[GRASS-SVN] r30853 - grass/trunk/gui/wxpython/vdigit
Thu Apr 3 10:54:19 EDT 2008
Author: martinl
Date: 2008-04-03 10:54:19 -0400 (Thu, 03 Apr 2008)
New Revision: 30853
   grass/trunk/gui/wxpython/vdigit/cats.cpp
   grass/trunk/gui/wxpython/vdigit/digit.h
   grass/trunk/gui/wxpython/vdigit/line.cpp
   grass/trunk/gui/wxpython/vdigit/undo.cpp
   grass/trunk/gui/wxpython/vdigit/vertex.cpp
wxGUI (vdigit): undo updated for selected tools (rewrite line)
Modified: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp	2008-04-03 12:45:00 UTC (rev 30852)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp	2008-04-03 14:54:19 UTC (rev 30853)
@@ -256,8 +256,20 @@
 		layer, *c, add);
+    /* register changeset */
+    AddActionToChangeset(changesets.size(), REWRITE, display->selected->value[0]);
     ret = Vect_rewrite_line(display->mapInfo, line, type,
 			    Points, Cats);
+    if (ret > 0) {
+	/* updates feature id (id is changed since line has been rewriten) */
+	changesets[changesets.size()-1][0].line = ret;
+    else {
+	changesets.erase(changesets.size()-1);
     if (line_id == -1) {
 	/* update line id since the line was rewritten */
 	display->selected->value[0] = ret;
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h	2008-04-03 12:45:00 UTC (rev 30852)
+++ grass/trunk/gui/wxpython/vdigit/digit.h	2008-04-03 14:54:19 UTC (rev 30853)
@@ -18,7 +18,7 @@
     struct Map_info** OpenBackgroundVectorMap(const char *);
     /* undo/redo */
-    enum action_type { ADD, DELETE };
+    enum action_type { ADD, DELETE, REWRITE };
     struct action_meta {
 	action_type type;
 	int line;
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp	2008-04-03 12:45:00 UTC (rev 30852)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp	2008-04-03 14:54:19 UTC (rev 30853)
@@ -214,13 +214,22 @@
 			threshold, (snap == SNAP) ? 0 : 1);
+    AddActionToChangeset(changesets.size(), REWRITE, line);
     /* rewrite line */
     if (ret == 0) {
-	if (Vect_rewrite_line(display->mapInfo, line, type, points, cats) < 0) {
-	    ret = -1;
+	ret = Vect_rewrite_line(display->mapInfo, line, type, points, cats);
+    if (ret > 0) {
+	changesets[changesets.size()-1][0].line = Vect_get_num_lines(display->mapInfo);
+    else {
     Vect_destroy_line_struct(points);
     Vect_destroy_cats_struct(cats);
@@ -238,22 +247,39 @@
    \param x,y,z coordinates (z is used only if map is 3d)
    \param thresh threshold value to find a point on line
+   \return number of modified lines
+   \return -1 on error
 int Digit::SplitLine(double x, double y, double z,
 		     double thresh)
-    int ret;
+    int ret, changeset;
     struct line_pnts *point;
+    struct ilist *list;
     if (!display->mapInfo)
 	return -1;
     point = Vect_new_line_struct();
+    list  = Vect_new_list();
     Vect_append_point(point, x, y, z);
+    changeset = changesets.size();
+    for (int i = 0; i < display->selected->n_values; i++) {
+	AddActionToChangeset(changeset, DELETE, display->selected->value[i]);
     ret = Vedit_split_lines(display->mapInfo, display->selected,
-			    point, thresh, NULL);
+			    point, thresh, list);
+    for (int i = 0; i < list->n_values; i++) {
+	AddActionToChangeset(changeset, ADD, list->value[i]);
+    Vect_destroy_list(list);
     Vect_destroy_line_struct(point);
     return ret;
@@ -407,7 +433,8 @@
 int Digit::MoveLines(double move_x, double move_y, double move_z,
 		     const char *bgmap, int snap, double thresh)
-    int ret;
+    long int nlines;
     struct Map_info **BgMap; /* backgroud vector maps */
     int nbgmaps;             /* number of registrated background maps */
@@ -426,11 +453,27 @@
+	AddActionToChangeset(changeset, REWRITE, display->selected->value[i]);
+    nlines = Vect_get_num_lines(display->mapInfo);
     ret = Vedit_move_lines(display->mapInfo, BgMap, nbgmaps,
 			   display->selected,
 			   move_x, move_y, move_z,
 			   snap, thresh);
+    if (ret > 0) {
+	    changesets[changeset][i].line = nlines + i + 1;
+    else {
+	changesets.erase(changeset);
     if (BgMap && BgMap[0]) {
 	Vect_close(BgMap[0]);
@@ -446,14 +489,31 @@
 int Digit::FlipLines()
-    int ret;
+    long int nlines;
     if (!display->mapInfo) {
 	return -1;
     ret = Vedit_flip_lines(display->mapInfo, display->selected);
+    if (ret > 0) {
+    else {
     return ret;
@@ -575,7 +635,8 @@
 int Digit::CopyLines(std::vector<int> ids, const char* bgmap_name)
-    int ret;
+    long int nlines;
     struct Map_info *bgMap;
     struct ilist *list;
@@ -586,7 +647,6 @@
 	return -1;
     if (bgmap_name) {
 	const char *mapset;
 	bgMap = (struct Map_info *) G_malloc(sizeof (struct Map_info));
@@ -605,9 +665,19 @@
 	list = display->selected;
     ret = Vedit_copy_lines (display->mapInfo, bgMap,
 			    list);
+    if (ret > 0) {
+	    AddActionToChangeset(changeset, ADD, nlines + i + 1);
     if (list != display->selected) {
Modified: grass/trunk/gui/wxpython/vdigit/undo.cpp
--- grass/trunk/gui/wxpython/vdigit/undo.cpp	2008-04-03 12:45:00 UTC (rev 30852)
+++ grass/trunk/gui/wxpython/vdigit/undo.cpp	2008-04-03 14:54:19 UTC (rev 30853)
@@ -72,7 +72,7 @@
    \brief Apply changeset (undo/redo changeset)
    \param changeset changeset id
    \param undo if true -> undo otherwise redo
@@ -105,6 +105,18 @@
 			changeset, (*i).line);
+	else if ((*i).type == REWRITE) {
+	    if (Vect_line_alive(display->mapInfo, (*i).line)) {
+		G_debug(3, "Digit.ApplyChangeset(): changeset=%d, action=rewrite, line=%d",
+			changeset, (*i).line);
+		if (Vect_rewrite_line (display->mapInfo, (*i).line, (*i).ltype, (*i).Points, (*i).Cats) < 0)
+		    return -1;
+	    else {
+		G_debug(3, "Digit.ApplyChangeset(): changeset=%d, action=rewrite, line=%d -> dead",
 	else { /* DELETE */
 	    if (!Vect_line_alive(display->mapInfo, (*i).line)) {
 		G_debug(3, "Digit.ApplyChangeset(): changeset=%d, action=delete, line=%d -> added",
Modified: grass/trunk/gui/wxpython/vdigit/vertex.cpp
--- grass/trunk/gui/wxpython/vdigit/vertex.cpp	2008-04-03 12:45:00 UTC (rev 30852)
+++ grass/trunk/gui/wxpython/vdigit/vertex.cpp	2008-04-03 14:54:19 UTC (rev 30853)
@@ -47,6 +47,9 @@
 	return -1;
+    if (display->selected->n_values != 1)
+	return 0;
     BgMap = NULL;
     nbgmaps = 0;
     if (bgmap && strlen(bgmap) > 0) {
@@ -62,6 +65,9 @@
     /* move only first found vertex in bbox */
     ret = Vedit_move_vertex(display->mapInfo, BgMap, nbgmaps,
 			    display->selected,
@@ -69,6 +75,14 @@
 			    1, snap);
+    if (ret > 0) {
+    else {
@@ -97,12 +111,18 @@
     int ret;
-    if (!display->mapInfo || display->selected->n_values != 1)
+    if (!display->mapInfo)
 	return -1;
+	return 0;
     if (add) {
 	ret = Vedit_add_vertex(display->mapInfo, display->selected,
 			       point, thresh);
@@ -112,6 +132,14 @@
 				  point, thresh);
+    if (ret > 0) {
+    else {
     return ret;
