[GRASS-SVN] r32502 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Aug 4 00:56:52 EDT 2008
Author: cmbarton
Date: 2008-08-04 00:56:52 -0400 (Mon, 04 Aug 2008)
New Revision: 32502
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
Bug fixes for layer management
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-03 20:19:04 UTC (rev 32501)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-04 04:56:52 UTC (rev 32502)
@@ -715,6 +715,7 @@
self.GetPyData(layer)[0]['cmd'] = cmdValidated
elif ltype == 'raster':
cmd = ['d.rast']
if UserSettings.Get(group='cmd', key='rasterOverlay', subkey='enabled'):
cmd.append('-o')
menuform.GUI().ParseCommand(cmd, completed=(self.GetOptData,layer,params),
@@ -890,7 +891,7 @@
layer = self.GetNextVisible(layer)
# change parameters for item in layers list in render.Map
- if layer and self.drag == False:
+ if layer == False:
self.ChangeLayer(layer)
self.GetPyData(layer)[0]['cmd'] = cmd.split(' ')
maplayer = self.GetPyData(layer)[0]['maplayer']
@@ -993,9 +994,13 @@
# reorder layers in render.Map to match new order after drag and drop
self.ReorderLayers()
+ # redraw map if auto-rendering is enabled
+ if self.mapdisplay.autoRender.GetValue():
+ self.mapdisplay.OnRender(None)
# select new item
self.SelectItem(newItem)
def RecreateItem (self, dragItem, dropTarget, parent=None):
Recreate item (needed for OnEndDrag())
@@ -1011,7 +1016,7 @@
# recreate spin/text control for layer
btnbmp = Icons["layeropts"].GetBitmap((16,16))
newctrl = buttons.GenBitmapButton(self, id=wx.ID_ANY, bitmap=btnbmp)
- newctrl.SetToolTip(_("Click to edit layer settings"))
+ newctrl.SetToolTipString(_("Click to edit layer settings"))
self.Bind(wx.EVT_BUTTON, self.OnLayerContextMenu, newctrl)
opacity = self.GetPyData(dragItem)[0]['maplayer'].GetOpacity()
windval = self.GetPyData(dragItem)[0]['maplayer'].GetOpacity()
@@ -1140,7 +1145,7 @@
itemList = ""
- for item in range(0, self.GetCount()):
+ for item in range(self.GetCount()):
itemList += self.GetItemText(vislayer) + ','
if self.GetPyData(vislayer)[0]['type'] != 'group':
treelayers.append(self.GetPyData(vislayer)[0]['maplayer'])
