[GRASS-SVN] r30855 - in grass-addons/gipe: r.out.vic_met r.out.vic_soil
Thu Apr 3 23:14:38 EDT 2008
Author: ychemin
Date: 2008-04-03 23:14:38 -0400 (Thu, 03 Apr 2008)
New Revision: 30855
   grass-addons/gipe/r.out.vic_met/main.c
   grass-addons/gipe/r.out.vic_soil/main.c
Update
Modified: grass-addons/gipe/r.out.vic_met/main.c
--- grass-addons/gipe/r.out.vic_met/main.c	2008-04-03 15:15:59 UTC (rev 30854)
+++ grass-addons/gipe/r.out.vic_met/main.c	2008-04-04 03:14:38 UTC (rev 30855)
@@ -35,7 +35,8 @@
 	int verbose=1;
 	int not_ll=0;//if proj is not lat/long, it will be 1.
 	struct GModule *module;
-	struct Option *input1, *input2, *input3, *output1;
+	struct Option *input1, *input2, *input3, *input4;
+	struct Option *output1, *output2;
 	struct Flag *flag1;
 	struct History history; //metadata
@@ -48,9 +49,11 @@
 	char 	*tmax_name;// input second time_series raster files names
 	char 	*tmin_name;// input third time_series raster files names
 	char 	*result1; 	//output file base name
+	char 	*result2; 	//output Soil file name
 	char 	result_lat_long[50]; 	//output file name
 	//File Descriptors
 	int 	infd_prcp[MAXFILES], infd_tmax[MAXFILES], infd_tmin[MAXFILES];
+	int	infd;
 	int 	i=0,j=0;
 	double 	xp, yp;
@@ -62,9 +65,11 @@
 	void 			*inrast_prcp[MAXFILES];
 	void 			*inrast_tmax[MAXFILES];
 	void 			*inrast_tmin[MAXFILES];
+	void 			*inrast_elevation;
 	RASTER_MAP_TYPE 	data_type_inrast_prcp[MAXFILES];
 	RASTER_MAP_TYPE 	data_type_inrast_tmax[MAXFILES];
 	RASTER_MAP_TYPE 	data_type_inrast_tmin[MAXFILES];
+	RASTER_MAP_TYPE 	data_type_inrast_elevation;
 	FILE	*f; 		// output ascii file
 	int 	grid_count; 	// grid cell count
@@ -77,13 +82,21 @@
 	int	nfiles1, nfiles2, nfiles3, nfiles_shortest;// count no. input files
 	char	**test1, **test2, **test3; // test number of input files
 	char	**ptr1, **ptr2, **ptr3;	// test number of input files
+	/* Elevation map 			*/
+	char	*in;
+	FILE	*g; 		// output soil ascii file
+	int 	process; 	// process grid cell switch
+	char 	*dummy_data1; 	// dummy data part 1
+	char 	*dummy_data2; 	// dummy data part 2
+	double	elevation;	// average evevation of grid cell
 	G_gisinit(argv[0]);
 	module = G_define_module();
-	module->keywords = _("VIC, hydrology, precipitation, Tmax, Tmin");
-	module->description = _("creates a meteorological ascii file \
-			from 3 time series maps: precipitation, Tmax and Tmin.");
+	module->keywords = _("VIC, hydrology, precipitation, Tmax, Tmin, soil");
+	module->description = _("creates a meteorological ascii file for each non-null cell from 3 time series maps: precipitation, Tmax and Tmin. Also creates a dummy soil file from elevation.");
 	/* Define the different options */
 	input1 = G_define_standard_option(G_OPT_R_INPUT) ;
@@ -101,20 +114,30 @@
 	input3->multiple   = YES;
 	input3->description=_("Names of the Tmin input maps");
-	output1 = G_define_option() ;
+	input4 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input4->key	   = _("dem");
+	input4->description=_("Name of the elevation input map");
+	output1 = G_define_option();
 	output1->key      	=_("output");
 	output1->description	=_("Base Name of the output vic meteorological ascii files");
 	output1->answer     	=_("data_");
+	output2 = G_define_option() ;
+	output2->key        =_("output_soil");
+	output2->description=_("Name of the output vic soil ascii file");
+	output2->answer     =_("vic_soil.asc");
 	flag1 = G_define_flag() ;
 	flag1->key		= 'a';
-	flag1->description	=_("append data if file already exists \
-				(useful if adding additional year of data)");
+	flag1->description	=_("append meteorological data if file already exists (useful if adding additional year of data)");
 	if (G_parser(argc, argv))
 		exit (EXIT_FAILURE);
-	result1 	 	= output1->answer;
+	result1 	= output1->answer;
+	in		= input4->answer;
+	result2 	= output2->answer;
 	/* LOADING TMAX TIME SERIES MAPS 		*/
 	test1 = input1->answers;
@@ -195,6 +218,18 @@
 	} else {
 		nfiles_shortest = nfiles3;
+	/* Load Elevation file				*/
+	mapset = G_find_cell2(in, "");
+	if (mapset == NULL) {
+		G_fatal_error(_("cell file [%s] not found"), in);
+	data_type_inrast_elevation = G_raster_map_type(in,mapset);
+	if ( (infd = G_open_cell_old (in,mapset)) < 0)
+		G_fatal_error (_("Cannot open cell file [%s]"), in);
+	if (G_get_cellhd (in, mapset, &cellhd) < 0)
+		G_fatal_error (_("Cannot read file header of [%s])"), in);
+	inrast_elevation = G_allocate_raster_buf(data_type_inrast_elevation);
 	G_debug(3, "number of rows %d",cellhd.rows);
@@ -229,14 +264,27 @@
 		if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
 			G_fatal_error(_("Unable to set up lat/long projection parameters"));
 	}//End of stolen from r.sun :P
+	/*Initialize grid cell process switch*/
+	g=fopen(result2,"w");
+	/*If =1 then process, if =0 then skip*/
+	process = 1;
 	/*Initialize grid cell count*/
 	grid_count = 1;
+	/*Initialize output file */
+	fprintf(g,"#RUN\tGRID\tLAT\tLNG\tINFILT\tDs\tDs_MAX\tWs\tC\tEXPT_1\tEXPT_2\tEXPT_3\tKsat_1\tKsat_2\tKsat_3\tPHI_1\tPHI_2\tPHI_3\tMOIST_1\tMOIST_2\tMOIST_3\tELEV\tDEPTH_1\tDEPTH_2\tDEPTH_3\tAVG_T\tDP\tBUBLE1\tBUBLE2\tBUBLE3\tQUARZ1\tQUARZ2\tQUARZ3\tBULKDN1\tBULKDN2\tBULKDN3\tPARTDN1\tPARTDN2\tPARTDN3\tOFF_GMT\tWcrFT1\tWcrFT2\tWcrFT3\tWpFT1\tWpFT2\tWpFT3\tZ0_SOIL\tZ0_SNOW\tPRCP\tRESM1\tRESM2\tRESM3\tFS_ACTV\tJULY_TAVG\n");
+	/*Initialize dummy data*/
+	dummy_data1 = "0.010\t1.e-4\t3.05\t0.93\t2\t4.0\t4.0\t4.0\t250.0\t250.0\t250.0\t-999\t-999\t-999\t0.4\t0.4\t0.4";
+	dummy_data2 = "0.1\t6.90\t2.000\t14.0\t4.0\t75.0\t75.0\t75.0\t0.24\t0.24\t0.24\t1306\t1367\t1367\t2650\t2650\t2650\t-6\t0.330\t0.330\t0.330\t0.133\t0.133\t0.133\t0.001\t0.010\t500\t0.02\t0.02\t0.02\t1\t18.665\n";
 	for (row = 0; row < nrows; row++){
 		DCELL d_prcp[MAXFILES];
 		DCELL d_tmax[MAXFILES];
 		DCELL d_tmin[MAXFILES];
+		DCELL d_elevation;
 		G_percent(row,nrows,2);
 		for(i=0;i<nfiles_shortest;i++){
 			if(G_get_raster_row(infd_prcp[i],inrast_prcp[i],row,data_type_inrast_prcp[i])<0)
@@ -246,6 +294,9 @@
 			if(G_get_raster_row(infd_tmin[i],inrast_tmin[i],row,data_type_inrast_tmin[i])<0)
 				G_fatal_error(_("Could not read from tmin<%d>"),i+1);
+		if(G_get_raster_row(infd,inrast_elevation,row,data_type_inrast_elevation)<0)
+			G_fatal_error(_("Could not read from <%s>"),in);
 		for (col=0; col < ncols; col++){
 				/*Extract prcp time series data*/
@@ -285,7 +336,18 @@
 						break;
+			/*Extract elevation data*/
+			switch(data_type_inrast_elevation){
+				case CELL_TYPE:
+					d_elevation = (double) ((CELL *) inrast_elevation)[col];
+					break;
+				case FCELL_TYPE:
+					d_elevation = (double) ((FCELL *) inrast_elevation)[col];
+					break;
+				case DCELL_TYPE:
+					d_elevation = ((DCELL *) inrast_elevation)[col];
+					break;
 			/*Extract lat/long data*/
 			latitude = ymax - ( row * stepy );
 			longitude = xmin + ( col * stepx );
@@ -293,14 +355,17 @@
 				if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
 				    G_fatal_error(_("Error in pj_do_proj"));
+			}else{
+				//Do nothing
 			if(G_is_d_null_value(&prcp[0])||
 			G_is_d_null_value(&d_tmax[0])||
-			G_is_d_null_value(&d_tmin[0])){
+			G_is_d_null_value(&d_tmin[0])||
+			G_is_d_null_value(&d_elevation)){
 				/* Do nothing */
 			} else {
 				/* Make the output .dat file name */
-				sprintf(result_lat_long,"%s%.4f%s%.4f%s",result1,latitude,"_",longitude,".dat");
+				sprintf(result_lat_long,"%s%.4f%s%.4f",result1,latitude,"_",longitude);
 				/*Open new ascii file*/
 				if (flag1->answer){
 					/*Initialize grid cell in append mode*/
@@ -314,11 +379,14 @@
 					fprintf(f,"%.2f  %.2f  %.2f\n", d_prcp[i], d_tmax[i], d_tmin[i]);
 				fclose(f);
+				/*Print to soil ascii file*/
+				fprintf(g,"%d\t%d\t%6.3f\t%7.3f\t%s\t%7.2f\t%s\n", process, grid_count, latitude, longitude, dummy_data1, d_elevation, dummy_data2);
 				grid_count=grid_count+1;
 	G_message(_("Created %d VIC meteorological files"),grid_count);
+	G_message(_("Created %d VIC grid cells soil definitions"),grid_count);
 	for(i=0;i<nfiles1;i++){
 		G_free (inrast_prcp[i]);
 		G_close_cell (infd_prcp[i]);
@@ -331,6 +399,9 @@
 		G_free (inrast_tmin[i]);
 		G_close_cell (infd_tmin[i]);
+	G_free (inrast_elevation);
+	G_close_cell (infd);
+	fclose(g);
 	exit(EXIT_SUCCESS);
Modified: grass-addons/gipe/r.out.vic_soil/main.c
--- grass-addons/gipe/r.out.vic_soil/main.c	2008-04-03 15:15:59 UTC (rev 30854)
+++ grass-addons/gipe/r.out.vic_soil/main.c	2008-04-04 03:14:38 UTC (rev 30855)
@@ -135,6 +135,7 @@
 	/* Set up parameters for projection to lat/long if necessary */
 	if ((G_projection() != PROJECTION_LL)) {
 		not_ll=1;
+		G_message("projection is not Lat/long, converting...");
 		struct Key_Value *in_proj_info, *in_unit_info;
 		if ((in_proj_info = G_get_projinfo()) == NULL)
 			G_fatal_error(_("Can't get projection info of current location"));
@@ -162,7 +163,7 @@
-			longitude = xmin + ( col * stepx );
+			longitude = xmin + ( col * stepx ) ;
 			if(not_ll){
@@ -179,14 +180,19 @@
 					break;
 				case DCELL_TYPE:
-					d_elevation = ((DCELL *) inrast_elevation)[col];
+					d_elevation = (double) ((DCELL *) inrast_elevation)[col];
 					break;
-			/*Print to ascii file*/
-			fprintf(f,"%d\t%d\t%6.3f\t%7.3f\t%s\t%7.2f\t%s\n", process, grid_count, latitude, longitude, dummy_data1, d_elevation, dummy_data2);
-			grid_count=grid_count+1;
+			if(G_is_d_null_value(&d_elevation)){
+				/* Do nothing */
+			} else {
+				/*Print to ascii file*/
+				fprintf(f,"%d\t%d\t%6.3f\t%7.3f\t%s\t%7.2f\t%s\n", process, grid_count, latitude, longitude, dummy_data1, d_elevation, dummy_data2);
+				grid_count=grid_count+1;
+	G_message("Generated soil info for %d grid cells",grid_count);
 	fclose(f);
