[GRASS-SVN] r30941 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Apr 11 13:13:16 EDT 2008
Author: martinl
Date: 2008-04-11 13:13:16 -0400 (Fri, 11 Apr 2008)
New Revision: 30941
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI (atm): use button 'apply' only for select statements, not for execute commands (add/drop/rename column, add layer, etc.)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-04-11 14:57:52 UTC (rev 30940)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-04-11 17:13:16 UTC (rev 30941)
@@ -461,12 +461,12 @@
# buttons
- self.btnApply = wx.Button(parent=self.panel, id=wx.ID_APPLY)
+ # self.btnApply = wx.Button(parent=self.panel, id=wx.ID_APPLY)
self.btnQuit = wx.Button(parent=self.panel, id=wx.ID_EXIT)
# self.btn_unselect = wx.Button(self, -1, "Unselect")
# events
- self.btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+ # self.btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
self.btnQuit.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
self.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnLayerPageChanged, self.browsePage)
self.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnLayerPageChanged, self.manageTablePage)
@@ -546,6 +546,8 @@
# border=3)
# sql statement box
+ btnApply = wx.Button(parent=panel, id=wx.ID_APPLY)
+ btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
btnSqlBuilder = wx.Button(parent=panel, id=wx.ID_ANY, label=_("SQL Builder"))
btnSqlBuilder.Bind(wx.EVT_BUTTON, self.OnBuilder)
@@ -584,7 +586,8 @@
flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
sqlFlexSizer.Add(item=sqlSimpleSizer,
flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
- sqlFlexSizer.Add((0,0))
+ sqlFlexSizer.Add(item=btnApply,
+ flag=wx.ALIGN_RIGHT)
sqlFlexSizer.Add(item=sqlAdvanced,
flag=wx.ALIGN_CENTER_VERTICAL)
sqlFlexSizer.Add(item=sqlStatement,
@@ -650,7 +653,7 @@
# table description
table = self.mapDBInfo.layers[layer]['table']
tableBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
- label=" %s " % _("Table %s") % table)
+ label=" %s " % _("Table %s - right-click to delete records") % table)
tableSizer = wx.StaticBoxSizer(tableBox, wx.VERTICAL)
@@ -719,10 +722,10 @@
# rename col
label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Rename column"))
- column = wx.TextCtrl(parent=panel, id=wx.ID_ANY, value='',
- size=(150, -1), style=wx.TE_PROCESS_ENTER)
- column.Bind(wx.EVT_TEXT, self.OnTableRenameColumnName,)
- column.Bind(wx.EVT_TEXT_ENTER, self.OnTableItemChange)
+ column = wx.ComboBox(parent=panel, id=wx.ID_ANY, size=(150, -1),
+ style=wx.CB_SIMPLE | wx.CB_READONLY,
+ choices=self.mapDBInfo.GetColumns(table))
+ column.SetSelection(0)
self.layerPage[layer]['renameCol'] = column.GetId()
addSizer.Add(item=label,
@@ -862,8 +865,8 @@
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
btnSizer.Add(item=self.btnQuit, proportion=1,
flag=wx.ALL | wx.ALIGN_RIGHT | wx.SHAPED, border=5)
- btnSizer.Add(item=self.btnApply,
- flag=wx.ALL, border=5)
+ # btnSizer.Add(item=self.btnApply,
+ # flag=wx.ALL, border=5)
mainSizer.Add(item=self.notebook, proportion=1, flag=wx.EXPAND)
mainSizer.Add(item=btnSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=5)
@@ -1228,21 +1231,26 @@
name = self.FindWindowById(self.layerPage[self.layer]['renameCol']).GetValue()
nameTo = self.FindWindowById(self.layerPage[self.layer]['renameColTo']).GetValue()
+ table = self.mapDBInfo.layers[self.layer]["table"]
if not name or not nameTo:
wx.MessageBox(self=self,
message=_("Unable to rename column. "
"No column name defined."),
caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ return
else:
item = list.FindItem(start=-1, str=name)
if item > -1:
if list.FindItem(start=-1, str=nameTo) > -1:
wx.MessageBox(parent=self,
- message=_("Unable to rename column <%(column)s>. "
- "Column <%(columnTo)s> already exists in the table <%(table)s>.") % \
+ message=_("Unable to rename column <%(column)s> to "
+ "<%(columnTo)s>. Column already exists "
+ "in the table <%(table)s>.") % \
{'column' : name, 'columnTo' : nameTo,
- 'table' : self.mapDBInfo.layers[self.layer]["table"]},
+ 'table' : table},
+ return
else:
list.SetItemText(item, nameTo)
@@ -1254,9 +1262,19 @@
"Column <%(column)s> doesn't exist in the table <%(table)s>.") %
- {'column' : name, 'table' : self.mapDBInfo.layers[self.layer]["table"]},
+ {'column' : name, 'table' : table},
+ return
+ # apply changes
+ self.OnApply(event)
+ print self.mapDBInfo.GetColumns(table)
+ # update widgets
+ self.FindWindowById(self.layerPage[self.layer]['renameCol']).SetItems(self.mapDBInfo.GetColumns(table))
+ self.FindWindowById(self.layerPage[self.layer]['renameCol']).SetSelection(0)
+ self.FindWindowById(self.layerPage[self.layer]['renameColTo']).SetValue('')
event.Skip()
def OnTableRightUp(self, event):
@@ -1294,18 +1312,35 @@
list.DeleteItem(item)
item = list.GetFirstSelected()
+ # apply changes
+ # update widgets
+ table = self.mapDBInfo.layers[self.layer]['table']
event.Skip()
def OnTableItemDeleteAll(self, event):
"""Delete all items from the list"""
cols = self.mapDBInfo.GetColumns(table)
- self.listOfCommands = [['v.db.dropcol',
- 'map=%s' % self.vectmap,
- 'layer=%d' % self.layer,
- 'column=%s' % ','.join(cols)]]
+ for col in cols:
+ self.listOfCommands = [['v.db.dropcol',
+ 'map=%s' % self.vectmap,
+ 'layer=%d' % self.layer,
+ 'column=%s' % col]]
self.FindWindowById(self.layerPage[self.layer]['tableData']).DeleteAllItems()
+ # apply changes
+ # update widgets
event.Skip()
def OnTableReload(self, event):
@@ -1322,39 +1357,48 @@
message=_("Unable to add column to the table. "
+ return
+ type = self.FindWindowById(self.layerPage[self.layer]['addColType']). \
+ GetStringSelection()
+ # cast type if needed
+ if type == 'double':
+ type = 'double precision'
+ if type == 'varchar':
+ length = int(self.FindWindowById(self.layerPage[self.layer]['addColLength']). \
+ GetValue())
else:
- type = self.FindWindowById(self.layerPage[self.layer]['addColType']). \
- GetStringSelection()
- # cast type if needed
- if type == 'double':
- type = 'double precision'
- if type == 'varchar':
- length = int(self.FindWindowById(self.layerPage[self.layer]['addColLength']). \
- GetValue())
- else:
- length = '' # FIXME
- # add item to the list of table columns
- list = self.FindWindowById(self.layerPage[self.layer]['tableData'])
- # check for duplicate items
- if list.FindItem(start=-1, str=name) > -1:
- wx.MessageBox(parent=self,
- message=_("Column <%(column)s> already exists in table <%(table)s>.") % \
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
- return
- index = list.InsertStringItem(sys.maxint, str(name))
- list.SetStringItem(index, 0, str(name))
- list.SetStringItem(index, 1, str(type))
- list.SetStringItem(index, 2, str(length))
+ length = '' # FIXME
- # add v.db.addcol command to the list
- type += ' (%d)' % length
- self.listOfCommands.append(['v.db.addcol',
- 'columns=%s %s' % (name, type)])
+ # add item to the list of table columns
+ list = self.FindWindowById(self.layerPage[self.layer]['tableData'])
+ # check for duplicate items
+ if list.FindItem(start=-1, str=name) > -1:
+ wx.MessageBox(parent=self,
+ message=_("Column <%(column)s> already exists in table <%(table)s>.") % \
+ {'column' : name, 'table' : self.mapDBInfo.layers[self.layer]["table"]},
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ return
+ index = list.InsertStringItem(sys.maxint, str(name))
+ list.SetStringItem(index, 0, str(name))
+ list.SetStringItem(index, 1, str(type))
+ list.SetStringItem(index, 2, str(length))
+ # add v.db.addcol command to the list
+ type += ' (%d)' % length
+ self.listOfCommands.append(['v.db.addcol',
+ 'columns=%s %s' % (name, type)])
+ # apply changes
+ # update widgets
+ self.FindWindowById(self.layerPage[self.layer]['addColName']).SetValue('')
def OnLayerPageChanged(self, event):
"""Layer tab changed"""
pageNum = event.GetSelection()
@@ -1406,7 +1450,6 @@
# update data list
list = self.FindWindowById(self.layerPage[self.layer]['data'])
list.Update(self.mapDBInfo)
- self.OnDataReload(None)
# reset list of commands
self.listOfCommands = []
@@ -1434,8 +1477,8 @@
# reset list of statements
self.listOfSQLStatements = []
- # perform select statement
- self.OnApplySqlStatement(event)
+ # perform select statement
+ self.OnApplySqlStatement(event)
def OnApplySqlStatement(self, event):
"""Apply simple/advanced sql statement"""
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-04-11 14:57:52 UTC (rev 30940)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-04-11 17:13:16 UTC (rev 30941)
@@ -248,7 +248,7 @@
# vector specific items
if mltype and mltype == "vector":
self.popupMenu.AppendSeparator()
- self.popupMenu.Append(self.popupID4, text=_("Show attribute table"))
+ self.popupMenu.Append(self.popupID4, text=_("Show attribute data"))
self.Bind (wx.EVT_MENU, self.gismgr.OnShowAttributeTable, id=self.popupID4)
self.popupMenu.Append(self.popupID5, text=_("Start editing"))
