[GRASS-SVN] r30847 - grass-addons/vector/v.strahler
svn_grass at osgeo.org
Wed Apr 2 13:13:11 EDT 2008
Author: annalisapg
Date: 2008-04-02 13:13:11 -0400 (Wed, 02 Apr 2008)
New Revision: 30847
grass-addons/vector/v.strahler/r.broscoe.sh
Updated1
Modified: grass-addons/vector/v.strahler/r.broscoe.sh
--- grass-addons/vector/v.strahler/r.broscoe.sh 2008-04-02 17:03:30 UTC (rev 30846)
+++ grass-addons/vector/v.strahler/r.broscoe.sh 2008-04-02 17:13:11 UTC (rev 30847)
@@ -107,7 +107,7 @@
echo "initializing statistics for threshold value=$j"
-r.strahler dem=$dem xcoor=$xcoor ycoor=$ycoor thr=$j output=ordered_$j textoutput=orderedtxt_$j --overwrite
+r.strahler.sh dem=$dem xcoor=$xcoor ycoor=$ycoor thr=$j output=ordered_$j textoutput=orderedtxt_$j --overwrite
rm one
rm two
@@ -151,7 +151,9 @@
v.rast.stats vector=ord1_pl_3d_cat raster=$dem colprefix=stats percentile=90 --verbose -c
- for i in `db.select table=ord1_pl_3d_cat database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ driver=dbf 'sql=select cat from ord1_pl_3d_cat' | sed 1d`
+ db_driver=`db.connect -p | grep driver | cut -f2 -d':'`
+ db_database=`db.connect -p | grep database | cut -f2 -d':'`
+ for i in `db.select table=ord1_pl_3d_cat database=$db_database driver=$db_driver 'sql=select cat from ord1_pl_3d_cat' | sed 1d`
do
min=`echo "select stats_min from ord1_pl_3d_cat where cat=$i" | db.select | sed 1d`
