[GRASS-SVN] r30934 - grass/trunk/lib/external/shapelib
Fri Apr 11 05:54:10 EDT 2008
Author: neteler
Date: 2008-04-11 05:54:10 -0400 (Fri, 11 Apr 2008)
New Revision: 30934
Added:
   grass/trunk/lib/external/shapelib/safileio.c
   grass/trunk/lib/external/shapelib/README
added safileio.c from Frank Warmerdam/SHAPELIB for SASetupDefaultHooks etc
Modified: grass/trunk/lib/external/shapelib/README
--- grass/trunk/lib/external/shapelib/README	2008-04-11 09:33:44 UTC (rev 30933)
+++ grass/trunk/lib/external/shapelib/README	2008-04-11 09:54:10 UTC (rev 30934)
@@ -1,15 +1,19 @@
-Update history of SHAPELIB:
- ogr/ogrsf_frmts/shape/
+Update history of SHAPELIB copy:
+* files shpopen.c,shapefil.h,dbfopen.c:
+   from ogr/ogrsf_frmts/shape/
+* file safileio.c
+   from SHAPELIB itself (http://shapelib.maptools.org/)
 Last update
 * taken from GDAL 1.5.1-SVN (Sun Mar 30 11:20:43 CEST 2008)
 * taken from GDAL 1.5.0-CVS (Wed Sep  5 13:48:48 CEST 2007)
 * taken from GDAL 1.3.2-CVS (Sat Jun 17 22:08:04 CEST 2006)
 Additional fixes:
- - dbfopen.c (around line 1013)
+* dbfopen.c (around line 1013)
    GDAL bug #809 (http://trac.osgeo.org/gdal/ticket/809)
- - Use <grass/shapefil.h> etc rather than "shapefil.h"
+* Use <grass/shapefil.h> etc rather than "shapefil.h"
    in both shpopen.c and dbfopen.c
Added: grass/trunk/lib/external/shapelib/safileio.c
--- grass/trunk/lib/external/shapelib/safileio.c	                        (rev 0)
+++ grass/trunk/lib/external/shapelib/safileio.c	2008-04-11 09:54:10 UTC (rev 30934)
@@ -0,0 +1,286 @@
+ * $Id: safileio.c,v 1.4 2008/01/16 20:05:14 bram Exp $
+ * Project:  Shapelib
+ * Purpose:  Default implementation of file io based on stdio.
+ * Author:   Frank Warmerdam, warmerdam at pobox.com
+ * Copyright (c) 2007, Frank Warmerdam
+ * This software is available under the following "MIT Style" license,
+ * or at the option of the licensee under the LGPL (see LICENSE.LGPL).  This
+ * option is discussed in more detail in shapelib.html.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
+ * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * $Log: safileio.c,v $
+ * Revision 1.4  2008/01/16 20:05:14  bram
+ * Add file hooks that accept UTF-8 encoded filenames on some platforms.  Use SASetupUtf8Hooks
+ *  tosetup the hooks and check SHPAPI_UTF8_HOOKS for its availability.  Currently, this
+ *  is only available on the Windows platform that decodes the UTF-8 filenames to wide
+ *  character strings and feeds them to _wfopen and _wremove.
+ * Revision 1.3  2007/12/18 18:28:11  bram
+ * - create hook for client specific atof (bugzilla ticket 1615)
+ * - check for NULL handle before closing cpCPG file, and close after reading.
+ * Revision 1.2  2007/12/15 20:25:30  bram
+ * dbfopen.c now reads the Code Page information from the DBF file, and exports
+ * this information as a string through the DBFGetCodePage function.  This is
+ * either the number from the LDID header field ("LDID/<number>") or as the
+ * content of an accompanying .CPG file.  When creating a DBF file, the code can
+ * be set using DBFCreateEx.
+ * Revision 1.1  2007/12/06 06:56:41  fwarmerdam
+ * new
+#include "shapefil.h"
+#include <math.h>
+#include <limits.h>
+#include <assert.h>
+#include <stdlib.h>
+#include <string.h>
+#include <stdio.h>
+SHP_CVSID("$Id: safileio.c,v 1.4 2008/01/16 20:05:14 bram Exp $");
+#ifdef SHPAPI_UTF8_HOOKS
+#   ifdef SHPAPI_WINDOWS
+#       define WIN32_LEAN_AND_MEAN
+#       define NOMINMAX
+#       include <windows.h>
+#       pragma comment(lib, "kernel32.lib")
+#   endif
+#endif
+/*                              SADFOpen()                              */
+SAFile SADFOpen( const char *pszFilename, const char *pszAccess )
+    return (SAFile) fopen( pszFilename, pszAccess );
+/*                              SADFRead()                              */
+SAOffset SADFRead( void *p, SAOffset size, SAOffset nmemb, SAFile file )
+    return (SAOffset) fread( p, (size_t) size, (size_t) nmemb,
+                             (FILE *) file );
+/*                             SADFWrite()                              */
+SAOffset SADFWrite( void *p, SAOffset size, SAOffset nmemb, SAFile file )
+    return (SAOffset) fwrite( p, (size_t) size, (size_t) nmemb,
+                              (FILE *) file );
+/*                              SADFSeek()                              */
+SAOffset SADFSeek( SAFile file, SAOffset offset, int whence )
+    return (SAOffset) fseek( (FILE *) file, (long) offset, whence );
+/*                              SADFTell()                              */
+SAOffset SADFTell( SAFile file )
+    return (SAOffset) ftell( (FILE *) file );
+/*                             SADFFlush()                              */
+int SADFFlush( SAFile file )
+    return fflush( (FILE *) file );
+/*                             SADFClose()                              */
+int SADFClose( SAFile file )
+    return fclose( (FILE *) file );
+/*                             SADFClose()                              */
+int SADRemove( const char *filename )
+    return remove( filename );
+/*                              SADError()                              */
+void SADError( const char *message )
+    fprintf( stderr, "%s\n", message );
+/*                        SASetupDefaultHooks()                         */
+void SASetupDefaultHooks( SAHooks *psHooks )
+    psHooks->FOpen   = SADFOpen;
+    psHooks->FRead   = SADFRead;
+    psHooks->FWrite  = SADFWrite;
+    psHooks->FSeek   = SADFSeek;
+    psHooks->FTell   = SADFTell;
+    psHooks->FFlush  = SADFFlush;
+    psHooks->FClose  = SADFClose;
+    psHooks->Remove  = SADRemove;
+    psHooks->Error   = SADError;
+    psHooks->Atof    = atof;
+#ifdef SHPAPI_WINDOWS
+/*                          Utf8ToWideChar                              */
+const wchar_t* Utf8ToWideChar( const char *pszFilename )
+    int nMulti, nWide;
+    wchar_t *pwszFileName;
+    nMulti = strlen(pszFilename) + 1;
+    nWide = MultiByteToWideChar( CP_UTF8, 0, pszFilename, nMulti, 0, 0);
+    if( nWide == 0 )
+        return NULL;
+    pwszFileName = (wchar_t*) malloc(nWide * sizeof(wchar_t));
+    if ( pwszFileName == NULL )
+        return NULL;
+    if( MultiByteToWideChar( CP_UTF8, 0, pszFilename, nMulti, pwszFileName, nWide ) == 0 )
+        free( pwszFileName );
+        return NULL;
+    return pwszFileName;
+/*                           SAUtf8WFOpen                               */
+SAFile SAUtf8WFOpen( const char *pszFilename, const char *pszAccess )
+    SAFile file = NULL;
+    const wchar_t *pwszFileName, *pwszAccess;
+    pwszFileName = Utf8ToWideChar( pszFilename );
+    pwszAccess = Utf8ToWideChar( pszAccess );
+    if( pwszFileName != NULL && pwszFileName != NULL)
+        file = (SAFile) _wfopen( pwszFileName, pwszAccess );
+    free ((wchar_t*) pwszFileName);
+    free ((wchar_t*) pwszAccess);
+    return file;
+/*                             SAUtf8WRemove()                          */
+int SAUtf8WRemove( const char *pszFilename )
+    const wchar_t *pwszFileName = Utf8ToWideChar( pszFilename );
+    int rc = -1;
+    if( pwszFileName != NULL )
+        rc = _wremove( pwszFileName );
+    return rc;
+#endif
+/*                          SASetupUtf8Hooks()                          */
+void SASetupUtf8Hooks( SAHooks *psHooks )
+    psHooks->FOpen   = SAUtf8WFOpen;
+    psHooks->Remove  = SAUtf8WRemove;
+#else
+#   error "no implementations of UTF-8 hooks available for this platform"
+#endif
+#endif
Property changes on: grass/trunk/lib/external/shapelib/safileio.c
___________________________________________________________________
   + native
