[GRASS-SVN] r32497 -
grass/branches/develbranch_6/scripts/v.what.vect
svn_grass at osgeo.org
Sun Aug 3 14:06:32 EDT 2008
Author: marisn
Date: 2008-08-03 14:06:32 -0400 (Sun, 03 Aug 2008)
New Revision: 32497
grass/branches/develbranch_6/scripts/v.what.vect/description.html
grass/branches/develbranch_6/scripts/v.what.vect/v.what.vect
Added query distance. Allows to upload values also from points
Modified: grass/branches/develbranch_6/scripts/v.what.vect/description.html
--- grass/branches/develbranch_6/scripts/v.what.vect/description.html 2008-08-03 18:04:50 UTC (rev 32496)
+++ grass/branches/develbranch_6/scripts/v.what.vect/description.html 2008-08-03 18:06:32 UTC (rev 32497)
@@ -9,8 +9,8 @@
The upload <b>column</b>, into which the query results are stored, must be
present in the <b>vector</b> map. Use <em>v.db.addcol</em> to add one if needed.
<p>
-This module only uploads attributes which exist at the exact positions of
-the input's <b>vector</b> points. For a "nearest feature" fit, use
+Use dmax parameter to control query distance tolerance (how far points can be from
+<b>qvector</b> features). For more options, use
<em>v.distance</em> instead.
<P>
In case of a multipoint input <b>vector</b> map, with several points having the
Modified: grass/branches/develbranch_6/scripts/v.what.vect/v.what.vect
--- grass/branches/develbranch_6/scripts/v.what.vect/v.what.vect 2008-08-03 18:04:50 UTC (rev 32496)
+++ grass/branches/develbranch_6/scripts/v.what.vect/v.what.vect 2008-08-03 18:06:32 UTC (rev 32497)
@@ -61,6 +61,13 @@
#% description: Column to be queried
#% required : yes
#%end
+#%option
+#% key: dmax
+#% type: double
+#% description: Maximum query distance in map units
+#% answer: 0.0
+#% required: no
+#%end
if [ -z "$GISBASE" ] ; then
@@ -72,12 +79,11 @@
exec g.parser "$0" "$@"
fi
exec v.distance from="$GIS_OPT_VECTOR" \
to="$GIS_OPT_QVECTOR" \
column="$GIS_OPT_COLUMN" \
to_column="$GIS_OPT_QCOLUMN" \
upload=to_attr \
- dmax=0 \
+ dmax=$GIS_OPT_DMAX \
from_layer=$GIS_OPT_LAYER \
to_layer=$GIS_OPT_QLAYER
