[GRASS-SVN] r30989 - grass/trunk/lib/vector/vedit
svn_grass at osgeo.org
Mon Apr 14 14:59:21 EDT 2008
Author: martinl
Date: 2008-04-14 14:59:21 -0400 (Mon, 14 Apr 2008)
New Revision: 30989
grass/trunk/lib/vector/vedit/select.c
veditlib: perform query globally (query all vector objects in vector map) only if input list of lines is empty
Modified: grass/trunk/lib/vector/vedit/select.c
--- grass/trunk/lib/vector/vedit/select.c 2008-04-14 16:13:33 UTC (rev 30988)
+++ grass/trunk/lib/vector/vedit/select.c 2008-04-14 18:59:21 UTC (rev 30989)
@@ -17,13 +17,18 @@
static int select_by_query(struct Map_info *, int, int, double,
int, struct line_pnts *, struct line_cats *);
+static int merge_lists (struct ilist* alist, struct ilist* blist);
\brief Select features by query (based on geometry properties)
Currently supported:
- - QUERY_LENGTH, select all features longer then threshold (or shorter if threshold is negative)
- - QUERY_DANGLE, select all dangles longer then threshold (or shorter if threshold is negative)
+ - QUERY_LENGTH, select all features longer than threshold (or shorter if threshold is < 0)
+ - QUERY_DANGLE, select all dangles longer than threshold (or shorter if threshold is < 0)
+ Perform global query if <i>List</i> is empty otherwise query only
+ selected vector objects.
\param[in] Map vector map
\param[in] type feature type
\param[in] layer layer number
@@ -46,43 +51,72 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
- List_query = Vect_new_list();
+ if (List->n_values == 0) {
+ List_query = List;
+ else {
+ List_query = Vect_new_list();
switch (query) {
case QUERY_LENGTH: {
- num = Vect_get_num_lines (Map);
- for (line = 1; line <= num; line++) {
- if (select_by_query(Map, line, type, thresh,
- query, Points, Cats))
- Vect_list_append(List, line);
+ /* query all vector objects in vector map */
+ num = Vect_get_num_lines(Map);
+ for (line = 1; line <= num; line++) {
+ if (select_by_query(Map, line, type, thresh,
+ query, Points, Cats))
+ Vect_list_append(List_query, line);
+ else {
+ for (i = 0; i < List->n_values; i++) {
+ line = List->value[i];
+ query, Points, Cats)) {
break;
case QUERY_DANGLE: {
+ struct ilist *List_dangle;
+ List_dangle = Vect_new_list();
thresh_tmp = fabs(thresh);
+ /* select dangles shorter than 'thresh_tmp' */
Vect_select_dangles (Map, type, thresh_tmp, NULL,
- List_query);
+ List_dangle);
if (thresh <= 0.0) { /* shorter than */
- for(i = 0; i < List_query->n_values; i++) {
- Vect_list_append(List, List_query->value[i]);
+ for(i = 0; i < List_dangle->n_values; i++) {
+ Vect_list_append(List_query, List_dangle->value[i]);
else { /* longer than */
for(i = 1; i <= Vect_get_num_lines(Map); i++) {
- if (!Vect_val_in_list(List_query, i))
- Vect_list_append(List, i);
+ if (!Vect_val_in_list(List_dangle, i))
+ Vect_list_append(List_query, i);
+ Vect_destroy_list(List_dangle);
break;
default: break;
+ if (List != List_query) {
+ merge_lists(List, List_query);
+ Vect_destroy_list(List_query);
G_debug (3, "Vedit_select_by_query(): %d lines selected (by query %d)", List -> n_values, query);
Vect_destroy_line_struct(Points);
Vect_destroy_cats_struct(Cats);
- Vect_destroy_list(List_query);
return List -> n_values;
@@ -94,8 +128,8 @@
\return 0 line test negative
\return -1 on error (line is dead)
-static int select_by_query(struct Map_info *Map, int line, int type, double thresh,
- int query, struct line_pnts *Points, struct line_cats *Cats)
+int select_by_query(struct Map_info *Map, int line, int type, double thresh,
+ int query, struct line_pnts *Points, struct line_cats *Cats)
int ltype;
double length;
@@ -198,3 +232,31 @@
return 0;
+ \brief Merge two lists, i.e. store only duplicate items
+ \param[in,out] alist list to be merged
+ \param[in] blist list used for merging
+ \return result number of items
+int merge_lists (struct ilist* alist, struct ilist* blist)
+ int i;
+ struct ilist* list_del;
+ list_del = Vect_new_list();
+ for (i = 0; i < alist -> n_values; i++) {
+ if (!Vect_val_in_list (blist, alist -> value[i]))
+ Vect_list_append (list_del, alist -> value[i]);
+ Vect_list_delete_list (alist, list_del);
+ Vect_destroy_list (list_del);
+ return alist -> n_values;
