[GRASS-SVN] r32481 - in grass/trunk/gui: icons/silk
wxpython/gui_modules wxpython/icons/silk
svn_grass at osgeo.org
Sun Aug 3 06:06:45 EDT 2008
Author: martinl
Date: 2008-08-03 06:06:45 -0400 (Sun, 03 Aug 2008)
New Revision: 32481
Added:
grass/trunk/gui/icons/silk/map_edit.png
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/utils.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
grass/trunk/gui/wxpython/icons/silk/__init__.py
wxGUI: some fixes related to the last changes in layer manager items, edit icon added for silk theme
Added: grass/trunk/gui/icons/silk/map_edit.png
(Binary files differ)
Property changes on: grass/trunk/gui/icons/silk/map_edit.png
___________________________________________________________________
+ image/png
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-08-03 09:46:40 UTC (rev 32480)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-08-03 10:06:45 UTC (rev 32481)
@@ -2162,7 +2162,7 @@
zoomreg = {}
layer = self.GetSelectedLayer()
if layer is None:
return
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2008-08-03 09:46:40 UTC (rev 32480)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2008-08-03 10:06:45 UTC (rev 32481)
@@ -68,6 +68,9 @@
mapname = ''
+ if len(dcmd) < 1:
+ return mapname
if 'd.grid' == dcmd[0]:
mapname = 'grid'
elif 'd.geodesic' in dcmd[0]:
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-03 09:46:40 UTC (rev 32480)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-03 10:06:45 UTC (rev 32481)
@@ -470,7 +470,7 @@
opacity_pct = int(new_opacity * 100)
layername = self.GetItemText(self.layer_selected)
layerbase = layername.split('(')[0].strip()
- self.SetItemText(self.layer_selected, \
+ self.SetItemText(self.layer_selected,
layerbase + ' (opacity: ' + str(opacity_pct) + '%)')
# redraw map if auto-rendering is enabled
@@ -528,7 +528,7 @@
self.groupnode += 1
else:
btnbmp = Icons["layeropts"].GetBitmap((16,16))
- ctrl = buttons.GenBitmapButton(self, id=wx.ID_ANY, bitmap=btnbmp)
+ ctrl = buttons.GenBitmapButton(self, id=wx.ID_ANY, bitmap=btnbmp, size=(24,24))
ctrl.SetToolTipString(_("Click to edit layer settings"))
self.Bind(wx.EVT_BUTTON, self.OnLayerContextMenu, ctrl)
# add layer to the layer tree
@@ -622,7 +622,7 @@
if ltype != 'group':
if lopacity:
- opacity = int(l_opacity * 100)
+ opacity = int(lopacity * 100)
else:
opacity = 100
@@ -669,6 +669,8 @@
# use predefined layer name if given
if lname:
if ltype != 'command':
+ if opacity:
+ lname = lname + ' (opacity: ' + str(opacity) + '%)'
self.SetItemText(layer, lname)
else:
ctrl.SetValue(lname)
@@ -1162,8 +1164,12 @@
opac = self.GetPyData(item)[0]['maplayer'].GetOpacity(float=True)
chk = self.IsItemChecked(item)
hidden = not self.IsVisible(item)
+ # determine layer name
+ layerName = utils.GetLayerNameFromCmd(cmdlist, fullyQualified=True)
+ if not layerName:
+ layerName = self.GetItemText(item)
maplayer = self.Map.ChangeLayer(layer=self.GetPyData(item)[0]['maplayer'], type=type,
- command=cmdlist, name=self.GetItemText(item),
+ command=cmdlist, name=layerName,
l_active=chk, l_hidden=hidden, l_opacity=opac, l_render=False)
self.GetPyData(item)[0]['maplayer'] = maplayer
Modified: grass/trunk/gui/wxpython/icons/silk/__init__.py
--- grass/trunk/gui/wxpython/icons/silk/__init__.py 2008-08-03 09:46:40 UTC (rev 32480)
+++ grass/trunk/gui/wxpython/icons/silk/__init__.py 2008-08-03 10:06:45 UTC (rev 32481)
@@ -79,6 +79,7 @@
"addhis" : 'his.png',
"addthematic": 'thematic.png',
"addchart" : 'chart_bar.png',
+ "layeropts" : 'map_edit.png',
# profile analysis
"transect" : 'image_edit.png',
"profiledraw" : 'arrow_refresh.png',
