[GRASS-SVN] r31041 - in grass/trunk/gui/wxpython: . gui_modules
Sat Apr 19 13:02:47 EDT 2008
Author: martinl
Date: 2008-04-19 13:02:47 -0400 (Sat, 19 Apr 2008)
New Revision: 31041
   grass/trunk/gui/wxpython/gui_modules/preferences.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI (preferences): remember the position of gui windows on save, trac #130
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-04-19 14:52:02 UTC (rev 31040)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-04-19 17:02:47 UTC (rev 31041)
@@ -54,8 +54,12 @@
             # general
             'general': {
-                'mapsetPath'  : { 'selection' : 0 }, # current mapset search path
-                'changeOpacityLevel' : { 'enabled' : False }, # show opacity level widget
+                # current mapset search path
+                'mapsetPath'  : { 'selection' : 0 },
+                # show opacity level widget
+                'changeOpacityLevel' : { 'enabled' : False },
+                # use default window layout (layer manager, displays, ...)
+                'defWindowPos' : { 'enabled' : False, 'dim' : '' },
             # display
@@ -441,12 +445,28 @@
                                     name="GetSelection")
         mapsetPath.SetSelection(self.settings.Get(group='general', key='mapsetPath', subkey='selection'))
         self.winId['general:mapsetPath:selection'] = mapsetPath.GetId()
         gridSizer.Add(item=mapsetPath,
                       flag=wx.ALIGN_RIGHT |
                       wx.ALIGN_CENTER_VERTICAL,
                       pos=(row, 1))
+        # default window layout
+        row += 1
+        defaultPos = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                 label=_("Save current window layout as default"),
+                                 name='IsChecked')
+        defaultPos.SetValue(self.settings.Get(group='general', key='defWindowPos', subkey='enabled'))
+        defaultPos.SetToolTip(wx.ToolTip (_("Save current position and size of Layer Manager window and opened "
+                                            "Map Display window(s) and use as default for next sessions.")))
+        self.winId['general:defWindowPos:enabled'] = defaultPos.GetId()
+        gridSizer.Add(item=defaultPos,
+                      pos=(row, 0), span=(1, 2))
         sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
         border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
@@ -972,6 +992,26 @@
                 value = win.GetValue()
             self.settings.Set(group, key, subkey, value)
+        # update default window dimension
+        if self.settings.Get(group='general', key='defWindowPos', subkey='enabled') is True:
+            dim = ''
+            # layer manager
+            pos = self.parent.GetPosition()
+            size = self.parent.GetSize()
+            dim = '%d,%d,%d,%d' % (pos[0], pos[1], size[0], size[1])
+            # opened displays
+            for page in range(0, self.parent.gm_cb.GetPageCount()):
+                pos = self.parent.gm_cb.GetPage(page).maptree.mapdisplay.GetPosition()
+                size = self.parent.gm_cb.GetPage(page).maptree.mapdisplay.GetSize()
+                dim += ',%d,%d,%d,%d' % (pos[0], pos[1], size[0], size[1])
+            self.settings.Set(group='general', key='defWindowPos', subkey='dim', value=dim)
+        else:
+            self.settings.Set(group='general', key='defWindowPos', subkey='dim', value='')
 class SetDefaultFont(wx.Dialog):
     Opens a file selection dialog to select default font
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2008-04-19 14:52:02 UTC (rev 31040)
+++ grass/trunk/gui/wxpython/wxgui.py	2008-04-19 17:02:47 UTC (rev 31041)
@@ -152,6 +152,17 @@
         wx.CallAfter(self.notebook.SetSelection, 0)
+        # use default window layout ?
+        if UserSettings.Get(group='general', key='defWindowPos', subkey='enabled') is True:
+            dim = UserSettings.Get(group='general', key='defWindowPos', subkey='dim')
+            try:
+               x, y = map(int, dim.split(',')[0:2])
+               w, h = map(int, dim.split(',')[2:4])
+               self.SetPosition((x, y))
+               self.SetSize((w, h))
+            except:
+                pass
         # load workspace file if requested
         if (self.workspaceFile):
             # load given workspace file
@@ -883,8 +894,6 @@
                 displayPos = mapTree.mapdisplay.GetPosition()
                 displaySize = mapTree.mapdisplay.GetSize()
                 file.write('%s<display render="%d" '
                            'mode="%d" showCompExtent="%d" '
                            'dim="%d,%d,%d,%d">\n' % (' ' * self.indent,
@@ -1182,8 +1191,6 @@
         self.curr_page.Layout()
         self.curr_page.maptree.Layout()
-        self.disp_idx += 1
         #        self._auimgr.SetManagedWindow(self.curr_page.maptree.testframe)
         #        self._auimgr.AddPane(self.curr_page.maptree.testframe,
@@ -1194,6 +1201,20 @@
         #        self._auimgr.Update()
+            idx = 4 + self.disp_idx * 4
+            try:
+                x, y = map(int, dim.split(',')[idx:idx + 2])
+                w, h = map(int, dim.split(',')[idx + 2:idx + 4])
+                self.curr_page.maptree.mapdisplay.SetPosition((x, y))
+                self.curr_page.maptree.mapdisplay.SetSize((w, h))
+            except:
+                pass
+        self.disp_idx += 1
         return self.curr_page.maptree.mapdisplay
     # toolBar button handlers
