[GRASS-SVN] r30905 - grass/trunk/gui/wxpython/gui_modules
Tue Apr 8 07:39:43 EDT 2008
Author: martinl
Date: 2008-04-08 07:39:43 -0400 (Tue, 08 Apr 2008)
New Revision: 30905
   grass/trunk/gui/wxpython/gui_modules/dbm.py
   grass/trunk/gui/wxpython/gui_modules/render.py
wxGUI (render): additional fixes for rendering query layers, related to r30904
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py	2008-04-08 10:51:37 UTC (rev 30904)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py	2008-04-08 11:39:43 UTC (rev 30905)
@@ -1635,6 +1635,9 @@
         list = self.FindWindowById(self.layerPage[self.layer]['data'])
         cats = list.GetSelectedItems() # FIXME: category can be hiden in list
+        if self.mapdisplay.Map.GetLayerIndex(self.qlayer) < 0:
+            self.qlayer = None
         if self.qlayer:
             self.qlayer.SetCmd(self.mapdisplay.AddTmpVectorMapLayer(self.vectmap, cats, addLayer=False))
         else:
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2008-04-08 10:51:37 UTC (rev 30904)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2008-04-08 11:39:43 UTC (rev 30905)
@@ -73,6 +73,8 @@
         self.hidden  = hidden
         self.opacity = opacity
+        self.force_render = True
         Debug.msg (3, "Layer.__init__(): type=%s, cmd='%s', name=%s, " \
                        "active=%d, opacity=%d, hidden=%d" % \
                        (self.type, self.GetCmd(string=True), self.name, self.active,
@@ -158,6 +160,8 @@
         else:
             os.unsetenv("GRASS_PNGFILE")
+        self.force_render = False
         return self.mapfile
     def GetCmd(self, string=False):
@@ -198,6 +202,9 @@
         """Set new command for layer"""
         self.cmdlist = cmd
         Debug.msg(3, "Layer.SetCmd(): cmd='%s'" % self.GetCmd(string=True))
+        # for re-rendering
 class MapLayer(Layer):
     """Represents map layer in the map canvas"""
@@ -720,9 +727,12 @@
                 continue
             # render if there is no mapfile
-            if layer.mapfile == None or \
-                   (not os.path.isfile(layer.mapfile) or not os.path.getsize(layer.mapfile)):
-                layer.Render()
+            if force or \
+               layer.force_render or \
+               layer.mapfile == None or \
+               (not os.path.isfile(layer.mapfile) or not os.path.getsize(layer.mapfile)):
+                if not layer.Render():
+                    continue
             # update process bar
             if mapWindow is not None:
@@ -730,11 +740,6 @@
             wx.Yield()
-            # redraw layer content
-            if force:
-                if not layer.Render():
-                    continue
             # add image to compositing list
             if layer.type != "overlay":
                 maps.append(layer.mapfile)
@@ -974,21 +979,26 @@
         return None
-    def GetLayerIndex(self, layer):
+    def GetLayerIndex(self, layer, overlay=False):
         Get index of layer in layer list.
         @param layer layer instace in layer tree
+        @param overlay use list of overlays instead
         @return layer index
-        @return None
+        @return -1 if layer not found
-        if layer in self.layers:
-            return self.layers.index(layer)
+        if overlay:
+            list = self.overlay
         else:
-            return None
+            list = self.layers
+        if layer in list:
+            return list.index(layer)
+        return -1
     def AddOverlay(self, id, type, command,
                    l_active=True, l_hidden=True, l_opacity=1.0, l_render=False):
