[GRASS-SVN] r30991 - grass/branches/releasebranch_6_3/gui/tcltk/gis.m
Mon Apr 14 16:22:17 EDT 2008
Author: marisn
Date: 2008-04-14 16:22:17 -0400 (Mon, 14 Apr 2008)
New Revision: 30991
   grass/branches/releasebranch_6_3/gui/tcltk/gis.m/gm.tcl
   grass/branches/releasebranch_6_3/gui/tcltk/gis.m/gmlib.tcl
   grass/branches/releasebranch_6_3/gui/tcltk/gis.m/gmtree.tcl
   grass/branches/releasebranch_6_3/gui/tcltk/gis.m/legend.tcl
   grass/branches/releasebranch_6_3/gui/tcltk/gis.m/maplabels.tcl
   grass/branches/releasebranch_6_3/gui/tcltk/gis.m/rastnums.tcl
   grass/branches/releasebranch_6_3/gui/tcltk/gis.m/vector.tcl
Some fixes for digitization start from gis.m; Fixed font selection for gis.m raster legend (ticket #79); gis.m PS labels now works with @mapset (merged from trunk)
Modified: grass/branches/releasebranch_6_3/gui/tcltk/gis.m/gm.tcl
--- grass/branches/releasebranch_6_3/gui/tcltk/gis.m/gm.tcl	2008-04-14 19:00:53 UTC (rev 30990)
+++ grass/branches/releasebranch_6_3/gui/tcltk/gis.m/gm.tcl	2008-04-14 20:22:17 UTC (rev 30991)
@@ -482,7 +482,7 @@
 		catch {file delete $file}
-	if {[file exists $legfile]} {catch {file delete -force $legfile}}
+	if {[info exists legfile] && [file exists $legfile]} {catch {file delete -force $legfile}}
 	unset mon
Modified: grass/branches/releasebranch_6_3/gui/tcltk/gis.m/gmlib.tcl
--- grass/branches/releasebranch_6_3/gui/tcltk/gis.m/gmlib.tcl	2008-04-14 19:00:53 UTC (rev 30990)
+++ grass/branches/releasebranch_6_3/gui/tcltk/gis.m/gmlib.tcl	2008-04-14 20:22:17 UTC (rev 30991)
@@ -19,7 +19,7 @@
 namespace eval GmLib {
-	global array filename # mon
+	global array filename ;# mon
Modified: grass/branches/releasebranch_6_3/gui/tcltk/gis.m/gmtree.tcl
--- grass/branches/releasebranch_6_3/gui/tcltk/gis.m/gmtree.tcl	2008-04-14 19:00:53 UTC (rev 30990)
+++ grass/branches/releasebranch_6_3/gui/tcltk/gis.m/gmtree.tcl	2008-04-14 20:22:17 UTC (rev 30991)
@@ -18,9 +18,9 @@
     variable legend_height 20
     variable legend_width 30
     variable treeht 6
-	global array tree # mon
-	variable array pg # mon
+	global array tree ;# mon
+	variable array pg ;# mon
@@ -1143,7 +1143,7 @@
 #digitize
 proc GmTree::vedit { } {
     variable tree
-	global options
+	global options env
     global mon
     if { [array size GmTree::tree] < 1 } {
@@ -1158,14 +1158,26 @@
     set type [GmTree::node_type $sel]
+    set id [GmTree::node_id $sel]
     switch $type {
         raster {
-        Gm::xmon term r.digit
+			if { $GmRaster::opt($id,1,map) == "" } {
+        		tk_messageBox -type ok -icon warning -message [G_msg "Selected raster layer is empty"]
+        		return
+        	unset env(GRASS_RENDER_IMMEDIATE)
+			guarantee_xmon
+			term r.digit
+			set env(GRASS_RENDER_IMMEDIATE) "TRUE"
             return
         vector {
-	    GmVector::WorkOnVector $sel 0
+        	if { $GmVector::opt($id,1,vect) == "" } {
+        		tk_messageBox -type ok -icon warning -message [G_msg "Selected vector layer is empty"]
+        		return
+	    	GmVector::WorkOnVector $sel 0
         default {
         	tk_messageBox -type ok -icon warning -message [G_msg "You can digitize raster or vector maps only"]
Modified: grass/branches/releasebranch_6_3/gui/tcltk/gis.m/legend.tcl
--- grass/branches/releasebranch_6_3/gui/tcltk/gis.m/legend.tcl	2008-04-14 19:00:53 UTC (rev 30990)
+++ grass/branches/releasebranch_6_3/gui/tcltk/gis.m/legend.tcl	2008-04-14 20:22:17 UTC (rev 30991)
@@ -117,7 +117,7 @@
 	if {$GmLegend::opt($id,1,font) != "" } {
 		set Gm::dfont $GmLegend::opt($id,1,font)
-	Gm:DefaultFont dlegend
+	Gm::defaultfont dlegend
 	tkwait variable Gm::dfont
 	set GmLegend::opt($id,1,font) $Gm::dfont
 	set Gm::dfont ""
Modified: grass/branches/releasebranch_6_3/gui/tcltk/gis.m/maplabels.tcl
--- grass/branches/releasebranch_6_3/gui/tcltk/gis.m/maplabels.tcl	2008-04-14 19:00:53 UTC (rev 30990)
+++ grass/branches/releasebranch_6_3/gui/tcltk/gis.m/maplabels.tcl	2008-04-14 20:22:17 UTC (rev 30991)
@@ -312,8 +312,9 @@
     set can($mon) $MapCanvas::can($mon)
     if {[string match {*[@]*} $opt($id,1,labels)]} {
-		set tmp [string range $opt($id,1,labels) 0 [expr [string first "@" $opt($id,1,labels)] - 1] ]
-		set labelpath "$env(GISDBASE)/$env(LOCATION_NAME)/PERMANENT/paint/labels/$tmp"
+		set labelfname [string range $opt($id,1,labels) 0 [expr [string first "@" $opt($id,1,labels)] - 1] ]
+		set labelmname [string range $opt($id,1,labels) [expr [string first "@" $opt($id,1,labels)] + 1] [string length $opt($id,1,labels)] ]
+		set labelpath "$env(GISDBASE)/$env(LOCATION_NAME)/$labelmname/paint/labels/$labelfname"
     } else {
 		set labelpath "$env(GISDBASE)/$env(LOCATION_NAME)/$env(MAPSET)/paint/labels/$opt($id,1,labels)"
@@ -321,7 +322,10 @@
     if { ! ( $opt($id,1,_check) ) } { return }
     # open the v.label file for reading
-	catch {set labelfile [open $labelpath r]}
+	if { [catch {set labelfile [open $labelpath r]} err ] } {
+		GmLib::errmsg $err [G_msg "Could not open labels file "]
+		return
 	#loop through coordinates and options for each label
     while { [gets $labelfile in] > -1 } {
Modified: grass/branches/releasebranch_6_3/gui/tcltk/gis.m/rastnums.tcl
--- grass/branches/releasebranch_6_3/gui/tcltk/gis.m/rastnums.tcl	2008-04-14 19:00:53 UTC (rev 30990)
+++ grass/branches/releasebranch_6_3/gui/tcltk/gis.m/rastnums.tcl	2008-04-14 20:22:17 UTC (rev 30991)
@@ -114,7 +114,7 @@
 	if {$GmRnums::opt($id,1,font) != "" } {
 		set Gm::dfont $GmRnums::opt($id,1,font)
-	Gm:DefaultFont drastnum
+	Gm::defaultfont drastnum
 	set GmRnums::opt($id,1,font) $Gm::dfont
 	set Gm::dfont ""
Modified: grass/branches/releasebranch_6_3/gui/tcltk/gis.m/vector.tcl
--- grass/branches/releasebranch_6_3/gui/tcltk/gis.m/vector.tcl	2008-04-14 19:00:53 UTC (rev 30990)
+++ grass/branches/releasebranch_6_3/gui/tcltk/gis.m/vector.tcl	2008-04-14 20:22:17 UTC (rev 30991)
@@ -745,7 +745,7 @@
         set cmd [list v.digit -n "map=$opt($id,1,vect)"]
-     set bg_command [GmGroup::vdigit_display "root" "vector:$id"]
+     set bg_command [GmGroup::vdigit_display "vector:$id"]
      if {$bg_command != ""} {
      	append cmd " {bgcmd=$bg_command}"
