.9460	1.0820	8.2090	14.6950	8.2254	14.2637
+1033	1986.9918	362	1.4055	0.7237	0.9460	1.0820	8.2090	14.6950	8.2313	14.2632
+1034	1986.9945	363	1.4055	0.7236	0.9460	1.0820	8.2090	14.6950	8.2342	14.2641
+1035	1986.9973	364	1.4054	0.7236	0.9459	1.0820	8.2090	14.6950	8.2342	14.2662
+1036	1986.9999	365	1.4053	0.7236	0.9459	1.0820	8.2090	14.6950	8.2312	14.2697
+1037	1987.0027	1	1.4052	0.7235	0.9459	1.0820	8.2090	14.6950	8.2253	14.2744
+1038	1987.0055	2	1.4052	0.7235	0.9458	1.0820	8.2090	14.6950	8.2166	14.2803
+1039	1987.0082	3	1.4051	0.7235	0.9458	1.0820	8.2090	14.6950	8.2052	14.2873
+1040	1987.0110	4	1.4050	0.7235	0.9458	1.0820	8.2090	14.6950	8.1914	14.2954
+1041	1987.0137	5	1.4049	0.7234	0.9458	1.0820	8.2090	14.6950	8.1754	14.3044
+1042	1987.0164	6	1.4049	0.7234	0.9457	1.0820	8.2090	14.6950	8.1576	14.3142
+1043	1987.0192	7	1.4048	0.7234	0.9457	1.0820	8.2090	14.6950	8.1384	14.3248
+1044	1987.0219	8	1.4047	0.7234	0.9457	1.0820	8.2090	14.6950	8.1179	14.3361
+1045	1987.0247	9	1.4046	0.7233	0.9456	1.0820	8.2090	14.6950	8.0968	14.3479
+1046	1987.0274	10	1.4046	0.7233	0.9456	1.0820	8.2090	14.6950	8.0753	14.3601
+1047	1987.0301	11	1.4045	0.7233	0.9456	1.0820	8.2090	14.6950	8.0539	14.3726
+1048	1987.0329	12	1.4044	0.7233	0.9456	1.0820	8.2090	14.6950	8.0329	14.3852
+1049	1987.0356	13	1.4043	0.7232	0.9455	1.0820	8.2090	14.6950	8.0127	14.3979
+1050	1987.0384	14	1.4042	0.7232	0.9455	1.0820	8.2090	14.6950	7.9937	14.4105
+1051	1987.0411	15	1.4042	0.7232	0.9455	1.0820	8.2090	14.6950	7.9762	14.4229
+1052	1987.0438	16	1.4041	0.7231	0.9455	1.0820	8.2090	14.6950	7.9605	14.4350
+1053	1987.0466	17	1.4040	0.7231	0.9454	1.0820	8.2090	14.6950	7.9469	14.4466
+1054	1987.0493	18	1.4040	0.7231	0.9454	1.0820	8.2090	14.6950	7.9355	14.4576
+1055	1987.0521	19	1.4039	0.7231	0.9454	1.0820	8.2090	14.6950	7.9266	14.4678
+1056	1987.0548	20	1.4038	0.7230	0.9453	1.0820	8.2090	14.6950	7.9203	14.4773
+1057	1987.0575	21	1.4037	0.7230	0.9453	1.0820	8.2090	14.6950	7.9168	14.4859
+1058	1987.0603	22	1.4037	0.7230	0.9453	1.0820	8.2090	14.6950	7.9159	14.4934
+1059	1987.0630	23	1.4036	0.7230	0.9453	1.0820	8.2090	14.6950	7.9178	14.4998
+1060	1987.0658	24	1.4035	0.7229	0.9452	1.0820	8.2090	14.6950	7.9224	14.5050
+1061	1987.0685	25	1.4034	0.7229	0.9452	1.0820	8.2090	14.6950	7.9297	14.5089
+1062	1987.0712	26	1.4034	0.7229	0.9452	1.0820	8.2090	14.6950	7.9394	14.5116
+1063	1987.0740	27	1.4033	0.7229	0.9451	1.0820	8.2090	14.6950	7.9514	14.5129
+1064	1987.0767	28	1.4032	0.7228	0.9451	1.0820	8.2090	14.6950	8.2090	14.6950
+1065	1987.0795	29	1.4031	0.7228	0.9451	1.0820	8.2090	14.6950	8.1915	14.6941
+1066	1987.0822	30	1.4031	0.7228	0.9451	1.0820	8.2090	14.6950	8.1724	14.6918
+1067	1987.0849	31	1.4030	0.7227	0.9450	1.0820	8.2090	14.6950	8.1521	14.6880
+1068	1987.0877	32	1.4029	0.7227	0.9450	1.0820	8.2090	14.6950	8.1310	14.6828
+1069	1987.0904	33	1.4028	0.7227	0.9450	1.0820	8.2090	14.6950	8.1094	14.6761
+1070	1987.0932	34	1.4028	0.7227	0.9450	1.0820	8.2090	14.6950	8.0878	14.6681
+1071	1987.0959	35	1.4027	0.7226	0.9449	1.0820	8.2090	14.6950	8.0665	14.6587
+1072	1987.0986	36	1.4026	0.7226	0.9449	1.0820	8.2090	14.6950	8.0459	14.6481
+1073	1987.1014	37	1.4025	0.7226	0.9449	1.0820	8.2090	14.6950	8.0265	14.6362
+1074	1987.1041	38	1.4025	0.7226	0.9448	1.0820	8.2090	14.6950	8.0084	14.6232
+1075	1987.1068	39	1.4024	0.7225	0.9448	1.0820	8.2090	14.6950	7.9922	14.6092
+1076	1987.1096	40	1.4023	0.7225	0.9448	1.0820	8.2090	14.6950	7.9779	14.5943
+1077	1987.1123	41	1.4022	0.7225	0.9448	1.0820	8.2090	14.6950	7.9658	14.5786
+1078	1987.1151	42	1.4022	0.7225	0.9447	1.0820	8.2090	14.6950	7.9563	14.5621
+1079	1987.1178	43	1.4021	0.7224	0.9447	1.0820	8.2090	14.6950	7.9493	14.5451
+1080	1987.1205	44	1.4020	0.7224	0.9447	1.0820	8.2090	14.6950	7.9450	14.5276
+1081	1987.1233	45	1.4019	0.7224	0.9446	1.0820	8.2090	14.6950	7.9434	14.5098
+1082	1987.1260	46	1.4019	0.7224	0.9446	1.0820	8.2090	14.6950	7.9447	14.4918
+1083	1987.1288	47	1.4018	0.7223	0.9446	1.0820	8.2090	14.6950	7.9486	14.4737
+1084	1987.1315	48	1.4017	0.7223	0.9446	1.0820	8.2090	14.6950	7.9553	14.4556
+1085	1987.1342	49	1.4017	0.7223	0.9445	1.0820	8.2090	14.6950	7.9645	14.4378
+1086	1987.1370	50	1.4016	0.7222	0.9445	1.0820	8.2090	14.6950	7.9760	14.4203
+1087	1987.1397	51	1.4015	0.7222	0.9445	1.0820	8.2090	14.6950	7.9897	14.4032
+1088	1987.1425	52	1.4014	0.7222	0.9445	1.0820	8.2090	14.6950	8.0053	14.3867
+1089	1987.1452	53	1.4014	0.7222	0.9444	1.0820	8.2090	14.6950	8.0226	14.3708
+1090	1987.1479	54	1.4013	0.7221	0.9444	1.0820	8.2090	14.6950	8.0412	14.3558
+1091	1987.1507	55	1.4012	0.7221	0.9444	1.0820	8.2090	14.6950	8.0607	14.3416
+1092	1987.1534	56	1.4011	0.7221	0.9444	1.0820	8.2090	14.6950	8.0808	14.3283
+1093	1987.1562	57	1.4011	0.7221	0.9443	1.0820	8.2090	14.6950	8.1011	14.3161
+1094	1987.1589	58	1.4010	0.7220	0.9443	1.0820	8.2090	14.6950	8.1213	14.3051
+1095	1987.1616	59	1.4009	0.7220	0.9443	1.0820	8.2090	14.6950	8.1409	14.2952
+1096	1987.1644	60	1.4008	0.7220	0.9442	1.0820	8.2090	14.6950	8.1594	14.2866
+1097	1987.1671	61	1.4008	0.7220	0.9442	1.0820	8.2090	14.6950	8.1767	14.2793
+1098	1987.1699	62	1.4007	0.7219	0.9442	1.0820	8.2090	14.6950	8.1922	14.2734
+1099	1987.1726	63	1.4006	0.7219	0.9442	1.0820	8.2090	14.6950	8.2057	14.2688
+1100	1987.1753	64	1.4005	0.7219	0.9441	1.0820	8.2090	14.6950	8.2169	14.2655
+1101	1987.1781	65	1.4005	0.7219	0.9441	1.0820	8.2090	14.6950	8.2254	14.2637
+1102	1987.1808	66	1.4004	0.7218	0.9441	1.0820	8.2090	14.6950	8.2313	14.2632
+1103	1987.1836	67	1.4003	0.7218	0.9441	1.0820	8.2090	14.6950	8.2342	14.2641
+1104	1987.1863	68	1.4003	0.7218	0.9440	1.0820	8.2090	14.6950	8.2342	14.2662
+1105	1987.1890	69	1.4002	0.7218	0.9440	1.0820	8.2090	14.6950	8.2312	14.2697
+1106	1987.1918	70	1.4001	0.7217	0.9440	1.0820	8.2090	14.6950	8.2253	14.2744
+1107	1987.1945	71	1.4000	0.7217	0.9439	1.0820	8.2090	14.6950	8.2166	14.2803
+1108	1987.1973	72	1.4000	0.7217	0.9439	1.0820	8.2090	14.6950	8.2052	14.2873
+1109	1987.2000	73	1.3999	0.7216	0.9439	1.0820	8.2090	14.6950	8.1914	14.2954
+1110	1987.2027	74	1.3998	0.7216	0.9439	1.0820	8.2090	14.6950	8.1754	14.3044
+1111	1987.2055	75	1.3997	0.7216	0.9438	1.0820	8.2090	14.6950	8.1576	14.3142
+1112	1987.2082	76	1.3997	0.7216	0.9438	1.0820	8.2090	14.6950	8.1384	14.3248
+1113	1987.2110	77	1.3996	0.7215	0.9438	1.0820	8.2090	14.6950	8.1179	14.3361
+1114	1987.2137	78	1.3995	0.7215	0.9438	1.0820	8.2090	14.6950	8.0968	14.3479
+1115	1987.2164	79	1.3994	0.7215	0.9437	1.0820	8.2090	14.6950	8.0753	14.3601
+1116	1987.2192	80	1.3994	0.7215	0.9437	1.0820	8.2090	14.6950	8.0539	14.3726
+1117	1987.2219	81	1.3993	0.7214	0.9437	1.0820	8.2090	14.6950	8.0329	14.3852
+1118	1987.2247	82	1.3992	0.7214	0.9436	1.0820	8.2090	14.6950	8.0127	14.3979
+1119	1987.2274	83	1.3992	0.7214	0.9436	1.0820	8.2090	14.6950	7.9937	14.4105
+1120	1987.2301	84	1.3991	0.7214	0.9436	1.0820	8.2090	14.6950	7.9762	14.4229
+1121	1987.2329	85	1.3990	0.7213	0.9436	1.0820	8.2090	14.6950	7.9605	14.4350
+1122	1987.2356	86	1.3989	0.7213	0.9435	1.0820	8.2090	14.6950	7.9469	14.4466
+1123	1987.2384	87	1.3989	0.7213	0.9435	1.0820	8.2090	14.6950	7.9355	14.4576
+1124	1987.2411	88	1.3988	0.7213	0.9435	1.0820	8.2090	14.6950	7.9266	14.4678
+1125	1987.2438	89	1.3987	0.7212	0.9435	1.0820	8.2090	14.6950	7.9203	14.4773
+1126	1987.2466	90	1.3986	0.7212	0.9434	1.0820	8.2090	14.6950	7.9168	14.4859
+1127	1987.2493	91	1.3986	0.7212	0.9434	1.0820	8.2090	14.6950	7.9159	14.4934
+1128	1987.2521	92	1.3985	0.7212	0.9434	1.0820	8.2090	14.6950	7.9178	14.4998
+1129	1987.2548	93	1.3984	0.7211	0.9434	1.0820	8.2090	14.6950	7.9224	14.5050
+1130	1987.2575	94	1.3984	0.7211	0.9433	1.0820	8.2090	14.6950	7.9297	14.5089
+1131	1987.2603	95	1.3983	0.7211	0.9433	1.0820	8.2090	14.6950	7.9394	14.5116
+1132	1987.2630	96	1.3982	0.7210	0.9433	1.0820	8.2090	14.6950	7.9514	14.5129
+1133	1987.2658	97	1.3981	0.7210	0.9433	1.0820	8.2090	14.6950	7.9655	14.5128
+1134	1987.2685	98	1.3981	0.7210	0.9432	1.0820	8.2090	14.6950	7.9815	14.5112
+1135	1987.2712	99	1.3980	0.7210	0.9432	1.0820	8.2090	14.6950	7.9990	14.5083
+1136	1987.2740	100	1.3979	0.7209	0.9432	1.0820	8.2090	14.6950	8.0177	14.5039
+1137	1987.2767	101	1.3978	0.7209	0.9431	1.0820	8.2090	14.6950	8.0372	14.4981
+1138	1987.2795	102	1.3978	0.7209	0.9431	1.0820	8.2090	14.6950	8.0573	14.4910
+1139	1987.2822	103	1.3977	0.7209	0.9431	1.0820	8.2090	14.6950	8.0775	14.4825
+1140	1987.2849	104	1.3976	0.7208	0.9431	1.0820	8.2090	14.6950	8.0974	14.4727
+1141	1987.2877	105	1.3976	0.7208	0.9430	1.0820	8.2090	14.6950	8.2090	14.6950
+1142	1987.2904	106	1.3975	0.7208	0.9430	1.0820	8.2090	14.6950	8.1915	14.6941
+1143	1987.2932	107	1.3974	0.7208	0.9430	1.0820	8.2090	14.6950	8.1724	14.6918
+1144	1987.2959	108	1.3973	0.7207	0.9430	1.0820	8.2090	14.6950	8.1521	14.6880
+1145	1987.2986	109	1.3973	0.7207	0.9429	1.0820	8.2090	14.6950	8.1310	14.6828
+1146	1987.3014	110	1.3972	0.7207	0.9429	1.0820	8.2090	14.6950	8.1094	14.6761
+1147	1987.3041	111	1.3971	0.7207	0.9429	1.0820	8.2090	14.6950	8.0878	14.6681
+1148	1987.3068	112	1.3971	0.7206	0.9429	1.0820	8.2090	14.6950	8.0665	14.6587
+1149	1987.3096	113	1.3970	0.7206	0.9428	1.0820	8.2090	14.6950	8.0459	14.6481
+1150	1987.3123	114	1.3969	0.7206	0.9428	1.0820	8.2090	14.6950	8.0265	14.6362
+1151	1987.3151	115	1.3968	0.7206	0.9428	1.0820	8.2090	14.6950	8.0084	14.6232
+1152	1987.3178	116	1.3968	0.7205	0.9428	1.0820	8.2090	14.6950	7.9922	14.6092
+1153	1987.3205	117	1.3967	0.7205	0.9427	1.0820	8.2090	14.6950	7.9779	14.5943
+1154	1987.3233	118	1.3966	0.7205	0.9427	1.0820	8.2090	14.6950	7.9658	14.5786
+1155	1987.3260	119	1.3965	0.7205	0.9427	1.0820	8.2090	14.6950	7.9563	14.5621
+1156	1987.3288	120	1.3965	0.7204	0.9426	1.0820	8.2090	14.6950	7.9493	14.5451
+1157	1987.3315	121	1.3964	0.7204	0.9426	1.0820	8.2090	14.6950	7.9450	14.5276
+1158	1987.3342	122	1.3963	0.7204	0.9426	1.0820	8.2090	14.6950	7.9434	14.5098
+1159	1987.3370	123	1.3963	0.7204	0.9426	1.0820	8.2090	14.6950	7.9447	14.4918
+1160	1987.3397	124	1.3962	0.7203	0.9425	1.0820	8.2090	14.6950	7.9486	14.4737
+1161	1987.3425	125	1.3961	0.7203	0.9425	1.0820	8.2090	14.6950	7.9553	14.4556
+1162	1987.3452	126	1.3960	0.7203	0.9425	1.0820	8.2090	14.6950	7.9645	14.4378
+1163	1987.3479	127	1.3960	0.7202	0.9425	1.0820	8.2090	14.6950	7.9760	14.4203
+1164	1987.3507	128	1.3959	0.7202	0.9424	1.0820	8.2090	14.6950	7.9897	14.4032
+1165	1987.3534	129	1.3958	0.7202	0.9424	1.0820	8.2090	14.6950	8.0053	14.3867
+1166	1987.3562	130	1.3958	0.7202	0.9424	1.0820	8.2090	14.6950	8.0226	14.3708
+1167	1987.3589	131	1.3957	0.7201	0.9424	1.0820	8.2090	14.6950	8.0412	14.3558
+1168	1987.3616	132	1.3956	0.7201	0.9423	1.0820	8.2090	14.6950	8.0607	14.3416
+1169	1987.3644	133	1.3955	0.7201	0.9423	1.0820	8.2090	14.6950	8.0808	14.3283
+1170	1987.3671	134	1.3955	0.7201	0.9423	1.0820	8.2090	14.6950	8.1011	14.3161
+1171	1987.3699	135	1.3954	0.7200	0.9423	1.0820	8.2090	14.6950	8.1213	14.3051
+1172	1987.3726	136	1.3953	0.7200	0.9422	1.0820	8.2090	14.6950	8.1409	14.2952
+1173	1987.3753	137	1.3953	0.7200	0.9422	1.0820	8.2090	14.6950	8.1594	14.2866
+1174	1987.3781	138	1.3952	0.7200	0.9422	1.0820	8.2090	14.6950	8.1767	14.2793
+1175	1987.3808	139	1.3951	0.7199	0.9422	1.0820	8.2090	14.6950	8.1922	14.2734
+1176	1987.3836	140	1.3950	0.7199	0.9421	1.0820	8.2090	14.6950	8.2057	14.2688
+1177	1987.3863	141	1.3950	0.7199	0.9421	1.0820	8.2090	14.6950	8.2169	14.2655
+1178	1987.3890	142	1.3949	0.7199	0.9421	1.0820	8.2090	14.6950	8.2254	14.2637
+1179	1987.3918	143	1.3948	0.7198	0.9421	1.0820	8.2090	14.6950	8.2313	14.2632
+1180	1987.3945	144	1.3948	0.7198	0.9420	1.0820	8.2090	14.6950	8.2342	14.2641
+1181	1987.3973	145	1.3947	0.7198	0.9420	1.0820	8.2090	14.6950	8.2342	14.2662
+1182	1987.4000	146	1.3946	0.7198	0.9420	1.0820	8.2090	14.6950	8.2312	14.2697
+1183	1987.4027	147	1.3945	0.7197	0.9420	1.0820	8.2090	14.6950	8.2253	14.2744
+1184	1987.4055	148	1.3945	0.7197	0.9419	1.0820	8.2090	14.6950	8.2166	14.2803
+1185	1987.4082	149	1.3944	0.7197	0.9419	1.0820	8.2090	14.6950	8.2052	14.2873
+1186	1987.4110	150	1.3943	0.7197	0.9419	1.0820	8.2090	14.6950	8.1914	14.2954
+1187	1987.4137	151	1.3943	0.7196	0.9418	1.0820	8.2090	14.6950	8.1754	14.3044
+1188	1987.4164	152	1.3942	0.7196	0.9418	1.0820	8.2090	14.6950	8.1576	14.3142
+1189	1987.4192	153	1.3941	0.7196	0.9418	1.0820	8.2090	14.6950	8.1384	14.3248
+1190	1987.4219	154	1.3941	0.7196	0.9418	1.0820	8.2090	14.6950	8.1179	14.3361
+1191	1987.4247	155	1.3940	0.7195	0.9417	1.0820	8.2090	14.6950	8.0968	14.3479
+1192	1987.4274	156	1.3939	0.7195	0.9417	1.0820	8.2090	14.6950	8.0753	14.3601
+1193	1987.4301	157	1.3938	0.7195	0.9417	1.0820	8.2090	14.6950	8.0539	14.3726
+1194	1987.4329	158	1.3938	0.7195	0.9417	1.0820	8.2090	14.6950	8.0329	14.3852
+1195	1987.4356	159	1.3937	0.7194	0.9416	1.0820	8.2090	14.6950	8.0127	14.3979
+1196	1987.4384	160	1.3936	0.7194	0.9416	1.0820	8.2090	14.6950	7.9937	14.4105
+1197	1987.4411	161	1.3936	0.7194	0.9416	1.0820	8.2090	14.6950	7.9762	14.4229
+1198	1987.4438	162	1.3935	0.7194	0.9416	1.0820	8.2090	14.6950	7.9605	14.4350
+1199	1987.4466	163	1.3934	0.7193	0.9415	1.0820	8.2090	14.6950	7.9469	14.4466
+1200	1987.4493	164	1.3933	0.7193	0.9415	1.0820	8.2090	14.6950	7.9355	14.4576
+1201	1987.4521	165	1.3933	0.7193	0.9415	1.0820	8.2090	14.6950	7.9266	14.4678
+1202	1987.4548	166	1.3932	0.7193	0.9415	1.0820	8.2090	14.6950	7.9203	14.4773
+1203	1987.4575	167	1.3931	0.7192	0.9414	1.0820	8.2090	14.6950	7.9168	14.4859
+1204	1987.4603	168	1.3931	0.7192	0.9414	1.0820	8.2090	14.6950	7.9159	14.4934
+1205	1987.4630	169	1.3930	0.7192	0.9414	1.0820	8.2090	14.6950	7.9178	14.4998
+1206	1987.4658	170	1.3929	0.7191	0.9414	1.0820	8.2090	14.6950	7.9224	14.5050
+1207	1987.4685	171	1.3928	0.7191	0.9413	1.0820	8.2090	14.6950	7.9297	14.5089
+1208	1987.4712	172	1.3928	0.7191	0.9413	1.0820	8.2090	14.6950	7.9394	14.5116
+1209	1987.4740	173	1.3927	0.7191	0.9413	1.0820	8.2090	14.6950	7.9514	14.5129
+1210	1987.4767	174	1.3926	0.7190	0.9413	1.0820	8.2090	14.6950	7.9655	14.5128
+1211	1987.4795	175	1.3926	0.7190	0.9412	1.0820	8.2090	14.6950	7.9815	14.5112
+1212	1987.4822	176	1.3925	0.7190	0.9412	1.0820	8.2090	14.6950	7.9990	14.5083
+1213	1987.4849	177	1.3924	0.7190	0.9412	1.0820	8.2090	14.6950	8.0177	14.5039
+1214	1987.4877	178	1.3924	0.7189	0.9412	1.0820	8.2090	14.6950	8.0372	14.4981
+1215	1987.4904	179	1.3923	0.7189	0.9411	1.0820	8.2090	14.6950	8.0573	14.4910
+1216	1987.4932	180	1.3922	0.7189	0.9411	1.0820	8.2090	14.6950	8.0775	14.4825
+1217	1987.4959	181	1.3921	0.7189	0.9411	1.0820	8.2090	14.6950	8.0974	14.4727
+1218	1987.4986	182	1.3921	0.7188	0.9411	1.0820	8.2090	14.6950	8.1166	14.4618
+1219	1987.5014	183	1.3920	0.7188	0.9410	1.0820	8.2090	14.6950	8.1347	14.4497
+1220	1987.5041	184	1.3919	0.7188	0.9410	1.0820	8.2090	14.6950	8.1515	14.4365
+1221	1987.5068	185	1.3919	0.7188	0.9410	1.0820	8.2090	14.6950	8.1664	14.4224
+1222	1987.5096	186	1.3918	0.7187	0.9410	1.0820	8.2090	14.6950	8.1792	14.4074
+1223	1987.5123	187	1.3917	0.7187	0.9409	1.0820	8.2090	14.6950	8.1897	14.3917
+1224	1987.5151	188	1.3917	0.7187	0.9409	1.0820	8.2090	14.6950	8.1976	14.3753
+1225	1987.5178	189	1.3916	0.7187	0.9409	1.0820	8.2090	14.6950	8.2026	14.3585
+1226	1987.5205	190	1.3915	0.7186	0.9409	1.0820	8.2090	14.6950	8.2048	14.3412
+1227	1987.5233	191	1.3914	0.7186	0.9408	1.0820	8.2090	14.6950	8.2041	14.3237
+1228	1987.5260	192	1.3914	0.7186	0.9408	1.0820	8.2090	14.6950	8.2004	14.3060
+1229	1987.5288	193	1.3913	0.7186	0.9408	1.0820	8.2090	14.6950	8.1938	14.2883
+1230	1987.5315	194	1.3912	0.7185	0.9408	1.0820	8.2090	14.6950	8.1844	14.2708
+1231	1987.5342	195	1.3912	0.7185	0.9407	1.0820	8.2090	14.6950	8.1725	14.2535
+1232	1987.5370	196	1.3911	0.7185	0.9407	1.0820	8.2090	14.6950	8.1582	14.2365
+1233	1987.5397	197	1.3910	0.7185	0.9407	1.0820	8.2090	14.6950	8.1419	14.2201
+1234	1987.5425	198	1.3910	0.7184	0.9407	1.0820	8.2090	14.6950	8.1238	14.2042
+1235	1987.5452	199	1.3909	0.7184	0.9406	1.0820	8.2090	14.6950	8.1044	14.1891
+1236	1987.5479	200	1.3908	0.7184	0.9406	1.0820	8.2090	14.6950	8.0839	14.1747
+1237	1987.5507	201	1.3907	0.7184	0.9406	1.0820	8.2090	14.6950	8.0628	14.1612
+1238	1987.5534	202	1.3907	0.7183	0.9406	1.0820	8.2090	14.6950	8.0414	14.1488
+1239	1987.5562	203	1.3906	0.7183	0.9405	1.0820	8.2090	14.6950	8.2090	14.6950
+1240	1987.5589	204	1.3905	0.7183	0.9405	1.0820	8.2090	14.6950	8.1915	14.6941
+1241	1987.5616	205	1.3905	0.7183	0.9405	1.0820	8.2090	14.6950	8.1724	14.6918
+1242	1987.5644	206	1.3904	0.7182	0.9405	1.0820	8.2090	14.6950	8.1521	14.6880
+1243	1987.5671	207	1.3903	0.7182	0.9404	1.0820	8.2090	14.6950	8.1310	14.6828
+1244	1987.5699	208	1.3903	0.7182	0.9404	1.0820	8.2090	14.6950	8.1094	14.6761
+1245	1987.5726	209	1.3902	0.7182	0.9404	1.0820	8.2090	14.6950	8.0878	14.6681
+1246	1987.5753	210	1.3901	0.7181	0.9404	1.0820	8.2090	14.6950	8.0665	14.6587
+1247	1987.5781	211	1.3901	0.7181	0.9403	1.0820	8.2090	14.6950	8.0459	14.6481
+1248	1987.5808	212	1.3900	0.7181	0.9403	1.0820	8.2090	14.6950	8.0265	14.6362
+1249	1987.5836	213	1.3899	0.7181	0.9403	1.0820	8.2090	14.6950	8.0084	14.6232
+1250	1987.5863	214	1.3898	0.7180	0.9403	1.0820	8.2090	14.6950	7.9922	14.6092
+1251	1987.5890	215	1.3898	0.7180	0.9402	1.0820	8.2090	14.6950	7.9779	14.5943
+1252	1987.5918	216	1.3897	0.7180	0.9402	1.0820	8.2090	14.6950	7.9658	14.5786
+1253	1987.5945	217	1.3896	0.7180	0.9402	1.0820	8.2090	14.6950	7.9563	14.5621
+1254	1987.5973	218	1.3896	0.7179	0.9402	1.0820	8.2090	14.6950	7.9493	14.5451
+1255	1987.6000	219	1.3895	0.7179	0.9402	1.0820	8.2090	14.6950	7.9450	14.5276
+1256	1987.6027	220	1.3894	0.7179	0.9401	1.0820	8.2090	14.6950	7.9434	14.5098
+1257	1987.6055	221	1.3894	0.7179	0.9401	1.0820	8.2090	14.6950	7.9447	14.4918
+1258	1987.6082	222	1.3893	0.7178	0.9401	1.0820	8.2090	14.6950	7.9486	14.4737
+1259	1987.6110	223	1.3892	0.7178	0.9401	1.0820	8.2090	14.6950	7.9553	14.4556
+1260	1987.6137	224	1.3892	0.7178	0.9400	1.0820	8.2090	14.6950	7.9645	14.4378
+1261	1987.6164	225	1.3891	0.7178	0.9400	1.0820	8.2090	14.6950	7.9760	14.4203
+1262	1987.6192	226	1.3890	0.7177	0.9400	1.0820	8.2090	14.6950	7.9897	14.4032
+1263	1987.6219	227	1.3889	0.7177	0.9400	1.0820	8.2090	14.6950	8.0053	14.3867
+1264	1987.6247	228	1.3889	0.7177	0.9399	1.0820	8.2090	14.6950	8.0226	14.3708
+1265	1987.6274	229	1.3888	0.7177	0.9399	1.0820	8.2090	14.6950	8.0412	14.3558
+1266	1987.6301	230	1.3887	0.7176	0.9399	1.0820	8.2090	14.6950	8.0607	14.3416
+1267	1987.6329	231	1.3887	0.7176	0.9399	1.0820	8.2090	14.6950	8.0808	14.3283
+1268	1987.6356	232	1.3886	0.7176	0.9398	1.0820	8.2090	14.6950	8.1011	14.3161
+1269	1987.6384	233	1.3885	0.7176	0.9398	1.0820	8.2090	14.6950	8.1213	14.3051
+1270	1987.6411	234	1.3885	0.7175	0.9398	1.0820	8.2090	14.6950	8.1409	14.2952
+1271	1987.6438	235	1.3884	0.7175	0.9398	1.0820	8.2090	14.6950	8.1594	14.2866
+1272	1987.6466	236	1.3883	0.7175	0.9397	1.0820	8.2090	14.6950	8.1767	14.2793
+1273	1987.6493	237	1.3883	0.7175	0.9397	1.0820	8.2090	14.6950	8.1922	14.2734
+1274	1987.6521	238	1.3882	0.7174	0.9397	1.0820	8.2090	14.6950	8.2057	14.2688
+1275	1987.6548	239	1.3881	0.7174	0.9397	1.0820	8.2090	14.6950	8.2169	14.2655
+1276	1987.6575	240	1.3881	0.7174	0.9396	1.0820	8.2090	14.6950	8.2254	14.2637
+1277	1987.6603	241	1.3880	0.7174	0.9396	1.0820	8.2090	14.6950	8.2313	14.2632
+1278	1987.6630	242	1.3879	0.7173	0.9396	1.0820	8.2090	14.6950	8.2342	14.2641
+1279	1987.6658	243	1.3878	0.7173	0.9396	1.0820	8.2090	14.6950	8.2342	14.2662
+1280	1987.6685	244	1.3878	0.7173	0.9395	1.0820	8.2090	14.6950	8.2312	14.2697
+1281	1987.6712	245	1.3877	0.7173	0.9395	1.0820	8.2090	14.6950	8.2253	14.2744
+1282	1987.6740	246	1.3876	0.7172	0.9395	1.0820	8.2090	14.6950	8.2166	14.2803
+1283	1987.6767	247	1.3876	0.7172	0.9395	1.0820	8.2090	14.6950	8.2052	14.2873
+1284	1987.6795	248	1.3875	0.7172	0.9394	1.0820	8.2090	14.6950	8.1914	14.2954
+1285	1987.6822	249	1.3874	0.7172	0.9394	1.0820	8.2090	14.6950	8.1754	14.3044
+1286	1987.6849	250	1.3874	0.7171	0.9394	1.0820	8.2090	14.6950	8.1576	14.3142
+1287	1987.6877	251	1.3873	0.7171	0.9394	1.0820	8.2090	14.6950	8.1384	14.3248
+1288	1987.6904	252	1.3872	0.7171	0.9394	1.0820	8.2090	14.6950	8.1179	14.3361
+1289	1987.6932	253	1.3872	0.7171	0.9393	1.0820	8.2090	14.6950	8.0968	14.3479
+1290	1987.6959	254	1.3871	0.7170	0.9393	1.0820	8.2090	14.6950	8.0753	14.3601
+1291	1987.6986	255	1.3870	0.7170	0.9393	1.0820	8.2090	14.6950	8.0539	14.3726
+1292	1987.7014	256	1.3870	0.7170	0.9393	1.0820	8.2090	14.6950	8.0329	14.3852
+1293	1987.7041	257	1.3869	0.7170	0.9392	1.0820	8.2090	14.6950	8.0127	14.3979
+1294	1987.7068	258	1.3868	0.7169	0.9392	1.0820	8.2090	14.6950	7.9937	14.4105
+1295	1987.7096	259	1.3868	0.7169	0.9392	1.0820	8.2090	14.6950	7.9762	14.4229
+1296	1987.7123	260	1.3867	0.7169	0.9392	1.0820	8.2090	14.6950	7.9605	14.4350
+1297	1987.7151	261	1.3866	0.7169	0.9391	1.0820	8.2090	14.6950	7.9469	14.4466
+1298	1987.7178	262	1.3865	0.7168	0.9391	1.0820	8.2090	14.6950	7.9355	14.4576
+1299	1987.7205	263	1.3865	0.7168	0.9391	1.0820	8.2090	14.6950	7.9266	14.4678
+1300	1987.7233	264	1.3864	0.7168	0.9391	1.0820	8.2090	14.6950	7.9203	14.4773
+1301	1987.7260	265	1.3863	0.7168	0.9390	1.0820	8.2090	14.6950	7.9168	14.4859
+1302	1987.7288	266	1.3863	0.7167	0.9390	1.0820	8.2090	14.6950	7.9159	14.4934
+1303	1987.7315	267	1.3862	0.7167	0.9390	1.0820	8.2090	14.6950	7.9178	14.4998
+1304	1987.7342	268	1.3861	0.7167	0.9390	1.0820	8.2090	14.6950	7.9224	14.5050
+1305	1987.7370	269	1.3861	0.7167	0.9389	1.0820	8.2090	14.6950	7.9297	14.5089
+1306	1987.7397	270	1.3860	0.7166	0.9389	1.0820	8.2090	14.6950	7.9394	14.5116
+1307	1987.7425	271	1.3859	0.7166	0.9389	1.0820	8.2090	14.6950	7.9514	14.5129
+1308	1987.7452	272	1.3859	0.7166	0.9389	1.0820	8.2090	14.6950	7.9655	14.5128
+1309	1987.7479	273	1.3858	0.7166	0.9389	1.0820	8.2090	14.6950	7.9815	14.5112
+1310	1987.7507	274	1.3857	0.7165	0.9388	1.0820	8.2090	14.6950	7.9990	14.5083
+1311	1987.7534	275	1.3857	0.7165	0.9388	1.0820	8.2090	14.6950	8.0177	14.5039
+1312	1987.7562	276	1.3856	0.7165	0.9388	1.0820	8.2090	14.6950	8.0372	14.4981
+1313	1987.7589	277	1.3855	0.7165	0.9388	1.0820	8.2090	14.6950	8.0573	14.4910
+1314	1987.7616	278	1.3855	0.7165	0.9387	1.0820	8.2090	14.6950	8.0775	14.4825
+1315	1987.7644	279	1.3854	0.7164	0.9387	1.0820	8.2090	14.6950	8.0974	14.4727
+1316	1987.7671	280	1.3853	0.7164	0.9387	1.0820	8.2090	14.6950	8.1166	14.4618
+1317	1987.7699	281	1.3853	0.7164	0.9387	1.0820	8.2090	14.6950	8.1347	14.4497
+1318	1987.7726	282	1.3852	0.7164	0.9386	1.0820	8.2090	14.6950	8.1515	14.4365
+1319	1987.7753	283	1.3851	0.7163	0.9386	1.0820	8.2090	14.6950	8.1664	14.4224
+1320	1987.7781	284	1.3851	0.7163	0.9386	1.0820	8.2090	14.6950	8.1792	14.4074
+1321	1987.7808	285	1.3850	0.7163	0.9386	1.0820	8.2090	14.6950	8.1897	14.3917
+1322	1987.7836	286	1.3849	0.7163	0.9385	1.0820	8.2090	14.6950	8.1976	14.3753
+1323	1987.7863	287	1.3849	0.7162	0.9385	1.0820	8.2090	14.6950	8.2026	14.3585
+1324	1987.7890	288	1.3848	0.7162	0.9385	1.0820	8.2090	14.6950	8.2048	14.3412
+1325	1987.7918	289	1.3847	0.7162	0.9385	1.0820	8.2090	14.6950	8.2041	14.3237
+1326	1987.7945	290	1.3847	0.7162	0.9385	1.0820	8.2090	14.6950	8.2004	14.3060
+1327	1987.7973	291	1.3846	0.7161	0.9384	1.0820	8.2090	14.6950	8.1938	14.2883
+1328	1987.8000	292	1.3845	0.7161	0.9384	1.0820	8.2090	14.6950	8.1844	14.2708
+1329	1987.8027	293	1.3845	0.7161	0.9384	1.0820	8.2090	14.6950	8.1725	14.2535
+1330	1987.8055	294	1.3844	0.7161	0.9384	1.0820	8.2090	14.6950	8.1582	14.2365
+1331	1987.8082	295	1.3843	0.7160	0.9383	1.0820	8.2090	14.6950	8.1419	14.2201
+1332	1987.8110	296	1.3842	0.7160	0.9383	1.0820	8.2090	14.6950	8.1238	14.2042
+1333	1987.8137	297	1.3842	0.7160	0.9383	1.0820	8.2090	14.6950	8.1044	14.1891
+1334	1987.8164	298	1.3841	0.7160	0.9383	1.0820	8.2090	14.6950	8.0839	14.1747
+1335	1987.8192	299	1.3840	0.7159	0.9382	1.0820	8.2090	14.6950	8.0628	14.1612
+1336	1987.8219	300	1.3840	0.7159	0.9382	1.0820	8.2090	14.6950	8.0414	14.1488
+1337	1987.8247	301	1.3839	0.7159	0.9382	1.0820	8.2090	14.6950	8.2090	14.6950
+1338	1987.8274	302	1.3838	0.7159	0.9382	1.0820	8.2090	14.6950	8.1915	14.6941
+1339	1987.8301	303	1.3838	0.7158	0.9382	1.0820	8.2090	14.6950	8.1724	14.6918
+1340	1987.8329	304	1.3837	0.7158	0.9381	1.0820	8.2090	14.6950	8.1521	14.6880
+1341	1987.8356	305	1.3836	0.7158	0.9381	1.0820	8.2090	14.6950	8.1310	14.6828
+1342	1987.8384	306	1.3836	0.7158	0.9381	1.0820	8.2090	14.6950	8.1094	14.6761
+1343	1987.8411	307	1.3835	0.7157	0.9381	1.0820	8.2090	14.6950	8.0878	14.6681
+1344	1987.8438	308	1.3834	0.7157	0.9380	1.0820	8.2090	14.6950	8.0665	14.6587
+1345	1987.8466	309	1.3834	0.7157	0.9380	1.0820	8.2090	14.6950	8.0459	14.6481
+1346	1987.8493	310	1.3833	0.7157	0.9380	1.0820	8.2090	14.6950	8.0265	14.6362
+1347	1987.8521	311	1.3832	0.7156	0.9380	1.0820	8.2090	14.6950	8.0084	14.6232
+1348	1987.8548	312	1.3832	0.7156	0.9379	1.0820	8.2090	14.6950	7.9922	14.6092
+1349	1987.8575	313	1.3831	0.7156	0.9379	1.0820	8.2090	14.6950	7.9779	14.5943
+1350	1987.8603	314	1.3830	0.7156	0.9379	1.0820	8.2090	14.6950	7.9658	14.5786
+1351	1987.8630	315	1.3830	0.7155	0.9379	1.0820	8.2090	14.6950	7.9563	14.5621
+1352	1987.8658	316	1.3829	0.7155	0.9379	1.0820	8.2090	14.6950	7.9493	14.5451
+1353	1987.8685	317	1.3828	0.7155	0.9378	1.0820	8.2090	14.6950	7.9450	14.5276
+1354	1987.8712	318	1.3828	0.7155	0.9378	1.0820	8.2090	14.6950	7.9434	14.5098
+1355	1987.8740	319	1.3827	0.7154	0.9378	1.0820	8.2090	14.6950	7.9447	14.4918
+1356	1987.8767	320	1.3826	0.7154	0.9378	1.0820	8.2090	14.6950	7.9486	14.4737
+1357	1987.8795	321	1.3826	0.7154	0.9377	1.0820	8.2090	14.6950	7.9553	14.4556
+1358	1987.8822	322	1.3825	0.7154	0.9377	1.0820	8.2090	14.6950	7.9645	14.4378
+1359	1987.8849	323	1.3824	0.7154	0.9377	1.0820	8.2090	14.6950	7.9760	14.4203
+1360	1987.8877	324	1.3824	0.7153	0.9377	1.0820	8.2090	14.6950	7.9897	14.4032
+1361	1987.8904	325	1.3823	0.7153	0.9376	1.0820	8.2090	14.6950	8.0053	14.3867
+1362	1987.8932	326	1.3822	0.7153	0.9376	1.0820	8.2090	14.6950	8.0226	14.3708
+1363	1987.8959	327	1.3822	0.7153	0.9376	1.0820	8.2090	14.6950	8.0412	14.3558
+1364	1987.8986	328	1.3821	0.7152	0.9376	1.0820	8.2090	14.6950	8.0607	14.3416
+1365	1987.9014	329	1.3820	0.7152	0.9376	1.0820	8.2090	14.6950	8.0808	14.3283
+1366	1987.9041	330	1.3820	0.7152	0.9375	1.0820	8.2090	14.6950	8.1011	14.3161
+1367	1987.9068	331	1.3819	0.7152	0.9375	1.0820	8.2090	14.6950	8.1213	14.3051
+1368	1987.9096	332	1.3818	0.7151	0.9375	1.0820	8.2090	14.6950	8.1409	14.2952
+1369	1987.9123	333	1.3818	0.7151	0.9375	1.0820	8.2090	14.6950	8.1594	14.2866
+1370	1987.9151	334	1.3817	0.7151	0.9374	1.0820	8.2090	14.6950	8.1767	14.2793
+1371	1987.9178	335	1.3816	0.7151	0.9374	1.0820	8.2090	14.6950	8.1922	14.2734
+1372	1987.9205	336	1.3816	0.7150	0.9374	1.0820	8.2090	14.6950	8.2057	14.2688
+1373	1987.9233	337	1.3815	0.7150	0.9374	1.0820	8.2090	14.6950	8.2169	14.2655
+1374	1987.9260	338	1.3814	0.7150	0.9374	1.0820	8.2090	14.6950	8.2254	14.2637
+1375	1987.9288	339	1.3814	0.7150	0.9373	1.0820	8.2090	14.6950	8.2313	14.2632
+1376	1987.9315	340	1.3813	0.7149	0.9373	1.0820	8.2090	14.6950	8.2342	14.2641
+1377	1987.9342	341	1.3813	0.7149	0.9373	1.0820	8.2090	14.6950	8.2342	14.2662
+1378	1987.9370	342	1.3812	0.7149	0.9373	1.0820	8.2090	14.6950	8.2312	14.2697
+1379	1987.9397	343	1.3811	0.7149	0.9372	1.0820	8.2090	14.6950	8.2253	14.2744
+1380	1987.9425	344	1.3811	0.7148	0.9372	1.0820	8.2090	14.6950	8.2166	14.2803
+1381	1987.9452	345	1.3810	0.7148	0.9372	1.0820	8.2090	14.6950	8.2052	14.2873
+1382	1987.9479	346	1.3809	0.7148	0.9372	1.0820	8.2090	14.6950	8.1914	14.2954
+1383	1987.9507	347	1.3809	0.7148	0.9372	1.0820	8.2090	14.6950	8.1754	14.3044
+1384	1987.9534	348	1.3808	0.7147	0.9371	1.0820	8.2090	14.6950	8.1576	14.3142
+1385	1987.9562	349	1.3807	0.7147	0.9371	1.0820	8.2090	14.6950	8.1384	14.3248
+1386	1987.9589	350	1.3807	0.7147	0.9371	1.0820	8.2090	14.6950	8.1179	14.3361
+1387	1987.9616	351	1.3806	0.7147	0.9371	1.0820	8.2090	14.6950	8.0968	14.3479
+1388	1987.9644	352	1.3805	0.7146	0.9370	1.0820	8.2090	14.6950	8.0753	14.3601
+1389	1987.9671	353	1.3805	0.7146	0.9370	1.0820	8.2090	14.6950	8.0539	14.3726
+1390	1987.9699	354	1.3804	0.7146	0.9370	1.0820	8.2090	14.6950	8.0329	14.3852
+1391	1987.9726	355	1.3803	0.7146	0.9370	1.0820	8.2090	14.6950	8.0127	14.3979
+1392	1987.9753	356	1.3803	0.7146	0.9370	1.0820	8.2090	14.6950	7.9937	14.4105
+1393	1987.9781	357	1.3802	0.7145	0.9369	1.0820	8.2090	14.6950	7.9762	14.4229
+1394	1987.9808	358	1.3801	0.7145	0.9369	1.0820	8.2090	14.6950	7.9605	14.4350
+1395	1987.9836	359	1.3801	0.7145	0.9369	1.0820	8.2090	14.6950	7.9469	14.4466
+1396	1987.9863	360	1.3800	0.7145	0.9369	1.0820	8.2090	14.6950	7.9355	14.4576
+1397	1987.9890	361	1.3799	0.7144	0.9368	1.0820	8.2090	14.6950	7.9266	14.4678
+1398	1987.9918	362	1.3799	0.7144	0.9368	1.0820	8.2090	14.6950	7.9203	14.4773
+1399	1987.9945	363	1.3798	0.7144	0.9368	1.0820	8.2090	14.6950	7.9168	14.4859
+1400	1987.9973	364	1.3797	0.7144	0.9368	1.0820	8.2090	14.6950	7.9159	14.4934
+1401	1987.9999	365	1.3797	0.7143	0.9368	1.0820	8.2090	14.6950	7.9178	14.4998
+1402	1988.0027	1	1.3796	0.7143	0.9367	1.0820	8.2090	14.6950	7.9224	14.5050
+1403	1988.0055	2	1.3795	0.7143	0.9367	1.0820	8.2090	14.6950	7.9297	14.5089
+1404	1988.0082	3	1.3795	0.7143	0.9367	1.0820	8.2090	14.6950	7.9394	14.5116
+1405	1988.0109	4	1.3794	0.7142	0.9367	1.0820	8.2090	14.6950	7.9514	14.5129
+1406	1988.0137	5	1.3793	0.7142	0.9366	1.0820	8.2090	14.6950	7.9655	14.5128
+1407	1988.0164	6	1.3793	0.7142	0.9366	1.0820	8.2090	14.6950	7.9815	14.5112
+1408	1988.0191	7	1.3792	0.7142	0.9366	1.0820	8.2090	14.6950	7.9990	14.5083
+1409	1988.0219	8	1.3792	0.7141	0.9366	1.0820	8.2090	14.6950	8.0177	14.5039
+1410	1988.0246	9	1.3791	0.7141	0.9366	1.0820	8.2090	14.6950	8.0372	14.4981
+1411	1988.0273	10	1.3790	0.7141	0.9365	1.0820	8.2090	14.6950	8.0573	14.4910
+1412	1988.0301	11	1.3790	0.7141	0.9365	1.0820	8.2090	14.6950	8.0775	14.4825
+1413	1988.0328	12	1.3789	0.7140	0.9365	1.0820	8.2090	14.6950	8.0974	14.4727
+1414	1988.0355	13	1.3788	0.7140	0.9365	1.0820	8.2090	14.6950	8.1166	14.4618
+1415	1988.0383	14	1.3788	0.7140	0.9364	1.0820	8.2090	14.6950	8.1347	14.4497
+1416	1988.0410	15	1.3787	0.7140	0.9364	1.0820	8.2090	14.6950	8.1515	14.4365
+1417	1988.0437	16	1.3786	0.7140	0.9364	1.0820	8.2090	14.6950	8.1664	14.4224
+1418	1988.0464	17	1.3786	0.7139	0.9364	1.0820	8.2090	14.6950	8.1792	14.4074
+1419	1988.0492	18	1.3785	0.7139	0.9364	1.0820	8.2090	14.6950	8.1897	14.3917
+1420	1988.0519	19	1.3784	0.7139	0.9363	1.0820	8.2090	14.6950	8.1976	14.3753
+1421	1988.0546	20	1.3784	0.7139	0.9363	1.0820	8.2090	14.6950	8.2026	14.3585
+1422	1988.0574	21	1.3783	0.7138	0.9363	1.0820	8.2090	14.6950	8.2048	14.3412
+1423	1988.0601	22	1.3782	0.7138	0.9363	1.0820	8.2090	14.6950	8.2041	14.3237
+1424	1988.0628	23	1.3782	0.7138	0.9362	1.0820	8.2090	14.6950	8.2004	14.3060
+1425	1988.0656	24	1.3781	0.7138	0.9362	1.0820	8.2090	14.6950	8.1938	14.2883
+1426	1988.0683	25	1.3781	0.7137	0.9362	1.0820	8.2090	14.6950	8.1844	14.2708
+1427	1988.0710	26	1.3780	0.7137	0.9362	1.0820	8.2090	14.6950	8.1725	14.2535
+1428	1988.0738	27	1.3779	0.7137	0.9362	1.0820	8.2090	14.6950	8.1582	14.2365
+1429	1988.0765	28	1.3779	0.7137	0.9361	1.0820	8.2090	14.6950	8.1419	14.2201
+1430	1988.0792	29	1.3778	0.7136	0.9361	1.0820	8.2090	14.6950	8.1238	14.2042
+1431	1988.0820	30	1.3777	0.7136	0.9361	1.0820	8.2090	14.6950	8.1044	14.1891
+1432	1988.0847	31	1.3777	0.7136	0.9361	1.0820	8.2090	14.6950	8.0839	14.1747
+1433	1988.0874	32	1.3776	0.7136	0.9360	1.0820	8.2090	14.6950	8.0628	14.1612
+1434	1988.0902	33	1.3775	0.7135	0.9360	1.0820	8.2090	14.6950	8.2031	14.1336
+1435	1988.0929	34	1.3775	0.7135	0.9360	1.0820	8.2090	14.6950	8.2090	14.6950
+1436	1988.0956	35	1.3774	0.7135	0.9360	1.0820	8.2090	14.6950	8.1945	14.6942
+1437	1988.0984	36	1.3773	0.7135	0.9360	1.0820	8.2090	14.6950	8.1788	14.6920
+1438	1988.1011	37	1.3773	0.7135	0.9359	1.0820	8.2090	14.6950	8.1623	14.6885
+1439	1988.1038	38	1.3772	0.7134	0.9359	1.0820	8.2090	14.6950	8.1450	14.6836
+1440	1988.1066	39	1.3771	0.7134	0.9359	1.0820	8.2090	14.6950	8.1272	14.6773
+1441	1988.1093	40	1.3771	0.7134	0.9359	1.0820	8.2090	14.6950	8.1092	14.6698
+1442	1988.1120	41	1.3770	0.7134	0.9359	1.0820	8.2090	14.6950	8.0912	14.6611
+1443	1988.1148	42	1.3770	0.7133	0.9358	1.0820	8.2090	14.6950	8.0733	14.6511
+1444	1988.1175	43	1.3769	0.7133	0.9358	1.0820	8.2090	14.6950	8.0560	14.6400
+1445	1988.1202	44	1.3768	0.7133	0.9358	1.0820	8.2090	14.6950	8.0392	14.6279
+1446	1988.1230	45	1.3768	0.7133	0.9358	1.0820	8.2090	14.6950	8.0233	14.6148
+1447	1988.1257	46	1.3767	0.7132	0.9357	1.0820	8.2090	14.6950	8.0085	14.6009
+1448	1988.1284	47	1.3766	0.7132	0.9357	1.0820	8.2090	14.6950	7.9948	14.5861
+1449	1988.1311	48	1.3766	0.7132	0.9357	1.0820	8.2090	14.6950	7.9826	14.5707
+1450	1988.1339	49	1.3765	0.7132	0.9357	1.0820	8.2090	14.6950	7.9718	14.5547
+1451	1988.1366	50	1.3764	0.7131	0.9357	1.0820	8.2090	14.6950	7.9626	14.5382
+1452	1988.1393	51	1.3764	0.7131	0.9356	1.0820	8.2090	14.6950	7.9551	14.5213
+1453	1988.1421	52	1.3763	0.7131	0.9356	1.0820	8.2090	14.6950	7.9495	14.5043
+1454	1988.1448	53	1.3763	0.7131	0.9356	1.0820	8.2090	14.6950	7.9456	14.4870
+1455	1988.1475	54	1.3762	0.7131	0.9356	1.0820	8.2090	14.6950	7.9437	14.4698
+1456	1988.1503	55	1.3761	0.7130	0.9356	1.0820	8.2090	14.6950	7.9436	14.4527
+1457	1988.1530	56	1.3761	0.7130	0.9355	1.0820	8.2090	14.6950	7.9454	14.4357
+1458	1988.1557	57	1.3760	0.7130	0.9355	1.0820	8.2090	14.6950	7.9491	14.4191
+1459	1988.1585	58	1.3759	0.7130	0.9355	1.0820	8.2090	14.6950	7.9546	14.4029
+1460	1988.1612	59	1.3759	0.7129	0.9355	1.0820	8.2090	14.6950	7.9618	14.3872
+1461	1988.1639	60	1.3758	0.7129	0.9354	1.0820	8.2090	14.6950	7.9706	14.3722
+1462	1988.1667	61	1.3757	0.7129	0.9354	1.0820	8.2090	14.6950	7.9809	14.3578
+1463	1988.1694	62	1.3757	0.7129	0.9354	1.0820	8.2090	14.6950	7.9926	14.3442
+1464	1988.1721	63	1.3756	0.7128	0.9354	1.0820	8.2090	14.6950	8.0056	14.3315
+1465	1988.1749	64	1.3755	0.7128	0.9354	1.0820	8.2090	14.6950	8.0197	14.3197
+1466	1988.1776	65	1.3755	0.7128	0.9353	1.0820	8.2090	14.6950	8.0346	14.3089
+1467	1988.1803	66	1.3754	0.7128	0.9353	1.0820	8.2090	14.6950	8.0503	14.2992
+1468	1988.1831	67	1.3754	0.7127	0.9353	1.0820	8.2090	14.6950	8.0665	14.2906
+1469	1988.1858	68	1.3753	0.7127	0.9353	1.0820	8.2090	14.6950	8.0830	14.2831
+1470	1988.1885	69	1.3752	0.7127	0.9353	1.0820	8.2090	14.6950	8.0996	14.2768
+1471	1988.1913	70	1.3752	0.7127	0.9352	1.0820	8.2090	14.6950	8.1161	14.2716
+1472	1988.1940	71	1.3751	0.7127	0.9352	1.0820	8.2090	14.6950	8.1323	14.2677
+1473	1988.1967	72	1.3750	0.7126	0.9352	1.0820	8.2090	14.6950	8.1479	14.2650
+1474	1988.1995	73	1.3750	0.7126	0.9352	1.0820	8.2090	14.6950	8.1627	14.2635
+1475	1988.2022	74	1.3749	0.7126	0.9352	1.0820	8.2090	14.6950	8.1767	14.2632
+1476	1988.2049	75	1.3749	0.7126	0.9351	1.0820	8.2090	14.6950	8.1894	14.2641
+1477	1988.2077	76	1.3748	0.7125	0.9351	1.0820	8.2090	14.6950	8.2009	14.2662
+1478	1988.2104	77	1.3747	0.7125	0.9351	1.0820	8.2090	14.6950	8.2109	14.2693
+1479	1988.2131	78	1.3747	0.7125	0.9351	1.0820	8.2090	14.6950	8.2192	14.2736
+1480	1988.2158	79	1.3746	0.7125	0.9350	1.0820	8.2090	14.6950	8.2259	14.2789
+1481	1988.2186	80	1.3745	0.7124	0.9350	1.0820	8.2090	14.6950	8.2307	14.2851
+1482	1988.2213	81	1.3745	0.7124	0.9350	1.0820	8.2090	14.6950	8.2336	14.2923
+1483	1988.2240	82	1.3744	0.7124	0.9350	1.0820	8.2090	14.6950	8.2346	14.3003
+1484	1988.2268	83	1.3743	0.7124	0.9350	1.0820	8.2090	14.6950	8.2336	14.3091
+1485	1988.2295	84	1.3743	0.7123	0.9349	1.0820	8.2090	14.6950	8.2307	14.3186
+1486	1988.2322	85	1.3742	0.7123	0.9349	1.0820	8.2090	14.6950	8.2259	14.3287
+1487	1988.2350	86	1.3742	0.7123	0.9349	1.0820	8.2090	14.6950	8.2193	14.3393
+1488	1988.2377	87	1.3741	0.7123	0.9349	1.0820	8.2090	14.6950	8.2109	14.3503
+1489	1988.2404	88	1.3740	0.7123	0.9349	1.0820	8.2090	14.6950	8.2008	14.3616
+1490	1988.2432	89	1.3740	0.7122	0.9348	1.0820	8.2090	14.6950	8.1893	14.3732
+1491	1988.2459	90	1.3739	0.7122	0.9348	1.0820	8.2090	14.6950	8.1764	14.3849
+1492	1988.2486	91	1.3738	0.7122	0.9348	1.0820	8.2090	14.6950	8.1623	14.3966
+1493	1988.2514	92	1.3738	0.7122	0.9348	1.0820	8.2090	14.6950	8.1471	14.4083
+1494	1988.2541	93	1.3737	0.7121	0.9348	1.0820	8.2090	14.6950	8.1312	14.4198
+1495	1988.2568	94	1.3737	0.7121	0.9347	1.0820	8.2090	14.6950	8.1146	14.4310
+1496	1988.2596	95	1.3736	0.7121	0.9347	1.0820	8.2090	14.6950	8.0976	14.4418
+1497	1988.2623	96	1.3735	0.7121	0.9347	1.0820	8.2090	14.6950	8.0804	14.4522
+1498	1988.2650	97	1.3735	0.7120	0.9347	1.0820	8.2090	14.6950	8.0632	14.4620
+1499	1988.2678	98	1.3734	0.7120	0.9346	1.0820	8.2090	14.6950	8.0462	14.4712
+1500	1988.2705	99	1.3733	0.7120	0.9346	1.0820	8.2090	14.6950	8.0295	14.4796
+1501	1988.2732	100	1.3733	0.7120	0.9346	1.0820	8.2090	14.6950	8.0134	14.4872
+1502	1988.2760	101	1.3732	0.7120	0.9346	1.0820	8.2090	14.6950	7.9981	14.4940
+1503	1988.2787	102	1.3731	0.7119	0.9346	1.0820	8.2090	14.6950	7.9837	14.4998
+1504	1988.2814	103	1.3731	0.7119	0.9345	1.0820	8.2090	14.6950	7.9704	14.5046
+1505	1988.2842	104	1.3730	0.7119	0.9345	1.0820	8.2090	14.6950	7.9582	14.5084
+1506	1988.2869	105	1.3730	0.7119	0.9345	1.0820	8.2090	14.6950	7.9475	14.5110
+1507	1988.2896	106	1.3729	0.7118	0.9345	1.0820	8.2090	14.6950	7.9381	14.5126
+1508	1988.2923	107	1.3728	0.7118	0.9345	1.0820	8.2090	14.6950	7.9304	14.5130
+1509	1988.2951	108	1.3728	0.7118	0.9344	1.0820	8.2090	14.6950	7.9242	14.5122
+1510	1988.2978	109	1.3727	0.7118	0.9344	1.0820	8.2090	14.6950	7.9197	14.5103
+1511	1988.3005	110	1.3726	0.7117	0.9344	1.0820	8.2090	14.6950	7.9169	14.5071
+1512	1988.3033	111	1.3726	0.7117	0.9344	1.0820	8.2090	14.6950	7.9159	14.5028
+1513	1988.3060	112	1.3725	0.7117	0.9344	1.0820	8.2090	14.6950	7.9166	14.4974
+1514	1988.3087	113	1.3725	0.7117	0.9343	1.0820	8.2090	14.6950	7.9190	14.4908
+1515	1988.3115	114	1.3724	0.7117	0.9343	1.0820	8.2090	14.6950	7.9230	14.4832
+1516	1988.3142	115	1.3723	0.7116	0.9343	1.0820	8.2090	14.6950	7.9288	14.4745
+1517	1988.3169	116	1.3723	0.7116	0.9343	1.0820	8.2090	14.6950	7.9360	14.4648
+1518	1988.3197	117	1.3722	0.7116	0.9343	1.0820	8.2090	14.6950	7.9448	14.4542
+1519	1988.3224	118	1.3721	0.7116	0.9342	1.0820	8.2090	14.6950	7.9549	14.4427
+1520	1988.3251	119	1.3721	0.7115	0.9342	1.0820	8.2090	14.6950	7.9663	14.4304
+1521	1988.3279	120	1.3720	0.7115	0.9342	1.0820	8.2090	14.6950	7.9788	14.4174
+1522	1988.3306	121	1.3720	0.7115	0.9342	1.0820	8.2090	14.6950	7.9923	14.4037
+1523	1988.3333	122	1.3719	0.7115	0.9342	1.0820	8.2090	14.6950	8.0066	14.3894
+1524	1988.3361	123	1.3718	0.7114	0.9341	1.0820	8.2090	14.6950	8.0216	14.3747
+1525	1988.3388	124	1.3718	0.7114	0.9341	1.0820	8.2090	14.6950	8.0371	14.3595
+1526	1988.3415	125	1.3717	0.7114	0.9341	1.0820	8.2090	14.6950	8.0528	14.3440
+1527	1988.3443	126	1.3716	0.7114	0.9341	1.0820	8.2090	14.6950	8.0687	14.3284
+1528	1988.3470	127	1.3716	0.7114	0.9341	1.0820	8.2090	14.6950	8.0845	14.3126
+1529	1988.3497	128	1.3715	0.7113	0.9340	1.0820	8.2090	14.6950	8.1000	14.2967
+1530	1988.3525	129	1.3715	0.7113	0.9340	1.0820	8.2090	14.6950	8.1150	14.2810
+1531	1988.3552	130	1.3714	0.7113	0.9340	1.0820	8.2090	14.6950	8.1294	14.2653
+1532	1988.3579	131	1.3713	0.7113	0.9340	1.0820	8.2090	14.6950	8.1430	14.2500
+1533	1988.3607	132	1.3713	0.7112	0.9340	1.0820	8.2090	14.6950	8.2090	14.6950
+1534	1988.3634	133	1.3712	0.7112	0.9339	1.0820	8.2090	14.6950	8.1955	14.6943
+1535	1988.3661	134	1.3712	0.7112	0.9339	1.0820	8.2090	14.6950	8.1809	14.6924
+1536	1988.3689	135	1.3711	0.7112	0.9339	1.0820	8.2090	14.6950	8.1656	14.6894
+1537	1988.3716	136	1.3710	0.7111	0.9339	1.0820	8.2090	14.6950	8.1495	14.6853
+1538	1988.3743	137	1.3710	0.7111	0.9338	1.0820	8.2090	14.6950	8.1330	14.6800
+1539	1988.3770	138	1.3709	0.7111	0.9338	1.0820	8.2090	14.6950	8.1162	14.6736
+1540	1988.3798	139	1.3708	0.7111	0.9338	1.0820	8.2090	14.6950	8.0993	14.6661
+1541	1988.3825	140	1.3708	0.7111	0.9338	1.0820	8.2090	14.6950	8.0826	14.6576
+1542	1988.3852	141	1.3707	0.7110	0.9338	1.0820	8.2090	14.6950	8.0661	14.6481
+1543	1988.3880	142	1.3707	0.7110	0.9337	1.0820	8.2090	14.6950	8.0500	14.6376
+1544	1988.3907	143	1.3706	0.7110	0.9337	1.0820	8.2090	14.6950	8.0346	14.6263
+1545	1988.3934	144	1.3705	0.7110	0.9337	1.0820	8.2090	14.6950	8.0200	14.6142
+1546	1988.3962	145	1.3705	0.7109	0.9337	1.0820	8.2090	14.6950	8.0063	14.6013
+1547	1988.3989	146	1.3704	0.7109	0.9337	1.0820	8.2090	14.6950	7.9937	14.5878
+1548	1988.4016	147	1.3703	0.7109	0.9336	1.0820	8.2090	14.6950	7.9823	14.5737
+1549	1988.4044	148	1.3703	0.7109	0.9336	1.0820	8.2090	14.6950	7.9722	14.5590
+1550	1988.4071	149	1.3702	0.7108	0.9336	1.0820	8.2090	14.6950	7.9635	14.5440
+1551	1988.4098	150	1.3702	0.7108	0.9336	1.0820	8.2090	14.6950	7.9563	14.5286
+1552	1988.4126	151	1.3701	0.7108	0.9336	1.0820	8.2090	14.6950	7.9506	14.5130
+1553	1988.4153	152	1.3700	0.7108	0.9335	1.0820	8.2090	14.6950	7.9466	14.4972
+1554	1988.4180	153	1.3700	0.7108	0.9335	1.0820	8.2090	14.6950	7.9442	14.4813
+1555	1988.4208	154	1.3699	0.7107	0.9335	1.0820	8.2090	14.6950	7.9434	14.4655
+1556	1988.4235	155	1.3699	0.7107	0.9335	1.0820	8.2090	14.6950	7.9443	14.4497
+1557	1988.4262	156	1.3698	0.7107	0.9335	1.0820	8.2090	14.6950	7.9468	14.4342
+1558	1988.4290	157	1.3697	0.7107	0.9334	1.0820	8.2090	14.6950	7.9510	14.4189
+1559	1988.4317	158	1.3697	0.7106	0.9334	1.0820	8.2090	14.6950	7.9566	14.4040
+1560	1988.4344	159	1.3696	0.7106	0.9334	1.0820	8.2090	14.6950	7.9638	14.3895
+1561	1988.4372	160	1.3695	0.7106	0.9334	1.0820	8.2090	14.6950	7.9723	14.3755
+1562	1988.4399	161	1.3695	0.7106	0.9334	1.0820	8.2090	14.6950	7.9822	14.3621
+1563	1988.4426	162	1.3694	0.7105	0.9333	1.0820	8.2090	14.6950	7.9933	14.3493
+1564	1988.4454	163	1.3694	0.7105	0.9333	1.0820	8.2090	14.6950	8.0054	14.3373
+1565	1988.4481	164	1.3693	0.7105	0.9333	1.0820	8.2090	14.6950	8.0185	14.3260
+1566	1988.4508	165	1.3692	0.7105	0.9333	1.0820	8.2090	14.6950	8.0324	14.3155
+1567	1988.4536	166	1.3692	0.7105	0.9333	1.0820	8.2090	14.6950	8.0470	14.3059
+1568	1988.4563	167	1.3691	0.7104	0.9332	1.0820	8.2090	14.6950	8.0620	14.2972
+1569	1988.4590	168	1.3691	0.7104	0.9332	1.0820	8.2090	14.6950	8.0774	14.2894
+1570	1988.4617	169	1.3690	0.7104	0.9332	1.0820	8.2090	14.6950	8.0929	14.2826
+1571	1988.4645	170	1.3689	0.7104	0.9332	1.0820	8.2090	14.6950	8.1084	14.2769
+1572	1988.4672	171	1.3689	0.7103	0.9332	1.0820	8.2090	14.6950	8.1237	14.2721
+1573	1988.4699	172	1.3688	0.7103	0.9331	1.0820	8.2090	14.6950	8.1386	14.2683
+1574	1988.4727	173	1.3688	0.7103	0.9331	1.0820	8.2090	14.6950	8.1530	14.2656
+1575	1988.4754	174	1.3687	0.7103	0.9331	1.0820	8.2090	14.6950	8.1666	14.2639
+1576	1988.4781	175	1.3686	0.7103	0.9331	1.0820	8.2090	14.6950	8.1794	14.2632
+1577	1988.4809	176	1.3686	0.7102	0.9331	1.0820	8.2090	14.6950	8.1911	14.2635
+1578	1988.4836	177	1.3685	0.7102	0.9331	1.0820	8.2090	14.6950	8.2017	14.2648
+1579	1988.4863	178	1.3684	0.7102	0.9330	1.0820	8.2090	14.6950	8.2110	14.2671
+1580	1988.4891	179	1.3684	0.7102	0.9330	1.0820	8.2090	14.6950	8.2188	14.2704
+1581	1988.4918	180	1.3683	0.7101	0.9330	1.0820	8.2090	14.6950	8.2252	14.2745
+1582	1988.4945	181	1.3683	0.7101	0.9330	1.0820	8.2090	14.6950	8.2299	14.2795
+1583	1988.4973	182	1.3682	0.7101	0.9330	1.0820	8.2090	14.6950	8.2331	14.2853
+1584	1988.5000	183	1.3681	0.7101	0.9329	1.0820	8.2090	14.6950	8.2345	14.2919
+1585	1988.5027	184	1.3681	0.7100	0.9329	1.0820	8.2090	14.6950	8.2342	14.2993
+1586	1988.5055	185	1.3680	0.7100	0.9329	1.0820	8.2090	14.6950	8.2323	14.3072
+1587	1988.5082	186	1.3680	0.7100	0.9329	1.0820	8.2090	14.6950	8.2286	14.3158
+1588	1988.5109	187	1.3679	0.7100	0.9329	1.0820	8.2090	14.6950	8.2233	14.3249
+1589	1988.5137	188	1.3678	0.7100	0.9328	1.0820	8.2090	14.6950	8.2164	14.3345
+1590	1988.5164	189	1.3678	0.7099	0.9328	1.0820	8.2090	14.6950	8.2081	14.3445
+1591	1988.5191	190	1.3677	0.7099	0.9328	1.0820	8.2090	14.6950	8.1983	14.3547
+1592	1988.5219	191	1.3677	0.7099	0.9328	1.0820	8.2090	14.6950	8.1872	14.3653
+1593	1988.5246	192	1.3676	0.7099	0.9328	1.0820	8.2090	14.6950	8.1750	14.3760
+1594	1988.5273	193	1.3675	0.7098	0.9327	1.0820	8.2090	14.6950	8.1617	14.3868
+1595	1988.5301	194	1.3675	0.7098	0.9327	1.0820	8.2090	14.6950	8.1476	14.3976
+1596	1988.5328	195	1.3674	0.7098	0.9327	1.0820	8.2090	14.6950	8.1327	14.4083
+1597	1988.5355	196	1.3674	0.7098	0.9327	1.0820	8.2090	14.6950	8.1173	14.4189
+1598	1988.5383	197	1.3673	0.7098	0.9327	1.0820	8.2090	14.6950	8.1014	14.4292
+1599	1988.5410	198	1.3672	0.7097	0.9326	1.0820	8.2090	14.6950	8.0854	14.4393
+1600	1988.5437	199	1.3672	0.7097	0.9326	1.0820	8.2090	14.6950	8.0692	14.4489
+1601	1988.5464	200	1.3671	0.7097	0.9326	1.0820	8.2090	14.6950	8.0532	14.4582
+1602	1988.5492	201	1.3671	0.7097	0.9326	1.0820	8.2090	14.6950	8.0375	14.4669
+1603	1988.5519	202	1.3670	0.7096	0.9326	1.0820	8.2090	14.6950	8.0221	14.4750
+1604	1988.5546	203	1.3669	0.7096	0.9325	1.0820	8.2090	14.6950	8.0074	14.4825
+1605	1988.5574	204	1.3669	0.7096	0.9325	1.0820	8.2090	14.6950	7.9933	14.4892
+1606	1988.5601	205	1.3668	0.7096	0.9325	1.0820	8.2090	14.6950	7.9801	14.4952
+1607	1988.5628	206	1.3668	0.7095	0.9325	1.0820	8.2090	14.6950	7.9679	14.5004
+1608	1988.5656	207	1.3667	0.7095	0.9325	1.0820	8.2090	14.6950	7.9568	14.5048
+1609	1988.5683	208	1.3666	0.7095	0.9324	1.0820	8.2090	14.6950	7.9468	14.5083
+1610	1988.5710	209	1.3666	0.7095	0.9324	1.0820	8.2090	14.6950	7.9382	14.5108
+1611	1988.5738	210	1.3665	0.7095	0.9324	1.0820	8.2090	14.6950	7.9308	14.5124
+1612	1988.5765	211	1.3664	0.7094	0.9324	1.0820	8.2090	14.6950	7.9249	14.5130
+1613	1988.5792	212	1.3664	0.7094	0.9324	1.0820	8.2090	14.6950	7.9204	14.5126
+1614	1988.5820	213	1.3663	0.7094	0.9323	1.0820	8.2090	14.6950	7.9175	14.5112
+1615	1988.5847	214	1.3663	0.7094	0.9323	1.0820	8.2090	14.6950	7.9160	14.5089
+1616	1988.5874	215	1.3662	0.7093	0.9323	1.0820	8.2090	14.6950	7.9161	14.5055
+1617	1988.5902	216	1.3661	0.7093	0.9323	1.0820	8.2090	14.6950	7.9176	14.5012
+1618	1988.5929	217	1.3661	0.7093	0.9323	1.0820	8.2090	14.6950	7.9207	14.4959
+1619	1988.5956	218	1.3660	0.7093	0.9323	1.0820	8.2090	14.6950	7.9252	14.4896
+1620	1988.5984	219	1.3660	0.7093	0.9322	1.0820	8.2090	14.6950	7.9311	14.4824
+1621	1988.6011	220	1.3659	0.7092	0.9322	1.0820	8.2090	14.6950	7.9384	14.4744
+1622	1988.6038	221	1.3658	0.7092	0.9322	1.0820	8.2090	14.6950	7.9469	14.4655
+1623	1988.6066	222	1.3658	0.7092	0.9322	1.0820	8.2090	14.6950	7.9566	14.4558
+1624	1988.6093	223	1.3657	0.7092	0.9322	1.0820	8.2090	14.6950	7.9674	14.4454
+1625	1988.6120	224	1.3657	0.7091	0.9321	1.0820	8.2090	14.6950	7.9791	14.4342
+1626	1988.6148	225	1.3656	0.7091	0.9321	1.0820	8.2090	14.6950	7.9918	14.4224
+1627	1988.6175	226	1.3655	0.7091	0.9321	1.0820	8.2090	14.6950	8.0051	14.4101
+1628	1988.6202	227	1.3655	0.7091	0.9321	1.0820	8.2090	14.6950	8.0190	14.3972
+1629	1988.6230	228	1.3654	0.7091	0.9321	1.0820	8.2090	14.6950	8.0334	14.3839
+1630	1988.6257	229	1.3654	0.7090	0.9320	1.0820	8.2090	14.6950	8.0481	14.3702
+1631	1988.6284	230	1.3653	0.7090	0.9320	1.0820	8.2090	14.6950	8.2090	14.6950
+1632	1988.6311	231	1.3653	0.7090	0.9320	1.0820	8.2090	14.6950	8.1963	14.6944
+1633	1988.6339	232	1.3652	0.7090	0.9320	1.0820	8.2090	14.6950	8.1828	14.6928
+1634	1988.6366	233	1.3651	0.7089	0.9320	1.0820	8.2090	14.6950	8.1684	14.6902
+1635	1988.6393	234	1.3651	0.7089	0.9319	1.0820	8.2090	14.6950	8.1535	14.6866
+1636	1988.6421	235	1.3650	0.7089	0.9319	1.0820	8.2090	14.6950	8.1381	14.6820
+1637	1988.6448	236	1.3650	0.7089	0.9319	1.0820	8.2090	14.6950	8.1224	14.6765
+1638	1988.6475	237	1.3649	0.7089	0.9319	1.0820	8.2090	14.6950	8.1066	14.6701
+1639	1988.6503	238	1.3648	0.7088	0.9319	1.0820	8.2090	14.6950	8.0907	14.6627
+1640	1988.6530	239	1.3648	0.7088	0.9319	1.0820	8.2090	14.6950	8.0751	14.6545
+1641	1988.6557	240	1.3647	0.7088	0.9318	1.0820	8.2090	14.6950	8.0597	14.6454
+1642	1988.6585	241	1.3647	0.7088	0.9318	1.0820	8.2090	14.6950	8.0449	14.6355
+1643	1988.6612	242	1.3646	0.7087	0.9318	1.0820	8.2090	14.6950	8.0306	14.6249
+1644	1988.6639	243	1.3645	0.7087	0.9318	1.0820	8.2090	14.6950	8.0171	14.6136
+1645	1988.6667	244	1.3645	0.7087	0.9318	1.0820	8.2090	14.6950	8.0044	14.6017
+1646	1988.6694	245	1.3644	0.7087	0.9317	1.0820	8.2090	14.6950	7.9927	14.5892
+1647	1988.6721	246	1.3644	0.7087	0.9317	1.0820	8.2090	14.6950	7.9820	14.5762
+1648	1988.6749	247	1.3643	0.7086	0.9317	1.0820	8.2090	14.6950	7.9725	14.5627
+1649	1988.6776	248	1.3642	0.7086	0.9317	1.0820	8.2090	14.6950	7.9643	14.5489
+1650	1988.6803	249	1.3642	0.7086	0.9317	1.0820	8.2090	14.6950	7.9573	14.5348
+1651	1988.6831	250	1.3641	0.7086	0.9316	1.0820	8.2090	14.6950	7.9517	14.5204
+1652	1988.6858	251	1.3641	0.7085	0.9316	1.0820	8.2090	14.6950	7.9476	14.5058
+1653	1988.6885	252	1.3640	0.7085	0.9316	1.0820	8.2090	14.6950	7.9448	14.4911
+1654	1988.6913	253	1.3639	0.7085	0.9316	1.0820	8.2090	14.6950	7.9435	14.4764
+1655	1988.6940	254	1.3639	0.7085	0.9316	1.0820	8.2090	14.6950	7.9437	14.4617
+1656	1988.6967	255	1.3638	0.7084	0.9316	1.0820	8.2090	14.6950	7.9453	14.4472
+1657	1988.6995	256	1.3638	0.7084	0.9315	1.0820	8.2090	14.6950	7.9484	14.4328
+1658	1988.7022	257	1.3637	0.7084	0.9315	1.0820	8.2090	14.6950	7.9528	14.4187
+1659	1988.7049	258	1.3636	0.7084	0.9315	1.0820	8.2090	14.6950	7.9586	14.4048
+1660	1988.7077	259	1.3636	0.7084	0.9315	1.0820	8.2090	14.6950	7.9656	14.3914
+1661	1988.7104	260	1.3635	0.7083	0.9315	1.0820	8.2090	14.6950	7.9739	14.3783
+1662	1988.7131	261	1.3635	0.7083	0.9314	1.0820	8.2090	14.6950	7.9834	14.3658
+1663	1988.7158	262	1.3634	0.7083	0.9314	1.0820	8.2090	14.6950	7.9938	14.3538
+1664	1988.7186	263	1.3633	0.7083	0.9314	1.0820	8.2090	14.6950	8.0053	14.3423
+1665	1988.7213	264	1.3633	0.7082	0.9314	1.0820	8.2090	14.6950	8.0175	14.3315
+1666	1988.7240	265	1.3632	0.7082	0.9314	1.0820	8.2090	14.6950	8.0305	14.3214
+1667	1988.7268	266	1.3632	0.7082	0.9313	1.0820	8.2090	14.6950	8.0441	14.3120
+1668	1988.7295	267	1.3631	0.7082	0.9313	1.0820	8.2090	14.6950	8.0581	14.3034
+1669	1988.7322	268	1.3631	0.7082	0.9313	1.0820	8.2090	14.6950	8.0725	14.2955
+1670	1988.7350	269	1.3630	0.7081	0.9313	1.0820	8.2090	14.6950	8.0870	14.2885
+1671	1988.7377	270	1.3629	0.7081	0.9313	1.0820	8.2090	14.6950	8.1016	14.2823
+1672	1988.7404	271	1.3629	0.7081	0.9313	1.0820	8.2090	14.6950	8.1161	14.2769
+1673	1988.7432	272	1.3628	0.7081	0.9312	1.0820	8.2090	14.6950	8.1303	14.2725
+1674	1988.7459	273	1.3628	0.7080	0.9312	1.0820	8.2090	14.6950	8.1441	14.2688
+1675	1988.7486	274	1.3627	0.7080	0.9312	1.0820	8.2090	14.6950	8.1574	14.2661
+1676	1988.7514	275	1.3626	0.7080	0.9312	1.0820	8.2090	14.6950	8.1700	14.2643
+1677	1988.7541	276	1.3626	0.7080	0.9312	1.0820	8.2090	14.6950	8.1818	14.2633
+1678	1988.7568	277	1.3625	0.7080	0.9311	1.0820	8.2090	14.6950	8.1926	14.2632
+1679	1988.7596	278	1.3625	0.7079	0.9311	1.0820	8.2090	14.6950	8.2024	14.2640
+1680	1988.7623	279	1.3624	0.7079	0.9311	1.0820	8.2090	14.6950	8.2111	14.2656
+1681	1988.7650	280	1.3624	0.7079	0.9311	1.0820	8.2090	14.6950	8.2185	14.2681
+1682	1988.7678	281	1.3623	0.7079	0.9311	1.0820	8.2090	14.6950	8.2246	14.2713
+1683	1988.7705	282	1.3622	0.7079	0.9310	1.0820	8.2090	14.6950	8.2292	14.2753
+1684	1988.7732	283	1.3622	0.7078	0.9310	1.0820	8.2090	14.6950	8.2325	14.2801
+1685	1988.7760	284	1.3621	0.7078	0.9310	1.0820	8.2090	14.6950	8.2343	14.2855
+1686	1988.7787	285	1.3621	0.7078	0.9310	1.0820	8.2090	14.6950	8.2345	14.2916
+1687	1988.7814	286	1.3620	0.7078	0.9310	1.0820	8.2090	14.6950	8.2333	14.2984
+1688	1988.7842	287	1.3619	0.7077	0.9310	1.0820	8.2090	14.6950	8.2305	14.3057
+1689	1988.7869	288	1.3619	0.7077	0.9309	1.0820	8.2090	14.6950	8.2264	14.3135
+1690	1988.7896	289	1.3618	0.7077	0.9309	1.0820	8.2090	14.6950	8.2207	14.3218
+1691	1988.7923	290	1.3618	0.7077	0.9309	1.0820	8.2090	14.6950	8.2137	14.3305
+1692	1988.7951	291	1.3617	0.7077	0.9309	1.0820	8.2090	14.6950	8.2055	14.3396
+1693	1988.7978	292	1.3616	0.7076	0.9309	1.0820	8.2090	14.6950	8.1960	14.3489
+1694	1988.8005	293	1.3616	0.7076	0.9308	1.0820	8.2090	14.6950	8.1854	14.3586
+1695	1988.8033	294	1.3615	0.7076	0.9308	1.0820	8.2090	14.6950	8.1737	14.3684
+1696	1988.8060	295	1.3615	0.7076	0.9308	1.0820	8.2090	14.6950	8.1612	14.3783
+1697	1988.8087	296	1.3614	0.7075	0.9308	1.0820	8.2090	14.6950	8.1479	14.3883
+1698	1988.8115	297	1.3614	0.7075	0.9308	1.0820	8.2090	14.6950	8.1340	14.3983
+1699	1988.8142	298	1.3613	0.7075	0.9308	1.0820	8.2090	14.6950	8.1196	14.4083
+1700	1988.8169	299	1.3612	0.7075	0.9307	1.0820	8.2090	14.6950	8.1048	14.4181
+1701	1988.8197	300	1.3612	0.7075	0.9307	1.0820	8.2090	14.6950	8.0897	14.4277
+1702	1988.8224	301	1.3611	0.7074	0.9307	1.0820	8.2090	14.6950	8.0746	14.4370
+1703	1988.8251	302	1.3611	0.7074	0.9307	1.0820	8.2090	14.6950	8.0595	14.4461
+1704	1988.8279	303	1.3610	0.7074	0.9307	1.0820	8.2090	14.6950	8.0446	14.4548
+1705	1988.8306	304	1.3610	0.7074	0.9306	1.0820	8.2090	14.6950	8.0300	14.4631
+1706	1988.8333	305	1.3609	0.7073	0.9306	1.0820	8.2090	14.6950	8.0158	14.4709
+1707	1988.8361	306	1.3608	0.7073	0.9306	1.0820	8.2090	14.6950	8.0022	14.4781
+1708	1988.8388	307	1.3608	0.7073	0.9306	1.0820	8.2090	14.6950	7.9892	14.4848
+1709	1988.8415	308	1.3607	0.7073	0.9306	1.0820	8.2090	14.6950	7.9771	14.4909
+1710	1988.8443	309	1.3607	0.7073	0.9306	1.0820	8.2090	14.6950	7.9658	14.4963
+1711	1988.8470	310	1.3606	0.7072	0.9305	1.0820	8.2090	14.6950	7.9555	14.5010
+1712	1988.8497	311	1.3605	0.7072	0.9305	1.0820	8.2090	14.6950	7.9463	14.5050
+1713	1988.8525	312	1.3605	0.7072	0.9305	1.0820	8.2090	14.6950	7.9382	14.5082
+1714	1988.8552	313	1.3604	0.7072	0.9305	1.0820	8.2090	14.6950	7.9312	14.5106
+1715	1988.8579	314	1.3604	0.7071	0.9305	1.0820	8.2090	14.6950	7.9256	14.5122
+1716	1988.8607	315	1.3603	0.7071	0.9304	1.0820	8.2090	14.6950	7.9212	14.5129
+1717	1988.8634	316	1.3603	0.7071	0.9304	1.0820	8.2090	14.6950	7.9181	14.5128
+1718	1988.8661	317	1.3602	0.7071	0.9304	1.0820	8.2090	14.6950	7.9163	14.5119
+1719	1988.8689	318	1.3601	0.7071	0.9304	1.0820	8.2090	14.6950	7.9159	14.5101
+1720	1988.8716	319	1.3601	0.7070	0.9304	1.0820	8.2090	14.6950	7.9168	14.5075
+1721	1988.8743	320	1.3600	0.7070	0.9304	1.0820	8.2090	14.6950	7.9190	14.5040
+1722	1988.8770	321	1.3600	0.7070	0.9303	1.0820	8.2090	14.6950	8.2090	14.6950
+1723	1988.8798	322	1.3599	0.7070	0.9303	1.0820	8.2090	14.6950	8.1970	14.6945
+1724	1988.8825	323	1.3599	0.7070	0.9303	1.0820	8.2090	14.6950	8.1843	14.6930
+1725	1988.8852	324	1.3598	0.7069	0.9303	1.0820	8.2090	14.6950	8.1708	14.6908
+1726	1988.8880	325	1.3597	0.7069	0.9303	1.0820	8.2090	14.6950	8.1567	14.6876
+1727	1988.8907	326	1.3597	0.7069	0.9303	1.0820	8.2090	14.6950	8.1422	14.6836
+1728	1988.8934	327	1.3596	0.7069	0.9302	1.0820	8.2090	14.6950	8.1275	14.6788
+1729	1988.8962	328	1.3596	0.7068	0.9302	1.0820	8.2090	14.6950	8.1125	14.6731
+1730	1988.8989	329	1.3595	0.7068	0.9302	1.0820	8.2090	14.6950	8.0975	14.6666
+1731	1988.9016	330	1.3594	0.7068	0.9302	1.0820	8.2090	14.6950	8.0826	14.6593
+1732	1988.9044	331	1.3594	0.7068	0.9302	1.0820	8.2090	14.6950	8.0679	14.6513
+1733	1988.9071	332	1.3593	0.7068	0.9301	1.0820	8.2090	14.6950	8.0536	14.6426
+1734	1988.9098	333	1.3593	0.7067	0.9301	1.0820	8.2090	14.6950	8.0397	14.6331
+1735	1988.9126	334	1.3592	0.7067	0.9301	1.0820	8.2090	14.6950	8.0264	14.6231
+1736	1988.9153	335	1.3592	0.7067	0.9301	1.0820	8.2090	14.6950	8.0138	14.6124
+1737	1988.9180	336	1.3591	0.7067	0.9301	1.0820	8.2090	14.6950	8.0020	14.6012
+1738	1988.9208	337	1.3590	0.7066	0.9301	1.0820	8.2090	14.6950	7.9911	14.5895
+1739	1988.9235	338	1.3590	0.7066	0.9300	1.0820	8.2090	14.6950	7.9811	14.5774
+1740	1988.9262	339	1.3589	0.7066	0.9300	1.0820	8.2090	14.6950	7.9722	14.5648
+1741	1988.9290	340	1.3589	0.7066	0.9300	1.0820	8.2090	14.6950	7.9644	14.5519
+1742	1988.9317	341	1.3588	0.7066	0.9300	1.0820	8.2090	14.6950	7.9578	14.5387
+1743	1988.9344	342	1.3588	0.7065	0.9300	1.0820	8.2090	14.6950	7.9524	14.5253
+1744	1988.9372	343	1.3587	0.7065	0.9299	1.0820	8.2090	14.6950	7.9482	14.5117
+1745	1988.9399	344	1.3586	0.7065	0.9299	1.0820	8.2090	14.6950	7.9453	14.4980
+1746	1988.9426	345	1.3586	0.7065	0.9299	1.0820	8.2090	14.6950	7.9438	14.4843
+1747	1988.9454	346	1.3585	0.7064	0.9299	1.0820	8.2090	14.6950	7.9435	14.4705
+1748	1988.9481	347	1.3585	0.7064	0.9299	1.0820	8.2090	14.6950	7.9445	14.4568
+1749	1988.9508	348	1.3584	0.7064	0.9299	1.0820	8.2090	14.6950	7.9468	14.4432
+1750	1988.9536	349	1.3584	0.7064	0.9298	1.0820	8.2090	14.6950	7.9504	14.4298
+1751	1988.9563	350	1.3583	0.7064	0.9298	1.0820	8.2090	14.6950	7.9552	14.4166
+1752	1988.9590	351	1.3582	0.7063	0.9298	1.0820	8.2090	14.6950	7.9612	14.4037
+1753	1988.9617	352	1.3582	0.7063	0.9298	1.0820	8.2090	14.6950	7.9683	14.3911
+1754	1988.9645	353	1.3581	0.7063	0.9298	1.0820	8.2090	14.6950	7.9765	14.3789
+1755	1988.9672	354	1.3581	0.7063	0.9298	1.0820	8.2090	14.6950	7.9857	14.3671
+1756	1988.9699	355	1.3580	0.7063	0.9297	1.0820	8.2090	14.6950	7.9958	14.3558
+1757	1988.9727	356	1.3580	0.7062	0.9297	1.0820	8.2090	14.6950	8.0067	14.3450
+1758	1988.9754	357	1.3579	0.7062	0.9297	1.0820	8.2090	14.6950	8.0184	14.3347
+1759	1988.9781	358	1.3578	0.7062	0.9297	1.0820	8.2090	14.6950	8.0307	14.3250
+1760	1988.9809	359	1.3578	0.7062	0.9297	1.0820	8.2090	14.6950	8.0436	14.3160
+1761	1988.9836	360	1.3577	0.7061	0.9296	1.0820	8.2090	14.6950	8.0568	14.3076
+1762	1988.9863	361	1.3577	0.7061	0.9296	1.0820	8.2090	14.6950	8.0704	14.2998
+1763	1988.9891	362	1.3576	0.7061	0.9296	1.0820	8.2090	14.6950	8.0841	14.2928
+1764	1988.9918	363	1.3576	0.7061	0.9296	1.0820	8.2090	14.6950	8.0979	14.2864
+1765	1988.9945	364	1.3575	0.7061	0.9296	1.0820	8.2090	14.6950	8.1117	14.2809
+1766	1988.9973	365	1.3574	0.7060	0.9296	1.0820	8.2090	14.6950	8.1252	14.2760
+1767	1988.9999	366	1.3574	0.7060	0.9295	1.0820	8.2090	14.6950	8.1385	14.2720
+1768	1989.0027	1	1.3573	0.7060	0.9295	1.0820	8.2090	14.6950	8.1513	14.2687
+1769	1989.0055	2	1.3573	0.7060	0.9295	1.0820	8.2090	14.6950	8.1635	14.2661
+1770	1989.0082	3	1.3572	0.7060	0.9295	1.0820	8.2090	14.6950	8.1751	14.2644
+1771	1989.0110	4	1.3572	0.7059	0.9295	1.0820	8.2090	14.6950	8.1859	14.2634
+1772	1989.0137	5	1.3571	0.7059	0.9295	1.0820	8.2090	14.6950	8.1959	14.2632
+1773	1989.0164	6	1.3571	0.7059	0.9294	1.0820	8.2090	14.6950	8.2048	14.2637
+1774	1989.0192	7	1.3570	0.7059	0.9294	1.0820	8.2090	14.6950	8.2128	14.2650
+1775	1989.0219	8	1.3569	0.7058	0.9294	1.0820	8.2090	14.6950	8.2195	14.2670
+1776	1989.0247	9	1.3569	0.7058	0.9294	1.0820	8.2090	14.6950	8.2251	14.2698
+1777	1989.0274	10	1.3568	0.7058	0.9294	1.0820	8.2090	14.6950	8.2295	14.2732
+1778	1989.0301	11	1.3568	0.7058	0.9294	1.0820	8.2090	14.6950	8.2325	14.2772
+1779	1989.0329	12	1.3567	0.7058	0.9293	1.0820	8.2090	14.6950	8.2342	14.2819
+1780	1989.0356	13	1.3567	0.7057	0.9293	1.0820	8.2090	14.6950	8.2346	14.2872
+1781	1989.0384	14	1.3566	0.7057	0.9293	1.0820	8.2090	14.6950	8.2336	14.2931
+1782	1989.0411	15	1.3565	0.7057	0.9293	1.0820	8.2090	14.6950	8.2313	14.2995
+1783	1989.0438	16	1.3565	0.7057	0.9293	1.0820	8.2090	14.6950	8.2276	14.3064
+1784	1989.0466	17	1.3564	0.7057	0.9292	1.0820	8.2090	14.6950	8.2227	14.3138
+1785	1989.0493	18	1.3564	0.7056	0.9292	1.0820	8.2090	14.6950	8.2165	14.3215
+1786	1989.0521	19	1.3563	0.7056	0.9292	1.0820	8.2090	14.6950	8.2092	14.3297
+1787	1989.0548	20	1.3563	0.7056	0.9292	1.0820	8.2090	14.6950	8.2007	14.3381
+1788	1989.0575	21	1.3562	0.7056	0.9292	1.0820	8.2090	14.6950	8.1912	14.3469
+1789	1989.0603	22	1.3561	0.7055	0.9292	1.0820	8.2090	14.6950	8.1807	14.3558
+1790	1989.0630	23	1.3561	0.7055	0.9291	1.0820	8.2090	14.6950	8.1694	14.3650
+1791	1989.0658	24	1.3560	0.7055	0.9291	1.0820	8.2090	14.6950	8.1573	14.3742
+1792	1989.0685	25	1.3560	0.7055	0.9291	1.0820	8.2090	14.6950	8.1445	14.3836
+1793	1989.0712	26	1.3559	0.7055	0.9291	1.0820	8.2090	14.6950	8.1312	14.3929
+1794	1989.0740	27	1.3559	0.7054	0.9291	1.0820	8.2090	14.6950	8.1175	14.4023
+1795	1989.0767	28	1.3558	0.7054	0.9291	1.0820	8.2090	14.6950	8.1035	14.4115
+1796	1989.0795	29	1.3558	0.7054	0.9290	1.0820	8.2090	14.6950	8.0892	14.4207
+1797	1989.0822	30	1.3557	0.7054	0.9290	1.0820	8.2090	14.6950	8.0749	14.4296
+1798	1989.0849	31	1.3556	0.7054	0.9290	1.0820	8.2090	14.6950	8.0606	14.4383
+1799	1989.0877	32	1.3556	0.7053	0.9290	1.0820	8.2090	14.6950	8.0464	14.4468
+1800	1989.0904	33	1.3555	0.7053	0.9290	1.0820	8.2090	14.6950	8.0326	14.4549
+1801	1989.0932	34	1.3555	0.7053	0.9290	1.0820	8.2090	14.6950	8.0191	14.4627
+1802	1989.0959	35	1.3554	0.7053	0.9289	1.0820	8.2090	14.6950	8.0060	14.4700
+1803	1989.0986	36	1.3554	0.7052	0.9289	1.0820	8.2090	14.6950	7.9936	14.4769
+1804	1989.1014	37	1.3553	0.7052	0.9289	1.0820	8.2090	14.6950	7.9818	14.4833
+1805	1989.1041	38	1.3552	0.7052	0.9289	1.0820	8.2090	14.6950	7.9708	14.4891
+1806	1989.1068	39	1.3552	0.7052	0.9289	1.0820	8.2090	14.6950	7.9606	14.4944
+1807	1989.1096	40	1.3551	0.7052	0.9289	1.0820	8.2090	14.6950	7.9513	14.4990
+1808	1989.1123	41	1.3551	0.7051	0.9288	1.0820	8.2090	14.6950	7.9430	14.5031
+1809	1989.1151	42	1.3550	0.7051	0.9288	1.0820	8.2090	14.6950	7.9357	14.5065
+1810	1989.1178	43	1.3550	0.7051	0.9288	1.0820	8.2090	14.6950	7.9295	14.5092
+1811	1989.1205	44	1.3549	0.7051	0.9288	1.0820	8.2090	14.6950	7.9244	14.5112
+1812	1989.1233	45	1.3549	0.7051	0.9288	1.0820	8.2090	14.6950	7.9205	14.5124
+1813	1989.1260	46	1.3548	0.7050	0.9288	1.0820	8.2090	14.6950	7.9178	14.5130
+1814	1989.1288	47	1.3547	0.7050	0.9287	1.0820	8.2090	14.6950	7.9162	14.5128
+1815	1989.1315	48	1.3547	0.7050	0.9287	1.0820	8.2090	14.6950	7.9159	14.5118
+1816	1989.1342	49	1.3546	0.7050	0.9287	1.0820	8.2090	14.6950	7.9167	14.5101
+1817	1989.1370	50	1.3546	0.7049	0.9287	1.0820	8.2090	14.6950	7.9188	14.5077
+1818	1989.1397	51	1.3545	0.7049	0.9287	1.0820	8.2090	14.6950	7.9220	14.5045
+1819	1989.1425	52	1.3545	0.7049	0.9286	1.0820	8.2090	14.6950	7.9263	14.5006
+1820	1989.1452	53	1.3544	0.7049	0.9286	1.0820	8.2090	14.6950	7.9317	14.4959
+1821	1989.1479	54	1.3544	0.7049	0.9286	1.0820	8.2090	14.6950	7.9382	14.4906
+1822	1989.1507	55	1.3543	0.7048	0.9286	1.0820	8.2090	14.6950	7.9457	14.4845
+1823	1989.1534	56	1.3542	0.7048	0.9286	1.0820	8.2090	14.6950	7.9541	14.4778
+1824	1989.1562	57	1.3542	0.7048	0.9286	1.0820	8.2090	14.6950	7.9634	14.4704
+1825	1989.1589	58	1.3541	0.7048	0.9285	1.0820	8.2090	14.6950	7.9735	14.4625
+1826	1989.1616	59	1.3541	0.7048	0.9285	1.0820	8.2090	14.6950	7.9844	14.4539
+1827	1989.1644	60	1.3540	0.7047	0.9285	1.0820	8.2090	14.6950	7.9958	14.4447
+1828	1989.1671	61	1.3540	0.7047	0.9285	1.0820	8.2090	14.6950	8.0078	14.4351
+1829	1989.1699	62	1.3539	0.7047	0.9285	1.0820	8.2090	14.6950	8.0203	14.4250
+1830	1989.1726	63	1.3539	0.7047	0.9285	1.0820	8.2090	14.6950	8.0330	14.4144
+1831	1989.1753	64	1.3538	0.7046	0.9284	1.0820	8.2090	14.6950	8.0461	14.4034
+1832	1989.1781	65	1.3537	0.7046	0.9284	1.0820	8.2090	14.6950	8.0592	14.3920
+1833	1989.1808	66	1.3537	0.7046	0.9284	1.0820	8.2090	14.6950	8.0724	14.3803
+1834	1989.1836	67	1.3536	0.7046	0.9284	1.0820	8.2090	14.6950	8.0855	14.3684
+1835	1989.1863	68	1.3536	0.7046	0.9284	1.0820	8.2090	14.6950	8.0984	14.3562
+1836	1989.1890	69	1.3535	0.7045	0.9284	1.0820	8.2090	14.6950	8.1110	14.3438
+1837	1989.1918	70	1.3535	0.7045	0.9283	1.0820	8.2090	14.6950	8.1232	14.3313
+1838	1989.1945	71	1.3534	0.7045	0.9283	1.0820	8.2090	14.6950	8.1349	14.3188
+1839	1989.1973	72	1.3534	0.7045	0.9283	1.0820	8.2090	14.6950	8.1459	14.3061
+1840	1989.2000	73	1.3533	0.7045	0.9283	1.0820	8.2090	14.6950	8.1562	14.2935
+1841	1989.2027	74	1.3532	0.7044	0.9283	1.0820	8.2090	14.6950	8.1658	14.2809
+1842	1989.2055	75	1.3532	0.7044	0.9283	1.0820	8.2090	14.6950	8.1744	14.2684
+1843	1989.2082	76	1.3531	0.7044	0.9282	1.0820	8.2090	14.6950	8.1821	14.2561
+1844	1989.2110	77	1.3531	0.7044	0.9282	1.0820	8.2090	14.6950	8.1888	14.2439
+1845	1989.2137	78	1.3530	0.7043	0.9282	1.0820	8.2090	14.6950	8.1944	14.2320
+1846	1989.2164	79	1.3530	0.7043	0.9282	1.0820	8.2090	14.6950	8.1988	14.2203
+1847	1989.2192	80	1.3529	0.7043	0.9282	1.0820	8.2090	14.6950	8.2021	14.2089
+1848	1989.2219	81	1.3529	0.7043	0.9282	1.0820	8.2090	14.6950	8.2041	14.1979
+1849	1989.2247	82	1.3528	0.7043	0.9281	1.0820	8.2090	14.6950	8.2049	14.1873
+1850	1989.2274	83	1.3527	0.7042	0.9281	1.0820	8.2090	14.6950	8.2045	14.1771
+1851	1989.2301	84	1.3527	0.7042	0.9281	1.0820	8.2090	14.6950	8.2028	14.1673
+1852	1989.2329	85	1.3526	0.7042	0.9281	1.0820	8.2090	14.6950	8.1999	14.1580
+1853	1989.2356	86	1.3526	0.7042	0.9281	1.0820	8.2090	14.6950	8.1959	14.1493
+1854	1989.2384	87	1.3525	0.7042	0.9281	1.0820	8.2090	14.6950	8.1906	14.1410
+1855	1989.2411	88	1.3525	0.7041	0.9280	1.0820	8.2090	14.6950	8.2090	14.6950
+1856	1989.2438	89	1.3524	0.7041	0.9280	1.0820	8.2090	14.6950	8.1979	14.6945
+1857	1989.2466	90	1.3524	0.7041	0.9280	1.0820	8.2090	14.6950	8.1862	14.6933
+1858	1989.2493	91	1.3523	0.7041	0.9280	1.0820	8.2090	14.6950	8.1738	14.6914
+1859	1989.2521	92	1.3522	0.7041	0.9280	1.0820	8.2090	14.6950	8.1609	14.6888
+1860	1989.2548	93	1.3522	0.7040	0.9280	1.0820	8.2090	14.6950	8.1476	14.6854
+1861	1989.2575	94	1.3521	0.7040	0.9280	1.0820	8.2090	14.6950	8.1339	14.6813
+1862	1989.2603	95	1.3521	0.7040	0.9279	1.0820	8.2090	14.6950	8.1201	14.6766
+1863	1989.2630	96	1.3520	0.7040	0.9279	1.0820	8.2090	14.6950	8.1062	14.6711
+1864	1989.2658	97	1.3520	0.7039	0.9279	1.0820	8.2090	14.6950	8.0923	14.6650
+1865	1989.2685	98	1.3519	0.7039	0.9279	1.0820	8.2090	14.6950	8.0786	14.6582
+1866	1989.2712	99	1.3519	0.7039	0.9279	1.0820	8.2090	14.6950	8.0650	14.6508
+1867	1989.2740	100	1.3518	0.7039	0.9279	1.0820	8.2090	14.6950	8.0518	14.6428
+1868	1989.2767	101	1.3518	0.7039	0.9278	1.0820	8.2090	14.6950	8.0389	14.6342
+1869	1989.2795	102	1.3517	0.7038	0.9278	1.0820	8.2090	14.6950	8.0266	14.6251
+1870	1989.2822	103	1.3516	0.7038	0.9278	1.0820	8.2090	14.6950	8.0149	14.6155
+1871	1989.2849	104	1.3516	0.7038	0.9278	1.0820	8.2090	14.6950	8.0039	14.6054
+1872	1989.2877	105	1.3515	0.7038	0.9278	1.0820	8.2090	14.6950	7.9936	14.5949
+1873	1989.2904	106	1.3515	0.7038	0.9278	1.0820	8.2090	14.6950	7.9841	14.5839
+1874	1989.2932	107	1.3514	0.7037	0.9277	1.0820	8.2090	14.6950	7.9755	14.5727
+1875	1989.2959	108	1.3514	0.7037	0.9277	1.0820	8.2090	14.6950	7.9678	14.5611
+1876	1989.2986	109	1.3513	0.7037	0.9277	1.0820	8.2090	14.6950	7.9611	14.5492
+1877	1989.3014	110	1.3513	0.7037	0.9277	1.0820	8.2090	14.6950	7.9555	14.5371
+1878	1989.3041	111	1.3512	0.7037	0.9277	1.0820	8.2090	14.6950	7.9509	14.5248
+1879	1989.3068	112	1.3512	0.7036	0.9277	1.0820	8.2090	14.6950	7.9473	14.5124
+1880	1989.3096	113	1.3511	0.7036	0.9276	1.0820	8.2090	14.6950	7.9449	14.4999
+1881	1989.3123	114	1.3510	0.7036	0.9276	1.0820	8.2090	14.6950	7.9437	14.4873
+1882	1989.3151	115	1.3510	0.7036	0.9276	1.0820	8.2090	14.6950	7.9435	14.4747
+1883	1989.3178	116	1.3509	0.7036	0.9276	1.0820	8.2090	14.6950	7.9444	14.4622
+1884	1989.3205	117	1.3509	0.7035	0.9276	1.0820	8.2090	14.6950	7.9465	14.4497
+1885	1989.3233	118	1.3508	0.7035	0.9276	1.0820	8.2090	14.6950	7.9497	14.4374
+1886	1989.3260	119	1.3508	0.7035	0.9275	1.0820	8.2090	14.6950	7.9539	14.4252
+1887	1989.3288	120	1.3507	0.7035	0.9275	1.0820	8.2090	14.6950	7.9591	14.4132
+1888	1989.3315	121	1.3507	0.7034	0.9275	1.0820	8.2090	14.6950	7.9653	14.4014
+1889	1989.3342	122	1.3506	0.7034	0.9275	1.0820	8.2090	14.6950	7.9725	14.3900
+1890	1989.3370	123	1.3506	0.7034	0.9275	1.0820	8.2090	14.6950	7.9806	14.3788
+1891	1989.3397	124	1.3505	0.7034	0.9275	1.0820	8.2090	14.6950	7.9895	14.3680
+1892	1989.3425	125	1.3504	0.7034	0.9274	1.0820	8.2090	14.6950	7.9991	14.3576
+1893	1989.3452	126	1.3504	0.7033	0.9274	1.0820	8.2090	14.6950	8.0095	14.3476
+1894	1989.3479	127	1.3503	0.7033	0.9274	1.0820	8.2090	14.6950	8.0204	14.3381
+1895	1989.3507	128	1.3503	0.7033	0.9274	1.0820	8.2090	14.6950	8.0319	14.3290
+1896	1989.3534	129	1.3502	0.7033	0.9274	1.0820	8.2090	14.6950	8.0439	14.3205
+1897	1989.3562	130	1.3502	0.7033	0.9274	1.0820	8.2090	14.6950	8.0561	14.3124
+1898	1989.3589	131	1.3501	0.7032	0.9273	1.0820	8.2090	14.6950	8.0687	14.3050
+1899	1989.3616	132	1.3501	0.7032	0.9273	1.0820	8.2090	14.6950	8.0814	14.2981
+1900	1989.3644	133	1.3500	0.7032	0.9273	1.0820	8.2090	14.6950	8.0942	14.2917
+1901	1989.3671	134	1.3500	0.7032	0.9273	1.0820	8.2090	14.6950	8.1070	14.2860
+1902	1989.3699	135	1.3499	0.7032	0.9273	1.0820	8.2090	14.6950	8.1197	14.2809
+1903	1989.3726	136	1.3499	0.7031	0.9273	1.0820	8.2090	14.6950	8.1321	14.2765
+1904	1989.3753	137	1.3498	0.7031	0.9273	1.0820	8.2090	14.6950	8.1442	14.2727
+1905	1989.3781	138	1.3497	0.7031	0.9272	1.0820	8.2090	14.6950	8.1559	14.2695
+1906	1989.3808	139	1.3497	0.7031	0.9272	1.0820	8.2090	14.6950	8.1670	14.2670
+1907	1989.3836	140	1.3496	0.7031	0.9272	1.0820	8.2090	14.6950	8.1776	14.2651
+1908	1989.3863	141	1.3496	0.7030	0.9272	1.0820	8.2090	14.6950	8.1875	14.2638
+1909	1989.3890	142	1.3495	0.7030	0.9272	1.0820	8.2090	14.6950	8.1966	14.2632
+1910	1989.3918	143	1.3495	0.7030	0.9272	1.0820	8.2090	14.6950	8.2049	14.2633
+1911	1989.3945	144	1.3494	0.7030	0.9271	1.0820	8.2090	14.6950	8.2123	14.2639
+1912	1989.3973	145	1.3494	0.7029	0.9271	1.0820	8.2090	14.6950	8.2187	14.2652
+1913	1989.4000	146	1.3493	0.7029	0.9271	1.0820	8.2090	14.6950	8.2240	14.2671
+1914	1989.4027	147	1.3493	0.7029	0.9271	1.0820	8.2090	14.6950	8.2283	14.2696
+1915	1989.4055	148	1.3492	0.7029	0.9271	1.0820	8.2090	14.6950	8.2315	14.2727
+1916	1989.4082	149	1.3492	0.7029	0.9271	1.0820	8.2090	14.6950	8.2336	14.2763
+1917	1989.4110	150	1.3491	0.7028	0.9270	1.0820	8.2090	14.6950	8.2345	14.2805
+1918	1989.4137	151	1.3490	0.7028	0.9270	1.0820	8.2090	14.6950	8.2343	14.2851
+1919	1989.4164	152	1.3490	0.7028	0.9270	1.0820	8.2090	14.6950	8.2329	14.2903
+1920	1989.4192	153	1.3489	0.7028	0.9270	1.0820	8.2090	14.6950	8.2304	14.2959
+1921	1989.4219	154	1.3489	0.7028	0.9270	1.0820	8.2090	14.6950	8.2267	14.3019
+1922	1989.4247	155	1.3488	0.7027	0.9270	1.0820	8.2090	14.6950	8.2220	14.3084
+1923	1989.4274	156	1.3488	0.7027	0.9270	1.0820	8.2090	14.6950	8.2161	14.3152
+1924	1989.4301	157	1.3487	0.7027	0.9269	1.0820	8.2090	14.6950	8.2093	14.3224
+1925	1989.4329	158	1.3487	0.7027	0.9269	1.0820	8.2090	14.6950	8.2015	14.3298
+1926	1989.4356	159	1.3486	0.7027	0.9269	1.0820	8.2090	14.6950	8.1928	14.3375
+1927	1989.4384	160	1.3486	0.7026	0.9269	1.0820	8.2090	14.6950	8.1832	14.3455
+1928	1989.4411	161	1.3485	0.7026	0.9269	1.0820	8.2090	14.6950	8.1729	14.3537
+1929	1989.4438	162	1.3485	0.7026	0.9269	1.0820	8.2090	14.6950	8.1619	14.3620
+1930	1989.4466	163	1.3484	0.7026	0.9268	1.0820	8.2090	14.6950	8.1503	14.3704
+1931	1989.4493	164	1.3484	0.7026	0.9268	1.0820	8.2090	14.6950	8.1382	14.3789
+1932	1989.4521	165	1.3483	0.7025	0.9268	1.0820	8.2090	14.6950	8.1257	14.3875
+1933	1989.4548	166	1.3482	0.7025	0.9268	1.0820	8.2090	14.6950	8.1128	14.3961
+1934	1989.4575	167	1.3482	0.7025	0.9268	1.0820	8.2090	14.6950	8.0998	14.4046
+1935	1989.4603	168	1.3481	0.7025	0.9268	1.0820	8.2090	14.6950	8.0865	14.4130
+1936	1989.4630	169	1.3481	0.7025	0.9267	1.0820	8.2090	14.6950	8.0732	14.4214
+1937	1989.4658	170	1.3480	0.7024	0.9267	1.0820	8.2090	14.6950	8.0600	14.4296
+1938	1989.4685	171	1.3480	0.7024	0.9267	1.0820	8.2090	14.6950	8.0469	14.4375
+1939	1989.4712	172	1.3479	0.7024	0.9267	1.0820	8.2090	14.6950	8.0340	14.4453
+1940	1989.4740	173	1.3479	0.7024	0.9267	1.0820	8.2090	14.6950	8.0214	14.4528
+1941	1989.4767	174	1.3478	0.7023	0.9267	1.0820	8.2090	14.6950	8.0092	14.4600
+1942	1989.4795	175	1.3478	0.7023	0.9267	1.0820	8.2090	14.6950	7.9975	14.4669
+1943	1989.4822	176	1.3477	0.7023	0.9266	1.0820	8.2090	14.6950	7.9863	14.4734
+1944	1989.4849	177	1.3477	0.7023	0.9266	1.0820	8.2090	14.6950	7.9758	14.4794
+1945	1989.4877	178	1.3476	0.7023	0.9266	1.0820	8.2090	14.6950	7.9659	14.4851
+1946	1989.4904	179	1.3476	0.7022	0.9266	1.0820	8.2090	14.6950	7.9568	14.4903
+1947	1989.4932	180	1.3475	0.7022	0.9266	1.0820	8.2090	14.6950	7.9485	14.4950
+1948	1989.4959	181	1.3474	0.7022	0.9266	1.0820	8.2090	14.6950	7.9411	14.4993
+1949	1989.4986	182	1.3474	0.7022	0.9265	1.0820	8.2090	14.6950	7.9346	14.5030
+1950	1989.5014	183	1.3473	0.7022	0.9265	1.0820	8.2090	14.6950	7.9290	14.5061
+1951	1989.5041	184	1.3473	0.7021	0.9265	1.0820	8.2090	14.6950	7.9243	14.5087
+1952	1989.5068	185	1.3472	0.7021	0.9265	1.0820	8.2090	14.6950	7.9207	14.5106
+1953	1989.5096	186	1.3472	0.7021	0.9265	1.0820	8.2090	14.6950	7.9180	14.5120
+1954	1989.5123	187	1.3471	0.7021	0.9265	1.0820	8.2090	14.6950	7.9164	14.5128
+1955	1989.5151	188	1.3471	0.7021	0.9265	1.0820	8.2090	14.6950	7.9159	14.5130
+1956	1989.5178	189	1.3470	0.7020	0.9264	1.0820	8.2090	14.6950	7.9163	14.5125
+1957	1989.5205	190	1.3470	0.7020	0.9264	1.0820	8.2090	14.6950	7.9178	14.5114
+1958	1989.5233	191	1.3469	0.7020	0.9264	1.0820	8.2090	14.6950	7.9203	14.5097
+1959	1989.5260	192	1.3469	0.7020	0.9264	1.0820	8.2090	14.6950	7.9238	14.5074
+1960	1989.5288	193	1.3468	0.7020	0.9264	1.0820	8.2090	14.6950	8.2090	14.6950
+1961	1989.5315	194	1.3468	0.7019	0.9264	1.0820	8.2090	14.6950	8.1986	14.6946
+1962	1989.5342	195	1.3467	0.7019	0.9263	1.0820	8.2090	14.6950	8.1875	14.6935
+1963	1989.5370	196	1.3467	0.7019	0.9263	1.0820	8.2090	14.6950	8.1758	14.6919
+1964	1989.5397	197	1.3466	0.7019	0.9263	1.0820	8.2090	14.6950	8.1637	14.6895
+1965	1989.5425	198	1.3465	0.7019	0.9263	1.0820	8.2090	14.6950	8.1512	14.6866
+1966	1989.5452	199	1.3465	0.7018	0.9263	1.0820	8.2090	14.6950	8.1384	14.6830
+1967	1989.5479	200	1.3464	0.7018	0.9263	1.0820	8.2090	14.6950	8.1254	14.6788
+1968	1989.5507	201	1.3464	0.7018	0.9263	1.0820	8.2090	14.6950	8.1123	14.6740
+1969	1989.5534	202	1.3463	0.7018	0.9262	1.0820	8.2090	14.6950	8.0991	14.6685
+1970	1989.5562	203	1.3463	0.7018	0.9262	1.0820	8.2090	14.6950	8.0860	14.6625
+1971	1989.5589	204	1.3462	0.7017	0.9262	1.0820	8.2090	14.6950	8.0731	14.6560
+1972	1989.5616	205	1.3462	0.7017	0.9262	1.0820	8.2090	14.6950	8.0603	14.6489
+1973	1989.5644	206	1.3461	0.7017	0.9262	1.0820	8.2090	14.6950	8.0479	14.6413
+1974	1989.5671	207	1.3461	0.7017	0.9262	1.0820	8.2090	14.6950	8.0359	14.6332
+1975	1989.5699	208	1.3460	0.7017	0.9261	1.0820	8.2090	14.6950	8.0244	14.6246
+1976	1989.5726	209	1.3460	0.7016	0.9261	1.0820	8.2090	14.6950	8.0134	14.6156
+1977	1989.5753	210	1.3459	0.7016	0.9261	1.0820	8.2090	14.6950	8.0030	14.6062
+1978	1989.5781	211	1.3459	0.7016	0.9261	1.0820	8.2090	14.6950	7.9933	14.5963
+1979	1989.5808	212	1.3458	0.7016	0.9261	1.0820	8.2090	14.6950	7.9843	14.5862
+1980	1989.5836	213	1.3458	0.7015	0.9261	1.0820	8.2090	14.6950	7.9762	14.5757
+1981	1989.5863	214	1.3457	0.7015	0.9261	1.0820	8.2090	14.6950	7.9688	14.5649
+1982	1989.5890	215	1.3457	0.7015	0.9260	1.0820	8.2090	14.6950	7.9623	14.5539
+1983	1989.5918	216	1.3456	0.7015	0.9260	1.0820	8.2090	14.6950	7.9568	14.5426
+1984	1989.5945	217	1.3455	0.7015	0.9260	1.0820	8.2090	14.6950	7.9521	14.5312
+1985	1989.5973	218	1.3455	0.7014	0.9260	1.0820	8.2090	14.6950	7.9485	14.5196
+1986	1989.6000	219	1.3454	0.7014	0.9260	1.0820	8.2090	14.6950	7.9458	14.5080
+1987	1989.6027	220	1.3454	0.7014	0.9260	1.0820	8.2090	14.6950	7.9441	14.4962
+1988	1989.6055	221	1.3453	0.7014	0.9259	1.0820	8.2090	14.6950	7.9434	14.4844
+1989	1989.6082	222	1.3453	0.7014	0.9259	1.0820	8.2090	14.6950	7.9438	14.4726
+1990	1989.6110	223	1.3452	0.7013	0.9259	1.0820	8.2090	14.6950	7.9451	14.4609
+1991	1989.6137	224	1.3452	0.7013	0.9259	1.0820	8.2090	14.6950	7.9474	14.4492
+1992	1989.6164	225	1.3451	0.7013	0.9259	1.0820	8.2090	14.6950	7.9507	14.4376
+1993	1989.6192	226	1.3451	0.7013	0.9259	1.0820	8.2090	14.6950	7.9549	14.4262
+1994	1989.6219	227	1.3450	0.7013	0.9259	1.0820	8.2090	14.6950	7.9600	14.4149
+1995	1989.6247	228	1.3450	0.7012	0.9258	1.0820	8.2090	14.6950	7.9660	14.4039
+1996	1989.6274	229	1.3449	0.7012	0.9258	1.0820	8.2090	14.6950	7.9729	14.3931
+1997	1989.6301	230	1.3449	0.7012	0.9258	1.0820	8.2090	14.6950	7.9805	14.3825
+1998	1989.6329	231	1.3448	0.7012	0.9258	1.0820	8.2090	14.6950	7.9889	14.3723
+1999	1989.6356	232	1.3448	0.7012	0.9258	1.0820	8.2090	14.6950	7.9980	14.3624
+2000	1989.6384	233	1.3447	0.7011	0.9258	1.0820	8.2090	14.6950	8.0077	14.3528
+2001	1989.6411	234	1.3447	0.7011	0.9258	1.0820	8.2090	14.6950	8.0179	14.3437
+2002	1989.6438	235	1.3446	0.7011	0.9257	1.0820	8.2090	14.6950	8.0287	14.3349
+2003	1989.6466	236	1.3446	0.7011	0.9257	1.0820	8.2090	14.6950	8.0398	14.3265
+2004	1989.6493	237	1.3445	0.7011	0.9257	1.0820	8.2090	14.6950	8.0514	14.3187
+2005	1989.6521	238	1.3445	0.7010	0.9257	1.0820	8.2090	14.6950	8.0631	14.3112
+2006	1989.6548	239	1.3444	0.7010	0.9257	1.0820	8.2090	14.6950	8.0751	14.3043
+2007	1989.6575	240	1.3444	0.7010	0.9257	1.0820	8.2090	14.6950	8.0872	14.2979
+2008	1989.6603	241	1.3443	0.7010	0.9256	1.0820	8.2090	14.6950	8.0993	14.2920
+2009	1989.6630	242	1.3442	0.7010	0.9256	1.0820	8.2090	14.6950	8.1113	14.2866
+2010	1989.6658	243	1.3442	0.7009	0.9256	1.0820	8.2090	14.6950	8.1233	14.2817
+2011	1989.6685	244	1.3441	0.7009	0.9256	1.0820	8.2090	14.6950	8.1349	14.2774
+2012	1989.6712	245	1.3441	0.7009	0.9256	1.0820	8.2090	14.6950	8.1463	14.2737
+2013	1989.6740	246	1.3440	0.7009	0.9256	1.0820	8.2090	14.6950	8.1573	14.2705
+2014	1989.6767	247	1.3440	0.7009	0.9256	1.0820	8.2090	14.6950	8.1678	14.2679
+2015	1989.6795	248	1.3439	0.7008	0.9255	1.0820	8.2090	14.6950	8.1778	14.2659
+2016	1989.6822	249	1.3439	0.7008	0.9255	1.0820	8.2090	14.6950	8.1871	14.2644
+2017	1989.6849	250	1.3438	0.7008	0.9255	1.0820	8.2090	14.6950	8.1958	14.2635
+2018	1989.6877	251	1.3438	0.7008	0.9255	1.0820	8.2090	14.6950	8.2037	14.2632
+2019	1989.6904	252	1.3437	0.7008	0.9255	1.0820	8.2090	14.6950	8.2109	14.2634
+2020	1989.6932	253	1.3437	0.7007	0.9255	1.0820	8.2090	14.6950	8.2171	14.2642
+2021	1989.6959	254	1.3436	0.7007	0.9255	1.0820	8.2090	14.6950	8.2225	14.2655
+2022	1989.6986	255	1.3436	0.7007	0.9254	1.0820	8.2090	14.6950	8.2269	14.2673
+2023	1989.7014	256	1.3435	0.7007	0.9254	1.0820	8.2090	14.6950	8.2303	14.2697
+2024	1989.7041	257	1.3435	0.7007	0.9254	1.0820	8.2090	14.6950	8.2328	14.2725
+2025	1989.7068	258	1.3434	0.7006	0.9254	1.0820	8.2090	14.6950	8.2342	14.2759
+2026	1989.7096	259	1.3434	0.7006	0.9254	1.0820	8.2090	14.6950	8.2346	14.2797
+2027	1989.7123	260	1.3433	0.7006	0.9254	1.0820	8.2090	14.6950	8.2339	14.2840
+2028	1989.7151	261	1.3433	0.7006	0.9253	1.0820	8.2090	14.6950	8.2323	14.2887
+2029	1989.7178	262	1.3432	0.7006	0.9253	1.0820	8.2090	14.6950	8.2295	14.2938
+2030	1989.7205	263	1.3432	0.7005	0.9253	1.0820	8.2090	14.6950	8.2258	14.2993
+2031	1989.7233	264	1.3431	0.7005	0.9253	1.0820	8.2090	14.6950	8.2212	14.3052
+2032	1989.7260	265	1.3431	0.7005	0.9253	1.0820	8.2090	14.6950	8.2155	14.3114
+2033	1989.7288	266	1.3430	0.7005	0.9253	1.0820	8.2090	14.6950	8.2090	14.3179
+2034	1989.7315	267	1.3430	0.7005	0.9253	1.0820	8.2090	14.6950	8.2016	14.3247
+2035	1989.7342	268	1.3429	0.7004	0.9252	1.0820	8.2090	14.6950	8.1934	14.3318
+2036	1989.7370	269	1.3429	0.7004	0.9252	1.0820	8.2090	14.6950	8.1844	14.3391
+2037	1989.7397	270	1.3428	0.7004	0.9252	1.0820	8.2090	14.6950	8.1748	14.3466
+2038	1989.7425	271	1.3428	0.7004	0.9252	1.0820	8.2090	14.6950	8.1645	14.3542
+2039	1989.7452	272	1.3427	0.7004	0.9252	1.0820	8.2090	14.6950	8.1537	14.3620
+2040	1989.7479	273	1.3426	0.7003	0.9252	1.0820	8.2090	14.6950	8.1424	14.3699
+2041	1989.7507	274	1.3426	0.7003	0.9252	1.0820	8.2090	14.6950	8.1307	14.3779
+2042	1989.7534	275	1.3425	0.7003	0.9251	1.0820	8.2090	14.6950	8.1186	14.3859
+2043	1989.7562	276	1.3425	0.7003	0.9251	1.0820	8.2090	14.6950	8.1064	14.3940
+2044	1989.7589	277	1.3424	0.7003	0.9251	1.0820	8.2090	14.6950	8.0939	14.4020
+2045	1989.7616	278	1.3424	0.7002	0.9251	1.0820	8.2090	14.6950	8.0813	14.4099
+2046	1989.7644	279	1.3423	0.7002	0.9251	1.0820	8.2090	14.6950	8.0688	14.4178
+2047	1989.7671	280	1.3423	0.7002	0.9251	1.0820	8.2090	14.6950	8.0563	14.4255
+2048	1989.7699	281	1.3422	0.7002	0.9251	1.0820	8.2090	14.6950	8.0439	14.4331
+2049	1989.7726	282	1.3422	0.7002	0.9250	1.0820	8.2090	14.6950	8.0318	14.4405
+2050	1989.7753	283	1.3421	0.7001	0.9250	1.0820	8.2090	14.6950	8.0199	14.4477
+2051	1989.7781	284	1.3421	0.7001	0.9250	1.0820	8.2090	14.6950	8.0084	14.4546
+2052	1989.7808	285	1.3420	0.7001	0.9250	1.0820	8.2090	14.6950	7.9974	14.4613
+2053	1989.7836	286	1.3420	0.7001	0.9250	1.0820	8.2090	14.6950	7.9868	14.4677
+2054	1989.7863	287	1.3419	0.7001	0.9250	1.0820	8.2090	14.6950	7.9768	14.4737
+2055	1989.7890	288	1.3419	0.7000	0.9250	1.0820	8.2090	14.6950	7.9674	14.4794
+2056	1989.7918	289	1.3418	0.7000	0.9249	1.0820	8.2090	14.6950	7.9587	14.4847
+2057	1989.7945	290	1.3418	0.7000	0.9249	1.0820	8.2090	14.6950	7.9506	14.4897
+2058	1989.7973	291	1.3417	0.7000	0.9249	1.0820	8.2090	14.6950	7.9434	14.4942
+2059	1989.8000	292	1.3417	0.7000	0.9249	1.0820	8.2090	14.6950	7.9369	14.4982
+2060	1989.8027	293	1.3416	0.6999	0.9249	1.0820	8.2090	14.6950	7.9312	14.5018
+2061	1989.8055	294	1.3416	0.6999	0.9249	1.0820	8.2090	14.6950	7.9264	14.5050
+2062	1989.8082	295	1.3415	0.6999	0.9249	1.0820	8.2090	14.6950	7.9225	14.5076
+2063	1989.8110	296	1.3415	0.6999	0.9248	1.0820	8.2090	14.6950	7.9195	14.5097
+2064	1989.8137	297	1.3414	0.6999	0.9248	1.0820	8.2090	14.6950	7.9174	14.5113
+2065	1989.8164	298	1.3414	0.6998	0.9248	1.0820	8.2090	14.6950	7.9162	14.5124
+2066	1989.8192	299	1.3413	0.6998	0.9248	1.0820	8.2090	14.6950	7.9159	14.5129
+2067	1989.8219	300	1.3413	0.6998	0.9248	1.0820	8.2090	14.6950	7.9165	14.5129
+2068	1989.8247	301	1.3412	0.6998	0.9248	1.0820	8.2090	14.6950	7.9181	14.5124
+2069	1989.8274	302	1.3412	0.6998	0.9248	1.0820	8.2090	14.6950	7.9205	14.5113
+2070	1989.8301	303	1.3411	0.6997	0.9247	1.0820	8.2090	14.6950	7.9239	14.5096
+2071	1989.8329	304	1.3411	0.6997	0.9247	1.0820	8.2090	14.6950	7.9281	14.5074
+2072	1989.8356	305	1.3410	0.6997	0.9247	1.0820	8.2090	14.6950	7.9331	14.5047
+2073	1989.8384	306	1.3410	0.6997	0.9247	1.0820	8.2090	14.6950	7.9390	14.5014
+2074	1989.8411	307	1.3409	0.6997	0.9247	1.0820	8.2090	14.6950	7.9456	14.4976
+2075	1989.8438	308	1.3409	0.6996	0.9247	1.0820	8.2090	14.6950	7.9529	14.4932
+2076	1989.8466	309	1.3408	0.6996	0.9247	1.0820	8.2090	14.6950	7.9609	14.4884
+2077	1989.8493	310	1.3408	0.6996	0.9246	1.0820	8.2090	14.6950	7.9696	14.4830
+2078	1989.8521	311	1.3407	0.6996	0.9246	1.0820	8.2090	14.6950	7.9788	14.4771
+2079	1989.8548	312	1.3407	0.6996	0.9246	1.0820	8.2090	14.6950	7.9885	14.4708
+2080	1989.8575	313	1.3406	0.6995	0.9246	1.0820	8.2090	14.6950	7.9987	14.4640
+2081	1989.8603	314	1.3406	0.6995	0.9246	1.0820	8.2090	14.6950	8.0093	14.4568
+2082	1989.8630	315	1.3405	0.6995	0.9246	1.0820	8.2090	14.6950	8.0203	14.4492
+2083	1989.8658	316	1.3405	0.6995	0.9246	1.0820	8.2090	14.6950	8.0315	14.4411
+2084	1989.8685	317	1.3404	0.6995	0.9245	1.0820	8.2090	14.6950	8.0429	14.4327
+2085	1989.8712	318	1.3404	0.6994	0.9245	1.0820	8.2090	14.6950	8.0544	14.4240
+2086	1989.8740	319	1.3403	0.6994	0.9245	1.0820	8.2090	14.6950	8.0659	14.4149
+2087	1989.8767	320	1.3403	0.6994	0.9245	1.0820	8.2090	14.6950	8.0775	14.4055
+2088	1989.8795	321	1.3402	0.6994	0.9245	1.0820	8.2090	14.6950	8.0889	14.3959
+2089	1989.8822	322	1.3402	0.6994	0.9245	1.0820	8.2090	14.6950	8.1002	14.3860
+2090	1989.8849	323	1.3401	0.6993	0.9245	1.0820	8.2090	14.6950	8.1112	14.3759
+2091	1989.8877	324	1.3401	0.6993	0.9244	1.0820	8.2090	14.6950	8.1219	14.3656
+2092	1989.8904	325	1.3400	0.6993	0.9244	1.0820	8.2090	14.6950	8.1322	14.3551
+2093	1989.8932	326	1.3400	0.6993	0.9244	1.0820	8.2090	14.6950	8.1421	14.3445
+2094	1989.8959	327	1.3399	0.6993	0.9244	1.0820	8.2090	14.6950	8.1514	14.3338
+2095	1989.8986	328	1.3399	0.6992	0.9244	1.0820	8.2090	14.6950	8.1602	14.3230
+2096	1989.9014	329	1.3398	0.6992	0.9244	1.0820	8.2090	14.6950	8.1683	14.3122
+2097	1989.9041	330	1.3398	0.6992	0.9244	1.0820	8.2090	14.6950	8.1757	14.3014
+2098	1989.9068	331	1.3397	0.6992	0.9243	1.0820	8.2090	14.6950	8.1824	14.2906
+2099	1989.9096	332	1.3397	0.6992	0.9243	1.0820	8.2090	14.6950	8.1882	14.2798
+2100	1989.9123	333	1.3396	0.6992	0.9243	1.0820	8.2090	14.6950	8.1933	14.2691
+2101	1989.9151	334	1.3396	0.6991	0.9243	1.0820	8.2090	14.6950	8.1974	14.2585
+2102	1989.9178	335	1.3395	0.6991	0.9243	1.0820	8.2090	14.6950	8.2007	14.2480
+2103	1989.9205	336	1.3395	0.6991	0.9243	1.0820	8.2090	14.6950	8.2031	14.2377
+2104	1989.9233	337	1.3394	0.6991	0.9243	1.0820	8.2090	14.6950	8.2045	14.2276
+2105	1989.9260	338	1.3394	0.6991	0.9242	1.0820	8.2090	14.6950	8.2049	14.2177
+2106	1989.9288	339	1.3393	0.6990	0.9242	1.0820	8.2090	14.6950	8.2044	14.2080
+2107	1989.9315	340	1.3393	0.6990	0.9242	1.0820	8.2090	14.6950	8.2090	14.6950
+2108	1989.9342	341	1.3392	0.6990	0.9242	1.0820	8.2090	14.6950	8.1993	14.6946
+2109	1989.9370	342	1.3392	0.6990	0.9242	1.0820	8.2090	14.6950	8.1891	14.6938
+2110	1989.9397	343	1.3391	0.6990	0.9242	1.0820	8.2090	14.6950	8.1783	14.6923
+2111	1989.9425	344	1.3391	0.6989	0.9242	1.0820	8.2090	14.6950	8.1672	14.6904
+2112	1989.9452	345	1.3390	0.6989	0.9241	1.0820	8.2090	14.6950	8.1556	14.6878
+2113	1989.9479	346	1.3390	0.6989	0.9241	1.0820	8.2090	14.6950	8.1438	14.6848
+2114	1989.9507	347	1.3389	0.6989	0.9241	1.0820	8.2090	14.6950	8.1318	14.6812
+2115	1989.9534	348	1.3389	0.6989	0.9241	1.0820	8.2090	14.6950	8.1197	14.6772
+2116	1989.9562	349	1.3388	0.6988	0.9241	1.0820	8.2090	14.6950	8.1075	14.6726
+2117	1989.9589	350	1.3388	0.6988	0.9241	1.0820	8.2090	14.6950	8.0952	14.6675
+2118	1989.9616	351	1.3387	0.6988	0.9241	1.0820	8.2090	14.6950	8.0831	14.6619
+2119	1989.9644	352	1.3387	0.6988	0.9240	1.0820	8.2090	14.6950	8.0711	14.6558
+2120	1989.9671	353	1.3386	0.6988	0.9240	1.0820	8.2090	14.6950	8.0593	14.6493
+2121	1989.9699	354	1.3386	0.6987	0.9240	1.0820	8.2090	14.6950	8.0478	14.6424
+2122	1989.9726	355	1.3385	0.6987	0.9240	1.0820	8.2090	14.6950	8.0366	14.6350
+2123	1989.9753	356	1.3385	0.6987	0.9240	1.0820	8.2090	14.6950	8.0259	14.6272
+2124	1989.9781	357	1.3384	0.6987	0.9240	1.0820	8.2090	14.6950	8.0156	14.6191
+2125	1989.9808	358	1.3384	0.6987	0.9240	1.0820	8.2090	14.6950	8.0058	14.6106
+2126	1989.9836	359	1.3383	0.6986	0.9239	1.0820	8.2090	14.6950	7.9966	14.6017
+2127	1989.9863	360	1.3383	0.6986	0.9239	1.0820	8.2090	14.6950	7.9879	14.5926
+2128	1989.9890	361	1.3382	0.6986	0.9239	1.0820	8.2090	14.6950	7.9800	14.5831
+2129	1989.9918	362	1.3382	0.6986	0.9239	1.0820	8.2090	14.6950	7.9728	14.5734
+2130	1989.9945	363	1.3381	0.6986	0.9239	1.0820	8.2090	14.6950	7.9663	14.5635
+2131	1989.9973	364	1.3381	0.6985	0.9239	1.0820	8.2090	14.6950	7.9605	14.5533
+2132	1989.9999	365	1.3380	0.6985	0.9239	1.0820	8.2090	14.6950	7.9556	14.5430
+2133	1990.0027	1	1.3380	0.6985	0.9239	1.0820	8.2090	14.6950	7.9515	14.5325
+2134	1990.0055	2	1.3379	0.6985	0.9238	1.0820	8.2090	14.6950	7.9482	14.5219
+2135	1990.0082	3	1.3379	0.6985	0.9238	1.0820	8.2090	14.6950	7.9457	14.5112
+2136	1990.0110	4	1.3378	0.6984	0.9238	1.0820	8.2090	14.6950	7.9442	14.5004
+2137	1990.0137	5	1.3378	0.6984	0.9238	1.0820	8.2090	14.6950	7.9435	14.4896
+2138	1990.0164	6	1.3377	0.6984	0.9238	1.0820	8.2090	14.6950	7.9436	14.4788
+2139	1990.0192	7	1.3377	0.6984	0.9238	1.0820	8.2090	14.6950	7.9447	14.4679
+2140	1990.0219	8	1.3376	0.6984	0.9238	1.0820	8.2090	14.6950	7.9465	14.4572
+2141	1990.0247	9	1.3376	0.6983	0.9237	1.0820	8.2090	14.6950	7.9492	14.4465
+2142	1990.0274	10	1.3375	0.6983	0.9237	1.0820	8.2090	14.6950	7.9528	14.4359
+2143	1990.0301	11	1.3375	0.6983	0.9237	1.0820	8.2090	14.6950	7.9571	14.4254
+2144	1990.0329	12	1.3374	0.6983	0.9237	1.0820	8.2090	14.6950	7.9623	14.4150
+2145	1990.0356	13	1.3374	0.6983	0.9237	1.0820	8.2090	14.6950	7.9681	14.4049
+2146	1990.0384	14	1.3373	0.6983	0.9237	1.0820	8.2090	14.6950	7.9747	14.3949
+2147	1990.0411	15	1.3373	0.6982	0.9237	1.0820	8.2090	14.6950	7.9820	14.3852
+2148	1990.0438	16	1.3372	0.6982	0.9236	1.0820	8.2090	14.6950	7.9898	14.3757
+2149	1990.0466	17	1.3372	0.6982	0.9236	1.0820	8.2090	14.6950	7.9983	14.3665
+2150	1990.0493	18	1.3371	0.6982	0.9236	1.0820	8.2090	14.6950	8.0073	14.3575
+2151	1990.0521	19	1.3371	0.6982	0.9236	1.0820	8.2090	14.6950	8.0168	14.3489
+2152	1990.0548	20	1.3370	0.6981	0.9236	1.0820	8.2090	14.6950	8.0267	14.3406
+2153	1990.0575	21	1.3370	0.6981	0.9236	1.0820	8.2090	14.6950	8.0370	14.3327
+2154	1990.0603	22	1.3369	0.6981	0.9236	1.0820	8.2090	14.6950	8.0477	14.3251
+2155	1990.0630	23	1.3369	0.6981	0.9236	1.0820	8.2090	14.6950	8.0585	14.3179
+2156	1990.0658	24	1.3368	0.6981	0.9235	1.0820	8.2090	14.6950	8.0696	14.3111
+2157	1990.0685	25	1.3368	0.6980	0.9235	1.0820	8.2090	14.6950	8.0808	14.3047
+2158	1990.0712	26	1.3367	0.6980	0.9235	1.0820	8.2090	14.6950	8.0920	14.2988
+2159	1990.0740	27	1.3367	0.6980	0.9235	1.0820	8.2090	14.6950	8.1033	14.2932
+2160	1990.0767	28	1.3366	0.6980	0.9235	1.0820	8.2090	14.6950	8.1145	14.2882
+2161	1990.0795	29	1.3366	0.6980	0.9235	1.0820	8.2090	14.6950	8.1255	14.2835
+2162	1990.0822	30	1.3365	0.6979	0.9235	1.0820	8.2090	14.6950	8.1363	14.2794
+2163	1990.0849	31	1.3365	0.6979	0.9234	1.0820	8.2090	14.6950	8.1468	14.2757
+2164	1990.0877	32	1.3364	0.6979	0.9234	1.0820	8.2090	14.6950	8.1570	14.2725
+2165	1990.0904	33	1.3364	0.6979	0.9234	1.0820	8.2090	14.6950	8.1668	14.2697
+2166	1990.0932	34	1.3363	0.6979	0.9234	1.0820	8.2090	14.6950	8.1762	14.2675
+2167	1990.0959	35	1.3363	0.6978	0.9234	1.0820	8.2090	14.6950	8.1850	14.2657
+2168	1990.0986	36	1.3363	0.6978	0.9234	1.0820	8.2090	14.6950	8.1932	14.2644
+2169	1990.1014	37	1.3362	0.6978	0.9234	1.0820	8.2090	14.6950	8.2008	14.2635
+2170	1990.1041	38	1.3362	0.6978	0.9234	1.0820	8.2090	14.6950	8.2078	14.2632
+2171	1990.1068	39	1.3361	0.6978	0.9233	1.0820	8.2090	14.6950	8.2140	14.2633
+2172	1990.1096	40	1.3361	0.6977	0.9233	1.0820	8.2090	14.6950	8.2194	14.2639
+2173	1990.1123	41	1.3360	0.6977	0.9233	1.0820	8.2090	14.6950	8.2241	14.2649
+2174	1990.1151	42	1.3360	0.6977	0.9233	1.0820	8.2090	14.6950	8.2279	14.2664
+2175	1990.1178	43	1.3359	0.6977	0.9233	1.0820	8.2090	14.6950	8.2309	14.2684
+2176	1990.1205	44	1.3359	0.6977	0.9233	1.0820	8.2090	14.6950	8.2330	14.2707
+2177	1990.1233	45	1.3358	0.6977	0.9233	1.0820	8.2090	14.6950	8.2343	14.2735
+2178	1990.1260	46	1.3358	0.6976	0.9232	1.0820	8.2090	14.6950	8.2346	14.2767
+2179	1990.1288	47	1.3357	0.6976	0.9232	1.0820	8.2090	14.6950	8.2340	14.2803
+2180	1990.1315	48	1.3357	0.6976	0.9232	1.0820	8.2090	14.6950	8.2326	14.2843
+2181	1990.1342	49	1.3356	0.6976	0.9232	1.0820	8.2090	14.6950	8.2302	14.2886
+2182	1990.1370	50	1.3356	0.6976	0.9232	1.0820	8.2090	14.6950	8.2270	14.2933
+2183	1990.1397	51	1.3355	0.6975	0.9232	1.0820	8.2090	14.6950	8.2230	14.2983
+2184	1990.1425	52	1.3355	0.6975	0.9232	1.0820	8.2090	14.6950	8.2181	14.3036
+2185	1990.1452	53	1.3354	0.6975	0.9231	1.0820	8.2090	14.6950	8.2124	14.3093
+2186	1990.1479	54	1.3354	0.6975	0.9231	1.0820	8.2090	14.6950	8.2059	14.3151
+2187	1990.1507	55	1.3353	0.6975	0.9231	1.0820	8.2090	14.6950	8.1988	14.3213
+2188	1990.1534	56	1.3353	0.6974	0.9231	1.0820	8.2090	14.6950	8.1909	14.3276
+2189	1990.1562	57	1.3352	0.6974	0.9231	1.0820	8.2090	14.6950	8.1824	14.3342
+2190	1990.1589	58	1.3352	0.6974	0.9231	1.0820	8.2090	14.6950	8.1734	14.3410
+2191	1990.1616	59	1.3351	0.6974	0.9231	1.0820	8.2090	14.6950	8.1638	14.3479
+2192	1990.1644	60	1.3351	0.6974	0.9231	1.0820	8.2090	14.6950	8.1537	14.3549
+2193	1990.1671	61	1.3350	0.6973	0.9230	1.0820	8.2090	14.6950	8.1432	14.3621
+2194	1990.1699	62	1.3350	0.6973	0.9230	1.0820	8.2090	14.6950	8.1323	14.3694
+2195	1990.1726	63	1.3349	0.6973	0.9230	1.0820	8.2090	14.6950	8.1212	14.3767
+2196	1990.1753	64	1.3349	0.6973	0.9230	1.0820	8.2090	14.6950	8.1098	14.3840
+2197	1990.1781	65	1.3348	0.6973	0.9230	1.0820	8.2090	14.6950	8.0983	14.3914
+2198	1990.1808	66	1.3348	0.6973	0.9230	1.0820	8.2090	14.6950	8.0867	14.3988
+2199	1990.1836	67	1.3347	0.6972	0.9230	1.0820	8.2090	14.6950	8.0750	14.4061
+2200	1990.1863	68	1.3347	0.6972	0.9230	1.0820	8.2090	14.6950	8.0633	14.4134
+2201	1990.1890	69	1.3347	0.6972	0.9229	1.0820	8.2090	14.6950	8.0517	14.4206
+2202	1990.1918	70	1.3346	0.6972	0.9229	1.0820	8.2090	14.6950	8.0403	14.4276
+2203	1990.1945	71	1.3346	0.6972	0.9229	1.0820	8.2090	14.6950	8.0291	14.4345
+2204	1990.1973	72	1.3345	0.6971	0.9229	1.0820	8.2090	14.6950	8.0181	14.4413
+2205	1990.2000	73	1.3345	0.6971	0.9229	1.0820	8.2090	14.6950	8.0075	14.4479
+2206	1990.2027	74	1.3344	0.6971	0.9229	1.0820	8.2090	14.6950	7.9972	14.4543
+2207	1990.2055	75	1.3344	0.6971	0.9229	1.0820	8.2090	14.6950	7.9874	14.4605
+2208	1990.2082	76	1.3343	0.6971	0.9228	1.0820	8.2090	14.6950	7.9781	14.4664
+2209	1990.2110	77	1.3343	0.6970	0.9228	1.0820	8.2090	14.6950	7.9692	14.4720
+2210	1990.2137	78	1.3342	0.6970	0.9228	1.0820	8.2090	14.6950	7.9610	14.4773
+2211	1990.2164	79	1.3342	0.6970	0.9228	1.0820	8.2090	14.6950	8.2090	14.6950
+2212	1990.2192	80	1.3341	0.6970	0.9228	1.0820	8.2090	14.6950	8.1998	14.6947
+2213	1990.2219	81	1.3341	0.6970	0.9228	1.0820	8.2090	14.6950	8.1901	14.6939
+2214	1990.2247	82	1.3340	0.6969	0.9228	1.0820	8.2090	14.6950	8.1799	14.6926
+2215	1990.2274	83	1.3340	0.6969	0.9228	1.0820	8.2090	14.6950	8.1693	14.6908
+2216	1990.2301	84	1.3339	0.6969	0.9227	1.0820	8.2090	14.6950	8.1584	14.6886
+2217	1990.2329	85	1.3339	0.6969	0.9227	1.0820	8.2090	14.6950	8.1472	14.6859
+2218	1990.2356	86	1.3338	0.6969	0.9227	1.0820	8.2090	14.6950	8.1359	14.6827
+2219	1990.2384	87	1.3338	0.6969	0.9227	1.0820	8.2090	14.6950	8.1243	14.6790
+2220	1990.2411	88	1.3337	0.6968	0.9227	1.0820	8.2090	14.6950	8.1127	14.6749
+2221	1990.2438	89	1.3337	0.6968	0.9227	1.0820	8.2090	14.6950	8.1010	14.6703
+2222	1990.2466	90	1.3336	0.6968	0.9227	1.0820	8.2090	14.6950	8.0894	14.6653
+2223	1990.2493	91	1.3336	0.6968	0.9227	1.0820	8.2090	14.6950	8.0779	14.6598
+2224	1990.2521	92	1.3335	0.6968	0.9226	1.0820	8.2090	14.6950	8.0666	14.6540
+2225	1990.2548	93	1.3335	0.6967	0.9226	1.0820	8.2090	14.6950	8.0554	14.6477
+2226	1990.2575	94	1.3335	0.6967	0.9226	1.0820	8.2090	14.6950	8.0446	14.6410
+2227	1990.2603	95	1.3334	0.6967	0.9226	1.0820	8.2090	14.6950	8.0340	14.6340
+2228	1990.2630	96	1.3334	0.6967	0.9226	1.0820	8.2090	14.6950	8.0238	14.6266
+2229	1990.2658	97	1.3333	0.6967	0.9226	1.0820	8.2090	14.6950	8.0141	14.6189
+2230	1990.2685	98	1.3333	0.6966	0.9226	1.0820	8.2090	14.6950	8.0049	14.6109
+2231	1990.2712	99	1.3332	0.6966	0.9225	1.0820	8.2090	14.6950	7.9961	14.6025
+2232	1990.2740	100	1.3332	0.6966	0.9225	1.0820	8.2090	14.6950	7.9879	14.5939
+2233	1990.2767	101	1.3331	0.6966	0.9225	1.0820	8.2090	14.6950	7.9804	14.5850
+2234	1990.2795	102	1.3331	0.6966	0.9225	1.0820	8.2090	14.6950	7.9734	14.5759
+2235	1990.2822	103	1.3330	0.6965	0.9225	1.0820	8.2090	14.6950	7.9671	14.5665
+2236	1990.2849	104	1.3330	0.6965	0.9225	1.0820	8.2090	14.6950	7.9615	14.5570
+2237	1990.2877	105	1.3329	0.6965	0.9225	1.0820	8.2090	14.6950	7.9567	14.5473
+2238	1990.2904	106	1.3329	0.6965	0.9225	1.0820	8.2090	14.6950	7.9525	14.5374
+2239	1990.2932	107	1.3328	0.6965	0.9224	1.0820	8.2090	14.6950	7.9492	14.5275
+2240	1990.2959	108	1.3328	0.6965	0.9224	1.0820	8.2090	14.6950	7.9466	14.5174
+2241	1990.2986	109	1.3327	0.6964	0.9224	1.0820	8.2090	14.6950	7.9447	14.5072
+2242	1990.3014	110	1.3327	0.6964	0.9224	1.0820	8.2090	14.6950	7.9437	14.4970
+2243	1990.3041	111	1.3326	0.6964	0.9224	1.0820	8.2090	14.6950	7.9434	14.4868
+2244	1990.3068	112	1.3326	0.6964	0.9224	1.0820	8.2090	14.6950	7.9440	14.4765
+2245	1990.3096	113	1.3325	0.6964	0.9224	1.0820	8.2090	14.6950	7.9453	14.4663
+2246	1990.3123	114	1.3325	0.6963	0.9224	1.0820	8.2090	14.6950	7.9473	14.4561
+2247	1990.3151	115	1.3325	0.6963	0.9223	1.0820	8.2090	14.6950	7.9502	14.4460
+2248	1990.3178	116	1.3324	0.6963	0.9223	1.0820	8.2090	14.6950	7.9538	14.4360
+2249	1990.3205	117	1.3324	0.6963	0.9223	1.0820	8.2090	14.6950	7.9581	14.4261
+2250	1990.3233	118	1.3323	0.6963	0.9223	1.0820	8.2090	14.6950	7.9631	14.4163
+2251	1990.3260	119	1.3323	0.6962	0.9223	1.0820	8.2090	14.6950	7.9687	14.4066
+2252	1990.3288	120	1.3322	0.6962	0.9223	1.0820	8.2090	14.6950	7.9750	14.3972
+2253	1990.3315	121	1.3322	0.6962	0.9223	1.0820	8.2090	14.6950	7.9820	14.3879
+2254	1990.3342	122	1.3321	0.6962	0.9223	1.0820	8.2090	14.6950	7.9895	14.3789
+2255	1990.3370	123	1.3321	0.6962	0.9222	1.0820	8.2090	14.6950	7.9975	14.3700
+2256	1990.3397	124	1.3320	0.6962	0.9222	1.0820	8.2090	14.6950	8.0060	14.3615
+2257	1990.3425	125	1.3320	0.6961	0.9222	1.0820	8.2090	14.6950	8.0150	14.3532
+2258	1990.3452	126	1.3319	0.6961	0.9222	1.0820	8.2090	14.6950	8.0244	14.3452
+2259	1990.3479	127	1.3319	0.6961	0.9222	1.0820	8.2090	14.6950	8.0341	14.3375
+2260	1990.3507	128	1.3318	0.6961	0.9222	1.0820	8.2090	14.6950	8.0441	14.3301
+2261	1990.3534	129	1.3318	0.6961	0.9222	1.0820	8.2090	14.6950	8.0544	14.3230
+2262	1990.3562	130	1.3317	0.6960	0.9222	1.0820	8.2090	14.6950	8.0649	14.3163
+2263	1990.3589	131	1.3317	0.6960	0.9221	1.0820	8.2090	14.6950	8.0755	14.3100
+2264	1990.3616	132	1.3317	0.6960	0.9221	1.0820	8.2090	14.6950	8.0862	14.3040
+2265	1990.3644	133	1.3316	0.6960	0.9221	1.0820	8.2090	14.6950	8.0969	14.2984
+2266	1990.3671	134	1.3316	0.6960	0.9221	1.0820	8.2090	14.6950	8.1076	14.2932
+2267	1990.3699	135	1.3315	0.6959	0.9221	1.0820	8.2090	14.6950	8.1182	14.2884
+2268	1990.3726	136	1.3315	0.6959	0.9221	1.0820	8.2090	14.6950	8.1286	14.2840
+2269	1990.3753	137	1.3314	0.6959	0.9221	1.0820	8.2090	14.6950	8.1389	14.2800
+2270	1990.3781	138	1.3314	0.6959	0.9220	1.0820	8.2090	14.6950	8.1488	14.2764
+2271	1990.3808	139	1.3313	0.6959	0.9220	1.0820	8.2090	14.6950	8.1585	14.2733
+2272	1990.3836	140	1.3313	0.6959	0.9220	1.0820	8.2090	14.6950	8.1678	14.2705
+2273	1990.3863	141	1.3312	0.6958	0.9220	1.0820	8.2090	14.6950	8.1766	14.2682
+2274	1990.3890	142	1.3312	0.6958	0.9220	1.0820	8.2090	14.6950	8.1850	14.2664
+2275	1990.3918	143	1.3311	0.6958	0.9220	1.0820	8.2090	14.6950	8.1929	14.2649
+2276	1990.3945	144	1.3311	0.6958	0.9220	1.0820	8.2090	14.6950	8.2002	14.2639
+2277	1990.3973	145	1.3310	0.6958	0.9220	1.0820	8.2090	14.6950	8.2069	14.2633
+2278	1990.4000	146	1.3310	0.6957	0.9219	1.0820	8.2090	14.6950	8.2129	14.2632
+2279	1990.4027	147	1.3310	0.6957	0.9219	1.0820	8.2090	14.6950	8.2182	14.2634
+2280	1990.4055	148	1.3309	0.6957	0.9219	1.0820	8.2090	14.6950	8.2229	14.2641
+2281	1990.4082	149	1.3309	0.6957	0.9219	1.0820	8.2090	14.6950	8.2268	14.2652
+2282	1990.4110	150	1.3308	0.6957	0.9219	1.0820	8.2090	14.6950	8.2299	14.2667
+2283	1990.4137	151	1.3308	0.6956	0.9219	1.0820	8.2090	14.6950	8.2322	14.2685
+2284	1990.4164	152	1.3307	0.6956	0.9219	1.0820	8.2090	14.6950	8.2338	14.2708
+2285	1990.4192	153	1.3307	0.6956	0.9219	1.0820	8.2090	14.6950	8.2345	14.2735
+2286	1990.4219	154	1.3306	0.6956	0.9218	1.0820	8.2090	14.6950	8.2345	14.2765
+2287	1990.4247	155	1.3306	0.6956	0.9218	1.0820	8.2090	14.6950	8.2336	14.2798
+2288	1990.4274	156	1.3305	0.6956	0.9218	1.0820	8.2090	14.6950	8.2319	14.2835
+2289	1990.4301	157	1.3305	0.6955	0.9218	1.0820	8.2090	14.6950	8.2294	14.2875
+2290	1990.4329	158	1.3304	0.6955	0.9218	1.0820	8.2090	14.6950	8.2261	14.2919
+2291	1990.4356	159	1.3304	0.6955	0.9218	1.0820	8.2090	14.6950	8.2221	14.2965
+2292	1990.4384	160	1.3303	0.6955	0.9218	1.0820	8.2090	14.6950	8.2173	14.3014
+2293	1990.4411	161	1.3303	0.6955	0.9218	1.0820	8.2090	14.6950	8.2118	14.3066
+2294	1990.4438	162	1.3303	0.6954	0.9218	1.0820	8.2090	14.6950	8.2056	14.3121
+2295	1990.4466	163	1.3302	0.6954	0.9217	1.0820	8.2090	14.6950	8.1987	14.3178
+2296	1990.4493	164	1.3302	0.6954	0.9217	1.0820	8.2090	14.6950	8.1913	14.3237
+2297	1990.4521	165	1.3301	0.6954	0.9217	1.0820	8.2090	14.6950	8.1832	14.3297
+2298	1990.4548	166	1.3301	0.6954	0.9217	1.0820	8.2090	14.6950	8.1746	14.3360
+2299	1990.4575	167	1.3300	0.6953	0.9217	1.0820	8.2090	14.6950	8.1656	14.3424
+2300	1990.4603	168	1.3300	0.6953	0.9217	1.0820	8.2090	14.6950	8.1561	14.3490
+2301	1990.4630	169	1.3299	0.6953	0.9217	1.0820	8.2090	14.6950	8.1462	14.3557
+2302	1990.4658	170	1.3299	0.6953	0.9217	1.0820	8.2090	14.6950	8.1359	14.3625
+2303	1990.4685	171	1.3298	0.6953	0.9216	1.0820	8.2090	14.6950	8.1254	14.3693
+2304	1990.4712	172	1.3298	0.6953	0.9216	1.0820	8.2090	14.6950	8.1147	14.3763
+2305	1990.4740	173	1.3297	0.6952	0.9216	1.0820	8.2090	14.6950	8.1037	14.3832
+2306	1990.4767	174	1.3297	0.6952	0.9216	1.0820	8.2090	14.6950	8.0927	14.3902
+2307	1990.4795	175	1.3296	0.6952	0.9216	1.0820	8.2090	14.6950	8.0816	14.3972
+2308	1990.4822	176	1.3296	0.6952	0.9216	1.0820	8.2090	14.6950	8.0705	14.4041
+2309	1990.4849	177	1.3296	0.6952	0.9216	1.0820	8.2090	14.6950	8.0594	14.4110
+2310	1990.4877	178	1.3295	0.6951	0.9216	1.0820	8.2090	14.6950	8.0484	14.4178
+2311	1990.4904	179	1.3295	0.6951	0.9215	1.0820	8.2090	14.6950	8.0375	14.4245
+2312	1990.4932	180	1.3294	0.6951	0.9215	1.0820	8.2090	14.6950	8.0269	14.4312
+2313	1990.4959	181	1.3294	0.6951	0.9215	1.0820	8.2090	14.6950	8.0165	14.4376
+2314	1990.4986	182	1.3293	0.6951	0.9215	1.0820	8.2090	14.6950	8.0064	14.4440
+2315	1990.5014	183	1.3293	0.6951	0.9215	1.0820	8.2090	14.6950	7.9967	14.4501
+2316	1990.5041	184	1.3292	0.6950	0.9215	1.0820	8.2090	14.6950	7.9874	14.4561
+2317	1990.5068	185	1.3292	0.6950	0.9215	1.0820	8.2090	14.6950	7.9784	14.4619
+2318	1990.5096	186	1.3291	0.6950	0.9215	1.0820	8.2090	14.6950	7.9700	14.4674
+2319	1990.5123	187	1.3291	0.6950	0.9214	1.0820	8.2090	14.6950	7.9620	14.4727
+2320	1990.5151	188	1.3290	0.6950	0.9214	1.0820	8.2090	14.6950	7.9547	14.4777
+2321	1990.5178	189	1.3290	0.6949	0.9214	1.0820	8.2090	14.6950	7.9478	14.4825
+2322	1990.5205	190	1.3290	0.6949	0.9214	1.0820	8.2090	14.6950	7.9416	14.4869
+2323	1990.5233	191	1.3289	0.6949	0.9214	1.0820	8.2090	14.6950	7.9360	14.4911
+2324	1990.5260	192	1.3289	0.6949	0.9214	1.0820	8.2090	14.6950	7.9311	14.4949
+2325	1990.5288	193	1.3288	0.6949	0.9214	1.0820	8.2090	14.6950	7.9268	14.4984
+2326	1990.5315	194	1.3288	0.6948	0.9214	1.0820	8.2090	14.6950	7.9232	14.5015
+2327	1990.5342	195	1.3287	0.6948	0.9213	1.0820	8.2090	14.6950	7.9203	14.5043
+2328	1990.5370	196	1.3287	0.6948	0.9213	1.0820	8.2090	14.6950	7.9181	14.5067
+2329	1990.5397	197	1.3286	0.6948	0.9213	1.0820	8.2090	14.6950	7.9167	14.5087
+2330	1990.5425	198	1.3286	0.6948	0.9213	1.0820	8.2090	14.6950	7.9160	14.5104
+2331	1990.5452	199	1.3285	0.6948	0.9213	1.0820	8.2090	14.6950	8.2090	14.6950
+2332	1990.5479	200	1.3285	0.6947	0.9213	1.0820	8.2090	14.6950	8.2003	14.6947
+2333	1990.5507	201	1.3285	0.6947	0.9213	1.0820	8.2090	14.6950	8.1911	14.6940
+2334	1990.5534	202	1.3284	0.6947	0.9213	1.0820	8.2090	14.6950	8.1815	14.6929
+2335	1990.5562	203	1.3284	0.6947	0.9212	1.0820	8.2090	14.6950	8.1715	14.6913
+2336	1990.5589	204	1.3283	0.6947	0.9212	1.0820	8.2090	14.6950	8.1613	14.6893
+2337	1990.5616	205	1.3283	0.6946	0.9212	1.0820	8.2090	14.6950	8.1508	14.6869
+2338	1990.5644	206	1.3282	0.6946	0.9212	1.0820	8.2090	14.6950	8.1400	14.6840
+2339	1990.5671	207	1.3282	0.6946	0.9212	1.0820	8.2090	14.6950	8.1291	14.6808
+2340	1990.5699	208	1.3281	0.6946	0.9212	1.0820	8.2090	14.6950	8.1181	14.6771
+2341	1990.5726	209	1.3281	0.6946	0.9212	1.0820	8.2090	14.6950	8.1071	14.6730
+2342	1990.5753	210	1.3280	0.6946	0.9212	1.0820	8.2090	14.6950	8.0961	14.6686
+2343	1990.5781	211	1.3280	0.6945	0.9212	1.0820	8.2090	14.6950	8.0851	14.6637
+2344	1990.5808	212	1.3279	0.6945	0.9211	1.0820	8.2090	14.6950	8.0742	14.6585
+2345	1990.5836	213	1.3279	0.6945	0.9211	1.0820	8.2090	14.6950	8.0635	14.6529
+2346	1990.5863	214	1.3279	0.6945	0.9211	1.0820	8.2090	14.6950	8.0530	14.6470
+2347	1990.5890	215	1.3278	0.6945	0.9211	1.0820	8.2090	14.6950	8.0428	14.6407
+2348	1990.5918	216	1.3278	0.6944	0.9211	1.0820	8.2090	14.6950	8.0328	14.6340
+2349	1990.5945	217	1.3277	0.6944	0.9211	1.0820	8.2090	14.6950	8.0232	14.6271
+2350	1990.5973	218	1.3277	0.6944	0.9211	1.0820	8.2090	14.6950	8.0140	14.6199
+2351	1990.6000	219	1.3276	0.6944	0.9211	1.0820	8.2090	14.6950	8.0052	14.6123
+2352	1990.6027	220	1.3276	0.6944	0.9210	1.0820	8.2090	14.6950	7.9969	14.6045
+2353	1990.6055	221	1.3275	0.6944	0.9210	1.0820	8.2090	14.6950	7.9891	14.5965
+2354	1990.6082	222	1.3275	0.6943	0.9210	1.0820	8.2090	14.6950	7.9818	14.5882
+2355	1990.6110	223	1.3274	0.6943	0.9210	1.0820	8.2090	14.6950	7.9751	14.5797
+2356	1990.6137	224	1.3274	0.6943	0.9210	1.0820	8.2090	14.6950	7.9689	14.5710
+2357	1990.6164	225	1.3274	0.6943	0.9210	1.0820	8.2090	14.6950	7.9634	14.5621
+2358	1990.6192	226	1.3273	0.6943	0.9210	1.0820	8.2090	14.6950	7.9586	14.5531
+2359	1990.6219	227	1.3273	0.6942	0.9210	1.0820	8.2090	14.6950	7.9543	14.5439
+2360	1990.6247	228	1.3272	0.6942	0.9209	1.0820	8.2090	14.6950	7.9508	14.5346
+2361	1990.6274	229	1.3272	0.6942	0.9209	1.0820	8.2090	14.6950	7.9479	14.5252
+2362	1990.6301	230	1.3271	0.6942	0.9209	1.0820	8.2090	14.6950	7.9458	14.5157
+2363	1990.6329	231	1.3271	0.6942	0.9209	1.0820	8.2090	14.6950	7.9443	14.5061
+2364	1990.6356	232	1.3270	0.6942	0.9209	1.0820	8.2090	14.6950	7.9435	14.4965
+2365	1990.6384	233	1.3270	0.6941	0.9209	1.0820	8.2090	14.6950	7.9435	14.4869
+2366	1990.6411	234	1.3270	0.6941	0.9209	1.0820	8.2090	14.6950	7.9441	14.4772
+2367	1990.6438	235	1.3269	0.6941	0.9209	1.0820	8.2090	14.6950	7.9455	14.4676
+2368	1990.6466	236	1.3269	0.6941	0.9209	1.0820	8.2090	14.6950	7.9475	14.4580
+2369	1990.6493	237	1.3268	0.6941	0.9208	1.0820	8.2090	14.6950	7.9503	14.4485
+2370	1990.6521	238	1.3268	0.6940	0.9208	1.0820	8.2090	14.6950	7.9536	14.4390
+2371	1990.6548	239	1.3267	0.6940	0.9208	1.0820	8.2090	14.6950	7.9577	14.4296
+2372	1990.6575	240	1.3267	0.6940	0.9208	1.0820	8.2090	14.6950	7.9624	14.4204
+2373	1990.6603	241	1.3266	0.6940	0.9208	1.0820	8.2090	14.6950	7.9676	14.4112
+2374	1990.6630	242	1.3266	0.6940	0.9208	1.0820	8.2090	14.6950	7.9735	14.4023
+2375	1990.6658	243	1.3265	0.6940	0.9208	1.0820	8.2090	14.6950	7.9799	14.3934
+2376	1990.6685	244	1.3265	0.6939	0.9208	1.0820	8.2090	14.6950	7.9868	14.3848
+2377	1990.6712	245	1.3265	0.6939	0.9207	1.0820	8.2090	14.6950	7.9943	14.3763
+2378	1990.6740	246	1.3264	0.6939	0.9207	1.0820	8.2090	14.6950	8.0022	14.3681
+2379	1990.6767	247	1.3264	0.6939	0.9207	1.0820	8.2090	14.6950	8.0105	14.3601
+2380	1990.6795	248	1.3263	0.6939	0.9207	1.0820	8.2090	14.6950	8.0192	14.3523
+2381	1990.6822	249	1.3263	0.6938	0.9207	1.0820	8.2090	14.6950	8.0282	14.3448
+2382	1990.6849	250	1.3262	0.6938	0.9207	1.0820	8.2090	14.6950	8.0375	14.3376
+2383	1990.6877	251	1.3262	0.6938	0.9207	1.0820	8.2090	14.6950	8.0471	14.3306
+2384	1990.6904	252	1.3261	0.6938	0.9207	1.0820	8.2090	14.6950	8.0569	14.3239
+2385	1990.6932	253	1.3261	0.6938	0.9207	1.0820	8.2090	14.6950	8.0669	14.3176
+2386	1990.6959	254	1.3260	0.6938	0.9206	1.0820	8.2090	14.6950	8.0770	14.3115
+2387	1990.6986	255	1.3260	0.6937	0.9206	1.0820	8.2090	14.6950	8.0871	14.3058
+2388	1990.7014	256	1.3260	0.6937	0.9206	1.0820	8.2090	14.6950	8.0973	14.3004
+2389	1990.7041	257	1.3259	0.6937	0.9206	1.0820	8.2090	14.6950	8.1074	14.2954
+2390	1990.7068	258	1.3259	0.6937	0.9206	1.0820	8.2090	14.6950	8.1175	14.2907
+2391	1990.7096	259	1.3258	0.6937	0.9206	1.0820	8.2090	14.6950	8.1274	14.2863
+2392	1990.7123	260	1.3258	0.6936	0.9206	1.0820	8.2090	14.6950	8.1371	14.2823
+2393	1990.7151	261	1.3257	0.6936	0.9206	1.0820	8.2090	14.6950	8.1466	14.2787
+2394	1990.7178	262	1.3257	0.6936	0.9206	1.0820	8.2090	14.6950	8.1559	14.2755
+2395	1990.7205	263	1.3256	0.6936	0.9205	1.0820	8.2090	14.6950	8.1648	14.2726
+2396	1990.7233	264	1.3256	0.6936	0.9205	1.0820	8.2090	14.6950	8.1733	14.2701
+2397	1990.7260	265	1.3256	0.6936	0.9205	1.0820	8.2090	14.6950	8.1814	14.2680
+2398	1990.7288	266	1.3255	0.6935	0.9205	1.0820	8.2090	14.6950	8.1891	14.2663
+2399	1990.7315	267	1.3255	0.6935	0.9205	1.0820	8.2090	14.6950	8.1963	14.2650
+2400	1990.7342	268	1.3254	0.6935	0.9205	1.0820	8.2090	14.6950	8.2030	14.2640
+2401	1990.7370	269	1.3254	0.6935	0.9205	1.0820	8.2090	14.6950	8.2091	14.2634
+2402	1990.7397	270	1.3253	0.6935	0.9205	1.0820	8.2090	14.6950	8.2146	14.2632
+2403	1990.7425	271	1.3253	0.6934	0.9204	1.0820	8.2090	14.6950	8.2195	14.2633
+2404	1990.7452	272	1.3252	0.6934	0.9204	1.0820	8.2090	14.6950	8.2237	14.2639
+2405	1990.7479	273	1.3252	0.6934	0.9204	1.0820	8.2090	14.6950	8.2273	14.2647
+2406	1990.7507	274	1.3252	0.6934	0.9204	1.0820	8.2090	14.6950	8.2302	14.2660
+2407	1990.7534	275	1.3251	0.6934	0.9204	1.0820	8.2090	14.6950	8.2323	14.2676
+2408	1990.7562	276	1.3251	0.6934	0.9204	1.0820	8.2090	14.6950	8.2338	14.2695
+2409	1990.7589	277	1.3250	0.6933	0.9204	1.0820	8.2090	14.6950	8.2345	14.2718
+2410	1990.7616	278	1.3250	0.6933	0.9204	1.0820	8.2090	14.6950	8.2345	14.2744
+2411	1990.7644	279	1.3249	0.6933	0.9204	1.0820	8.2090	14.6950	8.2338	14.2773
+2412	1990.7671	280	1.3249	0.6933	0.9203	1.0820	8.2090	14.6950	8.2323	14.2806
+2413	1990.7699	281	1.3248	0.6933	0.9203	1.0820	8.2090	14.6950	8.2301	14.2841
+2414	1990.7726	282	1.3248	0.6932	0.9203	1.0820	8.2090	14.6950	8.2272	14.2880
+2415	1990.7753	283	1.3248	0.6932	0.9203	1.0820	8.2090	14.6950	8.2237	14.2921
+2416	1990.7781	284	1.3247	0.6932	0.9203	1.0820	8.2090	14.6950	8.2194	14.2964
+2417	1990.7808	285	1.3247	0.6932	0.9203	1.0820	8.2090	14.6950	8.2145	14.3011
+2418	1990.7836	286	1.3246	0.6932	0.9203	1.0820	8.2090	14.6950	8.2089	14.3059
+2419	1990.7863	287	1.3246	0.6932	0.9203	1.0820	8.2090	14.6950	8.2028	14.3110
+2420	1990.7890	288	1.3245	0.6931	0.9203	1.0820	8.2090	14.6950	8.1960	14.3163
+2421	1990.7918	289	1.3245	0.6931	0.9202	1.0820	8.2090	14.6950	8.1888	14.3218
+2422	1990.7945	290	1.3244	0.6931	0.9202	1.0820	8.2090	14.6950	8.1810	14.3274
+2423	1990.7973	291	1.3244	0.6931	0.9202	1.0820	8.2090	14.6950	8.1727	14.3333
+2424	1990.8000	292	1.3244	0.6931	0.9202	1.0820	8.2090	14.6950	8.1641	14.3393
+2425	1990.8027	293	1.3243	0.6931	0.9202	1.0820	8.2090	14.6950	8.1550	14.3454
+2426	1990.8055	294	1.3243	0.6930	0.9202	1.0820	8.2090	14.6950	8.1456	14.3516
+2427	1990.8082	295	1.3242	0.6930	0.9202	1.0820	8.2090	14.6950	8.1359	14.3579
+2428	1990.8110	296	1.3242	0.6930	0.9202	1.0820	8.2090	14.6950	8.1259	14.3643
+2429	1990.8137	297	1.3241	0.6930	0.9201	1.0820	8.2090	14.6950	8.1157	14.3708
+2430	1990.8164	298	1.3241	0.6930	0.9201	1.0820	8.2090	14.6950	8.1054	14.3773
+2431	1990.8192	299	1.3240	0.6929	0.9201	1.0820	8.2090	14.6950	8.0949	14.3839
+2432	1990.8219	300	1.3240	0.6929	0.9201	1.0820	8.2090	14.6950	8.0844	14.3904
+2433	1990.8247	301	1.3240	0.6929	0.9201	1.0820	8.2090	14.6950	8.0739	14.3970
+2434	1990.8274	302	1.3239	0.6929	0.9201	1.0820	8.2090	14.6950	8.0633	14.4035
+2435	1990.8301	303	1.3239	0.6929	0.9201	1.0820	8.2090	14.6950	8.0529	14.4100
+2436	1990.8329	304	1.3238	0.6929	0.9201	1.0820	8.2090	14.6950	8.0425	14.4164
+2437	1990.8356	305	1.3238	0.6928	0.9201	1.0820	8.2090	14.6950	8.0324	14.4228
+2438	1990.8384	306	1.3237	0.6928	0.9200	1.0820	8.2090	14.6950	8.0224	14.4291
+2439	1990.8411	307	1.3237	0.6928	0.9200	1.0820	8.2090	14.6950	8.0126	14.4352
+2440	1990.8438	308	1.3237	0.6928	0.9200	1.0820	8.2090	14.6950	8.0032	14.4412
+2441	1990.8466	309	1.3236	0.6928	0.9200	1.0820	8.2090	14.6950	7.9941	14.4471
+2442	1990.8493	310	1.3236	0.6927	0.9200	1.0820	8.2090	14.6950	7.9853	14.4528
+2443	1990.8521	311	1.3235	0.6927	0.9200	1.0820	8.2090	14.6950	7.9769	14.4584
+2444	1990.8548	312	1.3235	0.6927	0.9200	1.0820	8.2090	14.6950	7.9690	14.4637
+2445	1990.8575	313	1.3234	0.6927	0.9200	1.0820	8.2090	14.6950	7.9615	14.4688
+2446	1990.8603	314	1.3234	0.6927	0.9200	1.0820	8.2090	14.6950	7.9545	14.4738
+2447	1990.8630	315	1.3233	0.6927	0.9199	1.0820	8.2090	14.6950	7.9481	14.4784
+2448	1990.8658	316	1.3233	0.6926	0.9199	1.0820	8.2090	14.6950	7.9421	14.4829
+2449	1990.8685	317	1.3233	0.6926	0.9199	1.0820	8.2090	14.6950	7.9367	14.4871
+2450	1990.8712	318	1.3232	0.6926	0.9199	1.0820	8.2090	14.6950	7.9320	14.4910
+2451	1990.8740	319	1.3232	0.6926	0.9199	1.0820	8.2090	14.6950	7.9278	14.4946
+2452	1990.8767	320	1.3231	0.6926	0.9199	1.0820	8.2090	14.6950	7.9242	14.4979
+2453	1990.8795	321	1.3231	0.6926	0.9199	1.0820	8.2090	14.6950	7.9212	14.5009
+2454	1990.8822	322	1.3230	0.6925	0.9199	1.0820	8.2090	14.6950	7.9189	14.5036
+2455	1990.8849	323	1.3230	0.6925	0.9199	1.0820	8.2090	14.6950	7.9173	14.5060
+2456	1990.8877	324	1.3230	0.6925	0.9198	1.0820	8.2090	14.6950	7.9162	14.5080
+2457	1990.8904	325	1.3229	0.6925	0.9198	1.0820	8.2090	14.6950	7.9159	14.5097
+2458	1990.8932	326	1.3229	0.6925	0.9198	1.0820	8.2090	14.6950	7.9161	14.5111
+2459	1990.8959	327	1.3228	0.6924	0.9198	1.0820	8.2090	14.6950	7.9171	14.5121
+2460	1990.8986	328	1.3228	0.6924	0.9198	1.0820	8.2090	14.6950	7.9186	14.5127
+2461	1990.9014	329	1.3227	0.6924	0.9198	1.0820	8.2090	14.6950	7.9208	14.5130
+2462	1990.9041	330	1.3227	0.6924	0.9198	1.0820	8.2090	14.6950	7.9236	14.5129
+2463	1990.9068	331	1.3226	0.6924	0.9198	1.0820	8.2090	14.6950	7.9270	14.5125
+2464	1990.9096	332	1.3226	0.6924	0.9198	1.0820	8.2090	14.6950	7.9311	14.5116
+2465	1990.9123	333	1.3226	0.6923	0.9197	1.0820	8.2090	14.6950	7.9357	14.5105
+2466	1990.9151	334	1.3225	0.6923	0.9197	1.0820	8.2090	14.6950	7.9408	14.5089
+2467	1990.9178	335	1.3225	0.6923	0.9197	1.0820	8.2090	14.6950	8.2090	14.6950
+2468	1990.9205	336	1.3224	0.6923	0.9197	1.0820	8.2090	14.6950	8.2008	14.6947
+2469	1990.9233	337	1.3224	0.6923	0.9197	1.0820	8.2090	14.6950	8.1921	14.6941
+2470	1990.9260	338	1.3223	0.6923	0.9197	1.0820	8.2090	14.6950	8.1831	14.6931
+2471	1990.9288	339	1.3223	0.6922	0.9197	1.0820	8.2090	14.6950	8.1738	14.6917
+2472	1990.9315	340	1.3223	0.6922	0.9197	1.0820	8.2090	14.6950	8.1642	14.6900
+2473	1990.9342	341	1.3222	0.6922	0.9197	1.0820	8.2090	14.6950	8.1543	14.6878
+2474	1990.9370	342	1.3222	0.6922	0.9196	1.0820	8.2090	14.6950	8.1442	14.6853
+2475	1990.9397	343	1.3221	0.6922	0.9196	1.0820	8.2090	14.6950	8.1340	14.6825
+2476	1990.9425	344	1.3221	0.6921	0.9196	1.0820	8.2090	14.6950	8.1237	14.6792
+2477	1990.9452	345	1.3220	0.6921	0.9196	1.0820	8.2090	14.6950	8.1132	14.6756
+2478	1990.9479	346	1.3220	0.6921	0.9196	1.0820	8.2090	14.6950	8.1028	14.6717
+2479	1990.9507	347	1.3220	0.6921	0.9196	1.0820	8.2090	14.6950	8.0924	14.6674
+2480	1990.9534	348	1.3219	0.6921	0.9196	1.0820	8.2090	14.6950	8.0821	14.6628
+2481	1990.9562	349	1.3219	0.6921	0.9196	1.0820	8.2090	14.6950	8.0718	14.6578
+2482	1990.9589	350	1.3218	0.6920	0.9196	1.0820	8.2090	14.6950	8.0618	14.6526
+2483	1990.9616	351	1.3218	0.6920	0.9195	1.0820	8.2090	14.6950	8.0519	14.6470
+2484	1990.9644	352	1.3217	0.6920	0.9195	1.0820	8.2090	14.6950	8.0422	14.6411
+2485	1990.9671	353	1.3217	0.6920	0.9195	1.0820	8.2090	14.6950	8.0328	14.6349
+2486	1990.9699	354	1.3216	0.6920	0.9195	1.0820	8.2090	14.6950	8.0238	14.6285
+2487	1990.9726	355	1.3216	0.6920	0.9195	1.0820	8.2090	14.6950	8.0150	14.6217
+2488	1990.9753	356	1.3216	0.6919	0.9195	1.0820	8.2090	14.6950	8.0067	14.6148
+2489	1990.9781	357	1.3215	0.6919	0.9195	1.0820	8.2090	14.6950	7.9987	14.6075
+2490	1990.9808	358	1.3215	0.6919	0.9195	1.0820	8.2090	14.6950	7.9912	14.6001
+2491	1990.9836	359	1.3214	0.6919	0.9195	1.0820	8.2090	14.6950	7.9842	14.5924
+2492	1990.9863	360	1.3214	0.6919	0.9194	1.0820	8.2090	14.6950	7.9776	14.5846
+2493	1990.9890	361	1.3213	0.6918	0.9194	1.0820	8.2090	14.6950	7.9716	14.5765
+2494	1990.9918	362	1.3213	0.6918	0.9194	1.0820	8.2090	14.6950	7.9661	14.5683
+2495	1990.9945	363	1.3213	0.6918	0.9194	1.0820	8.2090	14.6950	7.9612	14.5599
+2496	1990.9973	364	1.3212	0.6918	0.9194	1.0820	8.2090	14.6950	7.9569	14.5514
+2497	1990.9999	365	1.3212	0.6918	0.9194	1.0820	8.2090	14.6950	7.9531	14.5428
+2498	1991.0027	1	1.3211	0.6918	0.9194	1.0820	8.2090	14.6950	7.9499	14.5341
+2499	1991.0055	2	1.3211	0.6917	0.9194	1.0820	8.2090	14.6950	7.9474	14.5252
+2500	1991.0082	3	1.3210	0.6917	0.9194	1.0820	8.2090	14.6950	7.9455	14.5163
+2501	1991.0110	4	1.3210	0.6917	0.9194	1.0820	8.2090	14.6950	7.9442	14.5074
+2502	1991.0137	5	1.3210	0.6917	0.9193	1.0820	8.2090	14.6950	7.9435	14.4984
+2503	1991.0164	6	1.3209	0.6917	0.9193	1.0820	8.2090	14.6950	7.9435	14.4894
+2504	1991.0192	7	1.3209	0.6917	0.9193	1.0820	8.2090	14.6950	7.9441	14.4803
+2505	1991.0219	8	1.3208	0.6916	0.9193	1.0820	8.2090	14.6950	7.9453	14.4713
+2506	1991.0247	9	1.3208	0.6916	0.9193	1.0820	8.2090	14.6950	7.9471	14.4623
+2507	1991.0274	10	1.3207	0.6916	0.9193	1.0820	8.2090	14.6950	7.9496	14.4533
+2508	1991.0301	11	1.3207	0.6916	0.9193	1.0820	8.2090	14.6950	7.9526	14.4444
+2509	1991.0329	12	1.3207	0.6916	0.9193	1.0820	8.2090	14.6950	7.9562	14.4356
+2510	1991.0356	13	1.3206	0.6915	0.9193	1.0820	8.2090	14.6950	7.9604	14.4268
+2511	1991.0384	14	1.3206	0.6915	0.9192	1.0820	8.2090	14.6950	7.9652	14.4182
+2512	1991.0411	15	1.3205	0.6915	0.9192	1.0820	8.2090	14.6950	7.9705	14.4096
+2513	1991.0438	16	1.3205	0.6915	0.9192	1.0820	8.2090	14.6950	7.9762	14.4012
+2514	1991.0466	17	1.3204	0.6915	0.9192	1.0820	8.2090	14.6950	7.9825	14.3930
+2515	1991.0493	18	1.3204	0.6915	0.9192	1.0820	8.2090	14.6950	7.9892	14.3849
+2516	1991.0521	19	1.3204	0.6914	0.9192	1.0820	8.2090	14.6950	7.9964	14.3769
+2517	1991.0548	20	1.3203	0.6914	0.9192	1.0820	8.2090	14.6950	8.0039	14.3692
+2518	1991.0575	21	1.3203	0.6914	0.9192	1.0820	8.2090	14.6950	8.0119	14.3617
+2519	1991.0603	22	1.3202	0.6914	0.9192	1.0820	8.2090	14.6950	8.0201	14.3543
+2520	1991.0630	23	1.3202	0.6914	0.9191	1.0820	8.2090	14.6950	8.0287	14.3472
+2521	1991.0658	24	1.3201	0.6914	0.9191	1.0820	8.2090	14.6950	8.0375	14.3403
+2522	1991.0685	25	1.3201	0.6913	0.9191	1.0820	8.2090	14.6950	8.0465	14.3337
+2523	1991.0712	26	1.3201	0.6913	0.9191	1.0820	8.2090	14.6950	8.0558	14.3273
+2524	1991.0740	27	1.3200	0.6913	0.9191	1.0820	8.2090	14.6950	8.0652	14.3212
+2525	1991.0767	28	1.3200	0.6913	0.9191	1.0820	8.2090	14.6950	8.0747	14.3153
+2526	1991.0795	29	1.3199	0.6913	0.9191	1.0820	8.2090	14.6950	8.0842	14.3098
+2527	1991.0822	30	1.3199	0.6913	0.9191	1.0820	8.2090	14.6950	8.0938	14.3045
+2528	1991.0849	31	1.3198	0.6912	0.9191	1.0820	8.2090	14.6950	8.1034	14.2995
+2529	1991.0877	32	1.3198	0.6912	0.9191	1.0820	8.2090	14.6950	8.1129	14.2948
+2530	1991.0904	33	1.3198	0.6912	0.9190	1.0820	8.2090	14.6950	8.1224	14.2904
+2531	1991.0932	34	1.3197	0.6912	0.9190	1.0820	8.2090	14.6950	8.1317	14.2864
+2532	1991.0959	35	1.3197	0.6912	0.9190	1.0820	8.2090	14.6950	8.1408	14.2826
+2533	1991.0986	36	1.3196	0.6911	0.9190	1.0820	8.2090	14.6950	8.1497	14.2792
+2534	1991.1014	37	1.3196	0.6911	0.9190	1.0820	8.2090	14.6950	8.1583	14.2761
+2535	1991.1041	38	1.3196	0.6911	0.9190	1.0820	8.2090	14.6950	8.1666	14.2734
+2536	1991.1068	39	1.3195	0.6911	0.9190	1.0820	8.2090	14.6950	8.1746	14.2709
+2537	1991.1096	40	1.3195	0.6911	0.9190	1.0820	8.2090	14.6950	8.1823	14.2688
+2538	1991.1123	41	1.3194	0.6911	0.9190	1.0820	8.2090	14.6950	8.1895	14.2670
+2539	1991.1151	42	1.3194	0.6910	0.9189	1.0820	8.2090	14.6950	8.1963	14.2656
+2540	1991.1178	43	1.3193	0.6910	0.9189	1.0820	8.2090	14.6950	8.2026	14.2645
+2541	1991.1205	44	1.3193	0.6910	0.9189	1.0820	8.2090	14.6950	8.2084	14.2637
+2542	1991.1233	45	1.3193	0.6910	0.9189	1.0820	8.2090	14.6950	8.2137	14.2633
+2543	1991.1260	46	1.3192	0.6910	0.9189	1.0820	8.2090	14.6950	8.2184	14.2632
+2544	1991.1288	47	1.3192	0.6910	0.9189	1.0820	8.2090	14.6950	8.2226	14.2634
+2545	1991.1315	48	1.3191	0.6909	0.9189	1.0820	8.2090	14.6950	8.2261	14.2639
+2546	1991.1342	49	1.3191	0.6909	0.9189	1.0820	8.2090	14.6950	8.2291	14.2648
+2547	1991.1370	50	1.3190	0.6909	0.9189	1.0820	8.2090	14.6950	8.2314	14.2660
+2548	1991.1397	51	1.3190	0.6909	0.9189	1.0820	8.2090	14.6950	8.2331	14.2674
+2549	1991.1425	52	1.3190	0.6909	0.9188	1.0820	8.2090	14.6950	8.2342	14.2692
+2550	1991.1452	53	1.3189	0.6909	0.9188	1.0820	8.2090	14.6950	8.2346	14.2713
+2551	1991.1479	54	1.3189	0.6908	0.9188	1.0820	8.2090	14.6950	8.2344	14.2737
+2552	1991.1507	55	1.3188	0.6908	0.9188	1.0820	8.2090	14.6950	8.2335	14.2763
+2553	1991.1534	56	1.3188	0.6908	0.9188	1.0820	8.2090	14.6950	8.2319	14.2793
+2554	1991.1562	57	1.3187	0.6908	0.9188	1.0820	8.2090	14.6950	8.2297	14.2825
+2555	1991.1589	58	1.3187	0.6908	0.9188	1.0820	8.2090	14.6950	8.2269	14.2859
+2556	1991.1616	59	1.3187	0.6907	0.9188	1.0820	8.2090	14.6950	8.2235	14.2896
+2557	1991.1644	60	1.3186	0.6907	0.9188	1.0820	8.2090	14.6950	8.2194	14.2936
+2558	1991.1671	61	1.3186	0.6907	0.9187	1.0820	8.2090	14.6950	8.2148	14.2978
+2559	1991.1699	62	1.3185	0.6907	0.9187	1.0820	8.2090	14.6950	8.2096	14.3021
+2560	1991.1726	63	1.3185	0.6907	0.9187	1.0820	8.2090	14.6950	8.2039	14.3067
+2561	1991.1753	64	1.3185	0.6907	0.9187	1.0820	8.2090	14.6950	8.1977	14.3115
+2562	1991.1781	65	1.3184	0.6906	0.9187	1.0820	8.2090	14.6950	8.1909	14.3165
+2563	1991.1808	66	1.3184	0.6906	0.9187	1.0820	8.2090	14.6950	8.1837	14.3217
+2564	1991.1836	67	1.3183	0.6906	0.9187	1.0820	8.2090	14.6950	8.1761	14.3270
+2565	1991.1863	68	1.3183	0.6906	0.9187	1.0820	8.2090	14.6950	8.1681	14.3324
+2566	1991.1890	69	1.3182	0.6906	0.9187	1.0820	8.2090	14.6950	8.1597	14.3380
+2567	1991.1918	70	1.3182	0.6906	0.9187	1.0820	8.2090	14.6950	8.1510	14.3437
+2568	1991.1945	71	1.3182	0.6905	0.9186	1.0820	8.2090	14.6950	8.1420	14.3495
+2569	1991.1973	72	1.3181	0.6905	0.9186	1.0820	8.2090	14.6950	8.1327	14.3554
+2570	1991.2000	73	1.3181	0.6905	0.9186	1.0820	8.2090	14.6950	8.1232	14.3614
+2571	1991.2027	74	1.3180	0.6905	0.9186	1.0820	8.2090	14.6950	8.1136	14.3674
+2572	1991.2055	75	1.3180	0.6905	0.9186	1.0820	8.2090	14.6950	8.1038	14.3735
+2573	1991.2082	76	1.3180	0.6905	0.9186	1.0820	8.2090	14.6950	8.0939	14.3796
+2574	1991.2110	77	1.3179	0.6904	0.9186	1.0820	8.2090	14.6950	8.0840	14.3858
+2575	1991.2137	78	1.3179	0.6904	0.9186	1.0820	8.2090	14.6950	8.0740	14.3919
+2576	1991.2164	79	1.3178	0.6904	0.9186	1.0820	8.2090	14.6950	8.0641	14.3981
+2577	1991.2192	80	1.3178	0.6904	0.9185	1.0820	8.2090	14.6950	8.0542	14.4042
+2578	1991.2219	81	1.3177	0.6904	0.9185	1.0820	8.2090	14.6950	8.0444	14.4103
+2579	1991.2247	82	1.3177	0.6904	0.9185	1.0820	8.2090	14.6950	8.0347	14.4163
+2580	1991.2274	83	1.3177	0.6903	0.9185	1.0820	8.2090	14.6950	8.0253	14.4222
+2581	1991.2301	84	1.3176	0.6903	0.9185	1.0820	8.2090	14.6950	8.0160	14.4281
+2582	1991.2329	85	1.3176	0.6903	0.9185	1.0820	8.2090	14.6950	8.0070	14.4339
+2583	1991.2356	86	1.3175	0.6903	0.9185	1.0820	8.2090	14.6950	7.9982	14.4396
+2584	1991.2384	87	1.3175	0.6903	0.9185	1.0820	8.2090	14.6950	7.9898	14.4451
+2585	1991.2411	88	1.3175	0.6903	0.9185	1.0820	8.2090	14.6950	7.9817	14.4505
+2586	1991.2438	89	1.3174	0.6902	0.9185	1.0820	8.2090	14.6950	7.9739	14.4558
+2587	1991.2466	90	1.3174	0.6902	0.9184	1.0820	8.2090	14.6950	7.9666	14.4609
+2588	1991.2493	91	1.3173	0.6902	0.9184	1.0820	8.2090	14.6950	7.9596	14.4658
+2589	1991.2521	92	1.3173	0.6902	0.9184	1.0820	8.2090	14.6950	7.9531	14.4706
+2590	1991.2548	93	1.3172	0.6902	0.9184	1.0820	8.2090	14.6950	7.9471	14.4751
+2591	1991.2575	94	1.3172	0.6901	0.9184	1.0820	8.2090	14.6950	7.9416	14.4795
+2592	1991.2603	95	1.3172	0.6901	0.9184	1.0820	8.2090	14.6950	7.9365	14.4836
+2593	1991.2630	96	1.3171	0.6901	0.9184	1.0820	8.2090	14.6950	7.9320	14.4874
+2594	1991.2658	97	1.3171	0.6901	0.9184	1.0820	8.2090	14.6950	7.9280	14.4911
+2595	1991.2685	98	1.3170	0.6901	0.9184	1.0820	8.2090	14.6950	7.9246	14.4945
+2596	1991.2712	99	1.3170	0.6901	0.9184	1.0820	8.2090	14.6950	7.9217	14.4976
+2597	1991.2740	100	1.3170	0.6900	0.9183	1.0820	8.2090	14.6950	7.9194	14.5005
+2598	1991.2767	101	1.3169	0.6900	0.9183	1.0820	8.2090	14.6950	7.9177	14.5030
+2599	1991.2795	102	1.3169	0.6900	0.9183	1.0820	8.2090	14.6950	7.9165	14.5053
+2600	1991.2822	103	1.3168	0.6900	0.9183	1.0820	8.2090	14.6950	7.9159	14.5073
+2601	1991.2849	104	1.3168	0.6900	0.9183	1.0820	8.2090	14.6950	7.9159	14.5091
+2602	1991.2877	105	1.3167	0.6900	0.9183	1.0820	8.2090	14.6950	7.9165	14.5105
+2603	1991.2904	106	1.3167	0.6899	0.9183	1.0820	8.2090	14.6950	7.9176	14.5116
+2604	1991.2932	107	1.3167	0.6899	0.9183	1.0820	8.2090	14.6950	7.9194	14.5124
+2605	1991.2959	108	1.3166	0.6899	0.9183	1.0820	8.2090	14.6950	7.9216	14.5128
+2606	1991.2986	109	1.3166	0.6899	0.9183	1.0820	8.2090	14.6950	7.9245	14.5130
+2607	1991.3014	110	1.3165	0.6899	0.9182	1.0820	8.2090	14.6950	7.9278	14.5128
+2608	1991.3041	111	1.3165	0.6899	0.9182	1.0820	8.2090	14.6950	7.9317	14.5123
+2609	1991.3068	112	1.3165	0.6898	0.9182	1.0820	8.2090	14.6950	7.9361	14.5115
+2610	1991.3096	113	1.3164	0.6898	0.9182	1.0820	8.2090	14.6950	7.9410	14.5104
+2611	1991.3123	114	1.3164	0.6898	0.9182	1.0820	8.2090	14.6950	7.9464	14.5090
+2612	1991.3151	115	1.3163	0.6898	0.9182	1.0820	8.2090	14.6950	7.9522	14.5072
+2613	1991.3178	116	1.3163	0.6898	0.9182	1.0820	8.2090	14.6950	7.9584	14.5051
+2614	1991.3205	117	1.3163	0.6898	0.9182	1.0820	8.2090	14.6950	7.9651	14.5027
+2615	1991.3233	118	1.3162	0.6897	0.9182	1.0820	8.2090	14.6950	7.9721	14.4999
+2616	1991.3260	119	1.3162	0.6897	0.9182	1.0820	8.2090	14.6950	7.9795	14.4969
+2617	1991.3288	120	1.3161	0.6897	0.9181	1.0820	8.2090	14.6950	7.9872	14.4935
+2618	1991.3315	121	1.3161	0.6897	0.9181	1.0820	8.2090	14.6950	8.2090	14.6950
+2619	1991.3342	122	1.3161	0.6897	0.9181	1.0820	8.2090	14.6950	8.2013	14.6948
+2620	1991.3370	123	1.3160	0.6897	0.9181	1.0820	8.2090	14.6950	8.1932	14.6942
+2621	1991.3397	124	1.3160	0.6896	0.9181	1.0820	8.2090	14.6950	8.1847	14.6933
+2622	1991.3425	125	1.3159	0.6896	0.9181	1.0820	8.2090	14.6950	8.1760	14.6921
+2623	1991.3452	126	1.3159	0.6896	0.9181	1.0820	8.2090	14.6950	8.1670	14.6906
+2624	1991.3479	127	1.3158	0.6896	0.9181	1.0820	8.2090	14.6950	8.1578	14.6887
+2625	1991.3507	128	1.3158	0.6896	0.9181	1.0820	8.2090	14.6950	8.1483	14.6865
+2626	1991.3534	129	1.3158	0.6896	0.9181	1.0820	8.2090	14.6950	8.1388	14.6840
+2627	1991.3562	130	1.3157	0.6895	0.9180	1.0820	8.2090	14.6950	8.1291	14.6812
+2628	1991.3589	131	1.3157	0.6895	0.9180	1.0820	8.2090	14.6950	8.1193	14.6780
+2629	1991.3616	132	1.3156	0.6895	0.9180	1.0820	8.2090	14.6950	8.1095	14.6746
+2630	1991.3644	133	1.3156	0.6895	0.9180	1.0820	8.2090	14.6950	8.0997	14.6708
+2631	1991.3671	134	1.3156	0.6895	0.9180	1.0820	8.2090	14.6950	8.0899	14.6667
+2632	1991.3699	135	1.3155	0.6895	0.9180	1.0820	8.2090	14.6950	8.0802	14.6624
+2633	1991.3726	136	1.3155	0.6894	0.9180	1.0820	8.2090	14.6950	8.0706	14.6577
+2634	1991.3753	137	1.3154	0.6894	0.9180	1.0820	8.2090	14.6950	8.0611	14.6528
+2635	1991.3781	138	1.3154	0.6894	0.9180	1.0820	8.2090	14.6950	8.0518	14.6476
+2636	1991.3808	139	1.3154	0.6894	0.9180	1.0820	8.2090	14.6950	8.0427	14.6421
+2637	1991.3836	140	1.3153	0.6894	0.9179	1.0820	8.2090	14.6950	8.0338	14.6364
+2638	1991.3863	141	1.3153	0.6894	0.9179	1.0820	8.2090	14.6950	8.0252	14.6304
+2639	1991.3890	142	1.3152	0.6893	0.9179	1.0820	8.2090	14.6950	8.0169	14.6242
+2640	1991.3918	143	1.3152	0.6893	0.9179	1.0820	8.2090	14.6950	8.0090	14.6178
+2641	1991.3945	144	1.3152	0.6893	0.9179	1.0820	8.2090	14.6950	8.0014	14.6112
+2642	1991.3973	145	1.3151	0.6893	0.9179	1.0820	8.2090	14.6950	7.9942	14.6043
+2643	1991.4000	146	1.3151	0.6893	0.9179	1.0820	8.2090	14.6950	7.9873	14.5973
+2644	1991.4027	147	1.3150	0.6892	0.9179	1.0820	8.2090	14.6950	7.9809	14.5900
+2645	1991.4055	148	1.3150	0.6892	0.9179	1.0820	8.2090	14.6950	7.9750	14.5826
+2646	1991.4082	149	1.3149	0.6892	0.9179	1.0820	8.2090	14.6950	7.9695	14.5751
+2647	1991.4110	150	1.3149	0.6892	0.9178	1.0820	8.2090	14.6950	7.9645	14.5674
+2648	1991.4137	151	1.3149	0.6892	0.9178	1.0820	8.2090	14.6950	7.9600	14.5595
+2649	1991.4164	152	1.3148	0.6892	0.9178	1.0820	8.2090	14.6950	7.9561	14.5516
+2650	1991.4192	153	1.3148	0.6891	0.9178	1.0820	8.2090	14.6950	7.9526	14.5435
+2651	1991.4219	154	1.3147	0.6891	0.9178	1.0820	8.2090	14.6950	7.9497	14.5354
+2652	1991.4247	155	1.3147	0.6891	0.9178	1.0820	8.2090	14.6950	7.9474	14.5271
+2653	1991.4274	156	1.3147	0.6891	0.9178	1.0820	8.2090	14.6950	7.9455	14.5188
+2654	1991.4301	157	1.3146	0.6891	0.9178	1.0820	8.2090	14.6950	7.9443	14.5105
+2655	1991.4329	158	1.3146	0.6891	0.9178	1.0820	8.2090	14.6950	7.9436	14.5021
+2656	1991.4356	159	1.3145	0.6890	0.9178	1.0820	8.2090	14.6950	7.9434	14.4936
+2657	1991.4384	160	1.3145	0.6890	0.9177	1.0820	8.2090	14.6950	7.9439	14.4852
+2658	1991.4411	161	1.3145	0.6890	0.9177	1.0820	8.2090	14.6950	7.9448	14.4767
+2659	1991.4438	162	1.3144	0.6890	0.9177	1.0820	8.2090	14.6950	7.9464	14.4683
+2660	1991.4466	163	1.3144	0.6890	0.9177	1.0820	8.2090	14.6950	7.9484	14.4599
+2661	1991.4493	164	1.3143	0.6890	0.9177	1.0820	8.2090	14.6950	7.9510	14.4515
+2662	1991.4521	165	1.3143	0.6889	0.9177	1.0820	8.2090	14.6950	7.9541	14.4432
+2663	1991.4548	166	1.3143	0.6889	0.9177	1.0820	8.2090	14.6950	7.9578	14.4350
+2664	1991.4575	167	1.3142	0.6889	0.9177	1.0820	8.2090	14.6950	7.9619	14.4268
+2665	1991.4603	168	1.3142	0.6889	0.9177	1.0820	8.2090	14.6950	7.9665	14.4187
+2666	1991.4630	169	1.3141	0.6889	0.9177	1.0820	8.2090	14.6950	7.9716	14.4107
+2667	1991.4658	170	1.3141	0.6889	0.9176	1.0820	8.2090	14.6950	7.9771	14.4028
+2668	1991.4685	171	1.3141	0.6888	0.9176	1.0820	8.2090	14.6950	7.9831	14.3951
+2669	1991.4712	172	1.3140	0.6888	0.9176	1.0820	8.2090	14.6950	7.9894	14.3875
+2670	1991.4740	173	1.3140	0.6888	0.9176	1.0820	8.2090	14.6950	7.9962	14.3800
+2671	1991.4767	174	1.3139	0.6888	0.9176	1.0820	8.2090	14.6950	8.0033	14.3727
+2672	1991.4795	175	1.3139	0.6888	0.9176	1.0820	8.2090	14.6950	8.0107	14.3655
+2673	1991.4822	176	1.3139	0.6888	0.9176	1.0820	8.2090	14.6950	8.0184	14.3586
+2674	1991.4849	177	1.3138	0.6887	0.9176	1.0820	8.2090	14.6950	8.0264	14.3518
+2675	1991.4877	178	1.3138	0.6887	0.9176	1.0820	8.2090	14.6950	8.0347	14.3452
+2676	1991.4904	179	1.3137	0.6887	0.9176	1.0820	8.2090	14.6950	8.0431	14.3388
+2677	1991.4932	180	1.3137	0.6887	0.9176	1.0820	8.2090	14.6950	8.0517	14.3327
+2678	1991.4959	181	1.3137	0.6887	0.9175	1.0820	8.2090	14.6950	8.0605	14.3267
+2679	1991.4986	182	1.3136	0.6887	0.9175	1.0820	8.2090	14.6950	8.0694	14.3210
+2680	1991.5014	183	1.3136	0.6886	0.9175	1.0820	8.2090	14.6950	8.0784	14.3156
+2681	1991.5041	184	1.3135	0.6886	0.9175	1.0820	8.2090	14.6950	8.0874	14.3103
+2682	1991.5068	185	1.3135	0.6886	0.9175	1.0820	8.2090	14.6950	8.0964	14.3054
+2683	1991.5096	186	1.3135	0.6886	0.9175	1.0820	8.2090	14.6950	8.1055	14.3006
+2684	1991.5123	187	1.3134	0.6886	0.9175	1.0820	8.2090	14.6950	8.1144	14.2962
+2685	1991.5151	188	1.3134	0.6886	0.9175	1.0820	8.2090	14.6950	8.1233	14.2920
+2686	1991.5178	189	1.3133	0.6885	0.9175	1.0820	8.2090	14.6950	8.1320	14.2881
+2687	1991.5205	190	1.3133	0.6885	0.9175	1.0820	8.2090	14.6950	8.1406	14.2844
+2688	1991.5233	191	1.3133	0.6885	0.9174	1.0820	8.2090	14.6950	8.1490	14.2811
+2689	1991.5260	192	1.3132	0.6885	0.9174	1.0820	8.2090	14.6950	8.1572	14.2780
+2690	1991.5288	193	1.3132	0.6885	0.9174	1.0820	8.2090	14.6950	8.1651	14.2752
+2691	1991.5315	194	1.3131	0.6885	0.9174	1.0820	8.2090	14.6950	8.1727	14.2727
+2692	1991.5342	195	1.3131	0.6884	0.9174	1.0820	8.2090	14.6950	8.1800	14.2705
+2693	1991.5370	196	1.3131	0.6884	0.9174	1.0820	8.2090	14.6950	8.1869	14.2686
+2694	1991.5397	197	1.3130	0.6884	0.9174	1.0820	8.2090	14.6950	8.1934	14.2670
+2695	1991.5425	198	1.3130	0.6884	0.9174	1.0820	8.2090	14.6950	8.1996	14.2656
+2696	1991.5452	199	1.3129	0.6884	0.9174	1.0820	8.2090	14.6950	8.2053	14.2646
+2697	1991.5479	200	1.3129	0.6884	0.9174	1.0820	8.2090	14.6950	8.2106	14.2638
+2698	1991.5507	201	1.3129	0.6883	0.9174	1.0820	8.2090	14.6950	8.2154	14.2634
+2699	1991.5534	202	1.3128	0.6883	0.9173	1.0820	8.2090	14.6950	8.2197	14.2632
+2700	1991.5562	203	1.3128	0.6883	0.9173	1.0820	8.2090	14.6950	8.2234	14.2633
+2701	1991.5589	204	1.3127	0.6883	0.9173	1.0820	8.2090	14.6950	8.2267	14.2637
+2702	1991.5616	205	1.3127	0.6883	0.9173	1.0820	8.2090	14.6950	8.2294	14.2643
+2703	1991.5644	206	1.3127	0.6883	0.9173	1.0820	8.2090	14.6950	8.2315	14.2653
+2704	1991.5671	207	1.3126	0.6882	0.9173	1.0820	8.2090	14.6950	8.2331	14.2665
+2705	1991.5699	208	1.3126	0.6882	0.9173	1.0820	8.2090	14.6950	8.2341	14.2680
+2706	1991.5726	209	1.3125	0.6882	0.9173	1.0820	8.2090	14.6950	8.2346	14.2698
+2707	1991.5753	210	1.3125	0.6882	0.9173	1.0820	8.2090	14.6950	8.2344	14.2718
+2708	1991.5781	211	1.3125	0.6882	0.9173	1.0820	8.2090	14.6950	8.2337	14.2740
+2709	1991.5808	212	1.3124	0.6882	0.9172	1.0820	8.2090	14.6950	8.2324	14.2766
+2710	1991.5836	213	1.3124	0.6881	0.9172	1.0820	8.2090	14.6950	8.2306	14.2793
+2711	1991.5863	214	1.3123	0.6881	0.9172	1.0820	8.2090	14.6950	8.2282	14.2823
+2712	1991.5890	215	1.3123	0.6881	0.9172	1.0820	8.2090	14.6950	8.2252	14.2855
+2713	1991.5918	216	1.3123	0.6881	0.9172	1.0820	8.2090	14.6950	8.2217	14.2889
+2714	1991.5945	217	1.3122	0.6881	0.9172	1.0820	8.2090	14.6950	8.2176	14.2926
+2715	1991.5973	218	1.3122	0.6881	0.9172	1.0820	8.2090	14.6950	8.2131	14.2964
+2716	1991.6000	219	1.3121	0.6881	0.9172	1.0820	8.2090	14.6950	8.2080	14.3005
+2717	1991.6027	220	1.3121	0.6880	0.9172	1.0820	8.2090	14.6950	8.2025	14.3047
+2718	1991.6055	221	1.3121	0.6880	0.9172	1.0820	8.2090	14.6950	8.1965	14.3091
+2719	1991.6082	222	1.3120	0.6880	0.9172	1.0820	8.2090	14.6950	8.1901	14.3136
+2720	1991.6110	223	1.3120	0.6880	0.9171	1.0820	8.2090	14.6950	8.1833	14.3183
+2721	1991.6137	224	1.3119	0.6880	0.9171	1.0820	8.2090	14.6950	8.1761	14.3232
+2722	1991.6164	225	1.3119	0.6880	0.9171	1.0820	8.2090	14.6950	8.1685	14.3282
+2723	1991.6192	226	1.3119	0.6879	0.9171	1.0820	8.2090	14.6950	8.1606	14.3333
+2724	1991.6219	227	1.3118	0.6879	0.9171	1.0820	8.2090	14.6950	8.1525	14.3386
+2725	1991.6247	228	1.3118	0.6879	0.9171	1.0820	8.2090	14.6950	8.1441	14.3439
+2726	1991.6274	229	1.3117	0.6879	0.9171	1.0820	8.2090	14.6950	8.1354	14.3493
+2727	1991.6301	230	1.3117	0.6879	0.9171	1.0820	8.2090	14.6950	8.1265	14.3548
+2728	1991.6329	231	1.3117	0.6879	0.9171	1.0820	8.2090	14.6950	8.1175	14.3604
+2729	1991.6356	232	1.3116	0.6878	0.9171	1.0820	8.2090	14.6950	8.1083	14.3661
+2730	1991.6384	233	1.3116	0.6878	0.9171	1.0820	8.2090	14.6950	8.0991	14.3717
+2731	1991.6411	234	1.3116	0.6878	0.9170	1.0820	8.2090	14.6950	8.0897	14.3775
+2732	1991.6438	235	1.3115	0.6878	0.9170	1.0820	8.2090	14.6950	8.0803	14.3832
+2733	1991.6466	236	1.3115	0.6878	0.9170	1.0820	8.2090	14.6950	8.0710	14.3889
+2734	1991.6493	237	1.3114	0.6878	0.9170	1.0820	8.2090	14.6950	8.0616	14.3947
+2735	1991.6521	238	1.3114	0.6877	0.9170	1.0820	8.2090	14.6950	8.0523	14.4004
+2736	1991.6548	239	1.3114	0.6877	0.9170	1.0820	8.2090	14.6950	8.0431	14.4061
+2737	1991.6575	240	1.3113	0.6877	0.9170	1.0820	8.2090	14.6950	8.0340	14.4118
+2738	1991.6603	241	1.3113	0.6877	0.9170	1.0820	8.2090	14.6950	8.0251	14.4174
+2739	1991.6630	242	1.3112	0.6877	0.9170	1.0820	8.2090	14.6950	8.0164	14.4230
+2740	1991.6658	243	1.3112	0.6877	0.9170	1.0820	8.2090	14.6950	8.0079	14.4285
+2741	1991.6685	244	1.3112	0.6876	0.9169	1.0820	8.2090	14.6950	7.9996	14.4339
+2742	1991.6712	245	1.3111	0.6876	0.9169	1.0820	8.2090	14.6950	7.9916	14.4392
+2743	1991.6740	246	1.3111	0.6876	0.9169	1.0820	8.2090	14.6950	7.9839	14.4444
+2744	1991.6767	247	1.3110	0.6876	0.9169	1.0820	8.2090	14.6950	7.9765	14.4495
+2745	1991.6795	248	1.3110	0.6876	0.9169	1.0820	8.2090	14.6950	7.9694	14.4544
+2746	1991.6822	249	1.3110	0.6876	0.9169	1.0820	8.2090	14.6950	7.9627	14.4592
+2747	1991.6849	250	1.3109	0.6875	0.9169	1.0820	8.2090	14.6950	7.9564	14.4639
+2748	1991.6877	251	1.3109	0.6875	0.9169	1.0820	8.2090	14.6950	7.9505	14.4684
+2749	1991.6904	252	1.3108	0.6875	0.9169	1.0820	8.2090	14.6950	7.9450	14.4727
+2750	1991.6932	253	1.3108	0.6875	0.9169	1.0820	8.2090	14.6950	7.9399	14.4769
+2751	1991.6959	254	1.3108	0.6875	0.9169	1.0820	8.2090	14.6950	7.9353	14.4809
+2752	1991.6986	255	1.3107	0.6875	0.9168	1.0820	8.2090	14.6950	7.9312	14.4847
+2753	1991.7014	256	1.3107	0.6874	0.9168	1.0820	8.2090	14.6950	7.9275	14.4882
+2754	1991.7041	257	1.3107	0.6874	0.9168	1.0820	8.2090	14.6950	7.9244	14.4916
+2755	1991.7068	258	1.3106	0.6874	0.9168	1.0820	8.2090	14.6950	7.9217	14.4947
+2756	1991.7096	259	1.3106	0.6874	0.9168	1.0820	8.2090	14.6950	7.9195	14.4976
+2757	1991.7123	260	1.3105	0.6874	0.9168	1.0820	8.2090	14.6950	7.9178	14.5003
+2758	1991.7151	261	1.3105	0.6874	0.9168	1.0820	8.2090	14.6950	7.9167	14.5028
+2759	1991.7178	262	1.3105	0.6873	0.9168	1.0820	8.2090	14.6950	7.9160	14.5049
+2760	1991.7205	263	1.3104	0.6873	0.9168	1.0820	8.2090	14.6950	7.9159	14.5069
+2761	1991.7233	264	1.3104	0.6873	0.9168	1.0820	8.2090	14.6950	7.9163	14.5086
+2762	1991.7260	265	1.3103	0.6873	0.9168	1.0820	8.2090	14.6950	7.9171	14.5100
+2763	1991.7288	266	1.3103	0.6873	0.9167	1.0820	8.2090	14.6950	7.9185	14.5111
+2764	1991.7315	267	1.3103	0.6873	0.9167	1.0820	8.2090	14.6950	7.9204	14.5120
+2765	1991.7342	268	1.3102	0.6872	0.9167	1.0820	8.2090	14.6950	7.9228	14.5126
+2766	1991.7370	269	1.3102	0.6872	0.9167	1.0820	8.2090	14.6950	7.9257	14.5129
+2767	1991.7397	270	1.3101	0.6872	0.9167	1.0820	8.2090	14.6950	7.9290	14.5130
+2768	1991.7425	271	1.3101	0.6872	0.9167	1.0820	8.2090	14.6950	7.9328	14.5127
+2769	1991.7452	272	1.3101	0.6872	0.9167	1.0820	8.2090	14.6950	7.9371	14.5122
+2770	1991.7479	273	1.3100	0.6872	0.9167	1.0820	8.2090	14.6950	7.9418	14.5114
+2771	1991.7507	274	1.3100	0.6872	0.9167	1.0820	8.2090	14.6950	7.9469	14.5104
+2772	1991.7534	275	1.3100	0.6871	0.9167	1.0820	8.2090	14.6950	8.2090	14.6950
+2773	1991.7562	276	1.3099	0.6871	0.9167	1.0820	8.2090	14.6950	8.2017	14.6948
+2774	1991.7589	277	1.3099	0.6871	0.9166	1.0820	8.2090	14.6950	8.1941	14.6943
+2775	1991.7616	278	1.3098	0.6871	0.9166	1.0820	8.2090	14.6950	8.1862	14.6935
+2776	1991.7644	279	1.3098	0.6871	0.9166	1.0820	8.2090	14.6950	8.1780	14.6924
+2777	1991.7671	280	1.3098	0.6871	0.9166	1.0820	8.2090	14.6950	8.1695	14.6911
+2778	1991.7699	281	1.3097	0.6870	0.9166	1.0820	8.2090	14.6950	8.1609	14.6894
+2779	1991.7726	282	1.3097	0.6870	0.9166	1.0820	8.2090	14.6950	8.1521	14.6875
+2780	1991.7753	283	1.3096	0.6870	0.9166	1.0820	8.2090	14.6950	8.1431	14.6853
+2781	1991.7781	284	1.3096	0.6870	0.9166	1.0820	8.2090	14.6950	8.1340	14.6828
+2782	1991.7808	285	1.3096	0.6870	0.9166	1.0820	8.2090	14.6950	8.1248	14.6800
+2783	1991.7836	286	1.3095	0.6870	0.9166	1.0820	8.2090	14.6950	8.1156	14.6770
+2784	1991.7863	287	1.3095	0.6869	0.9166	1.0820	8.2090	14.6950	8.1063	14.6736
+2785	1991.7890	288	1.3095	0.6869	0.9165	1.0820	8.2090	14.6950	8.0970	14.6700
+2786	1991.7918	289	1.3094	0.6869	0.9165	1.0820	8.2090	14.6950	8.0878	14.6662
+2787	1991.7945	290	1.3094	0.6869	0.9165	1.0820	8.2090	14.6950	8.0786	14.6621
+2788	1991.7973	291	1.3093	0.6869	0.9165	1.0820	8.2090	14.6950	8.0696	14.6577
+2789	1991.8000	292	1.3093	0.6869	0.9165	1.0820	8.2090	14.6950	8.0606	14.6531
+2790	1991.8027	293	1.3093	0.6868	0.9165	1.0820	8.2090	14.6950	8.0519	14.6482
+2791	1991.8055	294	1.3092	0.6868	0.9165	1.0820	8.2090	14.6950	8.0433	14.6431
+2792	1991.8082	295	1.3092	0.6868	0.9165	1.0820	8.2090	14.6950	8.0349	14.6378
+2793	1991.8110	296	1.3091	0.6868	0.9165	1.0820	8.2090	14.6950	8.0267	14.6323
+2794	1991.8137	297	1.3091	0.6868	0.9165	1.0820	8.2090	14.6950	8.0188	14.6266
+2795	1991.8164	298	1.3091	0.6868	0.9165	1.0820	8.2090	14.6950	8.0112	14.6206
+2796	1991.8192	299	1.3090	0.6867	0.9164	1.0820	8.2090	14.6950	8.0040	14.6145
+2797	1991.8219	300	1.3090	0.6867	0.9164	1.0820	8.2090	14.6950	7.9970	14.6081
+2798	1991.8247	301	1.3090	0.6867	0.9164	1.0820	8.2090	14.6950	7.9904	14.6016
+2799	1991.8274	302	1.3089	0.6867	0.9164	1.0820	8.2090	14.6950	7.9842	14.5950
+2800	1991.8301	303	1.3089	0.6867	0.9164	1.0820	8.2090	14.6950	7.9783	14.5882
+2801	1991.8329	304	1.3088	0.6867	0.9164	1.0820	8.2090	14.6950	7.9729	14.5812
+2802	1991.8356	305	1.3088	0.6867	0.9164	1.0820	8.2090	14.6950	7.9679	14.5741
+2803	1991.8384	306	1.3088	0.6866	0.9164	1.0820	8.2090	14.6950	7.9633	14.5668
+2804	1991.8411	307	1.3087	0.6866	0.9164	1.0820	8.2090	14.6950	7.9592	14.5595
+2805	1991.8438	308	1.3087	0.6866	0.9164	1.0820	8.2090	14.6950	7.9555	14.5520
+2806	1991.8466	309	1.3086	0.6866	0.9164	1.0820	8.2090	14.6950	7.9523	14.5445
+2807	1991.8493	310	1.3086	0.6866	0.9164	1.0820	8.2090	14.6950	7.9496	14.5368
+2808	1991.8521	311	1.3086	0.6866	0.9163	1.0820	8.2090	14.6950	7.9474	14.5291
+2809	1991.8548	312	1.3085	0.6865	0.9163	1.0820	8.2090	14.6950	7.9457	14.5214
+2810	1991.8575	313	1.3085	0.6865	0.9163	1.0820	8.2090	14.6950	7.9444	14.5135
+2811	1991.8603	314	1.3085	0.6865	0.9163	1.0820	8.2090	14.6950	7.9437	14.5057
+2812	1991.8630	315	1.3084	0.6865	0.9163	1.0820	8.2090	14.6950	7.9434	14.4978
+2813	1991.8658	316	1.3084	0.6865	0.9163	1.0820	8.2090	14.6950	7.9437	14.4899
+2814	1991.8685	317	1.3083	0.6865	0.9163	1.0820	8.2090	14.6950	7.9444	14.4819
+2815	1991.8712	318	1.3083	0.6864	0.9163	1.0820	8.2090	14.6950	7.9457	14.4740
+2816	1991.8740	319	1.3083	0.6864	0.9163	1.0820	8.2090	14.6950	7.9474	14.4661
+2817	1991.8767	320	1.3082	0.6864	0.9163	1.0820	8.2090	14.6950	7.9496	14.4582
+2818	1991.8795	321	1.3082	0.6864	0.9163	1.0820	8.2090	14.6950	7.9523	14.4504
+2819	1991.8822	322	1.3081	0.6864	0.9162	1.0820	8.2090	14.6950	7.9554	14.4426
+2820	1991.8849	323	1.3081	0.6864	0.9162	1.0820	8.2090	14.6950	7.9590	14.4349
+2821	1991.8877	324	1.3081	0.6863	0.9162	1.0820	8.2090	14.6950	7.9630	14.4272
+2822	1991.8904	325	1.3080	0.6863	0.9162	1.0820	8.2090	14.6950	7.9675	14.4196
+2823	1991.8932	326	1.3080	0.6863	0.9162	1.0820	8.2090	14.6950	7.9724	14.4121
+2824	1991.8959	327	1.3080	0.6863	0.9162	1.0820	8.2090	14.6950	7.9776	14.4047
+2825	1991.8986	328	1.3079	0.6863	0.9162	1.0820	8.2090	14.6950	7.9833	14.3974
+2826	1991.9014	329	1.3079	0.6863	0.9162	1.0820	8.2090	14.6950	7.9893	14.3902
+2827	1991.9041	330	1.3078	0.6863	0.9162	1.0820	8.2090	14.6950	7.9956	14.3831
+2828	1991.9068	331	1.3078	0.6862	0.9162	1.0820	8.2090	14.6950	8.0023	14.3762
+2829	1991.9096	332	1.3078	0.6862	0.9162	1.0820	8.2090	14.6950	8.0092	14.3694
+2830	1991.9123	333	1.3077	0.6862	0.9161	1.0820	8.2090	14.6950	8.0165	14.3628
+2831	1991.9151	334	1.3077	0.6862	0.9161	1.0820	8.2090	14.6950	8.0239	14.3563
+2832	1991.9178	335	1.3077	0.6862	0.9161	1.0820	8.2090	14.6950	8.0316	14.3500
+2833	1991.9205	336	1.3076	0.6862	0.9161	1.0820	8.2090	14.6950	8.0395	14.3439
+2834	1991.9233	337	1.3076	0.6861	0.9161	1.0820	8.2090	14.6950	8.0476	14.3380
+2835	1991.9260	338	1.3075	0.6861	0.9161	1.0820	8.2090	14.6950	8.0558	14.3322
+2836	1991.9288	339	1.3075	0.6861	0.9161	1.0820	8.2090	14.6950	8.0642	14.3266
+2837	1991.9315	340	1.3075	0.6861	0.9161	1.0820	8.2090	14.6950	8.0726	14.3213
+2838	1991.9342	341	1.3074	0.6861	0.9161	1.0820	8.2090	14.6950	8.0811	14.3161
+2839	1991.9370	342	1.3074	0.6861	0.9161	1.0820	8.2090	14.6950	8.0896	14.3112
+2840	1991.9397	343	1.3074	0.6860	0.9161	1.0820	8.2090	14.6950	8.0982	14.3065
+2841	1991.9425	344	1.3073	0.6860	0.9161	1.0820	8.2090	14.6950	8.1067	14.3020
+2842	1991.9452	345	1.3073	0.6860	0.9160	1.0820	8.2090	14.6950	8.1151	14.2978
+2843	1991.9479	346	1.3072	0.6860	0.9160	1.0820	8.2090	14.6950	8.1235	14.2937
+2844	1991.9507	347	1.3072	0.6860	0.9160	1.0820	8.2090	14.6950	8.1317	14.2899
+2845	1991.9534	348	1.3072	0.6860	0.9160	1.0820	8.2090	14.6950	8.1398	14.2864
+2846	1991.9562	349	1.3071	0.6859	0.9160	1.0820	8.2090	14.6950	8.1478	14.2831
+2847	1991.9589	350	1.3071	0.6859	0.9160	1.0820	8.2090	14.6950	8.1555	14.2800
+2848	1991.9616	351	1.3071	0.6859	0.9160	1.0820	8.2090	14.6950	8.1630	14.2772
+2849	1991.9644	352	1.3070	0.6859	0.9160	1.0820	8.2090	14.6950	8.1703	14.2747
+2850	1991.9671	353	1.3070	0.6859	0.9160	1.0820	8.2090	14.6950	8.1773	14.2724
+2851	1991.9699	354	1.3069	0.6859	0.9160	1.0820	8.2090	14.6950	8.1840	14.2703
+2852	1991.9726	355	1.3069	0.6859	0.9160	1.0820	8.2090	14.6950	8.1903	14.2686
+2853	1991.9753	356	1.3069	0.6858	0.9159	1.0820	8.2090	14.6950	8.1963	14.2670
+2854	1991.9781	357	1.3068	0.6858	0.9159	1.0820	8.2090	14.6950	8.2020	14.2657
+2855	1991.9808	358	1.3068	0.6858	0.9159	1.0820	8.2090	14.6950	8.2072	14.2647
+2856	1991.9836	359	1.3068	0.6858	0.9159	1.0820	8.2090	14.6950	8.2120	14.2640
+2857	1991.9863	360	1.3067	0.6858	0.9159	1.0820	8.2090	14.6950	8.2164	14.2635
+2858	1991.9890	361	1.3067	0.6858	0.9159	1.0820	8.2090	14.6950	8.2204	14.2632
+2859	1991.9918	362	1.3066	0.6857	0.9159	1.0820	8.2090	14.6950	8.2239	14.2632
+2860	1991.9945	363	1.3066	0.6857	0.9159	1.0820	8.2090	14.6950	8.2269	14.2635
+2861	1991.9973	364	1.3066	0.6857	0.9159	1.0820	8.2090	14.6950	8.2294	14.2639
+2862	1991.9999	365	1.3065	0.6857	0.9159	1.0820	8.2090	14.6950	8.2315	14.2647
+2863	1992.0027	1	1.3065	0.6857	0.9159	1.0820	8.2090	14.6950	8.2330	14.2657
+2864	1992.0055	2	1.3065	0.6857	0.9159	1.0820	8.2090	14.6950	8.2340	14.2669
+2865	1992.0082	3	1.3064	0.6856	0.9158	1.0820	8.2090	14.6950	8.2345	14.2684
+2866	1992.0109	4	1.3064	0.6856	0.9158	1.0820	8.2090	14.6950	8.2345	14.2700
+2867	1992.0137	5	1.3063	0.6856	0.9158	1.0820	8.2090	14.6950	8.2340	14.2720
+2868	1992.0164	6	1.3063	0.6856	0.9158	1.0820	8.2090	14.6950	8.2330	14.2741
+2869	1992.0191	7	1.3063	0.6856	0.9158	1.0820	8.2090	14.6950	8.2315	14.2765
+2870	1992.0219	8	1.3062	0.6856	0.9158	1.0820	8.2090	14.6950	8.2294	14.2790
+2871	1992.0246	9	1.3062	0.6856	0.9158	1.0820	8.2090	14.6950	8.2269	14.2818
+2872	1992.0273	10	1.3062	0.6855	0.9158	1.0820	8.2090	14.6950	8.2239	14.2848
+2873	1992.0301	11	1.3061	0.6855	0.9158	1.0820	8.2090	14.6950	8.2203	14.2879
+2874	1992.0328	12	1.3061	0.6855	0.9158	1.0820	8.2090	14.6950	8.2164	14.2913
+2875	1992.0355	13	1.3060	0.6855	0.9158	1.0820	8.2090	14.6950	8.2120	14.2948
+2876	1992.0383	14	1.3060	0.6855	0.9158	1.0820	8.2090	14.6950	8.2071	14.2985
+2877	1992.0410	15	1.3060	0.6855	0.9157	1.0820	8.2090	14.6950	8.2018	14.3024
+2878	1992.0437	16	1.3059	0.6854	0.9157	1.0820	8.2090	14.6950	8.1961	14.3064
+2879	1992.0464	17	1.3059	0.6854	0.9157	1.0820	8.2090	14.6950	8.1901	14.3106
+2880	1992.0492	18	1.3059	0.6854	0.9157	1.0820	8.2090	14.6950	8.1836	14.3149
+2881	1992.0519	19	1.3058	0.6854	0.9157	1.0820	8.2090	14.6950	8.1769	14.3194
+2882	1992.0546	20	1.3058	0.6854	0.9157	1.0820	8.2090	14.6950	8.1698	14.3239
+2883	1992.0574	21	1.3057	0.6854	0.9157	1.0820	8.2090	14.6950	8.1624	14.3287
+2884	1992.0601	22	1.3057	0.6853	0.9157	1.0820	8.2090	14.6950	8.1548	14.3335
+2885	1992.0628	23	1.3057	0.6853	0.9157	1.0820	8.2090	14.6950	8.1469	14.3384
+2886	1992.0656	24	1.3056	0.6853	0.9157	1.0820	8.2090	14.6950	8.1388	14.3434
+2887	1992.0683	25	1.3056	0.6853	0.9157	1.0820	8.2090	14.6950	8.1305	14.3484
+2888	1992.0710	26	1.3056	0.6853	0.9157	1.0820	8.2090	14.6950	8.1220	14.3536
+2889	1992.0738	27	1.3055	0.6853	0.9156	1.0820	8.2090	14.6950	8.1134	14.3588
+2890	1992.0765	28	1.3055	0.6853	0.9156	1.0820	8.2090	14.6950	8.1047	14.3641
+2891	1992.0792	29	1.3055	0.6852	0.9156	1.0820	8.2090	14.6950	8.0960	14.3694
+2892	1992.0820	30	1.3054	0.6852	0.9156	1.0820	8.2090	14.6950	8.0871	14.3748
+2893	1992.0847	31	1.3054	0.6852	0.9156	1.0820	8.2090	14.6950	8.0783	14.3801
+2894	1992.0874	32	1.3053	0.6852	0.9156	1.0820	8.2090	14.6950	8.0694	14.3855
+2895	1992.0902	33	1.3053	0.6852	0.9156	1.0820	8.2090	14.6950	8.0606	14.3909
+2896	1992.0929	34	1.3053	0.6852	0.9156	1.0820	8.2090	14.6950	8.0518	14.3963
+2897	1992.0956	35	1.3052	0.6851	0.9156	1.0820	8.2090	14.6950	8.0432	14.4017
+2898	1992.0984	36	1.3052	0.6851	0.9156	1.0820	8.2090	14.6950	8.0346	14.4070
+2899	1992.1011	37	1.3052	0.6851	0.9156	1.0820	8.2090	14.6950	8.0262	14.4123
+2900	1992.1038	38	1.3051	0.6851	0.9156	1.0820	8.2090	14.6950	8.0179	14.4176
+2901	1992.1066	39	1.3051	0.6851	0.9155	1.0820	8.2090	14.6950	8.0098	14.4228
+2902	1992.1093	40	1.3050	0.6851	0.9155	1.0820	8.2090	14.6950	8.0019	14.4279
+2903	1992.1120	41	1.3050	0.6851	0.9155	1.0820	8.2090	14.6950	7.9943	14.4330
+2904	1992.1148	42	1.3050	0.6850	0.9155	1.0820	8.2090	14.6950	7.9869	14.4380
+2905	1992.1175	43	1.3049	0.6850	0.9155	1.0820	8.2090	14.6950	7.9798	14.4429
+2906	1992.1202	44	1.3049	0.6850	0.9155	1.0820	8.2090	14.6950	7.9730	14.4477
+2907	1992.1230	45	1.3049	0.6850	0.9155	1.0820	8.2090	14.6950	7.9665	14.4524
+2908	1992.1257	46	1.3048	0.6850	0.9155	1.0820	8.2090	14.6950	7.9603	14.4570
+2909	1992.1284	47	1.3048	0.6850	0.9155	1.0820	8.2090	14.6950	7.9544	14.4614
+2910	1992.1311	48	1.3048	0.6849	0.9155	1.0820	8.2090	14.6950	7.9490	14.4658
+2911	1992.1339	49	1.3047	0.6849	0.9155	1.0820	8.2090	14.6950	7.9439	14.4699
+2912	1992.1366	50	1.3047	0.6849	0.9155	1.0820	8.2090	14.6950	7.9392	14.4739
+2913	1992.1393	51	1.3046	0.6849	0.9154	1.0820	8.2090	14.6950	7.9349	14.4778
+2914	1992.1421	52	1.3046	0.6849	0.9154	1.0820	8.2090	14.6950	7.9310	14.4815
+2915	1992.1448	53	1.3046	0.6849	0.9154	1.0820	8.2090	14.6950	7.9276	14.4850
+2916	1992.1475	54	1.3045	0.6849	0.9154	1.0820	8.2090	14.6950	7.9246	14.4884
+2917	1992.1503	55	1.3045	0.6848	0.9154	1.0820	8.2090	14.6950	7.9220	14.4915
+2918	1992.1530	56	1.3045	0.6848	0.9154	1.0820	8.2090	14.6950	7.9198	14.4945
+2919	1992.1557	57	1.3044	0.6848	0.9154	1.0820	8.2090	14.6950	7.9182	14.4972
+2920	1992.1585	58	1.3044	0.6848	0.9154	1.0820	8.2090	14.6950	7.9169	14.4998
+2921	1992.1612	59	1.3044	0.6848	0.9154	1.0820	8.2090	14.6950	7.9162	14.5021
+2922	1992.1639	60	1.3043	0.6848	0.9154	1.0820	8.2090	14.6950	7.9159	14.5042
+2923	1992.1667	61	1.3043	0.6847	0.9154	1.0820	8.2090	14.6950	7.9160	14.5061
+2924	1992.1694	62	1.3042	0.6847	0.9154	1.0820	8.2090	14.6950	7.9166	14.5078
+2925	1992.1721	63	1.3042	0.6847	0.9153	1.0820	8.2090	14.6950	7.9177	14.5093
+2926	1992.1749	64	1.3042	0.6847	0.9153	1.0820	8.2090	14.6950	7.9192	14.5105
+2927	1992.1776	65	1.3041	0.6847	0.9153	1.0820	8.2090	14.6950	7.9211	14.5115
+2928	1992.1803	66	1.3041	0.6847	0.9153	1.0820	8.2090	14.6950	7.9235	14.5122
+2929	1992.1831	67	1.3041	0.6846	0.9153	1.0820	8.2090	14.6950	7.9263	14.5127
+2930	1992.1858	68	1.3040	0.6846	0.9153	1.0820	8.2090	14.6950	7.9296	14.5130
+2931	1992.1885	69	1.3040	0.6846	0.9153	1.0820	8.2090	14.6950	7.9332	14.5130
+2932	1992.1913	70	1.3040	0.6846	0.9153	1.0820	8.2090	14.6950	7.9372	14.5127
+2933	1992.1940	71	1.3039	0.6846	0.9153	1.0820	8.2090	14.6950	7.9417	14.5123
+2934	1992.1967	72	1.3039	0.6846	0.9153	1.0820	8.2090	14.6950	7.9465	14.5115
+2935	1992.1995	73	1.3038	0.6846	0.9153	1.0820	8.2090	14.6950	7.9516	14.5105
+2936	1992.2022	74	1.3038	0.6845	0.9153	1.0820	8.2090	14.6950	7.9571	14.5093
+2937	1992.2049	75	1.3038	0.6845	0.9152	1.0820	8.2090	14.6950	7.9629	14.5078
+2938	1992.2077	76	1.3037	0.6845	0.9152	1.0820	8.2090	14.6950	7.9691	14.5061
+2939	1992.2104	77	1.3037	0.6845	0.9152	1.0820	8.2090	14.6950	7.9755	14.5041
+2940	1992.2131	78	1.3037	0.6845	0.9152	1.0820	8.2090	14.6950	7.9822	14.5019
+2941	1992.2158	79	1.3036	0.6845	0.9152	1.0820	8.2090	14.6950	7.9891	14.4995
+2942	1992.2186	80	1.3036	0.6844	0.9152	1.0820	8.2090	14.6950	7.9963	14.4968
+2943	1992.2213	81	1.3036	0.6844	0.9152	1.0820	8.2090	14.6950	8.0036	14.4939
+2944	1992.2240	82	1.3035	0.6844	0.9152	1.0820	8.2090	14.6950	8.0112	14.4907
+2945	1992.2268	83	1.3035	0.6844	0.9152	1.0820	8.2090	14.6950	8.0189	14.4873
+2946	1992.2295	84	1.3034	0.6844	0.9152	1.0820	8.2090	14.6950	8.0267	14.4837
+2947	1992.2322	85	1.3034	0.6844	0.9152	1.0820	8.2090	14.6950	8.0347	14.4798
+2948	1992.2350	86	1.3034	0.6844	0.9152	1.0820	8.2090	14.6950	8.0427	14.4758
+2949	1992.2377	87	1.3033	0.6843	0.9152	1.0820	8.2090	14.6950	8.0508	14.4715
+2950	1992.2404	88	1.3033	0.6843	0.9151	1.0820	8.2090	14.6950	8.0590	14.4671
+2951	1992.2432	89	1.3033	0.6843	0.9151	1.0820	8.2090	14.6950	8.0671	14.4624
+2952	1992.2459	90	1.3032	0.6843	0.9151	1.0820	8.2090	14.6950	8.0753	14.4575
+2953	1992.2486	91	1.3032	0.6843	0.9151	1.0820	8.2090	14.6950	8.0833	14.4525
+2954	1992.2514	92	1.3032	0.6843	0.9151	1.0820	8.2090	14.6950	8.0914	14.4472
+2955	1992.2541	93	1.3031	0.6842	0.9151	1.0820	8.2090	14.6950	8.0993	14.4418
+2956	1992.2568	94	1.3031	0.6842	0.9151	1.0820	8.2090	14.6950	8.1071	14.4362
+2957	1992.2596	95	1.3031	0.6842	0.9151	1.0820	8.2090	14.6950	8.1148	14.4305
+2958	1992.2623	96	1.3030	0.6842	0.9151	1.0820	8.2090	14.6950	8.1223	14.4246
+2959	1992.2650	97	1.3030	0.6842	0.9151	1.0820	8.2090	14.6950	8.1296	14.4185
+2960	1992.2678	98	1.3029	0.6842	0.9151	1.0820	8.2090	14.6950	8.1367	14.4123
+2961	1992.2705	99	1.3029	0.6842	0.9151	1.0820	8.2090	14.6950	8.1435	14.4060
+2962	1992.2732	100	1.3029	0.6841	0.9150	1.0820	8.2090	14.6950	8.1501	14.3996
+2963	1992.2760	101	1.3028	0.6841	0.9150	1.0820	8.2090	14.6950	8.1564	14.3930
+2964	1992.2787	102	1.3028	0.6841	0.9150	1.0820	8.2090	14.6950	8.1624	14.3863
+2965	1992.2814	103	1.3028	0.6841	0.9150	1.0820	8.2090	14.6950	8.1680	14.3796
+2966	1992.2842	104	1.3027	0.6841	0.9150	1.0820	8.2090	14.6950	8.1733	14.3727
+2967	1992.2869	105	1.3027	0.6841	0.9150	1.0820	8.2090	14.6950	8.1783	14.3658
+2968	1992.2896	106	1.3027	0.6840	0.9150	1.0820	8.2090	14.6950	8.1829	14.3588
+2969	1992.2923	107	1.3026	0.6840	0.9150	1.0820	8.2090	14.6950	8.1870	14.3517
+2970	1992.2951	108	1.3026	0.6840	0.9150	1.0820	8.2090	14.6950	8.1908	14.3446
+2971	1992.2978	109	1.3025	0.6840	0.9150	1.0820	8.2090	14.6950	8.1942	14.3374
+2972	1992.3005	110	1.3025	0.6840	0.9150	1.0820	8.2090	14.6950	8.1971	14.3302
+2973	1992.3033	111	1.3025	0.6840	0.9150	1.0820	8.2090	14.6950	8.1995	14.3229
+2974	1992.3060	112	1.3024	0.6840	0.9150	1.0820	8.2090	14.6950	8.2015	14.3157
+2975	1992.3087	113	1.3024	0.6839	0.9149	1.0820	8.2090	14.6950	8.2031	14.3084
+2976	1992.3115	114	1.3024	0.6839	0.9149	1.0820	8.2090	14.6950	8.2042	14.3011
+2977	1992.3142	115	1.3023	0.6839	0.9149	1.0820	8.2090	14.6950	8.2048	14.2938
+2978	1992.3169	116	1.3023	0.6839	0.9149	1.0820	8.2090	14.6950	8.2049	14.2866
+2979	1992.3197	117	1.3023	0.6839	0.9149	1.0820	8.2090	14.6950	8.2046	14.2794
+2980	1992.3224	118	1.3022	0.6839	0.9149	1.0820	8.2090	14.6950	8.2038	14.2722
+2981	1992.3251	119	1.3022	0.6839	0.9149	1.0820	8.2090	14.6950	8.2025	14.2650
+2982	1992.3279	120	1.3022	0.6838	0.9149	1.0820	8.2090	14.6950	8.2090	14.6950
+2983	1992.3306	121	1.3021	0.6838	0.9149	1.0820	8.2090	14.6950	8.2022	14.6948
+2984	1992.3333	122	1.3021	0.6838	0.9149	1.0820	8.2090	14.6950	8.1952	14.6944
+2985	1992.3361	123	1.3020	0.6838	0.9149	1.0820	8.2090	14.6950	8.1879	14.6937
+2986	1992.3388	124	1.3020	0.6838	0.9149	1.0820	8.2090	14.6950	8.1803	14.6928
+2987	1992.3415	125	1.3020	0.6838	0.9148	1.0820	8.2090	14.6950	8.1726	14.6917
+2988	1992.3443	126	1.3019	0.6837	0.9148	1.0820	8.2090	14.6950	8.1646	14.6903
+2989	1992.3470	127	1.3019	0.6837	0.9148	1.0820	8.2090	14.6950	8.1565	14.6886
+2990	1992.3497	128	1.3019	0.6837	0.9148	1.0820	8.2090	14.6950	8.1482	14.6867
+2991	1992.3525	129	1.3018	0.6837	0.9148	1.0820	8.2090	14.6950	8.1398	14.6846
+2992	1992.3552	130	1.3018	0.6837	0.9148	1.0820	8.2090	14.6950	8.1313	14.6822
+2993	1992.3579	131	1.3018	0.6837	0.9148	1.0820	8.2090	14.6950	8.1228	14.6796
+2994	1992.3607	132	1.3017	0.6837	0.9148	1.0820	8.2090	14.6950	8.1142	14.6768
+2995	1992.3634	133	1.3017	0.6836	0.9148	1.0820	8.2090	14.6950	8.1056	14.6737
+2996	1992.3661	134	1.3017	0.6836	0.9148	1.0820	8.2090	14.6950	8.0970	14.6704
+2997	1992.3689	135	1.3016	0.6836	0.9148	1.0820	8.2090	14.6950	8.0884	14.6669
+2998	1992.3716	136	1.3016	0.6836	0.9148	1.0820	8.2090	14.6950	8.0799	14.6631
+2999	1992.3743	137	1.3016	0.6836	0.9148	1.0820	8.2090	14.6950	8.0714	14.6592
+3000	1992.3770	138	1.3015	0.6836	0.9147	1.0820	8.2090	14.6950	8.0631	14.6550
+3001	1992.3798	139	1.3015	0.6835	0.9147	1.0820	8.2090	14.6950	8.0549	14.6506
+3002	1992.3825	140	1.3014	0.6835	0.9147	1.0820	8.2090	14.6950	8.0468	14.6461
+3003	1992.3852	141	1.3014	0.6835	0.9147	1.0820	8.2090	14.6950	8.0390	14.6413
+3004	1992.3880	142	1.3014	0.6835	0.9147	1.0820	8.2090	14.6950	8.0313	14.6363
+3005	1992.3907	143	1.3013	0.6835	0.9147	1.0820	8.2090	14.6950	8.0238	14.6312
+3006	1992.3934	144	1.3013	0.6835	0.9147	1.0820	8.2090	14.6950	8.0166	14.6258
+3007	1992.3962	145	1.3013	0.6835	0.9147	1.0820	8.2090	14.6950	8.0096	14.6203
+3008	1992.3989	146	1.3012	0.6834	0.9147	1.0820	8.2090	14.6950	8.0029	14.6147
+3009	1992.4016	147	1.3012	0.6834	0.9147	1.0820	8.2090	14.6950	7.9964	14.6089
+3010	1992.4044	148	1.3012	0.6834	0.9147	1.0820	8.2090	14.6950	7.9903	14.6029
+3011	1992.4071	149	1.3011	0.6834	0.9147	1.0820	8.2090	14.6950	7.9845	14.5968
+3012	1992.4098	150	1.3011	0.6834	0.9147	1.0820	8.2090	14.6950	7.9791	14.5905
+3013	1992.4126	151	1.3011	0.6834	0.9146	1.0820	8.2090	14.6950	7.9740	14.5842
+3014	1992.4153	152	1.3010	0.6834	0.9146	1.0820	8.2090	14.6950	7.9692	14.5777
+3015	1992.4180	153	1.3010	0.6833	0.9146	1.0820	8.2090	14.6950	7.9648	14.5711
+3016	1992.4208	154	1.3010	0.6833	0.9146	1.0820	8.2090	14.6950	7.9608	14.5644
+3017	1992.4235	155	1.3009	0.6833	0.9146	1.0820	8.2090	14.6950	7.9572	14.5576
+3018	1992.4262	156	1.3009	0.6833	0.9146	1.0820	8.2090	14.6950	7.9540	14.5507
+3019	1992.4290	157	1.3008	0.6833	0.9146	1.0820	8.2090	14.6950	7.9513	14.5437
+3020	1992.4317	158	1.3008	0.6833	0.9146	1.0820	8.2090	14.6950	7.9489	14.5366
+3021	1992.4344	159	1.3008	0.6832	0.9146	1.0820	8.2090	14.6950	7.9469	14.5295
+3022	1992.4372	160	1.3007	0.6832	0.9146	1.0820	8.2090	14.6950	7.9454	14.5224
+3023	1992.4399	161	1.3007	0.6832	0.9146	1.0820	8.2090	14.6950	7.9443	14.5152
+3024	1992.4426	162	1.3007	0.6832	0.9146	1.0820	8.2090	14.6950	7.9437	14.5079
+3025	1992.4454	163	1.3006	0.6832	0.9146	1.0820	8.2090	14.6950	7.9434	14.5007
+3026	1992.4481	164	1.3006	0.6832	0.9145	1.0820	8.2090	14.6950	7.9436	14.4934
+3027	1992.4508	165	1.3006	0.6832	0.9145	1.0820	8.2090	14.6950	7.9442	14.4861
+3028	1992.4536	166	1.3005	0.6831	0.9145	1.0820	8.2090	14.6950	7.9453	14.4788
+3029	1992.4563	167	1.3005	0.6831	0.9145	1.0820	8.2090	14.6950	7.9468	14.4715
+3030	1992.4590	168	1.3005	0.6831	0.9145	1.0820	8.2090	14.6950	7.9486	14.4642
+3031	1992.4617	169	1.3004	0.6831	0.9145	1.0820	8.2090	14.6950	7.9509	14.4569
+3032	1992.4645	170	1.3004	0.6831	0.9145	1.0820	8.2090	14.6950	7.9536	14.4497
+3033	1992.4672	171	1.3004	0.6831	0.9145	1.0820	8.2090	14.6950	7.9567	14.4425
+3034	1992.4699	172	1.3003	0.6830	0.9145	1.0820	8.2090	14.6950	7.9602	14.4354
+3035	1992.4727	173	1.3003	0.6830	0.9145	1.0820	8.2090	14.6950	7.9641	14.4283
+3036	1992.4754	174	1.3003	0.6830	0.9145	1.0820	8.2090	14.6950	7.9683	14.4213
+3037	1992.4781	175	1.3002	0.6830	0.9145	1.0820	8.2090	14.6950	7.9728	14.4144
+3038	1992.4809	176	1.3002	0.6830	0.9145	1.0820	8.2090	14.6950	7.9778	14.4075
+3039	1992.4836	177	1.3001	0.6830	0.9144	1.0820	8.2090	14.6950	7.9830	14.4007
+3040	1992.4863	178	1.3001	0.6830	0.9144	1.0820	8.2090	14.6950	7.9885	14.3941
+3041	1992.4891	179	1.3001	0.6829	0.9144	1.0820	8.2090	14.6950	7.9944	14.3875
+3042	1992.4918	180	1.3000	0.6829	0.9144	1.0820	8.2090	14.6950	8.0005	14.3810
+3043	1992.4945	181	1.3000	0.6829	0.9144	1.0820	8.2090	14.6950	8.0069	14.3747
+3044	1992.4973	182	1.3000	0.6829	0.9144	1.0820	8.2090	14.6950	8.0135	14.3684
+3045	1992.5000	183	1.2999	0.6829	0.9144	1.0820	8.2090	14.6950	8.0204	14.3623
+3046	1992.5027	184	1.2999	0.6829	0.9144	1.0820	8.2090	14.6950	8.0274	14.3564
+3047	1992.5055	185	1.2999	0.6829	0.9144	1.0820	8.2090	14.6950	8.0347	14.3506
+3048	1992.5082	186	1.2998	0.6828	0.9144	1.0820	8.2090	14.6950	8.0421	14.3449
+3049	1992.5109	187	1.2998	0.6828	0.9144	1.0820	8.2090	14.6950	8.0496	14.3394
+3050	1992.5137	188	1.2998	0.6828	0.9144	1.0820	8.2090	14.6950	8.0573	14.3340
+3051	1992.5164	189	1.2997	0.6828	0.9144	1.0820	8.2090	14.6950	8.0650	14.3288
+3052	1992.5191	190	1.2997	0.6828	0.9143	1.0820	8.2090	14.6950	8.0729	14.3238
+3053	1992.5219	191	1.2997	0.6828	0.9143	1.0820	8.2090	14.6950	8.0808	14.3190
+3054	1992.5246	192	1.2996	0.6828	0.9143	1.0820	8.2090	14.6950	8.0887	14.3143
+3055	1992.5273	193	1.2996	0.6827	0.9143	1.0820	8.2090	14.6950	8.0966	14.3098
+3056	1992.5301	194	1.2996	0.6827	0.9143	1.0820	8.2090	14.6950	8.1045	14.3055
+3057	1992.5328	195	1.2995	0.6827	0.9143	1.0820	8.2090	14.6950	8.1124	14.3014
+3058	1992.5355	196	1.2995	0.6827	0.9143	1.0820	8.2090	14.6950	8.1202	14.2975
+3059	1992.5383	197	1.2995	0.6827	0.9143	1.0820	8.2090	14.6950	8.1279	14.2938
+3060	1992.5410	198	1.2994	0.6827	0.9143	1.0820	8.2090	14.6950	8.1355	14.2903
+3061	1992.5437	199	1.2994	0.6826	0.9143	1.0820	8.2090	14.6950	8.1430	14.2870
+3062	1992.5464	200	1.2994	0.6826	0.9143	1.0820	8.2090	14.6950	8.1503	14.2839
+3063	1992.5492	201	1.2993	0.6826	0.9143	1.0820	8.2090	14.6950	8.1574	14.2810
+3064	1992.5519	202	1.2993	0.6826	0.9143	1.0820	8.2090	14.6950	8.1643	14.2784
+3065	1992.5546	203	1.2992	0.6826	0.9143	1.0820	8.2090	14.6950	8.1711	14.2759
+3066	1992.5574	204	1.2992	0.6826	0.9142	1.0820	8.2090	14.6950	8.1775	14.2737
+3067	1992.5601	205	1.2992	0.6826	0.9142	1.0820	8.2090	14.6950	8.1837	14.2716
+3068	1992.5628	206	1.2991	0.6825	0.9142	1.0820	8.2090	14.6950	8.1897	14.2698
+3069	1992.5656	207	1.2991	0.6825	0.9142	1.0820	8.2090	14.6950	8.1953	14.2682
+3070	1992.5683	208	1.2991	0.6825	0.9142	1.0820	8.2090	14.6950	8.2006	14.2669
+3071	1992.5710	209	1.2990	0.6825	0.9142	1.0820	8.2090	14.6950	8.2056	14.2657
+3072	1992.5738	210	1.2990	0.6825	0.9142	1.0820	8.2090	14.6950	8.2102	14.2648
+3073	1992.5765	211	1.2990	0.6825	0.9142	1.0820	8.2090	14.6950	8.2144	14.2640
+3074	1992.5792	212	1.2989	0.6825	0.9142	1.0820	8.2090	14.6950	8.2183	14.2635
+3075	1992.5820	213	1.2989	0.6824	0.9142	1.0820	8.2090	14.6950	8.2218	14.2632
+3076	1992.5847	214	1.2989	0.6824	0.9142	1.0820	8.2090	14.6950	8.2249	14.2632
+3077	1992.5874	215	1.2988	0.6824	0.9142	1.0820	8.2090	14.6950	8.2276	14.2633
+3078	1992.5902	216	1.2988	0.6824	0.9142	1.0820	8.2090	14.6950	8.2298	14.2637
+3079	1992.5929	217	1.2988	0.6824	0.9141	1.0820	8.2090	14.6950	8.2317	14.2642
+3080	1992.5956	218	1.2987	0.6824	0.9141	1.0820	8.2090	14.6950	8.2330	14.2650
+3081	1992.5984	219	1.2987	0.6823	0.9141	1.0820	8.2090	14.6950	8.2340	14.2660
+3082	1992.6011	220	1.2987	0.6823	0.9141	1.0820	8.2090	14.6950	8.2345	14.2671
+3083	1992.6038	221	1.2986	0.6823	0.9141	1.0820	8.2090	14.6950	8.2346	14.2685
+3084	1992.6066	222	1.2986	0.6823	0.9141	1.0820	8.2090	14.6950	8.2342	14.2701
+3085	1992.6093	223	1.2986	0.6823	0.9141	1.0820	8.2090	14.6950	8.2334	14.2718
+3086	1992.6120	224	1.2985	0.6823	0.9141	1.0820	8.2090	14.6950	8.2321	14.2738
+3087	1992.6148	225	1.2985	0.6823	0.9141	1.0820	8.2090	14.6950	8.2090	14.6950
+3088	1992.6175	226	1.2985	0.6822	0.9141	1.0820	8.2090	14.6950	8.2025	14.6948
+3089	1992.6202	227	1.2984	0.6822	0.9141	1.0820	8.2090	14.6950	8.1957	14.6944
+3090	1992.6230	228	1.2984	0.6822	0.9141	1.0820	8.2090	14.6950	8.1886	14.6938
+3091	1992.6257	229	1.2984	0.6822	0.9141	1.0820	8.2090	14.6950	8.1814	14.6930
+3092	1992.6284	230	1.2983	0.6822	0.9141	1.0820	8.2090	14.6950	8.1739	14.6919
+3093	1992.6311	231	1.2983	0.6822	0.9140	1.0820	8.2090	14.6950	8.1663	14.6906
+3094	1992.6339	232	1.2983	0.6822	0.9140	1.0820	8.2090	14.6950	8.1584	14.6891
+3095	1992.6366	233	1.2982	0.6821	0.9140	1.0820	8.2090	14.6950	8.1505	14.6873
+3096	1992.6393	234	1.2982	0.6821	0.9140	1.0820	8.2090	14.6950	8.1424	14.6853
+3097	1992.6421	235	1.2982	0.6821	0.9140	1.0820	8.2090	14.6950	8.1342	14.6831
+3098	1992.6448	236	1.2981	0.6821	0.9140	1.0820	8.2090	14.6950	8.1260	14.6807
+3099	1992.6475	237	1.2981	0.6821	0.9140	1.0820	8.2090	14.6950	8.1177	14.6781
+3100	1992.6503	238	1.2980	0.6821	0.9140	1.0820	8.2090	14.6950	8.1094	14.6752
+3101	1992.6530	239	1.2980	0.6821	0.9140	1.0820	8.2090	14.6950	8.1011	14.6722
+3102	1992.6557	240	1.2980	0.6820	0.9140	1.0820	8.2090	14.6950	8.0928	14.6689
+3103	1992.6585	241	1.2979	0.6820	0.9140	1.0820	8.2090	14.6950	8.0845	14.6654
+3104	1992.6612	242	1.2979	0.6820	0.9140	1.0820	8.2090	14.6950	8.0763	14.6617
+3105	1992.6639	243	1.2979	0.6820	0.9140	1.0820	8.2090	14.6950	8.0682	14.6579
+3106	1992.6667	244	1.2978	0.6820	0.9139	1.0820	8.2090	14.6950	8.0602	14.6538
+3107	1992.6694	245	1.2978	0.6820	0.9139	1.0820	8.2090	14.6950	8.0524	14.6495
+3108	1992.6721	246	1.2978	0.6820	0.9139	1.0820	8.2090	14.6950	8.0446	14.6451
+3109	1992.6749	247	1.2977	0.6819	0.9139	1.0820	8.2090	14.6950	8.0371	14.6404
+3110	1992.6776	248	1.2977	0.6819	0.9139	1.0820	8.2090	14.6950	8.0297	14.6356
+3111	1992.6803	249	1.2977	0.6819	0.9139	1.0820	8.2090	14.6950	8.0225	14.6307
+3112	1992.6831	250	1.2976	0.6819	0.9139	1.0820	8.2090	14.6950	8.0155	14.6255
+3113	1992.6858	251	1.2976	0.6819	0.9139	1.0820	8.2090	14.6950	8.0088	14.6202
+3114	1992.6885	252	1.2976	0.6819	0.9139	1.0820	8.2090	14.6950	8.0024	14.6148
+3115	1992.6913	253	1.2975	0.6818	0.9139	1.0820	8.2090	14.6950	7.9962	14.6092
+3116	1992.6940	254	1.2975	0.6818	0.9139	1.0820	8.2090	14.6950	7.9903	14.6035
+3117	1992.6967	255	1.2975	0.6818	0.9139	1.0820	8.2090	14.6950	7.9847	14.5976
+3118	1992.6995	256	1.2974	0.6818	0.9139	1.0820	8.2090	14.6950	7.9794	14.5916
+3119	1992.7022	257	1.2974	0.6818	0.9139	1.0820	8.2090	14.6950	7.9744	14.5855
+3120	1992.7049	258	1.2974	0.6818	0.9138	1.0820	8.2090	14.6950	7.9698	14.5793
+3121	1992.7077	259	1.2973	0.6818	0.9138	1.0820	8.2090	14.6950	7.9655	14.5729
+3122	1992.7104	260	1.2973	0.6817	0.9138	1.0820	8.2090	14.6950	7.9616	14.5665
+3123	1992.7131	261	1.2973	0.6817	0.9138	1.0820	8.2090	14.6950	7.9580	14.5600
+3124	1992.7158	262	1.2972	0.6817	0.9138	1.0820	8.2090	14.6950	7.9549	14.5534
+3125	1992.7186	263	1.2972	0.6817	0.9138	1.0820	8.2090	14.6950	7.9521	14.5467
+3126	1992.7213	264	1.2972	0.6817	0.9138	1.0820	8.2090	14.6950	7.9496	14.5399
+3127	1992.7240	265	1.2971	0.6817	0.9138	1.0820	8.2090	14.6950	7.9476	14.5331
+3128	1992.7268	266	1.2971	0.6817	0.9138	1.0820	8.2090	14.6950	7.9460	14.5263
+3129	1992.7295	267	1.2971	0.6816	0.9138	1.0820	8.2090	14.6950	7.9448	14.5194
+3130	1992.7322	268	1.2970	0.6816	0.9138	1.0820	8.2090	14.6950	7.9439	14.5124
+3131	1992.7350	269	1.2970	0.6816	0.9138	1.0820	8.2090	14.6950	7.9435	14.5054
+3132	1992.7377	270	1.2970	0.6816	0.9138	1.0820	8.2090	14.6950	7.9435	14.4984
+3133	1992.7404	271	1.2969	0.6816	0.9138	1.0820	8.2090	14.6950	7.9438	14.4914
+3134	1992.7432	272	1.2969	0.6816	0.9137	1.0820	8.2090	14.6950	7.9446	14.4844
+3135	1992.7459	273	1.2969	0.6816	0.9137	1.0820	8.2090	14.6950	7.9458	14.4774
+3136	1992.7486	274	1.2968	0.6815	0.9137	1.0820	8.2090	14.6950	7.9473	14.4703
+3137	1992.7514	275	1.2968	0.6815	0.9137	1.0820	8.2090	14.6950	7.9493	14.4633
+3138	1992.7541	276	1.2968	0.6815	0.9137	1.0820	8.2090	14.6950	7.9516	14.4564
+3139	1992.7568	277	1.2967	0.6815	0.9137	1.0820	8.2090	14.6950	7.9543	14.4494
+3140	1992.7596	278	1.2967	0.6815	0.9137	1.0820	8.2090	14.6950	7.9573	14.4425
+3141	1992.7623	279	1.2967	0.6815	0.9137	1.0820	8.2090	14.6950	7.9608	14.4356
+3142	1992.7650	280	1.2966	0.6815	0.9137	1.0820	8.2090	14.6950	7.9645	14.4288
+3143	1992.7678	281	1.2966	0.6814	0.9137	1.0820	8.2090	14.6950	7.9686	14.4221
+3144	1992.7705	282	1.2966	0.6814	0.9137	1.0820	8.2090	14.6950	7.9731	14.4154
+3145	1992.7732	283	1.2965	0.6814	0.9137	1.0820	8.2090	14.6950	7.9778	14.4088
+3146	1992.7760	284	1.2965	0.6814	0.9137	1.0820	8.2090	14.6950	7.9829	14.4022
+3147	1992.7787	285	1.2965	0.6814	0.9137	1.0820	8.2090	14.6950	7.9882	14.3958
+3148	1992.7814	286	1.2964	0.6814	0.9136	1.0820	8.2090	14.6950	7.9938	14.3894
+3149	1992.7842	287	1.2964	0.6814	0.9136	1.0820	8.2090	14.6950	7.9997	14.3832
+3150	1992.7869	288	1.2964	0.6813	0.9136	1.0820	8.2090	14.6950	8.0059	14.3770
+3151	1992.7896	289	1.2963	0.6813	0.9136	1.0820	8.2090	14.6950	8.0122	14.3710
+3152	1992.7923	290	1.2963	0.6813	0.9136	1.0820	8.2090	14.6950	8.0188	14.3651
+3153	1992.7951	291	1.2963	0.6813	0.9136	1.0820	8.2090	14.6950	8.0256	14.3593
+3154	1992.7978	292	1.2962	0.6813	0.9136	1.0820	8.2090	14.6950	8.0325	14.3536
+3155	1992.8005	293	1.2962	0.6813	0.9136	1.0820	8.2090	14.6950	8.0396	14.3481
+3156	1992.8033	294	1.2962	0.6813	0.9136	1.0820	8.2090	14.6950	8.0468	14.3427
+3157	1992.8060	295	1.2961	0.6812	0.9136	1.0820	8.2090	14.6950	8.0542	14.3374
+3158	1992.8087	296	1.2961	0.6812	0.9136	1.0820	8.2090	14.6950	8.0616	14.3323
+3159	1992.8115	297	1.2961	0.6812	0.9136	1.0820	8.2090	14.6950	8.0692	14.3274
+3160	1992.8142	298	1.2960	0.6812	0.9136	1.0820	8.2090	14.6950	8.0768	14.3226
+3161	1992.8169	299	1.2960	0.6812	0.9136	1.0820	8.2090	14.6950	8.0844	14.3180
+3162	1992.8197	300	1.2960	0.6812	0.9136	1.0820	8.2090	14.6950	8.0921	14.3135
+3163	1992.8224	301	1.2959	0.6811	0.9135	1.0820	8.2090	14.6950	8.0997	14.3092
+3164	1992.8251	302	1.2959	0.6811	0.9135	1.0820	8.2090	14.6950	8.1073	14.3051
+3165	1992.8279	303	1.2959	0.6811	0.9135	1.0820	8.2090	14.6950	8.1149	14.3012
+3166	1992.8306	304	1.2958	0.6811	0.9135	1.0820	8.2090	14.6950	8.1224	14.2974
+3167	1992.8333	305	1.2958	0.6811	0.9135	1.0820	8.2090	14.6950	8.1299	14.2939
+3168	1992.8361	306	1.2958	0.6811	0.9135	1.0820	8.2090	14.6950	8.1372	14.2905
+3169	1992.8388	307	1.2957	0.6811	0.9135	1.0820	8.2090	14.6950	8.1444	14.2873
+3170	1992.8415	308	1.2957	0.6810	0.9135	1.0820	8.2090	14.6950	8.1514	14.2843
+3171	1992.8443	309	1.2957	0.6810	0.9135	1.0820	8.2090	14.6950	8.1583	14.2815
+3172	1992.8470	310	1.2956	0.6810	0.9135	1.0820	8.2090	14.6950	8.1649	14.2789
+3173	1992.8497	311	1.2956	0.6810	0.9135	1.0820	8.2090	14.6950	8.1714	14.2765
+3174	1992.8525	312	1.2956	0.6810	0.9135	1.0820	8.2090	14.6950	8.1776	14.2743
+3175	1992.8552	313	1.2955	0.6810	0.9135	1.0820	8.2090	14.6950	8.1836	14.2723
+3176	1992.8579	314	1.2955	0.6810	0.9135	1.0820	8.2090	14.6950	8.1894	14.2704
+3177	1992.8607	315	1.2955	0.6809	0.9134	1.0820	8.2090	14.6950	8.1948	14.2688
+3178	1992.8634	316	1.2954	0.6809	0.9134	1.0820	8.2090	14.6950	8.2000	14.2674
+3179	1992.8661	317	1.2954	0.6809	0.9134	1.0820	8.2090	14.6950	8.2048	14.2662
+3180	1992.8689	318	1.2954	0.6809	0.9134	1.0820	8.2090	14.6950	8.2093	14.2652
+3181	1992.8716	319	1.2953	0.6809	0.9134	1.0820	8.2090	14.6950	8.2135	14.2644
+3182	1992.8743	320	1.2953	0.6809	0.9134	1.0820	8.2090	14.6950	8.2174	14.2638
+3183	1992.8770	321	1.2953	0.6809	0.9134	1.0820	8.2090	14.6950	8.2208	14.2634
+3184	1992.8798	322	1.2952	0.6808	0.9134	1.0820	8.2090	14.6950	8.2239	14.2632
+3185	1992.8825	323	1.2952	0.6808	0.9134	1.0820	8.2090	14.6950	8.2267	14.2632
+3186	1992.8852	324	1.2952	0.6808	0.9134	1.0820	8.2090	14.6950	8.2290	14.2634
+3187	1992.8880	325	1.2951	0.6808	0.9134	1.0820	8.2090	14.6950	8.2309	14.2638
+3188	1992.8907	326	1.2951	0.6808	0.9134	1.0820	8.2090	14.6950	8.2325	14.2644
+3189	1992.8934	327	1.2951	0.6808	0.9134	1.0820	8.2090	14.6950	8.2336	14.2651
+3190	1992.8962	328	1.2950	0.6808	0.9134	1.0820	8.2090	14.6950	8.2343	14.2661
+3191	1992.8989	329	1.2950	0.6807	0.9133	1.0820	8.2090	14.6950	8.2346	14.2672
+3192	1992.9016	330	1.2950	0.6807	0.9133	1.0820	8.2090	14.6950	8.2345	14.2686
+3193	1992.9044	331	1.2949	0.6807	0.9133	1.0820	8.2090	14.6950	8.2339	14.2701
+3194	1992.9071	332	1.2949	0.6807	0.9133	1.0820	8.2090	14.6950	8.2330	14.2718
+3195	1992.9098	333	1.2949	0.6807	0.9133	1.0820	8.2090	14.6950	8.2317	14.2736
+3196	1992.9126	334	1.2948	0.6807	0.9133	1.0820	8.2090	14.6950	8.2299	14.2757
+3197	1992.9153	335	1.2948	0.6807	0.9133	1.0820	8.2090	14.6950	8.2277	14.2779
+3198	1992.9180	336	1.2948	0.6806	0.9133	1.0820	8.2090	14.6950	8.2252	14.2803
+3199	1992.9208	337	1.2947	0.6806	0.9133	1.0820	8.2090	14.6950	8.2222	14.2828
+3200	1992.9235	338	1.2947	0.6806	0.9133	1.0820	8.2090	14.6950	8.2189	14.2855
+3201	1992.9262	339	1.2947	0.6806	0.9133	1.0820	8.2090	14.6950	8.2152	14.2883
+3202	1992.9290	340	1.2946	0.6806	0.9133	1.0820	8.2090	14.6950	8.2111	14.2913
+3203	1992.9317	341	1.2946	0.6806	0.9133	1.0820	8.2090	14.6950	8.2067	14.2944
+3204	1992.9344	342	1.2946	0.6806	0.9133	1.0820	8.2090	14.6950	8.2020	14.2977
+3205	1992.9372	343	1.2945	0.6805	0.9133	1.0820	8.2090	14.6950	8.1969	14.3011
+3206	1992.9399	344	1.2945	0.6805	0.9132	1.0820	8.2090	14.6950	8.1916	14.3046
+3207	1992.9426	345	1.2945	0.6805	0.9132	1.0820	8.2090	14.6950	8.1859	14.3082
+3208	1992.9454	346	1.2944	0.6805	0.9132	1.0820	8.2090	14.6950	8.1799	14.3120
+3209	1992.9481	347	1.2944	0.6805	0.9132	1.0820	8.2090	14.6950	8.1737	14.3159
+3210	1992.9508	348	1.2944	0.6805	0.9132	1.0820	8.2090	14.6950	8.1672	14.3198
+3211	1992.9536	349	1.2943	0.6805	0.9132	1.0820	8.2090	14.6950	8.1606	14.3239
+3212	1992.9563	350	1.2943	0.6804	0.9132	1.0820	8.2090	14.6950	8.1537	14.3281
+3213	1992.9590	351	1.2943	0.6804	0.9132	1.0820	8.2090	14.6950	8.1466	14.3323
+3214	1992.9617	352	1.2943	0.6804	0.9132	1.0820	8.2090	14.6950	8.1393	14.3367
+3215	1992.9645	353	1.2942	0.6804	0.9132	1.0820	8.2090	14.6950	8.1319	14.3411
+3216	1992.9672	354	1.2942	0.6804	0.9132	1.0820	8.2090	14.6950	8.1243	14.3455
+3217	1992.9699	355	1.2942	0.6804	0.9132	1.0820	8.2090	14.6950	8.1166	14.3501
+3218	1992.9727	356	1.2941	0.6804	0.9132	1.0820	8.2090	14.6950	8.1089	14.3546
+3219	1992.9754	357	1.2941	0.6803	0.9132	1.0820	8.2090	14.6950	8.1010	14.3593
+3220	1992.9781	358	1.2941	0.6803	0.9132	1.0820	8.2090	14.6950	8.0931	14.3640
+3221	1992.9809	359	1.2940	0.6803	0.9131	1.0820	8.2090	14.6950	8.0852	14.3687
+3222	1992.9836	360	1.2940	0.6803	0.9131	1.0820	8.2090	14.6950	8.0773	14.3734
+3223	1992.9863	361	1.2940	0.6803	0.9131	1.0820	8.2090	14.6950	8.0693	14.3782
+3224	1992.9891	362	1.2939	0.6803	0.9131	1.0820	8.2090	14.6950	8.0614	14.3829
+3225	1992.9918	363	1.2939	0.6803	0.9131	1.0820	8.2090	14.6950	8.0535	14.3877
+3226	1992.9945	364	1.2939	0.6802	0.9131	1.0820	8.2090	14.6950	8.0457	14.3925
+3227	1992.9973	365	1.2938	0.6802	0.9131	1.0820	8.2090	14.6950	8.0380	14.3973
+3228	1992.9999	366	1.2938	0.6802	0.9131	1.0820	8.2090	14.6950	8.0304	14.4020
+3229	1993.0027	1	1.2938	0.6802	0.9131	1.0820	8.2090	14.6950	8.0229	14.4068
+3230	1993.0055	2	1.2937	0.6802	0.9131	1.0820	8.2090	14.6950	8.0155	14.4115
+3231	1993.0082	3	1.2937	0.6802	0.9131	1.0820	8.2090	14.6950	8.0083	14.4162
+3232	1993.0110	4	1.2937	0.6802	0.9131	1.0820	8.2090	14.6950	8.0013	14.4208
+3233	1993.0137	5	1.2936	0.6801	0.9131	1.0820	8.2090	14.6950	7.9944	14.4254
+3234	1993.0164	6	1.2936	0.6801	0.9131	1.0820	8.2090	14.6950	7.9878	14.4300
+3235	1993.0192	7	1.2936	0.6801	0.9131	1.0820	8.2090	14.6950	7.9813	14.4344
+3236	1993.0219	8	1.2935	0.6801	0.9130	1.0820	8.2090	14.6950	7.9751	14.4388
+3237	1993.0247	9	1.2935	0.6801	0.9130	1.0820	8.2090	14.6950	7.9692	14.4432
+3238	1993.0274	10	1.2935	0.6801	0.9130	1.0820	8.2090	14.6950	7.9635	14.4474
+3239	1993.0301	11	1.2934	0.6801	0.9130	1.0820	8.2090	14.6950	7.9581	14.4516
+3240	1993.0329	12	1.2934	0.6800	0.9130	1.0820	8.2090	14.6950	7.9530	14.4557
+3241	1993.0356	13	1.2934	0.6800	0.9130	1.0820	8.2090	14.6950	7.9481	14.4597
+3242	1993.0384	14	1.2933	0.6800	0.9130	1.0820	8.2090	14.6950	7.9436	14.4636
+3243	1993.0411	15	1.2933	0.6800	0.9130	1.0820	8.2090	14.6950	7.9394	14.4673
+3244	1993.0438	16	1.2933	0.6800	0.9130	1.0820	8.2090	14.6950	7.9355	14.4710
+3245	1993.0466	17	1.2932	0.6800	0.9130	1.0820	8.2090	14.6950	7.9320	14.4745
+3246	1993.0493	18	1.2932	0.6800	0.9130	1.0820	8.2090	14.6950	7.9287	14.4779
+3247	1993.0521	19	1.2932	0.6799	0.9130	1.0820	8.2090	14.6950	7.9259	14.4812
+3248	1993.0548	20	1.2931	0.6799	0.9130	1.0820	8.2090	14.6950	7.9234	14.4844
+3249	1993.0575	21	1.2931	0.6799	0.9130	1.0820	8.2090	14.6950	7.9212	14.4874
+3250	1993.0603	22	1.2931	0.6799	0.9130	1.0820	8.2090	14.6950	7.9194	14.4902
+3251	1993.0630	23	1.2931	0.6799	0.9129	1.0820	8.2090	14.6950	7.9180	14.4929
+3252	1993.0658	24	1.2930	0.6799	0.9129	1.0820	8.2090	14.6950	7.9169	14.4955
+3253	1993.0685	25	1.2930	0.6799	0.9129	1.0820	8.2090	14.6950	7.9162	14.4979
+3254	1993.0712	26	1.2930	0.6798	0.9129	1.0820	8.2090	14.6950	7.9159	14.5001
+3255	1993.0740	27	1.2929	0.6798	0.9129	1.0820	8.2090	14.6950	7.9159	14.5022
+3256	1993.0767	28	1.2929	0.6798	0.9129	1.0820	8.2090	14.6950	7.9163	14.5040
+3257	1993.0795	29	1.2929	0.6798	0.9129	1.0820	8.2090	14.6950	7.9171	14.5058
+3258	1993.0822	30	1.2928	0.6798	0.9129	1.0820	8.2090	14.6950	7.9182	14.5073
+3259	1993.0849	31	1.2928	0.6798	0.9129	1.0820	8.2090	14.6950	7.9197	14.5087
+3260	1993.0877	32	1.2928	0.6798	0.9129	1.0820	8.2090	14.6950	7.9216	14.5098
+3261	1993.0904	33	1.2927	0.6798	0.9129	1.0820	8.2090	14.6950	7.9238	14.5108
+3262	1993.0932	34	1.2927	0.6797	0.9129	1.0820	8.2090	14.6950	7.9263	14.5117
+3263	1993.0959	35	1.2927	0.6797	0.9129	1.0820	8.2090	14.6950	7.9292	14.5123
+3264	1993.0986	36	1.2926	0.6797	0.9129	1.0820	8.2090	14.6950	7.9324	14.5127
+3265	1993.1014	37	1.2926	0.6797	0.9129	1.0820	8.2090	14.6950	7.9360	14.5129
+3266	1993.1041	38	1.2926	0.6797	0.9128	1.0820	8.2090	14.6950	7.9398	14.5130
+3267	1993.1068	39	1.2925	0.6797	0.9128	1.0820	8.2090	14.6950	7.9440	14.5128
+3268	1993.1096	40	1.2925	0.6797	0.9128	1.0820	8.2090	14.6950	7.9484	14.5125
+3269	1993.1123	41	1.2925	0.6796	0.9128	1.0820	8.2090	14.6950	7.9531	14.5120
+3270	1993.1151	42	1.2924	0.6796	0.9128	1.0820	8.2090	14.6950	7.9581	14.5112
+3271	1993.1178	43	1.2924	0.6796	0.9128	1.0820	8.2090	14.6950	7.9634	14.5103
+3272	1993.1205	44	1.2924	0.6796	0.9128	1.0820	8.2090	14.6950	7.9689	14.5092
+3273	1993.1233	45	1.2923	0.6796	0.9128	1.0820	8.2090	14.6950	7.9746	14.5079
+3274	1993.1260	46	1.2923	0.6796	0.9128	1.0820	8.2090	14.6950	7.9806	14.5063
+3275	1993.1288	47	1.2923	0.6796	0.9128	1.0820	8.2090	14.6950	7.9868	14.5046
+3276	1993.1315	48	1.2923	0.6795	0.9128	1.0820	8.2090	14.6950	7.9931	14.5027
+3277	1993.1342	49	1.2922	0.6795	0.9128	1.0820	8.2090	14.6950	7.9996	14.5006
+3278	1993.1370	50	1.2922	0.6795	0.9128	1.0820	8.2090	14.6950	8.0063	14.4984
+3279	1993.1397	51	1.2922	0.6795	0.9128	1.0820	8.2090	14.6950	8.0131	14.4959
+3280	1993.1425	52	1.2921	0.6795	0.9128	1.0820	8.2090	14.6950	8.0201	14.4933
+3281	1993.1452	53	1.2921	0.6795	0.9127	1.0820	8.2090	14.6950	8.0271	14.4904
+3282	1993.1479	54	1.2921	0.6795	0.9127	1.0820	8.2090	14.6950	8.0342	14.4874
+3283	1993.1507	55	1.2920	0.6794	0.9127	1.0820	8.2090	14.6950	8.0415	14.4842
+3284	1993.1534	56	1.2920	0.6794	0.9127	1.0820	8.2090	14.6950	8.0487	14.4808
+3285	1993.1562	57	1.2920	0.6794	0.9127	1.0820	8.2090	14.6950	8.0560	14.4773
+3286	1993.1589	58	1.2919	0.6794	0.9127	1.0820	8.2090	14.6950	8.0633	14.4736
+3287	1993.1616	59	1.2919	0.6794	0.9127	1.0820	8.2090	14.6950	8.0706	14.4697
+3288	1993.1644	60	1.2919	0.6794	0.9127	1.0820	8.2090	14.6950	8.0779	14.4657
+3289	1993.1671	61	1.2918	0.6794	0.9127	1.0820	8.2090	14.6950	8.0852	14.4615
+3290	1993.1699	62	1.2918	0.6793	0.9127	1.0820	8.2090	14.6950	8.0923	14.4572
+3291	1993.1726	63	1.2918	0.6793	0.9127	1.0820	8.2090	14.6950	8.0994	14.4527
+3292	1993.1753	64	1.2917	0.6793	0.9127	1.0820	8.2090	14.6950	8.1065	14.4481
+3293	1993.1781	65	1.2917	0.6793	0.9127	1.0820	8.2090	14.6950	8.1134	14.4433
+3294	1993.1808	66	1.2917	0.6793	0.9127	1.0820	8.2090	14.6950	8.1201	14.4384
+3295	1993.1836	67	1.2916	0.6793	0.9127	1.0820	8.2090	14.6950	8.1267	14.4333
+3296	1993.1863	68	1.2916	0.6793	0.9126	1.0820	8.2090	14.6950	8.1332	14.4282
+3297	1993.1890	69	1.2916	0.6792	0.9126	1.0820	8.2090	14.6950	8.1394	14.4229
+3298	1993.1918	70	1.2916	0.6792	0.9126	1.0820	8.2090	14.6950	8.1455	14.4175
+3299	1993.1945	71	1.2915	0.6792	0.9126	1.0820	8.2090	14.6950	8.1513	14.4120
+3300	1993.1973	72	1.2915	0.6792	0.9126	1.0820	8.2090	14.6950	8.1569	14.4064
+3301	1993.2000	73	1.2915	0.6792	0.9126	1.0820	8.2090	14.6950	8.1623	14.4007
+3302	1993.2027	74	1.2914	0.6792	0.9126	1.0820	8.2090	14.6950	8.1674	14.3949
+3303	1993.2055	75	1.2914	0.6792	0.9126	1.0820	8.2090	14.6950	8.1722	14.3890
+3304	1993.2082	76	1.2914	0.6791	0.9126	1.0820	8.2090	14.6950	8.1768	14.3831
+3305	1993.2110	77	1.2913	0.6791	0.9126	1.0820	8.2090	14.6950	8.1810	14.3770
+3306	1993.2137	78	1.2913	0.6791	0.9126	1.0820	8.2090	14.6950	8.1849	14.3709
+3307	1993.2164	79	1.2913	0.6791	0.9126	1.0820	8.2090	14.6950	8.1885	14.3648
+3308	1993.2192	80	1.2912	0.6791	0.9126	1.0820	8.2090	14.6950	8.1918	14.3585
+3309	1993.2219	81	1.2912	0.6791	0.9126	1.0820	8.2090	14.6950	8.1947	14.3523
+3310	1993.2247	82	1.2912	0.6791	0.9126	1.0820	8.2090	14.6950	8.1972	14.3459
+3311	1993.2274	83	1.2911	0.6791	0.9126	1.0820	8.2090	14.6950	8.1994	14.3396
+3312	1993.2301	84	1.2911	0.6790	0.9125	1.0820	8.2090	14.6950	8.2013	14.3332
+3313	1993.2329	85	1.2911	0.6790	0.9125	1.0820	8.2090	14.6950	8.2027	14.3268
+3314	1993.2356	86	1.2910	0.6790	0.9125	1.0820	8.2090	14.6950	8.2038	14.3203
+3315	1993.2384	87	1.2910	0.6790	0.9125	1.0820	8.2090	14.6950	8.2046	14.3139
+3316	1993.2411	88	1.2910	0.6790	0.9125	1.0820	8.2090	14.6950	8.2049	14.3074
+3317	1993.2438	89	1.2910	0.6790	0.9125	1.0820	8.2090	14.6950	8.2049	14.3010
+3318	1993.2466	90	1.2909	0.6790	0.9125	1.0820	8.2090	14.6950	8.2044	14.2945
+3319	1993.2493	91	1.2909	0.6789	0.9125	1.0820	8.2090	14.6950	8.2036	14.2881
+3320	1993.2521	92	1.2909	0.6789	0.9125	1.0820	8.2090	14.6950	8.2025	14.2817
+3321	1993.2548	93	1.2908	0.6789	0.9125	1.0820	8.2090	14.6950	8.2009	14.2753
+3322	1993.2575	94	1.2908	0.6789	0.9125	1.0820	8.2090	14.6950	8.1990	14.2689
+3323	1993.2603	95	1.2908	0.6789	0.9125	1.0820	8.2090	14.6950	8.1967	14.2626
+3324	1993.2630	96	1.2907	0.6789	0.9125	1.0820	8.2090	14.6950	8.1940	14.2563
+3325	1993.2658	97	1.2907	0.6789	0.9125	1.0820	8.2090	14.6950	8.1910	14.2501
+3326	1993.2685	98	1.2907	0.6788	0.9125	1.0820	8.2090	14.6950	8.1877	14.2439
+3327	1993.2712	99	1.2906	0.6788	0.9125	1.0820	8.2090	14.6950	8.1840	14.2378
+3328	1993.2740	100	1.2906	0.6788	0.9124	1.0820	8.2090	14.6950	8.1800	14.2317
+3329	1993.2767	101	1.2906	0.6788	0.9124	1.0820	8.2090	14.6950	8.1757	14.2257
+3330	1993.2795	102	1.2905	0.6788	0.9124	1.0820	8.2090	14.6950	8.1710	14.2198
+3331	1993.2822	103	1.2905	0.6788	0.9124	1.0820	8.2090	14.6950	8.1661	14.2140
+3332	1993.2849	104	1.2905	0.6788	0.9124	1.0820	8.2090	14.6950	8.1609	14.2082
+3333	1993.2877	105	1.2905	0.6787	0.9124	1.0820	8.2090	14.6950	8.1554	14.2026
+3334	1993.2904	106	1.2904	0.6787	0.9124	1.0820	8.2090	14.6950	8.1497	14.1970
+3335	1993.2932	107	1.2904	0.6787	0.9124	1.0820	8.2090	14.6950	8.1437	14.1915
+3336	1993.2959	108	1.2904	0.6787	0.9124	1.0820	8.2090	14.6950	8.1375	14.1862
+3337	1993.2986	109	1.2903	0.6787	0.9124	1.0820	8.2090	14.6950	8.1311	14.1809
+3338	1993.3014	110	1.2903	0.6787	0.9124	1.0820	8.2090	14.6950	8.1245	14.1758
+3339	1993.3041	111	1.2903	0.6787	0.9124	1.0820	8.2090	14.6950	8.1177	14.1708
+3340	1993.3068	112	1.2902	0.6786	0.9124	1.0820	8.2090	14.6950	8.1108	14.1659
+3341	1993.3096	113	1.2902	0.6786	0.9124	1.0820	8.2090	14.6950	8.1037	14.1612
+3342	1993.3123	114	1.2902	0.6786	0.9124	1.0820	8.2090	14.6950	8.0965	14.1565
+3343	1993.3151	115	1.2901	0.6786	0.9124	1.0820	8.2090	14.6950	8.0892	14.1520
+3344	1993.3178	116	1.2901	0.6786	0.9123	1.0820	8.2090	14.6950	8.0818	14.1477
+3345	1993.3205	117	1.2901	0.6786	0.9123	1.0820	8.2090	14.6950	8.0743	14.1434
+3346	1993.3233	118	1.2900	0.6786	0.9123	1.0820	8.2090	14.6950	8.0668	14.1394
+3347	1993.3260	119	1.2900	0.6786	0.9123	1.0820	8.2090	14.6950	8.0592	14.1354
+3348	1993.3288	120	1.2900	0.6785	0.9123	1.0820	8.2090	14.6950	8.0516	14.1317
+3349	1993.3315	121	1.2900	0.6785	0.9123	1.0820	8.2090	14.6950	8.0440	14.1281
+3350	1993.3342	122	1.2899	0.6785	0.9123	1.0820	8.2090	14.6950	8.0365	14.1246
+3351	1993.3370	123	1.2899	0.6785	0.9123	1.0820	8.2090	14.6950	8.0289	14.1213
+3352	1993.3397	124	1.2899	0.6785	0.9123	1.0820	8.2090	14.6950	8.0214	14.1181
+3353	1993.3425	125	1.2898	0.6785	0.9123	1.0820	8.2090	14.6950	8.0140	14.1151
+3354	1993.3452	126	1.2898	0.6785	0.9123	1.0820	8.2090	14.6950	8.0067	14.1123
+3355	1993.3479	127	1.2898	0.6784	0.9123	1.0820	8.2090	14.6950	7.9994	14.1097
+3356	1993.3507	128	1.2897	0.6784	0.9123	1.0820	8.2090	14.6950	7.9923	14.1072
+3357	1993.3534	129	1.2897	0.6784	0.9123	1.0820	8.2090	14.6950	7.9853	14.1049
+3358	1993.3562	130	1.2897	0.6784	0.9123	1.0820	8.2090	14.6950	7.9785	14.1027
+3359	1993.3589	131	1.2896	0.6784	0.9123	1.0820	8.2090	14.6950	7.9718	14.1008
+3360	1993.3616	132	1.2896	0.6784	0.9122	1.0820	8.2090	14.6950	7.9653	14.0990
+3361	1993.3644	133	1.2896	0.6784	0.9122	1.0820	8.2090	14.6950	7.9590	14.0973
+3362	1993.3671	134	1.2896	0.6783	0.9122	1.0820	8.2090	14.6950	7.9528	14.0959
+3363	1993.3699	135	1.2895	0.6783	0.9122	1.0820	8.2090	14.6950	7.9469	14.0946
+3364	1993.3726	136	1.2895	0.6783	0.9122	1.0820	8.2090	14.6950	7.9413	14.0935
+3365	1993.3753	137	1.2895	0.6783	0.9122	1.0820	8.2090	14.6950	7.9358	14.0925
+3366	1993.3781	138	1.2894	0.6783	0.9122	1.0820	8.2090	14.6950	7.9306	14.0918
+3367	1993.3808	139	1.2894	0.6783	0.9122	1.0820	8.2090	14.6950	7.9257	14.0912
+3368	1993.3836	140	1.2894	0.6783	0.9122	1.0820	8.2090	14.6950	7.9211	14.0908
+3369	1993.3863	141	1.2893	0.6783	0.9122	1.0820	8.2090	14.6950	7.9167	14.0905
+3370	1993.3890	142	1.2893	0.6782	0.9122	1.0820	8.2090	14.6950	7.9126	14.0905
+3371	1993.3918	143	1.2893	0.6782	0.9122	1.0820	8.2090	14.6950	7.9088	14.0906
+3372	1993.3945	144	1.2892	0.6782	0.9122	1.0820	8.2090	14.6950	7.9054	14.0908
+3373	1993.3973	145	1.2892	0.6782	0.9122	1.0820	8.2090	14.6950	7.9022	14.0913
+3374	1993.4000	146	1.2892	0.6782	0.9122	1.0820	8.2090	14.6950	7.8993	14.0919
+3375	1993.4027	147	1.2892	0.6782	0.9122	1.0820	8.2090	14.6950	7.8968	14.0927
+3376	1993.4055	148	1.2891	0.6782	0.9121	1.0820	8.2090	14.6950	7.8946	14.0936
+3377	1993.4082	149	1.2891	0.6781	0.9121	1.0820	8.2090	14.6950	7.8927	14.0947
+3378	1993.4110	150	1.2891	0.6781	0.9121	1.0820	8.2090	14.6950	7.8912	14.0959
+3379	1993.4137	151	1.2890	0.6781	0.9121	1.0820	8.2090	14.6950	7.8900	14.0973
+3380	1993.4164	152	1.2890	0.6781	0.9121	1.0820	8.2090	14.6950	7.8891	14.0989
+3381	1993.4192	153	1.2890	0.6781	0.9121	1.0820	8.2090	14.6950	7.8886	14.1006
+3382	1993.4219	154	1.2889	0.6781	0.9121	1.0820	8.2090	14.6950	7.8884	14.1024
+3383	1993.4247	155	1.2889	0.6781	0.9121	1.0820	8.2090	14.6950	7.8885	14.1044
+3384	1993.4274	156	1.2889	0.6780	0.9121	1.0820	8.2090	14.6950	7.8890	14.1066
+3385	1993.4301	157	1.2888	0.6780	0.9121	1.0820	8.2090	14.6950	7.8898	14.1089
+3386	1993.4329	158	1.2888	0.6780	0.9121	1.0820	8.2090	14.6950	7.8910	14.1113
+3387	1993.4356	159	1.2888	0.6780	0.9121	1.0820	8.2090	14.6950	7.8925	14.1138
+3388	1993.4384	160	1.2888	0.6780	0.9121	1.0820	8.2090	14.6950	7.8943	14.1165
+3389	1993.4411	161	1.2887	0.6780	0.9121	1.0820	8.2090	14.6950	7.8964	14.1193
+3390	1993.4438	162	1.2887	0.6780	0.9121	1.0820	8.2090	14.6950	7.8989	14.1222
+3391	1993.4466	163	1.2887	0.6780	0.9121	1.0820	8.2090	14.6950	7.9016	14.1252
+3392	1993.4493	164	1.2886	0.6779	0.9121	1.0820	8.2090	14.6950	7.9047	14.1284
+3393	1993.4521	165	1.2886	0.6779	0.9120	1.0820	8.2090	14.6950	7.9080	14.1316
+3394	1993.4548	166	1.2886	0.6779	0.9120	1.0820	8.2090	14.6950	7.9117	14.1350
+3395	1993.4575	167	1.2885	0.6779	0.9120	1.0820	8.2090	14.6950	7.9156	14.1384
+3396	1993.4603	168	1.2885	0.6779	0.9120	1.0820	8.2090	14.6950	7.9198	14.1420
+3397	1993.4630	169	1.2885	0.6779	0.9120	1.0820	8.2090	14.6950	7.9243	14.1456
+3398	1993.4658	170	1.2884	0.6779	0.9120	1.0820	8.2090	14.6950	7.9290	14.1494
+3399	1993.4685	171	1.2884	0.6778	0.9120	1.0820	8.2090	14.6950	7.9339	14.1532
+3400	1993.4712	172	1.2884	0.6778	0.9120	1.0820	8.2090	14.6950	7.9391	14.1570
+3401	1993.4740	173	1.2884	0.6778	0.9120	1.0820	8.2090	14.6950	7.9445	14.1610
+3402	1993.4767	174	1.2883	0.6778	0.9120	1.0820	8.2090	14.6950	7.9501	14.1650
+3403	1993.4795	175	1.2883	0.6778	0.9120	1.0820	8.2090	14.6950	7.9559	14.1691
+3404	1993.4822	176	1.2883	0.6778	0.9120	1.0820	8.2090	14.6950	7.9619	14.1732
+3405	1993.4849	177	1.2882	0.6778	0.9120	1.0820	8.2090	14.6950	7.9680	14.1774
+3406	1993.4877	178	1.2882	0.6777	0.9120	1.0820	8.2090	14.6950	7.9743	14.1816
+3407	1993.4904	179	1.2882	0.6777	0.9120	1.0820	8.2090	14.6950	7.9808	14.1858
+3408	1993.4932	180	1.2881	0.6777	0.9120	1.0820	8.2090	14.6950	7.9873	14.1901
+3409	1993.4959	181	1.2881	0.6777	0.9119	1.0820	8.2090	14.6950	7.9940	14.1944
+3410	1993.4986	182	1.2881	0.6777	0.9119	1.0820	8.2090	14.6950	8.0007	14.1988
+3411	1993.5014	183	1.2881	0.6777	0.9119	1.0820	8.2090	14.6950	8.0076	14.2031
+3412	1993.5041	184	1.2880	0.6777	0.9119	1.0820	8.2090	14.6950	8.0145	14.2075
+3413	1993.5068	185	1.2880	0.6777	0.9119	1.0820	8.2090	14.6950	8.0214	14.2119
+3414	1993.5096	186	1.2880	0.6776	0.9119	1.0820	8.2090	14.6950	8.0284	14.2163
+3415	1993.5123	187	1.2879	0.6776	0.9119	1.0820	8.2090	14.6950	8.0354	14.2206
+3416	1993.5151	188	1.2879	0.6776	0.9119	1.0820	8.2090	14.6950	8.0423	14.2250
+3417	1993.5178	189	1.2879	0.6776	0.9119	1.0820	8.2090	14.6950	8.0493	14.2293
+3418	1993.5205	190	1.2878	0.6776	0.9119	1.0820	8.2090	14.6950	8.0562	14.2336
+3419	1993.5233	191	1.2878	0.6776	0.9119	1.0820	8.2090	14.6950	8.0631	14.2379
+3420	1993.5260	192	1.2878	0.6776	0.9119	1.0820	8.2090	14.6950	8.0699	14.2422
+3421	1993.5288	193	1.2877	0.6775	0.9119	1.0820	8.2090	14.6950	8.0766	14.2464
+3422	1993.5315	194	1.2877	0.6775	0.9119	1.0820	8.2090	14.6950	8.0832	14.2506
+3423	1993.5342	195	1.2877	0.6775	0.9119	1.0820	8.2090	14.6950	8.0897	14.2547
+3424	1993.5370	196	1.2877	0.6775	0.9119	1.0820	8.2090	14.6950	8.0960	14.2588
+3425	1993.5397	197	1.2876	0.6775	0.9119	1.0820	8.2090	14.6950	8.1022	14.2628
+3426	1993.5425	198	1.2876	0.6775	0.9118	1.0820	8.2090	14.6950	8.1083	14.2667
+3427	1993.5452	199	1.2876	0.6775	0.9118	1.0820	8.2090	14.6950	8.1141	14.2706
+3428	1993.5479	200	1.2875	0.6775	0.9118	1.0820	8.2090	14.6950	8.1198	14.2744
+3429	1993.5507	201	1.2875	0.6774	0.9118	1.0820	8.2090	14.6950	8.1253	14.2781
+3430	1993.5534	202	1.2875	0.6774	0.9118	1.0820	8.2090	14.6950	8.1305	14.2817
+3431	1993.5562	203	1.2874	0.6774	0.9118	1.0820	8.2090	14.6950	8.1355	14.2853
+3432	1993.5589	204	1.2874	0.6774	0.9118	1.0820	8.2090	14.6950	8.1402	14.2887
+3433	1993.5616	205	1.2874	0.6774	0.9118	1.0820	8.2090	14.6950	8.1447	14.2921
+3434	1993.5644	206	1.2874	0.6774	0.9118	1.0820	8.2090	14.6950	8.1489	14.2953
+3435	1993.5671	207	1.2873	0.6774	0.9118	1.0820	8.2090	14.6950	8.1529	14.2985
+3436	1993.5699	208	1.2873	0.6773	0.9118	1.0820	8.2090	14.6950	8.1565	14.3015
+3437	1993.5726	209	1.2873	0.6773	0.9118	1.0820	8.2090	14.6950	8.1599	14.3044
+3438	1993.5753	210	1.2872	0.6773	0.9118	1.0820	8.2090	14.6950	8.1629	14.3072
+3439	1993.5781	211	1.2872	0.6773	0.9118	1.0820	8.2090	14.6950	8.1656	14.3099
+3440	1993.5808	212	1.2872	0.6773	0.9118	1.0820	8.2090	14.6950	8.1680	14.3124
+3441	1993.5836	213	1.2871	0.6773	0.9118	1.0820	8.2090	14.6950	8.1701	14.3148
+3442	1993.5863	214	1.2871	0.6773	0.9118	1.0820	8.2090	14.6950	8.1718	14.3171
+3443	1993.5890	215	1.2871	0.6773	0.9117	1.0820	8.2090	14.6950	8.1732	14.3192
+3444	1993.5918	216	1.2871	0.6772	0.9117	1.0820	8.2090	14.6950	8.1743	14.3212
+3445	1993.5945	217	1.2870	0.6772	0.9117	1.0820	8.2090	14.6950	8.1750	14.3231
+3446	1993.5973	218	1.2870	0.6772	0.9117	1.0820	8.2090	14.6950	8.1753	14.3248
+3447	1993.6000	219	1.2870	0.6772	0.9117	1.0820	8.2090	14.6950	8.1753	14.3264
+3448	1993.6027	220	1.2869	0.6772	0.9117	1.0820	8.2090	14.6950	8.1750	14.3278
+3449	1993.6055	221	1.2869	0.6772	0.9117	1.0820	8.2090	14.6950	8.1743	14.3290
+3450	1993.6082	222	1.2869	0.6772	0.9117	1.0820	8.2090	14.6950	8.1732	14.3301
+3451	1993.6110	223	1.2868	0.6771	0.9117	1.0820	8.2090	14.6950	8.1719	14.3310
+3452	1993.6137	224	1.2868	0.6771	0.9117	1.0820	8.2090	14.6950	8.1701	14.3318
+3453	1993.6164	225	1.2868	0.6771	0.9117	1.0820	8.2090	14.6950	8.1681	14.3324
+3454	1993.6192	226	1.2868	0.6771	0.9117	1.0820	8.2090	14.6950	8.1657	14.3329
+3455	1993.6219	227	1.2867	0.6771	0.9117	1.0820	8.2090	14.6950	8.1629	14.3331
+3456	1993.6247	228	1.2867	0.6771	0.9117	1.0820	8.2090	14.6950	8.1599	14.3333
+3457	1993.6274	229	1.2867	0.6771	0.9117	1.0820	8.2090	14.6950	8.1565	14.3332
+3458	1993.6301	230	1.2866	0.6770	0.9117	1.0820	8.2090	14.6950	8.1528	14.3330
+3459	1993.6329	231	1.2866	0.6770	0.9117	1.0820	8.2090	14.6950	8.1489	14.3326
+3460	1993.6356	232	1.2866	0.6770	0.9116	1.0820	8.2090	14.6950	8.1446	14.3321
+3461	1993.6384	233	1.2866	0.6770	0.9116	1.0820	8.2090	14.6950	8.1401	14.3313
+3462	1993.6411	234	1.2865	0.6770	0.9116	1.0820	8.2090	14.6950	8.1353	14.3305
+3463	1993.6438	235	1.2865	0.6770	0.9116	1.0820	8.2090	14.6950	8.1303	14.3294
+3464	1993.6466	236	1.2865	0.6770	0.9116	1.0820	8.2090	14.6950	8.1250	14.3282
+3465	1993.6493	237	1.2864	0.6770	0.9116	1.0820	8.2090	14.6950	8.1195	14.3268
+3466	1993.6521	238	1.2864	0.6769	0.9116	1.0820	8.2090	14.6950	8.1137	14.3252
+3467	1993.6548	239	1.2864	0.6769	0.9116	1.0820	8.2090	14.6950	8.1078	14.3235
+3468	1993.6575	240	1.2863	0.6769	0.9116	1.0820	8.2090	14.6950	8.1016	14.3216
+3469	1993.6603	241	1.2863	0.6769	0.9116	1.0820	8.2090	14.6950	8.0953	14.3196
+3470	1993.6630	242	1.2863	0.6769	0.9116	1.0820	8.2090	14.6950	8.0889	14.3173
+3471	1993.6658	243	1.2863	0.6769	0.9116	1.0820	8.2090	14.6950	8.0822	14.3150
+3472	1993.6685	244	1.2862	0.6769	0.9116	1.0820	8.2090	14.6950	8.0755	14.3124
+3473	1993.6712	245	1.2862	0.6769	0.9116	1.0820	8.2090	14.6950	8.0686	14.3097
+3474	1993.6740	246	1.2862	0.6768	0.9116	1.0820	8.2090	14.6950	8.0616	14.3069
+3475	1993.6767	247	1.2861	0.6768	0.9116	1.0820	8.2090	14.6950	8.0546	14.3039
+3476	1993.6795	248	1.2861	0.6768	0.9116	1.0820	8.2090	14.6950	8.0475	14.3008
+3477	1993.6822	249	1.2861	0.6768	0.9116	1.0820	8.2090	14.6950	8.0403	14.2975
+3478	1993.6849	250	1.2860	0.6768	0.9115	1.0820	8.2090	14.6950	8.0331	14.2940
+3479	1993.6877	251	1.2860	0.6768	0.9115	1.0820	8.2090	14.6950	8.0258	14.2905
+3480	1993.6904	252	1.2860	0.6768	0.9115	1.0820	8.2090	14.6950	8.0186	14.2868
+3481	1993.6932	253	1.2860	0.6767	0.9115	1.0820	8.2090	14.6950	8.0113	14.2829
+3482	1993.6959	254	1.2859	0.6767	0.9115	1.0820	8.2090	14.6950	8.0041	14.2789
+3483	1993.6986	255	1.2859	0.6767	0.9115	1.0820	8.2090	14.6950	7.9969	14.2748
+3484	1993.7014	256	1.2859	0.6767	0.9115	1.0820	8.2090	14.6950	7.9898	14.2706
+3485	1993.7041	257	1.2858	0.6767	0.9115	1.0820	8.2090	14.6950	7.9827	14.2662
+3486	1993.7068	258	1.2858	0.6767	0.9115	1.0820	8.2090	14.6950	7.9758	14.2618
+3487	1993.7096	259	1.2858	0.6767	0.9115	1.0820	8.2090	14.6950	7.9689	14.2572
+3488	1993.7123	260	1.2858	0.6767	0.9115	1.0820	8.2090	14.6950	7.9621	14.2525
+3489	1993.7151	261	1.2857	0.6766	0.9115	1.0820	8.2090	14.6950	7.9555	14.2477
+3490	1993.7178	262	1.2857	0.6766	0.9115	1.0820	8.2090	14.6950	7.9490	14.2428
+3491	1993.7205	263	1.2857	0.6766	0.9115	1.0820	8.2090	14.6950	7.9426	14.2378
+3492	1993.7233	264	1.2856	0.6766	0.9115	1.0820	8.2090	14.6950	7.9364	14.2327
+3493	1993.7260	265	1.2856	0.6766	0.9115	1.0820	8.2090	14.6950	7.9304	14.2275
+3494	1993.7288	266	1.2856	0.6766	0.9115	1.0820	8.2090	14.6950	7.9246	14.2223
+3495	1993.7315	267	1.2855	0.6766	0.9114	1.0820	8.2090	14.6950	7.9190	14.2169
+3496	1993.7342	268	1.2855	0.6765	0.9114	1.0820	8.2090	14.6950	7.9135	14.2115
+3497	1993.7370	269	1.2855	0.6765	0.9114	1.0820	8.2090	14.6950	7.9083	14.2060
+3498	1993.7397	270	1.2855	0.6765	0.9114	1.0820	8.2090	14.6950	7.9034	14.2005
+3499	1993.7425	271	1.2854	0.6765	0.9114	1.0820	8.2090	14.6950	7.8986	14.1949
+3500	1993.7452	272	1.2854	0.6765	0.9114	1.0820	8.2090	14.6950	7.8942	14.1892
+3501	1993.7479	273	1.2854	0.6765	0.9114	1.0820	8.2090	14.6950	7.8899	14.1835
+3502	1993.7507	274	1.2853	0.6765	0.9114	1.0820	8.2090	14.6950	7.8860	14.1778
+3503	1993.7534	275	1.2853	0.6765	0.9114	1.0820	8.2090	14.6950	7.8823	14.1720
+3504	1993.7562	276	1.2853	0.6764	0.9114	1.0820	8.2090	14.6950	7.8789	14.1662
+3505	1993.7589	277	1.2853	0.6764	0.9114	1.0820	8.2090	14.6950	7.8758	14.1603
+3506	1993.7616	278	1.2852	0.6764	0.9114	1.0820	8.2090	14.6950	7.8729	14.1544
+3507	1993.7644	279	1.2852	0.6764	0.9114	1.0820	8.2090	14.6950	7.8704	14.1485
+3508	1993.7671	280	1.2852	0.6764	0.9114	1.0820	8.2090	14.6950	7.8681	14.1426
+3509	1993.7699	281	1.2851	0.6764	0.9114	1.0820	8.2090	14.6950	7.8662	14.1367
+3510	1993.7726	282	1.2851	0.6764	0.9114	1.0820	8.2090	14.6950	7.8646	14.1308
+3511	1993.7753	283	1.2851	0.6763	0.9114	1.0820	8.2090	14.6950	7.8632	14.1248
+3512	1993.7781	284	1.2851	0.6763	0.9114	1.0820	8.2090	14.6950	7.8622	14.1189
+3513	1993.7808	285	1.2850	0.6763	0.9113	1.0820	8.2090	14.6950	7.8615	14.1130
+3514	1993.7836	286	1.2850	0.6763	0.9113	1.0820	8.2090	14.6950	7.8611	14.1071
+3515	1993.7863	287	1.2850	0.6763	0.9113	1.0820	8.2090	14.6950	7.8610	14.1012
+3516	1993.7890	288	1.2849	0.6763	0.9113	1.0820	8.2090	14.6950	7.8612	14.0954
+3517	1993.7918	289	1.2849	0.6763	0.9113	1.0820	8.2090	14.6950	7.8618	14.0896
+3518	1993.7945	290	1.2849	0.6763	0.9113	1.0820	8.2090	14.6950	7.8626	14.0838
+3519	1993.7973	291	1.2848	0.6762	0.9113	1.0820	8.2090	14.6950	7.8638	14.0781
+3520	1993.8000	292	1.2848	0.6762	0.9113	1.0820	8.2090	14.6950	7.8652	14.0724
+3521	1993.8027	293	1.2848	0.6762	0.9113	1.0820	8.2090	14.6950	7.8670	14.0667
+3522	1993.8055	294	1.2848	0.6762	0.9113	1.0820	8.2090	14.6950	7.8690	14.0611
+3523	1993.8082	295	1.2847	0.6762	0.9113	1.0820	8.2090	14.6950	7.8713	14.0556
+3524	1993.8110	296	1.2847	0.6762	0.9113	1.0820	8.2090	14.6950	7.8740	14.0501
+3525	1993.8137	297	1.2847	0.6762	0.9113	1.0820	8.2090	14.6950	7.8769	14.0447
+3526	1993.8164	298	1.2846	0.6762	0.9113	1.0820	8.2090	14.6950	7.8800	14.0394
+3527	1993.8192	299	1.2846	0.6761	0.9113	1.0820	8.2090	14.6950	7.8835	14.0341
+3528	1993.8219	300	1.2846	0.6761	0.9113	1.0820	8.2090	14.6950	7.8872	14.0289
+3529	1993.8247	301	1.2846	0.6761	0.9113	1.0820	8.2090	14.6950	7.8911	14.0238
+3530	1993.8274	302	1.2845	0.6761	0.9113	1.0820	8.2090	14.6950	7.8953	14.0188
+3531	1993.8301	303	1.2845	0.6761	0.9112	1.0820	8.2090	14.6950	7.8997	14.0139
+3532	1993.8329	304	1.2845	0.6761	0.9112	1.0820	8.2090	14.6950	7.9044	14.0090
+3533	1993.8356	305	1.2844	0.6761	0.9112	1.0820	8.2090	14.6950	7.9092	14.0043
+3534	1993.8384	306	1.2844	0.6760	0.9112	1.0820	8.2090	14.6950	7.9143	13.9997
+3535	1993.8411	307	1.2844	0.6760	0.9112	1.0820	8.2090	14.6950	7.9196	13.9952
+3536	1993.8438	308	1.2844	0.6760	0.9112	1.0820	8.2090	14.6950	7.9250	13.9907
+3537	1993.8466	309	1.2843	0.6760	0.9112	1.0820	8.2090	14.6950	7.9306	13.9864
+3538	1993.8493	310	1.2843	0.6760	0.9112	1.0820	8.2090	14.6950	7.9364	13.9823
+3539	1993.8521	311	1.2843	0.6760	0.9112	1.0820	8.2090	14.6950	7.9423	13.9782
+3540	1993.8548	312	1.2842	0.6760	0.9112	1.0820	8.2090	14.6950	7.9484	13.9742
+3541	1993.8575	313	1.2842	0.6760	0.9112	1.0820	8.2090	14.6950	7.9546	13.9704
+3542	1993.8603	314	1.2842	0.6759	0.9112	1.0820	8.2090	14.6950	7.9609	13.9667
+3543	1993.8630	315	1.2842	0.6759	0.9112	1.0820	8.2090	14.6950	7.9673	13.9631
+3544	1993.8658	316	1.2841	0.6759	0.9112	1.0820	8.2090	14.6950	7.9737	13.9597
+3545	1993.8685	317	1.2841	0.6759	0.9112	1.0820	8.2090	14.6950	7.9803	13.9564
+3546	1993.8712	318	1.2841	0.6759	0.9112	1.0820	8.2090	14.6950	7.9869	13.9532
+3547	1993.8740	319	1.2840	0.6759	0.9112	1.0820	8.2090	14.6950	7.9935	13.9502
+3548	1993.8767	320	1.2840	0.6759	0.9112	1.0820	8.2090	14.6950	8.0002	13.9473
+3549	1993.8795	321	1.2840	0.6759	0.9111	1.0820	8.2090	14.6950	8.0068	13.9445
+3550	1993.8822	322	1.2840	0.6758	0.9111	1.0820	8.2090	14.6950	8.0135	13.9419
+3551	1993.8849	323	1.2839	0.6758	0.9111	1.0820	8.2090	14.6950	8.0201	13.9394
+3552	1993.8877	324	1.2839	0.6758	0.9111	1.0820	8.2090	14.6950	8.0268	13.9371
+3553	1993.8904	325	1.2839	0.6758	0.9111	1.0820	8.2090	14.6950	8.0333	13.9349
+3554	1993.8932	326	1.2838	0.6758	0.9111	1.0820	8.2090	14.6950	8.0398	13.9328
+3555	1993.8959	327	1.2838	0.6758	0.9111	1.0820	8.2090	14.6950	8.0462	13.9309
+3556	1993.8986	328	1.2838	0.6758	0.9111	1.0820	8.2090	14.6950	8.0526	13.9292
+3557	1993.9014	329	1.2837	0.6757	0.9111	1.0820	8.2090	14.6950	8.0588	13.9276
+3558	1993.9041	330	1.2837	0.6757	0.9111	1.0820	8.2090	14.6950	8.0649	13.9261
+3559	1993.9068	331	1.2837	0.6757	0.9111	1.0820	8.2090	14.6950	8.0709	13.9248
+3560	1993.9096	332	1.2837	0.6757	0.9111	1.0820	8.2090	14.6950	8.0767	13.9237
+3561	1993.9123	333	1.2836	0.6757	0.9111	1.0820	8.2090	14.6950	8.0824	13.9227
+3562	1993.9151	334	1.2836	0.6757	0.9111	1.0820	8.2090	14.6950	8.0879	13.9219
+3563	1993.9178	335	1.2836	0.6757	0.9111	1.0820	8.2090	14.6950	8.0932	13.9212
+3564	1993.9205	336	1.2836	0.6757	0.9111	1.0820	8.2090	14.6950	8.0984	13.9206
+3565	1993.9233	337	1.2835	0.6756	0.9111	1.0820	8.2090	14.6950	8.1033	13.9202
+3566	1993.9260	338	1.2835	0.6756	0.9111	1.0820	8.2090	14.6950	8.1080	13.9200
+3567	1993.9288	339	1.2835	0.6756	0.9111	1.0820	8.2090	14.6950	8.1124	13.9199
+3568	1993.9315	340	1.2834	0.6756	0.9110	1.0820	8.2090	14.6950	8.1166	13.9199
+3569	1993.9342	341	1.2834	0.6756	0.9110	1.0820	8.2090	14.6950	8.1206	13.9201
+3570	1993.9370	342	1.2834	0.6756	0.9110	1.0820	8.2090	14.6950	8.1243	13.9204
+3571	1993.9397	343	1.2834	0.6756	0.9110	1.0820	8.2090	14.6950	8.1277	13.9209
+3572	1993.9425	344	1.2833	0.6756	0.9110	1.0820	8.2090	14.6950	8.1309	13.9215
+3573	1993.9452	345	1.2833	0.6755	0.9110	1.0820	8.2090	14.6950	8.1338	13.9223
+3574	1993.9479	346	1.2833	0.6755	0.9110	1.0820	8.2090	14.6950	8.1363	13.9232
+3575	1993.9507	347	1.2832	0.6755	0.9110	1.0820	8.2090	14.6950	8.1386	13.9242
+3576	1993.9534	348	1.2832	0.6755	0.9110	1.0820	8.2090	14.6950	8.1406	13.9254
+3577	1993.9562	349	1.2832	0.6755	0.9110	1.0820	8.2090	14.6950	8.1423	13.9267
+3578	1993.9589	350	1.2832	0.6755	0.9110	1.0820	8.2090	14.6950	8.1436	13.9281
+3579	1993.9616	351	1.2831	0.6755	0.9110	1.0820	8.2090	14.6950	8.1447	13.9297
+3580	1993.9644	352	1.2831	0.6755	0.9110	1.0820	8.2090	14.6950	8.1454	13.9314
+3581	1993.9671	353	1.2831	0.6754	0.9110	1.0820	8.2090	14.6950	8.1458	13.9332
+3582	1993.9699	354	1.2830	0.6754	0.9110	1.0820	8.2090	14.6950	8.1459	13.9352
+3583	1993.9726	355	1.2830	0.6754	0.9110	1.0820	8.2090	14.6950	8.2090	14.6950
+3584	1993.9753	356	1.2830	0.6754	0.9110	1.0820	8.2090	14.6950	8.2034	14.6949
+3585	1993.9781	357	1.2830	0.6754	0.9110	1.0820	8.2090	14.6950	8.1976	14.6946
+3586	1993.9808	358	1.2829	0.6754	0.9109	1.0820	8.2090	14.6950	8.1916	14.6941
+3587	1993.9836	359	1.2829	0.6754	0.9109	1.0820	8.2090	14.6950	8.1855	14.6935
+3588	1993.9863	360	1.2829	0.6753	0.9109	1.0820	8.2090	14.6950	8.1791	14.6927
+3589	1993.9890	361	1.2828	0.6753	0.9109	1.0820	8.2090	14.6950	8.1727	14.6918
+3590	1993.9918	362	1.2828	0.6753	0.9109	1.0820	8.2090	14.6950	8.1661	14.6907
+3591	1993.9945	363	1.2828	0.6753	0.9109	1.0820	8.2090	14.6950	8.1593	14.6894
+3592	1993.9973	364	1.2828	0.6753	0.9109	1.0820	8.2090	14.6950	8.1525	14.6880
+3593	1993.9999	365	1.2827	0.6753	0.9109	1.0820	8.2090	14.6950	8.1456	14.6864
+3594	1994.0027	1	1.2827	0.6753	0.9109	1.0820	8.2090	14.6950	8.1386	14.6846
+3595	1994.0055	2	1.2827	0.6753	0.9109	1.0820	8.2090	14.6950	8.1316	14.6827
+3596	1994.0082	3	1.2826	0.6752	0.9109	1.0820	8.2090	14.6950	8.1245	14.6806
+3597	1994.0110	4	1.2826	0.6752	0.9109	1.0820	8.2090	14.6950	8.1173	14.6784
+3598	1994.0137	5	1.2826	0.6752	0.9109	1.0820	8.2090	14.6950	8.1102	14.6760
+3599	1994.0164	6	1.2826	0.6752	0.9109	1.0820	8.2090	14.6950	8.1030	14.6735
+3600	1994.0192	7	1.2825	0.6752	0.9109	1.0820	8.2090	14.6950	8.0959	14.6708
+3601	1994.0219	8	1.2825	0.6752	0.9109	1.0820	8.2090	14.6950	8.0887	14.6679
+3602	1994.0247	9	1.2825	0.6752	0.9109	1.0820	8.2090	14.6950	8.0816	14.6649
+3603	1994.0274	10	1.2824	0.6752	0.9109	1.0820	8.2090	14.6950	8.0746	14.6618
+3604	1994.0301	11	1.2824	0.6751	0.9109	1.0820	8.2090	14.6950	8.0676	14.6585
+3605	1994.0329	12	1.2824	0.6751	0.9108	1.0820	8.2090	14.6950	8.0608	14.6551
+3606	1994.0356	13	1.2824	0.6751	0.9108	1.0820	8.2090	14.6950	8.0540	14.6516
+3607	1994.0384	14	1.2823	0.6751	0.9108	1.0820	8.2090	14.6950	8.0473	14.6479
+3608	1994.0411	15	1.2823	0.6751	0.9108	1.0820	8.2090	14.6950	8.0407	14.6440
+3609	1994.0438	16	1.2823	0.6751	0.9108	1.0820	8.2090	14.6950	8.0343	14.6401
+3610	1994.0466	17	1.2822	0.6751	0.9108	1.0820	8.2090	14.6950	8.0280	14.6360
+3611	1994.0493	18	1.2822	0.6751	0.9108	1.0820	8.2090	14.6950	8.0218	14.6318
+3612	1994.0521	19	1.2822	0.6750	0.9108	1.0820	8.2090	14.6950	8.0158	14.6275
+3613	1994.0548	20	1.2822	0.6750	0.9108	1.0820	8.2090	14.6950	8.0100	14.6231
+3614	1994.0575	21	1.2821	0.6750	0.9108	1.0820	8.2090	14.6950	8.0044	14.6185
+3615	1994.0603	22	1.2821	0.6750	0.9108	1.0820	8.2090	14.6950	7.9990	14.6139
+3616	1994.0630	23	1.2821	0.6750	0.9108	1.0820	8.2090	14.6950	7.9938	14.6091
+3617	1994.0658	24	1.2821	0.6750	0.9108	1.0820	8.2090	14.6950	7.9888	14.6042
+3618	1994.0685	25	1.2820	0.6750	0.9108	1.0820	8.2090	14.6950	7.9840	14.5993
+3619	1994.0712	26	1.2820	0.6750	0.9108	1.0820	8.2090	14.6950	7.9795	14.5942
+3620	1994.0740	27	1.2820	0.6749	0.9108	1.0820	8.2090	14.6950	7.9752	14.5891
+3621	1994.0767	28	1.2819	0.6749	0.9108	1.0820	8.2090	14.6950	7.9711	14.5839
+3622	1994.0795	29	1.2819	0.6749	0.9108	1.0820	8.2090	14.6950	7.9673	14.5786
+3623	1994.0822	30	1.2819	0.6749	0.9108	1.0820	8.2090	14.6950	7.9638	14.5732
+3624	1994.0849	31	1.2819	0.6749	0.9107	1.0820	8.2090	14.6950	7.9605	14.5677
+3625	1994.0877	32	1.2818	0.6749	0.9107	1.0820	8.2090	14.6950	7.9576	14.5622
+3626	1994.0904	33	1.2818	0.6749	0.9107	1.0820	8.2090	14.6950	7.9548	14.5567
+3627	1994.0932	34	1.2818	0.6749	0.9107	1.0820	8.2090	14.6950	7.9524	14.5510
+3628	1994.0959	35	1.2817	0.6748	0.9107	1.0820	8.2090	14.6950	7.9503	14.5453
+3629	1994.0986	36	1.2817	0.6748	0.9107	1.0820	8.2090	14.6950	7.9484	14.5396
+3630	1994.1014	37	1.2817	0.6748	0.9107	1.0820	8.2090	14.6950	7.9468	14.5338
+3631	1994.1041	38	1.2817	0.6748	0.9107	1.0820	8.2090	14.6950	7.9456	14.5280
+3632	1994.1068	39	1.2816	0.6748	0.9107	1.0820	8.2090	14.6950	7.9446	14.5221
+3633	1994.1096	40	1.2816	0.6748	0.9107	1.0820	8.2090	14.6950	7.9439	14.5162
+3634	1994.1123	41	1.2816	0.6748	0.9107	1.0820	8.2090	14.6950	7.9435	14.5103
+3635	1994.1151	42	1.2815	0.6747	0.9107	1.0820	8.2090	14.6950	7.9434	14.5044
+3636	1994.1178	43	1.2815	0.6747	0.9107	1.0820	8.2090	14.6950	7.9436	14.4985
+3637	1994.1205	44	1.2815	0.6747	0.9107	1.0820	8.2090	14.6950	7.9441	14.4925
+3638	1994.1233	45	1.2815	0.6747	0.9107	1.0820	8.2090	14.6950	7.9449	14.4865
+3639	1994.1260	46	1.2814	0.6747	0.9107	1.0820	8.2090	14.6950	8.2090	14.6950
+3640	1994.1288	47	1.2814	0.6747	0.9107	1.0820	8.2090	14.6950	8.2035	14.6949
+3641	1994.1315	48	1.2814	0.6747	0.9107	1.0820	8.2090	14.6950	8.1978	14.6946
+3642	1994.1342	49	1.2814	0.6747	0.9107	1.0820	8.2090	14.6950	8.1919	14.6942
+3643	1994.1370	50	1.2813	0.6746	0.9107	1.0820	8.2090	14.6950	8.1858	14.6936
+3644	1994.1397	51	1.2813	0.6746	0.9106	1.0820	8.2090	14.6950	8.1796	14.6928
+3645	1994.1425	52	1.2813	0.6746	0.9106	1.0820	8.2090	14.6950	8.1733	14.6919
+3646	1994.1452	53	1.2812	0.6746	0.9106	1.0820	8.2090	14.6950	8.1668	14.6908
+3647	1994.1479	54	1.2812	0.6746	0.9106	1.0820	8.2090	14.6950	8.1602	14.6896
+3648	1994.1507	55	1.2812	0.6746	0.9106	1.0820	8.2090	14.6950	8.1535	14.6882
+3649	1994.1534	56	1.2812	0.6746	0.9106	1.0820	8.2090	14.6950	8.1467	14.6867
+3650	1994.1562	57	1.2811	0.6746	0.9106	1.0820	8.2090	14.6950	8.1398	14.6850
+3651	1994.1589	58	1.2811	0.6745	0.9106	1.0820	8.2090	14.6950	8.1329	14.6831
+3652	1994.1616	59	1.2811	0.6745	0.9106	1.0820	8.2090	14.6950	8.1259	14.6811
+3653	1994.1644	60	1.2810	0.6745	0.9106	1.0820	8.2090	14.6950	8.1189	14.6789
+3654	1994.1671	61	1.2810	0.6745	0.9106	1.0820	8.2090	14.6950	8.1118	14.6766
+3655	1994.1699	62	1.2810	0.6745	0.9106	1.0820	8.2090	14.6950	8.1048	14.6742
+3656	1994.1726	63	1.2810	0.6745	0.9106	1.0820	8.2090	14.6950	8.0977	14.6716
+3657	1994.1753	64	1.2809	0.6745	0.9106	1.0820	8.2090	14.6950	8.0907	14.6688
+3658	1994.1781	65	1.2809	0.6745	0.9106	1.0820	8.2090	14.6950	8.0837	14.6659
+3659	1994.1808	66	1.2809	0.6744	0.9106	1.0820	8.2090	14.6950	8.0768	14.6629
+3660	1994.1836	67	1.2809	0.6744	0.9106	1.0820	8.2090	14.6950	8.0699	14.6597
+3661	1994.1863	68	1.2808	0.6744	0.9106	1.0820	8.2090	14.6950	8.0631	14.6564
+3662	1994.1890	69	1.2808	0.6744	0.9106	1.0820	8.2090	14.6950	8.0564	14.6529
+3663	1994.1918	70	1.2808	0.6744	0.9105	1.0820	8.2090	14.6950	8.0497	14.6494
+3664	1994.1945	71	1.2807	0.6744	0.9105	1.0820	8.2090	14.6950	8.0432	14.6457
+3665	1994.1973	72	1.2807	0.6744	0.9105	1.0820	8.2090	14.6950	8.0368	14.6418
+3666	1994.2000	73	1.2807	0.6744	0.9105	1.0820	8.2090	14.6950	8.0306	14.6379
+3667	1994.2027	74	1.2807	0.6743	0.9105	1.0820	8.2090	14.6950	8.0245	14.6338
+3668	1994.2055	75	1.2806	0.6743	0.9105	1.0820	8.2090	14.6950	8.0185	14.6296
+3669	1994.2082	76	1.2806	0.6743	0.9105	1.0820	8.2090	14.6950	8.0127	14.6253
+3670	1994.2110	77	1.2806	0.6743	0.9105	1.0820	8.2090	14.6950	8.0071	14.6209
+3671	1994.2137	78	1.2806	0.6743	0.9105	1.0820	8.2090	14.6950	8.0017	14.6164
+3672	1994.2164	79	1.2805	0.6743	0.9105	1.0820	8.2090	14.6950	7.9964	14.6117
+3673	1994.2192	80	1.2805	0.6743	0.9105	1.0820	8.2090	14.6950	7.9914	14.6070
+3674	1994.2219	81	1.2805	0.6743	0.9105	1.0820	8.2090	14.6950	7.9866	14.6022
+3675	1994.2247	82	1.2804	0.6742	0.9105	1.0820	8.2090	14.6950	7.9820	14.5973
+3676	1994.2274	83	1.2804	0.6742	0.9105	1.0820	8.2090	14.6950	7.9776	14.5923
+3677	1994.2301	84	1.2804	0.6742	0.9105	1.0820	8.2090	14.6950	7.9735	14.5872
+3678	1994.2329	85	1.2804	0.6742	0.9105	1.0820	8.2090	14.6950	7.9696	14.5820
+3679	1994.2356	86	1.2803	0.6742	0.9105	1.0820	8.2090	14.6950	7.9660	14.5768
+3680	1994.2384	87	1.2803	0.6742	0.9105	1.0820	8.2090	14.6950	7.9626	14.5715
+3681	1994.2411	88	1.2803	0.6742	0.9105	1.0820	8.2090	14.6950	7.9595	14.5661
+3682	1994.2438	89	1.2803	0.6742	0.9105	1.0820	8.2090	14.6950	7.9566	14.5607
+3683	1994.2466	90	1.2802	0.6741	0.9104	1.0820	8.2090	14.6950	7.9540	14.5552
+3684	1994.2493	91	1.2802	0.6741	0.9104	1.0820	8.2090	14.6950	7.9517	14.5496
+3685	1994.2521	92	1.2802	0.6741	0.9104	1.0820	8.2090	14.6950	7.9497	14.5440
+3686	1994.2548	93	1.2801	0.6741	0.9104	1.0820	8.2090	14.6950	7.9479	14.5384
+3687	1994.2575	94	1.2801	0.6741	0.9104	1.0820	8.2090	14.6950	7.9465	14.5327
+3688	1994.2603	95	1.2801	0.6741	0.9104	1.0820	8.2090	14.6950	7.9453	14.5269
+3689	1994.2630	96	1.2801	0.6741	0.9104	1.0820	8.2090	14.6950	7.9444	14.5212
+3690	1994.2658	97	1.2800	0.6741	0.9104	1.0820	8.2090	14.6950	7.9438	14.5154
+3691	1994.2685	98	1.2800	0.6740	0.9104	1.0820	8.2090	14.6950	7.9435	14.5096
+3692	1994.2712	99	1.2800	0.6740	0.9104	1.0820	8.2090	14.6950	7.9434	14.5037
+3693	1994.2740	100	1.2800	0.6740	0.9104	1.0820	8.2090	14.6950	7.9437	14.4979
+3694	1994.2767	101	1.2799	0.6740	0.9104	1.0820	8.2090	14.6950	7.9442	14.4920
+3695	1994.2795	102	1.2799	0.6740	0.9104	1.0820	8.2090	14.6950	7.9451	14.4862
+3696	1994.2822	103	1.2799	0.6740	0.9104	1.0820	8.2090	14.6950	7.9462	14.4803
+3697	1994.2849	104	1.2798	0.6740	0.9104	1.0820	8.2090	14.6950	7.9476	14.4744
+3698	1994.2877	105	1.2798	0.6740	0.9104	1.0820	8.2090	14.6950	7.9492	14.4686
+3699	1994.2904	106	1.2798	0.6739	0.9104	1.0820	8.2090	14.6950	7.9512	14.4627
+3700	1994.2932	107	1.2798	0.6739	0.9104	1.0820	8.2090	14.6950	7.9534	14.4569
+3701	1994.2959	108	1.2797	0.6739	0.9104	1.0820	8.2090	14.6950	7.9559	14.4511
+3702	1994.2986	109	1.2797	0.6739	0.9104	1.0820	8.2090	14.6950	7.9586	14.4453
+3703	1994.3014	110	1.2797	0.6739	0.9103	1.0820	8.2090	14.6950	7.9616	14.4396
+3704	1994.3041	111	1.2797	0.6739	0.9103	1.0820	8.2090	14.6950	7.9648	14.4339
+3705	1994.3068	112	1.2796	0.6739	0.9103	1.0820	8.2090	14.6950	7.9683	14.4282
+3706	1994.3096	113	1.2796	0.6739	0.9103	1.0820	8.2090	14.6950	7.9720	14.4225
+3707	1994.3123	114	1.2796	0.6738	0.9103	1.0820	8.2090	14.6950	7.9760	14.4170
+3708	1994.3151	115	1.2795	0.6738	0.9103	1.0820	8.2090	14.6950	7.9801	14.4114
+3709	1994.3178	116	1.2795	0.6738	0.9103	1.0820	8.2090	14.6950	7.9845	14.4059
+3710	1994.3205	117	1.2795	0.6738	0.9103	1.0820	8.2090	14.6950	7.9891	14.4005
+3711	1994.3233	118	1.2795	0.6738	0.9103	1.0820	8.2090	14.6950	7.9939	14.3951
+3712	1994.3260	119	1.2794	0.6738	0.9103	1.0820	8.2090	14.6950	7.9988	14.3898
+3713	1994.3288	120	1.2794	0.6738	0.9103	1.0820	8.2090	14.6950	8.0040	14.3846
+3714	1994.3315	121	1.2794	0.6738	0.9103	1.0820	8.2090	14.6950	8.0093	14.3794
+3715	1994.3342	122	1.2794	0.6737	0.9103	1.0820	8.2090	14.6950	8.0148	14.3743
+3716	1994.3370	123	1.2793	0.6737	0.9103	1.0820	8.2090	14.6950	8.0204	14.3693
+3717	1994.3397	124	1.2793	0.6737	0.9103	1.0820	8.2090	14.6950	8.0262	14.3644
+3718	1994.3425	125	1.2793	0.6737	0.9103	1.0820	8.2090	14.6950	8.0320	14.3596
+3719	1994.3452	126	1.2792	0.6737	0.9103	1.0820	8.2090	14.6950	8.0380	14.3548
+3720	1994.3479	127	1.2792	0.6737	0.9103	1.0820	8.2090	14.6950	8.0441	14.3502
+3721	1994.3507	128	1.2792	0.6737	0.9103	1.0820	8.2090	14.6950	8.0503	14.3456
+3722	1994.3534	129	1.2792	0.6737	0.9103	1.0820	8.2090	14.6950	8.0566	14.3412
+3723	1994.3562	130	1.2791	0.6736	0.9103	1.0820	8.2090	14.6950	8.0629	14.3368
+3724	1994.3589	131	1.2791	0.6736	0.9102	1.0820	8.2090	14.6950	8.0693	14.3326
+3725	1994.3616	132	1.2791	0.6736	0.9102	1.0820	8.2090	14.6950	8.0758	14.3284
+3726	1994.3644	133	1.2791	0.6736	0.9102	1.0820	8.2090	14.6950	8.0822	14.3244
+3727	1994.3671	134	1.2790	0.6736	0.9102	1.0820	8.2090	14.6950	8.0887	14.3205
+3728	1994.3699	135	1.2790	0.6736	0.9102	1.0820	8.2090	14.6950	8.0952	14.3166
+3729	1994.3726	136	1.2790	0.6736	0.9102	1.0820	8.2090	14.6950	8.1017	14.3130
+3730	1994.3753	137	1.2790	0.6736	0.9102	1.0820	8.2090	14.6950	8.1081	14.3094
+3731	1994.3781	138	1.2789	0.6735	0.9102	1.0820	8.2090	14.6950	8.1145	14.3059
+3732	1994.3808	139	1.2789	0.6735	0.9102	1.0820	8.2090	14.6950	8.1209	14.3026
+3733	1994.3836	140	1.2789	0.6735	0.9102	1.0820	8.2090	14.6950	8.1272	14.2994
+3734	1994.3863	141	1.2788	0.6735	0.9102	1.0820	8.2090	14.6950	8.1335	14.2963
+3735	1994.3890	142	1.2788	0.6735	0.9102	1.0820	8.2090	14.6950	8.1396	14.2934
+3736	1994.3918	143	1.2788	0.6735	0.9102	1.0820	8.2090	14.6950	8.1457	14.2906
+3737	1994.3945	144	1.2788	0.6735	0.9102	1.0820	8.2090	14.6950	8.1516	14.2879
+3738	1994.3973	145	1.2787	0.6735	0.9102	1.0820	8.2090	14.6950	8.1575	14.2854
+3739	1994.4000	146	1.2787	0.6735	0.9102	1.0820	8.2090	14.6950	8.1631	14.2830
+3740	1994.4027	147	1.2787	0.6734	0.9102	1.0820	8.2090	14.6950	8.1687	14.2807
+3741	1994.4055	148	1.2787	0.6734	0.9102	1.0820	8.2090	14.6950	8.1741	14.2785
+3742	1994.4082	149	1.2786	0.6734	0.9102	1.0820	8.2090	14.6950	8.1793	14.2765
+3743	1994.4110	150	1.2786	0.6734	0.9102	1.0820	8.2090	14.6950	8.1843	14.2747
+3744	1994.4137	151	1.2786	0.6734	0.9101	1.0820	8.2090	14.6950	8.1892	14.2729
+3745	1994.4164	152	1.2786	0.6734	0.9101	1.0820	8.2090	14.6950	8.1938	14.2714
+3746	1994.4192	153	1.2785	0.6734	0.9101	1.0820	8.2090	14.6950	8.1983	14.2699
+3747	1994.4219	154	1.2785	0.6734	0.9101	1.0820	8.2090	14.6950	8.2025	14.2686
+3748	1994.4247	155	1.2785	0.6733	0.9101	1.0820	8.2090	14.6950	8.2065	14.2674
+3749	1994.4274	156	1.2784	0.6733	0.9101	1.0820	8.2090	14.6950	8.2102	14.2664
+3750	1994.4301	157	1.2784	0.6733	0.9101	1.0820	8.2090	14.6950	8.2137	14.2655
+3751	1994.4329	158	1.2784	0.6733	0.9101	1.0820	8.2090	14.6950	8.2170	14.2648
+3752	1994.4356	159	1.2784	0.6733	0.9101	1.0820	8.2090	14.6950	8.2200	14.2642
+3753	1994.4384	160	1.2783	0.6733	0.9101	1.0820	8.2090	14.6950	8.2227	14.2637
+3754	1994.4411	161	1.2783	0.6733	0.9101	1.0820	8.2090	14.6950	8.2252	14.2634
+3755	1994.4438	162	1.2783	0.6733	0.9101	1.0820	8.2090	14.6950	8.2274	14.2632
+3756	1994.4466	163	1.2783	0.6732	0.9101	1.0820	8.2090	14.6950	8.2293	14.2632
+3757	1994.4493	164	1.2782	0.6732	0.9101	1.0820	8.2090	14.6950	8.2309	14.2633
+3758	1994.4521	165	1.2782	0.6732	0.9101	1.0820	8.2090	14.6950	8.2322	14.2635
+3759	1994.4548	166	1.2782	0.6732	0.9101	1.0820	8.2090	14.6950	8.2333	14.2639
+3760	1994.4575	167	1.2782	0.6732	0.9101	1.0820	8.2090	14.6950	8.2340	14.2644
+3761	1994.4603	168	1.2781	0.6732	0.9101	1.0820	8.2090	14.6950	8.2344	14.2650
+3762	1994.4630	169	1.2781	0.6732	0.9101	1.0820	8.2090	14.6950	8.2346	14.2658
+3763	1994.4658	170	1.2781	0.6732	0.9101	1.0820	8.2090	14.6950	8.2345	14.2667
+3764	1994.4685	171	1.2780	0.6731	0.9101	1.0820	8.2090	14.6950	8.2340	14.2677
+3765	1994.4712	172	1.2780	0.6731	0.9100	1.0820	8.2090	14.6950	8.2333	14.2688
+3766	1994.4740	173	1.2780	0.6731	0.9100	1.0820	8.2090	14.6950	8.2322	14.2701
+3767	1994.4767	174	1.2780	0.6731	0.9100	1.0820	8.2090	14.6950	8.2309	14.2715
+3768	1994.4795	175	1.2779	0.6731	0.9100	1.0820	8.2090	14.6950	8.2293	14.2730
+3769	1994.4822	176	1.2779	0.6731	0.9100	1.0820	8.2090	14.6950	8.2274	14.2747
+3770	1994.4849	177	1.2779	0.6731	0.9100	1.0820	8.2090	14.6950	8.2252	14.2764
+3771	1994.4877	178	1.2779	0.6731	0.9100	1.0820	8.2090	14.6950	8.2227	14.2783
+3772	1994.4904	179	1.2778	0.6730	0.9100	1.0820	8.2090	14.6950	8.2200	14.2803
+3773	1994.4932	180	1.2778	0.6730	0.9100	1.0820	8.2090	14.6950	8.2170	14.2824
+3774	1994.4959	181	1.2778	0.6730	0.9100	1.0820	8.2090	14.6950	8.2137	14.2846
+3775	1994.4986	182	1.2778	0.6730	0.9100	1.0820	8.2090	14.6950	8.2102	14.2870
+3776	1994.5014	183	1.2777	0.6730	0.9100	1.0820	8.2090	14.6950	8.2064	14.2894
+3777	1994.5041	184	1.2777	0.6730	0.9100	1.0820	8.2090	14.6950	8.2024	14.2919
+3778	1994.5068	185	1.2777	0.6730	0.9100	1.0820	8.2090	14.6950	8.1981	14.2945
+3779	1994.5096	186	1.2777	0.6730	0.9100	1.0820	8.2090	14.6950	8.1936	14.2972
+3780	1994.5123	187	1.2776	0.6730	0.9100	1.0820	8.2090	14.6950	8.1889	14.3000
+3781	1994.5151	188	1.2776	0.6729	0.9100	1.0820	8.2090	14.6950	8.1840	14.3029
+3782	1994.5178	189	1.2776	0.6729	0.9100	1.0820	8.2090	14.6950	8.1789	14.3059
+3783	1994.5205	190	1.2775	0.6729	0.9100	1.0820	8.2090	14.6950	8.1736	14.3090
+3784	1994.5233	191	1.2775	0.6729	0.9100	1.0820	8.2090	14.6950	8.1682	14.3121
+3785	1994.5260	192	1.2775	0.6729	0.9100	1.0820	8.2090	14.6950	8.1626	14.3154
+3786	1994.5288	193	1.2775	0.6729	0.9100	1.0820	8.2090	14.6950	8.1568	14.3187
+3787	1994.5315	194	1.2774	0.6729	0.9099	1.0820	8.2090	14.6950	8.1508	14.3220
+3788	1994.5342	195	1.2774	0.6729	0.9099	1.0820	8.2090	14.6950	8.1448	14.3255
+3789	1994.5370	196	1.2774	0.6728	0.9099	1.0820	8.2090	14.6950	8.1386	14.3290
+3790	1994.5397	197	1.2774	0.6728	0.9099	1.0820	8.2090	14.6950	8.1323	14.3325
+3791	1994.5425	198	1.2773	0.6728	0.9099	1.0820	8.2090	14.6950	8.1259	14.3361
+3792	1994.5452	199	1.2773	0.6728	0.9099	1.0820	8.2090	14.6950	8.1194	14.3398
+3793	1994.5479	200	1.2773	0.6728	0.9099	1.0820	8.2090	14.6950	8.1129	14.3435
+3794	1994.5507	201	1.2773	0.6728	0.9099	1.0820	8.2090	14.6950	8.1063	14.3473
+3795	1994.5534	202	1.2772	0.6728	0.9099	1.0820	8.2090	14.6950	8.0996	14.3511
+3796	1994.5562	203	1.2772	0.6728	0.9099	1.0820	8.2090	14.6950	8.0929	14.3549
+3797	1994.5589	204	1.2772	0.6727	0.9099	1.0820	8.2090	14.6950	8.0862	14.3588
+3798	1994.5616	205	1.2772	0.6727	0.9099	1.0820	8.2090	14.6950	8.0795	14.3627
+3799	1994.5644	206	1.2771	0.6727	0.9099	1.0820	8.2090	14.6950	8.0728	14.3666
+3800	1994.5671	207	1.2771	0.6727	0.9099	1.0820	8.2090	14.6950	8.0660	14.3705
+3801	1994.5699	208	1.2771	0.6727	0.9099	1.0820	8.2090	14.6950	8.0593	14.3745
+3802	1994.5726	209	1.2771	0.6727	0.9099	1.0820	8.2090	14.6950	8.0527	14.3785
+3803	1994.5753	210	1.2770	0.6727	0.9099	1.0820	8.2090	14.6950	8.0461	14.3825
+3804	1994.5781	211	1.2770	0.6727	0.9099	1.0820	8.2090	14.6950	8.0395	14.3864
+3805	1994.5808	212	1.2770	0.6726	0.9099	1.0820	8.2090	14.6950	8.0330	14.3904
+3806	1994.5836	213	1.2769	0.6726	0.9099	1.0820	8.2090	14.6950	8.0266	14.3944
+3807	1994.5863	214	1.2769	0.6726	0.9099	1.0820	8.2090	14.6950	8.0203	14.3984
+3808	1994.5890	215	1.2769	0.6726	0.9098	1.0820	8.2090	14.6950	8.0141	14.4024
+3809	1994.5918	216	1.2769	0.6726	0.9098	1.0820	8.2090	14.6950	8.0080	14.4063
+3810	1994.5945	217	1.2768	0.6726	0.9098	1.0820	8.2090	14.6950	8.0021	14.4103
+3811	1994.5973	218	1.2768	0.6726	0.9098	1.0820	8.2090	14.6950	7.9962	14.4142
+3812	1994.6000	219	1.2768	0.6726	0.9098	1.0820	8.2090	14.6950	7.9905	14.4181
+3813	1994.6027	220	1.2768	0.6726	0.9098	1.0820	8.2090	14.6950	7.9850	14.4220
+3814	1994.6055	221	1.2767	0.6725	0.9098	1.0820	8.2090	14.6950	7.9796	14.4258
+3815	1994.6082	222	1.2767	0.6725	0.9098	1.0820	8.2090	14.6950	7.9744	14.4296
+3816	1994.6110	223	1.2767	0.6725	0.9098	1.0820	8.2090	14.6950	7.9694	14.4333
+3817	1994.6137	224	1.2767	0.6725	0.9098	1.0820	8.2090	14.6950	7.9645	14.4370
+3818	1994.6164	225	1.2766	0.6725	0.9098	1.0820	8.2090	14.6950	7.9599	14.4407
+3819	1994.6192	226	1.2766	0.6725	0.9098	1.0820	8.2090	14.6950	7.9554	14.4443
+3820	1994.6219	227	1.2766	0.6725	0.9098	1.0820	8.2090	14.6950	7.9512	14.4478
+3821	1994.6247	228	1.2766	0.6725	0.9098	1.0820	8.2090	14.6950	7.9472	14.4513
+3822	1994.6274	229	1.2765	0.6724	0.9098	1.0820	8.2090	14.6950	7.9434	14.4547
+3823	1994.6301	230	1.2765	0.6724	0.9098	1.0820	8.2090	14.6950	7.9398	14.4581
+3824	1994.6329	231	1.2765	0.6724	0.9098	1.0820	8.2090	14.6950	7.9365	14.4614
+3825	1994.6356	232	1.2765	0.6724	0.9098	1.0820	8.2090	14.6950	7.9334	14.4646
+3826	1994.6384	233	1.2764	0.6724	0.9098	1.0820	8.2090	14.6950	7.9305	14.4677
+3827	1994.6411	234	1.2764	0.6724	0.9098	1.0820	8.2090	14.6950	7.9279	14.4708
+3828	1994.6438	235	1.2764	0.6724	0.9098	1.0820	8.2090	14.6950	7.9255	14.4737
+3829	1994.6466	236	1.2763	0.6724	0.9098	1.0820	8.2090	14.6950	7.9234	14.4766
+3830	1994.6493	237	1.2763	0.6723	0.9097	1.0820	8.2090	14.6950	7.9215	14.4794
+3831	1994.6521	238	1.2763	0.6723	0.9097	1.0820	8.2090	14.6950	7.9199	14.4821
+3832	1994.6548	239	1.2763	0.6723	0.9097	1.0820	8.2090	14.6950	7.9186	14.4847
+3833	1994.6575	240	1.2762	0.6723	0.9097	1.0820	8.2090	14.6950	7.9175	14.4872
+3834	1994.6603	241	1.2762	0.6723	0.9097	1.0820	8.2090	14.6950	7.9167	14.4896
+3835	1994.6630	242	1.2762	0.6723	0.9097	1.0820	8.2090	14.6950	7.9162	14.4919
+3836	1994.6658	243	1.2762	0.6723	0.9097	1.0820	8.2090	14.6950	7.9159	14.4941
+3837	1994.6685	244	1.2761	0.6723	0.9097	1.0820	8.2090	14.6950	7.9159	14.4962
+3838	1994.6712	245	1.2761	0.6723	0.9097	1.0820	8.2090	14.6950	7.9161	14.4981
+3839	1994.6740	246	1.2761	0.6722	0.9097	1.0820	8.2090	14.6950	7.9166	14.5000
+3840	1994.6767	247	1.2761	0.6722	0.9097	1.0820	8.2090	14.6950	7.9174	14.5017
+3841	1994.6795	248	1.2760	0.6722	0.9097	1.0820	8.2090	14.6950	7.9184	14.5033
+3842	1994.6822	249	1.2760	0.6722	0.9097	1.0820	8.2090	14.6950	7.9197	14.5048
+3843	1994.6849	250	1.2760	0.6722	0.9097	1.0820	8.2090	14.6950	7.9213	14.5062
+3844	1994.6877	251	1.2760	0.6722	0.9097	1.0820	8.2090	14.6950	7.9231	14.5075
+3845	1994.6904	252	1.2759	0.6722	0.9097	1.0820	8.2090	14.6950	7.9251	14.5086
+3846	1994.6932	253	1.2759	0.6722	0.9097	1.0820	8.2090	14.6950	7.9274	14.5096
+3847	1994.6959	254	1.2759	0.6721	0.9097	1.0820	8.2090	14.6950	7.9299	14.5105
+3848	1994.6986	255	1.2759	0.6721	0.9097	1.0820	8.2090	14.6950	7.9327	14.5112
+3849	1994.7014	256	1.2758	0.6721	0.9097	1.0820	8.2090	14.6950	7.9357	14.5119
+3850	1994.7041	257	1.2758	0.6721	0.9097	1.0820	8.2090	14.6950	7.9389	14.5123
+3851	1994.7068	258	1.2758	0.6721	0.9097	1.0820	8.2090	14.6950	7.9424	14.5127
+3852	1994.7096	259	1.2758	0.6721	0.9096	1.0820	8.2090	14.6950	7.9460	14.5129
+3853	1994.7123	260	1.2757	0.6721	0.9096	1.0820	8.2090	14.6950	7.9499	14.5130
+3854	1994.7151	261	1.2757	0.6721	0.9096	1.0820	8.2090	14.6950	7.9540	14.5129
+3855	1994.7178	262	1.2757	0.6720	0.9096	1.0820	8.2090	14.6950	7.9582	14.5128
+3856	1994.7205	263	1.2757	0.6720	0.9096	1.0820	8.2090	14.6950	7.9627	14.5124
+3857	1994.7233	264	1.2756	0.6720	0.9096	1.0820	8.2090	14.6950	7.9673	14.5120
+3858	1994.7260	265	1.2756	0.6720	0.9096	1.0820	8.2090	14.6950	7.9721	14.5114
+3859	1994.7288	266	1.2756	0.6720	0.9096	1.0820	8.2090	14.6950	7.9770	14.5106
+3860	1994.7315	267	1.2756	0.6720	0.9096	1.0820	8.2090	14.6950	7.9821	14.5098
+3861	1994.7342	268	1.2755	0.6720	0.9096	1.0820	8.2090	14.6950	7.9874	14.5088
+3862	1994.7370	269	1.2755	0.6720	0.9096	1.0820	8.2090	14.6950	7.9928	14.5076
+3863	1994.7397	270	1.2755	0.6720	0.9096	1.0820	8.2090	14.6950	7.9983	14.5064
+3864	1994.7425	271	1.2755	0.6719	0.9096	1.0820	8.2090	14.6950	8.0039	14.5050
+3865	1994.7452	272	1.2754	0.6719	0.9096	1.0820	8.2090	14.6950	8.0096	14.5034
+3866	1994.7479	273	1.2754	0.6719	0.9096	1.0820	8.2090	14.6950	8.0154	14.5017
+3867	1994.7507	274	1.2754	0.6719	0.9096	1.0820	8.2090	14.6950	8.0213	14.4999
+3868	1994.7534	275	1.2754	0.6719	0.9096	1.0820	8.2090	14.6950	8.0273	14.4980
+3869	1994.7562	276	1.2753	0.6719	0.9096	1.0820	8.2090	14.6950	8.0334	14.4959
+3870	1994.7589	277	1.2753	0.6719	0.9096	1.0820	8.2090	14.6950	8.0395	14.4937
+3871	1994.7616	278	1.2753	0.6719	0.9096	1.0820	8.2090	14.6950	8.0456	14.4914
+3872	1994.7644	279	1.2752	0.6718	0.9096	1.0820	8.2090	14.6950	8.0518	14.4889
+3873	1994.7671	280	1.2752	0.6718	0.9096	1.0820	8.2090	14.6950	8.0580	14.4864
+3874	1994.7699	281	1.2752	0.6718	0.9096	1.0820	8.2090	14.6950	8.0641	14.4837
+3875	1994.7726	282	1.2752	0.6718	0.9095	1.0820	8.2090	14.6950	8.0703	14.4808
+3876	1994.7753	283	1.2751	0.6718	0.9095	1.0820	8.2090	14.6950	8.0765	14.4779
+3877	1994.7781	284	1.2751	0.6718	0.9095	1.0820	8.2090	14.6950	8.0827	14.4748
+3878	1994.7808	285	1.2751	0.6718	0.9095	1.0820	8.2090	14.6950	8.0888	14.4717
+3879	1994.7836	286	1.2751	0.6718	0.9095	1.0820	8.2090	14.6950	8.0948	14.4684
+3880	1994.7863	287	1.2750	0.6718	0.9095	1.0820	8.2090	14.6950	8.1008	14.4650
+3881	1994.7890	288	1.2750	0.6717	0.9095	1.0820	8.2090	14.6950	8.1068	14.4615
+3882	1994.7918	289	1.2750	0.6717	0.9095	1.0820	8.2090	14.6950	8.1126	14.4579
+3883	1994.7945	290	1.2750	0.6717	0.9095	1.0820	8.2090	14.6950	8.1184	14.4542
+3884	1994.7973	291	1.2749	0.6717	0.9095	1.0820	8.2090	14.6950	8.1240	14.4503
+3885	1994.8000	292	1.2749	0.6717	0.9095	1.0820	8.2090	14.6950	8.1295	14.4464
+3886	1994.8027	293	1.2749	0.6717	0.9095	1.0820	8.2090	14.6950	8.1350	14.4424
+3887	1994.8055	294	1.2749	0.6717	0.9095	1.0820	8.2090	14.6950	8.1402	14.4383
+3888	1994.8082	295	1.2748	0.6717	0.9095	1.0820	8.2090	14.6950	8.1454	14.4341
+3889	1994.8110	296	1.2748	0.6716	0.9095	1.0820	8.2090	14.6950	8.1503	14.4298
+3890	1994.8137	297	1.2748	0.6716	0.9095	1.0820	8.2090	14.6950	8.1551	14.4255
+3891	1994.8164	298	1.2748	0.6716	0.9095	1.0820	8.2090	14.6950	8.1598	14.4210
+3892	1994.8192	299	1.2747	0.6716	0.9095	1.0820	8.2090	14.6950	8.1642	14.4165
+3893	1994.8219	300	1.2747	0.6716	0.9095	1.0820	8.2090	14.6950	8.1685	14.4119
+3894	1994.8247	301	1.2747	0.6716	0.9095	1.0820	8.2090	14.6950	8.1725	14.4072
+3895	1994.8274	302	1.2747	0.6716	0.9095	1.0820	8.2090	14.6950	8.1764	14.4025
+3896	1994.8301	303	1.2746	0.6716	0.9095	1.0820	8.2090	14.6950	8.1800	14.3976
+3897	1994.8329	304	1.2746	0.6716	0.9094	1.0820	8.2090	14.6950	8.1834	14.3928
+3898	1994.8356	305	1.2746	0.6715	0.9094	1.0820	8.2090	14.6950	8.1866	14.3878
+3899	1994.8384	306	1.2746	0.6715	0.9094	1.0820	8.2090	14.6950	8.1895	14.3829
+3900	1994.8411	307	1.2745	0.6715	0.9094	1.0820	8.2090	14.6950	8.1922	14.3778
+3901	1994.8438	308	1.2745	0.6715	0.9094	1.0820	8.2090	14.6950	8.1946	14.3727
+3902	1994.8466	309	1.2745	0.6715	0.9094	1.0820	8.2090	14.6950	8.1968	14.3676
+3903	1994.8493	310	1.2745	0.6715	0.9094	1.0820	8.2090	14.6950	8.1988	14.3624
+3904	1994.8521	311	1.2744	0.6715	0.9094	1.0820	8.2090	14.6950	8.2005	14.3572
+3905	1994.8548	312	1.2744	0.6715	0.9094	1.0820	8.2090	14.6950	8.2019	14.3520
+3906	1994.8575	313	1.2744	0.6714	0.9094	1.0820	8.2090	14.6950	8.2030	14.3467
+3907	1994.8603	314	1.2744	0.6714	0.9094	1.0820	8.2090	14.6950	8.2039	14.3414
+3908	1994.8630	315	1.2743	0.6714	0.9094	1.0820	8.2090	14.6950	8.2045	14.3361
+3909	1994.8658	316	1.2743	0.6714	0.9094	1.0820	8.2090	14.6950	8.2049	14.3307
+3910	1994.8685	317	1.2743	0.6714	0.9094	1.0820	8.2090	14.6950	8.2049	14.3254
+3911	1994.8712	318	1.2743	0.6714	0.9094	1.0820	8.2090	14.6950	8.2047	14.3200
+3912	1994.8740	319	1.2742	0.6714	0.9094	1.0820	8.2090	14.6950	8.2042	14.3146
+3913	1994.8767	320	1.2742	0.6714	0.9094	1.0820	8.2090	14.6950	8.2035	14.3092
+3914	1994.8795	321	1.2742	0.6714	0.9094	1.0820	8.2090	14.6950	8.2025	14.3039
+3915	1994.8822	322	1.2742	0.6713	0.9094	1.0820	8.2090	14.6950	8.2012	14.2985
+3916	1994.8849	323	1.2741	0.6713	0.9094	1.0820	8.2090	14.6950	8.1996	14.2931
+3917	1994.8877	324	1.2741	0.6713	0.9094	1.0820	8.2090	14.6950	8.1978	14.2877
+3918	1994.8904	325	1.2741	0.6713	0.9094	1.0820	8.2090	14.6950	8.1957	14.2824
+3919	1994.8932	326	1.2741	0.6713	0.9094	1.0820	8.2090	14.6950	8.1933	14.2770
+3920	1994.8959	327	1.2740	0.6713	0.9094	1.0820	8.2090	14.6950	8.1907	14.2717
+3921	1994.8986	328	1.2740	0.6713	0.9093	1.0820	8.2090	14.6950	8.1879	14.2664
+3922	1994.9014	329	1.2740	0.6713	0.9093	1.0820	8.2090	14.6950	8.1848	14.2611
+3923	1994.9041	330	1.2740	0.6712	0.9093	1.0820	8.2090	14.6950	8.1815	14.2559
+3924	1994.9068	331	1.2739	0.6712	0.9093	1.0820	8.2090	14.6950	8.1780	14.2507
+3925	1994.9096	332	1.2739	0.6712	0.9093	1.0820	8.2090	14.6950	8.1742	14.2455
+3926	1994.9123	333	1.2739	0.6712	0.9093	1.0820	8.2090	14.6950	8.1702	14.2404
+3927	1994.9151	334	1.2739	0.6712	0.9093	1.0820	8.2090	14.6950	8.1660	14.2353
+3928	1994.9178	335	1.2738	0.6712	0.9093	1.0820	8.2090	14.6950	8.1616	14.2303
+3929	1994.9205	336	1.2738	0.6712	0.9093	1.0820	8.2090	14.6950	8.1570	14.2253
+3930	1994.9233	337	1.2738	0.6712	0.9093	1.0820	8.2090	14.6950	8.1522	14.2203
+3931	1994.9260	338	1.2738	0.6712	0.9093	1.0820	8.2090	14.6950	8.1473	14.2155
+3932	1994.9288	339	1.2737	0.6711	0.9093	1.0820	8.2090	14.6950	8.1421	14.2106
+3933	1994.9315	340	1.2737	0.6711	0.9093	1.0820	8.2090	14.6950	8.1368	14.2059
+3934	1994.9342	341	1.2737	0.6711	0.9093	1.0820	8.2090	14.6950	8.1314	14.2012
+3935	1994.9370	342	1.2737	0.6711	0.9093	1.0820	8.2090	14.6950	8.1258	14.1965
+3936	1994.9397	343	1.2736	0.6711	0.9093	1.0820	8.2090	14.6950	8.1201	14.1920
+3937	1994.9425	344	1.2736	0.6711	0.9093	1.0820	8.2090	14.6950	8.1143	14.1875
+3938	1994.9452	345	1.2736	0.6711	0.9093	1.0820	8.2090	14.6950	8.1084	14.1831
+3939	1994.9479	346	1.2736	0.6711	0.9093	1.0820	8.2090	14.6950	8.1024	14.1788
+3940	1994.9507	347	1.2735	0.6710	0.9093	1.0820	8.2090	14.6950	8.0963	14.1745
+3941	1994.9534	348	1.2735	0.6710	0.9093	1.0820	8.2090	14.6950	8.0901	14.1703
+3942	1994.9562	349	1.2735	0.6710	0.9093	1.0820	8.2090	14.6950	8.0838	14.1663
+3943	1994.9589	350	1.2735	0.6710	0.9093	1.0820	8.2090	14.6950	8.0775	14.1623
+3944	1994.9616	351	1.2734	0.6710	0.9092	1.0820	8.2090	14.6950	8.0711	14.1584
+3945	1994.9644	352	1.2734	0.6710	0.9092	1.0820	8.2090	14.6950	8.0647	14.1546
+3946	1994.9671	353	1.2734	0.6710	0.9092	1.0820	8.2090	14.6950	8.0583	14.1508
+3947	1994.9699	354	1.2734	0.6710	0.9092	1.0820	8.2090	14.6950	8.0519	14.1472
+3948	1994.9726	355	1.2733	0.6710	0.9092	1.0820	8.2090	14.6950	8.0455	14.1437
+3949	1994.9753	356	1.2733	0.6709	0.9092	1.0820	8.2090	14.6950	8.0390	14.1403
+3950	1994.9781	357	1.2733	0.6709	0.9092	1.0820	8.2090	14.6950	8.0326	14.1370
+3951	1994.9808	358	1.2733	0.6709	0.9092	1.0820	8.2090	14.6950	8.0263	14.1338
+3952	1994.9836	359	1.2732	0.6709	0.9092	1.0820	8.2090	14.6950	8.0199	14.1307
+3953	1994.9863	360	1.2732	0.6709	0.9092	1.0820	8.2090	14.6950	8.0136	14.1277
+3954	1994.9890	361	1.2732	0.6709	0.9092	1.0820	8.2090	14.6950	8.0074	14.1248
+3955	1994.9918	362	1.2732	0.6709	0.9092	1.0820	8.2090	14.6950	8.0013	14.1220
+3956	1994.9945	363	1.2731	0.6709	0.9092	1.0820	8.2090	14.6950	7.9952	14.1193
+3957	1994.9973	364	1.2731	0.6709	0.9092	1.0820	8.2090	14.6950	7.9892	14.1168
+3958	1994.9999	365	1.2731	0.6708	0.9092	1.0820	8.2090	14.6950	7.9833	14.1143
+3959	1995.0027	1	1.2731	0.6708	0.9092	1.0820	8.2090	14.6950	7.9776	14.1120
+3960	1995.0055	2	1.2731	0.6708	0.9092	1.0820	8.2090	14.6950	7.9719	14.1098
+3961	1995.0082	3	1.2730	0.6708	0.9092	1.0820	8.2090	14.6950	7.9664	14.1077
+3962	1995.0110	4	1.2730	0.6708	0.9092	1.0820	8.2090	14.6950	7.9610	14.1057
+3963	1995.0137	5	1.2730	0.6708	0.9092	1.0820	8.2090	14.6950	7.9557	14.1039
+3964	1995.0164	6	1.2730	0.6708	0.9092	1.0820	8.2090	14.6950	7.9506	14.1021
+3965	1995.0192	7	1.2729	0.6708	0.9092	1.0820	8.2090	14.6950	7.9457	14.1005
+3966	1995.0219	8	1.2729	0.6707	0.9092	1.0820	8.2090	14.6950	7.9409	14.0990
+3967	1995.0247	9	1.2729	0.6707	0.9092	1.0820	8.2090	14.6950	7.9363	14.0976
+3968	1995.0274	10	1.2729	0.6707	0.9091	1.0820	8.2090	14.6950	7.9319	14.0964
+3969	1995.0301	11	1.2728	0.6707	0.9091	1.0820	8.2090	14.6950	7.9276	14.0952
+3970	1995.0329	12	1.2728	0.6707	0.9091	1.0820	8.2090	14.6950	7.9236	14.0942
+3971	1995.0356	13	1.2728	0.6707	0.9091	1.0820	8.2090	14.6950	7.9197	14.0933
+3972	1995.0384	14	1.2728	0.6707	0.9091	1.0820	8.2090	14.6950	7.9161	14.0926
+3973	1995.0411	15	1.2727	0.6707	0.9091	1.0820	8.2090	14.6950	7.9126	14.0919
+3974	1995.0438	16	1.2727	0.6707	0.9091	1.0820	8.2090	14.6950	7.9094	14.0914
+3975	1995.0466	17	1.2727	0.6706	0.9091	1.0820	8.2090	14.6950	7.9064	14.0910
+3976	1995.0493	18	1.2727	0.6706	0.9091	1.0820	8.2090	14.6950	7.9036	14.0907
+3977	1995.0521	19	1.2726	0.6706	0.9091	1.0820	8.2090	14.6950	7.9011	14.0905
+3978	1995.0548	20	1.2726	0.6706	0.9091	1.0820	8.2090	14.6950	7.8987	14.0905
+3979	1995.0575	21	1.2726	0.6706	0.9091	1.0820	8.2090	14.6950	7.8966	14.0905
+3980	1995.0603	22	1.2726	0.6706	0.9091	1.0820	8.2090	14.6950	7.8948	14.0907
+3981	1995.0630	23	1.2725	0.6706	0.9091	1.0820	8.2090	14.6950	7.8931	14.0910
+3982	1995.0658	24	1.2725	0.6706	0.9091	1.0820	8.2090	14.6950	7.8917	14.0915
+3983	1995.0685	25	1.2725	0.6706	0.9091	1.0820	8.2090	14.6950	7.8906	14.0920
+3984	1995.0712	26	1.2725	0.6705	0.9091	1.0820	8.2090	14.6950	7.8897	14.0926
+3985	1995.0740	27	1.2724	0.6705	0.9091	1.0820	8.2090	14.6950	7.8890	14.0934
+3986	1995.0767	28	1.2724	0.6705	0.9091	1.0820	8.2090	14.6950	7.8886	14.0943
+3987	1995.0795	29	1.2724	0.6705	0.9091	1.0820	8.2090	14.6950	7.8884	14.0953
+3988	1995.0822	30	1.2724	0.6705	0.9091	1.0820	8.2090	14.6950	7.8885	14.0964
+3989	1995.0849	31	1.2723	0.6705	0.9091	1.0820	8.2090	14.6950	7.8888	14.0976
+3990	1995.0877	32	1.2723	0.6705	0.9091	1.0820	8.2090	14.6950	7.8893	14.0989
+3991	1995.0904	33	1.2723	0.6705	0.9091	1.0820	8.2090	14.6950	7.8901	14.1003
+3992	1995.0932	34	1.2723	0.6704	0.9090	1.0820	8.2090	14.6950	7.8911	14.1018
+3993	1995.0959	35	1.2722	0.6704	0.9090	1.0820	8.2090	14.6950	7.8924	14.1034
+3994	1995.0986	36	1.2722	0.6704	0.9090	1.0820	8.2090	14.6950	7.8939	14.1051
+3995	1995.1014	37	1.2722	0.6704	0.9090	1.0820	8.2090	14.6950	7.8956	14.1070
+3996	1995.1041	38	1.2722	0.6704	0.9090	1.0820	8.2090	14.6950	7.8976	14.1089
+3997	1995.1068	39	1.2721	0.6704	0.9090	1.0820	8.2090	14.6950	7.8997	14.1109
+3998	1995.1096	40	1.2721	0.6704	0.9090	1.0820	8.2090	14.6950	7.9021	14.1130
+3999	1995.1123	41	1.2721	0.6704	0.9090	1.0820	8.2090	14.6950	7.9048	14.1152
+4000	1995.1151	42	1.2721	0.6704	0.9090	1.0820	8.2090	14.6950	7.9076	14.1174
+4001	1995.1178	43	1.2721	0.6703	0.9090	1.0820	8.2090	14.6950	7.9106	14.1198
+4002	1995.1205	44	1.2720	0.6703	0.9090	1.0820	8.2090	14.6950	7.9139	14.1222
+4003	1995.1233	45	1.2720	0.6703	0.9090	1.0820	8.2090	14.6950	7.9173	14.1248
+4004	1995.1260	46	1.2720	0.6703	0.9090	1.0820	8.2090	14.6950	7.9209	14.1274
+4005	1995.1288	47	1.2720	0.6703	0.9090	1.0820	8.2090	14.6950	7.9248	14.1301
+4006	1995.1315	48	1.2719	0.6703	0.9090	1.0820	8.2090	14.6950	7.9288	14.1328
+4007	1995.1342	49	1.2719	0.6703	0.9090	1.0820	8.2090	14.6950	7.9329	14.1356
+4008	1995.1370	50	1.2719	0.6703	0.9090	1.0820	8.2090	14.6950	7.9373	14.1385
+4009	1995.1397	51	1.2719	0.6703	0.9090	1.0820	8.2090	14.6950	7.9418	14.1415
+4010	1995.1425	52	1.2718	0.6702	0.9090	1.0820	8.2090	14.6950	7.9464	14.1445
+4011	1995.1452	53	1.2718	0.6702	0.9090	1.0820	8.2090	14.6950	7.9512	14.1476
+4012	1995.1479	54	1.2718	0.6702	0.9090	1.0820	8.2090	14.6950	7.9561	14.1507
+4013	1995.1507	55	1.2718	0.6702	0.9090	1.0820	8.2090	14.6950	7.9612	14.1539
+4014	1995.1534	56	1.2717	0.6702	0.9090	1.0820	8.2090	14.6950	7.9664	14.1572
+4015	1995.1562	57	1.2717	0.6702	0.9090	1.0820	8.2090	14.6950	7.9717	14.1604
+4016	1995.1589	58	1.2717	0.6702	0.9090	1.0820	8.2090	14.6950	7.9771	14.1638
+4017	1995.1616	59	1.2717	0.6702	0.9089	1.0820	8.2090	14.6950	7.9826	14.1672
+4018	1995.1644	60	1.2716	0.6702	0.9089	1.0820	8.2090	14.6950	7.9881	14.1706
+4019	1995.1671	61	1.2716	0.6701	0.9089	1.0820	8.2090	14.6950	8.2090	14.6950
+4020	1995.1699	62	1.2716	0.6701	0.9089	1.0820	8.2090	14.6950	8.2040	14.6949
+4021	1995.1726	63	1.2716	0.6701	0.9089	1.0820	8.2090	14.6950	8.1989	14.6947
+4022	1995.1753	64	1.2715	0.6701	0.9089	1.0820	8.2090	14.6950	8.1936	14.6943
+4023	1995.1781	65	1.2715	0.6701	0.9089	1.0820	8.2090	14.6950	8.1882	14.6938
+4024	1995.1808	66	1.2715	0.6701	0.9089	1.0820	8.2090	14.6950	8.1826	14.6932
+4025	1995.1836	67	1.2715	0.6701	0.9089	1.0820	8.2090	14.6950	8.1769	14.6925
+4026	1995.1863	68	1.2715	0.6701	0.9089	1.0820	8.2090	14.6950	8.1711	14.6916
+4027	1995.1890	69	1.2714	0.6701	0.9089	1.0820	8.2090	14.6950	8.1652	14.6906
+4028	1995.1918	70	1.2714	0.6700	0.9089	1.0820	8.2090	14.6950	8.1592	14.6895
+4029	1995.1945	71	1.2714	0.6700	0.9089	1.0820	8.2090	14.6950	8.1531	14.6882
+4030	1995.1973	72	1.2714	0.6700	0.9089	1.0820	8.2090	14.6950	8.1470	14.6869
+4031	1995.2000	73	1.2713	0.6700	0.9089	1.0820	8.2090	14.6950	8.1408	14.6853
+4032	1995.2027	74	1.2713	0.6700	0.9089	1.0820	8.2090	14.6950	8.1345	14.6837
+4033	1995.2055	75	1.2713	0.6700	0.9089	1.0820	8.2090	14.6950	8.1282	14.6820
+4034	1995.2082	76	1.2713	0.6700	0.9089	1.0820	8.2090	14.6950	8.1219	14.6801
+4035	1995.2110	77	1.2712	0.6700	0.9089	1.0820	8.2090	14.6950	8.1155	14.6781
+4036	1995.2137	78	1.2712	0.6699	0.9089	1.0820	8.2090	14.6950	8.1091	14.6760
+4037	1995.2164	79	1.2712	0.6699	0.9089	1.0820	8.2090	14.6950	8.1028	14.6738
+4038	1995.2192	80	1.2712	0.6699	0.9089	1.0820	8.2090	14.6950	8.0964	14.6714
+4039	1995.2219	81	1.2711	0.6699	0.9089	1.0820	8.2090	14.6950	8.0900	14.6689
+4040	1995.2247	82	1.2711	0.6699	0.9089	1.0820	8.2090	14.6950	8.0837	14.6663
+4041	1995.2274	83	1.2711	0.6699	0.9089	1.0820	8.2090	14.6950	8.0774	14.6636
+4042	1995.2301	84	1.2711	0.6699	0.9088	1.0820	8.2090	14.6950	8.0712	14.6608
+4043	1995.2329	85	1.2710	0.6699	0.9088	1.0820	8.2090	14.6950	8.0650	14.6579
+4044	1995.2356	86	1.2710	0.6699	0.9088	1.0820	8.2090	14.6950	8.0589	14.6549
+4045	1995.2384	87	1.2710	0.6698	0.9088	1.0820	8.2090	14.6950	8.0529	14.6517
+4046	1995.2411	88	1.2710	0.6698	0.9088	1.0820	8.2090	14.6950	8.0469	14.6485
+4047	1995.2438	89	1.2710	0.6698	0.9088	1.0820	8.2090	14.6950	8.0411	14.6451
+4048	1995.2466	90	1.2709	0.6698	0.9088	1.0820	8.2090	14.6950	8.0353	14.6417
+4049	1995.2493	91	1.2709	0.6698	0.9088	1.0820	8.2090	14.6950	8.0297	14.6381
+4050	1995.2521	92	1.2709	0.6698	0.9088	1.0820	8.2090	14.6950	8.0242	14.6345
+4051	1995.2548	93	1.2709	0.6698	0.9088	1.0820	8.2090	14.6950	8.0188	14.6307
+4052	1995.2575	94	1.2708	0.6698	0.9088	1.0820	8.2090	14.6950	8.0135	14.6269
+4053	1995.2603	95	1.2708	0.6698	0.9088	1.0820	8.2090	14.6950	8.0084	14.6230
+4054	1995.2630	96	1.2708	0.6697	0.9088	1.0820	8.2090	14.6950	8.0034	14.6190
+4055	1995.2658	97	1.2708	0.6697	0.9088	1.0820	8.2090	14.6950	7.9986	14.6149
+4056	1995.2685	98	1.2707	0.6697	0.9088	1.0820	8.2090	14.6950	7.9940	14.6107
+4057	1995.2712	99	1.2707	0.6697	0.9088	1.0820	8.2090	14.6950	7.9895	14.6065
+4058	1995.2740	100	1.2707	0.6697	0.9088	1.0820	8.2090	14.6950	7.9852	14.6021
+4059	1995.2767	101	1.2707	0.6697	0.9088	1.0820	8.2090	14.6950	7.9811	14.5977
+4060	1995.2795	102	1.2706	0.6697	0.9088	1.0820	8.2090	14.6950	7.9772	14.5932
+4061	1995.2822	103	1.2706	0.6697	0.9088	1.0820	8.2090	14.6950	7.9735	14.5887
+4062	1995.2849	104	1.2706	0.6697	0.9088	1.0820	8.2090	14.6950	7.9699	14.5841
+4063	1995.2877	105	1.2706	0.6696	0.9088	1.0820	8.2090	14.6950	7.9666	14.5794
+4064	1995.2904	106	1.2705	0.6696	0.9088	1.0820	8.2090	14.6950	7.9635	14.5747
+4065	1995.2932	107	1.2705	0.6696	0.9088	1.0820	8.2090	14.6950	7.9606	14.5699
+4066	1995.2959	108	1.2705	0.6696	0.9088	1.0820	8.2090	14.6950	7.9579	14.5650
+4067	1995.2986	109	1.2705	0.6696	0.9088	1.0820	8.2090	14.6950	7.9555	14.5601
+4068	1995.3014	110	1.2705	0.6696	0.9087	1.0820	8.2090	14.6950	7.9532	14.5552
+4069	1995.3041	111	1.2704	0.6696	0.9087	1.0820	8.2090	14.6950	7.9512	14.5502
+4070	1995.3068	112	1.2704	0.6696	0.9087	1.0820	8.2090	14.6950	7.9494	14.5452
+4071	1995.3096	113	1.2704	0.6696	0.9087	1.0820	8.2090	14.6950	7.9479	14.5401
+4072	1995.3123	114	1.2704	0.6695	0.9087	1.0820	8.2090	14.6950	7.9465	14.5350
+4073	1995.3151	115	1.2703	0.6695	0.9087	1.0820	8.2090	14.6950	7.9454	14.5299
+4074	1995.3178	116	1.2703	0.6695	0.9087	1.0820	8.2090	14.6950	7.9446	14.5247
+4075	1995.3205	117	1.2703	0.6695	0.9087	1.0820	8.2090	14.6950	7.9440	14.5196
+4076	1995.3233	118	1.2703	0.6695	0.9087	1.0820	8.2090	14.6950	7.9436	14.5144
+4077	1995.3260	119	1.2702	0.6695	0.9087	1.0820	8.2090	14.6950	7.9434	14.5091
+4078	1995.3288	120	1.2702	0.6695	0.9087	1.0820	8.2090	14.6950	7.9435	14.5039
+4079	1995.3315	121	1.2702	0.6695	0.9087	1.0820	8.2090	14.6950	7.9438	14.4986
+4080	1995.3342	122	1.2702	0.6695	0.9087	1.0820	8.2090	14.6950	7.9444	14.4934
+4081	1995.3370	123	1.2701	0.6694	0.9087	1.0820	8.2090	14.6950	7.9452	14.4881
+4082	1995.3397	124	1.2701	0.6694	0.9087	1.0820	8.2090	14.6950	7.9462	14.4829
+4083	1995.3425	125	1.2701	0.6694	0.9087	1.0820	8.2090	14.6950	7.9474	14.4776
+4084	1995.3452	126	1.2701	0.6694	0.9087	1.0820	8.2090	14.6950	7.9489	14.4723
+4085	1995.3479	127	1.2701	0.6694	0.9087	1.0820	8.2090	14.6950	7.9506	14.4671
+4086	1995.3507	128	1.2700	0.6694	0.9087	1.0820	8.2090	14.6950	7.9525	14.4618
+4087	1995.3534	129	1.2700	0.6694	0.9087	1.0820	8.2090	14.6950	7.9547	14.4566
+4088	1995.3562	130	1.2700	0.6694	0.9087	1.0820	8.2090	14.6950	7.9570	14.4514
+4089	1995.3589	131	1.2700	0.6694	0.9087	1.0820	8.2090	14.6950	7.9596	14.4462
+4090	1995.3616	132	1.2699	0.6693	0.9087	1.0820	8.2090	14.6950	7.9624	14.4410
+4091	1995.3644	133	1.2699	0.6693	0.9087	1.0820	8.2090	14.6950	7.9653	14.4359
+4092	1995.3671	134	1.2699	0.6693	0.9087	1.0820	8.2090	14.6950	7.9685	14.4308
+4093	1995.3699	135	1.2699	0.6693	0.9087	1.0820	8.2090	14.6950	7.9719	14.4257
+4094	1995.3726	136	1.2698	0.6693	0.9086	1.0820	8.2090	14.6950	7.9754	14.4206
+4095	1995.3753	137	1.2698	0.6693	0.9086	1.0820	8.2090	14.6950	7.9792	14.4156
+4096	1995.3781	138	1.2698	0.6693	0.9086	1.0820	8.2090	14.6950	7.9831	14.4107
+4097	1995.3808	139	1.2698	0.6693	0.9086	1.0820	8.2090	14.6950	7.9871	14.4057
+4098	1995.3836	140	1.2698	0.6693	0.9086	1.0820	8.2090	14.6950	7.9914	14.4009
+4099	1995.3863	141	1.2697	0.6692	0.9086	1.0820	8.2090	14.6950	7.9958	14.3960
+4100	1995.3890	142	1.2697	0.6692	0.9086	1.0820	8.2090	14.6950	8.0003	14.3913
+4101	1995.3918	143	1.2697	0.6692	0.9086	1.0820	8.2090	14.6950	8.0050	14.3865
+4102	1995.3945	144	1.2697	0.6692	0.9086	1.0820	8.2090	14.6950	8.0099	14.3819
+4103	1995.3973	145	1.2696	0.6692	0.9086	1.0820	8.2090	14.6950	8.0148	14.3773
+4104	1995.4000	146	1.2696	0.6692	0.9086	1.0820	8.2090	14.6950	8.0199	14.3727
+4105	1995.4027	147	1.2696	0.6692	0.9086	1.0820	8.2090	14.6950	8.0251	14.3683
+4106	1995.4055	148	1.2696	0.6692	0.9086	1.0820	8.2090	14.6950	8.0304	14.3639
+4107	1995.4082	149	1.2695	0.6692	0.9086	1.0820	8.2090	14.6950	8.0358	14.3595
+4108	1995.4110	150	1.2695	0.6691	0.9086	1.0820	8.2090	14.6950	8.0413	14.3553
+4109	1995.4137	151	1.2695	0.6691	0.9086	1.0820	8.2090	14.6950	8.0468	14.3511
+4110	1995.4164	152	1.2695	0.6691	0.9086	1.0820	8.2090	14.6950	8.0525	14.3470
+4111	1995.4192	153	1.2694	0.6691	0.9086	1.0820	8.2090	14.6950	8.0582	14.3429
+4112	1995.4219	154	1.2694	0.6691	0.9086	1.0820	8.2090	14.6950	8.0639	14.3390
+4113	1995.4247	155	1.2694	0.6691	0.9086	1.0820	8.2090	14.6950	8.0697	14.3351
+4114	1995.4274	156	1.2694	0.6691	0.9086	1.0820	8.2090	14.6950	8.0755	14.3313
+4115	1995.4301	157	1.2694	0.6691	0.9086	1.0820	8.2090	14.6950	8.0814	14.3276
+4116	1995.4329	158	1.2693	0.6691	0.9086	1.0820	8.2090	14.6950	8.0872	14.3240
+4117	1995.4356	159	1.2693	0.6690	0.9086	1.0820	8.2090	14.6950	8.0931	14.3205
+4118	1995.4384	160	1.2693	0.6690	0.9086	1.0820	8.2090	14.6950	8.0990	14.3171
+4119	1995.4411	161	1.2693	0.6690	0.9086	1.0820	8.2090	14.6950	8.1048	14.3137
+4120	1995.4438	162	1.2692	0.6690	0.9085	1.0820	8.2090	14.6950	8.1107	14.3105
+4121	1995.4466	163	1.2692	0.6690	0.9085	1.0820	8.2090	14.6950	8.1164	14.3074
+4122	1995.4493	164	1.2692	0.6690	0.9085	1.0820	8.2090	14.6950	8.1222	14.3043
+4123	1995.4521	165	1.2692	0.6690	0.9085	1.0820	8.2090	14.6950	8.1279	14.3014
+4124	1995.4548	166	1.2691	0.6690	0.9085	1.0820	8.2090	14.6950	8.1335	14.2986
+4125	1995.4575	167	1.2691	0.6690	0.9085	1.0820	8.2090	14.6950	8.1391	14.2958
+4126	1995.4603	168	1.2691	0.6689	0.9085	1.0820	8.2090	14.6950	8.1446	14.2932
+4127	1995.4630	169	1.2691	0.6689	0.9085	1.0820	8.2090	14.6950	8.1500	14.2907
+4128	1995.4658	170	1.2691	0.6689	0.9085	1.0820	8.2090	14.6950	8.1553	14.2883
+4129	1995.4685	171	1.2690	0.6689	0.9085	1.0820	8.2090	14.6950	8.1605	14.2860
+4130	1995.4712	172	1.2690	0.6689	0.9085	1.0820	8.2090	14.6950	8.1656	14.2838
+4131	1995.4740	173	1.2690	0.6689	0.9085	1.0820	8.2090	14.6950	8.1706	14.2817
+4132	1995.4767	174	1.2690	0.6689	0.9085	1.0820	8.2090	14.6950	8.1754	14.2797
+4133	1995.4795	175	1.2689	0.6689	0.9085	1.0820	8.2090	14.6950	8.1801	14.2778
+4134	1995.4822	176	1.2689	0.6689	0.9085	1.0820	8.2090	14.6950	8.1846	14.2760
+4135	1995.4849	177	1.2689	0.6688	0.9085	1.0820	8.2090	14.6950	8.1890	14.2744
+4136	1995.4877	178	1.2689	0.6688	0.9085	1.0820	8.2090	14.6950	8.1932	14.2729
+4137	1995.4904	179	1.2689	0.6688	0.9085	1.0820	8.2090	14.6950	8.1973	14.2714
+4138	1995.4932	180	1.2688	0.6688	0.9085	1.0820	8.2090	14.6950	8.2012	14.2701
+4139	1995.4959	181	1.2688	0.6688	0.9085	1.0820	8.2090	14.6950	8.2048	14.2689
+4140	1995.4986	182	1.2688	0.6688	0.9085	1.0820	8.2090	14.6950	8.2083	14.2678
+4141	1995.5014	183	1.2688	0.6688	0.9085	1.0820	8.2090	14.6950	8.2116	14.2669
+4142	1995.5041	184	1.2687	0.6688	0.9085	1.0820	8.2090	14.6950	8.2147	14.2660
+4143	1995.5068	185	1.2687	0.6688	0.9085	1.0820	8.2090	14.6950	8.2176	14.2653
+4144	1995.5096	186	1.2687	0.6687	0.9085	1.0820	8.2090	14.6950	8.2203	14.2646
+4145	1995.5123	187	1.2687	0.6687	0.9085	1.0820	8.2090	14.6950	8.2228	14.2641
+4146	1995.5151	188	1.2686	0.6687	0.9085	1.0820	8.2090	14.6950	8.2250	14.2637
+4147	1995.5178	189	1.2686	0.6687	0.9084	1.0820	8.2090	14.6950	8.2270	14.2634
+4148	1995.5205	190	1.2686	0.6687	0.9084	1.0820	8.2090	14.6950	8.2288	14.2632
+4149	1995.5233	191	1.2686	0.6687	0.9084	1.0820	8.2090	14.6950	8.2303	14.2632
+4150	1995.5260	192	1.2686	0.6687	0.9084	1.0820	8.2090	14.6950	8.2316	14.2632
+4151	1995.5288	193	1.2685	0.6687	0.9084	1.0820	8.2090	14.6950	8.2327	14.2634
+4152	1995.5315	194	1.2685	0.6687	0.9084	1.0820	8.2090	14.6950	8.2336	14.2636
+4153	1995.5342	195	1.2685	0.6687	0.9084	1.0820	8.2090	14.6950	8.2341	14.2640
+4154	1995.5370	196	1.2685	0.6686	0.9084	1.0820	8.2090	14.6950	8.2345	14.2645
+4155	1995.5397	197	1.2684	0.6686	0.9084	1.0820	8.2090	14.6950	8.2346	14.2651
+4156	1995.5425	198	1.2684	0.6686	0.9084	1.0820	8.2090	14.6950	8.2345	14.2658
+4157	1995.5452	199	1.2684	0.6686	0.9084	1.0820	8.2090	14.6950	8.2341	14.2666
+4158	1995.5479	200	1.2684	0.6686	0.9084	1.0820	8.2090	14.6950	8.2335	14.2675
+4159	1995.5507	201	1.2683	0.6686	0.9084	1.0820	8.2090	14.6950	8.2326	14.2685
+4160	1995.5534	202	1.2683	0.6686	0.9084	1.0820	8.2090	14.6950	8.2315	14.2696
+4161	1995.5562	203	1.2683	0.6686	0.9084	1.0820	8.2090	14.6950	8.2301	14.2708
+4162	1995.5589	204	1.2683	0.6686	0.9084	1.0820	8.2090	14.6950	8.2286	14.2721
+4163	1995.5616	205	1.2683	0.6685	0.9084	1.0820	8.2090	14.6950	8.2267	14.2735
+4164	1995.5644	206	1.2682	0.6685	0.9084	1.0820	8.2090	14.6950	8.2247	14.2750
+4165	1995.5671	207	1.2682	0.6685	0.9084	1.0820	8.2090	14.6950	8.2224	14.2766
+4166	1995.5699	208	1.2682	0.6685	0.9084	1.0820	8.2090	14.6950	8.2199	14.2783
+4167	1995.5726	209	1.2682	0.6685	0.9084	1.0820	8.2090	14.6950	8.2172	14.2801
+4168	1995.5753	210	1.2681	0.6685	0.9084	1.0820	8.2090	14.6950	8.2143	14.2820
+4169	1995.5781	211	1.2681	0.6685	0.9084	1.0820	8.2090	14.6950	8.2111	14.2839
+4170	1995.5808	212	1.2681	0.6685	0.9084	1.0820	8.2090	14.6950	8.2078	14.2860
+4171	1995.5836	213	1.2681	0.6685	0.9084	1.0820	8.2090	14.6950	8.2042	14.2881
+4172	1995.5863	214	1.2681	0.6684	0.9084	1.0820	8.2090	14.6950	8.2005	14.2903
+4173	1995.5890	215	1.2680	0.6684	0.9084	1.0820	8.2090	14.6950	8.1966	14.2926
+4174	1995.5918	216	1.2680	0.6684	0.9083	1.0820	8.2090	14.6950	8.1924	14.2950
+4175	1995.5945	217	1.2680	0.6684	0.9083	1.0820	8.2090	14.6950	8.1882	14.2974
+4176	1995.5973	218	1.2680	0.6684	0.9083	1.0820	8.2090	14.6950	8.1837	14.2999
+4177	1995.6000	219	1.2679	0.6684	0.9083	1.0820	8.2090	14.6950	8.1791	14.3025
+4178	1995.6027	220	1.2679	0.6684	0.9083	1.0820	8.2090	14.6950	8.1743	14.3052
+4179	1995.6055	221	1.2679	0.6684	0.9083	1.0820	8.2090	14.6950	8.1694	14.3079
+4180	1995.6082	222	1.2679	0.6684	0.9083	1.0820	8.2090	14.6950	8.1643	14.3107
+4181	1995.6110	223	1.2678	0.6683	0.9083	1.0820	8.2090	14.6950	8.1592	14.3136
+4182	1995.6137	224	1.2678	0.6683	0.9083	1.0820	8.2090	14.6950	8.1539	14.3165
+4183	1995.6164	225	1.2678	0.6683	0.9083	1.0820	8.2090	14.6950	8.1484	14.3195
+4184	1995.6192	226	1.2678	0.6683	0.9083	1.0820	8.2090	14.6950	8.1429	14.3225
+4185	1995.6219	227	1.2678	0.6683	0.9083	1.0820	8.2090	14.6950	8.1373	14.3256
+4186	1995.6247	228	1.2677	0.6683	0.9083	1.0820	8.2090	14.6950	8.1316	14.3288
+4187	1995.6274	229	1.2677	0.6683	0.9083	1.0820	8.2090	14.6950	8.1258	14.3320
+4188	1995.6301	230	1.2677	0.6683	0.9083	1.0820	8.2090	14.6950	8.1199	14.3352
+4189	1995.6329	231	1.2677	0.6683	0.9083	1.0820	8.2090	14.6950	8.1140	14.3385
+4190	1995.6356	232	1.2676	0.6682	0.9083	1.0820	8.2090	14.6950	8.1081	14.3418
+4191	1995.6384	233	1.2676	0.6682	0.9083	1.0820	8.2090	14.6950	8.1020	14.3451
+4192	1995.6411	234	1.2676	0.6682	0.9083	1.0820	8.2090	14.6950	8.0960	14.3485
+4193	1995.6438	235	1.2676	0.6682	0.9083	1.0820	8.2090	14.6950	8.0899	14.3519
+4194	1995.6466	236	1.2676	0.6682	0.9083	1.0820	8.2090	14.6950	8.0838	14.3554
+4195	1995.6493	237	1.2675	0.6682	0.9083	1.0820	8.2090	14.6950	8.0778	14.3589
+4196	1995.6521	238	1.2675	0.6682	0.9083	1.0820	8.2090	14.6950	8.0717	14.3624
+4197	1995.6548	239	1.2675	0.6682	0.9083	1.0820	8.2090	14.6950	8.0656	14.3659
+4198	1995.6575	240	1.2675	0.6682	0.9083	1.0820	8.2090	14.6950	8.0595	14.3694
+4199	1995.6603	241	1.2674	0.6682	0.9083	1.0820	8.2090	14.6950	8.0535	14.3730
+4200	1995.6630	242	1.2674	0.6681	0.9083	1.0820	8.2090	14.6950	8.0475	14.3765
+4201	1995.6658	243	1.2674	0.6681	0.9083	1.0820	8.2090	14.6950	8.0416	14.3801
+4202	1995.6685	244	1.2674	0.6681	0.9082	1.0820	8.2090	14.6950	8.0357	14.3837
+4203	1995.6712	245	1.2674	0.6681	0.9082	1.0820	8.2090	14.6950	8.0298	14.3873
+4204	1995.6740	246	1.2673	0.6681	0.9082	1.0820	8.2090	14.6950	8.0241	14.3908
+4205	1995.6767	247	1.2673	0.6681	0.9082	1.0820	8.2090	14.6950	8.0184	14.3944
+4206	1995.6795	248	1.2673	0.6681	0.9082	1.0820	8.2090	14.6950	8.0128	14.3980
+4207	1995.6822	249	1.2673	0.6681	0.9082	1.0820	8.2090	14.6950	8.0073	14.4016
+4208	1995.6849	250	1.2672	0.6681	0.9082	1.0820	8.2090	14.6950	8.0019	14.4051
+4209	1995.6877	251	1.2672	0.6680	0.9082	1.0820	8.2090	14.6950	7.9966	14.4087
+4210	1995.6904	252	1.2672	0.6680	0.9082	1.0820	8.2090	14.6950	7.9915	14.4122
+4211	1995.6932	253	1.2672	0.6680	0.9082	1.0820	8.2090	14.6950	7.9864	14.4157
+4212	1995.6959	254	1.2672	0.6680	0.9082	1.0820	8.2090	14.6950	7.9815	14.4192
+4213	1995.6986	255	1.2671	0.6680	0.9082	1.0820	8.2090	14.6950	7.9767	14.4227
+4214	1995.7014	256	1.2671	0.6680	0.9082	1.0820	8.2090	14.6950	7.9721	14.4261
+4215	1995.7041	257	1.2671	0.6680	0.9082	1.0820	8.2090	14.6950	7.9676	14.4295
+4216	1995.7068	258	1.2671	0.6680	0.9082	1.0820	8.2090	14.6950	7.9633	14.4329
+4217	1995.7096	259	1.2670	0.6680	0.9082	1.0820	8.2090	14.6950	7.9591	14.4362
+4218	1995.7123	260	1.2670	0.6679	0.9082	1.0820	8.2090	14.6950	7.9551	14.4395
+4219	1995.7151	261	1.2670	0.6679	0.9082	1.0820	8.2090	14.6950	7.9513	14.4427
+4220	1995.7178	262	1.2670	0.6679	0.9082	1.0820	8.2090	14.6950	7.9476	14.4459
+4221	1995.7205	263	1.2670	0.6679	0.9082	1.0820	8.2090	14.6950	7.9442	14.4491
+4222	1995.7233	264	1.2669	0.6679	0.9082	1.0820	8.2090	14.6950	7.9409	14.4522
+4223	1995.7260	265	1.2669	0.6679	0.9082	1.0820	8.2090	14.6950	7.9378	14.4553
+4224	1995.7288	266	1.2669	0.6679	0.9082	1.0820	8.2090	14.6950	7.9349	14.4583
+4225	1995.7315	267	1.2669	0.6679	0.9082	1.0820	8.2090	14.6950	7.9322	14.4612
+4226	1995.7342	268	1.2668	0.6679	0.9082	1.0820	8.2090	14.6950	7.9297	14.4641
+4227	1995.7370	269	1.2668	0.6679	0.9082	1.0820	8.2090	14.6950	7.9273	14.4669
+4228	1995.7397	270	1.2668	0.6678	0.9082	1.0820	8.2090	14.6950	7.9252	14.4697
+4229	1995.7425	271	1.2668	0.6678	0.9082	1.0820	8.2090	14.6950	7.9234	14.4724
+4230	1995.7452	272	1.2668	0.6678	0.9081	1.0820	8.2090	14.6950	7.9217	14.4750
+4231	1995.7479	273	1.2667	0.6678	0.9081	1.0820	8.2090	14.6950	7.9202	14.4776
+4232	1995.7507	274	1.2667	0.6678	0.9081	1.0820	8.2090	14.6950	7.9189	14.4801
+4233	1995.7534	275	1.2667	0.6678	0.9081	1.0820	8.2090	14.6950	7.9179	14.4825
+4234	1995.7562	276	1.2667	0.6678	0.9081	1.0820	8.2090	14.6950	7.9171	14.4848
+4235	1995.7589	277	1.2666	0.6678	0.9081	1.0820	8.2090	14.6950	7.9164	14.4870
+4236	1995.7616	278	1.2666	0.6678	0.9081	1.0820	8.2090	14.6950	7.9161	14.4892
+4237	1995.7644	279	1.2666	0.6677	0.9081	1.0820	8.2090	14.6950	7.9159	14.4913
+4238	1995.7671	280	1.2666	0.6677	0.9081	1.0820	8.2090	14.6950	7.9159	14.4933
+4239	1995.7699	281	1.2666	0.6677	0.9081	1.0820	8.2090	14.6950	7.9162	14.4952
+4240	1995.7726	282	1.2665	0.6677	0.9081	1.0820	8.2090	14.6950	7.9166	14.4970
+4241	1995.7753	283	1.2665	0.6677	0.9081	1.0820	8.2090	14.6950	7.9173	14.4987
+4242	1995.7781	284	1.2665	0.6677	0.9081	1.0820	8.2090	14.6950	7.9182	14.5004
+4243	1995.7808	285	1.2665	0.6677	0.9081	1.0820	8.2090	14.6950	7.9193	14.5019
+4244	1995.7836	286	1.2664	0.6677	0.9081	1.0820	8.2090	14.6950	7.9206	14.5034
+4245	1995.7863	287	1.2664	0.6677	0.9081	1.0820	8.2090	14.6950	7.9222	14.5047
+4246	1995.7890	288	1.2664	0.6676	0.9081	1.0820	8.2090	14.6950	7.9239	14.5060
+4247	1995.7918	289	1.2664	0.6676	0.9081	1.0820	8.2090	14.6950	7.9258	14.5071
+4248	1995.7945	290	1.2664	0.6676	0.9081	1.0820	8.2090	14.6950	7.9279	14.5082
+4249	1995.7973	291	1.2663	0.6676	0.9081	1.0820	8.2090	14.6950	7.9303	14.5091
+4250	1995.8000	292	1.2663	0.6676	0.9081	1.0820	8.2090	14.6950	7.9328	14.5100
+4251	1995.8027	293	1.2663	0.6676	0.9081	1.0820	8.2090	14.6950	7.9355	14.5107
+4252	1995.8055	294	1.2663	0.6676	0.9081	1.0820	8.2090	14.6950	7.9384	14.5114
+4253	1995.8082	295	1.2662	0.6676	0.9081	1.0820	8.2090	14.6950	7.9415	14.5119
+4254	1995.8110	296	1.2662	0.6676	0.9081	1.0820	8.2090	14.6950	7.9447	14.5123
+4255	1995.8137	297	1.2662	0.6676	0.9081	1.0820	8.2090	14.6950	7.9481	14.5127
+4256	1995.8164	298	1.2662	0.6675	0.9081	1.0820	8.2090	14.6950	7.9517	14.5129
+4257	1995.8192	299	1.2662	0.6675	0.9081	1.0820	8.2090	14.6950	7.9555	14.5130
+4258	1995.8219	300	1.2661	0.6675	0.9081	1.0820	8.2090	14.6950	7.9594	14.5130
+4259	1995.8247	301	1.2661	0.6675	0.9080	1.0820	8.2090	14.6950	7.9634	14.5129
+4260	1995.8274	302	1.2661	0.6675	0.9080	1.0820	8.2090	14.6950	7.9676	14.5126
+4261	1995.8301	303	1.2661	0.6675	0.9080	1.0820	8.2090	14.6950	7.9720	14.5123
+4262	1995.8329	304	1.2661	0.6675	0.9080	1.0820	8.2090	14.6950	7.9764	14.5119
+4263	1995.8356	305	1.2660	0.6675	0.9080	1.0820	8.2090	14.6950	7.9810	14.5113
+4264	1995.8384	306	1.2660	0.6675	0.9080	1.0820	8.2090	14.6950	7.9858	14.5107
+4265	1995.8411	307	1.2660	0.6674	0.9080	1.0820	8.2090	14.6950	7.9906	14.5099
+4266	1995.8438	308	1.2660	0.6674	0.9080	1.0820	8.2090	14.6950	7.9955	14.5090
+4267	1995.8466	309	1.2659	0.6674	0.9080	1.0820	8.2090	14.6950	8.0006	14.5080
+4268	1995.8493	310	1.2659	0.6674	0.9080	1.0820	8.2090	14.6950	8.0057	14.5069
+4269	1995.8521	311	1.2659	0.6674	0.9080	1.0820	8.2090	14.6950	8.0109	14.5057
+4270	1995.8548	312	1.2659	0.6674	0.9080	1.0820	8.2090	14.6950	8.0162	14.5044
+4271	1995.8575	313	1.2659	0.6674	0.9080	1.0820	8.2090	14.6950	8.0215	14.5030
+4272	1995.8603	314	1.2658	0.6674	0.9080	1.0820	8.2090	14.6950	8.0269	14.5015
+4273	1995.8630	315	1.2658	0.6674	0.9080	1.0820	8.2090	14.6950	8.0324	14.4998
+4274	1995.8658	316	1.2658	0.6674	0.9080	1.0820	8.2090	14.6950	8.0379	14.4981
+4275	1995.8685	317	1.2658	0.6673	0.9080	1.0820	8.2090	14.6950	8.0434	14.4962
+4276	1995.8712	318	1.2657	0.6673	0.9080	1.0820	8.2090	14.6950	8.0490	14.4943
+4277	1995.8740	319	1.2657	0.6673	0.9080	1.0820	8.2090	14.6950	8.0546	14.4922
+4278	1995.8767	320	1.2657	0.6673	0.9080	1.0820	8.2090	14.6950	8.0602	14.4901
+4279	1995.8795	321	1.2657	0.6673	0.9080	1.0820	8.2090	14.6950	8.0658	14.4878
+4280	1995.8822	322	1.2657	0.6673	0.9080	1.0820	8.2090	14.6950	8.0714	14.4855
+4281	1995.8849	323	1.2656	0.6673	0.9080	1.0820	8.2090	14.6950	8.0770	14.4830
+4282	1995.8877	324	1.2656	0.6673	0.9080	1.0820	8.2090	14.6950	8.0826	14.4805
+4283	1995.8904	325	1.2656	0.6673	0.9080	1.0820	8.2090	14.6950	8.0881	14.4778
+4284	1995.8932	326	1.2656	0.6672	0.9080	1.0820	8.2090	14.6950	8.0936	14.4751
+4285	1995.8959	327	1.2655	0.6672	0.9080	1.0820	8.2090	14.6950	8.0990	14.4722
+4286	1995.8986	328	1.2655	0.6672	0.9080	1.0820	8.2090	14.6950	8.1044	14.4693
+4287	1995.9014	329	1.2655	0.6672	0.9080	1.0820	8.2090	14.6950	8.1097	14.4663
+4288	1995.9041	330	1.2655	0.6672	0.9079	1.0820	8.2090	14.6950	8.1150	14.4632
+4289	1995.9068	331	1.2655	0.6672	0.9079	1.0820	8.2090	14.6950	8.1202	14.4600
+4290	1995.9096	332	1.2654	0.6672	0.9079	1.0820	8.2090	14.6950	8.1252	14.4567
+4291	1995.9123	333	1.2654	0.6672	0.9079	1.0820	8.2090	14.6950	8.1302	14.4533
+4292	1995.9151	334	1.2654	0.6672	0.9079	1.0820	8.2090	14.6950	8.1351	14.4499
+4293	1995.9178	335	1.2654	0.6672	0.9079	1.0820	8.2090	14.6950	8.1399	14.4464
+4294	1995.9205	336	1.2654	0.6671	0.9079	1.0820	8.2090	14.6950	8.1445	14.4428
+4295	1995.9233	337	1.2653	0.6671	0.9079	1.0820	8.2090	14.6950	8.1491	14.4391
+4296	1995.9260	338	1.2653	0.6671	0.9079	1.0820	8.2090	14.6950	8.1535	14.4353
+4297	1995.9288	339	1.2653	0.6671	0.9079	1.0820	8.2090	14.6950	8.1577	14.4315
+4298	1995.9315	340	1.2653	0.6671	0.9079	1.0820	8.2090	14.6950	8.1618	14.4276
+4299	1995.9342	341	1.2652	0.6671	0.9079	1.0820	8.2090	14.6950	8.1658	14.4237
+4300	1995.9370	342	1.2652	0.6671	0.9079	1.0820	8.2090	14.6950	8.1696	14.4197
+4301	1995.9397	343	1.2652	0.6671	0.9079	1.0820	8.2090	14.6950	8.1732	14.4156
+4302	1995.9425	344	1.2652	0.6671	0.9079	1.0820	8.2090	14.6950	8.1766	14.4114
+4303	1995.9452	345	1.2652	0.6670	0.9079	1.0820	8.2090	14.6950	8.1799	14.4072
+4304	1995.9479	346	1.2651	0.6670	0.9079	1.0820	8.2090	14.6950	8.1830	14.4030
+4305	1995.9507	347	1.2651	0.6670	0.9079	1.0820	8.2090	14.6950	8.1859	14.3987
+4306	1995.9534	348	1.2651	0.6670	0.9079	1.0820	8.2090	14.6950	8.1886	14.3943
+4307	1995.9562	349	1.2651	0.6670	0.9079	1.0820	8.2090	14.6950	8.1912	14.3899
+4308	1995.9589	350	1.2651	0.6670	0.9079	1.0820	8.2090	14.6950	8.1935	14.3855
+4309	1995.9616	351	1.2650	0.6670	0.9079	1.0820	8.2090	14.6950	8.1956	14.3810
+4310	1995.9644	352	1.2650	0.6670	0.9079	1.0820	8.2090	14.6950	8.1975	14.3764
+4311	1995.9671	353	1.2650	0.6670	0.9079	1.0820	8.2090	14.6950	8.1992	14.3718
+4312	1995.9699	354	1.2650	0.6670	0.9079	1.0820	8.2090	14.6950	8.2007	14.3672
+4313	1995.9726	355	1.2649	0.6669	0.9079	1.0820	8.2090	14.6950	8.2019	14.3626
+4314	1995.9753	356	1.2649	0.6669	0.9079	1.0820	8.2090	14.6950	8.2030	14.3579
+4315	1995.9781	357	1.2649	0.6669	0.9079	1.0820	8.2090	14.6950	8.2038	14.3532
+4316	1995.9808	358	1.2649	0.6669	0.9079	1.0820	8.2090	14.6950	8.2044	14.3485
+4317	1995.9836	359	1.2649	0.6669	0.9079	1.0820	8.2090	14.6950	8.2048	14.3437
+4318	1995.9863	360	1.2648	0.6669	0.9078	1.0820	8.2090	14.6950	8.2049	14.3390
+4319	1995.9890	361	1.2648	0.6669	0.9078	1.0820	8.2090	14.6950	8.2049	14.3342
+4320	1995.9918	362	1.2648	0.6669	0.9078	1.0820	8.2090	14.6950	8.2046	14.3294
+4321	1995.9945	363	1.2648	0.6669	0.9078	1.0820	8.2090	14.6950	8.2041	14.3246
+4322	1995.9973	364	1.2648	0.6668	0.9078	1.0820	8.2090	14.6950	8.2033	14.3197
+4323	1995.9999	365	1.2647	0.6668	0.9078	1.0820	8.2090	14.6950	8.2024	14.3149
+4324	1996.0027	1	1.2647	0.6668	0.9078	1.0820	8.2090	14.6950	8.2012	14.3101
+4325	1996.0055	2	1.2647	0.6668	0.9078	1.0820	8.2090	14.6950	8.1998	14.3052
+4326	1996.0082	3	1.2647	0.6668	0.9078	1.0820	8.2090	14.6950	8.1982	14.3004
+4327	1996.0109	4	1.2646	0.6668	0.9078	1.0820	8.2090	14.6950	8.1963	14.2956
+4328	1996.0137	5	1.2646	0.6668	0.9078	1.0820	8.2090	14.6950	8.1943	14.2907
+4329	1996.0164	6	1.2646	0.6668	0.9078	1.0820	8.2090	14.6950	8.1920	14.2859
+4330	1996.0191	7	1.2646	0.6668	0.9078	1.0820	8.2090	14.6950	8.1896	14.2811
+4331	1996.0219	8	1.2646	0.6668	0.9078	1.0820	8.2090	14.6950	8.1869	14.2763
+4332	1996.0246	9	1.2645	0.6667	0.9078	1.0820	8.2090	14.6950	8.1841	14.2716
+4333	1996.0273	10	1.2645	0.6667	0.9078	1.0820	8.2090	14.6950	8.1811	14.2668
+4334	1996.0301	11	1.2645	0.6667	0.9078	1.0820	8.2090	14.6950	8.1778	14.2621
+4335	1996.0328	12	1.2645	0.6667	0.9078	1.0820	8.2090	14.6950	8.1744	14.2573
+4336	1996.0355	13	1.2645	0.6667	0.9078	1.0820	8.2090	14.6950	8.1708	14.2527
+4337	1996.0383	14	1.2644	0.6667	0.9078	1.0820	8.2090	14.6950	8.1671	14.2480
+4338	1996.0410	15	1.2644	0.6667	0.9078	1.0820	8.2090	14.6950	8.1631	14.2434
+4339	1996.0437	16	1.2644	0.6667	0.9078	1.0820	8.2090	14.6950	8.1590	14.2388
+4340	1996.0464	17	1.2644	0.6667	0.9078	1.0820	8.2090	14.6950	8.1548	14.2342
+4341	1996.0492	18	1.2643	0.6667	0.9078	1.0820	8.2090	14.6950	8.1504	14.2297
+4342	1996.0519	19	1.2643	0.6666	0.9078	1.0820	8.2090	14.6950	8.1459	14.2252
+4343	1996.0546	20	1.2643	0.6666	0.9078	1.0820	8.2090	14.6950	8.1412	14.2208
+4344	1996.0574	21	1.2643	0.6666	0.9078	1.0820	8.2090	14.6950	8.1364	14.2164
+4345	1996.0601	22	1.2643	0.6666	0.9078	1.0820	8.2090	14.6950	8.1315	14.2121
+4346	1996.0628	23	1.2642	0.6666	0.9078	1.0820	8.2090	14.6950	8.1264	14.2078
+4347	1996.0656	24	1.2642	0.6666	0.9078	1.0820	8.2090	14.6950	8.1213	14.2035
+4348	1996.0683	25	1.2642	0.6666	0.9078	1.0820	8.2090	14.6950	8.1161	14.1993
+4349	1996.0710	26	1.2642	0.6666	0.9077	1.0820	8.2090	14.6950	8.1107	14.1952
+4350	1996.0738	27	1.2642	0.6666	0.9077	1.0820	8.2090	14.6950	8.1053	14.1911
+4351	1996.0765	28	1.2641	0.6665	0.9077	1.0820	8.2090	14.6950	8.0998	14.1871
+4352	1996.0792	29	1.2641	0.6665	0.9077	1.0820	8.2090	14.6950	8.0943	14.1831
+4353	1996.0820	30	1.2641	0.6665	0.9077	1.0820	8.2090	14.6950	8.0886	14.1793
+4354	1996.0847	31	1.2641	0.6665	0.9077	1.0820	8.2090	14.6950	8.0830	14.1754
+4355	1996.0874	32	1.2641	0.6665	0.9077	1.0820	8.2090	14.6950	8.0773	14.1717
+4356	1996.0902	33	1.2640	0.6665	0.9077	1.0820	8.2090	14.6950	8.0715	14.1680
+4357	1996.0929	34	1.2640	0.6665	0.9077	1.0820	8.2090	14.6950	8.0657	14.1644
+4358	1996.0956	35	1.2640	0.6665	0.9077	1.0820	8.2090	14.6950	8.0599	14.1608
+4359	1996.0984	36	1.2640	0.6665	0.9077	1.0820	8.2090	14.6950	8.0541	14.1573
+4360	1996.1011	37	1.2639	0.6665	0.9077	1.0820	8.2090	14.6950	8.0483	14.1539
+4361	1996.1038	38	1.2639	0.6664	0.9077	1.0820	8.2090	14.6950	8.0425	14.1506
+4362	1996.1066	39	1.2639	0.6664	0.9077	1.0820	8.2090	14.6950	8.0367	14.1474
+4363	1996.1093	40	1.2639	0.6664	0.9077	1.0820	8.2090	14.6950	8.0309	14.1442
+4364	1996.1120	41	1.2639	0.6664	0.9077	1.0820	8.2090	14.6950	8.0251	14.1411
+4365	1996.1148	42	1.2638	0.6664	0.9077	1.0820	8.2090	14.6950	8.0194	14.1381
+4366	1996.1175	43	1.2638	0.6664	0.9077	1.0820	8.2090	14.6950	8.0137	14.1352
+4367	1996.1202	44	1.2638	0.6664	0.9077	1.0820	8.2090	14.6950	8.2090	14.6950
+4368	1996.1230	45	1.2638	0.6664	0.9077	1.0820	8.2090	14.6950	8.2044	14.6949
+4369	1996.1257	46	1.2638	0.6664	0.9077	1.0820	8.2090	14.6950	8.1997	14.6947
+4370	1996.1284	47	1.2637	0.6664	0.9077	1.0820	8.2090	14.6950	8.1949	14.6944
+4371	1996.1311	48	1.2637	0.6663	0.9077	1.0820	8.2090	14.6950	8.1899	14.6940
+4372	1996.1339	49	1.2637	0.6663	0.9077	1.0820	8.2090	14.6950	8.1848	14.6935
+4373	1996.1366	50	1.2637	0.6663	0.9077	1.0820	8.2090	14.6950	8.1797	14.6929
+4374	1996.1393	51	1.2637	0.6663	0.9077	1.0820	8.2090	14.6950	8.1744	14.6921
+4375	1996.1421	52	1.2636	0.6663	0.9077	1.0820	8.2090	14.6950	8.1690	14.6913
+4376	1996.1448	53	1.2636	0.6663	0.9077	1.0820	8.2090	14.6950	8.1636	14.6904
+4377	1996.1475	54	1.2636	0.6663	0.9077	1.0820	8.2090	14.6950	8.1580	14.6893
+4378	1996.1503	55	1.2636	0.6663	0.9077	1.0820	8.2090	14.6950	8.1524	14.6881
+4379	1996.1530	56	1.2636	0.6663	0.9077	1.0820	8.2090	14.6950	8.1468	14.6869
+4380	1996.1557	57	1.2635	0.6663	0.9076	1.0820	8.2090	14.6950	8.1410	14.6855
+4381	1996.1585	58	1.2635	0.6662	0.9076	1.0820	8.2090	14.6950	8.1353	14.6841
+4382	1996.1612	59	1.2635	0.6662	0.9076	1.0820	8.2090	14.6950	8.1295	14.6825
+4383	1996.1639	60	1.2635	0.6662	0.9076	1.0820	8.2090	14.6950	8.1237	14.6808
+4384	1996.1667	61	1.2634	0.6662	0.9076	1.0820	8.2090	14.6950	8.1178	14.6790
+4385	1996.1694	62	1.2634	0.6662	0.9076	1.0820	8.2090	14.6950	8.1119	14.6771
+4386	1996.1721	63	1.2634	0.6662	0.9076	1.0820	8.2090	14.6950	8.1061	14.6752
+4387	1996.1749	64	1.2634	0.6662	0.9076	1.0820	8.2090	14.6950	8.1002	14.6731
+4388	1996.1776	65	1.2634	0.6662	0.9076	1.0820	8.2090	14.6950	8.0944	14.6709
+4389	1996.1803	66	1.2633	0.6662	0.9076	1.0820	8.2090	14.6950	8.0885	14.6686
+4390	1996.1831	67	1.2633	0.6661	0.9076	1.0820	8.2090	14.6950	8.0827	14.6663
+4391	1996.1858	68	1.2633	0.6661	0.9076	1.0820	8.2090	14.6950	8.0769	14.6638
+4392	1996.1885	69	1.2633	0.6661	0.9076	1.0820	8.2090	14.6950	8.0712	14.6612
+4393	1996.1913	70	1.2633	0.6661	0.9076	1.0820	8.2090	14.6950	8.0655	14.6586
+4394	1996.1940	71	1.2632	0.6661	0.9076	1.0820	8.2090	14.6950	8.0599	14.6558
+4395	1996.1967	72	1.2632	0.6661	0.9076	1.0820	8.2090	14.6950	8.0543	14.6530
+4396	1996.1995	73	1.2632	0.6661	0.9076	1.0820	8.2090	14.6950	8.0488	14.6501
+4397	1996.2022	74	1.2632	0.6661	0.9076	1.0820	8.2090	14.6950	8.0434	14.6470
+4398	1996.2049	75	1.2632	0.6661	0.9076	1.0820	8.2090	14.6950	8.0381	14.6439
+4399	1996.2077	76	1.2631	0.6661	0.9076	1.0820	8.2090	14.6950	8.0328	14.6408
+4400	1996.2104	77	1.2631	0.6660	0.9076	1.0820	8.2090	14.6950	8.0277	14.6375
+4401	1996.2131	78	1.2631	0.6660	0.9076	1.0820	8.2090	14.6950	8.0227	14.6341
+4402	1996.2158	79	1.2631	0.6660	0.9076	1.0820	8.2090	14.6950	8.0177	14.6307
+4403	1996.2186	80	1.2631	0.6660	0.9076	1.0820	8.2090	14.6950	8.0129	14.6272
+4404	1996.2213	81	1.2630	0.6660	0.9076	1.0820	8.2090	14.6950	8.0082	14.6236
+4405	1996.2240	82	1.2630	0.6660	0.9076	1.0820	8.2090	14.6950	8.0036	14.6200
+4406	1996.2268	83	1.2630	0.6660	0.9076	1.0820	8.2090	14.6950	7.9992	14.6163
+4407	1996.2295	84	1.2630	0.6660	0.9076	1.0820	8.2090	14.6950	7.9949	14.6125
+4408	1996.2322	85	1.2630	0.6660	0.9076	1.0820	8.2090	14.6950	7.9908	14.6086
+4409	1996.2350	86	1.2629	0.6660	0.9076	1.0820	8.2090	14.6950	7.9868	14.6047
+4410	1996.2377	87	1.2629	0.6659	0.9076	1.0820	8.2090	14.6950	7.9829	14.6007
+4411	1996.2404	88	1.2629	0.6659	0.9076	1.0820	8.2090	14.6950	7.9792	14.5967
+4412	1996.2432	89	1.2629	0.6659	0.9075	1.0820	8.2090	14.6950	7.9757	14.5926
+4413	1996.2459	90	1.2628	0.6659	0.9075	1.0820	8.2090	14.6950	7.9723	14.5884
+4414	1996.2486	91	1.2628	0.6659	0.9075	1.0820	8.2090	14.6950	7.9692	14.5842
+4415	1996.2514	92	1.2628	0.6659	0.9075	1.0820	8.2090	14.6950	7.9661	14.5799
+4416	1996.2541	93	1.2628	0.6659	0.9075	1.0820	8.2090	14.6950	7.9633	14.5756
+4417	1996.2568	94	1.2628	0.6659	0.9075	1.0820	8.2090	14.6950	7.9606	14.5712
+4418	1996.2596	95	1.2627	0.6659	0.9075	1.0820	8.2090	14.6950	7.9582	14.5668
+4419	1996.2623	96	1.2627	0.6659	0.9075	1.0820	8.2090	14.6950	7.9559	14.5623
+4420	1996.2650	97	1.2627	0.6658	0.9075	1.0820	8.2090	14.6950	7.9538	14.5578
+4421	1996.2678	98	1.2627	0.6658	0.9075	1.0820	8.2090	14.6950	7.9518	14.5533
+4422	1996.2705	99	1.2627	0.6658	0.9075	1.0820	8.2090	14.6950	7.9501	14.5487
+4423	1996.2732	100	1.2626	0.6658	0.9075	1.0820	8.2090	14.6950	7.9486	14.5441
+4424	1996.2760	101	1.2626	0.6658	0.9075	1.0820	8.2090	14.6950	7.9473	14.5395
+4425	1996.2787	102	1.2626	0.6658	0.9075	1.0820	8.2090	14.6950	7.9461	14.5348
+4426	1996.2814	103	1.2626	0.6658	0.9075	1.0820	8.2090	14.6950	7.9452	14.5301
+4427	1996.2842	104	1.2626	0.6658	0.9075	1.0820	8.2090	14.6950	7.9444	14.5254
+4428	1996.2869	105	1.2625	0.6658	0.9075	1.0820	8.2090	14.6950	7.9439	14.5207
+4429	1996.2896	106	1.2625	0.6658	0.9075	1.0820	8.2090	14.6950	7.9436	14.5159
+4430	1996.2923	107	1.2625	0.6657	0.9075	1.0820	8.2090	14.6950	7.9434	14.5112
+4431	1996.2951	108	1.2625	0.6657	0.9075	1.0820	8.2090	14.6950	7.9435	14.5064
+4432	1996.2978	109	1.2625	0.6657	0.9075	1.0820	8.2090	14.6950	7.9437	14.5016
+4433	1996.3005	110	1.2624	0.6657	0.9075	1.0820	8.2090	14.6950	7.9442	14.4968
+4434	1996.3033	111	1.2624	0.6657	0.9075	1.0820	8.2090	14.6950	7.9449	14.4920
+4435	1996.3060	112	1.2624	0.6657	0.9075	1.0820	8.2090	14.6950	7.9457	14.4872
+4436	1996.3087	113	1.2624	0.6657	0.9075	1.0820	8.2090	14.6950	7.9467	14.4823
+4437	1996.3115	114	1.2624	0.6657	0.9075	1.0820	8.2090	14.6950	7.9480	14.4775
+4438	1996.3142	115	1.2623	0.6657	0.9075	1.0820	8.2090	14.6950	7.9494	14.4727
+4439	1996.3169	116	1.2623	0.6657	0.9075	1.0820	8.2090	14.6950	7.9510	14.4679
+4440	1996.3197	117	1.2623	0.6656	0.9075	1.0820	8.2090	14.6950	7.9528	14.4631
+4441	1996.3224	118	1.2623	0.6656	0.9075	1.0820	8.2090	14.6950	7.9548	14.4583
+4442	1996.3251	119	1.2623	0.6656	0.9075	1.0820	8.2090	14.6950	7.9570	14.4536
+4443	1996.3279	120	1.2622	0.6656	0.9075	1.0820	8.2090	14.6950	7.9593	14.4488
+4444	1996.3306	121	1.2622	0.6656	0.9075	1.0820	8.2090	14.6950	7.9619	14.4441
+4445	1996.3333	122	1.2622	0.6656	0.9074	1.0820	8.2090	14.6950	7.9646	14.4393
+4446	1996.3361	123	1.2622	0.6656	0.9074	1.0820	8.2090	14.6950	7.9674	14.4346
+4447	1996.3388	124	1.2622	0.6656	0.9074	1.0820	8.2090	14.6950	7.9705	14.4300
+4448	1996.3415	125	1.2621	0.6656	0.9074	1.0820	8.2090	14.6950	7.9736	14.4253
+4449	1996.3443	126	1.2621	0.6656	0.9074	1.0820	8.2090	14.6950	7.9770	14.4207
+4450	1996.3470	127	1.2621	0.6655	0.9074	1.0820	8.2090	14.6950	7.9805	14.4161
+4451	1996.3497	128	1.2621	0.6655	0.9074	1.0820	8.2090	14.6950	7.9841	14.4116
+4452	1996.3525	129	1.2621	0.6655	0.9074	1.0820	8.2090	14.6950	7.9879	14.4071
+4453	1996.3552	130	1.2620	0.6655	0.9074	1.0820	8.2090	14.6950	7.9919	14.4026
+4454	1996.3579	131	1.2620	0.6655	0.9074	1.0820	8.2090	14.6950	7.9959	14.3982
+4455	1996.3607	132	1.2620	0.6655	0.9074	1.0820	8.2090	14.6950	8.0001	14.3938
+4456	1996.3634	133	1.2620	0.6655	0.9074	1.0820	8.2090	14.6950	8.0044	14.3894
+4457	1996.3661	134	1.2619	0.6655	0.9074	1.0820	8.2090	14.6950	8.0088	14.3851
+4458	1996.3689	135	1.2619	0.6655	0.9074	1.0820	8.2090	14.6950	8.0134	14.3809
+4459	1996.3716	136	1.2619	0.6655	0.9074	1.0820	8.2090	14.6950	8.0180	14.3767
+4460	1996.3743	137	1.2619	0.6654	0.9074	1.0820	8.2090	14.6950	8.0227	14.3725
+4461	1996.3770	138	1.2619	0.6654	0.9074	1.0820	8.2090	14.6950	8.0276	14.3684
+4462	1996.3798	139	1.2618	0.6654	0.9074	1.0820	8.2090	14.6950	8.0325	14.3644
+4463	1996.3825	140	1.2618	0.6654	0.9074	1.0820	8.2090	14.6950	8.0375	14.3604
+4464	1996.3852	141	1.2618	0.6654	0.9074	1.0820	8.2090	14.6950	8.0425	14.3565
+4465	1996.3880	142	1.2618	0.6654	0.9074	1.0820	8.2090	14.6950	8.0477	14.3527
+4466	1996.3907	143	1.2618	0.6654	0.9074	1.0820	8.2090	14.6950	8.0529	14.3489
+4467	1996.3934	144	1.2617	0.6654	0.9074	1.0820	8.2090	14.6950	8.0581	14.3451
+4468	1996.3962	145	1.2617	0.6654	0.9074	1.0820	8.2090	14.6950	8.0634	14.3415
+4469	1996.3989	146	1.2617	0.6654	0.9074	1.0820	8.2090	14.6950	8.0687	14.3379
+4470	1996.4016	147	1.2617	0.6653	0.9074	1.0820	8.2090	14.6950	8.0741	14.3344
+4471	1996.4044	148	1.2617	0.6653	0.9074	1.0820	8.2090	14.6950	8.0794	14.3309
+4472	1996.4071	149	1.2616	0.6653	0.9074	1.0820	8.2090	14.6950	8.0848	14.3275
+4473	1996.4098	150	1.2616	0.6653	0.9074	1.0820	8.2090	14.6950	8.0902	14.3242
+4474	1996.4126	151	1.2616	0.6653	0.9074	1.0820	8.2090	14.6950	8.0956	14.3210
+4475	1996.4153	152	1.2616	0.6653	0.9074	1.0820	8.2090	14.6950	8.1010	14.3179
+4476	1996.4180	153	1.2616	0.6653	0.9074	1.0820	8.2090	14.6950	8.1064	14.3148
+4477	1996.4208	154	1.2615	0.6653	0.9074	1.0820	8.2090	14.6950	8.1117	14.3118
+4478	1996.4235	155	1.2615	0.6653	0.9073	1.0820	8.2090	14.6950	8.1171	14.3089
+4479	1996.4262	156	1.2615	0.6653	0.9073	1.0820	8.2090	14.6950	8.1223	14.3061
+4480	1996.4290	157	1.2615	0.6652	0.9073	1.0820	8.2090	14.6950	8.1276	14.3033
+4481	1996.4317	158	1.2615	0.6652	0.9073	1.0820	8.2090	14.6950	8.1328	14.3007
+4482	1996.4344	159	1.2614	0.6652	0.9073	1.0820	8.2090	14.6950	8.1379	14.2981
+4483	1996.4372	160	1.2614	0.6652	0.9073	1.0820	8.2090	14.6950	8.1430	14.2956
+4484	1996.4399	161	1.2614	0.6652	0.9073	1.0820	8.2090	14.6950	8.1480	14.2932
+4485	1996.4426	162	1.2614	0.6652	0.9073	1.0820	8.2090	14.6950	8.1529	14.2909
+4486	1996.4454	163	1.2614	0.6652	0.9073	1.0820	8.2090	14.6950	8.1578	14.2887
+4487	1996.4481	164	1.2613	0.6652	0.9073	1.0820	8.2090	14.6950	8.1625	14.2866
+4488	1996.4508	165	1.2613	0.6652	0.9073	1.0820	8.2090	14.6950	8.1671	14.2845
+4489	1996.4536	166	1.2613	0.6652	0.9073	1.0820	8.2090	14.6950	8.1717	14.2826
+4490	1996.4563	167	1.2613	0.6651	0.9073	1.0820	8.2090	14.6950	8.1761	14.2807
+4491	1996.4590	168	1.2613	0.6651	0.9073	1.0820	8.2090	14.6950	8.1804	14.2789
+4492	1996.4617	169	1.2612	0.6651	0.9073	1.0820	8.2090	14.6950	8.1846	14.2773
+4493	1996.4645	170	1.2612	0.6651	0.9073	1.0820	8.2090	14.6950	8.1886	14.2757
+4494	1996.4672	171	1.2612	0.6651	0.9073	1.0820	8.2090	14.6950	8.1925	14.2742
+4495	1996.4699	172	1.2612	0.6651	0.9073	1.0820	8.2090	14.6950	8.1963	14.2728
+4496	1996.4727	173	1.2612	0.6651	0.9073	1.0820	8.2090	14.6950	8.1999	14.2715
+4497	1996.4754	174	1.2611	0.6651	0.9073	1.0820	8.2090	14.6950	8.2033	14.2703
+4498	1996.4781	175	1.2611	0.6651	0.9073	1.0820	8.2090	14.6950	8.2066	14.2692
+4499	1996.4809	176	1.2611	0.6651	0.9073	1.0820	8.2090	14.6950	8.2098	14.2681
+4500	1996.4836	177	1.2611	0.6650	0.9073	1.0820	8.2090	14.6950	8.2127	14.2672
+4501	1996.4863	178	1.2611	0.6650	0.9073	1.0820	8.2090	14.6950	8.2155	14.2664
+4502	1996.4891	179	1.2610	0.6650	0.9073	1.0820	8.2090	14.6950	8.2181	14.2657
+4503	1996.4918	180	1.2610	0.6650	0.9073	1.0820	8.2090	14.6950	8.2206	14.2650
+4504	1996.4945	181	1.2610	0.6650	0.9073	1.0820	8.2090	14.6950	8.2228	14.2645
+4505	1996.4973	182	1.2610	0.6650	0.9073	1.0820	8.2090	14.6950	8.2249	14.2640
+4506	1996.5000	183	1.2610	0.6650	0.9073	1.0820	8.2090	14.6950	8.2267	14.2637
+4507	1996.5027	184	1.2609	0.6650	0.9073	1.0820	8.2090	14.6950	8.2284	14.2634
+4508	1996.5055	185	1.2609	0.6650	0.9073	1.0820	8.2090	14.6950	8.2299	14.2632
+4509	1996.5082	186	1.2609	0.6650	0.9073	1.0820	8.2090	14.6950	8.2312	14.2632
+4510	1996.5109	187	1.2609	0.6649	0.9073	1.0820	8.2090	14.6950	8.2323	14.2632
+4511	1996.5137	188	1.2609	0.6649	0.9073	1.0820	8.2090	14.6950	8.2331	14.2633
+4512	1996.5164	189	1.2608	0.6649	0.9072	1.0820	8.2090	14.6950	8.2338	14.2635
+4513	1996.5191	190	1.2608	0.6649	0.9072	1.0820	8.2090	14.6950	8.2343	14.2638
+4514	1996.5219	191	1.2608	0.6649	0.9072	1.0820	8.2090	14.6950	8.2345	14.2642
+4515	1996.5246	192	1.2608	0.6649	0.9072	1.0820	8.2090	14.6950	8.2346	14.2647
+4516	1996.5273	193	1.2608	0.6649	0.9072	1.0820	8.2090	14.6950	8.2344	14.2652
+4517	1996.5301	194	1.2607	0.6649	0.9072	1.0820	8.2090	14.6950	8.2341	14.2659
+4518	1996.5328	195	1.2607	0.6649	0.9072	1.0820	8.2090	14.6950	8.2335	14.2666
+4519	1996.5355	196	1.2607	0.6649	0.9072	1.0820	8.2090	14.6950	8.2328	14.2675
+4520	1996.5383	197	1.2607	0.6649	0.9072	1.0820	8.2090	14.6950	8.2318	14.2684
+4521	1996.5410	198	1.2607	0.6648	0.9072	1.0820	8.2090	14.6950	8.2306	14.2694
+4522	1996.5437	199	1.2606	0.6648	0.9072	1.0820	8.2090	14.6950	8.2293	14.2705
+4523	1996.5464	200	1.2606	0.6648	0.9072	1.0820	8.2090	14.6950	8.2277	14.2716
+4524	1996.5492	201	1.2606	0.6648	0.9072	1.0820	8.2090	14.6950	8.2259	14.2729
+4525	1996.5519	202	1.2606	0.6648	0.9072	1.0820	8.2090	14.6950	8.2240	14.2742
+4526	1996.5546	203	1.2606	0.6648	0.9072	1.0820	8.2090	14.6950	8.2218	14.2756
+4527	1996.5574	204	1.2606	0.6648	0.9072	1.0820	8.2090	14.6950	8.2195	14.2771
+4528	1996.5601	205	1.2605	0.6648	0.9072	1.0820	8.2090	14.6950	8.2169	14.2787
+4529	1996.5628	206	1.2605	0.6648	0.9072	1.0820	8.2090	14.6950	8.2142	14.2803
+4530	1996.5656	207	1.2605	0.6648	0.9072	1.0820	8.2090	14.6950	8.2113	14.2821
+4531	1996.5683	208	1.2605	0.6647	0.9072	1.0820	8.2090	14.6950	8.2083	14.2839
+4532	1996.5710	209	1.2605	0.6647	0.9072	1.0820	8.2090	14.6950	8.2050	14.2857
+4533	1996.5738	210	1.2604	0.6647	0.9072	1.0820	8.2090	14.6950	8.2016	14.2877
+4534	1996.5765	211	1.2604	0.6647	0.9072	1.0820	8.2090	14.6950	8.1981	14.2897
+4535	1996.5792	212	1.2604	0.6647	0.9072	1.0820	8.2090	14.6950	8.1944	14.2917
+4536	1996.5820	213	1.2604	0.6647	0.9072	1.0820	8.2090	14.6950	8.1905	14.2939
+4537	1996.5847	214	1.2604	0.6647	0.9072	1.0820	8.2090	14.6950	8.1865	14.2961
+4538	1996.5874	215	1.2603	0.6647	0.9072	1.0820	8.2090	14.6950	8.1823	14.2984
+4539	1996.5902	216	1.2603	0.6647	0.9072	1.0820	8.2090	14.6950	8.1781	14.3007
+4540	1996.5929	217	1.2603	0.6647	0.9072	1.0820	8.2090	14.6950	8.1736	14.3031
+4541	1996.5956	218	1.2603	0.6646	0.9072	1.0820	8.2090	14.6950	8.1691	14.3055
+4542	1996.5984	219	1.2603	0.6646	0.9072	1.0820	8.2090	14.6950	8.1645	14.3080
+4543	1996.6011	220	1.2602	0.6646	0.9072	1.0820	8.2090	14.6950	8.1597	14.3106
+4544	1996.6038	221	1.2602	0.6646	0.9072	1.0820	8.2090	14.6950	8.1548	14.3132
+4545	1996.6066	222	1.2602	0.6646	0.9072	1.0820	8.2090	14.6950	8.1499	14.3159
+4546	1996.6093	223	1.2602	0.6646	0.9072	1.0820	8.2090	14.6950	8.1448	14.3186
+4547	1996.6120	224	1.2602	0.6646	0.9071	1.0820	8.2090	14.6950	8.1397	14.3213
+4548	1996.6148	225	1.2601	0.6646	0.9071	1.0820	8.2090	14.6950	8.1345	14.3241
+4549	1996.6175	226	1.2601	0.6646	0.9071	1.0820	8.2090	14.6950	8.1292	14.3270
+4550	1996.6202	227	1.2601	0.6646	0.9071	1.0820	8.2090	14.6950	8.1238	14.3299
+4551	1996.6230	228	1.2601	0.6645	0.9071	1.0820	8.2090	14.6950	8.1184	14.3328
+4552	1996.6257	229	1.2601	0.6645	0.9071	1.0820	8.2090	14.6950	8.1130	14.3358
+4553	1996.6284	230	1.2600	0.6645	0.9071	1.0820	8.2090	14.6950	8.1075	14.3388
+4554	1996.6311	231	1.2600	0.6645	0.9071	1.0820	8.2090	14.6950	8.1020	14.3418
+4555	1996.6339	232	1.2600	0.6645	0.9071	1.0820	8.2090	14.6950	8.0964	14.3449
+4556	1996.6366	233	1.2600	0.6645	0.9071	1.0820	8.2090	14.6950	8.0908	14.3479
+4557	1996.6393	234	1.2600	0.6645	0.9071	1.0820	8.2090	14.6950	8.0852	14.3511
+4558	1996.6421	235	1.2599	0.6645	0.9071	1.0820	8.2090	14.6950	8.0796	14.3542
+4559	1996.6448	236	1.2599	0.6645	0.9071	1.0820	8.2090	14.6950	8.0740	14.3574
+4560	1996.6475	237	1.2599	0.6645	0.9071	1.0820	8.2090	14.6950	8.0684	14.3606
+4561	1996.6503	238	1.2599	0.6645	0.9071	1.0820	8.2090	14.6950	8.0628	14.3638
+4562	1996.6530	239	1.2599	0.6644	0.9071	1.0820	8.2090	14.6950	8.0573	14.3670
+4563	1996.6557	240	1.2598	0.6644	0.9071	1.0820	8.2090	14.6950	8.0517	14.3702
+4564	1996.6585	241	1.2598	0.6644	0.9071	1.0820	8.2090	14.6950	8.0462	14.3735
+4565	1996.6612	242	1.2598	0.6644	0.9071	1.0820	8.2090	14.6950	8.0408	14.3768
+4566	1996.6639	243	1.2598	0.6644	0.9071	1.0820	8.2090	14.6950	8.0354	14.3800
+4567	1996.6667	244	1.2598	0.6644	0.9071	1.0820	8.2090	14.6950	8.0300	14.3833
+4568	1996.6694	245	1.2597	0.6644	0.9071	1.0820	8.2090	14.6950	8.0247	14.3866
+4569	1996.6721	246	1.2597	0.6644	0.9071	1.0820	8.2090	14.6950	8.0195	14.3898
+4570	1996.6749	247	1.2597	0.6644	0.9071	1.0820	8.2090	14.6950	8.0143	14.3931
+4571	1996.6776	248	1.2597	0.6644	0.9071	1.0820	8.2090	14.6950	8.0092	14.3964
+4572	1996.6803	249	1.2597	0.6643	0.9071	1.0820	8.2090	14.6950	8.0042	14.3997
+4573	1996.6831	250	1.2597	0.6643	0.9071	1.0820	8.2090	14.6950	7.9993	14.4029
+4574	1996.6858	251	1.2596	0.6643	0.9071	1.0820	8.2090	14.6950	7.9945	14.4062
+4575	1996.6885	252	1.2596	0.6643	0.9071	1.0820	8.2090	14.6950	7.9898	14.4094
+4576	1996.6913	253	1.2596	0.6643	0.9071	1.0820	8.2090	14.6950	7.9852	14.4126
+4577	1996.6940	254	1.2596	0.6643	0.9071	1.0820	8.2090	14.6950	7.9807	14.4158
+4578	1996.6967	255	1.2596	0.6643	0.9071	1.0820	8.2090	14.6950	7.9763	14.4190
+4579	1996.6995	256	1.2595	0.6643	0.9071	1.0820	8.2090	14.6950	7.9721	14.4222
+4580	1996.7022	257	1.2595	0.6643	0.9071	1.0820	8.2090	14.6950	7.9679	14.4253
+4581	1996.7049	258	1.2595	0.6643	0.9071	1.0820	8.2090	14.6950	7.9639	14.4285
+4582	1996.7077	259	1.2595	0.6642	0.9071	1.0820	8.2090	14.6950	7.9601	14.4316
+4583	1996.7104	260	1.2595	0.6642	0.9070	1.0820	8.2090	14.6950	7.9563	14.4346
+4584	1996.7131	261	1.2594	0.6642	0.9070	1.0820	8.2090	14.6950	7.9528	14.4376
+4585	1996.7158	262	1.2594	0.6642	0.9070	1.0820	8.2090	14.6950	7.9493	14.4406
+4586	1996.7186	263	1.2594	0.6642	0.9070	1.0820	8.2090	14.6950	7.9461	14.4436
+4587	1996.7213	264	1.2594	0.6642	0.9070	1.0820	8.2090	14.6950	7.9429	14.4465
+4588	1996.7240	265	1.2594	0.6642	0.9070	1.0820	8.2090	14.6950	7.9400	14.4494
+4589	1996.7268	266	1.2593	0.6642	0.9070	1.0820	8.2090	14.6950	7.9372	14.4523
+4590	1996.7295	267	1.2593	0.6642	0.9070	1.0820	8.2090	14.6950	7.9345	14.4551
+4591	1996.7322	268	1.2593	0.6642	0.9070	1.0820	8.2090	14.6950	7.9320	14.4578
+4592	1996.7350	269	1.2593	0.6642	0.9070	1.0820	8.2090	14.6950	7.9297	14.4605
+4593	1996.7377	270	1.2593	0.6641	0.9070	1.0820	8.2090	14.6950	7.9276	14.4632
+4594	1996.7404	271	1.2592	0.6641	0.9070	1.0820	8.2090	14.6950	7.9256	14.4658
+4595	1996.7432	272	1.2592	0.6641	0.9070	1.0820	8.2090	14.6950	7.9238	14.4683
+4596	1996.7459	273	1.2592	0.6641	0.9070	1.0820	8.2090	14.6950	7.9222	14.4708
+4597	1996.7486	274	1.2592	0.6641	0.9070	1.0820	8.2090	14.6950	7.9208	14.4733
+4598	1996.7514	275	1.2592	0.6641	0.9070	1.0820	8.2090	14.6950	7.9196	14.4756
+4599	1996.7541	276	1.2592	0.6641	0.9070	1.0820	8.2090	14.6950	7.9185	14.4780
+4600	1996.7568	277	1.2591	0.6641	0.9070	1.0820	8.2090	14.6950	7.9176	14.4802
+4601	1996.7596	278	1.2591	0.6641	0.9070	1.0820	8.2090	14.6950	7.9169	14.4824
+4602	1996.7623	279	1.2591	0.6641	0.9070	1.0820	8.2090	14.6950	7.9164	14.4846
+4603	1996.7650	280	1.2591	0.6640	0.9070	1.0820	8.2090	14.6950	7.9160	14.4866
+4604	1996.7678	281	1.2591	0.6640	0.9070	1.0820	8.2090	14.6950	7.9159	14.4886
+4605	1996.7705	282	1.2590	0.6640	0.9070	1.0820	8.2090	14.6950	7.9159	14.4906
+4606	1996.7732	283	1.2590	0.6640	0.9070	1.0820	8.2090	14.6950	7.9161	14.4924
+4607	1996.7760	284	1.2590	0.6640	0.9070	1.0820	8.2090	14.6950	7.9165	14.4942
+4608	1996.7787	285	1.2590	0.6640	0.9070	1.0820	8.2090	14.6950	7.9171	14.4959
+4609	1996.7814	286	1.2590	0.6640	0.9070	1.0820	8.2090	14.6950	7.9178	14.4975
+4610	1996.7842	287	1.2589	0.6640	0.9070	1.0820	8.2090	14.6950	7.9188	14.4991
+4611	1996.7869	288	1.2589	0.6640	0.9070	1.0820	8.2090	14.6950	7.9199	14.5006
+4612	1996.7896	289	1.2589	0.6640	0.9070	1.0820	8.2090	14.6950	7.9212	14.5020
+4613	1996.7923	290	1.2589	0.6640	0.9070	1.0820	8.2090	14.6950	7.9226	14.5033
+4614	1996.7951	291	1.2589	0.6639	0.9070	1.0820	8.2090	14.6950	7.9243	14.5046
+4615	1996.7978	292	1.2588	0.6639	0.9070	1.0820	8.2090	14.6950	7.9261	14.5057
+4616	1996.8005	293	1.2588	0.6639	0.9070	1.0820	8.2090	14.6950	7.9280	14.5068
+4617	1996.8033	294	1.2588	0.6639	0.9070	1.0820	8.2090	14.6950	7.9302	14.5078
+4618	1996.8060	295	1.2588	0.6639	0.9070	1.0820	8.2090	14.6950	7.9325	14.5087
+4619	1996.8087	296	1.2588	0.6639	0.9070	1.0820	8.2090	14.6950	7.9350	14.5095
+4620	1996.8115	297	1.2588	0.6639	0.9069	1.0820	8.2090	14.6950	7.9376	14.5103
+4621	1996.8142	298	1.2587	0.6639	0.9069	1.0820	8.2090	14.6950	7.9404	14.5109
+4622	1996.8169	299	1.2587	0.6639	0.9069	1.0820	8.2090	14.6950	7.9433	14.5115
+4623	1996.8197	300	1.2587	0.6639	0.9069	1.0820	8.2090	14.6950	7.9464	14.5120
+4624	1996.8224	301	1.2587	0.6638	0.9069	1.0820	8.2090	14.6950	7.9496	14.5123
+4625	1996.8251	302	1.2587	0.6638	0.9069	1.0820	8.2090	14.6950	7.9529	14.5126
+4626	1996.8279	303	1.2586	0.6638	0.9069	1.0820	8.2090	14.6950	7.9564	14.5129
+4627	1996.8306	304	1.2586	0.6638	0.9069	1.0820	8.2090	14.6950	7.9600	14.5130
+4628	1996.8333	305	1.2586	0.6638	0.9069	1.0820	8.2090	14.6950	7.9638	14.5130
+4629	1996.8361	306	1.2586	0.6638	0.9069	1.0820	8.2090	14.6950	7.9677	14.5129
+4630	1996.8388	307	1.2586	0.6638	0.9069	1.0820	8.2090	14.6950	7.9716	14.5128
+4631	1996.8415	308	1.2585	0.6638	0.9069	1.0820	8.2090	14.6950	7.9757	14.5125
+4632	1996.8443	309	1.2585	0.6638	0.9069	1.0820	8.2090	14.6950	7.9799	14.5122
+4633	1996.8470	310	1.2585	0.6638	0.9069	1.0820	8.2090	14.6950	7.9843	14.5118
+4634	1996.8497	311	1.2585	0.6638	0.9069	1.0820	8.2090	14.6950	7.9887	14.5112
+4635	1996.8525	312	1.2585	0.6637	0.9069	1.0820	8.2090	14.6950	7.9932	14.5106
+4636	1996.8552	313	1.2584	0.6637	0.9069	1.0820	8.2090	14.6950	7.9977	14.5099
+4637	1996.8579	314	1.2584	0.6637	0.9069	1.0820	8.2090	14.6950	8.0024	14.5091
+4638	1996.8607	315	1.2584	0.6637	0.9069	1.0820	8.2090	14.6950	8.0071	14.5082
+4639	1996.8634	316	1.2584	0.6637	0.9069	1.0820	8.2090	14.6950	8.0120	14.5072
+4640	1996.8661	317	1.2584	0.6637	0.9069	1.0820	8.2090	14.6950	8.0168	14.5062
+4641	1996.8689	318	1.2584	0.6637	0.9069	1.0820	8.2090	14.6950	8.0217	14.5050
+4642	1996.8716	319	1.2583	0.6637	0.9069	1.0820	8.2090	14.6950	8.0267	14.5037
+4643	1996.8743	320	1.2583	0.6637	0.9069	1.0820	8.2090	14.6950	8.0317	14.5024
+4644	1996.8770	321	1.2583	0.6637	0.9069	1.0820	8.2090	14.6950	8.0368	14.5010
+4645	1996.8798	322	1.2583	0.6636	0.9069	1.0820	8.2090	14.6950	8.0419	14.4995
+4646	1996.8825	323	1.2583	0.6636	0.9069	1.0820	8.2090	14.6950	8.0470	14.4978
+4647	1996.8852	324	1.2582	0.6636	0.9069	1.0820	8.2090	14.6950	8.0522	14.4961
+4648	1996.8880	325	1.2582	0.6636	0.9069	1.0820	8.2090	14.6950	8.0573	14.4944
+4649	1996.8907	326	1.2582	0.6636	0.9069	1.0820	8.2090	14.6950	8.0625	14.4925
+4650	1996.8934	327	1.2582	0.6636	0.9069	1.0820	8.2090	14.6950	8.0676	14.4905
+4651	1996.8962	328	1.2582	0.6636	0.9069	1.0820	8.2090	14.6950	8.0728	14.4885
+4652	1996.8989	329	1.2581	0.6636	0.9069	1.0820	8.2090	14.6950	8.0779	14.4864
+4653	1996.9016	330	1.2581	0.6636	0.9069	1.0820	8.2090	14.6950	8.0830	14.4842
+4654	1996.9044	331	1.2581	0.6636	0.9069	1.0820	8.2090	14.6950	8.0881	14.4819
+4655	1996.9071	332	1.2581	0.6636	0.9069	1.0820	8.2090	14.6950	8.0931	14.4795
+4656	1996.9098	333	1.2581	0.6635	0.9069	1.0820	8.2090	14.6950	8.0982	14.4770
+4657	1996.9126	334	1.2581	0.6635	0.9068	1.0820	8.2090	14.6950	8.1031	14.4745
+4658	1996.9153	335	1.2580	0.6635	0.9068	1.0820	8.2090	14.6950	8.1080	14.4719
+4659	1996.9180	336	1.2580	0.6635	0.9068	1.0820	8.2090	14.6950	8.1129	14.4692
+4660	1996.9208	337	1.2580	0.6635	0.9068	1.0820	8.2090	14.6950	8.1177	14.4665
+4661	1996.9235	338	1.2580	0.6635	0.9068	1.0820	8.2090	14.6950	8.1224	14.4636
+4662	1996.9262	339	1.2580	0.6635	0.9068	1.0820	8.2090	14.6950	8.1271	14.4607
+4663	1996.9290	340	1.2579	0.6635	0.9068	1.0820	8.2090	14.6950	8.1316	14.4578
+4664	1996.9317	341	1.2579	0.6635	0.9068	1.0820	8.2090	14.6950	8.1361	14.4547
+4665	1996.9344	342	1.2579	0.6635	0.9068	1.0820	8.2090	14.6950	8.1405	14.4516
+4666	1996.9372	343	1.2579	0.6634	0.9068	1.0820	8.2090	14.6950	8.1447	14.4484
+4667	1996.9399	344	1.2579	0.6634	0.9068	1.0820	8.2090	14.6950	8.1489	14.4452
+4668	1996.9426	345	1.2578	0.6634	0.9068	1.0820	8.2090	14.6950	8.1529	14.4418
+4669	1996.9454	346	1.2578	0.6634	0.9068	1.0820	8.2090	14.6950	8.1569	14.4385
+4670	1996.9481	347	1.2578	0.6634	0.9068	1.0820	8.2090	14.6950	8.1607	14.4350
+4671	1996.9508	348	1.2578	0.6634	0.9068	1.0820	8.2090	14.6950	8.1644	14.4315
+4672	1996.9536	349	1.2578	0.6634	0.9068	1.0820	8.2090	14.6950	8.1679	14.4280
+4673	1996.9563	350	1.2578	0.6634	0.9068	1.0820	8.2090	14.6950	8.1713	14.4244
+4674	1996.9590	351	1.2577	0.6634	0.9068	1.0820	8.2090	14.6950	8.1746	14.4207
+4675	1996.9617	352	1.2577	0.6634	0.9068	1.0820	8.2090	14.6950	8.1777	14.4170
+4676	1996.9645	353	1.2577	0.6634	0.9068	1.0820	8.2090	14.6950	8.1807	14.4132
+4677	1996.9672	354	1.2577	0.6633	0.9068	1.0820	8.2090	14.6950	8.1835	14.4094
+4678	1996.9699	355	1.2577	0.6633	0.9068	1.0820	8.2090	14.6950	8.1861	14.4056
+4679	1996.9727	356	1.2576	0.6633	0.9068	1.0820	8.2090	14.6950	8.1886	14.4016
+4680	1996.9754	357	1.2576	0.6633	0.9068	1.0820	8.2090	14.6950	8.1910	14.3977
+4681	1996.9781	358	1.2576	0.6633	0.9068	1.0820	8.2090	14.6950	8.1931	14.3937
+4682	1996.9809	359	1.2576	0.6633	0.9068	1.0820	8.2090	14.6950	8.1951	14.3897
+4683	1996.9836	360	1.2576	0.6633	0.9068	1.0820	8.2090	14.6950	8.1969	14.3856
+4684	1996.9863	361	1.2575	0.6633	0.9068	1.0820	8.2090	14.6950	8.1985	14.3815
+4685	1996.9891	362	1.2575	0.6633	0.9068	1.0820	8.2090	14.6950	8.2000	14.3773
+4686	1996.9918	363	1.2575	0.6633	0.9068	1.0820	8.2090	14.6950	8.2012	14.3732
+4687	1996.9945	364	1.2575	0.6633	0.9068	1.0820	8.2090	14.6950	8.2023	14.3690
+4688	1996.9973	365	1.2575	0.6632	0.9068	1.0820	8.2090	14.6950	8.2032	14.3647
+4689	1996.9999	366	1.2575	0.6632	0.9068	1.0820	8.2090	14.6950	8.2039	14.3605
+4690	1997.0027	1	1.2574	0.6632	0.9068	1.0820	8.2090	14.6950	8.2044	14.3562
+4691	1997.0055	2	1.2574	0.6632	0.9068	1.0820	8.2090	14.6950	8.2048	14.3519
+4692	1997.0082	3	1.2574	0.6632	0.9068	1.0820	8.2090	14.6950	8.2049	14.3475
+4693	1997.0110	4	1.2574	0.6632	0.9068	1.0820	8.2090	14.6950	8.2049	14.3432
+4694	1997.0137	5	1.2574	0.6632	0.9068	1.0820	8.2090	14.6950	8.2046	14.3388
+4695	1997.0164	6	1.2573	0.6632	0.9067	1.0820	8.2090	14.6950	8.2042	14.3345
+4696	1997.0192	7	1.2573	0.6632	0.9067	1.0820	8.2090	14.6950	8.2036	14.3301
+4697	1997.0219	8	1.2573	0.6632	0.9067	1.0820	8.2090	14.6950	8.2028	14.3257
+4698	1997.0247	9	1.2573	0.6631	0.9067	1.0820	8.2090	14.6950	8.2018	14.3213
+4699	1997.0274	10	1.2573	0.6631	0.9067	1.0820	8.2090	14.6950	8.2006	14.3168
+4700	1997.0301	11	1.2573	0.6631	0.9067	1.0820	8.2090	14.6950	8.1993	14.3124
+4701	1997.0329	12	1.2572	0.6631	0.9067	1.0820	8.2090	14.6950	8.1978	14.3080
+4702	1997.0356	13	1.2572	0.6631	0.9067	1.0820	8.2090	14.6950	8.1960	14.3036
+4703	1997.0384	14	1.2572	0.6631	0.9067	1.0820	8.2090	14.6950	8.1941	14.2992
+4704	1997.0411	15	1.2572	0.6631	0.9067	1.0820	8.2090	14.6950	8.1921	14.2947
+4705	1997.0438	16	1.2572	0.6631	0.9067	1.0820	8.2090	14.6950	8.1898	14.2903
+4706	1997.0466	17	1.2571	0.6631	0.9067	1.0820	8.2090	14.6950	8.1874	14.2859
+4707	1997.0493	18	1.2571	0.6631	0.9067	1.0820	8.2090	14.6950	8.1848	14.2815
+4708	1997.0521	19	1.2571	0.6631	0.9067	1.0820	8.2090	14.6950	8.1821	14.2771
+4709	1997.0548	20	1.2571	0.6630	0.9067	1.0820	8.2090	14.6950	8.1792	14.2728
+4710	1997.0575	21	1.2571	0.6630	0.9067	1.0820	8.2090	14.6950	8.1761	14.2684
+4711	1997.0603	22	1.2570	0.6630	0.9067	1.0820	8.2090	14.6950	8.1729	14.2641
+4712	1997.0630	23	1.2570	0.6630	0.9067	1.0820	8.2090	14.6950	8.1695	14.2598
+4713	1997.0658	24	1.2570	0.6630	0.9067	1.0820	8.2090	14.6950	8.1660	14.2555
+4714	1997.0685	25	1.2570	0.6630	0.9067	1.0820	8.2090	14.6950	8.1623	14.2512
+4715	1997.0712	26	1.2570	0.6630	0.9067	1.0820	8.2090	14.6950	8.1586	14.2469
+4716	1997.0740	27	1.2570	0.6630	0.9067	1.0820	8.2090	14.6950	8.1546	14.2427
+4717	1997.0767	28	1.2569	0.6630	0.9067	1.0820	8.2090	14.6950	8.1506	14.2385
+4718	1997.0795	29	1.2569	0.6630	0.9067	1.0820	8.2090	14.6950	8.1464	14.2343
+4719	1997.0822	30	1.2569	0.6630	0.9067	1.0820	8.2090	14.6950	8.1422	14.2302
+4720	1997.0849	31	1.2569	0.6629	0.9067	1.0820	8.2090	14.6950	8.1378	14.2261
+4721	1997.0877	32	1.2569	0.6629	0.9067	1.0820	8.2090	14.6950	8.1333	14.2220
+4722	1997.0904	33	1.2568	0.6629	0.9067	1.0820	8.2090	14.6950	8.1287	14.2180
+4723	1997.0932	34	1.2568	0.6629	0.9067	1.0820	8.2090	14.6950	8.1240	14.2140
+4724	1997.0959	35	1.2568	0.6629	0.9067	1.0820	8.2090	14.6950	8.1193	14.2101
+4725	1997.0986	36	1.2568	0.6629	0.9067	1.0820	8.2090	14.6950	8.1144	14.2062
+4726	1997.1014	37	1.2568	0.6629	0.9067	1.0820	8.2090	14.6950	8.1095	14.2023
+4727	1997.1041	38	1.2568	0.6629	0.9067	1.0820	8.2090	14.6950	8.1045	14.1985
+4728	1997.1068	39	1.2567	0.6629	0.9067	1.0820	8.2090	14.6950	8.0994	14.1947
+4729	1997.1096	40	1.2567	0.6629	0.9067	1.0820	8.2090	14.6950	8.0943	14.1910
+4730	1997.1123	41	1.2567	0.6629	0.9067	1.0820	8.2090	14.6950	8.0891	14.1873
+4731	1997.1151	42	1.2567	0.6628	0.9067	1.0820	8.2090	14.6950	8.0839	14.1837
+4732	1997.1178	43	1.2567	0.6628	0.9067	1.0820	8.2090	14.6950	8.0787	14.1801
+4733	1997.1205	44	1.2566	0.6628	0.9067	1.0820	8.2090	14.6950	8.0734	14.1766
+4734	1997.1233	45	1.2566	0.6628	0.9067	1.0820	8.2090	14.6950	8.0681	14.1731
+4735	1997.1260	46	1.2566	0.6628	0.9066	1.0820	8.2090	14.6950	8.0628	14.1697
+4736	1997.1288	47	1.2566	0.6628	0.9066	1.0820	8.2090	14.6950	8.0574	14.1664
+4737	1997.1315	48	1.2566	0.6628	0.9066	1.0820	8.2090	14.6950	8.0521	14.1631
+4738	1997.1342	49	1.2566	0.6628	0.9066	1.0820	8.2090	14.6950	8.0467	14.1599
+4739	1997.1370	50	1.2565	0.6628	0.9066	1.0820	8.2090	14.6950	8.0414	14.1567
+4740	1997.1397	51	1.2565	0.6628	0.9066	1.0820	8.2090	14.6950	8.0360	14.1536
+4741	1997.1425	52	1.2565	0.6627	0.9066	1.0820	8.2090	14.6950	8.0307	14.1506
+4742	1997.1452	53	1.2565	0.6627	0.9066	1.0820	8.2090	14.6950	8.0254	14.1476
+4743	1997.1479	54	1.2565	0.6627	0.9066	1.0820	8.2090	14.6950	8.0201	14.1447
+4744	1997.1507	55	1.2564	0.6627	0.9066	1.0820	8.2090	14.6950	8.0149	14.1419
+4745	1997.1534	56	1.2564	0.6627	0.9066	1.0820	8.2090	14.6950	8.0097	14.1391
+4746	1997.1562	57	1.2564	0.6627	0.9066	1.0820	8.2090	14.6950	8.0046	14.1364
+4747	1997.1589	58	1.2564	0.6627	0.9066	1.0820	8.2090	14.6950	7.9995	14.1338
+4748	1997.1616	59	1.2564	0.6627	0.9066	1.0820	8.2090	14.6950	7.9944	14.1312
+4749	1997.1644	60	1.2564	0.6627	0.9066	1.0820	8.2090	14.6950	7.9894	14.1287
+4750	1997.1671	61	1.2563	0.6627	0.9066	1.0820	8.2090	14.6950	7.9845	14.1263
+4751	1997.1699	62	1.2563	0.6627	0.9066	1.0820	8.2090	14.6950	7.9797	14.1240
+4752	1997.1726	63	1.2563	0.6626	0.9066	1.0820	8.2090	14.6950	7.9749	14.1217
+4753	1997.1753	64	1.2563	0.6626	0.9066	1.0820	8.2090	14.6950	7.9703	14.1195
+4754	1997.1781	65	1.2563	0.6626	0.9066	1.0820	8.2090	14.6950	7.9657	14.1174
+4755	1997.1808	66	1.2562	0.6626	0.9066	1.0820	8.2090	14.6950	7.9612	14.1154
+4756	1997.1836	67	1.2562	0.6626	0.9066	1.0820	8.2090	14.6950	7.9568	14.1134
+4757	1997.1863	68	1.2562	0.6626	0.9066	1.0820	8.2090	14.6950	7.9525	14.1115
+4758	1997.1890	69	1.2562	0.6626	0.9066	1.0820	8.2090	14.6950	7.9484	14.1097
+4759	1997.1918	70	1.2562	0.6626	0.9066	1.0820	8.2090	14.6950	7.9443	14.1080
+4760	1997.1945	71	1.2562	0.6626	0.9066	1.0820	8.2090	14.6950	7.9403	14.1064
+4761	1997.1973	72	1.2561	0.6626	0.9066	1.0820	8.2090	14.6950	8.2090	14.6950
+4762	1997.2000	73	1.2561	0.6626	0.9066	1.0820	8.2090	14.6950	8.2048	14.6949
+4763	1997.2027	74	1.2561	0.6625	0.9066	1.0820	8.2090	14.6950	8.2005	14.6948
+4764	1997.2055	75	1.2561	0.6625	0.9066	1.0820	8.2090	14.6950	8.1961	14.6945
+4765	1997.2082	76	1.2561	0.6625	0.9066	1.0820	8.2090	14.6950	8.1916	14.6942
+4766	1997.2110	77	1.2560	0.6625	0.9066	1.0820	8.2090	14.6950	8.1870	14.6937
+4767	1997.2137	78	1.2560	0.6625	0.9066	1.0820	8.2090	14.6950	8.1823	14.6932
+4768	1997.2164	79	1.2560	0.6625	0.9066	1.0820	8.2090	14.6950	8.1775	14.6926
+4769	1997.2192	80	1.2560	0.6625	0.9066	1.0820	8.2090	14.6950	8.1726	14.6919
+4770	1997.2219	81	1.2560	0.6625	0.9066	1.0820	8.2090	14.6950	8.1676	14.6911
+4771	1997.2247	82	1.2560	0.6625	0.9066	1.0820	8.2090	14.6950	8.1626	14.6902
+4772	1997.2274	83	1.2559	0.6625	0.9066	1.0820	8.2090	14.6950	8.1575	14.6893
+4773	1997.2301	84	1.2559	0.6625	0.9066	1.0820	8.2090	14.6950	8.1524	14.6882
+4774	1997.2329	85	1.2559	0.6624	0.9066	1.0820	8.2090	14.6950	8.1472	14.6871
+4775	1997.2356	86	1.2559	0.6624	0.9065	1.0820	8.2090	14.6950	8.1420	14.6859
+4776	1997.2384	87	1.2559	0.6624	0.9065	1.0820	8.2090	14.6950	8.1367	14.6845
+4777	1997.2411	88	1.2558	0.6624	0.9065	1.0820	8.2090	14.6950	8.1314	14.6831
+4778	1997.2438	89	1.2558	0.6624	0.9065	1.0820	8.2090	14.6950	8.1261	14.6817
+4779	1997.2466	90	1.2558	0.6624	0.9065	1.0820	8.2090	14.6950	8.1207	14.6801
+4780	1997.2493	91	1.2558	0.6624	0.9065	1.0820	8.2090	14.6950	8.1154	14.6784
+4781	1997.2521	92	1.2558	0.6624	0.9065	1.0820	8.2090	14.6950	8.1100	14.6767
+4782	1997.2548	93	1.2558	0.6624	0.9065	1.0820	8.2090	14.6950	8.1046	14.6749
+4783	1997.2575	94	1.2557	0.6624	0.9065	1.0820	8.2090	14.6950	8.0992	14.6730
+4784	1997.2603	95	1.2557	0.6624	0.9065	1.0820	8.2090	14.6950	8.0939	14.6710
+4785	1997.2630	96	1.2557	0.6623	0.9065	1.0820	8.2090	14.6950	8.0885	14.6689
+4786	1997.2658	97	1.2557	0.6623	0.9065	1.0820	8.2090	14.6950	8.0832	14.6668
+4787	1997.2685	98	1.2557	0.6623	0.9065	1.0820	8.2090	14.6950	8.0779	14.6645
+4788	1997.2712	99	1.2557	0.6623	0.9065	1.0820	8.2090	14.6950	8.0726	14.6622
+4789	1997.2740	100	1.2556	0.6623	0.9065	1.0820	8.2090	14.6950	8.0674	14.6598
+4790	1997.2767	101	1.2556	0.6623	0.9065	1.0820	8.2090	14.6950	8.0622	14.6574
+4791	1997.2795	102	1.2556	0.6623	0.9065	1.0820	8.2090	14.6950	8.0571	14.6548
+4792	1997.2822	103	1.2556	0.6623	0.9065	1.0820	8.2090	14.6950	8.0520	14.6522
+4793	1997.2849	104	1.2556	0.6623	0.9065	1.0820	8.2090	14.6950	8.0470	14.6495
+4794	1997.2877	105	1.2555	0.6623	0.9065	1.0820	8.2090	14.6950	8.0420	14.6468
+4795	1997.2904	106	1.2555	0.6623	0.9065	1.0820	8.2090	14.6950	8.0372	14.6440
+4796	1997.2932	107	1.2555	0.6622	0.9065	1.0820	8.2090	14.6950	8.0324	14.6411
+4797	1997.2959	108	1.2555	0.6622	0.9065	1.0820	8.2090	14.6950	8.0277	14.6381
+4798	1997.2986	109	1.2555	0.6622	0.9065	1.0820	8.2090	14.6950	8.0230	14.6351
+4799	1997.3014	110	1.2555	0.6622	0.9065	1.0820	8.2090	14.6950	8.0185	14.6320
+4800	1997.3041	111	1.2554	0.6622	0.9065	1.0820	8.2090	14.6950	8.0141	14.6288
+4801	1997.3068	112	1.2554	0.6622	0.9065	1.0820	8.2090	14.6950	8.0097	14.6256
+4802	1997.3096	113	1.2554	0.6622	0.9065	1.0820	8.2090	14.6950	8.0055	14.6223
+4803	1997.3123	114	1.2554	0.6622	0.9065	1.0820	8.2090	14.6950	8.0014	14.6189
+4804	1997.3151	115	1.2554	0.6622	0.9065	1.0820	8.2090	14.6950	7.9974	14.6155
+4805	1997.3178	116	1.2553	0.6622	0.9065	1.0820	8.2090	14.6950	7.9935	14.6120
+4806	1997.3205	117	1.2553	0.6622	0.9065	1.0820	8.2090	14.6950	7.9897	14.6085
+4807	1997.3233	118	1.2553	0.6621	0.9065	1.0820	8.2090	14.6950	7.9861	14.6049
+4808	1997.3260	119	1.2553	0.6621	0.9065	1.0820	8.2090	14.6950	7.9826	14.6013
+4809	1997.3288	120	1.2553	0.6621	0.9065	1.0820	8.2090	14.6950	7.9792	14.5976
+4810	1997.3315	121	1.2553	0.6621	0.9065	1.0820	8.2090	14.6950	7.9760	14.5939
+4811	1997.3342	122	1.2552	0.6621	0.9065	1.0820	8.2090	14.6950	7.9729	14.5901
+4812	1997.3370	123	1.2552	0.6621	0.9065	1.0820	8.2090	14.6950	7.9699	14.5863
+4813	1997.3397	124	1.2552	0.6621	0.9065	1.0820	8.2090	14.6950	7.9671	14.5824
+4814	1997.3425	125	1.2552	0.6621	0.9065	1.0820	8.2090	14.6950	7.9644	14.5785
+4815	1997.3452	126	1.2552	0.6621	0.9065	1.0820	8.2090	14.6950	7.9619	14.5746
+4816	1997.3479	127	1.2552	0.6621	0.9064	1.0820	8.2090	14.6950	7.9596	14.5706
+4817	1997.3507	128	1.2551	0.6621	0.9064	1.0820	8.2090	14.6950	7.9573	14.5666
+4818	1997.3534	129	1.2551	0.6620	0.9064	1.0820	8.2090	14.6950	7.9553	14.5625
+4819	1997.3562	130	1.2551	0.6620	0.9064	1.0820	8.2090	14.6950	7.9534	14.5584
+4820	1997.3589	131	1.2551	0.6620	0.9064	1.0820	8.2090	14.6950	7.9517	14.5543
+4821	1997.3616	132	1.2551	0.6620	0.9064	1.0820	8.2090	14.6950	7.9501	14.5501
+4822	1997.3644	133	1.2550	0.6620	0.9064	1.0820	8.2090	14.6950	7.9487	14.5459
+4823	1997.3671	134	1.2550	0.6620	0.9064	1.0820	8.2090	14.6950	7.9475	14.5417
+4824	1997.3699	135	1.2550	0.6620	0.9064	1.0820	8.2090	14.6950	7.9464	14.5375
+4825	1997.3726	136	1.2550	0.6620	0.9064	1.0820	8.2090	14.6950	7.9455	14.5332
+4826	1997.3753	137	1.2550	0.6620	0.9064	1.0820	8.2090	14.6950	7.9447	14.5289
+4827	1997.3781	138	1.2550	0.6620	0.9064	1.0820	8.2090	14.6950	7.9441	14.5246
+4828	1997.3808	139	1.2549	0.6620	0.9064	1.0820	8.2090	14.6950	7.9437	14.5203
+4829	1997.3836	140	1.2549	0.6619	0.9064	1.0820	8.2090	14.6950	7.9435	14.5160
+4830	1997.3863	141	1.2549	0.6619	0.9064	1.0820	8.2090	14.6950	7.9434	14.5116
+4831	1997.3890	142	1.2549	0.6619	0.9064	1.0820	8.2090	14.6950	7.9435	14.5073
+4832	1997.3918	143	1.2549	0.6619	0.9064	1.0820	8.2090	14.6950	7.9438	14.5029
+4833	1997.3945	144	1.2549	0.6619	0.9064	1.0820	8.2090	14.6950	7.9442	14.4985
+4834	1997.3973	145	1.2548	0.6619	0.9064	1.0820	8.2090	14.6950	7.9448	14.4941
+4835	1997.4000	146	1.2548	0.6619	0.9064	1.0820	8.2090	14.6950	7.9456	14.4897
+4836	1997.4027	147	1.2548	0.6619	0.9064	1.0820	8.2090	14.6950	7.9465	14.4853
+4837	1997.4055	148	1.2548	0.6619	0.9064	1.0820	8.2090	14.6950	7.9476	14.4809
+4838	1997.4082	149	1.2548	0.6619	0.9064	1.0820	8.2090	14.6950	7.9488	14.4766
+4839	1997.4110	150	1.2547	0.6619	0.9064	1.0820	8.2090	14.6950	7.9502	14.4722
+4840	1997.4137	151	1.2547	0.6618	0.9064	1.0820	8.2090	14.6950	7.9518	14.4678
+4841	1997.4164	152	1.2547	0.6618	0.9064	1.0820	8.2090	14.6950	7.9535	14.4634
+4842	1997.4192	153	1.2547	0.6618	0.9064	1.0820	8.2090	14.6950	7.9554	14.4591
+4843	1997.4219	154	1.2547	0.6618	0.9064	1.0820	8.2090	14.6950	7.9574	14.4547
+4844	1997.4247	155	1.2547	0.6618	0.9064	1.0820	8.2090	14.6950	7.9596	14.4504
+4845	1997.4274	156	1.2546	0.6618	0.9064	1.0820	8.2090	14.6950	7.9619	14.4460
+4846	1997.4301	157	1.2546	0.6618	0.9064	1.0820	8.2090	14.6950	7.9644	14.4417
+4847	1997.4329	158	1.2546	0.6618	0.9064	1.0820	8.2090	14.6950	7.9670	14.4374
+4848	1997.4356	159	1.2546	0.6618	0.9064	1.0820	8.2090	14.6950	7.9697	14.4332
+4849	1997.4384	160	1.2546	0.6618	0.9064	1.0820	8.2090	14.6950	7.9726	14.4289
+4850	1997.4411	161	1.2546	0.6618	0.9064	1.0820	8.2090	14.6950	7.9756	14.4247
+4851	1997.4438	162	1.2545	0.6617	0.9064	1.0820	8.2090	14.6950	7.9788	14.4205
+4852	1997.4466	163	1.2545	0.6617	0.9064	1.0820	8.2090	14.6950	7.9820	14.4163
+4853	1997.4493	164	1.2545	0.6617	0.9064	1.0820	8.2090	14.6950	7.9854	14.4121
+4854	1997.4521	165	1.2545	0.6617	0.9064	1.0820	8.2090	14.6950	7.9890	14.4080
+4855	1997.4548	166	1.2545	0.6617	0.9064	1.0820	8.2090	14.6950	7.9926	14.4039
+4856	1997.4575	167	1.2545	0.6617	0.9064	1.0820	8.2090	14.6950	7.9963	14.3999
+4857	1997.4603	168	1.2544	0.6617	0.9064	1.0820	8.2090	14.6950	8.0002	14.3959
+4858	1997.4630	169	1.2544	0.6617	0.9064	1.0820	8.2090	14.6950	8.0041	14.3919
+4859	1997.4658	170	1.2544	0.6617	0.9063	1.0820	8.2090	14.6950	8.0082	14.3879
+4860	1997.4685	171	1.2544	0.6617	0.9063	1.0820	8.2090	14.6950	8.0123	14.3840
+4861	1997.4712	172	1.2544	0.6617	0.9063	1.0820	8.2090	14.6950	8.0165	14.3802
+4862	1997.4740	173	1.2543	0.6617	0.9063	1.0820	8.2090	14.6950	8.0208	14.3763
+4863	1997.4767	174	1.2543	0.6616	0.9063	1.0820	8.2090	14.6950	8.0252	14.3726
+4864	1997.4795	175	1.2543	0.6616	0.9063	1.0820	8.2090	14.6950	8.0297	14.3688
+4865	1997.4822	176	1.2543	0.6616	0.9063	1.0820	8.2090	14.6950	8.0342	14.3651
+4866	1997.4849	177	1.2543	0.6616	0.9063	1.0820	8.2090	14.6950	8.0388	14.3615
+4867	1997.4877	178	1.2543	0.6616	0.9063	1.0820	8.2090	14.6950	8.0435	14.3579
+4868	1997.4904	179	1.2542	0.6616	0.9063	1.0820	8.2090	14.6950	8.0482	14.3544
+4869	1997.4932	180	1.2542	0.6616	0.9063	1.0820	8.2090	14.6950	8.0529	14.3509
+4870	1997.4959	181	1.2542	0.6616	0.9063	1.0820	8.2090	14.6950	8.0577	14.3475
+4871	1997.4986	182	1.2542	0.6616	0.9063	1.0820	8.2090	14.6950	8.0626	14.3441
+4872	1997.5014	183	1.2542	0.6616	0.9063	1.0820	8.2090	14.6950	8.0675	14.3408
+4873	1997.5041	184	1.2542	0.6616	0.9063	1.0820	8.2090	14.6950	8.0724	14.3375
+4874	1997.5068	185	1.2541	0.6615	0.9063	1.0820	8.2090	14.6950	8.0773	14.3343
+4875	1997.5096	186	1.2541	0.6615	0.9063	1.0820	8.2090	14.6950	8.0822	14.3311
+4876	1997.5123	187	1.2541	0.6615	0.9063	1.0820	8.2090	14.6950	8.0872	14.3281
+4877	1997.5151	188	1.2541	0.6615	0.9063	1.0820	8.2090	14.6950	8.0921	14.3250
+4878	1997.5178	189	1.2541	0.6615	0.9063	1.0820	8.2090	14.6950	8.0971	14.3221
+4879	1997.5205	190	1.2541	0.6615	0.9063	1.0820	8.2090	14.6950	8.1020	14.3192
+4880	1997.5233	191	1.2540	0.6615	0.9063	1.0820	8.2090	14.6950	8.1069	14.3164
+4881	1997.5260	192	1.2540	0.6615	0.9063	1.0820	8.2090	14.6950	8.1118	14.3136
+4882	1997.5288	193	1.2540	0.6615	0.9063	1.0820	8.2090	14.6950	8.1167	14.3109
+4883	1997.5315	194	1.2540	0.6615	0.9063	1.0820	8.2090	14.6950	8.1216	14.3083
+4884	1997.5342	195	1.2540	0.6615	0.9063	1.0820	8.2090	14.6950	8.1264	14.3057
+4885	1997.5370	196	1.2539	0.6614	0.9063	1.0820	8.2090	14.6950	8.1312	14.3032
+4886	1997.5397	197	1.2539	0.6614	0.9063	1.0820	8.2090	14.6950	8.1359	14.3008
+4887	1997.5425	198	1.2539	0.6614	0.9063	1.0820	8.2090	14.6950	8.1406	14.2984
+4888	1997.5452	199	1.2539	0.6614	0.9063	1.0820	8.2090	14.6950	8.1452	14.2961
+4889	1997.5479	200	1.2539	0.6614	0.9063	1.0820	8.2090	14.6950	8.1497	14.2939
+4890	1997.5507	201	1.2539	0.6614	0.9063	1.0820	8.2090	14.6950	8.1542	14.2918
+4891	1997.5534	202	1.2538	0.6614	0.9063	1.0820	8.2090	14.6950	8.1586	14.2897
+4892	1997.5562	203	1.2538	0.6614	0.9063	1.0820	8.2090	14.6950	8.1630	14.2878
+4893	1997.5589	204	1.2538	0.6614	0.9063	1.0820	8.2090	14.6950	8.1672	14.2858
+4894	1997.5616	205	1.2538	0.6614	0.9063	1.0820	8.2090	14.6950	8.1714	14.2840
+4895	1997.5644	206	1.2538	0.6614	0.9063	1.0820	8.2090	14.6950	8.1754	14.2822
+4896	1997.5671	207	1.2538	0.6613	0.9063	1.0820	8.2090	14.6950	8.1794	14.2806
+4897	1997.5699	208	1.2537	0.6613	0.9063	1.0820	8.2090	14.6950	8.1833	14.2789
+4898	1997.5726	209	1.2537	0.6613	0.9063	1.0820	8.2090	14.6950	8.1870	14.2774
+4899	1997.5753	210	1.2537	0.6613	0.9063	1.0820	8.2090	14.6950	8.1906	14.2760
+4900	1997.5781	211	1.2537	0.6613	0.9063	1.0820	8.2090	14.6950	8.1942	14.2746
+4901	1997.5808	212	1.2537	0.6613	0.9063	1.0820	8.2090	14.6950	8.1976	14.2733
+4902	1997.5836	213	1.2537	0.6613	0.9062	1.0820	8.2090	14.6950	8.2008	14.2721
+4903	1997.5863	214	1.2536	0.6613	0.9062	1.0820	8.2090	14.6950	8.2040	14.2709
+4904	1997.5890	215	1.2536	0.6613	0.9062	1.0820	8.2090	14.6950	8.2070	14.2698
+4905	1997.5918	216	1.2536	0.6613	0.9062	1.0820	8.2090	14.6950	8.2098	14.2689
+4906	1997.5945	217	1.2536	0.6613	0.9062	1.0820	8.2090	14.6950	8.2125	14.2680
+4907	1997.5973	218	1.2536	0.6613	0.9062	1.0820	8.2090	14.6950	8.2151	14.2671
+4908	1997.6000	219	1.2536	0.6612	0.9062	1.0820	8.2090	14.6950	8.2175	14.2664
+4909	1997.6027	220	1.2535	0.6612	0.9062	1.0820	8.2090	14.6950	8.2198	14.2657
+4910	1997.6055	221	1.2535	0.6612	0.9062	1.0820	8.2090	14.6950	8.2219	14.2651
+4911	1997.6082	222	1.2535	0.6612	0.9062	1.0820	8.2090	14.6950	8.2239	14.2646
+4912	1997.6110	223	1.2535	0.6612	0.9062	1.0820	8.2090	14.6950	8.2257	14.2642
+4913	1997.6137	224	1.2535	0.6612	0.9062	1.0820	8.2090	14.6950	8.2274	14.2638
+4914	1997.6164	225	1.2535	0.6612	0.9062	1.0820	8.2090	14.6950	8.2288	14.2635
+4915	1997.6192	226	1.2534	0.6612	0.9062	1.0820	8.2090	14.6950	8.2302	14.2633
+4916	1997.6219	227	1.2534	0.6612	0.9062	1.0820	8.2090	14.6950	8.2313	14.2632
+4917	1997.6247	228	1.2534	0.6612	0.9062	1.0820	8.2090	14.6950	8.2323	14.2632
+4918	1997.6274	229	1.2534	0.6612	0.9062	1.0820	8.2090	14.6950	8.2331	14.2632
+4919	1997.6301	230	1.2534	0.6611	0.9062	1.0820	8.2090	14.6950	8.2337	14.2633
+4920	1997.6329	231	1.2533	0.6611	0.9062	1.0820	8.2090	14.6950	8.2342	14.2635
+4921	1997.6356	232	1.2533	0.6611	0.9062	1.0820	8.2090	14.6950	8.2345	14.2638
+4922	1997.6384	233	1.2533	0.6611	0.9062	1.0820	8.2090	14.6950	8.2346	14.2641
+4923	1997.6411	234	1.2533	0.6611	0.9062	1.0820	8.2090	14.6950	8.2345	14.2645
+4924	1997.6438	235	1.2533	0.6611	0.9062	1.0820	8.2090	14.6950	8.2343	14.2650
+4925	1997.6466	236	1.2533	0.6611	0.9062	1.0820	8.2090	14.6950	8.2339	14.2656
+4926	1997.6493	237	1.2532	0.6611	0.9062	1.0820	8.2090	14.6950	8.2333	14.2662
+4927	1997.6521	238	1.2532	0.6611	0.9062	1.0820	8.2090	14.6950	8.2326	14.2669
+4928	1997.6548	239	1.2532	0.6611	0.9062	1.0820	8.2090	14.6950	8.2317	14.2677
+4929	1997.6575	240	1.2532	0.6611	0.9062	1.0820	8.2090	14.6950	8.2306	14.2685
+4930	1997.6603	241	1.2532	0.6610	0.9062	1.0820	8.2090	14.6950	8.2293	14.2695
+4931	1997.6630	242	1.2532	0.6610	0.9062	1.0820	8.2090	14.6950	8.2279	14.2705
+4932	1997.6658	243	1.2531	0.6610	0.9062	1.0820	8.2090	14.6950	8.2263	14.2715
+4933	1997.6685	244	1.2531	0.6610	0.9062	1.0820	8.2090	14.6950	8.2246	14.2726
+4934	1997.6712	245	1.2531	0.6610	0.9062	1.0820	8.2090	14.6950	8.2227	14.2738
+4935	1997.6740	246	1.2531	0.6610	0.9062	1.0820	8.2090	14.6950	8.2206	14.2751
+4936	1997.6767	247	1.2531	0.6610	0.9062	1.0820	8.2090	14.6950	8.2184	14.2764
+4937	1997.6795	248	1.2531	0.6610	0.9062	1.0820	8.2090	14.6950	8.2160	14.2778
+4938	1997.6822	249	1.2530	0.6610	0.9062	1.0820	8.2090	14.6950	8.2134	14.2793
+4939	1997.6849	250	1.2530	0.6610	0.9062	1.0820	8.2090	14.6950	8.2107	14.2808
+4940	1997.6877	251	1.2530	0.6610	0.9062	1.0820	8.2090	14.6950	8.2079	14.2824
+4941	1997.6904	252	1.2530	0.6610	0.9062	1.0820	8.2090	14.6950	8.2049	14.2841
+4942	1997.6932	253	1.2530	0.6609	0.9062	1.0820	8.2090	14.6950	8.2018	14.2858
+4943	1997.6959	254	1.2530	0.6609	0.9062	1.0820	8.2090	14.6950	8.1986	14.2875
+4944	1997.6986	255	1.2529	0.6609	0.9062	1.0820	8.2090	14.6950	8.1952	14.2893
+4945	1997.7014	256	1.2529	0.6609	0.9062	1.0820	8.2090	14.6950	8.1917	14.2912
+4946	1997.7041	257	1.2529	0.6609	0.9062	1.0820	8.2090	14.6950	8.1881	14.2932
+4947	1997.7068	258	1.2529	0.6609	0.9061	1.0820	8.2090	14.6950	8.1843	14.2951
+4948	1997.7096	259	1.2529	0.6609	0.9061	1.0820	8.2090	14.6950	8.1805	14.2972
+4949	1997.7123	260	1.2529	0.6609	0.9061	1.0820	8.2090	14.6950	8.1765	14.2993
+4950	1997.7151	261	1.2528	0.6609	0.9061	1.0820	8.2090	14.6950	8.1724	14.3014
+4951	1997.7178	262	1.2528	0.6609	0.9061	1.0820	8.2090	14.6950	8.1682	14.3036
+4952	1997.7205	263	1.2528	0.6609	0.9061	1.0820	8.2090	14.6950	8.1639	14.3059
+4953	1997.7233	264	1.2528	0.6608	0.9061	1.0820	8.2090	14.6950	8.1596	14.3081
+4954	1997.7260	265	1.2528	0.6608	0.9061	1.0820	8.2090	14.6950	8.1551	14.3105
+4955	1997.7288	266	1.2528	0.6608	0.9061	1.0820	8.2090	14.6950	8.1506	14.3129
+4956	1997.7315	267	1.2527	0.6608	0.9061	1.0820	8.2090	14.6950	8.1459	14.3153
+4957	1997.7342	268	1.2527	0.6608	0.9061	1.0820	8.2090	14.6950	8.1413	14.3177
+4958	1997.7370	269	1.2527	0.6608	0.9061	1.0820	8.2090	14.6950	8.1365	14.3202
+4959	1997.7397	270	1.2527	0.6608	0.9061	1.0820	8.2090	14.6950	8.1317	14.3228
+4960	1997.7425	271	1.2527	0.6608	0.9061	1.0820	8.2090	14.6950	8.1268	14.3253
+4961	1997.7452	272	1.2527	0.6608	0.9061	1.0820	8.2090	14.6950	8.1219	14.3280
+4962	1997.7479	273	1.2526	0.6608	0.9061	1.0820	8.2090	14.6950	8.1169	14.3306
+4963	1997.7507	274	1.2526	0.6608	0.9061	1.0820	8.2090	14.6950	8.1119	14.3333
+4964	1997.7534	275	1.2526	0.6608	0.9061	1.0820	8.2090	14.6950	8.1069	14.3360
+4965	1997.7562	276	1.2526	0.6607	0.9061	1.0820	8.2090	14.6950	8.1018	14.3387
+4966	1997.7589	277	1.2526	0.6607	0.9061	1.0820	8.2090	14.6950	8.0967	14.3415
+4967	1997.7616	278	1.2526	0.6607	0.9061	1.0820	8.2090	14.6950	8.0916	14.3443
+4968	1997.7644	279	1.2525	0.6607	0.9061	1.0820	8.2090	14.6950	8.0864	14.3471
+4969	1997.7671	280	1.2525	0.6607	0.9061	1.0820	8.2090	14.6950	8.0813	14.3499
+4970	1997.7699	281	1.2525	0.6607	0.9061	1.0820	8.2090	14.6950	8.0762	14.3528
+4971	1997.7726	282	1.2525	0.6607	0.9061	1.0820	8.2090	14.6950	8.0710	14.3557
+4972	1997.7753	283	1.2525	0.6607	0.9061	1.0820	8.2090	14.6950	8.0659	14.3586
+4973	1997.7781	284	1.2525	0.6607	0.9061	1.0820	8.2090	14.6950	8.0608	14.3615
+4974	1997.7808	285	1.2524	0.6607	0.9061	1.0820	8.2090	14.6950	8.0557	14.3644
+4975	1997.7836	286	1.2524	0.6607	0.9061	1.0820	8.2090	14.6950	8.0506	14.3673
+4976	1997.7863	287	1.2524	0.6607	0.9061	1.0820	8.2090	14.6950	8.0456	14.3703
+4977	1997.7890	288	1.2524	0.6606	0.9061	1.0820	8.2090	14.6950	8.0406	14.3733
+4978	1997.7918	289	1.2524	0.6606	0.9061	1.0820	8.2090	14.6950	8.0356	14.3762
+4979	1997.7945	290	1.2524	0.6606	0.9061	1.0820	8.2090	14.6950	8.0307	14.3792
+4980	1997.7973	291	1.2523	0.6606	0.9061	1.0820	8.2090	14.6950	8.0258	14.3822
+4981	1997.8000	292	1.2523	0.6606	0.9061	1.0820	8.2090	14.6950	8.0210	14.3852
+4982	1997.8027	293	1.2523	0.6606	0.9061	1.0820	8.2090	14.6950	8.0163	14.3882
+4983	1997.8055	294	1.2523	0.6606	0.9061	1.0820	8.2090	14.6950	8.0116	14.3912
+4984	1997.8082	295	1.2523	0.6606	0.9061	1.0820	8.2090	14.6950	8.0069	14.3941
+4985	1997.8110	296	1.2523	0.6606	0.9061	1.0820	8.2090	14.6950	8.0024	14.3971
+4986	1997.8137	297	1.2522	0.6606	0.9061	1.0820	8.2090	14.6950	7.9979	14.4001
+4987	1997.8164	298	1.2522	0.6606	0.9061	1.0820	8.2090	14.6950	7.9935	14.4031
+4988	1997.8192	299	1.2522	0.6605	0.9061	1.0820	8.2090	14.6950	7.9892	14.4060
+4989	1997.8219	300	1.2522	0.6605	0.9061	1.0820	8.2090	14.6950	7.9850	14.4090
+4990	1997.8247	301	1.2522	0.6605	0.9061	1.0820	8.2090	14.6950	7.9809	14.4119
+4991	1997.8274	302	1.2522	0.6605	0.9061	1.0820	8.2090	14.6950	7.9769	14.4149
+4992	1997.8301	303	1.2521	0.6605	0.9061	1.0820	8.2090	14.6950	7.9730	14.4178
+4993	1997.8329	304	1.2521	0.6605	0.9061	1.0820	8.2090	14.6950	7.9691	14.4207
+4994	1997.8356	305	1.2521	0.6605	0.9060	1.0820	8.2090	14.6950	7.9654	14.4235
+4995	1997.8384	306	1.2521	0.6605	0.9060	1.0820	8.2090	14.6950	7.9618	14.4264
+4996	1997.8411	307	1.2521	0.6605	0.9060	1.0820	8.2090	14.6950	7.9584	14.4292
+4997	1997.8438	308	1.2521	0.6605	0.9060	1.0820	8.2090	14.6950	7.9550	14.4320
+4998	1997.8466	309	1.2520	0.6605	0.9060	1.0820	8.2090	14.6950	7.9518	14.4348
+4999	1997.8493	310	1.2520	0.6605	0.9060	1.0820	8.2090	14.6950	7.9487	14.4376
+5000	1997.8521	311	1.2520	0.6604	0.9060	1.0820	8.2090	14.6950	7.9457	14.4403
+5001	1997.8548	312	1.2520	0.6604	0.9060	1.0820	8.2090	14.6950	7.9428	14.4430
+5002	1997.8575	313	1.2520	0.6604	0.9060	1.0820	8.2090	14.6950	7.9401	14.4457
+5003	1997.8603	314	1.2520	0.6604	0.9060	1.0820	8.2090	14.6950	7.9375	14.4484
+5004	1997.8630	315	1.2519	0.6604	0.9060	1.0820	8.2090	14.6950	7.9351	14.4510
+5005	1997.8658	316	1.2519	0.6604	0.9060	1.0820	8.2090	14.6950	7.9327	14.4535
+5006	1997.8685	317	1.2519	0.6604	0.9060	1.0820	8.2090	14.6950	7.9306	14.4561
+5007	1997.8712	318	1.2519	0.6604	0.9060	1.0820	8.2090	14.6950	7.9286	14.4586
+5008	1997.8740	319	1.2519	0.6604	0.9060	1.0820	8.2090	14.6950	7.9267	14.4610
+5009	1997.8767	320	1.2519	0.6604	0.9060	1.0820	8.2090	14.6950	7.9249	14.4634
+5010	1997.8795	321	1.2518	0.6604	0.9060	1.0820	8.2090	14.6950	7.9234	14.4658
+5011	1997.8822	322	1.2518	0.6603	0.9060	1.0820	8.2090	14.6950	7.9219	14.4681
+5012	1997.8849	323	1.2518	0.6603	0.9060	1.0820	8.2090	14.6950	7.9206	14.4704
+5013	1997.8877	324	1.2518	0.6603	0.9060	1.0820	8.2090	14.6950	7.9195	14.4727
+5014	1997.8904	325	1.2518	0.6603	0.9060	1.0820	8.2090	14.6950	7.9185	14.4748
+5015	1997.8932	326	1.2518	0.6603	0.9060	1.0820	8.2090	14.6950	7.9177	14.4770
+5016	1997.8959	327	1.2517	0.6603	0.9060	1.0820	8.2090	14.6950	7.9170	14.4791
+5017	1997.8986	328	1.2517	0.6603	0.9060	1.0820	8.2090	14.6950	7.9165	14.4811
+5018	1997.9014	329	1.2517	0.6603	0.9060	1.0820	8.2090	14.6950	7.9161	14.4831
+5019	1997.9041	330	1.2517	0.6603	0.9060	1.0820	8.2090	14.6950	7.9159	14.4850
+5020	1997.9068	331	1.2517	0.6603	0.9060	1.0820	8.2090	14.6950	7.9159	14.4869
+5021	1997.9096	332	1.2517	0.6603	0.9060	1.0820	8.2090	14.6950	7.9160	14.4887
+5022	1997.9123	333	1.2516	0.6603	0.9060	1.0820	8.2090	14.6950	7.9162	14.4905
+5023	1997.9151	334	1.2516	0.6602	0.9060	1.0820	8.2090	14.6950	7.9166	14.4922
+5024	1997.9178	335	1.2516	0.6602	0.9060	1.0820	8.2090	14.6950	7.9172	14.4938
+5025	1997.9205	336	1.2516	0.6602	0.9060	1.0820	8.2090	14.6950	7.9179	14.4954
+5026	1997.9233	337	1.2516	0.6602	0.9060	1.0820	8.2090	14.6950	7.9187	14.4969
+5027	1997.9260	338	1.2516	0.6602	0.9060	1.0820	8.2090	14.6950	7.9197	14.4984
+5028	1997.9288	339	1.2516	0.6602	0.9060	1.0820	8.2090	14.6950	7.9209	14.4997
+5029	1997.9315	340	1.2515	0.6602	0.9060	1.0820	8.2090	14.6950	7.9222	14.5011
+5030	1997.9342	341	1.2515	0.6602	0.9060	1.0820	8.2090	14.6950	7.9236	14.5023
+5031	1997.9370	342	1.2515	0.6602	0.9060	1.0820	8.2090	14.6950	7.9252	14.5035
+5032	1997.9397	343	1.2515	0.6602	0.9060	1.0820	8.2090	14.6950	7.9270	14.5046
+5033	1997.9425	344	1.2515	0.6602	0.9060	1.0820	8.2090	14.6950	7.9288	14.5057
+5034	1997.9452	345	1.2515	0.6602	0.9060	1.0820	8.2090	14.6950	7.9308	14.5067
+5035	1997.9479	346	1.2514	0.6601	0.9060	1.0820	8.2090	14.6950	7.9330	14.5076
+5036	1997.9507	347	1.2514	0.6601	0.9060	1.0820	8.2090	14.6950	7.9353	14.5085
+5037	1997.9534	348	1.2514	0.6601	0.9060	1.0820	8.2090	14.6950	7.9377	14.5092
+5038	1997.9562	349	1.2514	0.6601	0.9060	1.0820	8.2090	14.6950	7.9402	14.5099
+5039	1997.9589	350	1.2514	0.6601	0.9060	1.0820	8.2090	14.6950	7.9429	14.5106
+5040	1997.9616	351	1.2514	0.6601	0.9060	1.0820	8.2090	14.6950	7.9457	14.5111
+5041	1997.9644	352	1.2513	0.6601	0.9059	1.0820	8.2090	14.6950	7.9486	14.5116
+5042	1997.9671	353	1.2513	0.6601	0.9059	1.0820	8.2090	14.6950	7.9517	14.5120
+5043	1997.9699	354	1.2513	0.6601	0.9059	1.0820	8.2090	14.6950	7.9548	14.5124
+5044	1997.9726	355	1.2513	0.6601	0.9059	1.0820	8.2090	14.6950	7.9581	14.5126
+5045	1997.9753	356	1.2513	0.6601	0.9059	1.0820	8.2090	14.6950	7.9614	14.5128
+5046	1997.9781	357	1.2513	0.6601	0.9059	1.0820	8.2090	14.6950	7.9649	14.5130
+5047	1997.9808	358	1.2512	0.6600	0.9059	1.0820	8.2090	14.6950	7.9685	14.5130
+5048	1997.9836	359	1.2512	0.6600	0.9059	1.0820	8.2090	14.6950	7.9722	14.5130
+5049	1997.9863	360	1.2512	0.6600	0.9059	1.0820	8.2090	14.6950	7.9759	14.5129
+5050	1997.9890	361	1.2512	0.6600	0.9059	1.0820	8.2090	14.6950	7.9798	14.5127
+5051	1997.9918	362	1.2512	0.6600	0.9059	1.0820	8.2090	14.6950	7.9837	14.5124
+5052	1997.9945	363	1.2512	0.6600	0.9059	1.0820	8.2090	14.6950	7.9878	14.5121
+5053	1997.9973	364	1.2511	0.6600	0.9059	1.0820	8.2090	14.6950	7.9919	14.5116
+5054	1997.9999	365	1.2511	0.6600	0.9059	1.0820	8.2090	14.6950	7.9960	14.5112
+5055	1998.0027	1	1.2511	0.6600	0.9059	1.0820	8.2090	14.6950	8.0003	14.5106
+5056	1998.0055	2	1.2511	0.6600	0.9059	1.0820	8.2090	14.6950	8.0046	14.5099
+5057	1998.0082	3	1.2511	0.6600	0.9059	1.0820	8.2090	14.6950	8.0090	14.5092
+5058	1998.0110	4	1.2511	0.6600	0.9059	1.0820	8.2090	14.6950	8.0134	14.5084
+5059	1998.0137	5	1.2510	0.6599	0.9059	1.0820	8.2090	14.6950	8.0179	14.5076
+5060	1998.0164	6	1.2510	0.6599	0.9059	1.0820	8.2090	14.6950	8.0224	14.5066
+5061	1998.0192	7	1.2510	0.6599	0.9059	1.0820	8.2090	14.6950	8.0270	14.5056
+5062	1998.0219	8	1.2510	0.6599	0.9059	1.0820	8.2090	14.6950	8.0316	14.5045
+5063	1998.0247	9	1.2510	0.6599	0.9059	1.0820	8.2090	14.6950	8.0362	14.5033
+5064	1998.0274	10	1.2510	0.6599	0.9059	1.0820	8.2090	14.6950	8.0409	14.5021
+5065	1998.0301	11	1.2510	0.6599	0.9059	1.0820	8.2090	14.6950	8.0455	14.5007
+5066	1998.0329	12	1.2509	0.6599	0.9059	1.0820	8.2090	14.6950	8.0503	14.4993
+5067	1998.0356	13	1.2509	0.6599	0.9059	1.0820	8.2090	14.6950	8.0550	14.4979
+5068	1998.0384	14	1.2509	0.6599	0.9059	1.0820	8.2090	14.6950	8.0597	14.4963
+5069	1998.0411	15	1.2509	0.6599	0.9059	1.0820	8.2090	14.6950	8.0644	14.4947
+5070	1998.0438	16	1.2509	0.6598	0.9059	1.0820	8.2090	14.6950	8.0691	14.4930
+5071	1998.0466	17	1.2509	0.6598	0.9059	1.0820	8.2090	14.6950	8.0739	14.4913
+5072	1998.0493	18	1.2508	0.6598	0.9059	1.0820	8.2090	14.6950	8.0786	14.4894
+5073	1998.0521	19	1.2508	0.6598	0.9059	1.0820	8.2090	14.6950	8.0833	14.4875
+5074	1998.0548	20	1.2508	0.6598	0.9059	1.0820	8.2090	14.6950	8.0879	14.4856
+5075	1998.0575	21	1.2508	0.6598	0.9059	1.0820	8.2090	14.6950	8.0926	14.4835
+5076	1998.0603	22	1.2508	0.6598	0.9059	1.0820	8.2090	14.6950	8.0972	14.4814
+5077	1998.0630	23	1.2508	0.6598	0.9059	1.0820	8.2090	14.6950	8.1017	14.4793
+5078	1998.0658	24	1.2507	0.6598	0.9059	1.0820	8.2090	14.6950	8.1062	14.4770
+5079	1998.0685	25	1.2507	0.6598	0.9059	1.0820	8.2090	14.6950	8.1107	14.4747
+5080	1998.0712	26	1.2507	0.6598	0.9059	1.0820	8.2090	14.6950	8.1151	14.4723
+5081	1998.0740	27	1.2507	0.6598	0.9059	1.0820	8.2090	14.6950	8.1195	14.4699
+5082	1998.0767	28	1.2507	0.6597	0.9059	1.0820	8.2090	14.6950	8.1238	14.4674
+5083	1998.0795	29	1.2507	0.6597	0.9059	1.0820	8.2090	14.6950	8.1281	14.4649
+5084	1998.0822	30	1.2506	0.6597	0.9059	1.0820	8.2090	14.6950	8.1322	14.4622
+5085	1998.0849	31	1.2506	0.6597	0.9059	1.0820	8.2090	14.6950	8.1363	14.4596
+5086	1998.0877	32	1.2506	0.6597	0.9059	1.0820	8.2090	14.6950	8.1403	14.4568
+5087	1998.0904	33	1.2506	0.6597	0.9059	1.0820	8.2090	14.6950	8.1442	14.4540
+5088	1998.0932	34	1.2506	0.6597	0.9059	1.0820	8.2090	14.6950	8.1481	14.4512
+5089	1998.0959	35	1.2506	0.6597	0.9059	1.0820	8.2090	14.6950	8.1518	14.4483
+5090	1998.0986	36	1.2506	0.6597	0.9059	1.0820	8.2090	14.6950	8.1555	14.4453
+5091	1998.1014	37	1.2505	0.6597	0.9058	1.0820	8.2090	14.6950	8.1590	14.4423
+5092	1998.1041	38	1.2505	0.6597	0.9058	1.0820	8.2090	14.6950	8.1624	14.4392
+5093	1998.1068	39	1.2505	0.6597	0.9058	1.0820	8.2090	14.6950	8.1658	14.4361
+5094	1998.1096	40	1.2505	0.6596	0.9058	1.0820	8.2090	14.6950	8.1690	14.4330
+5095	1998.1123	41	1.2505	0.6596	0.9058	1.0820	8.2090	14.6950	8.1721	14.4297
+5096	1998.1151	42	1.2505	0.6596	0.9058	1.0820	8.2090	14.6950	8.1750	14.4265
+5097	1998.1178	43	1.2504	0.6596	0.9058	1.0820	8.2090	14.6950	8.1779	14.4232
+5098	1998.1205	44	1.2504	0.6596	0.9058	1.0820	8.2090	14.6950	8.1806	14.4198
+5099	1998.1233	45	1.2504	0.6596	0.9058	1.0820	8.2090	14.6950	8.1832	14.4164
+5100	1998.1260	46	1.2504	0.6596	0.9058	1.0820	8.2090	14.6950	8.1856	14.4130
+5101	1998.1288	47	1.2504	0.6596	0.9058	1.0820	8.2090	14.6950	8.1880	14.4095
+5102	1998.1315	48	1.2504	0.6596	0.9058	1.0820	8.2090	14.6950	8.1901	14.4060
+5103	1998.1342	49	1.2503	0.6596	0.9058	1.0820	8.2090	14.6950	8.1922	14.4024
+5104	1998.1370	50	1.2503	0.6596	0.9058	1.0820	8.2090	14.6950	8.1941	14.3988
+5105	1998.1397	51	1.2503	0.6596	0.9058	1.0820	8.2090	14.6950	8.1958	14.3952
+5106	1998.1425	52	1.2503	0.6595	0.9058	1.0820	8.2090	14.6950	8.1974	14.3915
+5107	1998.1452	53	1.2503	0.6595	0.9058	1.0820	8.2090	14.6950	8.1989	14.3878
+5108	1998.1479	54	1.2503	0.6595	0.9058	1.0820	8.2090	14.6950	8.2002	14.3841
+5109	1998.1507	55	1.2503	0.6595	0.9058	1.0820	8.2090	14.6950	8.2013	14.3803
+5110	1998.1534	56	1.2502	0.6595	0.9058	1.0820	8.2090	14.6950	8.2023	14.3766
+5111	1998.1562	57	1.2502	0.6595	0.9058	1.0820	8.2090	14.6950	8.2031	14.3728
+5112	1998.1589	58	1.2502	0.6595	0.9058	1.0820	8.2090	14.6950	8.2038	14.3689
+5113	1998.1616	59	1.2502	0.6595	0.9058	1.0820	8.2090	14.6950	8.2043	14.3651
+5114	1998.1644	60	1.2502	0.6595	0.9058	1.0820	8.2090	14.6950	8.2047	14.3612
+5115	1998.1671	61	1.2502	0.6595	0.9058	1.0820	8.2090	14.6950	8.2049	14.3573
+5116	1998.1699	62	1.2501	0.6595	0.9058	1.0820	8.2090	14.6950	8.2049	14.3534
+5117	1998.1726	63	1.2501	0.6595	0.9058	1.0820	8.2090	14.6950	8.2048	14.3494
+5118	1998.1753	64	1.2501	0.6594	0.9058	1.0820	8.2090	14.6950	8.2045	14.3455
+5119	1998.1781	65	1.2501	0.6594	0.9058	1.0820	8.2090	14.6950	8.2041	14.3415
+5120	1998.1808	66	1.2501	0.6594	0.9058	1.0820	8.2090	14.6950	8.2035	14.3375
+5121	1998.1836	67	1.2501	0.6594	0.9058	1.0820	8.2090	14.6950	8.2028	14.3335
+5122	1998.1863	68	1.2500	0.6594	0.9058	1.0820	8.2090	14.6950	8.2019	14.3295
+5123	1998.1890	69	1.2500	0.6594	0.9058	1.0820	8.2090	14.6950	8.2008	14.3255
+5124	1998.1918	70	1.2500	0.6594	0.9058	1.0820	8.2090	14.6950	8.1996	14.3215
+5125	1998.1945	71	1.2500	0.6594	0.9058	1.0820	8.2090	14.6950	8.2090	14.6950
+5126	1998.1973	72	1.2500	0.6594	0.9058	1.0820	8.2090	14.6950	8.2051	14.6949
+5127	1998.2000	73	1.2500	0.6594	0.9058	1.0820	8.2090	14.6950	8.2011	14.6948
+5128	1998.2027	74	1.2500	0.6594	0.9058	1.0820	8.2090	14.6950	8.1971	14.6946
+5129	1998.2055	75	1.2499	0.6594	0.9058	1.0820	8.2090	14.6950	8.1929	14.6943
+5130	1998.2082	76	1.2499	0.6593	0.9058	1.0820	8.2090	14.6950	8.1886	14.6939
+5131	1998.2110	77	1.2499	0.6593	0.9058	1.0820	8.2090	14.6950	8.1843	14.6934
+5132	1998.2137	78	1.2499	0.6593	0.9058	1.0820	8.2090	14.6950	8.1799	14.6929
+5133	1998.2164	79	1.2499	0.6593	0.9058	1.0820	8.2090	14.6950	8.1754	14.6923
+5134	1998.2192	80	1.2499	0.6593	0.9058	1.0820	8.2090	14.6950	8.1708	14.6917
+5135	1998.2219	81	1.2498	0.6593	0.9058	1.0820	8.2090	14.6950	8.1662	14.6909
+5136	1998.2247	82	1.2498	0.6593	0.9058	1.0820	8.2090	14.6950	8.1615	14.6901
+5137	1998.2274	83	1.2498	0.6593	0.9058	1.0820	8.2090	14.6950	8.1568	14.6892
+5138	1998.2301	84	1.2498	0.6593	0.9058	1.0820	8.2090	14.6950	8.1520	14.6882
+5139	1998.2329	85	1.2498	0.6593	0.9058	1.0820	8.2090	14.6950	8.1472	14.6871
+5140	1998.2356	86	1.2498	0.6593	0.9058	1.0820	8.2090	14.6950	8.1424	14.6860
+5141	1998.2384	87	1.2497	0.6593	0.9058	1.0820	8.2090	14.6950	8.1375	14.6848
+5142	1998.2411	88	1.2497	0.6593	0.9057	1.0820	8.2090	14.6950	8.1325	14.6835
+5143	1998.2438	89	1.2497	0.6592	0.9057	1.0820	8.2090	14.6950	8.1276	14.6822
+5144	1998.2466	90	1.2497	0.6592	0.9057	1.0820	8.2090	14.6950	8.1226	14.6808
+5145	1998.2493	91	1.2497	0.6592	0.9057	1.0820	8.2090	14.6950	8.1176	14.6793
+5146	1998.2521	92	1.2497	0.6592	0.9057	1.0820	8.2090	14.6950	8.1127	14.6777
+5147	1998.2548	93	1.2497	0.6592	0.9057	1.0820	8.2090	14.6950	8.1077	14.6761
+5148	1998.2575	94	1.2496	0.6592	0.9057	1.0820	8.2090	14.6950	8.1027	14.6744
+5149	1998.2603	95	1.2496	0.6592	0.9057	1.0820	8.2090	14.6950	8.0977	14.6726
+5150	1998.2630	96	1.2496	0.6592	0.9057	1.0820	8.2090	14.6950	8.0927	14.6707
+5151	1998.2658	97	1.2496	0.6592	0.9057	1.0820	8.2090	14.6950	8.0877	14.6688
+5152	1998.2685	98	1.2496	0.6592	0.9057	1.0820	8.2090	14.6950	8.0828	14.6668
+5153	1998.2712	99	1.2496	0.6592	0.9057	1.0820	8.2090	14.6950	8.0779	14.6648
+5154	1998.2740	100	1.2495	0.6592	0.9057	1.0820	8.2090	14.6950	8.0730	14.6627
+5155	1998.2767	101	1.2495	0.6591	0.9057	1.0820	8.2090	14.6950	8.0681	14.6605
+5156	1998.2795	102	1.2495	0.6591	0.9057	1.0820	8.2090	14.6950	8.0633	14.6582
+5157	1998.2822	103	1.2495	0.6591	0.9057	1.0820	8.2090	14.6950	8.0585	14.6559
+5158	1998.2849	104	1.2495	0.6591	0.9057	1.0820	8.2090	14.6950	8.0538	14.6535
+5159	1998.2877	105	1.2495	0.6591	0.9057	1.0820	8.2090	14.6950	8.0491	14.6511
+5160	1998.2904	106	1.2495	0.6591	0.9057	1.0820	8.2090	14.6950	8.0445	14.6486
+5161	1998.2932	107	1.2494	0.6591	0.9057	1.0820	8.2090	14.6950	8.0399	14.6460
+5162	1998.2959	108	1.2494	0.6591	0.9057	1.0820	8.2090	14.6950	8.0354	14.6433
+5163	1998.2986	109	1.2494	0.6591	0.9057	1.0820	8.2090	14.6950	8.0310	14.6407
+5164	1998.3014	110	1.2494	0.6591	0.9057	1.0820	8.2090	14.6950	8.0267	14.6379
+5165	1998.3041	111	1.2494	0.6591	0.9057	1.0820	8.2090	14.6950	8.0224	14.6351
+5166	1998.3068	112	1.2494	0.6591	0.9057	1.0820	8.2090	14.6950	8.0182	14.6322
+5167	1998.3096	113	1.2493	0.6590	0.9057	1.0820	8.2090	14.6950	8.0141	14.6293
+5168	1998.3123	114	1.2493	0.6590	0.9057	1.0820	8.2090	14.6950	8.0100	14.6263
+5169	1998.3151	115	1.2493	0.6590	0.9057	1.0820	8.2090	14.6950	8.0061	14.6233
+5170	1998.3178	116	1.2493	0.6590	0.9057	1.0820	8.2090	14.6950	8.0022	14.6202
+5171	1998.3205	117	1.2493	0.6590	0.9057	1.0820	8.2090	14.6950	7.9985	14.6171
+5172	1998.3233	118	1.2493	0.6590	0.9057	1.0820	8.2090	14.6950	7.9949	14.6139
+5173	1998.3260	119	1.2493	0.6590	0.9057	1.0820	8.2090	14.6950	7.9913	14.6107
+5174	1998.3288	120	1.2492	0.6590	0.9057	1.0820	8.2090	14.6950	7.9879	14.6074
+5175	1998.3315	121	1.2492	0.6590	0.9057	1.0820	8.2090	14.6950	7.9846	14.6041
+5176	1998.3342	122	1.2492	0.6590	0.9057	1.0820	8.2090	14.6950	7.9814	14.6008
+5177	1998.3370	123	1.2492	0.6590	0.9057	1.0820	8.2090	14.6950	7.9783	14.5973
+5178	1998.3397	124	1.2492	0.6590	0.9057	1.0820	8.2090	14.6950	7.9753	14.5939
+5179	1998.3425	125	1.2492	0.6589	0.9057	1.0820	8.2090	14.6950	7.9724	14.5904
+5180	1998.3452	126	1.2491	0.6589	0.9057	1.0820	8.2090	14.6950	7.9697	14.5869
+5181	1998.3479	127	1.2491	0.6589	0.9057	1.0820	8.2090	14.6950	7.9671	14.5833
+5182	1998.3507	128	1.2491	0.6589	0.9057	1.0820	8.2090	14.6950	7.9646	14.5797
+5183	1998.3534	129	1.2491	0.6589	0.9057	1.0820	8.2090	14.6950	7.9623	14.5761
+5184	1998.3562	130	1.2491	0.6589	0.9057	1.0820	8.2090	14.6950	7.9600	14.5724
+5185	1998.3589	131	1.2491	0.6589	0.9057	1.0820	8.2090	14.6950	7.9580	14.5687
+5186	1998.3616	132	1.2491	0.6589	0.9057	1.0820	8.2090	14.6950	7.9560	14.5649
+5187	1998.3644	133	1.2490	0.6589	0.9057	1.0820	8.2090	14.6950	7.9542	14.5612
+5188	1998.3671	134	1.2490	0.6589	0.9057	1.0820	8.2090	14.6950	7.9525	14.5574
+5189	1998.3699	135	1.2490	0.6589	0.9057	1.0820	8.2090	14.6950	7.9510	14.5535
+5190	1998.3726	136	1.2490	0.6589	0.9057	1.0820	8.2090	14.6950	7.9496	14.5497
+5191	1998.3753	137	1.2490	0.6589	0.9057	1.0820	8.2090	14.6950	7.9483	14.5458
+5192	1998.3781	138	1.2490	0.6588	0.9057	1.0820	8.2090	14.6950	7.9472	14.5419
+5193	1998.3808	139	1.2489	0.6588	0.9057	1.0820	8.2090	14.6950	7.9462	14.5380
+5194	1998.3836	140	1.2489	0.6588	0.9057	1.0820	8.2090	14.6950	7.9454	14.5341
+5195	1998.3863	141	1.2489	0.6588	0.9056	1.0820	8.2090	14.6950	7.9447	14.5301
+5196	1998.3890	142	1.2489	0.6588	0.9056	1.0820	8.2090	14.6950	7.9442	14.5261
+5197	1998.3918	143	1.2489	0.6588	0.9056	1.0820	8.2090	14.6950	7.9438	14.5222
+5198	1998.3945	144	1.2489	0.6588	0.9056	1.0820	8.2090	14.6950	7.9435	14.5182
+5199	1998.3973	145	1.2489	0.6588	0.9056	1.0820	8.2090	14.6950	7.9434	14.5141
+5200	1998.4000	146	1.2488	0.6588	0.9056	1.0820	8.2090	14.6950	7.9435	14.5101
+5201	1998.4027	147	1.2488	0.6588	0.9056	1.0820	8.2090	14.6950	7.9436	14.5061
+5202	1998.4055	148	1.2488	0.6588	0.9056	1.0820	8.2090	14.6950	7.9440	14.5020
+5203	1998.4082	149	1.2488	0.6588	0.9056	1.0820	8.2090	14.6950	7.9444	14.4980
+5204	1998.4110	150	1.2488	0.6587	0.9056	1.0820	8.2090	14.6950	7.9451	14.4939
+5205	1998.4137	151	1.2488	0.6587	0.9056	1.0820	8.2090	14.6950	7.9458	14.4899
+5206	1998.4164	152	1.2487	0.6587	0.9056	1.0820	8.2090	14.6950	7.9467	14.4858
+5207	1998.4192	153	1.2487	0.6587	0.9056	1.0820	8.2090	14.6950	7.9477	14.4818
+5208	1998.4219	154	1.2487	0.6587	0.9056	1.0820	8.2090	14.6950	7.9489	14.4777
+5209	1998.4247	155	1.2487	0.6587	0.9056	1.0820	8.2090	14.6950	7.9502	14.4736
+5210	1998.4274	156	1.2487	0.6587	0.9056	1.0820	8.2090	14.6950	7.9517	14.4696
+5211	1998.4301	157	1.2487	0.6587	0.9056	1.0820	8.2090	14.6950	7.9533	14.4655
+5212	1998.4329	158	1.2487	0.6587	0.9056	1.0820	8.2090	14.6950	7.9550	14.4615
+5213	1998.4356	159	1.2486	0.6587	0.9056	1.0820	8.2090	14.6950	7.9568	14.4575
+5214	1998.4384	160	1.2486	0.6587	0.9056	1.0820	8.2090	14.6950	7.9588	14.4535
+5215	1998.4411	161	1.2486	0.6587	0.9056	1.0820	8.2090	14.6950	7.9609	14.4494
+5216	1998.4438	162	1.2486	0.6586	0.9056	1.0820	8.2090	14.6950	7.9631	14.4454
+5217	1998.4466	163	1.2486	0.6586	0.9056	1.0820	8.2090	14.6950	7.9655	14.4415
+5218	1998.4493	164	1.2486	0.6586	0.9056	1.0820	8.2090	14.6950	7.9680	14.4375
+5219	1998.4521	165	1.2485	0.6586	0.9056	1.0820	8.2090	14.6950	7.9706	14.4335
+5220	1998.4548	166	1.2485	0.6586	0.9056	1.0820	8.2090	14.6950	7.9733	14.4296
+5221	1998.4575	167	1.2485	0.6586	0.9056	1.0820	8.2090	14.6950	7.9761	14.4257
+5222	1998.4603	168	1.2485	0.6586	0.9056	1.0820	8.2090	14.6950	7.9790	14.4218
+5223	1998.4630	169	1.2485	0.6586	0.9056	1.0820	8.2090	14.6950	7.9821	14.4179
+5224	1998.4658	170	1.2485	0.6586	0.9056	1.0820	8.2090	14.6950	7.9852	14.4141
+5225	1998.4685	171	1.2485	0.6586	0.9056	1.0820	8.2090	14.6950	7.9885	14.4103
+5226	1998.4712	172	1.2484	0.6586	0.9056	1.0820	8.2090	14.6950	7.9918	14.4065
+5227	1998.4740	173	1.2484	0.6586	0.9056	1.0820	8.2090	14.6950	7.9953	14.4027
+5228	1998.4767	174	1.2484	0.6586	0.9056	1.0820	8.2090	14.6950	7.9988	14.3989
+5229	1998.4795	175	1.2484	0.6585	0.9056	1.0820	8.2090	14.6950	8.0024	14.3952
+5230	1998.4822	176	1.2484	0.6585	0.9056	1.0820	8.2090	14.6950	8.0062	14.3916
+5231	1998.4849	177	1.2484	0.6585	0.9056	1.0820	8.2090	14.6950	8.0100	14.3879
+5232	1998.4877	178	1.2484	0.6585	0.9056	1.0820	8.2090	14.6950	8.0138	14.3843
+5233	1998.4904	179	1.2483	0.6585	0.9056	1.0820	8.2090	14.6950	8.0178	14.3807
+5234	1998.4932	180	1.2483	0.6585	0.9056	1.0820	8.2090	14.6950	8.0218	14.3772
+5235	1998.4959	181	1.2483	0.6585	0.9056	1.0820	8.2090	14.6950	8.0259	14.3737
+5236	1998.4986	182	1.2483	0.6585	0.9056	1.0820	8.2090	14.6950	8.0300	14.3702
+5237	1998.5014	183	1.2483	0.6585	0.9056	1.0820	8.2090	14.6950	8.0343	14.3668
+5238	1998.5041	184	1.2483	0.6585	0.9056	1.0820	8.2090	14.6950	8.0385	14.3634
+5239	1998.5068	185	1.2482	0.6585	0.9056	1.0820	8.2090	14.6950	8.0428	14.3601
+5240	1998.5096	186	1.2482	0.6585	0.9056	1.0820	8.2090	14.6950	8.0472	14.3568
+5241	1998.5123	187	1.2482	0.6584	0.9056	1.0820	8.2090	14.6950	8.0516	14.3535
+5242	1998.5151	188	1.2482	0.6584	0.9056	1.0820	8.2090	14.6950	8.0561	14.3503
+5243	1998.5178	189	1.2482	0.6584	0.9056	1.0820	8.2090	14.6950	8.0605	14.3471
+5244	1998.5205	190	1.2482	0.6584	0.9056	1.0820	8.2090	14.6950	8.0651	14.3440
+5245	1998.5233	191	1.2482	0.6584	0.9056	1.0820	8.2090	14.6950	8.0696	14.3409
+5246	1998.5260	192	1.2481	0.6584	0.9056	1.0820	8.2090	14.6950	8.0742	14.3379
+5247	1998.5288	193	1.2481	0.6584	0.9056	1.0820	8.2090	14.6950	8.0787	14.3349
+5248	1998.5315	194	1.2481	0.6584	0.9056	1.0820	8.2090	14.6950	8.0833	14.3320
+5249	1998.5342	195	1.2481	0.6584	0.9055	1.0820	8.2090	14.6950	8.0879	14.3291
+5250	1998.5370	196	1.2481	0.6584	0.9055	1.0820	8.2090	14.6950	8.0925	14.3263
+5251	1998.5397	197	1.2481	0.6584	0.9055	1.0820	8.2090	14.6950	8.0971	14.3236
+5252	1998.5425	198	1.2481	0.6584	0.9055	1.0820	8.2090	14.6950	8.1017	14.3209
+5253	1998.5452	199	1.2480	0.6584	0.9055	1.0820	8.2090	14.6950	8.1063	14.3182
+5254	1998.5479	200	1.2480	0.6583	0.9055	1.0820	8.2090	14.6950	8.1108	14.3156
+5255	1998.5507	201	1.2480	0.6583	0.9055	1.0820	8.2090	14.6950	8.1154	14.3131
+5256	1998.5534	202	1.2480	0.6583	0.9055	1.0820	8.2090	14.6950	8.1199	14.3106
+5257	1998.5562	203	1.2480	0.6583	0.9055	1.0820	8.2090	14.6950	8.1244	14.3081
+5258	1998.5589	204	1.2480	0.6583	0.9055	1.0820	8.2090	14.6950	8.1288	14.3058
+5259	1998.5616	205	1.2479	0.6583	0.9055	1.0820	8.2090	14.6950	8.1332	14.3035
+5260	1998.5644	206	1.2479	0.6583	0.9055	1.0820	8.2090	14.6950	8.1376	14.3012
+5261	1998.5671	207	1.2479	0.6583	0.9055	1.0820	8.2090	14.6950	8.1419	14.2990
+5262	1998.5699	208	1.2479	0.6583	0.9055	1.0820	8.2090	14.6950	8.1462	14.2969
+5263	1998.5726	209	1.2479	0.6583	0.9055	1.0820	8.2090	14.6950	8.1504	14.2948
+5264	1998.5753	210	1.2479	0.6583	0.9055	1.0820	8.2090	14.6950	8.1546	14.2928
+5265	1998.5781	211	1.2479	0.6583	0.9055	1.0820	8.2090	14.6950	8.1587	14.2909
+5266	1998.5808	212	1.2478	0.6582	0.9055	1.0820	8.2090	14.6950	8.1627	14.2890
+5267	1998.5836	213	1.2478	0.6582	0.9055	1.0820	8.2090	14.6950	8.1667	14.2872
+5268	1998.5863	214	1.2478	0.6582	0.9055	1.0820	8.2090	14.6950	8.1705	14.2854
+5269	1998.5890	215	1.2478	0.6582	0.9055	1.0820	8.2090	14.6950	8.1743	14.2837
+5270	1998.5918	216	1.2478	0.6582	0.9055	1.0820	8.2090	14.6950	8.1780	14.2821
+5271	1998.5945	217	1.2478	0.6582	0.9055	1.0820	8.2090	14.6950	8.1817	14.2806
+5272	1998.5973	218	1.2478	0.6582	0.9055	1.0820	8.2090	14.6950	8.1852	14.2791
+5273	1998.6000	219	1.2477	0.6582	0.9055	1.0820	8.2090	14.6950	8.1886	14.2777
+5274	1998.6027	220	1.2477	0.6582	0.9055	1.0820	8.2090	14.6950	8.1920	14.2763
+5275	1998.6055	221	1.2477	0.6582	0.9055	1.0820	8.2090	14.6950	8.1952	14.2750
+5276	1998.6082	222	1.2477	0.6582	0.9055	1.0820	8.2090	14.6950	8.1983	14.2738
+5277	1998.6110	223	1.2477	0.6582	0.9055	1.0820	8.2090	14.6950	8.2013	14.2726
+5278	1998.6137	224	1.2477	0.6582	0.9055	1.0820	8.2090	14.6950	8.2042	14.2715
+5279	1998.6164	225	1.2476	0.6581	0.9055	1.0820	8.2090	14.6950	8.2070	14.2705
+5280	1998.6192	226	1.2476	0.6581	0.9055	1.0820	8.2090	14.6950	8.2097	14.2695
+5281	1998.6219	227	1.2476	0.6581	0.9055	1.0820	8.2090	14.6950	8.2122	14.2686
+5282	1998.6247	228	1.2476	0.6581	0.9055	1.0820	8.2090	14.6950	8.2146	14.2678
+5283	1998.6274	229	1.2476	0.6581	0.9055	1.0820	8.2090	14.6950	8.2169	14.2671
+5284	1998.6301	230	1.2476	0.6581	0.9055	1.0820	8.2090	14.6950	8.2191	14.2664
+5285	1998.6329	231	1.2476	0.6581	0.9055	1.0820	8.2090	14.6950	8.2211	14.2658
+5286	1998.6356	232	1.2475	0.6581	0.9055	1.0820	8.2090	14.6950	8.2230	14.2652
+5287	1998.6384	233	1.2475	0.6581	0.9055	1.0820	8.2090	14.6950	8.2247	14.2647
+5288	1998.6411	234	1.2475	0.6581	0.9055	1.0820	8.2090	14.6950	8.2263	14.2643
+5289	1998.6438	235	1.2475	0.6581	0.9055	1.0820	8.2090	14.6950	8.2278	14.2639
+5290	1998.6466	236	1.2475	0.6581	0.9055	1.0820	8.2090	14.6950	8.2291	14.2637
+5291	1998.6493	237	1.2475	0.6581	0.9055	1.0820	8.2090	14.6950	8.2303	14.2634
+5292	1998.6521	238	1.2475	0.6580	0.9055	1.0820	8.2090	14.6950	8.2314	14.2633
+5293	1998.6548	239	1.2474	0.6580	0.9055	1.0820	8.2090	14.6950	8.2323	14.2632
+5294	1998.6575	240	1.2474	0.6580	0.9055	1.0820	8.2090	14.6950	8.2330	14.2632
+5295	1998.6603	241	1.2474	0.6580	0.9055	1.0820	8.2090	14.6950	8.2336	14.2632
+5296	1998.6630	242	1.2474	0.6580	0.9055	1.0820	8.2090	14.6950	8.2341	14.2633
+5297	1998.6658	243	1.2474	0.6580	0.9055	1.0820	8.2090	14.6950	8.2344	14.2635
+5298	1998.6685	244	1.2474	0.6580	0.9055	1.0820	8.2090	14.6950	8.2346	14.2637
+5299	1998.6712	245	1.2474	0.6580	0.9055	1.0820	8.2090	14.6950	8.2346	14.2641
+5300	1998.6740	246	1.2473	0.6580	0.9055	1.0820	8.2090	14.6950	8.2344	14.2644
+5301	1998.6767	247	1.2473	0.6580	0.9055	1.0820	8.2090	14.6950	8.2342	14.2649
+5302	1998.6795	248	1.2473	0.6580	0.9055	1.0820	8.2090	14.6950	8.2337	14.2654
+5303	1998.6822	249	1.2473	0.6580	0.9055	1.0820	8.2090	14.6950	8.2331	14.2659
+5304	1998.6849	250	1.2473	0.6579	0.9055	1.0820	8.2090	14.6950	8.2324	14.2665
+5305	1998.6877	251	1.2473	0.6579	0.9055	1.0820	8.2090	14.6950	8.2315	14.2672
+5306	1998.6904	252	1.2473	0.6579	0.9054	1.0820	8.2090	14.6950	8.2305	14.2680
+5307	1998.6932	253	1.2472	0.6579	0.9054	1.0820	8.2090	14.6950	8.2293	14.2688
+5308	1998.6959	254	1.2472	0.6579	0.9054	1.0820	8.2090	14.6950	8.2280	14.2697
+5309	1998.6986	255	1.2472	0.6579	0.9054	1.0820	8.2090	14.6950	8.2265	14.2706
+5310	1998.7014	256	1.2472	0.6579	0.9054	1.0820	8.2090	14.6950	8.2249	14.2716
+5311	1998.7041	257	1.2472	0.6579	0.9054	1.0820	8.2090	14.6950	8.2232	14.2726
+5312	1998.7068	258	1.2472	0.6579	0.9054	1.0820	8.2090	14.6950	8.2213	14.2737
+5313	1998.7096	259	1.2471	0.6579	0.9054	1.0820	8.2090	14.6950	8.2193	14.2749
+5314	1998.7123	260	1.2471	0.6579	0.9054	1.0820	8.2090	14.6950	8.2172	14.2761
+5315	1998.7151	261	1.2471	0.6579	0.9054	1.0820	8.2090	14.6950	8.2149	14.2774
+5316	1998.7178	262	1.2471	0.6579	0.9054	1.0820	8.2090	14.6950	8.2125	14.2787
+5317	1998.7205	263	1.2471	0.6578	0.9054	1.0820	8.2090	14.6950	8.2099	14.2801
+5318	1998.7233	264	1.2471	0.6578	0.9054	1.0820	8.2090	14.6950	8.2073	14.2815
+5319	1998.7260	265	1.2471	0.6578	0.9054	1.0820	8.2090	14.6950	8.2045	14.2830
+5320	1998.7288	266	1.2470	0.6578	0.9054	1.0820	8.2090	14.6950	8.2016	14.2845
+5321	1998.7315	267	1.2470	0.6578	0.9054	1.0820	8.2090	14.6950	8.1985	14.2861
+5322	1998.7342	268	1.2470	0.6578	0.9054	1.0820	8.2090	14.6950	8.1954	14.2878
+5323	1998.7370	269	1.2470	0.6578	0.9054	1.0820	8.2090	14.6950	8.1922	14.2895
+5324	1998.7397	270	1.2470	0.6578	0.9054	1.0820	8.2090	14.6950	8.1888	14.2912
+5325	1998.7425	271	1.2470	0.6578	0.9054	1.0820	8.2090	14.6950	8.1854	14.2930
+5326	1998.7452	272	1.2470	0.6578	0.9054	1.0820	8.2090	14.6950	8.1818	14.2948
+5327	1998.7479	273	1.2469	0.6578	0.9054	1.0820	8.2090	14.6950	8.1781	14.2967
+5328	1998.7507	274	1.2469	0.6578	0.9054	1.0820	8.2090	14.6950	8.1744	14.2986
+5329	1998.7534	275	1.2469	0.6578	0.9054	1.0820	8.2090	14.6950	8.1706	14.3006
+5330	1998.7562	276	1.2469	0.6577	0.9054	1.0820	8.2090	14.6950	8.1666	14.3026
+5331	1998.7589	277	1.2469	0.6577	0.9054	1.0820	8.2090	14.6950	8.1626	14.3046
+5332	1998.7616	278	1.2469	0.6577	0.9054	1.0820	8.2090	14.6950	8.1586	14.3067
+5333	1998.7644	279	1.2469	0.6577	0.9054	1.0820	8.2090	14.6950	8.1544	14.3089
+5334	1998.7671	280	1.2468	0.6577	0.9054	1.0820	8.2090	14.6950	8.1502	14.3110
+5335	1998.7699	281	1.2468	0.6577	0.9054	1.0820	8.2090	14.6950	8.1459	14.3132
+5336	1998.7726	282	1.2468	0.6577	0.9054	1.0820	8.2090	14.6950	8.1415	14.3155
+5337	1998.7753	283	1.2468	0.6577	0.9054	1.0820	8.2090	14.6950	8.1371	14.3178
+5338	1998.7781	284	1.2468	0.6577	0.9054	1.0820	8.2090	14.6950	8.1326	14.3201
+5339	1998.7808	285	1.2468	0.6577	0.9054	1.0820	8.2090	14.6950	8.1281	14.3224
+5340	1998.7836	286	1.2468	0.6577	0.9054	1.0820	8.2090	14.6950	8.1236	14.3248
+5341	1998.7863	287	1.2467	0.6577	0.9054	1.0820	8.2090	14.6950	8.1190	14.3272
+5342	1998.7890	288	1.2467	0.6577	0.9054	1.0820	8.2090	14.6950	8.1143	14.3296
+5343	1998.7918	289	1.2467	0.6576	0.9054	1.0820	8.2090	14.6950	8.1097	14.3321
+5344	1998.7945	290	1.2467	0.6576	0.9054	1.0820	8.2090	14.6950	8.1050	14.3346
+5345	1998.7973	291	1.2467	0.6576	0.9054	1.0820	8.2090	14.6950	8.1003	14.3371
+5346	1998.8000	292	1.2467	0.6576	0.9054	1.0820	8.2090	14.6950	8.0955	14.3396
+5347	1998.8027	293	1.2467	0.6576	0.9054	1.0820	8.2090	14.6950	8.0908	14.3422
+5348	1998.8055	294	1.2466	0.6576	0.9054	1.0820	8.2090	14.6950	8.0860	14.3448
+5349	1998.8082	295	1.2466	0.6576	0.9054	1.0820	8.2090	14.6950	8.0812	14.3474
+5350	1998.8110	296	1.2466	0.6576	0.9054	1.0820	8.2090	14.6950	8.0765	14.3500
+5351	1998.8137	297	1.2466	0.6576	0.9054	1.0820	8.2090	14.6950	8.0717	14.3527
+5352	1998.8164	298	1.2466	0.6576	0.9054	1.0820	8.2090	14.6950	8.0669	14.3553
+5353	1998.8192	299	1.2466	0.6576	0.9054	1.0820	8.2090	14.6950	8.0622	14.3580
+5354	1998.8219	300	1.2466	0.6576	0.9054	1.0820	8.2090	14.6950	8.0574	14.3607
+5355	1998.8247	301	1.2465	0.6575	0.9054	1.0820	8.2090	14.6950	8.0527	14.3634
+5356	1998.8274	302	1.2465	0.6575	0.9054	1.0820	8.2090	14.6950	8.0480	14.3661
+5357	1998.8301	303	1.2465	0.6575	0.9054	1.0820	8.2090	14.6950	8.0434	14.3688
+5358	1998.8329	304	1.2465	0.6575	0.9054	1.0820	8.2090	14.6950	8.0387	14.3716
+5359	1998.8356	305	1.2465	0.6575	0.9054	1.0820	8.2090	14.6950	8.0341	14.3743
+5360	1998.8384	306	1.2465	0.6575	0.9054	1.0820	8.2090	14.6950	8.0296	14.3771
+5361	1998.8411	307	1.2465	0.6575	0.9054	1.0820	8.2090	14.6950	8.0251	14.3798
+5362	1998.8438	308	1.2464	0.6575	0.9054	1.0820	8.2090	14.6950	8.0206	14.3826
+5363	1998.8466	309	1.2464	0.6575	0.9054	1.0820	8.2090	14.6950	8.0162	14.3853
+5364	1998.8493	310	1.2464	0.6575	0.9054	1.0820	8.2090	14.6950	8.0118	14.3881
+5365	1998.8521	311	1.2464	0.6575	0.9053	1.0820	8.2090	14.6950	8.0075	14.3909
+5366	1998.8548	312	1.2464	0.6575	0.9053	1.0820	8.2090	14.6950	8.0033	14.3936
+5367	1998.8575	313	1.2464	0.6575	0.9053	1.0820	8.2090	14.6950	7.9991	14.3964
+5368	1998.8603	314	1.2464	0.6574	0.9053	1.0820	8.2090	14.6950	7.9950	14.3991
+5369	1998.8630	315	1.2463	0.6574	0.9053	1.0820	8.2090	14.6950	7.9910	14.4019
+5370	1998.8658	316	1.2463	0.6574	0.9053	1.0820	8.2090	14.6950	7.9870	14.4046
+5371	1998.8685	317	1.2463	0.6574	0.9053	1.0820	8.2090	14.6950	7.9832	14.4074
+5372	1998.8712	318	1.2463	0.6574	0.9053	1.0820	8.2090	14.6950	7.9794	14.4101
+5373	1998.8740	319	1.2463	0.6574	0.9053	1.0820	8.2090	14.6950	7.9757	14.4128
+5374	1998.8767	320	1.2463	0.6574	0.9053	1.0820	8.2090	14.6950	7.9721	14.4155
+5375	1998.8795	321	1.2463	0.6574	0.9053	1.0820	8.2090	14.6950	7.9685	14.4182
+5376	1998.8822	322	1.2462	0.6574	0.9053	1.0820	8.2090	14.6950	7.9651	14.4209
+5377	1998.8849	323	1.2462	0.6574	0.9053	1.0820	8.2090	14.6950	7.9618	14.4235
+5378	1998.8877	324	1.2462	0.6574	0.9053	1.0820	8.2090	14.6950	7.9585	14.4262
+5379	1998.8904	325	1.2462	0.6574	0.9053	1.0820	8.2090	14.6950	7.9554	14.4288
+5380	1998.8932	326	1.2462	0.6574	0.9053	1.0820	8.2090	14.6950	7.9524	14.4314
+5381	1998.8959	327	1.2462	0.6573	0.9053	1.0820	8.2090	14.6950	7.9495	14.4340
+5382	1998.8986	328	1.2462	0.6573	0.9053	1.0820	8.2090	14.6950	7.9467	14.4365
+5383	1998.9014	329	1.2461	0.6573	0.9053	1.0820	8.2090	14.6950	7.9440	14.4391
+5384	1998.9041	330	1.2461	0.6573	0.9053	1.0820	8.2090	14.6950	7.9414	14.4416
+5385	1998.9068	331	1.2461	0.6573	0.9053	1.0820	8.2090	14.6950	7.9389	14.4441
+5386	1998.9096	332	1.2461	0.6573	0.9053	1.0820	8.2090	14.6950	7.9366	14.4465
+5387	1998.9123	333	1.2461	0.6573	0.9053	1.0820	8.2090	14.6950	7.9343	14.4490
+5388	1998.9151	334	1.2461	0.6573	0.9053	1.0820	8.2090	14.6950	7.9322	14.4514
+5389	1998.9178	335	1.2461	0.6573	0.9053	1.0820	8.2090	14.6950	7.9302	14.4538
+5390	1998.9205	336	1.2460	0.6573	0.9053	1.0820	8.2090	14.6950	7.9284	14.4561
+5391	1998.9233	337	1.2460	0.6573	0.9053	1.0820	8.2090	14.6950	7.9266	14.4584
+5392	1998.9260	338	1.2460	0.6573	0.9053	1.0820	8.2090	14.6950	7.9250	14.4607
+5393	1998.9288	339	1.2460	0.6573	0.9053	1.0820	8.2090	14.6950	7.9236	14.4629
+5394	1998.9315	340	1.2460	0.6572	0.9053	1.0820	8.2090	14.6950	7.9222	14.4651
+5395	1998.9342	341	1.2460	0.6572	0.9053	1.0820	8.2090	14.6950	7.9210	14.4673
+5396	1998.9370	342	1.2460	0.6572	0.9053	1.0820	8.2090	14.6950	7.9199	14.4694
+5397	1998.9397	343	1.2459	0.6572	0.9053	1.0820	8.2090	14.6950	7.9189	14.4715
+5398	1998.9425	344	1.2459	0.6572	0.9053	1.0820	8.2090	14.6950	7.9181	14.4736
+5399	1998.9452	345	1.2459	0.6572	0.9053	1.0820	8.2090	14.6950	7.9174	14.4756
+5400	1998.9479	346	1.2459	0.6572	0.9053	1.0820	8.2090	14.6950	7.9168	14.4775
+5401	1998.9507	347	1.2459	0.6572	0.9053	1.0820	8.2090	14.6950	7.9164	14.4795
+5402	1998.9534	348	1.2459	0.6572	0.9053	1.0820	8.2090	14.6950	7.9161	14.4813
+5403	1998.9562	349	1.2459	0.6572	0.9053	1.0820	8.2090	14.6950	7.9159	14.4832
+5404	1998.9589	350	1.2458	0.6572	0.9053	1.0820	8.2090	14.6950	7.9159	14.4849
+5405	1998.9616	351	1.2458	0.6572	0.9053	1.0820	8.2090	14.6950	7.9160	14.4867
+5406	1998.9644	352	1.2458	0.6572	0.9053	1.0820	8.2090	14.6950	7.9162	14.4884
+5407	1998.9671	353	1.2458	0.6572	0.9053	1.0820	8.2090	14.6950	7.9165	14.4900
+5408	1998.9699	354	1.2458	0.6571	0.9053	1.0820	8.2090	14.6950	7.9170	14.4916
+5409	1998.9726	355	1.2458	0.6571	0.9053	1.0820	8.2090	14.6950	7.9177	14.4931
+5410	1998.9753	356	1.2458	0.6571	0.9053	1.0820	8.2090	14.6950	7.9184	14.4946
+5411	1998.9781	357	1.2457	0.6571	0.9053	1.0820	8.2090	14.6950	7.9193	14.4960
+5412	1998.9808	358	1.2457	0.6571	0.9053	1.0820	8.2090	14.6950	7.9203	14.4974
+5413	1998.9836	359	1.2457	0.6571	0.9053	1.0820	8.2090	14.6950	7.9214	14.4987
+5414	1998.9863	360	1.2457	0.6571	0.9053	1.0820	8.2090	14.6950	7.9227	14.5000
+5415	1998.9890	361	1.2457	0.6571	0.9053	1.0820	8.2090	14.6950	7.9241	14.5012
+5416	1998.9918	362	1.2457	0.6571	0.9053	1.0820	8.2090	14.6950	7.9256	14.5024
+5417	1998.9945	363	1.2457	0.6571	0.9053	1.0820	8.2090	14.6950	7.9272	14.5035
+5418	1998.9973	364	1.2456	0.6571	0.9053	1.0820	8.2090	14.6950	7.9290	14.5045
+5419	1998.9999	365	1.2456	0.6571	0.9053	1.0820	8.2090	14.6950	7.9309	14.5055
+5420	1999.0027	1	1.2456	0.6571	0.9053	1.0820	8.2090	14.6950	7.9329	14.5065
+5421	1999.0055	2	1.2456	0.6570	0.9053	1.0820	8.2090	14.6950	7.9350	14.5073
+5422	1999.0082	3	1.2456	0.6570	0.9053	1.0820	8.2090	14.6950	7.9372	14.5081
+5423	1999.0110	4	1.2456	0.6570	0.9053	1.0820	8.2090	14.6950	7.9395	14.5089
+5424	1999.0137	5	1.2456	0.6570	0.9053	1.0820	8.2090	14.6950	7.9420	14.5096
+5425	1999.0164	6	1.2455	0.6570	0.9053	1.0820	8.2090	14.6950	7.9445	14.5102
+5426	1999.0192	7	1.2455	0.6570	0.9052	1.0820	8.2090	14.6950	7.9472	14.5108
+5427	1999.0219	8	1.2455	0.6570	0.9052	1.0820	8.2090	14.6950	7.9500	14.5113
+5428	1999.0247	9	1.2455	0.6570	0.9052	1.0820	8.2090	14.6950	7.9528	14.5117
+5429	1999.0274	10	1.2455	0.6570	0.9052	1.0820	8.2090	14.6950	7.9558	14.5121
+5430	1999.0301	11	1.2455	0.6570	0.9052	1.0820	8.2090	14.6950	7.9588	14.5124
+5431	1999.0329	12	1.2455	0.6570	0.9052	1.0820	8.2090	14.6950	7.9620	14.5126
+5432	1999.0356	13	1.2454	0.6570	0.9052	1.0820	8.2090	14.6950	7.9652	14.5128
+5433	1999.0384	14	1.2454	0.6570	0.9052	1.0820	8.2090	14.6950	7.9686	14.5129
+5434	1999.0411	15	1.2454	0.6569	0.9052	1.0820	8.2090	14.6950	7.9720	14.5130
+5435	1999.0438	16	1.2454	0.6569	0.9052	1.0820	8.2090	14.6950	7.9755	14.5130
+5436	1999.0466	17	1.2454	0.6569	0.9052	1.0820	8.2090	14.6950	7.9790	14.5129
+5437	1999.0493	18	1.2454	0.6569	0.9052	1.0820	8.2090	14.6950	7.9827	14.5128
+5438	1999.0521	19	1.2454	0.6569	0.9052	1.0820	8.2090	14.6950	7.9864	14.5126
+5439	1999.0548	20	1.2453	0.6569	0.9052	1.0820	8.2090	14.6950	7.9902	14.5123
+5440	1999.0575	21	1.2453	0.6569	0.9052	1.0820	8.2090	14.6950	7.9940	14.5120
+5441	1999.0603	22	1.2453	0.6569	0.9052	1.0820	8.2090	14.6950	7.9979	14.5116
+5442	1999.0630	23	1.2453	0.6569	0.9052	1.0820	8.2090	14.6950	8.0019	14.5111
+5443	1999.0658	24	1.2453	0.6569	0.9052	1.0820	8.2090	14.6950	8.0059	14.5106
+5444	1999.0685	25	1.2453	0.6569	0.9052	1.0820	8.2090	14.6950	8.0100	14.5100
+5445	1999.0712	26	1.2453	0.6569	0.9052	1.0820	8.2090	14.6950	8.0141	14.5093
+5446	1999.0740	27	1.2453	0.6569	0.9052	1.0820	8.2090	14.6950	8.0183	14.5086
+5447	1999.0767	28	1.2452	0.6568	0.9052	1.0820	8.2090	14.6950	8.0225	14.5078
+5448	1999.0795	29	1.2452	0.6568	0.9052	1.0820	8.2090	14.6950	8.0267	14.5070
+5449	1999.0822	30	1.2452	0.6568	0.9052	1.0820	8.2090	14.6950	8.0310	14.5060
+5450	1999.0849	31	1.2452	0.6568	0.9052	1.0820	8.2090	14.6950	8.0353	14.5051
+5451	1999.0877	32	1.2452	0.6568	0.9052	1.0820	8.2090	14.6950	8.0396	14.5040
+5452	1999.0904	33	1.2452	0.6568	0.9052	1.0820	8.2090	14.6950	8.0440	14.5029
+5453	1999.0932	34	1.2452	0.6568	0.9052	1.0820	8.2090	14.6950	8.0483	14.5017
+5454	1999.0959	35	1.2451	0.6568	0.9052	1.0820	8.2090	14.6950	8.0527	14.5005
+5455	1999.0986	36	1.2451	0.6568	0.9052	1.0820	8.2090	14.6950	8.0571	14.4992
+5456	1999.1014	37	1.2451	0.6568	0.9052	1.0820	8.2090	14.6950	8.0615	14.4978
+5457	1999.1041	38	1.2451	0.6568	0.9052	1.0820	8.2090	14.6950	8.0659	14.4964
+5458	1999.1068	39	1.2451	0.6568	0.9052	1.0820	8.2090	14.6950	8.0703	14.4949
+5459	1999.1096	40	1.2451	0.6568	0.9052	1.0820	8.2090	14.6950	8.0746	14.4934
+5460	1999.1123	41	1.2451	0.6567	0.9052	1.0820	8.2090	14.6950	8.0790	14.4917
+5461	1999.1151	42	1.2450	0.6567	0.9052	1.0820	8.2090	14.6950	8.0834	14.4901
+5462	1999.1178	43	1.2450	0.6567	0.9052	1.0820	8.2090	14.6950	8.0877	14.4883
+5463	1999.1205	44	1.2450	0.6567	0.9052	1.0820	8.2090	14.6950	8.0920	14.4865
+5464	1999.1233	45	1.2450	0.6567	0.9052	1.0820	8.2090	14.6950	8.0963	14.4847
+5465	1999.1260	46	1.2450	0.6567	0.9052	1.0820	8.2090	14.6950	8.1005	14.4828
+5466	1999.1288	47	1.2450	0.6567	0.9052	1.0820	8.2090	14.6950	8.1047	14.4808
+5467	1999.1315	48	1.2450	0.6567	0.9052	1.0820	8.2090	14.6950	8.1089	14.4788
+5468	1999.1342	49	1.2449	0.6567	0.9052	1.0820	8.2090	14.6950	8.1130	14.4767
+5469	1999.1370	50	1.2449	0.6567	0.9052	1.0820	8.2090	14.6950	8.1171	14.4746
+5470	1999.1397	51	1.2449	0.6567	0.9052	1.0820	8.2090	14.6950	8.1212	14.4724
+5471	1999.1425	52	1.2449	0.6567	0.9052	1.0820	8.2090	14.6950	8.1251	14.4701
+5472	1999.1452	53	1.2449	0.6567	0.9052	1.0820	8.2090	14.6950	8.1290	14.4679
+5473	1999.1479	54	1.2449	0.6567	0.9052	1.0820	8.2090	14.6950	8.1329	14.4655
+5474	1999.1507	55	1.2449	0.6566	0.9052	1.0820	8.2090	14.6950	8.1367	14.4631
+5475	1999.1534	56	1.2449	0.6566	0.9052	1.0820	8.2090	14.6950	8.1404	14.4606
+5476	1999.1562	57	1.2448	0.6566	0.9052	1.0820	8.2090	14.6950	8.1441	14.4581
+5477	1999.1589	58	1.2448	0.6566	0.9052	1.0820	8.2090	14.6950	8.1476	14.4556
+5478	1999.1616	59	1.2448	0.6566	0.9052	1.0820	8.2090	14.6950	8.1511	14.4530
+5479	1999.1644	60	1.2448	0.6566	0.9052	1.0820	8.2090	14.6950	8.1545	14.4503
+5480	1999.1671	61	1.2448	0.6566	0.9052	1.0820	8.2090	14.6950	8.1578	14.4476
+5481	1999.1699	62	1.2448	0.6566	0.9052	1.0820	8.2090	14.6950	8.1610	14.4449
+5482	1999.1726	63	1.2448	0.6566	0.9052	1.0820	8.2090	14.6950	8.1642	14.4421
+5483	1999.1753	64	1.2447	0.6566	0.9052	1.0820	8.2090	14.6950	8.1672	14.4392
+5484	1999.1781	65	1.2447	0.6566	0.9052	1.0820	8.2090	14.6950	8.1702	14.4364
+5485	1999.1808	66	1.2447	0.6566	0.9052	1.0820	8.2090	14.6950	8.1730	14.4334
+5486	1999.1836	67	1.2447	0.6566	0.9052	1.0820	8.2090	14.6950	8.1757	14.4305
+5487	1999.1863	68	1.2447	0.6565	0.9052	1.0820	8.2090	14.6950	8.1783	14.4275
+5488	1999.1890	69	1.2447	0.6565	0.9052	1.0820	8.2090	14.6950	8.1808	14.4244
+5489	1999.1918	70	1.2447	0.6565	0.9052	1.0820	8.2090	14.6950	8.1832	14.4213
+5490	1999.1945	71	1.2446	0.6565	0.9051	1.0820	8.2090	14.6950	8.1855	14.4182
+5491	1999.1973	72	1.2446	0.6565	0.9051	1.0820	8.2090	14.6950	8.1877	14.4151
+5492	1999.2000	73	1.2446	0.6565	0.9051	1.0820	8.2090	14.6950	8.1897	14.4119
+5493	1999.2027	74	1.2446	0.6565	0.9051	1.0820	8.2090	14.6950	8.2090	14.6950
+5494	1999.2055	75	1.2446	0.6565	0.9051	1.0820	8.2090	14.6950	8.2054	14.6949
+5495	1999.2082	76	1.2446	0.6565	0.9051	1.0820	8.2090	14.6950	8.2017	14.6948
+5496	1999.2110	77	1.2446	0.6565	0.9051	1.0820	8.2090	14.6950	8.1979	14.6946
+5497	1999.2137	78	1.2446	0.6565	0.9051	1.0820	8.2090	14.6950	8.1940	14.6944
+5498	1999.2164	79	1.2445	0.6565	0.9051	1.0820	8.2090	14.6950	8.1901	14.6940
+5499	1999.2192	80	1.2445	0.6565	0.9051	1.0820	8.2090	14.6950	8.1860	14.6936
+5500	1999.2219	81	1.2445	0.6565	0.9051	1.0820	8.2090	14.6950	8.1820	14.6932
+5501	1999.2247	82	1.2445	0.6564	0.9051	1.0820	8.2090	14.6950	8.1778	14.6927
+5502	1999.2274	83	1.2445	0.6564	0.9051	1.0820	8.2090	14.6950	8.1736	14.6921
+5503	1999.2301	84	1.2445	0.6564	0.9051	1.0820	8.2090	14.6950	8.1693	14.6914
+5504	1999.2329	85	1.2445	0.6564	0.9051	1.0820	8.2090	14.6950	8.1650	14.6907
+5505	1999.2356	86	1.2444	0.6564	0.9051	1.0820	8.2090	14.6950	8.1606	14.6899
+5506	1999.2384	87	1.2444	0.6564	0.9051	1.0820	8.2090	14.6950	8.1562	14.6891
+5507	1999.2411	88	1.2444	0.6564	0.9051	1.0820	8.2090	14.6950	8.1518	14.6882
+5508	1999.2438	89	1.2444	0.6564	0.9051	1.0820	8.2090	14.6950	8.1473	14.6872
+5509	1999.2466	90	1.2444	0.6564	0.9051	1.0820	8.2090	14.6950	8.1427	14.6862
+5510	1999.2493	91	1.2444	0.6564	0.9051	1.0820	8.2090	14.6950	8.1382	14.6851
+5511	1999.2521	92	1.2444	0.6564	0.9051	1.0820	8.2090	14.6950	8.1336	14.6839
+5512	1999.2548	93	1.2443	0.6564	0.9051	1.0820	8.2090	14.6950	8.1290	14.6827
+5513	1999.2575	94	1.2443	0.6564	0.9051	1.0820	8.2090	14.6950	8.1243	14.6814
+5514	1999.2603	95	1.2443	0.6563	0.9051	1.0820	8.2090	14.6950	8.1197	14.6800
+5515	1999.2630	96	1.2443	0.6563	0.9051	1.0820	8.2090	14.6950	8.1151	14.6786
+5516	1999.2658	97	1.2443	0.6563	0.9051	1.0820	8.2090	14.6950	8.1104	14.6771
+5517	1999.2685	98	1.2443	0.6563	0.9051	1.0820	8.2090	14.6950	8.1057	14.6756
+5518	1999.2712	99	1.2443	0.6563	0.9051	1.0820	8.2090	14.6950	8.1011	14.6740
+5519	1999.2740	100	1.2443	0.6563	0.9051	1.0820	8.2090	14.6950	8.0964	14.6723
+5520	1999.2767	101	1.2442	0.6563	0.9051	1.0820	8.2090	14.6950	8.0918	14.6706
+5521	1999.2795	102	1.2442	0.6563	0.9051	1.0820	8.2090	14.6950	8.0872	14.6688
+5522	1999.2822	103	1.2442	0.6563	0.9051	1.0820	8.2090	14.6950	8.0826	14.6669
+5523	1999.2849	104	1.2442	0.6563	0.9051	1.0820	8.2090	14.6950	8.0780	14.6650
+5524	1999.2877	105	1.2442	0.6563	0.9051	1.0820	8.2090	14.6950	8.0734	14.6631
+5525	1999.2904	106	1.2442	0.6563	0.9051	1.0820	8.2090	14.6950	8.0689	14.6611
+5526	1999.2932	107	1.2442	0.6563	0.9051	1.0820	8.2090	14.6950	8.0644	14.6590
+5527	1999.2959	108	1.2441	0.6563	0.9051	1.0820	8.2090	14.6950	8.0599	14.6569
+5528	1999.2986	109	1.2441	0.6562	0.9051	1.0820	8.2090	14.6950	8.0555	14.6547
+5529	1999.3014	110	1.2441	0.6562	0.9051	1.0820	8.2090	14.6950	8.0511	14.6524
+5530	1999.3041	111	1.2441	0.6562	0.9051	1.0820	8.2090	14.6950	8.0468	14.6501
+5531	1999.3068	112	1.2441	0.6562	0.9051	1.0820	8.2090	14.6950	8.0425	14.6478
+5532	1999.3096	113	1.2441	0.6562	0.9051	1.0820	8.2090	14.6950	8.0382	14.6454
+5533	1999.3123	114	1.2441	0.6562	0.9051	1.0820	8.2090	14.6950	8.0341	14.6429
+5534	1999.3151	115	1.2440	0.6562	0.9051	1.0820	8.2090	14.6950	8.0300	14.6404
+5535	1999.3178	116	1.2440	0.6562	0.9051	1.0820	8.2090	14.6950	8.0259	14.6378
+5536	1999.3205	117	1.2440	0.6562	0.9051	1.0820	8.2090	14.6950	8.0219	14.6352
+5537	1999.3233	118	1.2440	0.6562	0.9051	1.0820	8.2090	14.6950	8.0180	14.6326
+5538	1999.3260	119	1.2440	0.6562	0.9051	1.0820	8.2090	14.6950	8.0142	14.6299
+5539	1999.3288	120	1.2440	0.6562	0.9051	1.0820	8.2090	14.6950	8.0104	14.6271
+5540	1999.3315	121	1.2440	0.6562	0.9051	1.0820	8.2090	14.6950	8.0067	14.6243
+5541	1999.3342	122	1.2440	0.6561	0.9051	1.0820	8.2090	14.6950	8.0031	14.6215
+5542	1999.3370	123	1.2439	0.6561	0.9051	1.0820	8.2090	14.6950	7.9996	14.6186
+5543	1999.3397	124	1.2439	0.6561	0.9051	1.0820	8.2090	14.6950	7.9962	14.6157
+5544	1999.3425	125	1.2439	0.6561	0.9051	1.0820	8.2090	14.6950	7.9928	14.6127
+5545	1999.3452	126	1.2439	0.6561	0.9051	1.0820	8.2090	14.6950	7.9896	14.6097
+5546	1999.3479	127	1.2439	0.6561	0.9051	1.0820	8.2090	14.6950	7.9864	14.6066
+5547	1999.3507	128	1.2439	0.6561	0.9051	1.0820	8.2090	14.6950	7.9834	14.6035
+5548	1999.3534	129	1.2439	0.6561	0.9051	1.0820	8.2090	14.6950	7.9804	14.6004
+5549	1999.3562	130	1.2438	0.6561	0.9051	1.0820	8.2090	14.6950	7.9776	14.5972
+5550	1999.3589	131	1.2438	0.6561	0.9051	1.0820	8.2090	14.6950	7.9748	14.5940
+5551	1999.3616	132	1.2438	0.6561	0.9051	1.0820	8.2090	14.6950	7.9722	14.5908
+5552	1999.3644	133	1.2438	0.6561	0.9051	1.0820	8.2090	14.6950	7.9696	14.5875
+5553	1999.3671	134	1.2438	0.6561	0.9051	1.0820	8.2090	14.6950	7.9672	14.5842
+5554	1999.3699	135	1.2438	0.6561	0.9051	1.0820	8.2090	14.6950	7.9649	14.5809
+5555	1999.3726	136	1.2438	0.6560	0.9051	1.0820	8.2090	14.6950	7.9627	14.5775
+5556	1999.3753	137	1.2438	0.6560	0.9050	1.0820	8.2090	14.6950	7.9606	14.5741
+5557	1999.3781	138	1.2437	0.6560	0.9050	1.0820	8.2090	14.6950	7.9586	14.5707
+5558	1999.3808	139	1.2437	0.6560	0.9050	1.0820	8.2090	14.6950	7.9567	14.5672
+5559	1999.3836	140	1.2437	0.6560	0.9050	1.0820	8.2090	14.6950	7.9550	14.5637
+5560	1999.3863	141	1.2437	0.6560	0.9050	1.0820	8.2090	14.6950	7.9533	14.5602
+5561	1999.3890	142	1.2437	0.6560	0.9050	1.0820	8.2090	14.6950	7.9518	14.5567
+5562	1999.3918	143	1.2437	0.6560	0.9050	1.0820	8.2090	14.6950	7.9505	14.5531
+5563	1999.3945	144	1.2437	0.6560	0.9050	1.0820	8.2090	14.6950	7.9492	14.5495
+5564	1999.3973	145	1.2436	0.6560	0.9050	1.0820	8.2090	14.6950	7.9481	14.5459
+5565	1999.4000	146	1.2436	0.6560	0.9050	1.0820	8.2090	14.6950	7.9470	14.5423
+5566	1999.4027	147	1.2436	0.6560	0.9050	1.0820	8.2090	14.6950	7.9462	14.5387
+5567	1999.4055	148	1.2436	0.6560	0.9050	1.0820	8.2090	14.6950	7.9454	14.5350
+5568	1999.4082	149	1.2436	0.6559	0.9050	1.0820	8.2090	14.6950	7.9448	14.5314
+5569	1999.4110	150	1.2436	0.6559	0.9050	1.0820	8.2090	14.6950	7.9442	14.5277
+5570	1999.4137	151	1.2436	0.6559	0.9050	1.0820	8.2090	14.6950	7.9438	14.5240
+5571	1999.4164	152	1.2436	0.6559	0.9050	1.0820	8.2090	14.6950	7.9436	14.5203
+5572	1999.4192	153	1.2435	0.6559	0.9050	1.0820	8.2090	14.6950	7.9434	14.5165
+5573	1999.4219	154	1.2435	0.6559	0.9050	1.0820	8.2090	14.6950	7.9434	14.5128
+5574	1999.4247	155	1.2435	0.6559	0.9050	1.0820	8.2090	14.6950	7.9435	14.5091
+5575	1999.4274	156	1.2435	0.6559	0.9050	1.0820	8.2090	14.6950	7.9438	14.5053
+5576	1999.4301	157	1.2435	0.6559	0.9050	1.0820	8.2090	14.6950	7.9441	14.5016
+5577	1999.4329	158	1.2435	0.6559	0.9050	1.0820	8.2090	14.6950	7.9446	14.4978
+5578	1999.4356	159	1.2435	0.6559	0.9050	1.0820	8.2090	14.6950	7.9452	14.4940
+5579	1999.4384	160	1.2435	0.6559	0.9050	1.0820	8.2090	14.6950	7.9460	14.4903
+5580	1999.4411	161	1.2434	0.6559	0.9050	1.0820	8.2090	14.6950	7.9468	14.4865
+5581	1999.4438	162	1.2434	0.6559	0.9050	1.0820	8.2090	14.6950	7.9478	14.4827
+5582	1999.4466	163	1.2434	0.6558	0.9050	1.0820	8.2090	14.6950	7.9489	14.4789
+5583	1999.4493	164	1.2434	0.6558	0.9050	1.0820	8.2090	14.6950	7.9501	14.4752
+5584	1999.4521	165	1.2434	0.6558	0.9050	1.0820	8.2090	14.6950	7.9515	14.4714
+5585	1999.4548	166	1.2434	0.6558	0.9050	1.0820	8.2090	14.6950	7.9529	14.4676
+5586	1999.4575	167	1.2434	0.6558	0.9050	1.0820	8.2090	14.6950	7.9545	14.4639
+5587	1999.4603	168	1.2433	0.6558	0.9050	1.0820	8.2090	14.6950	7.9562	14.4601
+5588	1999.4630	169	1.2433	0.6558	0.9050	1.0820	8.2090	14.6950	7.9580	14.4564
+5589	1999.4658	170	1.2433	0.6558	0.9050	1.0820	8.2090	14.6950	7.9599	14.4527
+5590	1999.4685	171	1.2433	0.6558	0.9050	1.0820	8.2090	14.6950	7.9619	14.4489
+5591	1999.4712	172	1.2433	0.6558	0.9050	1.0820	8.2090	14.6950	7.9641	14.4452
+5592	1999.4740	173	1.2433	0.6558	0.9050	1.0820	8.2090	14.6950	7.9663	14.4415
+5593	1999.4767	174	1.2433	0.6558	0.9050	1.0820	8.2090	14.6950	7.9687	14.4378
+5594	1999.4795	175	1.2433	0.6558	0.9050	1.0820	8.2090	14.6950	7.9711	14.4342
+5595	1999.4822	176	1.2432	0.6558	0.9050	1.0820	8.2090	14.6950	7.9736	14.4305
+5596	1999.4849	177	1.2432	0.6557	0.9050	1.0820	8.2090	14.6950	7.9763	14.4269
+5597	1999.4877	178	1.2432	0.6557	0.9050	1.0820	8.2090	14.6950	7.9790	14.4232
+5598	1999.4904	179	1.2432	0.6557	0.9050	1.0820	8.2090	14.6950	7.9819	14.4196
+5599	1999.4932	180	1.2432	0.6557	0.9050	1.0820	8.2090	14.6950	7.9848	14.4160
+5600	1999.4959	181	1.2432	0.6557	0.9050	1.0820	8.2090	14.6950	7.9878	14.4125
+5601	1999.4986	182	1.2432	0.6557	0.9050	1.0820	8.2090	14.6950	7.9909	14.4089
+5602	1999.5014	183	1.2431	0.6557	0.9050	1.0820	8.2090	14.6950	7.9941	14.4054
+5603	1999.5041	184	1.2431	0.6557	0.9050	1.0820	8.2090	14.6950	7.9974	14.4019
+5604	1999.5068	185	1.2431	0.6557	0.9050	1.0820	8.2090	14.6950	8.0007	14.3984
+5605	1999.5096	186	1.2431	0.6557	0.9050	1.0820	8.2090	14.6950	8.0041	14.3950
+5606	1999.5123	187	1.2431	0.6557	0.9050	1.0820	8.2090	14.6950	8.0076	14.3916
+5607	1999.5151	188	1.2431	0.6557	0.9050	1.0820	8.2090	14.6950	8.0112	14.3882
+5608	1999.5178	189	1.2431	0.6557	0.9050	1.0820	8.2090	14.6950	8.0149	14.3848
+5609	1999.5205	190	1.2431	0.6557	0.9050	1.0820	8.2090	14.6950	8.0186	14.3815
+5610	1999.5233	191	1.2430	0.6556	0.9050	1.0820	8.2090	14.6950	8.0223	14.3782
+5611	1999.5260	192	1.2430	0.6556	0.9050	1.0820	8.2090	14.6950	8.0261	14.3749
+5612	1999.5288	193	1.2430	0.6556	0.9050	1.0820	8.2090	14.6950	8.0300	14.3717
+5613	1999.5315	194	1.2430	0.6556	0.9050	1.0820	8.2090	14.6950	8.0339	14.3685
+5614	1999.5342	195	1.2430	0.6556	0.9050	1.0820	8.2090	14.6950	8.0379	14.3653
+5615	1999.5370	196	1.2430	0.6556	0.9050	1.0820	8.2090	14.6950	8.0419	14.3622
+5616	1999.5397	197	1.2430	0.6556	0.9050	1.0820	8.2090	14.6950	8.0460	14.3591
+5617	1999.5425	198	1.2430	0.6556	0.9050	1.0820	8.2090	14.6950	8.0501	14.3561
+5618	1999.5452	199	1.2429	0.6556	0.9050	1.0820	8.2090	14.6950	8.0542	14.3530
+5619	1999.5479	200	1.2429	0.6556	0.9050	1.0820	8.2090	14.6950	8.0584	14.3501
+5620	1999.5507	201	1.2429	0.6556	0.9050	1.0820	8.2090	14.6950	8.0626	14.3471
+5621	1999.5534	202	1.2429	0.6556	0.9050	1.0820	8.2090	14.6950	8.0668	14.3442
+5622	1999.5562	203	1.2429	0.6556	0.9050	1.0820	8.2090	14.6950	8.0710	14.3414
+5623	1999.5589	204	1.2429	0.6556	0.9050	1.0820	8.2090	14.6950	8.0753	14.3385
+5624	1999.5616	205	1.2429	0.6555	0.9050	1.0820	8.2090	14.6950	8.0796	14.3358
+5625	1999.5644	206	1.2428	0.6555	0.9050	1.0820	8.2090	14.6950	8.0838	14.3330
+5626	1999.5671	207	1.2428	0.6555	0.9049	1.0820	8.2090	14.6950	8.0881	14.3303
+5627	1999.5699	208	1.2428	0.6555	0.9049	1.0820	8.2090	14.6950	8.0924	14.3277
+5628	1999.5726	209	1.2428	0.6555	0.9049	1.0820	8.2090	14.6950	8.0967	14.3251
+5629	1999.5753	210	1.2428	0.6555	0.9049	1.0820	8.2090	14.6950	8.1010	14.3226
+5630	1999.5781	211	1.2428	0.6555	0.9049	1.0820	8.2090	14.6950	8.1053	14.3201
+5631	1999.5808	212	1.2428	0.6555	0.9049	1.0820	8.2090	14.6950	8.1095	14.3176
+5632	1999.5836	213	1.2428	0.6555	0.9049	1.0820	8.2090	14.6950	8.1138	14.3152
+5633	1999.5863	214	1.2427	0.6555	0.9049	1.0820	8.2090	14.6950	8.1180	14.3129
+5634	1999.5890	215	1.2427	0.6555	0.9049	1.0820	8.2090	14.6950	8.1222	14.3105
+5635	1999.5918	216	1.2427	0.6555	0.9049	1.0820	8.2090	14.6950	8.1264	14.3083
+5636	1999.5945	217	1.2427	0.6555	0.9049	1.0820	8.2090	14.6950	8.1305	14.3061
+5637	1999.5973	218	1.2427	0.6555	0.9049	1.0820	8.2090	14.6950	8.1346	14.3039
+5638	1999.6000	219	1.2427	0.6554	0.9049	1.0820	8.2090	14.6950	8.1387	14.3018
+5639	1999.6027	220	1.2427	0.6554	0.9049	1.0820	8.2090	14.6950	8.1427	14.2998
+5640	1999.6055	221	1.2427	0.6554	0.9049	1.0820	8.2090	14.6950	8.1467	14.2978
+5641	1999.6082	222	1.2426	0.6554	0.9049	1.0820	8.2090	14.6950	8.1506	14.2958
+5642	1999.6110	223	1.2426	0.6554	0.9049	1.0820	8.2090	14.6950	8.1545	14.2939
+5643	1999.6137	224	1.2426	0.6554	0.9049	1.0820	8.2090	14.6950	8.1583	14.2921
+5644	1999.6164	225	1.2426	0.6554	0.9049	1.0820	8.2090	14.6950	8.1621	14.2903
+5645	1999.6192	226	1.2426	0.6554	0.9049	1.0820	8.2090	14.6950	8.1658	14.2886
+5646	1999.6219	227	1.2426	0.6554	0.9049	1.0820	8.2090	14.6950	8.1694	14.2869
+5647	1999.6247	228	1.2426	0.6554	0.9049	1.0820	8.2090	14.6950	8.1730	14.2853
+5648	1999.6274	229	1.2426	0.6554	0.9049	1.0820	8.2090	14.6950	8.1765	14.2837
+5649	1999.6301	230	1.2425	0.6554	0.9049	1.0820	8.2090	14.6950	8.1799	14.2822
+5650	1999.6329	231	1.2425	0.6554	0.9049	1.0820	8.2090	14.6950	8.1832	14.2808
+5651	1999.6356	232	1.2425	0.6554	0.9049	1.0820	8.2090	14.6950	8.1865	14.2794
+5652	1999.6384	233	1.2425	0.6553	0.9049	1.0820	8.2090	14.6950	8.1896	14.2780
+5653	1999.6411	234	1.2425	0.6553	0.9049	1.0820	8.2090	14.6950	8.1927	14.2767
+5654	1999.6438	235	1.2425	0.6553	0.9049	1.0820	8.2090	14.6950	8.1957	14.2755
+5655	1999.6466	236	1.2425	0.6553	0.9049	1.0820	8.2090	14.6950	8.1986	14.2744
+5656	1999.6493	237	1.2424	0.6553	0.9049	1.0820	8.2090	14.6950	8.2014	14.2732
+5657	1999.6521	238	1.2424	0.6553	0.9049	1.0820	8.2090	14.6950	8.2041	14.2722
+5658	1999.6548	239	1.2424	0.6553	0.9049	1.0820	8.2090	14.6950	8.2067	14.2712
+5659	1999.6575	240	1.2424	0.6553	0.9049	1.0820	8.2090	14.6950	8.2092	14.2703
+5660	1999.6603	241	1.2424	0.6553	0.9049	1.0820	8.2090	14.6950	8.2116	14.2694
+5661	1999.6630	242	1.2424	0.6553	0.9049	1.0820	8.2090	14.6950	8.2139	14.2686
+5662	1999.6658	243	1.2424	0.6553	0.9049	1.0820	8.2090	14.6950	8.2161	14.2678
+5663	1999.6685	244	1.2424	0.6553	0.9049	1.0820	8.2090	14.6950	8.2181	14.2671
+5664	1999.6712	245	1.2423	0.6553	0.9049	1.0820	8.2090	14.6950	8.2201	14.2665
+5665	1999.6740	246	1.2423	0.6553	0.9049	1.0820	8.2090	14.6950	8.2219	14.2659
+5666	1999.6767	247	1.2423	0.6552	0.9049	1.0820	8.2090	14.6950	8.2236	14.2653
+5667	1999.6795	248	1.2423	0.6552	0.9049	1.0820	8.2090	14.6950	8.2252	14.2649
+5668	1999.6822	249	1.2423	0.6552	0.9049	1.0820	8.2090	14.6950	8.2267	14.2644
+5669	1999.6849	250	1.2423	0.6552	0.9049	1.0820	8.2090	14.6950	8.2280	14.2641
+5670	1999.6877	251	1.2423	0.6552	0.9049	1.0820	8.2090	14.6950	8.2293	14.2638
+5671	1999.6904	252	1.2423	0.6552	0.9049	1.0820	8.2090	14.6950	8.2304	14.2636
+5672	1999.6932	253	1.2422	0.6552	0.9049	1.0820	8.2090	14.6950	8.2313	14.2634
+5673	1999.6959	254	1.2422	0.6552	0.9049	1.0820	8.2090	14.6950	8.2322	14.2633
+5674	1999.6986	255	1.2422	0.6552	0.9049	1.0820	8.2090	14.6950	8.2329	14.2632
+5675	1999.7014	256	1.2422	0.6552	0.9049	1.0820	8.2090	14.6950	8.2335	14.2632
+5676	1999.7041	257	1.2422	0.6552	0.9049	1.0820	8.2090	14.6950	8.2340	14.2632
+5677	1999.7068	258	1.2422	0.6552	0.9049	1.0820	8.2090	14.6950	8.2343	14.2633
+5678	1999.7096	259	1.2422	0.6552	0.9049	1.0820	8.2090	14.6950	8.2345	14.2635
+5679	1999.7123	260	1.2422	0.6552	0.9049	1.0820	8.2090	14.6950	8.2346	14.2637
+5680	1999.7151	261	1.2421	0.6551	0.9049	1.0820	8.2090	14.6950	8.2345	14.2640
+5681	1999.7178	262	1.2421	0.6551	0.9049	1.0820	8.2090	14.6950	8.2344	14.2643
+5682	1999.7205	263	1.2421	0.6551	0.9049	1.0820	8.2090	14.6950	8.2341	14.2647
+5683	1999.7233	264	1.2421	0.6551	0.9049	1.0820	8.2090	14.6950	8.2336	14.2651
+5684	1999.7260	265	1.2421	0.6551	0.9049	1.0820	8.2090	14.6950	8.2330	14.2656
+5685	1999.7288	266	1.2421	0.6551	0.9049	1.0820	8.2090	14.6950	8.2323	14.2662
+5686	1999.7315	267	1.2421	0.6551	0.9049	1.0820	8.2090	14.6950	8.2315	14.2668
+5687	1999.7342	268	1.2421	0.6551	0.9049	1.0820	8.2090	14.6950	8.2306	14.2674
+5688	1999.7370	269	1.2420	0.6551	0.9049	1.0820	8.2090	14.6950	8.2295	14.2681
+5689	1999.7397	270	1.2420	0.6551	0.9049	1.0820	8.2090	14.6950	8.2283	14.2689
+5690	1999.7425	271	1.2420	0.6551	0.9049	1.0820	8.2090	14.6950	8.2269	14.2697
+5691	1999.7452	272	1.2420	0.6551	0.9049	1.0820	8.2090	14.6950	8.2255	14.2706
+5692	1999.7479	273	1.2420	0.6551	0.9049	1.0820	8.2090	14.6950	8.2239	14.2715
+5693	1999.7507	274	1.2420	0.6551	0.9049	1.0820	8.2090	14.6950	8.2222	14.2724
+5694	1999.7534	275	1.2420	0.6550	0.9049	1.0820	8.2090	14.6950	8.2204	14.2734
+5695	1999.7562	276	1.2420	0.6550	0.9049	1.0820	8.2090	14.6950	8.2184	14.2745
+5696	1999.7589	277	1.2419	0.6550	0.9049	1.0820	8.2090	14.6950	8.2164	14.2756
+5697	1999.7616	278	1.2419	0.6550	0.9049	1.0820	8.2090	14.6950	8.2142	14.2768
+5698	1999.7644	279	1.2419	0.6550	0.9049	1.0820	8.2090	14.6950	8.2119	14.2780
+5699	1999.7671	280	1.2419	0.6550	0.9048	1.0820	8.2090	14.6950	8.2096	14.2793
+5700	1999.7699	281	1.2419	0.6550	0.9048	1.0820	8.2090	14.6950	8.2071	14.2806
+5701	1999.7726	282	1.2419	0.6550	0.9048	1.0820	8.2090	14.6950	8.2045	14.2819
+5702	1999.7753	283	1.2419	0.6550	0.9048	1.0820	8.2090	14.6950	8.2018	14.2833
+5703	1999.7781	284	1.2419	0.6550	0.9048	1.0820	8.2090	14.6950	8.1989	14.2847
+5704	1999.7808	285	1.2418	0.6550	0.9048	1.0820	8.2090	14.6950	8.1960	14.2862
+5705	1999.7836	286	1.2418	0.6550	0.9048	1.0820	8.2090	14.6950	8.1930	14.2877
+5706	1999.7863	287	1.2418	0.6550	0.9048	1.0820	8.2090	14.6950	8.1899	14.2893
+5707	1999.7890	288	1.2418	0.6550	0.9048	1.0820	8.2090	14.6950	8.1867	14.2909
+5708	1999.7918	289	1.2418	0.6549	0.9048	1.0820	8.2090	14.6950	8.1835	14.2926
+5709	1999.7945	290	1.2418	0.6549	0.9048	1.0820	8.2090	14.6950	8.1801	14.2943
+5710	1999.7973	291	1.2418	0.6549	0.9048	1.0820	8.2090	14.6950	8.1767	14.2960
+5711	1999.8000	292	1.2418	0.6549	0.9048	1.0820	8.2090	14.6950	8.1731	14.2978
+5712	1999.8027	293	1.2417	0.6549	0.9048	1.0820	8.2090	14.6950	8.1695	14.2996
+5713	1999.8055	294	1.2417	0.6549	0.9048	1.0820	8.2090	14.6950	8.1659	14.3014
+5714	1999.8082	295	1.2417	0.6549	0.9048	1.0820	8.2090	14.6950	8.1621	14.3033
+5715	1999.8110	296	1.2417	0.6549	0.9048	1.0820	8.2090	14.6950	8.1583	14.3052
+5716	1999.8137	297	1.2417	0.6549	0.9048	1.0820	8.2090	14.6950	8.1544	14.3072
+5717	1999.8164	298	1.2417	0.6549	0.9048	1.0820	8.2090	14.6950	8.1505	14.3091
+5718	1999.8192	299	1.2417	0.6549	0.9048	1.0820	8.2090	14.6950	8.1465	14.3112
+5719	1999.8219	300	1.2417	0.6549	0.9048	1.0820	8.2090	14.6950	8.1424	14.3132
+5720	1999.8247	301	1.2416	0.6549	0.9048	1.0820	8.2090	14.6950	8.1383	14.3153
+5721	1999.8274	302	1.2416	0.6549	0.9048	1.0820	8.2090	14.6950	8.1342	14.3174
+5722	1999.8301	303	1.2416	0.6549	0.9048	1.0820	8.2090	14.6950	8.1300	14.3195
+5723	1999.8329	304	1.2416	0.6548	0.9048	1.0820	8.2090	14.6950	8.1258	14.3217
+5724	1999.8356	305	1.2416	0.6548	0.9048	1.0820	8.2090	14.6950	8.1215	14.3239
+5725	1999.8384	306	1.2416	0.6548	0.9048	1.0820	8.2090	14.6950	8.1172	14.3261
+5726	1999.8411	307	1.2416	0.6548	0.9048	1.0820	8.2090	14.6950	8.1128	14.3284
+5727	1999.8438	308	1.2416	0.6548	0.9048	1.0820	8.2090	14.6950	8.1085	14.3307
+5728	1999.8466	309	1.2415	0.6548	0.9048	1.0820	8.2090	14.6950	8.1041	14.3330
+5729	1999.8493	310	1.2415	0.6548	0.9048	1.0820	8.2090	14.6950	8.0997	14.3353
+5730	1999.8521	311	1.2415	0.6548	0.9048	1.0820	8.2090	14.6950	8.0953	14.3376
+5731	1999.8548	312	1.2415	0.6548	0.9048	1.0820	8.2090	14.6950	8.0908	14.3400
+5732	1999.8575	313	1.2415	0.6548	0.9048	1.0820	8.2090	14.6950	8.0864	14.3424
+5733	1999.8603	314	1.2415	0.6548	0.9048	1.0820	8.2090	14.6950	8.0819	14.3448
+5734	1999.8630	315	1.2415	0.6548	0.9048	1.0820	8.2090	14.6950	8.0775	14.3472
+5735	1999.8658	316	1.2415	0.6548	0.9048	1.0820	8.2090	14.6950	8.0730	14.3496
+5736	1999.8685	317	1.2414	0.6548	0.9048	1.0820	8.2090	14.6950	8.0686	14.3521
+5737	1999.8712	318	1.2414	0.6547	0.9048	1.0820	8.2090	14.6950	8.0642	14.3546
+5738	1999.8740	319	1.2414	0.6547	0.9048	1.0820	8.2090	14.6950	8.0597	14.3570
+5739	1999.8767	320	1.2414	0.6547	0.9048	1.0820	8.2090	14.6950	8.0553	14.3595
+5740	1999.8795	321	1.2414	0.6547	0.9048	1.0820	8.2090	14.6950	8.0509	14.3620
+5741	1999.8822	322	1.2414	0.6547	0.9048	1.0820	8.2090	14.6950	8.0466	14.3646
+5742	1999.8849	323	1.2414	0.6547	0.9048	1.0820	8.2090	14.6950	8.0422	14.3671
+5743	1999.8877	324	1.2414	0.6547	0.9048	1.0820	8.2090	14.6950	8.0379	14.3696
+5744	1999.8904	325	1.2413	0.6547	0.9048	1.0820	8.2090	14.6950	8.0336	14.3722
+5745	1999.8932	326	1.2413	0.6547	0.9048	1.0820	8.2090	14.6950	8.0294	14.3747
+5746	1999.8959	327	1.2413	0.6547	0.9048	1.0820	8.2090	14.6950	8.0252	14.3773
+5747	1999.8986	328	1.2413	0.6547	0.9048	1.0820	8.2090	14.6950	8.0210	14.3798
+5748	1999.9014	329	1.2413	0.6547	0.9048	1.0820	8.2090	14.6950	8.0169	14.3824
+5749	1999.9041	330	1.2413	0.6547	0.9048	1.0820	8.2090	14.6950	8.0128	14.3850
+5750	1999.9068	331	1.2413	0.6547	0.9048	1.0820	8.2090	14.6950	8.0088	14.3875
+5751	1999.9096	332	1.2413	0.6547	0.9048	1.0820	8.2090	14.6950	8.0048	14.3901
+5752	1999.9123	333	1.2412	0.6546	0.9048	1.0820	8.2090	14.6950	8.0009	14.3927
+5753	1999.9151	334	1.2412	0.6546	0.9048	1.0820	8.2090	14.6950	7.9970	14.3952
+5754	1999.9178	335	1.2412	0.6546	0.9048	1.0820	8.2090	14.6950	7.9933	14.3978
+5755	1999.9205	336	1.2412	0.6546	0.9048	1.0820	8.2090	14.6950	7.9895	14.4003
+5756	1999.9233	337	1.2412	0.6546	0.9048	1.0820	8.2090	14.6950	7.9859	14.4029
+5757	1999.9260	338	1.2412	0.6546	0.9048	1.0820	8.2090	14.6950	7.9823	14.4054
+5758	1999.9288	339	1.2412	0.6546	0.9048	1.0820	8.2090	14.6950	7.9788	14.4080
+5759	1999.9315	340	1.2412	0.6546	0.9048	1.0820	8.2090	14.6950	7.9753	14.4105
+5760	1999.9342	341	1.2411	0.6546	0.9048	1.0820	8.2090	14.6950	7.9719	14.4130
+5761	1999.9370	342	1.2411	0.6546	0.9048	1.0820	8.2090	14.6950	7.9687	14.4155
+5762	1999.9397	343	1.2411	0.6546	0.9048	1.0820	8.2090	14.6950	7.9655	14.4180
+5763	1999.9425	344	1.2411	0.6546	0.9048	1.0820	8.2090	14.6950	7.9623	14.4205
+5764	1999.9452	345	1.2411	0.6546	0.9048	1.0820	8.2090	14.6950	7.9593	14.4230
+5765	1999.9479	346	1.2411	0.6546	0.9048	1.0820	8.2090	14.6950	7.9564	14.4255
+5766	1999.9507	347	1.2411	0.6545	0.9048	1.0820	8.2090	14.6950	7.9535	14.4279
+5767	1999.9534	348	1.2411	0.6545	0.9048	1.0820	8.2090	14.6950	7.9507	14.4303
+5768	1999.9562	349	1.2410	0.6545	0.9048	1.0820	8.2090	14.6950	7.9481	14.4327
+5769	1999.9589	350	1.2410	0.6545	0.9048	1.0820	8.2090	14.6950	7.9455	14.4351
+5770	1999.9616	351	1.2410	0.6545	0.9048	1.0820	8.2090	14.6950	7.9430	14.4375
+5771	1999.9644	352	1.2410	0.6545	0.9048	1.0820	8.2090	14.6950	7.9407	14.4399
+5772	1999.9671	353	1.2410	0.6545	0.9048	1.0820	8.2090	14.6950	7.9384	14.4422
+5773	1999.9699	354	1.2410	0.6545	0.9048	1.0820	8.2090	14.6950	7.9362	14.4445
+5774	1999.9726	355	1.2410	0.6545	0.9048	1.0820	8.2090	14.6950	7.9341	14.4468
+5775	1999.9753	356	1.2410	0.6545	0.9047	1.0820	8.2090	14.6950	7.9322	14.4490
+5776	1999.9781	357	1.2409	0.6545	0.9047	1.0820	8.2090	14.6950	7.9303	14.4513
+5777	1999.9808	358	1.2409	0.6545	0.9047	1.0820	8.2090	14.6950	7.9286	14.4535
+5778	1999.9836	359	1.2409	0.6545	0.9047	1.0820	8.2090	14.6950	7.9269	14.4557
+5779	1999.9863	360	1.2409	0.6545	0.9047	1.0820	8.2090	14.6950	7.9254	14.4578
+5780	1999.9890	361	1.2409	0.6545	0.9047	1.0820	8.2090	14.6950	7.9240	14.4599
+5781	1999.9918	362	1.2409	0.6544	0.9047	1.0820	8.2090	14.6950	7.9227	14.4620
+5782	1999.9945	363	1.2409	0.6544	0.9047	1.0820	8.2090	14.6950	7.9215	14.4641
+5783	1999.9973	364	1.2409	0.6544	0.9047	1.0820	8.2090	14.6950	7.9204	14.4661
+5784	1999.9999	365	1.2408	0.6544	0.9047	1.0820	8.2090	14.6950	7.9195	14.4681
+5785	2000.0027	1	1.2408	0.6544	0.9047	1.0820	8.2090	14.6950	7.9186	14.4701
+5786	2000.0055	2	1.2408	0.6544	0.9047	1.0820	8.2090	14.6950	7.9179	14.4720
+5787	2000.0082	3	1.2408	0.6544	0.9047	1.0820	8.2090	14.6950	7.9172	14.4739
+5788	2000.0109	4	1.2408	0.6544	0.9047	1.0820	8.2090	14.6950	7.9167	14.4758
+5789	2000.0137	5	1.2408	0.6544	0.9047	1.0820	8.2090	14.6950	7.9163	14.4776
+5790	2000.0164	6	1.2408	0.6544	0.9047	1.0820	8.2090	14.6950	7.9161	14.4794
+5791	2000.0191	7	1.2408	0.6544	0.9047	1.0820	8.2090	14.6950	7.9159	14.4811
+5792	2000.0219	8	1.2407	0.6544	0.9047	1.0820	8.2090	14.6950	7.9159	14.4828
+5793	2000.0246	9	1.2407	0.6544	0.9047	1.0820	8.2090	14.6950	7.9159	14.4845
+5794	2000.0273	10	1.2407	0.6544	0.9047	1.0820	8.2090	14.6950	7.9161	14.4861
+5795	2000.0301	11	1.2407	0.6543	0.9047	1.0820	8.2090	14.6950	7.9164	14.4877
+5796	2000.0328	12	1.2407	0.6543	0.9047	1.0820	8.2090	14.6950	7.9168	14.4892
+5797	2000.0355	13	1.2407	0.6543	0.9047	1.0820	8.2090	14.6950	7.9174	14.4907
+5798	2000.0383	14	1.2407	0.6543	0.9047	1.0820	8.2090	14.6950	7.9180	14.4922
+5799	2000.0410	15	1.2407	0.6543	0.9047	1.0820	8.2090	14.6950	7.9188	14.4936
+5800	2000.0437	16	1.2407	0.6543	0.9047	1.0820	8.2090	14.6950	7.9196	14.4950
+5801	2000.0464	17	1.2406	0.6543	0.9047	1.0820	8.2090	14.6950	7.9206	14.4963
+5802	2000.0492	18	1.2406	0.6543	0.9047	1.0820	8.2090	14.6950	7.9217	14.4976
+5803	2000.0519	19	1.2406	0.6543	0.9047	1.0820	8.2090	14.6950	7.9229	14.4988
+5804	2000.0546	20	1.2406	0.6543	0.9047	1.0820	8.2090	14.6950	7.9242	14.5000
+5805	2000.0574	21	1.2406	0.6543	0.9047	1.0820	8.2090	14.6950	7.9256	14.5011
+5806	2000.0601	22	1.2406	0.6543	0.9047	1.0820	8.2090	14.6950	7.9271	14.5022
+5807	2000.0628	23	1.2406	0.6543	0.9047	1.0820	8.2090	14.6950	7.9288	14.5032
+5808	2000.0656	24	1.2406	0.6543	0.9047	1.0820	8.2090	14.6950	7.9305	14.5042
+5809	2000.0683	25	1.2405	0.6543	0.9047	1.0820	8.2090	14.6950	7.9323	14.5051
+5810	2000.0710	26	1.2405	0.6542	0.9047	1.0820	8.2090	14.6950	7.9343	14.5060
+5811	2000.0738	27	1.2405	0.6542	0.9047	1.0820	8.2090	14.6950	7.9363	14.5069
+5812	2000.0765	28	1.2405	0.6542	0.9047	1.0820	8.2090	14.6950	7.9384	14.5076
+5813	2000.0792	29	1.2405	0.6542	0.9047	1.0820	8.2090	14.6950	7.9407	14.5084
+5814	2000.0820	30	1.2405	0.6542	0.9047	1.0820	8.2090	14.6950	7.9430	14.5091
+5815	2000.0847	31	1.2405	0.6542	0.9047	1.0820	8.2090	14.6950	7.9454	14.5097
+5816	2000.0874	32	1.2405	0.6542	0.9047	1.0820	8.2090	14.6950	7.9479	14.5103
+5817	2000.0902	33	1.2404	0.6542	0.9047	1.0820	8.2090	14.6950	7.9505	14.5108
+5818	2000.0929	34	1.2404	0.6542	0.9047	1.0820	8.2090	14.6950	7.9532	14.5112
+5819	2000.0956	35	1.2404	0.6542	0.9047	1.0820	8.2090	14.6950	7.9560	14.5117
+5820	2000.0984	36	1.2404	0.6542	0.9047	1.0820	8.2090	14.6950	7.9588	14.5120
+5821	2000.1011	37	1.2404	0.6542	0.9047	1.0820	8.2090	14.6950	7.9618	14.5123
+5822	2000.1038	38	1.2404	0.6542	0.9047	1.0820	8.2090	14.6950	7.9648	14.5126
+5823	2000.1066	39	1.2404	0.6542	0.9047	1.0820	8.2090	14.6950	7.9679	14.5128
+5824	2000.1093	40	1.2404	0.6542	0.9047	1.0820	8.2090	14.6950	7.9710	14.5129
+5825	2000.1120	41	1.2404	0.6541	0.9047	1.0820	8.2090	14.6950	7.9743	14.5130
+5826	2000.1148	42	1.2403	0.6541	0.9047	1.0820	8.2090	14.6950	7.9776	14.5130
+5827	2000.1175	43	1.2403	0.6541	0.9047	1.0820	8.2090	14.6950	7.9809	14.5130
+5828	2000.1202	44	1.2403	0.6541	0.9047	1.0820	8.2090	14.6950	7.9844	14.5129
+5829	2000.1230	45	1.2403	0.6541	0.9047	1.0820	8.2090	14.6950	7.9879	14.5127
+5830	2000.1257	46	1.2403	0.6541	0.9047	1.0820	8.2090	14.6950	7.9914	14.5125
+5831	2000.1284	47	1.2403	0.6541	0.9047	1.0820	8.2090	14.6950	7.9950	14.5123
+5832	2000.1311	48	1.2403	0.6541	0.9047	1.0820	8.2090	14.6950	7.9987	14.5120
+5833	2000.1339	49	1.2403	0.6541	0.9047	1.0820	8.2090	14.6950	8.0024	14.5116
+5834	2000.1366	50	1.2402	0.6541	0.9047	1.0820	8.2090	14.6950	8.0061	14.5112
+5835	2000.1393	51	1.2402	0.6541	0.9047	1.0820	8.2090	14.6950	8.0099	14.5107
+5836	2000.1421	52	1.2402	0.6541	0.9047	1.0820	8.2090	14.6950	8.0138	14.5102
+5837	2000.1448	53	1.2402	0.6541	0.9047	1.0820	8.2090	14.6950	8.0177	14.5096
+5838	2000.1475	54	1.2402	0.6541	0.9047	1.0820	8.2090	14.6950	8.0216	14.5089
+5839	2000.1503	55	1.2402	0.6541	0.9047	1.0820	8.2090	14.6950	8.0255	14.5082
+5840	2000.1530	56	1.2402	0.6540	0.9047	1.0820	8.2090	14.6950	8.0295	14.5075
+5841	2000.1557	57	1.2402	0.6540	0.9047	1.0820	8.2090	14.6950	8.0335	14.5066
+5842	2000.1585	58	1.2401	0.6540	0.9047	1.0820	8.2090	14.6950	8.0375	14.5058
+5843	2000.1612	59	1.2401	0.6540	0.9047	1.0820	8.2090	14.6950	8.0416	14.5048
+5844	2000.1639	60	1.2401	0.6540	0.9047	1.0820	8.2090	14.6950	8.0456	14.5039
+5845	2000.1667	61	1.2401	0.6540	0.9047	1.0820	8.2090	14.6950	8.0497	14.5028
+5846	2000.1694	62	1.2401	0.6540	0.9047	1.0820	8.2090	14.6950	8.0538	14.5017
+5847	2000.1721	63	1.2401	0.6540	0.9047	1.0820	8.2090	14.6950	8.0579	14.5006
+5848	2000.1749	64	1.2401	0.6540	0.9047	1.0820	8.2090	14.6950	8.0620	14.4994
+5849	2000.1776	65	1.2401	0.6540	0.9047	1.0820	8.2090	14.6950	8.0661	14.4981
+5850	2000.1803	66	1.2401	0.6540	0.9047	1.0820	8.2090	14.6950	8.0702	14.4968
+5851	2000.1831	67	1.2400	0.6540	0.9047	1.0820	8.2090	14.6950	8.0742	14.4954
+5852	2000.1858	68	1.2400	0.6540	0.9047	1.0820	8.2090	14.6950	8.0783	14.4940
+5853	2000.1885	69	1.2400	0.6540	0.9047	1.0820	8.2090	14.6950	8.0824	14.4926
+5854	2000.1913	70	1.2400	0.6540	0.9047	1.0820	8.2090	14.6950	8.0864	14.4910
+5855	2000.1940	71	1.2400	0.6539	0.9047	1.0820	8.2090	14.6950	8.0905	14.4895
+5856	2000.1967	72	1.2400	0.6539	0.9046	1.0820	8.2090	14.6950	8.0945	14.4878
+5857	2000.1995	73	1.2400	0.6539	0.9046	1.0820	8.2090	14.6950	8.0984	14.4862
+5858	2000.2022	74	1.2400	0.6539	0.9046	1.0820	8.2090	14.6950	8.1024	14.4844
+5859	2000.2049	75	1.2399	0.6539	0.9046	1.0820	8.2090	14.6950	8.1063	14.4827
+5860	2000.2077	76	1.2399	0.6539	0.9046	1.0820	8.2090	14.6950	8.1102	14.4808
+5861	2000.2104	77	1.2399	0.6539	0.9046	1.0820	8.2090	14.6950	8.1140	14.4789
+5862	2000.2131	78	1.2399	0.6539	0.9046	1.0820	8.2090	14.6950	8.1178	14.4770
+5863	2000.2158	79	1.2399	0.6539	0.9046	1.0820	8.2090	14.6950	8.1216	14.4750
+5864	2000.2186	80	1.2399	0.6539	0.9046	1.0820	8.2090	14.6950	8.1253	14.4730
+5865	2000.2213	81	1.2399	0.6539	0.9046	1.0820	8.2090	14.6950	8.1289	14.4710
+5866	2000.2240	82	1.2399	0.6539	0.9046	1.0820	8.2090	14.6950	8.2090	14.6950
+5867	2000.2268	83	1.2399	0.6539	0.9046	1.0820	8.2090	14.6950	8.2056	14.6949
+5868	2000.2295	84	1.2398	0.6539	0.9046	1.0820	8.2090	14.6950	8.2021	14.6948
+5869	2000.2322	85	1.2398	0.6539	0.9046	1.0820	8.2090	14.6950	8.1986	14.6947
+5870	2000.2350	86	1.2398	0.6538	0.9046	1.0820	8.2090	14.6950	8.1950	14.6944
+5871	2000.2377	87	1.2398	0.6538	0.9046	1.0820	8.2090	14.6950	8.1913	14.6942
+5872	2000.2404	88	1.2398	0.6538	0.9046	1.0820	8.2090	14.6950	8.1876	14.6938
+5873	2000.2432	89	1.2398	0.6538	0.9046	1.0820	8.2090	14.6950	8.1838	14.6934
+5874	2000.2459	90	1.2398	0.6538	0.9046	1.0820	8.2090	14.6950	8.1799	14.6930
+5875	2000.2486	91	1.2398	0.6538	0.9046	1.0820	8.2090	14.6950	8.1760	14.6925
+5876	2000.2514	92	1.2397	0.6538	0.9046	1.0820	8.2090	14.6950	8.1721	14.6919
+5877	2000.2541	93	1.2397	0.6538	0.9046	1.0820	8.2090	14.6950	8.1681	14.6913
+5878	2000.2568	94	1.2397	0.6538	0.9046	1.0820	8.2090	14.6950	8.1640	14.6906
+5879	2000.2596	95	1.2397	0.6538	0.9046	1.0820	8.2090	14.6950	8.1599	14.6898
+5880	2000.2623	96	1.2397	0.6538	0.9046	1.0820	8.2090	14.6950	8.1557	14.6890
+5881	2000.2650	97	1.2397	0.6538	0.9046	1.0820	8.2090	14.6950	8.1516	14.6882
+5882	2000.2678	98	1.2397	0.6538	0.9046	1.0820	8.2090	14.6950	8.1474	14.6873
+5883	2000.2705	99	1.2397	0.6538	0.9046	1.0820	8.2090	14.6950	8.1431	14.6863
+5884	2000.2732	100	1.2397	0.6538	0.9046	1.0820	8.2090	14.6950	8.1389	14.6853
+5885	2000.2760	101	1.2396	0.6537	0.9046	1.0820	8.2090	14.6950	8.1346	14.6842
+5886	2000.2787	102	1.2396	0.6537	0.9046	1.0820	8.2090	14.6950	8.1303	14.6831
+5887	2000.2814	103	1.2396	0.6537	0.9046	1.0820	8.2090	14.6950	8.1259	14.6819
+5888	2000.2842	104	1.2396	0.6537	0.9046	1.0820	8.2090	14.6950	8.1216	14.6807
+5889	2000.2869	105	1.2396	0.6537	0.9046	1.0820	8.2090	14.6950	8.1172	14.6794
+5890	2000.2896	106	1.2396	0.6537	0.9046	1.0820	8.2090	14.6950	8.1129	14.6780
+5891	2000.2923	107	1.2396	0.6537	0.9046	1.0820	8.2090	14.6950	8.1085	14.6766
+5892	2000.2951	108	1.2396	0.6537	0.9046	1.0820	8.2090	14.6950	8.1042	14.6752
+5893	2000.2978	109	1.2395	0.6537	0.9046	1.0820	8.2090	14.6950	8.0998	14.6737
+5894	2000.3005	110	1.2395	0.6537	0.9046	1.0820	8.2090	14.6950	8.0954	14.6721
+5895	2000.3033	111	1.2395	0.6537	0.9046	1.0820	8.2090	14.6950	8.0911	14.6705
+5896	2000.3060	112	1.2395	0.6537	0.9046	1.0820	8.2090	14.6950	8.0868	14.6688
+5897	2000.3087	113	1.2395	0.6537	0.9046	1.0820	8.2090	14.6950	8.0825	14.6671
+5898	2000.3115	114	1.2395	0.6537	0.9046	1.0820	8.2090	14.6950	8.0782	14.6653
+5899	2000.3142	115	1.2395	0.6537	0.9046	1.0820	8.2090	14.6950	8.0739	14.6635
+5900	2000.3169	116	1.2395	0.6536	0.9046	1.0820	8.2090	14.6950	8.0696	14.6616
+5901	2000.3197	117	1.2395	0.6536	0.9046	1.0820	8.2090	14.6950	8.0654	14.6597
+5902	2000.3224	118	1.2394	0.6536	0.9046	1.0820	8.2090	14.6950	8.0612	14.6577
+5903	2000.3251	119	1.2394	0.6536	0.9046	1.0820	8.2090	14.6950	8.0571	14.6557
+5904	2000.3279	120	1.2394	0.6536	0.9046	1.0820	8.2090	14.6950	8.0530	14.6536
+5905	2000.3306	121	1.2394	0.6536	0.9046	1.0820	8.2090	14.6950	8.0489	14.6515
+5906	2000.3333	122	1.2394	0.6536	0.9046	1.0820	8.2090	14.6950	8.0448	14.6494
+5907	2000.3361	123	1.2394	0.6536	0.9046	1.0820	8.2090	14.6950	8.0408	14.6472
+5908	2000.3388	124	1.2394	0.6536	0.9046	1.0820	8.2090	14.6950	8.0369	14.6449
+5909	2000.3415	125	1.2394	0.6536	0.9046	1.0820	8.2090	14.6950	8.0330	14.6426
+5910	2000.3443	126	1.2393	0.6536	0.9046	1.0820	8.2090	14.6950	8.0292	14.6403
+5911	2000.3470	127	1.2393	0.6536	0.9046	1.0820	8.2090	14.6950	8.0254	14.6379
+5912	2000.3497	128	1.2393	0.6536	0.9046	1.0820	8.2090	14.6950	8.0217	14.6354
+5913	2000.3525	129	1.2393	0.6536	0.9046	1.0820	8.2090	14.6950	8.0180	14.6330
+5914	2000.3552	130	1.2393	0.6536	0.9046	1.0820	8.2090	14.6950	8.0144	14.6305
+5915	2000.3579	131	1.2393	0.6535	0.9046	1.0820	8.2090	14.6950	8.0109	14.6279
+5916	2000.3607	132	1.2393	0.6535	0.9046	1.0820	8.2090	14.6950	8.0074	14.6253
+5917	2000.3634	133	1.2393	0.6535	0.9046	1.0820	8.2090	14.6950	8.0040	14.6227
+5918	2000.3661	134	1.2393	0.6535	0.9046	1.0820	8.2090	14.6950	8.0007	14.6200
+5919	2000.3689	135	1.2392	0.6535	0.9046	1.0820	8.2090	14.6950	7.9975	14.6173
+5920	2000.3716	136	1.2392	0.6535	0.9046	1.0820	8.2090	14.6950	7.9943	14.6145
+5921	2000.3743	137	1.2392	0.6535	0.9046	1.0820	8.2090	14.6950	7.9912	14.6117
+5922	2000.3770	138	1.2392	0.6535	0.9046	1.0820	8.2090	14.6950	7.9882	14.6089
+5923	2000.3798	139	1.2392	0.6535	0.9046	1.0820	8.2090	14.6950	7.9853	14.6061
+5924	2000.3825	140	1.2392	0.6535	0.9046	1.0820	8.2090	14.6950	7.9825	14.6032
+5925	2000.3852	141	1.2392	0.6535	0.9046	1.0820	8.2090	14.6950	7.9797	14.6003
+5926	2000.3880	142	1.2392	0.6535	0.9046	1.0820	8.2090	14.6950	7.9771	14.5973
+5927	2000.3907	143	1.2392	0.6535	0.9046	1.0820	8.2090	14.6950	7.9745	14.5943
+5928	2000.3934	144	1.2391	0.6535	0.9046	1.0820	8.2090	14.6950	7.9720	14.5913
+5929	2000.3962	145	1.2391	0.6535	0.9046	1.0820	8.2090	14.6950	7.9697	14.5882
+5930	2000.3989	146	1.2391	0.6534	0.9046	1.0820	8.2090	14.6950	7.9674	14.5852
+5931	2000.4016	147	1.2391	0.6534	0.9046	1.0820	8.2090	14.6950	7.9652	14.5821
+5932	2000.4044	148	1.2391	0.6534	0.9046	1.0820	8.2090	14.6950	7.9631	14.5789
+5933	2000.4071	149	1.2391	0.6534	0.9046	1.0820	8.2090	14.6950	7.9611	14.5758
+5934	2000.4098	150	1.2391	0.6534	0.9046	1.0820	8.2090	14.6950	7.9592	14.5726
+5935	2000.4126	151	1.2391	0.6534	0.9046	1.0820	8.2090	14.6950	7.9575	14.5694
+5936	2000.4153	152	1.2390	0.6534	0.9046	1.0820	8.2090	14.6950	7.9558	14.5661
+5937	2000.4180	153	1.2390	0.6534	0.9046	1.0820	8.2090	14.6950	7.9542	14.5629
+5938	2000.4208	154	1.2390	0.6534	0.9046	1.0820	8.2090	14.6950	7.9527	14.5596
+5939	2000.4235	155	1.2390	0.6534	0.9046	1.0820	8.2090	14.6950	7.9514	14.5563
+5940	2000.4262	156	1.2390	0.6534	0.9046	1.0820	8.2090	14.6950	7.9501	14.5530
+5941	2000.4290	157	1.2390	0.6534	0.9045	1.0820	8.2090	14.6950	7.9489	14.5496
+5942	2000.4317	158	1.2390	0.6534	0.9045	1.0820	8.2090	14.6950	7.9479	14.5463
+5943	2000.4344	159	1.2390	0.6534	0.9045	1.0820	8.2090	14.6950	7.9470	14.5429
+5944	2000.4372	160	1.2390	0.6534	0.9045	1.0820	8.2090	14.6950	7.9461	14.5395
+5945	2000.4399	161	1.2389	0.6533	0.9045	1.0820	8.2090	14.6950	7.9454	14.5361
+5946	2000.4426	162	1.2389	0.6533	0.9045	1.0820	8.2090	14.6950	7.9448	14.5327
+5947	2000.4454	163	1.2389	0.6533	0.9045	1.0820	8.2090	14.6950	7.9443	14.5292
+5948	2000.4481	164	1.2389	0.6533	0.9045	1.0820	8.2090	14.6950	7.9439	14.5258
+5949	2000.4508	165	1.2389	0.6533	0.9045	1.0820	8.2090	14.6950	7.9436	14.5223
+5950	2000.4536	166	1.2389	0.6533	0.9045	1.0820	8.2090	14.6950	7.9435	14.5189
+5951	2000.4563	167	1.2389	0.6533	0.9045	1.0820	8.2090	14.6950	7.9434	14.5154
+5952	2000.4590	168	1.2389	0.6533	0.9045	1.0820	8.2090	14.6950	7.9435	14.5119
+5953	2000.4617	169	1.2389	0.6533	0.9045	1.0820	8.2090	14.6950	7.9436	14.5084
+5954	2000.4645	170	1.2388	0.6533	0.9045	1.0820	8.2090	14.6950	7.9439	14.5049
+5955	2000.4672	171	1.2388	0.6533	0.9045	1.0820	8.2090	14.6950	7.9443	14.5014
+5956	2000.4699	172	1.2388	0.6533	0.9045	1.0820	8.2090	14.6950	7.9448	14.4979
+5957	2000.4727	173	1.2388	0.6533	0.9045	1.0820	8.2090	14.6950	7.9454	14.4944
+5958	2000.4754	174	1.2388	0.6533	0.9045	1.0820	8.2090	14.6950	7.9461	14.4909
+5959	2000.4781	175	1.2388	0.6533	0.9045	1.0820	8.2090	14.6950	7.9469	14.4874
+5960	2000.4809	176	1.2388	0.6533	0.9045	1.0820	8.2090	14.6950	7.9478	14.4838
+5961	2000.4836	177	1.2388	0.6532	0.9045	1.0820	8.2090	14.6950	7.9488	14.4803
+5962	2000.4863	178	1.2388	0.6532	0.9045	1.0820	8.2090	14.6950	7.9500	14.4768
+5963	2000.4891	179	1.2387	0.6532	0.9045	1.0820	8.2090	14.6950	7.9512	14.4733
+5964	2000.4918	180	1.2387	0.6532	0.9045	1.0820	8.2090	14.6950	7.9526	14.4698
+5965	2000.4945	181	1.2387	0.6532	0.9045	1.0820	8.2090	14.6950	7.9540	14.4663
+5966	2000.4973	182	1.2387	0.6532	0.9045	1.0820	8.2090	14.6950	7.9555	14.4628
+5967	2000.5000	183	1.2387	0.6532	0.9045	1.0820	8.2090	14.6950	7.9572	14.4593
+5968	2000.5027	184	1.2387	0.6532	0.9045	1.0820	8.2090	14.6950	7.9589	14.4558
+5969	2000.5055	185	1.2387	0.6532	0.9045	1.0820	8.2090	14.6950	7.9608	14.4523
+5970	2000.5082	186	1.2387	0.6532	0.9045	1.0820	8.2090	14.6950	7.9627	14.4488
+5971	2000.5109	187	1.2387	0.6532	0.9045	1.0820	8.2090	14.6950	7.9647	14.4453
+5972	2000.5137	188	1.2386	0.6532	0.9045	1.0820	8.2090	14.6950	7.9668	14.4419
+5973	2000.5164	189	1.2386	0.6532	0.9045	1.0820	8.2090	14.6950	7.9691	14.4384
+5974	2000.5191	190	1.2386	0.6532	0.9045	1.0820	8.2090	14.6950	7.9714	14.4350
+5975	2000.5219	191	1.2386	0.6532	0.9045	1.0820	8.2090	14.6950	7.9737	14.4316
+5976	2000.5246	192	1.2386	0.6531	0.9045	1.0820	8.2090	14.6950	7.9762	14.4282
+5977	2000.5273	193	1.2386	0.6531	0.9045	1.0820	8.2090	14.6950	7.9788	14.4248
+5978	2000.5301	194	1.2386	0.6531	0.9045	1.0820	8.2090	14.6950	7.9814	14.4214
+5979	2000.5328	195	1.2386	0.6531	0.9045	1.0820	8.2090	14.6950	7.9842	14.4181
+5980	2000.5355	196	1.2385	0.6531	0.9045	1.0820	8.2090	14.6950	7.9870	14.4147
+5981	2000.5383	197	1.2385	0.6531	0.9045	1.0820	8.2090	14.6950	7.9898	14.4114
+5982	2000.5410	198	1.2385	0.6531	0.9045	1.0820	8.2090	14.6950	7.9928	14.4081
+5983	2000.5437	199	1.2385	0.6531	0.9045	1.0820	8.2090	14.6950	7.9958	14.4048
+5984	2000.5464	200	1.2385	0.6531	0.9045	1.0820	8.2090	14.6950	7.9989	14.4016
+5985	2000.5492	201	1.2385	0.6531	0.9045	1.0820	8.2090	14.6950	8.0021	14.3983
+5986	2000.5519	202	1.2385	0.6531	0.9045	1.0820	8.2090	14.6950	8.0053	14.3951
+5987	2000.5546	203	1.2385	0.6531	0.9045	1.0820	8.2090	14.6950	8.0086	14.3919
+5988	2000.5574	204	1.2385	0.6531	0.9045	1.0820	8.2090	14.6950	8.0120	14.3888
+5989	2000.5601	205	1.2384	0.6531	0.9045	1.0820	8.2090	14.6950	8.0154	14.3856
+5990	2000.5628	206	1.2384	0.6531	0.9045	1.0820	8.2090	14.6950	8.0189	14.3825
+5991	2000.5656	207	1.2384	0.6531	0.9045	1.0820	8.2090	14.6950	8.0224	14.3794
+5992	2000.5683	208	1.2384	0.6530	0.9045	1.0820	8.2090	14.6950	8.0260	14.3764
+5993	2000.5710	209	1.2384	0.6530	0.9045	1.0820	8.2090	14.6950	8.0296	14.3733
+5994	2000.5738	210	1.2384	0.6530	0.9045	1.0820	8.2090	14.6950	8.0333	14.3703
+5995	2000.5765	211	1.2384	0.6530	0.9045	1.0820	8.2090	14.6950	8.0370	14.3674
+5996	2000.5792	212	1.2384	0.6530	0.9045	1.0820	8.2090	14.6950	8.0407	14.3644
+5997	2000.5820	213	1.2384	0.6530	0.9045	1.0820	8.2090	14.6950	8.0445	14.3615
+5998	2000.5847	214	1.2383	0.6530	0.9045	1.0820	8.2090	14.6950	8.0483	14.3586
+5999	2000.5874	215	1.2383	0.6530	0.9045	1.0820	8.2090	14.6950	8.0522	14.3558
+6000	2000.5902	216	1.2383	0.6530	0.9045	1.0820	8.2090	14.6950	8.0561	14.3530
+6001	2000.5929	217	1.2383	0.6530	0.9045	1.0820	8.2090	14.6950	8.0600	14.3502
+6002	2000.5956	218	1.2383	0.6530	0.9045	1.0820	8.2090	14.6950	8.0639	14.3474
+6003	2000.5984	219	1.2383	0.6530	0.9045	1.0820	8.2090	14.6950	8.0679	14.3447
+6004	2000.6011	220	1.2383	0.6530	0.9045	1.0820	8.2090	14.6950	8.0718	14.3421
+6005	2000.6038	221	1.2383	0.6530	0.9045	1.0820	8.2090	14.6950	8.0758	14.3394
+6006	2000.6066	222	1.2383	0.6530	0.9045	1.0820	8.2090	14.6950	8.0798	14.3368
+6007	2000.6093	223	1.2382	0.6529	0.9045	1.0820	8.2090	14.6950	8.0838	14.3342
+6008	2000.6120	224	1.2382	0.6529	0.9045	1.0820	8.2090	14.6950	8.0878	14.3317
+6009	2000.6148	225	1.2382	0.6529	0.9045	1.0820	8.2090	14.6950	8.0919	14.3292
+6010	2000.6175	226	1.2382	0.6529	0.9045	1.0820	8.2090	14.6950	8.0959	14.3268
+6011	2000.6202	227	1.2382	0.6529	0.9045	1.0820	8.2090	14.6950	8.0999	14.3244
+6012	2000.6230	228	1.2382	0.6529	0.9045	1.0820	8.2090	14.6950	8.1039	14.3220
+6013	2000.6257	229	1.2382	0.6529	0.9045	1.0820	8.2090	14.6950	8.1079	14.3197
+6014	2000.6284	230	1.2382	0.6529	0.9045	1.0820	8.2090	14.6950	8.1119	14.3174
+6015	2000.6311	231	1.2382	0.6529	0.9045	1.0820	8.2090	14.6950	8.1158	14.3152
+6016	2000.6339	232	1.2381	0.6529	0.9045	1.0820	8.2090	14.6950	8.1198	14.3130
+6017	2000.6366	233	1.2381	0.6529	0.9045	1.0820	8.2090	14.6950	8.1237	14.3108
+6018	2000.6393	234	1.2381	0.6529	0.9045	1.0820	8.2090	14.6950	8.1276	14.3087
+6019	2000.6421	235	1.2381	0.6529	0.9045	1.0820	8.2090	14.6950	8.1314	14.3066
+6020	2000.6448	236	1.2381	0.6529	0.9045	1.0820	8.2090	14.6950	8.1353	14.3046
+6021	2000.6475	237	1.2381	0.6529	0.9045	1.0820	8.2090	14.6950	8.1391	14.3026
+6022	2000.6503	238	1.2381	0.6529	0.9045	1.0820	8.2090	14.6950	8.1428	14.3007
+6023	2000.6530	239	1.2381	0.6528	0.9045	1.0820	8.2090	14.6950	8.1466	14.2988
+6024	2000.6557	240	1.2381	0.6528	0.9045	1.0820	8.2090	14.6950	8.1503	14.2970
+6025	2000.6585	241	1.2380	0.6528	0.9045	1.0820	8.2090	14.6950	8.1539	14.2952
+6026	2000.6612	242	1.2380	0.6528	0.9045	1.0820	8.2090	14.6950	8.1575	14.2934
+6027	2000.6639	243	1.2380	0.6528	0.9045	1.0820	8.2090	14.6950	8.1610	14.2917
+6028	2000.6667	244	1.2380	0.6528	0.9045	1.0820	8.2090	14.6950	8.1645	14.2901
+6029	2000.6694	245	1.2380	0.6528	0.9045	1.0820	8.2090	14.6950	8.1679	14.2884
+6030	2000.6721	246	1.2380	0.6528	0.9045	1.0820	8.2090	14.6950	8.1713	14.2869
+6031	2000.6749	247	1.2380	0.6528	0.9044	1.0820	8.2090	14.6950	8.1746	14.2854
+6032	2000.6776	248	1.2380	0.6528	0.9044	1.0820	8.2090	14.6950	8.1778	14.2839
+6033	2000.6803	249	1.2380	0.6528	0.9044	1.0820	8.2090	14.6950	8.1810	14.2825
+6034	2000.6831	250	1.2379	0.6528	0.9044	1.0820	8.2090	14.6950	8.1841	14.2811
+6035	2000.6858	251	1.2379	0.6528	0.9044	1.0820	8.2090	14.6950	8.1871	14.2798
+6036	2000.6885	252	1.2379	0.6528	0.9044	1.0820	8.2090	14.6950	8.1901	14.2785
+6037	2000.6913	253	1.2379	0.6528	0.9044	1.0820	8.2090	14.6950	8.1930	14.2773
+6038	2000.6940	254	1.2379	0.6528	0.9044	1.0820	8.2090	14.6950	8.1958	14.2762
+6039	2000.6967	255	1.2379	0.6527	0.9044	1.0820	8.2090	14.6950	8.1985	14.2750
+6040	2000.6995	256	1.2379	0.6527	0.9044	1.0820	8.2090	14.6950	8.2011	14.2740
+6041	2000.7022	257	1.2379	0.6527	0.9044	1.0820	8.2090	14.6950	8.2036	14.2729
+6042	2000.7049	258	1.2379	0.6527	0.9044	1.0820	8.2090	14.6950	8.2061	14.2720
+6043	2000.7077	259	1.2378	0.6527	0.9044	1.0820	8.2090	14.6950	8.2085	14.2711
+6044	2000.7104	260	1.2378	0.6527	0.9044	1.0820	8.2090	14.6950	8.2107	14.2702
+6045	2000.7131	261	1.2378	0.6527	0.9044	1.0820	8.2090	14.6950	8.2129	14.2694
+6046	2000.7158	262	1.2378	0.6527	0.9044	1.0820	8.2090	14.6950	8.2150	14.2686
+6047	2000.7186	263	1.2378	0.6527	0.9044	1.0820	8.2090	14.6950	8.2170	14.2679
+6048	2000.7213	264	1.2378	0.6527	0.9044	1.0820	8.2090	14.6950	8.2189	14.2672
+6049	2000.7240	265	1.2378	0.6527	0.9044	1.0820	8.2090	14.6950	8.2207	14.2666
+6050	2000.7268	266	1.2378	0.6527	0.9044	1.0820	8.2090	14.6950	8.2223	14.2660
+6051	2000.7295	267	1.2378	0.6527	0.9044	1.0820	8.2090	14.6950	8.2239	14.2655
+6052	2000.7322	268	1.2377	0.6527	0.9044	1.0820	8.2090	14.6950	8.2254	14.2651
+6053	2000.7350	269	1.2377	0.6527	0.9044	1.0820	8.2090	14.6950	8.2268	14.2647
+6054	2000.7377	270	1.2377	0.6526	0.9044	1.0820	8.2090	14.6950	8.2280	14.2643
+6055	2000.7404	271	1.2377	0.6526	0.9044	1.0820	8.2090	14.6950	8.2292	14.2640
+6056	2000.7432	272	1.2377	0.6526	0.9044	1.0820	8.2090	14.6950	8.2302	14.2637
+6057	2000.7459	273	1.2377	0.6526	0.9044	1.0820	8.2090	14.6950	8.2312	14.2635
+6058	2000.7486	274	1.2377	0.6526	0.9044	1.0820	8.2090	14.6950	8.2320	14.2634
+6059	2000.7514	275	1.2377	0.6526	0.9044	1.0820	8.2090	14.6950	8.2327	14.2632
+6060	2000.7541	276	1.2377	0.6526	0.9044	1.0820	8.2090	14.6950	8.2333	14.2632
+6061	2000.7568	277	1.2376	0.6526	0.9044	1.0820	8.2090	14.6950	8.2338	14.2632
+6062	2000.7596	278	1.2376	0.6526	0.9044	1.0820	8.2090	14.6950	8.2342	14.2632
+6063	2000.7623	279	1.2376	0.6526	0.9044	1.0820	8.2090	14.6950	8.2344	14.2633
+6064	2000.7650	280	1.2376	0.6526	0.9044	1.0820	8.2090	14.6950	8.2346	14.2634
+6065	2000.7678	281	1.2376	0.6526	0.9044	1.0820	8.2090	14.6950	8.2346	14.2636
+6066	2000.7705	282	1.2376	0.6526	0.9044	1.0820	8.2090	14.6950	8.2345	14.2639
+6067	2000.7732	283	1.2376	0.6526	0.9044	1.0820	8.2090	14.6950	8.2343	14.2641
+6068	2000.7760	284	1.2376	0.6526	0.9044	1.0820	8.2090	14.6950	8.2340	14.2645
+6069	2000.7787	285	1.2376	0.6526	0.9044	1.0820	8.2090	14.6950	8.2336	14.2649
+6070	2000.7814	286	1.2375	0.6525	0.9044	1.0820	8.2090	14.6950	8.2331	14.2653
+6071	2000.7842	287	1.2375	0.6525	0.9044	1.0820	8.2090	14.6950	8.2324	14.2658
+6072	2000.7869	288	1.2375	0.6525	0.9044	1.0820	8.2090	14.6950	8.2316	14.2663
+6073	2000.7896	289	1.2375	0.6525	0.9044	1.0820	8.2090	14.6950	8.2308	14.2668
+6074	2000.7923	290	1.2375	0.6525	0.9044	1.0820	8.2090	14.6950	8.2298	14.2675
+6075	2000.7951	291	1.2375	0.6525	0.9044	1.0820	8.2090	14.6950	8.2287	14.2681
+6076	2000.7978	292	1.2375	0.6525	0.9044	1.0820	8.2090	14.6950	8.2275	14.2688
+6077	2000.8005	293	1.2375	0.6525	0.9044	1.0820	8.2090	14.6950	8.2262	14.2696
+6078	2000.8033	294	1.2375	0.6525	0.9044	1.0820	8.2090	14.6950	8.2248	14.2704
+6079	2000.8060	295	1.2375	0.6525	0.9044	1.0820	8.2090	14.6950	8.2232	14.2712
+6080	2000.8087	296	1.2374	0.6525	0.9044	1.0820	8.2090	14.6950	8.2216	14.2721
+6081	2000.8115	297	1.2374	0.6525	0.9044	1.0820	8.2090	14.6950	8.2199	14.2730
+6082	2000.8142	298	1.2374	0.6525	0.9044	1.0820	8.2090	14.6950	8.2180	14.2740
+6083	2000.8169	299	1.2374	0.6525	0.9044	1.0820	8.2090	14.6950	8.2161	14.2750
+6084	2000.8197	300	1.2374	0.6525	0.9044	1.0820	8.2090	14.6950	8.2140	14.2761
+6085	2000.8224	301	1.2374	0.6525	0.9044	1.0820	8.2090	14.6950	8.2119	14.2772
+6086	2000.8251	302	1.2374	0.6524	0.9044	1.0820	8.2090	14.6950	8.2097	14.2783
+6087	2000.8279	303	1.2374	0.6524	0.9044	1.0820	8.2090	14.6950	8.2073	14.2795
+6088	2000.8306	304	1.2374	0.6524	0.9044	1.0820	8.2090	14.6950	8.2049	14.2807
+6089	2000.8333	305	1.2373	0.6524	0.9044	1.0820	8.2090	14.6950	8.2024	14.2820
+6090	2000.8361	306	1.2373	0.6524	0.9044	1.0820	8.2090	14.6950	8.1998	14.2833
+6091	2000.8388	307	1.2373	0.6524	0.9044	1.0820	8.2090	14.6950	8.1971	14.2846
+6092	2000.8415	308	1.2373	0.6524	0.9044	1.0820	8.2090	14.6950	8.1943	14.2860
+6093	2000.8443	309	1.2373	0.6524	0.9044	1.0820	8.2090	14.6950	8.1915	14.2874
+6094	2000.8470	310	1.2373	0.6524	0.9044	1.0820	8.2090	14.6950	8.1885	14.2889
+6095	2000.8497	311	1.2373	0.6524	0.9044	1.0820	8.2090	14.6950	8.1855	14.2904
+6096	2000.8525	312	1.2373	0.6524	0.9044	1.0820	8.2090	14.6950	8.1824	14.2919
+6097	2000.8552	313	1.2373	0.6524	0.9044	1.0820	8.2090	14.6950	8.1793	14.2935
+6098	2000.8579	314	1.2372	0.6524	0.9044	1.0820	8.2090	14.6950	8.1760	14.2950
+6099	2000.8607	315	1.2372	0.6524	0.9044	1.0820	8.2090	14.6950	8.1727	14.2967
+6100	2000.8634	316	1.2372	0.6524	0.9044	1.0820	8.2090	14.6950	8.1693	14.2983
+6101	2000.8661	317	1.2372	0.6524	0.9044	1.0820	8.2090	14.6950	8.1659	14.3000
+6102	2000.8689	318	1.2372	0.6523	0.9044	1.0820	8.2090	14.6950	8.1624	14.3018
+6103	2000.8716	319	1.2372	0.6523	0.9044	1.0820	8.2090	14.6950	8.1588	14.3035
+6104	2000.8743	320	1.2372	0.6523	0.9044	1.0820	8.2090	14.6950	8.1552	14.3053
+6105	2000.8770	321	1.2372	0.6523	0.9044	1.0820	8.2090	14.6950	8.1515	14.3071
+6106	2000.8798	322	1.2372	0.6523	0.9044	1.0820	8.2090	14.6950	8.1478	14.3090
+6107	2000.8825	323	1.2371	0.6523	0.9044	1.0820	8.2090	14.6950	8.1440	14.3109
+6108	2000.8852	324	1.2371	0.6523	0.9044	1.0820	8.2090	14.6950	8.1402	14.3128
+6109	2000.8880	325	1.2371	0.6523	0.9044	1.0820	8.2090	14.6950	8.1363	14.3147
+6110	2000.8907	326	1.2371	0.6523	0.9044	1.0820	8.2090	14.6950	8.1324	14.3167
+6111	2000.8934	327	1.2371	0.6523	0.9044	1.0820	8.2090	14.6950	8.1285	14.3187
+6112	2000.8962	328	1.2371	0.6523	0.9044	1.0820	8.2090	14.6950	8.1245	14.3207
+6113	2000.8989	329	1.2371	0.6523	0.9044	1.0820	8.2090	14.6950	8.1205	14.3227
+6114	2000.9016	330	1.2371	0.6523	0.9044	1.0820	8.2090	14.6950	8.1165	14.3248
+6115	2000.9044	331	1.2371	0.6523	0.9044	1.0820	8.2090	14.6950	8.1124	14.3269
+6116	2000.9071	332	1.2371	0.6523	0.9044	1.0820	8.2090	14.6950	8.1083	14.3290
+6117	2000.9098	333	1.2370	0.6523	0.9044	1.0820	8.2090	14.6950	8.1042	14.3311
+6118	2000.9126	334	1.2370	0.6522	0.9044	1.0820	8.2090	14.6950	8.1001	14.3332
+6119	2000.9153	335	1.2370	0.6522	0.9044	1.0820	8.2090	14.6950	8.0960	14.3354
+6120	2000.9180	336	1.2370	0.6522	0.9044	1.0820	8.2090	14.6950	8.0918	14.3376
+6121	2000.9208	337	1.2370	0.6522	0.9044	1.0820	8.2090	14.6950	8.0876	14.3398
+6122	2000.9235	338	1.2370	0.6522	0.9044	1.0820	8.2090	14.6950	8.0835	14.3420
+6123	2000.9262	339	1.2370	0.6522	0.9044	1.0820	8.2090	14.6950	8.0793	14.3442
+6124	2000.9290	340	1.2370	0.6522	0.9044	1.0820	8.2090	14.6950	8.0752	14.3465
+6125	2000.9317	341	1.2370	0.6522	0.9044	1.0820	8.2090	14.6950	8.0710	14.3488
+6126	2000.9344	342	1.2369	0.6522	0.9044	1.0820	8.2090	14.6950	8.0668	14.3511
+6127	2000.9372	343	1.2369	0.6522	0.9043	1.0820	8.2090	14.6950	8.0627	14.3533
+6128	2000.9399	344	1.2369	0.6522	0.9043	1.0820	8.2090	14.6950	8.0585	14.3557
+6129	2000.9426	345	1.2369	0.6522	0.9043	1.0820	8.2090	14.6950	8.0544	14.3580
+6130	2000.9454	346	1.2369	0.6522	0.9043	1.0820	8.2090	14.6950	8.0503	14.3603
+6131	2000.9481	347	1.2369	0.6522	0.9043	1.0820	8.2090	14.6950	8.0462	14.3627
+6132	2000.9508	348	1.2369	0.6522	0.9043	1.0820	8.2090	14.6950	8.0422	14.3650
+6133	2000.9536	349	1.2369	0.6522	0.9043	1.0820	8.2090	14.6950	8.0381	14.3674
+6134	2000.9563	350	1.2369	0.6521	0.9043	1.0820	8.2090	14.6950	8.0341	14.3697
+6135	2000.9590	351	1.2368	0.6521	0.9043	1.0820	8.2090	14.6950	8.0301	14.3721
+6136	2000.9617	352	1.2368	0.6521	0.9043	1.0820	8.2090	14.6950	8.0262	14.3745
+6137	2000.9645	353	1.2368	0.6521	0.9043	1.0820	8.2090	14.6950	8.0223	14.3769
+6138	2000.9672	354	1.2368	0.6521	0.9043	1.0820	8.2090	14.6950	8.0184	14.3793
+6139	2000.9699	355	1.2368	0.6521	0.9043	1.0820	8.2090	14.6950	8.0146	14.3816
+6140	2000.9727	356	1.2368	0.6521	0.9043	1.0820	8.2090	14.6950	8.0108	14.3840
+6141	2000.9754	357	1.2368	0.6521	0.9043	1.0820	8.2090	14.6950	8.0070	14.3864
+6142	2000.9781	358	1.2368	0.6521	0.9043	1.0820	8.2090	14.6950	8.0033	14.3888
+6143	2000.9809	359	1.2368	0.6521	0.9043	1.0820	8.2090	14.6950	7.9997	14.3912
+6144	2000.9836	360	1.2368	0.6521	0.9043	1.0820	8.2090	14.6950	7.9961	14.3936
+6145	2000.9863	361	1.2367	0.6521	0.9043	1.0820	8.2090	14.6950	7.9926	14.3960
+6146	2000.9891	362	1.2367	0.6521	0.9043	1.0820	8.2090	14.6950	7.9891	14.3984
+6147	2000.9918	363	1.2367	0.6521	0.9043	1.0820	8.2090	14.6950	7.9857	14.4008
+6148	2000.9945	364	1.2367	0.6521	0.9043	1.0820	8.2090	14.6950	7.9823	14.4032
+6149	2000.9973	365	1.2367	0.6521	0.9043	1.0820	8.2090	14.6950	7.9790	14.4055
+6150	2000.9999	366	1.2367	0.6521	0.9043	1.0820	8.2090	14.6950	7.9758	14.4079
+6151	2001.0027	1	1.2367	0.6520	0.9043	1.0820	8.2090	14.6950	7.9726	14.4103
+6152	2001.0055	2	1.2367	0.6520	0.9043	1.0820	8.2090	14.6950	7.9695	14.4126
+6153	2001.0082	3	1.2367	0.6520	0.9043	1.0820	8.2090	14.6950	7.9665	14.4150
+6154	2001.0110	4	1.2366	0.6520	0.9043	1.0820	8.2090	14.6950	7.9635	14.4173
+6155	2001.0137	5	1.2366	0.6520	0.9043	1.0820	8.2090	14.6950	7.9607	14.4196
+6156	2001.0164	6	1.2366	0.6520	0.9043	1.0820	8.2090	14.6950	7.9579	14.4219
+6157	2001.0192	7	1.2366	0.6520	0.9043	1.0820	8.2090	14.6950	7.9551	14.4242
+6158	2001.0219	8	1.2366	0.6520	0.9043	1.0820	8.2090	14.6950	7.9525	14.4265
+6159	2001.0247	9	1.2366	0.6520	0.9043	1.0820	8.2090	14.6950	7.9500	14.4288
+6160	2001.0274	10	1.2366	0.6520	0.9043	1.0820	8.2090	14.6950	7.9475	14.4311
+6161	2001.0301	11	1.2366	0.6520	0.9043	1.0820	8.2090	14.6950	7.9451	14.4333
+6162	2001.0329	12	1.2366	0.6520	0.9043	1.0820	8.2090	14.6950	7.9428	14.4355
+6163	2001.0356	13	1.2366	0.6520	0.9043	1.0820	8.2090	14.6950	7.9406	14.4377
+6164	2001.0384	14	1.2365	0.6520	0.9043	1.0820	8.2090	14.6950	7.9384	14.4399
+6165	2001.0411	15	1.2365	0.6520	0.9043	1.0820	8.2090	14.6950	7.9364	14.4421
+6166	2001.0438	16	1.2365	0.6520	0.9043	1.0820	8.2090	14.6950	7.9345	14.4443
+6167	2001.0466	17	1.2365	0.6519	0.9043	1.0820	8.2090	14.6950	7.9326	14.4464
+6168	2001.0493	18	1.2365	0.6519	0.9043	1.0820	8.2090	14.6950	7.9308	14.4485
+6169	2001.0521	19	1.2365	0.6519	0.9043	1.0820	8.2090	14.6950	7.9292	14.4506
+6170	2001.0548	20	1.2365	0.6519	0.9043	1.0820	8.2090	14.6950	7.9276	14.4527
+6171	2001.0575	21	1.2365	0.6519	0.9043	1.0820	8.2090	14.6950	7.9261	14.4547
+6172	2001.0603	22	1.2365	0.6519	0.9043	1.0820	8.2090	14.6950	7.9248	14.4567
+6173	2001.0630	23	1.2364	0.6519	0.9043	1.0820	8.2090	14.6950	7.9235	14.4587
+6174	2001.0658	24	1.2364	0.6519	0.9043	1.0820	8.2090	14.6950	7.9223	14.4607
+6175	2001.0685	25	1.2364	0.6519	0.9043	1.0820	8.2090	14.6950	7.9212	14.4626
+6176	2001.0712	26	1.2364	0.6519	0.9043	1.0820	8.2090	14.6950	7.9202	14.4646
+6177	2001.0740	27	1.2364	0.6519	0.9043	1.0820	8.2090	14.6950	7.9193	14.4664
+6178	2001.0767	28	1.2364	0.6519	0.9043	1.0820	8.2090	14.6950	7.9185	14.4683
+6179	2001.0795	29	1.2364	0.6519	0.9043	1.0820	8.2090	14.6950	7.9179	14.4701
+6180	2001.0822	30	1.2364	0.6519	0.9043	1.0820	8.2090	14.6950	7.9173	14.4719
+6181	2001.0849	31	1.2364	0.6519	0.9043	1.0820	8.2090	14.6950	7.9168	14.4737
+6182	2001.0877	32	1.2364	0.6519	0.9043	1.0820	8.2090	14.6950	7.9164	14.4754
+6183	2001.0904	33	1.2363	0.6518	0.9043	1.0820	8.2090	14.6950	7.9161	14.4772
+6184	2001.0932	34	1.2363	0.6518	0.9043	1.0820	8.2090	14.6950	7.9159	14.4788
+6185	2001.0959	35	1.2363	0.6518	0.9043	1.0820	8.2090	14.6950	7.9159	14.4805
+6186	2001.0986	36	1.2363	0.6518	0.9043	1.0820	8.2090	14.6950	7.9159	14.4821
+6187	2001.1014	37	1.2363	0.6518	0.9043	1.0820	8.2090	14.6950	7.9160	14.4837
+6188	2001.1041	38	1.2363	0.6518	0.9043	1.0820	8.2090	14.6950	7.9162	14.4852
+6189	2001.1068	39	1.2363	0.6518	0.9043	1.0820	8.2090	14.6950	7.9166	14.4867
+6190	2001.1096	40	1.2363	0.6518	0.9043	1.0820	8.2090	14.6950	7.9170	14.4882
+6191	2001.1123	41	1.2363	0.6518	0.9043	1.0820	8.2090	14.6950	7.9175	14.4896
+6192	2001.1151	42	1.2362	0.6518	0.9043	1.0820	8.2090	14.6950	7.9181	14.4910
+6193	2001.1178	43	1.2362	0.6518	0.9043	1.0820	8.2090	14.6950	7.9189	14.4923
+6194	2001.1205	44	1.2362	0.6518	0.9043	1.0820	8.2090	14.6950	7.9197	14.4936
+6195	2001.1233	45	1.2362	0.6518	0.9043	1.0820	8.2090	14.6950	7.9206	14.4949
+6196	2001.1260	46	1.2362	0.6518	0.9043	1.0820	8.2090	14.6950	7.9216	14.4962
+6197	2001.1288	47	1.2362	0.6518	0.9043	1.0820	8.2090	14.6950	7.9227	14.4973
+6198	2001.1315	48	1.2362	0.6518	0.9043	1.0820	8.2090	14.6950	7.9239	14.4985
+6199	2001.1342	49	1.2362	0.6517	0.9043	1.0820	8.2090	14.6950	7.9252	14.4996
+6200	2001.1370	50	1.2362	0.6517	0.9043	1.0820	8.2090	14.6950	7.9266	14.5007
+6201	2001.1397	51	1.2362	0.6517	0.9043	1.0820	8.2090	14.6950	7.9281	14.5017
+6202	2001.1425	52	1.2361	0.6517	0.9043	1.0820	8.2090	14.6950	7.9297	14.5027
+6203	2001.1452	53	1.2361	0.6517	0.9043	1.0820	8.2090	14.6950	7.9314	14.5036
+6204	2001.1479	54	1.2361	0.6517	0.9043	1.0820	8.2090	14.6950	7.9331	14.5046
+6205	2001.1507	55	1.2361	0.6517	0.9043	1.0820	8.2090	14.6950	7.9350	14.5054
+6206	2001.1534	56	1.2361	0.6517	0.9043	1.0820	8.2090	14.6950	7.9369	14.5062
+6207	2001.1562	57	1.2361	0.6517	0.9043	1.0820	8.2090	14.6950	7.9389	14.5070
+6208	2001.1589	58	1.2361	0.6517	0.9043	1.0820	8.2090	14.6950	7.9410	14.5077
+6209	2001.1616	59	1.2361	0.6517	0.9043	1.0820	8.2090	14.6950	7.9432	14.5084
+6210	2001.1644	60	1.2361	0.6517	0.9043	1.0820	8.2090	14.6950	7.9455	14.5090
+6211	2001.1671	61	1.2360	0.6517	0.9043	1.0820	8.2090	14.6950	7.9479	14.5096
+6212	2001.1699	62	1.2360	0.6517	0.9043	1.0820	8.2090	14.6950	7.9503	14.5102
+6213	2001.1726	63	1.2360	0.6517	0.9043	1.0820	8.2090	14.6950	7.9528	14.5107
+6214	2001.1753	64	1.2360	0.6517	0.9043	1.0820	8.2090	14.6950	7.9554	14.5111
+6215	2001.1781	65	1.2360	0.6517	0.9043	1.0820	8.2090	14.6950	7.9580	14.5115
+6216	2001.1808	66	1.2360	0.6516	0.9043	1.0820	8.2090	14.6950	7.9607	14.5119
+6217	2001.1836	67	1.2360	0.6516	0.9043	1.0820	8.2090	14.6950	7.9635	14.5122
+6218	2001.1863	68	1.2360	0.6516	0.9043	1.0820	8.2090	14.6950	7.9664	14.5124
+6219	2001.1890	69	1.2360	0.6516	0.9043	1.0820	8.2090	14.6950	7.9693	14.5126
+6220	2001.1918	70	1.2360	0.6516	0.9043	1.0820	8.2090	14.6950	7.9723	14.5128
+6221	2001.1945	71	1.2359	0.6516	0.9043	1.0820	8.2090	14.6950	7.9754	14.5129
+6222	2001.1973	72	1.2359	0.6516	0.9043	1.0820	8.2090	14.6950	7.9785	14.5130
+6223	2001.2000	73	1.2359	0.6516	0.9043	1.0820	8.2090	14.6950	7.9816	14.5130
+6224	2001.2027	74	1.2359	0.6516	0.9043	1.0820	8.2090	14.6950	7.9849	14.5130
+6225	2001.2055	75	1.2359	0.6516	0.9043	1.0820	8.2090	14.6950	7.9881	14.5129
+6226	2001.2082	76	1.2359	0.6516	0.9043	1.0820	8.2090	14.6950	7.9915	14.5128
+6227	2001.2110	77	1.2359	0.6516	0.9043	1.0820	8.2090	14.6950	7.9948	14.5126
+6228	2001.2137	78	1.2359	0.6516	0.9043	1.0820	8.2090	14.6950	7.9983	14.5124
+6229	2001.2164	79	1.2359	0.6516	0.9042	1.0820	8.2090	14.6950	8.0017	14.5121
+6230	2001.2192	80	1.2359	0.6516	0.9042	1.0820	8.2090	14.6950	8.0052	14.5118
+6231	2001.2219	81	1.2358	0.6516	0.9042	1.0820	8.2090	14.6950	8.0088	14.5114
+6232	2001.2247	82	1.2358	0.6515	0.9042	1.0820	8.2090	14.6950	8.0124	14.5110
+6233	2001.2274	83	1.2358	0.6515	0.9042	1.0820	8.2090	14.6950	8.0160	14.5105
+6234	2001.2301	84	1.2358	0.6515	0.9042	1.0820	8.2090	14.6950	8.0196	14.5100
+6235	2001.2329	85	1.2358	0.6515	0.9042	1.0820	8.2090	14.6950	8.0233	14.5094
+6236	2001.2356	86	1.2358	0.6515	0.9042	1.0820	8.2090	14.6950	8.0270	14.5088
+6237	2001.2384	87	1.2358	0.6515	0.9042	1.0820	8.2090	14.6950	8.0307	14.5081
+6238	2001.2411	88	1.2358	0.6515	0.9042	1.0820	8.2090	14.6950	8.0345	14.5074
+6239	2001.2438	89	1.2358	0.6515	0.9042	1.0820	8.2090	14.6950	8.0383	14.5066
+6240	2001.2466	90	1.2358	0.6515	0.9042	1.0820	8.2090	14.6950	8.0421	14.5058
+6241	2001.2493	91	1.2357	0.6515	0.9042	1.0820	8.2090	14.6950	8.0459	14.5050
+6242	2001.2521	92	1.2357	0.6515	0.9042	1.0820	8.2090	14.6950	8.0497	14.5041
+6243	2001.2548	93	1.2357	0.6515	0.9042	1.0820	8.2090	14.6950	8.0535	14.5031
+6244	2001.2575	94	1.2357	0.6515	0.9042	1.0820	8.2090	14.6950	8.0573	14.5021
+6245	2001.2603	95	1.2357	0.6515	0.9042	1.0820	8.2090	14.6950	8.0612	14.5010
+6246	2001.2630	96	1.2357	0.6515	0.9042	1.0820	8.2090	14.6950	8.0650	14.4999
+6247	2001.2658	97	1.2357	0.6515	0.9042	1.0820	8.2090	14.6950	8.0688	14.4988
+6248	2001.2685	98	1.2357	0.6515	0.9042	1.0820	8.2090	14.6950	8.0726	14.4976
+6249	2001.2712	99	1.2357	0.6514	0.9042	1.0820	8.2090	14.6950	8.0765	14.4964
+6250	2001.2740	100	1.2356	0.6514	0.9042	1.0820	8.2090	14.6950	8.0803	14.4951
+6251	2001.2767	101	1.2356	0.6514	0.9042	1.0820	8.2090	14.6950	8.0841	14.4937
+6252	2001.2795	102	1.2356	0.6514	0.9042	1.0820	8.2090	14.6950	8.0879	14.4924
+6253	2001.2822	103	1.2356	0.6514	0.9042	1.0820	8.2090	14.6950	8.0916	14.4909
+6254	2001.2849	104	1.2356	0.6514	0.9042	1.0820	8.2090	14.6950	8.0954	14.4895
+6255	2001.2877	105	1.2356	0.6514	0.9042	1.0820	8.2090	14.6950	8.0991	14.4879
+6256	2001.2904	106	1.2356	0.6514	0.9042	1.0820	8.2090	14.6950	8.1028	14.4864
+6257	2001.2932	107	1.2356	0.6514	0.9042	1.0820	8.2090	14.6950	8.1064	14.4848
+6258	2001.2959	108	1.2356	0.6514	0.9042	1.0820	8.2090	14.6950	8.1101	14.4831
+6259	2001.2986	109	1.2356	0.6514	0.9042	1.0820	8.2090	14.6950	8.1137	14.4814
+6260	2001.3014	110	1.2355	0.6514	0.9042	1.0820	8.2090	14.6950	8.1172	14.4797
+6261	2001.3041	111	1.2355	0.6514	0.9042	1.0820	8.2090	14.6950	8.1207	14.4779
+6262	2001.3068	112	1.2355	0.6514	0.9042	1.0820	8.2090	14.6950	8.1242	14.4761
+6263	2001.3096	113	1.2355	0.6514	0.9042	1.0820	8.2090	14.6950	8.1277	14.4742
+6264	2001.3123	114	1.2355	0.6514	0.9042	1.0820	8.2090	14.6950	8.1310	14.4723
+6265	2001.3151	115	1.2355	0.6514	0.9042	1.0820	8.2090	14.6950	8.1344	14.4704
+6266	2001.3178	116	1.2355	0.6513	0.9042	1.0820	8.2090	14.6950	8.1377	14.4684
+6267	2001.3205	117	1.2355	0.6513	0.9042	1.0820	8.2090	14.6950	8.1409	14.4664
+6268	2001.3233	118	1.2355	0.6513	0.9042	1.0820	8.2090	14.6950	8.1441	14.4643
+6269	2001.3260	119	1.2355	0.6513	0.9042	1.0820	8.2090	14.6950	8.1472	14.4622
+6270	2001.3288	120	1.2354	0.6513	0.9042	1.0820	8.2090	14.6950	8.1503	14.4601
+6271	2001.3315	121	1.2354	0.6513	0.9042	1.0820	8.2090	14.6950	8.1533	14.4579
+6272	2001.3342	122	1.2354	0.6513	0.9042	1.0820	8.2090	14.6950	8.1562	14.4557
+6273	2001.3370	123	1.2354	0.6513	0.9042	1.0820	8.2090	14.6950	8.1590	14.4534
+6274	2001.3397	124	1.2354	0.6513	0.9042	1.0820	8.2090	14.6950	8.1618	14.4511
+6275	2001.3425	125	1.2354	0.6513	0.9042	1.0820	8.2090	14.6950	8.1646	14.4488
+6276	2001.3452	126	1.2354	0.6513	0.9042	1.0820	8.2090	14.6950	8.1672	14.4464
+6277	2001.3479	127	1.2354	0.6513	0.9042	1.0820	8.2090	14.6950	8.1698	14.4440
+6278	2001.3507	128	1.2354	0.6513	0.9042	1.0820	8.2090	14.6950	8.1723	14.4416
+6279	2001.3534	129	1.2354	0.6513	0.9042	1.0820	8.2090	14.6950	8.1747	14.4392
+6280	2001.3562	130	1.2353	0.6513	0.9042	1.0820	8.2090	14.6950	8.1770	14.4367
+6281	2001.3589	131	1.2353	0.6513	0.9042	1.0820	8.2090	14.6950	8.1792	14.4341
+6282	2001.3616	132	1.2353	0.6513	0.9042	1.0820	8.2090	14.6950	8.1814	14.4316
+6283	2001.3644	133	1.2353	0.6512	0.9042	1.0820	8.2090	14.6950	8.1835	14.4290
+6284	2001.3671	134	1.2353	0.6512	0.9042	1.0820	8.2090	14.6950	8.1855	14.4264
+6285	2001.3699	135	1.2353	0.6512	0.9042	1.0820	8.2090	14.6950	8.1874	14.4237
+6286	2001.3726	136	1.2353	0.6512	0.9042	1.0820	8.2090	14.6950	8.1892	14.4210
+6287	2001.3753	137	1.2353	0.6512	0.9042	1.0820	8.2090	14.6950	8.1909	14.4183
+6288	2001.3781	138	1.2353	0.6512	0.9042	1.0820	8.2090	14.6950	8.1925	14.4156
+6289	2001.3808	139	1.2353	0.6512	0.9042	1.0820	8.2090	14.6950	8.1940	14.4128
+6290	2001.3836	140	1.2352	0.6512	0.9042	1.0820	8.2090	14.6950	8.1955	14.4100
+6291	2001.3863	141	1.2352	0.6512	0.9042	1.0820	8.2090	14.6950	8.1968	14.4072
+6292	2001.3890	142	1.2352	0.6512	0.9042	1.0820	8.2090	14.6950	8.1980	14.4044
+6293	2001.3918	143	1.2352	0.6512	0.9042	1.0820	8.2090	14.6950	8.1992	14.4015
+6294	2001.3945	144	1.2352	0.6512	0.9042	1.0820	8.2090	14.6950	8.2002	14.3986
+6295	2001.3973	145	1.2352	0.6512	0.9042	1.0820	8.2090	14.6950	8.2011	14.3957
+6296	2001.4000	146	1.2352	0.6512	0.9042	1.0820	8.2090	14.6950	8.2020	14.3928
+6297	2001.4027	147	1.2352	0.6512	0.9042	1.0820	8.2090	14.6950	8.2027	14.3898
+6298	2001.4055	148	1.2352	0.6512	0.9042	1.0820	8.2090	14.6950	8.2033	14.3869
+6299	2001.4082	149	1.2352	0.6511	0.9042	1.0820	8.2090	14.6950	8.2039	14.3839
+6300	2001.4110	150	1.2351	0.6511	0.9042	1.0820	8.2090	14.6950	8.2043	14.3809
+6301	2001.4137	151	1.2351	0.6511	0.9042	1.0820	8.2090	14.6950	8.2046	14.3778
+6302	2001.4164	152	1.2351	0.6511	0.9042	1.0820	8.2090	14.6950	8.2048	14.3748
+6303	2001.4192	153	1.2351	0.6511	0.9042	1.0820	8.2090	14.6950	8.2049	14.3717
+6304	2001.4219	154	1.2351	0.6511	0.9042	1.0820	8.2090	14.6950	8.2049	14.3687
+6305	2001.4247	155	1.2351	0.6511	0.9042	1.0820	8.2090	14.6950	8.2048	14.3656
+6306	2001.4274	156	1.2351	0.6511	0.9042	1.0820	8.2090	14.6950	8.2046	14.3625
+6307	2001.4301	157	1.2351	0.6511	0.9042	1.0820	8.2090	14.6950	8.2043	14.3593
+6308	2001.4329	158	1.2351	0.6511	0.9042	1.0820	8.2090	14.6950	8.2039	14.3562
+6309	2001.4356	159	1.2351	0.6511	0.9042	1.0820	8.2090	14.6950	8.2034	14.3531
+6310	2001.4384	160	1.2350	0.6511	0.9042	1.0820	8.2090	14.6950	8.2027	14.3499
+6311	2001.4411	161	1.2350	0.6511	0.9042	1.0820	8.2090	14.6950	8.2020	14.3467
+6312	2001.4438	162	1.2350	0.6511	0.9042	1.0820	8.2090	14.6950	8.2012	14.3436
+6313	2001.4466	163	1.2350	0.6511	0.9042	1.0820	8.2090	14.6950	8.2003	14.3404
+6314	2001.4493	164	1.2350	0.6511	0.9042	1.0820	8.2090	14.6950	8.1992	14.3372
+6315	2001.4521	165	1.2350	0.6511	0.9042	1.0820	8.2090	14.6950	8.1981	14.3340
+6316	2001.4548	166	1.2350	0.6510	0.9042	1.0820	8.2090	14.6950	8.1969	14.3308
+6317	2001.4575	167	1.2350	0.6510	0.9042	1.0820	8.2090	14.6950	8.1955	14.3276
+6318	2001.4603	168	1.2350	0.6510	0.9042	1.0820	8.2090	14.6950	8.1941	14.3243
+6319	2001.4630	169	1.2350	0.6510	0.9042	1.0820	8.2090	14.6950	8.1926	14.3211
+6320	2001.4658	170	1.2349	0.6510	0.9042	1.0820	8.2090	14.6950	8.1910	14.3179
+6321	2001.4685	171	1.2349	0.6510	0.9042	1.0820	8.2090	14.6950	8.1892	14.3147
+6322	2001.4712	172	1.2349	0.6510	0.9042	1.0820	8.2090	14.6950	8.1874	14.3114
+6323	2001.4740	173	1.2349	0.6510	0.9042	1.0820	8.2090	14.6950	8.1855	14.3082
+6324	2001.4767	174	1.2349	0.6510	0.9042	1.0820	8.2090	14.6950	8.1835	14.3050
+6325	2001.4795	175	1.2349	0.6510	0.9042	1.0820	8.2090	14.6950	8.1814	14.3017
+6326	2001.4822	176	1.2349	0.6510	0.9042	1.0820	8.2090	14.6950	8.1793	14.2985
+6327	2001.4849	177	1.2349	0.6510	0.9042	1.0820	8.2090	14.6950	8.1770	14.2953
+6328	2001.4877	178	1.2349	0.6510	0.9042	1.0820	8.2090	14.6950	8.1747	14.2921
+6329	2001.4904	179	1.2349	0.6510	0.9042	1.0820	8.2090	14.6950	8.1722	14.2888
+6330	2001.4932	180	1.2348	0.6510	0.9042	1.0820	8.2090	14.6950	8.1697	14.2856
+6331	2001.4959	181	1.2348	0.6510	0.9042	1.0820	8.2090	14.6950	8.1671	14.2824
+6332	2001.4986	182	1.2348	0.6510	0.9042	1.0820	8.2090	14.6950	8.1645	14.2792
+6333	2001.5014	183	1.2348	0.6509	0.9042	1.0820	8.2090	14.6950	8.1617	14.2760
+6334	2001.5041	184	1.2348	0.6509	0.9042	1.0820	8.2090	14.6950	8.1589	14.2728
+6335	2001.5068	185	1.2348	0.6509	0.9042	1.0820	8.2090	14.6950	8.1560	14.2696
+6336	2001.5096	186	1.2348	0.6509	0.9042	1.0820	8.2090	14.6950	8.1531	14.2664
+6337	2001.5123	187	1.2348	0.6509	0.9042	1.0820	8.2090	14.6950	8.1500	14.2633
+6338	2001.5151	188	1.2348	0.6509	0.9042	1.0820	8.2090	14.6950	8.1469	14.2601
+6339	2001.5178	189	1.2348	0.6509	0.9041	1.0820	8.2090	14.6950	8.1438	14.2570
+6340	2001.5205	190	1.2347	0.6509	0.9041	1.0820	8.2090	14.6950	8.1406	14.2538
+6341	2001.5233	191	1.2347	0.6509	0.9041	1.0820	8.2090	14.6950	8.1373	14.2507
+6342	2001.5260	192	1.2347	0.6509	0.9041	1.0820	8.2090	14.6950	8.1339	14.2476
+6343	2001.5288	193	1.2347	0.6509	0.9041	1.0820	8.2090	14.6950	8.1305	14.2445
+6344	2001.5315	194	1.2347	0.6509	0.9041	1.0820	8.2090	14.6950	8.1271	14.2414
+6345	2001.5342	195	1.2347	0.6509	0.9041	1.0820	8.2090	14.6950	8.1236	14.2384
+6346	2001.5370	196	1.2347	0.6509	0.9041	1.0820	8.2090	14.6950	8.1201	14.2353
+6347	2001.5397	197	1.2347	0.6509	0.9041	1.0820	8.2090	14.6950	8.1165	14.2323
+6348	2001.5425	198	1.2347	0.6509	0.9041	1.0820	8.2090	14.6950	8.1128	14.2293
+6349	2001.5452	199	1.2347	0.6509	0.9041	1.0820	8.2090	14.6950	8.1092	14.2263
+6350	2001.5479	200	1.2346	0.6509	0.9041	1.0820	8.2090	14.6950	8.1055	14.2233
+6351	2001.5507	201	1.2346	0.6508	0.9041	1.0820	8.2090	14.6950	8.1017	14.2204
+6352	2001.5534	202	1.2346	0.6508	0.9041	1.0820	8.2090	14.6950	8.0979	14.2174
+6353	2001.5562	203	1.2346	0.6508	0.9041	1.0820	8.2090	14.6950	8.0941	14.2145
+6354	2001.5589	204	1.2346	0.6508	0.9041	1.0820	8.2090	14.6950	8.0903	14.2116
+6355	2001.5616	205	1.2346	0.6508	0.9041	1.0820	8.2090	14.6950	8.0864	14.2087
+6356	2001.5644	206	1.2346	0.6508	0.9041	1.0820	8.2090	14.6950	8.0825	14.2059
+6357	2001.5671	207	1.2346	0.6508	0.9041	1.0820	8.2090	14.6950	8.0786	14.2031
+6358	2001.5699	208	1.2346	0.6508	0.9041	1.0820	8.2090	14.6950	8.0747	14.2003
+6359	2001.5726	209	1.2346	0.6508	0.9041	1.0820	8.2090	14.6950	8.0708	14.1975
+6360	2001.5753	210	1.2345	0.6508	0.9041	1.0820	8.2090	14.6950	8.0668	14.1947
+6361	2001.5781	211	1.2345	0.6508	0.9041	1.0820	8.2090	14.6950	8.0628	14.1920
+6362	2001.5808	212	1.2345	0.6508	0.9041	1.0820	8.2090	14.6950	8.0589	14.1893
+6363	2001.5836	213	1.2345	0.6508	0.9041	1.0820	8.2090	14.6950	8.0549	14.1866
+6364	2001.5863	214	1.2345	0.6508	0.9041	1.0820	8.2090	14.6950	8.0509	14.1840
+6365	2001.5890	215	1.2345	0.6508	0.9041	1.0820	8.2090	14.6950	8.0469	14.1814
+6366	2001.5918	216	1.2345	0.6508	0.9041	1.0820	8.2090	14.6950	8.0430	14.1788
+6367	2001.5945	217	1.2345	0.6508	0.9041	1.0820	8.2090	14.6950	8.0390	14.1762
+6368	2001.5973	218	1.2345	0.6507	0.9041	1.0820	8.2090	14.6950	8.0350	14.1737
+6369	2001.6000	219	1.2345	0.6507	0.9041	1.0820	8.2090	14.6950	8.0311	14.1712
+6370	2001.6027	220	1.2345	0.6507	0.9041	1.0820	8.2090	14.6950	8.0271	14.1687
+6371	2001.6055	221	1.2344	0.6507	0.9041	1.0820	8.2090	14.6950	8.0232	14.1663
+6372	2001.6082	222	1.2344	0.6507	0.9041	1.0820	8.2090	14.6950	8.0193	14.1639
+6373	2001.6110	223	1.2344	0.6507	0.9041	1.0820	8.2090	14.6950	8.0154	14.1615
+6374	2001.6137	224	1.2344	0.6507	0.9041	1.0820	8.2090	14.6950	8.0115	14.1592
+6375	2001.6164	225	1.2344	0.6507	0.9041	1.0820	8.2090	14.6950	8.0077	14.1569
+6376	2001.6192	226	1.2344	0.6507	0.9041	1.0820	8.2090	14.6950	8.0039	14.1546
+6377	2001.6219	227	1.2344	0.6507	0.9041	1.0820	8.2090	14.6950	8.0001	14.1523
+6378	2001.6247	228	1.2344	0.6507	0.9041	1.0820	8.2090	14.6950	7.9963	14.1501
+6379	2001.6274	229	1.2344	0.6507	0.9041	1.0820	8.2090	14.6950	7.9926	14.1480
+6380	2001.6301	230	1.2344	0.6507	0.9041	1.0820	8.2090	14.6950	7.9889	14.1458
+6381	2001.6329	231	1.2343	0.6507	0.9041	1.0820	8.2090	14.6950	7.9853	14.1437
+6382	2001.6356	232	1.2343	0.6507	0.9041	1.0820	8.2090	14.6950	7.9817	14.1417
+6383	2001.6384	233	1.2343	0.6507	0.9041	1.0820	8.2090	14.6950	7.9781	14.1396
+6384	2001.6411	234	1.2343	0.6507	0.9041	1.0820	8.2090	14.6950	7.9746	14.1377
+6385	2001.6438	235	1.2343	0.6506	0.9041	1.0820	8.2090	14.6950	7.9711	14.1357
+6386	2001.6466	236	1.2343	0.6506	0.9041	1.0820	8.2090	14.6950	7.9677	14.1338
+6387	2001.6493	237	1.2343	0.6506	0.9041	1.0820	8.2090	14.6950	7.9643	14.1319
+6388	2001.6521	238	1.2343	0.6506	0.9041	1.0820	8.2090	14.6950	7.9610	14.1301
+6389	2001.6548	239	1.2343	0.6506	0.9041	1.0820	8.2090	14.6950	7.9577	14.1283
+6390	2001.6575	240	1.2343	0.6506	0.9041	1.0820	8.2090	14.6950	7.9545	14.1265
+6391	2001.6603	241	1.2342	0.6506	0.9041	1.0820	8.2090	14.6950	7.9513	14.1248
+6392	2001.6630	242	1.2342	0.6506	0.9041	1.0820	8.2090	14.6950	7.9482	14.1231
+6393	2001.6658	243	1.2342	0.6506	0.9041	1.0820	8.2090	14.6950	7.9452	14.1215
+6394	2001.6685	244	1.2342	0.6506	0.9041	1.0820	8.2090	14.6950	7.9422	14.1199
+6395	2001.6712	245	1.2342	0.6506	0.9041	1.0820	8.2090	14.6950	7.9393	14.1183
+6396	2001.6740	246	1.2342	0.6506	0.9041	1.0820	8.2090	14.6950	7.9365	14.1168
+6397	2001.6767	247	1.2342	0.6506	0.9041	1.0820	8.2090	14.6950	7.9337	14.1153
+6398	2001.6795	248	1.2342	0.6506	0.9041	1.0820	8.2090	14.6950	7.9310	14.1139
+6399	2001.6822	249	1.2342	0.6506	0.9041	1.0820	8.2090	14.6950	7.9284	14.1125
+6400	2001.6849	250	1.2342	0.6506	0.9041	1.0820	8.2090	14.6950	7.9259	14.1111
+6401	2001.6877	251	1.2341	0.6506	0.9041	1.0820	8.2090	14.6950	7.9234	14.1098
+6402	2001.6904	252	1.2341	0.6505	0.9041	1.0820	8.2090	14.6950	7.9210	14.1085
+6403	2001.6932	253	1.2341	0.6505	0.9041	1.0820	8.2090	14.6950	7.9187	14.1073
+6404	2001.6959	254	1.2341	0.6505	0.9041	1.0820	8.2090	14.6950	7.9164	14.1061
+6405	2001.6986	255	1.2341	0.6505	0.9041	1.0820	8.2090	14.6950	7.9143	14.1050
+6406	2001.7014	256	1.2341	0.6505	0.9041	1.0820	8.2090	14.6950	7.9122	14.1039
+6407	2001.7041	257	1.2341	0.6505	0.9041	1.0820	8.2090	14.6950	7.9102	14.1028
+6408	2001.7068	258	1.2341	0.6505	0.9041	1.0820	8.2090	14.6950	7.9083	14.1018
+6409	2001.7096	259	1.2341	0.6505	0.9041	1.0820	8.2090	14.6950	7.9064	14.1008
+6410	2001.7123	260	1.2341	0.6505	0.9041	1.0820	8.2090	14.6950	7.9047	14.0999
+6411	2001.7151	261	1.2341	0.6505	0.9041	1.0820	8.2090	14.6950	7.9030	14.0990
+6412	2001.7178	262	1.2340	0.6505	0.9041	1.0820	8.2090	14.6950	7.9014	14.0982
+6413	2001.7205	263	1.2340	0.6505	0.9041	1.0820	8.2090	14.6950	7.8999	14.0974
+6414	2001.7233	264	1.2340	0.6505	0.9041	1.0820	8.2090	14.6950	7.8985	14.0966
+6415	2001.7260	265	1.2340	0.6505	0.9041	1.0820	8.2090	14.6950	7.8972	14.0959
+6416	2001.7288	266	1.2340	0.6505	0.9041	1.0820	8.2090	14.6950	7.8960	14.0953
+6417	2001.7315	267	1.2340	0.6505	0.9041	1.0820	8.2090	14.6950	7.8948	14.0946
+6418	2001.7342	268	1.2340	0.6505	0.9041	1.0820	8.2090	14.6950	7.8938	14.0941
+6419	2001.7370	269	1.2340	0.6505	0.9041	1.0820	8.2090	14.6950	7.8928	14.0935
+6420	2001.7397	270	1.2340	0.6504	0.9041	1.0820	8.2090	14.6950	7.8920	14.0930
+6421	2001.7425	271	1.2340	0.6504	0.9041	1.0820	8.2090	14.6950	7.8912	14.0926
+6422	2001.7452	272	1.2339	0.6504	0.9041	1.0820	8.2090	14.6950	7.8905	14.0922
+6423	2001.7479	273	1.2339	0.6504	0.9041	1.0820	8.2090	14.6950	7.8900	14.0918
+6424	2001.7507	274	1.2339	0.6504	0.9041	1.0820	8.2090	14.6950	7.8895	14.0915
+6425	2001.7534	275	1.2339	0.6504	0.9041	1.0820	8.2090	14.6950	7.8891	14.0912
+6426	2001.7562	276	1.2339	0.6504	0.9041	1.0820	8.2090	14.6950	7.8888	14.0910
+6427	2001.7589	277	1.2339	0.6504	0.9041	1.0820	8.2090	14.6950	7.8885	14.0908
+6428	2001.7616	278	1.2339	0.6504	0.9041	1.0820	8.2090	14.6950	7.8884	14.0907
+6429	2001.7644	279	1.2339	0.6504	0.9041	1.0820	8.2090	14.6950	7.8884	14.0906
+6430	2001.7671	280	1.2339	0.6504	0.9041	1.0820	8.2090	14.6950	7.8885	14.0905
+6431	2001.7699	281	1.2339	0.6504	0.9041	1.0820	8.2090	14.6950	7.8886	14.0905
+6432	2001.7726	282	1.2339	0.6504	0.9041	1.0820	8.2090	14.6950	7.8889	14.0905
+6433	2001.7753	283	1.2338	0.6504	0.9041	1.0820	8.2090	14.6950	7.8892	14.0906
+6434	2001.7781	284	1.2338	0.6504	0.9041	1.0820	8.2090	14.6950	7.8896	14.0907
+6435	2001.7808	285	1.2338	0.6504	0.9041	1.0820	8.2090	14.6950	7.8902	14.0908
+6436	2001.7836	286	1.2338	0.6504	0.9041	1.0820	8.2090	14.6950	7.8908	14.0910
+6437	2001.7863	287	1.2338	0.6503	0.9041	1.0820	8.2090	14.6950	7.8915	14.0913
+6438	2001.7890	288	1.2338	0.6503	0.9041	1.0820	8.2090	14.6950	7.8923	14.0916
+6439	2001.7918	289	1.2338	0.6503	0.9041	1.0820	8.2090	14.6950	7.8932	14.0919
+6440	2001.7945	290	1.2338	0.6503	0.9041	1.0820	8.2090	14.6950	7.8942	14.0922
+6441	2001.7973	291	1.2338	0.6503	0.9041	1.0820	8.2090	14.6950	7.8952	14.0926
+6442	2001.8000	292	1.2338	0.6503	0.9041	1.0820	8.2090	14.6950	7.8964	14.0931
+6443	2001.8027	293	1.2337	0.6503	0.9041	1.0820	8.2090	14.6950	7.8976	14.0936
+6444	2001.8055	294	1.2337	0.6503	0.9041	1.0820	8.2090	14.6950	7.8990	14.0941
+6445	2001.8082	295	1.2337	0.6503	0.9041	1.0820	8.2090	14.6950	7.9004	14.0947
+6446	2001.8110	296	1.2337	0.6503	0.9041	1.0820	8.2090	14.6950	7.9019	14.0953
+6447	2001.8137	297	1.2337	0.6503	0.9041	1.0820	8.2090	14.6950	7.9034	14.0959
+6448	2001.8164	298	1.2337	0.6503	0.9041	1.0820	8.2090	14.6950	7.9051	14.0966
+6449	2001.8192	299	1.2337	0.6503	0.9041	1.0820	8.2090	14.6950	7.9069	14.0973
+6450	2001.8219	300	1.2337	0.6503	0.9041	1.0820	8.2090	14.6950	7.9087	14.0981
+6451	2001.8247	301	1.2337	0.6503	0.9041	1.0820	8.2090	14.6950	7.9106	14.0989
+6452	2001.8274	302	1.2337	0.6503	0.9041	1.0820	8.2090	14.6950	7.9126	14.0997
+6453	2001.8301	303	1.2337	0.6503	0.9041	1.0820	8.2090	14.6950	7.9146	14.1006
+6454	2001.8329	304	1.2336	0.6503	0.9041	1.0820	8.2090	14.6950	7.9168	14.1015
+6455	2001.8356	305	1.2336	0.6502	0.9041	1.0820	8.2090	14.6950	7.9190	14.1024
+6456	2001.8384	306	1.2336	0.6502	0.9040	1.0820	8.2090	14.6950	7.9212	14.1034
+6457	2001.8411	307	1.2336	0.6502	0.9040	1.0820	8.2090	14.6950	7.9236	14.1044
+6458	2001.8438	308	1.2336	0.6502	0.9040	1.0820	8.2090	14.6950	7.9260	14.1055
+6459	2001.8466	309	1.2336	0.6502	0.9040	1.0820	8.2090	14.6950	7.9285	14.1066
+6460	2001.8493	310	1.2336	0.6502	0.9040	1.0820	8.2090	14.6950	7.9311	14.1077
+6461	2001.8521	311	1.2336	0.6502	0.9040	1.0820	8.2090	14.6950	7.9337	14.1089
+6462	2001.8548	312	1.2336	0.6502	0.9040	1.0820	8.2090	14.6950	7.9364	14.1101
+6463	2001.8575	313	1.2336	0.6502	0.9040	1.0820	8.2090	14.6950	7.9391	14.1113
+6464	2001.8603	314	1.2335	0.6502	0.9040	1.0820	8.2090	14.6950	7.9419	14.1125
+6465	2001.8630	315	1.2335	0.6502	0.9040	1.0820	8.2090	14.6950	7.9448	14.1138
+6466	2001.8658	316	1.2335	0.6502	0.9040	1.0820	8.2090	14.6950	7.9477	14.1151
+6467	2001.8685	317	1.2335	0.6502	0.9040	1.0820	8.2090	14.6950	7.9507	14.1165
+6468	2001.8712	318	1.2335	0.6502	0.9040	1.0820	8.2090	14.6950	7.9537	14.1179
+6469	2001.8740	319	1.2335	0.6502	0.9040	1.0820	8.2090	14.6950	7.9568	14.1193
+6470	2001.8767	320	1.2335	0.6502	0.9040	1.0820	8.2090	14.6950	7.9599	14.1208
+6471	2001.8795	321	1.2335	0.6502	0.9040	1.0820	8.2090	14.6950	7.9631	14.1222
+6472	2001.8822	322	1.2335	0.6502	0.9040	1.0820	8.2090	14.6950	7.9663	14.1237
+6473	2001.8849	323	1.2335	0.6501	0.9040	1.0820	8.2090	14.6950	7.9695	14.1253
+6474	2001.8877	324	1.2335	0.6501	0.9040	1.0820	8.2090	14.6950	7.9728	14.1268
+6475	2001.8904	325	1.2334	0.6501	0.9040	1.0820	8.2090	14.6950	7.9762	14.1284
+6476	2001.8932	326	1.2334	0.6501	0.9040	1.0820	8.2090	14.6950	7.9796	14.1300
+6477	2001.8959	327	1.2334	0.6501	0.9040	1.0820	8.2090	14.6950	7.9830	14.1317
+6478	2001.8986	328	1.2334	0.6501	0.9040	1.0820	8.2090	14.6950	7.9864	14.1333
+6479	2001.9014	329	1.2334	0.6501	0.9040	1.0820	8.2090	14.6950	7.9899	14.1350
+6480	2001.9041	330	1.2334	0.6501	0.9040	1.0820	8.2090	14.6950	7.9934	14.1368
+6481	2001.9068	331	1.2334	0.6501	0.9040	1.0820	8.2090	14.6950	7.9969	14.1385
+6482	2001.9096	332	1.2334	0.6501	0.9040	1.0820	8.2090	14.6950	8.0005	14.1403
+6483	2001.9123	333	1.2334	0.6501	0.9040	1.0820	8.2090	14.6950	8.0040	14.1421
+6484	2001.9151	334	1.2334	0.6501	0.9040	1.0820	8.2090	14.6950	8.0076	14.1439
+6485	2001.9178	335	1.2334	0.6501	0.9040	1.0820	8.2090	14.6950	8.0113	14.1457
+6486	2001.9205	336	1.2333	0.6501	0.9040	1.0820	8.2090	14.6950	8.0149	14.1476
+6487	2001.9233	337	1.2333	0.6501	0.9040	1.0820	8.2090	14.6950	8.0185	14.1494
+6488	2001.9260	338	1.2333	0.6501	0.9040	1.0820	8.2090	14.6950	8.0222	14.1513
+6489	2001.9288	339	1.2333	0.6501	0.9040	1.0820	8.2090	14.6950	8.0258	14.1532
+6490	2001.9315	340	1.2333	0.6501	0.9040	1.0820	8.2090	14.6950	8.0295	14.1552
+6491	2001.9342	341	1.2333	0.6500	0.9040	1.0820	8.2090	14.6950	8.0331	14.1571
+6492	2001.9370	342	1.2333	0.6500	0.9040	1.0820	8.2090	14.6950	8.0368	14.1591
+6493	2001.9397	343	1.2333	0.6500	0.9040	1.0820	8.2090	14.6950	8.0404	14.1611
+6494	2001.9425	344	1.2333	0.6500	0.9040	1.0820	8.2090	14.6950	8.0441	14.1631
+6495	2001.9452	345	1.2333	0.6500	0.9040	1.0820	8.2090	14.6950	8.0477	14.1651
+6496	2001.9479	346	1.2333	0.6500	0.9040	1.0820	8.2090	14.6950	8.0514	14.1671
+6497	2001.9507	347	1.2332	0.6500	0.9040	1.0820	8.2090	14.6950	8.0550	14.1692
+6498	2001.9534	348	1.2332	0.6500	0.9040	1.0820	8.2090	14.6950	8.0586	14.1712
+6499	2001.9562	349	1.2332	0.6500	0.9040	1.0820	8.2090	14.6950	8.0622	14.1733
+6500	2001.9589	350	1.2332	0.6500	0.9040	1.0820	8.2090	14.6950	8.0658	14.1754
+6501	2001.9616	351	1.2332	0.6500	0.9040	1.0820	8.2090	14.6950	8.0694	14.1775
+6502	2001.9644	352	1.2332	0.6500	0.9040	1.0820	8.2090	14.6950	8.0729	14.1796
+6503	2001.9671	353	1.2332	0.6500	0.9040	1.0820	8.2090	14.6950	8.0764	14.1817
+6504	2001.9699	354	1.2332	0.6500	0.9040	1.0820	8.2090	14.6950	8.0799	14.1838
+6505	2001.9726	355	1.2332	0.6500	0.9040	1.0820	8.2090	14.6950	8.0833	14.1860
+6506	2001.9753	356	1.2332	0.6500	0.9040	1.0820	8.2090	14.6950	8.0867	14.1881
+6507	2001.9781	357	1.2331	0.6500	0.9040	1.0820	8.2090	14.6950	8.0901	14.1903
+6508	2001.9808	358	1.2331	0.6500	0.9040	1.0820	8.2090	14.6950	8.0935	14.1924
+6509	2001.9836	359	1.2331	0.6499	0.9040	1.0820	8.2090	14.6950	8.0968	14.1946
+6510	2001.9863	360	1.2331	0.6499	0.9040	1.0820	8.2090	14.6950	8.1000	14.1968
+6511	2001.9890	361	1.2331	0.6499	0.9040	1.0820	8.2090	14.6950	8.1032	14.1990
+6512	2001.9918	362	1.2331	0.6499	0.9040	1.0820	8.2090	14.6950	8.1064	14.2011
+6513	2001.9945	363	1.2331	0.6499	0.9040	1.0820	8.2090	14.6950	8.1095	14.2033
+6514	2001.9973	364	1.2331	0.6499	0.9040	1.0820	8.2090	14.6950	8.1126	14.2055
+6515	2001.9999	365	1.2331	0.6499	0.9040	1.0820	8.2090	14.6950	8.1156	14.2077
+6516	2002.0027	1	1.2331	0.6499	0.9040	1.0820	8.2090	14.6950	8.1186	14.2099
+6517	2002.0055	2	1.2331	0.6499	0.9040	1.0820	8.2090	14.6950	8.1215	14.2121
+6518	2002.0082	3	1.2330	0.6499	0.9040	1.0820	8.2090	14.6950	8.1244	14.2143
+6519	2002.0110	4	1.2330	0.6499	0.9040	1.0820	8.2090	14.6950	8.1272	14.2165
+6520	2002.0137	5	1.2330	0.6499	0.9040	1.0820	8.2090	14.6950	8.1299	14.2186
+6521	2002.0164	6	1.2330	0.6499	0.9040	1.0820	8.2090	14.6950	8.1326	14.2208
+6522	2002.0192	7	1.2330	0.6499	0.9040	1.0820	8.2090	14.6950	8.1352	14.2230
+6523	2002.0219	8	1.2330	0.6499	0.9040	1.0820	8.2090	14.6950	8.1377	14.2252
+6524	2002.0247	9	1.2330	0.6499	0.9040	1.0820	8.2090	14.6950	8.1401	14.2274
+6525	2002.0274	10	1.2330	0.6499	0.9040	1.0820	8.2090	14.6950	8.1425	14.2295
+6526	2002.0301	11	1.2330	0.6499	0.9040	1.0820	8.2090	14.6950	8.1449	14.2317
+6527	2002.0329	12	1.2330	0.6498	0.9040	1.0820	8.2090	14.6950	8.1471	14.2339
+6528	2002.0356	13	1.2330	0.6498	0.9040	1.0820	8.2090	14.6950	8.1493	14.2360
+6529	2002.0384	14	1.2329	0.6498	0.9040	1.0820	8.2090	14.6950	8.1514	14.2382
+6530	2002.0411	15	1.2329	0.6498	0.9040	1.0820	8.2090	14.6950	8.1534	14.2403
+6531	2002.0438	16	1.2329	0.6498	0.9040	1.0820	8.2090	14.6950	8.1553	14.2424
+6532	2002.0466	17	1.2329	0.6498	0.9040	1.0820	8.2090	14.6950	8.1571	14.2445
+6533	2002.0493	18	1.2329	0.6498	0.9040	1.0820	8.2090	14.6950	8.1589	14.2466
+6534	2002.0521	19	1.2329	0.6498	0.9040	1.0820	8.2090	14.6950	8.1606	14.2487
+6535	2002.0548	20	1.2329	0.6498	0.9040	1.0820	8.2090	14.6950	8.1622	14.2508
+6536	2002.0575	21	1.2329	0.6498	0.9040	1.0820	8.2090	14.6950	8.1637	14.2529
+6537	2002.0603	22	1.2329	0.6498	0.9040	1.0820	8.2090	14.6950	8.1651	14.2549
+6538	2002.0630	23	1.2329	0.6498	0.9040	1.0820	8.2090	14.6950	8.1664	14.2570
+6539	2002.0658	24	1.2329	0.6498	0.9040	1.0820	8.2090	14.6950	8.1677	14.2590
+6540	2002.0685	25	1.2328	0.6498	0.9040	1.0820	8.2090	14.6950	8.1688	14.2610
+6541	2002.0712	26	1.2328	0.6498	0.9040	1.0820	8.2090	14.6950	8.1699	14.2630
+6542	2002.0740	27	1.2328	0.6498	0.9040	1.0820	8.2090	14.6950	8.1709	14.2650
+6543	2002.0767	28	1.2328	0.6498	0.9040	1.0820	8.2090	14.6950	8.1717	14.2670
+6544	2002.0795	29	1.2328	0.6498	0.9040	1.0820	8.2090	14.6950	8.1725	14.2689
+6545	2002.0822	30	1.2328	0.6497	0.9040	1.0820	8.2090	14.6950	8.1732	14.2709
+6546	2002.0849	31	1.2328	0.6497	0.9040	1.0820	8.2090	14.6950	8.1738	14.2728
+6547	2002.0877	32	1.2328	0.6497	0.9040	1.0820	8.2090	14.6950	8.1743	14.2747
+6548	2002.0904	33	1.2328	0.6497	0.9040	1.0820	8.2090	14.6950	8.1747	14.2765
+6549	2002.0932	34	1.2328	0.6497	0.9040	1.0820	8.2090	14.6950	8.1750	14.2784
+6550	2002.0959	35	1.2328	0.6497	0.9040	1.0820	8.2090	14.6950	8.1752	14.2802
+6551	2002.0986	36	1.2327	0.6497	0.9040	1.0820	8.2090	14.6950	8.1753	14.2820
+6552	2002.1014	37	1.2327	0.6497	0.9040	1.0820	8.2090	14.6950	8.1754	14.2838
+6553	2002.1041	38	1.2327	0.6497	0.9040	1.0820	8.2090	14.6950	8.1753	14.2856
+6554	2002.1068	39	1.2327	0.6497	0.9040	1.0820	8.2090	14.6950	8.1751	14.2873
+6555	2002.1096	40	1.2327	0.6497	0.9040	1.0820	8.2090	14.6950	8.1749	14.2890
+6556	2002.1123	41	1.2327	0.6497	0.9040	1.0820	8.2090	14.6950	8.1745	14.2907
+6557	2002.1151	42	1.2327	0.6497	0.9040	1.0820	8.2090	14.6950	8.1740	14.2923
+6558	2002.1178	43	1.2327	0.6497	0.9040	1.0820	8.2090	14.6950	8.1735	14.2940
+6559	2002.1205	44	1.2327	0.6497	0.9040	1.0820	8.2090	14.6950	8.1728	14.2956
+6560	2002.1233	45	1.2327	0.6497	0.9040	1.0820	8.2090	14.6950	8.1721	14.2972
+6561	2002.1260	46	1.2327	0.6497	0.9040	1.0820	8.2090	14.6950	8.1712	14.2987
+6562	2002.1288	47	1.2326	0.6497	0.9040	1.0820	8.2090	14.6950	8.1703	14.3003
+6563	2002.1315	48	1.2326	0.6496	0.9040	1.0820	8.2090	14.6950	8.1693	14.3018
+6564	2002.1342	49	1.2326	0.6496	0.9040	1.0820	8.2090	14.6950	8.1682	14.3032
+6565	2002.1370	50	1.2326	0.6496	0.9040	1.0820	8.2090	14.6950	8.1670	14.3047
+6566	2002.1397	51	1.2326	0.6496	0.9040	1.0820	8.2090	14.6950	8.1657	14.3061
+6567	2002.1425	52	1.2326	0.6496	0.9040	1.0820	8.2090	14.6950	8.1643	14.3074
+6568	2002.1452	53	1.2326	0.6496	0.9040	1.0820	8.2090	14.6950	8.1628	14.3088
+6569	2002.1479	54	1.2326	0.6496	0.9040	1.0820	8.2090	14.6950	8.1612	14.3101
+6570	2002.1507	55	1.2326	0.6496	0.9040	1.0820	8.2090	14.6950	8.1596	14.3114
+6571	2002.1534	56	1.2326	0.6496	0.9040	1.0820	8.2090	14.6950	8.1578	14.3126
+6572	2002.1562	57	1.2326	0.6496	0.9040	1.0820	8.2090	14.6950	8.1560	14.3139
+6573	2002.1589	58	1.2325	0.6496	0.9040	1.0820	8.2090	14.6950	8.1541	14.3150
+6574	2002.1616	59	1.2325	0.6496	0.9040	1.0820	8.2090	14.6950	8.1521	14.3162
+6575	2002.1644	60	1.2325	0.6496	0.9040	1.0820	8.2090	14.6950	8.1500	14.3173
+6576	2002.1671	61	1.2325	0.6496	0.9040	1.0820	8.2090	14.6950	8.1479	14.3184
+6577	2002.1699	62	1.2325	0.6496	0.9040	1.0820	8.2090	14.6950	8.1456	14.3194
+6578	2002.1726	63	1.2325	0.6496	0.9040	1.0820	8.2090	14.6950	8.1433	14.3205
+6579	2002.1753	64	1.2325	0.6496	0.9040	1.0820	8.2090	14.6950	8.1410	14.3214
+6580	2002.1781	65	1.2325	0.6496	0.9040	1.0820	8.2090	14.6950	8.1385	14.3224
+6581	2002.1808	66	1.2325	0.6495	0.9040	1.0820	8.2090	14.6950	8.1360	14.3233
+6582	2002.1836	67	1.2325	0.6495	0.9040	1.0820	8.2090	14.6950	8.1334	14.3241
+6583	2002.1863	68	1.2325	0.6495	0.9040	1.0820	8.2090	14.6950	8.1307	14.3250
+6584	2002.1890	69	1.2324	0.6495	0.9039	1.0820	8.2090	14.6950	8.1280	14.3257
+6585	2002.1918	70	1.2324	0.6495	0.9039	1.0820	8.2090	14.6950	8.1252	14.3265
+6586	2002.1945	71	1.2324	0.6495	0.9039	1.0820	8.2090	14.6950	8.1223	14.3272
+6587	2002.1973	72	1.2324	0.6495	0.9039	1.0820	8.2090	14.6950	8.1194	14.3279
+6588	2002.2000	73	1.2324	0.6495	0.9039	1.0820	8.2090	14.6950	8.1164	14.3285
+6589	2002.2027	74	1.2324	0.6495	0.9039	1.0820	8.2090	14.6950	8.1134	14.3291
+6590	2002.2055	75	1.2324	0.6495	0.9039	1.0820	8.2090	14.6950	8.1103	14.3297
+6591	2002.2082	76	1.2324	0.6495	0.9039	1.0820	8.2090	14.6950	8.1071	14.3302
+6592	2002.2110	77	1.2324	0.6495	0.9039	1.0820	8.2090	14.6950	8.1039	14.3307
+6593	2002.2137	78	1.2324	0.6495	0.9039	1.0820	8.2090	14.6950	8.1007	14.3311
+6594	2002.2164	79	1.2324	0.6495	0.9039	1.0820	8.2090	14.6950	8.0974	14.3315
+6595	2002.2192	80	1.2323	0.6495	0.9039	1.0820	8.2090	14.6950	8.0940	14.3319
+6596	2002.2219	81	1.2323	0.6495	0.9039	1.0820	8.2090	14.6950	8.0906	14.3322
+6597	2002.2247	82	1.2323	0.6495	0.9039	1.0820	8.2090	14.6950	8.0872	14.3325
+6598	2002.2274	83	1.2323	0.6495	0.9039	1.0820	8.2090	14.6950	8.0837	14.3327
+6599	2002.2301	84	1.2323	0.6495	0.9039	1.0820	8.2090	14.6950	8.0802	14.3329
+6600	2002.2329	85	1.2323	0.6494	0.9039	1.0820	8.2090	14.6950	8.0767	14.3331
+6601	2002.2356	86	1.2323	0.6494	0.9039	1.0820	8.2090	14.6950	8.0731	14.3332
+6602	2002.2384	87	1.2323	0.6494	0.9039	1.0820	8.2090	14.6950	8.0695	14.3332
+6603	2002.2411	88	1.2323	0.6494	0.9039	1.0820	8.2090	14.6950	8.0658	14.3333
+6604	2002.2438	89	1.2323	0.6494	0.9039	1.0820	8.2090	14.6950	8.0622	14.3333
+6605	2002.2466	90	1.2323	0.6494	0.9039	1.0820	8.2090	14.6950	8.0585	14.3332
+6606	2002.2493	91	1.2322	0.6494	0.9039	1.0820	8.2090	14.6950	8.0548	14.3331
+6607	2002.2521	92	1.2322	0.6494	0.9039	1.0820	8.2090	14.6950	8.0511	14.3330
+6608	2002.2548	93	1.2322	0.6494	0.9039	1.0820	8.2090	14.6950	8.0473	14.3328
+6609	2002.2575	94	1.2322	0.6494	0.9039	1.0820	8.2090	14.6950	8.0436	14.3326
+6610	2002.2603	95	1.2322	0.6494	0.9039	1.0820	8.2090	14.6950	8.0398	14.3323
+6611	2002.2630	96	1.2322	0.6494	0.9039	1.0820	8.2090	14.6950	8.0360	14.3320
+6612	2002.2658	97	1.2322	0.6494	0.9039	1.0820	8.2090	14.6950	8.0322	14.3316
+6613	2002.2685	98	1.2322	0.6494	0.9039	1.0820	8.2090	14.6950	8.0284	14.3312
+6614	2002.2712	99	1.2322	0.6494	0.9039	1.0820	8.2090	14.6950	8.0246	14.3308
+6615	2002.2740	100	1.2322	0.6494	0.9039	1.0820	8.2090	14.6950	8.0208	14.3303
+6616	2002.2767	101	1.2322	0.6494	0.9039	1.0820	8.2090	14.6950	8.0170	14.3298
+6617	2002.2795	102	1.2322	0.6494	0.9039	1.0820	8.2090	14.6950	8.0132	14.3292
+6618	2002.2822	103	1.2321	0.6493	0.9039	1.0820	8.2090	14.6950	8.0094	14.3286
+6619	2002.2849	104	1.2321	0.6493	0.9039	1.0820	8.2090	14.6950	8.0056	14.3280
+6620	2002.2877	105	1.2321	0.6493	0.9039	1.0820	8.2090	14.6950	8.0019	14.3273
+6621	2002.2904	106	1.2321	0.6493	0.9039	1.0820	8.2090	14.6950	7.9981	14.3266
+6622	2002.2932	107	1.2321	0.6493	0.9039	1.0820	8.2090	14.6950	7.9943	14.3258
+6623	2002.2959	108	1.2321	0.6493	0.9039	1.0820	8.2090	14.6950	7.9906	14.3250
+6624	2002.2986	109	1.2321	0.6493	0.9039	1.0820	8.2090	14.6950	7.9869	14.3241
+6625	2002.3014	110	1.2321	0.6493	0.9039	1.0820	8.2090	14.6950	7.9832	14.3232
+6626	2002.3041	111	1.2321	0.6493	0.9039	1.0820	8.2090	14.6950	7.9795	14.3223
+6627	2002.3068	112	1.2321	0.6493	0.9039	1.0820	8.2090	14.6950	7.9759	14.3213
+6628	2002.3096	113	1.2321	0.6493	0.9039	1.0820	8.2090	14.6950	7.9723	14.3203
+6629	2002.3123	114	1.2320	0.6493	0.9039	1.0820	8.2090	14.6950	7.9687	14.3193
+6630	2002.3151	115	1.2320	0.6493	0.9039	1.0820	8.2090	14.6950	7.9651	14.3182
+6631	2002.3178	116	1.2320	0.6493	0.9039	1.0820	8.2090	14.6950	7.9616	14.3170
+6632	2002.3205	117	1.2320	0.6493	0.9039	1.0820	8.2090	14.6950	7.9581	14.3158
+6633	2002.3233	118	1.2320	0.6493	0.9039	1.0820	8.2090	14.6950	7.9546	14.3146
+6634	2002.3260	119	1.2320	0.6493	0.9039	1.0820	8.2090	14.6950	7.9512	14.3134
+6635	2002.3288	120	1.2320	0.6493	0.9039	1.0820	8.2090	14.6950	7.9478	14.3121
+6636	2002.3315	121	1.2320	0.6493	0.9039	1.0820	8.2090	14.6950	7.9445	14.3107
+6637	2002.3342	122	1.2320	0.6492	0.9039	1.0820	8.2090	14.6950	7.9412	14.3093
+6638	2002.3370	123	1.2320	0.6492	0.9039	1.0820	8.2090	14.6950	7.9380	14.3079
+6639	2002.3397	124	1.2320	0.6492	0.9039	1.0820	8.2090	14.6950	7.9348	14.3065
+6640	2002.3425	125	1.2319	0.6492	0.9039	1.0820	8.2090	14.6950	7.9316	14.3050
+6641	2002.3452	126	1.2319	0.6492	0.9039	1.0820	8.2090	14.6950	7.9285	14.3035
+6642	2002.3479	127	1.2319	0.6492	0.9039	1.0820	8.2090	14.6950	7.9255	14.3019
+6643	2002.3507	128	1.2319	0.6492	0.9039	1.0820	8.2090	14.6950	7.9225	14.3003
+6644	2002.3534	129	1.2319	0.6492	0.9039	1.0820	8.2090	14.6950	7.9195	14.2986
+6645	2002.3562	130	1.2319	0.6492	0.9039	1.0820	8.2090	14.6950	7.9167	14.2970
+6646	2002.3589	131	1.2319	0.6492	0.9039	1.0820	8.2090	14.6950	7.9138	14.2953
+6647	2002.3616	132	1.2319	0.6492	0.9039	1.0820	8.2090	14.6950	7.9111	14.2935
+6648	2002.3644	133	1.2319	0.6492	0.9039	1.0820	8.2090	14.6950	7.9084	14.2917
+6649	2002.3671	134	1.2319	0.6492	0.9039	1.0820	8.2090	14.6950	7.9057	14.2899
+6650	2002.3699	135	1.2319	0.6492	0.9039	1.0820	8.2090	14.6950	7.9032	14.2880
+6651	2002.3726	136	1.2319	0.6492	0.9039	1.0820	8.2090	14.6950	7.9007	14.2862
+6652	2002.3753	137	1.2318	0.6492	0.9039	1.0820	8.2090	14.6950	7.8982	14.2842
+6653	2002.3781	138	1.2318	0.6492	0.9039	1.0820	8.2090	14.6950	7.8959	14.2823
+6654	2002.3808	139	1.2318	0.6492	0.9039	1.0820	8.2090	14.6950	7.8936	14.2803
+6655	2002.3836	140	1.2318	0.6491	0.9039	1.0820	8.2090	14.6950	7.8913	14.2783
+6656	2002.3863	141	1.2318	0.6491	0.9039	1.0820	8.2090	14.6950	7.8892	14.2762
+6657	2002.3890	142	1.2318	0.6491	0.9039	1.0820	8.2090	14.6950	7.8871	14.2741
+6658	2002.3918	143	1.2318	0.6491	0.9039	1.0820	8.2090	14.6950	7.8851	14.2720
+6659	2002.3945	144	1.2318	0.6491	0.9039	1.0820	8.2090	14.6950	7.8832	14.2699
+6660	2002.3973	145	1.2318	0.6491	0.9039	1.0820	8.2090	14.6950	7.8813	14.2677
+6661	2002.4000	146	1.2318	0.6491	0.9039	1.0820	8.2090	14.6950	7.8795	14.2655
+6662	2002.4027	147	1.2318	0.6491	0.9039	1.0820	8.2090	14.6950	7.8778	14.2633
+6663	2002.4055	148	1.2317	0.6491	0.9039	1.0820	8.2090	14.6950	7.8762	14.2610
+6664	2002.4082	149	1.2317	0.6491	0.9039	1.0820	8.2090	14.6950	7.8747	14.2587
+6665	2002.4110	150	1.2317	0.6491	0.9039	1.0820	8.2090	14.6950	7.8732	14.2564
+6666	2002.4137	151	1.2317	0.6491	0.9039	1.0820	8.2090	14.6950	7.8718	14.2540
+6667	2002.4164	152	1.2317	0.6491	0.9039	1.0820	8.2090	14.6950	7.8705	14.2517
+6668	2002.4192	153	1.2317	0.6491	0.9039	1.0820	8.2090	14.6950	7.8693	14.2493
+6669	2002.4219	154	1.2317	0.6491	0.9039	1.0820	8.2090	14.6950	7.8681	14.2468
+6670	2002.4247	155	1.2317	0.6491	0.9039	1.0820	8.2090	14.6950	7.8671	14.2444
+6671	2002.4274	156	1.2317	0.6491	0.9039	1.0820	8.2090	14.6950	7.8661	14.2419
+6672	2002.4301	157	1.2317	0.6491	0.9039	1.0820	8.2090	14.6950	7.8652	14.2394
+6673	2002.4329	158	1.2317	0.6491	0.9039	1.0820	8.2090	14.6950	7.8644	14.2369
+6674	2002.4356	159	1.2317	0.6490	0.9039	1.0820	8.2090	14.6950	7.8637	14.2344
+6675	2002.4384	160	1.2316	0.6490	0.9039	1.0820	8.2090	14.6950	7.8631	14.2318
+6676	2002.4411	161	1.2316	0.6490	0.9039	1.0820	8.2090	14.6950	7.8625	14.2292
+6677	2002.4438	162	1.2316	0.6490	0.9039	1.0820	8.2090	14.6950	7.8621	14.2266
+6678	2002.4466	163	1.2316	0.6490	0.9039	1.0820	8.2090	14.6950	7.8617	14.2240
+6679	2002.4493	164	1.2316	0.6490	0.9039	1.0820	8.2090	14.6950	7.8614	14.2213
+6680	2002.4521	165	1.2316	0.6490	0.9039	1.0820	8.2090	14.6950	7.8612	14.2186
+6681	2002.4548	166	1.2316	0.6490	0.9039	1.0820	8.2090	14.6950	7.8611	14.2160
+6682	2002.4575	167	1.2316	0.6490	0.9039	1.0820	8.2090	14.6950	7.8610	14.2132
+6683	2002.4603	168	1.2316	0.6490	0.9039	1.0820	8.2090	14.6950	7.8611	14.2105
+6684	2002.4630	169	1.2316	0.6490	0.9039	1.0820	8.2090	14.6950	7.8612	14.2078
+6685	2002.4658	170	1.2316	0.6490	0.9039	1.0820	8.2090	14.6950	7.8614	14.2050
+6686	2002.4685	171	1.2315	0.6490	0.9039	1.0820	8.2090	14.6950	7.8617	14.2022
+6687	2002.4712	172	1.2315	0.6490	0.9039	1.0820	8.2090	14.6950	7.8621	14.1995
+6688	2002.4740	173	1.2315	0.6490	0.9039	1.0820	8.2090	14.6950	7.8626	14.1967
+6689	2002.4767	174	1.2315	0.6490	0.9039	1.0820	8.2090	14.6950	7.8631	14.1938
+6690	2002.4795	175	1.2315	0.6490	0.9039	1.0820	8.2090	14.6950	7.8638	14.1910
+6691	2002.4822	176	1.2315	0.6490	0.9039	1.0820	8.2090	14.6950	7.8645	14.1882
+6692	2002.4849	177	1.2315	0.6490	0.9039	1.0820	8.2090	14.6950	7.8653	14.1853
+6693	2002.4877	178	1.2315	0.6489	0.9039	1.0820	8.2090	14.6950	7.8662	14.1824
+6694	2002.4904	179	1.2315	0.6489	0.9039	1.0820	8.2090	14.6950	7.8672	14.1796
+6695	2002.4932	180	1.2315	0.6489	0.9039	1.0820	8.2090	14.6950	7.8682	14.1767
+6696	2002.4959	181	1.2315	0.6489	0.9039	1.0820	8.2090	14.6950	7.8694	14.1738
+6697	2002.4986	182	1.2315	0.6489	0.9039	1.0820	8.2090	14.6950	7.8706	14.1709
+6698	2002.5014	183	1.2314	0.6489	0.9039	1.0820	8.2090	14.6950	7.8719	14.1679
+6699	2002.5041	184	1.2314	0.6489	0.9039	1.0820	8.2090	14.6950	7.8732	14.1650
+6700	2002.5068	185	1.2314	0.6489	0.9039	1.0820	8.2090	14.6950	7.8747	14.1621
+6701	2002.5096	186	1.2314	0.6489	0.9039	1.0820	8.2090	14.6950	7.8762	14.1591
+6702	2002.5123	187	1.2314	0.6489	0.9039	1.0820	8.2090	14.6950	7.8778	14.1562
+6703	2002.5151	188	1.2314	0.6489	0.9039	1.0820	8.2090	14.6950	7.8795	14.1533
+6704	2002.5178	189	1.2314	0.6489	0.9039	1.0820	8.2090	14.6950	7.8812	14.1503
+6705	2002.5205	190	1.2314	0.6489	0.9039	1.0820	8.2090	14.6950	7.8830	14.1473
+6706	2002.5233	191	1.2314	0.6489	0.9039	1.0820	8.2090	14.6950	7.8849	14.1444
+6707	2002.5260	192	1.2314	0.6489	0.9039	1.0820	8.2090	14.6950	7.8869	14.1414
+6708	2002.5288	193	1.2314	0.6489	0.9039	1.0820	8.2090	14.6950	7.8889	14.1384
+6709	2002.5315	194	1.2313	0.6489	0.9039	1.0820	8.2090	14.6950	7.8910	14.1355
+6710	2002.5342	195	1.2313	0.6489	0.9039	1.0820	8.2090	14.6950	7.8932	14.1325
+6711	2002.5370	196	1.2313	0.6489	0.9039	1.0820	8.2090	14.6950	7.8954	14.1295
+6712	2002.5397	197	1.2313	0.6488	0.9039	1.0820	8.2090	14.6950	7.8977	14.1266
+6713	2002.5425	198	1.2313	0.6488	0.9039	1.0820	8.2090	14.6950	7.9000	14.1236
+6714	2002.5452	199	1.2313	0.6488	0.9039	1.0820	8.2090	14.6950	7.9025	14.1206
+6715	2002.5479	200	1.2313	0.6488	0.9039	1.0820	8.2090	14.6950	7.9049	14.1177
+6716	2002.5507	201	1.2313	0.6488	0.9039	1.0820	8.2090	14.6950	7.9075	14.1147
+6717	2002.5534	202	1.2313	0.6488	0.9039	1.0820	8.2090	14.6950	7.9101	14.1118
+6718	2002.5562	203	1.2313	0.6488	0.9039	1.0820	8.2090	14.6950	7.9127	14.1088
+6719	2002.5589	204	1.2313	0.6488	0.9039	1.0820	8.2090	14.6950	7.9154	14.1059
+6720	2002.5616	205	1.2313	0.6488	0.9039	1.0820	8.2090	14.6950	7.9182	14.1029
+6721	2002.5644	206	1.2312	0.6488	0.9039	1.0820	8.2090	14.6950	7.9210	14.1000
+6722	2002.5671	207	1.2312	0.6488	0.9039	1.0820	8.2090	14.6950	7.9239	14.0971
+6723	2002.5699	208	1.2312	0.6488	0.9038	1.0820	8.2090	14.6950	7.9268	14.0941
+6724	2002.5726	209	1.2312	0.6488	0.9038	1.0820	8.2090	14.6950	7.9297	14.0912
+6725	2002.5753	210	1.2312	0.6488	0.9038	1.0820	8.2090	14.6950	7.9327	14.0883
+6726	2002.5781	211	1.2312	0.6488	0.9038	1.0820	8.2090	14.6950	7.9358	14.0854
+6727	2002.5808	212	1.2312	0.6488	0.9038	1.0820	8.2090	14.6950	7.9388	14.0825
+6728	2002.5836	213	1.2312	0.6488	0.9038	1.0820	8.2090	14.6950	7.9420	14.0797
+6729	2002.5863	214	1.2312	0.6488	0.9038	1.0820	8.2090	14.6950	7.9451	14.0768
+6730	2002.5890	215	1.2312	0.6488	0.9038	1.0820	8.2090	14.6950	7.9483	14.0739
+6731	2002.5918	216	1.2312	0.6487	0.9038	1.0820	8.2090	14.6950	7.9515	14.0711
+6732	2002.5945	217	1.2312	0.6487	0.9038	1.0820	8.2090	14.6950	7.9548	14.0683
+6733	2002.5973	218	1.2311	0.6487	0.9038	1.0820	8.2090	14.6950	7.9581	14.0654
+6734	2002.6000	219	1.2311	0.6487	0.9038	1.0820	8.2090	14.6950	7.9614	14.0626
+6735	2002.6027	220	1.2311	0.6487	0.9038	1.0820	8.2090	14.6950	7.9647	14.0599
+6736	2002.6055	221	1.2311	0.6487	0.9038	1.0820	8.2090	14.6950	7.9681	14.0571
+6737	2002.6082	222	1.2311	0.6487	0.9038	1.0820	8.2090	14.6950	7.9715	14.0543
+6738	2002.6110	223	1.2311	0.6487	0.9038	1.0820	8.2090	14.6950	7.9749	14.0516
+6739	2002.6137	224	1.2311	0.6487	0.9038	1.0820	8.2090	14.6950	7.9783	14.0488
+6740	2002.6164	225	1.2311	0.6487	0.9038	1.0820	8.2090	14.6950	7.9818	14.0461
+6741	2002.6192	226	1.2311	0.6487	0.9038	1.0820	8.2090	14.6950	7.9852	14.0434
+6742	2002.6219	227	1.2311	0.6487	0.9038	1.0820	8.2090	14.6950	7.9887	14.0408
+6743	2002.6247	228	1.2311	0.6487	0.9038	1.0820	8.2090	14.6950	7.9922	14.0381
+6744	2002.6274	229	1.2311	0.6487	0.9038	1.0820	8.2090	14.6950	7.9957	14.0355
+6745	2002.6301	230	1.2310	0.6487	0.9038	1.0820	8.2090	14.6950	7.9991	14.0329
+6746	2002.6329	231	1.2310	0.6487	0.9038	1.0820	8.2090	14.6950	8.0026	14.0303
+6747	2002.6356	232	1.2310	0.6487	0.9038	1.0820	8.2090	14.6950	8.0061	14.0277
+6748	2002.6384	233	1.2310	0.6487	0.9038	1.0820	8.2090	14.6950	8.0096	14.0251
+6749	2002.6411	234	1.2310	0.6487	0.9038	1.0820	8.2090	14.6950	8.0131	14.0226
+6750	2002.6438	235	1.2310	0.6486	0.9038	1.0820	8.2090	14.6950	8.0166	14.0201
+6751	2002.6466	236	1.2310	0.6486	0.9038	1.0820	8.2090	14.6950	8.0201	14.0176
+6752	2002.6493	237	1.2310	0.6486	0.9038	1.0820	8.2090	14.6950	8.0236	14.0151
+6753	2002.6521	238	1.2310	0.6486	0.9038	1.0820	8.2090	14.6950	8.0270	14.0127
+6754	2002.6548	239	1.2310	0.6486	0.9038	1.0820	8.2090	14.6950	8.0305	14.0103
+6755	2002.6575	240	1.2310	0.6486	0.9038	1.0820	8.2090	14.6950	8.0339	14.0079
+6756	2002.6603	241	1.2310	0.6486	0.9038	1.0820	8.2090	14.6950	8.0373	14.0055
+6757	2002.6630	242	1.2309	0.6486	0.9038	1.0820	8.2090	14.6950	8.0407	14.0032
+6758	2002.6658	243	1.2309	0.6486	0.9038	1.0820	8.2090	14.6950	8.0441	14.0009
+6759	2002.6685	244	1.2309	0.6486	0.9038	1.0820	8.2090	14.6950	8.0474	13.9986
+6760	2002.6712	245	1.2309	0.6486	0.9038	1.0820	8.2090	14.6950	8.0508	13.9963
+6761	2002.6740	246	1.2309	0.6486	0.9038	1.0820	8.2090	14.6950	8.0541	13.9941
+6762	2002.6767	247	1.2309	0.6486	0.9038	1.0820	8.2090	14.6950	8.0573	13.9918
+6763	2002.6795	248	1.2309	0.6486	0.9038	1.0820	8.2090	14.6950	8.0606	13.9897
+6764	2002.6822	249	1.2309	0.6486	0.9038	1.0820	8.2090	14.6950	8.0638	13.9875
+6765	2002.6849	250	1.2309	0.6486	0.9038	1.0820	8.2090	14.6950	8.0669	13.9854
+6766	2002.6877	251	1.2309	0.6486	0.9038	1.0820	8.2090	14.6950	8.0701	13.9833
+6767	2002.6904	252	1.2309	0.6486	0.9038	1.0820	8.2090	14.6950	8.0732	13.9812
+6768	2002.6932	253	1.2308	0.6486	0.9038	1.0820	8.2090	14.6950	8.0762	13.9792
+6769	2002.6959	254	1.2308	0.6485	0.9038	1.0820	8.2090	14.6950	8.0792	13.9772
+6770	2002.6986	255	1.2308	0.6485	0.9038	1.0820	8.2090	14.6950	8.0822	13.9752
+6771	2002.7014	256	1.2308	0.6485	0.9038	1.0820	8.2090	14.6950	8.0851	13.9732
+6772	2002.7041	257	1.2308	0.6485	0.9038	1.0820	8.2090	14.6950	8.0879	13.9713
+6773	2002.7068	258	1.2308	0.6485	0.9038	1.0820	8.2090	14.6950	8.0907	13.9694
+6774	2002.7096	259	1.2308	0.6485	0.9038	1.0820	8.2090	14.6950	8.0935	13.9676
+6775	2002.7123	260	1.2308	0.6485	0.9038	1.0820	8.2090	14.6950	8.0962	13.9658
+6776	2002.7151	261	1.2308	0.6485	0.9038	1.0820	8.2090	14.6950	8.0989	13.9640
+6777	2002.7178	262	1.2308	0.6485	0.9038	1.0820	8.2090	14.6950	8.1014	13.9622
+6778	2002.7205	263	1.2308	0.6485	0.9038	1.0820	8.2090	14.6950	8.1040	13.9605
+6779	2002.7233	264	1.2308	0.6485	0.9038	1.0820	8.2090	14.6950	8.1064	13.9588
+6780	2002.7260	265	1.2307	0.6485	0.9038	1.0820	8.2090	14.6950	8.1089	13.9571
+6781	2002.7288	266	1.2307	0.6485	0.9038	1.0820	8.2090	14.6950	8.1112	13.9555
+6782	2002.7315	267	1.2307	0.6485	0.9038	1.0820	8.2090	14.6950	8.1135	13.9539
+6783	2002.7342	268	1.2307	0.6485	0.9038	1.0820	8.2090	14.6950	8.1157	13.9524
+6784	2002.7370	269	1.2307	0.6485	0.9038	1.0820	8.2090	14.6950	8.1178	13.9508
+6785	2002.7397	270	1.2307	0.6485	0.9038	1.0820	8.2090	14.6950	8.1199	13.9494
+6786	2002.7425	271	1.2307	0.6485	0.9038	1.0820	8.2090	14.6950	8.1219	13.9479
+6787	2002.7452	272	1.2307	0.6485	0.9038	1.0820	8.2090	14.6950	8.1238	13.9465
+6788	2002.7479	273	1.2307	0.6485	0.9038	1.0820	8.2090	14.6950	8.1257	13.9451
+6789	2002.7507	274	1.2307	0.6484	0.9038	1.0820	8.2090	14.6950	8.1275	13.9438
+6790	2002.7534	275	1.2307	0.6484	0.9038	1.0820	8.2090	14.6950	8.1292	13.9425
+6791	2002.7562	276	1.2307	0.6484	0.9038	1.0820	8.2090	14.6950	8.1308	13.9412
+6792	2002.7589	277	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1323	13.9399
+6793	2002.7616	278	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1338	13.9387
+6794	2002.7644	279	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1352	13.9376
+6795	2002.7671	280	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1365	13.9364
+6796	2002.7699	281	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1377	13.9353
+6797	2002.7726	282	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1389	13.9343
+6798	2002.7753	283	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1399	13.9333
+6799	2002.7781	284	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1409	13.9323
+6800	2002.7808	285	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1418	13.9313
+6801	2002.7836	286	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1426	13.9304
+6802	2002.7863	287	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1433	13.9296
+6803	2002.7890	288	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1439	13.9287
+6804	2002.7918	289	1.2306	0.6484	0.9038	1.0820	8.2090	14.6950	8.1445	13.9279
+6805	2002.7945	290	1.2305	0.6484	0.9038	1.0820	8.2090	14.6950	8.1449	13.9272
+6806	2002.7973	291	1.2305	0.6484	0.9038	1.0820	8.2090	14.6950	8.1453	13.9264
+6807	2002.8000	292	1.2305	0.6484	0.9038	1.0820	8.2090	14.6950	8.1456	13.9258
+6808	2002.8027	293	1.2305	0.6483	0.9038	1.0820	8.2090	14.6950	8.1458	13.9251
+6809	2002.8055	294	1.2305	0.6483	0.9038	1.0820	8.2090	14.6950	8.1459	13.9245
+6810	2002.8082	295	1.2305	0.6483	0.9038	1.0820	8.2090	14.6950	8.1459	13.9239
+6811	2002.8110	296	1.2305	0.6483	0.9038	1.0820	8.2090	14.6950	8.1458	13.9234
+6812	2002.8137	297	1.2305	0.6483	0.9038	1.0820	8.2090	14.6950	8.1457	13.9229
+6813	2002.8164	298	1.2305	0.6483	0.9038	1.0820	8.2090	14.6950	8.1454	13.9224
+6814	2002.8192	299	1.2305	0.6483	0.9038	1.0820	8.2090	14.6950	8.1451	13.9220
+6815	2002.8219	300	1.2305	0.6483	0.9038	1.0820	8.2090	14.6950	8.1447	13.9216
+6816	2002.8247	301	1.2305	0.6483	0.9038	1.0820	8.2090	14.6950	8.1442	13.9213
+6817	2002.8274	302	1.2304	0.6483	0.9038	1.0820	8.2090	14.6950	8.1436	13.9210
+6818	2002.8301	303	1.2304	0.6483	0.9038	1.0820	8.2090	14.6950	8.1429	13.9207
+6819	2002.8329	304	1.2304	0.6483	0.9038	1.0820	8.2090	14.6950	8.1421	13.9205
+6820	2002.8356	305	1.2304	0.6483	0.9038	1.0820	8.2090	14.6950	8.1413	13.9203
+6821	2002.8384	306	1.2304	0.6483	0.9038	1.0820	8.2090	14.6950	8.1403	13.9201
+6822	2002.8411	307	1.2304	0.6483	0.9038	1.0820	8.2090	14.6950	8.1393	13.9200
+6823	2002.8438	308	1.2304	0.6483	0.9038	1.0820	8.2090	14.6950	8.1382	13.9199
+6824	2002.8466	309	1.2304	0.6483	0.9038	1.0820	8.2090	14.6950	8.1370	13.9199
+6825	2002.8493	310	1.2304	0.6483	0.9038	1.0820	8.2090	14.6950	8.1357	13.9199
+6826	2002.8521	311	1.2304	0.6483	0.9038	1.0820	8.2090	14.6950	8.1343	13.9199
+6827	2002.8548	312	1.2304	0.6483	0.9038	1.0820	8.2090	14.6950	8.1329	13.9199
+6828	2002.8575	313	1.2304	0.6482	0.9038	1.0820	8.2090	14.6950	8.1314	13.9200
+6829	2002.8603	314	1.2303	0.6482	0.9038	1.0820	8.2090	14.6950	8.1298	13.9202
+6830	2002.8630	315	1.2303	0.6482	0.9038	1.0820	8.2090	14.6950	8.1281	13.9203
+6831	2002.8658	316	1.2303	0.6482	0.9038	1.0820	8.2090	14.6950	8.1263	13.9206
+6832	2002.8685	317	1.2303	0.6482	0.9038	1.0820	8.2090	14.6950	8.1245	13.9208
+6833	2002.8712	318	1.2303	0.6482	0.9038	1.0820	8.2090	14.6950	8.1226	13.9211
+6834	2002.8740	319	1.2303	0.6482	0.9038	1.0820	8.2090	14.6950	8.1206	13.9214
+6835	2002.8767	320	1.2303	0.6482	0.9038	1.0820	8.2090	14.6950	8.1185	13.9217
+6836	2002.8795	321	1.2303	0.6482	0.9038	1.0820	8.2090	14.6950	8.1164	13.9221
+6837	2002.8822	322	1.2303	0.6482	0.9038	1.0820	8.2090	14.6950	8.1142	13.9225
+6838	2002.8849	323	1.2303	0.6482	0.9038	1.0820	8.2090	14.6950	8.1119	13.9230
+6839	2002.8877	324	1.2303	0.6482	0.9038	1.0820	8.2090	14.6950	8.1096	13.9235
+6840	2002.8904	325	1.2303	0.6482	0.9038	1.0820	8.2090	14.6950	8.1072	13.9240
+6841	2002.8932	326	1.2302	0.6482	0.9038	1.0820	8.2090	14.6950	8.1047	13.9246
+6842	2002.8959	327	1.2302	0.6482	0.9038	1.0820	8.2090	14.6950	8.1022	13.9252
+6843	2002.8986	328	1.2302	0.6482	0.9038	1.0820	8.2090	14.6950	8.0996	13.9258
+6844	2002.9014	329	1.2302	0.6482	0.9038	1.0820	8.2090	14.6950	8.0969	13.9264
+6845	2002.9041	330	1.2302	0.6482	0.9038	1.0820	8.2090	14.6950	8.0942	13.9271
+6846	2002.9068	331	1.2302	0.6482	0.9038	1.0820	8.2090	14.6950	8.0914	13.9279
+6847	2002.9096	332	1.2302	0.6482	0.9038	1.0820	8.2090	14.6950	8.0886	13.9286
+6848	2002.9123	333	1.2302	0.6481	0.9038	1.0820	8.2090	14.6950	8.0857	13.9294
+6849	2002.9151	334	1.2302	0.6481	0.9038	1.0820	8.2090	14.6950	8.0828	13.9302
+6850	2002.9178	335	1.2302	0.6481	0.9038	1.0820	8.2090	14.6950	8.0798	13.9311
+6851	2002.9205	336	1.2302	0.6481	0.9038	1.0820	8.2090	14.6950	8.0768	13.9320
+6852	2002.9233	337	1.2302	0.6481	0.9038	1.0820	8.2090	14.6950	8.0737	13.9329
+6853	2002.9260	338	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.0705	13.9338
+6854	2002.9288	339	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.0674	13.9348
+6855	2002.9315	340	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.0642	13.9358
+6856	2002.9342	341	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.0609	13.9368
+6857	2002.9370	342	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.0576	13.9379
+6858	2002.9397	343	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.0543	13.9390
+6859	2002.9425	344	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.0509	13.9401
+6860	2002.9452	345	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.2090	14.6950
+6861	2002.9479	346	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.2061	14.6950
+6862	2002.9507	347	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.2032	14.6949
+6863	2002.9534	348	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.2002	14.6947
+6864	2002.9562	349	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.1971	14.6946
+6865	2002.9589	350	1.2301	0.6481	0.9038	1.0820	8.2090	14.6950	8.1940	14.6944
+6866	2002.9616	351	1.2300	0.6481	0.9038	1.0820	8.2090	14.6950	8.1909	14.6941
+6867	2002.9644	352	1.2300	0.6481	0.9038	1.0820	8.2090	14.6950	8.1877	14.6938
+6868	2002.9671	353	1.2300	0.6480	0.9038	1.0820	8.2090	14.6950	8.1844	14.6935
+6869	2002.9699	354	1.2300	0.6480	0.9038	1.0820	8.2090	14.6950	8.1811	14.6931
+6870	2002.9726	355	1.2300	0.6480	0.9038	1.0820	8.2090	14.6950	8.1778	14.6927
+6871	2002.9753	356	1.2300	0.6480	0.9038	1.0820	8.2090	14.6950	8.1744	14.6923
+6872	2002.9781	357	1.2300	0.6480	0.9038	1.0820	8.2090	14.6950	8.1710	14.6918
+6873	2002.9808	358	1.2300	0.6480	0.9038	1.0820	8.2090	14.6950	8.1676	14.6912
+6874	2002.9836	359	1.2300	0.6480	0.9038	1.0820	8.2090	14.6950	8.1641	14.6907
+6875	2002.9863	360	1.2300	0.6480	0.9038	1.0820	8.2090	14.6950	8.1606	14.6900
+6876	2002.9890	361	1.2300	0.6480	0.9037	1.0820	8.2090	14.6950	8.1571	14.6894
+6877	2002.9918	362	1.2300	0.6480	0.9037	1.0820	8.2090	14.6950	8.1535	14.6887
+6878	2002.9945	363	1.2299	0.6480	0.9037	1.0820	8.2090	14.6950	8.1500	14.6880
+6879	2002.9973	364	1.2299	0.6480	0.9037	1.0820	8.2090	14.6950	8.1464	14.6872
+6880	2002.9999	365	1.2299	0.6480	0.9037	1.0820	8.2090	14.6950	8.1427	14.6864
+6881	2003.0027	1	1.2299	0.6480	0.9037	1.0820	8.2090	14.6950	8.1391	14.6855
+6882	2003.0055	2	1.2299	0.6480	0.9037	1.0820	8.2090	14.6950	8.1354	14.6846
+6883	2003.0082	3	1.2299	0.6480	0.9037	1.0820	8.2090	14.6950	8.1317	14.6837
+6884	2003.0110	4	1.2299	0.6480	0.9037	1.0820	8.2090	14.6950	8.1280	14.6827
+6885	2003.0137	5	1.2299	0.6480	0.9037	1.0820	8.2090	14.6950	8.1243	14.6817
+6886	2003.0164	6	1.2299	0.6480	0.9037	1.0820	8.2090	14.6950	8.1206	14.6806
+6887	2003.0192	7	1.2299	0.6480	0.9037	1.0820	8.2090	14.6950	8.1169	14.6795
+6888	2003.0219	8	1.2299	0.6479	0.9037	1.0820	8.2090	14.6950	8.1132	14.6784
+6889	2003.0247	9	1.2299	0.6479	0.9037	1.0820	8.2090	14.6950	8.1095	14.6772
+6890	2003.0274	10	1.2299	0.6479	0.9037	1.0820	8.2090	14.6950	8.1057	14.6760
+6891	2003.0301	11	1.2298	0.6479	0.9037	1.0820	8.2090	14.6950	8.1020	14.6747
+6892	2003.0329	12	1.2298	0.6479	0.9037	1.0820	8.2090	14.6950	8.0983	14.6734
+6893	2003.0356	13	1.2298	0.6479	0.9037	1.0820	8.2090	14.6950	8.0946	14.6721
+6894	2003.0384	14	1.2298	0.6479	0.9037	1.0820	8.2090	14.6950	8.0909	14.6707
+6895	2003.0411	15	1.2298	0.6479	0.9037	1.0820	8.2090	14.6950	8.0872	14.6693
+6896	2003.0438	16	1.2298	0.6479	0.9037	1.0820	8.2090	14.6950	8.0835	14.6679
+6897	2003.0466	17	1.2298	0.6479	0.9037	1.0820	8.2090	14.6950	8.0798	14.6664
+6898	2003.0493	18	1.2298	0.6479	0.9037	1.0820	8.2090	14.6950	8.0761	14.6649
+6899	2003.0521	19	1.2298	0.6479	0.9037	1.0820	8.2090	14.6950	8.0725	14.6633
+6900	2003.0548	20	1.2298	0.6479	0.9037	1.0820	8.2090	14.6950	8.0689	14.6617
+6901	2003.0575	21	1.2298	0.6479	0.9037	1.0820	8.2090	14.6950	8.0653	14.6601
+6902	2003.0603	22	1.2298	0.6479	0.9037	1.0820	8.2090	14.6950	8.0617	14.6585
+6903	2003.0630	23	1.2297	0.6479	0.9037	1.0820	8.2090	14.6950	8.0581	14.6568
+6904	2003.0658	24	1.2297	0.6479	0.9037	1.0820	8.2090	14.6950	8.0546	14.6550
+6905	2003.0685	25	1.2297	0.6479	0.9037	1.0820	8.2090	14.6950	8.0511	14.6533
+6906	2003.0712	26	1.2297	0.6479	0.9037	1.0820	8.2090	14.6950	8.0476	14.6515
+6907	2003.0740	27	1.2297	0.6479	0.9037	1.0820	8.2090	14.6950	8.0442	14.6496
+6908	2003.0767	28	1.2297	0.6478	0.9037	1.0820	8.2090	14.6950	8.0408	14.6478
+6909	2003.0795	29	1.2297	0.6478	0.9037	1.0820	8.2090	14.6950	8.0374	14.6459
+6910	2003.0822	30	1.2297	0.6478	0.9037	1.0820	8.2090	14.6950	8.0341	14.6439
+6911	2003.0849	31	1.2297	0.6478	0.9037	1.0820	8.2090	14.6950	8.0308	14.6420
+6912	2003.0877	32	1.2297	0.6478	0.9037	1.0820	8.2090	14.6950	8.0275	14.6400
+6913	2003.0904	33	1.2297	0.6478	0.9037	1.0820	8.2090	14.6950	8.0243	14.6380
+6914	2003.0932	34	1.2297	0.6478	0.9037	1.0820	8.2090	14.6950	8.0211	14.6359
+6915	2003.0959	35	1.2297	0.6478	0.9037	1.0820	8.2090	14.6950	8.0180	14.6338
+6916	2003.0986	36	1.2296	0.6478	0.9037	1.0820	8.2090	14.6950	8.0149	14.6317
+6917	2003.1014	37	1.2296	0.6478	0.9037	1.0820	8.2090	14.6950	8.0119	14.6295
+6918	2003.1041	38	1.2296	0.6478	0.9037	1.0820	8.2090	14.6950	8.0089	14.6274
+6919	2003.1068	39	1.2296	0.6478	0.9037	1.0820	8.2090	14.6950	8.0060	14.6251
+6920	2003.1096	40	1.2296	0.6478	0.9037	1.0820	8.2090	14.6950	8.0031	14.6229
+6921	2003.1123	41	1.2296	0.6478	0.9037	1.0820	8.2090	14.6950	8.0003	14.6206
+6922	2003.1151	42	1.2296	0.6478	0.9037	1.0820	8.2090	14.6950	7.9975	14.6184
+6923	2003.1178	43	1.2296	0.6478	0.9037	1.0820	8.2090	14.6950	7.9948	14.6160
+6924	2003.1205	44	1.2296	0.6478	0.9037	1.0820	8.2090	14.6950	7.9922	14.6137
+6925	2003.1233	45	1.2296	0.6478	0.9037	1.0820	8.2090	14.6950	7.9896	14.6113
+6926	2003.1260	46	1.2296	0.6478	0.9037	1.0820	8.2090	14.6950	7.9870	14.6089
+6927	2003.1288	47	1.2296	0.6478	0.9037	1.0820	8.2090	14.6950	7.9846	14.6065
+6928	2003.1315	48	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9822	14.6041
+6929	2003.1342	49	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9798	14.6016
+6930	2003.1370	50	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9776	14.5991
+6931	2003.1397	51	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9753	14.5966
+6932	2003.1425	52	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9732	14.5940
+6933	2003.1452	53	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9711	14.5915
+6934	2003.1479	54	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9691	14.5889
+6935	2003.1507	55	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9672	14.5863
+6936	2003.1534	56	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9653	14.5836
+6937	2003.1562	57	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9635	14.5810
+6938	2003.1589	58	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9618	14.5783
+6939	2003.1616	59	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9602	14.5757
+6940	2003.1644	60	1.2295	0.6477	0.9037	1.0820	8.2090	14.6950	7.9586	14.5730
+6941	2003.1671	61	1.2294	0.6477	0.9037	1.0820	8.2090	14.6950	7.9571	14.5702
+6942	2003.1699	62	1.2294	0.6477	0.9037	1.0820	8.2090	14.6950	7.9557	14.5675
+6943	2003.1726	63	1.2294	0.6477	0.9037	1.0820	8.2090	14.6950	7.9543	14.5647
+6944	2003.1753	64	1.2294	0.6477	0.9037	1.0820	8.2090	14.6950	7.9530	14.5620
+6945	2003.1781	65	1.2294	0.6477	0.9037	1.0820	8.2090	14.6950	7.9518	14.5592
+6946	2003.1808	66	1.2294	0.6477	0.9037	1.0820	8.2090	14.6950	7.9507	14.5564
+6947	2003.1836	67	1.2294	0.6477	0.9037	1.0820	8.2090	14.6950	7.9497	14.5536
+6948	2003.1863	68	1.2294	0.6476	0.9037	1.0820	8.2090	14.6950	7.9487	14.5507
+6949	2003.1890	69	1.2294	0.6476	0.9037	1.0820	8.2090	14.6950	7.9478	14.5479
+6950	2003.1918	70	1.2294	0.6476	0.9037	1.0820	8.2090	14.6950	7.9470	14.5450
+6951	2003.1945	71	1.2294	0.6476	0.9037	1.0820	8.2090	14.6950	7.9463	14.5422
+6952	2003.1973	72	1.2294	0.6476	0.9037	1.0820	8.2090	14.6950	7.9457	14.5393
+6953	2003.2000	73	1.2294	0.6476	0.9037	1.0820	8.2090	14.6950	7.9451	14.5364
+6954	2003.2027	74	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9446	14.5335
+6955	2003.2055	75	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9442	14.5306
+6956	2003.2082	76	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9439	14.5277
+6957	2003.2110	77	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9437	14.5247
+6958	2003.2137	78	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9435	14.5218
+6959	2003.2164	79	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9434	14.5189
+6960	2003.2192	80	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9434	14.5159
+6961	2003.2219	81	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9435	14.5130
+6962	2003.2247	82	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9437	14.5100
+6963	2003.2274	83	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9439	14.5070
+6964	2003.2301	84	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9442	14.5041
+6965	2003.2329	85	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9446	14.5011
+6966	2003.2356	86	1.2293	0.6476	0.9037	1.0820	8.2090	14.6950	7.9451	14.4981
+6967	2003.2384	87	1.2292	0.6476	0.9037	1.0820	8.2090	14.6950	7.9457	14.4951
+6968	2003.2411	88	1.2292	0.6476	0.9037	1.0820	8.2090	14.6950	7.9463	14.4921
+6969	2003.2438	89	1.2292	0.6475	0.9037	1.0820	8.2090	14.6950	7.9470	14.4892
+6970	2003.2466	90	1.2292	0.6475	0.9037	1.0820	8.2090	14.6950	7.9478	14.4862
+6971	2003.2493	91	1.2292	0.6475	0.9037	1.0820	8.2090	14.6950	7.9487	14.4832
+6972	2003.2521	92	1.2292	0.6475	0.9037	1.0820	8.2090	14.6950	7.9496	14.4802
+6973	2003.2548	93	1.2292	0.6475	0.9037	1.0820	8.2090	14.6950	7.9507	14.4772
+6974	2003.2575	94	1.2292	0.6475	0.9037	1.0820	8.2090	14.6950	7.9518	14.4742
+6975	2003.2603	95	1.2292	0.6475	0.9037	1.0820	8.2090	14.6950	7.9529	14.4713
+6976	2003.2630	96	1.2292	0.6475	0.9037	1.0820	8.2090	14.6950	7.9542	14.4683
+6977	2003.2658	97	1.2292	0.6475	0.9037	1.0820	8.2090	14.6950	7.9555	14.4653
+6978	2003.2685	98	1.2292	0.6475	0.9037	1.0820	8.2090	14.6950	7.9569	14.4623
+6979	2003.2712	99	1.2292	0.6475	0.9037	1.0820	8.2090	14.6950	7.9584	14.4594
+6980	2003.2740	100	1.2291	0.6475	0.9037	1.0820	8.2090	14.6950	7.9599	14.4564
+6981	2003.2767	101	1.2291	0.6475	0.9037	1.0820	8.2090	14.6950	7.9615	14.4534
+6982	2003.2795	102	1.2291	0.6475	0.9037	1.0820	8.2090	14.6950	7.9632	14.4505
+6983	2003.2822	103	1.2291	0.6475	0.9037	1.0820	8.2090	14.6950	7.9650	14.4475
+6984	2003.2849	104	1.2291	0.6475	0.9037	1.0820	8.2090	14.6950	7.9668	14.4446
+6985	2003.2877	105	1.2291	0.6475	0.9037	1.0820	8.2090	14.6950	7.9687	14.4417
+6986	2003.2904	106	1.2291	0.6475	0.9037	1.0820	8.2090	14.6950	7.9706	14.4388
+6987	2003.2932	107	1.2291	0.6475	0.9037	1.0820	8.2090	14.6950	7.9726	14.4358
+6988	2003.2959	108	1.2291	0.6475	0.9037	1.0820	8.2090	14.6950	7.9747	14.4329
+6989	2003.2986	109	1.2291	0.6474	0.9037	1.0820	8.2090	14.6950	7.9768	14.4300
+6990	2003.3014	110	1.2291	0.6474	0.9037	1.0820	8.2090	14.6950	7.9790	14.4272
+6991	2003.3041	111	1.2291	0.6474	0.9037	1.0820	8.2090	14.6950	7.9813	14.4243
+6992	2003.3068	112	1.2291	0.6474	0.9037	1.0820	8.2090	14.6950	7.9836	14.4214
+6993	2003.3096	113	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	7.9860	14.4186
+6994	2003.3123	114	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	7.9884	14.4157
+6995	2003.3151	115	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	7.9909	14.4129
+6996	2003.3178	116	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	7.9935	14.4101
+6997	2003.3205	117	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	7.9961	14.4073
+6998	2003.3233	118	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	7.9987	14.4045
+6999	2003.3260	119	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	8.0014	14.4018
+7000	2003.3288	120	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	8.0042	14.3990
+7001	2003.3315	121	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	8.0070	14.3963
+7002	2003.3342	122	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	8.0098	14.3936
+7003	2003.3370	123	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	8.0127	14.3909
+7004	2003.3397	124	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	8.0156	14.3882
+7005	2003.3425	125	1.2290	0.6474	0.9037	1.0820	8.2090	14.6950	8.0186	14.3855
+7006	2003.3452	126	1.2289	0.6474	0.9037	1.0820	8.2090	14.6950	8.0216	14.3829
+7007	2003.3479	127	1.2289	0.6474	0.9037	1.0820	8.2090	14.6950	8.0246	14.3803
+7008	2003.3507	128	1.2289	0.6474	0.9037	1.0820	8.2090	14.6950	8.0277	14.3777
+7009	2003.3534	129	1.2289	0.6474	0.9037	1.0820	8.2090	14.6950	8.0308	14.3751
+7010	2003.3562	130	1.2289	0.6473	0.9037	1.0820	8.2090	14.6950	8.0340	14.3725
+7011	2003.3589	131	1.2289	0.6473	0.9037	1.0820	8.2090	14.6950	8.0371	14.3700
+7012	2003.3616	132	1.2289	0.6473	0.9037	1.0820	8.2090	14.6950	8.0403	14.3674
+7013	2003.3644	133	1.2289	0.6473	0.9037	1.0820	8.2090	14.6950	8.0436	14.3649
+7014	2003.3671	134	1.2289	0.6473	0.9037	1.0820	8.2090	14.6950	8.0468	14.3625
+7015	2003.3699	135	1.2289	0.6473	0.9037	1.0820	8.2090	14.6950	8.0501	14.3600
+7016	2003.3726	136	1.2289	0.6473	0.9037	1.0820	8.2090	14.6950	8.0534	14.3576
+7017	2003.3753	137	1.2289	0.6473	0.9037	1.0820	8.2090	14.6950	8.0567	14.3552
+7018	2003.3781	138	1.2289	0.6473	0.9037	1.0820	8.2090	14.6950	8.0601	14.3528
+7019	2003.3808	139	1.2288	0.6473	0.9037	1.0820	8.2090	14.6950	8.0634	14.3504
+7020	2003.3836	140	1.2288	0.6473	0.9037	1.0820	8.2090	14.6950	8.0668	14.3481
+7021	2003.3863	141	1.2288	0.6473	0.9037	1.0820	8.2090	14.6950	8.0702	14.3458
+7022	2003.3890	142	1.2288	0.6473	0.9037	1.0820	8.2090	14.6950	8.0736	14.3435
+7023	2003.3918	143	1.2288	0.6473	0.9037	1.0820	8.2090	14.6950	8.0770	14.3412
+7024	2003.3945	144	1.2288	0.6473	0.9037	1.0820	8.2090	14.6950	8.0804	14.3390
+7025	2003.3973	145	1.2288	0.6473	0.9037	1.0820	8.2090	14.6950	8.0839	14.3368
+7026	2003.4000	146	1.2288	0.6473	0.9037	1.0820	8.2090	14.6950	8.0873	14.3346
+7027	2003.4027	147	1.2288	0.6473	0.9037	1.0820	8.2090	14.6950	8.0907	14.3325
+7028	2003.4055	148	1.2288	0.6473	0.9037	1.0820	8.2090	14.6950	8.0942	14.3304
+7029	2003.4082	149	1.2288	0.6473	0.9037	1.0820	8.2090	14.6950	8.0976	14.3283
+7030	2003.4110	150	1.2288	0.6473	0.9037	1.0820	8.2090	14.6950	8.1010	14.3262
+7031	2003.4137	151	1.2288	0.6472	0.9037	1.0820	8.2090	14.6950	8.1044	14.3242
+7032	2003.4164	152	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1078	14.3222
+7033	2003.4192	153	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1112	14.3202
+7034	2003.4219	154	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1146	14.3182
+7035	2003.4247	155	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1180	14.3163
+7036	2003.4274	156	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1214	14.3144
+7037	2003.4301	157	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1247	14.3126
+7038	2003.4329	158	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1280	14.3107
+7039	2003.4356	159	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1313	14.3089
+7040	2003.4384	160	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1346	14.3072
+7041	2003.4411	161	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1379	14.3054
+7042	2003.4438	162	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1411	14.3038
+7043	2003.4466	163	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1443	14.3021
+7044	2003.4493	164	1.2287	0.6472	0.9037	1.0820	8.2090	14.6950	8.1475	14.3005
+7045	2003.4521	165	1.2286	0.6472	0.9037	1.0820	8.2090	14.6950	8.1506	14.2989
+7046	2003.4548	166	1.2286	0.6472	0.9036	1.0820	8.2090	14.6950	8.1537	14.2973
+7047	2003.4575	167	1.2286	0.6472	0.9036	1.0820	8.2090	14.6950	8.1568	14.2957
+7048	2003.4603	168	1.2286	0.6472	0.9036	1.0820	8.2090	14.6950	8.1598	14.2942
+7049	2003.4630	169	1.2286	0.6472	0.9036	1.0820	8.2090	14.6950	8.1628	14.2928
+7050	2003.4658	170	1.2286	0.6472	0.9036	1.0820	8.2090	14.6950	8.1658	14.2913
+7051	2003.4685	171	1.2286	0.6471	0.9036	1.0820	8.2090	14.6950	8.1687	14.2899
+7052	2003.4712	172	1.2286	0.6471	0.9036	1.0820	8.2090	14.6950	8.1716	14.2886
+7053	2003.4740	173	1.2286	0.6471	0.9036	1.0820	8.2090	14.6950	8.1744	14.2873
+7054	2003.4767	174	1.2286	0.6471	0.9036	1.0820	8.2090	14.6950	8.1772	14.2860
+7055	2003.4795	175	1.2286	0.6471	0.9036	1.0820	8.2090	14.6950	8.1799	14.2847
+7056	2003.4822	176	1.2286	0.6471	0.9036	1.0820	8.2090	14.6950	8.1826	14.2835
+7057	2003.4849	177	1.2286	0.6471	0.9036	1.0820	8.2090	14.6950	8.1852	14.2823
+7058	2003.4877	178	1.2286	0.6471	0.9036	1.0820	8.2090	14.6950	8.1878	14.2811
+7059	2003.4904	179	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.1903	14.2800
+7060	2003.4932	180	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.1927	14.2789
+7061	2003.4959	181	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.1951	14.2779
+7062	2003.4986	182	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.1975	14.2768
+7063	2003.5014	183	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.1997	14.2759
+7064	2003.5041	184	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.2020	14.2749
+7065	2003.5068	185	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.2041	14.2740
+7066	2003.5096	186	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.2062	14.2732
+7067	2003.5123	187	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.2082	14.2723
+7068	2003.5151	188	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.2102	14.2715
+7069	2003.5178	189	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.2121	14.2708
+7070	2003.5205	190	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.2139	14.2700
+7071	2003.5233	191	1.2285	0.6471	0.9036	1.0820	8.2090	14.6950	8.2156	14.2693
+7072	2003.5260	192	1.2284	0.6471	0.9036	1.0820	8.2090	14.6950	8.2173	14.2687
+7073	2003.5288	193	1.2284	0.6470	0.9036	1.0820	8.2090	14.6950	8.2189	14.2681
+7074	2003.5315	194	1.2284	0.6470	0.9036	1.0820	8.2090	14.6950	8.2205	14.2675
+7075	2003.5342	195	1.2284	0.6470	0.9036	1.0820	8.2090	14.6950	8.2219	14.2670
+7076	2003.5370	196	1.2284	0.6470	0.9036	1.0820	8.2090	14.6950	8.2233	14.2665
+7077	2003.5397	197	1.2284	0.6470	0.9036	1.0820	8.2090	14.6950	8.2246	14.2660
+7078	2003.5425	198	1.2284	0.6470	0.9036	1.0820	8.2090	14.6950	8.2258	14.2655
+7079	2003.5452	199	1.2284	0.6470	0.9036	1.0820	8.2090	14.6950	8.2270	14.2652
+7080	2003.5479	200	1.2284	0.6470	0.9036	1.0820	8.2090	14.6950	8.2280	14.2648
+7081	2003.5507	201	1.2284	0.6470	0.9036	1.0820	8.2090	14.6950	8.2290	14.2645
+7082	2003.5534	202	1.2284	0.6470	0.9036	1.0820	8.2090	14.6950	8.2299	14.2642
+7083	2003.5562	203	1.2284	0.6470	0.9036	1.0820	8.2090	14.6950	8.2308	14.2639
+7084	2003.5589	204	1.2284	0.6470	0.9036	1.0820	8.2090	14.6950	8.2315	14.2637
+7085	2003.5616	205	1.2283	0.6470	0.9036	1.0820	8.2090	14.6950	8.2322	14.2635
+7086	2003.5644	206	1.2283	0.6470	0.9036	1.0820	8.2090	14.6950	8.2328	14.2634
+7087	2003.5671	207	1.2283	0.6470	0.9036	1.0820	8.2090	14.6950	8.2333	14.2633
+7088	2003.5699	208	1.2283	0.6470	0.9036	1.0820	8.2090	14.6950	8.2337	14.2632
+7089	2003.5726	209	1.2283	0.6470	0.9036	1.0820	8.2090	14.6950	8.2341	14.2632
+7090	2003.5753	210	1.2283	0.6470	0.9036	1.0820	8.2090	14.6950	8.2343	14.2632
+7091	2003.5781	211	1.2283	0.6470	0.9036	1.0820	8.2090	14.6950	8.2345	14.2632
+7092	2003.5808	212	1.2283	0.6470	0.9036	1.0820	8.2090	14.6950	8.2346	14.2633
+7093	2003.5836	213	1.2283	0.6470	0.9036	1.0820	8.2090	14.6950	8.2346	14.2634
+7094	2003.5863	214	1.2283	0.6469	0.9036	1.0820	8.2090	14.6950	8.2345	14.2635
+7095	2003.5890	215	1.2283	0.6469	0.9036	1.0820	8.2090	14.6950	8.2344	14.2637
+7096	2003.5918	216	1.2283	0.6469	0.9036	1.0820	8.2090	14.6950	8.2341	14.2639
+7097	2003.5945	217	1.2283	0.6469	0.9036	1.0820	8.2090	14.6950	8.2338	14.2642
+7098	2003.5973	218	1.2283	0.6469	0.9036	1.0820	8.2090	14.6950	8.2334	14.2645
+7099	2003.6000	219	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2329	14.2648
+7100	2003.6027	220	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2323	14.2651
+7101	2003.6055	221	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2317	14.2655
+7102	2003.6082	222	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2309	14.2659
+7103	2003.6110	223	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2301	14.2664
+7104	2003.6137	224	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2292	14.2669
+7105	2003.6164	225	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2283	14.2674
+7106	2003.6192	226	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2272	14.2679
+7107	2003.6219	227	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2261	14.2685
+7108	2003.6247	228	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2249	14.2691
+7109	2003.6274	229	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2236	14.2698
+7110	2003.6301	230	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2222	14.2705
+7111	2003.6329	231	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2207	14.2712
+7112	2003.6356	232	1.2282	0.6469	0.9036	1.0820	8.2090	14.6950	8.2192	14.2719
+7113	2003.6384	233	1.2281	0.6469	0.9036	1.0820	8.2090	14.6950	8.2176	14.2727
+7114	2003.6411	234	1.2281	0.6469	0.9036	1.0820	8.2090	14.6950	8.2160	14.2735
+7115	2003.6438	235	1.2281	0.6468	0.9036	1.0820	8.2090	14.6950	8.2142	14.2744
+7116	2003.6466	236	1.2281	0.6468	0.9036	1.0820	8.2090	14.6950	8.2124	14.2752
+7117	2003.6493	237	1.2281	0.6468	0.9036	1.0820	8.2090	14.6950	8.2105	14.2761
+7118	2003.6521	238	1.2281	0.6468	0.9036	1.0820	8.2090	14.6950	8.2086	14.2771
+7119	2003.6548	239	1.2281	0.6468	0.9036	1.0820	8.2090	14.6950	8.2065	14.2780
+7120	2003.6575	240	1.2281	0.6468	0.9036	1.0820	8.2090	14.6950	8.2044	14.2790
+7121	2003.6603	241	1.2281	0.6468	0.9036	1.0820	8.2090	14.6950	8.2023	14.2801
+7122	2003.6630	242	1.2281	0.6468	0.9036	1.0820	8.2090	14.6950	8.2001	14.2811
+7123	2003.6658	243	1.2281	0.6468	0.9036	1.0820	8.2090	14.6950	8.1978	14.2822
+7124	2003.6685	244	1.2281	0.6468	0.9036	1.0820	8.2090	14.6950	8.1954	14.2833
+7125	2003.6712	245	1.2281	0.6468	0.9036	1.0820	8.2090	14.6950	8.1930	14.2844
+7126	2003.6740	246	1.2280	0.6468	0.9036	1.0820	8.2090	14.6950	8.1905	14.2856
+7127	2003.6767	247	1.2280	0.6468	0.9036	1.0820	8.2090	14.6950	8.1880	14.2868
+7128	2003.6795	248	1.2280	0.6468	0.9036	1.0820	8.2090	14.6950	8.1854	14.2880
+7129	2003.6822	249	1.2280	0.6468	0.9036	1.0820	8.2090	14.6950	8.1828	14.2892
+7130	2003.6849	250	1.2280	0.6468	0.9036	1.0820	8.2090	14.6950	8.1801	14.2905
+7131	2003.6877	251	1.2280	0.6468	0.9036	1.0820	8.2090	14.6950	8.1773	14.2918
+7132	2003.6904	252	1.2280	0.6468	0.9036	1.0820	8.2090	14.6950	8.1745	14.2931
+7133	2003.6932	253	1.2280	0.6468	0.9036	1.0820	8.2090	14.6950	8.1717	14.2945
+7134	2003.6959	254	1.2280	0.6468	0.9036	1.0820	8.2090	14.6950	8.1688	14.2958
+7135	2003.6986	255	1.2280	0.6468	0.9036	1.0820	8.2090	14.6950	8.1658	14.2972
+7136	2003.7014	256	1.2280	0.6467	0.9036	1.0820	8.2090	14.6950	8.1628	14.2987
+7137	2003.7041	257	1.2280	0.6467	0.9036	1.0820	8.2090	14.6950	8.1598	14.3001
+7138	2003.7068	258	1.2280	0.6467	0.9036	1.0820	8.2090	14.6950	8.1567	14.3016
+7139	2003.7096	259	1.2280	0.6467	0.9036	1.0820	8.2090	14.6950	8.1536	14.3031
+7140	2003.7123	260	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1505	14.3046
+7141	2003.7151	261	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1473	14.3061
+7142	2003.7178	262	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1440	14.3077
+7143	2003.7205	263	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1408	14.3092
+7144	2003.7233	264	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1375	14.3108
+7145	2003.7260	265	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1342	14.3124
+7146	2003.7288	266	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1308	14.3141
+7147	2003.7315	267	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1274	14.3157
+7148	2003.7342	268	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1240	14.3174
+7149	2003.7370	269	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1206	14.3191
+7150	2003.7397	270	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1172	14.3208
+7151	2003.7425	271	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1137	14.3225
+7152	2003.7452	272	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1102	14.3243
+7153	2003.7479	273	1.2279	0.6467	0.9036	1.0820	8.2090	14.6950	8.1067	14.3260
+7154	2003.7507	274	1.2278	0.6467	0.9036	1.0820	8.2090	14.6950	8.1032	14.3278
+7155	2003.7534	275	1.2278	0.6467	0.9036	1.0820	8.2090	14.6950	8.0997	14.3296
+7156	2003.7562	276	1.2278	0.6467	0.9036	1.0820	8.2090	14.6950	8.0961	14.3314
+7157	2003.7589	277	1.2278	0.6467	0.9036	1.0820	8.2090	14.6950	8.0926	14.3332
+7158	2003.7616	278	1.2278	0.6466	0.9036	1.0820	8.2090	14.6950	8.0890	14.3351
+7159	2003.7644	279	1.2278	0.6466	0.9036	1.0820	8.2090	14.6950	8.0855	14.3369
+7160	2003.7671	280	1.2278	0.6466	0.9036	1.0820	8.2090	14.6950	8.0819	14.3388
+7161	2003.7699	281	1.2278	0.6466	0.9036	1.0820	8.2090	14.6950	8.0784	14.3407
+7162	2003.7726	282	1.2278	0.6466	0.9036	1.0820	8.2090	14.6950	8.0748	14.3426
+7163	2003.7753	283	1.2278	0.6466	0.9036	1.0820	8.2090	14.6950	8.0712	14.3445
+7164	2003.7781	284	1.2278	0.6466	0.9036	1.0820	8.2090	14.6950	8.0677	14.3464
+7165	2003.7808	285	1.2278	0.6466	0.9036	1.0820	8.2090	14.6950	8.0641	14.3483
+7166	2003.7836	286	1.2278	0.6466	0.9036	1.0820	8.2090	14.6950	8.0606	14.3502
+7167	2003.7863	287	1.2278	0.6466	0.9036	1.0820	8.2090	14.6950	8.0571	14.3522
+7168	2003.7890	288	1.2277	0.6466	0.9036	1.0820	8.2090	14.6950	8.0535	14.3541
+7169	2003.7918	289	1.2277	0.6466	0.9036	1.0820	8.2090	14.6950	8.0500	14.3561
+7170	2003.7945	290	1.2277	0.6466	0.9036	1.0820	8.2090	14.6950	8.0465	14.3581
+7171	2003.7973	291	1.2277	0.6466	0.9036	1.0820	8.2090	14.6950	8.0431	14.3600
+7172	2003.8000	292	1.2277	0.6466	0.9036	1.0820	8.2090	14.6950	8.0396	14.3620
+7173	2003.8027	293	1.2277	0.6466	0.9036	1.0820	8.2090	14.6950	8.0362	14.3640
+7174	2003.8055	294	1.2277	0.6466	0.9036	1.0820	8.2090	14.6950	8.0328	14.3660
+7175	2003.8082	295	1.2277	0.6466	0.9036	1.0820	8.2090	14.6950	8.0294	14.3680
+7176	2003.8110	296	1.2277	0.6466	0.9036	1.0820	8.2090	14.6950	8.0260	14.3700
+7177	2003.8137	297	1.2277	0.6466	0.9036	1.0820	8.2090	14.6950	8.0226	14.3720
+7178	2003.8164	298	1.2277	0.6466	0.9036	1.0820	8.2090	14.6950	8.0193	14.3741
+7179	2003.8192	299	1.2277	0.6466	0.9036	1.0820	8.2090	14.6950	8.0160	14.3761
+7180	2003.8219	300	1.2277	0.6465	0.9036	1.0820	8.2090	14.6950	8.0128	14.3781
+7181	2003.8247	301	1.2277	0.6465	0.9036	1.0820	8.2090	14.6950	8.0096	14.3801
+7182	2003.8274	302	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	8.0064	14.3822
+7183	2003.8301	303	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	8.0032	14.3842
+7184	2003.8329	304	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	8.0001	14.3862
+7185	2003.8356	305	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	7.9970	14.3883
+7186	2003.8384	306	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	7.9940	14.3903
+7187	2003.8411	307	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	7.9910	14.3923
+7188	2003.8438	308	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	7.9880	14.3944
+7189	2003.8466	309	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	7.9851	14.3964
+7190	2003.8493	310	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	7.9822	14.3984
+7191	2003.8521	311	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	7.9794	14.4004
+7192	2003.8548	312	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	7.9767	14.4025
+7193	2003.8575	313	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	7.9739	14.4045
+7194	2003.8603	314	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	7.9713	14.4065
+7195	2003.8630	315	1.2276	0.6465	0.9036	1.0820	8.2090	14.6950	7.9686	14.4085
+7196	2003.8658	316	1.2275	0.6465	0.9036	1.0820	8.2090	14.6950	7.9661	14.4105
+7197	2003.8685	317	1.2275	0.6465	0.9036	1.0820	8.2090	14.6950	7.9635	14.4125
+7198	2003.8712	318	1.2275	0.6465	0.9036	1.0820	8.2090	14.6950	7.9611	14.4145
+7199	2003.8740	319	1.2275	0.6465	0.9036	1.0820	8.2090	14.6950	7.9587	14.4165
+7200	2003.8767	320	1.2275	0.6465	0.9036	1.0820	8.2090	14.6950	7.9563	14.4184
+7201	2003.8795	321	1.2275	0.6464	0.9036	1.0820	8.2090	14.6950	7.9540	14.4204
+7202	2003.8822	322	1.2275	0.6464	0.9036	1.0820	8.2090	14.6950	7.9518	14.4224
+7203	2003.8849	323	1.2275	0.6464	0.9036	1.0820	8.2090	14.6950	7.9496	14.4243
+7204	2003.8877	324	1.2275	0.6464	0.9036	1.0820	8.2090	14.6950	7.9475	14.4263
+7205	2003.8904	325	1.2275	0.6464	0.9036	1.0820	8.2090	14.6950	7.9455	14.4282
+7206	2003.8932	326	1.2275	0.6464	0.9036	1.0820	8.2090	14.6950	7.9435	14.4301
+7207	2003.8959	327	1.2275	0.6464	0.9036	1.0820	8.2090	14.6950	7.9416	14.4320
+7208	2003.8986	328	1.2275	0.6464	0.9036	1.0820	8.2090	14.6950	7.9397	14.4339
+7209	2003.9014	329	1.2275	0.6464	0.9036	1.0820	8.2090	14.6950	7.9379	14.4358
+7210	2003.9041	330	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9362	14.4377
+7211	2003.9068	331	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9345	14.4396
+7212	2003.9096	332	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9329	14.4414
+7213	2003.9123	333	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9314	14.4432
+7214	2003.9151	334	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9300	14.4451
+7215	2003.9178	335	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9286	14.4469
+7216	2003.9205	336	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9273	14.4487
+7217	2003.9233	337	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9260	14.4504
+7218	2003.9260	338	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9248	14.4522
+7219	2003.9288	339	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9237	14.4539
+7220	2003.9315	340	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9227	14.4557
+7221	2003.9342	341	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9217	14.4574
+7222	2003.9370	342	1.2274	0.6464	0.9036	1.0820	8.2090	14.6950	7.9208	14.4590
+7223	2003.9397	343	1.2274	0.6463	0.9036	1.0820	8.2090	14.6950	7.9200	14.4607
+7224	2003.9425	344	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9193	14.4624
+7225	2003.9452	345	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9186	14.4640
+7226	2003.9479	346	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9180	14.4656
+7227	2003.9507	347	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9175	14.4672
+7228	2003.9534	348	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9170	14.4688
+7229	2003.9562	349	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9166	14.4703
+7230	2003.9589	350	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9163	14.4718
+7231	2003.9616	351	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9161	14.4734
+7232	2003.9644	352	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9160	14.4748
+7233	2003.9671	353	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9159	14.4763
+7234	2003.9699	354	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9159	14.4777
+7235	2003.9726	355	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9159	14.4791
+7236	2003.9753	356	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9161	14.4805
+7237	2003.9781	357	1.2273	0.6463	0.9036	1.0820	8.2090	14.6950	7.9163	14.4819
+7238	2003.9808	358	1.2272	0.6463	0.9035	1.0820	8.2090	14.6950	7.9166	14.4832
+7239	2003.9836	359	1.2272	0.6463	0.9035	1.0820	8.2090	14.6950	7.9169	14.4846
+7240	2003.9863	360	1.2272	0.6463	0.9035	1.0820	8.2090	14.6950	7.9174	14.4858
+7241	2003.9890	361	1.2272	0.6463	0.9035	1.0820	8.2090	14.6950	7.9179	14.4871
+7242	2003.9918	362	1.2272	0.6463	0.9035	1.0820	8.2090	14.6950	7.9184	14.4883
+7243	2003.9945	363	1.2272	0.6463	0.9035	1.0820	8.2090	14.6950	7.9191	14.4896
+7244	2003.9973	364	1.2272	0.6463	0.9035	1.0820	8.2090	14.6950	7.9198	14.4907
+7245	2003.9999	365	1.2272	0.6463	0.9035	1.0820	8.2090	14.6950	7.9206	14.4919
+7246	2004.0027	1	1.2272	0.6462	0.9035	1.0820	8.2090	14.6950	7.9215	14.4930
+7247	2004.0055	2	1.2272	0.6462	0.9035	1.0820	8.2090	14.6950	7.9224	14.4941
+7248	2004.0082	3	1.2272	0.6462	0.9035	1.0820	8.2090	14.6950	7.9234	14.4952
+7249	2004.0109	4	1.2272	0.6462	0.9035	1.0820	8.2090	14.6950	7.9245	14.4962
+7250	2004.0137	5	1.2272	0.6462	0.9035	1.0820	8.2090	14.6950	7.9256	14.4973
+7251	2004.0164	6	1.2272	0.6462	0.9035	1.0820	8.2090	14.6950	7.9268	14.4982
+7252	2004.0191	7	1.2272	0.6462	0.9035	1.0820	8.2090	14.6950	7.9281	14.4992
+7253	2004.0219	8	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9295	14.5001
+7254	2004.0246	9	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9309	14.5010
+7255	2004.0273	10	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9324	14.5019
+7256	2004.0301	11	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9339	14.5027
+7257	2004.0328	12	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9355	14.5035
+7258	2004.0355	13	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9372	14.5043
+7259	2004.0383	14	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9389	14.5050
+7260	2004.0410	15	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9407	14.5057
+7261	2004.0437	16	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9425	14.5064
+7262	2004.0464	17	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9445	14.5071
+7263	2004.0492	18	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9464	14.5077
+7264	2004.0519	19	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9485	14.5083
+7265	2004.0546	20	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9505	14.5088
+7266	2004.0574	21	1.2271	0.6462	0.9035	1.0820	8.2090	14.6950	7.9527	14.5093
+7267	2004.0601	22	1.2270	0.6462	0.9035	1.0820	8.2090	14.6950	7.9549	14.5098
+7268	2004.0628	23	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9571	14.5103
+7269	2004.0656	24	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9594	14.5107
+7270	2004.0683	25	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9618	14.5111
+7271	2004.0710	26	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9642	14.5114
+7272	2004.0738	27	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9667	14.5117
+7273	2004.0765	28	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9692	14.5120
+7274	2004.0792	29	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9717	14.5122
+7275	2004.0820	30	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9743	14.5125
+7276	2004.0847	31	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9769	14.5126
+7277	2004.0874	32	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9796	14.5128
+7278	2004.0902	33	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9823	14.5129
+7279	2004.0929	34	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9851	14.5130
+7280	2004.0956	35	1.2270	0.6461	0.9035	1.0820	8.2090	14.6950	7.9879	14.5130
+7281	2004.0984	36	1.2269	0.6461	0.9035	1.0820	8.2090	14.6950	7.9907	14.5130
+7282	2004.1011	37	1.2269	0.6461	0.9035	1.0820	8.2090	14.6950	7.9936	14.5130
+7283	2004.1038	38	1.2269	0.6461	0.9035	1.0820	8.2090	14.6950	7.9965	14.5129
+7284	2004.1066	39	1.2269	0.6461	0.9035	1.0820	8.2090	14.6950	7.9994	14.5128
+7285	2004.1093	40	1.2269	0.6461	0.9035	1.0820	8.2090	14.6950	8.0024	14.5127
+7286	2004.1120	41	1.2269	0.6461	0.9035	1.0820	8.2090	14.6950	8.0054	14.5125
+7287	2004.1148	42	1.2269	0.6461	0.9035	1.0820	8.2090	14.6950	8.0085	14.5123
+7288	2004.1175	43	1.2269	0.6461	0.9035	1.0820	8.2090	14.6950	8.0115	14.5120
+7289	2004.1202	44	1.2269	0.6461	0.9035	1.0820	8.2090	14.6950	8.0146	14.5118
+7290	2004.1230	45	1.2269	0.6460	0.9035	1.0820	8.2090	14.6950	8.0177	14.5114
+7291	2004.1257	46	1.2269	0.6460	0.9035	1.0820	8.2090	14.6950	8.0208	14.5111
+7292	2004.1284	47	1.2269	0.6460	0.9035	1.0820	8.2090	14.6950	8.0240	14.5107
+7293	2004.1311	48	1.2269	0.6460	0.9035	1.0820	8.2090	14.6950	8.0271	14.5103
+7294	2004.1339	49	1.2269	0.6460	0.9035	1.0820	8.2090	14.6950	8.0303	14.5098
+7295	2004.1366	50	1.2269	0.6460	0.9035	1.0820	8.2090	14.6950	8.0335	14.5093
+7296	2004.1393	51	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0368	14.5088
+7297	2004.1421	52	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0400	14.5083
+7298	2004.1448	53	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0432	14.5077
+7299	2004.1475	54	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0465	14.5070
+7300	2004.1503	55	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0497	14.5064
+7301	2004.1530	56	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0530	14.5057
+7302	2004.1557	57	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0563	14.5049
+7303	2004.1585	58	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0596	14.5042
+7304	2004.1612	59	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0628	14.5034
+7305	2004.1639	60	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0661	14.5025
+7306	2004.1667	61	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0694	14.5016
+7307	2004.1694	62	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0727	14.5007
+7308	2004.1721	63	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0759	14.4998
+7309	2004.1749	64	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0792	14.4988
+7310	2004.1776	65	1.2268	0.6460	0.9035	1.0820	8.2090	14.6950	8.0824	14.4978
+7311	2004.1803	66	1.2267	0.6460	0.9035	1.0820	8.2090	14.6950	8.0857	14.4968
+7312	2004.1831	67	1.2267	0.6460	0.9035	1.0820	8.2090	14.6950	8.0889	14.4957
+7313	2004.1858	68	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.0921	14.4946
+7314	2004.1885	69	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.0953	14.4934
+7315	2004.1913	70	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.0985	14.4923
+7316	2004.1940	71	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.1016	14.4910
+7317	2004.1967	72	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.1048	14.4898
+7318	2004.1995	73	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.1079	14.4885
+7319	2004.2022	74	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.1110	14.4872
+7320	2004.2049	75	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.1141	14.4859
+7321	2004.2077	76	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.1171	14.4845
+7322	2004.2104	77	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.1201	14.4831
+7323	2004.2131	78	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.1231	14.4817
+7324	2004.2158	79	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.1260	14.4802
+7325	2004.2186	80	1.2267	0.6459	0.9035	1.0820	8.2090	14.6950	8.1290	14.4787
+7326	2004.2213	81	1.2266	0.6459	0.9035	1.0820	8.2090	14.6950	8.1318	14.4772
+7327	2004.2240	82	1.2266	0.6459	0.9035	1.0820	8.2090	14.6950	8.1347	14.4756
+7328	2004.2268	83	1.2266	0.6459	0.9035	1.0820	8.2090	14.6950	8.1375	14.4740
+7329	2004.2295	84	1.2266	0.6459	0.9035	1.0820	8.2090	14.6950	8.2090	14.6950
+7330	2004.2322	85	1.2266	0.6459	0.9035	1.0820	8.2090	14.6950	8.2063	14.6950
+7331	2004.2350	86	1.2266	0.6459	0.9035	1.0820	8.2090	14.6950	8.2035	14.6949
+7332	2004.2377	87	1.2266	0.6459	0.9035	1.0820	8.2090	14.6950	8.2007	14.6948
+7333	2004.2404	88	1.2266	0.6459	0.9035	1.0820	8.2090	14.6950	8.1979	14.6946
+7334	2004.2432	89	1.2266	0.6459	0.9035	1.0820	8.2090	14.6950	8.1950	14.6944
+7335	2004.2459	90	1.2266	0.6459	0.9035	1.0820	8.2090	14.6950	8.1921	14.6942
+7336	2004.2486	91	1.2266	0.6458	0.9035	1.0820	8.2090	14.6950	8.1891	14.6940
+7337	2004.2514	92	1.2266	0.6458	0.9035	1.0820	8.2090	14.6950	8.1861	14.6937
+7338	2004.2541	93	1.2266	0.6458	0.9035	1.0820	8.2090	14.6950	8.1830	14.6934
+7339	2004.2568	94	1.2266	0.6458	0.9035	1.0820	8.2090	14.6950	8.1800	14.6930
+7340	2004.2596	95	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1768	14.6926
+7341	2004.2623	96	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1737	14.6922
+7342	2004.2650	97	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1705	14.6917
+7343	2004.2678	98	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1673	14.6912
+7344	2004.2705	99	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1640	14.6907
+7345	2004.2732	100	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1607	14.6901
+7346	2004.2760	101	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1574	14.6895
+7347	2004.2787	102	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1541	14.6888
+7348	2004.2814	103	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1508	14.6882
+7349	2004.2842	104	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1474	14.6874
+7350	2004.2869	105	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1440	14.6867
+7351	2004.2896	106	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1406	14.6859
+7352	2004.2923	107	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1372	14.6851
+7353	2004.2951	108	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1337	14.6842
+7354	2004.2978	109	1.2265	0.6458	0.9035	1.0820	8.2090	14.6950	8.1303	14.6833
+7355	2004.3005	110	1.2264	0.6458	0.9035	1.0820	8.2090	14.6950	8.1268	14.6824
+7356	2004.3033	111	1.2264	0.6458	0.9035	1.0820	8.2090	14.6950	8.1234	14.6814
+7357	2004.3060	112	1.2264	0.6458	0.9035	1.0820	8.2090	14.6950	8.1199	14.6805
+7358	2004.3087	113	1.2264	0.6458	0.9035	1.0820	8.2090	14.6950	8.1164	14.6794
+7359	2004.3115	114	1.2264	0.6457	0.9035	1.0820	8.2090	14.6950	8.1129	14.6784
+7360	2004.3142	115	1.2264	0.6457	0.9035	1.0820	8.2090	14.6950	8.1094	14.6773
+7361	2004.3169	116	1.2264	0.6457	0.9035	1.0820	8.2090	14.6950	8.1059	14.6761
+7362	2004.3197	117	1.2264	0.6457	0.9035	1.0820	8.2090	14.6950	8.1025	14.6750
+7363	2004.3224	118	1.2264	0.6457	0.9035	1.0820	8.2090	14.6950	8.0990	14.6738
+7364	2004.3251	119	1.2264	0.6457	0.9035	1.0820	8.2090	14.6950	8.0955	14.6725
+7365	2004.3279	120	1.2264	0.6457	0.9035	1.0820	8.2090	14.6950	8.0920	14.6713
+7366	2004.3306	121	1.2264	0.6457	0.9035	1.0820	8.2090	14.6950	8.0885	14.6700
+7367	2004.3333	122	1.2264	0.6457	0.9035	1.0820	8.2090	14.6950	8.0851	14.6687
+7368	2004.3361	123	1.2264	0.6457	0.9035	1.0820	8.2090	14.6950	8.0816	14.6673
+7369	2004.3388	124	1.2264	0.6457	0.9035	1.0820	8.2090	14.6950	8.0782	14.6659
+7370	2004.3415	125	1.2263	0.6457	0.9035	1.0820	8.2090	14.6950	8.0748	14.6645
+7371	2004.3443	126	1.2263	0.6457	0.9035	1.0820	8.2090	14.6950	8.0714	14.6630
+7372	2004.3470	127	1.2263	0.6457	0.9035	1.0820	8.2090	14.6950	8.0680	14.6615
+7373	2004.3497	128	1.2263	0.6457	0.9035	1.0820	8.2090	14.6950	8.0646	14.6600
+7374	2004.3525	129	1.2263	0.6457	0.9035	1.0820	8.2090	14.6950	8.0613	14.6585
+7375	2004.3552	130	1.2263	0.6457	0.9035	1.0820	8.2090	14.6950	8.0580	14.6569
+7376	2004.3579	131	1.2263	0.6457	0.9035	1.0820	8.2090	14.6950	8.0547	14.6553
+7377	2004.3607	132	1.2263	0.6457	0.9035	1.0820	8.2090	14.6950	8.0514	14.6536
+7378	2004.3634	133	1.2263	0.6457	0.9035	1.0820	8.2090	14.6950	8.0481	14.6520
+7379	2004.3661	134	1.2263	0.6457	0.9035	1.0820	8.2090	14.6950	8.0449	14.6503
+7380	2004.3689	135	1.2263	0.6457	0.9035	1.0820	8.2090	14.6950	8.0417	14.6485
+7381	2004.3716	136	1.2263	0.6457	0.9035	1.0820	8.2090	14.6950	8.0385	14.6468
+7382	2004.3743	137	1.2263	0.6456	0.9035	1.0820	8.2090	14.6950	8.0354	14.6450
+7383	2004.3770	138	1.2263	0.6456	0.9035	1.0820	8.2090	14.6950	8.0323	14.6432
+7384	2004.3798	139	1.2263	0.6456	0.9035	1.0820	8.2090	14.6950	8.0292	14.6413
+7385	2004.3825	140	1.2263	0.6456	0.9035	1.0820	8.2090	14.6950	8.0262	14.6394
+7386	2004.3852	141	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	8.0232	14.6375
+7387	2004.3880	142	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	8.0203	14.6356
+7388	2004.3907	143	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	8.0174	14.6337
+7389	2004.3934	144	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	8.0145	14.6317
+7390	2004.3962	145	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	8.0117	14.6297
+7391	2004.3989	146	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	8.0089	14.6277
+7392	2004.4016	147	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	8.0061	14.6256
+7393	2004.4044	148	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	8.0034	14.6235
+7394	2004.4071	149	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	8.0008	14.6214
+7395	2004.4098	150	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	7.9982	14.6193
+7396	2004.4126	151	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	7.9956	14.6171
+7397	2004.4153	152	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	7.9931	14.6150
+7398	2004.4180	153	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	7.9907	14.6128
+7399	2004.4208	154	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	7.9883	14.6105
+7400	2004.4235	155	1.2262	0.6456	0.9035	1.0820	8.2090	14.6950	7.9860	14.6083
+7401	2004.4262	156	1.2261	0.6456	0.9035	1.0820	8.2090	14.6950	7.9837	14.6060
+7402	2004.4290	157	1.2261	0.6456	0.9035	1.0820	8.2090	14.6950	7.9814	14.6037
+7403	2004.4317	158	1.2261	0.6456	0.9035	1.0820	8.2090	14.6950	7.9793	14.6014
+7404	2004.4344	159	1.2261	0.6456	0.9035	1.0820	8.2090	14.6950	7.9771	14.5991
+7405	2004.4372	160	1.2261	0.6455	0.9035	1.0820	8.2090	14.6950	7.9751	14.5967
+7406	2004.4399	161	1.2261	0.6455	0.9035	1.0820	8.2090	14.6950	7.9731	14.5944
+7407	2004.4426	162	1.2261	0.6455	0.9035	1.0820	8.2090	14.6950	7.9711	14.5920
+7408	2004.4454	163	1.2261	0.6455	0.9035	1.0820	8.2090	14.6950	7.9693	14.5896
+7409	2004.4481	164	1.2261	0.6455	0.9035	1.0820	8.2090	14.6950	7.9674	14.5872
+7410	2004.4508	165	1.2261	0.6455	0.9035	1.0820	8.2090	14.6950	7.9657	14.5847
+7411	2004.4536	166	1.2261	0.6455	0.9035	1.0820	8.2090	14.6950	7.9640	14.5823
+7412	2004.4563	167	1.2261	0.6455	0.9035	1.0820	8.2090	14.6950	7.9624	14.5798
+7413	2004.4590	168	1.2261	0.6455	0.9035	1.0820	8.2090	14.6950	7.9608	14.5773
+7414	2004.4617	169	1.2261	0.6455	0.9035	1.0820	8.2090	14.6950	7.9593	14.5748
+7415	2004.4645	170	1.2261	0.6455	0.9035	1.0820	8.2090	14.6950	7.9579	14.5722
+7416	2004.4672	171	1.2260	0.6455	0.9035	1.0820	8.2090	14.6950	7.9565	14.5697
+7417	2004.4699	172	1.2260	0.6455	0.9035	1.0820	8.2090	14.6950	7.9552	14.5671
+7418	2004.4727	173	1.2260	0.6455	0.9035	1.0820	8.2090	14.6950	7.9539	14.5646
+7419	2004.4754	174	1.2260	0.6455	0.9035	1.0820	8.2090	14.6950	7.9528	14.5620
+7420	2004.4781	175	1.2260	0.6455	0.9035	1.0820	8.2090	14.6950	7.9517	14.5594
+7421	2004.4809	176	1.2260	0.6455	0.9035	1.0820	8.2090	14.6950	7.9506	14.5568
+7422	2004.4836	177	1.2260	0.6455	0.9035	1.0820	8.2090	14.6950	7.9497	14.5541
+7423	2004.4863	178	1.2260	0.6455	0.9035	1.0820	8.2090	14.6950	7.9488	14.5515
+7424	2004.4891	179	1.2260	0.6455	0.9035	1.0820	8.2090	14.6950	7.9479	14.5489
+7425	2004.4918	180	1.2260	0.6455	0.9035	1.0820	8.2090	14.6950	7.9472	14.5462
+7426	2004.4945	181	1.2260	0.6455	0.9035	1.0820	8.2090	14.6950	7.9465	14.5435
+7427	2004.4973	182	1.2260	0.6455	0.9035	1.0820	8.2090	14.6950	7.9459	14.5408
+7428	2004.5000	183	1.2260	0.6454	0.9035	1.0820	8.2090	14.6950	7.9453	14.5382
+7429	2004.5027	184	1.2260	0.6454	0.9035	1.0820	8.2090	14.6950	7.9448	14.5355
+7430	2004.5055	185	1.2260	0.6454	0.9035	1.0820	8.2090	14.6950	7.9444	14.5327
+7431	2004.5082	186	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9441	14.5300
+7432	2004.5109	187	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9438	14.5273
+7433	2004.5137	188	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9436	14.5246
+7434	2004.5164	189	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9435	14.5218
+7435	2004.5191	190	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9434	14.5191
+7436	2004.5219	191	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9434	14.5163
+7437	2004.5246	192	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9435	14.5136
+7438	2004.5273	193	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9437	14.5108
+7439	2004.5301	194	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9439	14.5080
+7440	2004.5328	195	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9442	14.5053
+7441	2004.5355	196	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9446	14.5025
+7442	2004.5383	197	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9450	14.4997
+7443	2004.5410	198	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9455	14.4969
+7444	2004.5437	199	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9461	14.4941
+7445	2004.5464	200	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9467	14.4914
+7446	2004.5492	201	1.2259	0.6454	0.9035	1.0820	8.2090	14.6950	7.9474	14.4886
+7447	2004.5519	202	1.2258	0.6454	0.9035	1.0820	8.2090	14.6950	7.9482	14.4858
+7448	2004.5546	203	1.2258	0.6454	0.9035	1.0820	8.2090	14.6950	7.9490	14.4830
+7449	2004.5574	204	1.2258	0.6454	0.9035	1.0820	8.2090	14.6950	7.9499	14.4802
+7450	2004.5601	205	1.2258	0.6454	0.9035	1.0820	8.2090	14.6950	7.9509	14.4774
+7451	2004.5628	206	1.2258	0.6454	0.9035	1.0820	8.2090	14.6950	7.9520	14.4746
+7452	2004.5656	207	1.2258	0.6453	0.9035	1.0820	8.2090	14.6950	7.9531	14.4719
+7453	2004.5683	208	1.2258	0.6453	0.9035	1.0820	8.2090	14.6950	7.9542	14.4691
+7454	2004.5710	209	1.2258	0.6453	0.9035	1.0820	8.2090	14.6950	7.9555	14.4663
+7455	2004.5738	210	1.2258	0.6453	0.9035	1.0820	8.2090	14.6950	7.9568	14.4635
+7456	2004.5765	211	1.2258	0.6453	0.9035	1.0820	8.2090	14.6950	7.9581	14.4608
+7457	2004.5792	212	1.2258	0.6453	0.9034	1.0820	8.2090	14.6950	7.9596	14.4580
+7458	2004.5820	213	1.2258	0.6453	0.9034	1.0820	8.2090	14.6950	7.9611	14.4552
+7459	2004.5847	214	1.2258	0.6453	0.9034	1.0820	8.2090	14.6950	7.9626	14.4525
+7460	2004.5874	215	1.2258	0.6453	0.9034	1.0820	8.2090	14.6950	7.9642	14.4497
+7461	2004.5902	216	1.2258	0.6453	0.9034	1.0820	8.2090	14.6950	7.9659	14.4470
+7462	2004.5929	217	1.2258	0.6453	0.9034	1.0820	8.2090	14.6950	7.9676	14.4442
+7463	2004.5956	218	1.2257	0.6453	0.9034	1.0820	8.2090	14.6950	7.9694	14.4415
+7464	2004.5984	219	1.2257	0.6453	0.9034	1.0820	8.2090	14.6950	7.9713	14.4388
+7465	2004.6011	220	1.2257	0.6453	0.9034	1.0820	8.2090	14.6950	7.9732	14.4361
+7466	2004.6038	221	1.2257	0.6453	0.9034	1.0820	8.2090	14.6950	7.9751	14.4333
+7467	2004.6066	222	1.2257	0.6453	0.9034	1.0820	8.2090	14.6950	7.9771	14.4306
+7468	2004.6093	223	1.2257	0.6453	0.9034	1.0820	8.2090	14.6950	7.9792	14.4279
+7469	2004.6120	224	1.2257	0.6453	0.9034	1.0820	8.2090	14.6950	7.9813	14.4253
+7470	2004.6148	225	1.2257	0.6453	0.9034	1.0820	8.2090	14.6950	7.9835	14.4226
+7471	2004.6175	226	1.2257	0.6453	0.9034	1.0820	8.2090	14.6950	7.9857	14.4199
+7472	2004.6202	227	1.2257	0.6453	0.9034	1.0820	8.2090	14.6950	7.9880	14.4173
+7473	2004.6230	228	1.2257	0.6453	0.9034	1.0820	8.2090	14.6950	7.9903	14.4146
+7474	2004.6257	229	1.2257	0.6453	0.9034	1.0820	8.2090	14.6950	7.9927	14.4120
+7475	2004.6284	230	1.2257	0.6452	0.9034	1.0820	8.2090	14.6950	7.9951	14.4094
+7476	2004.6311	231	1.2257	0.6452	0.9034	1.0820	8.2090	14.6950	7.9975	14.4068
+7477	2004.6339	232	1.2257	0.6452	0.9034	1.0820	8.2090	14.6950	8.0001	14.4042
+7478	2004.6366	233	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0026	14.4016
+7479	2004.6393	234	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0052	14.3990
+7480	2004.6421	235	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0078	14.3965
+7481	2004.6448	236	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0105	14.3940
+7482	2004.6475	237	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0132	14.3914
+7483	2004.6503	238	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0159	14.3889
+7484	2004.6530	239	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0187	14.3864
+7485	2004.6557	240	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0215	14.3840
+7486	2004.6585	241	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0244	14.3815
+7487	2004.6612	242	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0272	14.3791
+7488	2004.6639	243	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0302	14.3766
+7489	2004.6667	244	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0331	14.3742
+7490	2004.6694	245	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0361	14.3718
+7491	2004.6721	246	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0390	14.3695
+7492	2004.6749	247	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0421	14.3671
+7493	2004.6776	248	1.2256	0.6452	0.9034	1.0820	8.2090	14.6950	8.0451	14.3648
+7494	2004.6803	249	1.2255	0.6452	0.9034	1.0820	8.2090	14.6950	8.0482	14.3625
+7495	2004.6831	250	1.2255	0.6452	0.9034	1.0820	8.2090	14.6950	8.0512	14.3602
+7496	2004.6858	251	1.2255	0.6452	0.9034	1.0820	8.2090	14.6950	8.0543	14.3579
+7497	2004.6885	252	1.2255	0.6452	0.9034	1.0820	8.2090	14.6950	8.0575	14.3557
+7498	2004.6913	253	1.2255	0.6452	0.9034	1.0820	8.2090	14.6950	8.0606	14.3534
+7499	2004.6940	254	1.2255	0.6451	0.9034	1.0820	8.2090	14.6950	8.0637	14.3512
+7500	2004.6967	255	1.2255	0.6451	0.9034	1.0820	8.2090	14.6950	8.0669	14.3490
+7501	2004.6995	256	1.2255	0.6451	0.9034	1.0820	8.2090	14.6950	8.0701	14.3469
+7502	2004.7022	257	1.2255	0.6451	0.9034	1.0820	8.2090	14.6950	8.0732	14.3447
+7503	2004.7049	258	1.2255	0.6451	0.9034	1.0820	8.2090	14.6950	8.0764	14.3426
+7504	2004.7077	259	1.2255	0.6451	0.9034	1.0820	8.2090	14.6950	8.0796	14.3405
+7505	2004.7104	260	1.2255	0.6451	0.9034	1.0820	8.2090	14.6950	8.0828	14.3384
+7506	2004.7131	261	1.2255	0.6451	0.9034	1.0820	8.2090	14.6950	8.0860	14.3364
+7507	2004.7158	262	1.2255	0.6451	0.9034	1.0820	8.2090	14.6950	8.0893	14.3344
+7508	2004.7186	263	1.2255	0.6451	0.9034	1.0820	8.2090	14.6950	8.0925	14.3324
+7509	2004.7213	264	1.2255	0.6451	0.9034	1.0820	8.2090	14.6950	8.0957	14.3304
+7510	2004.7240	265	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.0989	14.3284
+7511	2004.7268	266	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.1021	14.3265
+7512	2004.7295	267	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.1053	14.3246
+7513	2004.7322	268	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.1085	14.3227
+7514	2004.7350	269	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.1116	14.3208
+7515	2004.7377	270	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.1148	14.3190
+7516	2004.7404	271	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.1180	14.3172
+7517	2004.7432	272	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.1211	14.3154
+7518	2004.7459	273	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.1243	14.3137
+7519	2004.7486	274	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.1274	14.3120
+7520	2004.7514	275	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.1305	14.3103
+7521	2004.7541	276	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.1335	14.3086
+7522	2004.7568	277	1.2254	0.6451	0.9034	1.0820	8.2090	14.6950	8.1366	14.3070
+7523	2004.7596	278	1.2254	0.6450	0.9034	1.0820	8.2090	14.6950	8.1396	14.3054
+7524	2004.7623	279	1.2254	0.6450	0.9034	1.0820	8.2090	14.6950	8.1426	14.3038
+7525	2004.7650	280	1.2254	0.6450	0.9034	1.0820	8.2090	14.6950	8.1456	14.3022
+7526	2004.7678	281	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1486	14.3007
+7527	2004.7705	282	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1515	14.2992
+7528	2004.7732	283	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1544	14.2977
+7529	2004.7760	284	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1573	14.2963
+7530	2004.7787	285	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1601	14.2949
+7531	2004.7814	286	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1629	14.2935
+7532	2004.7842	287	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1657	14.2921
+7533	2004.7869	288	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1684	14.2908
+7534	2004.7896	289	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1711	14.2895
+7535	2004.7923	290	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1737	14.2882
+7536	2004.7951	291	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1764	14.2870
+7537	2004.7978	292	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1789	14.2858
+7538	2004.8005	293	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1814	14.2846
+7539	2004.8033	294	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1839	14.2835
+7540	2004.8060	295	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1864	14.2824
+7541	2004.8087	296	1.2253	0.6450	0.9034	1.0820	8.2090	14.6950	8.1887	14.2813
+7542	2004.8115	297	1.2252	0.6450	0.9034	1.0820	8.2090	14.6950	8.1911	14.2802
+7543	2004.8142	298	1.2252	0.6450	0.9034	1.0820	8.2090	14.6950	8.1934	14.2792
+7544	2004.8169	299	1.2252	0.6450	0.9034	1.0820	8.2090	14.6950	8.1956	14.2782
+7545	2004.8197	300	1.2252	0.6450	0.9034	1.0820	8.2090	14.6950	8.1978	14.2773
+7546	2004.8224	301	1.2252	0.6450	0.9034	1.0820	8.2090	14.6950	8.1999	14.2763
+7547	2004.8251	302	1.2252	0.6449	0.9034	1.0820	8.2090	14.6950	8.2020	14.2754
+7548	2004.8279	303	1.2252	0.6449	0.9034	1.0820	8.2090	14.6950	8.2040	14.2746
+7549	2004.8306	304	1.2252	0.6449	0.9034	1.0820	8.2090	14.6950	8.2060	14.2737
+7550	2004.8333	305	1.2252	0.6449	0.9034	1.0820	8.2090	14.6950	8.2079	14.2729
+7551	2004.8361	306	1.2252	0.6449	0.9034	1.0820	8.2090	14.6950	8.2097	14.2722
+7552	2004.8388	307	1.2252	0.6449	0.9034	1.0820	8.2090	14.6950	8.2115	14.2714
+7553	2004.8415	308	1.2252	0.6449	0.9034	1.0820	8.2090	14.6950	8.2132	14.2707
+7554	2004.8443	309	1.2252	0.6449	0.9034	1.0820	8.2090	14.6950	8.2149	14.2700
+7555	2004.8470	310	1.2252	0.6449	0.9034	1.0820	8.2090	14.6950	8.2165	14.2694
+7556	2004.8497	311	1.2252	0.6449	0.9034	1.0820	8.2090	14.6950	8.2180	14.2688
+7557	2004.8525	312	1.2252	0.6449	0.9034	1.0820	8.2090	14.6950	8.2195	14.2682
+7558	2004.8552	313	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2209	14.2677
+7559	2004.8579	314	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2222	14.2671
+7560	2004.8607	315	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2235	14.2667
+7561	2004.8634	316	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2247	14.2662
+7562	2004.8661	317	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2259	14.2658
+7563	2004.8689	318	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2269	14.2654
+7564	2004.8716	319	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2279	14.2650
+7565	2004.8743	320	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2289	14.2647
+7566	2004.8770	321	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2298	14.2644
+7567	2004.8798	322	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2306	14.2641
+7568	2004.8825	323	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2313	14.2639
+7569	2004.8852	324	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2319	14.2637
+7570	2004.8880	325	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2325	14.2635
+7571	2004.8907	326	1.2251	0.6449	0.9034	1.0820	8.2090	14.6950	8.2330	14.2634
+7572	2004.8934	327	1.2251	0.6448	0.9034	1.0820	8.2090	14.6950	8.2335	14.2633
+7573	2004.8962	328	1.2251	0.6448	0.9034	1.0820	8.2090	14.6950	8.2338	14.2632
+7574	2004.8989	329	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2341	14.2632
+7575	2004.9016	330	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2344	14.2632
+7576	2004.9044	331	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2345	14.2632
+7577	2004.9071	332	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2346	14.2632
+7578	2004.9098	333	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2346	14.2633
+7579	2004.9126	334	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2345	14.2634
+7580	2004.9153	335	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2344	14.2636
+7581	2004.9180	336	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2342	14.2637
+7582	2004.9208	337	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2339	14.2640
+7583	2004.9235	338	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2335	14.2642
+7584	2004.9262	339	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2331	14.2645
+7585	2004.9290	340	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2326	14.2647
+7586	2004.9317	341	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2320	14.2651
+7587	2004.9344	342	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2314	14.2654
+7588	2004.9372	343	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2307	14.2658
+7589	2004.9399	344	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2299	14.2662
+7590	2004.9426	345	1.2250	0.6448	0.9034	1.0820	8.2090	14.6950	8.2290	14.2667
+7591	2004.9454	346	1.2249	0.6448	0.9034	1.0820	8.2090	14.6950	8.2281	14.2671
+7592	2004.9481	347	1.2249	0.6448	0.9034	1.0820	8.2090	14.6950	8.2271	14.2676
+7593	2004.9508	348	1.2249	0.6448	0.9034	1.0820	8.2090	14.6950	8.2260	14.2682
+7594	2004.9536	349	1.2249	0.6448	0.9034	1.0820	8.2090	14.6950	8.2249	14.2687
+7595	2004.9563	350	1.2249	0.6448	0.9034	1.0820	8.2090	14.6950	8.2237	14.2693
+7596	2004.9590	351	1.2249	0.6447	0.9034	1.0820	8.2090	14.6950	8.2224	14.2699
+7597	2004.9617	352	1.2249	0.6447	0.9034	1.0820	8.2090	14.6950	8.2210	14.2706
+7598	2004.9645	353	1.2249	0.6447	0.9034	1.0820	8.2090	14.6950	8.2196	14.2712
+7599	2004.9672	354	1.2249	0.6447	0.9034	1.0820	8.2090	14.6950	8.2182	14.2719
+7600	2004.9699	355	1.2249	0.6447	0.9034	1.0820	8.2090	14.6950	8.2166	14.2727
+7601	2004.9727	356	1.2249	0.6447	0.9034	1.0820	8.2090	14.6950	8.2150	14.2734
+7602	2004.9754	357	1.2249	0.6447	0.9034	1.0820	8.2090	14.6950	8.2134	14.2742
+7603	2004.9781	358	1.2249	0.6447	0.9034	1.0820	8.2090	14.6950	8.2116	14.2750
+7604	2004.9809	359	1.2249	0.6447	0.9034	1.0820	8.2090	14.6950	8.2099	14.2758
+7605	2004.9836	360	1.2249	0.6447	0.9034	1.0820	8.2090	14.6950	8.2080	14.2767
+7606	2004.9863	361	1.2249	0.6447	0.9034	1.0820	8.2090	14.6950	8.2061	14.2776
+7607	2004.9891	362	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.2041	14.2785
+7608	2004.9918	363	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.2021	14.2794
+7609	2004.9945	364	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.2000	14.2804
+7610	2004.9973	365	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.1979	14.2814
+7611	2004.9999	366	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.1957	14.2824
+7612	2005.0027	1	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.1934	14.2834
+7613	2005.0055	2	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.1911	14.2845
+7614	2005.0082	3	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.1888	14.2856
+7615	2005.0110	4	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.1864	14.2867
+7616	2005.0137	5	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.1839	14.2878
+7617	2005.0164	6	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.1814	14.2890
+7618	2005.0192	7	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.1789	14.2902
+7619	2005.0219	8	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.1763	14.2914
+7620	2005.0247	9	1.2248	0.6447	0.9034	1.0820	8.2090	14.6950	8.1736	14.2926
+7621	2005.0274	10	1.2248	0.6446	0.9034	1.0820	8.2090	14.6950	8.1710	14.2938
+7622	2005.0301	11	1.2248	0.6446	0.9034	1.0820	8.2090	14.6950	8.1682	14.2951
+7623	2005.0329	12	1.2248	0.6446	0.9034	1.0820	8.2090	14.6950	8.1655	14.2964
+7624	2005.0356	13	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1627	14.2977
+7625	2005.0384	14	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1598	14.2990
+7626	2005.0411	15	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1569	14.3004
+7627	2005.0438	16	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1540	14.3017
+7628	2005.0466	17	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1511	14.3031
+7629	2005.0493	18	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1481	14.3045
+7630	2005.0521	19	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1451	14.3060
+7631	2005.0548	20	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1420	14.3074
+7632	2005.0575	21	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1390	14.3089
+7633	2005.0603	22	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1359	14.3104
+7634	2005.0630	23	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1328	14.3119
+7635	2005.0658	24	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1296	14.3134
+7636	2005.0685	25	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1264	14.3149
+7637	2005.0712	26	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1233	14.3165
+7638	2005.0740	27	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1200	14.3181
+7639	2005.0767	28	1.2247	0.6446	0.9034	1.0820	8.2090	14.6950	8.1168	14.3196
+7640	2005.0795	29	1.2246	0.6446	0.9034	1.0820	8.2090	14.6950	8.1136	14.3212
+7641	2005.0822	30	1.2246	0.6446	0.9034	1.0820	8.2090	14.6950	8.1103	14.3229
+7642	2005.0849	31	1.2246	0.6446	0.9034	1.0820	8.2090	14.6950	8.1070	14.3245
+7643	2005.0877	32	1.2246	0.6446	0.9034	1.0820	8.2090	14.6950	8.1038	14.3261
+7644	2005.0904	33	1.2246	0.6446	0.9034	1.0820	8.2090	14.6950	8.1005	14.3278
+7645	2005.0932	34	1.2246	0.6446	0.9034	1.0820	8.2090	14.6950	8.0971	14.3295
+7646	2005.0959	35	1.2246	0.6445	0.9034	1.0820	8.2090	14.6950	8.0938	14.3312
+7647	2005.0986	36	1.2246	0.6445	0.9034	1.0820	8.2090	14.6950	8.0905	14.3329
+7648	2005.1014	37	1.2246	0.6445	0.9034	1.0820	8.2090	14.6950	8.0872	14.3346
+7649	2005.1041	38	1.2246	0.6445	0.9034	1.0820	8.2090	14.6950	8.0839	14.3363
+7650	2005.1068	39	1.2246	0.6445	0.9034	1.0820	8.2090	14.6950	8.0805	14.3380
+7651	2005.1096	40	1.2246	0.6445	0.9034	1.0820	8.2090	14.6950	8.0772	14.3398
+7652	2005.1123	41	1.2246	0.6445	0.9034	1.0820	8.2090	14.6950	8.0739	14.3415
+7653	2005.1151	42	1.2246	0.6445	0.9034	1.0820	8.2090	14.6950	8.0705	14.3433
+7654	2005.1178	43	1.2246	0.6445	0.9034	1.0820	8.2090	14.6950	8.0672	14.3451
+7655	2005.1205	44	1.2246	0.6445	0.9034	1.0820	8.2090	14.6950	8.0639	14.3469
+7656	2005.1233	45	1.2246	0.6445	0.9034	1.0820	8.2090	14.6950	8.0606	14.3487
+7657	2005.1260	46	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0573	14.3505
+7658	2005.1288	47	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0540	14.3523
+7659	2005.1315	48	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0507	14.3541
+7660	2005.1342	49	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0474	14.3559
+7661	2005.1370	50	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0442	14.3578
+7662	2005.1397	51	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0409	14.3596
+7663	2005.1425	52	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0377	14.3615
+7664	2005.1452	53	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0345	14.3633
+7665	2005.1479	54	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0313	14.3652
+7666	2005.1507	55	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0281	14.3671
+7667	2005.1534	56	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0250	14.3689
+7668	2005.1562	57	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0219	14.3708
+7669	2005.1589	58	1.2245	0.6445	0.9034	1.0820	8.2090	14.6950	8.0188	14.3727
+7670	2005.1616	59	1.2245	0.6444	0.9034	1.0820	8.2090	14.6950	8.0157	14.3746
+7671	2005.1644	60	1.2245	0.6444	0.9034	1.0820	8.2090	14.6950	8.0127	14.3765
+7672	2005.1671	61	1.2245	0.6444	0.9034	1.0820	8.2090	14.6950	8.0096	14.3783
+7673	2005.1699	62	1.2245	0.6444	0.9034	1.0820	8.2090	14.6950	8.0066	14.3802
+7674	2005.1726	63	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	8.0037	14.3821
+7675	2005.1753	64	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	8.0008	14.3840
+7676	2005.1781	65	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9979	14.3859
+7677	2005.1808	66	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9950	14.3878
+7678	2005.1836	67	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9922	14.3897
+7679	2005.1863	68	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9894	14.3916
+7680	2005.1890	69	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9867	14.3935
+7681	2005.1918	70	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9840	14.3954
+7682	2005.1945	71	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9813	14.3973
+7683	2005.1973	72	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9787	14.3992
+7684	2005.2000	73	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9761	14.4011
+7685	2005.2027	74	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9735	14.4030
+7686	2005.2055	75	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9710	14.4048
+7687	2005.2082	76	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9686	14.4067
+7688	2005.2110	77	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9662	14.4086
+7689	2005.2137	78	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9638	14.4105
+7690	2005.2164	79	1.2244	0.6444	0.9034	1.0820	8.2090	14.6950	7.9615	14.4123
+7691	2005.2192	80	1.2243	0.6444	0.9034	1.0820	8.2090	14.6950	7.9593	14.4142
+7692	2005.2219	81	1.2243	0.6444	0.9034	1.0820	8.2090	14.6950	7.9570	14.4160
+7693	2005.2247	82	1.2243	0.6444	0.9034	1.0820	8.2090	14.6950	7.9549	14.4179
+7694	2005.2274	83	1.2243	0.6444	0.9034	1.0820	8.2090	14.6950	7.9528	14.4197
+7695	2005.2301	84	1.2243	0.6444	0.9034	1.0820	8.2090	14.6950	7.9507	14.4216
+7696	2005.2329	85	1.2243	0.6443	0.9034	1.0820	8.2090	14.6950	7.9487	14.4234
+7697	2005.2356	86	1.2243	0.6443	0.9034	1.0820	8.2090	14.6950	7.9468	14.4252
+7698	2005.2384	87	1.2243	0.6443	0.9034	1.0820	8.2090	14.6950	7.9449	14.4270
+7699	2005.2411	88	1.2243	0.6443	0.9034	1.0820	8.2090	14.6950	7.9430	14.4288
+7700	2005.2438	89	1.2243	0.6443	0.9034	1.0820	8.2090	14.6950	7.9412	14.4306
+7701	2005.2466	90	1.2243	0.6443	0.9034	1.0820	8.2090	14.6950	7.9395	14.4324
+7702	2005.2493	91	1.2243	0.6443	0.9034	1.0820	8.2090	14.6950	7.9378	14.4342
+7703	2005.2521	92	1.2243	0.6443	0.9034	1.0820	8.2090	14.6950	7.9362	14.4359
+7704	2005.2548	93	1.2243	0.6443	0.9034	1.0820	8.2090	14.6950	7.9347	14.4377
+7705	2005.2575	94	1.2243	0.6443	0.9034	1.0820	8.2090	14.6950	7.9332	14.4394
+7706	2005.2603	95	1.2243	0.6443	0.9034	1.0820	8.2090	14.6950	7.9317	14.4411
+7707	2005.2630	96	1.2243	0.6443	0.9034	1.0820	8.2090	14.6950	7.9303	14.4428
+7708	2005.2658	97	1.2242	0.6443	0.9034	1.0820	8.2090	14.6950	7.9290	14.4445
+7709	2005.2685	98	1.2242	0.6443	0.9034	1.0820	8.2090	14.6950	7.9278	14.4462
+7710	2005.2712	99	1.2242	0.6443	0.9034	1.0820	8.2090	14.6950	7.9266	14.4479
+7711	2005.2740	100	1.2242	0.6443	0.9034	1.0820	8.2090	14.6950	7.9254	14.4496
+7712	2005.2767	101	1.2242	0.6443	0.9034	1.0820	8.2090	14.6950	7.9244	14.4512
+7713	2005.2795	102	1.2242	0.6443	0.9033	1.0820	8.2090	14.6950	7.9234	14.4529
+7714	2005.2822	103	1.2242	0.6443	0.9033	1.0820	8.2090	14.6950	7.9224	14.4545
+7715	2005.2849	104	1.2242	0.6443	0.9033	1.0820	8.2090	14.6950	7.9215	14.4561
+7716	2005.2877	105	1.2242	0.6443	0.9033	1.0820	8.2090	14.6950	7.9207	14.4577
+7717	2005.2904	106	1.2242	0.6443	0.9033	1.0820	8.2090	14.6950	7.9199	14.4592
+7718	2005.2932	107	1.2242	0.6443	0.9033	1.0820	8.2090	14.6950	7.9193	14.4608
+7719	2005.2959	108	1.2242	0.6443	0.9033	1.0820	8.2090	14.6950	7.9186	14.4623
+7720	2005.2986	109	1.2242	0.6443	0.9033	1.0820	8.2090	14.6950	7.9181	14.4639
+7721	2005.3014	110	1.2242	0.6442	0.9033	1.0820	8.2090	14.6950	7.9176	14.4654
+7722	2005.3041	111	1.2242	0.6442	0.9033	1.0820	8.2090	14.6950	7.9171	14.4669
+7723	2005.3068	112	1.2242	0.6442	0.9033	1.0820	8.2090	14.6950	7.9167	14.4683
+7724	2005.3096	113	1.2242	0.6442	0.9033	1.0820	8.2090	14.6950	7.9164	14.4698
+7725	2005.3123	114	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9162	14.4712
+7726	2005.3151	115	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9160	14.4726
+7727	2005.3178	116	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9159	14.4740
+7728	2005.3205	117	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9159	14.4754
+7729	2005.3233	118	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9159	14.4767
+7730	2005.3260	119	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9160	14.4781
+7731	2005.3288	120	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9161	14.4794
+7732	2005.3315	121	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9163	14.4807
+7733	2005.3342	122	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9166	14.4820
+7734	2005.3370	123	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9169	14.4832
+7735	2005.3397	124	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9173	14.4844
+7736	2005.3425	125	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9178	14.4856
+7737	2005.3452	126	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9183	14.4868
+7738	2005.3479	127	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9189	14.4880
+7739	2005.3507	128	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9196	14.4891
+7740	2005.3534	129	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9203	14.4902
+7741	2005.3562	130	1.2241	0.6442	0.9033	1.0820	8.2090	14.6950	7.9211	14.4913
+7742	2005.3589	131	1.2240	0.6442	0.9033	1.0820	8.2090	14.6950	7.9219	14.4924
+7743	2005.3616	132	1.2240	0.6442	0.9033	1.0820	8.2090	14.6950	7.9228	14.4934
+7744	2005.3644	133	1.2240	0.6442	0.9033	1.0820	8.2090	14.6950	7.9238	14.4945
+7745	2005.3671	134	1.2240	0.6442	0.9033	1.0820	8.2090	14.6950	7.9248	14.4955
+7746	2005.3699	135	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9259	14.4964
+7747	2005.3726	136	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9270	14.4974
+7748	2005.3753	137	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9283	14.4983
+7749	2005.3781	138	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9295	14.4992
+7750	2005.3808	139	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9308	14.5000
+7751	2005.3836	140	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9322	14.5009
+7752	2005.3863	141	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9336	14.5017
+7753	2005.3890	142	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9351	14.5025
+7754	2005.3918	143	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9367	14.5032
+7755	2005.3945	144	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9383	14.5040
+7756	2005.3973	145	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9399	14.5047
+7757	2005.4000	146	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9417	14.5054
+7758	2005.4027	147	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9434	14.5060
+7759	2005.4055	148	1.2240	0.6441	0.9033	1.0820	8.2090	14.6950	7.9452	14.5066
+7760	2005.4082	149	1.2239	0.6441	0.9033	1.0820	8.2090	14.6950	7.9471	14.5072
+7761	2005.4110	150	1.2239	0.6441	0.9033	1.0820	8.2090	14.6950	7.9490	14.5078
+7762	2005.4137	151	1.2239	0.6441	0.9033	1.0820	8.2090	14.6950	7.9510	14.5083
+7763	2005.4164	152	1.2239	0.6441	0.9033	1.0820	8.2090	14.6950	7.9530	14.5088
+7764	2005.4192	153	1.2239	0.6441	0.9033	1.0820	8.2090	14.6950	7.9550	14.5093
+7765	2005.4219	154	1.2239	0.6441	0.9033	1.0820	8.2090	14.6950	7.9572	14.5098
+7766	2005.4247	155	1.2239	0.6441	0.9033	1.0820	8.2090	14.6950	7.9593	14.5102
+7767	2005.4274	156	1.2239	0.6441	0.9033	1.0820	8.2090	14.6950	7.9615	14.5106
+7768	2005.4301	157	1.2239	0.6441	0.9033	1.0820	8.2090	14.6950	7.9637	14.5109
+7769	2005.4329	158	1.2239	0.6441	0.9033	1.0820	8.2090	14.6950	7.9660	14.5113
+7770	2005.4356	159	1.2239	0.6441	0.9033	1.0820	8.2090	14.6950	7.9684	14.5116
+7771	2005.4384	160	1.2239	0.6441	0.9033	1.0820	8.2090	14.6950	7.9707	14.5119
+7772	2005.4411	161	1.2239	0.6440	0.9033	1.0820	8.2090	14.6950	7.9731	14.5121
+7773	2005.4438	162	1.2239	0.6440	0.9033	1.0820	8.2090	14.6950	7.9756	14.5123
+7774	2005.4466	163	1.2239	0.6440	0.9033	1.0820	8.2090	14.6950	7.9781	14.5125
+7775	2005.4493	164	1.2239	0.6440	0.9033	1.0820	8.2090	14.6950	7.9806	14.5127
+7776	2005.4521	165	1.2239	0.6440	0.9033	1.0820	8.2090	14.6950	7.9832	14.5128
+7777	2005.4548	166	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	7.9857	14.5129
+7778	2005.4575	167	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	7.9884	14.5130
+7779	2005.4603	168	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	7.9910	14.5130
+7780	2005.4630	169	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	7.9937	14.5130
+7781	2005.4658	170	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	7.9964	14.5130
+7782	2005.4685	171	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	7.9992	14.5129
+7783	2005.4712	172	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	8.0020	14.5128
+7784	2005.4740	173	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	8.0048	14.5127
+7785	2005.4767	174	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	8.0076	14.5126
+7786	2005.4795	175	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	8.0105	14.5124
+7787	2005.4822	176	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	8.0133	14.5122
+7788	2005.4849	177	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	8.0162	14.5119
+7789	2005.4877	178	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	8.0192	14.5117
+7790	2005.4904	179	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	8.0221	14.5114
+7791	2005.4932	180	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	8.0250	14.5110
+7792	2005.4959	181	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	8.0280	14.5107
+7793	2005.4986	182	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	8.0310	14.5103
+7794	2005.5014	183	1.2238	0.6440	0.9033	1.0820	8.2090	14.6950	8.0340	14.5098
+7795	2005.5041	184	1.2237	0.6440	0.9033	1.0820	8.2090	14.6950	8.0370	14.5094
+7796	2005.5068	185	1.2237	0.6440	0.9033	1.0820	8.2090	14.6950	8.0400	14.5089
+7797	2005.5096	186	1.2237	0.6440	0.9033	1.0820	8.2090	14.6950	8.0431	14.5084
+7798	2005.5123	187	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0461	14.5078
+7799	2005.5151	188	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0492	14.5073
+7800	2005.5178	189	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0522	14.5067
+7801	2005.5205	190	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0553	14.5060
+7802	2005.5233	191	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0583	14.5053
+7803	2005.5260	192	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0614	14.5046
+7804	2005.5288	193	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0645	14.5039
+7805	2005.5315	194	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0675	14.5032
+7806	2005.5342	195	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0706	14.5024
+7807	2005.5370	196	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0737	14.5015
+7808	2005.5397	197	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0767	14.5007
+7809	2005.5425	198	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0798	14.4998
+7810	2005.5452	199	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0828	14.4989
+7811	2005.5479	200	1.2237	0.6439	0.9033	1.0820	8.2090	14.6950	8.0858	14.4980
+7812	2005.5507	201	1.2236	0.6439	0.9033	1.0820	8.2090	14.6950	8.0888	14.4970
+7813	2005.5534	202	1.2236	0.6439	0.9033	1.0820	8.2090	14.6950	8.0919	14.4960
+7814	2005.5562	203	1.2236	0.6439	0.9033	1.0820	8.2090	14.6950	8.0948	14.4950
+7815	2005.5589	204	1.2236	0.6439	0.9033	1.0820	8.2090	14.6950	8.0978	14.4939
+7816	2005.5616	205	1.2236	0.6439	0.9033	1.0820	8.2090	14.6950	8.1008	14.4928
+7817	2005.5644	206	1.2236	0.6439	0.9033	1.0820	8.2090	14.6950	8.1037	14.4917
+7818	2005.5671	207	1.2236	0.6439	0.9033	1.0820	8.2090	14.6950	8.1067	14.4906
+7819	2005.5699	208	1.2236	0.6439	0.9033	1.0820	8.2090	14.6950	8.1096	14.4894
+7820	2005.5726	209	1.2236	0.6439	0.9033	1.0820	8.2090	14.6950	8.1124	14.4882
+7821	2005.5753	210	1.2236	0.6439	0.9033	1.0820	8.2090	14.6950	8.1153	14.4870
+7822	2005.5781	211	1.2236	0.6439	0.9033	1.0820	8.2090	14.6950	8.1181	14.4857
+7823	2005.5808	212	1.2236	0.6439	0.9033	1.0820	8.2090	14.6950	8.1210	14.4845
+7824	2005.5836	213	1.2236	0.6438	0.9033	1.0820	8.2090	14.6950	8.1237	14.4831
+7825	2005.5863	214	1.2236	0.6438	0.9033	1.0820	8.2090	14.6950	8.1265	14.4818
+7826	2005.5890	215	1.2236	0.6438	0.9033	1.0820	8.2090	14.6950	8.1292	14.4804
+7827	2005.5918	216	1.2236	0.6438	0.9033	1.0820	8.2090	14.6950	8.1319	14.4791
+7828	2005.5945	217	1.2236	0.6438	0.9033	1.0820	8.2090	14.6950	8.1346	14.4776
+7829	2005.5973	218	1.2236	0.6438	0.9033	1.0820	8.2090	14.6950	8.1372	14.4762
+7830	2005.6000	219	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1398	14.4747
+7831	2005.6027	220	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1424	14.4732
+7832	2005.6055	221	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1449	14.4717
+7833	2005.6082	222	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1474	14.4702
+7834	2005.6110	223	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1498	14.4686
+7835	2005.6137	224	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1522	14.4670
+7836	2005.6164	225	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1546	14.4654
+7837	2005.6192	226	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1569	14.4637
+7838	2005.6219	227	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1592	14.4620
+7839	2005.6247	228	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1614	14.4604
+7840	2005.6274	229	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1636	14.4586
+7841	2005.6301	230	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1658	14.4569
+7842	2005.6329	231	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1679	14.4551
+7843	2005.6356	232	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1699	14.4533
+7844	2005.6384	233	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1719	14.4515
+7845	2005.6411	234	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1738	14.4497
+7846	2005.6438	235	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1757	14.4478
+7847	2005.6466	236	1.2235	0.6438	0.9033	1.0820	8.2090	14.6950	8.1776	14.4460
+7848	2005.6493	237	1.2234	0.6438	0.9033	1.0820	8.2090	14.6950	8.1794	14.4441
+7849	2005.6521	238	1.2234	0.6438	0.9033	1.0820	8.2090	14.6950	8.1811	14.4421
+7850	2005.6548	239	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1828	14.4402
+7851	2005.6575	240	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1844	14.4382
+7852	2005.6603	241	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1860	14.4362
+7853	2005.6630	242	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1875	14.4342
+7854	2005.6658	243	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1889	14.4322
+7855	2005.6685	244	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1903	14.4302
+7856	2005.6712	245	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1916	14.4281
+7857	2005.6740	246	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1929	14.4260
+7858	2005.6767	247	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1941	14.4239
+7859	2005.6795	248	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1953	14.4218
+7860	2005.6822	249	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1963	14.4197
+7861	2005.6849	250	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1974	14.4175
+7862	2005.6877	251	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1983	14.4154
+7863	2005.6904	252	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.1992	14.4132
+7864	2005.6932	253	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.2001	14.4110
+7865	2005.6959	254	1.2234	0.6437	0.9033	1.0820	8.2090	14.6950	8.2008	14.4087
+7866	2005.6986	255	1.2233	0.6437	0.9033	1.0820	8.2090	14.6950	8.2015	14.4065
+7867	2005.7014	256	1.2233	0.6437	0.9033	1.0820	8.2090	14.6950	8.2022	14.4043
+7868	2005.7041	257	1.2233	0.6437	0.9033	1.0820	8.2090	14.6950	8.2027	14.4020
+7869	2005.7068	258	1.2233	0.6437	0.9033	1.0820	8.2090	14.6950	8.2032	14.3997
+7870	2005.7096	259	1.2233	0.6437	0.9033	1.0820	8.2090	14.6950	8.2037	14.3974
+7871	2005.7123	260	1.2233	0.6437	0.9033	1.0820	8.2090	14.6950	8.2041	14.3951
+7872	2005.7151	261	1.2233	0.6437	0.9033	1.0820	8.2090	14.6950	8.2044	14.3928
+7873	2005.7178	262	1.2233	0.6437	0.9033	1.0820	8.2090	14.6950	8.2046	14.3905
+7874	2005.7205	263	1.2233	0.6437	0.9033	1.0820	8.2090	14.6950	8.2048	14.3881
+7875	2005.7233	264	1.2233	0.6437	0.9033	1.0820	8.2090	14.6950	8.2049	14.3857
+7876	2005.7260	265	1.2233	0.6437	0.9033	1.0820	8.2090	14.6950	8.2049	14.3834
+7877	2005.7288	266	1.2233	0.6436	0.9033	1.0820	8.2090	14.6950	8.2049	14.3810
+7878	2005.7315	267	1.2233	0.6436	0.9033	1.0820	8.2090	14.6950	8.2048	14.3786
+7879	2005.7342	268	1.2233	0.6436	0.9033	1.0820	8.2090	14.6950	8.2047	14.3762
+7880	2005.7370	269	1.2233	0.6436	0.9033	1.0820	8.2090	14.6950	8.2044	14.3738
+7881	2005.7397	270	1.2233	0.6436	0.9033	1.0820	8.2090	14.6950	8.2041	14.3713
+7882	2005.7425	271	1.2233	0.6436	0.9033	1.0820	8.2090	14.6950	8.2038	14.3689
+7883	2005.7452	272	1.2233	0.6436	0.9033	1.0820	8.2090	14.6950	8.2033	14.3665
+7884	2005.7479	273	1.2233	0.6436	0.9033	1.0820	8.2090	14.6950	8.2028	14.3640
+7885	2005.7507	274	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.2023	14.3615
+7886	2005.7534	275	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.2017	14.3591
+7887	2005.7562	276	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.2010	14.3566
+7888	2005.7589	277	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.2002	14.3541
+7889	2005.7616	278	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1994	14.3516
+7890	2005.7644	279	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1985	14.3491
+7891	2005.7671	280	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1976	14.3466
+7892	2005.7699	281	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1965	14.3441
+7893	2005.7726	282	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1955	14.3416
+7894	2005.7753	283	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1943	14.3390
+7895	2005.7781	284	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1931	14.3365
+7896	2005.7808	285	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1919	14.3340
+7897	2005.7836	286	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1905	14.3314
+7898	2005.7863	287	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1892	14.3289
+7899	2005.7890	288	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1877	14.3263
+7900	2005.7918	289	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1862	14.3238
+7901	2005.7945	290	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1847	14.3212
+7902	2005.7973	291	1.2232	0.6436	0.9033	1.0820	8.2090	14.6950	8.1830	14.3187
+7903	2005.8000	292	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1814	14.3161
+7904	2005.8027	293	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1796	14.3136
+7905	2005.8055	294	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1778	14.3110
+7906	2005.8082	295	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1760	14.3084
+7907	2005.8110	296	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1741	14.3059
+7908	2005.8137	297	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1721	14.3033
+7909	2005.8164	298	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1701	14.3008
+7910	2005.8192	299	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1681	14.2982
+7911	2005.8219	300	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1660	14.2956
+7912	2005.8247	301	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1638	14.2931
+7913	2005.8274	302	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1616	14.2905
+7914	2005.8301	303	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1594	14.2880
+7915	2005.8329	304	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1571	14.2854
+7916	2005.8356	305	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1547	14.2829
+7917	2005.8384	306	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1523	14.2804
+7918	2005.8411	307	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1499	14.2778
+7919	2005.8438	308	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1474	14.2753
+7920	2005.8466	309	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1449	14.2728
+7921	2005.8493	310	1.2231	0.6435	0.9033	1.0820	8.2090	14.6950	8.1424	14.2702
+7922	2005.8521	311	1.2230	0.6435	0.9033	1.0820	8.2090	14.6950	8.1398	14.2677
+7923	2005.8548	312	1.2230	0.6435	0.9033	1.0820	8.2090	14.6950	8.1372	14.2652
+7924	2005.8575	313	1.2230	0.6435	0.9033	1.0820	8.2090	14.6950	8.1345	14.2627
+7925	2005.8603	314	1.2230	0.6435	0.9033	1.0820	8.2090	14.6950	8.1318	14.2602
+7926	2005.8630	315	1.2230	0.6435	0.9033	1.0820	8.2090	14.6950	8.1291	14.2577
+7927	2005.8658	316	1.2230	0.6435	0.9033	1.0820	8.2090	14.6950	8.1263	14.2552
+7928	2005.8685	317	1.2230	0.6435	0.9033	1.0820	8.2090	14.6950	8.1235	14.2528
+7929	2005.8712	318	1.2230	0.6435	0.9033	1.0820	8.2090	14.6950	8.1207	14.2503
+7930	2005.8740	319	1.2230	0.6434	0.9033	1.0820	8.2090	14.6950	8.1178	14.2478
+7931	2005.8767	320	1.2230	0.6434	0.9033	1.0820	8.2090	14.6950	8.1149	14.2454
+7932	2005.8795	321	1.2230	0.6434	0.9033	1.0820	8.2090	14.6950	8.1120	14.2429
+7933	2005.8822	322	1.2230	0.6434	0.9033	1.0820	8.2090	14.6950	8.1091	14.2405
+7934	2005.8849	323	1.2230	0.6434	0.9033	1.0820	8.2090	14.6950	8.1061	14.2381
+7935	2005.8877	324	1.2230	0.6434	0.9033	1.0820	8.2090	14.6950	8.1031	14.2357
+7936	2005.8904	325	1.2230	0.6434	0.9033	1.0820	8.2090	14.6950	8.1001	14.2333
+7937	2005.8932	326	1.2230	0.6434	0.9033	1.0820	8.2090	14.6950	8.0971	14.2309
+7938	2005.8959	327	1.2230	0.6434	0.9033	1.0820	8.2090	14.6950	8.0940	14.2285
+7939	2005.8986	328	1.2230	0.6434	0.9033	1.0820	8.2090	14.6950	8.0909	14.2261
+7940	2005.9014	329	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0879	14.2238
+7941	2005.9041	330	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0848	14.2214
+7942	2005.9068	331	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0816	14.2191
+7943	2005.9096	332	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0785	14.2168
+7944	2005.9123	333	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0754	14.2145
+7945	2005.9151	334	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0722	14.2122
+7946	2005.9178	335	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0691	14.2099
+7947	2005.9205	336	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0659	14.2076
+7948	2005.9233	337	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0627	14.2054
+7949	2005.9260	338	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0596	14.2031
+7950	2005.9288	339	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0564	14.2009
+7951	2005.9315	340	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0532	14.1987
+7952	2005.9342	341	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0500	14.1965
+7953	2005.9370	342	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0468	14.1943
+7954	2005.9397	343	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0437	14.1922
+7955	2005.9425	344	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0405	14.1900
+7956	2005.9452	345	1.2229	0.6434	0.9033	1.0820	8.2090	14.6950	8.0373	14.1879
+7957	2005.9479	346	1.2229	0.6433	0.9033	1.0820	8.2090	14.6950	8.0341	14.1858
+7958	2005.9507	347	1.2229	0.6433	0.9033	1.0820	8.2090	14.6950	8.0310	14.1837
+7959	2005.9534	348	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	8.0278	14.1816
+7960	2005.9562	349	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	8.0247	14.1796
+7961	2005.9589	350	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	8.0215	14.1776
+7962	2005.9616	351	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	8.0184	14.1755
+7963	2005.9644	352	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	8.0153	14.1735
+7964	2005.9671	353	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	8.0122	14.1716
+7965	2005.9699	354	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	8.0091	14.1696
+7966	2005.9726	355	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	8.0061	14.1676
+7967	2005.9753	356	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	8.0030	14.1657
+7968	2005.9781	357	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	8.0000	14.1638
+7969	2005.9808	358	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	7.9970	14.1619
+7970	2005.9836	359	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	7.9940	14.1601
+7971	2005.9863	360	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	7.9910	14.1582
+7972	2005.9890	361	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	7.9881	14.1564
+7973	2005.9918	362	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	7.9852	14.1546
+7974	2005.9945	363	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	7.9823	14.1528
+7975	2005.9973	364	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	7.9794	14.1511
+7976	2005.9999	365	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	7.9766	14.1494
+7977	2006.0027	1	1.2228	0.6433	0.9033	1.0820	8.2090	14.6950	7.9738	14.1476
+7978	2006.0055	2	1.2227	0.6433	0.9033	1.0820	8.2090	14.6950	7.9710	14.1460
+7979	2006.0082	3	1.2227	0.6433	0.9033	1.0820	8.2090	14.6950	7.9683	14.1443
+7980	2006.0110	4	1.2227	0.6433	0.9033	1.0820	8.2090	14.6950	7.9656	14.1426
+7981	2006.0137	5	1.2227	0.6433	0.9033	1.0820	8.2090	14.6950	7.9629	14.1410
+7982	2006.0164	6	1.2227	0.6433	0.9033	1.0820	8.2090	14.6950	7.9603	14.1394
+7983	2006.0192	7	1.2227	0.6433	0.9033	1.0820	8.2090	14.6950	7.9576	14.1378
+7984	2006.0219	8	1.2227	0.6433	0.9033	1.0820	8.2090	14.6950	7.9551	14.1363
+7985	2006.0247	9	1.2227	0.6432	0.9033	1.0820	8.2090	14.6950	7.9525	14.1348
+7986	2006.0274	10	1.2227	0.6432	0.9033	1.0820	8.2090	14.6950	7.9500	14.1333
+7987	2006.0301	11	1.2227	0.6432	0.9033	1.0820	8.2090	14.6950	7.9476	14.1318
+7988	2006.0329	12	1.2227	0.6432	0.9033	1.0820	8.2090	14.6950	7.9452	14.1303
+7989	2006.0356	13	1.2227	0.6432	0.9033	1.0820	8.2090	14.6950	7.9428	14.1289
+7990	2006.0384	14	1.2227	0.6432	0.9033	1.0820	8.2090	14.6950	7.9405	14.1275
+7991	2006.0411	15	1.2227	0.6432	0.9033	1.0820	8.2090	14.6950	7.9382	14.1261
+7992	2006.0438	16	1.2227	0.6432	0.9033	1.0820	8.2090	14.6950	7.9359	14.1247
+7993	2006.0466	17	1.2227	0.6432	0.9033	1.0820	8.2090	14.6950	7.9337	14.1234
+7994	2006.0493	18	1.2227	0.6432	0.9033	1.0820	8.2090	14.6950	7.9315	14.1221
+7995	2006.0521	19	1.2227	0.6432	0.9033	1.0820	8.2090	14.6950	7.9294	14.1208
+7996	2006.0548	20	1.2227	0.6432	0.9033	1.0820	8.2090	14.6950	7.9274	14.1196
+7997	2006.0575	21	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9253	14.1183
+7998	2006.0603	22	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9234	14.1171
+7999	2006.0630	23	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9214	14.1159
+8000	2006.0658	24	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9196	14.1148
+8001	2006.0685	25	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9177	14.1136
+8002	2006.0712	26	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9160	14.1125
+8003	2006.0740	27	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9142	14.1115
+8004	2006.0767	28	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9126	14.1104
+8005	2006.0795	29	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9109	14.1094
+8006	2006.0822	30	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9094	14.1084
+8007	2006.0849	31	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9079	14.1074
+8008	2006.0877	32	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9064	14.1065
+8009	2006.0904	33	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9050	14.1056
+8010	2006.0932	34	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9036	14.1047
+8011	2006.0959	35	1.2226	0.6432	0.9033	1.0820	8.2090	14.6950	7.9023	14.1038
+8012	2006.0986	36	1.2226	0.6431	0.9033	1.0820	8.2090	14.6950	7.9011	14.1030
+8013	2006.1014	37	1.2226	0.6431	0.9033	1.0820	8.2090	14.6950	7.8999	14.1022
+8014	2006.1041	38	1.2226	0.6431	0.9033	1.0820	8.2090	14.6950	7.8988	14.1014
+8015	2006.1068	39	1.2226	0.6431	0.9033	1.0820	8.2090	14.6950	7.8977	14.1006
+8016	2006.1096	40	1.2225	0.6431	0.9033	1.0820	8.2090	14.6950	7.8967	14.0999
+8017	2006.1123	41	1.2225	0.6431	0.9033	1.0820	8.2090	14.6950	7.8957	14.0992
+8018	2006.1151	42	1.2225	0.6431	0.9033	1.0820	8.2090	14.6950	7.8948	14.0985
+8019	2006.1178	43	1.2225	0.6431	0.9033	1.0820	8.2090	14.6950	7.8940	14.0979
+8020	2006.1205	44	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8932	14.0972
+8021	2006.1233	45	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8925	14.0966
+8022	2006.1260	46	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8918	14.0961
+8023	2006.1288	47	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8912	14.0955
+8024	2006.1315	48	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8907	14.0950
+8025	2006.1342	49	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8902	14.0945
+8026	2006.1370	50	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8897	14.0941
+8027	2006.1397	51	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8894	14.0937
+8028	2006.1425	52	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8891	14.0932
+8029	2006.1452	53	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8888	14.0929
+8030	2006.1479	54	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8886	14.0925
+8031	2006.1507	55	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8885	14.0922
+8032	2006.1534	56	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8884	14.0919
+8033	2006.1562	57	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8884	14.0916
+8034	2006.1589	58	1.2225	0.6431	0.9032	1.0820	8.2090	14.6950	7.8884	14.0914
+8035	2006.1616	59	1.2224	0.6431	0.9032	1.0820	8.2090	14.6950	7.8885	14.0912
+8036	2006.1644	60	1.2224	0.6431	0.9032	1.0820	8.2090	14.6950	7.8887	14.0910
+8037	2006.1671	61	1.2224	0.6431	0.9032	1.0820	8.2090	14.6950	7.8889	14.0909
+8038	2006.1699	62	1.2224	0.6431	0.9032	1.0820	8.2090	14.6950	7.8892	14.0907
+8039	2006.1726	63	1.2224	0.6431	0.9032	1.0820	8.2090	14.6950	7.8896	14.0906
+8040	2006.1753	64	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	7.8900	14.0905
+8041	2006.1781	65	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	7.8904	14.0905
+8042	2006.1808	66	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	7.8909	14.0905
+8043	2006.1836	67	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	7.8915	14.0905
+8044	2006.1863	68	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	7.8921	14.0905
+8045	2006.1890	69	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	7.8928	14.0906
+8046	2006.1918	70	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	7.8936	14.0907
+8047	2006.1945	71	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	7.8944	14.0908
+8048	2006.1973	72	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	7.8952	14.0909
+8049	2006.2000	73	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	7.8961	14.0911
+8050	2006.2027	74	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	7.8971	14.0913
+8051	2006.2055	75	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	8.2090	14.6950
+8052	2006.2082	76	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	8.2065	14.6950
+8053	2006.2110	77	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	8.2040	14.6949
+8054	2006.2137	78	1.2224	0.6430	0.9032	1.0820	8.2090	14.6950	8.2015	14.6948
+8055	2006.2164	79	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1989	14.6947
+8056	2006.2192	80	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1963	14.6945
+8057	2006.2219	81	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1937	14.6944
+8058	2006.2247	82	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1910	14.6941
+8059	2006.2274	83	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1883	14.6939
+8060	2006.2301	84	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1855	14.6936
+8061	2006.2329	85	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1827	14.6933
+8062	2006.2356	86	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1799	14.6930
+8063	2006.2384	87	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1771	14.6927
+8064	2006.2411	88	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1742	14.6923
+8065	2006.2438	89	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1713	14.6919
+8066	2006.2466	90	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1684	14.6914
+8067	2006.2493	91	1.2223	0.6430	0.9032	1.0820	8.2090	14.6950	8.1654	14.6909
+8068	2006.2521	92	1.2223	0.6429	0.9032	1.0820	8.2090	14.6950	8.1625	14.6904
+8069	2006.2548	93	1.2223	0.6429	0.9032	1.0820	8.2090	14.6950	8.1595	14.6899
+8070	2006.2575	94	1.2223	0.6429	0.9032	1.0820	8.2090	14.6950	8.1565	14.6893
+8071	2006.2603	95	1.2223	0.6429	0.9032	1.0820	8.2090	14.6950	8.1534	14.6887
+8072	2006.2630	96	1.2223	0.6429	0.9032	1.0820	8.2090	14.6950	8.1504	14.6881
+8073	2006.2658	97	1.2223	0.6429	0.9032	1.0820	8.2090	14.6950	8.1473	14.6875
+8074	2006.2685	98	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1442	14.6868
+8075	2006.2712	99	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1411	14.6861
+8076	2006.2740	100	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1380	14.6854
+8077	2006.2767	101	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1349	14.6846
+8078	2006.2795	102	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1318	14.6838
+8079	2006.2822	103	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1286	14.6830
+8080	2006.2849	104	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1255	14.6821
+8081	2006.2877	105	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1223	14.6812
+8082	2006.2904	106	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1191	14.6803
+8083	2006.2932	107	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1160	14.6794
+8084	2006.2959	108	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1128	14.6784
+8085	2006.2986	109	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1096	14.6775
+8086	2006.3014	110	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1065	14.6764
+8087	2006.3041	111	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1033	14.6754
+8088	2006.3068	112	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.1001	14.6743
+8089	2006.3096	113	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.0969	14.6732
+8090	2006.3123	114	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.0938	14.6721
+8091	2006.3151	115	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.0906	14.6709
+8092	2006.3178	116	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.0875	14.6697
+8093	2006.3205	117	1.2222	0.6429	0.9032	1.0820	8.2090	14.6950	8.0843	14.6685
+8094	2006.3233	118	1.2221	0.6429	0.9032	1.0820	8.2090	14.6950	8.0812	14.6673
+8095	2006.3260	119	1.2221	0.6429	0.9032	1.0820	8.2090	14.6950	8.0781	14.6660
+8096	2006.3288	120	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0750	14.6647
+8097	2006.3315	121	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0719	14.6634
+8098	2006.3342	122	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0688	14.6621
+8099	2006.3370	123	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0657	14.6607
+8100	2006.3397	124	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0626	14.6593
+8101	2006.3425	125	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0596	14.6579
+8102	2006.3452	126	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0566	14.6565
+8103	2006.3479	127	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0536	14.6550
+8104	2006.3507	128	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0506	14.6535
+8105	2006.3534	129	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0477	14.6520
+8106	2006.3562	130	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0447	14.6505
+8107	2006.3589	131	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0418	14.6489
+8108	2006.3616	132	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0389	14.6473
+8109	2006.3644	133	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0361	14.6457
+8110	2006.3671	134	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0333	14.6441
+8111	2006.3699	135	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0305	14.6424
+8112	2006.3726	136	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0277	14.6407
+8113	2006.3753	137	1.2221	0.6428	0.9032	1.0820	8.2090	14.6950	8.0249	14.6390
+8114	2006.3781	138	1.2220	0.6428	0.9032	1.0820	8.2090	14.6950	8.0222	14.6373
+8115	2006.3808	139	1.2220	0.6428	0.9032	1.0820	8.2090	14.6950	8.0196	14.6355
+8116	2006.3836	140	1.2220	0.6428	0.9032	1.0820	8.2090	14.6950	8.0169	14.6338
+8117	2006.3863	141	1.2220	0.6428	0.9032	1.0820	8.2090	14.6950	8.0143	14.6320
+8118	2006.3890	142	1.2220	0.6428	0.9032	1.0820	8.2090	14.6950	8.0117	14.6302
+8119	2006.3918	143	1.2220	0.6428	0.9032	1.0820	8.2090	14.6950	8.0092	14.6283
+8120	2006.3945	144	1.2220	0.6428	0.9032	1.0820	8.2090	14.6950	8.0067	14.6265
+8121	2006.3973	145	1.2220	0.6428	0.9032	1.0820	8.2090	14.6950	8.0042	14.6246
+8122	2006.4000	146	1.2220	0.6428	0.9032	1.0820	8.2090	14.6950	8.0018	14.6227
+8123	2006.4027	147	1.2220	0.6428	0.9032	1.0820	8.2090	14.6950	7.9994	14.6208
+8124	2006.4055	148	1.2220	0.6427	0.9032	1.0820	8.2090	14.6950	7.9971	14.6189
+8125	2006.4082	149	1.2220	0.6427	0.9032	1.0820	8.2090	14.6950	7.9948	14.6169
+8126	2006.4110	150	1.2220	0.6427	0.9032	1.0820	8.2090	14.6950	7.9925	14.6149
+8127	2006.4137	151	1.2220	0.6427	0.9032	1.0820	8.2090	14.6950	7.9903	14.6129
+8128	2006.4164	152	1.2220	0.6427	0.9032	1.0820	8.2090	14.6950	7.9881	14.6109
+8129	2006.4192	153	1.2220	0.6427	0.9032	1.0820	8.2090	14.6950	7.9860	14.6089
+8130	2006.4219	154	1.2220	0.6427	0.9032	1.0820	8.2090	14.6950	7.9839	14.6068
+8131	2006.4247	155	1.2220	0.6427	0.9032	1.0820	8.2090	14.6950	7.9819	14.6048
+8132	2006.4274	156	1.2220	0.6427	0.9032	1.0820	8.2090	14.6950	7.9799	14.6027
+8133	2006.4301	157	1.2220	0.6427	0.9032	1.0820	8.2090	14.6950	7.9779	14.6006
+8134	2006.4329	158	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9760	14.5985
+8135	2006.4356	159	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9742	14.5963
+8136	2006.4384	160	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9724	14.5942
+8137	2006.4411	161	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9706	14.5920
+8138	2006.4438	162	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9689	14.5898
+8139	2006.4466	163	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9673	14.5876
+8140	2006.4493	164	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9657	14.5854
+8141	2006.4521	165	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9641	14.5832
+8142	2006.4548	166	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9627	14.5810
+8143	2006.4575	167	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9612	14.5787
+8144	2006.4603	168	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9598	14.5764
+8145	2006.4630	169	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9585	14.5741
+8146	2006.4658	170	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9572	14.5719
+8147	2006.4685	171	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9560	14.5695
+8148	2006.4712	172	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9548	14.5672
+8149	2006.4740	173	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9537	14.5649
+8150	2006.4767	174	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9527	14.5625
+8151	2006.4795	175	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9517	14.5602
+8152	2006.4822	176	1.2219	0.6427	0.9032	1.0820	8.2090	14.6950	7.9507	14.5578
+8153	2006.4849	177	1.2219	0.6426	0.9032	1.0820	8.2090	14.6950	7.9498	14.5555
+8154	2006.4877	178	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9490	14.5531
+8155	2006.4904	179	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9482	14.5507
+8156	2006.4932	180	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9475	14.5483
+8157	2006.4959	181	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9468	14.5459
+8158	2006.4986	182	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9462	14.5434
+8159	2006.5014	183	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9457	14.5410
+8160	2006.5041	184	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9452	14.5386
+8161	2006.5068	185	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9448	14.5361
+8162	2006.5096	186	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9444	14.5337
+8163	2006.5123	187	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9441	14.5312
+8164	2006.5151	188	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9439	14.5287
+8165	2006.5178	189	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9437	14.5263
+8166	2006.5205	190	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9435	14.5238
+8167	2006.5233	191	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9434	14.5213
+8168	2006.5260	192	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9434	14.5188
+8169	2006.5288	193	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9435	14.5163
+8170	2006.5315	194	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9436	14.5138
+8171	2006.5342	195	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9437	14.5113
+8172	2006.5370	196	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9439	14.5088
+8173	2006.5397	197	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9442	14.5063
+8174	2006.5425	198	1.2218	0.6426	0.9032	1.0820	8.2090	14.6950	7.9445	14.5038
+8175	2006.5452	199	1.2217	0.6426	0.9032	1.0820	8.2090	14.6950	7.9449	14.5012
+8176	2006.5479	200	1.2217	0.6426	0.9032	1.0820	8.2090	14.6950	7.9454	14.4987
+8177	2006.5507	201	1.2217	0.6426	0.9032	1.0820	8.2090	14.6950	7.9459	14.4962
+8178	2006.5534	202	1.2217	0.6426	0.9032	1.0820	8.2090	14.6950	7.9464	14.4937
+8179	2006.5562	203	1.2217	0.6426	0.9032	1.0820	8.2090	14.6950	7.9470	14.4911
+8180	2006.5589	204	1.2217	0.6426	0.9032	1.0820	8.2090	14.6950	7.9477	14.4886
+8181	2006.5616	205	1.2217	0.6426	0.9032	1.0820	8.2090	14.6950	7.9484	14.4861
+8182	2006.5644	206	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9492	14.4836
+8183	2006.5671	207	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9501	14.4810
+8184	2006.5699	208	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9510	14.4785
+8185	2006.5726	209	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9519	14.4760
+8186	2006.5753	210	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9529	14.4735
+8187	2006.5781	211	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9540	14.4709
+8188	2006.5808	212	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9551	14.4684
+8189	2006.5836	213	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9562	14.4659
+8190	2006.5863	214	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9575	14.4634
+8191	2006.5890	215	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9587	14.4609
+8192	2006.5918	216	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9600	14.4584
+8193	2006.5945	217	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9614	14.4558
+8194	2006.5973	218	1.2217	0.6425	0.9032	1.0820	8.2090	14.6950	7.9628	14.4533
+8195	2006.6000	219	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9643	14.4508
+8196	2006.6027	220	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9658	14.4484
+8197	2006.6055	221	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9674	14.4459
+8198	2006.6082	222	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9690	14.4434
+8199	2006.6110	223	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9707	14.4409
+8200	2006.6137	224	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9724	14.4384
+8201	2006.6164	225	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9742	14.4360
+8202	2006.6192	226	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9760	14.4335
+8203	2006.6219	227	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9778	14.4311
+8204	2006.6247	228	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9797	14.4286
+8205	2006.6274	229	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9816	14.4262
+8206	2006.6301	230	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9836	14.4237
+8207	2006.6329	231	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9856	14.4213
+8208	2006.6356	232	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9877	14.4189
+8209	2006.6384	233	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9898	14.4165
+8210	2006.6411	234	1.2216	0.6425	0.9032	1.0820	8.2090	14.6950	7.9920	14.4141
+8211	2006.6438	235	1.2216	0.6424	0.9032	1.0820	8.2090	14.6950	7.9941	14.4117
+8212	2006.6466	236	1.2216	0.6424	0.9032	1.0820	8.2090	14.6950	7.9964	14.4094
+8213	2006.6493	237	1.2216	0.6424	0.9032	1.0820	8.2090	14.6950	7.9986	14.4070
+8214	2006.6521	238	1.2216	0.6424	0.9032	1.0820	8.2090	14.6950	8.0009	14.4047
+8215	2006.6548	239	1.2216	0.6424	0.9032	1.0820	8.2090	14.6950	8.0032	14.4023
+8216	2006.6575	240	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0056	14.4000
+8217	2006.6603	241	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0080	14.3977
+8218	2006.6630	242	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0104	14.3954
+8219	2006.6658	243	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0129	14.3931
+8220	2006.6685	244	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0154	14.3908
+8221	2006.6712	245	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0179	14.3885
+8222	2006.6740	246	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0204	14.3863
+8223	2006.6767	247	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0230	14.3840
+8224	2006.6795	248	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0256	14.3818
+8225	2006.6822	249	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0283	14.3796
+8226	2006.6849	250	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0309	14.3774
+8227	2006.6877	251	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0336	14.3752
+8228	2006.6904	252	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0363	14.3730
+8229	2006.6932	253	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0390	14.3708
+8230	2006.6959	254	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0418	14.3687
+8231	2006.6986	255	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0445	14.3666
+8232	2006.7014	256	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0473	14.3645
+8233	2006.7041	257	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0501	14.3624
+8234	2006.7068	258	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0529	14.3603
+8235	2006.7096	259	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0557	14.3582
+8236	2006.7123	260	1.2215	0.6424	0.9032	1.0820	8.2090	14.6950	8.0586	14.3562
+8237	2006.7151	261	1.2214	0.6424	0.9032	1.0820	8.2090	14.6950	8.0614	14.3542
+8238	2006.7178	262	1.2214	0.6424	0.9032	1.0820	8.2090	14.6950	8.0643	14.3521
+8239	2006.7205	263	1.2214	0.6424	0.9032	1.0820	8.2090	14.6950	8.0672	14.3502
+8240	2006.7233	264	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.0701	14.3482
+8241	2006.7260	265	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.0730	14.3462
+8242	2006.7288	266	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.0759	14.3443
+8243	2006.7315	267	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.0788	14.3424
+8244	2006.7342	268	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.0817	14.3405
+8245	2006.7370	269	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.0846	14.3386
+8246	2006.7397	270	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.0875	14.3367
+8247	2006.7425	271	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.0904	14.3349
+8248	2006.7452	272	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.0934	14.3330
+8249	2006.7479	273	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.0963	14.3312
+8250	2006.7507	274	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.0992	14.3295
+8251	2006.7534	275	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.1021	14.3277
+8252	2006.7562	276	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.1050	14.3259
+8253	2006.7589	277	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.1079	14.3242
+8254	2006.7616	278	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.1108	14.3225
+8255	2006.7644	279	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.1137	14.3208
+8256	2006.7671	280	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.1166	14.3192
+8257	2006.7699	281	1.2214	0.6423	0.9032	1.0820	8.2090	14.6950	8.1195	14.3175
+8258	2006.7726	282	1.2213	0.6423	0.9032	1.0820	8.2090	14.6950	8.1223	14.3159
+8259	2006.7753	283	1.2213	0.6423	0.9032	1.0820	8.2090	14.6950	8.1252	14.3143
+8260	2006.7781	284	1.2213	0.6423	0.9032	1.0820	8.2090	14.6950	8.1280	14.3128
+8261	2006.7808	285	1.2213	0.6423	0.9032	1.0820	8.2090	14.6950	8.1308	14.3112
+8262	2006.7836	286	1.2213	0.6423	0.9032	1.0820	8.2090	14.6950	8.1336	14.3097
+8263	2006.7863	287	1.2213	0.6423	0.9032	1.0820	8.2090	14.6950	8.1364	14.3082
+8264	2006.7890	288	1.2213	0.6423	0.9032	1.0820	8.2090	14.6950	8.1392	14.3067
+8265	2006.7918	289	1.2213	0.6423	0.9032	1.0820	8.2090	14.6950	8.1419	14.3052
+8266	2006.7945	290	1.2213	0.6423	0.9032	1.0820	8.2090	14.6950	8.1446	14.3038
+8267	2006.7973	291	1.2213	0.6423	0.9032	1.0820	8.2090	14.6950	8.1473	14.3024
+8268	2006.8000	292	1.2213	0.6423	0.9032	1.0820	8.2090	14.6950	8.1500	14.3010
+8269	2006.8027	293	1.2213	0.6423	0.9032	1.0820	8.2090	14.6950	8.1527	14.2996
+8270	2006.8055	294	1.2213	0.6422	0.9032	1.0820	8.2090	14.6950	8.1553	14.2983
+8271	2006.8082	295	1.2213	0.6422	0.9032	1.0820	8.2090	14.6950	8.1579	14.2970
+8272	2006.8110	296	1.2213	0.6422	0.9032	1.0820	8.2090	14.6950	8.1605	14.2957
+8273	2006.8137	297	1.2213	0.6422	0.9032	1.0820	8.2090	14.6950	8.1630	14.2944
+8274	2006.8164	298	1.2213	0.6422	0.9032	1.0820	8.2090	14.6950	8.1655	14.2932
+8275	2006.8192	299	1.2213	0.6422	0.9032	1.0820	8.2090	14.6950	8.1680	14.2919
+8276	2006.8219	300	1.2213	0.6422	0.9032	1.0820	8.2090	14.6950	8.1705	14.2907
+8277	2006.8247	301	1.2213	0.6422	0.9032	1.0820	8.2090	14.6950	8.1729	14.2896
+8278	2006.8274	302	1.2213	0.6422	0.9032	1.0820	8.2090	14.6950	8.1753	14.2884
+8279	2006.8301	303	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.1776	14.2873
+8280	2006.8329	304	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.1799	14.2862
+8281	2006.8356	305	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.1822	14.2851
+8282	2006.8384	306	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.1845	14.2841
+8283	2006.8411	307	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.1867	14.2830
+8284	2006.8438	308	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.1888	14.2820
+8285	2006.8466	309	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.1910	14.2811
+8286	2006.8493	310	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.1930	14.2801
+8287	2006.8521	311	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.1951	14.2792
+8288	2006.8548	312	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.1971	14.2783
+8289	2006.8575	313	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.1990	14.2774
+8290	2006.8603	314	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.2009	14.2766
+8291	2006.8630	315	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.2028	14.2757
+8292	2006.8658	316	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.2046	14.2750
+8293	2006.8685	317	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.2064	14.2742
+8294	2006.8712	318	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.2081	14.2734
+8295	2006.8740	319	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.2098	14.2727
+8296	2006.8767	320	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.2114	14.2720
+8297	2006.8795	321	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.2130	14.2714
+8298	2006.8822	322	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.2145	14.2707
+8299	2006.8849	323	1.2212	0.6422	0.9032	1.0820	8.2090	14.6950	8.2160	14.2701
+8300	2006.8877	324	1.2212	0.6421	0.9032	1.0820	8.2090	14.6950	8.2174	14.2695
+8301	2006.8904	325	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2188	14.2690
+8302	2006.8932	326	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2201	14.2684
+8303	2006.8959	327	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2213	14.2679
+8304	2006.8986	328	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2226	14.2674
+8305	2006.9014	329	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2237	14.2670
+8306	2006.9041	330	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2248	14.2665
+8307	2006.9068	331	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2258	14.2661
+8308	2006.9096	332	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2268	14.2658
+8309	2006.9123	333	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2277	14.2654
+8310	2006.9151	334	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2286	14.2651
+8311	2006.9178	335	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2294	14.2648
+8312	2006.9205	336	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2302	14.2645
+8313	2006.9233	337	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2309	14.2642
+8314	2006.9260	338	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2315	14.2640
+8315	2006.9288	339	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2321	14.2638
+8316	2006.9315	340	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2326	14.2637
+8317	2006.9342	341	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2331	14.2635
+8318	2006.9370	342	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2335	14.2634
+8319	2006.9397	343	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2338	14.2633
+8320	2006.9425	344	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2341	14.2632
+8321	2006.9452	345	1.2211	0.6421	0.9032	1.0820	8.2090	14.6950	8.2343	14.2632
+8322	2006.9479	346	1.2210	0.6421	0.9032	1.0820	8.2090	14.6950	8.2345	14.2632
+8323	2006.9507	347	1.2210	0.6421	0.9032	1.0820	8.2090	14.6950	8.2346	14.2632
+8324	2006.9534	348	1.2210	0.6421	0.9032	1.0820	8.2090	14.6950	8.2346	14.2632
+8325	2006.9562	349	1.2210	0.6421	0.9032	1.0820	8.2090	14.6950	8.2346	14.2633
+8326	2006.9589	350	1.2210	0.6421	0.9032	1.0820	8.2090	14.6950	8.2345	14.2634
+8327	2006.9616	351	1.2210	0.6421	0.9032	1.0820	8.2090	14.6950	8.2344	14.2635
+8328	2006.9644	352	1.2210	0.6421	0.9032	1.0820	8.2090	14.6950	8.2342	14.2636
+8329	2006.9671	353	1.2210	0.6421	0.9032	1.0820	8.2090	14.6950	8.2339	14.2638
+8330	2006.9699	354	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2336	14.2640
+8331	2006.9726	355	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2332	14.2642
+8332	2006.9753	356	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2327	14.2644
+8333	2006.9781	357	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2322	14.2647
+8334	2006.9808	358	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2317	14.2650
+8335	2006.9836	359	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2311	14.2653
+8336	2006.9863	360	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2304	14.2656
+8337	2006.9890	361	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2296	14.2660
+8338	2006.9918	362	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2288	14.2663
+8339	2006.9945	363	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2280	14.2667
+8340	2006.9973	364	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2271	14.2672
+8341	2006.9999	365	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2261	14.2676
+8342	2007.0027	1	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2251	14.2681
+8343	2007.0055	2	1.2210	0.6420	0.9032	1.0820	8.2090	14.6950	8.2240	14.2686
+8344	2007.0082	3	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.2228	14.2691
+8345	2007.0110	4	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.2217	14.2697
+8346	2007.0137	5	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.2204	14.2703
+8347	2007.0164	6	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.2191	14.2709
+8348	2007.0192	7	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.2177	14.2715
+8349	2007.0219	8	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.2163	14.2721
+8350	2007.0247	9	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.2149	14.2728
+8351	2007.0274	10	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.2133	14.2735
+8352	2007.0301	11	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.2090	14.6950
+8353	2007.0329	12	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.2066	14.6950
+8354	2007.0356	13	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.2042	14.6949
+8355	2007.0384	14	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.2018	14.6948
+8356	2007.0411	15	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.1993	14.6947
+8357	2007.0438	16	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.1968	14.6946
+8358	2007.0466	17	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.1942	14.6944
+8359	2007.0493	18	1.2209	0.6420	0.9032	1.0820	8.2090	14.6950	8.1917	14.6942
+8360	2007.0521	19	1.2209	0.6419	0.9032	1.0820	8.2090	14.6950	8.1891	14.6940
+8361	2007.0548	20	1.2209	0.6419	0.9032	1.0820	8.2090	14.6950	8.1864	14.6937
+8362	2007.0575	21	1.2209	0.6419	0.9032	1.0820	8.2090	14.6950	8.1837	14.6935
+8363	2007.0603	22	1.2209	0.6419	0.9032	1.0820	8.2090	14.6950	8.1810	14.6931
+8364	2007.0630	23	1.2209	0.6419	0.9032	1.0820	8.2090	14.6950	8.1783	14.6928
+8365	2007.0658	24	1.2209	0.6419	0.9032	1.0820	8.2090	14.6950	8.1756	14.6925
+8366	2007.0685	25	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1728	14.6921
+8367	2007.0712	26	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1700	14.6917
+8368	2007.0740	27	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1671	14.6912
+8369	2007.0767	28	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1643	14.6908
+8370	2007.0795	29	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1614	14.6903
+8371	2007.0822	30	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1585	14.6897
+8372	2007.0849	31	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1556	14.6892
+8373	2007.0877	32	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1527	14.6886
+8374	2007.0904	33	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1498	14.6880
+8375	2007.0932	34	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1468	14.6874
+8376	2007.0959	35	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1438	14.6867
+8377	2007.0986	36	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1408	14.6860
+8378	2007.1014	37	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1378	14.6853
+8379	2007.1041	38	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1348	14.6846
+8380	2007.1068	39	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1318	14.6838
+8381	2007.1096	40	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1288	14.6830
+8382	2007.1123	41	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1257	14.6822
+8383	2007.1151	42	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1227	14.6814
+8384	2007.1178	43	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1196	14.6805
+8385	2007.1205	44	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1166	14.6796
+8386	2007.1233	45	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1135	14.6787
+8387	2007.1260	46	1.2208	0.6419	0.9032	1.0820	8.2090	14.6950	8.1105	14.6778
+8388	2007.1288	47	1.2207	0.6419	0.9032	1.0820	8.2090	14.6950	8.1074	14.6768
+8389	2007.1315	48	1.2207	0.6419	0.9032	1.0820	8.2090	14.6950	8.1044	14.6758
+8390	2007.1342	49	1.2207	0.6419	0.9032	1.0820	8.2090	14.6950	8.1013	14.6748
+8391	2007.1370	50	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0982	14.6737
+8392	2007.1397	51	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0952	14.6726
+8393	2007.1425	52	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0921	14.6715
+8394	2007.1452	53	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0891	14.6704
+8395	2007.1479	54	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0861	14.6693
+8396	2007.1507	55	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0830	14.6681
+8397	2007.1534	56	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0800	14.6669
+8398	2007.1562	57	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0770	14.6657
+8399	2007.1589	58	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0740	14.6644
+8400	2007.1616	59	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0710	14.6632
+8401	2007.1644	60	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0681	14.6619
+8402	2007.1671	61	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0651	14.6605
+8403	2007.1699	62	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0622	14.6592
+8404	2007.1726	63	1.2207	0.6418	0.9032	1.0820	8.2090	14.6950	8.0592	14.6578
+8405	2007.1753	64	1.2207	0.6418	0.9031	1.0820	8.2090	14.6950	8.0563	14.6565
+8406	2007.1781	65	1.2207	0.6418	0.9031	1.0820	8.2090	14.6950	8.0534	14.6550
+8407	2007.1808	66	1.2207	0.6418	0.9031	1.0820	8.2090	14.6950	8.0506	14.6536
+8408	2007.1836	67	1.2207	0.6418	0.9031	1.0820	8.2090	14.6950	8.0477	14.6521
+8409	2007.1863	68	1.2207	0.6418	0.9031	1.0820	8.2090	14.6950	8.0449	14.6507
+8410	2007.1890	69	1.2206	0.6418	0.9031	1.0820	8.2090	14.6950	8.0421	14.6492
+8411	2007.1918	70	1.2206	0.6418	0.9031	1.0820	8.2090	14.6950	8.0393	14.6476
+8412	2007.1945	71	1.2206	0.6418	0.9031	1.0820	8.2090	14.6950	8.0366	14.6461
+8413	2007.1973	72	1.2206	0.6418	0.9031	1.0820	8.2090	14.6950	8.0338	14.6445
+8414	2007.2000	73	1.2206	0.6418	0.9031	1.0820	8.2090	14.6950	8.0311	14.6429
+8415	2007.2027	74	1.2206	0.6418	0.9031	1.0820	8.2090	14.6950	8.0284	14.6413
+8416	2007.2055	75	1.2206	0.6418	0.9031	1.0820	8.2090	14.6950	8.0258	14.6397
+8417	2007.2082	76	1.2206	0.6418	0.9031	1.0820	8.2090	14.6950	8.0232	14.6380
+8418	2007.2110	77	1.2206	0.6418	0.9031	1.0820	8.2090	14.6950	8.0206	14.6364
+8419	2007.2137	78	1.2206	0.6418	0.9031	1.0820	8.2090	14.6950	8.0180	14.6347
+8420	2007.2164	79	1.2206	0.6418	0.9031	1.0820	8.2090	14.6950	8.0155	14.6330
+8421	2007.2192	80	1.2206	0.6418	0.9031	1.0820	8.2090	14.6950	8.0130	14.6312
+8422	2007.2219	81	1.2206	0.6417	0.9031	1.0820	8.2090	14.6950	8.0105	14.6295
+8423	2007.2247	82	1.2206	0.6417	0.9031	1.0820	8.2090	14.6950	8.0081	14.6277
+8424	2007.2274	83	1.2206	0.6417	0.9031	1.0820	8.2090	14.6950	8.0057	14.6259
+8425	2007.2301	84	1.2206	0.6417	0.9031	1.0820	8.2090	14.6950	8.0033	14.6241
+8426	2007.2329	85	1.2206	0.6417	0.9031	1.0820	8.2090	14.6950	8.0010	14.6223
+8427	2007.2356	86	1.2206	0.6417	0.9031	1.0820	8.2090	14.6950	7.9987	14.6204
+8428	2007.2384	87	1.2206	0.6417	0.9031	1.0820	8.2090	14.6950	7.9965	14.6185
+8429	2007.2411	88	1.2206	0.6417	0.9031	1.0820	8.2090	14.6950	7.9943	14.6167
+8430	2007.2438	89	1.2206	0.6417	0.9031	1.0820	8.2090	14.6950	7.9921	14.6148
+8431	2007.2466	90	1.2206	0.6417	0.9031	1.0820	8.2090	14.6950	7.9900	14.6128
+8432	2007.2493	91	1.2206	0.6417	0.9031	1.0820	8.2090	14.6950	7.9879	14.6109
+8433	2007.2521	92	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9858	14.6089
+8434	2007.2548	93	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9838	14.6070
+8435	2007.2575	94	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9819	14.6050
+8436	2007.2603	95	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9799	14.6030
+8437	2007.2630	96	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9781	14.6010
+8438	2007.2658	97	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9762	14.5989
+8439	2007.2685	98	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9744	14.5969
+8440	2007.2712	99	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9727	14.5948
+8441	2007.2740	100	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9710	14.5927
+8442	2007.2767	101	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9694	14.5906
+8443	2007.2795	102	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9678	14.5885
+8444	2007.2822	103	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9662	14.5864
+8445	2007.2849	104	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9647	14.5843
+8446	2007.2877	105	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9632	14.5821
+8447	2007.2904	106	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9618	14.5799
+8448	2007.2932	107	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9605	14.5778
+8449	2007.2959	108	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9592	14.5756
+8450	2007.2986	109	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9579	14.5734
+8451	2007.3014	110	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9567	14.5712
+8452	2007.3041	111	1.2205	0.6417	0.9031	1.0820	8.2090	14.6950	7.9555	14.5689
+8453	2007.3068	112	1.2205	0.6416	0.9031	1.0820	8.2090	14.6950	7.9544	14.5667
+8454	2007.3096	113	1.2205	0.6416	0.9031	1.0820	8.2090	14.6950	7.9534	14.5645
+8455	2007.3123	114	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9524	14.5622
+8456	2007.3151	115	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9514	14.5599
+8457	2007.3178	116	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9505	14.5577
+8458	2007.3205	117	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9497	14.5554
+8459	2007.3233	118	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9489	14.5531
+8460	2007.3260	119	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9481	14.5508
+8461	2007.3288	120	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9475	14.5484
+8462	2007.3315	121	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9468	14.5461
+8463	2007.3342	122	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9462	14.5438
+8464	2007.3370	123	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9457	14.5415
+8465	2007.3397	124	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9452	14.5391
+8466	2007.3425	125	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9448	14.5368
+8467	2007.3452	126	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9445	14.5344
+8468	2007.3479	127	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9442	14.5320
+8469	2007.3507	128	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9439	14.5296
+8470	2007.3534	129	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9437	14.5273
+8471	2007.3562	130	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9436	14.5249
+8472	2007.3589	131	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9435	14.5225
+8473	2007.3616	132	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9434	14.5201
+8474	2007.3644	133	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9434	14.5177
+8475	2007.3671	134	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9435	14.5153
+8476	2007.3699	135	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9436	14.5129
+8477	2007.3726	136	1.2204	0.6416	0.9031	1.0820	8.2090	14.6950	7.9438	14.5105
+8478	2007.3753	137	1.2203	0.6416	0.9031	1.0820	8.2090	14.6950	7.9440	14.5081
+8479	2007.3781	138	1.2203	0.6416	0.9031	1.0820	8.2090	14.6950	7.9443	14.5056
+8480	2007.3808	139	1.2203	0.6416	0.9031	1.0820	8.2090	14.6950	7.9447	14.5032
+8481	2007.3836	140	1.2203	0.6416	0.9031	1.0820	8.2090	14.6950	7.9451	14.5008
+8482	2007.3863	141	1.2203	0.6416	0.9031	1.0820	8.2090	14.6950	7.9455	14.4984
+8483	2007.3890	142	1.2203	0.6416	0.9031	1.0820	8.2090	14.6950	7.9460	14.4959
+8484	2007.3918	143	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9466	14.4935
+8485	2007.3945	144	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9472	14.4911
+8486	2007.3973	145	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9478	14.4886
+8487	2007.4000	146	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9485	14.4862
+8488	2007.4027	147	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9493	14.4838
+8489	2007.4055	148	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9501	14.4813
+8490	2007.4082	149	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9510	14.4789
+8491	2007.4110	150	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9519	14.4765
+8492	2007.4137	151	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9528	14.4740
+8493	2007.4164	152	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9539	14.4716
+8494	2007.4192	153	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9549	14.4692
+8495	2007.4219	154	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9560	14.4668
+8496	2007.4247	155	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9572	14.4643
+8497	2007.4274	156	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9584	14.4619
+8498	2007.4301	157	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9597	14.4595
+8499	2007.4329	158	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9610	14.4571
+8500	2007.4356	159	1.2203	0.6415	0.9031	1.0820	8.2090	14.6950	7.9623	14.4547
+8501	2007.4384	160	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9637	14.4523
+8502	2007.4411	161	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9652	14.4499
+8503	2007.4438	162	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9667	14.4475
+8504	2007.4466	163	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9682	14.4451
+8505	2007.4493	164	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9698	14.4427
+8506	2007.4521	165	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9714	14.4403
+8507	2007.4548	166	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9731	14.4379
+8508	2007.4575	167	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9748	14.4356
+8509	2007.4603	168	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9766	14.4332
+8510	2007.4630	169	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9784	14.4308
+8511	2007.4658	170	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9802	14.4285
+8512	2007.4685	171	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9821	14.4261
+8513	2007.4712	172	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9840	14.4238
+8514	2007.4740	173	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9859	14.4215
+8515	2007.4767	174	1.2202	0.6415	0.9031	1.0820	8.2090	14.6950	7.9879	14.4191
+8516	2007.4795	175	1.2202	0.6414	0.9031	1.0820	8.2090	14.6950	7.9900	14.4168
+8517	2007.4822	176	1.2202	0.6414	0.9031	1.0820	8.2090	14.6950	7.9920	14.4145
+8518	2007.4849	177	1.2202	0.6414	0.9031	1.0820	8.2090	14.6950	7.9941	14.4122
+8519	2007.4877	178	1.2202	0.6414	0.9031	1.0820	8.2090	14.6950	7.9963	14.4099
+8520	2007.4904	179	1.2202	0.6414	0.9031	1.0820	8.2090	14.6950	7.9985	14.4077
+8521	2007.4932	180	1.2202	0.6414	0.9031	1.0820	8.2090	14.6950	8.0007	14.4054
+8522	2007.4959	181	1.2202	0.6414	0.9031	1.0820	8.2090	14.6950	8.0029	14.4031
+8523	2007.4986	182	1.2202	0.6414	0.9031	1.0820	8.2090	14.6950	8.0052	14.4009
+8524	2007.5014	183	1.2202	0.6414	0.9031	1.0820	8.2090	14.6950	8.0075	14.3987
+8525	2007.5041	184	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0098	14.3964
+8526	2007.5068	185	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0122	14.3942
+8527	2007.5096	186	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0146	14.3920
+8528	2007.5123	187	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0170	14.3898
+8529	2007.5151	188	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0194	14.3876
+8530	2007.5178	189	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0219	14.3855
+8531	2007.5205	190	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0244	14.3833
+8532	2007.5233	191	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0269	14.3812
+8533	2007.5260	192	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0295	14.3790
+8534	2007.5288	193	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0320	14.3769
+8535	2007.5315	194	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0346	14.3748
+8536	2007.5342	195	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0372	14.3727
+8537	2007.5370	196	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0399	14.3707
+8538	2007.5397	197	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0425	14.3686
+8539	2007.5425	198	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0452	14.3666
+8540	2007.5452	199	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0479	14.3645
+8541	2007.5479	200	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0506	14.3625
+8542	2007.5507	201	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0533	14.3605
+8543	2007.5534	202	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0560	14.3585
+8544	2007.5562	203	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0588	14.3565
+8545	2007.5589	204	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0615	14.3546
+8546	2007.5616	205	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0643	14.3526
+8547	2007.5644	206	1.2201	0.6414	0.9031	1.0820	8.2090	14.6950	8.0670	14.3507
+8548	2007.5671	207	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.0698	14.3488
+8549	2007.5699	208	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.0726	14.3469
+8550	2007.5726	209	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.0754	14.3451
+8551	2007.5753	210	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.0782	14.3432
+8552	2007.5781	211	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.0810	14.3414
+8553	2007.5808	212	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.0838	14.3395
+8554	2007.5836	213	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.0866	14.3377
+8555	2007.5863	214	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.0895	14.3359
+8556	2007.5890	215	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.0923	14.3342
+8557	2007.5918	216	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.0951	14.3324
+8558	2007.5945	217	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.0979	14.3307
+8559	2007.5973	218	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1007	14.3290
+8560	2007.6000	219	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1035	14.3273
+8561	2007.6027	220	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1063	14.3256
+8562	2007.6055	221	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1091	14.3240
+8563	2007.6082	222	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1119	14.3223
+8564	2007.6110	223	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1147	14.3207
+8565	2007.6137	224	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1175	14.3191
+8566	2007.6164	225	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1202	14.3175
+8567	2007.6192	226	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1230	14.3160
+8568	2007.6219	227	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1257	14.3145
+8569	2007.6247	228	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1284	14.3129
+8570	2007.6274	229	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1311	14.3114
+8571	2007.6301	230	1.2200	0.6413	0.9031	1.0820	8.2090	14.6950	8.1338	14.3100
+8572	2007.6329	231	1.2199	0.6413	0.9031	1.0820	8.2090	14.6950	8.1365	14.3085
+8573	2007.6356	232	1.2199	0.6413	0.9031	1.0820	8.2090	14.6950	8.1392	14.3071
+8574	2007.6384	233	1.2199	0.6413	0.9031	1.0820	8.2090	14.6950	8.1418	14.3057
+8575	2007.6411	234	1.2199	0.6413	0.9031	1.0820	8.2090	14.6950	8.1445	14.3043
+8576	2007.6438	235	1.2199	0.6413	0.9031	1.0820	8.2090	14.6950	8.1471	14.3029
+8577	2007.6466	236	1.2199	0.6413	0.9031	1.0820	8.2090	14.6950	8.1496	14.3016
+8578	2007.6493	237	1.2199	0.6413	0.9031	1.0820	8.2090	14.6950	8.1522	14.3002
+8579	2007.6521	238	1.2199	0.6413	0.9031	1.0820	8.2090	14.6950	8.1547	14.2989
+8580	2007.6548	239	1.2199	0.6413	0.9031	1.0820	8.2090	14.6950	8.1573	14.2977
+8581	2007.6575	240	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1597	14.2964
+8582	2007.6603	241	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1622	14.2952
+8583	2007.6630	242	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1646	14.2939
+8584	2007.6658	243	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1671	14.2928
+8585	2007.6685	244	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1694	14.2916
+8586	2007.6712	245	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1718	14.2904
+8587	2007.6740	246	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1741	14.2893
+8588	2007.6767	247	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1764	14.2882
+8589	2007.6795	248	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1786	14.2871
+8590	2007.6822	249	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1809	14.2861
+8591	2007.6849	250	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1830	14.2850
+8592	2007.6877	251	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1852	14.2840
+8593	2007.6904	252	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1873	14.2830
+8594	2007.6932	253	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1894	14.2821
+8595	2007.6959	254	1.2199	0.6412	0.9031	1.0820	8.2090	14.6950	8.1914	14.2811
+8596	2007.6986	255	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.1934	14.2802
+8597	2007.7014	256	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.1954	14.2793
+8598	2007.7041	257	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.1973	14.2785
+8599	2007.7068	258	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.1992	14.2776
+8600	2007.7096	259	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2010	14.2768
+8601	2007.7123	260	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2028	14.2760
+8602	2007.7151	261	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2046	14.2752
+8603	2007.7178	262	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2063	14.2745
+8604	2007.7205	263	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2079	14.2737
+8605	2007.7233	264	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2096	14.2730
+8606	2007.7260	265	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2111	14.2724
+8607	2007.7288	266	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2127	14.2717
+8608	2007.7315	267	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2141	14.2711
+8609	2007.7342	268	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2156	14.2705
+8610	2007.7370	269	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2170	14.2699
+8611	2007.7397	270	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2183	14.2693
+8612	2007.7425	271	1.2198	0.6412	0.9031	1.0820	8.2090	14.6950	8.2196	14.2688
+8613	2007.7452	272	1.2198	0.6411	0.9031	1.0820	8.2090	14.6950	8.2208	14.2683
+8614	2007.7479	273	1.2198	0.6411	0.9031	1.0820	8.2090	14.6950	8.2220	14.2678
+8615	2007.7507	274	1.2198	0.6411	0.9031	1.0820	8.2090	14.6950	8.2231	14.2673
+8616	2007.7534	275	1.2198	0.6411	0.9031	1.0820	8.2090	14.6950	8.2242	14.2669
+8617	2007.7562	276	1.2198	0.6411	0.9031	1.0820	8.2090	14.6950	8.2252	14.2665
+8618	2007.7589	277	1.2198	0.6411	0.9031	1.0820	8.2090	14.6950	8.2262	14.2661
+8619	2007.7616	278	1.2198	0.6411	0.9031	1.0820	8.2090	14.6950	8.2272	14.2657
+8620	2007.7644	279	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2280	14.2654
+8621	2007.7671	280	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2288	14.2651
+8622	2007.7699	281	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2296	14.2648
+8623	2007.7726	282	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2303	14.2645
+8624	2007.7753	283	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2310	14.2643
+8625	2007.7781	284	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2316	14.2641
+8626	2007.7808	285	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2321	14.2639
+8627	2007.7836	286	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2326	14.2637
+8628	2007.7863	287	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2331	14.2636
+8629	2007.7890	288	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2335	14.2634
+8630	2007.7918	289	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2338	14.2633
+8631	2007.7945	290	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2341	14.2633
+8632	2007.7973	291	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2343	14.2632
+8633	2007.8000	292	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2344	14.2632
+8634	2007.8027	293	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2345	14.2632
+8635	2007.8055	294	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2346	14.2632
+8636	2007.8082	295	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2346	14.2632
+8637	2007.8110	296	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2345	14.2633
+8638	2007.8137	297	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2344	14.2634
+8639	2007.8164	298	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2342	14.2635
+8640	2007.8192	299	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2340	14.2636
+8641	2007.8219	300	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2337	14.2638
+8642	2007.8247	301	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2334	14.2640
+8643	2007.8274	302	1.2197	0.6411	0.9031	1.0820	8.2090	14.6950	8.2330	14.2642
+8644	2007.8301	303	1.2196	0.6411	0.9031	1.0820	8.2090	14.6950	8.2325	14.2644
+8645	2007.8329	304	1.2196	0.6411	0.9031	1.0820	8.2090	14.6950	8.2320	14.2647
+8646	2007.8356	305	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2315	14.2650
+8647	2007.8384	306	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2308	14.2653
+8648	2007.8411	307	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2302	14.2656
+8649	2007.8438	308	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2294	14.2659
+8650	2007.8466	309	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2286	14.2663
+8651	2007.8493	310	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2278	14.2667
+8652	2007.8521	311	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2269	14.2671
+8653	2007.8548	312	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2260	14.2675
+8654	2007.8575	313	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2250	14.2680
+8655	2007.8603	314	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2239	14.2684
+8656	2007.8630	315	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2228	14.2689
+8657	2007.8658	316	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2217	14.2695
+8658	2007.8685	317	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2205	14.2700
+8659	2007.8712	318	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2192	14.2706
+8660	2007.8740	319	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2179	14.2712
+8661	2007.8767	320	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2166	14.2718
+8662	2007.8795	321	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2152	14.2724
+8663	2007.8822	322	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2137	14.2730
+8664	2007.8849	323	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2122	14.2737
+8665	2007.8877	324	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2107	14.2744
+8666	2007.8904	325	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2091	14.2751
+8667	2007.8932	326	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2074	14.2758
+8668	2007.8959	327	1.2196	0.6410	0.9031	1.0820	8.2090	14.6950	8.2057	14.2766
+8669	2007.8986	328	1.2195	0.6410	0.9031	1.0820	8.2090	14.6950	8.2040	14.2773
+8670	2007.9014	329	1.2195	0.6410	0.9031	1.0820	8.2090	14.6950	8.2022	14.2781
+8671	2007.9041	330	1.2195	0.6410	0.9031	1.0820	8.2090	14.6950	8.2004	14.2789
+8672	2007.9068	331	1.2195	0.6410	0.9031	1.0820	8.2090	14.6950	8.1985	14.2798
+8673	2007.9096	332	1.2195	0.6410	0.9031	1.0820	8.2090	14.6950	8.1966	14.2806
+8674	2007.9123	333	1.2195	0.6410	0.9031	1.0820	8.2090	14.6950	8.1947	14.2815
+8675	2007.9151	334	1.2195	0.6410	0.9031	1.0820	8.2090	14.6950	8.1927	14.2824
+8676	2007.9178	335	1.2195	0.6410	0.9031	1.0820	8.2090	14.6950	8.1907	14.2833
+8677	2007.9205	336	1.2195	0.6410	0.9031	1.0820	8.2090	14.6950	8.1886	14.2842
+8678	2007.9233	337	1.2195	0.6410	0.9031	1.0820	8.2090	14.6950	8.1865	14.2851
+8679	2007.9260	338	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1843	14.2861
+8680	2007.9288	339	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1822	14.2871
+8681	2007.9315	340	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1799	14.2881
+8682	2007.9342	341	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1777	14.2891
+8683	2007.9370	342	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1754	14.2901
+8684	2007.9397	343	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1731	14.2911
+8685	2007.9425	344	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1707	14.2922
+8686	2007.9452	345	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1683	14.2933
+8687	2007.9479	346	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1659	14.2944
+8688	2007.9507	347	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1634	14.2955
+8689	2007.9534	348	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1610	14.2966
+8690	2007.9562	349	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1584	14.2978
+8691	2007.9589	350	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1559	14.2989
+8692	2007.9616	351	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1533	14.3001
+8693	2007.9644	352	1.2195	0.6409	0.9031	1.0820	8.2090	14.6950	8.1508	14.3013
+8694	2007.9671	353	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1481	14.3025
+8695	2007.9699	354	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1455	14.3037
+8696	2007.9726	355	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1428	14.3050
+8697	2007.9753	356	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1402	14.3062
+8698	2007.9781	357	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1374	14.3075
+8699	2007.9808	358	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1347	14.3088
+8700	2007.9836	359	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1320	14.3101
+8701	2007.9863	360	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1292	14.3114
+8702	2007.9890	361	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1264	14.3127
+8703	2007.9918	362	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1236	14.3140
+8704	2007.9945	363	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1208	14.3154
+8705	2007.9973	364	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1180	14.3167
+8706	2007.9999	365	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1152	14.3181
+8707	2008.0027	1	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1123	14.3195
+8708	2008.0055	2	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1094	14.3209
+8709	2008.0082	3	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1066	14.3223
+8710	2008.0109	4	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1037	14.3237
+8711	2008.0137	5	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.1008	14.3251
+8712	2008.0164	6	1.2194	0.6409	0.9031	1.0820	8.2090	14.6950	8.0979	14.3266
+8713	2008.0191	7	1.2194	0.6408	0.9031	1.0820	8.2090	14.6950	8.0950	14.3280
+8714	2008.0219	8	1.2194	0.6408	0.9031	1.0820	8.2090	14.6950	8.0921	14.3295
+8715	2008.0246	9	1.2194	0.6408	0.9031	1.0820	8.2090	14.6950	8.0892	14.3310
+8716	2008.0273	10	1.2194	0.6408	0.9031	1.0820	8.2090	14.6950	8.0862	14.3324
+8717	2008.0301	11	1.2194	0.6408	0.9031	1.0820	8.2090	14.6950	8.0833	14.3339
+8718	2008.0328	12	1.2194	0.6408	0.9031	1.0820	8.2090	14.6950	8.0804	14.3354
+8719	2008.0355	13	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0775	14.3369
+8720	2008.0383	14	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0745	14.3385
+8721	2008.0410	15	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0716	14.3400
+8722	2008.0437	16	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0687	14.3415
+8723	2008.0464	17	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0658	14.3431
+8724	2008.0492	18	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0629	14.3446
+8725	2008.0519	19	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0600	14.3462
+8726	2008.0546	20	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0571	14.3477
+8727	2008.0574	21	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0542	14.3493
+8728	2008.0601	22	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0513	14.3509
+8729	2008.0628	23	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0484	14.3525
+8730	2008.0656	24	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0456	14.3541
+8731	2008.0683	25	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0427	14.3557
+8732	2008.0710	26	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0399	14.3573
+8733	2008.0738	27	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0371	14.3589
+8734	2008.0765	28	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0343	14.3605
+8735	2008.0792	29	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0315	14.3621
+8736	2008.0820	30	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0287	14.3637
+8737	2008.0847	31	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0259	14.3654
+8738	2008.0874	32	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0232	14.3670
+8739	2008.0902	33	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0204	14.3686
+8740	2008.0929	34	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0177	14.3703
+8741	2008.0956	35	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0150	14.3719
+8742	2008.0984	36	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0124	14.3735
+8743	2008.1011	37	1.2193	0.6408	0.9031	1.0820	8.2090	14.6950	8.0097	14.3752
+8744	2008.1038	38	1.2192	0.6408	0.9031	1.0820	8.2090	14.6950	8.0071	14.3768
+8745	2008.1066	39	1.2192	0.6408	0.9031	1.0820	8.2090	14.6950	8.0045	14.3785
+8746	2008.1093	40	1.2192	0.6408	0.9031	1.0820	8.2090	14.6950	8.0019	14.3801
+8747	2008.1120	41	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9994	14.3818
+8748	2008.1148	42	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9969	14.3835
+8749	2008.1175	43	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9944	14.3851
+8750	2008.1202	44	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9919	14.3868
+8751	2008.1230	45	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9895	14.3884
+8752	2008.1257	46	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9870	14.3901
+8753	2008.1284	47	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9847	14.3917
+8754	2008.1311	48	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9823	14.3934
+8755	2008.1339	49	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9800	14.3950
+8756	2008.1366	50	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9777	14.3967
+8757	2008.1393	51	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9754	14.3983
+8758	2008.1421	52	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9732	14.4000
+8759	2008.1448	53	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9710	14.4016
+8760	2008.1475	54	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9689	14.4033
+8761	2008.1503	55	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9668	14.4049
+8762	2008.1530	56	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9647	14.4066
+8763	2008.1557	57	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9626	14.4082
+8764	2008.1585	58	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9606	14.4098
+8765	2008.1612	59	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9587	14.4115
+8766	2008.1639	60	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9567	14.4131
+8767	2008.1667	61	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9548	14.4147
+8768	2008.1694	62	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9530	14.4163
+8769	2008.1721	63	1.2192	0.6407	0.9031	1.0820	8.2090	14.6950	7.9512	14.4179
+8770	2008.1749	64	1.2191	0.6407	0.9031	1.0820	8.2090	14.6950	7.9494	14.4195
+8771	2008.1776	65	1.2191	0.6407	0.9031	1.0820	8.2090	14.6950	7.9477	14.4211
+8772	2008.1803	66	1.2191	0.6407	0.9031	1.0820	8.2090	14.6950	7.9460	14.4227
+8773	2008.1831	67	1.2191	0.6407	0.9031	1.0820	8.2090	14.6950	7.9443	14.4243
+8774	2008.1858	68	1.2191	0.6407	0.9031	1.0820	8.2090	14.6950	7.9427	14.4259
+8775	2008.1885	69	1.2191	0.6407	0.9031	1.0820	8.2090	14.6950	7.9412	14.4275
+8776	2008.1913	70	1.2191	0.6407	0.9031	1.0820	8.2090	14.6950	7.9397	14.4291
+8777	2008.1940	71	1.2191	0.6407	0.9031	1.0820	8.2090	14.6950	7.9382	14.4306
+8778	2008.1967	72	1.2191	0.6407	0.9031	1.0820	8.2090	14.6950	7.9367	14.4322
+8779	2008.1995	73	1.2191	0.6407	0.9031	1.0820	8.2090	14.6950	7.9354	14.4337
+8780	2008.2022	74	1.2191	0.6407	0.9031	1.0820	8.2090	14.6950	7.9340	14.4353
+8781	2008.2049	75	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9327	14.4368
+8782	2008.2077	76	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9315	14.4383
+8783	2008.2104	77	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9303	14.4398
+8784	2008.2131	78	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9291	14.4413
+8785	2008.2158	79	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9280	14.4428
+8786	2008.2186	80	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9269	14.4443
+8787	2008.2213	81	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9259	14.4458
+8788	2008.2240	82	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9250	14.4473
+8789	2008.2268	83	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9240	14.4487
+8790	2008.2295	84	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9232	14.4502
+8791	2008.2322	85	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9223	14.4516
+8792	2008.2350	86	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9216	14.4530
+8793	2008.2377	87	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9208	14.4544
+8794	2008.2404	88	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9202	14.4558
+8795	2008.2432	89	1.2191	0.6406	0.9031	1.0820	8.2090	14.6950	7.9195	14.4572
+8796	2008.2459	90	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9190	14.4586
+8797	2008.2486	91	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9184	14.4600
+8798	2008.2514	92	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9179	14.4613
+8799	2008.2541	93	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9175	14.4627
+8800	2008.2568	94	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9171	14.4640
+8801	2008.2596	95	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9168	14.4653
+8802	2008.2623	96	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9165	14.4666
+8803	2008.2650	97	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9163	14.4679
+8804	2008.2678	98	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9161	14.4692
+8805	2008.2705	99	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9160	14.4704
+8806	2008.2732	100	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9159	14.4717
+8807	2008.2760	101	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9159	14.4729
+8808	2008.2787	102	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9159	14.4741
+8809	2008.2814	103	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9159	14.4753
+8810	2008.2842	104	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9161	14.4765
+8811	2008.2869	105	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9162	14.4777
+8812	2008.2896	106	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9164	14.4788
+8813	2008.2923	107	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9167	14.4800
+8814	2008.2951	108	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9170	14.4811
+8815	2008.2978	109	1.2190	0.6406	0.9031	1.0820	8.2090	14.6950	7.9174	14.4822
+8816	2008.3005	110	1.2190	0.6405	0.9031	1.0820	8.2090	14.6950	7.9178	14.4833
+8817	2008.3033	111	1.2190	0.6405	0.9031	1.0820	8.2090	14.6950	7.9183	14.4844
+8818	2008.3060	112	1.2190	0.6405	0.9031	1.0820	8.2090	14.6950	7.9188	14.4854
+8819	2008.3087	113	1.2190	0.6405	0.9031	1.0820	8.2090	14.6950	7.9193	14.4865
+8820	2008.3115	114	1.2190	0.6405	0.9031	1.0820	8.2090	14.6950	7.9199	14.4875
+8821	2008.3142	115	1.2190	0.6405	0.9031	1.0820	8.2090	14.6950	7.9206	14.4885
+8822	2008.3169	116	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9213	14.4895
+8823	2008.3197	117	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9220	14.4904
+8824	2008.3224	118	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9228	14.4914
+8825	2008.3251	119	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9237	14.4923
+8826	2008.3279	120	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9246	14.4932
+8827	2008.3306	121	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9255	14.4941
+8828	2008.3333	122	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9265	14.4950
+8829	2008.3361	123	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9275	14.4959
+8830	2008.3388	124	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9286	14.4967
+8831	2008.3415	125	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9297	14.4975
+8832	2008.3443	126	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9309	14.4983
+8833	2008.3470	127	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9321	14.4991
+8834	2008.3497	128	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9333	14.4998
+8835	2008.3525	129	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9346	14.5006
+8836	2008.3552	130	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9360	14.5013
+8837	2008.3579	131	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9374	14.5020
+8838	2008.3607	132	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9388	14.5027
+8839	2008.3634	133	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9402	14.5033
+8840	2008.3661	134	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9417	14.5040
+8841	2008.3689	135	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9433	14.5046
+8842	2008.3716	136	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9449	14.5052
+8843	2008.3743	137	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9465	14.5058
+8844	2008.3770	138	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9482	14.5063
+8845	2008.3798	139	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9499	14.5069
+8846	2008.3825	140	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9516	14.5074
+8847	2008.3852	141	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9534	14.5079
+8848	2008.3880	142	1.2189	0.6405	0.9031	1.0820	8.2090	14.6950	7.9552	14.5083
+8849	2008.3907	143	1.2188	0.6405	0.9031	1.0820	8.2090	14.6950	7.9570	14.5088
+8850	2008.3934	144	1.2188	0.6405	0.9031	1.0820	8.2090	14.6950	7.9589	14.5092
+8851	2008.3962	145	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9608	14.5096
+8852	2008.3989	146	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9628	14.5100
+8853	2008.4016	147	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9648	14.5103
+8854	2008.4044	148	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9668	14.5107
+8855	2008.4071	149	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9689	14.5110
+8856	2008.4098	150	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9709	14.5113
+8857	2008.4126	151	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9731	14.5115
+8858	2008.4153	152	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9752	14.5118
+8859	2008.4180	153	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9774	14.5120
+8860	2008.4208	154	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9796	14.5122
+8861	2008.4235	155	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9818	14.5124
+8862	2008.4262	156	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9841	14.5125
+8863	2008.4290	157	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9863	14.5127
+8864	2008.4317	158	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9887	14.5128
+8865	2008.4344	159	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9910	14.5129
+8866	2008.4372	160	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9933	14.5129
+8867	2008.4399	161	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9957	14.5130
+8868	2008.4426	162	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	7.9981	14.5130
+8869	2008.4454	163	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	8.0006	14.5130
+8870	2008.4481	164	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	8.0030	14.5130
+8871	2008.4508	165	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	8.0055	14.5129
+8872	2008.4536	166	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	8.0080	14.5128
+8873	2008.4563	167	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	8.0105	14.5127
+8874	2008.4590	168	1.2188	0.6404	0.9031	1.0820	8.2090	14.6950	8.0130	14.5126
+8875	2008.4617	169	1.2187	0.6404	0.9031	1.0820	8.2090	14.6950	8.0155	14.5125
+8876	2008.4645	170	1.2187	0.6404	0.9031	1.0820	8.2090	14.6950	8.0181	14.5123
+8877	2008.4672	171	1.2187	0.6404	0.9031	1.0820	8.2090	14.6950	8.0206	14.5121
+8878	2008.4699	172	1.2187	0.6404	0.9031	1.0820	8.2090	14.6950	8.0232	14.5119
+8879	2008.4727	173	1.2187	0.6404	0.9031	1.0820	8.2090	14.6950	8.0258	14.5116
+8880	2008.4754	174	1.2187	0.6404	0.9031	1.0820	8.2090	14.6950	8.0284	14.5114
+8881	2008.4781	175	1.2187	0.6404	0.9031	1.0820	8.2090	14.6950	8.0311	14.5111
+8882	2008.4809	176	1.2187	0.6404	0.9031	1.0820	8.2090	14.6950	8.0337	14.5108
+8883	2008.4836	177	1.2187	0.6404	0.9031	1.0820	8.2090	14.6950	8.0363	14.5104
+8884	2008.4863	178	1.2187	0.6404	0.9031	1.0820	8.2090	14.6950	8.0390	14.5101
+8885	2008.4891	179	1.2187	0.6404	0.9031	1.0820	8.2090	14.6950	8.0416	14.5097
+8886	2008.4918	180	1.2187	0.6404	0.9031	1.0820	8.2090	14.6950	8.0443	14.5093
+8887	2008.4945	181	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0470	14.5089
+8888	2008.4973	182	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0496	14.5084
+8889	2008.5000	183	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0523	14.5080
+8890	2008.5027	184	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0550	14.5075
+8891	2008.5055	185	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0577	14.5069
+8892	2008.5082	186	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0604	14.5064
+8893	2008.5109	187	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0631	14.5058
+8894	2008.5137	188	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0658	14.5052
+8895	2008.5164	189	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0685	14.5046
+8896	2008.5191	190	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0711	14.5040
+8897	2008.5219	191	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0738	14.5033
+8898	2008.5246	192	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0765	14.5026
+8899	2008.5273	193	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0792	14.5019
+8900	2008.5301	194	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0818	14.5012
+8901	2008.5328	195	1.2187	0.6403	0.9031	1.0820	8.2090	14.6950	8.0845	14.5005
+8902	2008.5355	196	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.0871	14.4997
+8903	2008.5383	197	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.0898	14.4989
+8904	2008.5410	198	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.0924	14.4981
+8905	2008.5437	199	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.0951	14.4972
+8906	2008.5464	200	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.0977	14.4964
+8907	2008.5492	201	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1003	14.4955
+8908	2008.5519	202	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1028	14.4946
+8909	2008.5546	203	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1054	14.4937
+8910	2008.5574	204	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1080	14.4927
+8911	2008.5601	205	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1105	14.4917
+8912	2008.5628	206	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1130	14.4907
+8913	2008.5656	207	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1155	14.4897
+8914	2008.5683	208	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1180	14.4887
+8915	2008.5710	209	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1205	14.4876
+8916	2008.5738	210	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1230	14.4865
+8917	2008.5765	211	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1254	14.4854
+8918	2008.5792	212	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1278	14.4843
+8919	2008.5820	213	1.2186	0.6403	0.9031	1.0820	8.2090	14.6950	8.1302	14.4832
+8920	2008.5847	214	1.2186	0.6403	0.9030	1.0820	8.2090	14.6950	8.1325	14.4820
+8921	2008.5874	215	1.2186	0.6403	0.9030	1.0820	8.2090	14.6950	8.1349	14.4808
+8922	2008.5902	216	1.2186	0.6402	0.9030	1.0820	8.2090	14.6950	8.1372	14.4796
+8923	2008.5929	217	1.2186	0.6402	0.9030	1.0820	8.2090	14.6950	8.1394	14.4784
+8924	2008.5956	218	1.2186	0.6402	0.9030	1.0820	8.2090	14.6950	8.1417	14.4771
+8925	2008.5984	219	1.2186	0.6402	0.9030	1.0820	8.2090	14.6950	8.1439	14.4759
+8926	2008.6011	220	1.2186	0.6402	0.9030	1.0820	8.2090	14.6950	8.1461	14.4746
+8927	2008.6038	221	1.2186	0.6402	0.9030	1.0820	8.2090	14.6950	8.1483	14.4733
+8928	2008.6066	222	1.2186	0.6402	0.9030	1.0820	8.2090	14.6950	8.1504	14.4720
+8929	2008.6093	223	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1525	14.4706
+8930	2008.6120	224	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1546	14.4693
+8931	2008.6148	225	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1566	14.4679
+8932	2008.6175	226	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1586	14.4665
+8933	2008.6202	227	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1606	14.4650
+8934	2008.6230	228	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1625	14.4636
+8935	2008.6257	229	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1645	14.4621
+8936	2008.6284	230	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1663	14.4607
+8937	2008.6311	231	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1681	14.4592
+8938	2008.6339	232	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1699	14.4577
+8939	2008.6366	233	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1717	14.4561
+8940	2008.6393	234	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1734	14.4546
+8941	2008.6421	235	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1751	14.4530
+8942	2008.6448	236	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1767	14.4514
+8943	2008.6475	237	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1783	14.4498
+8944	2008.6503	238	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1799	14.4482
+8945	2008.6530	239	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1814	14.4466
+8946	2008.6557	240	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1828	14.4449
+8947	2008.6585	241	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1843	14.4433
+8948	2008.6612	242	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1856	14.4416
+8949	2008.6639	243	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1870	14.4399
+8950	2008.6667	244	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1883	14.4382
+8951	2008.6694	245	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1895	14.4364
+8952	2008.6721	246	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1907	14.4347
+8953	2008.6749	247	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1919	14.4329
+8954	2008.6776	248	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1930	14.4311
+8955	2008.6803	249	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1940	14.4293
+8956	2008.6831	250	1.2185	0.6402	0.9030	1.0820	8.2090	14.6950	8.1950	14.4275
+8957	2008.6858	251	1.2184	0.6402	0.9030	1.0820	8.2090	14.6950	8.1960	14.4257
+8958	2008.6885	252	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.1969	14.4239
+8959	2008.6913	253	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.1978	14.4220
+8960	2008.6940	254	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.1986	14.4202
+8961	2008.6967	255	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.1994	14.4183
+8962	2008.6995	256	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2001	14.4164
+8963	2008.7022	257	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2008	14.4145
+8964	2008.7049	258	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2014	14.4126
+8965	2008.7077	259	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2020	14.4107
+8966	2008.7104	260	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2025	14.4087
+8967	2008.7131	261	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2030	14.4068
+8968	2008.7158	262	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2034	14.4048
+8969	2008.7186	263	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2038	14.4029
+8970	2008.7213	264	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2041	14.4009
+8971	2008.7240	265	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2044	14.3989
+8972	2008.7268	266	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2046	14.3969
+8973	2008.7295	267	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2047	14.3948
+8974	2008.7322	268	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2049	14.3928
+8975	2008.7350	269	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2049	14.3908
+8976	2008.7377	270	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2049	14.3887
+8977	2008.7404	271	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2049	14.3867
+8978	2008.7432	272	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2048	14.3846
+8979	2008.7459	273	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2047	14.3825
+8980	2008.7486	274	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2045	14.3805
+8981	2008.7514	275	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2042	14.3784
+8982	2008.7541	276	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2039	14.3763
+8983	2008.7568	277	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2036	14.3741
+8984	2008.7596	278	1.2184	0.6401	0.9030	1.0820	8.2090	14.6950	8.2032	14.3720
+8985	2008.7623	279	1.2183	0.6401	0.9030	1.0820	8.2090	14.6950	8.2027	14.3699
+8986	2008.7650	280	1.2183	0.6401	0.9030	1.0820	8.2090	14.6950	8.2022	14.3678
+8987	2008.7678	281	1.2183	0.6401	0.9030	1.0820	8.2090	14.6950	8.2017	14.3656
+8988	2008.7705	282	1.2183	0.6401	0.9030	1.0820	8.2090	14.6950	8.2011	14.3635
+8989	2008.7732	283	1.2183	0.6401	0.9030	1.0820	8.2090	14.6950	8.2004	14.3613
+8990	2008.7760	284	1.2183	0.6401	0.9030	1.0820	8.2090	14.6950	8.1997	14.3592
+8991	2008.7787	285	1.2183	0.6401	0.9030	1.0820	8.2090	14.6950	8.1990	14.3570
+8992	2008.7814	286	1.2183	0.6401	0.9030	1.0820	8.2090	14.6950	8.1982	14.3548
+8993	2008.7842	287	1.2183	0.6401	0.9030	1.0820	8.2090	14.6950	8.1973	14.3527
+8994	2008.7869	288	1.2183	0.6401	0.9030	1.0820	8.2090	14.6950	8.1964	14.3505
+8995	2008.7896	289	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1955	14.3483
+8996	2008.7923	290	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1945	14.3461
+8997	2008.7951	291	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1934	14.3439
+8998	2008.7978	292	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1923	14.3417
+8999	2008.8005	293	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1912	14.3395
+9000	2008.8033	294	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1900	14.3373
+9001	2008.8060	295	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1888	14.3351
+9002	2008.8087	296	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1875	14.3329
+9003	2008.8115	297	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1862	14.3306
+9004	2008.8142	298	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1848	14.3284
+9005	2008.8169	299	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1834	14.3262
+9006	2008.8197	300	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1819	14.3240
+9007	2008.8224	301	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1804	14.3217
+9008	2008.8251	302	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1789	14.3195
+9009	2008.8279	303	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1773	14.3173
+9010	2008.8306	304	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1757	14.3151
+9011	2008.8333	305	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1740	14.3128
+9012	2008.8361	306	1.2183	0.6400	0.9030	1.0820	8.2090	14.6950	8.1723	14.3106
+9013	2008.8388	307	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1705	14.3084
+9014	2008.8415	308	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1687	14.3061
+9015	2008.8443	309	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1669	14.3039
+9016	2008.8470	310	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1651	14.3016
+9017	2008.8497	311	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1631	14.2994
+9018	2008.8525	312	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1612	14.2972
+9019	2008.8552	313	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1592	14.2950
+9020	2008.8579	314	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1572	14.2927
+9021	2008.8607	315	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1552	14.2905
+9022	2008.8634	316	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1531	14.2883
+9023	2008.8661	317	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1510	14.2860
+9024	2008.8689	318	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1488	14.2838
+9025	2008.8716	319	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1466	14.2816
+9026	2008.8743	320	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1444	14.2794
+9027	2008.8770	321	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1422	14.2772
+9028	2008.8798	322	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1399	14.2750
+9029	2008.8825	323	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1376	14.2728
+9030	2008.8852	324	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1353	14.2706
+9031	2008.8880	325	1.2182	0.6400	0.9030	1.0820	8.2090	14.6950	8.1329	14.2684
+9032	2008.8907	326	1.2182	0.6399	0.9030	1.0820	8.2090	14.6950	8.1305	14.2662
+9033	2008.8934	327	1.2182	0.6399	0.9030	1.0820	8.2090	14.6950	8.1281	14.2640
+9034	2008.8962	328	1.2182	0.6399	0.9030	1.0820	8.2090	14.6950	8.1257	14.2618
+9035	2008.8989	329	1.2182	0.6399	0.9030	1.0820	8.2090	14.6950	8.1232	14.2596
+9036	2008.9016	330	1.2182	0.6399	0.9030	1.0820	8.2090	14.6950	8.1207	14.2574
+9037	2008.9044	331	1.2182	0.6399	0.9030	1.0820	8.2090	14.6950	8.1182	14.2553
+9038	2008.9071	332	1.2182	0.6399	0.9030	1.0820	8.2090	14.6950	8.1157	14.2531
+9039	2008.9098	333	1.2182	0.6399	0.9030	1.0820	8.2090	14.6950	8.1131	14.2509
+9040	2008.9126	334	1.2182	0.6399	0.9030	1.0820	8.2090	14.6950	8.1106	14.2488
+9041	2008.9153	335	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.1080	14.2467
+9042	2008.9180	336	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.1054	14.2445
+9043	2008.9208	337	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.1028	14.2424
+9044	2008.9235	338	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.1001	14.2403
+9045	2008.9262	339	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0975	14.2382
+9046	2008.9290	340	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0948	14.2360
+9047	2008.9317	341	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0921	14.2339
+9048	2008.9344	342	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0894	14.2319
+9049	2008.9372	343	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0867	14.2298
+9050	2008.9399	344	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0840	14.2277
+9051	2008.9426	345	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0812	14.2256
+9052	2008.9454	346	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0785	14.2236
+9053	2008.9481	347	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0757	14.2215
+9054	2008.9508	348	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0730	14.2195
+9055	2008.9536	349	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0702	14.2175
+9056	2008.9563	350	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0674	14.2154
+9057	2008.9590	351	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0647	14.2134
+9058	2008.9617	352	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0619	14.2114
+9059	2008.9645	353	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0591	14.2095
+9060	2008.9672	354	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0563	14.2075
+9061	2008.9699	355	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0535	14.2055
+9062	2008.9727	356	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0507	14.2036
+9063	2008.9754	357	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0479	14.2016
+9064	2008.9781	358	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0451	14.1997
+9065	2008.9809	359	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0423	14.1978
+9066	2008.9836	360	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0396	14.1959
+9067	2008.9863	361	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0368	14.1940
+9068	2008.9891	362	1.2181	0.6399	0.9030	1.0820	8.2090	14.6950	8.0340	14.1921
+9069	2008.9918	363	1.2181	0.6398	0.9030	1.0820	8.2090	14.6950	8.0312	14.1902
+9070	2008.9945	364	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	8.0285	14.1884
+9071	2008.9973	365	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	8.0257	14.1865
+9072	2008.9999	366	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	8.0229	14.1847
+9073	2009.0027	1	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	8.0202	14.1829
+9074	2009.0055	2	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	8.0175	14.1811
+9075	2009.0082	3	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	8.0147	14.1793
+9076	2009.0110	4	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	8.0120	14.1775
+9077	2009.0137	5	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	8.0093	14.1757
+9078	2009.0164	6	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	8.0066	14.1740
+9079	2009.0192	7	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	8.0040	14.1722
+9080	2009.0219	8	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	8.0013	14.1705
+9081	2009.0247	9	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9987	14.1688
+9082	2009.0274	10	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9960	14.1671
+9083	2009.0301	11	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9934	14.1655
+9084	2009.0329	12	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9908	14.1638
+9085	2009.0356	13	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9882	14.1622
+9086	2009.0384	14	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9857	14.1605
+9087	2009.0411	15	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9831	14.1589
+9088	2009.0438	16	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9806	14.1573
+9089	2009.0466	17	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9781	14.1557
+9090	2009.0493	18	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9756	14.1542
+9091	2009.0521	19	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9732	14.1526
+9092	2009.0548	20	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9708	14.1511
+9093	2009.0575	21	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9684	14.1496
+9094	2009.0603	22	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9660	14.1481
+9095	2009.0630	23	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9636	14.1466
+9096	2009.0658	24	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9613	14.1451
+9097	2009.0685	25	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9590	14.1437
+9098	2009.0712	26	1.2180	0.6398	0.9030	1.0820	8.2090	14.6950	7.9567	14.1423
+9099	2009.0740	27	1.2179	0.6398	0.9030	1.0820	8.2090	14.6950	7.9545	14.1408
+9100	2009.0767	28	1.2179	0.6398	0.9030	1.0820	8.2090	14.6950	7.9523	14.1394
+9101	2009.0795	29	1.2179	0.6398	0.9030	1.0820	8.2090	14.6950	7.9501	14.1381
+9102	2009.0822	30	1.2179	0.6398	0.9030	1.0820	8.2090	14.6950	7.9479	14.1367
+9103	2009.0849	31	1.2179	0.6398	0.9030	1.0820	8.2090	14.6950	7.9458	14.1354
+9104	2009.0877	32	1.2179	0.6398	0.9030	1.0820	8.2090	14.6950	7.9437	14.1340
+9105	2009.0904	33	1.2179	0.6398	0.9030	1.0820	8.2090	14.6950	7.9416	14.1327
+9106	2009.0932	34	1.2179	0.6398	0.9030	1.0820	8.2090	14.6950	7.9396	14.1315
+9107	2009.0959	35	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9376	14.1302
+9108	2009.0986	36	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9356	14.1289
+9109	2009.1014	37	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9337	14.1277
+9110	2009.1041	38	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9318	14.1265
+9111	2009.1068	39	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9299	14.1253
+9112	2009.1096	40	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9281	14.1241
+9113	2009.1123	41	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9263	14.1230
+9114	2009.1151	42	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9246	14.1218
+9115	2009.1178	43	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9228	14.1207
+9116	2009.1205	44	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9212	14.1196
+9117	2009.1233	45	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9195	14.1185
+9118	2009.1260	46	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9179	14.1175
+9119	2009.1288	47	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9163	14.1164
+9120	2009.1315	48	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9148	14.1154
+9121	2009.1342	49	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9133	14.1144
+9122	2009.1370	50	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9119	14.1134
+9123	2009.1397	51	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9105	14.1125
+9124	2009.1425	52	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9091	14.1115
+9125	2009.1452	53	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9078	14.1106
+9126	2009.1479	54	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9065	14.1097
+9127	2009.1507	55	1.2179	0.6397	0.9030	1.0820	8.2090	14.6950	7.9053	14.1088
+9128	2009.1534	56	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.9041	14.1080
+9129	2009.1562	57	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.9029	14.1071
+9130	2009.1589	58	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.9018	14.1063
+9131	2009.1616	59	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.9007	14.1055
+9132	2009.1644	60	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.8997	14.1047
+9133	2009.1671	61	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.8987	14.1040
+9134	2009.1699	62	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.8978	14.1032
+9135	2009.1726	63	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.8969	14.1025
+9136	2009.1753	64	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.8960	14.1018
+9137	2009.1781	65	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.8952	14.1011
+9138	2009.1808	66	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.8945	14.1005
+9139	2009.1836	67	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.8937	14.0999
+9140	2009.1863	68	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.8931	14.0992
+9141	2009.1890	69	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.8924	14.0987
+9142	2009.1918	70	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.8918	14.0981
+9143	2009.1945	71	1.2178	0.6397	0.9030	1.0820	8.2090	14.6950	7.8913	14.0975
+9144	2009.1973	72	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8908	14.0970
+9145	2009.2000	73	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8904	14.0965
+9146	2009.2027	74	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8900	14.0960
+9147	2009.2055	75	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8896	14.0955
+9148	2009.2082	76	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8893	14.0951
+9149	2009.2110	77	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8890	14.0947
+9150	2009.2137	78	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8888	14.0942
+9151	2009.2164	79	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8886	14.0939
+9152	2009.2192	80	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8885	14.0935
+9153	2009.2219	81	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8884	14.0932
+9154	2009.2247	82	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8884	14.0928
+9155	2009.2274	83	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8884	14.0925
+9156	2009.2301	84	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8885	14.0922
+9157	2009.2329	85	1.2178	0.6396	0.9030	1.0820	8.2090	14.6950	7.8886	14.0920
+9158	2009.2356	86	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8887	14.0917
+9159	2009.2384	87	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8889	14.0915
+9160	2009.2411	88	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8891	14.0913
+9161	2009.2438	89	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8894	14.0912
+9162	2009.2466	90	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8897	14.0910
+9163	2009.2493	91	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8901	14.0909
+9164	2009.2521	92	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8905	14.0907
+9165	2009.2548	93	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8910	14.0907
+9166	2009.2575	94	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8915	14.0906
+9167	2009.2603	95	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8921	14.0905
+9168	2009.2630	96	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8927	14.0905
+9169	2009.2658	97	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8933	14.0905
+9170	2009.2685	98	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8940	14.0905
+9171	2009.2712	99	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8947	14.0905
+9172	2009.2740	100	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8955	14.0906
+9173	2009.2767	101	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8963	14.0906
+9174	2009.2795	102	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8971	14.0907
+9175	2009.2822	103	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8980	14.0908
+9176	2009.2849	104	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.8990	14.0910
+9177	2009.2877	105	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.9000	14.0911
+9178	2009.2904	106	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.9010	14.0913
+9179	2009.2932	107	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.9021	14.0915
+9180	2009.2959	108	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.9032	14.0917
+9181	2009.2986	109	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.9043	14.0919
+9182	2009.3014	110	1.2177	0.6396	0.9030	1.0820	8.2090	14.6950	7.9055	14.0922
+9183	2009.3041	111	1.2177	0.6395	0.9030	1.0820	8.2090	14.6950	7.9067	14.0924
+9184	2009.3068	112	1.2177	0.6395	0.9030	1.0820	8.2090	14.6950	7.9080	14.0927
+9185	2009.3096	113	1.2177	0.6395	0.9030	1.0820	8.2090	14.6950	7.9093	14.0930
+9186	2009.3123	114	1.2177	0.6395	0.9030	1.0820	8.2090	14.6950	7.9107	14.0933
+9187	2009.3151	115	1.2177	0.6395	0.9030	1.0820	8.2090	14.6950	7.9120	14.0937
+9188	2009.3178	116	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9135	14.0941
+9189	2009.3205	117	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9149	14.0944
+9190	2009.3233	118	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9164	14.0948
+9191	2009.3260	119	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9179	14.0953
+9192	2009.3288	120	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9195	14.0957
+9193	2009.3315	121	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9211	14.0962
+9194	2009.3342	122	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9228	14.0966
+9195	2009.3370	123	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9244	14.0971
+9196	2009.3397	124	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9261	14.0977
+9197	2009.3425	125	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9279	14.0982
+9198	2009.3452	126	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9296	14.0987
+9199	2009.3479	127	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9315	14.0993
+9200	2009.3507	128	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9333	14.0999
+9201	2009.3534	129	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9352	14.1005
+9202	2009.3562	130	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9371	14.1011
+9203	2009.3589	131	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9390	14.1018
+9204	2009.3616	132	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9409	14.1024
+9205	2009.3644	133	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9429	14.1031
+9206	2009.3671	134	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9450	14.1038
+9207	2009.3699	135	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9470	14.1045
+9208	2009.3726	136	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9491	14.1052
+9209	2009.3753	137	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9512	14.1060
+9210	2009.3781	138	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9533	14.1067
+9211	2009.3808	139	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9554	14.1075
+9212	2009.3836	140	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9576	14.1083
+9213	2009.3863	141	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9598	14.1091
+9214	2009.3890	142	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9620	14.1099
+9215	2009.3918	143	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9643	14.1108
+9216	2009.3945	144	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9665	14.1116
+9217	2009.3973	145	1.2176	0.6395	0.9030	1.0820	8.2090	14.6950	7.9688	14.1125
+9218	2009.4000	146	1.2175	0.6395	0.9030	1.0820	8.2090	14.6950	7.9711	14.1134
+9219	2009.4027	147	1.2175	0.6395	0.9030	1.0820	8.2090	14.6950	7.9735	14.1143
+9220	2009.4055	148	1.2175	0.6395	0.9030	1.0820	8.2090	14.6950	7.9758	14.1152
+9221	2009.4082	149	1.2175	0.6395	0.9030	1.0820	8.2090	14.6950	7.9782	14.1162
+9222	2009.4110	150	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	7.9805	14.1171
+9223	2009.4137	151	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	7.9829	14.1181
+9224	2009.4164	152	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	7.9854	14.1190
+9225	2009.4192	153	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	7.9878	14.1200
+9226	2009.4219	154	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	7.9902	14.1210
+9227	2009.4247	155	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	7.9927	14.1221
+9228	2009.4274	156	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	7.9951	14.1231
+9229	2009.4301	157	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	7.9976	14.1242
+9230	2009.4329	158	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0001	14.1252
+9231	2009.4356	159	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0026	14.1263
+9232	2009.4384	160	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0051	14.1274
+9233	2009.4411	161	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0077	14.1285
+9234	2009.4438	162	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0102	14.1296
+9235	2009.4466	163	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0127	14.1307
+9236	2009.4493	164	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0153	14.1319
+9237	2009.4521	165	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0178	14.1330
+9238	2009.4548	166	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0204	14.1342
+9239	2009.4575	167	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0229	14.1354
+9240	2009.4603	168	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0255	14.1366
+9241	2009.4630	169	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0281	14.1378
+9242	2009.4658	170	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0306	14.1390
+9243	2009.4685	171	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0332	14.1402
+9244	2009.4712	172	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0358	14.1414
+9245	2009.4740	173	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0383	14.1427
+9246	2009.4767	174	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0409	14.1439
+9247	2009.4795	175	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0435	14.1452
+9248	2009.4822	176	1.2175	0.6394	0.9030	1.0820	8.2090	14.6950	8.0460	14.1465
+9249	2009.4849	177	1.2174	0.6394	0.9030	1.0820	8.2090	14.6950	8.0486	14.1477
+9250	2009.4877	178	1.2174	0.6394	0.9030	1.0820	8.2090	14.6950	8.0511	14.1490
+9251	2009.4904	179	1.2174	0.6394	0.9030	1.0820	8.2090	14.6950	8.0537	14.1503
+9252	2009.4932	180	1.2174	0.6394	0.9030	1.0820	8.2090	14.6950	8.0562	14.1517
+9253	2009.4959	181	1.2174	0.6394	0.9030	1.0820	8.2090	14.6950	8.0587	14.1530
+9254	2009.4986	182	1.2174	0.6394	0.9030	1.0820	8.2090	14.6950	8.0613	14.1543
+9255	2009.5014	183	1.2174	0.6394	0.9030	1.0820	8.2090	14.6950	8.0638	14.1557
+9256	2009.5041	184	1.2174	0.6394	0.9030	1.0820	8.2090	14.6950	8.0663	14.1570
+9257	2009.5068	185	1.2174	0.6394	0.9030	1.0820	8.2090	14.6950	8.0688	14.1584
+9258	2009.5096	186	1.2174	0.6394	0.9030	1.0820	8.2090	14.6950	8.0713	14.1597
+9259	2009.5123	187	1.2174	0.6394	0.9030	1.0820	8.2090	14.6950	8.0737	14.1611
+9260	2009.5151	188	1.2174	0.6394	0.9030	1.0820	8.2090	14.6950	8.0762	14.1625
+9261	2009.5178	189	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.0786	14.1639
+9262	2009.5205	190	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.0811	14.1653
+9263	2009.5233	191	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.0835	14.1667
+9264	2009.5260	192	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.0859	14.1681
+9265	2009.5288	193	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.0883	14.1695
+9266	2009.5315	194	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.0906	14.1709
+9267	2009.5342	195	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.0930	14.1724
+9268	2009.5370	196	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.0953	14.1738
+9269	2009.5397	197	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.0976	14.1752
+9270	2009.5425	198	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.0999	14.1767
+9271	2009.5452	199	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.1022	14.1781
+9272	2009.5479	200	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.1044	14.1796
+9273	2009.5507	201	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.1066	14.1811
+9274	2009.5534	202	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.1088	14.1825
+9275	2009.5562	203	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.1110	14.1840
+9276	2009.5589	204	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.1131	14.1855
+9277	2009.5616	205	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.1152	14.1870
+9278	2009.5644	206	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.1173	14.1885
+9279	2009.5671	207	1.2174	0.6393	0.9030	1.0820	8.2090	14.6950	8.1194	14.1899
+9280	2009.5699	208	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1214	14.1914
+9281	2009.5726	209	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1234	14.1929
+9282	2009.5753	210	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1254	14.1944
+9283	2009.5781	211	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1274	14.1959
+9284	2009.5808	212	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1293	14.1974
+9285	2009.5836	213	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1312	14.1989
+9286	2009.5863	214	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1330	14.2004
+9287	2009.5890	215	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1349	14.2019
+9288	2009.5918	216	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1366	14.2035
+9289	2009.5945	217	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1384	14.2050
+9290	2009.5973	218	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1401	14.2065
+9291	2009.6000	219	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1418	14.2080
+9292	2009.6027	220	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1435	14.2095
+9293	2009.6055	221	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1451	14.2110
+9294	2009.6082	222	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1466	14.2125
+9295	2009.6110	223	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1482	14.2141
+9296	2009.6137	224	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1497	14.2156
+9297	2009.6164	225	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1511	14.2171
+9298	2009.6192	226	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1526	14.2186
+9299	2009.6219	227	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1540	14.2201
+9300	2009.6247	228	1.2173	0.6393	0.9030	1.0820	8.2090	14.6950	8.1553	14.2216
+9301	2009.6274	229	1.2173	0.6392	0.9030	1.0820	8.2090	14.6950	8.1566	14.2231
+9302	2009.6301	230	1.2173	0.6392	0.9030	1.0820	8.2090	14.6950	8.1579	14.2246
+9303	2009.6329	231	1.2173	0.6392	0.9030	1.0820	8.2090	14.6950	8.1591	14.2261
+9304	2009.6356	232	1.2173	0.6392	0.9030	1.0820	8.2090	14.6950	8.1603	14.2276
+9305	2009.6384	233	1.2173	0.6392	0.9030	1.0820	8.2090	14.6950	8.1614	14.2291
+9306	2009.6411	234	1.2173	0.6392	0.9030	1.0820	8.2090	14.6950	8.1625	14.2306
+9307	2009.6438	235	1.2173	0.6392	0.9030	1.0820	8.2090	14.6950	8.1636	14.2321
+9308	2009.6466	236	1.2173	0.6392	0.9030	1.0820	8.2090	14.6950	8.1646	14.2336
+9309	2009.6493	237	1.2173	0.6392	0.9030	1.0820	8.2090	14.6950	8.1655	14.2351
+9310	2009.6521	238	1.2173	0.6392	0.9030	1.0820	8.2090	14.6950	8.1665	14.2366
+9311	2009.6548	239	1.2173	0.6392	0.9030	1.0820	8.2090	14.6950	8.1673	14.2381
+9312	2009.6575	240	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1682	14.2396
+9313	2009.6603	241	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1690	14.2410
+9314	2009.6630	242	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1697	14.2425
+9315	2009.6658	243	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1704	14.2440
+9316	2009.6685	244	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1711	14.2454
+9317	2009.6712	245	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1717	14.2469
+9318	2009.6740	246	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1722	14.2483
+9319	2009.6767	247	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1728	14.2498
+9320	2009.6795	248	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1732	14.2512
+9321	2009.6822	249	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1737	14.2526
+9322	2009.6849	250	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1740	14.2541
+9323	2009.6877	251	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1744	14.2555
+9324	2009.6904	252	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1747	14.2569
+9325	2009.6932	253	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1749	14.2583
+9326	2009.6959	254	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1751	14.2597
+9327	2009.6986	255	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1752	14.2611
+9328	2009.7014	256	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1753	14.2625
+9329	2009.7041	257	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1754	14.2638
+9330	2009.7068	258	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1754	14.2652
+9331	2009.7096	259	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1753	14.2666
+9332	2009.7123	260	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1752	14.2679
+9333	2009.7151	261	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1751	14.2693
+9334	2009.7178	262	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1749	14.2706
+9335	2009.7205	263	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1747	14.2719
+9336	2009.7233	264	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1744	14.2732
+9337	2009.7260	265	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1740	14.2745
+9338	2009.7288	266	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1737	14.2758
+9339	2009.7315	267	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1732	14.2771
+9340	2009.7342	268	1.2172	0.6392	0.9030	1.0820	8.2090	14.6950	8.1728	14.2784
+9341	2009.7370	269	1.2172	0.6391	0.9030	1.0820	8.2090	14.6950	8.1723	14.2797
+9342	2009.7397	270	1.2172	0.6391	0.9030	1.0820	8.2090	14.6950	8.1717	14.2809
+9343	2009.7425	271	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1711	14.2822
+9344	2009.7452	272	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1704	14.2834
+9345	2009.7479	273	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1697	14.2846
+9346	2009.7507	274	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1690	14.2858
+9347	2009.7534	275	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1682	14.2870
+9348	2009.7562	276	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1674	14.2882
+9349	2009.7589	277	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1665	14.2894
+9350	2009.7616	278	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1655	14.2906
+9351	2009.7644	279	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1646	14.2917
+9352	2009.7671	280	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1636	14.2929
+9353	2009.7699	281	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1625	14.2940
+9354	2009.7726	282	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1614	14.2951
+9355	2009.7753	283	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1603	14.2962
+9356	2009.7781	284	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1591	14.2973
+9357	2009.7808	285	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1578	14.2984
+9358	2009.7836	286	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1566	14.2994
+9359	2009.7863	287	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1553	14.3005
+9360	2009.7890	288	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1539	14.3015
+9361	2009.7918	289	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1525	14.3025
+9362	2009.7945	290	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1511	14.3035
+9363	2009.7973	291	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1496	14.3045
+9364	2009.8000	292	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1481	14.3055
+9365	2009.8027	293	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1466	14.3065
+9366	2009.8055	294	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1450	14.3074
+9367	2009.8082	295	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1433	14.3084
+9368	2009.8110	296	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1417	14.3093
+9369	2009.8137	297	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1400	14.3102
+9370	2009.8164	298	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1382	14.3111
+9371	2009.8192	299	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1365	14.3120
+9372	2009.8219	300	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1347	14.3128
+9373	2009.8247	301	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1328	14.3137
+9374	2009.8274	302	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1309	14.3145
+9375	2009.8301	303	1.2171	0.6391	0.9030	1.0820	8.2090	14.6950	8.1290	14.3153
+9376	2009.8329	304	1.2170	0.6391	0.9030	1.0820	8.2090	14.6950	8.1271	14.3161
+9377	2009.8356	305	1.2170	0.6391	0.9030	1.0820	8.2090	14.6950	8.1251	14.3169
+9378	2009.8384	306	1.2170	0.6391	0.9030	1.0820	8.2090	14.6950	8.1231	14.3176
+9379	2009.8411	307	1.2170	0.6391	0.9030	1.0820	8.2090	14.6950	8.1211	14.3184
+9380	2009.8438	308	1.2170	0.6391	0.9030	1.0820	8.2090	14.6950	8.1190	14.3191
+9381	2009.8466	309	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.1169	14.3198
+9382	2009.8493	310	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.1148	14.3205
+9383	2009.8521	311	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.1127	14.3212
+9384	2009.8548	312	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.1105	14.3218
+9385	2009.8575	313	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.1083	14.3225
+9386	2009.8603	314	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.1061	14.3231
+9387	2009.8630	315	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.1038	14.3237
+9388	2009.8658	316	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.1015	14.3243
+9389	2009.8685	317	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0992	14.3249
+9390	2009.8712	318	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0969	14.3254
+9391	2009.8740	319	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0946	14.3260
+9392	2009.8767	320	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0922	14.3265
+9393	2009.8795	321	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0898	14.3270
+9394	2009.8822	322	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0874	14.3274
+9395	2009.8849	323	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0850	14.3279
+9396	2009.8877	324	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0825	14.3284
+9397	2009.8904	325	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0800	14.3288
+9398	2009.8932	326	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0776	14.3292
+9399	2009.8959	327	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0751	14.3296
+9400	2009.8986	328	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0725	14.3299
+9401	2009.9014	329	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0700	14.3303
+9402	2009.9041	330	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0675	14.3306
+9403	2009.9068	331	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0649	14.3309
+9404	2009.9096	332	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0623	14.3312
+9405	2009.9123	333	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0598	14.3315
+9406	2009.9151	334	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0572	14.3318
+9407	2009.9178	335	1.2170	0.6390	0.9030	1.0820	8.2090	14.6950	8.0546	14.3320
+9408	2009.9205	336	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0519	14.3322
+9409	2009.9233	337	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0493	14.3324
+9410	2009.9260	338	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0467	14.3326
+9411	2009.9288	339	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0441	14.3327
+9412	2009.9315	340	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0414	14.3329
+9413	2009.9342	341	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0388	14.3330
+9414	2009.9370	342	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0361	14.3331
+9415	2009.9397	343	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0334	14.3332
+9416	2009.9425	344	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0308	14.3332
+9417	2009.9452	345	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0281	14.3332
+9418	2009.9479	346	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0255	14.3333
+9419	2009.9507	347	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0228	14.3333
+9420	2009.9534	348	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0201	14.3332
+9421	2009.9562	349	1.2169	0.6390	0.9030	1.0820	8.2090	14.6950	8.0175	14.3332
+9422	2009.9589	350	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	8.0148	14.3331
+9423	2009.9616	351	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	8.0121	14.3330
+9424	2009.9644	352	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	8.0095	14.3329
+9425	2009.9671	353	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	8.0068	14.3328
+9426	2009.9699	354	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	8.0042	14.3327
+9427	2009.9726	355	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	8.0015	14.3325
+9428	2009.9753	356	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	7.9989	14.3323
+9429	2009.9781	357	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	7.9962	14.3321
+9430	2009.9808	358	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	7.9936	14.3319
+9431	2009.9836	359	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	7.9910	14.3317
+9432	2009.9863	360	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	7.9884	14.3314
+9433	2009.9890	361	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	7.9858	14.3311
+9434	2009.9918	362	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	7.9832	14.3308
+9435	2009.9945	363	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	7.9806	14.3305
+9436	2009.9973	364	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	7.9780	14.3301
+9437	2009.9999	365	1.2169	0.6389	0.9030	1.0820	8.2090	14.6950	7.9755	14.3298
Added: grass-addons/gipe/i.dn2full.l5/tempk_landsat5.c
--- grass-addons/gipe/i.dn2full.l5/tempk_landsat5.c	                        (rev 0)
+++ grass-addons/gipe/i.dn2full.l5/tempk_landsat5.c	2008-04-02 03:59:42 UTC (rev 30840)
@@ -0,0 +1,16 @@
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+// Surface temperature for Landsat 5TM
+// Schneider and Mauser, 1996
+double tempk_landsat5( double l6 )
+	double	result;
+	result = 1260.56 / (log ((607.76 / (l6)) + 1.0)) ;
+	return result;
