[GRASS-SVN] r30975 - in grass/trunk/gui/wxpython: . gui_modules xml
svn_grass at osgeo.org
Sun Apr 13 13:33:25 EDT 2008
Author: martinl
Date: 2008-04-13 13:33:23 -0400 (Sun, 13 Apr 2008)
New Revision: 30975
grass/trunk/gui/wxpython/gui_modules/workspace.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
grass/trunk/gui/wxpython/wxgui.py
grass/trunk/gui/wxpython/xml/grass-gxw.dtd
wxGUI: mark in workspace file (gxw) selected map layers
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py 2008-04-13 16:23:45 UTC (rev 30974)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py 2008-04-13 17:33:23 UTC (rev 30975)
@@ -74,10 +74,11 @@
elif name == 'layer':
self.inLayer = True
- self.layerType = attrs.get('type', None)
- self.layerName = attrs.get('name', None)
- self.layerChecked = attrs.get('checked', None)
- self.layerOpacity = attrs.get('opacity', None)
+ self.layerType = attrs.get('type', None)
+ self.layerName = attrs.get('name', None)
+ self.layerChecked = attrs.get('checked', None)
+ self.layerOpacity = attrs.get('opacity', None)
+ self.layerSelected = False;
self.cmd = []
elif name == 'task':
@@ -98,6 +99,10 @@
name = attrs.get('name', None)
self.cmd.append('-' + name)
+ elif name == 'selected':
+ if self.inLayer:
+ self.layerSelected = True;
def endElement(self, name):
if name == 'gxw':
self.inGxw = False
@@ -112,13 +117,14 @@
self.inLayer = False
self.layers.append({
- "type" : self.layerType,
- "name" : self.layerName,
- "checked" : int(self.layerChecked),
- "opacity" : None,
- "cmd" : None,
- "group" : self.inGroup,
- "display" : self.displayIndex})
+ "type" : self.layerType,
+ "name" : self.layerName,
+ "checked" : int(self.layerChecked),
+ "opacity" : None,
+ "cmd" : None,
+ "group" : self.inGroup,
+ "display" : self.displayIndex,
+ "selected" : self.layerSelected})
if self.layerOpacity:
self.layers[-1]["opacity"] = float(self.layerOpacity)
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-04-13 16:23:45 UTC (rev 30974)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-04-13 17:33:23 UTC (rev 30975)
@@ -96,7 +96,7 @@
# title
self.mapdisplay.SetTitle(_("GRASS GIS Map Display: " +
- str(self.disp_idx) +
+ str(self.disp_idx + 1) +
" - Location: " + grassenv.GetGRASSVariable("LOCATION_NAME")))
# show new display
@@ -407,7 +407,8 @@
"""Rename layer"""
self.EditLabel(self.layer_selected)
- def AddLayer(self, ltype, lname=None, lchecked=None, lopacity=None, lcmd=None, lgroup=None):
+ def AddLayer(self, ltype, lname=None, lchecked=None,
+ lopacity=None, lcmd=None, lgroup=None):
"""Add new item to the layer tree, create corresponding MapLayer instance.
Launch property dialog if needed (raster, vector, etc.)
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-04-13 16:23:45 UTC (rev 30974)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-04-13 17:33:23 UTC (rev 30975)
@@ -111,7 +111,7 @@
self._auimgr = wx.aui.AuiManager(self)
# initialize variables
- self.disp_idx = 1 # index value for map displays and layer trees
+ self.disp_idx = 0 # index value for map displays and layer trees
self.curr_page = '' # currently selected page for layer tree notebook
self.curr_pagenum = '' # currently selected page number for layer tree notebook
self.encoding = 'ISO-8859-1' # default encoding for display fonts
@@ -166,7 +166,8 @@
# show map display widnow
# -> OnSize() -> UpdateMap()
- self.curr_page.maptree.mapdisplay.Show()
+ if not self.curr_page.maptree.mapdisplay.IsShown():
+ self.curr_page.maptree.mapdisplay.Show()
def __doLayout(self):
"""Do Layout (unused bacause of aui manager...)"""
@@ -600,18 +601,33 @@
wx.Yield()
maptree = None
+ selected = [] # list of selected layers
for layer in gxwXml.layers:
if layer['display'] >= self.disp_idx:
# start new map display if no display is available
self.NewDisplay()
maptree = self.gm_cb.GetPage(layer['display']).maptree
+ if not maptree.mapdisplay.IsShown():
+ # show map display
+ maptree.mapdisplay.Show()
newItem = maptree.AddLayer(ltype=layer['type'],
lname=layer['name'],
lchecked=layer['checked'],
lopacity=layer['opacity'],
lcmd=layer['cmd'],
lgroup=layer['group'])
- # maptree.PropertiesDialog(newItem, show=False)
+ if layer['selected']:
+ selected.append((maptree, newItem))
+ else:
+ maptree.SelectItem(newItem, select=False)
+ for maptree, layer in selected:
+ if not maptree.IsSelected(layer):
+ maptree.SelectItem(layer, select=True)
+ maptree.layer_selected = layer
busy.Destroy()
@@ -775,8 +791,12 @@
opacity = maplayer.GetOpacity(float=True)
file.write('%s<layer type="%s" name="%s" checked="%d" opacity="%f">\n' % \
(' ' * self.indent, type, name, checked, opacity));
+ self.indent += 4
+ # selected ?
+ if item == mapTree.layer_selected:
+ file.write('%s<selected />\n' % (' ' * self.indent))
# layer properties
- self.indent += 4
file.write('%s<task name="%s">\n' % (' ' * self.indent, cmd[0]))
self.indent += 4
for option in cmd[1:]:
@@ -1075,7 +1095,7 @@
# make a new page in the bookcontrol for the layer tree (on page 0 of the notebook)
self.pg_panel = wx.Panel(self.gm_cb, id=wx.ID_ANY, style= wx.EXPAND)
- self.gm_cb.AddPage(self.pg_panel, text="Display "+ str(self.disp_idx), select = True)
+ self.gm_cb.AddPage(self.pg_panel, text="Display "+ str(self.disp_idx + 1), select = True)
self.curr_page = self.gm_cb.GetCurrentPage()
# create layer tree (tree control for managing GIS layers) and put on new notebook page
Modified: grass/trunk/gui/wxpython/xml/grass-gxw.dtd
--- grass/trunk/gui/wxpython/xml/grass-gxw.dtd 2008-04-13 16:23:45 UTC (rev 30974)
+++ grass/trunk/gui/wxpython/xml/grass-gxw.dtd 2008-04-13 17:33:23 UTC (rev 30975)
@@ -29,7 +29,7 @@
<!-- map layer
-<!ELEMENT layer (task?)>
+<!ELEMENT layer (selected?, task?)>
<!ATTLIST layer type CDATA #REQUIRED>
<!ATTLIST layer name CDATA #REQUIRED>
<!ATTLIST layer checked CDATA #REQUIRED>
@@ -38,9 +38,13 @@
<!-- task describes the interface of a single
GRASS command.
-<!ELEMENT task (parameter*, flag*)>
+<!ELEMENT task (flag*, parameter*)>
<!ATTLIST task name CDATA #REQUIRED>
+<!-- layer selected
+<!ELEMENT selected EMPTY>
<!-- a parameter must have a name and a value
<!ELEMENT parameter (value)>
@@ -53,5 +57,5 @@
<!-- enabled flag
-<!ELEMENT flag EMPTY>
-<!ATTLIST flag name CDATA #REQUIRED>
+<!ELEMENT flag EMPTY>
+<!ATTLIST flag name CDATA #REQUIRED>
