[GRASS-SVN] r31116 - grass-web/trunk/grass63/binary/mswindows/native
Fri Apr 25 04:09:46 EDT 2008
Author: neteler
Date: 2008-04-25 04:09:45 -0400 (Fri, 25 Apr 2008)
New Revision: 31116
   grass-web/trunk/grass63/binary/mswindows/native/README.html
updated
Modified: grass-web/trunk/grass63/binary/mswindows/native/README.html
--- grass-web/trunk/grass63/binary/mswindows/native/README.html	2008-04-25 03:14:17 UTC (rev 31115)
+++ grass-web/trunk/grass63/binary/mswindows/native/README.html	2008-04-25 08:09:45 UTC (rev 31116)
@@ -5,9 +5,9 @@
 <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
 <meta http-equiv="Content-Language" content="en" />
 <meta name="Author" content="Marco Pasetti" />
-<meta name="Description" content="WinGRASS 6.3.0RC6 README" />
+<meta name="Description" content="WinGRASS 6.3.0 README" />
-<title>WinGRASS 6.3.0RC6 README</title>
+<title>WinGRASS 6.3.0 README</title>
 <style type="text/css" />
@@ -136,7 +136,7 @@
 <body>
-<h1>GRASS 6.3.0RC6 - Technology preview release candidate 6</h1>
+<h1>WinGRASS 6.3.0 - GRASS Windows-Native Experimental Project</h1>
 <div class="table-of-contents">
@@ -188,14 +188,14 @@
 features may not work.</p>
 <p>If you need a robust, bug-free release of GRASS on Windows you should install the Cygwin version of
-GRASS 6.2.3, available at <a target="_blank" href="http://grass.osgeo.org/grass62/binary/mswindows/">
-http://grass.osgeo.org/grass62/binary/mswindows/</a>.<p>
+GRASS 6.3.0, available at <a target="_blank" href="http://grass.osgeo.org/grass63/binary/mswindows/cygwin/">
+http://grass.osgeo.org/grass63/binary/mswindows/cygwin/</a>.<p>
 <p>See also <a target="_blank" href="http://grass.osgeo.org/wiki/WinGRASS_Current_Status">
 http://grass.osgeo.org/wiki/WinGRASS_Current_Status</a>.</p>
-<p>The current release of WinGRASS, based on GRASS 6.3.0RC6 (Technology preview release candidate 6), has been built on a
-i686 machine in the MinGW environment and contains parts of the following open source softwares and libraries:</p>
+<p>The current release of WinGRASS, based on GRASS 6.3.0, has been built on a i686 machine in the MinGW environment
+and contains parts of the following open source softwares and libraries:</p>
 <p>Software/Library (Release):</p>
@@ -230,13 +230,13 @@
 Flex and Bison, provided by GnuWin32 Project on SourceForge.NET
 (<a target="_blank" href="http://gnuwin32.sourceforge.net/">http://gnuwin32.sourceforge.net/</a>).</p>
-<p>The current release of GRASS 6.3.0RC6 has been built with the following configuration:</p>
+<p>The current release of GRASS 6.3.0 has been built with the following configuration:</p>
 <pre><code>GRASS is now configured for:  i686-pc-mingw32
- Source directory:            /usr/local/src/grass-6.3.0RC6
- Build directory:             /usr/local/src/grass-6.3.0RC6
- Installation directory:      ${prefix}/grass-6.3.0RC6
+ Source directory:            /usr/local/src/grass-6.3.0
+ Build directory:             /usr/local/src/grass-6.3.0
+ Installation directory:      ${prefix}/grass-6.3.0
  Startup script in directory: ${exec_prefix}/bin
  C compiler:                  gcc -g -O2
  C++ compiler:                c++ -g -O2
@@ -282,8 +282,14 @@
 <p><h3>Install GRASS</h3></p>
-<p>To install GRASS launch WinGRASS-6.3.0RC6-Setup.exe and follow the instructions in it.</p>
+<p>If you had already installed a previous release of WinGRASS (6.3.0RC5 or 6.3.0RC6), please uninstall it before to install the
+current WinGRASS release. Open the Add/Remove Programs application from the Windows Control Panel, select GRASS and remove it.</p>
+<p>Please, note that the uninstall procedure will erase the whole GRASS install direcory. Because of that we strongly
+recommend you to backup all your personal data stored in it before to uninstall GRASS.</p>
+<p>To install GRASS launch WinGRASS-6.3.0-Setup.exe and follow the instructions in it.</p>
 <p>If installed into a directory that has spaces in either its name or the path of directories leading up to it,
 some functionalities of GRASS might be hampered. We would highly appreciate if you tried and reported any problems,
 so that we can fix them. However, if you want to avoid any such issues, we recommend that you choose a simple
@@ -321,6 +327,8 @@
 </td>
 </tr></table>
+<p>The sample data files will be installed into a directory called GIS DataBase, that will be created in your Documents folder.</p>
 </div>
@@ -406,12 +414,21 @@
 <p>The following modules are missing in the current WinGRASS release:</p>
-<li>i.class</li>
-<li>i.ortho.photo</li>
-<li>i.points</li>
-<li>i.vpoints</li>
-<li>r.li</li>
-<li>r.terraflow</li>
+<li>r.li.daemon</li>
+<li>r.li.edgedensity</li>
+<li>r.li.patchdensity</li>
+<li>r.li.patchnum</li>
+<li>r.li.shape</li>
+<li>r.li.simpson</li>
+<li>r.li.shannon</li>
+<li>r.li.mps</li>
+<li>r.li.mpa</li>
+<li>r.li.padcv</li>
+<li>r.li.padsd</li>
+<li>r.li.padrange</li>
+<li>r.li.cwed</li>
+<li>r.li.richness</li>
+<li>r.li.dominance</li>
 </div>
@@ -473,11 +490,11 @@
 <p>The WinGRASS self-contained binary package (including all the builds and the installer script) is provided by Marco Pasetti.</p>
+<p>This document has been written by Marco Pasetti, in agreement with the GRASS Development Team.</p>
 <p>To contact them, e-mail to: GRASS Development Mailing List
 (<a target="_blank" href="http://lists.osgeo.org/mailman/listinfo/grass-dev">http://lists.osgeo.org/mailman/listinfo/grass-dev</a>).</p>
-<p>This document has been written by Marco Pasetti, in agreement with the GRASS Development Team.</p>
 </div>
 </body>
