[GRASS-SVN] r30888 - grass-addons/gipe/i.eb.h_SEBAL95
svn_grass at osgeo.org
Mon Apr 7 07:16:02 EDT 2008
Author: ychemin
Date: 2008-04-07 07:16:02 -0400 (Mon, 07 Apr 2008)
New Revision: 30888
grass-addons/gipe/i.eb.h_SEBAL95/main.c
bug fix
Modified: grass-addons/gipe/i.eb.h_SEBAL95/main.c
--- grass-addons/gipe/i.eb.h_SEBAL95/main.c 2008-04-07 11:08:40 UTC (rev 30887)
+++ grass-addons/gipe/i.eb.h_SEBAL95/main.c 2008-04-07 11:16:02 UTC (rev 30888)
@@ -169,11 +169,12 @@
albedo = input_albedo->answer;
h0 = output->answer;
- row_wet = atoi(input_row_wet->answer);
- col_wet = atoi(input_col_wet->answer);
- row_dry = atoi(input_row_dry->answer);
- col_dry = atoi(input_col_dry->answer);
+ if(input_row_wet->answer){
+ row_wet = atoi(input_row_wet->answer);
+ col_wet = atoi(input_col_wet->answer);
+ row_dry = atoi(input_row_dry->answer);
+ col_dry = atoi(input_col_dry->answer);
/* find maps in mapset */
mapset_T = G_find_cell2 (T, "");
if (mapset_T == NULL)
@@ -204,14 +205,14 @@
G_fatal_error (_("[%s] is an illegal name"), h0);
/* determine the input map type (CELL/FCELL/DCELL) */
- data_type_T = G_raster_map_type(T, mapset);
- data_type_u2 = G_raster_map_type(u2, mapset);
- data_type_DEM = G_raster_map_type(DEM, mapset);
- data_type_ndvi = G_raster_map_type(ndvi, mapset);
- data_type_Rn = G_raster_map_type(Rn, mapset);
- data_type_g0 = G_raster_map_type(g0, mapset);
+ data_type_T = G_raster_map_type(T, mapset_T);
+ data_type_u2 = G_raster_map_type(u2, mapset_u2);
+ data_type_DEM = G_raster_map_type(DEM, mapset_DEM);
+ data_type_ndvi = G_raster_map_type(ndvi, mapset_ndvi);
+ data_type_Rn = G_raster_map_type(Rn, mapset_Rn);
+ data_type_g0 = G_raster_map_type(g0, mapset_g0);
if(flag1->answer){
- data_type_albedo = G_raster_map_type(albedo, mapset);
+ data_type_albedo = G_raster_map_type(albedo, mapset_albedo);
if ( (infd_T = G_open_cell_old (T, mapset_T)) < 0)
G_fatal_error (_("Cannot open cell file [%s]"), T);
@@ -359,6 +360,8 @@
G_message("tempk_min=%f\ntempk_max=%f\n",tempk_min,tempk_max);
+ G_message("row_wet=%d\tcol_wet=%d\n",row_wet,col_wet);
+ G_message("row_dry=%d\tcol_dry=%d\n",row_dry,col_dry);
} /* END OF FLAG1 */
/* Pick up wet and dry pixel values */
DCELL d_Rn; /* Input raster */
@@ -387,7 +390,7 @@
/*Process dry pixel values*/
if (G_get_d_raster_row (infd_T, inrast_T, row_dry) < 0)
G_fatal_error (_("Could not read from <%s>"),T);
- if (G_get_d_raster_row (infd_DEM, inrast_DEM, row) < 0)
+ if (G_get_d_raster_row (infd_DEM, inrast_DEM, row_dry) < 0)
G_fatal_error (_("Could not read from <%s>"),DEM);
if (G_get_d_raster_row (infd_Rn, inrast_Rn, row_dry) < 0)
G_fatal_error (_("Could not read from <%s>"),Rn);
