[GRASS-SVN] r32487 - in grass/trunk/gui/wxpython: . gui_modules
icons scripts
svn_grass at osgeo.org
Sun Aug 3 07:20:50 EDT 2008
Author: martinl
Date: 2008-08-03 07:20:50 -0400 (Sun, 03 Aug 2008)
New Revision: 32487
Added:
grass/trunk/gui/wxpython/scripts/Makefile
grass/trunk/gui/wxpython/scripts/d.rast3d
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
grass/trunk/gui/wxpython/icons/icon.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: 3d raster map (voxel) dialog added
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-08-03 11:00:36 UTC (rev 32486)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-08-03 11:20:50 UTC (rev 32487)
@@ -199,7 +199,7 @@
def SetType(self, type):
"""Set layer type"""
- if type not in ('raster', 'vector', 'overlay', 'command'):
+ if type not in ('raster', '3d-raster', 'vector', 'overlay', 'command'):
raise gcmd.GStdError(_("Unsupported map layer type '%s'") % str(type))
self.type = type
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-03 11:00:36 UTC (rev 32486)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-03 11:20:50 UTC (rev 32487)
@@ -128,6 +128,9 @@
trgif = Icons["addrast"].GetBitmap(bmpsize)
self.rast_icon = il.Add(trgif)
+ trgif = Icons["addrast3d"].GetBitmap(bmpsize)
+ self.rast3d_icon = il.Add(trgif)
trgif = Icons["addrgb"].GetBitmap(bmpsize)
self.rgb_icon = il.Add(trgif)
@@ -497,7 +500,7 @@
"""Add new item to the layer tree, create corresponding MapLayer instance.
Launch property dialog if needed (raster, vector, etc.)
- @param ltype layer type (raster, vector, ...)
+ @param ltype layer type (raster, vector, 3d-raster, ...)
@param lname layer name
@param lchecked if True layer is checked
@param lopacity layer opacity level
@@ -577,6 +580,9 @@
if ltype == 'raster':
self.SetItemImage(layer, self.rast_icon)
self.SetItemText(layer, '%s %s' % (_('raster'), _('(double click to set properties)')))
+ elif ltype == '3d-raster':
+ self.SetItemImage(layer, self.rast3d_icon)
+ self.SetItemText(layer, '%s %s' % (_('3d raster'), _('(double click to set properties)')))
elif ltype == 'rgb':
self.SetItemImage(layer, self.rgb_icon)
self.SetItemText(layer, '%s %s' % (_('RGB'), _('(double click to set properties)')))
@@ -713,6 +719,10 @@
cmd.append('-o')
menuform.GUI().ParseCommand(cmd, completed=(self.GetOptData,layer,params),
parentframe=self)
+ cmd = ['d.rast3d']
+ menuform.GUI().ParseCommand(cmd, completed=(self.GetOptData,layer,params),
+ parentframe=self)
menuform.GUI().ParseCommand(['d.rgb'], completed=(self.GetOptData,layer,params),
parentframe=self)
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py 2008-08-03 11:00:36 UTC (rev 32486)
+++ grass/trunk/gui/wxpython/icons/icon.py 2008-08-03 11:20:50 UTC (rev 32487)
@@ -80,14 +80,14 @@
"digUndo" : wx.ART_ERROR, # FIXME
"digSettings" : 'settings.gif',
"digAdditionalTools" : wx.ART_ERROR, # FIXME
- # gis manager
+ # layer manager
"newdisplay" : 'gui-startmon.gif',
"workspaceNew" : 'file-new.gif',
"workspaceLoad" : 'file-new.gif', # change the icon if possible
"workspaceOpen" : 'file-open.gif',
"workspaceSave" : 'file-save.gif',
"addrast" : 'element-cell.gif',
- "addrast3d" : 'element-grid3.gif',
+ "addrast3d" : 'element-grid3.gif',
"addvect" : 'element-vector.gif',
"addcmd" : 'gui-cmd.gif',
"addgrp" : 'gui-group.gif',
Added: grass/trunk/gui/wxpython/scripts/Makefile
--- grass/trunk/gui/wxpython/scripts/Makefile (rev 0)
+++ grass/trunk/gui/wxpython/scripts/Makefile 2008-08-03 11:20:50 UTC (rev 32487)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR = ../../..
+include $(MODULE_TOPDIR)/include/Make/Platform.make
+include $(MODULE_TOPDIR)/include/Make/Dir.make
+ETCDIR = $(ETC)/gui/scripts
+default: install_scripts
+install_scripts:
+ $(MKDIR) $(ETCDIR)
+ $(INSTALL) d.rast3d $(ETCDIR)/
+clean: cleansubdirs
Added: grass/trunk/gui/wxpython/scripts/d.rast3d
--- grass/trunk/gui/wxpython/scripts/d.rast3d (rev 0)
+++ grass/trunk/gui/wxpython/scripts/d.rast3d 2008-08-03 11:20:50 UTC (rev 32487)
@@ -0,0 +1,40 @@
+#!/bin/sh
+# MODULE: d.rast3d
+# AUTHOR(S): Martin Landa <landa.martin gmail.com>
+# PURPOSE: Wrapper for wxGUI -- add 3d raster map layer into layer tree
+# COPYRIGHT: (C) 2008 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Displays 3d raster data in the active frame on the graphics monitor.
+#% keywords: display, raster3d, voxel
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,grid3,3d-raster
+#% description: 3D raster map to be displayed
+#% required : yes
+#%END
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+exit 0
Property changes on: grass/trunk/gui/wxpython/scripts/d.rast3d
___________________________________________________________________
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-08-03 11:00:36 UTC (rev 32486)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-08-03 11:20:50 UTC (rev 32487)
@@ -1217,17 +1217,17 @@
addvect = wx.MenuItem(vectmenu, -1, Icons["addvect"].GetLabel())
addvect.SetBitmap(Icons["addvect"].GetBitmap(self.iconsize))
vectmenu.AppendItem(addvect)
- self.Bind(wx.EVT_MENU, self.addVector, addvect)
+ self.Bind(wx.EVT_MENU, self.AddVector, addvect)
addtheme = wx.MenuItem(vectmenu, -1, Icons["addthematic"].GetLabel())
addtheme.SetBitmap(Icons["addthematic"].GetBitmap(self.iconsize))
vectmenu.AppendItem(addtheme)
- self.Bind(wx.EVT_MENU, self.addThemeMap, addtheme)
+ self.Bind(wx.EVT_MENU, self.AddThemeMap, addtheme)
addchart = wx.MenuItem(vectmenu, -1, Icons["addchart"].GetLabel())
addchart.SetBitmap(Icons["addchart"].GetBitmap(self.iconsize))
vectmenu.AppendItem(addchart)
- self.Bind(wx.EVT_MENU, self.addThemeChart, addchart)
+ self.Bind(wx.EVT_MENU, self.AddThemeChart, addchart)
# Popup the menu. If an item is selected then its handler
# will be called before PopupMenu returns.
@@ -1273,6 +1273,10 @@
self.notebook.SetSelection(0)
self.curr_page.maptree.AddLayer('raster')
+ def AddRaster3d(self, event):
+ self.notebook.SetSelection(0)
+ self.curr_page.maptree.AddLayer('3d-raster')
def AddRGB(self, event):
"""Add RGB layer"""
@@ -1298,21 +1302,17 @@
self.curr_page.maptree.AddLayer('rastnum')
- def AddRaster3d(self, event):
- self.notebook.SetSelection(0)
- self.curr_page.maptree.AddLayer('raster')
- def addVector(self, event):
+ def AddVector(self, event):
"""Add vector layer"""
self.curr_page.maptree.AddLayer('vector')
- def addThemeMap(self, event):
+ def AddThemeMap(self, event):
"""Add thematic map layer"""
self.curr_page.maptree.AddLayer('thememap')
- def addThemeChart(self, event):
+ def AddThemeChart(self, event):
"""Add thematic chart layer"""
self.curr_page.maptree.AddLayer('themechart')
