[GRASS-SVN] r30915 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Wed Apr 9 11:46:19 EDT 2008
Author: martinl
Date: 2008-04-09 11:46:19 -0400 (Wed, 09 Apr 2008)
New Revision: 30915
grass/trunk/gui/wxpython/gui_modules/menudata.py
grass/trunk/gui/wxpython/gui_modules/workspace.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: basic prototype of GRC file loader implemented (trac, #80)
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py 2008-04-09 11:31:53 UTC (rev 30914)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py 2008-04-09 15:46:19 UTC (rev 30915)
@@ -41,6 +41,11 @@
"self.OnWorkspaceLoad",
+ (_("Load GRC file (Tcl/Tk GUI)"),
+ _("Load map layers from GRC file to layer tree (not fully implemented)"),
+ "self.OnWorkspaceLoadGrcFile",
(_("Save workspace"),
_("Save current workspace to file"),
"self.OnWorkspaceSave",
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py 2008-04-09 11:31:53 UTC (rev 30914)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py 2008-04-09 15:46:19 UTC (rev 30915)
@@ -5,6 +5,7 @@
Classes:
- ProcessWorkspaceFile
+ - ProcessGrcFile
(C) 2007-2008 by the GRASS Development Team
This program is free software under the GNU General Public
@@ -16,6 +17,10 @@
@date 2007-2008
+import os
+import wx
### for gxw (workspace file) parsering
# xmlproc not available on Mac OS
# from xml.parsers.xmlproc import xmlproc
@@ -144,3 +149,243 @@
if self.inValue:
self.value += ch
+class ProcessGrcFile(object):
+ def __init__(self, filename):
+ """Process GRC file"""
+ self.filename = filename
+ # elements
+ self.inGroup = False
+ self.inRaster = False
+ self.inVector = False
+ # list of layers
+ self.layers = []
+ # error message
+ self.error = ''
+ self.num_error = 0
+ def read(self, parent):
+ """Read GRC file
+ @param parent parent window
+ @return list of map layers
+ try:
+ file = open(self.filename, "r")
+ except IOError:
+ wx.MessageBox(parent=parent,
+ message=_("Unable to open file <%s> for reading.") % self.filename,
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
+ return []
+ line_id = 1
+ for line in file.readlines():
+ self.process_line(line.rstrip('\n'), line_id)
+ line_id +=1
+ file.close()
+ if self.num_error > 0:
+ message=_("Some lines were skipped when reading settings "
+ "from file <%s>.\nSee 'Command output' window for details.\n\n"
+ "Number of skipped lines: %d" % \
+ (self.filename, self.num_error)),
+ caption=_("Warning"), style=wx.OK | wx.ICON_EXCLAMATION)
+ parent.goutput.WriteLog('Map layers loaded from GRC file <%s>' % self.filename)
+ parent.goutput.WriteLog('Skipped lines:\n%s' % self.error)
+ return self.layers
+ def process_line(self, line, line_id):
+ """Process line definition"""
+ element = self._get_element(line)
+ if element == 'Group':
+ self.groupName = self._get_value(line)
+ self.layers.append({
+ "type" : 'group',
+ "name" : self.groupName,
+ "checked" : None,
+ "opacity" : None,
+ "cmd" : None,
+ "group" : self.inGroup,
+ "display" : 0 })
+ self.inGroup = True
+ elif element == '_check':
+ if int(self._get_value(line)) == 1:
+ self.layers[-1]['checked'] = True
+ else:
+ self.layers[-1]['checked'] = False
+ elif element == 'End':
+ if self.inRaster:
+ elif self.inVector:
+ elif self.inGroup:
+ elif element == 'opacity':
+ self.layers[-1]['opacity'] = float(self._get_value(line))
+ # raster
+ elif element == 'Raster':
+ self.inRaster = True
+ "type" : 'raster',
+ "name" : self._get_value(line),
+ "checked" : None,
+ "opacity" : None,
+ "cmd" : ['d.rast'],
+ "display" : 0})
+ elif element == 'map' and self.inRaster:
+ self.layers[-1]['cmd'].append('map=%s' % self._get_value(line))
+ elif element == 'overlay' and self.inRaster:
+ self.layers[-1]['cmd'].append('-o')
+ elif element == 'rastquery' and self.inRaster:
+ value = self._get_value(line)
+ if value != '':
+ self.layers[-1]['cmd'].append('catlist=%s' % value)
+ elif element == 'bkcolor' and self.inRaster:
+ if value != '':
+ self.layers[-1]['cmd'].append('bg=%s' % value)
+ # vector
+ elif element == 'Vector':
+ self.inVector = True
+ "type" : 'vector',
+ "checked" : None,
+ "opacity" : None,
+ "cmd" : ['d.vect'],
+ "display" : 0})
+ elif element == 'vect' and self.inVector:
+ elif element in ('display_shape',
+ 'display_cat',
+ 'display_topo',
+ 'display_dir',
+ 'display_attr',
+ 'type_point',
+ 'type_line',
+ 'type_boundary',
+ 'type_centroid',
+ 'type_area',
+ 'type_face') and self.inVector:
+ name = element.split('_')[0]
+ type = element.split('_')[1]
+ paramId = self._get_cmd_param_index(self.layers[-1]['cmd'], name)
+ if paramId == -1:
+ self.layers[-1]['cmd'].append('%s=%s' % (name, type))
+ else:
+ self.layers[-1]['cmd'][paramId] += ',%s' % type
+ elif element in ('color',
+ 'fcolor',
+ 'lcolor') and self.inVector:
+ if value != '':
+ self.layers[-1]['cmd'].append('%s=%s' % (element,
+ self._color_name_to_rgb(value)))
+ elif element == 'rdmcolor' and self.inVector:
+ self.layers[-1]['cmd'].append('-c')
+ elif element == 'sqlcolor' and self.inVector:
+ self.layers[-1]['cmd'].append('-a')
+ elif element in ('icon',
+ 'size',
+ 'layer',
+ 'xref',
+ 'yref',
+ 'lsize',
+ 'where',
+ 'minreg',
+ 'maxreg') and self.inVector:
+ if value != '':
+ value))
+ elif element == 'lwidth':
+ if value != '':
+ self.layers[-1]['cmd'].append('width=%s' % value)
+ elif element == 'lfield':
+ if value != '':
+ self.layers[-1]['cmd'].append('llayer=%s' % value)
+ elif element == 'attribute':
+ if value != '':
+ self.layers[-1]['cmd'].append('attrcol=%s' % value)
+ elif element == 'cat':
+ if value != '':
+ self.layers[-1]['cmd'].append('cats=%s' % value)
+ else:
+ self.error += _(' row %d:') % line_id + line + os.linesep
+ self.num_error += 1
+ def _get_value(self, line):
+ """Get value of element"""
+ try:
+ return line.strip(' ').split(' ')[1].strip(' ')
+ except:
+ return ''
+ def _get_element(self, line):
+ """Get element tag"""
+ return line.strip(' ').split(' ')[0].strip(' ')
+ def _get_cmd_param_index(self, cmd, name):
+ """Get index of parameter in cmd list
+ @param cmd cmd list
+ @param name parameter name
+ @return index
+ @return -1 if not found
+ i = 0
+ for param in cmd:
+ if '=' not in param:
+ i += 1
+ continue
+ if param.split('=')[0] == name:
+ return i
+ i += 1
+ return -1
+ def _color_name_to_rgb(self, value):
+ """Convert color name (#) to rgb values"""
+ col = wx.NamedColour(value)
+ return str(col.Red()) + ':' + \
+ str(col.Green()) + ':' + \
+ str(col.Blue())
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-04-09 11:31:53 UTC (rev 30914)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-04-09 15:46:19 UTC (rev 30915)
@@ -454,9 +454,11 @@
layer = self.AppendItem(parentId=self.root,
text='', ct_type=1, wnd=ctrl)
elif lgroup is None or lgroup is True:
- # insert item on given position
+ # insert item as last child
parent = self.GetItemParent(self.layer_selected)
- layer = self.InsertItem(parentId=parent, input=self.GetPrevSibling(self.layer_selected),
+ # layer = self.InsertItem(parentId=parent, input=self.GetPrevSibling(self.layer_selected),
+ # text='', ct_type=1, wnd=ctrl)
+ layer = self.AppendItem(parentId=parent,
else: # group (first child of self.layer_selected)
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-04-09 11:31:53 UTC (rev 30914)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-04-09 15:46:19 UTC (rev 30915)
@@ -660,6 +660,43 @@
busy.Destroy()
+ def OnWorkspaceLoadGrcFile(self, event):
+ """Load map layers from GRC file (Tcl/Tk GUI) into map layer tree"""
+ dlg = wx.FileDialog(parent=self, message=_("Choose GRC file to load"),
+ defaultDir=os.getcwd(), wildcard="*.grc")
+ filename = ''
+ if dlg.ShowModal() == wx.ID_OK:
+ filename = dlg.GetPath()
+ if filename == '':
+ return
+ Debug.msg(4, "GMFrame.OnWorkspaceLoadGrcFile(): filename=%s" % filename)
+ # start new map display if no display is available
+ if not self.curr_page:
+ self.NewDisplay()
+ busy = wx.BusyInfo(message=_("Please wait, loading map layers into layer tree..."),
+ parent=self)
+ wx.Yield()
+ for layer in workspace.ProcessGrcFile(filename).read(self):
+ maptree = self.gm_cb.GetPage(layer['display']).maptree
+ newItem = maptree.AddLayer(ltype=layer['type'],
+ lname=layer['name'],
+ lchecked=layer['checked'],
+ lopacity=layer['opacity'],
+ lcmd=layer['cmd'],
+ lgroup=layer['group'])
+ busy.Destroy()
+ if maptree:
+ # reverse list of map layers
+ maptree.Map.ReverseListOfLayers()
def OnWorkspaceSaveAs(self, event=None):
"""Save workspace definition to selected file"""
