[GRASS-SVN] r31134 - grass-addons/raster/r.colors.tools
svn_grass at osgeo.org
Sun Apr 27 03:41:52 EDT 2008
Author: hamish
Date: 2008-04-27 03:41:52 -0400 (Sun, 27 Apr 2008)
New Revision: 31134
grass-addons/raster/r.colors.tools/r.cpt2grass
update to translate HSV input rules
Modified: grass-addons/raster/r.colors.tools/r.cpt2grass
--- grass-addons/raster/r.colors.tools/r.cpt2grass 2008-04-27 05:26:05 UTC (rev 31133)
+++ grass-addons/raster/r.colors.tools/r.cpt2grass 2008-04-27 07:41:52 UTC (rev 31134)
@@ -67,12 +67,21 @@
exit 1
fi
-if [ `grep 'COLOR_MODEL' "$GIS_OPT_INPUT" | cut -f2 -d= | grep -c 'HSV\|CMYK'` -gt 0 ] ; then
- echo "ERROR: Only the RGB color model is supported" 1>&2
- exit 1
-fi
+COLOR_MODEL=`grep '^# \?COLOR_MODEL' "$GIS_OPT_INPUT" | cut -f2 -d= | awk '{print $1}'`
+case "$COLOR_MODEL" in
+ RGB | HSV)
+ if [ -n "$GRASS_VERBOSE" ] && [ "$GRASS_VERBOSE" -gt 1 ] ; then
+ echo "Color model is $COLOR_MODEL" 1>&2
+ fi
+ CMYK | *)
+ echo "ERROR: Only the RGB and HSV color models are supported" 1>&2
+ exit 1
+esac
# check if we have awk
AWK=`which awk`
if [ "$AWK" = "" ] ; then
@@ -91,7 +100,77 @@
fi
+#### fn to convert hsv to rgb
+# Converts HSV to RGB. Based on the Foley and Van Dam HSV algorithm used
+# in the hsv.rgb.sh script in GRASS 4/5 by James Westervelt (CERL)
+HSVtoRGB() {
+ # Hue: 0-360 degrees
+ H=$1
+ # Satuaration: 0.0-1.0
+ S=$2
+ # Value: 0.0-1.0
+ V=$3
+ #if V == 0: black
+ #if V == 1: white
+ #else chromatic calculation
+ awk -v H="$H" -v S="$S" -v V="$V" 'BEGIN {
+# if(V == 0.0) {printf("R=0\nG=0\nB=0\n"); exit}
+# if(V == 1.0) {printf("R=255\nG=255\nB=255\n"); exit}
+ if(V == 0.0) {printf("black\n"); exit}
+ if(V == 1.0) {printf("white\n"); exit}
+ #print "chromatic: H=" H " S=" S " V=" V
+ if(H >=360) {H -= 360}
+ h = H/60.0
+ i = int(h)
+ f = h-i
+ p = V * (1-S)
+ q = V * (1-S*f)
+ t = V * (1-S*(1-f))
+ # init/fallback
+ R = G = B = 0
+ #switch/case not portable in (g)awk?
+ # red
+ if(i==0) {R = V}
+ if(i==1) {R = q}
+ if(i==2) {R = p}
+ if(i==3) {R = p}
+ if(i==4) {R = t}
+ if(i==5) {R = V}
+ # green
+ if(i==0) {G = t}
+ if(i==1) {G = V}
+ if(i==2) {G = V}
+ if(i==3) {G = q}
+ if(i==4) {G = p}
+ if(i==5) {G = p}
+ # blue
+ if(i==0) {B = p}
+ if(i==1) {B = p}
+ if(i==2) {B = t}
+ if(i==3) {B = V}
+ if(i==4) {B = V}
+ if(i==5) {B = q}
+ #printf("s=%.2f h=%.2f i=%d f=%.4f p=%.4f q=%.4f t=%.4f\n", S, h, i, f, p, q, t)
+# printf("R=%d\nG=%d\nB=%d\n", R*255, G*255, B*255)
+ printf("%d:%d:%d\n", R*255, G*255, B*255)
+#### process cpt file
# B background is for values less than the first color rule, F foreground is for greater.
# in GRASS we just consider that to be null, although we could define a color rule
# max<->near infinity to be solidly that color. ??
@@ -101,9 +180,20 @@
echo "# from [$GIS_OPT_INPUT] by $USER at `date`" >> "$TMP"
grep '^#' "$GIS_OPT_INPUT" >> "$TMP"
# null value color
-grep '^N' "$GIS_OPT_INPUT" | \
- awk '{printf("nv %d:%d:%d\n", $2, $3, $4)}' >> "$TMP"
+ RGB)
+ grep '^N' "$GIS_OPT_INPUT" | \
+ awk '{printf("nv %d:%d:%d\n", $2, $3, $4)}' >> "$TMP"
+ HSV)
+ HSV=`grep '^N' "$GIS_OPT_INPUT" | awk '{print $2 " " $3 " " $4}'`
+ RGB=`HSVtoRGB $HSV`
+ #echo "HSV=[$HSV] RGB=[$RGB]"
+ echo "nv $RGB" >> "$TMP"
+esac
# do it in an awk script:
@@ -112,9 +202,35 @@
#if N nv
if [ $GIS_FLAG_S -eq 0 ] ; then
- # the data
- grep '^[0-9.-]' "$GIS_OPT_INPUT" | \
- awk '{printf("%s %d:%d:%d\n%s %d:%d:%d\n", $1, $2, $3, $4, $5, $6, $7, $8)}' >> "$TMP"
+ # the data
+ case "$COLOR_MODEL" in
+ RGB)
+ grep '^[0-9.-]' "$GIS_OPT_INPUT" | \
+ awk '{printf("%s %d:%d:%d\n%s %d:%d:%d\n", $1, $2, $3, $4, $5, $6, $7, $8)}' >> "$TMP"
+ HSV)
+ while read LINE ; do
+ if [ `echo "$LINE" | grep -c '^[0-9.-]'` -lt 1 ] ; then
+ continue
+ fi
+ ELEV1=`echo "$LINE" | awk '{print $1}'`
+ H1=`echo "$LINE" | awk '{print $2}'`
+ S1=`echo "$LINE" | awk '{print $3}'`
+ V1=`echo "$LINE" | awk '{print $4}'`
+ ELEV2=`echo "$LINE" | awk '{print $5}'`
+ H2=`echo "$LINE" | awk '{print $6}'`
+ S2=`echo "$LINE" | awk '{print $7}'`
+ V2=`echo "$LINE" | awk '{print $8}'`
+ RGB1=`HSVtoRGB "$H1" "$S1" "$V1"`
+ RGB2=`HSVtoRGB "$H2" "$S2" "$V2"`
+ echo "$ELEV1 $RGB1" >> "$TMP"
+ echo "$ELEV2 $RGB2" >> "$TMP"
+ done < "$GIS_OPT_INPUT"
+ esac
else
# strech to fit data
@@ -143,16 +259,37 @@
PERCENT_MAX=`echo "$LINE_MAX" | awk -v RANGE="$RANGE" -v CMAX="$CPT_MAX" \
'{print 100 * (RANGE - (CMAX - $1)) / RANGE }'`
- echo "$LINE" | awk -v PMIN="$PERCENT_MIN" -v PMAX="$PERCENT_MAX" \
- '{printf("%s%% %d:%d:%d\n%s%% %d:%d:%d\n", PMIN, $2, $3, $4, PMAX, $6, $7, $8)}' >> "$TMP"
# DEBUG:
#echo "LINE: [$LINE]"
#echo " lmin=$LINE_MIN lmax=$LINE_MAX pmin=$PERCENT_MIN pmax=$PERCENT_MAX "
+ RGB)
+ echo "$LINE" | awk -v PMIN="$PERCENT_MIN" -v PMAX="$PERCENT_MAX" \
+ '{printf("%s%% %d:%d:%d\n%s%% %d:%d:%d\n", PMIN, $2, $3, $4, PMAX, $6, $7, $8)}' >> "$TMP"
+ HSV)
+ echo "${PERCENT_MIN}% $RGB1" >> "$TMP"
+ echo "${PERCENT_MAX}% $RGB2" >> "$TMP"
+ esac
fi
+#### apply new rules
uniq "$TMP" "${TMP}.u"
if [ -n "$GIS_OPT_MAP" ] ; then
