[GRASS-SVN] r30870 -
grass/branches/releasebranch_6_3/raster/r.in.mat
svn_grass at osgeo.org
Sat Apr 5 11:06:45 EDT 2008
Author: hamish
Date: 2008-04-05 11:06:45 -0400 (Sat, 05 Apr 2008)
New Revision: 30870
grass/branches/releasebranch_6_3/raster/r.in.mat/main.c
backport fixes from HEAD (including 64bit support- trac bug #22)
Modified: grass/branches/releasebranch_6_3/raster/r.in.mat/main.c
--- grass/branches/releasebranch_6_3/raster/r.in.mat/main.c 2008-04-05 14:57:41 UTC (rev 30869)
+++ grass/branches/releasebranch_6_3/raster/r.in.mat/main.c 2008-04-05 15:06:45 UTC (rev 30870)
@@ -52,20 +52,20 @@
int machine_endianness, file_endianness, endian_mismatch; /* 0=little, 1=big */
int data_format; /* 0=double 1=float 2=32bit signed int 5=8bit unsigned int (ie text) */
int data_type; /* 0=numbers 1=text */
- long format_block; /* combo of endianness, 0, data_format, and type */
- static long realflag = 0; /* 0=only real values used */
+ int format_block; /* combo of endianness, 0, data_format, and type */
+ int realflag = 0; /* 0=only real values used */
/* should type be specifically uint32 ??? */
- char array_name[65];
+ char array_name[65]; /* 65 = 64 + null-terminator */
int name_len;
- long mrows, ncols; /* text/data/map array dimensions*/
+ int mrows, ncols; /* text/data/map array dimensions*/
int *pval_i; /* for misc use */
float *pval_f; /* for misc use */
double *pval_d; /* for misc use */
char c, *buff; /* for misc use */
- char map_name[65], map_title[1024];
+ char map_name[65], map_title[1024]; /* 65 = 64 + null-terminator */
double map_name_d[1024]; /* I'm not sure why you'd save char strings as double, but whatever */
int have_name, have_data, have_title, have_n, have_s, have_e, have_w;
@@ -77,10 +77,7 @@
struct History history;
struct Option *inputfile, *outputfile;
- /* please, remove before GRASS 7 released */
- struct Flag *verbose;
+ struct Flag *verbose; /* remove for GRASS 7 */
struct GModule *module;
int cf;
@@ -106,7 +103,7 @@
outputfile = G_define_option() ;
outputfile->key = "output";
outputfile->type = TYPE_STRING;
- outputfile->required = YES;
+ outputfile->required = NO;
outputfile->gisprompt = "new,cell,raster" ;
outputfile->description= _("Name for the output raster map (override)");
@@ -120,6 +117,12 @@
exit(EXIT_FAILURE);
+ /* remove for GRASS 7 */
+ if(verbose->answer) {
+ putenv("GRASS_VERBOSE=3");
+ G_warning(_("The '-v' flag is superseded and will be removed "
+ "in future. Please use '--verbose' instead."));
/****** SETUP ****************************************************/
/* Check Endian State of Host Computer*/
@@ -141,7 +144,7 @@
have_n = have_s = have_e = have_w = 0;
/* Check Endian State of File */
- fread(&format_block, sizeof(long), 1, fp1);
+ fread(&format_block, sizeof(int), 1, fp1);
fseek(fp1, 0, SEEK_SET); /* frewind() */
file_endianness = format_block / 1000; /* 0=little, 1=big */
@@ -158,12 +161,12 @@
/****** READ MAP ****************************************************/
- G_message(_("Reading MAT-File..."));
+ G_verbose_message(_("Reading MAT-File..."));
while (!feof(fp1)) {
/* scan for needed array variables */
if(feof(fp1))
break;
@@ -181,19 +184,19 @@
/* 4 byte number of rows & columns */
- fread(&mrows, sizeof(long), 1, fp1);
- fread(&ncols, sizeof(long), 1, fp1);
+ fread(&mrows, sizeof(int), 1, fp1);
+ fread(&ncols, sizeof(int), 1, fp1);
if(mrows < 1 || ncols < 1)
G_fatal_error(_("Array contains no data"));
/* 4 byte real/imag flag 0=real vals only */
- fread(&realflag, sizeof(long), 1, fp1);
+ fread(&realflag, sizeof(int), 1, fp1);
if(realflag != 0)
G_fatal_error(_("Array contains imaginary data"));
/* length of array_name+1 */
- fread(&name_len, sizeof(long), 1, fp1);
+ fread(&name_len, sizeof(int), 1, fp1);
if(name_len < 1)
G_fatal_error(_("Invalid array name"));
@@ -205,11 +208,11 @@
G_debug(3, "array name = [%s]", array_name);
- G_debug(3, " format block = [%04ld]", format_block);
+ G_debug(3, " format block = [%04d]", format_block);
G_debug(3, " data format = [%d]", data_format);
G_debug(3, " data type = [%d]", data_type);
- G_debug(3, " rows = [%ld]", mrows);
- G_debug(3, " cols = [%ld]", ncols);
+ G_debug(3, " rows = [%d]", mrows);
+ G_debug(3, " cols = [%d]", ncols);
if(strcmp(array_name, "map_name") == 0) {
have_name = 1;
@@ -314,7 +317,7 @@
} /* endif map_data */
else {
- G_warning(_("Skipping unknown array '%s'"), array_name);
+ G_important_message(_("Skipping unknown array '%s'"), array_name);
switch (data_format) {
/* 0=double 1=float 2=32bit signed int 5=8bit unsigned int(text) */
case 0:
@@ -333,7 +336,7 @@
- G_debug(3, "Read array '%s' [%ld,%ld] format=%d type=%d\n",
+ G_debug(3, "Read array '%s' [%d,%d] format=%d type=%d\n",
array_name, ncols, mrows, data_format, data_type);
} /* while !EOF */
@@ -345,8 +348,25 @@
/* set map name */
- strncpy(map_name, outfile, 61);
+ if(have_name) {
+ if(outfile) {
+ if( 0 != strcmp(outfile, map_name) )
+ G_message(_("Setting map name to <%s> which overrides <%s>"),
+ outfile, map_name);
+ strncpy(map_name, outfile, 61);
+ else {
+ if(outfile) {
+ G_verbose_message(_("Setting map name to <%s>"), outfile);
+ else {
+ G_message(_("No 'map_name' array found; using <MatFile>"));
+ strcpy(map_name, "MatFile");
G_strip(map_name); /* remove leading and trailing whitespace */
if(G_legal_filename(map_name) != 1)
G_fatal_error(_("<%s> is an illegal file name"), map_name);
@@ -373,20 +393,27 @@
if(buff) G_fatal_error(buff);
G_set_window(®ion);
- if(verbose->answer)
- G_warning(_("The '-v' flag is superseded and will be removed "
- "in future. Please use '--verbose' instead."));
+ G_verbose_message("");
+ G_verbose_message(_("Map <%s> bounds set to:"), map_name);
+ G_verbose_message(_("northern edge=%f"), region.north);
+ G_verbose_message(_("southern edge=%f"), region.south);
+ G_verbose_message(_("eastern edge=%f"), region.east);
+ G_verbose_message(_("western edge=%f"), region.west);
+ G_verbose_message(_("nsres=%f"), region.ns_res);
+ G_verbose_message(_("ewres=%f"), region.ew_res);
+ G_verbose_message(_("rows=%d"), region.rows);
+ G_verbose_message(_("cols=%d"), region.cols);
/* prep memory */
- raster = G_allocate_raster_buf(map_type);
+ raster = G_allocate_raster_buf(map_type);
cf = G_open_raster_new(map_name, map_type);
if (cf < 0)
- G_fatal_error (_("Unable to create raster map <%s>"), outfile);
+ G_fatal_error(_("Unable to create raster map <%s>"), outfile);
/* write new raster map*/
- G_message(_("Writing new raster map..."));
+ G_verbose_message(_("Writing new raster map..."));
mrows = region.rows;
ncols = region.cols;
@@ -436,7 +463,7 @@
if( 1 != G_put_raster_row(cf, raster, map_type) ) {
G_close_cell(cf);
- G_fatal_error(_("Failed writing raster map <%s> row %d"), raster, row);
+ G_fatal_error(_("Writing raster map, row %d"), row);
G_percent(row, mrows, 5);
@@ -459,7 +486,9 @@
G_command_history(&history);
G_write_history(map_name, &history);
- return 0;
+ G_done_msg("");
+ exit(EXIT_SUCCESS);
