[GRASS-SVN] r31149 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sun Apr 27 15:27:49 EDT 2008
Author: martinl
Date: 2008-04-27 15:27:49 -0400 (Sun, 27 Apr 2008)
New Revision: 31149
Added:
   grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
Removed:
   grass/branches/develbranch_6/gui/wxpython/gui_modules/digit.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
wxGUI: 'digit' module renamed to 'vdigit' (including classes)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py	2008-04-27 18:54:24 UTC (rev 31148)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py	2008-04-27 19:27:49 UTC (rev 31149)
@@ -1,6 +1,5 @@
 all = [ "dbm",
         "debug",
-        "digit",
         "disp_print",
         "gcmd",
         "georect",
@@ -22,5 +21,6 @@
         "toolbox",
         "track",
         "utils",
+        "vdigit",
         "workspace",
         "wxgui_utils" ]
Deleted: grass/branches/develbranch_6/gui/wxpython/gui_modules/digit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/digit.py	2008-04-27 18:54:24 UTC (rev 31148)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/digit.py	2008-04-27 19:27:49 UTC (rev 31149)
@@ -1,2578 +0,0 @@
-MODULE: digit
-CLASSES:
- * DigitError
- * AbstractDigit
- * VEdit
- * VDigit
- * AbstractDisplayDriver
- * CDisplayDriver
- * DigitSettingsDialog
- * DigitCategoryDialog
- * DigitZBulkDialog
-PURPOSE: Digitization tool wxPython GUI prototype
-         Note: Initial version under development
-         Progress:
-          (1) v.edit called on the background (class VEdit)
-          (2) Reimplentation of v.digit (VDigit)
-         Import:
-          from digit import Digit as Digit
-AUTHORS: The GRASS Development Team
-         Martin Landa <landa.martin gmail.com>
-COPYRIGHT: (C) 2007-2008 by the GRASS Development Team
-           This program is free software under the GNU General Public
-           License (>=v2). Read the file COPYING that comes with GRASS
-           for details.
-import os
-import sys
-import string
-import copy
-import wx
-import wx.lib.colourselect as csel
-import wx.lib.mixins.listctrl as listmix
-import gcmd
-import dbm
-from debug import Debug as Debug
-import gselect
-import globalvar
-from preferences import globalSettings as UserSettings
-try:
-    digitPath = os.path.join(globalvar.ETCWXDIR, "vdigit")
-    sys.path.append(digitPath)
-    import grass6_wxvdigit as vdigit
-    GV_LINES = vdigit.GV_LINES
-    digitErr = ''
-except ImportError, err:
-    GV_LINES = None
-    digitErr = err
-    #    print >> sys.stderr, "%sWARNING: Digitization tool is disabled (%s). " \
-    #          "Detailed information in README file." % \
-    #          (os.linesep, err)
-# which interface to use?
-if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit' and GV_LINES is not None:
-    print >> sys.stderr, "%sWARNING: Digitization tool uses v.edit interface. " \
-        "This can significantly slow down some operations especially for " \
-        "middle-large vector maps. "\
-        "You can change the digitization interface in 'User preferences' " \
-        "(menu 'Config'->'Preferences')." % \
-          os.linesep
-class AbstractDigit:
-    Abstract digitization class
-    def __init__(self, mapwindow):
-        """Initialization
-        @param mapwindow reference to mapwindow (MapFrame) instance
-        @param settings  initial settings of digitization tool
-        self.map       = None
-        self.mapWindow = mapwindow
-        Debug.msg (3, "AbstractDigit.__init__(): map=%s" % \
-                   self.map)
-        #self.SetCategory()
-        self.driver = CDisplayDriver(self, mapwindow)
-    def SetCategoryNextToUse(self):
-        """Find maximum category number in the map layer
-        and update Digit.settings['category']
-        @return 'True' on success, 'False' on failure
-        # vector map layer without categories, reset to '1'
-        UserSettings.Set(group='vdigit', key='category', subkey='value', value=1)
-        if self.map:
-            if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit':
-                categoryCmd = gcmd.Command(cmd=["v.category", "-g", "--q",
-                                                "input=%s" % self.map,
-                                                "option=report"])
-                if categoryCmd.returncode != 0:
-                    return False
-                for line in categoryCmd.ReadStdOutput():
-                    if "all" in line:
-                        if UserSettings.Get(group='vdigit', key='layer', subkey='value') != int(line.split(' ')[0]):
-                            continue
-                        try:
-                            maxCat = int(line.split(' ')[-1]) + 1
-                            UserSettings.Set(group='vdigit', key='category', subkey='value', value=maxCat)
-                        except:
-                            return False
-                        return True
-            else:
-                                  value=self.digit.GetCategory(UserSettings.Get(group='vdigit', key='layer', subkey='value') + 1))
-    def SetCategory(self):
-        """Return category number to use (according Settings)"""
-        if UserSettings.Get(group='vdigit', key="categoryMode", subkey='value') == "No category":
-            UserSettings.Set(group='vdigit', key="category", subkey='value', value=1)
-        elif UserSettings.Get(group='vdigit', key="categoryMode", subkey='value') == "Next to use":
-            self.SetCategoryNextToUse()
-        return UserSettings.Get(group='vdigit', key="category", subkey='value')
-    def SetMapName(self, map):
-        """Set map name
-        @param map map name to be set up or None (will close currently edited map)
-        Debug.msg (3, "AbstractDigit.SetMapName map=%s" % map)
-        self.map = map
-        try:
-            ret = self.driver.Reset(self.map)
-        except StandardError, e:
-            raise gcmd.DigitError('Unable to initialize display driver, '
-                                  'see README file for more information.%s%s'
-                                  'Details: %s (%s)' % (os.linesep, os.linesep, e, digitErr))
-        if map and ret == -1:
-            raise gcmd.DigitError(_('Unable to open vector map <%s> for editing. '
-                                    'Data are probably corrupted, '
-                                    'try to run v.build for rebuilding the topology.') % map)
-        if not map and ret != 0:
-        if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') != 'v.edit':
-            try:
-                self.digit.InitCats()
-            except:
-                pass
-    def SelectLinesByQueryThresh(self):
-        """Generic method used for SelectLinesByQuery()
-        -- to get threshold value"""
-        thresh = 0.0
-        if UserSettings.Get(group='vdigit', key='query', subkey='type') == "length":
-            thresh = UserSettings.Get(group='vdigit', key='queryLength', subkey='thresh')
-            if UserSettings.Get(group='vdigit', key="queryLength", subkey='than') == "shorter than":
-                thresh = -1 * thresh
-        else:
-            thresh = UserSettings.Get(group='vdigit', key='queryDangle', subkey='thresh')
-            if UserSettings.Get(group='vdigit', key="queryDangle", subkey='than') == "shorter than":
-        return thresh
-    def GetSelectType(self):
-        """Get type(s) to be selected
-        Used by SelectLinesByBox() and SelectLinesByPoint()"""
-        type = 0
-        for feature in (('Point', vdigit.GV_POINT),
-                        ('Line', vdigit.GV_LINE),
-                        ('Centroid', vdigit.GV_CENTROID),
-                        ('Boundary', vdigit.GV_BOUNDARY)):
-            if UserSettings.Get(group='vdigit', key='selectFeature'+feature[0], subkey='enabled') is True:
-                type |= feature[1]
-        return type
-    def SelectLinesFromBackgroundMap(self, pos1, pos2):
-        """Select features from background map
-        @param pos1,pos2 bounding box defifinition
-        if UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value') == '':
-            Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): []")
-            return []
-        x1, y1 = pos1
-        x2, y2 = pos2
-        vEditCmd = gcmd.Command(['v.edit',
-                                 '--q',
-                                 'map=%s' % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'),
-                                 'tool=select',
-                                 'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1])])
-                                 #'polygon=%f,%f,%f,%f,%f,%f,%f,%f,%f,%f' % \
-                                 #    (x1, y1, x2, y1, x2, y2, x1, y2, x1, y1)])
-        try:
-            output = vEditCmd.ReadStdOutput()[0] # first line
-            ids = output.split(',')
-            ids = map(int, ids) # str -> int
-        except:
-            return []
-        Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): %s" % \
-                      ",".join(["%d" % v for v in ids]))
-        return ids
-class VEdit(AbstractDigit):
-    Prototype of digitization class based on v.edit command
-    Note: This should be replaced by VDigit class.
-        """Initialization
-        AbstractDigit.__init__(self, mapwindow)
-    def AddPoint (self, map, point, x, y, z=None):
-        """Add point/centroid
-        @param point feature type (True for point, otherwise centroid)
-        @param x,y,z coordinates
-        if point:
-            key = "P"
-        else:
-            key = "C"
-        layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
-        cat   = self.SetCategory()
-        if layer > 0 and cat != "None":
-            addstring =  "%s 1 1\n" % (key)
-        else:
-            addstring =  "%s 1\n" % (key)
-        addstring += "%f %f\n" % (x, y)
-            addstring += "%d %d\n" % (layer, cat)
-            Debug.msg (3, "VEdit.AddPoint(): map=%s, type=%s, layer=%d, cat=%d, x=%f, y=%f" % \
-                           (map, type, layer, cat, x, y))
-        else:
-            Debug.msg (3, "VEdit.AddPoint(): map=%s, type=%s, x=%f, y=%f" % \
-                           (map, type, x, y))
-        Debug.msg (4, "Vline.AddPoint(): input=%s" % addstring)
-        self.__AddFeature (map=map, input=addstring)
-    def AddLine (self, map, line, coords):
-        """Add line/boundary
-        @param line feature type (True for line, otherwise boundary)
-        @param list of coordinates
-        if len(coords) < 2:
-            return
-        if line:
-            key = "L"
-            flags = []
-        else:
-            key = "B"
-            flags = ['-c'] # close boundaries
-            addstring = "%s %d 1\n" % (key, len(coords))
-        else:
-            addstring = "%s %d\n" % (key, len(coords))
-        for point in coords:
-            addstring += "%f %f\n" % \
-                (float(point[0]), float(point [1]))
-            Debug.msg (3, "Vline.AddLine(): type=%s, layer=%d, cat=%d coords=%s" % \
-                           (key, layer, cat, coords))
-        else:
-            Debug.msg (3, "Vline.AddLine(): type=%s, coords=%s" % \
-                           (key, coords))
-        Debug.msg (4, "VEdit.AddLine(): input=%s" % addstring)
-        self.__AddFeature (map=map, input=addstring, flags=flags)
-    def __AddFeature (self, map, input, flags=[]):
-        """Generic method to add new vector feature
-        @param input feature definition in GRASS ASCII format
-        @param flags additional flags
-        if UserSettings.Get(group='vdigit', key='snapping', subkey='value') <= 0.0:
-            snap = "no"
-        else:
-            if UserSettings.Get(group='vdigit', key='snapToVertex', subkey='enabled') is True:
-                snap = "vertex"
-            else:
-                snap = "node"
-        command = ["v.edit", "-n", "--q",
-                   "map=%s" % map,
-                   "tool=add",
-                   "thresh=%f,%f" % (self.driver.GetThreshold(type='selectThresh'), self.driver.GetThreshold(type='snapping')),
-                   "snap=%s" % snap]
-        if UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value') != '':
-            command.append("bgmap=%s" % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'))
-        # additional flags
-        for flag in flags:
-            command.append(flag)
-        # run the command
-        Debug.msg(4, "VEdit.AddFeature(): input=%s" % input)
-        vedit = gcmd.Command(cmd=command, stdin=input, stderr=None)
-        # reload map (needed for v.edit)
-        self.driver.ReloadMap()
-    def DeleteSelectedLines(self):
-        """Delete selected features"""
-        selected = self.driver.GetSelected() # grassId
-        if len(selected) <= 0:
-            return False
-        ids = ",".join(["%d" % v for v in selected])
-        Debug.msg(4, "Digit.DeleteSelectedLines(): ids=%s" % \
-                      ids)
-        # delete also attributes if requested
-        if UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled') is True:
-            layerCommand = gcmd.Command(cmd=["v.db.connect",
-                                             "-g", "--q",
-                                             "map=%s" % self.map],
-                                        rerr=None, stderr=None)
-            if layerCommand.returncode == 0:
-                layers = {}
-                for line in layerCommand.ReadStdOutput():
-                    lineList = line.split(' ')
-                    layers[int(lineList[0])] = { "table"    : lineList[1],
-                                                 "key"      : lineList[2],
-                                                 "database" : lineList[3],
-                                                 "driver"   : lineList[4] }
-                for layer in layers.keys():
-                    printCats = gcmd.Command(['v.category',
-                                              '--q',
-                                              'input=%s' % self.map,
-                                              'layer=%d' % layer,
-                                              'option=print',
-                                              'id=%s' % ids])
-                    sql = 'DELETE FROM %s WHERE' % layers[layer]['table']
-                    n_cats = 0
-                    for cat in printCats.ReadStdOutput():
-                        for c in cat.split('/'):
-                            sql += ' cat = %d or' % int(c)
-                            n_cats += 1
-                    sql = sql.rstrip(' or')
-                    if n_cats > 0:
-                        gcmd.Command(['db.execute',
-                                      '--q',
-                                      'driver=%s' % layers[layer]['driver'],
-                                      'database=%s' % layers[layer]['database']],
-                                     stdin=sql,
-        command = [ "v.edit",
-                    "map=%s" % self.map,
-                    "tool=delete",
-                    "ids=%s" % ids]
-        # run the command
-        vedit = gcmd.Command(cmd=command, stderr=None)
-        return True
-    def MoveSelectedLines(self, move):
-        """Move selected features
-        @param move X,Y direction
-        return self.__MoveFeature("move", None, move)
-    def MoveSelectedVertex(self, coords, move):
-        """Move selected vertex
-        Feature geometry is changed.
-        @param coords click coordinates
-        return self.__MoveFeature("vertexmove", coords, move)
-    def __MoveFeature(self, tool, coords, move):
-        """Move selected vector feature (line, vertex)
-        @param tool   tool for v.edit
-        @param move   direction (x, y)
-            return False
-        Debug.msg(4, "Digit.MoveSelectedLines(): ids=%s, move=%s" % \
-                      (ids, move))
-            snap = "no"
-        else:
-                snap = "vertex"
-            else:
-                snap = "node"
-        command = ["v.edit", "--q",
-                   "tool=%s" % tool,
-                   "ids=%s" % ids,
-                   "move=%f,%f" % (float(move[0]),float(move[1])),
-                   "snap=%s" % snap]
-        if tool == "vertexmove":
-            command.append("coords=%f,%f" % (float(coords[0]), float(coords[1])))
-            command.append("-1") # modify only first selected
-        # run the command
-        return True
-    def AddVertex(self, coords):
-        """Add new vertex to the selected line/boundary on position 'coords'
-        @param coords coordinates to add vertex
-        return self.__ModifyVertex(coords, "vertexadd")
-    def RemoveVertex(self, coords):
-        """Remove vertex from the selected line/boundary on position 'coords'
-        @param coords coordinates to remove vertex
-        return self.__ModifyVertex(coords, "vertexdel")
-    def __ModifyVertex(self, coords, action):
-        """Generic method for vertex manipulation
-        @param action operation to perform
-        try:
-            line = self.driver.GetSelected()[0]
-        except:
-            return False
-                   "tool=%s" % action,
-                   "ids=%s" % line,
-                   "coords=%f,%f" % (float(coords[0]),float(coords[1])),
-                   "thresh=%f,%f" % (self.driver.GetThreshold(type='selectThresh'), self.driver.GetThreshold(type='snapping'))]
-        # run the command
-        return True
-    def SplitLine(self, coords):
-        """Split selected line/boundary on position 'coords'
-        @param coords coordinates to split line
-        try:
-        except:
-            return False
-                   "tool=break",
-                   "ids=%s" % line,
-                   "thresh=%f" % self.driver.GetThreshold(type='selectThresh')]
-        # run the command
-        # redraw map
-        return True
-    def EditLine(self, line, coords):
-        """Edit existing line/boundary
-        @param line id of line to be modified
-        @param coords list of coordinates of modified line
-        # remove line
-        vEditDelete = gcmd.Command(['v.edit',
-                                   '--q',
-                                   'map=%s' % self.map,
-                                   'tool=delete',
-                                   'ids=%s' % line], stderr=None)
-        # add line
-        if len(coords) > 0:
-            self.AddLine(self.map, "line", coords)
-    def __ModifyLines(self, tool):
-        """Generic method to modify selected lines/boundaries
-        @param tool operation to be performed by v.edit
-        ids = self.driver.GetSelected()
-        if len(ids) <= 0:
-            return False
-        vEdit = ['v.edit',
-                 '--q',
-                 'tool=%s' % tool,
-                 'ids=%s' % ",".join(["%d" % v for v in ids])]
-        if tool in ['snap', 'connect']:
-            vEdit.append("thresh=%f,%f" % (self.driver.GetThreshold(type='selectThresh'), self.driver.GetThreshold(type='snapping')))
-        runCmd = gcmd.Command(vEdit)
-        return True
-    def FlipLine(self):
-        """Flip selected lines/boundaries"""
-        return self.__ModifyLines('flip')
-    def MergeLine(self):
-        """Merge selected lines/boundaries"""
-        return self.__ModifyLines('merge')
-    def BreakLine(self):
-        """Break selected lines/boundaries"""
-        return self.__ModifyLines('break')
-    def SnapLine(self):
-        """Snap selected lines/boundaries"""
-        return self.__ModifyLines('snap')
-    def ConnectLine(self):
-        """Connect selected lines/boundaries"""
-        return self.__ModifyLines('connect')
-    def TypeConvForSelectedLines(self):
-        """Feature type conversion for selected objects.
-        Supported conversions:
-         - point <-> centroid
-         - line <-> boundary
-        return self.__ModifyLines('chtype')
-    def ZBulkLine(self, pos1, pos2, value, step):
-        """Provide z bulk-labeling (automated assigment of z coordinate
-        to 3d lines
-        @param pos1,pos2 bounding box definition for selecting lines to be labeled
-        @param value starting value
-        @param step  step value
-        gcmd.Command(['v.edit',
-                      '--q',
-                      'tool=zbulk',
-                      'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1]),
-                      'zbulk=%f,%f' % (value, step)])
-    def CopyLine(self, ids=None):
-        """Copy features from (background) vector map
-        @param ids list of line ids to be copied
-        if not ids:
-        if len(ids) <= 0:
-            return False
-                 '--q',
-                 'tool=copy',
-            vEdit.append('bgmap=%s' % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'))
-        return True
-    def CopyCats(self, cats, ids):
-        """Copy given categories to objects with id listed in ids
-        @param cats list of cats to be copied
-        @param ids  ids of lines to be modified
-        if len(cats) == 0 or len(ids) == 0:
-            return False
-        # collect cats
-                     '--q',
-                     'tool=catadd',
-                     'cats=%s' % ",".join(["%d" % v for v in cats]),
-                     'ids=%s' % ",".join(["%d" % v for v in ids])])
-        return True
-    def SelectLinesByQuery(self, pos1, pos2):
-        """Select features by query
-        @param pos1, pos2 bounding box definition
-        thresh = self.SelectLinesByQueryThresh()
-        w, n = pos1
-        e, s = pos2
-        if UserSettings.Get(group='vdigit', key='query', subkey='box') == False: # select globaly
-            vInfo = gcmd.Command(['v.info',
-                                  '-g'])
-            for item in vInfo.ReadStdOutput():
-                if 'north' in item:
-                    n = float(item.split('=')[1])
-                elif 'south' in item:
-                    s = float(item.split('=')[1])
-                elif 'east' in item:
-                    e = float(item.split('=')[1])
-                elif 'west' in item:
-                    w = float(item.split('=')[1])
-        vEdit = (['v.edit',
-                  '--q',
-                  'tool=select',
-                  'bbox=%f,%f,%f,%f' % (w, n, e, s),
-                  'query=%s' % UserSettings.Get(group='vdigit', key='query', subkey='type'),
-                  'thresh=0,0,%f' % thresh])
-        vEditCmd = gcmd.Command(vEdit)
-        try:
-        except:
-            return []
-        Debug.msg(4, "VEdit.SelectLinesByQuery(): %s" % \
-        return ids
-    def GetLayers(self):
-        """Return list of layers"""
-                                         "-g", "--q",
-            layers = []
-                layers.append(int(lineList[0]))
-            return layers
-        return [1,]
-    def Undo(self, level=-1):
-        """Undo not implemented here"""
-        wx.MessageBox(parent=self.mapWindow, message=_("Undondo is not implemented in vedit component. "
-                                                    "Use vdigit instead."),
-                      caption=_("Message"), style=wx.ID_OK | wx.ICON_INFORMATION | wx.CENTRE)
-class VDigit(AbstractDigit):
-    Prototype of digitization class based on v.digit reimplementation
-    Under development (wxWidgets C/C++ background)
-        """Initialization
-        try:
-            self.digit = vdigit.Digit(self.driver.GetDevice())
-        except (ImportError, NameError):
-            self.digit = None
-        self.toolbar = mapwindow.parent.digittoolbar
-    def __del__(self):
-        del self.digit
-        """Add new point/centroid
-        @param map   map name (unused, for compatability with VEdit)
-        @param point feature type (if true point otherwise centroid)
-        if point:
-            type = vdigit.GV_POINT
-        else:
-            type = vdigit.GV_CENTROID
-        snap, thresh = self.__getSnapThreshold()
-        if z:
-            ret = self.digit.AddLine(type, [x, y, z], layer, cat,
-                                     str(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value')), snap, thresh)
-        else:
-            ret = self.digit.AddLine(type, [x, y], layer, cat,
-        if ret == -1:
-            raise gcmd.DigitError, _("Adding new feature to vector map <%s> failed.") % map
-        self.toolbar.EnableUndo()
-        @param line   feature type (if True line, otherwise boundary)
-            return
-        if line:
-            type = vdigit.GV_LINE
-        else:
-            type = vdigit.GV_BOUNDARY
-        listCoords = []
-        for c in coords:
-            for x in c:
-                listCoords.append(x)
-        ret = self.digit.AddLine(type, listCoords, layer, cat,
-        if ret == -1:
-        @return number of deleted lines
-        nlines = self.digit.DeleteLines(UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled'))
-        if nlines > 0:
-        return nlines
-        nlines = self.digit.MoveLines(move[0], move[1], 0.0, # TODO 3D
-        if nlines > 0:
-        return nlines
-        """Move selected vertex of the line
-        @return 1 vertex moved
-        @return 0 vertex not moved (not found, line is not selected)
-        moved = self.digit.MoveVertex(coords[0], coords[1], 0.0, # TODO 3D
-                                      move[0], move[1], 0.0,
-                                      self.driver.GetThreshold(type='selectThresh'), thresh)
-        if moved:
-        return moved
-        @return 1 vertex added
-        @return 0 nothing changed
-        @return -1 on failure
-        added = self.digit.ModifyLineVertex(1, coords[0], coords[1], 0.0, # TODO 3D
-                                            self.driver.GetThreshold(type='selectThresh'))
-        if added > 0:
-        return added
-        @return 1 vertex removed
-        deleted = self.digit.ModifyLineVertex(0, coords[0], coords[1], 0.0, # TODO 3D
-        if deleted > 0:
-        return deleted
-        @return 1 line modified
-        @return -1 error
-        ret = self.digit.SplitLine(coords[0], coords[1], 0.0, # TODO 3D
-                                   self.driver.GetThreshold('selectThresh'))
-        if ret > 0:
-        return ret
-        @return feature id of new line
-        @return -1 on error
-        try:
-            lineid = line[0]
-        except:
-            lineid = -1
-        listCoords = []
-        for c in coords:
-            for x in c:
-        ret = self.digit.RewriteLine(lineid, listCoords,
-        if ret > 0:
-        return ret
-        @return number of modified lines
-        ret = self.digit.FlipLines()
-        if ret > 0:
-        return ret
-        ret = self.digit.MergeLines()
-        if ret > 0:
-        return ret
-        ret = self.digit.BreakLines()
-        if ret > 0:
-        return ret
-        @return on success
-        ret = self.digit.SnapLines(thresh)
-        if ret == 0:
-        return ret
-        @return 1 lines connected
-        @return 0 lines not connected
-        ret = self.digit.ConnectLines(thresh)
-        if ret > 0:
-        return ret
-        @return number of copied features
-        ret = self.digit.CopyLines(ids, str(UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value')))
-        if ret > 0:
-        return ret
-        @return number of modified features
-            return 0
-        ret = self.digit.CopyCats(cats, ids)
-        if ret > 0:
-        return ret
-        w, n = pos1
-        e, s = pos2
-        query = vdigit.QUERY_UNKNOWN
-        if UserSettings.Get(group='vdigit', key='query', subkey='type') == 'length':
-            query = vdigit.QUERY_LENGTH
-        elif UserSettings.Get(group='vdigit', key='query', subkey='type') == 'dangle':
-            query = vdigit.QUERY_DANGLE
-        type = vdigit.GV_POINTS | vdigit.GV_LINES # TODO: 3D
-        ids = self.digit.SelectLinesByQuery(w, n, 0.0, e, s, 1000.0,
-                                            UserSettings.Get(group='vdigit', key='query', subkey='box'),
-                                            query, type, thresh)
-        Debug.msg(4, "VDigit.SelectLinesByQuery(): %s" % \
-        return ids
-    def GetLineCats(self, line=-1):
-        """Get layer/category pairs from given (selected) line
-        @param line feature id (-1 for first selected line)
-        return self.digit.GetLineCats(line)
-    def SetLineCats(self, line, layer, cats, add=True):
-        """Set categories for given line and layer
-        @param layer layer number (-1 for first selected line)
-        @param cats list of categories
-        @param add if True to add, otherwise do delete categories
-        @return new feature id (feature need to be rewritten)
-        ret = self.digit.SetLineCats(line, layer, cats, add)
-        if ret > 0:
-        return ret
-        """Get list of layers"""
-        return self.digit.GetLayers()
-        ret = self.digit.TypeConvLines()
-        if ret > 0:
-        return ret
-        """Undo action
-        @param level levels to undo (0 to revert all)
-        @return id of current changeset
-        try:
-            ret = self.digit.Undo(level)
-        except SystemExit:
-            ret = -2
-        if ret == -2:
-            raise gcmd.DigitError, _("Undo failed, data corrupted.")
-        self.mapWindow.UpdateMap(render=False)
-        if ret < 0: # disable undo tool
-            self.toolbar.EnableUndo(False)
-    def __getSnapThreshold(self):
-        """Get snap mode and threshold value
-        @return (snap, thresh)
-        thresh = self.driver.GetThreshold()
-        if thresh > 0.0:
-                snap = vdigit.SNAPVERTEX
-            else:
-        else:
-            snap = v.digit.NO_SNAP
-        return (snap, thresh)
-if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit':
-    class Digit(VEdit):
-        """Default digit class"""
-            VEdit.__init__(self, mapwindow)
-            self.type = 'vedit'
-else:
-    class Digit(VDigit):
-            VDigit.__init__(self, mapwindow)
-            self.type = 'vdigit'
-            VDigit.__del__(self)
-class AbstractDisplayDriver:
-    """Abstract classs for display driver"""
-    def __init__(self, parent, mapwindow):
-        """Initialization
-        @param parent
-        @param mapwindow reference to mapwindow (MFrame)
-        self.parent      = parent
-        self.mapwindow   = mapwindow
-        self.ids         = {}   # dict[g6id] = [pdcId]
-        self.selected    = []   # list of selected objects (grassId!)
-    def GetThreshold(self, type='snapping', value=None, units=None):
-        """Return threshold in map units
-        @param value threshold to be set up
-        @param units units (map, screen)
-        if not value:
-            value = UserSettings.Get(group='vdigit', key=type, subkey='value')
-        if not units:
-            units = UserSettings.Get(group='vdigit', key=type, subkey='units')
-        if units == "screen pixels":
-            # pixel -> cell
-            reg = self.mapwindow.Map.region
-            if reg['nsres'] > reg['ewres']:
-                res = reg['nsres']
-            else:
-                res = reg['ewres']
-            threshold = value * res
-        else:
-            threshold = value
-        Debug.msg(4, "AbstractDisplayDriver.GetThreshold(): type=%s, thresh=%f" % (type, threshold))
-        return threshold
-class CDisplayDriver(AbstractDisplayDriver):
-    Display driver using grass6_wxdriver module
-        """Initialization
-        @param parent
-        AbstractDisplayDriver.__init__(self, parent, mapwindow)
-        # initialize wx display driver
-        try:
-            self.__display = vdigit.DisplayDriver(mapwindow.pdcVector)
-        except:
-            self.__display = None
-        self.UpdateSettings()
-    def GetDevice(self):
-        """Get device"""
-        return self.__display
-    def SetDevice(self, pdc):
-        """Set device for driver
-        @param pdc wx.PseudoDC instance
-        self.__display.SetDevice(pdc)
-    def Reset(self, map):
-        """Reset map
-        Open or close the vector map by driver.
-        @param map map name or None to close the map
-        @return 0 on success (close map)
-        @return topo level on success (open map)
-        @return non-zero (close map)
-        @return -1 on error (open map)
-        if map:
-            name, mapset = map.split('@')
-            try:
-                    ret = self.__display.OpenMap(str(name), str(mapset), False)
-                else:
-                    ret = self.__display.OpenMap(str(name), str(mapset), True)
-                ret = -1
-        else:
-            ret = self.__display.CloseMap()
-        return ret
-    def ReloadMap(self):
-        """Reload map (close and re-open).
-        Needed for v.edit, TODO: get rid of that..."""
-        Debug.msg(4, "CDisplayDriver.ReloadMap():")
-        self.__display.ReloadMap()
-    def DrawMap(self):
-        """Draw vector map layer content
-        @return wx.Image instance
-        nlines = self.__display.DrawMap(True) # force
-        Debug.msg(3, "CDisplayDriver.DrawMap(): nlines=%d" % nlines)
-        return nlines
-    def SelectLinesByBox(self, begin, end, type=0):
-        """Select vector features by given bounding box.
-        If type is given, only vector features of given type are selected.
-        @param begin,end bounding box definition
-        @param type      select only objects of given type
-        x1, y1 = begin
-        x2, y2 = end
-        nselected = self.__display.SelectLinesByBox(x1, y1, -1.0 * vdigit.PORT_DOUBLE_MAX,
-                                                    x2, y2, vdigit.PORT_DOUBLE_MAX,
-                                                    type)
-        Debug.msg(4, "CDisplayDriver.SelectLinesByBox(): selected=%d" % \
-                      nselected)
-        return nselected
-    def SelectLineByPoint(self, point, type=0):
-        """Select vector feature by coordinates of click point (in given threshold).
-        @param point click coordinates (bounding box given by threshold)
-        pointOnLine = self.__display.SelectLineByPoint(point[0], point[1], 0.0,
-                                                       self.GetThreshold(type='selectThresh'),
-                                                       type, 0); # without_z
-        if len(pointOnLine) > 0:
-            Debug.msg(4, "CDisplayDriver.SelectLineByPoint(): pointOnLine=%f,%f" % \
-                          (pointOnLine[0], pointOnLine[1]))
-            return pointOnLine
-        else:
-            Debug.msg(4, "CDisplayDriver.SelectLineByPoint(): no line found")
-            return None
-    def GetSelected(self, grassId=True):
-        """Return ids of selected vector features
-        @param grassId if grassId is True returns GRASS ids, otherwise
-        internal ids of objects drawn in PseudoDC"""
-        if grassId:
-            selected = self.__display.GetSelected(True)
-        else:
-            selected = self.__display.GetSelected(False)
-        Debug.msg(4, "CDisplayDriver.GetSelected(): grassId=%d, ids=%s" % \
-                      (grassId, (",".join(["%d" % v for v in selected]))))
-        return selected
-    def GetSelectedVertex(self, coords):
-        """Get PseudoDC id(s) of vertex (of selected line)
-        on position 'coords'
-        @param coords click position
-        x, y = coords
-        id = self.__display.GetSelectedVertex(x, y, self.GetThreshold(type='selectThresh'))
-        Debug.msg(4, "CDisplayDriver.GetSelectedVertex(): id=%s" % \
-                      (",".join(["%d" % v for v in id])))
-        return id
-    def SetSelected(self, id):
-        """Set selected vector features
-        @param id line id to be selected
-        Debug.msg(4, "CDisplayDriver.SetSelected(): id=%s" % \
-                  ",".join(["%d" % v for v in id]))
-        self.__display.SetSelected(id)
-    def UpdateRegion(self):
-        """Set geographical region
-        Needed for 'cell2pixel' conversion"""
-        map = self.mapwindow.Map
-        reg = map.region
-        self.__display.SetRegion(reg['n'],
-                                 reg['s'],
-                                 reg['e'],
-                                 reg['w'],
-                                 reg['nsres'],
-                                 reg['ewres'],
-                                 reg['center_easting'],
-                                 reg['center_northing'],
-                                 map.width, map.height)
-    def GetMapBoundingBox(self):
-        """Return bounding box of given vector map layer
-        @return (w,s,b,e,n,t)
-        return self.__display.GetMapBoundingBox()
-    def UpdateSettings(self):
-        """Update display driver settings"""
-        # TODO map units
-        if not self.__display:
-            return
-        self.__display.UpdateSettings (wx.Color(UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolPoint', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolLine', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[2],
-                                           255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolVertex', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='lineWidth', subkey='value'))
-class DigitSettingsDialog(wx.Dialog):
-    Standard settings dialog for digitization purposes
-    def __init__(self, parent, title, style=wx.DEFAULT_DIALOG_STYLE):
-        wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=title, style=style)
-        self.parent = parent # mapdisplay.BufferedWindow class instance
-        # notebook
-        notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
-        self.__CreateSymbologyPage(notebook)
-        parent.digit.SetCategory() # update category number (next to use)
-        self.__CreateGeneralPage(notebook)
-        self.__CreateAttributesPage(notebook)
-        self.__CreateQueryPage(notebook)
-        # buttons
-        btnApply = wx.Button(self, wx.ID_APPLY)
-        btnCancel = wx.Button(self, wx.ID_CANCEL)
-        btnSave = wx.Button(self, wx.ID_SAVE)
-        btnSave.SetDefault()
-        # bindigs
-        btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
-        btnApply.SetToolTipString(_("Apply changes for this session"))
-        btnApply.SetDefault()
-        btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
-        btnSave.SetToolTipString(_("Close dialog and save changes to user settings file"))
-        btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
-        btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
-        # sizers
-        btnSizer = wx.StdDialogButtonSizer()
-        btnSizer.AddButton(btnCancel)
-        btnSizer.AddButton(btnApply)
-        btnSizer.AddButton(btnSave)
-        btnSizer.Realize()
-        mainSizer = wx.BoxSizer(wx.VERTICAL)
-        mainSizer.Add(item=notebook, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
-        mainSizer.Add(item=btnSizer, proportion=0,
-                      flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
-        self.SetSizer(mainSizer)
-        mainSizer.Fit(self)
-    def __CreateSymbologyPage(self, notebook):
-        """Create notebook page concerning with symbology settings"""
-        panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
-        notebook.AddPage(page=panel, text=_("Symbology"))
-        sizer = wx.BoxSizer(wx.VERTICAL)
-        flexSizer = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
-        flexSizer.AddGrowableCol(0)
-        self.symbology = {}
-        for label, key in self.__SymbologyData():
-            textLabel = wx.StaticText(panel, wx.ID_ANY, label)
-            color = csel.ColourSelect(panel, id=wx.ID_ANY,
-                                      colour=UserSettings.Get(group='vdigit', key=key, subkey='color'), size=(25, 25))
-            isEnabled = UserSettings.Get(group='vdigit', key=key, subkey='enabled')
-            if isEnabled is not None:
-                enabled = wx.CheckBox(panel, id=wx.ID_ANY, label="")
-                enabled.SetValue(isEnabled)
-                self.symbology[key] = (enabled, color)
-            else:
-                enabled = (1, 1)
-                self.symbology[key] = (None, color)
-            flexSizer.Add(textLabel, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
-            flexSizer.Add(enabled, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-            flexSizer.Add(color, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
-        sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=10)
-        panel.SetSizer(sizer)
-        return panel
-    def __CreateGeneralPage(self, notebook):
-        notebook.AddPage(page=panel, text=_("General"))
-        border = wx.BoxSizer(wx.VERTICAL)
-        # display section
-        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Display"))
-        sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
-        # line width
-        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Line width"))
-        self.lineWidthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
-                                          initial=UserSettings.Get(group='vdigit', key="lineWidth", subkey='value'),
-                                          min=1, max=1e6)
-        units = wx.StaticText(parent=panel, id=wx.ID_ANY, size=(115, -1),
-                              label=UserSettings.Get(group='vdigit', key="lineWidth", subkey='units'),
-                              style=wx.ALIGN_LEFT)
-        flexSizer.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
-        flexSizer.Add(self.lineWidthValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-        flexSizer.Add(units, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL | wx.LEFT,
-                      border=10)
-        sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=1)
-        border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
-        # snapping section
-        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Snapping"))
-        flexSizer1 = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
-        flexSizer1.AddGrowableCol(0)
-        flexSizer2 = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
-        flexSizer2.AddGrowableCol(0)
-        # snapping
-        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Snapping threshold"))
-        self.snappingValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
-                                         initial=UserSettings.Get(group='vdigit', key="snapping", subkey='value'),
-                                         min=1, max=1e6)
-        self.snappingValue.Bind(wx.EVT_SPINCTRL, self.OnChangeSnappingValue)
-        self.snappingUnit = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
-                                      choices=["screen pixels", "map units"])
-        self.snappingUnit.SetStringSelection(UserSettings.Get(group='vdigit', key="snapping", subkey='units'))
-        self.snappingUnit.Bind(wx.EVT_CHOICE, self.OnChangeSnappingUnits)
-        flexSizer1.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
-        flexSizer1.Add(self.snappingValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-        flexSizer1.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
-        # background map
-        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Backgroud vector map"))
-        self.backgroundMap = gselect.Select(parent=panel, id=wx.ID_ANY, size=(200,-1),
-                                           type="vector")
-        self.backgroundMap.SetValue(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value'))
-        self.backgroundMap.Bind(wx.EVT_TEXT, self.OnChangeBackgroundMap)
-        flexSizer2.Add(text, proportion=1, flag=wx.ALIGN_CENTER_VERTICAL)
-        flexSizer2.Add(self.backgroundMap, proportion=1, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-        #flexSizer.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
-        vertexSizer = wx.BoxSizer(wx.VERTICAL)
-        self.snapVertex = wx.CheckBox(parent=panel, id=wx.ID_ANY,
-                                      label=_("Snap also to vertex"))
-        self.snapVertex.SetValue(UserSettings.Get(group='vdigit', key="snapToVertex", subkey='enabled'))
-        vertexSizer.Add(item=self.snapVertex, proportion=0, flag=wx.EXPAND)
-        self.mapUnits = self.parent.MapWindow.Map.ProjInfo()['units']
-        self.snappingInfo = wx.StaticText(parent=panel, id=wx.ID_ANY,
-                                          label=_("Snapping threshold is %(value).1f %(units)s") % \
-                                              {'value' : self.parent.digit.driver.GetThreshold(),
-                                               'units' : self.mapUnits})
-        vertexSizer.Add(item=self.snappingInfo, proportion=0,
-                        flag=wx.ALL | wx.EXPAND, border=1)
-        sizer.Add(item=flexSizer1, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
-        sizer.Add(item=flexSizer2, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
-        sizer.Add(item=vertexSizer, proportion=1, flag=wx.BOTTOM | wx.LEFT | wx.EXPAND, border=1)
-        border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
-        # select box
-        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Select vector features"))
-        # feature type
-        inSizer = wx.BoxSizer(wx.HORIZONTAL)
-        self.selectFeature = {}
-        for feature in ('Point', 'Line',
-                        'Centroid', 'Boundary'):
-            chkbox = wx.CheckBox(parent=panel, label=feature)
-            self.selectFeature[feature] = chkbox.GetId()
-            chkbox.SetValue(UserSettings.Get(group='vdigit', key='selectFeature'+feature, subkey='enabled'))
-            inSizer.Add(item=chkbox, proportion=0,
-                        flag=wx.EXPAND | wx.ALL, border=5)
-        sizer.Add(item=inSizer, proportion=0, flag=wx.EXPAND)
-        # threshold
-        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select threshold"))
-        self.selectThreshValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
-                                             initial=UserSettings.Get(group='vdigit', key="selectThresh", subkey='value'),
-                                             min=1, max=1e6)
-        flexSizer.Add(self.selectThreshValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-                      border=10)
-        sizer.Add(item=flexSizer, proportion=0, flag=wx.EXPAND)
-        border.Add(item=sizer, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
-        # save-on-exit box
-        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Save changes"))
-        # save changes on exit?
-        self.save = wx.CheckBox(parent=panel, label=_("Save changes on exit automatically"))
-        self.save.SetValue(UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled'))
-        sizer.Add(item=self.save, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
-        panel.SetSizer(border)
-        return panel
-    def __CreateQueryPage(self, notebook):
-        """Create notebook page for query tool"""
-        notebook.AddPage(page=panel, text=_("Query tool"))
-        # query tool box
-        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Choose query tool"))
-        LocUnits = self.parent.MapWindow.Map.ProjInfo()['units']
-        self.queryBox = wx.CheckBox(parent=panel, id=wx.ID_ANY, label=_("Select by box"))
-        self.queryBox.SetValue(UserSettings.Get(group='vdigit', key="query", subkey='box'))
-        sizer.Add(item=self.queryBox, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
-        sizer.Add((0, 5))
-        # length
-        self.queryLength = wx.RadioButton(parent=panel, id=wx.ID_ANY, label=_("length"))
-        self.queryLength.Bind(wx.EVT_RADIOBUTTON, self.OnChangeQuery)
-        sizer.Add(item=self.queryLength, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
-        flexSizer = wx.FlexGridSizer (cols=4, hgap=5, vgap=5)
-        txt = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select lines"))
-        self.queryLengthSL = wx.Choice (parent=panel, id=wx.ID_ANY,
-                                        choices = [_("shorter than"), _("longer than")])
-        self.queryLengthSL.SetStringSelection(UserSettings.Get(group='vdigit', key="queryLength", subkey='than'))
-        self.queryLengthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
-                                            initial=1,
-                                            min=0, max=1e6)
-        self.queryLengthValue.SetValue(UserSettings.Get(group='vdigit', key="queryLength", subkey='thresh'))
-        units = wx.StaticText(parent=panel, id=wx.ID_ANY, label="%s" % LocUnits)
-        flexSizer.Add(txt, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
-        flexSizer.Add(self.queryLengthSL, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-        flexSizer.Add(self.queryLengthValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-        flexSizer.Add(units, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
-        sizer.Add(item=flexSizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
-        # dangle
-        self.queryDangle = wx.RadioButton(parent=panel, id=wx.ID_ANY, label=_("dangle"))
-        self.queryDangle.Bind(wx.EVT_RADIOBUTTON, self.OnChangeQuery)
-        sizer.Add(item=self.queryDangle, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
-        txt = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select dangles"))
-        self.queryDangleSL = wx.Choice (parent=panel, id=wx.ID_ANY,
-        self.queryDangleSL.SetStringSelection(UserSettings.Get(group='vdigit', key="queryDangle", subkey='than'))
-        self.queryDangleValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
-                                       initial=1,
-                                       min=0, max=1e6)
-        self.queryDangleValue.SetValue(UserSettings.Get(group='vdigit', key="queryDangle", subkey='thresh'))
-        flexSizer.Add(self.queryDangleSL, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-        flexSizer.Add(self.queryDangleValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-        if UserSettings.Get(group='vdigit', key="query", subkey='type') == "length":
-            self.queryLength.SetValue(True)
-        else:
-            self.queryDangle.SetValue(True)
-        # enable & disable items
-        self.OnChangeQuery(None)
-        return panel
-    def __CreateAttributesPage(self, notebook):
-        notebook.AddPage(page=panel, text=_("Attributes"))
-        # add new record
-        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Digitize new feature"))
-        # checkbox
-        self.addRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
-                                     label=_("Add new record into table"))
-        self.addRecord.SetValue(UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled'))
-        sizer.Add(item=self.addRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
-        # settings
-        flexSizer = wx.FlexGridSizer(cols=2, hgap=3, vgap=3)
-        settings = ((_("Layer"), 1), (_("Category"), 1), (_("Mode"), _("Next to use")))
-        # layer
-        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Layer"))
-        if self.parent.digit.map:
-            layers = map(str, self.parent.digit.GetLayers())
-            if len(layers) == 0:
-                layers = [str(UserSettings.Get(group='vdigit', key="layer", subkey='value')), ]
-        else:
-        self.layer = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
-                               choices=layers)
-        self.layer.SetStringSelection(str(UserSettings.Get(group='vdigit', key="layer", subkey='value')))
-        flexSizer.Add(item=text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
-        flexSizer.Add(item=self.layer, proportion=0,
-                      flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
-        # category number
-        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category number"))
-        self.category = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
-                                    initial=UserSettings.Get(group='vdigit', key="category", subkey='value'),
-                                    min=-1e9, max=1e9)
-        if UserSettings.Get(group='vdigit', key="categoryMode", subkey='value') != "Manual entry":
-            self.category.Enable(False)
-        flexSizer.Add(item=self.category, proportion=0,
-        # category mode
-        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category mode"))
-        self.categoryMode = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
-                                      choices=[_("Next to use"), _("Manual entry"), _("No category")])
-        self.categoryMode.SetStringSelection(UserSettings.Get(group='vdigit', key="categoryMode", subkey='value'))
-        flexSizer.Add(item=self.categoryMode, proportion=0,
-                   flag=wx.ALL | wx.EXPAND, border=5)
-        # delete existing record
-        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Delete existing feature(s)"))
-        # checkbox
-        self.deleteRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
-                                        label=_("Delete record from table"))
-        self.deleteRecord.SetValue(UserSettings.Get(group='vdigit', key="delRecord", subkey='enabled'))
-        sizer.Add(item=self.deleteRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
-                   flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
-        # bindings
-        self.Bind(wx.EVT_CHECKBOX, self.OnChangeAddRecord, self.addRecord)
-        self.Bind(wx.EVT_CHOICE, self.OnChangeCategoryMode, self.categoryMode)
-        self.Bind(wx.EVT_CHOICE, self.OnChangeLayer, self.layer)
-        return panel
-    def __SymbologyData(self):
-        Data for __CreateSymbologyPage()
-        label | checkbox | color
-        return (
-            #            ("Background", "symbolBackground"),
-            ("Highlight", "symbolHighlight"),
-            ("Point", "symbolPoint"),
-            ("Line", "symbolLine"),
-            ("Boundary (no area)", "symbolBoundaryNo"),
-            ("Boundary (one area)", "symbolBoundaryOne"),
-            ("Boundary (two areas)", "symbolBoundaryTwo"),
-            ("Centroid (in area)", "symbolCentroidIn"),
-            ("Centroid (outside area)", "symbolCentroidOut"),
-            ("Centroid (duplicate in area)", "symbolCentroidDup"),
-            ("Node (one line)", "symbolNodeOne"),
-            ("Node (two lines)", "symbolNodeTwo"),
-            ("Vertex", "symbolVertex"))
-    def OnChangeCategoryMode(self, event):
-        """Change category mode"""
-        mode = event.GetString()
-        UserSettings.Set(group='vdigit', key="categoryMode", subkey='value', value=mode)
-        if mode == "Manual entry": # enable
-            self.category.Enable(True)
-        elif self.category.IsEnabled(): # disable
-        if mode == "No category" and self.addRecord.IsChecked():
-            self.addRecord.SetValue(False)
-        self.parent.digit.SetCategory()
-        self.category.SetValue(UserSettings.Get(group='vdigit', key='category', subkey='value'))
-    def OnChangeLayer(self, event):
-        """Layer changed"""
-        layer = int(event.GetString())
-        if layer > 0:
-            UserSettings.Set(group='vdigit', key='layer', subkey='value', value=layer)
-        event.Skip()
-    def OnChangeAddRecord(self, event):
-        """Checkbox 'Add new record' status changed"""
-        self.category.SetValue(self.parent.digit.SetCategory())
-    def OnChangeSnappingValue(self, event):
-        """Change snapping value - update static text"""
-        value = self.snappingValue.GetValue()
-        if self.snappingUnit.GetStringSelection() == "map units":
-            threshold = value
-        else:
-            threshold = self.parent.digit.driver.GetThreshold(value=value)
-        self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(units)s") %
-                                   {'value' : threshold,
-        event.Skip()
-    def OnChangeSnappingUnits(self, event):
-        """Snapping units change -> update static text"""
-        units = self.snappingUnit.GetStringSelection()
-        threshold = self.parent.digit.driver.GetThreshold(value=value, units=units)
-        if units == "map units":
-                                       {'value' : value,
-        else:
-        event.Skip()
-    def OnChangeBackgroundMap(self, event):
-        """Change background map"""
-        map = self.backgroundMap.GetValue()
-        UserSettings.Set(group='vdigit', key='backgroundMap', subkey='value', value=map)
-    def OnChangeQuery(self, event):
-        """Change query"""
-        if self.queryLength.GetValue():
-            # length
-            self.queryLengthSL.Enable(True)
-            self.queryLengthValue.Enable(True)
-            self.queryDangleSL.Enable(False)
-            self.queryDangleValue.Enable(False)
-        else:
-            # dangle
-            self.queryLengthSL.Enable(False)
-            self.queryLengthValue.Enable(False)
-            self.queryDangleSL.Enable(True)
-            self.queryDangleValue.Enable(True)
-    def OnSave(self, event):
-        """Button 'Save' clicked"""
-        self.parent.digittoolbar.settingsDialog = None
-        fileSettings = {}
-        UserSettings.ReadSettingsFile(settings=fileSettings)
-        fileSettings['vdigit'] = UserSettings.Get(group='vdigit')
-        file = UserSettings.SaveToFile(fileSettings)
-        self.parent.gismanager.goutput.WriteLog('Vector digitizer settings saved to file <%s>.' % file)
-        self.Close()
-    def OnApply(self, event):
-        """Button 'Apply' clicked"""
-    def OnCancel(self, event):
-        """Button 'Cancel' clicked"""
-        self.Close()
-        """Update UserSettings"""
-        # symbology
-        for key, (enabled, color) in self.symbology.iteritems():
-            if enabled:
-                UserSettings.Set(group='vdigit', key=key, subkey='enabled', value=enabled.IsChecked())
-                UserSettings.Set(group='vdigit', key=key, subkey='color', value=color.GetColour())
-            else:
-        # display
-        UserSettings.Set(group='vdigit', key="lineWidth", subkey='value', value=int(self.lineWidthValue.GetValue()))
-        # snapping
-        UserSettings.Set(group='vdigit', key="snapping", subkey='value', value=int(self.snappingValue.GetValue()))
-        UserSettings.Set(group='vdigit', key="snapping", subkey='units', value=self.snappingUnit.GetStringSelection())
-        UserSettings.Set(group='vdigit', key="snapToVertex", subkey='enabled', value=self.snapVertex.IsChecked())
-        # digitize new feature
-        UserSettings.Set(group='vdigit', key="addRecord", subkey='enabled', value=self.addRecord.IsChecked())
-        UserSettings.Set(group='vdigit', key="layer", subkey='value', value=int(self.layer.GetStringSelection()))
-            UserSettings.Set(group='vdigit', key="category", subkey='value', value=None)
-        else:
-            UserSettings.Set(group='vdigit', key="category", subkey='value', value=int(self.category.GetValue()))
-        UserSettings.Set(group='vdigit', key="categoryMode", subkey='value', value=self.categoryMode.GetStringSelection())
-        # delete existing feature
-        UserSettings.Set(group='vdigit', key="delRecord", subkey='enabled', value=self.deleteRecord.IsChecked())
-        # snapping threshold
-        self.parent.digit.threshold = self.parent.digit.driver.GetThreshold()
-        # query tool
-            UserSettings.Set(group='vdigit', key="query", subkey='type', value="length")
-        else:
-            UserSettings.Set(group='vdigit', key="query", subkey='type', value="dangle")
-        UserSettings.Set(group='vdigit', key="query", subkey='box', value=self.queryBox.IsChecked())
-        UserSettings.Set(group='vdigit', key="queryLength", subkey='than', value=self.queryLengthSL.GetStringSelection())
-        UserSettings.Set(group='vdigit', key="queryLength", subkey='thresh', value=int(self.queryLengthValue.GetValue()))
-        UserSettings.Set(group='vdigit', key="queryDangle", subkey='than', value=self.queryDangleSL.GetStringSelection())
-        UserSettings.Set(group='vdigit', key="queryDangle", subkey='thresh', value=int(self.queryDangleValue.GetValue()))
-        # select features
-            UserSettings.Set(group='vdigit', key='selectFeature'+feature, subkey='enabled',
-                                           value=self.FindWindowById(self.selectFeature[feature]).IsChecked())
-        UserSettings.Set(group='vdigit', key="selectThresh", subkey='value', value=int(self.selectThreshValue.GetValue()))
-        # on-exit
-        UserSettings.Set(group='vdigit', key="saveOnExit", subkey='enabled', value=self.save.IsChecked())
-        # update driver settings
-        self.parent.digit.driver.UpdateSettings()
-        # redraw map if auto-rendering is enabled
-        if self.parent.autoRender.GetValue():
-            self.parent.OnRender(None)
-class DigitCategoryDialog(wx.Dialog, listmix.ColumnSorterMixin):
-    Dialog used to display/modify categories of vector objects
-    @param parent
-    @param title dialog title
-    @param query {coordinates, qdist}    - v.edit/v.what
-    @param cats  directory of categories - vdigit
-    @param line  line id                 - vdigit
-    @param pos
-    @param style
-                 map, query=None, cats=None, line=None,
-                 pos=wx.DefaultPosition,
-                 style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
-        # parent
-        # map name
-        self.map = map
-        # line id (if not found remains 'None')
-        self.line = None
-        # {layer: [categories]}
-        self.cats = {}
-        # do not display dialog if no line is found (-> self.cats)
-        if cats is None:
-            if self.__GetCategories(query[0], query[1]) == 0 or not self.line:
-                Debug.msg(3, "DigitCategoryDialog(): nothing found!")
-                return
-        else:
-            # self.cats = dict(cats)
-            for layer in cats.keys():
-                self.cats[layer] = list(cats[layer]) # TODO: tuple to list
-            self.line = line
-        # make copy of cats (used for 'reload')
-        self.cats_orig = copy.deepcopy(self.cats)
-        Debug.msg(3, "DigitCategoryDialog(): line=%d, cats=%s" % \
-                      (self.line, self.cats))
-        wx.Dialog.__init__(self, parent=self.parent, id=wx.ID_ANY, title=title,
-                           style=style, pos=pos)
-        # list of categories
-        box = wx.StaticBox(parent=self, id=wx.ID_ANY,
-                           label=" %s " % _("List of categories"))
-        listSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
-        self.list = CategoryListCtrl(parent=self, id=wx.ID_ANY,
-                                     style=wx.LC_REPORT |
-                                     wx.BORDER_NONE |
-                                     wx.LC_SORT_ASCENDING |
-                                     wx.LC_HRULES |
-                                     wx.LC_VRULES)
-        # sorter
-        self.itemDataMap = self.list.Populate()
-        listmix.ColumnSorterMixin.__init__(self, 2)
-        listSizer.Add(item=self.list, proportion=1, flag=wx.EXPAND)
-        # add new category
-                           label=" %s " % _("Add new category"))
-        addSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
-        flexSizer = wx.FlexGridSizer (cols=5, hgap=5, vgap=5)
-        flexSizer.AddGrowableCol(3)
-        layerNewTxt = wx.StaticText(parent=self, id=wx.ID_ANY,
-                                 label="%s:" % _("Layer"))
-        self.layerNew = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(50, -1),
-                                    initial=1, min=1, max=1e9)
-        catNewTxt = wx.StaticText(parent=self, id=wx.ID_ANY,
-                               label="%s:" % _("Category"))
-        try:
-            newCat = max(self.cats[1]) + 1
-        except:
-            newCat = 1
-        self.catNew = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(75, -1),
-                                  initial=newCat, min=-1e9, max=1e9)
-        btnAddCat = wx.Button(self, wx.ID_ADD)
-        flexSizer.Add(item=layerNewTxt, proportion=0,
-        flexSizer.Add(item=self.layerNew, proportion=0,
-        flexSizer.Add(item=catNewTxt, proportion=0,
-                      flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT,
-                      border=10)
-        flexSizer.Add(item=self.catNew, proportion=0,
-        flexSizer.Add(item=btnAddCat, proportion=0,
-                      flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
-        addSizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
-        # buttons
-        #btnReload = wx.Button(self, wx.ID_UNDO, _("&Reload"))
-        btnOk = wx.Button(self, wx.ID_OK)
-        btnOk.SetDefault()
-        # sizers
-        #btnSizer.AddButton(btnReload)
-        #btnSizer.SetNegativeButton(btnReload)
-        btnSizer.AddButton(btnOk)
-        mainSizer.Add(item=listSizer, proportion=1,
-        mainSizer.Add(item=addSizer, proportion=0,
-                      flag=wx.EXPAND | wx.ALIGN_CENTER |
-                      wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
-        self.SetAutoLayout(True)
-        # set min size for dialog
-        self.SetMinSize(self.GetBestSize())
-        # bindings
-        # buttons
-        #btnReload.Bind(wx.EVT_BUTTON, self.OnReload)
-        btnOk.Bind(wx.EVT_BUTTON, self.OnOK)
-        btnAddCat.Bind(wx.EVT_BUTTON, self.OnAddCat)
-        # list
-        # self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected, self.list)
-        # self.list.Bind(wx.EVT_RIGHT_DOWN, self.OnRightDown)
-        self.list.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnRightUp) #wxMSW
-        self.list.Bind(wx.EVT_RIGHT_UP, self.OnRightUp) #wxGTK
-        self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnBeginEdit, self.list)
-        self.Bind(wx.EVT_LIST_END_LABEL_EDIT, self.OnEndEdit, self.list)
-        self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColClick, self.list)
-    def GetListCtrl(self):
-        """Used by ColumnSorterMixin"""
-        return self.list
-    def OnColClick(self, event):
-        """Click on column header (order by)"""
-        event.Skip()
-    def OnBeginEdit(self, event):
-        """Editing of item started"""
-        event.Allow()
-    def OnEndEdit(self, event):
-        """Finish editing of item"""
-        itemIndex = event.GetIndex()
-        layerOld = int (self.list.GetItem(itemIndex, 0).GetText())
-        catOld = int (self.list.GetItem(itemIndex, 1).GetText())
-        if event.GetColumn() == 0:
-            layerNew = int(event.GetLabel())
-            catNew = catOld
-        else:
-            layerNew = layerOld
-            catNew = int(event.GetLabel())
-        try:
-            if layerNew not in self.cats.keys():
-                self.cats[layerNew] = []
-            self.cats[layerNew].append(catNew)
-            self.cats[layerOld].remove(catOld)
-        except:
-            event.Veto()
-            self.list.SetStringItem(itemIndex, 0, str(layerNew))
-            self.list.SetStringItem(itemIndex, 1, str(catNew))
-            dlg = wx.MessageDialog(self, _("Unable to add new layer/category <%(layer)s/%(category)s>.\n"
-                                           "Layer and category number must be integer.\n"
-                                           "Layer number must be greater then zero.") %
-                                   { 'layer': str(self.layerNew.GetValue()),
-                                     'category' : str(self.catNew.GetValue()) },
-                                   _("Error"), wx.OK | wx.ICON_ERROR)
-            dlg.ShowModal()
-            dlg.Destroy()
-            return False
-    def OnRightDown(self, event):
-        """Mouse right button down"""
-        x = event.GetX()
-        y = event.GetY()
-        item, flags = self.list.HitTest((x, y))
-        if item !=  wx.NOT_FOUND and \
-                flags & wx.LIST_HITTEST_ONITEM:
-            self.list.Select(item)
-        event.Skip()
-    def OnRightUp(self, event):
-        """Mouse right button up"""
-        if not hasattr(self, "popupID1"):
-            self.popupID1 = wx.NewId()
-            self.popupID2 = wx.NewId()
-            self.popupID3 = wx.NewId()
-            self.Bind(wx.EVT_MENU, self.OnItemDelete,    id=self.popupID1)
-            self.Bind(wx.EVT_MENU, self.OnItemDeleteAll, id=self.popupID2)
-            self.Bind(wx.EVT_MENU, self.OnReload, id=self.popupID3)
-        # generate popup-menu
-        menu = wx.Menu()
-        menu.Append(self.popupID1, _("Delete selected"))
-        if self.list.GetFirstSelected() == -1:
-            menu.Enable(self.popupID1, False)
-        menu.Append(self.popupID2, _("Delete all"))
-        menu.AppendSeparator()
-        menu.Append(self.popupID3, _("Reload"))
-        self.PopupMenu(menu)
-        menu.Destroy()
-    def OnItemSelected(self, event):
-        """Item selected"""
-        event.Skip()
-    def OnItemDelete(self, event):
-        """Delete selected item(s) from the list (layer/category pair)"""
-        item = self.list.GetFirstSelected()
-        while item != -1:
-            layer = int (self.list.GetItem(item, 0).GetText())
-            cat = int (self.list.GetItem(item, 1).GetText())
-            self.list.DeleteItem(item)
-            self.cats[layer].remove(cat)
-        event.Skip()
-    def OnItemDeleteAll(self, event):
-        """Delete all items from the list"""
-        self.list.DeleteAllItems()
-        self.cats = {}
-        event.Skip()
-    def __GetCategories(self, coords, qdist):
-        """Get layer/category pairs for all available
-        layers
-        Return True line found or False if not found"""
-        cmdWhat = gcmd.Command(cmd=['v.what',
-                                   '--q',
-                                   'east_north=%f,%f' % \
-                                       (float(coords[0]), float(coords[1])),
-                                   'distance=%f' % qdist])
-        if cmdWhat.returncode != 0:
-            return False
-        for item in cmdWhat.ReadStdOutput():
-            litem = item.lower()
-            if "line:" in litem: # get line id
-                self.line = int(item.split(':')[1].strip())
-            elif "layer:" in litem: # add layer
-                layer = int(item.split(':')[1].strip())
-                if layer not in self.cats.keys():
-                    self.cats[layer] = []
-            elif "category:" in litem: # add category
-                self.cats[layer].append(int(item.split(':')[1].strip()))
-        return True
-    def OnReload(self, event):
-        """Reload button pressed"""
-        # restore original list
-        self.cats = copy.deepcopy(self.cats_orig)
-        # polulate list
-        self.itemDataMap = self.list.Populate(update=True)
-        event.Skip()
-        """Cancel button pressed"""
-        self.parent.parent.dialogs['category'] = None
-        if self.parent.parent.digit:
-            self.parent.parent.digit.driver.SetSelected([])
-            self.parent.UpdateMap(render=False)
-        else:
-            self.parent.parent.OnRender(None)
-        self.Close()
-        """Apply button pressed"""
-        # action : (catsFrom, catsTo)
-        check = {'catadd': (self.cats,      self.cats_orig),
-                 'catdel': (self.cats_orig, self.cats)}
-        # add/delete new category
-        for action, cats in check.iteritems():
-            for layer in cats[0].keys():
-                catList = []
-                for cat in cats[0][layer]:
-                    if layer not in cats[1].keys() or \
-                            cat not in cats[1][layer]:
-                        catList.append(cat)
-                if catList != []:
-                        vEditCmd = ['v.edit', '--q',
-                                    'tool=%s' % action,
-                                    'cats=%s' % ",".join(["%d" % v for v in catList]),
-                                    'id=%d' % self.line]
-                        gcmd.Command(vEditCmd)
-                    else:
-                        if action == 'catadd':
-                            add = True
-                        else:
-                            add = False
-                        self.line = self.parent.parent.digit.SetLineCats(-1, layer,
-        catList, add)
-                        if self.line < 0:
-                            wx.MessageBox(parent=self, message=_("Unable to update vector map."),
-                                          caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
-            self.parent.parent.digit.driver.ReloadMap()
-        event.Skip()
-    def OnOK(self, event):
-        """OK button pressed"""
-        self.OnApply(event)
-        self.OnCancel(event)
-    def OnAddCat(self, event):
-        """Button 'Add' new category pressed"""
-        try:
-            layer = int(self.layerNew.GetValue())
-            cat   = int(self.catNew.GetValue())
-            if layer <= 0:
-                raise ValueError
-        except ValueError:
-                                   {'layer' : str(self.layerNew.GetValue()),
-                                    'category' : str(self.catNew.GetValue())},
-            dlg.ShowModal()
-            dlg.Destroy()
-            return False
-        self.cats[layer].append(cat)
-        # reload list
-        # update category number for add
-        self.catNew.SetValue(cat + 1)
-        event.Skip()
-        return True
-    def GetLine(self):
-        """Get id of selected line of 'None' if no line is selected"""
-        return self.line
-    def UpdateDialog(self, query=None, cats=None, line=None):
-        """Update dialog
-        @param query {coordinates, distance} - v.edit/v.what
-        @param cats  directory layer/cats    - vdigit
-        Return True if updated otherwise False
-        self.line = None
-        self.cats = {}
-        if cats is None:
-            ret = self.__GetCategories(query[0], query[1])
-        else:
-            self.line = line
-            ret = 1
-        if ret == 0 or not self.line:
-            return False
-        # polulate list
-        try:
-        except:
-            newCat = 1
-        self.catNew.SetValue(newCat)
-        return True
-class CategoryListCtrl(wx.ListCtrl,
-                       listmix.ListCtrlAutoWidthMixin,
-                       listmix.TextEditMixin):
-    """List of layers/categories"""
-    def __init__(self, parent, id, pos=wx.DefaultPosition,
-                 size=wx.DefaultSize, style=0):
-        wx.ListCtrl.__init__(self, parent, id, pos, size, style)
-        listmix.ListCtrlAutoWidthMixin.__init__(self)
-        listmix.TextEditMixin.__init__(self)
-    def Populate(self, update=False):
-        """Populate the list"""
-        itemData = {} # requested by sorter
-        if not update:
-            self.InsertColumn(0, _("Layer"))
-            self.InsertColumn(1, _("Category"))
-        else:
-            self.DeleteAllItems()
-        i = 1
-        for layer in self.parent.cats.keys():
-            catsList = self.parent.cats[layer]
-            for cat in catsList:
-                index = self.InsertStringItem(sys.maxint, str(catsList[0]))
-                self.SetStringItem(index, 0, str(layer))
-                self.SetStringItem(index, 1, str(cat))
-                self.SetItemData(index, i)
-                itemData[i] = (str(layer), str(cat))
-                i = i + 1
-        if not update:
-            self.SetColumnWidth(0, 100)
-            self.SetColumnWidth(1, wx.LIST_AUTOSIZE)
-        self.currentItem = 0
-        return itemData
-class DigitZBulkDialog(wx.Dialog):
-    Dialog used for Z bulk-labeling tool
-    def __init__(self, parent, title, nselected, style=wx.DEFAULT_DIALOG_STYLE):
-        # panel  = wx.Panel(parent=self, id=wx.ID_ANY)
-        txt = wx.StaticText(parent=self,
-                            label=_("%d lines selected for z bulk-labeling") % nselected);
-        border.Add(item=txt, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
-        box   = wx.StaticBox (parent=self, id=wx.ID_ANY, label=" %s " % _("Set value"))
-        flexSizer = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
-        # starting value
-                            label=_("Starting value"));
-        self.value = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
-                                 initial=0,
-                                 min=-1e6, max=1e6)
-        flexSizer.Add(self.value, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-        # step
-                            label=_("Step"))
-        self.step  = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
-                                 initial=0,
-                                 min=0, max=1e6)
-        flexSizer.Add(self.step, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-        border.Add(item=sizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
-        # buttons
-        # sizers
-        mainSizer.Add(item=border, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-04-27 18:54:24 UTC (rev 31148)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-04-27 19:27:49 UTC (rev 31149)
@@ -60,9 +60,9 @@
 import globalvar
 import utils
 import gdialogs
-from digit import DigitCategoryDialog as DigitCategoryDialog
-from digit import DigitZBulkDialog    as DigitZBulkDialog
-from digit import GV_LINES            as Digit_Lines_Type
+from vdigit import VDigitCategoryDialog as VDigitCategoryDialog
+from vdigit import VDigitZBulkDialog    as VDigitZBulkDialog
+from vdigit import GV_LINES            as VDigit_Lines_Type
 from debug import Debug               as Debug
 from icon  import Icons               as Icons
 from preferences import globalSettings as UserSettings
@@ -1094,20 +1094,20 @@
                     if self.parent.dialogs['category'] is None:
                         # open new dialog
                         if digitClass.type == 'vedit':
-                            self.parent.dialogs['category'] = DigitCategoryDialog(parent=self,
-        map=map,
-        query=(coords, qdist),
-        pos=posWindow,
-        title=_("Update categories"))
+                            self.parent.dialogs['category'] = VDigitCategoryDialog(parent=self,
+        map=map,
+        query=(coords, qdist),
+        pos=posWindow,
+        title=_("Update categories"))
                         else:
                             if digitClass.driver.SelectLineByPoint(coords,
        digitClass.GetSelectType()) is not None:
-        map=map,
-        cats=digitClass.GetLineCats(),
-        line=digitClass.driver.GetSelected()[0],
-        pos=posWindow,
+        map=map,
+        cats=digitClass.GetLineCats(),
+        line=digitClass.driver.GetSelected()[0],
+        pos=posWindow,
                     else:
                         # update currently open dialog
@@ -1267,7 +1267,7 @@
                 # -> delete line || move line || move vertex
                 if digitToolbar.action in ["moveVertex", "editLine"]:
                     if len(digitClass.driver.GetSelected()) == 0:
-                        nselected = digitClass.driver.SelectLineByPoint(pos1, type=Digit_Lines_Type)
+                        nselected = digitClass.driver.SelectLineByPoint(pos1, type=VDigit_Lines_Type)
                         if digitToolbar.action == "editLine":
                             self.UpdateMap(render=False)
                             selVertex = digitClass.driver.GetSelectedVertex(pos1)[0]
@@ -1290,7 +1290,7 @@
                 elif digitToolbar.action == "copyCats":
                     if not hasattr(self, "copyCatsIds"):
                         # collect categories
                         if nselected:
                             qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / \
                                                 self.Map.width)
@@ -1360,7 +1360,7 @@
             elif digitToolbar.action in ["splitLine", "addVertex", "removeVertex"]:
                 pointOnLine = digitClass.driver.SelectLineByPoint(pos1,
-        type=Digit_Lines_Type)
+        type=VDigit_Lines_Type)
                 if pointOnLine:
                     self.UpdateMap(render=False) # highlight object
                     if digitToolbar.action in ["splitLine", "addVertex"]:
@@ -1643,8 +1643,8 @@
                 pos2 = self.polycoords[1]
                 selected = digitClass.driver.GetSelected()
-                dlg = DigitZBulkDialog(parent=self, title=_("Z bulk-labeling dialog"),
-                                       nselected=len(selected))
+                dlg = VDigitZBulkDialog(parent=self, title=_("Z bulk-labeling dialog"),
+                                        nselected=len(selected))
                 if dlg.ShowModal() == wx.ID_OK:
                     digitClass.ZBulkLine(pos1, pos2, dlg.value.GetValue(), dlg.step.GetValue())
@@ -2396,7 +2396,7 @@
                               CloseButton(False).Layer(2))
         elif name == "digit":
-            self.digittoolbar = toolbars.DigitToolbar(self, self.Map, self.tree)
+            self.digittoolbar = toolbars.VDigitToolbar(self, self.Map, self.tree)
             for toolRow in range(0, self.digittoolbar.numOfRows):
                 self._mgr.AddPane(self.digittoolbar.toolbar[toolRow],
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-04-27 18:54:24 UTC (rev 31148)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-04-27 19:27:49 UTC (rev 31149)
@@ -5,7 +5,7 @@
     * AbstractToolbar
     * MapToolbar
     * GRToolbar
-    * DigitToolbar
+    * VDigitToolbar
     * ProfileToolbar
 PURPOSE: Toolbars for Map Display window
@@ -25,9 +25,9 @@
 import globalvar
 import gcmd
 import grassenv
-import digit
 import gdialogs
-from digit import DigitSettingsDialog as DigitSettingsDialog
+import vdigit
+from vdigit import VDigitSettingsDialog as VDigitSettingsDialog
@@ -255,7 +255,7 @@
         if tool == "Digitize" and not self.mapdisplay.digittoolbar:
             self.mapdisplay.AddToolbar("digit")
-class DigitToolbar(AbstractToolbar):
+class VDigitToolbar(AbstractToolbar):
     Toolbar for digitization
@@ -408,14 +408,14 @@
     def OnAddPoint(self, event):
         """Add point to the vector map Laier"""
-        Debug.msg (2, "DigitToolbar.OnAddPoint()")
+        Debug.msg (2, "VDigitToolbar.OnAddPoint()")
         self.action = "addLine"
         self.type   = "point"
         self.parent.MapWindow.mouse['box'] = 'point'
     def OnAddLine(self, event):
         """Add line to the vector map layer"""
-        Debug.msg (2, "DigitToolbar.OnAddLine()")
+        Debug.msg (2, "VDigitToolbar.OnAddLine()")
         self.type   = "line"
         self.parent.MapWindow.mouse['box'] = 'line'
@@ -423,7 +423,7 @@
     def OnAddBoundary(self, event):
         """Add boundary to the vector map layer"""
-        Debug.msg (2, "DigitToolbar.OnAddBoundary()")
+        Debug.msg (2, "VDigitToolbar.OnAddBoundary()")
         self.type   = "boundary"
@@ -431,7 +431,7 @@
     def OnAddCentroid(self, event):
         """Add centroid to the vector map layer"""
-        Debug.msg (2, "DigitToolbar.OnAddCentroid()")
+        Debug.msg (2, "VDigitToolbar.OnAddCentroid()")
         self.type   = "centroid"
@@ -541,13 +541,13 @@
         """Show settings dialog"""
         if self.parent.digit is None:
-            reload(digit)
-            from digit import Digit as Digit
+            reload(vdigit)
+            from vdigit import Digit as Digit
             self.parent.digit = Digit(mapwindow=self.parent.MapWindow)
         if not self.settingsDialog:
-            self.settingsDialog = DigitSettingsDialog(parent=self.parent, title=_("Digitization settings"),
-                                                      style=wx.DEFAULT_DIALOG_STYLE)
+            self.settingsDialog = VDigitSettingsDialog(parent=self.parent, title=_("Digitization settings"),
+                                                       style=wx.DEFAULT_DIALOG_STYLE)
             self.settingsDialog.Show()
     def OnAdditionalToolMenu(self, event):
@@ -712,8 +712,8 @@
         @return True on success
         @return False on error
-        reload(digit)
+        reload(vdigit)
         try:
             self.layerSelectedID = self.layers.index(layerSelected)
@@ -733,7 +733,7 @@
         self.parent.maptoolbar.combo.SetValue ('Digitize')
         # set initial category number for new features (layer=1), etc.
-        Debug.msg (4, "DigitToolbar.StartEditing(): layerSelectedID=%d layer=%s" % \
+        Debug.msg (4, "VDigitToolbar.StartEditing(): layerSelectedID=%d layer=%s" % \
                    (self.layerSelectedID, mapLayer.name))
@@ -760,7 +760,7 @@
         if self.layers[self.layerSelectedID] == layerSelected:
             self.layerSelectedID = None
-            Debug.msg (4, "DigitToolbar.StopEditing(): layer=%s" % \
+            Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % \
                        (layerSelected.name))
             self.combo.SetValue (_('Select vector map'))
@@ -806,7 +806,7 @@
         Optionaly also update toolbar
-        Debug.msg (4, "DigitToolbar.UpdateListOfLayers(): updateTool=%d" % \
+        Debug.msg (4, "VDigitToolbar.UpdateListOfLayers(): updateTool=%d" % \
                    updateTool)
         layerNameSelected = None
Copied: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py (from rev 31138, grass/trunk/gui/wxpython/gui_modules/digit.py)
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	                        (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2008-04-27 19:27:49 UTC (rev 31149)
@@ -0,0 +1,2577 @@
+MODULE: vdigit
+CLASSES:
+ * AbstractDigit
+ * VEdit
+ * VDigit
+ * AbstractDisplayDriver
+ * CDisplayDriver
+ * VDigitSettingsDialog
+ * VDigitCategoryDialog
+ * VDigitZBulkDialog
+PURPOSE: Vector digitization tool for wxPython GUI
+         Note: Initial version under development
+         Progress:
+          (1) v.edit called on the background (class VEdit)
+          (2) Reimplentation of v.digit (VDigit)
+         Import:
+          from vdigit import VDigit as VDigit
+AUTHORS: The GRASS Development Team
+         Martin Landa <landa.martin gmail.com>
+COPYRIGHT: (C) 2007-2008 by the GRASS Development Team
+           This program is free software under the GNU General Public
+           License (>=v2). Read the file COPYING that comes with GRASS
+           for details.
+import os
+import sys
+import string
+import copy
+import wx
+import wx.lib.colourselect as csel
+import wx.lib.mixins.listctrl as listmix
+import gcmd
+import dbm
+from debug import Debug as Debug
+import gselect
+import globalvar
+from preferences import globalSettings as UserSettings
+try:
+    digitPath = os.path.join(globalvar.ETCWXDIR, "vdigit")
+    sys.path.append(digitPath)
+    import grass6_wxvdigit as wxvdigit
+    GV_LINES = wxvdigit.GV_LINES
+    digitErr = ''
+except ImportError, err:
+    GV_LINES = None
+    digitErr = err
+    #    print >> sys.stderr, "%sWARNING: Digitization tool is disabled (%s). " \
+    #          "Detailed information in README file." % \
+    #          (os.linesep, err)
+# which interface to use?
+if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit' and GV_LINES is not None:
+    print >> sys.stderr, "%sWARNING: Digitization tool uses v.edit interface. " \
+        "This can significantly slow down some operations especially for " \
+        "middle-large vector maps. "\
+        "You can change the digitization interface in 'User preferences' " \
+        "(menu 'Config'->'Preferences')." % \
+          os.linesep
+class AbstractDigit:
+    Abstract digitization class
+    def __init__(self, mapwindow):
+        """Initialization
+        @param mapwindow reference to mapwindow (MapFrame) instance
+        @param settings  initial settings of digitization tool
+        self.map       = None
+        self.mapWindow = mapwindow
+        Debug.msg (3, "AbstractDigit.__init__(): map=%s" % \
+                   self.map)
+        #self.SetCategory()
+        self.driver = CDisplayDriver(self, mapwindow)
+    def SetCategoryNextToUse(self):
+        """Find maximum category number in the map layer
+        and update Digit.settings['category']
+        @return 'True' on success, 'False' on failure
+        # vector map layer without categories, reset to '1'
+        UserSettings.Set(group='vdigit', key='category', subkey='value', value=1)
+        if self.map:
+            if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit':
+                categoryCmd = gcmd.Command(cmd=["v.category", "-g", "--q",
+                                                "input=%s" % self.map,
+                                                "option=report"])
+                if categoryCmd.returncode != 0:
+                    return False
+                for line in categoryCmd.ReadStdOutput():
+                    if "all" in line:
+                        if UserSettings.Get(group='vdigit', key='layer', subkey='value') != int(line.split(' ')[0]):
+                            continue
+                        try:
+                            maxCat = int(line.split(' ')[-1]) + 1
+                            UserSettings.Set(group='vdigit', key='category', subkey='value', value=maxCat)
+                        except:
+                            return False
+                        return True
+            else:
+                                  value=self.digit.GetCategory(UserSettings.Get(group='vdigit', key='layer', subkey='value') + 1))
+    def SetCategory(self):
+        """Return category number to use (according Settings)"""
+        if UserSettings.Get(group='vdigit', key="categoryMode", subkey='value') == "No category":
+            UserSettings.Set(group='vdigit', key="category", subkey='value', value=1)
+        elif UserSettings.Get(group='vdigit', key="categoryMode", subkey='value') == "Next to use":
+            self.SetCategoryNextToUse()
+        return UserSettings.Get(group='vdigit', key="category", subkey='value')
+    def SetMapName(self, map):
+        """Set map name
+        @param map map name to be set up or None (will close currently edited map)
+        Debug.msg (3, "AbstractDigit.SetMapName map=%s" % map)
+        self.map = map
+        try:
+            ret = self.driver.Reset(self.map)
+        except StandardError, e:
+            raise gcmd.DigitError('Unable to initialize display driver, '
+                                  'see README file for more information.%s%s'
+                                  'Details: %s (%s)' % (os.linesep, os.linesep, e, digitErr))
+        if map and ret == -1:
+            raise gcmd.DigitError(_('Unable to open vector map <%s> for editing. '
+                                    'Data are probably corrupted, '
+                                    'try to run v.build for rebuilding the topology.') % map)
+        if not map and ret != 0:
+        if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') != 'v.edit':
+            try:
+                self.digit.InitCats()
+            except:
+                pass
+    def SelectLinesByQueryThresh(self):
+        """Generic method used for SelectLinesByQuery()
+        -- to get threshold value"""
+        thresh = 0.0
+        if UserSettings.Get(group='vdigit', key='query', subkey='type') == "length":
+            thresh = UserSettings.Get(group='vdigit', key='queryLength', subkey='thresh')
+            if UserSettings.Get(group='vdigit', key="queryLength", subkey='than') == "shorter than":
+                thresh = -1 * thresh
+        else:
+            thresh = UserSettings.Get(group='vdigit', key='queryDangle', subkey='thresh')
+            if UserSettings.Get(group='vdigit', key="queryDangle", subkey='than') == "shorter than":
+        return thresh
+    def GetSelectType(self):
+        """Get type(s) to be selected
+        Used by SelectLinesByBox() and SelectLinesByPoint()"""
+        type = 0
+        for feature in (('Point', wxvdigit.GV_POINT),
+                        ('Line', wxvdigit.GV_LINE),
+                        ('Centroid', wxvdigit.GV_CENTROID),
+                        ('Boundary', wxvdigit.GV_BOUNDARY)):
+            if UserSettings.Get(group='vdigit', key='selectFeature'+feature[0], subkey='enabled') is True:
+                type |= feature[1]
+        return type
+    def SelectLinesFromBackgroundMap(self, pos1, pos2):
+        """Select features from background map
+        @param pos1,pos2 bounding box defifinition
+        if UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value') == '':
+            Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): []")
+            return []
+        x1, y1 = pos1
+        x2, y2 = pos2
+        vEditCmd = gcmd.Command(['v.edit',
+                                 '--q',
+                                 'map=%s' % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'),
+                                 'tool=select',
+                                 'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1])])
+                                 #'polygon=%f,%f,%f,%f,%f,%f,%f,%f,%f,%f' % \
+                                 #    (x1, y1, x2, y1, x2, y2, x1, y2, x1, y1)])
+        try:
+            output = vEditCmd.ReadStdOutput()[0] # first line
+            ids = output.split(',')
+            ids = map(int, ids) # str -> int
+        except:
+            return []
+        Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): %s" % \
+                      ",".join(["%d" % v for v in ids]))
+        return ids
+class VEdit(AbstractDigit):
+    Prototype of digitization class based on v.edit command
+    Note: This should be replaced by VDigit class.
+        """Initialization
+        AbstractDigit.__init__(self, mapwindow)
+    def AddPoint (self, map, point, x, y, z=None):
+        """Add point/centroid
+        @param point feature type (True for point, otherwise centroid)
+        @param x,y,z coordinates
+        if point:
+            key = "P"
+        else:
+            key = "C"
+        layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
+        cat   = self.SetCategory()
+        if layer > 0 and cat != "None":
+            addstring =  "%s 1 1\n" % (key)
+        else:
+            addstring =  "%s 1\n" % (key)
+        addstring += "%f %f\n" % (x, y)
+            addstring += "%d %d\n" % (layer, cat)
+            Debug.msg (3, "VEdit.AddPoint(): map=%s, type=%s, layer=%d, cat=%d, x=%f, y=%f" % \
+                           (map, type, layer, cat, x, y))
+        else:
+            Debug.msg (3, "VEdit.AddPoint(): map=%s, type=%s, x=%f, y=%f" % \
+                           (map, type, x, y))
+        Debug.msg (4, "Vline.AddPoint(): input=%s" % addstring)
+        self.__AddFeature (map=map, input=addstring)
+    def AddLine (self, map, line, coords):
+        """Add line/boundary
+        @param line feature type (True for line, otherwise boundary)
+        @param list of coordinates
+        if len(coords) < 2:
+            return
+        if line:
+            key = "L"
+            flags = []
+        else:
+            key = "B"
+            flags = ['-c'] # close boundaries
+            addstring = "%s %d 1\n" % (key, len(coords))
+        else:
+            addstring = "%s %d\n" % (key, len(coords))
+        for point in coords:
+            addstring += "%f %f\n" % \
+                (float(point[0]), float(point [1]))
+            Debug.msg (3, "Vline.AddLine(): type=%s, layer=%d, cat=%d coords=%s" % \
+                           (key, layer, cat, coords))
+        else:
+            Debug.msg (3, "Vline.AddLine(): type=%s, coords=%s" % \
+                           (key, coords))
+        Debug.msg (4, "VEdit.AddLine(): input=%s" % addstring)
+        self.__AddFeature (map=map, input=addstring, flags=flags)
+    def __AddFeature (self, map, input, flags=[]):
+        """Generic method to add new vector feature
+        @param input feature definition in GRASS ASCII format
+        @param flags additional flags
+        if UserSettings.Get(group='vdigit', key='snapping', subkey='value') <= 0.0:
+            snap = "no"
+        else:
+            if UserSettings.Get(group='vdigit', key='snapToVertex', subkey='enabled') is True:
+                snap = "vertex"
+            else:
+                snap = "node"
+        command = ["v.edit", "-n", "--q",
+                   "map=%s" % map,
+                   "tool=add",
+                   "thresh=%f,%f" % (self.driver.GetThreshold(type='selectThresh'), self.driver.GetThreshold(type='snapping')),
+                   "snap=%s" % snap]
+        if UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value') != '':
+            command.append("bgmap=%s" % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'))
+        # additional flags
+        for flag in flags:
+            command.append(flag)
+        # run the command
+        Debug.msg(4, "VEdit.AddFeature(): input=%s" % input)
+        vedit = gcmd.Command(cmd=command, stdin=input, stderr=None)
+        # reload map (needed for v.edit)
+        self.driver.ReloadMap()
+    def DeleteSelectedLines(self):
+        """Delete selected features"""
+        selected = self.driver.GetSelected() # grassId
+        if len(selected) <= 0:
+            return False
+        ids = ",".join(["%d" % v for v in selected])
+        Debug.msg(4, "Digit.DeleteSelectedLines(): ids=%s" % \
+                      ids)
+        # delete also attributes if requested
+        if UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled') is True:
+            layerCommand = gcmd.Command(cmd=["v.db.connect",
+                                             "-g", "--q",
+                                             "map=%s" % self.map],
+                                        rerr=None, stderr=None)
+            if layerCommand.returncode == 0:
+                layers = {}
+                for line in layerCommand.ReadStdOutput():
+                    lineList = line.split(' ')
+                    layers[int(lineList[0])] = { "table"    : lineList[1],
+                                                 "key"      : lineList[2],
+                                                 "database" : lineList[3],
+                                                 "driver"   : lineList[4] }
+                for layer in layers.keys():
+                    printCats = gcmd.Command(['v.category',
+                                              '--q',
+                                              'input=%s' % self.map,
+                                              'layer=%d' % layer,
+                                              'option=print',
+                                              'id=%s' % ids])
+                    sql = 'DELETE FROM %s WHERE' % layers[layer]['table']
+                    n_cats = 0
+                    for cat in printCats.ReadStdOutput():
+                        for c in cat.split('/'):
+                            sql += ' cat = %d or' % int(c)
+                            n_cats += 1
+                    sql = sql.rstrip(' or')
+                    if n_cats > 0:
+                        gcmd.Command(['db.execute',
+                                      '--q',
+                                      'driver=%s' % layers[layer]['driver'],
+                                      'database=%s' % layers[layer]['database']],
+                                     stdin=sql,
+        command = [ "v.edit",
+                    "map=%s" % self.map,
+                    "tool=delete",
+                    "ids=%s" % ids]
+        # run the command
+        vedit = gcmd.Command(cmd=command, stderr=None)
+        return True
+    def MoveSelectedLines(self, move):
+        """Move selected features
+        @param move X,Y direction
+        return self.__MoveFeature("move", None, move)
+    def MoveSelectedVertex(self, coords, move):
+        """Move selected vertex
+        Feature geometry is changed.
+        @param coords click coordinates
+        return self.__MoveFeature("vertexmove", coords, move)
+    def __MoveFeature(self, tool, coords, move):
+        """Move selected vector feature (line, vertex)
+        @param tool   tool for v.edit
+        @param move   direction (x, y)
+            return False
+        Debug.msg(4, "Digit.MoveSelectedLines(): ids=%s, move=%s" % \
+                      (ids, move))
+            snap = "no"
+        else:
+                snap = "vertex"
+            else:
+                snap = "node"
+        command = ["v.edit", "--q",
+                   "tool=%s" % tool,
+                   "ids=%s" % ids,
+                   "move=%f,%f" % (float(move[0]),float(move[1])),
+                   "snap=%s" % snap]
+        if tool == "vertexmove":
+            command.append("coords=%f,%f" % (float(coords[0]), float(coords[1])))
+            command.append("-1") # modify only first selected
+        # run the command
+        return True
+    def AddVertex(self, coords):
+        """Add new vertex to the selected line/boundary on position 'coords'
+        @param coords coordinates to add vertex
+        return self.__ModifyVertex(coords, "vertexadd")
+    def RemoveVertex(self, coords):
+        """Remove vertex from the selected line/boundary on position 'coords'
+        @param coords coordinates to remove vertex
+        return self.__ModifyVertex(coords, "vertexdel")
+    def __ModifyVertex(self, coords, action):
+        """Generic method for vertex manipulation
+        @param action operation to perform
+        try:
+            line = self.driver.GetSelected()[0]
+        except:
+            return False
+                   "tool=%s" % action,
+                   "ids=%s" % line,
+                   "coords=%f,%f" % (float(coords[0]),float(coords[1])),
+                   "thresh=%f,%f" % (self.driver.GetThreshold(type='selectThresh'), self.driver.GetThreshold(type='snapping'))]
+        # run the command
+        return True
+    def SplitLine(self, coords):
+        """Split selected line/boundary on position 'coords'
+        @param coords coordinates to split line
+        try:
+        except:
+            return False
+                   "tool=break",
+                   "ids=%s" % line,
+                   "thresh=%f" % self.driver.GetThreshold(type='selectThresh')]
+        # run the command
+        # redraw map
+        return True
+    def EditLine(self, line, coords):
+        """Edit existing line/boundary
+        @param line id of line to be modified
+        @param coords list of coordinates of modified line
+        # remove line
+        vEditDelete = gcmd.Command(['v.edit',
+                                   '--q',
+                                   'map=%s' % self.map,
+                                   'tool=delete',
+                                   'ids=%s' % line], stderr=None)
+        # add line
+        if len(coords) > 0:
+            self.AddLine(self.map, "line", coords)
+    def __ModifyLines(self, tool):
+        """Generic method to modify selected lines/boundaries
+        @param tool operation to be performed by v.edit
+        ids = self.driver.GetSelected()
+        if len(ids) <= 0:
+            return False
+        vEdit = ['v.edit',
+                 '--q',
+                 'tool=%s' % tool,
+                 'ids=%s' % ",".join(["%d" % v for v in ids])]
+        if tool in ['snap', 'connect']:
+            vEdit.append("thresh=%f,%f" % (self.driver.GetThreshold(type='selectThresh'), self.driver.GetThreshold(type='snapping')))
+        runCmd = gcmd.Command(vEdit)
+        return True
+    def FlipLine(self):
+        """Flip selected lines/boundaries"""
+        return self.__ModifyLines('flip')
+    def MergeLine(self):
+        """Merge selected lines/boundaries"""
+        return self.__ModifyLines('merge')
+    def BreakLine(self):
+        """Break selected lines/boundaries"""
+        return self.__ModifyLines('break')
+    def SnapLine(self):
+        """Snap selected lines/boundaries"""
+        return self.__ModifyLines('snap')
+    def ConnectLine(self):
+        """Connect selected lines/boundaries"""
+        return self.__ModifyLines('connect')
+    def TypeConvForSelectedLines(self):
+        """Feature type conversion for selected objects.
+        Supported conversions:
+         - point <-> centroid
+         - line <-> boundary
+        return self.__ModifyLines('chtype')
+    def ZBulkLine(self, pos1, pos2, value, step):
+        """Provide z bulk-labeling (automated assigment of z coordinate
+        to 3d lines
+        @param pos1,pos2 bounding box definition for selecting lines to be labeled
+        @param value starting value
+        @param step  step value
+        gcmd.Command(['v.edit',
+                      '--q',
+                      'tool=zbulk',
+                      'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1]),
+                      'zbulk=%f,%f' % (value, step)])
+    def CopyLine(self, ids=None):
+        """Copy features from (background) vector map
+        @param ids list of line ids to be copied
+        if not ids:
+        if len(ids) <= 0:
+            return False
+                 '--q',
+                 'tool=copy',
+            vEdit.append('bgmap=%s' % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'))
+        return True
+    def CopyCats(self, cats, ids):
+        """Copy given categories to objects with id listed in ids
+        @param cats list of cats to be copied
+        @param ids  ids of lines to be modified
+        if len(cats) == 0 or len(ids) == 0:
+            return False
+        # collect cats
+                     '--q',
+                     'tool=catadd',
+                     'cats=%s' % ",".join(["%d" % v for v in cats]),
+                     'ids=%s' % ",".join(["%d" % v for v in ids])])
+        return True
+    def SelectLinesByQuery(self, pos1, pos2):
+        """Select features by query
+        @param pos1, pos2 bounding box definition
+        thresh = self.SelectLinesByQueryThresh()
+        w, n = pos1
+        e, s = pos2
+        if UserSettings.Get(group='vdigit', key='query', subkey='box') == False: # select globaly
+            vInfo = gcmd.Command(['v.info',
+                                  '-g'])
+            for item in vInfo.ReadStdOutput():
+                if 'north' in item:
+                    n = float(item.split('=')[1])
+                elif 'south' in item:
+                    s = float(item.split('=')[1])
+                elif 'east' in item:
+                    e = float(item.split('=')[1])
+                elif 'west' in item:
+                    w = float(item.split('=')[1])
+        vEdit = (['v.edit',
+                  '--q',
+                  'tool=select',
+                  'bbox=%f,%f,%f,%f' % (w, n, e, s),
+                  'query=%s' % UserSettings.Get(group='vdigit', key='query', subkey='type'),
+                  'thresh=0,0,%f' % thresh])
+        vEditCmd = gcmd.Command(vEdit)
+        try:
+        except:
+            return []
+        Debug.msg(4, "VEdit.SelectLinesByQuery(): %s" % \
+        return ids
+    def GetLayers(self):
+        """Return list of layers"""
+                                         "-g", "--q",
+            layers = []
+                layers.append(int(lineList[0]))
+            return layers
+        return [1,]
+    def Undo(self, level=-1):
+        """Undo not implemented here"""
+        wx.MessageBox(parent=self.mapWindow, message=_("Undondo is not implemented in vedit component. "
+                                                    "Use vdigit instead."),
+                      caption=_("Message"), style=wx.ID_OK | wx.ICON_INFORMATION | wx.CENTRE)
+class VDigit(AbstractDigit):
+    Prototype of digitization class based on v.digit reimplementation
+    Under development (wxWidgets C/C++ background)
+        """Initialization
+        try:
+            self.digit = wxvdigit.Digit(self.driver.GetDevice())
+        except (ImportError, NameError):
+            self.digit = None
+        self.toolbar = mapwindow.parent.digittoolbar
+    def __del__(self):
+        del self.digit
+        """Add new point/centroid
+        @param map   map name (unused, for compatability with VEdit)
+        @param point feature type (if true point otherwise centroid)
+        if point:
+            type = wxvdigit.GV_POINT
+        else:
+            type = wxvdigit.GV_CENTROID
+        snap, thresh = self.__getSnapThreshold()
+        if z:
+            ret = self.digit.AddLine(type, [x, y, z], layer, cat,
+                                     str(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value')), snap, thresh)
+        else:
+            ret = self.digit.AddLine(type, [x, y], layer, cat,
+        if ret == -1:
+            raise gcmd.DigitError, _("Adding new feature to vector map <%s> failed.") % map
+        self.toolbar.EnableUndo()
+        @param line   feature type (if True line, otherwise boundary)
+            return
+        if line:
+            type = wxvdigit.GV_LINE
+        else:
+            type = wxvdigit.GV_BOUNDARY
+        listCoords = []
+        for c in coords:
+            for x in c:
+                listCoords.append(x)
+        ret = self.digit.AddLine(type, listCoords, layer, cat,
+        if ret == -1:
+        @return number of deleted lines
+        nlines = self.digit.DeleteLines(UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled'))
+        if nlines > 0:
+        return nlines
+        nlines = self.digit.MoveLines(move[0], move[1], 0.0, # TODO 3D
+        if nlines > 0:
+        return nlines
+        """Move selected vertex of the line
+        @return 1 vertex moved
+        @return 0 vertex not moved (not found, line is not selected)
+        moved = self.digit.MoveVertex(coords[0], coords[1], 0.0, # TODO 3D
+                                      move[0], move[1], 0.0,
+                                      self.driver.GetThreshold(type='selectThresh'), thresh)
+        if moved:
+        return moved
+        @return 1 vertex added
+        @return 0 nothing changed
+        @return -1 on failure
+        added = self.digit.ModifyLineVertex(1, coords[0], coords[1], 0.0, # TODO 3D
+                                            self.driver.GetThreshold(type='selectThresh'))
+        if added > 0:
+        return added
+        @return 1 vertex removed
+        deleted = self.digit.ModifyLineVertex(0, coords[0], coords[1], 0.0, # TODO 3D
+        if deleted > 0:
+        return deleted
+        @return 1 line modified
+        @return -1 error
+        ret = self.digit.SplitLine(coords[0], coords[1], 0.0, # TODO 3D
+                                   self.driver.GetThreshold('selectThresh'))
+        if ret > 0:
+        return ret
+        @return feature id of new line
+        @return -1 on error
+        try:
+            lineid = line[0]
+        except:
+            lineid = -1
+        listCoords = []
+        for c in coords:
+            for x in c:
+        ret = self.digit.RewriteLine(lineid, listCoords,
+        if ret > 0:
+        return ret
+        @return number of modified lines
+        ret = self.digit.FlipLines()
+        if ret > 0:
+        return ret
+        ret = self.digit.MergeLines()
+        if ret > 0:
+        return ret
+        ret = self.digit.BreakLines()
+        if ret > 0:
+        return ret
+        @return on success
+        ret = self.digit.SnapLines(thresh)
+        if ret == 0:
+        return ret
+        @return 1 lines connected
+        @return 0 lines not connected
+        ret = self.digit.ConnectLines(thresh)
+        if ret > 0:
+        return ret
+        @return number of copied features
+        ret = self.digit.CopyLines(ids, str(UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value')))
+        if ret > 0:
+        return ret
+        @return number of modified features
+            return 0
+        ret = self.digit.CopyCats(cats, ids)
+        if ret > 0:
+        return ret
+        w, n = pos1
+        e, s = pos2
+        query = wxvdigit.QUERY_UNKNOWN
+        if UserSettings.Get(group='vdigit', key='query', subkey='type') == 'length':
+            query = wxvdigit.QUERY_LENGTH
+        elif UserSettings.Get(group='vdigit', key='query', subkey='type') == 'dangle':
+            query = wxvdigit.QUERY_DANGLE
+        type = wxvdigit.GV_POINTS | wxvdigit.GV_LINES # TODO: 3D
+        ids = self.digit.SelectLinesByQuery(w, n, 0.0, e, s, 1000.0,
+                                            UserSettings.Get(group='vdigit', key='query', subkey='box'),
+                                            query, type, thresh)
+        Debug.msg(4, "VDigit.SelectLinesByQuery(): %s" % \
+        return ids
+    def GetLineCats(self, line=-1):
+        """Get layer/category pairs from given (selected) line
+        @param line feature id (-1 for first selected line)
+        return self.digit.GetLineCats(line)
+    def SetLineCats(self, line, layer, cats, add=True):
+        """Set categories for given line and layer
+        @param layer layer number (-1 for first selected line)
+        @param cats list of categories
+        @param add if True to add, otherwise do delete categories
+        @return new feature id (feature need to be rewritten)
+        ret = self.digit.SetLineCats(line, layer, cats, add)
+        if ret > 0:
+        return ret
+        """Get list of layers"""
+        return self.digit.GetLayers()
+        ret = self.digit.TypeConvLines()
+        if ret > 0:
+        return ret
+        """Undo action
+        @param level levels to undo (0 to revert all)
+        @return id of current changeset
+        try:
+            ret = self.digit.Undo(level)
+        except SystemExit:
+            ret = -2
+        if ret == -2:
+            raise gcmd.DigitError, _("Undo failed, data corrupted.")
+        self.mapWindow.UpdateMap(render=False)
+        if ret < 0: # disable undo tool
+            self.toolbar.EnableUndo(False)
+    def __getSnapThreshold(self):
+        """Get snap mode and threshold value
+        @return (snap, thresh)
+        thresh = self.driver.GetThreshold()
+        if thresh > 0.0:
+                snap = wxvdigit.SNAPVERTEX
+            else:
+        else:
+            snap = v.digit.NO_SNAP
+        return (snap, thresh)
+if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit':
+    class Digit(VEdit):
+        """Default digit class"""
+            VEdit.__init__(self, mapwindow)
+            self.type = 'vedit'
+else:
+    class Digit(VDigit):
+            VDigit.__init__(self, mapwindow)
+            self.type = 'vdigit'
+            VDigit.__del__(self)
+class AbstractDisplayDriver:
+    """Abstract classs for display driver"""
+    def __init__(self, parent, mapwindow):
+        """Initialization
+        @param parent
+        @param mapwindow reference to mapwindow (MFrame)
+        self.parent      = parent
+        self.mapwindow   = mapwindow
+        self.ids         = {}   # dict[g6id] = [pdcId]
+        self.selected    = []   # list of selected objects (grassId!)
+    def GetThreshold(self, type='snapping', value=None, units=None):
+        """Return threshold in map units
+        @param value threshold to be set up
+        @param units units (map, screen)
+        if not value:
+            value = UserSettings.Get(group='vdigit', key=type, subkey='value')
+        if not units:
+            units = UserSettings.Get(group='vdigit', key=type, subkey='units')
+        if units == "screen pixels":
+            # pixel -> cell
+            reg = self.mapwindow.Map.region
+            if reg['nsres'] > reg['ewres']:
+                res = reg['nsres']
+            else:
+                res = reg['ewres']
+            threshold = value * res
+        else:
+            threshold = value
+        Debug.msg(4, "AbstractDisplayDriver.GetThreshold(): type=%s, thresh=%f" % (type, threshold))
+        return threshold
+class CDisplayDriver(AbstractDisplayDriver):
+    Display driver using grass6_wxdriver module
+        """Initialization
+        @param parent
+        AbstractDisplayDriver.__init__(self, parent, mapwindow)
+        # initialize wx display driver
+        try:
+            self.__display = wxvdigit.DisplayDriver(mapwindow.pdcVector)
+        except:
+            self.__display = None
+        self.UpdateSettings()
+    def GetDevice(self):
+        """Get device"""
+        return self.__display
+    def SetDevice(self, pdc):
+        """Set device for driver
+        @param pdc wx.PseudoDC instance
+        self.__display.SetDevice(pdc)
+    def Reset(self, map):
+        """Reset map
+        Open or close the vector map by driver.
+        @param map map name or None to close the map
+        @return 0 on success (close map)
+        @return topo level on success (open map)
+        @return non-zero (close map)
+        @return -1 on error (open map)
+        if map:
+            name, mapset = map.split('@')
+            try:
+                    ret = self.__display.OpenMap(str(name), str(mapset), False)
+                else:
+                    ret = self.__display.OpenMap(str(name), str(mapset), True)
+                ret = -1
+        else:
+            ret = self.__display.CloseMap()
+        return ret
+    def ReloadMap(self):
+        """Reload map (close and re-open).
+        Needed for v.edit, TODO: get rid of that..."""
+        Debug.msg(4, "CDisplayDriver.ReloadMap():")
+        self.__display.ReloadMap()
+    def DrawMap(self):
+        """Draw vector map layer content
+        @return wx.Image instance
+        nlines = self.__display.DrawMap(True) # force
+        Debug.msg(3, "CDisplayDriver.DrawMap(): nlines=%d" % nlines)
+        return nlines
+    def SelectLinesByBox(self, begin, end, type=0):
+        """Select vector features by given bounding box.
+        If type is given, only vector features of given type are selected.
+        @param begin,end bounding box definition
+        @param type      select only objects of given type
+        x1, y1 = begin
+        x2, y2 = end
+        nselected = self.__display.SelectLinesByBox(x1, y1, -1.0 * wxvdigit.PORT_DOUBLE_MAX,
+                                                    x2, y2, wxvdigit.PORT_DOUBLE_MAX,
+                                                    type)
+        Debug.msg(4, "CDisplayDriver.SelectLinesByBox(): selected=%d" % \
+                      nselected)
+        return nselected
+    def SelectLineByPoint(self, point, type=0):
+        """Select vector feature by coordinates of click point (in given threshold).
+        @param point click coordinates (bounding box given by threshold)
+        pointOnLine = self.__display.SelectLineByPoint(point[0], point[1], 0.0,
+                                                       self.GetThreshold(type='selectThresh'),
+                                                       type, 0); # without_z
+        if len(pointOnLine) > 0:
+            Debug.msg(4, "CDisplayDriver.SelectLineByPoint(): pointOnLine=%f,%f" % \
+                          (pointOnLine[0], pointOnLine[1]))
+            return pointOnLine
+        else:
+            Debug.msg(4, "CDisplayDriver.SelectLineByPoint(): no line found")
+            return None
+    def GetSelected(self, grassId=True):
+        """Return ids of selected vector features
+        @param grassId if grassId is True returns GRASS ids, otherwise
+        internal ids of objects drawn in PseudoDC"""
+        if grassId:
+            selected = self.__display.GetSelected(True)
+        else:
+            selected = self.__display.GetSelected(False)
+        Debug.msg(4, "CDisplayDriver.GetSelected(): grassId=%d, ids=%s" % \
+                      (grassId, (",".join(["%d" % v for v in selected]))))
+        return selected
+    def GetSelectedVertex(self, coords):
+        """Get PseudoDC id(s) of vertex (of selected line)
+        on position 'coords'
+        @param coords click position
+        x, y = coords
+        id = self.__display.GetSelectedVertex(x, y, self.GetThreshold(type='selectThresh'))
+        Debug.msg(4, "CDisplayDriver.GetSelectedVertex(): id=%s" % \
+                      (",".join(["%d" % v for v in id])))
+        return id
+    def SetSelected(self, id):
+        """Set selected vector features
+        @param id line id to be selected
+        Debug.msg(4, "CDisplayDriver.SetSelected(): id=%s" % \
+                  ",".join(["%d" % v for v in id]))
+        self.__display.SetSelected(id)
+    def UpdateRegion(self):
+        """Set geographical region
+        Needed for 'cell2pixel' conversion"""
+        map = self.mapwindow.Map
+        reg = map.region
+        self.__display.SetRegion(reg['n'],
+                                 reg['s'],
+                                 reg['e'],
+                                 reg['w'],
+                                 reg['nsres'],
+                                 reg['ewres'],
+                                 reg['center_easting'],
+                                 reg['center_northing'],
+                                 map.width, map.height)
+    def GetMapBoundingBox(self):
+        """Return bounding box of given vector map layer
+        @return (w,s,b,e,n,t)
+        return self.__display.GetMapBoundingBox()
+    def UpdateSettings(self):
+        """Update display driver settings"""
+        # TODO map units
+        if not self.__display:
+            return
+        self.__display.UpdateSettings (wx.Color(UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[2],
+                                                255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='symbolPoint', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[2],
+                                                255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='symbolLine', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[2],
+                                           255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[2],
+                                                255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[2],
+                                                255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[2],
+                                                255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[2],
+                                                255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[2],
+                                                255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[2],
+                                                255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[2],
+                                                255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[2],
+                                                255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='symbolVertex', subkey='enabled'),
+                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[0],
+                                                UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[1],
+                                                UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[2],
+                                                255).GetRGB(),
+                                       UserSettings.Get(group='vdigit', key='lineWidth', subkey='value'))
+class VDigitSettingsDialog(wx.Dialog):
+    Standard settings dialog for digitization purposes
+    def __init__(self, parent, title, style=wx.DEFAULT_DIALOG_STYLE):
+        wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=title, style=style)
+        self.parent = parent # mapdisplay.BufferedWindow class instance
+        # notebook
+        notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+        self.__CreateSymbologyPage(notebook)
+        parent.digit.SetCategory() # update category number (next to use)
+        self.__CreateGeneralPage(notebook)
+        self.__CreateAttributesPage(notebook)
+        self.__CreateQueryPage(notebook)
+        # buttons
+        btnApply = wx.Button(self, wx.ID_APPLY)
+        btnCancel = wx.Button(self, wx.ID_CANCEL)
+        btnSave = wx.Button(self, wx.ID_SAVE)
+        btnSave.SetDefault()
+        # bindigs
+        btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+        btnApply.SetToolTipString(_("Apply changes for this session"))
+        btnApply.SetDefault()
+        btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
+        btnSave.SetToolTipString(_("Close dialog and save changes to user settings file"))
+        btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+        btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
+        # sizers
+        btnSizer = wx.StdDialogButtonSizer()
+        btnSizer.AddButton(btnCancel)
+        btnSizer.AddButton(btnApply)
+        btnSizer.AddButton(btnSave)
+        btnSizer.Realize()
+        mainSizer = wx.BoxSizer(wx.VERTICAL)
+        mainSizer.Add(item=notebook, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
+        mainSizer.Add(item=btnSizer, proportion=0,
+                      flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+        self.SetSizer(mainSizer)
+        mainSizer.Fit(self)
+    def __CreateSymbologyPage(self, notebook):
+        """Create notebook page concerning with symbology settings"""
+        panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
+        notebook.AddPage(page=panel, text=_("Symbology"))
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        flexSizer = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
+        flexSizer.AddGrowableCol(0)
+        self.symbology = {}
+        for label, key in self.__SymbologyData():
+            textLabel = wx.StaticText(panel, wx.ID_ANY, label)
+            color = csel.ColourSelect(panel, id=wx.ID_ANY,
+                                      colour=UserSettings.Get(group='vdigit', key=key, subkey='color'), size=(25, 25))
+            isEnabled = UserSettings.Get(group='vdigit', key=key, subkey='enabled')
+            if isEnabled is not None:
+                enabled = wx.CheckBox(panel, id=wx.ID_ANY, label="")
+                enabled.SetValue(isEnabled)
+                self.symbology[key] = (enabled, color)
+            else:
+                enabled = (1, 1)
+                self.symbology[key] = (None, color)
+            flexSizer.Add(textLabel, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+            flexSizer.Add(enabled, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+            flexSizer.Add(color, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+        sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=10)
+        panel.SetSizer(sizer)
+        return panel
+    def __CreateGeneralPage(self, notebook):
+        notebook.AddPage(page=panel, text=_("General"))
+        border = wx.BoxSizer(wx.VERTICAL)
+        # display section
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Display"))
+        sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        # line width
+        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Line width"))
+        self.lineWidthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
+                                          initial=UserSettings.Get(group='vdigit', key="lineWidth", subkey='value'),
+                                          min=1, max=1e6)
+        units = wx.StaticText(parent=panel, id=wx.ID_ANY, size=(115, -1),
+                              label=UserSettings.Get(group='vdigit', key="lineWidth", subkey='units'),
+                              style=wx.ALIGN_LEFT)
+        flexSizer.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+        flexSizer.Add(self.lineWidthValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+        flexSizer.Add(units, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL | wx.LEFT,
+                      border=10)
+        sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=1)
+        border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
+        # snapping section
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Snapping"))
+        flexSizer1 = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
+        flexSizer1.AddGrowableCol(0)
+        flexSizer2 = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
+        flexSizer2.AddGrowableCol(0)
+        # snapping
+        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Snapping threshold"))
+        self.snappingValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
+                                         initial=UserSettings.Get(group='vdigit', key="snapping", subkey='value'),
+                                         min=1, max=1e6)
+        self.snappingValue.Bind(wx.EVT_SPINCTRL, self.OnChangeSnappingValue)
+        self.snappingUnit = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+                                      choices=["screen pixels", "map units"])
+        self.snappingUnit.SetStringSelection(UserSettings.Get(group='vdigit', key="snapping", subkey='units'))
+        self.snappingUnit.Bind(wx.EVT_CHOICE, self.OnChangeSnappingUnits)
+        flexSizer1.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+        flexSizer1.Add(self.snappingValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+        flexSizer1.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+        # background map
+        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Backgroud vector map"))
+        self.backgroundMap = gselect.Select(parent=panel, id=wx.ID_ANY, size=(200,-1),
+                                           type="vector")
+        self.backgroundMap.SetValue(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value'))
+        self.backgroundMap.Bind(wx.EVT_TEXT, self.OnChangeBackgroundMap)
+        flexSizer2.Add(text, proportion=1, flag=wx.ALIGN_CENTER_VERTICAL)
+        flexSizer2.Add(self.backgroundMap, proportion=1, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+        #flexSizer.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+        vertexSizer = wx.BoxSizer(wx.VERTICAL)
+        self.snapVertex = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                      label=_("Snap also to vertex"))
+        self.snapVertex.SetValue(UserSettings.Get(group='vdigit', key="snapToVertex", subkey='enabled'))
+        vertexSizer.Add(item=self.snapVertex, proportion=0, flag=wx.EXPAND)
+        self.mapUnits = self.parent.MapWindow.Map.ProjInfo()['units']
+        self.snappingInfo = wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                          label=_("Snapping threshold is %(value).1f %(units)s") % \
+                                              {'value' : self.parent.digit.driver.GetThreshold(),
+                                               'units' : self.mapUnits})
+        vertexSizer.Add(item=self.snappingInfo, proportion=0,
+                        flag=wx.ALL | wx.EXPAND, border=1)
+        sizer.Add(item=flexSizer1, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
+        sizer.Add(item=flexSizer2, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
+        sizer.Add(item=vertexSizer, proportion=1, flag=wx.BOTTOM | wx.LEFT | wx.EXPAND, border=1)
+        border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
+        # select box
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Select vector features"))
+        # feature type
+        inSizer = wx.BoxSizer(wx.HORIZONTAL)
+        self.selectFeature = {}
+        for feature in ('Point', 'Line',
+                        'Centroid', 'Boundary'):
+            chkbox = wx.CheckBox(parent=panel, label=feature)
+            self.selectFeature[feature] = chkbox.GetId()
+            chkbox.SetValue(UserSettings.Get(group='vdigit', key='selectFeature'+feature, subkey='enabled'))
+            inSizer.Add(item=chkbox, proportion=0,
+                        flag=wx.EXPAND | wx.ALL, border=5)
+        sizer.Add(item=inSizer, proportion=0, flag=wx.EXPAND)
+        # threshold
+        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select threshold"))
+        self.selectThreshValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
+                                             initial=UserSettings.Get(group='vdigit', key="selectThresh", subkey='value'),
+                                             min=1, max=1e6)
+        flexSizer.Add(self.selectThreshValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+                      border=10)
+        sizer.Add(item=flexSizer, proportion=0, flag=wx.EXPAND)
+        border.Add(item=sizer, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
+        # save-on-exit box
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Save changes"))
+        # save changes on exit?
+        self.save = wx.CheckBox(parent=panel, label=_("Save changes on exit automatically"))
+        self.save.SetValue(UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled'))
+        sizer.Add(item=self.save, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+        panel.SetSizer(border)
+        return panel
+    def __CreateQueryPage(self, notebook):
+        """Create notebook page for query tool"""
+        notebook.AddPage(page=panel, text=_("Query tool"))
+        # query tool box
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Choose query tool"))
+        LocUnits = self.parent.MapWindow.Map.ProjInfo()['units']
+        self.queryBox = wx.CheckBox(parent=panel, id=wx.ID_ANY, label=_("Select by box"))
+        self.queryBox.SetValue(UserSettings.Get(group='vdigit', key="query", subkey='box'))
+        sizer.Add(item=self.queryBox, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+        sizer.Add((0, 5))
+        # length
+        self.queryLength = wx.RadioButton(parent=panel, id=wx.ID_ANY, label=_("length"))
+        self.queryLength.Bind(wx.EVT_RADIOBUTTON, self.OnChangeQuery)
+        sizer.Add(item=self.queryLength, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+        flexSizer = wx.FlexGridSizer (cols=4, hgap=5, vgap=5)
+        txt = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select lines"))
+        self.queryLengthSL = wx.Choice (parent=panel, id=wx.ID_ANY,
+                                        choices = [_("shorter than"), _("longer than")])
+        self.queryLengthSL.SetStringSelection(UserSettings.Get(group='vdigit', key="queryLength", subkey='than'))
+        self.queryLengthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
+                                            initial=1,
+                                            min=0, max=1e6)
+        self.queryLengthValue.SetValue(UserSettings.Get(group='vdigit', key="queryLength", subkey='thresh'))
+        units = wx.StaticText(parent=panel, id=wx.ID_ANY, label="%s" % LocUnits)
+        flexSizer.Add(txt, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+        flexSizer.Add(self.queryLengthSL, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+        flexSizer.Add(self.queryLengthValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+        flexSizer.Add(units, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+        sizer.Add(item=flexSizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+        # dangle
+        self.queryDangle = wx.RadioButton(parent=panel, id=wx.ID_ANY, label=_("dangle"))
+        self.queryDangle.Bind(wx.EVT_RADIOBUTTON, self.OnChangeQuery)
+        sizer.Add(item=self.queryDangle, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+        txt = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select dangles"))
+        self.queryDangleSL = wx.Choice (parent=panel, id=wx.ID_ANY,
+        self.queryDangleSL.SetStringSelection(UserSettings.Get(group='vdigit', key="queryDangle", subkey='than'))
+        self.queryDangleValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
+                                       initial=1,
+                                       min=0, max=1e6)
+        self.queryDangleValue.SetValue(UserSettings.Get(group='vdigit', key="queryDangle", subkey='thresh'))
+        flexSizer.Add(self.queryDangleSL, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+        flexSizer.Add(self.queryDangleValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+        if UserSettings.Get(group='vdigit', key="query", subkey='type') == "length":
+            self.queryLength.SetValue(True)
+        else:
+            self.queryDangle.SetValue(True)
+        # enable & disable items
+        self.OnChangeQuery(None)
+        return panel
+    def __CreateAttributesPage(self, notebook):
+        notebook.AddPage(page=panel, text=_("Attributes"))
+        # add new record
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Digitize new feature"))
+        # checkbox
+        self.addRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                     label=_("Add new record into table"))
+        self.addRecord.SetValue(UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled'))
+        sizer.Add(item=self.addRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+        # settings
+        flexSizer = wx.FlexGridSizer(cols=2, hgap=3, vgap=3)
+        settings = ((_("Layer"), 1), (_("Category"), 1), (_("Mode"), _("Next to use")))
+        # layer
+        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Layer"))
+        if self.parent.digit.map:
+            layers = map(str, self.parent.digit.GetLayers())
+            if len(layers) == 0:
+                layers = [str(UserSettings.Get(group='vdigit', key="layer", subkey='value')), ]
+        else:
+        self.layer = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+                               choices=layers)
+        self.layer.SetStringSelection(str(UserSettings.Get(group='vdigit', key="layer", subkey='value')))
+        flexSizer.Add(item=text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+        flexSizer.Add(item=self.layer, proportion=0,
+                      flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
+        # category number
+        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category number"))
+        self.category = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
+                                    initial=UserSettings.Get(group='vdigit', key="category", subkey='value'),
+                                    min=-1e9, max=1e9)
+        if UserSettings.Get(group='vdigit', key="categoryMode", subkey='value') != "Manual entry":
+            self.category.Enable(False)
+        flexSizer.Add(item=self.category, proportion=0,
+        # category mode
+        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category mode"))
+        self.categoryMode = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+                                      choices=[_("Next to use"), _("Manual entry"), _("No category")])
+        self.categoryMode.SetStringSelection(UserSettings.Get(group='vdigit', key="categoryMode", subkey='value'))
+        flexSizer.Add(item=self.categoryMode, proportion=0,
+                   flag=wx.ALL | wx.EXPAND, border=5)
+        # delete existing record
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Delete existing feature(s)"))
+        # checkbox
+        self.deleteRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                        label=_("Delete record from table"))
+        self.deleteRecord.SetValue(UserSettings.Get(group='vdigit', key="delRecord", subkey='enabled'))
+        sizer.Add(item=self.deleteRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+                   flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
+        # bindings
+        self.Bind(wx.EVT_CHECKBOX, self.OnChangeAddRecord, self.addRecord)
+        self.Bind(wx.EVT_CHOICE, self.OnChangeCategoryMode, self.categoryMode)
+        self.Bind(wx.EVT_CHOICE, self.OnChangeLayer, self.layer)
+        return panel
+    def __SymbologyData(self):
+        Data for __CreateSymbologyPage()
+        label | checkbox | color
+        return (
+            #            ("Background", "symbolBackground"),
+            ("Highlight", "symbolHighlight"),
+            ("Point", "symbolPoint"),
+            ("Line", "symbolLine"),
+            ("Boundary (no area)", "symbolBoundaryNo"),
+            ("Boundary (one area)", "symbolBoundaryOne"),
+            ("Boundary (two areas)", "symbolBoundaryTwo"),
+            ("Centroid (in area)", "symbolCentroidIn"),
+            ("Centroid (outside area)", "symbolCentroidOut"),
+            ("Centroid (duplicate in area)", "symbolCentroidDup"),
+            ("Node (one line)", "symbolNodeOne"),
+            ("Node (two lines)", "symbolNodeTwo"),
+            ("Vertex", "symbolVertex"))
+    def OnChangeCategoryMode(self, event):
+        """Change category mode"""
+        mode = event.GetString()
+        UserSettings.Set(group='vdigit', key="categoryMode", subkey='value', value=mode)
+        if mode == "Manual entry": # enable
+            self.category.Enable(True)
+        elif self.category.IsEnabled(): # disable
+        if mode == "No category" and self.addRecord.IsChecked():
+            self.addRecord.SetValue(False)
+        self.parent.digit.SetCategory()
+        self.category.SetValue(UserSettings.Get(group='vdigit', key='category', subkey='value'))
+    def OnChangeLayer(self, event):
+        """Layer changed"""
+        layer = int(event.GetString())
+        if layer > 0:
+            UserSettings.Set(group='vdigit', key='layer', subkey='value', value=layer)
+        event.Skip()
+    def OnChangeAddRecord(self, event):
+        """Checkbox 'Add new record' status changed"""
+        self.category.SetValue(self.parent.digit.SetCategory())
+    def OnChangeSnappingValue(self, event):
+        """Change snapping value - update static text"""
+        value = self.snappingValue.GetValue()
+        if self.snappingUnit.GetStringSelection() == "map units":
+            threshold = value
+        else:
+            threshold = self.parent.digit.driver.GetThreshold(value=value)
+        self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(units)s") %
+                                   {'value' : threshold,
+        event.Skip()
+    def OnChangeSnappingUnits(self, event):
+        """Snapping units change -> update static text"""
+        units = self.snappingUnit.GetStringSelection()
+        threshold = self.parent.digit.driver.GetThreshold(value=value, units=units)
+        if units == "map units":
+                                       {'value' : value,
+        else:
+        event.Skip()
+    def OnChangeBackgroundMap(self, event):
+        """Change background map"""
+        map = self.backgroundMap.GetValue()
+        UserSettings.Set(group='vdigit', key='backgroundMap', subkey='value', value=map)
+    def OnChangeQuery(self, event):
+        """Change query"""
+        if self.queryLength.GetValue():
+            # length
+            self.queryLengthSL.Enable(True)
+            self.queryLengthValue.Enable(True)
+            self.queryDangleSL.Enable(False)
+            self.queryDangleValue.Enable(False)
+        else:
+            # dangle
+            self.queryLengthSL.Enable(False)
+            self.queryLengthValue.Enable(False)
+            self.queryDangleSL.Enable(True)
+            self.queryDangleValue.Enable(True)
+    def OnSave(self, event):
+        """Button 'Save' clicked"""
+        self.parent.digittoolbar.settingsDialog = None
+        fileSettings = {}
+        UserSettings.ReadSettingsFile(settings=fileSettings)
+        fileSettings['vdigit'] = UserSettings.Get(group='vdigit')
+        file = UserSettings.SaveToFile(fileSettings)
+        self.parent.gismanager.goutput.WriteLog('Vector digitizer settings saved to file <%s>.' % file)
+        self.Close()
+    def OnApply(self, event):
+        """Button 'Apply' clicked"""
+    def OnCancel(self, event):
+        """Button 'Cancel' clicked"""
+        self.Close()
+        """Update UserSettings"""
+        # symbology
+        for key, (enabled, color) in self.symbology.iteritems():
+            if enabled:
+                UserSettings.Set(group='vdigit', key=key, subkey='enabled', value=enabled.IsChecked())
+                UserSettings.Set(group='vdigit', key=key, subkey='color', value=color.GetColour())
+            else:
+        # display
+        UserSettings.Set(group='vdigit', key="lineWidth", subkey='value', value=int(self.lineWidthValue.GetValue()))
+        # snapping
+        UserSettings.Set(group='vdigit', key="snapping", subkey='value', value=int(self.snappingValue.GetValue()))
+        UserSettings.Set(group='vdigit', key="snapping", subkey='units', value=self.snappingUnit.GetStringSelection())
+        UserSettings.Set(group='vdigit', key="snapToVertex", subkey='enabled', value=self.snapVertex.IsChecked())
+        # digitize new feature
+        UserSettings.Set(group='vdigit', key="addRecord", subkey='enabled', value=self.addRecord.IsChecked())
+        UserSettings.Set(group='vdigit', key="layer", subkey='value', value=int(self.layer.GetStringSelection()))
+            UserSettings.Set(group='vdigit', key="category", subkey='value', value=None)
+        else:
+            UserSettings.Set(group='vdigit', key="category", subkey='value', value=int(self.category.GetValue()))
+        UserSettings.Set(group='vdigit', key="categoryMode", subkey='value', value=self.categoryMode.GetStringSelection())
+        # delete existing feature
+        UserSettings.Set(group='vdigit', key="delRecord", subkey='enabled', value=self.deleteRecord.IsChecked())
+        # snapping threshold
+        self.parent.digit.threshold = self.parent.digit.driver.GetThreshold()
+        # query tool
+            UserSettings.Set(group='vdigit', key="query", subkey='type', value="length")
+        else:
+            UserSettings.Set(group='vdigit', key="query", subkey='type', value="dangle")
+        UserSettings.Set(group='vdigit', key="query", subkey='box', value=self.queryBox.IsChecked())
+        UserSettings.Set(group='vdigit', key="queryLength", subkey='than', value=self.queryLengthSL.GetStringSelection())
+        UserSettings.Set(group='vdigit', key="queryLength", subkey='thresh', value=int(self.queryLengthValue.GetValue()))
+        UserSettings.Set(group='vdigit', key="queryDangle", subkey='than', value=self.queryDangleSL.GetStringSelection())
+        UserSettings.Set(group='vdigit', key="queryDangle", subkey='thresh', value=int(self.queryDangleValue.GetValue()))
+        # select features
+            UserSettings.Set(group='vdigit', key='selectFeature'+feature, subkey='enabled',
+                                           value=self.FindWindowById(self.selectFeature[feature]).IsChecked())
+        UserSettings.Set(group='vdigit', key="selectThresh", subkey='value', value=int(self.selectThreshValue.GetValue()))
+        # on-exit
+        UserSettings.Set(group='vdigit', key="saveOnExit", subkey='enabled', value=self.save.IsChecked())
+        # update driver settings
+        self.parent.digit.driver.UpdateSettings()
+        # redraw map if auto-rendering is enabled
+        if self.parent.autoRender.GetValue():
+            self.parent.OnRender(None)
+class VDigitCategoryDialog(wx.Dialog, listmix.ColumnSorterMixin):
+    Dialog used to display/modify categories of vector objects
+    @param parent
+    @param title dialog title
+    @param query {coordinates, qdist}    - v.edit/v.what
+    @param cats  directory of categories - vdigit
+    @param line  line id                 - vdigit
+    @param pos
+    @param style
+                 map, query=None, cats=None, line=None,
+                 pos=wx.DefaultPosition,
+                 style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+        # parent
+        # map name
+        self.map = map
+        # line id (if not found remains 'None')
+        self.line = None
+        # {layer: [categories]}
+        self.cats = {}
+        # do not display dialog if no line is found (-> self.cats)
+        if cats is None:
+            if self.__GetCategories(query[0], query[1]) == 0 or not self.line:
+                Debug.msg(3, "VDigitCategoryDialog(): nothing found!")
+                return
+        else:
+            # self.cats = dict(cats)
+            for layer in cats.keys():
+                self.cats[layer] = list(cats[layer]) # TODO: tuple to list
+            self.line = line
+        # make copy of cats (used for 'reload')
+        self.cats_orig = copy.deepcopy(self.cats)
+        Debug.msg(3, "VDigitCategoryDialog(): line=%d, cats=%s" % \
+                      (self.line, self.cats))
+        wx.Dialog.__init__(self, parent=self.parent, id=wx.ID_ANY, title=title,
+                           style=style, pos=pos)
+        # list of categories
+        box = wx.StaticBox(parent=self, id=wx.ID_ANY,
+                           label=" %s " % _("List of categories"))
+        listSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        self.list = CategoryListCtrl(parent=self, id=wx.ID_ANY,
+                                     style=wx.LC_REPORT |
+                                     wx.BORDER_NONE |
+                                     wx.LC_SORT_ASCENDING |
+                                     wx.LC_HRULES |
+                                     wx.LC_VRULES)
+        # sorter
+        self.itemDataMap = self.list.Populate()
+        listmix.ColumnSorterMixin.__init__(self, 2)
+        listSizer.Add(item=self.list, proportion=1, flag=wx.EXPAND)
+        # add new category
+                           label=" %s " % _("Add new category"))
+        addSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        flexSizer = wx.FlexGridSizer (cols=5, hgap=5, vgap=5)
+        flexSizer.AddGrowableCol(3)
+        layerNewTxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                 label="%s:" % _("Layer"))
+        self.layerNew = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(50, -1),
+                                    initial=1, min=1, max=1e9)
+        catNewTxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+                               label="%s:" % _("Category"))
+        try:
+            newCat = max(self.cats[1]) + 1
+        except:
+            newCat = 1
+        self.catNew = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(75, -1),
+                                  initial=newCat, min=-1e9, max=1e9)
+        btnAddCat = wx.Button(self, wx.ID_ADD)
+        flexSizer.Add(item=layerNewTxt, proportion=0,
+        flexSizer.Add(item=self.layerNew, proportion=0,
+        flexSizer.Add(item=catNewTxt, proportion=0,
+                      flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT,
+                      border=10)
+        flexSizer.Add(item=self.catNew, proportion=0,
+        flexSizer.Add(item=btnAddCat, proportion=0,
+                      flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+        addSizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+        # buttons
+        #btnReload = wx.Button(self, wx.ID_UNDO, _("&Reload"))
+        btnOk = wx.Button(self, wx.ID_OK)
+        btnOk.SetDefault()
+        # sizers
+        #btnSizer.AddButton(btnReload)
+        #btnSizer.SetNegativeButton(btnReload)
+        btnSizer.AddButton(btnOk)
+        mainSizer.Add(item=listSizer, proportion=1,
+        mainSizer.Add(item=addSizer, proportion=0,
+                      flag=wx.EXPAND | wx.ALIGN_CENTER |
+                      wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
+        self.SetAutoLayout(True)
+        # set min size for dialog
+        self.SetMinSize(self.GetBestSize())
+        # bindings
+        # buttons
+        #btnReload.Bind(wx.EVT_BUTTON, self.OnReload)
+        btnOk.Bind(wx.EVT_BUTTON, self.OnOK)
+        btnAddCat.Bind(wx.EVT_BUTTON, self.OnAddCat)
+        # list
+        # self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected, self.list)
+        # self.list.Bind(wx.EVT_RIGHT_DOWN, self.OnRightDown)
+        self.list.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnRightUp) #wxMSW
+        self.list.Bind(wx.EVT_RIGHT_UP, self.OnRightUp) #wxGTK
+        self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnBeginEdit, self.list)
+        self.Bind(wx.EVT_LIST_END_LABEL_EDIT, self.OnEndEdit, self.list)
+        self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColClick, self.list)
+    def GetListCtrl(self):
+        """Used by ColumnSorterMixin"""
+        return self.list
+    def OnColClick(self, event):
+        """Click on column header (order by)"""
+        event.Skip()
+    def OnBeginEdit(self, event):
+        """Editing of item started"""
+        event.Allow()
+    def OnEndEdit(self, event):
+        """Finish editing of item"""
+        itemIndex = event.GetIndex()
+        layerOld = int (self.list.GetItem(itemIndex, 0).GetText())
+        catOld = int (self.list.GetItem(itemIndex, 1).GetText())
+        if event.GetColumn() == 0:
+            layerNew = int(event.GetLabel())
+            catNew = catOld
+        else:
+            layerNew = layerOld
+            catNew = int(event.GetLabel())
+        try:
+            if layerNew not in self.cats.keys():
+                self.cats[layerNew] = []
+            self.cats[layerNew].append(catNew)
+            self.cats[layerOld].remove(catOld)
+        except:
+            event.Veto()
+            self.list.SetStringItem(itemIndex, 0, str(layerNew))
+            self.list.SetStringItem(itemIndex, 1, str(catNew))
+            dlg = wx.MessageDialog(self, _("Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+                                           "Layer and category number must be integer.\n"
+                                           "Layer number must be greater then zero.") %
+                                   { 'layer': str(self.layerNew.GetValue()),
+                                     'category' : str(self.catNew.GetValue()) },
+                                   _("Error"), wx.OK | wx.ICON_ERROR)
+            dlg.ShowModal()
+            dlg.Destroy()
+            return False
+    def OnRightDown(self, event):
+        """Mouse right button down"""
+        x = event.GetX()
+        y = event.GetY()
+        item, flags = self.list.HitTest((x, y))
+        if item !=  wx.NOT_FOUND and \
+                flags & wx.LIST_HITTEST_ONITEM:
+            self.list.Select(item)
+        event.Skip()
+    def OnRightUp(self, event):
+        """Mouse right button up"""
+        if not hasattr(self, "popupID1"):
+            self.popupID1 = wx.NewId()
+            self.popupID2 = wx.NewId()
+            self.popupID3 = wx.NewId()
+            self.Bind(wx.EVT_MENU, self.OnItemDelete,    id=self.popupID1)
+            self.Bind(wx.EVT_MENU, self.OnItemDeleteAll, id=self.popupID2)
+            self.Bind(wx.EVT_MENU, self.OnReload, id=self.popupID3)
+        # generate popup-menu
+        menu = wx.Menu()
+        menu.Append(self.popupID1, _("Delete selected"))
+        if self.list.GetFirstSelected() == -1:
+            menu.Enable(self.popupID1, False)
+        menu.Append(self.popupID2, _("Delete all"))
+        menu.AppendSeparator()
+        menu.Append(self.popupID3, _("Reload"))
+        self.PopupMenu(menu)
+        menu.Destroy()
+    def OnItemSelected(self, event):
+        """Item selected"""
+        event.Skip()
+    def OnItemDelete(self, event):
+        """Delete selected item(s) from the list (layer/category pair)"""
+        item = self.list.GetFirstSelected()
+        while item != -1:
+            layer = int (self.list.GetItem(item, 0).GetText())
+            cat = int (self.list.GetItem(item, 1).GetText())
+            self.list.DeleteItem(item)
+            self.cats[layer].remove(cat)
+        event.Skip()
+    def OnItemDeleteAll(self, event):
+        """Delete all items from the list"""
+        self.list.DeleteAllItems()
+        self.cats = {}
+        event.Skip()
+    def __GetCategories(self, coords, qdist):
+        """Get layer/category pairs for all available
+        layers
+        Return True line found or False if not found"""
+        cmdWhat = gcmd.Command(cmd=['v.what',
+                                   '--q',
+                                   'east_north=%f,%f' % \
+                                       (float(coords[0]), float(coords[1])),
+                                   'distance=%f' % qdist])
+        if cmdWhat.returncode != 0:
+            return False
+        for item in cmdWhat.ReadStdOutput():
+            litem = item.lower()
+            if "line:" in litem: # get line id
+                self.line = int(item.split(':')[1].strip())
+            elif "layer:" in litem: # add layer
+                layer = int(item.split(':')[1].strip())
+                if layer not in self.cats.keys():
+                    self.cats[layer] = []
+            elif "category:" in litem: # add category
+                self.cats[layer].append(int(item.split(':')[1].strip()))
+        return True
+    def OnReload(self, event):
+        """Reload button pressed"""
+        # restore original list
+        self.cats = copy.deepcopy(self.cats_orig)
+        # polulate list
+        self.itemDataMap = self.list.Populate(update=True)
+        event.Skip()
+        """Cancel button pressed"""
+        self.parent.parent.dialogs['category'] = None
+        if self.parent.parent.digit:
+            self.parent.parent.digit.driver.SetSelected([])
+            self.parent.UpdateMap(render=False)
+        else:
+            self.parent.parent.OnRender(None)
+        self.Close()
+        """Apply button pressed"""
+        # action : (catsFrom, catsTo)
+        check = {'catadd': (self.cats,      self.cats_orig),
+                 'catdel': (self.cats_orig, self.cats)}
+        # add/delete new category
+        for action, cats in check.iteritems():
+            for layer in cats[0].keys():
+                catList = []
+                for cat in cats[0][layer]:
+                    if layer not in cats[1].keys() or \
+                            cat not in cats[1][layer]:
+                        catList.append(cat)
+                if catList != []:
+                        vEditCmd = ['v.edit', '--q',
+                                    'tool=%s' % action,
+                                    'cats=%s' % ",".join(["%d" % v for v in catList]),
+                                    'id=%d' % self.line]
+                        gcmd.Command(vEditCmd)
+                    else:
+                        if action == 'catadd':
+                            add = True
+                        else:
+                            add = False
+                        self.line = self.parent.parent.digit.SetLineCats(-1, layer,
+        catList, add)
+                        if self.line < 0:
+                            wx.MessageBox(parent=self, message=_("Unable to update vector map."),
+                                          caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
+            self.parent.parent.digit.driver.ReloadMap()
+        event.Skip()
+    def OnOK(self, event):
+        """OK button pressed"""
+        self.OnApply(event)
+        self.OnCancel(event)
+    def OnAddCat(self, event):
+        """Button 'Add' new category pressed"""
+        try:
+            layer = int(self.layerNew.GetValue())
+            cat   = int(self.catNew.GetValue())
+            if layer <= 0:
+                raise ValueError
+        except ValueError:
+                                   {'layer' : str(self.layerNew.GetValue()),
+                                    'category' : str(self.catNew.GetValue())},
+            dlg.ShowModal()
+            dlg.Destroy()
+            return False
+        self.cats[layer].append(cat)
+        # reload list
+        # update category number for add
+        self.catNew.SetValue(cat + 1)
+        event.Skip()
+        return True
+    def GetLine(self):
+        """Get id of selected line of 'None' if no line is selected"""
+        return self.line
+    def UpdateDialog(self, query=None, cats=None, line=None):
+        """Update dialog
+        @param query {coordinates, distance} - v.edit/v.what
+        @param cats  directory layer/cats    - vdigit
+        Return True if updated otherwise False
+        self.line = None
+        self.cats = {}
+        if cats is None:
+            ret = self.__GetCategories(query[0], query[1])
+        else:
+            self.line = line
+            ret = 1
+        if ret == 0 or not self.line:
+            return False
+        # polulate list
+        try:
+        except:
+            newCat = 1
+        self.catNew.SetValue(newCat)
+        return True
+class CategoryListCtrl(wx.ListCtrl,
+                       listmix.ListCtrlAutoWidthMixin,
+                       listmix.TextEditMixin):
+    """List of layers/categories"""
+    def __init__(self, parent, id, pos=wx.DefaultPosition,
+                 size=wx.DefaultSize, style=0):
+        wx.ListCtrl.__init__(self, parent, id, pos, size, style)
+        listmix.ListCtrlAutoWidthMixin.__init__(self)
+        listmix.TextEditMixin.__init__(self)
+    def Populate(self, update=False):
+        """Populate the list"""
+        itemData = {} # requested by sorter
+        if not update:
+            self.InsertColumn(0, _("Layer"))
+            self.InsertColumn(1, _("Category"))
+        else:
+            self.DeleteAllItems()
+        i = 1
+        for layer in self.parent.cats.keys():
+            catsList = self.parent.cats[layer]
+            for cat in catsList:
+                index = self.InsertStringItem(sys.maxint, str(catsList[0]))
+                self.SetStringItem(index, 0, str(layer))
+                self.SetStringItem(index, 1, str(cat))
+                self.SetItemData(index, i)
+                itemData[i] = (str(layer), str(cat))
+                i = i + 1
+        if not update:
+            self.SetColumnWidth(0, 100)
+            self.SetColumnWidth(1, wx.LIST_AUTOSIZE)
+        self.currentItem = 0
+        return itemData
+class VDigitZBulkDialog(wx.Dialog):
+    Dialog used for Z bulk-labeling tool
+    def __init__(self, parent, title, nselected, style=wx.DEFAULT_DIALOG_STYLE):
+        # panel  = wx.Panel(parent=self, id=wx.ID_ANY)
+        txt = wx.StaticText(parent=self,
+                            label=_("%d lines selected for z bulk-labeling") % nselected);
+        border.Add(item=txt, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
+        box   = wx.StaticBox (parent=self, id=wx.ID_ANY, label=" %s " % _("Set value"))
+        flexSizer = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
+        # starting value
+                            label=_("Starting value"));
+        self.value = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
+                                 initial=0,
+                                 min=-1e6, max=1e6)
+        flexSizer.Add(self.value, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+        # step
+                            label=_("Step"))
+        self.step  = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
+                                 initial=0,
+                                 min=0, max=1e6)
+        flexSizer.Add(self.step, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+        border.Add(item=sizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+        # buttons
+        # sizers
+        mainSizer.Add(item=border, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
