[GRASS-SVN] r32551 - in grass/trunk: . db/db.login general
general/g.ask general/g.proj general/manage/lib
imagery/i.class include include/Make lib lib/edit lib/gis
lib/imagery lib/init lib/proj lib/sites lib/vask
raster/r.coin raster/r.le/r.le.setup raster3d/r3.mkdspf
vector/v.transform
svn_grass at osgeo.org
Tue Aug 5 23:28:23 EDT 2008
Author: glynn
Date: 2008-08-05 23:28:21 -0400 (Tue, 05 Aug 2008)
New Revision: 32551
Removed:
grass/trunk/general/g.ask/Makefile
grass/trunk/general/g.ask/description.html
grass/trunk/general/g.ask/main.c
grass/trunk/general/manage/lib/menu.c
grass/trunk/include/edit.h
grass/trunk/include/vask.h
grass/trunk/lib/edit/Makefile
grass/trunk/lib/edit/edit_cats.c
grass/trunk/lib/edit/edit_cellhd.c
grass/trunk/lib/edit/edit_hist.c
grass/trunk/lib/gis/ask.c
grass/trunk/lib/gis/ask_cell.c
grass/trunk/lib/gis/ask_vctrs.c
grass/trunk/lib/gis/get_datum_name.c
grass/trunk/lib/gis/get_ell_name.c
grass/trunk/lib/gis/get_projname.c
grass/trunk/lib/gis/gets.c
grass/trunk/lib/gis/intr_char.c
grass/trunk/lib/gis/make_colr.c
grass/trunk/lib/gis/yes.c
grass/trunk/lib/imagery/ask_group.c
grass/trunk/lib/init/chk_dbase.c
grass/trunk/lib/init/mke_loc.c
grass/trunk/lib/init/mke_mapset.c
grass/trunk/lib/init/other.c
grass/trunk/lib/init/set_data.c
grass/trunk/lib/vask/Makefile
grass/trunk/lib/vask/README
grass/trunk/lib/vask/V_acc.c
grass/trunk/lib/vask/V_call.c
grass/trunk/lib/vask/V_clear.c
grass/trunk/lib/vask/V_const.c
grass/trunk/lib/vask/V_error.c
grass/trunk/lib/vask/V_exit.c
grass/trunk/lib/vask/V_init.c
grass/trunk/lib/vask/V_line.c
grass/trunk/lib/vask/V_ques.c
grass/trunk/lib/vask/V_support.c
grass/trunk/lib/vask/V_trim_dec.c
grass/trunk/raster/r.coin/check.c
grass/trunk/raster/r.coin/inter.c
grass/trunk/vector/v.transform/ask_trans.c
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/db/db.login/main.c
grass/trunk/general/Makefile
grass/trunk/general/g.proj/datumtrans.c
grass/trunk/general/g.proj/local_proto.h
grass/trunk/general/g.proj/main.c
grass/trunk/general/g.proj/output.c
grass/trunk/imagery/i.class/Makefile
grass/trunk/include/Make/Platform.make.in
grass/trunk/include/P_site.h
grass/trunk/include/config.h.in
grass/trunk/include/gisdefs.h
grass/trunk/include/gprojects.h
grass/trunk/include/imagedefs.h
grass/trunk/lib/Makefile
grass/trunk/lib/gis/parser.c
grass/trunk/lib/imagery/ls_groups.c
grass/trunk/lib/init/Makefile
grass/trunk/lib/proj/datum.c
grass/trunk/lib/sites/sites.c
grass/trunk/raster/r.coin/main.c
grass/trunk/raster/r.le/r.le.setup/Makefile
grass/trunk/raster3d/r3.mkdspf/main.c
grass/trunk/raster3d/r3.mkdspf/r3_find.c
grass/trunk/vector/v.transform/Makefile
Breaking stuff part 1: the 1970s called; they want their TTYs back
Remove vask, edit, curses, G_ask_*, G_yes, G_gets, I_ask_*, GPJ_ask_*
Remove g.ask, etc/set_data
Remove various terminal-interactive features
Break d.colors, g.setproj, i.class, i.ortho.photo, i.points, i.vpoints,
r.le, r.quant, r.support, r.digit, v.transform
Modified: grass/trunk/configure
--- grass/trunk/configure 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/configure 2008-08-06 03:28:21 UTC (rev 32551)
@@ -65,8 +65,6 @@
ac_help="$ac_help
--with-opendwg support openDWG functionality (default: no)"
ac_help="$ac_help
- --with-curses support Curses functionality (default: yes)"
-ac_help="$ac_help
--with-python[=path/python-config] enable support for Python SWIG bindings (python-config with path, \
e.g. '--with-python=/usr/bin/python2.5-config', default: no)"
ac_help="$ac_help
@@ -724,7 +722,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:728: checking host system type" >&5
+echo "configure:726: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -747,7 +745,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:751: checking for $ac_word" >&5
+echo "configure:749: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -774,7 +772,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:778: checking for $ac_word" >&5
+echo "configure:776: checking for $ac_word" >&5
@@ -822,7 +820,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:826: checking for $ac_word" >&5
+echo "configure:824: checking for $ac_word" >&5
@@ -851,7 +849,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:855: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:853: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -862,12 +860,12 @@
cat > conftest.$ac_ext << EOF
-#line 866 "configure"
+#line 864 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -893,19 +891,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:897: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:895: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:902: checking whether we are using GNU C" >&5
+echo "configure:900: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:907: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -923,7 +921,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:927: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:925: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -952,10 +950,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:956: checking for Cygwin environment" >&5
+echo "configure:954: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 959 "configure"
+#line 957 "configure"
int main() {
@@ -966,7 +964,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:970: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:968: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -982,17 +980,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:986: checking for mingw32 environment" >&5
+echo "configure:984: checking for mingw32 environment" >&5
-#line 989 "configure"
+#line 987 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:994: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1010,7 +1008,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1014: checking for executable suffix" >&5
+echo "configure:1012: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1029,23 +1027,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1033: checking for full floating-point support" >&5
+echo "configure:1031: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1038: checking whether "cc -mieee" works" >&5
+echo "configure:1036: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1042 "configure"
+#line 1040 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1049: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1047: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1061,7 +1059,7 @@
else
-#line 1065 "configure"
+#line 1063 "configure"
#include <float.h>
@@ -1075,7 +1073,7 @@
EOF
-if { (eval echo configure:1079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1088,14 +1086,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1092: checking for full floating-point support with -mieee" >&5
+echo "configure:1090: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1099 "configure"
+#line 1097 "configure"
#include <float.h>
@@ -1109,7 +1107,7 @@
EOF
-if { (eval echo configure:1113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1146,7 +1144,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1150: checking for $ac_word" >&5
+echo "configure:1148: checking for $ac_word" >&5
case "$pwd" in
@@ -1184,7 +1182,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1188: checking for source directory" >&5
+echo "configure:1186: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1195,7 +1193,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1199: checking for build directory" >&5
+echo "configure:1197: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1280,7 +1278,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1284: checking for MacOSX App" >&5
+echo "configure:1282: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1303,7 +1301,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1307: checking how to build libraries" >&5
+echo "configure:1305: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1346,7 +1344,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:1350: checking for $ac_word" >&5
+echo "configure:1348: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1371,7 +1369,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1375: checking how to run the C preprocessor" >&5
+echo "configure:1373: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1384,13 +1382,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 1388 "configure"
+#line 1386 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1394: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1392: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1401,13 +1399,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1405 "configure"
+#line 1403 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1411: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1409: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1418,13 +1416,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1422 "configure"
+#line 1420 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1452,7 +1450,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1456: checking if 64bit support is requested" >&5
+echo "configure:1454: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1472,7 +1470,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1476: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1474: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1496,7 +1494,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1500: checking system version (for dynamic loading)" >&5
+echo "configure:1498: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1522,13 +1520,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1526: checking for dlopen in -ldl" >&5
+echo "configure:1524: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1532 "configure"
+#line 1530 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1539,7 +1537,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1586,7 +1584,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1590: checking for $ac_word" >&5
+echo "configure:1588: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1715,13 +1713,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1719: checking for gettimeofday in -lbsd" >&5
+echo "configure:1717: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1725 "configure"
+#line 1723 "configure"
@@ -1732,7 +1730,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1773,13 +1771,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1777: checking for inet_ntoa in -lbind" >&5
+echo "configure:1775: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1783 "configure"
+#line 1781 "configure"
@@ -1790,7 +1788,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1851,13 +1849,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1855: checking for shl_load in -ldld" >&5
+echo "configure:1853: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1861 "configure"
+#line 1859 "configure"
@@ -1868,7 +1866,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1933,13 +1931,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:1937: checking for shl_load in -ldld" >&5
+echo "configure:1935: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 1943 "configure"
+#line 1941 "configure"
@@ -1950,7 +1948,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2072,15 +2070,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2076: checking for dld.h" >&5
+echo "configure:2074: checking for dld.h" >&5
-#line 2079 "configure"
+#line 2077 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2084: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2082: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2140,15 +2138,15 @@
else
-echo "configure:2144: checking for dld.h" >&5
+echo "configure:2142: checking for dld.h" >&5
-#line 2147 "configure"
+#line 2145 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2150: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2245,9 +2243,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2249: checking for ELF" >&5
+echo "configure:2247: checking for ELF" >&5
-#line 2251 "configure"
+#line 2249 "configure"
#ifdef __ELF__
@@ -2277,15 +2275,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2281: checking for dlfcn.h" >&5
+echo "configure:2279: checking for dlfcn.h" >&5
-#line 2284 "configure"
+#line 2282 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2287: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2309,9 +2307,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2313: checking for ELF" >&5
+echo "configure:2311: checking for ELF" >&5
-#line 2315 "configure"
+#line 2313 "configure"
#ifdef __ELF__
@@ -2635,17 +2633,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2639: checking for ld accepts -Bexport flag" >&5
+echo "configure:2637: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2642 "configure"
+#line 2640 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -2983,16 +2981,6 @@
fi
-# Check whether --with-curses or --without-curses was given.
-if test "${with_curses+set}" = set; then
- withval="$with_curses"
-else
- with_curses=yes
-fi
# Check whether --with-python or --without-python was given.
if test "${with_python+set}" = set; then
withval="$with_python"
@@ -3398,7 +3386,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3402: checking for additional include dirs" >&5
+echo "configure:3390: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3421,7 +3409,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3425: checking for additional library dirs" >&5
+echo "configure:3413: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3455,7 +3443,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3459: checking for a BSD compatible install" >&5
+echo "configure:3447: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3508,7 +3496,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3512: checking for $ac_word" >&5
+echo "configure:3500: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3539,13 +3527,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3543: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3531: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3549 "configure"
+#line 3537 "configure"
@@ -3556,7 +3544,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3581,7 +3569,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3585: checking for $ac_word" >&5
+echo "configure:3573: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3621,7 +3609,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3625: checking for $ac_word" >&5
+echo "configure:3613: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3652,7 +3640,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3656: checking for $ac_word" >&5
+echo "configure:3644: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3690,7 +3678,7 @@
-echo "configure:3694: checking for $ac_word" >&5
+echo "configure:3682: checking for $ac_word" >&5
@@ -3719,7 +3707,7 @@
-echo "configure:3723: checking for $ac_word" >&5
+echo "configure:3711: checking for $ac_word" >&5
@@ -3750,7 +3738,7 @@
-echo "configure:3754: checking for $ac_word" >&5
+echo "configure:3742: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3779,7 +3767,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3783: checking for $ac_word" >&5
+echo "configure:3771: checking for $ac_word" >&5
case "$PERL" in
@@ -3810,10 +3798,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3814: checking for ANSI C header files" >&5
+echo "configure:3802: checking for ANSI C header files" >&5
-#line 3817 "configure"
+#line 3805 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3821,7 +3809,7 @@
#include <float.h>
EOF
-{ (eval echo configure:3825: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3813: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3838,7 +3826,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3842 "configure"
+#line 3830 "configure"
#include <string.h>
EOF
@@ -3856,7 +3844,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3860 "configure"
+#line 3848 "configure"
#include <stdlib.h>
EOF
@@ -3877,7 +3865,7 @@
else
-#line 3881 "configure"
+#line 3869 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3888,7 +3876,7 @@
exit (0); }
EOF
-if { (eval echo configure:3892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -3915,15 +3903,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3919: checking for $ac_hdr" >&5
+echo "configure:3907: checking for $ac_hdr" >&5
-#line 3922 "configure"
+#line 3910 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3927: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3915: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3952,15 +3940,15 @@
do
-echo "configure:3956: checking for $ac_hdr" >&5
+echo "configure:3944: checking for $ac_hdr" >&5
-#line 3959 "configure"
+#line 3947 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3952: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3989,15 +3977,15 @@
do
-echo "configure:3993: checking for $ac_hdr" >&5
+echo "configure:3981: checking for $ac_hdr" >&5
-#line 3996 "configure"
+#line 3984 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3989: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4026,15 +4014,15 @@
do
-echo "configure:4030: checking for $ac_hdr" >&5
+echo "configure:4018: checking for $ac_hdr" >&5
-#line 4033 "configure"
+#line 4021 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4038: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4026: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4063,15 +4051,15 @@
do
-echo "configure:4067: checking for $ac_hdr" >&5
+echo "configure:4055: checking for $ac_hdr" >&5
-#line 4070 "configure"
+#line 4058 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4075: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4063: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4097,10 +4085,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4101: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4089: checking whether time.h and sys/time.h may both be included" >&5
-#line 4104 "configure"
+#line 4092 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4109,7 +4097,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4113: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4101: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4129,10 +4117,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4133: checking for off_t" >&5
+echo "configure:4121: checking for off_t" >&5
-#line 4136 "configure"
+#line 4124 "configure"
#if STDC_HEADERS
@@ -4159,10 +4147,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4163: checking for uid_t in sys/types.h" >&5
+echo "configure:4151: checking for uid_t in sys/types.h" >&5
-#line 4166 "configure"
+#line 4154 "configure"
EOF
@@ -4190,10 +4178,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4194: checking return type of signal handlers" >&5
+echo "configure:4182: checking return type of signal handlers" >&5
-#line 4197 "configure"
+#line 4185 "configure"
#include <signal.h>
@@ -4210,7 +4198,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4214: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4202: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4228,10 +4216,10 @@
-echo "configure:4232: checking for Cygwin environment" >&5
+echo "configure:4220: checking for Cygwin environment" >&5
-#line 4235 "configure"
+#line 4223 "configure"
int main() {
@@ -4242,7 +4230,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4246: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4234: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4260,10 +4248,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4264: checking for $ac_func" >&5
+echo "configure:4252: checking for $ac_func" >&5
-#line 4267 "configure"
+#line 4255 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4286,7 +4274,7 @@
; return 0; }
EOF
-if { (eval echo configure:4290: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4312,10 +4300,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4316: checking for $ac_func" >&5
+echo "configure:4304: checking for $ac_func" >&5
-#line 4319 "configure"
+#line 4307 "configure"
@@ -4338,7 +4326,7 @@
; return 0; }
EOF
-if { (eval echo configure:4342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4364,10 +4352,10 @@
for ac_func in drand48
do
-echo "configure:4368: checking for $ac_func" >&5
+echo "configure:4356: checking for $ac_func" >&5
-#line 4371 "configure"
+#line 4359 "configure"
@@ -4390,7 +4378,7 @@
; return 0; }
EOF
-if { (eval echo configure:4394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4416,10 +4404,10 @@
for ac_func in putenv setenv
do
-echo "configure:4420: checking for $ac_func" >&5
+echo "configure:4408: checking for $ac_func" >&5
-#line 4423 "configure"
+#line 4411 "configure"
@@ -4442,7 +4430,7 @@
; return 0; }
EOF
-if { (eval echo configure:4446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4468,10 +4456,10 @@
for ac_func in nanosleep
do
-echo "configure:4472: checking for $ac_func" >&5
+echo "configure:4460: checking for $ac_func" >&5
-#line 4475 "configure"
+#line 4463 "configure"
@@ -4494,7 +4482,7 @@
; return 0; }
EOF
-if { (eval echo configure:4498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4519,13 +4507,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4523: checking whether setpgrp takes no argument" >&5
+echo "configure:4511: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4529 "configure"
+#line 4517 "configure"
#ifdef HAVE_UNISTD_H
@@ -4545,7 +4533,7 @@
EOF
-if { (eval echo configure:4549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4573,16 +4561,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4577: checking for long long int" >&5
+echo "configure:4565: checking for long long int" >&5
-#line 4579 "configure"
+#line 4567 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4586: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4574: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -4602,7 +4590,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4606: checking for W11" >&5
+echo "configure:4594: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4630,7 +4618,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4634: checking for X" >&5
+echo "configure:4622: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4690,12 +4678,12 @@
# First, try using that file with no special directory specified.
-#line 4694 "configure"
+#line 4682 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4699: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4687: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4764,14 +4752,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4768 "configure"
+#line 4756 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -4876,17 +4864,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4880: checking whether -R must be followed by a space" >&5
+echo "configure:4868: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4883 "configure"
+#line 4871 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -4902,14 +4890,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4906 "configure"
+#line 4894 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -4941,13 +4929,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4945: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4933: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 4951 "configure"
+#line 4939 "configure"
@@ -4958,7 +4946,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4979,13 +4967,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4983: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4971: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 4989 "configure"
+#line 4977 "configure"
@@ -4996,7 +4984,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5024,10 +5012,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5028: checking for gethostbyname" >&5
+echo "configure:5016: checking for gethostbyname" >&5
-#line 5031 "configure"
+#line 5019 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5050,7 +5038,7 @@
; return 0; }
EOF
-if { (eval echo configure:5054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5070,13 +5058,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5074: checking for gethostbyname in -lnsl" >&5
+echo "configure:5062: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5080 "configure"
+#line 5068 "configure"
@@ -5087,7 +5075,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5116,10 +5104,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5120: checking for connect" >&5
+echo "configure:5108: checking for connect" >&5
-#line 5123 "configure"
+#line 5111 "configure"
which can conflict with char connect(); below. */
@@ -5142,7 +5130,7 @@
; return 0; }
EOF
-if { (eval echo configure:5146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5162,13 +5150,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5166: checking for connect in -lsocket" >&5
+echo "configure:5154: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5172 "configure"
+#line 5160 "configure"
@@ -5179,7 +5167,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5202,10 +5190,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5206: checking for remove" >&5
+echo "configure:5194: checking for remove" >&5
-#line 5209 "configure"
+#line 5197 "configure"
which can conflict with char remove(); below. */
@@ -5228,7 +5216,7 @@
; return 0; }
EOF
-if { (eval echo configure:5232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5248,13 +5236,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5252: checking for remove in -lposix" >&5
+echo "configure:5240: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5258 "configure"
+#line 5246 "configure"
@@ -5265,7 +5253,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5288,10 +5276,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5292: checking for shmat" >&5
+echo "configure:5280: checking for shmat" >&5
-#line 5295 "configure"
+#line 5283 "configure"
which can conflict with char shmat(); below. */
@@ -5314,7 +5302,7 @@
; return 0; }
EOF
-if { (eval echo configure:5318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5334,13 +5322,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5338: checking for shmat in -lipc" >&5
+echo "configure:5326: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5344 "configure"
+#line 5332 "configure"
@@ -5351,7 +5339,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5383,13 +5371,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5387: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5375: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5393 "configure"
+#line 5381 "configure"
@@ -5400,7 +5388,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5434,411 +5422,18 @@
-# Enable Curses option
-echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5442: checking whether to use Curses" >&5
-echo "$ac_t"""$with_curses"" 1>&6
-case "$with_curses" in
- "no") USE_CURSES= ;;
- "yes") USE_CURSES="1" ;;
- *) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
-esac
-if test -n "$USE_CURSES"; then
-ac_save_cppflags="$CPPFLAGS"
-CPPFLAGS=" $CPPFLAGS"
-for ac_hdr in curses.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:5461: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 5464 "configure"
-#include "confdefs.h"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:5469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=yes"
-else
- echo "$ac_err" >&5
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
- echo "$ac_t""yes" 1>&6
- ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
- cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
- echo "$ac_t""no" 1>&6
-{ echo "configure: error: *** Unable to locate curses includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
-echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5500: checking curses.h WINDOW structure component" >&5
-CURSES_MAXY=NONE
-#line 5503 "configure"
-#include <curses.h>
-int main() {
-WINDOW w; w.maxy = 0;
-; return 0; }
-EOF
-if { (eval echo configure:5512: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
- rm -rf conftest*
- CURSES_MAXY=maxy
-else
-fi
-rm -f conftest*
-#line 5521 "configure"
-int main() {
-WINDOW w; w._maxy = 0;
-; return 0; }
-EOF
-if { (eval echo configure:5530: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
- rm -rf conftest*
- CURSES_MAXY=_maxy
-else
-fi
-rm -f conftest*
-cat >> confdefs.h <<EOF
-#define CURSES_MAXY $CURSES_MAXY
-EOF
-echo "$ac_t""$CURSES_MAXY" 1>&6
-echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5546: checking for initscr in -lncurses" >&5
-ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-lncurses $LIBS"
-#line 5552 "configure"
-/* Override any gcc2 internal prototype to avoid an error. */
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char initscr();
-int main() {
-initscr()
-; return 0; }
-EOF
-if { (eval echo configure:5563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=yes"
-else
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
- CURSESLIB=-lncurses
-else
-echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5582: checking for initscr in -lcurses" >&5
-ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
-LIBS="-lcurses $LIBS"
-#line 5588 "configure"
-char initscr();
-int main() {
-initscr()
-; return 0; }
-EOF
-if { (eval echo configure:5599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- CURSESLIB=-lcurses
-else
- { echo "configure: error: *** Unable to locate curses library." 1>&2; exit 1; }
- CURSESLIB=
-fi
-fi
-echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5628: checking for keypad in -lncurses" >&5
-ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5634 "configure"
-char keypad();
-int main() {
-keypad()
-; return 0; }
-EOF
-if { (eval echo configure:5645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- cat >> confdefs.h <<\EOF
-#define HAVE_KEYPAD 1
-EOF
-else
-echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5667: checking for keypad in -lcurses" >&5
-ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5673 "configure"
-char keypad();
-int main() {
-keypad()
-; return 0; }
-EOF
-if { (eval echo configure:5684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
-EOF
-else
-fi
-fi
-fi # $USE_CURSES
-echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5714: checking for gtty in -lcompat" >&5
-ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
-LIBS="-lcompat $LIBS"
-#line 5720 "configure"
-char gtty();
-int main() {
-gtty()
-; return 0; }
-EOF
-if { (eval echo configure:5731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- COMPATLIB=-lcompat
-else
-echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5750: checking for gtty in -lbsd-compat" >&5
-ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
-LIBS="-lbsd-compat $LIBS"
-#line 5756 "configure"
-char gtty();
-int main() {
-gtty()
-; return 0; }
-EOF
-if { (eval echo configure:5767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- COMPATLIB=-lbsd-compat
-else
-echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5786: checking for gtty in -lbsd" >&5
-ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
-LIBS="-lbsd $LIBS"
-#line 5792 "configure"
-char gtty();
-int main() {
-gtty()
-; return 0; }
-EOF
-if { (eval echo configure:5803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- COMPATLIB=-lbsd
-else
- COMPATLIB=
-fi
-fi
-fi
# Note that some systems (FreeBSD for example) need an extra library for
# cuserid
ac_save_libs="$LIBS"
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5837: checking for library containing cuserid" >&5
+echo "configure:5432: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 5842 "configure"
+#line 5437 "configure"
@@ -5849,7 +5444,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -5860,7 +5455,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 5864 "configure"
+#line 5459 "configure"
@@ -5871,7 +5466,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -5897,10 +5492,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5901: checking for xdrmem_create" >&5
+echo "configure:5496: checking for xdrmem_create" >&5
-#line 5904 "configure"
+#line 5499 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -5923,7 +5518,7 @@
; return 0; }
EOF
-if { (eval echo configure:5927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -5941,13 +5536,13 @@
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5945: checking for xdrmem_create in -lsun" >&5
+echo "configure:5540: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 5951 "configure"
+#line 5546 "configure"
@@ -5958,7 +5553,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5977,13 +5572,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5981: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5576: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5987 "configure"
+#line 5582 "configure"
@@ -5994,7 +5589,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6013,13 +5608,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6017: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5612: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 6023 "configure"
+#line 5618 "configure"
@@ -6030,7 +5625,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6049,13 +5644,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6053: checking for xdrmem_create in -lxdr" >&5
+echo "configure:5648: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 6059 "configure"
+#line 5654 "configure"
@@ -6066,7 +5661,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6100,10 +5695,10 @@
for ac_func in asprintf
do
-echo "configure:6104: checking for $ac_func" >&5
+echo "configure:5699: checking for $ac_func" >&5
-#line 6107 "configure"
+#line 5702 "configure"
@@ -6126,7 +5721,7 @@
; return 0; }
EOF
-if { (eval echo configure:6130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6153,10 +5748,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6157: checking for atan" >&5
+echo "configure:5752: checking for atan" >&5
-#line 6160 "configure"
+#line 5755 "configure"
which can conflict with char atan(); below. */
@@ -6179,7 +5774,7 @@
; return 0; }
EOF
-if { (eval echo configure:6183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -6197,13 +5792,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6201: checking for atan in -lm" >&5
+echo "configure:5796: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 6207 "configure"
+#line 5802 "configure"
@@ -6214,7 +5809,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:6218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6241,10 +5836,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6245: checking for dlsym" >&5
+echo "configure:5840: checking for dlsym" >&5
-#line 6248 "configure"
+#line 5843 "configure"
which can conflict with char dlsym(); below. */
@@ -6267,7 +5862,7 @@
; return 0; }
EOF
-if { (eval echo configure:6271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -6285,13 +5880,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6289: checking for dlsym in -ldl" >&5
+echo "configure:5884: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 6295 "configure"
+#line 5890 "configure"
@@ -6302,7 +5897,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:6306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6329,10 +5924,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6333: checking for iconv" >&5
+echo "configure:5928: checking for iconv" >&5
-#line 6336 "configure"
+#line 5931 "configure"
which can conflict with char iconv(); below. */
@@ -6355,7 +5950,7 @@
; return 0; }
EOF
-if { (eval echo configure:6359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6373,13 +5968,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6377: checking for iconv in -liconv" >&5
+echo "configure:5972: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6383 "configure"
+#line 5978 "configure"
@@ -6390,7 +5985,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6409,13 +6004,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6413: checking for iconv in -lgiconv" >&5
+echo "configure:6008: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6419 "configure"
+#line 6014 "configure"
@@ -6426,7 +6021,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6445,10 +6040,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6449: checking for libiconv" >&5
+echo "configure:6044: checking for libiconv" >&5
-#line 6452 "configure"
+#line 6047 "configure"
which can conflict with char libiconv(); below. */
@@ -6471,7 +6066,7 @@
; return 0; }
EOF
-if { (eval echo configure:6475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6489,13 +6084,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6493: checking for libiconv in -liconv" >&5
+echo "configure:6088: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6499 "configure"
+#line 6094 "configure"
@@ -6506,7 +6101,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6525,13 +6120,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6529: checking for libiconv in -lgiconv" >&5
+echo "configure:6124: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6535 "configure"
+#line 6130 "configure"
@@ -6542,7 +6137,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6579,10 +6174,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6583: checking for socket" >&5
+echo "configure:6178: checking for socket" >&5
-#line 6586 "configure"
+#line 6181 "configure"
which can conflict with char socket(); below. */
@@ -6605,7 +6200,7 @@
; return 0; }
EOF
-if { (eval echo configure:6609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6623,13 +6218,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6627: checking for socket in -lsocket" >&5
+echo "configure:6222: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6633 "configure"
+#line 6228 "configure"
@@ -6640,7 +6235,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6688,7 +6283,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6692: checking for location of zlib includes" >&5
+echo "configure:6287: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6714,15 +6309,15 @@
do
-echo "configure:6718: checking for $ac_hdr" >&5
+echo "configure:6313: checking for $ac_hdr" >&5
-#line 6721 "configure"
+#line 6316 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6726: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6321: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6756,7 +6351,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6760: checking for location of zlib library" >&5
+echo "configure:6355: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6781,13 +6376,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6785: checking for deflate in -lz" >&5
+echo "configure:6380: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6791 "configure"
+#line 6386 "configure"
@@ -6798,7 +6393,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6846,7 +6441,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6850: checking for location of External PROJ.4 includes" >&5
+echo "configure:6445: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6872,15 +6467,15 @@
do
-echo "configure:6876: checking for $ac_hdr" >&5
+echo "configure:6471: checking for $ac_hdr" >&5
-#line 6879 "configure"
+#line 6474 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6884: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6479: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6917,7 +6512,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6921: checking External PROJ.4 version" >&5
+echo "configure:6516: checking External PROJ.4 version" >&5
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6925,7 +6520,7 @@
else
-#line 6929 "configure"
+#line 6524 "configure"
#include <stdio.h>
@@ -6937,7 +6532,7 @@
EOF
-if { (eval echo configure:6941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -6962,7 +6557,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6966: checking for location of External PROJ.4 library" >&5
+echo "configure:6561: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6987,13 +6582,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6991: checking for pj_get_def in -lproj" >&5
+echo "configure:6586: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 6997 "configure"
+#line 6592 "configure"
@@ -7004,7 +6599,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:7008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7038,7 +6633,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7042: checking for location of External PROJ.4 data files" >&5
+echo "configure:6637: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7062,14 +6657,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7066: checking for epsg" >&5
+echo "configure:6661: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7073: checking for $PROJSHARE/epsg" >&5
+echo "configure:6668: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7101,7 +6696,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7105: checking for $ac_word" >&5
+echo "configure:6700: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -7141,7 +6736,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7145: checking whether to use Readline" >&5
+echo "configure:6740: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7162,7 +6757,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7166: checking for location of Readline includes" >&5
+echo "configure:6761: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7188,15 +6783,15 @@
do
-echo "configure:7192: checking for $ac_hdr" >&5
+echo "configure:6787: checking for $ac_hdr" >&5
-#line 7195 "configure"
+#line 6790 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7200: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6795: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7232,15 +6827,15 @@
do
-echo "configure:7236: checking for $ac_hdr" >&5
+echo "configure:6831: checking for $ac_hdr" >&5
-#line 7239 "configure"
+#line 6834 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7244: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6839: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7274,7 +6869,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7278: checking for location of Readline library" >&5
+echo "configure:6873: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7299,13 +6894,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7303: checking for readline in -lreadline" >&5
+echo "configure:6898: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 7309 "configure"
+#line 6904 "configure"
@@ -7316,7 +6911,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7351,13 +6946,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7355: checking for add_history in -lhistory" >&5
+echo "configure:6950: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7361 "configure"
+#line 6956 "configure"
@@ -7368,7 +6963,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7411,7 +7006,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7415: checking whether to use JPEG" >&5
+echo "configure:7010: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7431,7 +7026,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7435: checking for location of JPEG includes" >&5
+echo "configure:7030: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7457,15 +7052,15 @@
do
-echo "configure:7461: checking for $ac_hdr" >&5
+echo "configure:7056: checking for $ac_hdr" >&5
-#line 7464 "configure"
+#line 7059 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7064: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7499,7 +7094,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7503: checking for location of JPEG library" >&5
+echo "configure:7098: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7526,13 +7121,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7530: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7125: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
-#line 7536 "configure"
+#line 7131 "configure"
@@ -7543,7 +7138,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7562,13 +7157,13 @@
-echo "configure:7566: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7161: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7572 "configure"
+#line 7167 "configure"
@@ -7579,7 +7174,7 @@
; return 0; }
EOF
-if { (eval echo configure:7583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7628,7 +7223,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7632: checking whether to use GDAL" >&5
+echo "configure:7227: checking whether to use GDAL" >&5
if test "`basename xx/$with_gdal`" = "gdal-config" ; then
GDAL_CONFIG="$with_gdal"
@@ -7641,7 +7236,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:7645: checking for $ac_word" >&5
+echo "configure:7240: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7701,14 +7296,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7705 "configure"
+#line 7300 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:7712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -7717,14 +7312,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7721 "configure"
+#line 7316 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:7728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -7752,7 +7347,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7756: checking whether to use TIFF" >&5
+echo "configure:7351: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7772,7 +7367,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7776: checking for location of TIFF includes" >&5
+echo "configure:7371: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7798,15 +7393,15 @@
do
-echo "configure:7802: checking for $ac_hdr" >&5
+echo "configure:7397: checking for $ac_hdr" >&5
-#line 7805 "configure"
+#line 7400 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7405: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7840,7 +7435,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7844: checking for location of TIFF library" >&5
+echo "configure:7439: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7871,13 +7466,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7875: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7470: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 7881 "configure"
+#line 7476 "configure"
@@ -7888,7 +7483,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7907,13 +7502,13 @@
-echo "configure:7911: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7506: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7917 "configure"
+#line 7512 "configure"
@@ -7924,7 +7519,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7943,13 +7538,13 @@
-echo "configure:7947: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7542: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7953 "configure"
+#line 7548 "configure"
@@ -7960,7 +7555,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7979,13 +7574,13 @@
-echo "configure:7983: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7578: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7989 "configure"
+#line 7584 "configure"
@@ -7996,7 +7591,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8015,13 +7610,13 @@
-echo "configure:8019: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7614: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8025 "configure"
+#line 7620 "configure"
@@ -8032,7 +7627,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8051,13 +7646,13 @@
-echo "configure:8055: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7650: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8061 "configure"
+#line 7656 "configure"
@@ -8068,7 +7663,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7667: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8087,13 +7682,13 @@
-echo "configure:8091: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7686: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8097 "configure"
+#line 7692 "configure"
@@ -8104,7 +7699,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8123,13 +7718,13 @@
-echo "configure:8127: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7722: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8133 "configure"
+#line 7728 "configure"
@@ -8140,7 +7735,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8238,7 +7833,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8242: checking whether to use PNG" >&5
+echo "configure:7837: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8257,7 +7852,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8261: checking for location of PNG includes" >&5
+echo "configure:7856: checking for location of PNG includes" >&5
case "$with_png_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8283,15 +7878,15 @@
do
-echo "configure:8287: checking for $ac_hdr" >&5
+echo "configure:7882: checking for $ac_hdr" >&5
-#line 8290 "configure"
+#line 7885 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8295: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7890: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8325,7 +7920,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8329: checking for location of PNG library" >&5
+echo "configure:7924: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8350,13 +7945,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8354: checking for png_read_image in -lpng" >&5
+echo "configure:7949: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8360 "configure"
+#line 7955 "configure"
@@ -8367,7 +7962,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8409,7 +8004,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8413: checking whether to use Tcl/Tk" >&5
+echo "configure:8008: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -8429,7 +8024,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8433: checking for location of Tcl/Tk includes" >&5
+echo "configure:8028: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8455,15 +8050,15 @@
do
-echo "configure:8459: checking for $ac_hdr" >&5
+echo "configure:8054: checking for $ac_hdr" >&5
-#line 8462 "configure"
+#line 8057 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8467: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8062: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8500,15 +8095,15 @@
do
-echo "configure:8504: checking for $ac_hdr" >&5
+echo "configure:8099: checking for $ac_hdr" >&5
-#line 8507 "configure"
+#line 8102 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8107: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8542,7 +8137,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8546: checking Tcl version" >&5
+echo "configure:8141: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -8550,7 +8145,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 8554 "configure"
+#line 8149 "configure"
#include <stdio.h>
@@ -8562,7 +8157,7 @@
EOF
-if { (eval echo configure:8566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8580,7 +8175,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8584: checking Tk version" >&5
+echo "configure:8179: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8588,7 +8183,7 @@
else
-#line 8592 "configure"
+#line 8187 "configure"
#include <stdio.h>
@@ -8600,7 +8195,7 @@
EOF
-if { (eval echo configure:8604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8629,7 +8224,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8633: checking for location of Tcl/Tk library" >&5
+echo "configure:8228: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8659,13 +8254,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8663: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8258: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8669 "configure"
+#line 8264 "configure"
@@ -8676,7 +8271,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8695,13 +8290,13 @@
-echo "configure:8699: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8294: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8705 "configure"
+#line 8300 "configure"
@@ -8712,7 +8307,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8739,13 +8334,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8743: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8338: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8749 "configure"
+#line 8344 "configure"
@@ -8756,7 +8351,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8775,13 +8370,13 @@
-echo "configure:8779: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8374: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8785 "configure"
+#line 8380 "configure"
@@ -8792,7 +8387,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8819,13 +8414,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8823: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8418: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8829 "configure"
+#line 8424 "configure"
@@ -8836,7 +8431,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8855,13 +8450,13 @@
-echo "configure:8859: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8454: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8865 "configure"
+#line 8460 "configure"
@@ -8872,7 +8467,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8950,13 +8545,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8954: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8549: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8960 "configure"
+#line 8555 "configure"
@@ -8967,7 +8562,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8986,13 +8581,13 @@
-echo "configure:8990: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8585: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8996 "configure"
+#line 8591 "configure"
@@ -9003,7 +8598,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9030,13 +8625,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9034: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8629: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9040 "configure"
+#line 8635 "configure"
@@ -9047,7 +8642,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9066,13 +8661,13 @@
-echo "configure:9070: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8665: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9076 "configure"
+#line 8671 "configure"
@@ -9083,7 +8678,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9110,13 +8705,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9114: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:8709: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9120 "configure"
+#line 8715 "configure"
@@ -9127,7 +8722,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9146,13 +8741,13 @@
-echo "configure:9150: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:8745: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9156 "configure"
+#line 8751 "configure"
@@ -9163,7 +8758,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9167: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9255,7 +8850,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9259: checking whether to use PostgreSQL" >&5
+echo "configure:8854: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9282,7 +8877,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9286: checking for location of PostgreSQL includes" >&5
+echo "configure:8881: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9308,15 +8903,15 @@
do
-echo "configure:9312: checking for $ac_hdr" >&5
+echo "configure:8907: checking for $ac_hdr" >&5
-#line 9315 "configure"
+#line 8910 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9320: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8915: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9354,7 +8949,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9358: checking for location of PostgreSQL library" >&5
+echo "configure:8953: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9383,13 +8978,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9387: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8982: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9393 "configure"
+#line 8988 "configure"
@@ -9400,7 +8995,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9419,13 +9014,13 @@
-echo "configure:9423: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9018: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9429 "configure"
+#line 9024 "configure"
@@ -9436,7 +9031,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9455,13 +9050,13 @@
-echo "configure:9459: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9054: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9465 "configure"
+#line 9060 "configure"
@@ -9472,7 +9067,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9491,13 +9086,13 @@
-echo "configure:9495: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9090: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9501 "configure"
+#line 9096 "configure"
@@ -9508,7 +9103,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9565,13 +9160,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9569: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9164: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9575 "configure"
+#line 9170 "configure"
@@ -9582,7 +9177,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9604,13 +9199,13 @@
-echo "configure:9608: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9203: checking for PQcmdTuples in -lpq" >&5
-#line 9614 "configure"
+#line 9209 "configure"
@@ -9621,7 +9216,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9664,7 +9259,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9668: checking whether to use MySQL" >&5
+echo "configure:9263: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9684,7 +9279,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9688: checking for location of MySQL includes" >&5
+echo "configure:9283: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9710,15 +9305,15 @@
do
-echo "configure:9714: checking for $ac_hdr" >&5
+echo "configure:9309: checking for $ac_hdr" >&5
-#line 9717 "configure"
+#line 9312 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9317: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9755,7 +9350,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9759: checking for location of MySQL library" >&5
+echo "configure:9354: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9786,13 +9381,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9790: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9385: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9796 "configure"
+#line 9391 "configure"
@@ -9803,7 +9398,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9822,13 +9417,13 @@
-echo "configure:9826: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9421: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9832 "configure"
+#line 9427 "configure"
@@ -9839,7 +9434,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9858,13 +9453,13 @@
-echo "configure:9862: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9457: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9868 "configure"
+#line 9463 "configure"
@@ -9875,7 +9470,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9894,13 +9489,13 @@
-echo "configure:9898: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9493: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9904 "configure"
+#line 9499 "configure"
@@ -9911,7 +9506,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9930,13 +9525,13 @@
-echo "configure:9934: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9529: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9940 "configure"
+#line 9535 "configure"
@@ -9947,7 +9542,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9966,13 +9561,13 @@
-echo "configure:9970: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9565: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9976 "configure"
+#line 9571 "configure"
@@ -9983,7 +9578,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10002,13 +9597,13 @@
-echo "configure:10006: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9601: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10012 "configure"
+#line 9607 "configure"
@@ -10019,7 +9614,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10038,13 +9633,13 @@
-echo "configure:10042: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9637: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10048 "configure"
+#line 9643 "configure"
@@ -10055,7 +9650,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9654: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10145,7 +9740,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:10149: checking for $ac_word" >&5
+echo "configure:9744: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -10186,10 +9781,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10190: checking for mysql_server_init" >&5
+echo "configure:9785: checking for mysql_server_init" >&5
cat > conftest.$ac_ext <<EOF
-#line 10193 "configure"
+#line 9788 "configure"
#include "confdefs.h"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -10212,7 +9807,7 @@
; return 0; }
EOF
-if { (eval echo configure:10216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -10250,7 +9845,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10254: checking whether to use SQLite" >&5
+echo "configure:9849: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10270,7 +9865,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10274: checking for location of SQLite includes" >&5
+echo "configure:9869: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10296,15 +9891,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:10300: checking for $ac_hdr" >&5
+echo "configure:9895: checking for $ac_hdr" >&5
-#line 10303 "configure"
+#line 9898 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:10308: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9903: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -10347,7 +9942,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10351: checking for location of SQLite library" >&5
+echo "configure:9946: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10374,13 +9969,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10378: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9973: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lsqlite3 $LIBS"
-#line 10384 "configure"
+#line 9979 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -10391,7 +9986,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -10410,13 +10005,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10414: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10009: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10420 "configure"
+#line 10015 "configure"
@@ -10427,7 +10022,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10480,7 +10075,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10484: checking whether to use FFMPEG" >&5
+echo "configure:10079: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10500,7 +10095,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10504: checking for location of FFMPEG includes" >&5
+echo "configure:10099: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10526,15 +10121,15 @@
do
-echo "configure:10530: checking for $ac_hdr" >&5
+echo "configure:10125: checking for $ac_hdr" >&5
-#line 10533 "configure"
+#line 10128 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10538: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10133: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10570,15 +10165,15 @@
do
-echo "configure:10574: checking for $ac_hdr" >&5
+echo "configure:10169: checking for $ac_hdr" >&5
-#line 10577 "configure"
+#line 10172 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10582: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10177: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10614,15 +10209,15 @@
do
-echo "configure:10618: checking for $ac_hdr" >&5
+echo "configure:10213: checking for $ac_hdr" >&5
-#line 10621 "configure"
+#line 10216 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10626: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10665,7 +10260,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10669: checking for location of FFMPEG library" >&5
+echo "configure:10264: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10692,13 +10287,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10696: checking for av_free in -lavutil" >&5
+echo "configure:10291: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10702 "configure"
+#line 10297 "configure"
@@ -10709,7 +10304,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10728,13 +10323,13 @@
-echo "configure:10732: checking for av_free in -lavutil" >&5
+echo "configure:10327: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10738 "configure"
+#line 10333 "configure"
@@ -10745,7 +10340,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10790,13 +10385,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10794: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10389: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10800 "configure"
+#line 10395 "configure"
@@ -10807,7 +10402,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10826,13 +10421,13 @@
-echo "configure:10830: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10425: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10836 "configure"
+#line 10431 "configure"
@@ -10843,7 +10438,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10888,13 +10483,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10892: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10487: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10898 "configure"
+#line 10493 "configure"
@@ -10905,7 +10500,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10924,13 +10519,13 @@
-echo "configure:10928: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10523: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10934 "configure"
+#line 10529 "configure"
@@ -10941,7 +10536,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11001,7 +10596,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:11005: checking whether to use OpenGL" >&5
+echo "configure:10600: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -11035,7 +10630,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11039: checking for location of OpenGL includes" >&5
+echo "configure:10634: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11061,15 +10656,15 @@
do
-echo "configure:11065: checking for $ac_hdr" >&5
+echo "configure:10660: checking for $ac_hdr" >&5
-#line 11068 "configure"
+#line 10663 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11073: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10668: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11103,7 +10698,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11107: checking for location of OpenGL library" >&5
+echo "configure:10702: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11132,13 +10727,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11136: checking for glBegin in -lGL" >&5
+echo "configure:10731: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11142 "configure"
+#line 10737 "configure"
@@ -11149,7 +10744,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11168,13 +10763,13 @@
-echo "configure:11172: checking for glBegin in -lGL" >&5
+echo "configure:10767: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11178 "configure"
+#line 10773 "configure"
@@ -11185,7 +10780,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11204,13 +10799,13 @@
-echo "configure:11208: checking for glBegin in -lGL" >&5
+echo "configure:10803: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11214 "configure"
+#line 10809 "configure"
@@ -11221,7 +10816,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11240,13 +10835,13 @@
-echo "configure:11244: checking for glBegin in -lGL" >&5
+echo "configure:10839: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11250 "configure"
+#line 10845 "configure"
@@ -11257,7 +10852,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11319,13 +10914,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11323: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10918: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11329 "configure"
+#line 10924 "configure"
@@ -11336,7 +10931,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11355,13 +10950,13 @@
-echo "configure:11359: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10954: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11365 "configure"
+#line 10960 "configure"
@@ -11372,7 +10967,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11419,10 +11014,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11423: checking for glXCreatePbuffer" >&5
+echo "configure:11018: checking for glXCreatePbuffer" >&5
-#line 11426 "configure"
+#line 11021 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11445,7 +11040,7 @@
; return 0; }
EOF
-if { (eval echo configure:11449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11482,10 +11077,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11486: checking for glXCreateGLXPixmap" >&5
+echo "configure:11081: checking for glXCreateGLXPixmap" >&5
-#line 11489 "configure"
+#line 11084 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11508,7 +11103,7 @@
; return 0; }
EOF
-if { (eval echo configure:11512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11551,7 +11146,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:11555: checking for location of OpenGL framework" >&5
+echo "configure:11150: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -11575,15 +11170,15 @@
do
-echo "configure:11579: checking for $ac_hdr" >&5
+echo "configure:11174: checking for $ac_hdr" >&5
-#line 11582 "configure"
+#line 11177 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11587: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11182: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11619,10 +11214,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11623: checking for glBegin" >&5
+echo "configure:11218: checking for glBegin" >&5
-#line 11626 "configure"
+#line 11221 "configure"
which can conflict with char glBegin(); below. */
@@ -11645,7 +11240,7 @@
; return 0; }
EOF
-if { (eval echo configure:11649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11682,10 +11277,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11686: checking for gluBeginCurve" >&5
+echo "configure:11281: checking for gluBeginCurve" >&5
-#line 11689 "configure"
+#line 11284 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11708,7 +11303,7 @@
; return 0; }
EOF
-if { (eval echo configure:11712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11756,7 +11351,7 @@
-echo "configure:11760: checking for location of OpenGL includes" >&5
+echo "configure:11355: checking for location of OpenGL includes" >&5
@@ -11782,15 +11377,15 @@
do
-echo "configure:11786: checking for $ac_hdr" >&5
+echo "configure:11381: checking for $ac_hdr" >&5
-#line 11789 "configure"
+#line 11384 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11794: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11389: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11824,7 +11419,7 @@
-echo "configure:11828: checking for location of OpenGL library" >&5
+echo "configure:11423: checking for location of OpenGL library" >&5
@@ -11849,18 +11444,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11853: checking for OpenGL library" >&5
+echo "configure:11448: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11857 "configure"
+#line 11452 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11884,18 +11479,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11888: checking for GLU library" >&5
+echo "configure:11483: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11892 "configure"
+#line 11487 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11944,7 +11539,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11948: checking whether to use ODBC" >&5
+echo "configure:11543: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11963,7 +11558,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11967: checking for location of ODBC includes" >&5
+echo "configure:11562: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11989,15 +11584,15 @@
do
-echo "configure:11993: checking for $ac_hdr" >&5
+echo "configure:11588: checking for $ac_hdr" >&5
-#line 11996 "configure"
+#line 11591 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11596: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12031,7 +11626,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12035: checking for location of ODBC library" >&5
+echo "configure:11630: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12056,13 +11651,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12060: checking for SQLConnect in -lodbc" >&5
+echo "configure:11655: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12066 "configure"
+#line 11661 "configure"
@@ -12073,7 +11668,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12098,13 +11693,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12102: checking for SQLConnect in -liodbc" >&5
+echo "configure:11697: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12108 "configure"
+#line 11703 "configure"
@@ -12115,7 +11710,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12140,11 +11735,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12144: checking for ODBC library" >&5
+echo "configure:11739: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12148 "configure"
+#line 11743 "configure"
#include <windows.h>
#include <sql.h>
@@ -12152,7 +11747,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12201,7 +11796,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12205: checking whether to use FFTW" >&5
+echo "configure:11800: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12220,7 +11815,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12224: checking for location of FFTW includes" >&5
+echo "configure:11819: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12246,15 +11841,15 @@
do
-echo "configure:12250: checking for $ac_hdr" >&5
+echo "configure:11845: checking for $ac_hdr" >&5
-#line 12253 "configure"
+#line 11848 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11853: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12282,15 +11877,15 @@
do
-echo "configure:12286: checking for $ac_hdr" >&5
+echo "configure:11881: checking for $ac_hdr" >&5
-#line 12289 "configure"
+#line 11884 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12294: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11889: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12318,15 +11913,15 @@
do
-echo "configure:12322: checking for $ac_hdr" >&5
+echo "configure:11917: checking for $ac_hdr" >&5
-#line 12325 "configure"
+#line 11920 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11925: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12372,7 +11967,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12376: checking for location of FFTW library" >&5
+echo "configure:11971: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12397,13 +11992,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12401: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11996: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12407 "configure"
+#line 12002 "configure"
@@ -12414,7 +12009,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12439,13 +12034,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12443: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12038: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12449 "configure"
+#line 12044 "configure"
@@ -12456,7 +12051,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12481,13 +12076,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12485: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12080: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12491 "configure"
+#line 12086 "configure"
@@ -12498,7 +12093,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12555,7 +12150,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12559: checking whether to use BLAS" >&5
+echo "configure:12154: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12576,7 +12171,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12580: checking for location of BLAS includes" >&5
+echo "configure:12175: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12596,7 +12191,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12600: checking for location of BLAS library" >&5
+echo "configure:12195: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12622,15 +12217,15 @@
do
-echo "configure:12626: checking for $ac_hdr" >&5
+echo "configure:12221: checking for $ac_hdr" >&5
-#line 12629 "configure"
+#line 12224 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12634: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12229: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12665,13 +12260,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12669: checking for dnrm2_ in -lblas" >&5
+echo "configure:12264: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12675 "configure"
+#line 12270 "configure"
@@ -12682,7 +12277,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12701,13 +12296,13 @@
-echo "configure:12705: checking for dnrm2_ in -lblas" >&5
+echo "configure:12300: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12711 "configure"
+#line 12306 "configure"
@@ -12718,7 +12313,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12762,13 +12357,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12766: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12361: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12772 "configure"
+#line 12367 "configure"
@@ -12779,7 +12374,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12794,13 +12389,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12798: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12393: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12804 "configure"
+#line 12399 "configure"
@@ -12811,7 +12406,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12815: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12826,13 +12421,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12830: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12425: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12836 "configure"
+#line 12431 "configure"
@@ -12843,7 +12438,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12888,16 +12483,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12892: checking for sgemm in $vlib_flags" >&5
+echo "configure:12487: checking for sgemm in $vlib_flags" >&5
-#line 12894 "configure"
+#line 12489 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12915,13 +12510,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12919: checking for sgemm_ in -lblas" >&5
+echo "configure:12514: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12925 "configure"
+#line 12520 "configure"
@@ -12932,7 +12527,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12947,13 +12542,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12951: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12546: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12957 "configure"
+#line 12552 "configure"
@@ -12964,7 +12559,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12979,13 +12574,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12983: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12578: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12989 "configure"
+#line 12584 "configure"
@@ -12996,7 +12591,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13030,13 +12625,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13034: checking for acosp in -lsunmath" >&5
+echo "configure:12629: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13040 "configure"
+#line 12635 "configure"
@@ -13047,7 +12642,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13062,13 +12657,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13066: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12661: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13072 "configure"
+#line 12667 "configure"
@@ -13079,7 +12674,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13109,13 +12704,13 @@
# Generic BLAS library
-echo "configure:13113: checking for sgemm_ in -lblas" >&5
+echo "configure:12708: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13119 "configure"
+#line 12714 "configure"
@@ -13126,7 +12721,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13165,7 +12760,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13169: checking whether to use LAPACK" >&5
+echo "configure:12764: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13190,7 +12785,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13194: checking for location of LAPACK includes" >&5
+echo "configure:12789: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13210,7 +12805,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13214: checking for location of LAPACK library" >&5
+echo "configure:12809: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13236,15 +12831,15 @@
do
-echo "configure:13240: checking for $ac_hdr" >&5
+echo "configure:12835: checking for $ac_hdr" >&5
-#line 13243 "configure"
+#line 12838 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13248: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12843: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13276,10 +12871,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13280: checking for dsegv_" >&5
+echo "configure:12875: checking for dsegv_" >&5
-#line 13283 "configure"
+#line 12878 "configure"
which can conflict with char dsegv_(); below. */
@@ -13302,7 +12897,7 @@
; return 0; }
EOF
-if { (eval echo configure:13306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13329,13 +12924,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13333: checking for desgv_ in -llapack" >&5
+echo "configure:12928: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13339 "configure"
+#line 12934 "configure"
@@ -13346,7 +12941,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13378,13 +12973,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13382: checking for dgesv_ in -llapack" >&5
+echo "configure:12977: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13388 "configure"
+#line 12983 "configure"
@@ -13395,7 +12990,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13414,13 +13009,13 @@
-echo "configure:13418: checking for dgesv_ in -llapack" >&5
+echo "configure:13013: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13424 "configure"
+#line 13019 "configure"
@@ -13431,7 +13026,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13487,7 +13082,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13491: checking whether to use Motif" >&5
+echo "configure:13086: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -13506,7 +13101,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13510: checking for location of Motif includes" >&5
+echo "configure:13105: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13532,15 +13127,15 @@
do
-echo "configure:13536: checking for $ac_hdr" >&5
+echo "configure:13131: checking for $ac_hdr" >&5
-#line 13539 "configure"
+#line 13134 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13139: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13574,7 +13169,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13578: checking for location of Motif library" >&5
+echo "configure:13173: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13599,13 +13194,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13603: checking for XmStringCreate in -lXm" >&5
+echo "configure:13198: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 13609 "configure"
+#line 13204 "configure"
@@ -13616,7 +13211,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:13620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13657,7 +13252,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13661: checking whether to use Cairo" >&5
+echo "configure:13256: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13683,15 +13278,15 @@
do
-echo "configure:13687: checking for $ac_hdr" >&5
+echo "configure:13282: checking for $ac_hdr" >&5
-#line 13690 "configure"
+#line 13285 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13695: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13290: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13731,10 +13326,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13735: checking for cairo_create" >&5
+echo "configure:13330: checking for cairo_create" >&5
-#line 13738 "configure"
+#line 13333 "configure"
which can conflict with char cairo_create(); below. */
@@ -13757,7 +13352,7 @@
; return 0; }
EOF
-if { (eval echo configure:13761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13798,7 +13393,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13802: checking whether to use GLw" >&5
+echo "configure:13397: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -13817,7 +13412,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13821: checking for location of GLw includes" >&5
+echo "configure:13416: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13843,15 +13438,15 @@
do
-echo "configure:13847: checking for $ac_hdr" >&5
+echo "configure:13442: checking for $ac_hdr" >&5
-#line 13850 "configure"
+#line 13445 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13855: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13879,15 +13474,15 @@
do
-echo "configure:13883: checking for $ac_hdr" >&5
+echo "configure:13478: checking for $ac_hdr" >&5
-#line 13886 "configure"
+#line 13481 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13891: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13927,7 +13522,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13931: checking for location of GLw library" >&5
+echo "configure:13526: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13952,13 +13547,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13956: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13551: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13962 "configure"
+#line 13557 "configure"
@@ -13969,7 +13564,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13994,13 +13589,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13998: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13593: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14004 "configure"
+#line 13599 "configure"
@@ -14011,7 +13606,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14036,13 +13631,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14040: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:13635: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14046 "configure"
+#line 13641 "configure"
@@ -14053,7 +13648,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14078,13 +13673,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14082: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:13677: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14088 "configure"
+#line 13683 "configure"
@@ -14095,7 +13690,7 @@
; return 0; }
EOF
-if { (eval echo configure:14099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14120,13 +13715,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14124: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:13719: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14130 "configure"
+#line 13725 "configure"
@@ -14137,7 +13732,7 @@
; return 0; }
EOF
-if { (eval echo configure:14141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14162,13 +13757,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14166: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:13761: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14172 "configure"
+#line 13767 "configure"
@@ -14179,7 +13774,7 @@
; return 0; }
EOF
-if { (eval echo configure:14183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14206,13 +13801,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14210: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:13805: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14216 "configure"
+#line 13811 "configure"
@@ -14223,7 +13818,7 @@
; return 0; }
EOF
-if { (eval echo configure:14227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14242,13 +13837,13 @@
-echo "configure:14246: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:13841: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14252 "configure"
+#line 13847 "configure"
@@ -14259,7 +13854,7 @@
; return 0; }
EOF
-if { (eval echo configure:14263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14286,13 +13881,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14290: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:13885: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14296 "configure"
+#line 13891 "configure"
@@ -14303,7 +13898,7 @@
; return 0; }
EOF
-if { (eval echo configure:14307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14322,13 +13917,13 @@
-echo "configure:14326: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:13921: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14332 "configure"
+#line 13927 "configure"
@@ -14339,7 +13934,7 @@
; return 0; }
EOF
-if { (eval echo configure:14343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14452,7 +14047,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14456: checking whether to use FreeType" >&5
+echo "configure:14051: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -14471,7 +14066,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14475: checking for location of FreeType includes" >&5
+echo "configure:14070: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14497,15 +14092,15 @@
do
-echo "configure:14501: checking for $ac_hdr" >&5
+echo "configure:14096: checking for $ac_hdr" >&5
-#line 14504 "configure"
+#line 14099 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14104: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14539,7 +14134,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14543: checking for location of FreeType library" >&5
+echo "configure:14138: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14564,13 +14159,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14568: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14163: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 14574 "configure"
+#line 14169 "configure"
@@ -14581,7 +14176,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:14585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14622,7 +14217,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14626: checking whether to use NLS" >&5
+echo "configure:14221: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -14642,10 +14237,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14646: checking for gettext" >&5
+echo "configure:14241: checking for gettext" >&5
-#line 14649 "configure"
+#line 14244 "configure"
which can conflict with char gettext(); below. */
@@ -14668,7 +14263,7 @@
; return 0; }
EOF
-if { (eval echo configure:14672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -14686,13 +14281,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14690: checking for gettext in -lintl" >&5
+echo "configure:14285: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 14696 "configure"
+#line 14291 "configure"
@@ -14703,7 +14298,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:14707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14738,7 +14333,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14742: checking whether to use C++" >&5
+echo "configure:14337: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -14754,7 +14349,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14758: checking for $ac_word" >&5
+echo "configure:14353: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14783,7 +14378,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14787: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14382: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14794,12 +14389,12 @@
cat > conftest.$ac_ext << EOF
-#line 14798 "configure"
+#line 14393 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:14803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -14825,19 +14420,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14829: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14424: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14834: checking whether we are using GNU C++" >&5
+echo "configure:14429: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14841: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14436: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -14855,7 +14450,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14859: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14454: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14896,7 +14491,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14900: checking whether to use openDWG" >&5
+echo "configure:14495: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -14916,7 +14511,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14920: checking for location of openDGW includes" >&5
+echo "configure:14515: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14942,15 +14537,15 @@
do
-echo "configure:14946: checking for $ac_hdr" >&5
+echo "configure:14541: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 14949 "configure"
+#line 14544 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14954: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14984,7 +14579,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14988: checking for location of openDWG library" >&5
+echo "configure:14583: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15031,7 +14626,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15035: checking for special C compiler options needed for large files" >&5
+echo "configure:14630: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15039,7 +14634,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15043 "configure"
+#line 14638 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15055,7 +14650,7 @@
; return 0; }
EOF
-if { (eval echo configure:15059: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14654: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -15064,7 +14659,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15068 "configure"
+#line 14663 "configure"
@@ -15080,7 +14675,7 @@
; return 0; }
EOF
-if { (eval echo configure:15084: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14679: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15100,11 +14695,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15104: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14699: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15108 "configure"
+#line 14703 "configure"
@@ -15120,14 +14715,14 @@
; return 0; }
EOF
-if { (eval echo configure:15124: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14719: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 15131 "configure"
+#line 14726 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15145,7 +14740,7 @@
; return 0; }
EOF
-if { (eval echo configure:15149: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14744: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15164,11 +14759,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15168: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14763: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15172 "configure"
+#line 14767 "configure"
@@ -15184,14 +14779,14 @@
; return 0; }
EOF
-if { (eval echo configure:15188: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14783: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15195 "configure"
+#line 14790 "configure"
#define _LARGE_FILES 1
@@ -15209,7 +14804,7 @@
; return 0; }
EOF
-if { (eval echo configure:15213: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14808: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15228,25 +14823,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15232: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14827: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15236 "configure"
+#line 14831 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15243: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14838: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15250 "configure"
+#line 14845 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15255,7 +14850,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15259: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14854: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -15276,10 +14871,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15280: checking if system supports Large Files at all" >&5
+echo "configure:14875: checking if system supports Large Files at all" >&5
-#line 15283 "configure"
+#line 14878 "configure"
#include <stdio.h>
@@ -15311,7 +14906,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:15315: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14910: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -15340,7 +14935,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15344: checking whether to use Python" >&5
+echo "configure:14939: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -15360,7 +14955,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:15364: checking for $ac_word" >&5
+echo "configure:14959: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -15405,15 +15000,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:15409: checking for $ac_hdr" >&5
+echo "configure:15004: checking for $ac_hdr" >&5
-#line 15412 "configure"
+#line 15007 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:15417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15012: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -15453,7 +15048,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:15457: checking for $ac_word" >&5
+echo "configure:15052: checking for $ac_word" >&5
case "$SWIG" in
@@ -15499,7 +15094,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15503: checking whether to use wxWidgets" >&5
+echo "configure:15098: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -15519,7 +15114,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:15523: checking for $ac_word" >&5
+echo "configure:15118: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -15567,7 +15162,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15571: checking wxWidgets version" >&5
+echo "configure:15166: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -15590,15 +15185,15 @@
do
-echo "configure:15594: checking for $ac_hdr" >&5
+echo "configure:15189: checking for $ac_hdr" >&5
-#line 15597 "configure"
+#line 15192 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15602: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15197: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15634,15 +15229,15 @@
do
-echo "configure:15638: checking for $ac_hdr" >&5
+echo "configure:15233: checking for $ac_hdr" >&5
-#line 15641 "configure"
+#line 15236 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15646: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15853,10 +15448,6 @@
s%@XLIB@%$XLIB%g
s%@XTLIB@%$XTLIB%g
s%@USE_X11@%$USE_X11%g
-s%@CURSES_MAXY@%$CURSES_MAXY%g
-s%@CURSESLIB@%$CURSESLIB%g
-s%@USE_CURSES@%$USE_CURSES%g
-s%@COMPATLIB@%$COMPATLIB%g
s%@DBMIEXTRALIB@%$DBMIEXTRALIB%g
s%@XDRLIB@%$XDRLIB%g
s%@HAVE_ASPRINTF@%$HAVE_ASPRINTF%g
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/configure.in 2008-08-06 03:28:21 UTC (rev 32551)
@@ -196,7 +196,6 @@
LOC_ARG_WITH(nls, NLS, no)
LOC_ARG_WITH(readline, Readline, no)
LOC_ARG_WITH(opendwg, openDWG, no)
-LOC_ARG_WITH(curses, Curses, yes)
AC_ARG_WITH(python,
[ --with-python[=path/python-config] enable support for Python SWIG bindings (python-config with path, \
e.g. '--with-python=/usr/bin/python2.5-config', default: no)],, with_python="no")
@@ -419,49 +418,6 @@
AC_SUBST(XTLIB)
AC_SUBST(USE_X11)
-# Enable Curses option
-LOC_CHECK_USE(curses,Curses,USE_CURSES)
-if test -n "$USE_CURSES"; then
-LOC_CHECK_INCLUDES(curses.h,curses,)
-AC_MSG_CHECKING(curses.h WINDOW structure component)
-CURSES_MAXY=NONE
-AC_TRY_COMPILE([
-#include <curses.h>
- ],[WINDOW w; w.maxy = 0;],
- CURSES_MAXY=maxy)
-AC_TRY_COMPILE([
- ],[WINDOW w; w._maxy = 0;],
- CURSES_MAXY=_maxy)
-AC_DEFINE_UNQUOTED(CURSES_MAXY,$CURSES_MAXY)
-AC_SUBST(CURSES_MAXY)
-AC_MSG_RESULT($CURSES_MAXY)
-AC_CHECK_LIB(ncurses, initscr, CURSESLIB=-lncurses, [
-AC_CHECK_LIB(curses, initscr, CURSESLIB=-lcurses, [
- AC_MSG_ERROR([*** Unable to locate curses library.])
- CURSESLIB=
-AC_SUBST(CURSESLIB)
-AC_SUBST(USE_CURSES)
-AC_CHECK_LIB(ncurses, keypad, [AC_DEFINE(HAVE_KEYPAD)], [
-AC_CHECK_LIB(curses, keypad, [AC_DEFINE(HAVE_KEYPAD)], [
-fi # $USE_CURSES
-AC_CHECK_LIB(compat, gtty, COMPATLIB=-lcompat, [
-AC_CHECK_LIB(bsd-compat, gtty, COMPATLIB=-lbsd-compat, [
-AC_CHECK_LIB(bsd, gtty, COMPATLIB=-lbsd, [
- COMPATLIB=
-AC_SUBST(COMPATLIB)
# Note that some systems (FreeBSD for example) need an extra library for
# cuserid
Modified: grass/trunk/db/db.login/main.c
--- grass/trunk/db/db.login/main.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/db/db.login/main.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -80,12 +80,13 @@
#endif
do {
fprintf(stderr,
- _
- ("\nEnter database password for connection\n<%s:%s:user=%s>\n"),
+ _("\nEnter database password for connection\n<%s:%s:user=%s>\n"),
driver->answer, database->answer, user->answer);
fprintf(stderr, _("Hit RETURN to cancel request\n"));
fprintf(stderr, ">");
- } while (!G_gets(answer));
+ *answer = '\0';
+ G_getl(answer, sizeof(answer), stdin);
+ } while (0);
#ifdef HAVE_TERMIOS_H
tcsetattr(STDIN_FILENO, TCSANOW, &tios);
#endif
Modified: grass/trunk/general/Makefile
--- grass/trunk/general/Makefile 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/general/Makefile 2008-08-06 03:28:21 UTC (rev 32551)
@@ -3,7 +3,6 @@
SUBDIRS = \
g.access \
- g.ask \
g.dirseps \
g.filename \
g.findetc \
Deleted: grass/trunk/general/g.ask/Makefile
--- grass/trunk/general/g.ask/Makefile 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/general/g.ask/Makefile 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,11 +0,0 @@
-MODULE_TOPDIR = ../..
-PGM = g.ask
-LIBES = $(GISLIB)
-DEPENDENCIES= $(GISDEP)
-include $(MODULE_TOPDIR)/include/Make/Module.make
-default: cmd
Deleted: grass/trunk/general/g.ask/description.html
--- grass/trunk/general/g.ask/description.html 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/general/g.ask/description.html 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,162 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>g.ask</EM> is designed for shell scripts that need to
-prompt the user for the name of a data base file in the
-user's current GRASS location. After <EM>g.ask</EM> is
-invoked with needed parameters, it will query the user for
-a file name of the specified <EM>type</EM> and
-<EM>element</EM>. After the user responds to this query,
-the program will write four lines to the UNIX output file
-specified by <EM>unixfile</EM>.
-<!-- unused
-<H2>OPTIONS</H2>
-<H3>Parameters:</H3>
-<DL>
-<DT><B>type=</B><EM>name</EM>
-<DD>The type of query. Options for <EM>name</EM> are
-<EM>old</EM>, <EM>new</EM>,
-<EM>any</EM>, and <EM>mapset</EM>; their functions are given below.
-"New", "any", and "mapset" only look in the user's current mapset.
-<DL>
-<DD>
-<DT><B>old</B>
-<DD>For existing data files anywhere in the user's mapset search path.
-<DT><B>new</B>
-<DD>Used to create a new file in the current mapset, which must not
-already exist there (if a file with this name exists there,
-it will not be overwritten).
-<DT><B>any</B>
-<DD>Creates a file in the current mapset, which may or may not
-already exist there. If a file with this name exists in the
-current mapset, it will be overwritten;
-if not, a new file with this name will be created.
-<DT><B>mapset</B>
-<DD>For files that must exist in the current mapset
-The shell write wants the name of a file which exists
-in the user's current mapset. This type would
-used instead of "old" if the file is to be modified.
-</DL>
-<DT><B>prompt=</B>"<EM>string</EM>"
-<DD>The prompt to be displayed to the user. If more than
-one word, the prompt should be enclosed within double
-quotes ("").
-<DT><B>element=</B><EM>name</EM>
-<DD>The name of the GRASS data base element (i.e.,
-directory under a GRASS mapset) whose files are to be
-queried.
-<DT><B>desc=</B>"<EM>string</EM>"
-<DD>A short description of the data base element which is
-meaningful to the user. If description contains more than
-one word, it should be enclosed within double quotes ("").
-<DT><B>unixfile=</B><EM>name</EM>
-<DD>The name of a UNIX file to store the user's response.
-See next section for what is written to this file and how
-it can be used by shell scripts.
-</DL>
-<H2>OUTPUT</H2>
-Upon receiving the user's response to its request for a
-file name, <EM>g.ask</EM> writes four lines to the
-specified <EM>unixfile</EM>; this output file is placed in
-the user's current working directory, unless otherwise
-specified, and contains the following lines:
-<div class="code">
-<PRE>
-name='<EM>some_name</EM>'
-mapset='<EM>some_mapset</EM>'
-fullname='<EM>some_fullname</EM>'
-file='<EM>some_fullpath</EM>'
-</pre></div>
-<P>
-The output is <EM>/bin/sh</EM> commands to set the variable
-<EM>name</EM> to the file name specified by the user (of
-the <EM>element</EM> and <EM>type</EM> requested by
-<EM>g.ask</EM>), <EM>mapset</EM> to the GRASS mapset in
-which this file resides (or will be created),
-<EM>fullname</EM> is the name with the mapset embedded in
-it, and <EM>file</EM> to the full UNIX path name
-identifying this file. These variables may be set in the
-<EM>/bin/sh</EM> as follows:
-<DL>
-<DD>
-<B>. unixfile</B>
-</DL>
-<P>
-The . is a shell command which means read the
-<EM>unixfile</EM> and execute the commands found there. It
-is NOT part of the <EM>unixfile</EM> name and MUST be
-followed by a space.
-<H2>NOTES</H2>
-The user may choose to simply hit the return key and not enter a file name.
-If this happens the variables will be set as follows:
-<div class="code">
-<PRE>
-name=
-mapset=
-fullname=
-file=
-</pre></div>
-<P>
-The following is a way to test for this case:
-<div class="code">
-<PRE>
-if [ ! "$file" ]
-then
- exit
-fi
-</PRE></div>
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.ask.html">d.ask</A></EM>,
-<EM><A HREF="g.filename.html">g.filename</A></EM>,
-<EM><A HREF="g.findfile.html">g.findfile</A></EM>,
-<EM><A HREF="g.gisenv.html">g.gisenv</A></EM>,
-<EM><A HREF="g.parser.html">g.parser</A></EM>
-<H2>AUTHOR</H2>
-Michael Shapiro,
-U.S.Army Construction Engineering Research Laboratory
-<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/general/g.ask/main.c
--- grass/trunk/general/g.ask/main.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/general/g.ask/main.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,124 +0,0 @@
- * MODULE: g.ask
- * AUTHOR(S): Michael Shapiro CERL (original contributor)
- * Markus Neteler <neteler itc.it>,
- * Bernhard Reiter <bernhard intevation.de>,
- * Glynn Clements <glynn gclements.plus.com>,
- * Jan-Oliver Wagner <jan intevation.de>
- * PURPOSE:
- * COPYRIGHT: (C) 1999-2006 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
-#include <stdio.h>
-#include <string.h>
-#include <stdlib.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-int main(int argc, char *argv[])
- char file[1024], name[40], *mapset;
- char *prompt;
- char *help[2];
- FILE *fd;
- struct GModule *module;
- struct Option *opt1;
- struct Option *opt2;
- struct Option *opt3;
- struct Option *opt4;
- struct Option *opt5;
- G_gisinit(argv[0]);
- module = G_define_module();
- module->keywords = _("general");
- module->description =
- "Prompts the user for the names of GRASS data base files.";
- /* Define the different options */
- opt1 = G_define_option();
- opt1->key = "type";
- opt1->type = TYPE_STRING;
- opt1->required = YES;
- opt1->description = "The type of query";
- opt1->options = "old,new,any,mapset";
- opt2 = G_define_option();
- opt2->key = "prompt";
- opt2->key_desc = "\"string\"";
- opt2->type = TYPE_STRING;
- opt2->required = NO;
- opt2->description = "The prompt to be displayed to the user";
- opt3 = G_define_option();
- opt3->key = "element";
- opt3->type = TYPE_STRING;
- opt3->required = YES;
- opt3->description = "The database element to be queried";
- opt4 = G_define_option();
- opt4->key = "desc";
- opt4->key_desc = "\"string\"";
- opt4->type = TYPE_STRING;
- opt4->required = NO;
- opt4->description = "A short description of the database element";
- opt5 = G_define_option();
- opt5->key = "unixfile";
- opt5->type = TYPE_STRING;
- opt5->required = YES;
- opt5->description =
- "The name of a unix file to store the user's response";
- if (argc < 2) { /* no interactive version allowed */
- help[0] = argv[0];
- help[1] = "help";
- argv = help;
- argc = 2;
- if (G_parser(argc, argv) < 0)
- exit(EXIT_FAILURE);
- prompt = opt2->answer;
- fd = fopen(opt5->answer, "w");
- if (fd == NULL) {
- fprintf(stderr, "%s - ", argv[0]);
- perror(opt5->answer);
- if (strcmp(opt1->answer, "old") == 0)
- mapset = G_ask_old(prompt, name, opt3->answer, opt4->answer);
- else if (strcmp(opt1->answer, "new") == 0)
- mapset = G_ask_new(prompt, name, opt3->answer, opt4->answer);
- else if (strcmp(opt1->answer, "any") == 0)
- mapset = G_ask_any(prompt, name, opt3->answer, opt4->answer, 0);
- else if (strcmp(opt1->answer, "mapset") == 0)
- mapset = G_ask_in_mapset(prompt, name, opt3->answer, opt4->answer);
- if (mapset) {
- fprintf(fd, "name='%s'\n", name);
- fprintf(fd, "mapset='%s'\n", mapset);
- fprintf(fd, "fullname='%s'\n", G_fully_qualified_name(name, mapset));
- G__file_name(file, opt3->answer, name, mapset);
- fprintf(fd, "file='%s'\n", file);
- G__make_mapset_element(opt3->answer);
- else {
- fprintf(fd, "name=\n");
- fprintf(fd, "mapset=\n");
- fprintf(fd, "file=\n");
- fclose(fd);
- exit(EXIT_SUCCESS);
Modified: grass/trunk/general/g.proj/datumtrans.c
--- grass/trunk/general/g.proj/datumtrans.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/general/g.proj/datumtrans.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -34,13 +34,10 @@
* \param force Force editing of parameters even if current co-ordinate
* system already contains fully specified parameters.
- * \param interactive Interactively prompt user for parameters, ignoring
- * value of datumtrans variable.
* \return 1 if a change was made, 0 if not.
-int set_datumtrans(int datumtrans, int force, int interactive)
+int set_datumtrans(int datumtrans, int force)
char *params, *datum = NULL;
int paramsets, status;
@@ -81,15 +78,9 @@
struct Key_Value *temp_projinfo;
int i;
- /* First of all obtain the new parameters either interactively
- * or through the supplied transform number index */
- if (interactive) {
- /* Print to stderr here as the function call will also */
- fprintf(stderr, "Datum name: %s (%s)", dstruct.name,
- dstruct.longname);
- GPJ_ask_datum_params(datum, &chosenparams);
- else {
+ /* First of all obtain the new parameters
+ * through the supplied transform number index */
struct gpj_datum_transform_list *list;
if (datumtrans > paramsets)
Modified: grass/trunk/general/g.proj/local_proto.h
--- grass/trunk/general/g.proj/local_proto.h 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/general/g.proj/local_proto.h 2008-08-06 03:28:21 UTC (rev 32551)
@@ -19,7 +19,7 @@
void print_datuminfo(void);
void print_proj4(int);
void print_wkt(int, int);
-void create_location(char *, int);
+void create_location(char *);
/* datumtrans.c */
-int set_datumtrans(int, int, int);
+int set_datumtrans(int, int);
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/general/g.proj/main.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -31,8 +31,7 @@
*printwkt, /* Print projection in WKT format */
*esristyle, /* Use ESRI-style WKT format */
*dontprettify, /* Print 'flat' output (no linebreaks) */
- *forcedatumtrans, /* Force override of datumtrans parameters */
- *interprompt; /* Enable interactive prompting */
+ *forcedatumtrans; /* Force override of datumtrans parameters */
struct Option *location, /* Name of new location to create */
*inepsg, /* EPSG projection code */
@@ -159,11 +158,6 @@
location->guisection = "Create/Edit_Locations";
location->description = _("Name of new location to create");
- interprompt = G_define_flag();
- interprompt->key = 'i';
- interprompt->description =
- _("Enable interactive prompting (for command-line use only)");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -211,8 +205,7 @@
G_fatal_error(_("Projection files missing"));
/* Set Datum Parameters if necessary or requested */
- set_datumtrans(atoi(dtrans->answer), forcedatumtrans->answer,
- interprompt->answer);
+ set_datumtrans(atoi(dtrans->answer), forcedatumtrans->answer);
/* Output */
@@ -232,7 +225,7 @@
print_wkt(esristyle->answer, dontprettify->answer);
if (create->answer)
- create_location(location->answer, interprompt->answer);
+ create_location(location->answer);
/* Tidy Up */
Modified: grass/trunk/general/g.proj/output.c
--- grass/trunk/general/g.proj/output.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/general/g.proj/output.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -143,7 +143,7 @@
return;
-void create_location(char *location, int interactive)
+void create_location(char *location)
int ret;
@@ -165,7 +165,6 @@
/* Create flag given but no location specified; overwrite
* projection files for current location */
- int go_ahead = 0;
char *mapset = G_mapset();
struct Key_Value *old_projinfo = NULL, *old_projunits = NULL;
struct Cell_head old_cellhd;
@@ -184,43 +183,9 @@
old_projunits = G_get_projunits();
- if (old_projinfo && old_projunits) {
- /* Warn as in g.setproj before overwriting current location */
- fprintf(stderr,
- _
- ("\n\nWARNING! A projection file already exists for this location\n"));
- fprintf(stderr,
- "\nThis file contains all the parameters for the\nlocation's projection: %s\n",
- G_find_key_value("proj", old_projinfo));
- fprintf(stderr,
- "\n Overriding this information implies that the old projection parameters\n");
- fprintf(stderr,
- " were incorrect. If you change the parameters, all existing data will be\n");
- fprintf(stderr,
- " interpreted differently by the projection software.\n%c%c%c",
- 7, 7, 7);
- fprintf(stderr,
- " GRASS will not re-project your data automatically\n\n");
- if (G_yes
- (_
- ("Would you still like to overwrite the current projection information "),
- 0))
- go_ahead = 1;
- else
- go_ahead = 1;
- else {
- /* Projection files missing for some reason;
- * go ahead and update */
- go_ahead = 1;
- if (go_ahead) {
int out_stat;
- char path[4096];
+ char path[GPATH_MAX];
/* Write out the PROJ_INFO, and PROJ_UNITS if available. */
if (projinfo != NULL) {
@@ -250,9 +215,6 @@
G_message(_("Projection information updated!"));
- else
- G_message(_("The projection information will not be updated."));
return;
Deleted: grass/trunk/general/manage/lib/menu.c
--- grass/trunk/general/manage/lib/menu.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/general/manage/lib/menu.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,160 +0,0 @@
-#include "list.h"
-static int count;
-static char **text;
-static int first, last;
-int menu(int type)
- int i;
- int n;
- int x;
- char buf[100];
- build_menu();
- first = 0;
- while (1) {
- last = first + 30;
- if (last > count)
- last = count;
- G_clear_screen();
- switch (type) {
- case RENAME:
- fprintf(stdout, "RENAME");
- break;
- case REMOVE:
- fprintf(stdout, "REMOVE");
- break;
- case COPY:
- fprintf(stdout, "COPY");
- break;
- case LIST:
- fprintf(stdout, "LIST");
- break;
- fprintf(stdout, " FACILITY\n\n");
- fprintf(stdout, "This program allows you to ");
- switch (type) {
- case RENAME:
- fprintf(stdout, "rename files found in your mapset");
- break;
- case REMOVE:
- fprintf(stdout, "remove files found in your mapset");
- break;
- case COPY:
- fprintf(stdout, "copy files from other mapsets into your mapset");
- break;
- case LIST:
- fprintf(stdout, "list files from mapsets in your search path");
- break;
- fprintf(stdout, "\n\n");
- fprintf(stdout, "Please select the type of file to be ");
- switch (type) {
- case RENAME:
- fprintf(stdout, "renamed");
- break;
- case REMOVE:
- fprintf(stdout, "removed");
- break;
- case COPY:
- fprintf(stdout, "copied");
- break;
- case LIST:
- fprintf(stdout, "listed");
- break;
- display_menu();
- fprintf(stdout, "\n");
- if (first > 0)
- fprintf(stdout, " - to see previous menu page\n");
- if (last < count)
- fprintf(stdout, " + to see next menu page\n");
- fprintf(stdout, "RETURN to exit\n\n");
- fprintf(stdout, "> ");
- if (!G_gets(buf))
- continue;
- if (*buf == 0) {
- free_menu();
- return -1;
- G_strip(buf);
- if (first > 0 && strcmp(buf, "-") == 0) {
- first -= 30;
- if (first < 0)
- first = 0;
- continue;
- if (last < count && strcmp(buf, "+") == 0) {
- first = last;
- continue;
- if (sscanf(buf, "%d", &x) != 1)
- continue;
- i = 1;
- for (n = 0; n < nlist; n++)
- if (list[n].status && (i++ == x)) {
- free_menu();
- return n;
-int build_menu(void)
- char buf[100];
- int n;
- count = 0;
- text = 0;
- if (list[n].status) {
- sprintf(buf, "%3d %-.30s", ++count, list[n].text);
- text = (char **)G_realloc(text, count * sizeof(char *));
- text[count - 1] = G_store(buf);
- return 0;
-int free_menu(void)
- while (count-- > 0)
- G_free(text[count]);
- return 0;
-int display_menu(void)
- int left, right;
- int i;
- left = first;
- right = first + 15;
- for (i = 0; i < 15; i++) {
- if (left >= last)
- break;
- if (right >= last)
- fprintf(stdout, " %-35.35s\n", text[left]);
- else
- fprintf(stdout, " %-35.35s %-35.35s\n", text[left],
- text[right]);
- left++;
- right++;
- return 0;
Modified: grass/trunk/imagery/i.class/Makefile
--- grass/trunk/imagery/i.class/Makefile 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/imagery/i.class/Makefile 2008-08-06 03:28:21 UTC (rev 32551)
@@ -2,8 +2,8 @@
PGM = i.class
-LIBES = $(IMAGERYLIB) $(DISPLAYLIB) $(RASTERLIB) $(GISLIB) $(VASKLIB) $(CURSES) $(GMATHLIB)
-DEPENDENCIES= $(IMAGERYDEP) $(DISPLAYDEP) $(RASTERDEP) $(GISDEP) $(VASKDEP) $(GMATHDEP)
+LIBES = $(IMAGERYLIB) $(DISPLAYLIB) $(RASTERLIB) $(GISLIB) $(GMATHLIB)
+DEPENDENCIES= $(IMAGERYDEP) $(DISPLAYDEP) $(RASTERDEP) $(GISDEP) $(GMATHDEP)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/include/Make/Platform.make.in 2008-08-06 03:28:21 UTC (rev 32551)
@@ -90,9 +90,6 @@
XEXTRALIBS = @X_EXTRA_LIBS@
USE_X11 = @USE_X11@
-COMPATLIB = @COMPATLIB@
-CURSES = @CURSESLIB@ $(COMPATLIB)
-USE_CURSES = @USE_CURSES@
MATHLIB = @MATHLIB@
XDRLIB = @XDRLIB@ @ZLIBINCPATH@ @ZLIBLIBPATH@ @ZLIB@
ICONVLIB = @ICONVLIB@
Modified: grass/trunk/include/P_site.h
--- grass/trunk/include/P_site.h 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/include/P_site.h 2008-08-06 03:28:21 UTC (rev 32551)
@@ -36,10 +36,6 @@
void G_sites_close(struct Map_info *);
char *G_find_sites(char *name, const char *mapset);
char *G_find_sites2(const char *name, const char *mapset);
-char *G_ask_sites_new(const char *prompt, char *name);
-char *G_ask_sites_old(const char *prompt, char *name);
-char *G_ask_sites_any(const char *prompt, char *name);
-char *G_ask_sites_in_mapset(const char *prompt, char *name);
int G__site_put(struct Map_info *, Site *, int);
struct Map_info *G_fopen_sites_old(const char *, const char *);
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/include/config.h.in 2008-08-06 03:28:21 UTC (rev 32551)
@@ -20,12 +20,6 @@
/* define for Windows static build */
#undef STATIC_BUILD
-/* define if curses.h exists */
-#undef HAVE_CURSES_H
-/* define if keypad in lib[n]curses */
-#undef HAVE_KEYPAD
/* define if limits.h exists */
#undef HAVE_LIMITS_H
@@ -95,9 +89,6 @@
/* Define the return type of signal handlers */
#define RETSIGTYPE int
-/* define curses.h WINDOW structure component */
-#define CURSES_MAXY @CURSES_MAXY@
/* define if ftime() exists */
#undef HAVE_FTIME
Deleted: grass/trunk/include/edit.h
--- grass/trunk/include/edit.h 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/include/edit.h 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,16 +0,0 @@
-#ifndef GRASS_EDIT_H
-#define GRASS_EDIT_H
-/* edit_cats.c */
-int E_edit_cats(const char *, struct Categories *, int);
-int E_edit_fp_cats(const char *, struct Categories *);
-/* edit_cellhd.c */
-int E_edit_cellhd(struct Cell_head *, int);
-/* edit_hist.c */
-int E_edit_history(struct History *);
-#endif
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/include/gisdefs.h 2008-08-06 03:28:21 UTC (rev 32551)
@@ -81,34 +81,7 @@
/* ascii_chk.c */
int G_ascii_check(char *);
-/* ask.c */
-char *G_ask_new(const char *, char *, char *, char *);
-char *G_ask_new_ext(const char *, char *, char *, char *, char *, int (*)());
-char *G_ask_old(const char *, char *, char *, char *);
-char *G_ask_old_ext(const char *, char *, char *, char *, char *, int (*)());
-char *G_ask_any(const char *, char *, char *, char *, int);
-char *G_ask_any_ext(const char *, char *, char *, char *, int, char *,
- int (*)());
-char *G_ask_in_mapset(const char *, char *, char *, char *);
-char *G_ask_in_mapset_ext(const char *, char *, char *, char *, char *,
- int (*)());
-char *G_ask_new_file(const char *, char *, char *, char *);
-char *G_ask_old_file(const char *, char *, char *, char *);
-int G_set_ask_return_msg(const char *);
-char *G_get_ask_return_msg(void);
-/* ask_cell.c */
-char *G_ask_cell_new(const char *, char *);
-char *G_ask_cell_old(const char *, char *);
-char *G_ask_cell_in_mapset(const char *, char *);
-char *G_ask_cell_any(const char *, char *);
-/* ask_vctrs.c */
-char *G_ask_vector_new(const char *, char *);
-char *G_ask_vector_old(const char *, char *);
-char *G_ask_vector_any(const char *, char *);
-char *G_ask_vector_in_mapset(const char *, char *);
/* asprintf.c */
/* Do it better if you know how */
/* asprintf is not found on MINGW but exists */
@@ -563,12 +536,6 @@
/* get_cellhd.c */
int G_get_cellhd(const char *, const char *, struct Cell_head *);
-/* get_datum_name.c */
-int G_ask_datum_name(char *, char *);
-/* get_ell_name.c */
-int G_ask_ellipse_name(char *);
/* get_ellipse.c */
int G_get_ellipsoid_parameters(double *, double *);
int G_get_spheroid_by_name(const char *, double *, double *, double *);
@@ -580,9 +547,6 @@
struct Key_Value *G_get_projunits(void);
struct Key_Value *G_get_projinfo(void);
-/* get_projname.c */
-int G_ask_proj_name(char *, char *);
/* get_row.c */
int G_get_map_row_nomask(int, CELL *, int);
int G_get_raster_row_nomask(int, void *, int, RASTER_MAP_TYPE);
@@ -611,9 +575,6 @@
int G_getl(char *, int, FILE *);
int G_getl2(char *, int, FILE *);
-/* gets.c */
-int G_gets(char *);
/* gisbase.c */
char *G_gisbase(void);
@@ -780,9 +741,6 @@
/* mach_name.c */
char *G__machine_name(void);
-/* make_colr.c */
-int G_ask_colors(const char *, const char *, struct Colors *);
/* make_loc.c */
int G__make_location(const char *, struct Cell_head *, struct Key_Value *,
struct Key_Value *, FILE *);
@@ -1271,9 +1229,6 @@
/* writ_zeros.c */
int G_write_zeros(int, size_t);
-/* yes.c */
-int G_yes(const char *, int);
/* zero.c */
int G_zero(void *, int);
Modified: grass/trunk/include/gprojects.h
--- grass/trunk/include/gprojects.h 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/include/gprojects.h 2008-08-06 03:28:21 UTC (rev 32551)
@@ -95,7 +95,6 @@
int GPJ_get_datum_params(char **, char **);
int GPJ__get_datum_params(struct Key_Value *, char **, char **);
void GPJ_free_datum(struct gpj_datum *);
-int GPJ_ask_datum_params(const char *, char **);
struct gpj_datum_transform_list *GPJ_get_datum_transform_by_name(const char
*inputname);
Modified: grass/trunk/include/imagedefs.h
--- grass/trunk/include/imagedefs.h 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/include/imagedefs.h 2008-08-06 03:28:21 UTC (rev 32551)
@@ -13,9 +13,6 @@
double ***I_alloc_double3(int, int, int);
int I_free_double3(double ***);
-/* ask_group.c */
-int I_ask_group_old(char *, char *);
/* eol.c */
int I_get_to_eol(char *, int, FILE *);
Deleted: grass/trunk/include/vask.h
--- grass/trunk/include/vask.h 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/include/vask.h 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,84 +0,0 @@
-#ifndef __VASK_H__
-#define __VASK_H__
-#include <signal.h>
-#ifdef MAKE_VASK_LIB
-#define MAX_ANSW 80
-#define MAX_CONST 80
-#define MAX_LINE 23
-*** target contains all the variable type that we will want to
-*** be looking for.
-union target
- char *c;
- short *h;
- int *i;
- long *l;
- float *f;
- double *d;
- double for_alignement;
-*** ans_rec contains all the information needed to go
-*** and get an answer from the screen.
-struct ans_rec
- union target targetptr; /* pointer to value */
- int var_type; /* value type */
- int row; /* row position */
- int col; /* column position */
- int length; /* length of entry */
- int decimal_places; /* number of decimal places */
-*** page is an array of pointers to lines on a page.
-struct page
- const char *line[MAX_LINE];
-struct V__
- struct ans_rec usr_answ[MAX_ANSW];
- struct ans_rec constant[MAX_CONST];
- struct page page;
- int NUM_ANSW;
- int NUM_CONST;
- int NUM_LINE;
- char interrupt_msg[80];
-/* one of the library routines (V_call) will define this struct */
-extern struct V__ V__;
-#endif
-void V_float_accuracy(int);
-int V_call(void);
-void V_intrpt_ok(void);
-void V_intrpt_msg(const char *);
-void V_clear(void);
-int V_const(void *, int, int, int, int);
-void V_error(const char *, ...);
-void V_exit(void);
-void V_init(void);
-int V_line(int, const char *);
-int V_ques(void *, int, int, int, int);
-int V__dump_window(void);
-void V__remove_trail(int, char *);
-void V__trim_decimal(char *);
-#endif /* __VASK_H__ */
Modified: grass/trunk/lib/Makefile
--- grass/trunk/lib/Makefile 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/Makefile 2008-08-06 03:28:21 UTC (rev 32551)
@@ -14,8 +14,6 @@
btree \
display \
db \
- vask \
- edit \
external \
fonts \
gtcltk \
Deleted: grass/trunk/lib/edit/Makefile
--- grass/trunk/lib/edit/Makefile 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/edit/Makefile 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,10 +0,0 @@
-EXTRA_LIBS=$(GISLIB) $(VASKLIB)
-LIB_NAME = $(EDIT_LIBNAME)
-include $(MODULE_TOPDIR)/include/Make/Lib.make
-default: lib
Deleted: grass/trunk/lib/edit/edit_cats.c
--- grass/trunk/lib/edit/edit_cats.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/edit/edit_cats.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,380 +0,0 @@
- * MODULE: edit library functions
- * AUTHOR(S): Originally part of gis lib dir in CERL GRASS code
- * Subsequent (post-CVS) contributors:
- * Radim Blazek <radim.blazek gmail.com>,
- * Eric G. Miller <egm2 jps.net>,
- * Brad Douglas <rez touchofmadness.com>,
- * PURPOSE: libraries for interactively editing raster support data
- * COPYRIGHT: (C) 1996-2006 by the GRASS Development Team
- * for details.
- * E_edit_cats (name, cats, option)
- * char *name
- * struct Categories *cats
- * Interactively prompts the user for category names for
- * cats->ncats categories. Uses screen oriented prompting through
- * the visual_ask library. Compile with $(VASKLIB) and $(CURSES)
- * name is used for informatin on the screen only.
- * No files are read or written
- * If option is 0, user can change number of cats
- * 1, user must initialize number of cats
- * -1, user may not change number of cats
- * Returns:
- * -1 if user canceled the edit
- * 1 if ok
- * note:
- * at present, this routine pretends to know nothing about the
- * category label generation capabilities using the cats.fmt
- * string. If it is necessary to let the user edit this
- * a separate interface must be used
-#include <grass/vask.h>
-#include <grass/edit.h>
-#define NLINES 10
-int E_edit_cats(const char *name, struct Categories *cats, int option)
- long incr;
- long atnum;
- long startcat;
- long endcat;
- long first_cat, last_cat;
- long catnum[NLINES];
- char buff[NLINES][80];
- char next[20];
- char next_line[80];
- char title[80];
- char msg1[80];
- char msg2[80];
- int line;
- CELL max_ind, max_cat, min_ind;
- DCELL max_val, min_val;
- if (G_quant_get_limits
- (&cats->q, &min_val, &max_val, &min_ind, &max_ind) < 0)
- max_cat = 0;
- else
- max_cat = (CELL) max_val;
- if (max_cat < 0)
- option = 1;
- last_cat = (long)max_cat;
- if (option >= 0) {
- V_clear();
- V_line(1, msg1);
- V_line(2, msg2);
- if (option == 0) {
- strcpy(msg1, "The current value for the highest category");
- sprintf(msg2, "in [%s] is shown below", name);
- V_line(3, "If you need to change it, enter another value");
- else {
- last_cat = 0;
- strcpy(msg1, "Please enter the highest category value");
- sprintf(msg2, "for [%s]", name);
- V_line(10, " Highest Category:");
- V_ques(&last_cat, 'l', 10, 28, 5);
- V_line(16, next_line);
- *next_line = 0;
- while (1) {
- V_intrpt_ok();
- if (!V_call())
- return -1;
- if (last_cat >= 0)
- break;
- sprintf(next_line, "** Negative values not allowed **");
- max_cat = last_cat;
- first_cat = 0;
- if (cats->ncats > 0 && min_val < 0)
- first_cat = (CELL) min_val;
- *title = 0;
- if (cats->title != NULL)
- strcpy(title, cats->title);
- startcat = first_cat;
- sprintf(msg1, "[%s] ENTER NEW CATEGORY NAMES FOR THESE CATEGORIES", name);
- while (1) {
- V_clear();
- V_line(0, msg1);
- V_line(2, "TITLE: ");
- V_line(3, "CAT NEW CATEGORY NAME");
- V_line(4, "NUM");
- V_ques(title, 's', 2, 8, 60);
- endcat =
- startcat + NLINES <=
- last_cat + 1 ? startcat + NLINES : last_cat + 1;
- line = 5;
- for (incr = startcat; incr < endcat; incr++) {
- atnum = incr - startcat;
- strcpy(buff[atnum], G_get_cat((CELL) incr, cats));
- catnum[atnum] = incr;
- V_const(&catnum[atnum], 'l', line, 1, 3);
- V_ques(buff[atnum], 's', line, 5, 60);
- line++;
- line += 2;
- *next = 0;
- if (endcat > last_cat)
- strcpy(next, "end");
- else
- sprintf(next, "%ld", endcat);
- sprintf(next_line, "%*s%*s (of %ld)", 41,
- "Next category ('end' to end): ", 5, "", last_cat);
- V_line(line, next_line);
- V_ques(next, 's', line, 41, 5);
- V_intrpt_ok();
- if (!V_call())
- return -1;
- /* store new category name in structure */
- G_strip(buff[atnum]);
- if (strcmp(buff[atnum], G_get_cat((CELL) incr, cats)) != 0)
- G_set_cat((CELL) incr, buff[atnum], cats);
- if (*next == 0)
- break;
- if (strcmp(next, "end") == 0)
- break;
- if (sscanf(next, "%ld", &endcat) != 1)
- continue;
- if (endcat < first_cat)
- endcat = first_cat;
- if (endcat > last_cat) {
- endcat = last_cat - NLINES + 1;
- if (endcat < 0)
- endcat = 0;
- startcat = endcat;
- if (cats->title)
- G_free(cats->title);
- G_strip(title);
- cats->title = G_store(title);
- return (1);
- * E_edit_fp_cats (name, cats)
- * char *name
- * fp ranges of data. Uses screen oriented prompting through
- * Returns:
- * 1 if ok
- * note:
-#define NLINES 10
-int E_edit_fp_cats(const char *name, struct Categories *cats)
- long incr;
- long atnum;
- long startcat;
- long endcat;
- char buff[NLINES][60];
- char next[20];
- char title[80];
- char msg1[80];
- char msg2[80];
- int line, ncats;
- size_t lab_len;
- DCELL max_val[NLINES], min_val[NLINES];
- DCELL dmin, dmax;
- CELL tmp_cell;
- struct Categories old_cats;
- struct FPRange fp_range;
- if (G_read_fp_range(name, G_mapset(), &fp_range) < 0)
- G_fatal_error("can't read the floating point range for %s", name);
- G_get_fp_range_min_max(&fp_range, &dmin, &dmax);
- /* first save old cats */
- G_copy_raster_cats(&old_cats, cats);
- G_init_raster_cats(old_cats.title, cats);
- G_free_raster_cats(cats);
- ncats = old_cats.ncats;
- V_clear();
- if (!ncats)
- sprintf(msg1, "There are no predefined fp ranges to label");
- else
- sprintf(msg1, "There are %d predefined fp ranges to label", ncats);
- sprintf(msg2, "Enter the number of fp ranges you want to label");
- V_line(1, msg1);
- V_line(2, msg2);
- V_ques(&ncats, 'l', 2, 48, 5);
- *next_line = 0;
- V_intrpt_ok();
- if (!V_call())
- return -1;
- *title = 0;
- if (old_cats.title != NULL)
- strcpy(title, old_cats.title);
- startcat = 0;
- sprintf(msg1, "The fp data in map %s ranges from %f to %f", name, dmin,
- dmax);
- sprintf(msg2, "[%s] ENTER NEW CATEGORY NAMES FOR THESE CATEGORIES", name);
- while (1) {
- V_clear();
- V_line(0, msg1);
- V_line(1, msg2);
- V_line(3, "TITLE: ");
- V_line(4, "FP RANGE NEW CATEGORY NAME");
- endcat = startcat + NLINES <= ncats ? startcat + NLINES : ncats;
- line = 6;
- if (incr < old_cats.ncats) {
- /* if editing existing range label */
- lab_len = strlen(old_cats.labels[incr]);
- if (lab_len > 58)
- lab_len = 58;
- strncpy(buff[atnum], old_cats.labels[incr], lab_len);
- buff[atnum][lab_len] = 0;
- G_quant_get_ith_rule(&old_cats.q, incr, &min_val[atnum],
- &max_val[atnum], &tmp_cell, &tmp_cell);
- else {
- /* adding new range label */
- strcpy(buff[atnum], "");
- max_val[atnum] = min_val[atnum] = 0;
- V_ques(&min_val[atnum], 'd', line, 1, 8);
- V_const("-", 's', line, 9, 1);
- V_ques(&max_val[atnum], 'd', line, 10, 8);
- V_ques(buff[atnum], 's', line, 19, 58);
- line++;
- line += 2;
- *next = 0;
- if (endcat >= ncats)
- else
- sprintf(next_line, "%*s%*s (of %d)", 41,
- "Next range number ('end' to end): ", 5, "", ncats);
- V_intrpt_ok();
- if (!V_call())
- return -1;
- if (!(strcmp(buff[atnum], "") == 0 &&
- min_val[atnum] == 0. && max_val[atnum] == 0.))
- G_set_d_raster_cat(&min_val[atnum], &max_val[atnum],
- buff[atnum], cats);
- if (*next == 0)
- break;
- break;
- continue;
- if (endcat < 0)
- endcat = 0;
- if (endcat > ncats) {
- endcat = ncats - NLINES + 1;
- if (endcat < 0)
- endcat = 0;
- G_strip(title);
- /* since label pointers in old_cats point to the old allocated strings,
- and cats now has all the newly allocated strings, it never reuses
- old ones, we need to free them */
- return (1);
Deleted: grass/trunk/lib/edit/edit_cellhd.c
--- grass/trunk/lib/edit/edit_cellhd.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/edit/edit_cellhd.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,604 +0,0 @@
- * for details.
-#define AS_CELLHD 1
-#define AS_WINDOW 0
-#define AS_DEF_WINDOW -1
-/* modified 26nov to use word region instead of window
- * as far as the USER is concerned.
- * E_edit_cellhd (cellhd, type)
- * struct Cell_head *cellhd (cellhd to be defined)
- * int type
- * 0 = region - user input resolutions
- * -1 = default region - user input resolutions
- * 1 = cellhd - rows and cols must be set
- * Screen oriented user interactive session for modifying a cell header
- * or region.
- * Uses the visual_ask V_ask routines. As such, programs including
- * this must load the GRASS library $(VASKLIB) and include $(CURSES) in
- * in the compile line
- * returns:
- * -1 error of some sort, or user cancels the edit
- * 0 ok
-/* Documentation moved here from the g.region man page:
- * (g.region no longer does interactive; lib/init/set_data.c is the
- * only thing left using E_edit_cellhd() AFAICT. --HB 28 Jan 2008)
- * <h2>REGION EDIT PROMPT</h2>
- * Most of the options will require the user to edit a
- * geographic region, be it the current geographic region or
- * one stored in the user's named region definitions
- * (the <kbd>windows</kbd> directory). A standard prompt is
- * used to perform this edit. An example is shown below:
- * <pre>
- * | IDENTIFY REGION |
- * | =========== DEFAULT REGION ========== |
- * | | Default North: 3402025.00 | |
- * | | ===YOUR REGION=== | |
- * | | | NORTH EDGE | | |
- * | | | 3402025.00_ | | |
- * | Def West: |WEST EDGE | |EAST EDGE | Def.East: |
- * | 233975.00 |233975.00_| |236025.00_| 236025.00 |
- * | | | SOUTH EDGE | | |
- * | | | 3399975.00_ | | |
- * | | Default South: 3399975.00 | |
- * | Default GRID RESOLUTION Region |
- * | 50.00 --- East-West --- 50.00__ |
- * | 50.00 -- North-South -- 50.00__ |
- * | AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE |
- * </pre>
- * The fields NORTH EDGE, SOUTH EDGE, WEST EDGE and EAST EDGE,
- * are the boundaries of the geographic region that the user
- * can change. The fields Default North, Default South, Def
- * West and Def East are the boundaries of the default
- * geographic region that are displayed for reference and
- * <em>cannot</em> be changed. The two GRID RESOLUTION Region
- * fields (east-west, and north-south) are the geographic
- * region's cell resolutions that the user can change. The
- * two GRID RESOLUTION Default fields list the resolutions of
- * the default geographic region; these are displayed for
- * reference and cannot be changed here by the user.
-static void format_value(int (*func) (double, char *, int),
- double x, char *buf, int projection);
-static void format_northing(double north, char *buf, int projection);
-static void format_easting(double east, char *buf, int projection);
-static void format_resolution(double res, char *buf, int projection);
-static int hitreturn(void);
-static char *cellhd_screen[] = {
- " IDENTIFY CELL HEADER",
- " ============================= DEFAULT REGION ========",
- " | Default North: |",
- " | ======= CELL HEADER ======= |",
- " | | NORTH EDGE: | |",
- " Def. West |WEST EDGE | |EAST EDGE | Def. East",
- " | | SOUTH EDGE: | |",
- " | Default South: |",
- " PROJECTION: ZONE:",
- NULL
-static char *window_screen[] = {
- " IDENTIFY REGION",
- " | ======= YOUR REGION ======= |",
- " Default GRID RESOLUTION Region",
- " --- East-West ---",
- " -- North-South --",
- NULL
-static char *def_window_screen[] = {
- " DEFINE THE DEFAULT REGION",
- " ====== DEFAULT REGION =======",
- " | NORTH EDGE: |",
- " WEST EDGE | |EAST EDGE",
- " | SOUTH EDGE: |",
- " GRID RESOLUTION",
- " East-West:",
- " North-South:",
- NULL
- if (projection != PROJECTION_XY) {
- int k = (projection == PROJECTION_LL) ? 3600 : 1;
- int i = (int)(x * k + (x < 0 ? -0.5 : 0.5));
- x = (double)i / k;
- func(x, buf, projection);
- buf[10] = '\0';
- format_value(G_format_northing, north, buf, projection);
- format_value(G_format_easting, east, buf, projection);
- format_value(G_format_resolution, res, buf, projection);
-int E_edit_cellhd(struct Cell_head *cellhd, int type)
- char ll_north[20];
- char ll_south[20];
- char ll_east[20];
- char ll_west[20];
- char ll_nsres[20];
- char ll_ewres[20];
- char ll_def_north[20];
- char ll_def_south[20];
- char ll_def_east[20];
- char ll_def_west[20];
- char ll_def_ewres[20];
- char ll_def_nsres[20];
- char projection[80];
- char **screen;
- struct Cell_head def_wind;
- double north, south, east, west;
- double nsres, ewres;
- char buf[64], buf2[30], *p;
- short ok;
- int line;
- char *prj;
- char *err;
- if (type == AS_CELLHD && (cellhd->rows <= 0 || cellhd->cols <= 0)) {
- G_message("E_edit_cellhd() - programmer error");
- G_message(" ** rows and cols must be positive **");
- return -1;
- if (type != AS_DEF_WINDOW) {
- if (G_get_default_window(&def_wind) != 1)
- return -1;
- if (cellhd->proj < 0) {
- cellhd->proj = def_wind.proj;
- cellhd->zone = def_wind.zone;
- else if (cellhd->zone < 0)
- prj = G__projection_name(cellhd->proj);
- if (!prj)
- prj = "** unknown **";
- sprintf(projection, "%d (%s)", cellhd->proj, prj);
- if (cellhd->west >= cellhd->east || cellhd->south >= cellhd->north) {
- cellhd->north = def_wind.north;
- cellhd->south = def_wind.south;
- cellhd->west = def_wind.west;
- cellhd->east = def_wind.east;
- if (type != AS_CELLHD) {
- cellhd->ew_res = def_wind.ew_res;
- cellhd->ns_res = def_wind.ns_res;
- cellhd->rows = def_wind.rows;
- cellhd->cols = def_wind.cols;
- if (cellhd->proj != def_wind.proj) {
- if (type == AS_CELLHD)
- G_message
- ("header projection %d differs from default projection %d",
- cellhd->proj, def_wind.proj);
- else
- G_message
- ("region projection %d differs from default projection %d",
- if (!G_yes("do you want to make them match? ", 1))
- return -1;
- if (cellhd->zone != def_wind.zone) {
- G_message("header zone %d differs from default zone %d",
- cellhd->zone, def_wind.zone);
- else
- G_message("region zone %d differs from default zone %d",
- return -1;
- *ll_def_north = 0;
- *ll_def_south = 0;
- *ll_def_east = 0;
- *ll_def_west = 0;
- *ll_def_ewres = 0;
- *ll_def_nsres = 0;
- format_northing(def_wind.north, ll_def_north, def_wind.proj);
- format_northing(def_wind.south, ll_def_south, def_wind.proj);
- format_easting(def_wind.east, ll_def_east, def_wind.proj);
- format_easting(def_wind.west, ll_def_west, def_wind.proj);
- format_resolution(def_wind.ew_res, ll_def_ewres, def_wind.proj);
- format_resolution(def_wind.ns_res, ll_def_nsres, def_wind.proj);
- *ll_north = 0;
- *ll_south = 0;
- *ll_east = 0;
- *ll_west = 0;
- *ll_ewres = 0;
- *ll_nsres = 0;
- format_northing(cellhd->north, ll_north, cellhd->proj);
- format_northing(cellhd->south, ll_south, cellhd->proj);
- format_easting(cellhd->east, ll_east, cellhd->proj);
- format_easting(cellhd->west, ll_west, cellhd->proj);
- format_resolution(cellhd->ew_res, ll_ewres, cellhd->proj);
- format_resolution(cellhd->ns_res, ll_nsres, cellhd->proj);
- while (1) {
- ok = 1;
- /* List window options on the screen for the user to answer */
- switch (type) {
- case AS_CELLHD:
- screen = cellhd_screen;
- break;
- case AS_DEF_WINDOW:
- screen = def_window_screen;
- break;
- default:
- screen = window_screen;
- break;
- V_clear();
- line = 0;
- while (*screen)
- V_line(line++, *screen++);
- /* V_ques ( variable, type, row, col, length) ; */
- V_ques(ll_north, 's', 6, 36, 10);
- V_ques(ll_south, 's', 10, 36, 10);
- V_ques(ll_west, 's', 9, 12, 10);
- V_ques(ll_east, 's', 9, 52, 10);
- V_ques(ll_ewres, 's', 18, 48, 10);
- V_ques(ll_nsres, 's', 19, 48, 10);
- V_const(ll_def_north, 's', 3, 36, 10);
- V_const(ll_def_south, 's', 13, 36, 10);
- V_const(ll_def_west, 's', 9, 1, 10);
- V_const(ll_def_east, 's', 9, 65, 10);
- V_const(ll_def_ewres, 's', 18, 21, 10);
- V_const(ll_def_nsres, 's', 19, 21, 10);
- V_const(projection, 's', 15, 23, (int)strlen(projection));
- V_const(&cellhd->zone, 'i', 15, 60, 3);
- V_intrpt_ok();
- if (!V_call())
- return -1;
- G_squeeze(ll_north);
- G_squeeze(ll_south);
- G_squeeze(ll_east);
- G_squeeze(ll_west);
- G_squeeze(ll_ewres);
- G_squeeze(ll_nsres);
- if (!G_scan_northing(ll_north, &cellhd->north, cellhd->proj)) {
- G_warning("Illegal value for north: %s", ll_north);
- ok = 0;
- if (!G_scan_northing(ll_south, &cellhd->south, cellhd->proj)) {
- G_warning("Illegal value for south: %s", ll_south);
- ok = 0;
- if (!G_scan_easting(ll_east, &cellhd->east, cellhd->proj)) {
- G_warning("Illegal value for east: %s", ll_east);
- ok = 0;
- if (!G_scan_easting(ll_west, &cellhd->west, cellhd->proj)) {
- G_warning("Illegal value for west: %s", ll_west);
- ok = 0;
- if (!G_scan_resolution(ll_ewres, &cellhd->ew_res, cellhd->proj)) {
- G_warning("Illegal east-west resolution: %s", ll_ewres);
- ok = 0;
- if (!G_scan_resolution(ll_nsres, &cellhd->ns_res, cellhd->proj)) {
- G_warning("Illegal north-south resolution: %s", ll_nsres);
- ok = 0;
- if (!ok) {
- hitreturn();
- continue;
- /* Adjust and complete the cell header */
- north = cellhd->north;
- south = cellhd->south;
- east = cellhd->east;
- west = cellhd->west;
- nsres = cellhd->ns_res;
- ewres = cellhd->ew_res;
- if ((err =
- G_adjust_Cell_head(cellhd, type == AS_CELLHD,
- type == AS_CELLHD))) {
- G_message("%s", err);
- hitreturn();
- continue;
- if (type == AS_CELLHD) {
- SHOW:
- fprintf(stderr, "\n\n");
- G_message(" projection: %s", projection);
- G_message(" zone: %d", cellhd->zone);
- G_format_northing(cellhd->north, buf, cellhd->proj);
- G_format_northing(north, buf2, cellhd->proj);
- fprintf(stderr, " north: %s", buf);
- if (strcmp(buf, buf2) != 0) {
- ok = 0;
- fprintf(stderr, " (Changed to match resolution)");
- fprintf(stderr, "\n");
- G_format_northing(cellhd->south, buf, cellhd->proj);
- G_format_northing(south, buf2, cellhd->proj);
- fprintf(stderr, " south: %s", buf);
- ok = 0;
- G_format_easting(cellhd->east, buf, cellhd->proj);
- G_format_easting(east, buf2, cellhd->proj);
- fprintf(stderr, " east: %s", buf);
- ok = 0;
- G_format_easting(cellhd->west, buf, cellhd->proj);
- G_format_easting(west, buf2, cellhd->proj);
- fprintf(stderr, " west: %s", buf);
- ok = 0;
- G_format_resolution(cellhd->ew_res, buf, cellhd->proj);
- G_format_resolution(ewres, buf2, cellhd->proj);
- fprintf(stderr, " e-w res: %s", buf);
- ok = 0;
- fprintf(stderr, " (Changed to conform to grid)");
- G_format_resolution(cellhd->ns_res, buf, cellhd->proj);
- G_format_resolution(nsres, buf2, cellhd->proj);
- fprintf(stderr, " n-s res: %s", buf);
- ok = 0;
- G_message(" total rows: %15d", cellhd->rows);
- G_message(" total cols: %15d", cellhd->cols);
- sprintf(buf, "%lf", (double)cellhd->rows * cellhd->cols);
- *(p = strchr(buf, '.')) = 0;
- G_insert_commas(buf);
- G_message(" total cells: %15s", buf);
- if (cellhd->north > def_wind.north) {
- G_warning("north falls outside the default region");
- ok = 0;
- if (cellhd->south < def_wind.south) {
- G_warning("south falls outside the default region");
- ok = 0;
- if (cellhd->proj != PROJECTION_LL) {
- if (cellhd->east > def_wind.east) {
- G_warning("east falls outside the default region");
- ok = 0;
- if (cellhd->west < def_wind.west) {
- G_warning("west falls outside the default region");
- ok = 0;
- ASK:
- fflush(stdin);
- fprintf(stderr, "\nDo you accept this header? (y/n) [%s] > ",
- ok ? "y" : "n");
- else
- fprintf(stderr, "\nDo you accept this region? (y/n) [%s] > ",
- ok ? "y" : "n");
- if (!G_gets(buf))
- goto SHOW;
- G_strip(buf);
- switch (*buf) {
- case 0:
- break;
- case 'y':
- case 'Y':
- ok = 1;
- break;
- case 'n':
- case 'N':
- ok = 0;
- break;
- default:
- goto ASK;
- if (ok)
- return 0;
- char buf[100];
- fprintf(stderr, "hit RETURN -->");
- if (!fgets(buf, 100, stdin))
- G_strip(buf);
- if (!strncmp(buf, "exit", sizeof(buf)))
- return 0;
Deleted: grass/trunk/lib/edit/edit_hist.c
--- grass/trunk/lib/edit/edit_hist.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/edit/edit_hist.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,145 +0,0 @@
- * for details.
- * E_edit_history (hist)
- * struct History *hist
- * Interactively prompts the user for history information.
- * Uses screen oriented prompting through the visual_ask library.
- * Programs using this must be compiled with the GRASS library $(VASKLIB)
- * and include $(CURSES) in the compile line
- * Returns: 1 ok
- * -1 user canceled edit
-int E_edit_history(struct History *phist)
- int len;
- int i;
- if (!*phist->mapid)
- sprintf(phist->mapid, "%s : %s", G_date(), "filename");
- if (!*phist->title)
- sprintf(phist->title, "%s", "filename");
- if (!*phist->mapset)
- sprintf(phist->mapset, "%s", G_mapset());
- if (!*phist->creator)
- sprintf(phist->creator, "%s", G_whoami());
- if (!*phist->maptype)
- sprintf(phist->maptype, "raster");
- V_clear();
- V_line(0, " ENTER/CORRECT FILE HISTORY INFORMATION");
- V_line(2, "Map ID ...");
- V_line(4, "Title ....");
- V_line(6, "Project ..");
- V_line(8, "Creator ..");
- V_line(10, "Maptype ..");
- V_line(12, "Data source");
- V_line(16, "Data Description");
- V_line(19, "For history comments see next page");
- len = RECORD_LEN - 1;
- if (len > 65)
- len = 65;
- phist->mapid[len] = 0;
- phist->title[len] = 0;
- phist->mapset[len] = 0;
- phist->creator[len] = 0;
- phist->maptype[len] = 0;
- len--;
- V_const(phist->mapid, 's', 2, 11, len);
- V_ques(phist->title, 's', 4, 11, len);
- V_const(phist->mapset, 's', 6, 11, len);
- V_const(phist->creator, 's', 8, 11, len);
- V_ques(phist->maptype, 's', 10, 11, len);
- phist->datsrc_1[len] = 0;
- phist->datsrc_2[len] = 0;
- phist->keywrd[len] = 0;
- len--;
- V_ques(phist->datsrc_1, 's', 13, 0, len);
- V_ques(phist->datsrc_2, 's', 14, 0, len);
- V_ques(phist->keywrd, 's', 17, 0, len);
- V_intrpt_ok();
- if (!V_call())
- return -1;
- G_strip(phist->title);
- G_strip(phist->maptype);
- G_strip(phist->datsrc_1);
- G_strip(phist->datsrc_2);
- G_strip(phist->keywrd);
- V_clear();
- V_line(0, " ENTER/CORRECT FILE HISTORY COMMENTS");
- V_ques(phist->edhist[0], 's', 2, 0, len);
- V_ques(phist->edhist[1], 's', 3, 0, len);
- V_ques(phist->edhist[2], 's', 4, 0, len);
- V_ques(phist->edhist[3], 's', 5, 0, len);
- V_ques(phist->edhist[4], 's', 6, 0, len);
- V_ques(phist->edhist[5], 's', 7, 0, len);
- V_ques(phist->edhist[6], 's', 8, 0, len);
- V_ques(phist->edhist[7], 's', 9, 0, len);
- V_ques(phist->edhist[8], 's', 10, 0, len);
- V_ques(phist->edhist[9], 's', 11, 0, len);
- V_ques(phist->edhist[10], 's', 12, 0, len);
- V_ques(phist->edhist[11], 's', 13, 0, len);
- V_ques(phist->edhist[12], 's', 14, 0, len);
- V_ques(phist->edhist[13], 's', 15, 0, len);
- V_ques(phist->edhist[14], 's', 16, 0, len);
- V_ques(phist->edhist[15], 's', 17, 0, len);
- V_ques(phist->edhist[16], 's', 18, 0, len);
- V_ques(phist->edhist[17], 's', 19, 0, len);
- V_ques(phist->edhist[18], 's', 20, 0, len);
- V_ques(phist->edhist[19], 's', 21, 0, 65);
- len++;
- for (i = 0; i <= 19; i++)
- phist->edhist[i][len] = 0;
- V_intrpt_ok();
- if (!V_call())
- return -1;
- G_strip(phist->edhist[i]);
- for (phist->edlinecnt = 19; phist->edlinecnt > 0; phist->edlinecnt--) {
- if (*phist->edhist[phist->edlinecnt] != 0)
- break;
- phist->edlinecnt++;
- V_clear();
- return (1);
Deleted: grass/trunk/lib/gis/ask.c
--- grass/trunk/lib/gis/ask.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/gis/ask.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,618 +0,0 @@
-* These routines prompt the user for names of GIS data files
-* G_ask_new (prompt, name, element, desc)
-* G_ask_old (prompt, name, element, desc)
-* G_ask_any (prompt, name, element, desc, warn)
-* G_ask_in_mapset (prompt, name, element, desc)
-* G_ask_new_file (prompt, name, element, desc)
-* G_ask_old_file (prompt, name, element, desc)
-* G_ask_new_ext (prompt, name, element, desc, option, lister)
-* G_ask_old_ext (prompt, name, element, desc, option, lister)
-* G_ask_any_ext (prompt, name, element, desc, warn, option, lister)
-* G_ask_in_mapset_ext (prompt, name, element, desc, option, lister)
-* char *prompt prompt to be printed. can be "" in which
-* case an appropriate prompt will be printed.
-* char *name buffer to hold the name input by the user
-* char *element GIS data element - "cell", "vect", etc.
-* char *desc a description of element. Used for prompting
-* and listing. Will be set to element if given as ""
-* (eg, if element is "vect", set desc = "vector")
-* char *option list option. a description of the option.
-* (eg, "with utms" will prompt as follows:
-* list -f for a list with utms)
-* int (*lister)() subroutine to return text for -f option.
-* G_ask_new() requires the user to enter the name of a file
-* which does not exist in the current mapset
-* (but which may exist in other mapsets).
-* G_ask_old() requires the user to enter the name of a file
-* which already exists.
-* G_ask_in_mapset() requires the user to enter the name of a file
-* which exists in the current mapset
-* G_ask_any() accepts any legal filename. Optionally warns user
-* if the file exists in the current mapset.
-* G_ask_new_file() requires the user to enter the name of a new file.
-* G_ask_old_file() requires the user to enter the name of any existing file.
-* returns:
-* char * mapset where file was found, or
-* mapset where file is to be created
-* NULL user hit RETURN to cancel the request
-* note:
-* These routines have a 'list' function built in. If a list -f
-* option is also desired, create a lister() routine, and
-* use G_ask_xxx_ext(). The lister() routine will be called as
-* follows:
-* lister (name, mapset, buf)
-* char *name name of file
-* char *mapset mapset to where file lives
-* char *buf buffer to hold description.
-* lister() should copy into buf.
-* buf will be large (about 400 bytes)
-* but only first 60 chars will be displayed
-* for each mapset, lister() will be called once with
-* name set to the empty string "" in order to get an title for the
-* list. Set buf to null to suppress title, otherwise copy title
-* into buf. The title will start above the text for the files.
-* then for each file in each mapset, lister() will be called
-* to obtain infomation about the file.
-* also:
-* G_set_ask_return_msg (msg) char *msg;
-* can be used to change the hit RETURN to cancel request message
-* displayed during the ask prompting.
-* G_get_ask_return_msg() will return the msg.
-#include <unistd.h>
- * OLD references any mapset
- * NEW, ANY, PRJ are for the current mapset only
- * OLD means must exist in some mapset
- * NEW means must not exist in current mapset
- * ANY means just get a name. If file exists, (optionally) warn user.
- * PRJ means must exist in current mapset
-#define OLD 0
-#define NEW 1
-#define PRJ 2
-#define ANY 3
-#define ANY_NW 4
-#define OLD_FILE 5
-#define NEW_FILE 6
-static char *ask_return_msg = 0;
-static char clear_return_msg = 0;
-static int (*no_lister) () = 0;
-static int parselist(const char *, int, char *);
-static char *ask(const char *, char *, char *, char *, char *, int (*)(),
- int);
- * \brief prompt for new database file
- * The user is asked to enter the name of
- * a new file which does not exist in the current mapset.
- * <b>Note.</b> The file chosen by the user may exist in other mapsets. This
- * routine does not look in other mapsets, since the assumption is that
- * <b>name</b> will be used to create a new file. New files are always created
- * in the current mapset.
- * \param prompt
- * \param name
- * \param element
- * \param desc
- * \return char *
-char *G_ask_new(const char *prompt, char *name, char *element, char *desc)
- return ask(prompt, name, element, desc, (char *)NULL, no_lister, NEW);
-char *G_ask_new_ext(const char *prompt, char *name, char *element, char *desc,
- char *option, int (*lister) ())
- return ask(prompt, name, element, desc, option, lister, NEW);
- * \brief prompt for existing database file
- * name of an existing database file.
- * <b>Note.</b> This routine looks for the file in the current mapset as well
- * as other mapsets. The mapsets that are searched are determined from the user's
- * mapset search path. See Mapset_Search_Path for some more details
- * about the search path.
- * \param prompt
- * \param name
- * \param element
- * \param label
- * \return char *
-char *G_ask_old(const char *prompt, char *name, char *element, char *desc)
- return ask(prompt, name, element, desc, (char *)NULL, no_lister, OLD);
-char *G_ask_old_ext(const char *prompt, char *name, char *element, char *desc,
- return ask(prompt, name, element, desc, option, lister, OLD);
- * \brief prompt for any valid file name
- * any leg al file name. If <b>warn</b> is 1 and the file chosen exists in the
- * current mapset, then the user is asked if it is ok to overwrite the file. If
- * <b>warn</b> is 0, then any leg al name is accepted and no warning is issued
- * to the user if the file exists.
- * \param prompt
- * \param name
- * \param element
- * \param label
- * \param warn
- * \return char *
-char *G_ask_any(const char *prompt, char *name, char *element, char *desc,
- int warn)
- warn ? ANY : ANY_NW);
-char *G_ask_any_ext(const char *prompt, char *name, char *element, char *desc,
- int warn, char *option, int (*lister) ())
- * name of an file which exists in the current mapset.
- * <b>Note.</b> The file chosen by the user may or may not exist in other
- * mapsets. This routine does not look in other mapsets, since the assumption is
- * that <b>name</b> will be used to modify a file. GRASS only permits users to
- * modify files in the current mapset.
- * \param prompt
- * \param name
- * \param element
- * \param label
- * \return char *
-char *G_ask_in_mapset(const char *prompt, char *name, char *element,
- char *desc)
- return ask(prompt, name, element, desc, (char *)NULL, no_lister, PRJ);
-char *G_ask_in_mapset_ext(const char *prompt, char *name, char *element,
- char *desc, char *option, int (*lister) ())
- return ask(prompt, name, element, desc, option, lister, PRJ);
- * \brief prompt for new file
- * The user is asked to enter the name of an file which doesn't exist.
- * \param prompt
- * \param name
- * \param element
- * \param label
- * \return char *
-char *G_ask_new_file(const char *prompt, char *name, char *element,
- char *desc)
- /* element is a dummy parameter for this function */
- NEW_FILE);
-/* do we need this function?
- char *
- G_ask_new_file_ext (prompt, name, element, desc, option, lister)
- char *prompt;
- char *name;
- char *element;
- char *desc;
- char *option;
- int (*lister)();
- return ask (prompt, name, element, desc, option, lister, NEW_FILE);
- * \brief prompt for existing file
- * The user is asked to enter the name of an file which exists.
- * \param prompt
- * \param name
- * \param element
- * \param label
- * \return char *
-char *G_ask_old_file(const char *prompt, char *name, char *element,
- char *desc)
- OLD_FILE);
- char *
- G_ask_old_file_ext (prompt, name, element, desc, option, lister)
- char *prompt;
- char *name;
- char *element;
- char *desc;
- char *option;
- int (*lister)();
- return ask (prompt, name, element, desc, option, lister, OLD_FILE);
- * \brief set Hit RETURN msg
- * The "Hit
- * RETURN to cancel request" part of the prompt in the prompting routines
- * described above, is modified to "Hit RETURN <b>msg.</b>"
- * \param msg
- * \return int
-int G_set_ask_return_msg(const char *msg)
- if (ask_return_msg)
- G_free(ask_return_msg);
- ask_return_msg = G_store(msg);
- clear_return_msg = 0;
- return 0;
- * \brief get Hit RETURN msg
- * The current
- * <i>msg</i> (as set by <i>G_set_ask_return_msg</i>) is returned.
- * \param void
- * \return char *
-char *G_get_ask_return_msg()
- static char none[80];
- strcpy(none, _("to cancel request"));
- return (ask_return_msg == NULL ? none : ask_return_msg);
-static char *ask(const char *prompt,
- char *name,
- char *element,
- char *desc, char *option, int (*lister) (), int type)
- char tmapset[GMAPSET_MAX];
- char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
- int name_is_qualified;
- int ok;
- char tprompt[256];
- char input[256];
- char *mapset;
- char *cur_mapset;
- G__check_gisinit();
- fflush(stdout);
- /* RETURN msg */
- if (clear_return_msg) {
- ask_return_msg = 0;
- clear_return_msg = ask_return_msg ? 1 : 0;
- /* make sure option is valid */
- if (lister && (option == 0 || *option == 0))
- lister = 0;
- /* set name to NO NAME at outset */
- *name = 0;
- * if element description not given, make it the same as the
- * element name
- if (desc == 0 || *desc == 0)
- desc = element;
- * if no prompt is given, build an approriate prompt
- if (prompt == 0 || *prompt == 0) {
- switch (type) {
- case NEW:
- case NEW_FILE:
- sprintf(tprompt, _("Enter a new %s file name"), desc);
- prompt = tprompt;
- break;
- case OLD:
- case PRJ:
- case OLD_FILE:
- sprintf(tprompt, _("Enter the name of an existing %s file"),
- desc);
- prompt = tprompt;
- break;
- default:
- sprintf(tprompt, _("Enter %s file name"), desc);
- prompt = tprompt;
- break;
- * get the current mapset name
- cur_mapset = G_mapset();
- while (1) {
- * print the prompt and input the request
- do {
- fprintf(stderr, "\n%s\n", prompt);
- /* no listing function implemented for old_file and new_file */
- if (type != OLD_FILE && type != NEW_FILE)
- fprintf(stderr,
- _("Enter 'list' for a list of existing %s files\n"),
- desc);
- if (lister) {
- fprintf(stderr, _("Enter 'list -f' for "));
- if (option && *option)
- fprintf(stderr, _("a list %s"), option);
- else
- fprintf(stderr, _("an extended list"));
- fprintf(stderr, _("Hit RETURN %s\n"), G_get_ask_return_msg());
- fprintf(stderr, "> ");
- while (!G_gets(input));
- G_strip(input);
- fprintf(stderr, "<%s>\n", input);
- * if the user just hit return (or blanks only)
- * return NULL
- if (*input == 0)
- return 0;
- if (type == OLD_FILE || type == NEW_FILE) {
- int exist;
- exist = (access(input, 0) == 0);
- if (type == OLD_FILE && !exist) {
- fprintf(stderr, _("\n** %s - not found **\n"), input);
- continue;
- if (type == NEW_FILE && exist) {
- char question[200];
- sprintf(question,
- _("\n** %s exists. ok to overwrite? "), input);
- if (!G_yes(question, 0))
- continue;
- strcpy(name, input);
- return G_store(input);
- * 'list' does a list without extension. if we are looking for a new
- * file only list the current mapset. Otherwise list all mapsets
- * in the mapset search list
- * 0 not a list request
- * 1 list
- * 2 list -f
- * 3 list mapset
- * 4 list -f mapset
- switch (parselist(input, lister ? 1 : 0, tmapset)) {
- case 0:
- break;
- case 1:
- G_list_element(element, desc, type == OLD ? "" : cur_mapset,
- no_lister);
- continue;
- case 2:
- lister);
- continue;
- case 3:
- G_list_element(element, desc, tmapset, no_lister);
- continue;
- case 4:
- G_list_element(element, desc, tmapset, lister);
- continue;
- default:
- fprintf(stderr, "** illegal request **\n");
- continue;
- if ((name_is_qualified =
- G__name_is_fully_qualified(input, xname, xmapset)))
- ok = G_legal_filename(xname) >= 0;
- else
- ok = G_legal_filename(input) >= 0;
- if (!ok) {
- fprintf(stderr, _("\n**<%s> illegal name **\n"), input);
- continue;
- * now look for the file.
- * new files must be simple names
- * and must not exist in the current mapset
- if (type != OLD) {
- if (name_is_qualified) {
- if (strcmp(cur_mapset, xmapset) != 0) {
- fprintf(stderr, _("\n** %s - illegal request **\n"),
- input);
- continue;
- strcpy(input, xname);
- mapset = G_find_file(element, input, cur_mapset);
- switch (type) {
- case NEW:
- if (!mapset) {
- return cur_mapset;
- fprintf(stderr,
- _("\n** %s - exists, select another name **\n"),
- input);
- break;
- case ANY:
- case ANY_NW:
- if (mapset && type == ANY) {
- sprintf(question,
- break;
- case PRJ:
- if (mapset) {
- break;
- default:
- G_fatal_error(_("ask: can't happen"));
- * old names can be simple or qualified
- * and must exist
- else {
- mapset = G_find_file(element, input, "");
- if (mapset) {
- strcpy(name, xname);
- else
- return mapset;
- return NULL;
-static int parselist(const char *input, int option, char *mapset)
- char list[GNAME_MAX];
- char f1[GMAPSET_MAX];
- char f2[GMAPSET_MAX];
- char f3[GMAPSET_MAX];
- int count;
- *list = *f1 = *f2 = 0;
- count = sscanf(input, "%s%s%s%s", list, f1, f2, f3);
- if (count < 1)
- return 0;
- if (strcmp(list, "list") != 0)
- return 0;
- if (count == 1)
- return 1; /* list */
- if (count > 3)
- return -1; /* illegal */
- if (*f1 == '-') { /* list -f */
- if (!option)
- return -1;
- if (f1[1] == 0 || f1[1] != 'f' || f1[2] != 0)
- return -1;
- if (count == 2)
- return 2;
- strcpy(mapset, f2);
- return 4;
- if (count != 2)
- return -1;
- strcpy(mapset, f1);
- return 3;
Deleted: grass/trunk/lib/gis/ask_cell.c
--- grass/trunk/lib/gis/ask_cell.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/gis/ask_cell.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,114 +0,0 @@
- * char *
- * G_ask_cell_new(prompt, name))
- * asks user to input name of a new cell file
- * char *
- * G_ask_cell_old(prompt, name)
- * asks user to input name of an existing cell file
- * char *
- * G_ask_cell_in_mapset(prompt, name)
- * asks user to input name of an existing cell file in current mapset
- * char *
- * G_ask_cell_any(prompt, name)
- * asks user to input name of a new or existing cell file in
- * the current mapset. Warns user about (possible) overwrite
- * if cell file already exists
- * parms:
- * const char *prompt optional prompt for user
- * char *name buffer to hold name of map found
- * returns:
- * char *pointer to a string with name of mapset
- * where file was found, or NULL if not found
- * note:
- * rejects all names that begin with .
-static int lister(char *, char *, char *);
- * \brief prompt for new raster map
- * Asks the user to enter a name for a raster map which does not
- * exist in the current mapset.
- * \param prompt
- * \param name
- * \return char *
-char *G_ask_cell_new(const char *prompt, char *name)
- return G_ask_new_ext(prompt, name, "cell", "raster", _("with titles"),
- lister);
- * \brief prompt for existing raster map
- * Asks the user to enter the name of an existing raster
- * file in any mapset in the database.
- * \param prompt
- * \param name
- * \return char *
-char *G_ask_cell_old(const char *prompt, char *name)
- return G_ask_old_ext(prompt, name, "cell", "raster", _("with titles"),
- lister);
- * file in the current mapset.
- * \param prompt
- * \param name
- * \return char *
-char *G_ask_cell_in_mapset(const char *prompt, char *name)
- return G_ask_in_mapset_ext(prompt, name, "cell", "raster",
- _("with titles"), lister);
-char *G_ask_cell_any(const char *prompt, char *name)
- return G_ask_any_ext(prompt, name, "cell", "raster", 1, _("with titles"),
- lister);
-static int lister(char *name, char *mapset, char *buf)
- char *title;
- *buf = 0;
- if (*name == 0)
- return 0;
- strcpy(buf, title = G_get_cell_title(name, mapset));
- if (*buf == 0)
- strcpy(buf, _("(no title)"));
- G_free(title);
- return 0;
Deleted: grass/trunk/lib/gis/ask_vctrs.c
--- grass/trunk/lib/gis/ask_vctrs.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/gis/ask_vctrs.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,86 +0,0 @@
- * prompt for vector maps (digit)
- * char *
- * G_ask_vector_new(prompt, name))
- * asks user to input name of a new vector map
- * char *
- * G_ask_vector_old(prompt, name)
- * asks user to input name of an existing vector map
- * char *
- * G_ask_vector_any(prompt, name)
- * asks user to input any vector name
- * char *
- * G_ask_vector_in_mapset(prompt, name)
- * in current mapset
- * parms:
- * returns:
- * \brief prompt for a new vector map
- * Asks the user to enter a name for a vector map which does not
- * \param prompt
- * \param name
- * \return char *
-char *G_ask_vector_new(const char *prompt, char *name)
- return G_ask_new(prompt, name, "vector", "vector");
- * \brief prompt for an existing vector map
- * Asks the user to enter the name of an existing vector
- * \param prompt
- * \param name
- * \return char *
-char *G_ask_vector_old(const char *prompt, char *name)
- return G_ask_old(prompt, name, "vector", "vector");
-char *G_ask_vector_any(const char *prompt, char *name)
- return G_ask_any(prompt, name, "vector", "vector", 1);
- * \param prompt
- * \param name
- * \return char *
-char *G_ask_vector_in_mapset(const char *prompt, char *name)
- return G_ask_in_mapset(prompt, name, "vector", "vector");
Deleted: grass/trunk/lib/gis/get_datum_name.c
--- grass/trunk/lib/gis/get_datum_name.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/gis/get_datum_name.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,123 +0,0 @@
- * MODULE: GRASS 5.0 gis library, get_datum_name.c
- * AUTHOR(S): unknown, updated by Andreas Lange, andreas.lange at rhein-main.de
- * PURPOSE: Get datum name for new location database
- * COPYRIGHT: (C) 2000 by the GRASS Development Team
- * for details.
- * G_ask_datum_name(char *datumname, char *ellpsname)
- * ask interactively for a valid datum name
- * returns <0 on error
- * returns 1 on success
- * \brief ask for a valid datum name
- * This function asks the user interactively for a valid datum name from the datum
- * table. The datum name is stored in the character array pointed to by
- * <b>datum</b>. The function returns 1 on sucess, -1 if no datum was entered
- * on command line and 0 on internal error.
- * \param datum
- * \return int
-int G_ask_datum_name(char *datumname, char *ellpsname)
- char buff[1024], answer[100], ellipse[100];
- char *dat, *Tmp_file;
- FILE *Tmp_fd = NULL;
- int i;
- for (;;) {
- do {
- fprintf(stderr, _("\nPlease specify datum name\n"));
- fprintf(stderr,
- _("Enter 'list' for the list of available datums\n"));
- fprintf(stderr,
- _
- ("or 'custom' if you wish to enter custom parameters\n"));
- fprintf(stderr, _("Hit RETURN to cancel request\n"));
- fprintf(stderr, ">");
- } while (!G_gets(answer));
- G_strip(answer);
- if (strlen(answer) == 0)
- return -1;
- if (strcmp(answer, "list") == 0) {
- Tmp_file = G_tempfile();
- if (NULL == (Tmp_fd = fopen(Tmp_file, "w")))
- G_warning(_("Cannot open temp file"));
- else {
- char *pager;
- fprintf(Tmp_fd, "Short Name\tLong Name / Description\n---\n");
- for (i = 0; (dat = G_datum_name(i)); i++) {
- fprintf(Tmp_fd, "%s\t%s\n\t\t\t(%s ellipsoid)\n---\n",
- dat, G_datum_description(i),
- G_datum_ellipsoid(i));
- fclose(Tmp_fd);
- pager = getenv("GRASS_PAGER");
- if (!pager || strlen(pager) == 0)
- pager = "cat";
- sprintf(buff, "%s \"%s\" 1>&2", pager,
- G_convert_dirseps_to_host(Tmp_file));
- G_system(buff);
- remove(Tmp_file);
- G_free(Tmp_file);
- else {
- if (G_strcasecmp(answer, "custom") == 0)
- break;
- if (G_get_datum_by_name(answer) < 0) {
- fprintf(stderr, _("\ninvalid datum\n"));
- else
- break;
- if (G_strcasecmp(answer, "custom") == 0) {
- /* For a custom datum we need to interactively ask for the ellipsoid */
- if (G_ask_ellipse_name(ellipse) < 0)
- return -1;
- sprintf(ellpsname, ellipse);
- sprintf(datumname, "custom");
- else {
- /* else can look it up from datum.table */
- if ((i = G_get_datum_by_name(answer)) < 0)
- return -1;
- sprintf(ellpsname, G_datum_ellipsoid(i));
- sprintf(datumname, G_datum_name(i));
- return 1;
Deleted: grass/trunk/lib/gis/get_ell_name.c
--- grass/trunk/lib/gis/get_ell_name.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/gis/get_ell_name.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,79 +0,0 @@
- * MODULE: GRASS 5 gis library, get_ell_name.c
- * PURPOSE: Get ellipse name from user
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
-#include <string.h>
-#include <stdlib.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-int G_ask_ellipse_name(char *spheroid)
- char buff[1024], answer[50];
- double aa, e2;
- char *sph, *Tmp_file;
- int i;
- if (NULL == (Tmp_fd = fopen(Tmp_file, "w"))) {
- G_fatal_error(_("Cannot open temp file"));
- fprintf(Tmp_fd, "sphere\n");
- for (i = 0; (sph = G_ellipsoid_name(i)); i++) {
- fprintf(Tmp_fd, "%s\n", sph);
- fclose(Tmp_fd);
- for (;;) {
- do {
- fprintf(stderr, _("\nPlease specify ellipsoid name\n"));
- fprintf(stderr,
- _("Enter 'list' for the list of available ellipsoids\n"));
- G_strip(answer);
- return -1;
- char *pager;
- pager = "cat";
- /* Always print interactive output to stderr */
- G_system(buff);
- else {
- if (strcmp(answer, "sphere") == 0)
- break;
- if (G_get_ellipsoid_by_name(answer, &aa, &e2) == 0) {
- fprintf(stderr, _("\ninvalid ellipsoid\n"));
- else
- break;
- sprintf(spheroid, "%s", answer);
- remove(Tmp_file);
- if (strcmp(spheroid, "sphere") == 0) {
- return 2;
- return 1;
Deleted: grass/trunk/lib/gis/get_projname.c
--- grass/trunk/lib/gis/get_projname.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/gis/get_projname.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,86 +0,0 @@
- * MODULE: GRASS 5 gis library, get_projname.c
- * PURPOSE: Get projection name from user
- * for details.
-int G_ask_proj_name(char *proj_id, char *proj_name)
- char path[GPATH_MAX], buff[GPATH_MAX], answer[50], *a;
- struct Key_Value *in_proj_keys;
- char *Tmp_file;
- int in_stat, i, npr;
- sprintf(path, "%s/etc/projections", G_gisbase());
- while (access(path, 0) != 0)
- G_fatal_error(_("%s not found"), path);
- in_proj_keys = G_read_key_value_file(path, &in_stat);
- if (in_stat != 0)
- G_fatal_error(_("ERROR in reading %s"), path);
- npr = in_proj_keys->nitems;
- for (i = 0; i < npr; i++) {
- fprintf(Tmp_fd, "%s -- %s\n", in_proj_keys->key[i],
- in_proj_keys->value[i]);
- fclose(Tmp_fd);
- for (;;) {
- do {
- fprintf(stderr, _("\n\nPlease specify projection name\n"));
- fprintf(stderr,
- _
- ("Enter 'list' for the list of available projections\n"));
- G_strip(answer);
- return -1;
- char *pager;
- pager = "cat";
- G_system(buff);
- else {
- a = G_find_key_value(answer, in_proj_keys);
- if (a == NULL) {
- fprintf(stderr, _("\ninvalid projection\n"));
- else
- break;
- sprintf(proj_id, "%s", answer);
- sprintf(proj_name, "%s", a);
- remove(Tmp_file);
- return 1;
Deleted: grass/trunk/lib/gis/gets.c
--- grass/trunk/lib/gis/gets.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/gis/gets.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,99 +0,0 @@
-#include <stdio.h>
- * G_gets (buf)
- * char *buf buffer to receive data
- * does a gets() from stdin. exits upon EOF.
- * if stdin is a tty (ie, not a pipe or redirected)
- * then ctrl-z is detected
- * returns
- * 1 read ok
- * 0 ctrl-z entered. calling routine should re-print a prompt
- * and call G_gets() again
- * note: This is very useful for allowing a program to
- * reprompt after the program is restarted after
- * being stopped with a ctrl-Z.
- * sample use:
- * do {
- * fprintf (stderr, "Enter some input: ") ;
- * } while ( ! G_gets(buff) ) ;
- * If the user suspends the process at this prompt G_gets will return
- * "0" causing the reprompting.
-static int ctrlz = 0;
-static void catch_ctrlz(int);
-static void catch_int(int);
-int G_gets(char *buf)
-#ifdef SIGTSTP
- RETSIGTYPE(*sigtstp) ();
- int tty;
-#endif
- char p[128];
- char *eof;
- ctrlz = 0;
-#ifdef SIGTSTP
- if ((tty = isatty(0))) {
- sigtstp = signal(SIGTSTP, catch_ctrlz);
- if (sigtstp != (RETSIGTYPE(*)())SIG_DFL)
- signal(SIGTSTP, sigtstp);
-#endif
- eof = fgets(p, 100, stdin);
- /* strip the EOL character */
- if (strlen(p) > 1 && p[strlen(p) - 1] == '\n' && p[strlen(p) - 2] == '\r')
- p[strlen(p) - 2] = '\0'; /* Handles DOS/Windows "\r\n" */
- else
- p[strlen(p) - 1] = '\0'; /* Handles Unix "\n" or old Mac "\r" */
- /* buf could be any length. Any overflow will occur here. */
- strcpy(buf, p);
-#ifdef SIGTSTP
- if (tty)
-#endif
- if (eof)
- return 1;
- if (ctrlz)
- return 0;
- exit(EXIT_SUCCESS);
-static void catch_ctrlz(int n)
-#ifdef __MINGW32__
- G_warning("catch_ctrlz: ignored Ctrl-z");
-#else
- RETSIGTYPE(*sigint) ();
- /* having caught ctrlz - effect a ctrl-z using kill */
- ctrlz = 1;
- signal(n, SIG_DFL);
- kill(0, n);
- /* for berkley systems, ctrlz will not cause eof on read */
- sigint = signal(SIGINT, catch_int);
- kill(getpid(), SIGINT);
- signal(SIGINT, sigint);
-#endif
-static void catch_int(int n)
Deleted: grass/trunk/lib/gis/intr_char.c
--- grass/trunk/lib/gis/intr_char.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/gis/intr_char.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,48 +0,0 @@
-#include <grass/config.h>
-#ifndef __MINGW32__
-#if defined(HAVE_TERMIOS_H)
-# include <termios.h>
-# define TYPE termios
-# define C c_cc[VINTR]
-#elif defined(HAVE_TERMIO_H)
-# include <termio.h>
-# define GET TCGETA
-#else
-# include <sgtty.h>
-# define TYPE tchars
-# define C t_intrc
-# define GET TIOCGETC
-#endif
-#endif
- * \brief return interrupt char
- * This routine returns the
- * user's keyboard interrupt character. This is the character that generates the
- * SIGINT signal from the keyboard.
- * \param ~
- * \return char
-char G_intr_char(void)
- char c = 0;
- struct TYPE buf;
-#ifdef HAVE_TERMIOS_H
- tcgetattr(2, &buf);
-#else
- ioctl(2, GET, &buf);
-#endif
- c = buf.C;
-#endif
- return c;
Deleted: grass/trunk/lib/gis/make_colr.c
--- grass/trunk/lib/gis/make_colr.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/gis/make_colr.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,95 +0,0 @@
- * G_make_color (name, mapset, colors)
- * char *name name of map
- * char *mapset mapset containing name
- * struct Colors *colors struct to hold colors
- * Interactively prompts user for deciding which type of color
- * lookup table is desired.
- * Red, green, and blue color ramps
- * Gray scale
- * Rainbow colors
- * Random colors
- * Color wave
- * Aspect colors
- * Red through yellow to green
- * Returns -1 user canceled the request
- * 1 color table is ok
-int G_ask_colors(const char *name, const char *mapset, struct Colors *pcolr)
- char buff[128];
- int answ;
- struct FPRange range;
- DCELL min, max;
- G_init_colors(pcolr);
- /* determine range cell values */
- if (G_read_fp_range(name, mapset, &range) < 0)
- return -1;
- G_get_fp_range_min_max(&range, &min, &max);
- if (G_is_d_null_value(&min) || G_is_d_null_value(&max)) {
- sprintf(buff, _(" The raster map %s@%s is empty"), name, mapset);
- G_warning(buff);
- return -1;
- /* Prompting */
- ASK:
- G_clear_screen();
- fprintf(stderr,
- _("\n\nColor table needed for file [%s] in mapset [%s].\n"), name,
- mapset);
- fprintf(stderr, _("\nPlease identify the type desired:\n"));
- fprintf(stderr, _(" 1: Random colors\n"));
- fprintf(stderr, _(" 2: Red, green, and blue color ramps\n"));
- fprintf(stderr, _(" 3: Color wave\n"));
- fprintf(stderr, _(" 4: Gray scale\n"));
- fprintf(stderr, _(" 5: Aspect\n"));
- fprintf(stderr, _(" 6: Rainbow colors\n"));
- fprintf(stderr, _(" 7: Red through yellow to green\n"));
- fprintf(stderr, _(" 8: Green through yellow to red\n"));
- fprintf(stderr, _("RETURN quit\n"));
- fprintf(stderr, "\n> ");
- for (;;) {
- if (!G_gets(buff))
- goto ASK;
- G_strip(buff);
- if (*buff == 0)
- return -1;
- if (sscanf(buff, "%d", &answ) != 1)
- answ = -1;
- switch (answ) {
- case 1:
- return G_make_random_colors(pcolr, (CELL) min, (CELL) max);
- case 2:
- return G_make_ramp_fp_colors(pcolr, min, max);
- case 3:
- return G_make_wave_fp_colors(pcolr, min, max);
- case 4:
- return G_make_grey_scale_fp_colors(pcolr, min, max);
- case 5:
- return G_make_aspect_fp_colors(pcolr, min, max);
- case 6:
- return G_make_rainbow_fp_colors(pcolr, min, max);
- case 7:
- return G_make_ryg_fp_colors(pcolr, min, max);
- case 8:
- return G_make_gyr_fp_colors(pcolr, min, max);
- default:
- fprintf(stderr, _("\n%s invalid; Try again > "), buff);
- break;
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/gis/parser.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -130,10 +130,6 @@
static int split_opts(void);
static int check_multiple_opts(void);
static int check_overwrite(void);
-static int interactive(const char *);
-static int interactive_flag(struct Flag *);
-static int interactive_option(struct Option *);
-static int gis_prompt(struct Option *, char *);
static int split_gisprompt(const char *, char *, char *, char *);
static void G_gui(void);
@@ -807,15 +803,8 @@
/* If there are NO arguments, go interactive */
if (argc < 2 && interactive_ok && isatty(0)) {
- if (getenv("GRASS_UI_TERM")) {
- interactive(argv[0]);
- opt_checked = 1;
- /* all options have been already checked interactively */
- else {
- G_gui();
- return -1;
+ G_gui();
+ return -1;
else if (argc < 2 && isatty(0)) {
G_usage();
@@ -2564,134 +2553,6 @@
return (error);
-static int interactive(const char *command)
- struct Item *item;
- /* Query for flags */
- if (!n_items) {
- fprintf(stderr, "PROGRAMMER ERROR: no flags or options\n");
- exit(EXIT_FAILURE);
- for (item = &first_item;;) {
- if (item->flag)
- interactive_flag(item->flag);
- else if (item->option)
- interactive_option(item->option);
- else
- break;
- item = item->next_item;
- if (item == NULL)
- break;
- return 0;
-static int interactive_flag(struct Flag *flag)
- char buff[1024];
- fprintf(stderr, _("\nFLAG: Set the following flag?\n"));
- sprintf(buff, " %s?", flag->description);
- flag->answer = G_yes(buff, 0);
- return 0;
-static int interactive_option(struct Option *opt)
- char buff[1024], *bptr;
- char buff2[1024];
- int set_one;
- int no_prompt;
- fprintf(stderr, _("\nOPTION: %s\n"), opt->description);
- fprintf(stderr, _(" key: %s\n"), opt->key);
- if (opt->key_desc)
- fprintf(stderr, _(" format: %s\n"), opt->key_desc);
- if (opt->def)
- fprintf(stderr, _(" default: %s\n"), opt->def);
- fprintf(stderr, _("required: %s\n"), opt->required ? "YES" : "NO");
- if (opt->multiple)
- fprintf(stderr, _("multiple: %s\n"), opt->multiple ? "YES" : "NO");
- if (opt->options)
- fprintf(stderr, _(" options: %s\n"), opt->options);
- show_options(0, opt->options) ;
- set_one = 0;
- for (;;) {
- *buff = '\0';
- if (opt->gisprompt)
- no_prompt = gis_prompt(opt, buff);
- else
- no_prompt = -1;
- if (no_prompt) {
- fprintf(stderr, _("enter option > "));
- if (fgets(buff, 1024, stdin) == 0)
- exit(EXIT_SUCCESS);;
- bptr = buff; /* strip newline */
- while (*bptr) {
- if (*bptr == '\n')
- *bptr = '\0';
- bptr++;
- if (strlen(buff) != 0) {
- if (opt->options)
- /* then check option */
- if (check_an_opt(opt->key, opt->type, opt->options, buff)) {
- if (G_yes(_(" Try again? "), 1))
- continue;
- else
- if (opt->checker)
- if (opt->checker(buff)) {
- fprintf(stderr, _("Sorry, %s is not accepted.\n"), buff);
- *buff = '\0';
- continue;
- else
- sprintf(buff2, "%s=%s", opt->key, buff);
- if (!opt->gisprompt) {
- fprintf(stderr, _("\nYou have chosen:\n %s\n"), buff2);
- if (G_yes(_("Is this correct? "), 1)) {
- set_option(buff2);
- set_one++;
- else {
- set_one++;
- } /* if strlen(buf ) !=0 */
- if ((strlen(buff) == 0) && opt->required && (set_one == 0))
- if ((strlen(buff) == 0) && (set_one > 0) && opt->multiple)
- break;
- if ((strlen(buff) == 0) && !opt->required)
- break;
- if ((set_one == 1) && !opt->multiple)
- break;
- return (0);
static int split_gisprompt(const char *gisprompt, char *age, char *element,
char *desc)
@@ -2722,52 +2583,6 @@
return 0;
-static int gis_prompt(struct Option *opt, char *buff)
- char age[KEYLENGTH];
- char element[KEYLENGTH];
- char desc[KEYLENGTH];
- char *ptr1;
- split_gisprompt(opt->gisprompt, age, element, desc);
- /*********ptr1 points to current mapset description***********/
- if (opt->answer)
- G_set_ask_return_msg(_("to accept the default"));
- if (!strcmp("old", age)) {
- ptr1 = G_ask_old("", buff, element, desc);
- if (ptr1) {
- strcpy(buff, G_fully_qualified_name(buff, ptr1));
- else if (!strcmp("new", age))
- ptr1 = G_ask_new("", buff, element, desc);
- else if (!strcmp("mapset", age))
- ptr1 = G_ask_in_mapset("", buff, element, desc);
- else if (!strcmp("any", age))
- ptr1 = G_ask_any("", buff, element, desc, 1);
- else if (!strcmp("old_file", age)) /* file must exist */
- ptr1 = G_ask_old_file("", buff, element, desc);
- else if (!strcmp("new_file", age)) /* file shouldn't exist unless overwrite is enabled */
- ptr1 = G_ask_new_file("", buff, element, desc);
- else if (!strcmp("color", age))
- /* These prompts are only implemented in the gui */
- /* The data can still be entered in the console */
- return -1;
- else {
- fprintf(stderr,
- "\nPROGRAMMER ERROR: first item in gisprompt is <%s>\n", age);
- fprintf(stderr,
- " Must be either new, old, mapset, any, old_file, new_file, or color\n");
- return -1;
- if (ptr1 == '\0')
- *buff = '\0';
- return 0;
* \brief Creates command to run non-interactive.
Deleted: grass/trunk/lib/gis/yes.c
--- grass/trunk/lib/gis/yes.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/gis/yes.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,71 +0,0 @@
- * \file yes.c
- * \brief GIS Library - Yes/No functions.
- * (C) 2001-2008 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author GRASS GIS Development Team
- * \date 1999-2008
-#include <stdio.h>
- * \brief Ask a yes/no question.
- * This routine prints a <b>question</b> to the user, and expects the user to
- * respond either yes or no. (Invalid responses are rejected and the process is
- * repeated until the user answers yes or no.)<br>
- * The <b>default</b> indicates what the RETURN key alone should mean. A
- * <b>default</b> of 1 indicates that RETURN means yes, 0 indicates that RETURN
- * means no. The <b>question</b> will be appended with ''(y/n) '', and,
- * if <b>default</b> is not -1, with ''[y] '' or ''[n] '', depending on
- * the <b>default.</b><br>
- * \param[in] question
- * \param[in] dflt
- * \return 0 for No
- * \return 1 for Yes
-int G_yes(const char *question, int dflt)
- fflush(stdout);
- while (1) {
- char answer[100];
- fprintf(stderr, "%s", question);
- while (1) {
- fprintf(stderr, "(y/n) ");
- if (dflt >= 0)
- fprintf(stderr, dflt == 0 ? "[n] " : "[y] ");
- fflush(stderr);
- if (!G_gets(answer))
- break;
- G_strip(answer);
- switch (*answer) {
- case 'y':
- case 'Y':
- return (1);
- case 'n':
- case 'N':
- return (0);
- case 0:
- if (dflt >= 0)
- return (dflt);
Deleted: grass/trunk/lib/imagery/ask_group.c
--- grass/trunk/lib/imagery/ask_group.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/imagery/ask_group.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,67 +0,0 @@
-* I_ask_group_old (prompt,group)
-* prompt the user for an imagery group file name
-#include <grass/imagery.h>
-static int ask_group(char *, char *);
- * \brief prompt for an existing group
- * Asks the user to enter the name of an existing <b>group</b>
- * \param prompt
- * \param group
- * \return int
-int I_ask_group_old(char *prompt, char *group)
- while (1) {
- if (*prompt == 0)
- prompt = "Select an imagery group file";
- if (!ask_group(prompt, group))
- return 0;
- if (I_find_group(group))
- return 1;
- fprintf(stderr, "\n** %s - not found **\n\n", group);
-static int ask_group(char *prompt, char *group)
- char buf[1024];
- while (1) {
- fprintf(stderr,
- "Enter 'list' for a list of existing imagery groups\n");
- fprintf(stderr, "Enter 'list -f' for a verbose listing\n");
- fprintf(stderr, "Hit RETURN %s\n", G_get_ask_return_msg());
- if (!G_gets(buf))
- continue;
- G_squeeze(buf);
- fprintf(stderr, "<%s>\n", buf);
- if (*buf == 0)
- return 0;
- if (strcmp(buf, "list") == 0)
- I_list_groups(0);
- else if (strcmp(buf, "list -f") == 0)
- I_list_groups(1);
- else if (G_legal_filename(buf) < 0)
- fprintf(stderr, "\n** <%s> - illegal name **\n\n", buf);
- else
- break;
- strcpy(group, buf);
- return 1;
Modified: grass/trunk/lib/imagery/ls_groups.c
--- grass/trunk/lib/imagery/ls_groups.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/imagery/ls_groups.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -71,9 +71,6 @@
fclose(temp);
G_spawn(getenv("GRASS_PAGER"), getenv("GRASS_PAGER"), tempfile, NULL);
remove(tempfile);
- fprintf(stdout, "hit RETURN to continue -->");
- fflush(stdout);
- G_gets(buf);
return 0;
@@ -129,9 +126,6 @@
fclose(temp);
remove(tempfile);
- fflush(stdout);
- G_gets(buf);
return 0;
Modified: grass/trunk/lib/init/Makefile
--- grass/trunk/lib/init/Makefile 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/init/Makefile 2008-08-06 03:28:21 UTC (rev 32551)
@@ -23,20 +23,11 @@
START_UP=grass$(GRASS_VERSION_MAJOR)$(GRASS_VERSION_MINOR)
EXTRA_CFLAGS = -DD_LOCATION_NAME=\"$(DEFAULT_LOCATION)\" -DD_GISDBASE=\"$(DEFAULT_DATABASE)\" -DGRASS_VERSION_NUMBER=\"'$(GRASS_VERSION_NUMBER)'\" -DGRASS_VERSION_UPDATE_PKG=\"'$(GRASS_VERSION_UPDATE_PKG)'\"
-SET_DATA = $(OBJDIR)/set_data.o $(OBJDIR)/mke_mapset.o \
- $(OBJDIR)/mke_loc.o $(OBJDIR)/chk_dbase.o $(OBJDIR)/other.o
-ifdef USE_CURSES
-SET_DATA_PROG = $(ETC)/set_data$(EXE)
-else
-SET_DATA_PROG =
-endif
FILES = \
$(ARCH_BINDIR)/$(START_UP) \
$(ETC)/Init.sh \
$(ETC)/prompt.sh \
- $(SET_DATA_PROG) \
$(ETC)/clean_temp$(EXE) \
$(ETC)/lock$(EXE) \
$(ETC)/run$(EXE) \
@@ -118,9 +109,6 @@
chmod +x $@
-$(ETC)/set_data$(EXE): $(SET_DATA)
- $(CC) $(LDFLAGS) -o $@ $(SET_DATA) $(EDITLIB) $(GISLIB) $(DATETIMELIB) $(VASKLIB) $(CURSES) $(MATHLIB) $(XDRLIB)
$(ETC)/echo$(EXE): $(OBJDIR)/echo.o
$(CC) $(LDFLAGS) $(OBJDIR)/echo.o -o $@
Deleted: grass/trunk/lib/init/chk_dbase.c
--- grass/trunk/lib/init/chk_dbase.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/init/chk_dbase.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,38 +0,0 @@
-#include <stdio.h>
-#include <sys/types.h>
-#include <sys/stat.h>
-# include <pwd.h>
-#endif
-int can_make_location(char *gisdbase, char *location)
- struct stat s;
- struct passwd *pwd;
- /* make sure this is a directory */
- if (stat(gisdbase, &s) != 0) {
- fprintf(stderr, "\n** %s not found **\n", gisdbase);
- return 0;
- if (!(s.st_mode & S_IFDIR)) {
- fprintf(stderr, "\n** %s is not a directory **\n", gisdbase);
- return 0;
- /* look for write permission */
- if (access(gisdbase, 2) == 0)
- return 1;
- fprintf(stderr, "\nNote\n");
- fprintf(stderr,
- " You don't have permission under %s to create a new location\n",
- gisdbase);
- if ((pwd = getpwuid(s.st_uid)))
- fprintf(stderr, " See user %s about creating location %s\n",
- pwd->pw_name, location);
-#endif
- return 0;
Deleted: grass/trunk/lib/init/mke_loc.c
--- grass/trunk/lib/init/mke_loc.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/init/mke_loc.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,195 +0,0 @@
-#include <stdio.h>
-#include "local_proto.h"
-int make_location(const char *gisdbase, const char *location_name)
- struct Cell_head window;
- char buf[GPATH_MAX];
- int i;
- char myname[75];
- char *mapset;
- char *name, c;
- FILE *fp;
- G_clear_screen();
- fprintf(stderr,
- "To create a new LOCATION, you will need the following information:\n");
- fprintf(stderr, "1. The coordinate system for the database\n");
- /*for (i = 1; name = G__projection_name(i); i++) */
- fprintf(stderr, " %s (for imagery and other unreferenced data)\n",
- G__projection_name(PROJECTION_XY));
- fprintf(stderr, " %s\n", G__projection_name(PROJECTION_LL));
- fprintf(stderr, " %s\n", G__projection_name(PROJECTION_UTM));
- fprintf(stderr, " %s\n", G__projection_name(PROJECTION_OTHER));
- fprintf(stderr, "2. The zone for the %s database\n",
- G__projection_name(PROJECTION_UTM));
- fprintf(stderr,
- " and all the necessary parameters for projections other than\n");
- fprintf(stderr, " %s, %s, and %s\n", G__projection_name(PROJECTION_LL),
- G__projection_name(PROJECTION_XY),
- fprintf(stderr,
- "3. The coordinates of the area to become the default region\n");
- fprintf(stderr, " and the grid resolution of this region\n");
- fprintf(stderr,
- "4. A short, one-line description or title for the location\n");
- if (!G_yes("Do you have all this information? ", 1))
- return 0;
- G_zero(&window, sizeof(window));
- while (1) {
- G_clear_screen();
- fprintf(stderr,
- "Please specify the coordinate system for location <%s>\n\n",
- location_name);
- fprintf(stderr, "A %s\n", G__projection_name(PROJECTION_XY));
- fprintf(stderr, "B %s\n", G__projection_name(PROJECTION_LL));
- fprintf(stderr, "C %s\n", G__projection_name(PROJECTION_UTM));
- fprintf(stderr, "D %s\n", G__projection_name(PROJECTION_OTHER));
- fprintf(stderr, "RETURN to cancel\n");
- if (!G_gets(buf))
- continue;
- G_strip(buf);
- if (*buf == 0)
- return 0;
- if (sscanf(buf, "%c", &c) != 1)
- continue;
- switch (c) {
- case 'A':
- i = PROJECTION_XY;
- break;
- case 'a':
- break;
- case 'B':
- i = PROJECTION_LL;
- break;
- case 'b':
- break;
- case 'C':
- i = PROJECTION_UTM;
- break;
- case 'c':
- break;
- case 'D':
- i = PROJECTION_OTHER;
- break;
- case 'd':
- break;
- default:
- continue;
- name = G__projection_name(i);
- if (name == NULL)
- continue;
- sprintf(buf, "\n%s coordinate system? ", name);
- if (G_yes(buf, 1))
- break;
- window.proj = i;
- while (window.proj == PROJECTION_UTM)
- fprintf (stderr, " ("Please specify the %s zone for location <%s>\n",
- G__projection_name(window.proj), location_name);
- fprintf (stderr, " ("or RETURN to cancel\n");
- fprintf (stderr, " ("\n");
- fprintf (stderr, " ("> ");
- if (!G_gets(buf))
- continue;
- G_strip (buf);
- if (*buf == 0) return 0;
- if (sscanf (buf, "%d", &i) != 1)
- continue;
- if (i > 0 && i <= 60)
- fprintf(stderr, "zone %d is illegal"\n);
- sprintf (buf, "zone %d? ", i);
- if (G_yes (buf, 1))
- window.zone = i;
- break;
- while (1) {
- G_clear_screen();
- fprintf(stderr,
- "Please enter a one line description for location <%s>\n\n",
- location_name);
- if (!G_gets(buf))
- continue;
- G_squeeze(buf);
- buf[sizeof(myname)] = 0;
- G_squeeze(buf);
- fprintf(stderr,
- "=====================================================\n");
- fprintf(stderr, "%s\n", buf);
- fprintf(stderr,
- if (G_yes("ok? ", *buf != 0))
- break;
- strcpy(myname, buf);
- if(G_edit_cellhd(&window, -1) < 0)
- return 0;
- mapset = "PERMANENT";
- G__setenv("MAPSET", mapset);
- G__setenv("LOCATION_NAME", location_name);
- sprintf(buf, "%s/%s", gisdbase, location_name);
- if (G_mkdir(buf) < 0)
- return 0;
- sprintf(buf, "%s/%s/%s", gisdbase, location_name, mapset);
- return 0;
- /* set the dummy window */
- window.north = 1.;
- window.south = 0.;
- window.top = 1.;
- window.bottom = 0.;
- window.rows = 1;
- window.rows3 = 1;
- window.cols = 1;
- window.cols3 = 1;
- window.depths = 1;
- window.ew_res = 1.;
- window.ew_res3 = 1.;
- window.ns_res = 1.;
- window.ns_res3 = 1.;
- window.tb_res = 1.;
- window.east = 1.;
- window.west = 0.;
- window.zone = 0.;
- /* make a dummy default window for location */
- /* later after calling g.setrpj we will let user create a real default window */
- G__put_window(&window, "", "DEFAULT_WIND");
- G__put_window(&window, "", "WIND");
- sprintf(buf, "%s/%s/%s/MYNAME", gisdbase, location_name, mapset);
- fp = fopen(buf, "w");
- fputs(myname, fp);
- fclose(fp);
- return 1;
Deleted: grass/trunk/lib/init/mke_mapset.c
--- grass/trunk/lib/init/mke_mapset.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/init/mke_mapset.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,52 +0,0 @@
-#include <stdio.h>
-#include <fcntl.h>
-#include <errno.h>
-extern int errno;
-int make_mapset(const char *location, const char *mapset)
- char buffer[GPATH_MAX];
- char *buffer2;
- FILE *fd;
- /* create the mapset directory */
- sprintf(buffer, "%s/%s", location, mapset);
- G_mkdir(buffer);
- /* give the mapset a default window for the entire location */
- G_get_default_window(&window);
- G_put_window(&window);
- /* generate DB settings file in new mapset */
- G_asprintf(&buffer2, "%s/%s/VAR", location, mapset);
- if ((fd = fopen(buffer2, "w")) == NULL) {
- perror("fopen");
- G_fatal_error("Cannot create <%s> file in new mapset", buffer2);
- /* Use DB_DEFAULT_DRIVER from <grass/dbmi.h> instead of hardcoding? */
- fprintf(fd, "DB_DRIVER: sqlite\n");
- fprintf(fd, "DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db\n");
- fclose(fd);
- G_free(buffer2);
-#ifdef KEEP_IF_DB_PER_MAP
- /* create similar dir structure for SQLite if a db file is to be
- created for every vector map instead of one DB per mapset */
- if (strcmp(DB_DEFAULT_DRIVER, "dbf") == 0) {
- /* Make the dbf/ subdirectory */
- sprintf(buffer, "%s/%s/dbf", location, mapset);
- if (G_mkdir(buffer) != 0)
- return -1;
-#endif
- return (0);
Deleted: grass/trunk/lib/init/other.c
--- grass/trunk/lib/init/other.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/init/other.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,57 +0,0 @@
-#include <fcntl.h>
-#include <stdio.h>
-static char *filename(const char *name, const char *mapset)
- static char path[GPATH_MAX];
- G__file_name(path, "", name, mapset);
- return path;
-int mapset_permissions(const char *mapset)
- int stat;
- stat = G__mapset_permissions(mapset);
- if (stat == 1) {
- if (access(filename(".lock", mapset), 0) == 0)
- stat = 0;
- return stat;
-int mapset_message(const char *mapset)
- if (printfile(filename(".message", mapset)))
- hit_return();
- return 0;
-int mapset_question(const char *mapset)
- if (printfile(filename(".question", mapset)))
- return G_yes("Select this mapset? ", -1);
- return 1;
-int printfile(const char *name)
- int fd;
- int n;
- char buf[1024];
- fd = open(name, 0);
- if (fd < 0)
- return 0;
- while ((n = read(fd, buf, sizeof buf)) > 0)
- write(STDOUT_FILENO, buf, n);
- close(fd);
- return 1;
Deleted: grass/trunk/lib/init/set_data.c
--- grass/trunk/lib/init/set_data.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/init/set_data.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,348 +0,0 @@
-/* setup: Program for GRASS user to first use. Sets environment
- * variables: LOCATION_NAME MAPSET GISDBASE
-/* these defines come from the Gmakefile, but are defined here to allow
- * debugging with saber
-#ifndef D_LOCATION_NAME
-#define D_LOCATION_NAME "spearfish"
-#endif
-#ifndef D_GISDBASE
-#define D_GISDBASE "/data"
-#endif
-#ifndef GRASS_VERSION_NUMBER
-#define GRASS_VERSION_NUMBER ""
-#endif
-static char *intro[] = {
- " PLEASE SET SESSION INFORMATION",
- "DATABASE: A directory (folder) on disk to contain all GRASS maps and data.",
- "LOCATION: This is the name of a geographic location. It is defined by a",
- " co-ordinate system and a rectangular boundary.",
- "MAPSET: Each GRASS session runs under a particular MAPSET. This consists of",
- " a rectangular REGION and a set of maps. Every LOCATION contains at",
- " least a MAPSET called PERMANENT, which is readable by all sessions.",
- " The REGION defaults to the entire area of the chosen LOCATION.",
- " You may change it later with the command: g.region",
- 0
-static char *loc_text =
- "LOCATION: (enter list for a list of locations)";
-static char *map_text =
- "MAPSET: (or mapsets within a location)";
-#include <grass/vask.h>
-#include <grass/edit.h>
-int main(int argc, char *argv[])
- char version[80];
- char gisdbase[70];
- char location_name[41];
- char location[1024];
- char mapset[41];
- int line;
- int yes;
- char *GISDBASE;
- char *LOCATION_NAME;
- char *MAPSET;
- int repeat;
- /* GISBASE
- * comes from the unix environment and must be set
- * make sure it is NOT in the .gisrc file
- * note: G_getenv() make a special case of this variable
- G_no_gisinit();
- G_unsetenv("GISBASE"); /* this cleans the variable */
- G_getenv("GISBASE"); /* this reads it from the unix environment */
- /* Gather all existing variables ********************************************* */
- GISDBASE = G__getenv("GISDBASE");
- LOCATION_NAME = G__getenv("LOCATION_NAME");
- MAPSET = G__getenv("MAPSET");
- if (!MAPSET)
- MAPSET = G_whoami();
- if (!LOCATION_NAME)
- LOCATION_NAME = D_LOCATION_NAME;
- if (!GISDBASE)
- GISDBASE = D_GISDBASE;
- strcpy(mapset, MAPSET);
- strcpy(location_name, LOCATION_NAME);
- strcpy(gisdbase, GISDBASE);
- G__setenv("GISDBASE", gisdbase);
- sprintf(version, " GRASS %s",
- GRASS_VERSION_NUMBER);
- for (repeat = 1; repeat; hit_return()) {
- V_clear();
- V_line(0, version);
- for (line = 1; intro[line]; line++)
- V_line(line, intro[line]);
- line++;
- V_line(line, loc_text);
- V_ques(location_name, 's', line++, 12, 25);
- V_line(line, map_text);
- V_ques(mapset, 's', line++, 12, 25);
- line++;
- V_line(line, "DATABASE:");
- V_ques(gisdbase, 's', line++, 10, sizeof(gisdbase) - 1);
- V_intrpt_ok();
- if (!V_call())
- exit(1);
- G_strip(gisdbase);
- if (*gisdbase == 0) {
- fprintf(stderr, "No DATABASE specified\n");
- strcpy(gisdbase, D_GISDBASE);
- continue;
-#ifdef __MINGW32__
- if (*gisdbase == '/') {
- char tmp[200], *p;
- sprintf(tmp, "%s", getenv("WD"));
- for (p = tmp + strlen(tmp); --p >= tmp && *p == '\\';) ;
- for (; --p >= tmp && *p != '\\';) ;
- for (; --p >= tmp && *p == '\\';) ;
- *(p + 1) = 0;
- for (p = tmp; *p; p++)
- if (*p == '\\')
- *p = '/';
- strcat(tmp, gisdbase);
- strcpy(gisdbase, tmp);
- if (!gisdbase[1] || gisdbase[1] != ':')
-#else
- if (*gisdbase != '/')
-#endif
- char temp[200];
- fprintf(stderr, "DATABASE <%s> - must start with /\n", gisdbase);
- sprintf(temp, " '%s'", gisdbase);
- strcpy(gisdbase, temp);
- continue;
- if (access(gisdbase, 0) != 0) {
- fprintf(stderr, "DATABASE <%s> - not found\n", gisdbase);
- continue;
- /* take only first word of responses */
- first_word(location_name);
- first_word(mapset);
- if (*location_name && (G_legal_filename(location_name) < 0)) {
- fprintf(stderr, "LOCATION <%s> - illegal name\n", location_name);
- continue;
- if (*mapset && (G_legal_filename(mapset) < 0)) {
- fprintf(stderr, "MAPSET <%s> - illegal name\n", mapset);
- continue;
- if (*location_name == 0 || strcmp(location_name, "list") == 0) {
- list_locations(gisdbase);
- *location_name = 0;
- continue;
- sprintf(location, "%s/%s", gisdbase, location_name);
- if (access(location, 0) != 0) {
- fprintf(stderr, "LOCATION <%s> - doesn't exist\n", location_name);
- if (!can_make_location(gisdbase, location_name))
- continue;
- fprintf(stderr, "\nWould you like to create location <%s> ? ",
- location_name);
- if (G_yes("", 1)) {
- if (make_location(gisdbase, location_name)) {
- G__setenv("MAPSET", "PERMANENT");
- G__write_env();
- if (system("g.setproj")) {
- if (E_edit_cellhd(&window, -1) < 0)
- fprintf(stderr,
- "WARNING: You did not provide default region for %s!\n",
- location_name);
- fprintf(stderr, "LOCATION <%s> created\n",
- location_name);
- fprintf(stderr,
- "\nBut the PROJECTION information files were not created!\n");
- fprintf(stderr,
- "You must run g.setproj successfully before projection software will work%c%c%c\n",
- 7, 7, 7);
- continue;
- else {
- fprintf(stderr,
- location_name);
- fprintf(stderr, "LOCATION <%s> created!\n",
- location_name);
- continue;
- fprintf(stderr, "LOCATION <%s> NOT created\n", location_name);
- continue;
- if (*mapset == 0 || strcmp(mapset, "list") == 0) {
- list_mapsets(location_name, location);
- *mapset = 0;
- continue;
- repeat = 0;
- switch (mapset_permissions(mapset)) {
- case -1:
- if (strcmp(mapset, G_whoami()) == 0) {
- yes = 1;
- else {
- repeat = 1;
- fprintf(stderr, "\n\nMapset <<%s>> is not available\n",
- mapset);
- fprintf(stderr,
- "\nWould you like to create < %s > as a new mapset? ",
- mapset);
- yes = G_yes("", 1);
- if (yes && (make_mapset(location, mapset) == 0))
- repeat = 0;
- break;
- case 0:
- fprintf(stderr, "\n\nSorry, no access to <<%s>>.\n", mapset);
- repeat = 1;
- break;
- case 1:
- mapset_message(mapset);
- if (!mapset_question(mapset))
- repeat = 1;
- break;
- if (!repeat)
- break;
- G__write_env();
- exit(0);
-int list_locations(const char *gisdbase)
- fprintf(stderr, "\nAvailable locations:\n");
- fprintf(stderr, "----------------------\n");
- G_ls(gisdbase, stderr);
- return 0;
-int list_mapsets(const char *location_name, const char *location)
- char **mapsets;
- int i, num_mapsets;
- int any, ok, any_ok;
- int len, tot_len;
- fprintf(stderr, "\nMapsets in location <%s>\n", location_name);
- mapsets = G__ls(location, &num_mapsets);
- any = 0;
- any_ok = 0;
- tot_len = 0;
- if (num_mapsets > 0) {
- for (i = 0; i < num_mapsets; i++) {
- any = 1;
- len = strlen(mapsets[i]) + 1;
- len /= 20;
- len = (len + 1) * 20;
- tot_len += len;
- if (tot_len > 75) {
- tot_len = len;
- if ((ok = (mapset_permissions(mapsets[i]) == 1)))
- any_ok = 1;
- fprintf(stderr, "%s%-*s", ok ? "(+)" : " ", len, mapsets[i]);
- if (tot_len)
- if (any_ok)
- fprintf(stderr,
- "\nnote: you only have access to mapsets marked with (+)\n");
- else if (any)
- fprintf(stderr,
- "\nnote: you do not have access to any of these mapsets\n");
- return 0;
-int first_word(char *buf)
- char temp[GNAME_MAX];
- *temp = 0;
- sscanf(buf, "%s", temp);
- strcpy(buf, temp);
- return 0;
-int hit_return(void)
- char buf[80];
- fprintf(stderr, "\nHit RETURN -->");
- G_gets(buf);
- return 0;
Modified: grass/trunk/lib/proj/datum.c
--- grass/trunk/lib/proj/datum.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/proj/datum.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -216,154 +216,6 @@
- * \brief Interactively ask for datum parameters for a particular datum
- * Uses traditional GRASS interactive prompt interface to provide
- * information to user and encourage him/her to select the most
- * appropriate set of datum transformation parameters for the location.
- * Could really benefit from an abstracted user interaction library
- * for seamless GUI interaction.
- * \param datumname String containing datum name that
- * parameters are to be found for. Must
- * exist in datum.table or be "custom"
- * \param params Pointer to a pointer that will have
- * memory allocated and into which a string
- * containing the datum parameters chosen
- * by the user will be placed.
- * \return 1 ok, -1 error or user cancelled
-int GPJ_ask_datum_params(const char *datumname, char **params)
- char buff[1024], answer[100];
- char *Tmp_file;
- struct gpj_datum_transform_list *list, *listhead, *old;
- int transformcount, currenttransform;
- if (G_strcasecmp(datumname, "custom") != 0) {
- G_warning(_("Unable to open temporary file"));
- fprintf(Tmp_fd, "Number\tDetails\t\n---\n");
- listhead = GPJ_get_datum_transform_by_name(datumname);
- list = listhead;
- transformcount = 0;
- while (list != NULL) {
- /* Count how many sets of transformation paramters have been
- * defined for this datum and print them to a temporary file
- * in case the user asks for them to be displayed */
- fprintf(Tmp_fd,
- "%d\tUsed in %s\n\t(PROJ.4 Params %s)\n\t%s\n---\n",
- list->count, list->where_used, list->params,
- list->comment);
- list = list->next;
- transformcount++;
- fclose(Tmp_fd);
- for (;;) {
- do {
- fprintf(stderr,
- ("\nNow select Datum Transformation Parameters\n"));
- fprintf(stderr,
- ("Please think carefully about the area covered by your data\n"
- "and the accuracy you require before making your selection.\n"));
- fprintf(stderr,
- ("\nEnter 'list' to see the list of available Parameter sets\n"));
- fprintf(stderr,
- ("Enter the corresponding number, or <RETURN> to cancel request\n"));
- G_strip(answer);
- if (strlen(answer) == 0) {
- remove(Tmp_file);
- G_free(Tmp_file);
- return -1;
- char *pager;
- pager = "cat";
- G_system(buff);
- else {
- if ((sscanf(answer, "%d", ¤ttransform) != 1) ||
- currenttransform > transformcount ||
- currenttransform < 1) {
- /* If a number was not typed, was less than 0 or greater
- * than the number of sets of parameters, ask again */
- fprintf(stderr, ("\ninvalid transformation number\n"));
- else
- break;
- remove(Tmp_file);
- G_free(Tmp_file);
- list = listhead;
- /* Search through the linked list to find the parameter string
- * that corresponds to the number entered */
- if (list->count == currenttransform)
- G_asprintf(params, list->params);
- /* Continue to end of list even after we find it, to free all
- * the memory used */
- old = list;
- list = old->next;
- G_free(old);
- else {
- /* Here we ask the user to enter customised parameters */
- for (;;) {
- do {
- fprintf(stderr,
- ("\nPlease specify datum transformation parameters in PROJ.4 syntax. Examples:\n"));
- fprintf(stderr,
- ("\ttowgs84=dx,dy,dz\t(3-parameter transformation)\n"));
- fprintf(stderr,
- ("\ttowgs84=dx,dy,dz,rx,ry,rz,m\t(7-parameter transformation)\n"));
- fprintf(stderr,
- ("\tnadgrids=alaska\t(Tables-based grid-shifting transformation)\n"));
- G_strip(answer);
- return -1;
- G_asprintf(params, answer);
- sprintf(buff,
- "Parameters to be used are:\n\"%s\"\nIs this correct?",
- *params);
- if (G_yes(buff, 1))
- break;
- return 1;
* \brief Internal function to find all possible sets of
* transformation parameters for a particular datum
Modified: grass/trunk/lib/sites/sites.c
--- grass/trunk/lib/sites/sites.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/sites/sites.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -249,35 +249,7 @@
- * char *
- * G_ask_sites_new(prompt, name))
- * asks user to input name of a new site list file
- * char *
- * G_ask_sites_old(prompt, name)
- * asks user to input name of an existing site list file
- * char *
- * G_ask_sites_any(prompt, name)
- * asks user to input any site list name
- * char *
- * G_ask_sites_in_mapset(prompt, name)
- * asks user to input name of an existing site list file in
- * current mapset
- * parms:
- * char *prompt optional prompt for user
- * returns:
- * note:
* struct Map_info *
* G_sites_open_old (name, mapset)
* opens the existing site list file 'name' in the 'mapset'
@@ -304,30 +276,6 @@
-char *G_ask_sites_new(const char *prompt, char *name)
-char *G_ask_sites_old(const char *prompt, char *name)
-char *G_ask_sites_any(const char *prompt, char *name)
-char *G_ask_sites_in_mapset(const char *prompt, char *name)
struct Map_info *G_sites_open_old(const char *name, const char *mapset)
struct Map_info *Map;
Deleted: grass/trunk/lib/vask/Makefile
--- grass/trunk/lib/vask/Makefile 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/Makefile 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,12 +0,0 @@
-MODULE_TOPDIR = ../..
-EXTRA_LIBS=$(GISLIB) $(CURSES)
-EXTRA_CFLAGS = -DMAKE_VASK_LIB
-LIB_NAME = $(VASK_LIBNAME)
-include $(MODULE_TOPDIR)/include/Make/Lib.make
-default: lib
Deleted: grass/trunk/lib/vask/README
--- grass/trunk/lib/vask/README 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/README 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,36 +0,0 @@
-From: Glynn Clements <glynn.clements at virgin.net>
-Date: Fri, 1 Jun 2001 00:31:44 +0100
-To: Markus Neteler <neteler at geog.uni-hannover.de>, grass5 at geog.uni-hannover.de
-Subject: Vask changes
-Glynn Clements wrote:
-> I'll do the more substantial changes to vasklib today or tonight.
-I've now commited these.
-The main change is that V_call() now has curses process the escape
-sequences for extended keys, rather than using hardcoded definitions.
-Extended keys (cursor keys, Home, End) should now work on any terminal
-which has a correct termcap/terminfo entry.
-One possible disadvantage is that if the termcap/terminfo entry is
-broken, you will get undesirable results. This seems most likely to
-happen with xterm, which has many configuration options which impact
-upon the necessary terminal description.
-The main one of relevance here is the sunKeyboard resource,
-corresponding to the [+/-]sp command line flag and the "Sun Keyboard"
-(or "VT220 Keyboard" in recent XFree86) menu option (Ctrl + left mouse
-button). This affects whether the escape sequences generated by
-Home/End are the Sun versions or the VT220 versions.
-BTW: I tagged the previous version of V_call.c with "pre-curses-fix",
-in case anyone needs the original breakage (to match a broken
-terminfo).
-Glynn Clements <glynn.clements at virgin.net>
Deleted: grass/trunk/lib/vask/V_acc.c
--- grass/trunk/lib/vask/V_acc.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/V_acc.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,50 +0,0 @@
- * \file V_acc.c
- * \brief Decimal precision functions.
- * This program is free software; you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation; either version 2 of the License, or (at
- * your option) any later version.
- * This program is distributed in the hope that it will be useful, but
- * WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
- * General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with this program; if not, write to the Free Software
- * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
- * \date 1999-2006
- * \brief Set number of decimal places.
- * <i>V_float_accuracy()</i> defines the number of decimal places in
- * which floats and doubles are displayed or accepted. <b>Num</b> is an
- * integer value defining the number of decimal places to be used. This
- * routine affects subsequent calls to <i>V_const()</i> and
- * <i>V_ques()</i>. Various inputs or displayed constants can be
- * represented with different numbers of decimal places within the same
- * screen display by making different calls to <i>V_float_accuracy()</i>
- * before calls to <i>V_ques()</i> or <i>V_const()</i>. <i>V_clear()</i>
- * resets the number of decimal places to the default (which is
- * unlimited).
- * \param[in] n
- * \return always returns 0
-void V_float_accuracy(int n)
- V__.decimal_places = n;
Deleted: grass/trunk/lib/vask/V_call.c
--- grass/trunk/lib/vask/V_call.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/V_call.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,507 +0,0 @@
- * \file V_call.c
- * \brief Interactive call functions.
- * \note Modified by Jacques Bouchard and Markus Neteler 6/99 to make
- * cursor keys working. Exit now with ESC-CR.
- * \date 2007-11-01
- ALGORITHM:
- | Zero out screen answer locations
- | Initial curses screens
- | Display text, constants, and answer fields
- | Write text (results from V_line() calls) to curses window
- | Write constants (results from V_const() calls) to curses window
- | Write answers (results from V_ques() calls) to curses window
- | Take commands from the keyboard
- | switch on commands:
- | case CR: case NL: case UP: case ESC:
- | switch on answer type
- | case string
- | remove trailing non-alphanumeric characters
- | copy answer to target denoted in V_ques() call
- | blank out screen line
- | copy target to curses window
- | case integer
- | run atoi on answer, putting results in target
- | denoted in V_ques() call
- | printf target to curses window
- | case long
- | run atol on answer, putting results in target
- | case float, double
- | run sscanf on answer, putting results in target
- | default:
- | do nothing
- | if ESC+CR return from V_call()
- | if UP shift to previous question
- | if CR or NL shift to next question
- | case BS: Move cursor back one column in current question
- | case FS: Move cursor forward one column in current
- | question
- | case RPLT: Replot the current screen image
- | case DUMP: Dump (append) the current window to the user's
- | home dir.
- | default: If an alphanumeric, put that char on the screen
- | and in the current answer field
- | call V_exit (erase screen and exit curses)
-#include <stdio.h>
-static void centered(const char *);
-static void fmt(char *, int, double);
-/* define the V__ struct defined in vask.h */
-struct V__ V__;
-#define DUMP 001
-#define BS 010
-#define FS 014
-#define NL 012
-#define UP 013
-#define CR 015
-#define RPLT 022
-#define ESC 033
-#define CTRLC 003
-#define TARGET V__.usr_answ[at_answer].targetptr
-#define ROW V__.usr_answ[at_answer].row
-#define COL V__.usr_answ[at_answer].col
-#define LENGTH V__.usr_answ[at_answer].length
-#define TYPE V__.usr_answ[at_answer].var_type
-#define ANSWER scr_answ[at_answer].position
-#define RELINE do { \
- move(ROW, COL) ; \
- for (incr2=0;incr2<LENGTH; incr2++) \
- addch('_') ; \
- } while (0)
-/* flag ctrl-c is to be allowed */
-static int interrupts_ok = 0; /* mod shapiro */
- * \fn int V_call (void)
- * \brief Interact with the user.
- * Interactively allow the user to enter answers into all available
- * fields (as previously defined). Answer fields have been created with
- * calls to <i>V_ques()</i>. Information fields have been created using
- * <i>V_const()</i>. General text has been created with calls to
- * <i>V_line()</i>.
- * <i>V_call()</i> clears the screen and writes the text and data values
- * specified by <i>V_line()</i>, <i>V_ques()</i> and <i>V_const()</i> to
- * the screen. It interfaces with the user, collecting user responses in
- * the <i>V_ques()</i> fields until the user is satisfied. A message is
- * automatically supplied on line number 23, explaining to the user to
- * enter an ESC when all inputs have been supplied as desired.
- * <i>V_call()</i> ends when the user hits ESC and returns a value of 1
- * (but see <i>V_intrpt_ok()</i> below). No error checking is done by
- * <i>V_call()</i>. Instead, all variables used in <i>V_ques()</i>
- * calls must be checked upon return from <i>V_call()</i>. If the user
- * has supplied inappropriate information, the user can be informed, and
- * the input prompted for again by further calls to <i>V_call()</i>.
- * \return 1 user entered ESC to continue
- * \return 0 user entered CTRL-C to cancel
- * \return -1 no match
-int V_call(void)
- int incr;
- int incr2;
- int num_answers;
- int at_answer;
- int at_constant;
- int ans_col = 0;
- int newchar;
- int lastchar = 0;
- int new_answer = 0;
- struct
- char position[80];
- } scr_answ[MAX_ANSW];
- int y, x; /* shapiro */
- char temp[100];
- int done;
- /* Zero out screen answer locations */
- for (incr = 0; incr < MAX_ANSW; incr++)
- for (incr2 = 0; incr2 < 80; incr2++)
- scr_answ[incr].position[incr2] = 000;
- /* Initialize the curses windows */
- V_init();
- /* Display text */
- for (incr = 0; incr < MAX_LINE; incr++) {
- move(incr, 0);
- addstr(V__.page.line[incr]);
- /* Display constants */
- for (at_constant = 0; at_constant < V__.NUM_CONST; at_constant++) {
- move(V__.constant[at_constant].row, V__.constant[at_constant].col);
- switch (V__.constant[at_constant].var_type) {
- case 's':
- addstr(V__.constant[at_constant].targetptr.c);
- break;
- case 'i':
- sprintf(temp, "%d", *V__.constant[at_constant].targetptr.i);
- addstr(temp);
- break;
- case 'l':
- sprintf(temp, "%ld", *V__.constant[at_constant].targetptr.l);
- addstr(temp);
- break;
- case 'f':
- fmt(temp, V__.constant[at_constant].decimal_places,
- (double)*V__.constant[at_constant].targetptr.f);
- addstr(temp);
- break;
- case 'd':
- (double)*V__.constant[at_constant].targetptr.d);
- addstr(temp);
- break;
- default:
- break;
- /* Display answer locations */
- for (at_answer = 0; at_answer < V__.NUM_ANSW; at_answer++) {
- /* clear ANSWER */
- for (incr = 0; incr < 80; incr++)
- scr_answ[at_answer].position[incr] = 000;
- switch (TYPE) {
- case 's':
- strcpy(ANSWER, TARGET.c);
- RELINE;
- for (incr = 0; incr < LENGTH; incr++) {
- if (*(TARGET.c + incr) == '\000')
- while (incr++ < LENGTH)
- addch('_');
- else
- addch(*(TARGET.c + incr));
- break;
- case 'i':
- sprintf(ANSWER, "%d", *TARGET.i);
- RELINE;
- addstr(ANSWER);
- break;
- case 'l':
- sprintf(ANSWER, "%ld", *TARGET.l);
- RELINE;
- addstr(ANSWER);
- break;
- case 'f':
- fmt(ANSWER, V__.usr_answ[at_answer].decimal_places,
- (double)*TARGET.f);
- RELINE;
- addstr(ANSWER);
- break;
- case 'd':
- (double)*TARGET.d);
- RELINE;
- addstr(ANSWER);
- break;
- default:
- break;
- num_answers = at_answer;
- if (interrupts_ok)
- move(22, 0);
- else
- move(23, 0);
- centered("AFTER COMPLETING ALL ANSWERS, HIT <ESC><ENTER> TO CONTINUE");
- if (interrupts_ok) {
- sprintf(temp, "(OR <Ctrl-C> TO %s)", V__.interrupt_msg);
- centered(temp);
- /* Begin taking commands/answers from terminal */
- at_answer = 0;
- move(ROW, COL);
- refresh();
- for (done = 0; !done;) {
- getyx(stdscr, y, x);
- newchar = getch();
- switch (newchar) {
- case ERR:
- break;
- case ESC:
- if (V__.NUM_ANSW <= 0)
- done = 1;
- break;
- case CTRLC:
- if (interrupts_ok || V__.NUM_ANSW <= 0)
- done = 1;
- break;
-#ifdef KEY_UP
- case KEY_UP:
-#endif
- case UP:
- new_answer = (at_answer + num_answers - 1) % num_answers;
- ans_col = 0;
- break;
-#ifdef KEY_DOWN
- case KEY_DOWN:
-#endif
- case CR:
- case NL:
- new_answer = (at_answer + 1) % num_answers;
- ans_col = 0;
- if (lastchar == ESC && (newchar == CR || newchar == NL))
- done = 1;
- break;
-#ifdef KEY_LEFT
- case KEY_LEFT:
- ans_col = (ans_col - 1 >= 0) ? ans_col - 1 : 0;
- break;
-#endif
-#ifdef KEY_BACKSPACE
- case KEY_BACKSPACE:
-#endif
- case BS:
- ANSWER[ans_col] = ' ';
- move(ROW, COL + ans_col);
- addch(' ');
- break;
-#ifdef KEY_RIGHT
- case KEY_RIGHT:
-#endif
- case FS:
- ans_col = (ans_col + 1 < LENGTH &&
- ANSWER[ans_col]) ? ans_col + 1 : ans_col;
- break;
-#ifdef KEY_HOME
- case KEY_HOME:
- ans_col = 0;
- break;
-#endif
-#ifdef KEY_END
- case KEY_END:
- for (ans_col = 0; ans_col < LENGTH && ANSWER[ans_col];
- ans_col++) ;
- break;
-#endif
-#ifdef KEY_REFRESH
- case KEY_REFRESH:
-#endif
- case RPLT:
- wrefresh(curscr);
- break;
-#ifdef KEY_PRINT
- case KEY_PRINT:
-#endif
- case DUMP:
- V__dump_window();
- break;
- case '\177':
- break;
- default:
- if (ans_col < LENGTH && newchar >= 040 && newchar <= 0377) {
- addch(newchar);
- ANSWER[ans_col] = newchar;
- ans_col++;
- break;
- if (new_answer != at_answer || done) {
- V__remove_trail(LENGTH, ANSWER);
- switch (TYPE) {
- case 's':
- strcpy(TARGET.c, ANSWER);
- RELINE;
- addstr(TARGET.c);
- break;
- case 'i':
- *TARGET.i = atoi(ANSWER);
- RELINE;
- sprintf(temp, "%d", *TARGET.i);
- addstr(temp);
- break;
- case 'l':
- *TARGET.l = atol(ANSWER);
- RELINE;
- sprintf(temp, "%ld", *TARGET.l);
- addstr(temp);
- break;
- case 'f':
- sscanf(ANSWER, "%f", TARGET.f);
- RELINE;
- addstr(ANSWER);
- break;
- case 'd':
- sscanf(ANSWER, "%lf", TARGET.d);
- RELINE;
- addstr(ANSWER);
- break;
- default:
- break;
- at_answer = new_answer;
- lastchar = newchar;
- refresh();
- if (done) {
- interrupts_ok = 0;
- V_exit();
- return (newchar != CTRLC);
- return -1;
- * \fn int V_intrpt_ok (void)
- * \brief Allow CTRL-C.
- * <i>V_call()</i> normally only allows the ESC character to end the
- * interactive input session. Sometimes, it is desirable to allow the
- * user to cancel the session. To provide this alternate means of exit,
- * the programmer can call <i>V_intrpt_ok()</i> before <i>V_call()</i>.
- * This allows the user to enter CTRL-C, which causes <i>V_call()</i> to
- * return a value of 0 instead of 1.<br>
- * A message is automatically supplied to the user on line 23 saying to
- * use CTRL-C to cancel the input session. The normal message
- * accompanying <i>V_call()</i> is moved up to line 22.<br>
- * <b>Note:</b> When <i>V_intrpt_ok()</i> is called, the programmer must
- * limit the use of <i>V_line()</i>, <i>V_ques()</i>, and
- * <i>V_const()</i> to lines 0-21.
-void V_intrpt_ok(void)
- interrupts_ok = 1; /* will be set false when V_call() exists */
- * \fn int V_intrpt_msg (const char *msg)
- * \brief Change CTRL-C message.
- * A call to <i>V_intrpt_msg()</i> changes the default
- * <i>V_intrpt_ok()</i> message from (OR <CTRL-C> TO CANCEL) to (OR
- * <CTRL-C> TO <i>msg</i>). The message is (re)set to the default by
- * <i>V_clear()</i>.
- * \param[in] msg
-void V_intrpt_msg(const char *msg)
- strcpy(V__.interrupt_msg, msg);
-static void fmt(char *s, int n, double x)
- char buf[20];
- if (n >= 0)
- sprintf(buf, "%%.%dlf", n);
- else
- strcpy(buf, "%.5lf");
- /* I had to use .5lf instead of just lf since a number like 65.8 got
- * sprintf'ed as 65.800003 this is a hack - I admit it.
- sprintf(s, buf, x);
- if (n < 0)
- V__trim_decimal(s);
-static void centered(const char *msg)
- int indent;
- indent = (80 - strlen(msg)) / 2;
- while (indent-- > 0)
- addstr(" ");
- addstr(msg);
- addstr("\n");
Deleted: grass/trunk/lib/vask/V_clear.c
--- grass/trunk/lib/vask/V_clear.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/V_clear.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,61 +0,0 @@
- * \file V_clear.c
- * \brief Screen clearning functions.
- * \date 1999-2006
-#include <stdio.h>
-#define DECIMAL_PLACES -1
- * \brief Zero out prompt and answer arrays.
- * This routine initializes the screen description information and must
- * be called before each new screen layout description.
-void V_clear(void)
- static const char text[] = "";
- int at_answer;
- for (at_answer = 0; at_answer < MAX_ANSW; at_answer++)
- V__.usr_answ[at_answer].length = 0;
- for (at_answer = 0; at_answer < MAX_CONST; at_answer++)
- V__.constant[at_answer].length = 0;
- for (at_answer = 0; at_answer < MAX_LINE; at_answer++)
- V__.page.line[at_answer] = text;
- V__.NUM_CONST = 0;
- V__.NUM_ANSW = 0;
- V__.NUM_LINE = 0;
- V_float_accuracy(DECIMAL_PLACES);
- sprintf(V__.interrupt_msg, "CANCEL");
Deleted: grass/trunk/lib/vask/V_const.c
--- grass/trunk/lib/vask/V_const.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/V_const.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,88 +0,0 @@
- * \file V_const.c
- * \brief Display constant functions.
- * \date 1999-2006
-#include <stdio.h>
- * \fn int V_const (void *src, char var_type, int row, int col, int length)
- * \brief Define screen constant.
- * This routine allows a program to identify a constant, and where that
- * constant should be placed on the screen in the next call to
- * <i>V_call()</i>. <b>var_type</b> is one of <i>int</i>, <i>long</i>,
- * <i>float</i>, <i>double</i>, or <i>char</i>.
- * \param[in] src
- * \param[in] var_type
- * \param[in] row
- * \param[in] col
- * \param[in] len
- * \return 0 on success
- * \return -1 on error
-int V_const(void *src, int var_type, int row, int col, int length)
- union target targetptr;
- targetptr.i = src;
- if (V__.NUM_CONST >= MAX_CONST) {
- V_error("Too many constants in call to V_const");
- return (-1);
- if ((row < 0) || (row >= MAX_LINE)) {
- V_error("Illegal row (%d) in call to V_const", row);
- return (-1);
- if ((col < 0) || (col > 80)) {
- V_error("Illegal column (%d) in call to V_const", col);
- return (-1);
- if ((length < 0) || ((length + col) > 80)) {
- V_error("Length out of bounds in call to V_const");
- return (-1);
- if ((var_type == 's') || (var_type == 'i') || (var_type == 'f')
- || (var_type == 'l') || (var_type == 'd')) {
- V__.constant[V__.NUM_CONST].targetptr = targetptr;
- V__.constant[V__.NUM_CONST].var_type = var_type;
- V__.constant[V__.NUM_CONST].row = row;
- V__.constant[V__.NUM_CONST].col = col;
- V__.constant[V__.NUM_CONST].length = length;
- V__.constant[V__.NUM_CONST].decimal_places = V__.decimal_places;
- V__.NUM_CONST++;
- return (0);
- else {
- V_error("Illegal variable type in call to V_const");
- return (-1);
Deleted: grass/trunk/lib/vask/V_error.c
--- grass/trunk/lib/vask/V_error.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/V_error.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,52 +0,0 @@
- * \file V_error.c
- * \brief Display error functions.
- * \date 1999-2006
-#include <stdio.h>
-#include <stdarg.h>
- * \fn int V_error (char *message)
- * \brief Dispay error routine.
- * Deals with error messages generated by other Visual ask routines.
- * \param[in] message
-void V_error(const char *fmt, ...)
- va_list ap;
- va_start(ap, fmt);
- fprintf(stderr, "V_ask error: ");
- vfprintf(stderr, fmt, ap);
- va_end(ap);
- G_sleep(4);
Deleted: grass/trunk/lib/vask/V_exit.c
--- grass/trunk/lib/vask/V_exit.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/V_exit.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,67 +0,0 @@
- * \file V_exit.c
- * \brief Interactive exit functions.
- * \date 1999-2006
-#include <stdio.h>
- * \fn int V_exit ()
- * \brief Erases the current screen and flushes the current curses setup.
-void V_exit(void)
-#ifdef HAVE_KEYPAD
- keypad(stdscr, 0);
-#endif
- clear();
- refresh();
- /* added for Mips' braindead implementation of curses
- * and the ordering is important
- echo();
- nl();
- noraw();
- endwin();
- fflush(stdout);
- fflush(stderr);
- fflush(stdin);
- /* Added 17 Sep 1990 dpg. is a hack we have been using on Sys V
- * machines it is not the correct way, but it seems to do the job.
- * Fixes the problem with prompts not being displayed after
- * exitting curses. */
-#ifdef SYSV
- setvbuf(stderr, NULL, _IONBF, 0);
- setvbuf(stdout, NULL, _IONBF, 0);
-#endif
Deleted: grass/trunk/lib/vask/V_init.c
--- grass/trunk/lib/vask/V_init.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/V_init.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,64 +0,0 @@
- * \file V_init.c
- * \brief Interactive initialization functions.
- * \date 1999-2006
- * \fn int V_init ()
- * \brief Initialize curses and prepare screen.
-void V_init(void)
- static int first = 1;
- G_clear_screen(); /* this is a kludge - xterm has problems
- * it shows what was on the screen after
- * endwin is called in V_exit()
- if (first) {
- initscr(); /* initialize curses and tty */
- first = 0;
- /* the order of these 3 calls is important for
- * Mips' braindead implementation of curses */
- noecho();
- nonl();
- raw();
- clear();
- refresh();
-#ifdef HAVE_KEYPAD
- keypad(stdscr, 1);
-#endif
Deleted: grass/trunk/lib/vask/V_line.c
--- grass/trunk/lib/vask/V_line.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/V_line.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,57 +0,0 @@
- * \file V_line.c
- * \brief Display line functions.
- * \date 1999-2006
- * \fn int V_line (int linenumber, char *text)
- * \brief Add line of text to screen for next call to <i>V_call()</i>.
- * This routine is used to place lines of text on the screen.
- * <b>linenumber</b> is an integer value of 0-22 specifying the row on
- * the screen where the <b>text</b> is placed. The top row on the screen
- * is row 0.<br>
- * <b>Warning:</b> <i>V_line()</i> does not copy the text to the screen
- * description. It only saves the text address. This implies that each
- * call to <i>V_line()</i> must use a different text buffer.
- * \param[in] linenumber
- * \param[in] text
-int V_line(int linenumber, const char *text)
- if (linenumber >= MAX_LINE || linenumber < 0) {
- V_error("Linenumber out of bounds in call to V_line");
- return (-1);
- V__.page.line[linenumber] = text;
- return 0;
Deleted: grass/trunk/lib/vask/V_ques.c
--- grass/trunk/lib/vask/V_ques.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/V_ques.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,119 +0,0 @@
- * \file V_ques.c
- * \brief Display question functions.
- * \date 1999-2006
- * \fn int V_ques (void *src, char var_type, int row, int col, int length)
- * \brief Define screen question.
- * <i>V_ques()</i> allows a program to identify a prompt field and where
- * that field should be placed on the screen in the next call to
- * <i>V_call()</i>.<br>
- * <i>V_ques()</i> specifies that the contents of memory at the address
- * of <b>src</b> are to be displayed on the screen at location
- * <b>row</b>, <b>col</b> for <b>len</b> characters.<br>
- * <i>V_ques()</i> further specifies that this screen location is a
- * prompt field. The user will be allowed to change the field on the
- * screen and thus change the <b>src</b> itself.
- * <b>var_type</b> specifies what type <b>src</b> points to: 'i' (int),
- * 'l' (long), 'f' (float), 'd' (double), or 's' (character string).<br>
- * <b>row</b> is an integer value of 0-22 specifying the row on the
- * screen where the value is placed. The top row on the screen is row
- * 0.<br>
- * <b>col</b> is an integer value of 0-79 specifying the column on the
- * screen where the value is placed. The leftmost column on the screen
- * is column 0.<br>
- * <b>len</b> specifies the number of columns that the value will
- * use.<br>
- * <b>Note:</b> The size of a character array passed to <i>V_ques()</i>
- * must be at least one byte longer than the length of the prompt field
- * to allow for NULL termination. Currently, you are limited to 20
- * constants and 80 variables.<br>
- * <b>Warning:</b> These routines store the address of <b>src</b> and
- * not the value itself. This implies that different variables must be
- * used for different calls. Programmers will instinctively use
- * different variables with <i>V_ques()</i>, but it is a stumbling block
- * for <i>V_const()</i>. Also, the programmer must initialize
- * <b>src</b> prior to calling these routines.
- * \remarks {Technically <b>src</b> needs to be initialized before
- * the call to <i>V_call()</i> since <i>V_const()</i> and
- * <i>V_ques()</i> only store the address of <b>src</b>.
- * <i>V_call()</i> looks up the values and places them on the screen.}
- * \param[in] src
- * \param[in] row
- * \param[in] col
- * \param[in] len
-int V_ques(void *src, int var_type, int row, int col, int length)
- if (V__.NUM_ANSW >= MAX_ANSW) {
- V_error("Too many questions in call to V_ques");
- return (-1);
- V_error("Illegal row (%d) in call to V_ques", row);
- return (-1);
- if ((col < 0) || (col >= 80)) {
- V_error("Illegal column (%d) in call to V_ques", col);
- return (-1);
- if (length <= 0) {
- V_error("Negative length in call to V_ques");
- return (-1);
- if (length + col > 80)
- length = 80 - col;
- V__.usr_answ[V__.NUM_ANSW].targetptr = targetptr;
- V__.usr_answ[V__.NUM_ANSW].var_type = var_type;
- V__.usr_answ[V__.NUM_ANSW].row = row;
- V__.usr_answ[V__.NUM_ANSW].col = col;
- V__.usr_answ[V__.NUM_ANSW].length = length;
- V__.usr_answ[V__.NUM_ANSW].decimal_places = V__.decimal_places;
- V__.NUM_ANSW++;
- return (0);
- else {
- V_error("Illegal variable type in call to V_ques");
- return (-1);
Deleted: grass/trunk/lib/vask/V_support.c
--- grass/trunk/lib/vask/V_support.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/V_support.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,110 +0,0 @@
- * \file V_support.c
- * \brief Interactive support functions.
- * \date 1999-2006
-#include <stdio.h>
-#include <pwd.h>
-#endif
-#include <unistd.h>
-#include <curses.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
- * \fn int V__dump_window ()
- * \brief Dumps screen to file.
-int V__dump_window(void)
- int atrow, atcol;
- FILE *file;
- char home[GPATH_MAX];
- int curx, cury;
- sprintf(home, "%s/visual_ask", G_home());
- if ((file = fopen(home, "a")) == NULL) {
- V_error(_("Unable to open file %s"), home);
- return (-1);
- getyx(stdscr, cury, curx);
- fprintf(file,
- "--------------------------------------------------------\n");
- for (atrow = 0; atrow < LINES; atrow++) {
- for (atcol = 0; atcol < COLS - 1; atcol++) {
- move(atrow, atcol);
- fprintf(file, "%c", (int)(inch() & A_CHARTEXT));
- fprintf(file, "\n");
- fprintf(file,
- fprintf(file, "\n\n");
- fclose(file);
- move(cury, curx);
- return 0;
- * \fn int V__remove_trail (int ans_col, char *answer)
- * \brief Remove trailing text from <b>answer</b>?
- * \param[in] ans_col
- * \param[in] answer
- * \return always returns 0;
-void V__remove_trail(int ans_col, char *answer)
- char *ans_ptr;
- ans_ptr = answer + ans_col;
- while (ans_col >= 0) {
- int c = *(unsigned char *)ans_ptr;
- if (c > '\040' && c != '\177' && c != '_')
- return;
- *ans_ptr = '\0';
- ans_col--;
- ans_ptr--;
- return;
Deleted: grass/trunk/lib/vask/V_trim_dec.c
--- grass/trunk/lib/vask/V_trim_dec.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/lib/vask/V_trim_dec.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,56 +0,0 @@
- * \file V_trim_dec.c
- * \brief Display trim functions.
- * \date 1999-2006
- * \fn int V__trim_decimal (char *buf)
- * \brief Remove trailing zeros from decimal number.
- * For example: 23.45000 would return 23.45.
- * \param[in,out] buf
-void V__trim_decimal(char *buf)
- char *mark;
- /* find the . */
- while (*buf != '.')
- if (*buf++ == '\0')
- return;
- mark = buf;
- while (*++buf)
- if (*buf != '0')
- mark = buf + 1;
- while (*mark)
- *mark++ = 0;
Deleted: grass/trunk/raster/r.coin/check.c
--- grass/trunk/raster/r.coin/check.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/raster/r.coin/check.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,58 +0,0 @@
- * MODULE: r.coin
- * AUTHOR(S): Michael O'Shea - CERL
- * Michael Shapiro - CERL
- * PURPOSE: Calculates the coincidence of two raster map layers.
- * COPYRIGHT: (C) 2006 by the GRASS Development Team
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
-#include <stdlib.h>
-#include "coin.h"
-/* computes the approximate number of lines/pages an 80 column
- * report would take, and asks the user if this is ok
-int check_report_size(void)
- long nlines;
- long npages;
- long npanels;
- char buf[100];
- npanels = ncat1 / 3;
- if (ncat1 % 3)
- npanels++;
- nlines = (12 + ncat2) * npanels + 11 + ncat2;
- npages = (nlines + 65) / 66;
- while (1) {
- fprintf(stdout, "\nThe coincidence table is %d rows by %d columns\n",
- ncat2, ncat1);
- fprintf(stdout,
- "The report will require approximately %ld lines (%ld pages)\n",
- nlines, npages);
- fprintf(stdout, "Do you want to continue? ");
- while (1) {
- fprintf(stdout, "(y/n) ");
- if (!G_gets(buf))
- break;
- if (*buf == 'y' || *buf == 'Y')
- return 1;
- if (*buf == 'n' || *buf == 'N')
- exit(0);
Deleted: grass/trunk/raster/r.coin/inter.c
--- grass/trunk/raster/r.coin/inter.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/raster/r.coin/inter.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,156 +0,0 @@
- * MODULE: r.coin
- * for details.
-#include "coin.h"
-#include <grass/spawn.h>
-int interactive_version(void)
- int cols;
- char key;
- char line[128], outname[GNAME_MAX], command[1024];
- char ans[80];
- setbuf(stderr, NULL);
- G_clear_screen();
- G_message(_("GIS Coincidence Tabulation Facility\n"));
- G_message(_("This utility will allow you to compare the "
- "coincidence of two map layers\n"));
- mapset1 = G_ask_cell_old("Enter Name of Map Layer 1", map1name);
- if (!mapset1)
- G_fatal_error(_("Raster map <%s> not found"), map1name);
- mapset2 = G_ask_cell_old("Enter Name of Map Layer 2", map2name);
- if (!mapset2)
- G_fatal_error(_("Raster map <%s> not found"), map2name);
- make_coin();
- check_report_size();
- while (1) {
- G_clear_screen();
- G_message(_("The report can be made in one of 8 units."));
- G_message(_("Please choose a unit by entering one of the "
- "following letter codes:"));
- G_message(_(" 'c': cells"));
- G_message(_(" 'p': percent cover of region"));
- G_message(_(" 'x': percent of '%s' category (column)"), map1name);
- G_message(_(" 'y': percent of '%s' category (row)"), map2name);
- G_message(_(" 'a': acres"));
- G_message(_(" 'h': hectares"));
- G_message(_(" 'k': square kilometers"));
- G_message(_(" 'm': square miles\n"));
- G_message(_(" 'Q': quit"));
- fprintf(stderr, "> ");
- *ans = 0;
- if (!G_gets(ans))
- continue;
- if (sscanf(ans, "%c", &key) != 1)
- continue;
- switch (key) {
- case 'c':
- case 'p':
- case 'x':
- case 'y':
- case 'a':
- case 'h':
- case 'k':
- case 'm':
- print_coin(key, 80, 1);
- break;
- case 'Q':
- exit(0);
- default:
- continue;
- sprintf(command, "%s \"%s\"", getenv("GRASS_PAGER"),
- G_convert_dirseps_to_host(dumpname));
- G_system(command);
- while (1) {
- fprintf(stderr,
- _
- ("Do you wish to save this report in a file? (y/n) [n] "));
- *ans = 0;
- if (!G_gets(ans))
- continue;
- G_strip(ans);
- if (ans[0] != 'y' && ans[0] != 'Y')
- break;
- fprintf(stderr, _("Enter the file name or path\n> "));
- if (!G_gets(line))
- continue;
- if (sscanf(line, "%s", outname) != 1)
- continue;
- fprintf(stderr, _("'%s' being saved\n"), outname);
- if (G_copy_file(dumpname, outname))
- /* Break out if file copy was successful otherwise try again */
- break;
- while (1) {
- *ans = 0;
- fprintf(stderr,
- _
- ("Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "));
- if (!G_gets(ans))
- continue;
- G_strip(ans);
- break;
- ask132:
- fprintf(stderr,
- _("Do you wish it printed in 80 or 132 columns?\n> "));
- *ans = 0;
- if (!G_gets(ans))
- continue;
- G_strip(ans);
- if (sscanf(ans, "%d", &cols) != 1)
- goto ask132;
- if (cols == 132)
- print_coin(key, 132, 1);
- else if (cols != 80)
- goto ask132;
- G_spawn("lpr", "lpr", dumpname, NULL);
- break;
- do {
- fprintf(stderr, _("Do you wish to run this report with a "
- "different unit of measure? (y/n) [y] "));
- *ans = 0;
- while (!G_gets(ans));
- G_strip(ans);
- if (*ans == 'n' || *ans == 'N')
- break;
- return 0;
Modified: grass/trunk/raster/r.coin/main.c
--- grass/trunk/raster/r.coin/main.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/raster/r.coin/main.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -52,10 +52,7 @@
window_cells = G_window_rows() * G_window_cols();
- if (argc > 1)
- command_version(argc, argv);
- else
- interactive_version();
+ command_version(argc, argv);
unlink(dumpname);
unlink(statname);
Modified: grass/trunk/raster/r.le/r.le.setup/Makefile
--- grass/trunk/raster/r.le/r.le.setup/Makefile 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/raster/r.le/r.le.setup/Makefile 2008-08-06 03:28:21 UTC (rev 32551)
@@ -2,8 +2,8 @@
PGM = r.le.setup
-LIBES = $(DISPLAYLIB) $(RASTERLIB) $(SITESLIB) $(VECTLIB) $(GISLIB) $(DATETIMELIB) $(VASKLIB) $(CURSES)
-DEPENDENCIES = $(RASTERDEP) $(DISPLAYDEP) $(SITESDEP) $(VECTDEP) $(GISDEP) $(DATETIMEDEP) $(VASKDEP)
+LIBES = $(DISPLAYLIB) $(RASTERLIB) $(SITESLIB) $(VECTLIB) $(GISLIB) $(DATETIMELIB)
+DEPENDENCIES = $(RASTERDEP) $(DISPLAYDEP) $(SITESDEP) $(VECTDEP) $(GISDEP) $(DATETIMEDEP)
EXTRA_INC = $(VECT_INC)
EXTRA_CFLAGS = $(VECT_CFLAGS)
CLEAN_SUBDIRS = polytocell
Modified: grass/trunk/raster3d/r3.mkdspf/main.c
--- grass/trunk/raster3d/r3.mkdspf/main.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/raster3d/r3.mkdspf/main.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -89,6 +89,7 @@
out->key = "dspf";
out->type = TYPE_STRING;
out->required = YES;
+ out->gisprompt = "new_file,file,output";
out->description = _("Name of output display file");
levels = G_define_option();
Modified: grass/trunk/raster3d/r3.mkdspf/r3_find.c
--- grass/trunk/raster3d/r3.mkdspf/r3_find.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/raster3d/r3.mkdspf/r3_find.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -30,9 +30,6 @@
/* return NULL on error: otherwise returns dspout */
char *check_get_any_dspname(char *dspf, char *g3f, char *mset)
- char element[200], question[200];
- static char dspout[200];
if (!G_legal_filename(dspf))
return (NULL);
@@ -41,18 +38,9 @@
if (mset) { /* otherwise must be reading only */
if (g3_find_dsp_file(g3f, dspf, mset)) { /* already exists */
- sprintf(question, "\n** %s exists. ok to overwrite? ", dspf);
- if (!G_yes(question, 0)) {
- if (NULL == G_ask_any("", dspout, element, "display", 1))
- return (NULL);
- return (dspout);
- /* or else just print a warning & use it as is */
+ /* the parser should handle the overwrite check */
- strcpy(dspout, dspf);
- return (dspout);
+ return dspf;
Modified: grass/trunk/vector/v.transform/Makefile
--- grass/trunk/vector/v.transform/Makefile 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/vector/v.transform/Makefile 2008-08-06 03:28:21 UTC (rev 32551)
@@ -5,12 +5,6 @@
include $(MODULE_TOPDIR)/include/Make/Module.make
-ifdef MINGW
-EXTRA_LIB=
-else
-EXTRA_LIB=$(VASKLIB) $(CURSES)
-endif
DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP)
LIBES = $(VECTLIB) $(DBMILIB) $(TRANSLIB) $(EXTRA_LIB) $(GISLIB)
Deleted: grass/trunk/vector/v.transform/ask_trans.c
--- grass/trunk/vector/v.transform/ask_trans.c 2008-08-06 00:57:07 UTC (rev 32550)
+++ grass/trunk/vector/v.transform/ask_trans.c 2008-08-06 03:28:21 UTC (rev 32551)
@@ -1,143 +0,0 @@
- * MODULE: v.transform
- * AUTHOR(S): See other files as well...
- * Eric G. Miller <egm2 at jps.net>
- * PURPOSE: To transform a vector layer's coordinates via a set of tie
- * points.
- * COPYRIGHT: (C) 2002 by the GRASS Development Team
- * for details.
- * ask_transform_coor (n_points) -
- * Uses Vask to get the sets of coordinates from the user.
- * shrink_map_coor() - condense the arrays used for the transform
- * library, also turns on the use[] if the coordinate set if valid.
- * Written by the GRASS Team, 02/16/90, -mh .
-#ifndef __MINGW32__
-#include <stdio.h>
-#include "trans.h"
-static int shrink_map_coor(void);
-int ask_transform_coor(int n_points)
- int i;
- int coor_cnt;
- int at_line;
- int at_point[MAX_COOR];
- /* at_point must be an array for Vask */
- char tmp[82];
- /* number of coordinates we can handle. this may be the second time
- * to this menu and some points may have been registered
- coor_cnt = MAX_COOR - reg_cnt;
- V_clear();
- V_line(1, " MAP REGISTRATION");
- V_line(2,
- V_line(3,
- "| | Existing Map | New Map |");
- V_line(4,
- "| Point # | X coord Y coord | X coord Y coord |");
- V_line(5,
- for (i = 0; i < MAX_COOR; i++) {
- at_line = i + 7;
- at_point[i] = i + 1;
- V_const(&at_point[i], 'i', at_line, 6, 6);
- V_ques(&ax[i], 'd', at_line, 15, 12);
- V_ques(&ay[i], 'd', at_line, 30, 12);
- V_ques(&bx[i], 'd', at_line, 45, 12);
- V_ques(&by[i], 'd', at_line, 60, 12);
- /* show min needed and max they can go to */
- sprintf(tmp, " Enter %d to %d points. Current number of points: %d",
- (MIN_COOR > reg_cnt) ? MIN_COOR - reg_cnt : 0, coor_cnt,
- n_points);
- V_line(at_line + 3, tmp);
- V_intrpt_ok();
- /* add message before exit */
- if (!V_call()) {
- V_exit();
- G_message(_("ask_transform_coor(): Leaving session.. \n"));
- G_sleep(2);
- return (-1);
- return (shrink_map_coor());
- * Condense the arrays and update use[].
- int i, k;
- for (i = 0, k = 0; i < MAX_COOR; i++) {
- if (ax[i] == 0.0 || ay[i] == 0.0 || bx[i] == 0.0 || by[i] == 0.0)
- continue;
- use[i] = 1;
- /* same place count it, but skip it */
- if (i == k) {
- ++k;
- continue;
- /* valid point store them */
- *(bx + k) = *(bx + i);
- *(by + k) = *(by + i);
- *(ax + k) = *(ax + i);
- *(ay + k) = *(ay + i);
- *(use + k) = *(use + i);
- *(residuals + k) = *(residuals + i);
- ++k;
- /* now make sure everything else is zero'ed out */
- i = (k <= 0) ? 0 : k;
- for (; i < MAX_COOR; i++) {
- *(bx + i) = 0.0;
- *(by + i) = 0.0;
- *(ax + i) = 0.0;
- *(ay + i) = 0.0;
- *(use + i) = 0;
- *(residuals + i) = 0.0;
- return (k);
-#endif /* __MINGW32__ */
