[GRASS-SVN] r30977 - grass-addons/gipe/r.out.vic
svn_grass at osgeo.org
Mon Apr 14 03:30:48 EDT 2008
Author: ychemin
Date: 2008-04-14 03:30:47 -0400 (Mon, 14 Apr 2008)
New Revision: 30977
grass-addons/gipe/r.out.vic/Makefile
grass-addons/gipe/r.out.vic/description.html
grass-addons/gipe/r.out.vic/main.c
Updated r.out.vic with hydrological flow direction for routing
Modified: grass-addons/gipe/r.out.vic/Makefile
--- grass-addons/gipe/r.out.vic/Makefile 2008-04-14 06:13:05 UTC (rev 30976)
+++ grass-addons/gipe/r.out.vic/Makefile 2008-04-14 07:30:47 UTC (rev 30977)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM = r.out.vic_met
+PGM = r.out.vic
LIBES = $(GPROJLIB) $(GISLIB)
DEPENDENCIES = $(GPROJDEP) $(GISDEP)
Modified: grass-addons/gipe/r.out.vic/description.html
--- grass-addons/gipe/r.out.vic/description.html 2008-04-14 06:13:05 UTC (rev 30976)
+++ grass-addons/gipe/r.out.vic/description.html 2008-04-14 07:30:47 UTC (rev 30977)
@@ -22,6 +22,9 @@
3 - Soil: Barely complete, it takes elevation data and lat/long, the rest is filled up with dummy soil data.
+4 - Routing file from GRASS flow direction file: Recoding to rout input file for VIC post-processing of hydrological surface runoff flow.
+http://www.hydro.washington.edu/Lettenmaier/Models/VIC/Documentation/Bernt/rout/mainframe_rout1.htm
<H2>NOTES</H2>
<H2>TODO</H2>
Modified: grass-addons/gipe/r.out.vic/main.c
--- grass-addons/gipe/r.out.vic/main.c 2008-04-14 06:13:05 UTC (rev 30976)
+++ grass-addons/gipe/r.out.vic/main.c 2008-04-14 07:30:47 UTC (rev 30977)
@@ -13,6 +13,12 @@
* 3 - Soil:
* Barely complete, it takes elevation data & lat/long,
* the rest is filled up with dummy soil data.
+ * 4 - Routing file from GRASS flow direction file:
+ * Recoding to rout input file for VIC post-processing
+ * of hydrological surface runoff flow.
+ * http://www.hydro.washington.edu/Lettenmaier/
+ * Models/VIC/Documentation/Bernt/
+ * rout/mainframe_rout1.htm
* COPYRIGHT: (C) 2008 by the GRASS Development Team
@@ -47,8 +53,8 @@
int not_ll=0;//if proj is not lat/long, it will be 1.
struct GModule *module;
struct Option *input1, *input2, *input3, *input4;
- struct Option *input5, *input6;
- struct Option *output1, *output2, *output3, *output4;
+ struct Option *input5, *input6, *input7;
+ struct Option *output1, *output2, *output3, *output4, *output5;
struct Flag *flag1;
struct History history; //metadata
@@ -62,14 +68,16 @@
char *tmin_name;// input third time_series raster files names
char *landcover_name;// input raster name
char lai_name[12]; // input monthly raster files name
+ char *fdir_name;// input flow direction raster name
char *result1; //output file base name
char *result2; //output Soil file name
char *result3; //output Veg file name
+ char *result4; //output flow direction file name
char result_lat_long[50]; //output file name
//File Descriptors
int infd_prcp[MAXFILES], infd_tmax[MAXFILES], infd_tmin[MAXFILES];
int infd;
- int infd_landcover, infd_lai[12];
+ int infd_landcover, infd_lai[12], infd_fdir;
int i=0,j=0;
double xp, yp;
@@ -84,12 +92,14 @@
void *inrast_elevation;
void *inrast_landcover;
void *inrast_lai[12];
+ void *inrast_fdir;
RASTER_MAP_TYPE data_type_inrast_prcp[MAXFILES];
RASTER_MAP_TYPE data_type_inrast_tmax[MAXFILES];
RASTER_MAP_TYPE data_type_inrast_tmin[MAXFILES];
RASTER_MAP_TYPE data_type_inrast_elevation;
RASTER_MAP_TYPE data_type_inrast_landcover;
RASTER_MAP_TYPE data_type_inrast_lai[12];
+ RASTER_MAP_TYPE data_type_inrast_fdir;
/* Meteorological maps */
@@ -112,7 +122,7 @@
char *dummy_data1; // dummy data part 1
char *dummy_data2; // dummy data part 2
double elevation; // average evevation of grid cell
/* Vegetation map */
FILE *h; // output ascii file
char *dummy_data3; // dummy data part 1
@@ -121,37 +131,61 @@
char **lai_ptr; // pointer to get the input2->answers
int nfiles; // count LAI input files
char **test, **ptr; // test number of LAI input files
+ /* Flow Direction */
+ FILE *e; // output flow direction ascii file
G_gisinit(argv[0]);
module = G_define_module();
module->keywords = _("VIC, hydrology, precipitation, Tmax, Tmin, soil");
- module->description = _("creates a meteorological ascii file for each non-null cell from 3 time series maps: precipitation, Tmax and Tmin. Also creates a dummy soil file from elevation.");
+ module->description = _("* PURPOSE: Creates VIC input files:\n\
+ * 1 - Meteorological:\n \
+ * Three time series of GIS data are needed:\n\
+ * Precipitation (mm/d), Tmax(C) and Tmin(C)\n\
+ * 2 - Vegetation:\n\
+ * Filling only Land cover class, with only one class,\n\
+ * and one standard root system.\n\
+ * Option to add monthly LAI (12 maps).\n\
+ * 3 - Soil:\n\
+ * Barely complete, it takes elevation data & lat/long,\n\
+ * the rest is filled up with dummy soil data.\n\
+ * 4 - Routing file from GRASS flow direction file:\n\
+ * Recoding to rout input file for VIC post-processing\n\
+ * of hydrological surface runoff flow.\n\
+ * http://www.hydro.washington.edu/Lettenmaier/\n\
+ * Models/VIC/Documentation/Bernt/\n\
+ * rout/mainframe_rout1.htm");
/* Define the different options */
input1 = G_define_standard_option(G_OPT_R_INPUT) ;
input1->key = _("prcp");
input1->multiple = YES;
input1->description=_("Names of the precipitation input maps");
+ input1->guisection=_("Required");
input2 = G_define_standard_option(G_OPT_R_INPUT) ;
input2->key = _("tmax");
input2->multiple = YES;
input2->description=_("Names of the Tmax input maps");
+ input2->guisection=_("Required");
input3 = G_define_standard_option(G_OPT_R_INPUT) ;
input3->key = _("tmin");
input3->multiple = YES;
input3->description=_("Names of the Tmin input maps");
+ input3->guisection=_("Required");
input4 = G_define_standard_option(G_OPT_R_INPUT) ;
input4->key = _("dem");
input4->description=_("Name of the elevation input map");
+ input4->guisection=_("Required");
input5 = G_define_standard_option(G_OPT_R_INPUT) ;
input5->key = _("landcover");
input5->description=_("Name of the land cover input map");
+ input5->guisection=_("Required");
input6 = G_define_standard_option(G_OPT_R_INPUT) ;
input6->key = _("LAI");
@@ -159,6 +193,11 @@
input6->required = NO;
input6->description=_("Name of the LAI input maps (12 of them!)");
+ input7 = G_define_standard_option(G_OPT_R_INPUT) ;
+ input7->key = _("flow_dir");
+ input7->description=_("Name of the flow direction input map (GRASS format)");
+ input7->guisection=_("Required");
output1 = G_define_option();
output1->key =_("output");
output1->description =_("Base Name of the output vic meteorological ascii files");
@@ -180,6 +219,11 @@
output4->description=_("Name of a standard vegetation library file");
output4->answer =_("veglib");
+ output5 = G_define_option() ;
+ output5->key =_("output_fdir");
+ output5->description=_("Name of the output flow direction ascii file");
+ output5->answer =_("vic_fdir.asc");
flag1 = G_define_flag() ;
flag1->key = 'a';
flag1->description =_("append meteorological data if file already exists (useful if adding additional year of data)");
@@ -192,6 +236,7 @@
result1 = output1->answer;
result2 = output2->answer;
result3 = output3->answer;
+ result4 = output5->answer;
/* STANDARD VEGLIB CREATION HERE */
if(output4->answer)
@@ -384,13 +429,35 @@
dummy_data3 = "0.10 0.1 1.00 0.65 0.50 0.25";
dummy_data4 = "0.312 0.413 0.413 0.413 0.413 0.488 0.975 1.150 0.625 0.312 0.312 0.312";
+ /* Flow Direction File */
+ /*Initialize grid cell process switch*/
+ e=fopen(result4,"w");
+ /*Print to ascii file*/
+ fprintf(e,"ncols\t%d\n", ncols);
+ fprintf(e,"nrows\t%d\n", nrows);
+ /*NORTHWEST LONGITUDE*/
+ fprintf(e,"xllcorner\t%f\n", xmin);
+ /*NORTHWEST LATITUDE*/
+ fprintf(e,"yllcorner\t%f\n", ymin);
+ if(stepx==stepy){
+ fprintf(e,"cellsize\t%f\n", stepx);
+ } else {
+ G_message("Flow Direction map cellsize_x=%f\n", stepx);
+ G_message("Flow Direction map cellsize_y=%f\n", stepy);
+ fprintf(e,"NODATA_value\t0\n");
for (row = 0; row < nrows; row++){
- DCELL d_prcp[MAXFILES];
- DCELL d_tmax[MAXFILES];
- DCELL d_tmin[MAXFILES];
- DCELL d_elevation;
- CELL c_landcover;
- DCELL d_lai[12];
+ DCELL d_prcp[MAXFILES];
+ DCELL d_tmax[MAXFILES];
+ DCELL d_tmin[MAXFILES];
+ DCELL d_elevation;
+ CELL c_landcover;
+ CELL c_fdir;
+ DCELL d_lai[12];
G_percent(row,nrows,2);
for(i=0;i<nfiles_shortest;i++){
if(G_get_raster_row(infd_prcp[i],inrast_prcp[i],row,data_type_inrast_prcp[i])<0)
@@ -410,6 +477,8 @@
G_fatal_error(_("Could not read from <%s>"),lai_name[i]);
+ if(G_get_raster_row(infd_fdir,inrast_fdir,row,data_type_inrast_fdir)<0)
+ G_fatal_error(_("Could not read from <%s>"),fdir_name);
for (col=0; col < ncols; col++){
/*Extract prcp time series data*/
@@ -489,6 +558,17 @@
+ switch(data_type_inrast_fdir){
+ case CELL_TYPE:
+ c_fdir= ((CELL *) inrast_fdir)[col];
+ break;
+ case FCELL_TYPE:
+ c_fdir= (int) ((FCELL *) inrast_fdir)[col];
+ break;
+ case DCELL_TYPE:
+ c_fdir= (int) ((DCELL *) inrast_fdir)[col];
+ break;
/*Extract lat/long data*/
latitude = ymax - ( row * stepy );
longitude = xmin + ( col * stepx );
@@ -503,8 +583,10 @@
G_is_d_null_value(&d_tmax[0])||
G_is_d_null_value(&d_tmin[0])||
G_is_d_null_value(&d_elevation)||
- G_is_c_null_value(&c_landcover)){
+ G_is_c_null_value(&c_landcover)||
+ G_is_c_null_value(&c_fdir)){
/* Do nothing */
+ c_fdir = 0;
} else {
/* Make the output .dat file name */
sprintf(result_lat_long,"%s%.4f%s%.4f",result1,latitude,"_",longitude);
@@ -541,10 +623,35 @@
grid_count=grid_count+1;
+ /*Grid cell value in that grid cell*/
+ if(c_fdir==0){
+ fprintf(e,"%d ",c_fdir);
+ } else if(c_fdir==1){
+ fprintf(e,"2 ");
+ } else if(c_fdir==2){
+ fprintf(e,"1 ");
+ } else if(c_fdir==3){
+ fprintf(e,"8 ");
+ } else if(c_fdir==4){
+ fprintf(e,"7 ");
+ } else if(c_fdir==5){
+ fprintf(e,"6 ");
+ } else if(c_fdir==6){
+ fprintf(e,"5 ");
+ } else if(c_fdir==7){
+ fprintf(e,"4 ");
+ } else if(c_fdir==8){
+ fprintf(f,"3 ");
+ } else {
+ fprintf(f,"0 ");
+ fprintf(e,"\n");
G_message(_("Created %d VIC meteorological files"),grid_count);
G_message(_("Created %d VIC grid cells soil/vegetation definitions"),grid_count);
+ G_message(_("Created a routing flow direction input file"));
for(i=0;i<nfiles1;i++){
G_free (inrast_prcp[i]);
G_close_cell (infd_prcp[i]);
@@ -567,8 +674,11 @@
G_close_cell (infd_lai[i]);
- fclose(h);
- fclose(g);
+ G_free (inrast_fdir);
+ G_close_cell (infd_fdir);
+ fclose(h);// Vegetation ascii file
+ fclose(g);// Soil ascii file
+ fclose(e);// Flow Direction ascii file
exit(EXIT_SUCCESS);
