[GRASS-SVN] r30892 - in grass-addons/raster/r.out.gmap: . r.out.gmap
svn_grass at osgeo.org
Mon Apr 7 10:02:24 EDT 2008
Author: neteler
Date: 2008-04-07 10:02:24 -0400 (Mon, 07 Apr 2008)
New Revision: 30892
Added:
grass-addons/raster/r.out.gmap/Makefile
grass-addons/raster/r.out.gmap/description.html
grass-addons/raster/r.out.gmap/main_tmp
Removed:
grass-addons/raster/r.out.gmap/r.out.gmap/Makefile
grass-addons/raster/r.out.gmap/r.out.gmap/description.html
grass-addons/raster/r.out.gmap/r.out.gmap/r.out.gmap
moved into right directory
Copied: grass-addons/raster/r.out.gmap/Makefile (from rev 30891, grass-addons/raster/r.out.gmap/r.out.gmap/Makefile)
--- grass-addons/raster/r.out.gmap/Makefile (rev 0)
+++ grass-addons/raster/r.out.gmap/Makefile 2008-04-07 14:02:24 UTC (rev 30892)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.out.gmap
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Copied: grass-addons/raster/r.out.gmap/description.html (from rev 30891, grass-addons/raster/r.out.gmap/r.out.gmap/description.html)
--- grass-addons/raster/r.out.gmap/description.html (rev 0)
+++ grass-addons/raster/r.out.gmap/description.html 2008-04-07 14:02:24 UTC (rev 30892)
@@ -0,0 +1,49 @@
+<H2>DESCRIPTION</H2>
+<EM>r.out.gmap</EM> outputs GRASS raster map into set of image tiles
+following the tiling scheme of Google Maps and Microsoft Virtual Earth.
+<H2>NOTES</H2>
+The r.out.gmap must be run from location with correct mercator projection
+used by Google Maps and Microsoft Virtual Earth. Projection can be defined using g.proj and setting the EPSG code to <em>esri.extra/900913</em> or by setting the proj4 parameters to <div class="code">
+ +proj=merc +lat_ts=0.0000000000 +lon_0=0.0000000000 +k_0=1.00000 00000 +x_0=0 +y_0=0 +no_defs +a=6378137 +b=6378137 </div> for <em>PROJ4</em> library version 4.6.0 and later. For <em>PROJ4</em> library version 4.5.0, the following definition should be used instead:
+<div class="code"> +proj=merc +lat_ts=0.0000000000 +lon_0=0.0000000000 +k_0=1.00000 00000 +x_0=0 +y_0=0 +no_defs +a=6378137 +b=6378137 +nadgrids=@null </div>
+<p>
+To publish the html code (using the -h flag) on internet, the Google Maps API key (line key=abcdefg in html file) has to be replaced by <a href="http://code.google.com/apis/maps/signup.html">site specific key</a>
+<p>
+Be careful when using n,s,e,w parameters, these should be set in the geographical coordinates (lat/lon).
+<p>
+<H2>EXAMPLE</H2>
+Export of the map <em>elevation.dem</em> from current mapset at the zoom level <em>10</em>. The output is written to the default <em>googlemap</em> directory:
+<div class="code"><pre>
+r.out.gmap input=elevation.dem zoom=10
+</pre></div>
+<p>
+Export of the map <em>elevation.dem</em> from mapset <em>srtm</em> location <em>wgs84</em> at zoom level <em>9</em>. Map export is restricted to specified extent. Output is written to <em>mytiles</em> directory. Example of google map html file with implemented tiles is created:
+r.out.gmap input=elevation.dem location=wgs84 mapset=srtm zoom=9 w=8.5 e=9.75 s=41.25 n=43 outdir=mytiles -hm
+</pre></div>
+<H2>REFERENCES</H2>
+<a href="http://www.remotesensing.org/proj/">PROJ4 library</a>
+<p>
+<a href="http://code.google.com/apis/maps/documentation/">Google Map API</a>
+<H2>SEE ALSO</H2>
+<EM><A HREF="g.proj.html">g.proj</A></EM>
+<H2>AUTHOR</H2>
+Tomas Cebecauer <br>
+Read more in the OSGeo Journal <a href="http://www.osgeo.org/journal"> Volume 5 (2008) </a>
+<p><i>Last changed: $Date: 2008-04-01 17:35:44 +0100 (Tue, 01 Apr 2008) $</i>
Copied: grass-addons/raster/r.out.gmap/main_tmp (from rev 30891, grass-addons/raster/r.out.gmap/r.out.gmap/r.out.gmap)
--- grass-addons/raster/r.out.gmap/main_tmp (rev 0)
+++ grass-addons/raster/r.out.gmap/main_tmp 2008-04-07 14:02:24 UTC (rev 30892)
@@ -0,0 +1,546 @@
+#!/bin/sh
+# MODULE: r.out.gmap
+# AUTHOR(S): Tomas Cebecauer.
+# PURPOSE: Raster data tiling for Google Maps and Microsoft Virtual Earth
+# COPYRIGHT: (C) 2008 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# REQUIRES: - bc, PROJ4 (cs2cs), sed, grep, awk, wc, cat
+#%Module
+#% description: Exports raster map in the Google Map or Microsoft Virtual Earth format
+#% keywords: raster, export
+#%End
+#%flag
+#% key: e
+#% description: Microsoft Virtual Earth naming style (default is Google Map naming style)
+#%END
+#%flag
+#% key: f
+#% description: Force processing if the current location projection test fails (not recommended)
+#%END
+#%flag
+#% key: h
+#% description: Create an example html file with google maps API for exported data (google maps only)
+#%END
+#%flag
+#% key: m
+#% description: Cut the output to specified edges
+#%END
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Input raster map
+#% required : yes
+#%END
+#%option
+#% key: location
+#% type: string
+#% description: Location of input map
+#% required : no
+#%END
+#%option
+#% key: mapset
+#% type: string
+#% description: Mapset of input map
+#% required : no
+#%END
+#%option
+#% key: interpolation
+#% type: string
+#% description: Interpolation method to use for re-projection
+#% answer: nearest
+#% options: nearest,bilinear,cubic
+#% required : no
+#% multiple: no
+#%end
+#%option
+#% key: zoom
+#% type: double
+#% description: Google Map zoom level to export
+#% options : 0-21
+#% required : yes
+#%END
+#%option
+#% key: n
+#% type: double
+#% description: Custom northern edge in lat/long on wgs84 ellipsoid
+#% options : -85.05-85.05
+#% required : no
+#%END
+#%option
+#% key: s
+#% type: double
+#% description: Custom southern edge in lat/long on wgs84 ellipsoid
+#% required : no
+#%END
+#%option
+#% key: e
+#% type: double
+#% description: Custom eastern edge in lat/long on wgs84 ellipsoid
+#% options : -180-180
+#% required : no
+#%END
+#%option
+#% key: w
+#% type: double
+#% description: Custom western edge in lat/long on wgs84 ellipsoid
+#% required : no
+#%END
+#%option
+#% key: outdir
+#% type: string
+#% description: directory to write output tiles
+#% answer: googlemap
+#% required : no
+#%END
+#constants:
+M2PX=$(echo "5340353.715440871795 / 6378137" | bc -l) #correction from meters to pixels(zoom 17)
+PX2M=$(echo "6378137 / 5340353.715440871795" | bc -l) #correction from meters to pixels(zoom 17)
+LEFT=$(echo "-16777216 * $PX2M" | bc -l) #minimum left coordinate of projection
+cleanup()
+#remove data
+ g.remove rast=out$$ --quiet
+exitprocedure()
+ g.message -e "User break!"
+ cleanup
+ exit 1
+trap "exitprocedure" 2 3 15
+if [ -z $GISBASE ] ; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+# check if bc exists
+if [ ! -x "`which bc`" ] ; then
+ g.message -e "'bc' program not found, install it first"
+ exit 1
+fi
+# check if cs2cs exists
+if [ ! -x "`which cs2cs`" ] ; then
+ g.message -e "'cs2cs' program not found, install it first\
+ http://proj.maptools.org"
+ exit 1
+fi
+# check if grep exists
+if [ ! -x "`which grep`" ] ; then
+ g.message -e "'grep' program not found, install it first"
+ exit 1
+fi
+# check if awk exists
+if [ ! -x "`which awk`" ] ; then
+ g.message -e "'awk' program not found, install it first"
+ exit 1
+fi
+# check if sed exists
+if [ ! -x "`which sed`" ] ; then
+ g.message -e "'sed' program not found, install it first"
+ exit 1
+fi
+# check if tr exists
+if [ ! -x "`which tr`" ] ; then
+ g.message -e "'tr' program not found, install it first"
+ exit 1
+fi
+# check if wc exists
+if [ ! -x "`which wc`" ] ; then
+ g.message -e "'wc' program not found, install it first"
+ exit 1
+fi
+# check if cat exists
+if [ ! -x "`which cat`" ] ; then
+ g.message -e "'cat' program not found, install it first"
+ exit 1
+fi
+# save command line
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+map="$GIS_OPT_INPUT"
+location="$GIS_OPT_LOCATION"
+mapset="$GIS_OPT_MAPSET"
+level="$GIS_OPT_ZOOM"
+interpol="$GIS_OPT_INTERPOLATION"
+newdir="$GIS_OPT_OUTDIR"
+# test if input map is set in form map at mapset
+hasat=`echo $map | grep '@' |wc -c`
+if [ $hasat -ge "3" ]; then #at least a at b
+ mapset=`echo $map | awk -F'@' '{print $2}'`
+ map=`echo $map | awk -F'@' '{print $1}'`
+fi
+# test zoom level for MVE export
+if [ $GIS_FLAG_E -eq "1" -a $level -eq "0" ]; then
+ g.message -e "zoom level $level not allowed for Microsoft Virtual Earth export"
+ exit 1
+fi
+# take env variables from current GRASS session
+eval `g.gisenv`
+: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
+ GMlocation=$LOCATION_NAME
+ GMmapset=$MAPSET
+ GMgisdbase=$GISDBASE
+ GMmapsetpath=$GISDBASE"/"$LOCATION_NAME"/"$MAPSET
+# if location and/or mapset not set use current location/mapset
+ if [ -z $mapset ]; then mapset=$GMmapset; fi
+ if [ -z $location ]; then location=$GMlocation; fi
+ mapsetpath=$GISDBASE"/"$location"/"$mapset
+# check wheter input map mapset differs from current mapset
+ diffinputmapset=1
+ if [ $GMmapset = $mapset -a $GMlocation = $location ]; then diffinputmapset=0; fi
+ if [ $GMmapset != $mapset -a $GMlocation = $location ]; then
+ g.mapsets addmapset=$mapset
+ diffinputmapset=0;
+ fi
+#test whether the script is run from mapset with google maps projection
+ gmproj='+proj=merc +lat_ts=0.0000000000 +lon_0=0.0000000000 +k_0=1.0000000000 +x_0=0 +y_0=0 +no_defs +a=6378137 +b=6378137'
+ latlonproj='+proj=longlat +a=6378137 +rf=298.257223563 +no_defs'
+correctproj=1
+ # test presence of all proj parameters
+reqired_par="proj lat_ts lon_0 x_0 y_0 a b no_defs"
+for reqpar in $reqired_par
+do
+ par=`g.proj -j | grep $reqpar`
+ if [ -z "$par" ]; then
+ correctproj=0
+ fi
+done
+if [ $correctproj -eq 1 ]; then
+ # get individual proj parameters
+ eval `g.proj -j | tr '+' ' ' | grep -v no_defs`
+ : ${proj?} ${lat_ts?} ${lon_0?} ${x_0?} ${y_0?} ${a?} ${b?} >&1
+ nodefs=`g.proj -j | grep no_defs`
+ # test presence/value of text parameters
+ if [ -z $nodefs -o $proj != 'merc' ]; then correctproj=0; fi
+ # test values of numeric parameters
+ testline="$lat_ts!=0.0 || $lon_0!=0.0 || $x_0!=0.0 || $y_0!=0.0 || $a!=6378137 || $b!=6378137"
+ if [ $(echo $testline | bc -l) -eq 1 ]; then correctproj=0; fi
+fi
+ # inform user
+if [ $correctproj -ne 1 ]; then
+ if [ $GIS_FLAG_F -eq "1" ]; then
+ g.message -w "projection for location \"$GMlocation\" differs from required google map mercator projection"
+ else
+ g.message -e "projection for location \"$GMlocation\" differs from required google map mercator projection"
+ currproj=`g.proj -jf`
+ g.message message="current projection: $currproj"
+ g.message message="required projection: $gmproj"
+ exit 1
+ fi
+fi
+#test whether the input grass mapset is used/exists
+if [ $diffinputmapset -eq 1 ]; then
+ msg=`g.mapset mapset=$mapset location=$location gisdbase=$GISDBASE 2>&1`
+ msgERR=`echo $msg | grep 'ERROR' | wc -c`
+ if [ $msgERR -gt 0 ]
+ then
+ g.message -e "input Mapset does not exist, or is used by GRASS"
+ exit 1
+ else # location/mapset successfuly changed, return back to the google map location/mapset
+ g.mapset mapset=$GMmapset location=$GMlocation gisdbase=$GMgisdbase >& /dev/null
+ fi
+fi
+#creates new directory for output
+ if [ -z $newdir ]; then
+ newdir="."
+ elif [ ! -d $newdir ]; then
+ mkdir $newdir
+ elif [ $newdir = "googlemap" ]; then
+ g.message "exporting tiles to ./googlemap"
+ fi
+# check existence of input map
+ infile=$mapsetpath"/cell/"$map
+ if [ ! -f "$infile" ]; then
+ g.message -e "cannot find input map " $map
+ exit 1
+ fi
+# force creation of color file if not exists
+ colorfile=$mapsetpath"/colr/"$map
+ if [ ! -f "$colorfile" ]; then
+ if [ $diffinputmapset -eq 1 ]; then
+ g.mapset mapset=$mapset location=$location gisdbase=$GISDBASE >& /dev/null
+ r.colors $map rast=$map
+ else
+ fi
+ g.message -w 'forced creation of colr file...'
+ fi
+# calculate resolution
+ res=$(echo "(2^(17-$level)) * $PX2M" | bc -l)
+ reshalf=$(echo "$res/2" | bc -l)
+ segsize=$(echo "$res*256" | bc -l)
+ g.region res=$res
+# get N,E,W,S and proj in input LOCATION
+ inproj=`g.proj -jf`
+ eval `r.info -g $map`
+ : ${north?} ${south?} ${west?} ${east?}
+ # go back to the GM loacation
+ else
+ minx=$west
+ maxx=$east
+ miny=$south
+ maxy=$north
+ fi
+# calculate bounding box in longitude/latitude and check for the limits
+ cs2cs_cmd='cs2cs -f %.10f '$inproj' +to '$latlonproj
+ #get min longitude
+ if [ -n "$GIS_OPT_W" ]; then
+ minlon="$GIS_OPT_W"
+ else
+ minlon1=`echo $west $north 0 | $cs2cs_cmd | awk '{print $1}'`
+ minlon2=`echo $west $south 0 | $cs2cs_cmd | awk '{print $1}'`
+ minlon=$minlon2
+ if [ $(echo "$minlon1 < $minlon2" | bc -l) -eq 1 ] ; then minlon=$minlon1; fi
+ if [ $(echo "$minlon <= -180.0" | bc -l) -eq 1 ]; then minlon=-179.999999999999; fi
+ fi
+ #get max longitude
+ if [ -n "$GIS_OPT_E" ]; then
+ maxlon="$GIS_OPT_E"
+ else
+ maxlon1=`echo $east $north 0 | $cs2cs_cmd | awk '{print $1}'`
+ maxlon2=`echo $east $south 0 | $cs2cs_cmd | awk '{print $1}'`
+ maxlon=$maxlon2
+ if [ $(echo "$maxlon1 > $maxlon2" | bc -l) -eq 1 ] ; then maxlon=$maxlon1; fi
+ if [ $(echo "$maxlon >= 180.0" | bc -l) -eq 1 ]; then maxlon=179.999999999999; fi
+ fi
+ #get min latitude
+ if [ -n "$GIS_OPT_S" ]; then
+ minlat="$GIS_OPT_S";
+ else
+ minlat1=`echo $west $south 0 | $cs2cs_cmd | awk '{print $2}'`
+ minlat2=`echo $east $south 0 | $cs2cs_cmd | awk '{print $2}'`
+ minlat=$minlat2
+ if [ $(echo "$minlat1 < $minlat2" | bc -l) -eq 1 ] ; then minlat=$minlat1; fi
+ if [ $(echo "$minlat < -85.05112877980659" | bc -l) -eq 1 ]; then minlat=-85.05112877980659; fi
+ fi
+ #get max latitude
+ if [ -n "$GIS_OPT_N" ]; then
+ maxlat="$GIS_OPT_N";
+ else
+ maxlat1=`echo $west $north 0 | $cs2cs_cmd | awk '{print $2}'`
+ maxlat2=`echo $east $north 0 | $cs2cs_cmd | awk '{print $2}'`
+ maxlat=$maxlat2
+ if [ $(echo "$maxlat1 > $maxlat2" | bc -l) -eq 1 ] ; then maxlat=$maxlat1; fi
+ if [ $(echo "$maxlat > 85.05112877980659" | bc -l) -eq 1 ]; then maxlat=85.05112877980659; fi
+ fi
+ cs2cs_cmd='cs2cs -f %.10f '$latlonproj' +to '$gmproj
+ if [ $diffinputmapset -eq 1 -o -n "$GIS_OPT_W" ]; then
+ minx=`echo $minlon $minlat 0 | $cs2cs_cmd | awk '{print $1}'`
+ fi
+ if [ $diffinputmapset -eq 1 -o -n "$GIS_OPT_E" ]; then
+ maxx=`echo $maxlon $minlat 0 | $cs2cs_cmd | awk '{print $1}'`
+ fi
+ if [ $diffinputmapset -eq 1 -o -n "$GIS_OPT_S" ]; then
+ miny=`echo $minlon $minlat 0 | $cs2cs_cmd | awk '{print $2}'`
+ fi
+ if [ $diffinputmapset -eq 1 -o -n "$GIS_OPT_N" ]; then
+ maxy=`echo $minlon $maxlat 0 | $cs2cs_cmd | awk '{print $2}'`
+ fi
+# remove mask if exists
+ if [ -f $GMmapsetpath/cell/MASK ] ; then
+ g.message "removing mask"
+ g.rename rast=MASK,MASK$$ >& /dev/null
+ fi
+# tiles usually cover larger area than bounding box, to clip it to box uncomment this
+ if [ $GIS_FLAG_M -eq "1" ]; then
+ g.region n=$maxy s=$miny e=$maxx w=$minx res=$res >& /dev/null
+ r.mapcalc MASK=1 >& /dev/null
+ fi
+#calcuate tiles
+ #reshalf is used to calculate centers of pixels from edges of pixels
+ colleft=$(echo "numb=(($minx - $LEFT + $reshalf) / $segsize);scale = 0;numb/1" | bc -l)
+ colright=$(echo "numb=(($maxx - $LEFT - $reshalf) / $segsize);scale = 0;numb/1" | bc -l)
+ rowtop=$(echo "numb=((0.0 - $maxy - $LEFT + $reshalf) / $segsize);scale = 0;numb/1" | bc -l)
+ rowbottom=$(echo "numb=((0.0 - $miny - $LEFT - $reshalf) / $segsize);scale = 0;numb/1" | bc -l)
+ g.message "Tiles: zoom $level cols $colleft - $colright rows $rowtop - $rowbottom"
+#finaly loop through the tiles and export
+ncolorfile=$GMmapsetpath"/colr/out"$$
+i=$colleft
+while [ $i -le $colright ]
+do
+ leftt=$(echo "numb=($i * $segsize) + $LEFT;scale = 10;numb/1" | bc -l)
+ right=$(echo "numb=($leftt + $segsize) ;scale = 10;numb/1" | bc -l)
+ j=$rowtop
+ while [ $j -le $rowbottom ]
+ do
+ top=$(echo "numb=0.0 - ($j * $segsize) - $LEFT;scale = 10;numb/1" | bc -l)
+ bottom=$(echo "numb=($top - $segsize) ;scale = 10;numb/1" | bc -l)
+ g.message "tile $i $j"
+ g.region w=$leftt e=$right s=$bottom n=$top res=$res
+#decide what will be exported
+ g.message -v "projecting..."
+ r.proj input=$map location=$location mapset=$mapset method=$interpol output=out$$ --quiet >& /dev/null
+ else
+ r.mapcalc out$$=$map
+ fi
+ #if nothing was projected (may happen if outside tha data) create empty file
+ nfile=$GMmapsetpath"/cell/out"$$
+ if [ ! -f $nfile ]; then
+ r.mapcalc out$$='null()' 2>&1 /dev/null
+ fi
+ cp $colorfile $ncolorfile # just copy color file
+ #export data
+ if [ $GIS_FLAG_E -eq "1" ] ; then
+ #file name in microsoft virtual earth style
+ mve_tile=$(echo "scale=0; res=0; lev=$level; anx=$i; any=$j; while(lev > 0){rx=0; ry=0; tileshalf=(2^(lev-1)); if (anx >= tileshalf) {anx=anx - tileshalf; rx=1};if (any >= tileshalf) {any=any - tileshalf; ry=1};res=res+((10^(lev-1))*((2*ry)+rx));lev=--lev }; res" | bc -l)
+ mve_tile=`printf "%0"$level"d" $mve_tile`
+ mve_file=$newdir"/"$mve_tile".png"
+ outfile=$mve_file
+ else
+ # file name in google map style
+ gm_file=$newdir"/z"$level"_"$i"x"$j".png"
+ outfile=$gm_file
+ fi
+ g.message -v "exporting $outfile ..."
+ r.out.png --quiet input=out$$ output=$outfile
+#remove data
+ if [ -f $GMmapsetpath"/cell/out"$$ ]
+ then
+ g.remove out$$ >& /dev/null
+ fi
+ j=`expr $j + 1`
+ done
+ i=`expr $i + 1`
+done
+#### html file
+if [ $GIS_FLAG_H -eq "1" -a $GIS_FLAG_E -ne "1" ]; then
+ midlon=$(echo "($maxlon + $minlon)/2" | bc -l)
+ midlat=$(echo "($maxlat + $minlat)/2" | bc -l)
+ cat << EOF > "${map}.html"
+<!DOCTYPE html "-//W3C//DTD XHTML 1.0 Strict//EN"
+"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+ <meta http-equiv="content-type" content="text/html; charset=utf-8"/>
+ <title>GRASS GIS r.out.gmap result</title>
+ <script src="http://maps.google.com/maps?file=api&v=2&key=abcdefg"
+ type="text/javascript"></script>
+ <script type="text/javascript">
+ function initialize() {
+ if (GBrowserIsCompatible()) {
+ var map = new GMap2(document.getElementById("map_canvas"));
+ /* add layer from grass*/
+ mapbounds = new GLatLngBounds(new GLatLng($minlat, $minlon), new GLatLng($maxlat, $maxlon));
+ var copyCollection = new GCopyrightCollection("");
+ copyCollection.addCopyright(new GCopyright(17, mapbounds, 2, "© 2008 GRASS GIS<br>"));
+ var anewLayer = new GTileLayer(copyCollection, 1,171);
+ anewLayer.getTileUrl = function(a,b){ return "${newdir}/z"+b+"_"+(a.x)+"x"+(a.y)+".png";};
+ var anewMapType = new GMapType([anewLayer], G_NORMAL_MAP.getProjection(), "Grassmap");
+ anewMapType.getMinimumResolution = function() {return 0;};
+ anewMapType.getMaximumResolution = function() {return 17;};
+ map.addMapType(anewMapType);
+ map.addControl(new GLargeMapControl());
+ map.addControl(new GMapTypeControl());
+ map.setCenter(new GLatLng(${midlat}, ${midlon}), ${level}, anewMapType);
+ </script>
+</head>
+<body onload="initialize()" onunload="GUnload()">
+ <div id="map_canvas" style="width: 500px; height: 400px"></div>
+</body>
+</html>
+EOF
+ g.message "'${map}.html' created."
+fi
+#remove custom mask
+if [ $GIS_FLAG_M -eq "1" ]; then
+ g.remove rast=MASK >& /dev/null
+fi
+#restore mask if exists
+if [ -f $GMmapsetpath/cell/MASK$$ ] ; then
+ g.message "restoring mask"
+ g.remove MASK >& /dev/null
+ g.rename rast=MASK$$,MASK >& /dev/null
+fi
Deleted: grass-addons/raster/r.out.gmap/r.out.gmap/Makefile
--- grass-addons/raster/r.out.gmap/r.out.gmap/Makefile 2008-04-07 13:54:45 UTC (rev 30891)
+++ grass-addons/raster/r.out.gmap/r.out.gmap/Makefile 2008-04-07 14:02:24 UTC (rev 30892)
@@ -1,7 +0,0 @@
-MODULE_TOPDIR = ../..
-PGM = r.out.gmap
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
Deleted: grass-addons/raster/r.out.gmap/r.out.gmap/description.html
--- grass-addons/raster/r.out.gmap/r.out.gmap/description.html 2008-04-07 13:54:45 UTC (rev 30891)
+++ grass-addons/raster/r.out.gmap/r.out.gmap/description.html 2008-04-07 14:02:24 UTC (rev 30892)
@@ -1,49 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>r.out.gmap</EM> outputs GRASS raster map into set of image tiles
-following the tiling scheme of Google Maps and Microsoft Virtual Earth.
-<H2>NOTES</H2>
-The r.out.gmap must be run from location with correct mercator projection
-used by Google Maps and Microsoft Virtual Earth. Projection can be defined using g.proj and setting the EPSG code to <em>esri.extra/900913</em> or by setting the proj4 parameters to <div class="code">
- +proj=merc +lat_ts=0.0000000000 +lon_0=0.0000000000 +k_0=1.00000 00000 +x_0=0 +y_0=0 +no_defs +a=6378137 +b=6378137 </div> for <em>PROJ4</em> library version 4.6.0 and later. For <em>PROJ4</em> library version 4.5.0, the following definition should be used instead:
-<div class="code"> +proj=merc +lat_ts=0.0000000000 +lon_0=0.0000000000 +k_0=1.00000 00000 +x_0=0 +y_0=0 +no_defs +a=6378137 +b=6378137 +nadgrids=@null </div>
-<p>
-To publish the html code (using the -h flag) on internet, the Google Maps API key (line key=abcdefg in html file) has to be replaced by <a href="http://code.google.com/apis/maps/signup.html">site specific key</a>
-<p>
-Be careful when using n,s,e,w parameters, these should be set in the geographical coordinates (lat/lon).
-<p>
-<H2>EXAMPLE</H2>
-Export of the map <em>elevation.dem</em> from current mapset at the zoom level <em>10</em>. The output is written to the default <em>googlemap</em> directory:
-<div class="code"><pre>
-r.out.gmap input=elevation.dem zoom=10
-</pre></div>
-<p>
-Export of the map <em>elevation.dem</em> from mapset <em>srtm</em> location <em>wgs84</em> at zoom level <em>9</em>. Map export is restricted to specified extent. Output is written to <em>mytiles</em> directory. Example of google map html file with implemented tiles is created:
-r.out.gmap input=elevation.dem location=wgs84 mapset=srtm zoom=9 w=8.5 e=9.75 s=41.25 n=43 outdir=mytiles -hm
-</pre></div>
-<H2>REFERENCES</H2>
-<a href="http://www.remotesensing.org/proj/">PROJ4 library</a>
-<p>
-<a href="http://code.google.com/apis/maps/documentation/">Google Map API</a>
-<H2>SEE ALSO</H2>
-<EM><A HREF="g.proj.html">g.proj</A></EM>
-<H2>AUTHOR</H2>
-Tomas Cebecauer <br>
-Read more in the OSGeo Journal <a href="http://www.osgeo.org/journal"> Volume 5 (2008) </a>
-<p><i>Last changed: $Date: 2008-04-01 17:35:44 +0100 (Tue, 01 Apr 2008) $</i>
Deleted: grass-addons/raster/r.out.gmap/r.out.gmap/r.out.gmap
--- grass-addons/raster/r.out.gmap/r.out.gmap/r.out.gmap 2008-04-07 13:54:45 UTC (rev 30891)
+++ grass-addons/raster/r.out.gmap/r.out.gmap/r.out.gmap 2008-04-07 14:02:24 UTC (rev 30892)
@@ -1,546 +0,0 @@
-#!/bin/sh
-# MODULE: r.out.gmap
-# AUTHOR(S): Tomas Cebecauer.
-# PURPOSE: Raster data tiling for Google Maps and Microsoft Virtual Earth
-# COPYRIGHT: (C) 2008 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-# REQUIRES: - bc, PROJ4 (cs2cs), sed, grep, awk, wc, cat
-#%Module
-#% description: Exports raster map in the Google Map or Microsoft Virtual Earth format
-#% keywords: raster, export
-#%End
-#%flag
-#% key: e
-#% description: Microsoft Virtual Earth naming style (default is Google Map naming style)
-#%END
-#%flag
-#% key: f
-#% description: Force processing if the current location projection test fails (not recommended)
-#%END
-#%flag
-#% key: h
-#% description: Create an example html file with google maps API for exported data (google maps only)
-#%END
-#%flag
-#% key: m
-#% description: Cut the output to specified edges
-#%END
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old,cell,raster
-#% description: Input raster map
-#% required : yes
-#%END
-#%option
-#% key: location
-#% type: string
-#% description: Location of input map
-#% required : no
-#%END
-#%option
-#% key: mapset
-#% type: string
-#% description: Mapset of input map
-#% required : no
-#%END
-#%option
-#% key: interpolation
-#% type: string
-#% description: Interpolation method to use for re-projection
-#% answer: nearest
-#% options: nearest,bilinear,cubic
-#% required : no
-#% multiple: no
-#%end
-#%option
-#% key: zoom
-#% type: double
-#% description: Google Map zoom level to export
-#% options : 0-21
-#% required : yes
-#%END
-#%option
-#% key: n
-#% type: double
-#% description: Custom northern edge in lat/long on wgs84 ellipsoid
-#% options : -85.05-85.05
-#% required : no
-#%END
-#%option
-#% key: s
-#% type: double
-#% description: Custom southern edge in lat/long on wgs84 ellipsoid
-#% required : no
-#%END
-#%option
-#% key: e
-#% type: double
-#% description: Custom eastern edge in lat/long on wgs84 ellipsoid
-#% options : -180-180
-#% required : no
-#%END
-#%option
-#% key: w
-#% type: double
-#% description: Custom western edge in lat/long on wgs84 ellipsoid
-#% required : no
-#%END
-#%option
-#% key: outdir
-#% type: string
-#% description: directory to write output tiles
-#% answer: googlemap
-#% required : no
-#%END
-#constants:
-M2PX=$(echo "5340353.715440871795 / 6378137" | bc -l) #correction from meters to pixels(zoom 17)
-PX2M=$(echo "6378137 / 5340353.715440871795" | bc -l) #correction from meters to pixels(zoom 17)
-LEFT=$(echo "-16777216 * $PX2M" | bc -l) #minimum left coordinate of projection
-cleanup()
-#remove data
- g.remove rast=out$$ --quiet
-exitprocedure()
- g.message -e "User break!"
- cleanup
- exit 1
-trap "exitprocedure" 2 3 15
-if [ -z $GISBASE ] ; then
- echo "You must be in GRASS GIS to run this program." 1>&2
- exit 1
-fi
-# check if bc exists
-if [ ! -x "`which bc`" ] ; then
- g.message -e "'bc' program not found, install it first"
- exit 1
-fi
-# check if cs2cs exists
-if [ ! -x "`which cs2cs`" ] ; then
- g.message -e "'cs2cs' program not found, install it first\
- http://proj.maptools.org"
- exit 1
-fi
-# check if grep exists
-if [ ! -x "`which grep`" ] ; then
- g.message -e "'grep' program not found, install it first"
- exit 1
-fi
-# check if awk exists
-if [ ! -x "`which awk`" ] ; then
- g.message -e "'awk' program not found, install it first"
- exit 1
-fi
-# check if sed exists
-if [ ! -x "`which sed`" ] ; then
- g.message -e "'sed' program not found, install it first"
- exit 1
-fi
-# check if tr exists
-if [ ! -x "`which tr`" ] ; then
- g.message -e "'tr' program not found, install it first"
- exit 1
-fi
-# check if wc exists
-if [ ! -x "`which wc`" ] ; then
- g.message -e "'wc' program not found, install it first"
- exit 1
-fi
-# check if cat exists
-if [ ! -x "`which cat`" ] ; then
- g.message -e "'cat' program not found, install it first"
- exit 1
-fi
-# save command line
-if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec g.parser "$0" "$@"
-fi
-map="$GIS_OPT_INPUT"
-location="$GIS_OPT_LOCATION"
-mapset="$GIS_OPT_MAPSET"
-level="$GIS_OPT_ZOOM"
-interpol="$GIS_OPT_INTERPOLATION"
-newdir="$GIS_OPT_OUTDIR"
-# test if input map is set in form map at mapset
-hasat=`echo $map | grep '@' |wc -c`
-if [ $hasat -ge "3" ]; then #at least a at b
- mapset=`echo $map | awk -F'@' '{print $2}'`
- map=`echo $map | awk -F'@' '{print $1}'`
-fi
-# test zoom level for MVE export
-if [ $GIS_FLAG_E -eq "1" -a $level -eq "0" ]; then
- g.message -e "zoom level $level not allowed for Microsoft Virtual Earth export"
- exit 1
-fi
-# take env variables from current GRASS session
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
- GMlocation=$LOCATION_NAME
- GMmapset=$MAPSET
- GMgisdbase=$GISDBASE
- GMmapsetpath=$GISDBASE"/"$LOCATION_NAME"/"$MAPSET
-# if location and/or mapset not set use current location/mapset
- if [ -z $mapset ]; then mapset=$GMmapset; fi
- if [ -z $location ]; then location=$GMlocation; fi
- mapsetpath=$GISDBASE"/"$location"/"$mapset
-# check wheter input map mapset differs from current mapset
- diffinputmapset=1
- if [ $GMmapset = $mapset -a $GMlocation = $location ]; then diffinputmapset=0; fi
- if [ $GMmapset != $mapset -a $GMlocation = $location ]; then
- g.mapsets addmapset=$mapset
- diffinputmapset=0;
- fi
-#test whether the script is run from mapset with google maps projection
- gmproj='+proj=merc +lat_ts=0.0000000000 +lon_0=0.0000000000 +k_0=1.0000000000 +x_0=0 +y_0=0 +no_defs +a=6378137 +b=6378137'
- latlonproj='+proj=longlat +a=6378137 +rf=298.257223563 +no_defs'
-correctproj=1
- # test presence of all proj parameters
-reqired_par="proj lat_ts lon_0 x_0 y_0 a b no_defs"
-for reqpar in $reqired_par
-do
- par=`g.proj -j | grep $reqpar`
- if [ -z "$par" ]; then
- correctproj=0
- fi
-done
-if [ $correctproj -eq 1 ]; then
- # get individual proj parameters
- eval `g.proj -j | tr '+' ' ' | grep -v no_defs`
- : ${proj?} ${lat_ts?} ${lon_0?} ${x_0?} ${y_0?} ${a?} ${b?} >&1
- nodefs=`g.proj -j | grep no_defs`
- # test presence/value of text parameters
- if [ -z $nodefs -o $proj != 'merc' ]; then correctproj=0; fi
- # test values of numeric parameters
- testline="$lat_ts!=0.0 || $lon_0!=0.0 || $x_0!=0.0 || $y_0!=0.0 || $a!=6378137 || $b!=6378137"
- if [ $(echo $testline | bc -l) -eq 1 ]; then correctproj=0; fi
-fi
- # inform user
-if [ $correctproj -ne 1 ]; then
- if [ $GIS_FLAG_F -eq "1" ]; then
- g.message -w "projection for location \"$GMlocation\" differs from required google map mercator projection"
- else
- g.message -e "projection for location \"$GMlocation\" differs from required google map mercator projection"
- currproj=`g.proj -jf`
- g.message message="current projection: $currproj"
- g.message message="required projection: $gmproj"
- exit 1
- fi
-fi
-#test whether the input grass mapset is used/exists
-if [ $diffinputmapset -eq 1 ]; then
- msg=`g.mapset mapset=$mapset location=$location gisdbase=$GISDBASE 2>&1`
- msgERR=`echo $msg | grep 'ERROR' | wc -c`
- if [ $msgERR -gt 0 ]
- then
- g.message -e "input Mapset does not exist, or is used by GRASS"
- exit 1
- else # location/mapset successfuly changed, return back to the google map location/mapset
- g.mapset mapset=$GMmapset location=$GMlocation gisdbase=$GMgisdbase >& /dev/null
- fi
-fi
-#creates new directory for output
- if [ -z $newdir ]; then
- newdir="."
- elif [ ! -d $newdir ]; then
- mkdir $newdir
- elif [ $newdir = "googlemap" ]; then
- g.message "exporting tiles to ./googlemap"
- fi
-# check existence of input map
- infile=$mapsetpath"/cell/"$map
- if [ ! -f "$infile" ]; then
- g.message -e "cannot find input map " $map
- exit 1
- fi
-# force creation of color file if not exists
- colorfile=$mapsetpath"/colr/"$map
- if [ ! -f "$colorfile" ]; then
- if [ $diffinputmapset -eq 1 ]; then
- g.mapset mapset=$mapset location=$location gisdbase=$GISDBASE >& /dev/null
- r.colors $map rast=$map
- else
- fi
- g.message -w 'forced creation of colr file...'
- fi
-# calculate resolution
- res=$(echo "(2^(17-$level)) * $PX2M" | bc -l)
- reshalf=$(echo "$res/2" | bc -l)
- segsize=$(echo "$res*256" | bc -l)
- g.region res=$res
-# get N,E,W,S and proj in input LOCATION
- inproj=`g.proj -jf`
- eval `r.info -g $map`
- : ${north?} ${south?} ${west?} ${east?}
- # go back to the GM loacation
- else
- minx=$west
- maxx=$east
- miny=$south
- maxy=$north
- fi
-# calculate bounding box in longitude/latitude and check for the limits
- cs2cs_cmd='cs2cs -f %.10f '$inproj' +to '$latlonproj
- #get min longitude
- if [ -n "$GIS_OPT_W" ]; then
- minlon="$GIS_OPT_W"
- else
- minlon1=`echo $west $north 0 | $cs2cs_cmd | awk '{print $1}'`
- minlon2=`echo $west $south 0 | $cs2cs_cmd | awk '{print $1}'`
- minlon=$minlon2
- if [ $(echo "$minlon1 < $minlon2" | bc -l) -eq 1 ] ; then minlon=$minlon1; fi
- if [ $(echo "$minlon <= -180.0" | bc -l) -eq 1 ]; then minlon=-179.999999999999; fi
- fi
- #get max longitude
- if [ -n "$GIS_OPT_E" ]; then
- maxlon="$GIS_OPT_E"
- else
- maxlon1=`echo $east $north 0 | $cs2cs_cmd | awk '{print $1}'`
- maxlon2=`echo $east $south 0 | $cs2cs_cmd | awk '{print $1}'`
- maxlon=$maxlon2
- if [ $(echo "$maxlon1 > $maxlon2" | bc -l) -eq 1 ] ; then maxlon=$maxlon1; fi
- if [ $(echo "$maxlon >= 180.0" | bc -l) -eq 1 ]; then maxlon=179.999999999999; fi
- fi
- #get min latitude
- if [ -n "$GIS_OPT_S" ]; then
- minlat="$GIS_OPT_S";
- else
- minlat1=`echo $west $south 0 | $cs2cs_cmd | awk '{print $2}'`
- minlat2=`echo $east $south 0 | $cs2cs_cmd | awk '{print $2}'`
- minlat=$minlat2
- if [ $(echo "$minlat1 < $minlat2" | bc -l) -eq 1 ] ; then minlat=$minlat1; fi
- if [ $(echo "$minlat < -85.05112877980659" | bc -l) -eq 1 ]; then minlat=-85.05112877980659; fi
- fi
- #get max latitude
- if [ -n "$GIS_OPT_N" ]; then
- maxlat="$GIS_OPT_N";
- else
- maxlat1=`echo $west $north 0 | $cs2cs_cmd | awk '{print $2}'`
- maxlat2=`echo $east $north 0 | $cs2cs_cmd | awk '{print $2}'`
- maxlat=$maxlat2
- if [ $(echo "$maxlat1 > $maxlat2" | bc -l) -eq 1 ] ; then maxlat=$maxlat1; fi
- if [ $(echo "$maxlat > 85.05112877980659" | bc -l) -eq 1 ]; then maxlat=85.05112877980659; fi
- fi
- cs2cs_cmd='cs2cs -f %.10f '$latlonproj' +to '$gmproj
- if [ $diffinputmapset -eq 1 -o -n "$GIS_OPT_W" ]; then
- minx=`echo $minlon $minlat 0 | $cs2cs_cmd | awk '{print $1}'`
- fi
- if [ $diffinputmapset -eq 1 -o -n "$GIS_OPT_E" ]; then
- maxx=`echo $maxlon $minlat 0 | $cs2cs_cmd | awk '{print $1}'`
- fi
- if [ $diffinputmapset -eq 1 -o -n "$GIS_OPT_S" ]; then
- miny=`echo $minlon $minlat 0 | $cs2cs_cmd | awk '{print $2}'`
- fi
- if [ $diffinputmapset -eq 1 -o -n "$GIS_OPT_N" ]; then
- maxy=`echo $minlon $maxlat 0 | $cs2cs_cmd | awk '{print $2}'`
- fi
-# remove mask if exists
- if [ -f $GMmapsetpath/cell/MASK ] ; then
- g.message "removing mask"
- g.rename rast=MASK,MASK$$ >& /dev/null
- fi
-# tiles usually cover larger area than bounding box, to clip it to box uncomment this
- if [ $GIS_FLAG_M -eq "1" ]; then
- g.region n=$maxy s=$miny e=$maxx w=$minx res=$res >& /dev/null
- r.mapcalc MASK=1 >& /dev/null
- fi
-#calcuate tiles
- #reshalf is used to calculate centers of pixels from edges of pixels
- colleft=$(echo "numb=(($minx - $LEFT + $reshalf) / $segsize);scale = 0;numb/1" | bc -l)
- colright=$(echo "numb=(($maxx - $LEFT - $reshalf) / $segsize);scale = 0;numb/1" | bc -l)
- rowtop=$(echo "numb=((0.0 - $maxy - $LEFT + $reshalf) / $segsize);scale = 0;numb/1" | bc -l)
- rowbottom=$(echo "numb=((0.0 - $miny - $LEFT - $reshalf) / $segsize);scale = 0;numb/1" | bc -l)
- g.message "Tiles: zoom $level cols $colleft - $colright rows $rowtop - $rowbottom"
-#finaly loop through the tiles and export
-ncolorfile=$GMmapsetpath"/colr/out"$$
-i=$colleft
-while [ $i -le $colright ]
-do
- leftt=$(echo "numb=($i * $segsize) + $LEFT;scale = 10;numb/1" | bc -l)
- right=$(echo "numb=($leftt + $segsize) ;scale = 10;numb/1" | bc -l)
- j=$rowtop
- while [ $j -le $rowbottom ]
- do
- top=$(echo "numb=0.0 - ($j * $segsize) - $LEFT;scale = 10;numb/1" | bc -l)
- bottom=$(echo "numb=($top - $segsize) ;scale = 10;numb/1" | bc -l)
- g.message "tile $i $j"
- g.region w=$leftt e=$right s=$bottom n=$top res=$res
-#decide what will be exported
- g.message -v "projecting..."
- r.proj input=$map location=$location mapset=$mapset method=$interpol output=out$$ --quiet >& /dev/null
- else
- r.mapcalc out$$=$map
- fi
- #if nothing was projected (may happen if outside tha data) create empty file
- nfile=$GMmapsetpath"/cell/out"$$
- if [ ! -f $nfile ]; then
- r.mapcalc out$$='null()' 2>&1 /dev/null
- fi
- cp $colorfile $ncolorfile # just copy color file
- #export data
- if [ $GIS_FLAG_E -eq "1" ] ; then
- #file name in microsoft virtual earth style
- mve_tile=$(echo "scale=0; res=0; lev=$level; anx=$i; any=$j; while(lev > 0){rx=0; ry=0; tileshalf=(2^(lev-1)); if (anx >= tileshalf) {anx=anx - tileshalf; rx=1};if (any >= tileshalf) {any=any - tileshalf; ry=1};res=res+((10^(lev-1))*((2*ry)+rx));lev=--lev }; res" | bc -l)
- mve_tile=`printf "%0"$level"d" $mve_tile`
- mve_file=$newdir"/"$mve_tile".png"
- outfile=$mve_file
- else
- # file name in google map style
- gm_file=$newdir"/z"$level"_"$i"x"$j".png"
- outfile=$gm_file
- fi
- g.message -v "exporting $outfile ..."
- r.out.png --quiet input=out$$ output=$outfile
-#remove data
- if [ -f $GMmapsetpath"/cell/out"$$ ]
- then
- g.remove out$$ >& /dev/null
- fi
- j=`expr $j + 1`
- done
- i=`expr $i + 1`
-done
-#### html file
-if [ $GIS_FLAG_H -eq "1" -a $GIS_FLAG_E -ne "1" ]; then
- midlon=$(echo "($maxlon + $minlon)/2" | bc -l)
- midlat=$(echo "($maxlat + $minlat)/2" | bc -l)
- cat << EOF > "${map}.html"
-<!DOCTYPE html "-//W3C//DTD XHTML 1.0 Strict//EN"
-"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
-<html xmlns="http://www.w3.org/1999/xhtml">
-<head>
- <meta http-equiv="content-type" content="text/html; charset=utf-8"/>
- <title>GRASS GIS r.out.gmap result</title>
- <script src="http://maps.google.com/maps?file=api&v=2&key=abcdefg"
- type="text/javascript"></script>
- <script type="text/javascript">
- function initialize() {
- if (GBrowserIsCompatible()) {
- var map = new GMap2(document.getElementById("map_canvas"));
- /* add layer from grass*/
- mapbounds = new GLatLngBounds(new GLatLng($minlat, $minlon), new GLatLng($maxlat, $maxlon));
- var copyCollection = new GCopyrightCollection("");
- copyCollection.addCopyright(new GCopyright(17, mapbounds, 2, "© 2008 GRASS GIS<br>"));
- var anewLayer = new GTileLayer(copyCollection, 1,171);
- anewLayer.getTileUrl = function(a,b){ return "${newdir}/z"+b+"_"+(a.x)+"x"+(a.y)+".png";};
- var anewMapType = new GMapType([anewLayer], G_NORMAL_MAP.getProjection(), "Grassmap");
- anewMapType.getMinimumResolution = function() {return 0;};
- anewMapType.getMaximumResolution = function() {return 17;};
- map.addMapType(anewMapType);
- map.addControl(new GLargeMapControl());
- map.addControl(new GMapTypeControl());
- map.setCenter(new GLatLng(${midlat}, ${midlon}), ${level}, anewMapType);
- </script>
-</head>
-<body onload="initialize()" onunload="GUnload()">
- <div id="map_canvas" style="width: 500px; height: 400px"></div>
-</body>
-</html>
-EOF
- g.message "'${map}.html' created."
-fi
-#remove custom mask
-if [ $GIS_FLAG_M -eq "1" ]; then
- g.remove rast=MASK >& /dev/null
-fi
-#restore mask if exists
-if [ -f $GMmapsetpath/cell/MASK$$ ] ; then
- g.message "restoring mask"
- g.remove MASK >& /dev/null
- g.rename rast=MASK$$,MASK >& /dev/null
-fi
