[GRASS-SVN] r31031 - grass/trunk/lib/init
svn_grass at osgeo.org
Fri Apr 18 17:55:11 EDT 2008
Author: hamish
Date: 2008-04-18 17:55:10 -0400 (Fri, 18 Apr 2008)
New Revision: 31031
grass/trunk/lib/init/init.sh
consolidate cygwin bash startup; adds GISBASE/etc/prompt.sh to cygwin
Modified: grass/trunk/lib/init/init.sh
--- grass/trunk/lib/init/init.sh 2008-04-18 21:42:05 UTC (rev 31030)
+++ grass/trunk/lib/init/init.sh 2008-04-18 21:55:10 UTC (rev 31031)
@@ -923,7 +923,7 @@
export HOME
-bash|msh)
+bash|msh|cygwin)
# save command history in mapset dir and remember more
export HISTFILE="$LOCATION/.bash_history"
if [ -z "$HISTSIZE" ] && [ -z "$HISTFILESIZE" ] ; then
@@ -938,7 +938,10 @@
export HOME
bashrc="$HOME/.bashrc"
rm -f "$bashrc"
- echo "test -z $PROFILEREAD && . /etc/profile" > "$bashrc"
+ if [ "$sh" != "cygwin" ] ; then
+ # this does not work on cygwin for unknown reasons
+ echo "test -z $PROFILEREAD && . /etc/profile" > "$bashrc"
+ fi
echo "test -r ~/.alias && . ~/.alias" >> "$bashrc"
echo "PS1='GRASS GRASS_VERSION_NUMBER ($LOCATION_NAME):\w > '" >> "$bashrc"
echo "PROMPT_COMMAND=$GISBASE/etc/prompt.sh" >> "$bashrc"
@@ -958,41 +961,6 @@
export HOME
-cygwin)
- # save command history in mapset dir and remember more
- export HISTFILE="$LOCATION/.bash_history"
- if [ -z "$HISTSIZE" ] && [ -z "$HISTFILESIZE" ] ; then
- export HISTSIZE=3000
- fi
- # instead of changing $HOME, start bash with: --rcfile "$LOCATION/.bashrc" ?
- # if so, must care be taken to explicity call .grass.bashrc et al for
- # non-interactive bash batch jobs?
- USERHOME="$HOME" # save original home
- HOME="$LOCATION" # save .bashrc in $LOCATION
- export HOME
- bashrc="$HOME/.bashrc"
- rm -f "$bashrc"
- # this does not work on cygwin for unknown reasons
- # echo "test -z $PROFILEREAD && . /etc/profile" > "$bashrc"
- echo "test -r ~/.alias && . ~/.alias" >> "$bashrc"
- echo "PS1='GRASS GRASS_VERSION_NUMBER ($LOCATION_NAME):\w > '" >> "$bashrc"
- if [ -r "$USERHOME/.grass.bashrc" ]
- then
- cat "$USERHOME/.grass.bashrc" >> "$bashrc"
- fi
- echo "export PATH=\"$PATH\"" >> "$bashrc"
- echo "export HOME=\"$USERHOME\"" >> "$bashrc" # restore user home path
- "$ETC/run" "$SHELL"
- EXIT_VAL=$?
- HOME="$USERHOME"
- export HOME
PS1="GRASS $GRASS_VERSION ($LOCATION_NAME):\w > "
