Author: glynn
Date: 2008-04-08 22:00:27 -0400 (Tue, 08 Apr 2008)
New Revision: 30908
grass/trunk/general/g.mapsets/main_cmd.c
Add removemapset= option
Modified: grass/trunk/general/g.mapsets/main_cmd.c
--- grass/trunk/general/g.mapsets/main_cmd.c 2008-04-09 00:52:14 UTC (rev 30907)
+++ grass/trunk/general/g.mapsets/main_cmd.c 2008-04-09 02:00:27 UTC (rev 30908)
@@ -38,8 +38,8 @@
char **tokens;
int no_tokens;
FILE *fp;
- struct GModule *module;
- struct Option *opt1, *opt2;
+ struct GModule *module;
+ struct Option *opt1, *opt2, *opt3;
struct Flag *print;
struct Flag *list;
@@ -66,6 +66,13 @@
opt2->multiple = YES ;
opt2->description= _("Name(s) of existing mapset(s) to add to search list");
+ opt3 = G_define_option() ;
+ opt3->key = "removemapset" ;
+ opt3->type = TYPE_STRING ;
+ opt3->required = NO ;
+ opt3->multiple = YES ;
+ opt3->description= _("Name(s) of existing mapset(s) to remove from search list");
list = G_define_flag();
list->key = 'l';
list->description = _("List all available mapsets");
@@ -128,7 +135,29 @@
+ /* remove from existing search path */
+ if (opt3->answer)
+ char *oldname;
+ Path[0] = '\0';
+ /* read existing mapsets from SEARCH_PATH */
+ for (n = 0; (oldname = G__mapset_name(n)) ; n++)
+ int found = 0;
+ for (ptr = opt3->answers; *ptr; ptr++)
+ if (strcmp(oldname, *ptr) == 0)
+ found = 1;
+ if (found)
+ continue;
+ strcat (Path, oldname);
+ strcat (Path, " ");
/* stuffem sets nchoices*/
if (nchoices == 0)
