[GRASS-SVN] r31125 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Apr 25 17:55:33 EDT 2008
Author: martinl
Date: 2008-04-25 17:55:33 -0400 (Fri, 25 Apr 2008)
New Revision: 31125
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/profile.py
wxGUI (profile): settings-related fixes (related to r31103)
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-04-25 20:50:47 UTC (rev 31124)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-04-25 21:55:33 UTC (rev 31125)
@@ -149,20 +149,17 @@
'saveOnExit' : { 'enabled' : False },
'profile': {
- 'raster0' : { 'pcolor' : wx.Colour(0, 0, 255), # profile line color
+ 'raster0' : { 'pcolor' : (0, 0, 255, 255), # profile line color
'pwidth' : 1, # profile line width
- 'pstyle' : wx.SOLID, # profile line pen style
- 'plegend' : _('Profile'), # profile legend string
+ 'pstyle' : 'solid', # profile line pen style
- 'raster1' : { 'pcolor' : wx.Colour(255, 0, 0),
+ 'raster1' : { 'pcolor' : (255, 0, 0, 255),
'pwidth' : 1,
- 'raster2' : { 'pcolor' : wx.Colour(0, 255, 0),
+ 'raster2' : { 'pcolor' : (0, 255, 0, 255),
'pwidth' : 1,
'font' : { 'titleSize' : 12,
'axisSize' : 11,
Modified: grass/trunk/gui/wxpython/gui_modules/profile.py
--- grass/trunk/gui/wxpython/gui_modules/profile.py 2008-04-25 20:50:47 UTC (rev 31124)
+++ grass/trunk/gui/wxpython/gui_modules/profile.py 2008-04-25 21:55:33 UTC (rev 31125)
@@ -72,6 +72,13 @@
self.mapwin = self.parent.MapWindow
self.Map = render.Map() # instance of render.Map to be associated with display
+ self.pstyledict = { 'solid' : wx.SOLID,
+ 'dot' : wx.DOT,
+ 'long-dash' : wx.LONG_DASH,
+ 'short-dash' : wx.SHORT_DASH,
+ 'dot-dash' : wx.DOT_DASH }
wx.Frame.__init__(self, parent, id, title, pos, size, style)
@@ -114,14 +121,17 @@
# 0 -> default raster map to profile
# 1, 2 -> optional raster map to profile
# units -> map data units (used for y axis legend)
- self.raster = { 0 : UserSettings.Get(group='profile', key='raster0'),
- 1 : UserSettings.Get(group='profile', key='raster1'),
- 2 : UserSettings.Get(group='profile', key='raster2') }
- for r in self.raster.itervalues():
- r['name'] = ''
- r['units'] = ''
- r['datalist'] = [] # list of distance,value pairs for plotting profile
- r['pline'] = None # first (default) profile line
+ self.raster = {}
+ for idx in (0, 1, 2):
+ self.raster[idx] = {}
+ self.raster[idx]['name'] = ''
+ self.raster[idx]['units'] = ''
+ self.raster[idx]['plegend'] = ''
+ # list of distance,value pairs for plotting profile
+ self.raster[idx]['datalist'] = []
+ # first (default) profile line
+ self.raster[idx]['pline'] = None
+ self.raster[idx]['prop'] = UserSettings.Get(group='profile', key='raster' + str(idx))
# set raster map name (if given)
for idx in range(len(rasterList)):
@@ -140,9 +150,6 @@
# title of window
self.ptitle = _('Profile of')
- for r in self.raster.keys():
- if self.raster[r]['name'] != '':
- self.ptitle += ' %s' % self.raster[r]['name']
# determine units (axis labels)
if self.parent.projinfo['units'] != '':
@@ -152,19 +159,22 @@
self.ylabel = _("Cell values")
self.properties = {}
- self.properties['font'] = UserSettings.Get(group='profile', key='font')
+ self.properties['font'] = {}
+ self.properties['font']['prop'] = UserSettings.Get(group='profile', key='font')
self.properties['font']['wxfont'] = wx.Font(11, wx.FONTFAMILY_SWISS,
wx.FONTSTYLE_NORMAL,
wx.FONTWEIGHT_NORMAL)
self.properties['marker'] = UserSettings.Get(group='profile', key='marker')
self.properties['grid'] = UserSettings.Get(group='profile', key='grid')
- self.properties['x-axis'] = UserSettings.Get(group='profile', key='x-axis')
+ self.properties['x-axis'] = {}
+ self.properties['x-axis']['prop'] = UserSettings.Get(group='profile', key='x-axis')
self.properties['x-axis']['axis'] = None
- self.properties['y-axis'] = UserSettings.Get(group='profile', key='y-axis')
- self.properties['x-axis']['axis'] = None
+ self.properties['y-axis'] = {}
+ self.properties['y-axis']['prop'] = UserSettings.Get(group='profile', key='y-axis')
+ self.properties['y-axis']['axis'] = None
self.properties['legend'] = UserSettings.Get(group='profile', key='legend')
# zooming disabled
@@ -177,8 +187,8 @@
# x and y axis set to normal (non-log)
self.client.setLogScale((False, False))
- self.client.SetXSpec(self.properties['x-axis']['type'])
- self.client.SetYSpec(self.properties['y-axis']['type'])
+ self.client.SetXSpec(self.properties['x-axis']['prop']['type'])
+ self.client.SetYSpec(self.properties['y-axis']['prop']['type'])
# Bind various events
@@ -214,7 +224,8 @@
self.raster[r]['name'] = dlg.raster[r]['name']
# plot profile
- self.OnCreateProfile(event=None)
+ if self.raster[0]['name']:
+ self.OnCreateProfile(event=None)
dlg.Destroy()
@@ -240,19 +251,9 @@
else:
self.coordstr = '%s,%d,%d' % (self.coordstr, point[0], point[1])
- else:
- wx.MessageBox(parent=self,
- message=_('You must draw a transect to profile in the map display window.'),
- caption=_('Nothing to profile'),
- style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
- return
if self.raster[0]['name'] == '':
return
- # set default title and legend text
- self.ptitle = _('Profile of')
# create datalist for each raster map
@@ -260,11 +261,11 @@
if r['name'] == '':
continue
r['datalist'] = self.CreateDatalist(r['name'], self.coordstr)
- r['plegend'] = _(' Profile of %s') % r['name']
+ r['plegend'] = _('Profile of %s') % r['name']
p = gcmd.Command(['r.info',
- 'map=%s' % self.raster[0]['name'],
+ 'map=%s' % r['name'],
'-u',
'--quiet'])
r['units'] = p.ReadStdOutput()[0].split('=')[1]
@@ -324,51 +325,54 @@
Set plot and text options
self.client.SetFont(self.properties['font']['wxfont'])
- self.client.SetFontSizeTitle(self.properties['font']['titleSize'])
- self.client.SetFontSizeAxis(self.properties['font']['axisSize'])
+ self.client.SetFontSizeTitle(self.properties['font']['prop']['titleSize'])
+ self.client.SetFontSizeAxis(self.properties['font']['prop']['axisSize'])
self.client.SetEnableZoom(self.zoom)
self.client.SetEnableDrag(self.drag)
- if self.properties['x-axis']['type'] == 'custom':
+ if self.properties['x-axis']['prop']['type'] == 'custom':
self.client.SetXSpec('min')
else:
- if self.properties['y-axis']['type'] == 'custom':
+ if self.properties['y-axis']['prop']['type'] == 'custom':
self.client.SetYSpec('min')
else:
- if self.properties['x-axis']['type'] == 'custom' and \
- self.properties['x-axis']['min'] != self.properties['x-axis']['max']:
- self.properties['x-axis']['axis'] = (self.properties['x-axis']['min'],
- self.properties['x-axis']['max'])
+ if self.properties['x-axis']['prop']['type'] == 'custom' and \
+ self.properties['x-axis']['prop']['min'] != self.properties['x-axis']['prop']['max']:
+ self.properties['x-axis']['prop']['axis'] = (self.properties['x-axis']['prop']['min'],
+ self.properties['x-axis']['prop']['max'])
else:
- if self.properties['y-axis']['type'] == 'custom' and \
- self.properties['y-axis']['min'] != self.properties['y-axis']['max']:
- self.properties['y-axis']['axis'] = (self.properties['y-axis']['min'],
- self.properties['y-axis']['max'])
+ if self.properties['y-axis']['prop']['type'] == 'custom' and \
+ self.properties['y-axis']['prop']['min'] != self.properties['y-axis']['prop']['max']:
+ self.properties['y-axis']['axis'] = (self.properties['y-axis']['prop']['min'],
+ self.properties['y-axis']['prop']['max'])
else:
self.client.SetEnableGrid(self.properties['grid']['enabled'])
- self.client.SetGridColour(self.properties['grid']['color'])
+ self.client.SetGridColour(wx.Color(self.properties['grid']['color'][0],
+ self.properties['grid']['color'][1],
+ self.properties['grid']['color'][2],
+ 255))
- self.client.SetFontSizeLegend(self.properties['font']['legendSize'])
+ self.client.SetFontSizeLegend(self.properties['font']['prop']['legendSize'])
self.client.SetEnableLegend(self.properties['legend']['enabled'])
- if self.properties['x-axis']['log'] == True:
+ if self.properties['x-axis']['prop']['log'] == True:
- if self.properties['y-axis']['log'] == True:
+ if self.properties['y-axis']['prop']['log'] == True:
- self.client.setLogScale((self.properties['x-axis']['log'],
- self.properties['y-axis']['log']))
+ self.client.setLogScale((self.properties['x-axis']['prop']['log'],
+ self.properties['y-axis']['prop']['log']))
# self.client.SetPointLabelFunc(self.DrawPointLabel())
@@ -401,7 +405,7 @@
segments, these are drawn as points. Profile transect is drawn, using
methods in mapdisp.py
- if self.raster[0]['name'] == '':
+ if len(self.mapwin.polycoords) == 0 or self.raster[0]['name'] == '':
dlg = wx.MessageDialog(parent=self,
@@ -433,15 +437,15 @@
self.plotlist = []
if len(r['datalist']) > 0:
- col = wx.Color(r['pcolor'][0],
- r['pcolor'][1],
- r['pcolor'][2],
- r['pcolor'][3])
+ col = wx.Color(r['prop']['pcolor'][0],
+ r['prop']['pcolor'][1],
+ r['prop']['pcolor'][2],
+ 255)
r['pline'] = plot.PolyLine(r['datalist'],
colour=col,
- width=r['pwidth'],
- style=r['pstyle'],
- legend=' ' + r['plegend'])
+ width=r['prop']['pwidth'],
+ style=self.pstyledict[r['prop']['pstyle']],
+ legend=r['plegend'])
self.plotlist.append(r['pline'])
@@ -458,15 +462,15 @@
self.xlabel,
self.ylabel)
else:
else:
self.client.Draw(self.profile, self.properties['x-axis']['axis'],
self.properties['y-axis']['axis'])
@@ -619,8 +623,8 @@
dlg.UpdateSettings()
self.profile.setTitle(dlg.ptitle)
self.profile.setXLabel(dlg.xlabel)
@@ -846,7 +850,7 @@
self.ptitlesize = wx.SpinCtrl(parent=self, id=wx.ID_ANY, value="", pos=(30, 50),
size=(50,-1), style=wx.SP_ARROW_KEYS)
self.ptitlesize.SetRange(5,100)
- self.ptitlesize.SetValue(int(self.properties['font']['titleSize']))
+ self.ptitlesize.SetValue(int(self.properties['font']['prop']['titleSize']))
gridSizer.Add(item=self.ptitlesize, pos=(1, 1))
@@ -877,7 +881,7 @@
self.axislabelsize = wx.SpinCtrl(parent=self, id=wx.ID_ANY, value="", pos=(30, 50),
size=(50, -1), style=wx.SP_ARROW_KEYS)
self.axislabelsize.SetRange(5, 100)
- self.axislabelsize.SetValue(int(self.properties['font']['axisSize']))
+ self.axislabelsize.SetValue(int(self.properties['font']['prop']['axisSize']))
gridSizer.Add(item=self.axislabelsize, pos=(4,1))
boxSizer.Add(item=gridSizer)
@@ -974,8 +978,8 @@
self.ylabel = event.GetString()
def UpdateSettings(self):
- self.properties['font']['titleSize'] = self.ptitlesize.GetValue()
- self.properties['font']['axisSize'] = self.axislabelsize.GetValue()
+ self.properties['font']['prop']['titleSize'] = self.ptitlesize.GetValue()
+ self.properties['font']['prop']['axisSize'] = self.axislabelsize.GetValue()
family = self.ffamilydict[self.ffamilycb.GetStringSelection()]
self.properties['font']['wxfont'].SetFamily(family)
@@ -993,13 +997,8 @@
marker size, color, fill, and style; grid and legend options.
# init variables
+ self.pstyledict = parent.pstyledict
- self.pstyledict = { 'solid' : wx.SOLID,
- 'dot' : wx.DOT,
- 'long-dash' : wx.LONG_DASH,
- 'short-dash' : wx.SHORT_DASH,
- 'dot-dash' : wx.DOT_DASH }
self.pttypelist = ['circle',
'dot',
'square',
@@ -1012,7 +1011,7 @@
'solid' : wx.SOLID }
self.axislist = ['min',
- 'auto'
+ 'auto',
'custom']
# widgets ids
@@ -1052,7 +1051,7 @@
row = 0
label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Line color"))
gridSizer.Add(item=label, flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
- pcolor = csel.ColourSelect(parent=self, id=wx.ID_ANY, colour=r['pcolor'])
+ pcolor = csel.ColourSelect(parent=self, id=wx.ID_ANY, colour=r['prop']['pcolor'])
self.wxId['pcolor'].append(pcolor.GetId())
gridSizer.Add(item=pcolor, pos=(row, 1))
@@ -1062,7 +1061,7 @@
pwidth = wx.SpinCtrl(parent=self, id=wx.ID_ANY, value="",
pwidth.SetRange(1, 10)
- pwidth.SetValue(r['pwidth'])
+ pwidth.SetValue(r['prop']['pwidth'])
self.wxId['pwidth'].append(pwidth.GetId())
gridSizer.Add(item=pwidth, pos=(row, 1))
@@ -1071,6 +1070,7 @@
pstyle = wx.ComboBox(parent=self, id=wx.ID_ANY,
size=(120, -1), choices=self.pstyledict.keys(), style=wx.CB_DROPDOWN)
+ pstyle.SetStringSelection(r['prop']['pstyle'])
self.wxId['pstyle'].append(pstyle.GetId())
gridSizer.Add(item=pstyle, pos=(row, 1))
@@ -1171,7 +1171,7 @@
boxSizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
- prop = self.properties[atype]
+ prop = self.properties[atype]['prop']
row = 0
label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Style"))
@@ -1246,7 +1246,7 @@
legendfontsize = wx.SpinCtrl(parent=self, id=wx.ID_ANY, value="",
legendfontsize.SetRange(5,100)
- legendfontsize.SetValue(int(self.properties['font']['legendSize']))
+ legendfontsize.SetValue(int(self.properties['font']['prop']['legendSize']))
self.wxId['font']['legendSize'] = legendfontsize.GetId()
gridSizer.Add(item=legendfontsize, pos=(row, 1))
@@ -1287,9 +1287,9 @@
idx = 0
- r['pcolor'] = self.FindWindowById(self.wxId['pcolor'][idx]).GetColour()[0:5] #?
- r['pwidth'] = int(self.FindWindowById(self.wxId['pwidth'][idx]).GetValue())
- r['pstyle'] = self.FindWindowById(self.wxId['pstyle'][idx]).GetStringSelection()
+ r['prop']['pcolor'] = self.FindWindowById(self.wxId['pcolor'][idx]).GetColour()
+ r['prop']['pwidth'] = int(self.FindWindowById(self.wxId['pwidth'][idx]).GetValue())
+ r['prop']['pstyle'] = self.pstyledict[self.FindWindowById(self.wxId['pstyle'][idx]).GetStringSelection()]
r['plegend'] = self.FindWindowById(self.wxId['plegend'][idx]).GetValue()
idx +=1
@@ -1300,15 +1300,15 @@
self.properties['marker']['legend'] = self.FindWindowById(self.wxId['marker']['legend']).GetValue()
for axis in ('x-axis', 'y-axis'):
- self.properties[axis]['type'] = self.FindWindowById(self.wxId[axis]['type']).GetValue()
- self.properties[axis]['min'] = self.FindWindowById(self.wxId[axis]['min']).GetValue()
- self.properties[axis]['max'] = self.FindWindowById(self.wxId[axis]['max']).GetValue()
- self.properties[axis]['log'] = self.FindWindowById(self.wxId[axis]['log']).IsChecked()
+ self.properties[axis]['prop']['type'] = self.FindWindowById(self.wxId[axis]['type']).GetValue()
+ self.properties[axis]['prop']['min'] = self.FindWindowById(self.wxId[axis]['min']).GetValue()
+ self.properties[axis]['prop']['max'] = self.FindWindowById(self.wxId[axis]['max']).GetValue()
+ self.properties[axis]['prop']['log'] = self.FindWindowById(self.wxId[axis]['log']).IsChecked()
self.properties['grid']['color'] = self.FindWindowById(self.wxId['grid']['color']).GetColour()
self.properties['grid']['enabled'] = self.FindWindowById(self.wxId['grid']['enabled']).IsChecked()
- self.properties['font']['legendSize'] = self.FindWindowById(self.wxId['font']['legendSize']).GetValue()
+ self.properties['font']['prop']['legendSize'] = self.FindWindowById(self.wxId['font']['legendSize']).GetValue()
self.properties['legend']['enabled'] = self.FindWindowById(self.wxId['legend']['enabled']).IsChecked()
