[GRASS-SVN] r32479 - in grass-addons/gipe: . i.eb.h_SEBAL01
svn_grass at osgeo.org
Sun Aug 3 05:43:49 EDT 2008
Author: ychemin
Date: 2008-08-03 05:43:49 -0400 (Sun, 03 Aug 2008)
New Revision: 32479
Added:
grass-addons/gipe/i.eb.h_SEBAL01/
grass-addons/gipe/i.eb.h_SEBAL01/Makefile
grass-addons/gipe/i.eb.h_SEBAL01/description.html
grass-addons/gipe/i.eb.h_SEBAL01/main.c
Removed:
grass-addons/gipe/i.eb.h_SEBAL95/
grass-addons/gipe/Makefile.imagery
grass-addons/gipe/gmmenu.tcl
grass-addons/gipe/menudata.py
rm i.eb.h_SEBAL95
Modified: grass-addons/gipe/Makefile.imagery
--- grass-addons/gipe/Makefile.imagery 2008-08-03 08:02:57 UTC (rev 32478)
+++ grass-addons/gipe/Makefile.imagery 2008-08-03 09:43:49 UTC (rev 32479)
@@ -19,6 +19,7 @@
i.eb.h0 \
i.eb.h_iter \
i.eb.h_SEBAL95 \
+ i.eb.h_SEBAL01 \
i.eb.molength \
i.eb.netrad \
i.eb.psi \
Modified: grass-addons/gipe/gmmenu.tcl
--- grass-addons/gipe/gmmenu.tcl 2008-08-03 08:02:57 UTC (rev 32478)
+++ grass-addons/gipe/gmmenu.tcl 2008-08-03 09:43:49 UTC (rev 32479)
@@ -621,7 +621,8 @@
{command {[G_msg "Sensible heat flux iteration (fixed delta T)"]} {} "i.eb.h_iter" {} -command {execute i.eb.h_iter }}
{separator}
{command {[G_msg "Support file for delta T iteration"]} {} "i.eb.wetdrypix" {} -command {execute i.eb.wetdrypix }}
- {command {[G_msg "Sensible heat flux (iteration on delta T)"]} {} "i.eb.h_SEBAL95" {} -command {execute i.eb.h_SEBAL95 }}
+ {command {[G_msg "Sensible heat flux (iteration on delta T, original)"]} {} "i.eb.h_SEBAL95" {} -command {execute i.eb.h_SEBAL95 }}
+ {command {[G_msg "Sensible heat flux (iteration on delta T, 2001)"]} {} "i.eb.h_SEBAL01" {} -command {execute i.eb.h_SEBAL01 }}
{separator}
{command {[G_msg "Evaporative fraction"]} {} "i.eb.evapfr" {} -command {execute i.eb.evapfr }}
Added: grass-addons/gipe/i.eb.h_SEBAL01/Makefile
--- grass-addons/gipe/i.eb.h_SEBAL01/Makefile (rev 0)
+++ grass-addons/gipe/i.eb.h_SEBAL01/Makefile 2008-08-03 09:43:49 UTC (rev 32479)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = i.eb.h_SEBAL01
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/gipe/i.eb.h_SEBAL01/description.html
--- grass-addons/gipe/i.eb.h_SEBAL01/description.html (rev 0)
+++ grass-addons/gipe/i.eb.h_SEBAL01/description.html 2008-08-03 09:43:49 UTC (rev 32479)
@@ -0,0 +1,53 @@
+<html>
+<body>
+<H2>NAME</H2> <B><I>i.eb.h_SEBAL01 </I></B>- computation of <i>sensible heat flux</i> [W/m2] after Bastiaanssen, 1995 in [1], used in this form in 2001 by [2].
+<H2>DESCRIPTION</H2>
+<p><EM>i.eb.h_SEBAL01</EM> will calculate the sensible heat flux map (h0), given the surface roughness (z0m), a map of the altitude corrected temperature (t0dem), a point data of the frictional velocity (u*), a value of actual vapour pressure (ea[KPa]), a value of the sensible heat flux (h=Rn-g0) at dry pixel and the (x,y) pairs for wet and dry pixels.
+<p>For more details on the algorithms see [1].
+<H2>OPTIONS</H2>
+<H2>NOTES</H2>
+- z0m can be alculated by i.eb.z0m or i.eb.z0m0.
+- ea can be calculated with standard meteorological data.
+ eoTmin=0.6108*EXP(17.27*Tmin/(Tmin+237.3))
+ eoTmax=0.6108*EXP(17.27*Tmax/(Tmax+237.3))
+ ea=(RH/100)/((eoTmin+eoTmax)/2)
+- t0dem = surface temperature + (altitude * 0.627 / 100)
+<H2>SEE ALSO</H2>
+<ul>
+ <li><a href=i.eb.z0m.html>i.eb.rohair</a>,
+ <a href=i.eb.z0m.html>i.eb.z0m</a>,
+ <a href=i.eb.z0m0.html>i.eb.z0m0</a>,
+ <a href=i.eb.h_iter.html>i.eb.h_iter</a>,
+ <a href=i.eb.h0.html>i.eb.h0</a>
+</ul>
+<H2>AUTHORS</H2>
+ <p>
+ <i>
+ <br>Yann Chemin, International Rice Research Institute, Los Banos, The Philippines.
+ </i>
+ <p>Contact: <a href="mailto:y.chemin at cgiar.org"> Yann chemin</a>
+<H2>REFERENCES</H2>
+ <p>[1] Bastiaanssen, W.G.M., 1995.
+ Estimation of Land surface paramters by remote sensing under clear-sky conditions. PhD thesis, Wageningen University, Wageningen, The Netherlands.
+ <p>[2] Chemin Y., Alexandridis T.A., 2001.
+<p><i>Last changed: $Date: 2008/08/01 09:00:00 $</i>
+</body>
+</html>
Property changes on: grass-addons/gipe/i.eb.h_SEBAL01/description.html
___________________________________________________________________
Added: grass-addons/gipe/i.eb.h_SEBAL01/main.c
--- grass-addons/gipe/i.eb.h_SEBAL01/main.c (rev 0)
+++ grass-addons/gipe/i.eb.h_SEBAL01/main.c 2008-08-03 09:43:49 UTC (rev 32479)
@@ -0,0 +1,661 @@
+ * MODULE: i.eb.h_SEBAL01
+ * AUTHOR(S): Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE: Calculates sensible heat flux by SEBAL iteration
+ * Delta T will be reassessed in the iterations !
+ * This has been seen in Bastiaanssen (1995),
+ * later modified by Chemin and Alexandridis (2001).
+ * COPYRIGHT: (C) 2002-2009 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+ * CHANGELOG:
+#include <stdio.h>
+#include <string.h>
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#define PI 3.14159265358979
+double **G_alloc_matrix (int rows, int cols)
+ double **m;
+ int i;
+ m = (double **) G_calloc (rows, sizeof(double *));
+ m[0] = (double *) G_calloc (rows*cols, sizeof(double));
+ for (i = 1; i < rows; i++)
+ m[i] = m[i-1] + cols;
+ return m;
+int main(int argc, char *argv[])
+ struct Cell_head cellhd;
+ char *mapset; // mapset name
+ /* buffer for in, tmp and out raster */
+ void *inrast_z0m, *inrast_t0dem;
+ DCELL *outrast;
+ int nrows, ncols;
+ int row, col;
+ int row_wet, col_wet;
+ int row_dry, col_dry;
+ double m_row_wet, m_col_wet;
+ double m_row_dry, m_col_dry;
+ int infd_z0m, infd_t0dem;
+ //int tmprohfd, tmprahfd;
+ int outfd;
+ char *mapset_z0m, *mapset_t0dem;
+ char *z0m, *t0dem;
+ char *h0;
+ double ustar, ea, h_dry;
+ struct History history;
+ struct GModule *module;
+ struct Option *input_z0m, *input_t0dem, *input_ustar;
+ struct Option *input_ea, *input_h_dry, *output;
+ struct Option *input_row_wet, *input_col_wet;
+ struct Option *input_row_dry, *input_col_dry;
+ struct Flag *flag3;
+ RASTER_MAP_TYPE data_type_z0m;
+ RASTER_MAP_TYPE data_type_t0dem;
+ RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
+ double xp, yp;
+ double xmin, ymin;
+ double xmax, ymax;
+ double stepx,stepy;
+ double latitude, longitude;
+ int rowDry, colDry, rowWet, colWet;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->description = _("Sensible Heat Flux iteration SEBAL 01");
+ /* Define different options */
+ input_z0m = G_define_standard_option(G_OPT_R_INPUT);
+ input_z0m->key = "z0m";
+ input_z0m->description = _("Name of aerodynamic resistance to heat momentum [s/m]");
+ input_t0dem = G_define_standard_option(G_OPT_R_INPUT);
+ input_t0dem->key = "t0dem";
+ input_t0dem->description = _("Name of altitude corrected surface temperature [K]");
+ input_ustar = G_define_option();
+ input_ustar->key = "ustar";
+ input_ustar->type = TYPE_DOUBLE;
+ input_ustar->required = YES;
+ input_ustar->gisprompt = "old,value";
+ input_ustar->answer = "0.32407";
+ input_ustar->description = _("Value of the friction velocity [m/s]");
+ input_ustar->guisection = _("Parameters");
+ input_ea = G_define_option();
+ input_ea->key = "ea";
+ input_ea->type = TYPE_DOUBLE;
+ input_ea->required = YES;
+ input_ea->gisprompt = "old,value";
+ input_ea->answer = "1.511";
+ input_ea->description = _("Value of the actual vapour pressure [KPa]");
+ input_ea->guisection = _("Parameters");
+ input_h_dry = G_define_option();
+ input_h_dry->key = "h_dry";
+ input_h_dry->type = TYPE_DOUBLE;
+ input_h_dry->required = YES;
+ input_h_dry->gisprompt = "old,value";
+ input_h_dry->answer = "222.07";
+ input_h_dry->description = _("Initial value of h0 at dry pixel (Rn-g0) [W/m2]");
+ input_h_dry->guisection = _("Parameters");
+ input_row_wet = G_define_option();
+ input_row_wet->key = "row_wet";
+ input_row_wet->type = TYPE_DOUBLE;
+ input_row_wet->required = YES;
+ input_row_wet->gisprompt = "old,value";
+ input_row_wet->description = _("Row value of the wet pixel");
+ input_row_wet->guisection = _("Parameters");
+ input_col_wet = G_define_option();
+ input_col_wet->key = "col_wet";
+ input_col_wet->type = TYPE_DOUBLE;
+ input_col_wet->required = YES;
+ input_col_wet->gisprompt = "old,value";
+ input_col_wet->description = _("Column value of the wet pixel");
+ input_col_wet->guisection = _("Parameters");
+ input_row_dry = G_define_option();
+ input_row_dry->key = "row_dry";
+ input_row_dry->type = TYPE_DOUBLE;
+ input_row_dry->required = YES;
+ input_row_dry->gisprompt = "old,value";
+ input_row_dry->description = _("Row value of the dry pixel");
+ input_row_dry->guisection = _("Parameters");
+ input_col_dry = G_define_option();
+ input_col_dry->key = "col_dry";
+ input_col_dry->type = TYPE_DOUBLE;
+ input_col_dry->required = YES;
+ input_col_dry->gisprompt = "old,value";
+ input_col_dry->description = _("Column value of the dry pixel");
+ input_col_dry->guisection = _("Parameters");
+ output = G_define_standard_option(G_OPT_R_OUTPUT) ;
+ output->key = "h0";
+ output->description= _("Name of output sensible heat flux layer [W/m2]");
+ /* Define the different flags */
+ flag3 = G_define_flag() ;
+ flag3->key = 'c' ;
+ flag3->description = _("Dry/Wet pixels coordinates are in image projection, not row/col");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ /* get entered parameters */
+ z0m = input_z0m->answer;
+ t0dem = input_t0dem->answer;
+ h0 = output->answer;
+ ustar = atof(input_ustar->answer);
+ ea = atof(input_ea->answer);
+ h_dry = atof(input_h_dry->answer);
+ m_row_wet = atof(input_row_wet->answer);
+ m_col_wet = atof(input_col_wet->answer);
+ m_row_dry = atof(input_row_dry->answer);
+ m_col_dry = atof(input_col_dry->answer);
+ if(flag3->answer){
+ G_message("Manual wet/dry pixels in image coordinates");
+ G_message("Wet Pixel=> x:%f y:%f",m_col_wet,m_row_wet);
+ G_message("Dry Pixel=> x:%f y:%f",m_col_dry,m_row_dry);
+ } else {
+ G_message("Wet Pixel=> row:%.0f col:%.0f",m_row_wet,m_col_wet);
+ G_message("Dry Pixel=> row:%.0f col:%.0f",m_row_dry,m_col_dry);
+ /* find maps in mapset */
+ mapset_z0m = G_find_cell2 (z0m, "");
+ if (mapset_z0m == NULL)
+ G_fatal_error (_("cell file [%s] not found"), z0m);
+ mapset_t0dem = G_find_cell2 (t0dem, "");
+ if (mapset_t0dem == NULL)
+ G_fatal_error (_("cell file [%s] not found"), t0dem);
+ /* check legal output name */
+ if (G_legal_filename (h0) < 0)
+ G_fatal_error (_("[%s] is an illegal name"), h0);
+ /* determine the input map type (CELL/FCELL/DCELL) */
+ data_type_z0m = G_raster_map_type(z0m, mapset_z0m);
+ data_type_t0dem = G_raster_map_type(t0dem, mapset_t0dem);
+ if ( (infd_z0m = G_open_cell_old (z0m, mapset_z0m)) < 0)
+ G_fatal_error (_("Cannot open cell file [%s]"), z0m);
+ if ( (infd_t0dem = G_open_cell_old (t0dem, mapset_t0dem)) < 0)
+ G_fatal_error (_("Cannot open cell file [%s]"),t0dem);
+ if (G_get_cellhd (z0m, mapset_z0m, &cellhd) < 0)
+ G_fatal_error (_("Cannot read file header of [%s]"), z0m);
+ if (G_get_cellhd (t0dem, mapset_t0dem, &cellhd) < 0)
+ G_fatal_error (_("Cannot read file header of [%s]"), t0dem);
+ /* Allocate input buffer */
+ inrast_z0m = G_allocate_raster_buf(data_type_z0m);
+ inrast_t0dem = G_allocate_raster_buf(data_type_t0dem);
+ G_debug(3, "number of rows %d",cellhd.rows);
+ /* Setup pixel location variables */
+ stepx=cellhd.ew_res;
+ stepy=cellhd.ns_res;
+ xmin=cellhd.west;
+ xmax=cellhd.east;
+ ymin=cellhd.south;
+ ymax=cellhd.north;
+ nrows = G_window_rows();
+ ncols = G_window_cols();
+ /* Allocate output buffer */
+ outrast = G_allocate_d_raster_buf();
+ if((outfd = G_open_raster_new (h0,DCELL_TYPE)) < 0)
+ G_fatal_error (_("Could not open <%s>"),h0);
+ /* Allocate memory for temporary images */
+ double **d_Roh, **d_Rah;
+ if( (d_Roh = G_alloc_matrix(nrows,ncols)) == NULL)
+ G_message("cannot allocate memory for temporary d_Roh image");
+ if( (d_Rah = G_alloc_matrix(nrows,ncols)) == NULL)
+ G_message("cannot allocate memory for temporary d_Rah image");
+ /* MANUAL T0DEM WET/DRY PIXELS */
+ DCELL d_t0dem_dry;
+ DCELL d_t0dem_wet;
+ /*DRY PIXEL*/
+ /*Calculate coordinates of row/col from projected ones*/
+ row = (int) (( ymax - m_row_dry ) / (double) stepy) ;
+ col = (int) (( m_col_dry - xmin ) / (double) stepx) ;
+ G_message("Dry Pixel | row:%i col:%i",row,col);
+ } else {
+ row = (int) m_row_dry;
+ col = (int) m_col_dry;
+ rowDry=row;
+ colDry=col;
+ if(G_get_raster_row(infd_t0dem,inrast_t0dem,row,data_type_t0dem)<0)
+ G_fatal_error(_("Could not read from <%s>"),t0dem);
+ switch(data_type_t0dem){
+ case CELL_TYPE:
+ d_t0dem_dry = (double) ((CELL *) inrast_t0dem)[col];
+ break;
+ case FCELL_TYPE:
+ d_t0dem_dry = (double) ((FCELL *) inrast_t0dem)[col];
+ break;
+ case DCELL_TYPE:
+ d_t0dem_dry = (double) ((DCELL *) inrast_t0dem)[col];
+ break;
+ /*WET PIXEL*/
+ row = (int) (( ymax - m_row_wet ) / (double) stepy) ;
+ col = (int) (( m_col_wet - xmin ) / (double) stepx) ;
+ G_message("Wet Pixel | row:%i col:%i",row,col);
+ } else {
+ row = m_row_wet;
+ col = m_col_wet;
+ rowWet=row;
+ colWet=col;
+ case CELL_TYPE:
+ d_t0dem_wet = (double) ((CELL *) inrast_t0dem)[col];
+ break;
+ case FCELL_TYPE:
+ d_t0dem_wet = (double) ((FCELL *) inrast_t0dem)[col];
+ break;
+ case DCELL_TYPE:
+ d_t0dem_wet = (double) ((DCELL *) inrast_t0dem)[col];
+ break;
+ /* END OF MANUAL WET/DRY PIXELS */
+ G_message("t0dem_dry = %f",d_t0dem_dry);
+ G_message("t0dem_wet = %f",d_t0dem_wet);
+ DCELL d_rah_dry;
+ DCELL d_roh_dry;
+ /* INITIALIZATION */
+ for (row = 0; row < nrows; row++)
+ DCELL d_t0dem;
+ DCELL d_z0m;
+ DCELL d_rah1;
+ DCELL d_roh1;
+ DCELL d_u5;
+ G_percent(row,nrows,2);
+ /* read a line input maps into buffers*/
+ if(G_get_raster_row(infd_z0m,inrast_z0m,row,data_type_z0m)<0)
+ G_fatal_error(_("Could not read from <%s>"),z0m);
+ if(G_get_raster_row(infd_t0dem,inrast_t0dem,row,data_type_t0dem) < 0)
+ /* read every cell in the line buffers */
+ for(col=0;col<ncols;col++)
+ switch(data_type_z0m){
+ case CELL_TYPE:
+ d_z0m = (double) ((CELL *) inrast_z0m)[col];
+ break;
+ case FCELL_TYPE:
+ d_z0m = (double) ((FCELL *) inrast_z0m)[col];
+ break;
+ case DCELL_TYPE:
+ d_z0m = (double) ((DCELL *) inrast_z0m)[col];
+ break;
+ case CELL_TYPE:
+ d_t0dem = (double) ((CELL *) inrast_t0dem)[col];
+ break;
+ case FCELL_TYPE:
+ d_t0dem = (double) ((FCELL *) inrast_t0dem)[col];
+ break;
+ case DCELL_TYPE:
+ d_t0dem = (double) ((DCELL *) inrast_t0dem)[col];
+ break;
+ if(G_is_d_null_value(&d_t0dem) ||
+ G_is_d_null_value(&d_z0m)){
+ /* do nothing */
+ d_Roh[row][col] = -999.9;
+ d_Rah[row][col] = -999.9;
+ } else {
+ d_u5=(ustar/0.41)*log(5/d_z0m);
+ d_rah1=(1/(d_u5*pow(0.41,2)))*log(5/d_z0m)*log(5/(d_z0m*0.1));
+ d_roh1=((998-ea)/(d_t0dem*2.87))+(ea/(d_t0dem*4.61));
+ if(d_roh1>5){
+ d_roh1=1.0;
+ } else {
+ d_roh1=((1000-4.65)/(d_t0dem*2.87))+(4.65/(d_t0dem*4.61));
+ if(row==rowDry&&col==colDry){//collect dry pix info
+ d_rah_dry = d_rah1;
+ d_roh_dry = d_roh1;
+ G_message("d_rah_dry=%f d_roh_dry=%f",d_rah_dry,d_roh_dry);
+ d_Roh[row][col] = d_roh1;
+ d_Rah[row][col] = d_rah1;
+ DCELL d_dT_dry;
+ // Calculate dT_dry
+ d_dT_dry = (h_dry*d_rah_dry)/(1004*d_roh_dry);
+ double a, b;
+ // Calculate coefficients for next dT equation
+// a = 1.0/ ((d_dT_dry-0.0) / (d_t0dem_dry-d_t0dem_wet));
+// b = ( a * d_t0dem_wet ) * (-1.0);
+ double sumx=d_t0dem_wet+d_t0dem_dry;
+ double sumy=d_dT_dry+0.0;
+ double sumx2=pow(d_t0dem_wet,2)+pow(d_t0dem_dry,2);
+ double sumxy=(d_t0dem_wet*0.0)+(d_t0dem_dry*d_dT_dry);
+ a = (sumxy - ((sumx * sumy) / 2.0)) / (sumx2 - (pow(sumx,2)/2.0));
+ b = (sumy - ( a * sumx)) / 2.0;
+ G_message("d_dT_dry=%f",d_dT_dry);
+ G_message("dT1=%f * t0dem + (%f)", a, b);
+ DCELL d_h_dry;
+ /* ITERATION 1 */
+ DCELL d_t0dem;
+ DCELL d_z0m;
+ DCELL d_h1;
+ DCELL d_rah1;
+ DCELL d_rah2;
+ DCELL d_roh1;
+ DCELL d_L;
+ DCELL d_x;
+ DCELL d_psih;
+ DCELL d_psim;
+ DCELL d_u5;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ d_rah1 = d_Rah[row][col];
+ d_roh1 = d_Roh[row][col];
+ /* do nothing */
+ } else {
+ if(d_rah1<1.0){
+ d_h1 = 0.0;
+ } else {
+ d_h1 = (1004*d_roh1)*(a*d_t0dem+b)/d_rah1;
+ d_L=-1004*d_roh1*pow(ustar,3)*d_t0dem/(d_h1*9.81*0.41);
+ d_x=pow((1-16*(5/d_L)),0.25);
+ d_psim=2*log((1+d_x)/2)+log((1+pow(d_x,2))/2)-2*atan(d_x)+0.5*PI;
+ d_psim=2*log((1+pow(d_x,2))/2);
+ d_rah2=(1/(d_u5*pow(0.41,2)))*log((5/d_z0m)-d_psim)*log((5/(d_z0m*0.1))-d_psih);
+ d_rah_dry = d_rah2;
+ d_h_dry = d_h1;
+ d_dT_dry = (d_h_dry*d_rah_dry)/(1004*d_roh_dry);
+// a = (d_dT_dry-0)/(d_t0dem_dry-d_t0dem_wet);
+// b = (-1.0) * ( a * d_t0dem_wet );
+// G_message("d_dT_dry=%f",d_dT_dry);
+// G_message("dT2=%f * t0dem + (%f)", a, b);
+ sumx=d_t0dem_wet+d_t0dem_dry;
+ sumy=d_dT_dry+0.0;
+ sumx2=pow(d_t0dem_wet,2)+pow(d_t0dem_dry,2);
+ sumxy=(d_t0dem_wet*0.0)+(d_t0dem_dry*d_dT_dry);
+ /* ITERATION 2 */
+ DCELL d_t0dem;
+ DCELL d_z0m;
+ DCELL d_rah2;
+ DCELL d_rah3;
+ DCELL d_roh1;
+ DCELL d_h2;
+ DCELL d_L;
+ DCELL d_x;
+ DCELL d_psih;
+ DCELL d_psim;
+ DCELL d_u5;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ d_rah2 = d_Rah[row][col];
+ /* do nothing */
+ } else {
+ if(d_rah2<1.0){
+ d_h2=0.0;
+ } else {
+ d_h2 = (1004*d_roh1)*(a*d_t0dem+b)/d_rah2;
+ d_L=-1004*d_roh1*pow(ustar,3)*d_t0dem/(d_h2*9.81*0.41);
+ d_rah3=(1/(d_u5*pow(0.41,2)))*log((5/d_z0m)-d_psim)*log((5/(d_z0m*0.1))-d_psih);
+ d_h_dry = d_h2;
+ d_Rah[row][col] = d_rah2;
+// G_message("dT3=%f * t0dem + (%f)", a, b);
+ /* ITERATION 3 */
+ DCELL d_t0dem;
+ DCELL d_z0m;
+ DCELL d_rah3;
+ DCELL d_roh1;
+ DCELL d_h3;
+ DCELL d_L;
+ DCELL d_x;
+ DCELL d_psih;
+ DCELL d_psim;
+ DCELL d; /* Output pixel */
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ d_rah3 = d_Rah[row][col];
+ G_set_d_null_value(&outrast[col],1);
+ } else {
+ if(d_rah3 < 1.0){
+ d_h3=0.0;
+ } else {
+ d_h3 = (1004*d_roh1)*(a*d_t0dem+b)/d_rah3;
+ if( d_h3 < 0 && d_h3 > -50 ){
+ d_h3 = 0.0;
+ if( d_h3 < -50 || d_h3 > 1000 ){
+ outrast[col] = d_h3;
+ if (G_put_d_raster_row (outfd, outrast) < 0)
+ G_fatal_error ("Cannot write to output file <%s>",h0);
+ G_free(inrast_z0m);
+ G_close_cell (infd_z0m);
+ G_free(inrast_t0dem);
+ G_close_cell (infd_t0dem);
+ G_free(outrast);
+ G_close_cell (outfd);
+ /* add command line incantation to history file */
+ G_short_history(h0, "raster", &history);
+ G_command_history(&history);
+ G_write_history(h0, &history);
+ exit(EXIT_SUCCESS);
Modified: grass-addons/gipe/menudata.py
--- grass-addons/gipe/menudata.py 2008-08-03 08:02:57 UTC (rev 32478)
+++ grass-addons/gipe/menudata.py 2008-08-03 09:43:49 UTC (rev 32479)
@@ -1576,6 +1576,10 @@
_("sensible heat flux iteration (SEBAL95)"),
"self.RunMenuCmd",
"i.eb.h_SEBAL95"),
+ (_("Sensible heat flux iteration (SEBAL01)"),
+ _("sensible heat flux iteration (SEBAL01)"),
+ "self.RunMenuCmd",
+ "i.eb.h_SEBAL01"),
(_("Evaporative fraction"),
_("evaporative fraction"),
