[GRASS-SVN] r30969 - grass/trunk/gui/wxpython/gui_modules
Sun Apr 13 10:28:39 EDT 2008
Author: martinl
Date: 2008-04-13 10:28:36 -0400 (Sun, 13 Apr 2008)
New Revision: 30969
   grass/trunk/gui/wxpython/gui_modules/dbm.py
   grass/trunk/gui/wxpython/gui_modules/gcmd.py
wxGUI (dbm.py): simplify loading data (sql 'select' statement)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py	2008-04-13 11:53:03 UTC (rev 30968)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py	2008-04-13 14:28:36 UTC (rev 30969)
@@ -1,7 +1,7 @@
 @package dbm.py
- at brief GRASS attribute table manager
+ at brief GRASS Attribute Table Manager
 This program is based on FileHunter, published in 'The wxPython Linux
 Tutorial' on wxPython WIKI pages.
@@ -10,7 +10,7 @@
 http://aspn.activestate.com/ASPN/Cookbook/Python/Recipe/426407
 @code
-dbm.py vector at mapset
+python dbm.py vector at mapset
 @endcode
 List of classes:
@@ -137,10 +137,14 @@
         self.mapDBInfo = mapDBInfo
         self.LoadData(self.layer)
-    def LoadData(self, layer, cols='*', where=''):
+    def LoadData(self, layer, sql=None):
         """Load data into list
-        Returns id of key column or -1 if key column is not displayed
+        @param layer layer number
+        @param sql SQL select statement (if None 'SELECT * FROM table)
+        @return id of key column
+        @return -1 if key column is not displayed
         # These two should probably be passed to init more cleanly
@@ -152,14 +156,17 @@
         # self.ClearAll()
         for i in range(self.GetColumnCount()):
-            self.DeleteColumn(0)
+            self.DeleteColumn(i)
         tableName    = self.mapDBInfo.layers[layer]['table']
         keyColumn    = self.mapDBInfo.layers[layer]['key']
         self.columns = self.mapDBInfo.tables[tableName]
-        if cols != '*':
-            columnNames = cols.split(',')
+        if sql is None:
+            sql = "SELECT * FROM %s" % tableName
+        if sql[7] != '*':
+            columnNames = sql[7:].split(' ')[0].split(',')
         else:
             columnNames = self.mapDBInfo.GetColumns(tableName)
@@ -185,15 +192,10 @@
             if i >= 256:
                 self.log.write(_("Can display only 256 columns."))
-        ### self.mapDBInfo.SelectFromTable(layer, cols, where) # <- values (FIXME)
         # read data
         # FIXME: Max. number of rows, while the GUI is still usable
-        if where is None or where is '':
-            sql="SELECT %s FROM %s" % (cols, tableName)
-        else:
-            sql="SELECT %s FROM %s WHERE %s" % (cols, tableName, where)
         # stdout can be very large, do not use PIPE, redirect to temp file
         # TODO: more effective way should be implemented...
@@ -547,7 +549,7 @@
             # sql statement box
             btnApply = wx.Button(parent=panel, id=wx.ID_APPLY)
-            btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+            btnApply.Bind(wx.EVT_BUTTON, self.OnApplySqlStatement)
             btnSqlBuilder = wx.Button(parent=panel, id=wx.ID_ANY, label=_("SQL Builder"))
             btnSqlBuilder.Bind(wx.EVT_BUTTON, self.OnBuilder)
@@ -1487,22 +1489,46 @@
         if self.FindWindowById(self.layerPage[self.layer]['simple']).GetValue():
             # simple sql statement
             where = self.FindWindowById(self.layerPage[self.layer]['where']).GetValue().strip()
-            if len(where) > 0:
-                keyColumn = listWin.LoadData(self.layer, where=where)
-            else:
+            try:
+                if len(where) > 0:
+                    sql = "SELECT * FROM %s WHERE %s" % (self.mapDBInfo.layers[self.layer]['table'],
+                                                         where)
+                    keyColumn = listWin.LoadData(self.layer, sql=sql)
+                else:
+                    keyColumn = listWin.LoadData(self.layer)
+            except gcmd.CmdError:
+                wx.MessageBox(parent=self,
+                              message=_("Loading attribute data failed. "
+                                        "Invalid SQL 'select' statement.\n\n"
+                                        "'%s'") % sql,
+                              caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+                self.FindWindowById(self.layerPage[self.layer]['where']).SetValue('')
         else:
             # advanced sql statement
-            valid, cols, where = \
-                self.ValidateSelectStatement( \
-                self.FindWindowById(self.layerPage[self.layer]['statement']).GetValue().strip())
+            # valid, cols, where = \
+            #    self.ValidateSelectStatement( \
+            #    self.FindWindowById(self.layerPage[self.layer]['statement']).GetValue().strip())
+            #Debug.msg(4, "AttributeManager.OnApplySqlStatament(): valid=%s, cols=%s, where=%s" %
+            #          (valid, cols, where))
+            sql = self.FindWindowById(self.layerPage[self.layer]['statement']).GetValue()
+            try:
+                # if valid is True:
+                                             sql=sql)
+                # else:
+                # raise gcmd.GException('')
+                                        "'%s'") % sql,
+                self.FindWindowById(self.layerPage[self.layer]['statement']).\
+                    SetValue("SELECT * FROM %s" % self.mapDBInfo.layers[self.layer]['table'])
-            Debug.msg(4, "AttributeManager.OnApplySqlStatament(): valid=%s, cols=%s, where=%s" %
-                      (valid, cols, where))
-            if valid is True:
-                keyColumn = listWin.LoadData(self.layer, cols=cols, where=where)
         # sort by key column
         if keyColumn > -1:
             listWin.SortListItems(col=keyColumn, ascending=True)
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py	2008-04-13 11:53:03 UTC (rev 30968)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py	2008-04-13 14:28:36 UTC (rev 30969)
@@ -571,6 +571,7 @@
                 # line = self.__read_all(self.module.stderr)
                 line = recv_some(self.module, e=0, stderr=1)
                 self.stderr.write(line)
+                self.rerr = line
         # get the last output
         if self.stdout:
@@ -581,6 +582,8 @@
+            if len(line) > 0:
+                self.rerr = line
         if hasattr(self.stderr, "gmstc"):
             # -> GMConsole
