[GRASS-SVN] r31175 - in grass/branches/develbranch_6/gui/wxpython: . gui_modules icons icons/silk
Tue Apr 29 17:46:47 EDT 2008
Author: martinl
Date: 2008-04-29 17:46:47 -0400 (Tue, 29 Apr 2008)
New Revision: 31175
   grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
   grass/branches/develbranch_6/gui/wxpython/icons/icon.py
   grass/branches/develbranch_6/gui/wxpython/icons/silk/__init__.py
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI (georect): code (GUI layout) cleaning (not fully finished)
Silk icons add for georect
GCPToolbar moved to 'toolbar' module
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py	2008-04-29 19:19:15 UTC (rev 31174)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py	2008-04-29 21:46:47 UTC (rev 31175)
@@ -8,6 +8,7 @@
  - Georectify
  - GCP
  - GRMap
+ - GrSettingsDialog
 COPYRIGHT: (C) 2006-2008 by the GRASS Development Team
            This program is free software under the GNU General Public
@@ -21,33 +22,26 @@
 # recheck once completed to see how many of these are still needed
 import os
 import sys
-import time
-import glob
-import math
 import tempfile
 import shutil
 import wx
-import wx.aui
-import wx.lib.filebrowsebutton as filebrowse
 from wx.lib.mixins.listctrl import CheckListCtrlMixin, ListCtrlAutoWidthMixin, TextEditMixin
+import wx.lib.colourselect as  csel
 import wx.wizard as wiz
-import wx.grid as gridlib
-from threading import Thread
 import globalvar
 import mapdisp
 import render
 import toolbars
 import menuform
 import gselect
-import disp_print
 import gcmd
 import utils
 from debug import Debug as Debug
 from icon import Icons as Icons
 from location_wizard import TitledPage as TitledPage
+from preferences import globalSettings as UserSettings
 try:
     import subprocess # Not needed if GRASS commands could actually be quiet
@@ -74,7 +68,7 @@
     def __init__(self, parent):
-        self.parent = parent
+        self.parent = parent # GMFrame
         # get environmental variables
@@ -170,12 +164,20 @@
                               l_hidden=False, l_opacity=1.0, l_render=False)
-            # open map display
+            # start GCP form
-            self.xy_mapdisp = mapdisp.MapFrame(self.parent, title=_("Set ground control points (GCPs)"),
+            self.gcpmgr = GCP(self.parent, grwiz=self)
+            self.gcpmgr.Show()
+            # start map display
+            self.xy_mapdisp = mapdisp.MapFrame(self.gcpmgr, title=_("Set ground control points (GCPs)"),
                                                size=globalvar.MAP_WINDOW_SIZE,
                                                toolbars=["georect"],
-                                               Map=self.Map, gismgr=self.parent, georect=True)
+                                               Map=self.Map, gismgr=self.parent)
+            self.gcpmgr.SetMapDisplay(self.xy_mapdisp)
             self.mapwin = self.xy_mapdisp.MapWindow
@@ -190,14 +192,6 @@
             # show new display & draw map
             self.xy_mapdisp.Show()
-            # start GCP form
-            self.gcpmgr = GCP(self.parent, grwiz=self)
-            self.gcpmgr.Show()
-            self.gcpmgr.Refresh()
-            self.gcpmgr.Update()
         else:
             self.Cleanup()
@@ -291,9 +285,8 @@
         for item in tmplist:
             if os.path.isdir(os.path.join(self.grassdatabase, item)) and \
-                os.path.exists(os.path.join(self.grassdatabase, item, 'PERMANENT')):
-                if item != self.parent.currentlocation: # skip current location
-                    self.locList.append(item)
+                    os.path.exists(os.path.join(self.grassdatabase, item, 'PERMANENT')):
+                self.locList.append(item)
         utils.ListSortLower(self.locList)
@@ -338,7 +331,7 @@
         self.Bind(wx.EVT_COMBOBOX, self.OnMapset, self.cb_mapset)
         self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
         self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
-        self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
+        # self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
     def OnMaptype(self,event):
         """Change map type"""
@@ -611,141 +604,183 @@
     Calls i.rectify or v.transform to georectify map.
-    def __init__(self,parent,id=-1,title="Create & manage ground control points",
-                 size=wx.DefaultSize, grwiz=None):
-        wx.Frame.__init__(self, parent, id , title, size=(600,300))
-        self.Centre(wx.HORIZONTAL)
+    def __init__(self, parent, grwiz, mapdisp=None, id=wx.ID_ANY,
+                 title=_("Create & manage ground control points"),
+                 size=wx.DefaultSize):
-        toolbar = self.__createToolBar()
-        self.grwiz = grwiz
+        wx.Frame.__init__(self, parent, id, title, size=(625, 300))
+        # init variables
+        self.mapdisp = mapdisp # XY-location Map Display
+        self.grwiz = grwiz # GR Wizard
         self.grassdatabase = self.grwiz.grassdatabase
         self.currentlocation = self.grwiz.currentlocation
         self.currentmapset = self.grwiz.currentmapset
         self.newlocation = self.grwiz.newlocation
         self.newmapset = self.grwiz.newmapset
         self.xylocation = self.grwiz.gisrc_dict['LOCATION_NAME']
         self.xymapset = self.grwiz.gisrc_dict['MAPSET']
         self.xygroup = self.grwiz.grouppage.xygroup
         self.extension = self.grwiz.grouppage.extension
-        self.pointsfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'POINTS')
-        self.rgrpfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'REF')
-        self.vgrpfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'VREF')
-        self.targetfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'TARGET')
+        self.file = {
+            'points' : os.path.join(self.grassdatabase,
+                                    self.xylocation,
+                                    self.xymapset,
+                                    'group',
+                                    self.xygroup,
+                                    'POINTS'),
+            'rgrp' : os.path.join(self.grassdatabase,
+                                  self.xylocation,
+                                  self.xymapset,
+                                  'group',
+                                  self.xygroup,
+                                  'REF'),
+            'vgrp' : os.path.join(self.grassdatabase,
+                                  self.xylocation,
+                                  self.xymapset,
+                                  'group',
+                                  self.xygroup,
+                                  'VREF'),
+            'target' : os.path.join(self.grassdatabase,
+                                    self.xylocation,
+                                    self.xymapset,
+                                    'group',
+                                    self.xygroup,
+                                    'TARGET'),
+        # polynomial order transformation for georectification
+        self.gr_order = 1
+        # number of GCPs selected to be used for georectification (checked)
+        self.GCPcount = 0
+        # forward RMS error
+        self.fwd_rmserror = 0.0
+        # backward RMS error
+        self.bkw_rmserror = 0.0
+        # list map coords and ID of map display they came from
+        self.mapcoordlist = []
         self.SetTarget(self.xygroup, self.currentlocation, self.currentmapset)
-        self.gr_order = 1 #polynomial order transformation for georectification
-        self.selected = 0 #gcp list item selected
-        self.GCPcount = 0 #number of GCPs selected to be used for georectification (checked)
-        self.fwd_rmserror = 0.0 # forward RMS error
-        self.bkw_rmserror = 0.0 # backward RMS error
-        self.mapcoordlist = [(0000000.00,0000000.00,'')] #list map coords and ID of map display they came from
+        # toolbar
+        self.SetMapDisplay(self.mapdisp)
+        # statusbar
+        self.CreateStatusBar(number=3)
+        self.SetStatusText(_('RMS error for selected points'), 0)
-        self.CreateStatusBar(3,1,-1,'gcpstatusbar')
-        self.SetStatusText('RMS error for selected points',0)
         # can put guage into custom statusbar for progress if can figure out how to get progress text from i.rectify
-        #self.gr_gauge = wx.Gauge(self, -1, 100, (-1,-1), (100, 25))
-        #self.gr_guage.Pulse()
+        # self.gr_gauge = wx.Gauge(self, -1, 100, (-1,-1), (100, 25))
+        # self.gr_guage.Pulse()
-        p = wx.Panel(self, -1, style=0)
+        panel = wx.Panel(parent=self)
-        self.sizer = wx.BoxSizer(wx.VERTICAL)
+        # do layout
+        sizer = wx.BoxSizer(wx.VERTICAL)
-        box = wx.BoxSizer(wx.HORIZONTAL)
-        self.rb_grmethod = wx.RadioBox(p, -1, "Select rectification method for rasters ",
-                                   wx.DefaultPosition, wx.DefaultSize,
-                                   ['1st order','2nd order', '3rd order'], 3, wx.RA_SPECIFY_COLS)
-        box.Add(self.rb_grmethod, 0, wx.ALIGN_CENTER|wx.ALL, 5)
-        self.sizer.Add(box, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
+        self.rb_grmethod = wx.RadioBox(parent=panel, id=wx.ID_ANY,
+                                       label=" %s " % _("Select rectification method for rasters"),
+                                       choices=[_('1st order'), _('2nd order'), _('3rd order')],
+                                       majorDimension=wx.RA_SPECIFY_COLS)
+        sizer.Add(item=self.rb_grmethod, proportion=0,
+                       flag=wx.EXPAND | wx.ALL, border=5)
+        box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
+                            label=" %s " % _("Ground Control Points"))
+        boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
         # initialize list control for GCP management
-        self.list = CheckListCtrl(p, -1, style=wx.LC_REPORT | wx.SUNKEN_BORDER | wx.LC_HRULES)
-        self.list.InsertColumn(0, 'use| X coord', width=120)
-        self.list.InsertColumn(1, 'Y coord')
-        self.list.InsertColumn(2, 'N coord')
-        self.list.InsertColumn(3, 'E coord')
-        self.list.InsertColumn(4, 'Forward error')
-        self.list.InsertColumn(5, 'Backward error')
-        if os.path.isfile(self.pointsfile):
-            self.ReadGCPs()
-            self.ResizeColumns()
-        elif self.list.GetItemCount() == 0:
-            # initialize 3 blank lines in the GCP list (minimum for georectification)
-            i = ('0000000.00','0000000.00','0000000.00','0000000.00','','')
-            index = self.list.InsertStringItem(sys.maxint, i[0])
-            self.list.SetStringItem(index, 1, i[1])
-            self.list.SetStringItem(index, 2, i[2])
-            self.list.SetStringItem(index, 3, i[3])
-            self.list.SetStringItem(index, 4, i[4])
-            self.list.SetStringItem(index, 5, i[5])
-            self.list.CheckItem(0, True)
-            self.AddGCP(None)
-            self.AddGCP(None)
+        self.list = GCPList(parent=panel, gcp=self)
+        self.list.LoadData()
-        self.sizer.Add(self.list, 1, wx.EXPAND|wx.ALL, 5)
-        p.SetSizer(self.sizer)
+        boxSizer.Add(item=self.list, proportion=1,
+                     flag=wx.EXPAND | wx.ALL, border=3)
+        sizer.Add(item=boxSizer, proportion=1,
+                  flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
+        # bindigs
         self.Bind(wx.EVT_RADIOBOX, self.OnGRMethod, self.rb_grmethod)
-        self.list.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
-        self.list.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnItemActivated)
         self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
-        self.Bind(wx.EVT_CLOSE, self.grwiz.Cleanup)
+        # self.Bind(wx.EVT_CLOSE, self.grwiz.Cleanup)
-    def __createToolBar(self):
-        """Creates toolbar"""
+        panel.SetSizer(sizer)
+        # sizer.Fit(self)
-        toolbar = self.CreateToolBar()
-        for each in self.toolbarData():
-            self.addToolbarButton(toolbar, *each)
-        toolbar.Realize()
-    def OnFocus(self, event):
-        self.grwiz.SwitchEnv('new')
-    def ResizeColumns(self):
-        for i in range(6):
-            self.list.SetColumnWidth(i, wx.LIST_AUTOSIZE)
+    def SetMapDisplay(self, win):
+        self.mapdisp = win
+        if self.mapdisp:
+            self.toolbar = toolbars.GCPToolbar(parent=self, mapdisplay=self.mapdisp, map=self.mapdisp.Map).GetToolbar()
+            self.SetToolBar(self.toolbar)
+        else:
+            self.toolbar = None
     def SetTarget(self, tgroup, tlocation, tmapset):
         Sets rectification target to current location and mapset
-       # check to see if we are georectifying map in current working location/mapset
+        # check to see if we are georectifying map in current working location/mapset
         if self.newlocation == self.currentlocation and self.newmapset == self.currentmapset:
-            cmdlist = ['i.target', 'c', 'group=%s' % tgroup]
+            cmdlist = ['i.target',
+                       '-c',
+                       'group=%s' % tgroup]
         else:
-            cmdlist = ['i.target', 'group=%s' % tgroup, 'location=%s' % tlocation, 'mapset=%s' % tmapset]
+                       'group=%s' % tgroup,
+                       'location=%s' % tlocation,
+                       'mapset=%s' % tmapset]
         gcmd.Command(cmd=cmdlist)
-    def addToolbarButton(self, toolbar, label, icon, help, handler):
-        """Adds button to the given toolbar"""
+    def AddGCP(self, event):
+        Appends an item to GCP list
+        self.list.AddItem()
+        self.mapcoordlist.append((0.0, 0.0, None))
-        if not label:
-            toolbar.AddSeparator()
+    def DeleteGCP(self, event):
+        Deletes selected item in GCP list
+        if self.list.GetItemCount() < 4:
+            wx.MessageBox(parent=self, message=_("At least 3 GCP required. Operation cancelled."),
+                          caption=_("Delete GCP"), style=wx.OK | wx.ICON_INFORMATION)
             return
-        tool = toolbar.AddLabelTool(id=wx.ID_ANY, label=label, bitmap=icon, shortHelp=help)
-        self.Bind(wx.EVT_TOOL, handler, tool)
-    def toolbarData(self):
+        item = self.list.DeleteItem()
+        del self.gcp.mapcoordlist[self.selected]
-        return   (
-                 ('savegcp', Icons["savefile"].GetBitmap(), 'Save GCPs to POINTS file', self.SaveGCPs),
-                 ('addgcp',  wx.ArtProvider.GetBitmap(wx.ART_NEW, wx.ART_TOOLBAR, (16,16)), 'Add new GCP', self.AddGCP),
-                 ('deletegcp',  wx.ArtProvider.GetBitmap(wx.ART_DELETE, wx.ART_TOOLBAR, (16,16)), 'Delete selected GCP', self.DeleteGCP),
-                 ('cleargcp', Icons["cleargcp"].GetBitmap(), Icons["cleargcp"].GetLabel(), self.ClearGCP),
-                 ('refreshgcp', Icons["refreshgcp"].GetBitmap(), Icons["refreshgcp"].GetLabel(), self.RefreshGCPMarks),
-                 ('rms', Icons["rms"].GetBitmap(), Icons["rms"].GetLabel(), self.OnRMS),
-                 ('georect',  Icons["georect"].GetBitmap(),  Icons["georect"].GetLabel(),  self.OnGeorect),
-                 ('quit',  wx.ArtProvider.GetBitmap(wx.ART_QUIT, wx.ART_TOOLBAR, (16,16)), 'Quit georectification module', self.OnQuit)
+    def ClearGCP(self, event):
+        Clears all values in selected item of GCP list and unchecks it
+        index = self.list.GetSelected()
+        for i in range(4):
+            self.list.SetStringItem(index, i, '0.0')
+        self.list.SetStringItem(index, 4, '')
+        self.list.SetStringItem(index, 5, '')
+        self.list.CheckItem(index, False)
+        self.mapcoordlist[index] = (0.0, 0.0, '')
     def SaveGCPs(self, event):
         Make a POINTS file or save GCP coordinates to existing POINTS file
@@ -776,66 +811,38 @@
             f.close()
         pass
-    def DeleteGCP(self, event):
-        Deletes selected item in GCP list
-        self.list.DeleteItem(self.selected)
-        del self.mapcoordlist[self.selected]
-    def AddGCP(self, event):
-        Appends an item to GCP list
-        self.list.Append(['0000000.00','0000000.00','0000000.00','0000000.00','',''])
-        index = self.list.GetItemCount() - 1
-        self.mapcoordlist.append((0000000.00,0000000.00,''))
-        self.list.SetItemState(index, wx.LIST_STATE_SELECTED, wx.LIST_STATE_SELECTED)
-        return index
     def SetGCPData(self, coordtype, coord, mapdisp=None, check=True):
         Inserts coordinates from mouse click on map
         into selected item of GCP list and checks it for use
-        index = self.selected
+        if index == wx.NOT_FOUND:
+            return
         coord0 = str(coord[0])
         coord1 = str(coord[1])
         if coordtype == 'gcpcoord':
             self.list.SetStringItem(index, 0, coord0)
             self.list.SetStringItem(index, 1, coord1)
-        if coordtype == 'mapcoord':
+        elif coordtype == 'mapcoord':
             self.list.SetStringItem(index, 2, coord0)
             self.list.SetStringItem(index, 3, coord1)
             self.mapcoordlist[index] = (coord[0], coord[1], mapdisp)
         self.list.CheckItem(index, check)
-    def ClearGCP(self, event):
-        Clears all values in selected item of GCP list and unchecks it
-        for i in range(4):
-            self.list.SetStringItem(index, i, '0000000.00')
-        self.list.SetStringItem(index, 4, '')
-        self.list.SetStringItem(index, 5, '')
-        self.mapcoordlist[index] = (0000000.00,0000000.00,'')
-        self.list.CheckItem(index, False)
+        # self.list.ResizeColumns()
     def ReadGCPs(self):
         Reads GCPs and georectified coordinates from POINTS file
         self.GCPcount = 0
-        f = open(self.pointsfile)
+        f = open(self.file['points'], 'r')
         try:
             GCPcnt = 0
             for line in f:
@@ -857,7 +864,10 @@
         if self.CheckGCPcount():
             self.RMSError(self.xygroup, self.gr_order)
+    def OnFocus(self, event):
+        self.grwiz.SwitchEnv('new')
     def OnRMS(self, event):
         RMS button handler
@@ -946,32 +956,21 @@
                 wx.MessageBox('Some maps were not georectified successfully')
         else:
             return
+    def OnSettings(self, event):
+        """Georectifier settings"""
+        dlg = GrSettingsDialog(parent=self, id=wx.ID_ANY, title=_('Georectifier settings'))
+        if dlg.ShowModal() == wx.ID_OK:
+            pass
+        dlg.Destroy()
     def OnQuit(self, event):
+        """Quit georectifier"""
         self.Destroy()
-        self.grwiz.Cleanup()
+        # self.grwiz.Cleanup()
-    def OnItemSelected(self, event):
-        self.selected = event.GetIndex()
-    def OnItemActivated(self, event):
-        When item double clicked, open editor to update coordinate values
-        coords = []
-        index = event.m_itemIndex
-            coords.append(self.list.GetItem(index, i).GetText())
-        dlg = EditGPC(self, -1, data=coords)
-        if dlg.ShowModal() == wx.ID_OK:
-            values = dlg.GetValues() # string
-                if values[i] != coords[i]:
-                    self.list.SetStringItem(index, i, values[i])
     def RefreshGCPMarks(self, event):
         Updates GCP and map coord maps and redraws
@@ -987,10 +986,10 @@
                 mapid = map[2]
         for index in range(self.list.GetItemCount()):
             if self.list.IsChecked(index) and (
-                (self.list.GetItem(index, 0).GetText() != '0000000.00' and
-                 self.list.GetItem(index, 1).GetText() != '0000000.00') or
-                (self.list.GetItem(index, 2).GetText() != '0000000.00' and
-                 self.list.GetItem(index, 3).GetText() != '0000000.00')
+                (self.list.GetItem(index, 0).GetText() != '0.0' and
+                 self.list.GetItem(index, 1).GetText() != '0.0') or
+                (self.list.GetItem(index, 2).GetText() != '0.0' and
+                 self.list.GetItem(index, 3).GetText() != '0.0')
                 coord0 = float(self.list.GetItem(index, 0).GetText())
                 coord1 = float(self.list.GetItem(index, 1).GetText())
@@ -1057,21 +1056,149 @@
         self.SetStatusText('forward: %s' % self.fwd_rmserror,1)
         self.SetStatusText('backward: %s' % self.bkw_rmserror,2)
-class CheckListCtrl(wx.ListCtrl, CheckListCtrlMixin, ListCtrlAutoWidthMixin):
-    def __init__(self, parent, ID=-1, pos=wx.DefaultPosition, size=wx.DefaultSize,
-                 style=0):
-        wx.ListCtrl.__init__(self, parent, -ID, pos, size, style)
+class GCPList(wx.ListCtrl,
+              CheckListCtrlMixin,
+              ListCtrlAutoWidthMixin):
+    def __init__(self, parent, gcp, id=wx.ID_ANY,
+                 pos=wx.DefaultPosition, size=wx.DefaultSize,
+                 style=wx.LC_REPORT | wx.SUNKEN_BORDER | wx.LC_HRULES |
+                 wx.LC_SINGLE_SEL):
+        wx.ListCtrl.__init__(self, parent, id, pos, size, style)
+        # Mixin settings
         CheckListCtrlMixin.__init__(self)
         ListCtrlAutoWidthMixin.__init__(self)
+        # TextEditMixin.__init__(self)
+        self.gcp = gcp # GCP class
+        # tracks whether list items are checked or not
+        self.CheckList = []
+        self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
+        self.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnItemActivated)
+        self._Create()
+        self.selected = wx.NOT_FOUND
+    def _Create(self):
+        idx_col = 0
+        for col in (_('use| X coord'),
+                    _('Y coord'),
+                    _('E coord'),
+                    _('N coord'),
+                    _('Forward error'),
+                    _('Backward error')):
+            self.InsertColumn(idx_col, col)
+            idx_col += 1
-        self.CheckList = [] # tracks whether list items are checked or not
-        #self.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnItemActivated)
+    def LoadData(self):
+        """Load data into list"""
+        self.DeleteAllItems()
-    # this is called by the base class when an item is checked/unchecked
+        if os.path.isfile(self.gcp.file['points']):
+            self.gcp.ReadGCPs()
+        else:
+            # 3 gcp is minimum
+            for i in range(3):
+                self.gcp.AddGCP(None)
+            # select first point by default
+            self.selected = 0
+            self.SetItemState(self.selected,
+                              wx.LIST_STATE_SELECTED,
+                              wx.LIST_STATE_SELECTED)
+        self.ResizeColumns()
     def OnCheckItem(self, index, flag):
+        """Item is checked/unchecked"""
         pass
+    def AddItem(self):
+        self.Append(['0.0',
+                     '0.0',
+                     '0.0',
+                     '0.0',
+        self.selected = self.GetItemCount() - 1
+        return self.selected
+    def DeleteItem(self):
+        if self.selected == wx.NOT_FOUND:
+            return
+        self.list.DeleteItem(self.selected)
+        if self.GetItemCount() > 0:
+            self.selected = GetItemCount() - 1
+        else:
+    def ResizeColumns(self):
+        """Resize columns"""
+        minWidth = 90
+        for i in range(self.GetColumnCount()):
+            self.SetColumnWidth(i, wx.LIST_AUTOSIZE)
+            if self.GetColumnWidth(i) < minWidth:
+                self.SetColumnWidth(i, minWidth)
+        self.SendSizeEvent()
+    def GetSelected(self):
+        """Get index of selected item"""
+    def OnItemSelected(self, event):
+        self.selected = event.GetIndex()
+    def OnItemActivated(self, event):
+        When item double clicked, open editor to update coordinate values
+        coords = []
+        index = event.GetIndex()
+            coords.append(self.GetItem(index, i).GetText())
+        dlg = EditGPC(parent=self, id=wx.ID_ANY, data=coords)
+            values = dlg.GetValues() # string
+            if len(values) == 0:
+                              caption=_("Edit GCP"),
+                              message=_("Invalid coordinate value. Operation cancelled."),
+                              style=wx.CENTRE | wx.ICON_ERROR | wx.ID_OK)
+            else:
+                for i in range(len(values)):
+                    if values[i] != coords[i]:
+                        self.SetStringItem(index, i, values[i])
+                self.gcp.mapcoordlist[index] = (float(values[0]), float(values[1]), None)
 class VectGroup(wx.Dialog):
     Dialog to create a vector group (VREF file) for georectifying
@@ -1167,68 +1294,197 @@
 class EditGPC(wx.Dialog):
-    """Dialog for editing GPC and map coordinates in list control"""
-    def __init__(self, parent, id, data,
-                style=wx.DEFAULT_DIALOG_STYLE):
-        wx.Dialog.__init__(self, parent, id, style=style)
+    def __init__(self, parent, data, id=wx.ID_ANY,
+                 title=_("Edit GCP"),
+                 style=wx.DEFAULT_DIALOG_STYLE):
+        """Dialog for editing GPC and map coordinates in list control"""
-        self.btnCancel = wx.Button(self, wx.ID_CANCEL)
-        self.btnSubmit = wx.Button(self, wx.ID_OK)
-        self.btnSubmit.SetDefault()
+        wx.Dialog.__init__(self, parent, id, title=title, style=style)
+                            label=" %s " % _("Ground Control Point"))
+        # source coordinates
+        gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
-        xlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
-                              label='X:')
-        box.Add(xlabel, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT, border=5)
-        self.xcoord = wx.TextCtrl(parent=self, id=wx.ID_ANY,
-                            value=data[0], size=(150, -1))
-        box.Add(self.xcoord, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT| wx.LEFT, border=5)
-        ylabel = wx.StaticText(parent=self, id=wx.ID_ANY,
-                              label='Y:')
-        box.Add(ylabel, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT| wx.LEFT, border=5)
-        self.ycoord = wx.TextCtrl(parent=self, id=wx.ID_ANY,
-                            value=data[1], size=(150, -1))
-        box.Add(self.ycoord, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT| wx.LEFT | wx.RIGHT, border=5)
-        sizer.Add(box, flag=wx.ALL, border=3)
+        self.xcoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
+        self.ycoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
+        self.ncoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
+        self.ecoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
-        elabel = wx.StaticText(parent=self, id=wx.ID_ANY,
-                              label='E:')
-        box.Add(elabel, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT| wx.LEFT, border=5)
-        self.ecoord = wx.TextCtrl(parent=self, id=wx.ID_ANY,
-                            value=data[2], size=(150, -1))
-        box.Add(self.ecoord, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT| wx.LEFT, border=5)
-        nlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
-                              label='N:')
-        box.Add(nlabel, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT| wx.LEFT, border=5)
-        self.ncoord = wx.TextCtrl(parent=self, id=wx.ID_ANY,
-                            value=data[3], size=(150, -1))
-        box.Add(self.ncoord, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT| wx.LEFT | wx.RIGHT, border=5)
+        row = 0
+        col = 0
+        idx = 0
+        for label, win in ((_("X:"), self.xcoord),
+                           (_("Y:"), self.ycoord),
+                           (_("E:"), self.ecoord),
+                           (_("N:"), self.ncoord)):
+            label = wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                  label=label)
+            gridSizer.Add(item=label,
+                          flag=wx.ALIGN_CENTER_VERTICAL,
+                          pos=(row, col))
+            col += 1
+            win.SetValue(str(data[idx]))
+            gridSizer.Add(item=win,
+                          pos=(row, col))
+            col += 1
+            idx += 1
+            if col > 3:
+                row += 1
+                col = 0
+        boxSizer.Add(item=gridSizer, proportion=1,
         # buttons
+        self.btnCancel = wx.Button(panel, wx.ID_CANCEL)
+        self.btnOk = wx.Button(panel, wx.ID_OK)
+        self.btnOk.SetDefault()
         btnSizer = wx.StdDialogButtonSizer()
         btnSizer.AddButton(self.btnCancel)
-        btnSizer.AddButton(self.btnSubmit)
+        btnSizer.AddButton(self.btnOk)
         btnSizer.Realize()
         sizer.Add(item=btnSizer, proportion=0,
-                  flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+                  flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
-        self.SetSizer(sizer)
         sizer.Fit(self)
-        self.Layout()
     def GetValues(self, columns=None):
         """Return list of values (as strings).
         valuelist = []
+        try:
+            float(self.xcoord.GetValue())
+            float(self.ycoord.GetValue())
+            float(self.ecoord.GetValue())
+            float(self.ncoord.GetValue())
+        except ValueError:
+            return valuelist
         valuelist.append(self.xcoord.GetValue())
         valuelist.append(self.ycoord.GetValue())
         valuelist.append(self.ecoord.GetValue())
         valuelist.append(self.ncoord.GetValue())
         return valuelist
+class GrSettingsDialog(wx.Dialog):
+    def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
+        wx.Dialog.__init__(self, parent, id, title, pos, size, style)
+        Dialog to set profile text options: font, title
+        and font size, axis labels and font size
+        # initialize variables
+        self.symbol = {}
+        self._do_layout()
+    def _do_layout(self):
+        """Do layout"""
+        # dialog layout
+        box = wx.StaticBox(parent=self, id=wx.ID_ANY,
+                           label=" %s " % _("Symbol settings"))
+        gridSizer.AddGrowableCol(1)
+        # symbol color
+        label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Color:"))
+        gridSizer.Add(item=label, flag=wx.ALIGN_CENTER_VERTICAL, pos=(0, 0))
+        col = UserSettings.Get(group='georect', key='symbol', subkey='color')
+        colWin = csel.ColourSelect(parent=self, id=wx.ID_ANY,
+                                   colour=wx.Colour(col[0],
+                                                    col[1],
+                                                    col[2],
+                                                    255))
+        self.symbol['color'] = colWin.GetId()
+        gridSizer.Add(item=colWin,
+                      flag=wx.ALIGN_RIGHT,
+                      pos=(0, 1))
+        boxSizer.Add(item=gridSizer, flag=wx.EXPAND)
+        sizer.Add(item=boxSizer, flag=wx.EXPAND | wx.ALL, border=5)
+        line = wx.StaticLine(parent=self, id=wx.ID_ANY, size=(20, -1), style=wx.LI_HORIZONTAL)
+        sizer.Add(item=line, proportion=0,
+                  flag=wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border=3)
+        # buttons
+        btnSave = wx.Button(self, wx.ID_SAVE)
+        btnApply = wx.Button(self, wx.ID_APPLY)
+        btnCancel = wx.Button(self, wx.ID_CANCEL)
+        btnSave.SetDefault()
+        # bindigs
+        btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+        btnApply.SetToolTipString(_("Apply changes for the current session"))
+        btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
+        btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
+        btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+        btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
+        # sizers
+        btnStdSizer = wx.StdDialogButtonSizer()
+        btnStdSizer.AddButton(btnCancel)
+        btnStdSizer.AddButton(btnSave)
+        btnStdSizer.AddButton(btnApply)
+        btnStdSizer.Realize()
+        sizer.Add(item=btnStdSizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
+        self.SetSizer(sizer)
+        sizer.Fit(self)
+    def UpdateSettings(self):
+        UserSettings.Set(group='georect', key='symbol', subkey='color',
+                         value=wx.FindWindowById(self.symbol['color']).GetColour())
+    def OnSave(self, event):
+        """Button 'Save' pressed"""
+        self.UpdateSettings()
+        fileSettings = {}
+        UserSettings.ReadSettingsFile(settings=fileSettings)
+        fileSettings['georect'] = UserSettings.Get(group='georect')
+        file = UserSettings.SaveToFile(fileSettings)
+        self.parent.parent.goutput.WriteLog(_('Georectifier settings saved to file \'%s\'.') % file)
+        self.Close()
+    def OnApply(self, event):
+        """Button 'Apply' pressed"""
+        self.Close()
+    def OnCancel(self, event):
+        """Button 'Cancel' pressed"""
+        self.Close()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-04-29 19:19:15 UTC (rev 31174)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-04-29 21:46:47 UTC (rev 31175)
@@ -1229,16 +1229,20 @@
                 self.DrawLines(pdc=self.pdcTmp)
             except:
                 pass
-        elif self.mouse["use"] == "pointer" and self.parent.gismanager.georectifying:
+        elif self.mouse["use"] == "pointer" and hasattr(self.parent.parent, "grwiz"):
+            # -> georectifying
             self.SetCursor(self.parent.cursors["cross"])
+            self.pen = wx.Pen(colour='blue', width=3, style=wx.SOLID)
             coord = self.Pixel2Cell(self.mouse['end'])
-            if self.parent.georect:
+            if self.parent.grtoolbar:
                 coordtype = 'gcpcoord'
             else:
                 coordtype = 'mapcoord'
-            self.gismanager.gr.gcpmgr.SetGCPData(coordtype, coord, self)
+            self.parent.parent.SetGCPData(coordtype, coord, self)
             self.DrawCross(pdc=self.pdcTmp, coords=self.mouse['end'],
-                                       size=5)
+                           size=5)
         elif self.mouse["use"] == "pointer" and self.parent.digittoolbar:
             # digitization tool active
@@ -2187,26 +2191,17 @@
                  style=wx.DEFAULT_FRAME_STYLE, toolbars=["map"],
                  tree=None, notebook=None, gismgr=None, page=None,
-                 Map=None, auimgr=None, georect=False):
+                 Map=None, auimgr=None):
-            Main map display window with toolbars, statusbar and
-            DrawWindow
+        Main map display window with toolbars, statusbar and
+        DrawWindow
-            Parameters:
-                parent  -- parent window, None, wx.Window()
-                id      -- window ID, int, wx.ID_ANY
-                title   -- window title, string
-                pos     -- where to place it, tupple, wx.Position
-                size    -- window size, tupple, wx.Size
-                style   -- window style
-                toolbars-- array of default toolbars, which should appear,
-                           currently: ['map', 'digit']
-                notebook-- control book ID in GIS Manager
-                tree    -- associated layer tree
-                gismgr  -- GIS Manager panel
-                page    -- notebook page with layer tree
-                Map     -- instance of render.Map
-                georect -- is window used by georectifier
+        @param toolbars array of activated toolbars, e.g. ['map', 'digit']
+        @param tree reference to layer tree
+        @param notebook control book ID in Layer Manager
+        @param gismgr Layer Manager panel
+        @param page notebook page with layer tree
+        @param Map instance of render.Map
         wx.Frame.__init__(self, parent, id, title, pos, size, style)
@@ -2216,7 +2211,6 @@
         self.tree       = tree      # GIS Manager layer tree object
         self.page       = page      # Notebook page holding the layer tree
         self.layerbook  = notebook  # GIS Manager layer tree notebook
-        self.georect    = georect   # Map display used for setting GCPs for georectifier
@@ -2380,28 +2374,28 @@
         Add defined toolbar to the window
         Currently known toolbars are:
-            * map
-            * digit
-            * georect
+         - map basic map toolbar
+         - digit vector digitizer
+         - georect georectifier
         if name == "map":
             self.maptoolbar = toolbars.MapToolbar(self, self.Map)
             self._mgr.AddPane(self.maptoolbar.toolbar,
                               wx.aui.AuiPaneInfo().
-                              Name("maptoolbar").Caption("Map Toolbar").
+                              Name("maptoolbar").Caption(_("Map Toolbar")).
                               ToolbarPane().Top().
                               LeftDockable(False).RightDockable(False).
                               BottomDockable(False).TopDockable(True).
                               CloseButton(False).Layer(2))
-        elif name == "digit":
+        if name == "digit":
             self.digittoolbar = toolbars.VDigitToolbar(self, self.Map, self.tree)
             for toolRow in range(0, self.digittoolbar.numOfRows):
                 self._mgr.AddPane(self.digittoolbar.toolbar[toolRow],
-                                  Name("digittoolbar" + str(toolRow)).Caption("Digit Toolbar").
+                                  Name("digittoolbar" + str(toolRow)).Caption(_("Digit Toolbar")).
                                   ToolbarPane().Top().Row(toolRow + 1).
@@ -2413,12 +2407,12 @@
             self.MapWindow.pen     = wx.Pen(colour='red',   width=2, style=wx.SOLID)
             self.MapWindow.polypen = wx.Pen(colour='green', width=2, style=wx.SOLID)
-        elif name == "georect":
+        if name == "georect":
             self.grtoolbar = toolbars.GRToolbar(self, self.Map)
             self._mgr.AddPane(self.grtoolbar.toolbar,
-                              Name("grtoolbar").Caption("Georectification Toolbar").
+                              Name("grtoolbar").Caption(_("Georectification Toolbar")).
@@ -2462,7 +2456,7 @@
         Change choicebook page to match display.
         Or set display for georectifying
-        if self.georect:
+        if self.grtoolbar:
             # display used to set GCPs in map to georectify
             try:
                 if event.GetActive():
@@ -2472,7 +2466,7 @@
             except:
                 pass
-        elif self.gismanager.georectifying:
+        elif self.grtoolbar:
             # in georectifying session; display used to get get geographic
             # coordinates for GCPs
             self.MapWindow.pen = wx.Pen(colour='black', width=2, style=wx.SOLID)
@@ -2543,7 +2537,7 @@
                 self.MapWindow.mouse['box'] = 'point'
             else: # moveLine, deleteLine
                 self.MapWindow.mouse['box'] = 'box'
             self.MapWindow.SetCursor(self.cursors["cross"])
         else:
             self.MapWindow.SetCursor(self.cursors["default"])
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2008-04-29 19:19:15 UTC (rev 31174)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2008-04-29 21:46:47 UTC (rev 31175)
@@ -149,44 +149,48 @@
                 'saveOnExit'            : { 'enabled' : False },
             'profile': {
-            'raster0' : { 'pcolor' : (0, 0, 255, 255), # profile line color
-                          'pwidth' : 1, # profile line width
-                          'pstyle' : 'solid', # profile line pen style
-            'raster1' : { 'pcolor' : (255, 0, 0, 255),
-                          'pwidth' : 1,
-            'raster2' : { 'pcolor' : (0, 255, 0, 255),
-                          'pwidth' : 1,
-            'font' : { 'titleSize' : 12,
-                       'axisSize' : 11,
-                       'legendSize' : 10,
-            'marker' : { 'color' : wx.Colour(0, 0, 0),
-                         'fill' : 'transparent',
-                         'size' : 2,
-                         'type' : 'triangle',
-                         'legend' : _('Segment break'),
-            'grid' : { 'color' : wx.Colour(200,200,200) ,
-                       'enabled' : True,
-            'x-axis' : { 'type' : 'auto', # axis format
-                         'min' : 0, # axis min for custom axis range
-                         'max': 0, # axis max for custom axis range
-                         'log' : False,
-            'y-axis' : { 'type' : 'auto', # axis format
-                         'log' : False,
-            'legend' : { 'enabled' : True
+                'raster0' : { 'pcolor' : (0, 0, 255, 255), # profile line color
+                              'pwidth' : 1, # profile line width
+                              'pstyle' : 'solid', # profile line pen style
+                'raster1' : { 'pcolor' : (255, 0, 0, 255),
+                              'pwidth' : 1,
+                'raster2' : { 'pcolor' : (0, 255, 0, 255),
+                              'pwidth' : 1,
+                'font' : { 'titleSize' : 12,
+                           'axisSize' : 11,
+                           'legendSize' : 10,
+                'marker' : { 'color' : wx.Colour(0, 0, 0),
+                             'fill' : 'transparent',
+                             'size' : 2,
+                             'type' : 'triangle',
+                             'legend' : _('Segment break'),
+                'grid' : { 'color' : wx.Colour(200,200,200) ,
+                           'enabled' : True,
+                'x-axis' : { 'type' : 'auto', # axis format
+                             'min' : 0, # axis min for custom axis range
+                             'max': 0, # axis max for custom axis range
+                             'log' : False,
+                'y-axis' : { 'type' : 'auto', # axis format
+                             'log' : False,
+                'legend' : { 'enabled' : True
+            'georect' : {
+                'symbol' : { 'color' : (0, 0, 255, 255),
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py	2008-04-29 19:19:15 UTC (rev 31174)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py	2008-04-29 21:46:47 UTC (rev 31175)
@@ -38,8 +38,6 @@
     downloading source or binaries."""
     print >> sys.stderr, "profile.py: " + msg
 import globalvar
 try:
     import subprocess
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-04-29 19:19:15 UTC (rev 31174)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-04-29 21:46:47 UTC (rev 31175)
@@ -5,6 +5,7 @@
     * AbstractToolbar
     * MapToolbar
     * GRToolbar
+    * GCPToolbar
     * VDigitToolbar
     * ProfileToolbar
@@ -67,8 +68,8 @@
         if label:
             toolWin = toolbar.AddLabelTool(tool, label, bitmap,
-                                        bmpDisabled, kind,
-                                        shortHelp, longHelp)
+                                           bmpDisabled, kind,
+                                           shortHelp, longHelp)
             parent.Bind(wx.EVT_TOOL, handler, toolWin)
         else: # add separator
@@ -225,8 +226,8 @@
              wx.ITEM_NORMAL, Icons["erase"].GetLabel(), Icons["erase"].GetDesc(),
              self.mapdisplay.OnErase),
-            (self.gcpset, "gcpset", Icons["gcpset"].GetBitmap(),
-             wx.ITEM_RADIO, Icons["gcpset"].GetLabel(), Icons["gcpset"].GetDesc(),
+            (self.gcpset, "grGcpSet", Icons["grGcpSet"].GetBitmap(),
+             wx.ITEM_RADIO, Icons["grGcpSet"].GetLabel(), Icons["grGcpSet"].GetDesc(),
              self.mapdisplay.OnPointer),
             (self.pan, "pan", Icons["pan"].GetBitmap(),
              wx.ITEM_RADIO, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
@@ -245,6 +246,69 @@
              self.mapdisplay.OnZoomMenu),
+class GCPToolbar(AbstractToolbar):
+    Toolbar for digitization
+    def __init__(self, parent, mapdisplay, map):
+        self.parent     = parent # GCP
+        self.mapcontent = map
+        self.mapdisplay = mapdisplay
+        self.toolbar = wx.ToolBar(parent=self.mapdisplay, id=wx.ID_ANY)
+        # self.SetToolBar(self.toolbar)
+        self.toolbar.SetToolBitmapSize(globalvar.toolbarSize)
+        self.InitToolbar(self.mapdisplay, self.toolbar, self.ToolbarData())
+        # realize the toolbar
+        self.toolbar.Realize()
+    def ToolbarData(self):
+        self.gcpSave = wx.NewId()
+        self.gcpAdd = wx.NewId()
+        self.gcpDelete = wx.NewId()
+        self.gcpClear = wx.NewId()
+        self.gcpRefresh = wx.NewId()
+        self.rms = wx.NewId()
+        self.georect = wx.NewId()
+        self.settings = wx.NewId()
+        self.quit = wx.NewId()
+        return (
+            (self.gcpSave, 'grGcpSave', Icons["grGcpSave"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpSave"].GetLabel(), Icons["grGcpSave"].GetDesc(),
+             self.parent.SaveGCPs),
+            (self.gcpAdd, 'grGrGcpAdd', Icons["grGcpAdd"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpAdd"].GetLabel(), Icons["grGcpAdd"].GetDesc(),
+             self.parent.AddGCP),
+            (self.gcpDelete, 'grGrGcpDelete', Icons["grGcpDelete"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpDelete"].GetLabel(), Icons["grGcpDelete"].GetDesc(),
+             self.parent.DeleteGCP),
+            (self.gcpClear, 'grGcpClear', Icons["grGcpClear"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpClear"].GetLabel(), Icons["grGcpClear"].GetDesc(),
+             self.parent.ClearGCP),
+            (self.gcpRefresh, 'grGcpRefresh', Icons["grGcpRefresh"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpRefresh"].GetLabel(), Icons["grGcpRefresh"].GetDesc(),
+             self.parent.RefreshGCPMarks),
+            (self.rms, 'grGcpRms', Icons["grGcpRms"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpRms"].GetLabel(), Icons["grGcpRms"].GetDesc(),
+             self.parent.OnRMS),
+            (self.georect, 'grGeorect', Icons["grGeorect"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGeorect"].GetLabel(), Icons["grGeorect"].GetDesc(),
+             self.parent.OnGeorect),
+            (self.settings, 'grSettings', Icons["grSettings"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grSettings"].GetLabel(), Icons["grSettings"].GetDesc(),
+             self.parent.OnSettings),
+            (self.quit, 'grGcpQuit', Icons["grGcpQuit"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["grGcpQuit"].GetLabel(), Icons["grGcpQuit"].GetDesc(),
+             self.parent.OnQuit)
 class VDigitToolbar(AbstractToolbar):
Modified: grass/branches/develbranch_6/gui/wxpython/icons/icon.py
--- grass/branches/develbranch_6/gui/wxpython/icons/icon.py	2008-04-29 19:19:15 UTC (rev 31174)
+++ grass/branches/develbranch_6/gui/wxpython/icons/icon.py	2008-04-29 21:46:47 UTC (rev 31175)
@@ -77,9 +77,9 @@
     ## attributes
     "digDispAttr" : 'display.attributes.gif',
     ## general
-    "digUndo" : wx.ART_ERROR,
+    "digUndo" : wx.ART_ERROR, # FIXME
     "digSettings" : 'settings.gif',
-    "digAdditionalTools" : wx.ART_ERROR,
+    "digAdditionalTools" : wx.ART_ERROR, # FIXME
     # gis manager
     "newdisplay" : 'gui-startmon.gif',
     "workspaceNew" : 'file-new.gif',
@@ -115,18 +115,23 @@
     "font"       : 'gui-font.gif',
     "histogram"  : 'module-d.histogram.gif',
     "color"      : 'edit-color.gif',
-    "options"    : wx.ART_ERROR,
+    "options"    :  wx.ART_ERROR, # FIXME
+    # profile
     "profile"    : 'gui-profile.gif',
     "transect"   : 'gui-profiledefine.gif',
-#    "profiledraw": 'gui-profiledraw.gif',
-    "profiledraw"  : 'gui-redraw.gif',
+    # "profiledraw": 'gui-profiledraw.gif',
+    "profiledraw" : 'gui-redraw.gif',
     "profileopt" : 'gui-profileopt.gif',
     # georectify
-    'cleargcp'   : 'gui-gcperase.gif',
-    'gcpset'     : 'gui-gcpset.gif',
-    'georect'    : 'gui-georect.gif',
-    'rms'        : 'gui-rms.gif',
-    'refreshgcp' : 'gui-display.gif'
+    'grGcpClear'   : 'gui-gcperase.gif',
+    'grGcpSet'     : 'gui-gcpset.gif',
+    'grGeorect'    : 'gui-georect.gif',
+    'grGcpRms'     : 'gui-rms.gif',
+    'grGcpRefresh' : 'gui-display.gif',
+    "grGcpSave"    : 'file-save.gif',
+    "grGcpAdd"     : wx.ART_ERROR, # FIXME
+    "grGcpDelete"  : wx.ART_ERROR, # FIXME
+    "grSettings"   : 'edit-color.gif',
 # merge icons dictionaries, join paths
@@ -388,17 +393,29 @@
     "analyze"    : MetaIcon (img=icons_img["analyze"],
                              label=_("Analyze")),
     # georectify
-    'cleargcp'   : MetaIcon (img=icons_img["cleargcp"],
-                             label=_("Clear selected GCP")),
-    'gcpset'     : MetaIcon (img=icons_img["gcpset"],
+    'grGcpSet'     : MetaIcon (img=icons_img["grGcpSet"],
                              label=_("Set GCP"),
                              desc=_("Define GCP (Ground Control Points)")),
-    'georect'    : MetaIcon (img=icons_img["georect"],
+    'grGeorect'    : MetaIcon (img=icons_img["grGeorect"],
                              label=_("Georectify")),
-    'rms'        : MetaIcon (img=icons_img["rms"],
-                             label=_("Recalculate RMS error")),
-    'refreshgcp' : MetaIcon (img=icons_img["refreshgcp"],
-                             label=_("Redraw GCP markers in map displays"))}
+    'grGcpRms'        : MetaIcon (img=icons_img["grGcpRms"],
+                                  label=_("Recalculate RMS error")),
+    'grGcpRefresh' : MetaIcon (img=icons_img["grGcpRefresh"],
+                               label=_("Redraw GCP markers in map displays")),
+    'grGcpSave' : MetaIcon (img=icons_img["grGcpSave"],
+                            label=_("Save GCPs to POINTS file")),
+    'grGcpAdd' : MetaIcon (img=icons_img["grGcpAdd"],
+                           label=_("Add new GCP")),
+    'grGcpDelete' : MetaIcon (img=icons_img["grGcpDelete"],
+                              label=_("Delete selected GCP")),
+    'grGcpClear' : MetaIcon (img=icons_img["grGcpClear"],
+                             label=_("Clear selected GCP")),
+    'grGcpQuit' : MetaIcon (img=icons_img["quit"],
+                            label=_("Quit georectification module")),
+    "grSettings": MetaIcon (img=icons_img["grSettings"],
+                            label=_("Settings"),
+                            desc=_("Settings dialog for georectification tool")),
 # testing ...
 if __name__ == "__main__":
Modified: grass/branches/develbranch_6/gui/wxpython/icons/silk/__init__.py
--- grass/branches/develbranch_6/gui/wxpython/icons/silk/__init__.py	2008-04-29 19:19:15 UTC (rev 31174)
+++ grass/branches/develbranch_6/gui/wxpython/icons/silk/__init__.py	2008-04-29 21:46:47 UTC (rev 31175)
@@ -83,5 +83,13 @@
     "profiledraw"  : 'arrow_refresh.png',
     "profileopt"   : 'color_swatch.png',
     # georectify
-    "gcpset" : 'bullet_add.png',
+    "grGcpSet"     : 'bullet_add.png',
+    'grGcpClear'   : 'cross.png',
+    'grGeorect'    : 'application_lightning.png',
+    'grGcpRms'     : 'error.png',
+    'grGcpRefresh' : 'arrow_refresh.png',
+    "grGcpSave"    : 'picture_save.png',
+    "grGcpAdd"     : 'bullet_add.png',
+    "grGcpDelete"  : 'bullet_delete.png',
+    "grSettings"   : 'color_swatch.png',
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2008-04-29 19:19:15 UTC (rev 31174)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2008-04-29 21:46:47 UTC (rev 31175)
@@ -117,8 +117,6 @@
         self.encoding      = 'ISO-8859-1' # default encoding for display fonts
         self.workspaceFile = workspace    # workspace file
         self.menucmd       = {}           # menuId / cmd
-        self.georectifying = False        # says whether we're running the georectifier
-        self.gr            = ""           # ID of georectify instance
         # creating widgets
         # -> self.notebook, self.goutput, self.outpage
@@ -341,8 +339,7 @@
         Launch georectifier module
-        self.gr = georect.GeorectWizard(self)
-        self.georectifying = True
+        georect.GeorectWizard(self)
     def OnMapsets(self, event):
