[GRASS-SVN] r32506 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Aug 4 04:57:50 EDT 2008
Author: martinl
Date: 2008-08-04 04:57:50 -0400 (Mon, 04 Aug 2008)
New Revision: 32506
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
grass/trunk/gui/wxpython/gui_modules/menudata.py
wxGUI: ImportDxfFile dialog fixes
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2008-08-04 07:54:46 UTC (rev 32505)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2008-08-04 08:57:50 UTC (rev 32506)
@@ -36,6 +36,7 @@
import gselect
import menuform
import utils
+import grass
from preferences import globalSettings as UserSettings
class NewVectorDialog(wx.Dialog):
@@ -733,12 +734,12 @@
# list of layers
- self.list = LayersList(self)
+ self.list = LayersList(self.panel)
self.list.LoadData()
self.add = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
label=_("Add imported layers into layer tree"))
- self.add.SetValue(True)
+ self.add.SetValue(UserSettings.Get(group='cmd', key='addNewLayer', subkey='enabled'))
# buttons
@@ -748,16 +749,11 @@
self.btn_cancel.SetToolTipString(_("Close dialog"))
self.btn_cancel.Bind(wx.EVT_BUTTON, self.OnCancel)
# run
- self.btn_run = wx.Button(parent=self.panel, id=wx.ID_OK, label= _("&Run"))
+ self.btn_run = wx.Button(parent=self.panel, id=wx.ID_OK, label= _("&Import"))
self.btn_run.SetToolTipString(_("Import selected layers"))
self.btn_run.SetDefault()
self.btn_run.Enable(False)
self.btn_run.Bind(wx.EVT_BUTTON, self.OnRun)
- # abort
- self.btn_abort = wx.Button(parent=self.panel, id=wx.ID_STOP)
- self.btn_abort.SetToolTipString(_("Abort the running command"))
- self.btn_abort.Enable(False)
- self.btn_abort.Bind(wx.EVT_BUTTON, self.OnAbort)
self.__doLayout()
self.Layout()
@@ -789,7 +785,7 @@
layerSizer = wx.StaticBoxSizer(layerBox, wx.HORIZONTAL)
layerSizer.Add(item=self.list, proportion=1,
- flag=wx.ALL | wx.EXPAND, border=5)
+ flag=wx.ALL | wx.EXPAND, border=5)
dialogSizer.Add(item=layerSizer, proportion=1,
flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
@@ -806,10 +802,6 @@
flag=wx.ALL | wx.ALIGN_CENTER,
border=10)
- btnsizer.Add(item=self.btn_abort, proportion=0,
- flag=wx.ALL | wx.ALIGN_CENTER,
- border=10)
btnsizer.Add(item=self.btn_run, proportion=0,
border=10)
@@ -818,15 +810,15 @@
flag=wx.ALIGN_CENTER)
# dialogSizer.SetSizeHints(self.panel)
- # self.panel.SetAutoLayout(True)
+ self.panel.SetAutoLayout(True)
self.panel.SetSizer(dialogSizer)
dialogSizer.Fit(self.panel)
self.Layout()
# auto-layout seems not work here - FIXME
- self.SetMinSize((globalvar.DIALOG_GSELECT_SIZE[0] + 125, 200))
+ self.SetMinSize((globalvar.DIALOG_GSELECT_SIZE[0] + 125, 300))
width = self.GetSize()[0]
- self.list.SetColumnWidth(col=1, width=width/2)
+ self.list.SetColumnWidth(col=1, width=width/2 - 50)
def OnCancel(self, event=None):
"""Close dialog"""
@@ -853,10 +845,15 @@
if self.add.IsChecked():
maptree = self.parent.curr_page.maptree
for layer, output in data:
+ if '@' not in output:
+ name = output + '@' + grass.gisenv()['MAPSET']
+ else:
+ name = output
# add imported layers into layer tree
maptree.AddLayer(ltype='vector',
- lname=output,
- lcmd=['d.vect', 'map=%s' % output])
+ lname=name,
+ lcmd=['d.vect',
+ 'map=%s' % name])
self.parent.notebook.SetSelection(0)
@@ -915,6 +912,9 @@
self.InsertColumn(1, _('Layer name'))
self.InsertColumn(2, _('Output vector map name (editable)'))
+ self.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnPopupMenu) #wxMSW
+ self.Bind(wx.EVT_RIGHT_UP, self.OnPopupMenu) #wxGTK
def LoadData(self, data=None):
"""Load data into list"""
if data is None:
@@ -928,7 +928,51 @@
self.CheckItem(index, True)
self.SetColumnWidth(col=0, width=wx.LIST_AUTOSIZE_USEHEADER)
+ def OnPopupMenu(self, event):
+ """Show popup menu"""
+ if self.GetItemCount() < 1:
+ return
+ if not hasattr(self, "popupDataID1"):
+ self.popupDataID1 = wx.NewId()
+ self.popupDataID2 = wx.NewId()
+ self.Bind(wx.EVT_MENU, self.OnSelectAll, id=self.popupDataID1)
+ self.Bind(wx.EVT_MENU, self.OnSelectNone, id=self.popupDataID2)
+ # generate popup-menu
+ menu = wx.Menu()
+ menu.Append(self.popupDataID1, _("Select all"))
+ menu.Append(self.popupDataID2, _("Deselect all"))
+ self.PopupMenu(menu)
+ menu.Destroy()
+ def OnSelectAll(self, event):
+ """Select all items"""
+ item = -1
+ while True:
+ item = self.GetNextItem(item)
+ if item == -1:
+ break
+ self.CheckItem(item, True)
+ event.Skip()
+ def OnSelectNone(self, event):
+ """Deselect items"""
+ item = -1
+ while True:
+ item = self.GetNextItem(item, wx.LIST_STATE_SELECTED)
+ if item == -1:
+ break
+ self.CheckItem(item, False)
+ event.Skip()
def GetLayers(self):
"""Get list of layers (layer name, output name)"""
data = []
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py 2008-08-04 07:54:46 UTC (rev 32505)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py 2008-08-04 08:57:50 UTC (rev 32506)
@@ -153,7 +153,7 @@
"self.OnMenuCmd",
"v.in.dxf"),
- (_("Multiple DXF import"),
+ (_("Multiple DXF layers import"),
_("Converts selected DXF layers to GRASS vector maps."),
"self.OnImportDxfFile",
