[GRASS-SVN] r31121 - in grass/trunk/demolocation/PERMANENT: . dbf
vector vector/mysites vector/point
svn_grass at osgeo.org
Fri Apr 25 15:44:58 EDT 2008
Author: neteler
Date: 2008-04-25 15:44:58 -0400 (Fri, 25 Apr 2008)
New Revision: 31121
Added:
grass/trunk/demolocation/PERMANENT/dbf/
grass/trunk/demolocation/PERMANENT/dbf/mysites.dbf
grass/trunk/demolocation/PERMANENT/dbf/point.dbf
grass/trunk/demolocation/PERMANENT/vector/
grass/trunk/demolocation/PERMANENT/vector/mysites/
grass/trunk/demolocation/PERMANENT/vector/mysites/cidx
grass/trunk/demolocation/PERMANENT/vector/mysites/coor
grass/trunk/demolocation/PERMANENT/vector/mysites/dbln
grass/trunk/demolocation/PERMANENT/vector/mysites/head
grass/trunk/demolocation/PERMANENT/vector/mysites/hist
grass/trunk/demolocation/PERMANENT/vector/mysites/topo
grass/trunk/demolocation/PERMANENT/vector/point/
grass/trunk/demolocation/PERMANENT/vector/point/cidx
grass/trunk/demolocation/PERMANENT/vector/point/coor
grass/trunk/demolocation/PERMANENT/vector/point/dbln
grass/trunk/demolocation/PERMANENT/vector/point/head
grass/trunk/demolocation/PERMANENT/vector/point/hist
grass/trunk/demolocation/PERMANENT/vector/point/topo
Removed:
grass/trunk/demolocation/PERMANENT/DEFAULT_WIND3
grass/trunk/demolocation/PERMANENT/WIND3
grass/trunk/demolocation/PERMANENT/dig/
grass/trunk/demolocation/PERMANENT/dig_att/
grass/trunk/demolocation/PERMANENT/dig_plus/
grass/trunk/demolocation/PERMANENT/site_lists/
removed legacy files; updated to current vector format (trac #144)
Deleted: grass/trunk/demolocation/PERMANENT/DEFAULT_WIND3
--- grass/trunk/demolocation/PERMANENT/DEFAULT_WIND3 2008-04-25 17:29:30 UTC (rev 31120)
+++ grass/trunk/demolocation/PERMANENT/DEFAULT_WIND3 2008-04-25 19:44:58 UTC (rev 31121)
@@ -1,14 +0,0 @@
-Proj: 3
-Zone: 0
-North: 90N
-South: 90S
-East: 180E
-West: 180W
-Top: 1
-Bottom: 0
-nofRows: 180
-nofCols: 360
-nofDepths: 1
-e-w resol: 1
-n-s resol: 1
-t-b resol: 1
Deleted: grass/trunk/demolocation/PERMANENT/WIND3
--- grass/trunk/demolocation/PERMANENT/WIND3 2008-04-25 17:29:30 UTC (rev 31120)
+++ grass/trunk/demolocation/PERMANENT/WIND3 2008-04-25 19:44:58 UTC (rev 31121)
@@ -1,14 +0,0 @@
-Proj: 3
-Zone: 0
-North: 90N
-South: 90S
-East: 180E
-West: 180W
-Top: 1
-Bottom: 0
-nofRows: 180
-nofCols: 360
-nofDepths: 1
-e-w resol: 1
-n-s resol: 1
-t-b resol: 1
Added: grass/trunk/demolocation/PERMANENT/dbf/mysites.dbf
(Binary files differ)
Property changes on: grass/trunk/demolocation/PERMANENT/dbf/mysites.dbf
___________________________________________________________________
+ application/octet-stream
Added: grass/trunk/demolocation/PERMANENT/dbf/point.dbf
Property changes on: grass/trunk/demolocation/PERMANENT/dbf/point.dbf
Added: grass/trunk/demolocation/PERMANENT/vector/mysites/cidx
Property changes on: grass/trunk/demolocation/PERMANENT/vector/mysites/cidx
Added: grass/trunk/demolocation/PERMANENT/vector/mysites/coor
Property changes on: grass/trunk/demolocation/PERMANENT/vector/mysites/coor
Added: grass/trunk/demolocation/PERMANENT/vector/mysites/dbln
--- grass/trunk/demolocation/PERMANENT/vector/mysites/dbln (rev 0)
+++ grass/trunk/demolocation/PERMANENT/vector/mysites/dbln 2008-04-25 19:44:58 UTC (rev 31121)
@@ -0,0 +1 @@
+1 mysites cat $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
Added: grass/trunk/demolocation/PERMANENT/vector/mysites/head
--- grass/trunk/demolocation/PERMANENT/vector/mysites/head (rev 0)
+++ grass/trunk/demolocation/PERMANENT/vector/mysites/head 2008-04-25 19:44:58 UTC (rev 31121)
@@ -0,0 +1,9 @@
+ORGANIZATION:
+DIGIT DATE:
+DIGIT NAME: neteler
+MAP NAME:
+MAP DATE: Fri Apr 25 21:41:24 2008
+MAP SCALE: 1
+OTHER INFO:
+ZONE: 0
+MAP THRESH: 0.000000
Added: grass/trunk/demolocation/PERMANENT/vector/mysites/hist
--- grass/trunk/demolocation/PERMANENT/vector/mysites/hist (rev 0)
+++ grass/trunk/demolocation/PERMANENT/vector/mysites/hist 2008-04-25 19:44:58 UTC (rev 31121)
@@ -0,0 +1,3 @@
+COMMAND: v.in.sites input="mysites" output="mysites"
+GISDBASE: /home/neteler/grass63
+LOCATION: demolocation MAPSET: PERMANENT USER: neteler DATE: Fri Apr 25 21:41:24 2008
Added: grass/trunk/demolocation/PERMANENT/vector/mysites/topo
Property changes on: grass/trunk/demolocation/PERMANENT/vector/mysites/topo
Added: grass/trunk/demolocation/PERMANENT/vector/point/cidx
Property changes on: grass/trunk/demolocation/PERMANENT/vector/point/cidx
Added: grass/trunk/demolocation/PERMANENT/vector/point/coor
Property changes on: grass/trunk/demolocation/PERMANENT/vector/point/coor
Added: grass/trunk/demolocation/PERMANENT/vector/point/dbln
--- grass/trunk/demolocation/PERMANENT/vector/point/dbln (rev 0)
+++ grass/trunk/demolocation/PERMANENT/vector/point/dbln 2008-04-25 19:44:58 UTC (rev 31121)
@@ -0,0 +1 @@
+1 point cat $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
Added: grass/trunk/demolocation/PERMANENT/vector/point/head
--- grass/trunk/demolocation/PERMANENT/vector/point/head (rev 0)
+++ grass/trunk/demolocation/PERMANENT/vector/point/head 2008-04-25 19:44:58 UTC (rev 31121)
@@ -0,0 +1,9 @@
+ORGANIZATION:
+DIGIT DATE:
+DIGIT NAME:
+MAP NAME:
+MAP DATE:
+MAP SCALE: 1
+OTHER INFO:
+ZONE: 0
Added: grass/trunk/demolocation/PERMANENT/vector/point/hist
--- grass/trunk/demolocation/PERMANENT/vector/point/hist (rev 0)
+++ grass/trunk/demolocation/PERMANENT/vector/point/hist 2008-04-25 19:44:58 UTC (rev 31121)
@@ -0,0 +1,15 @@
+COMMAND: v.convert input="point" output="point" endian="big"
+LOCATION: demolocation MAPSET: PERMANENT USER: neteler DATE: Fri Apr 25 21:41:49 2008
+COMMAND: v.db.connect map="point" driver="dbf" database="$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/" table="point" key="cat" layer=1
+LOCATION: demolocation MAPSET: PERMANENT USER: neteler DATE: Fri Apr 25 21:42:28 2008
+COMMAND: v.db.addtable "point" "col=name varchar(10)"
+LOCATION: demolocation MAPSET: PERMANENT USER: neteler DATE: Fri Apr 25 21:42:29 2008
+COMMAND: v.db.update "point" "col=name" "value=my point"
+LOCATION: demolocation MAPSET: PERMANENT USER: neteler DATE: Fri Apr 25 21:42:57 2008
Added: grass/trunk/demolocation/PERMANENT/vector/point/topo
Property changes on: grass/trunk/demolocation/PERMANENT/vector/point/topo
