[GRASS-SVN] r32577 - grass/trunk/vector/v.transform
svn_grass at osgeo.org
Wed Aug 6 13:06:40 EDT 2008
Author: glynn
Date: 2008-08-06 13:06:40 -0400 (Wed, 06 Aug 2008)
New Revision: 32577
grass/trunk/vector/v.transform/creat_trans.c
grass/trunk/vector/v.transform/local_proto.h
Remove interactive usage
Modified: grass/trunk/vector/v.transform/creat_trans.c
--- grass/trunk/vector/v.transform/creat_trans.c 2008-08-06 17:01:08 UTC (rev 32576)
+++ grass/trunk/vector/v.transform/creat_trans.c 2008-08-06 17:06:40 UTC (rev 32577)
@@ -18,8 +18,6 @@
* create_transform_conversion () - main driver routine to prepare
* the transformation equation.
- * yes_no_quest(s) - ask the user a yes, no question.
- * returns: 1 for yes, 0 for no
* Written by the GRASS Team, 02/16/90, -mh.
@@ -31,80 +29,6 @@
#include "trans.h"
#include "local_proto.h"
-int create_transform_conversion(struct file_info *Coord, int quiet)
- if (Coord->name[0] != '\0')
- create_transform_from_file(Coord, quiet);
- else
- create_transform_from_user();
- return 0;
-int create_transform_from_user(void)
- int status;
- int n_points;
- int ok;
- init_transform_arrays();
- n_points = 0;
- ok = 0;
- while (!ok) {
-#ifdef __MINGW32__
- G_fatal_error("Points cannot be entered interactively on Windows");
-#else
- /* go to Vask page to enter the coordinates */
- if ((n_points = ask_transform_coor(n_points)) < 0)
- exit(-1);
-#endif
- G_clear_screen();
- status = setup_transform(n_points);
- if (status != ALL_OK) {
- G_message(_(" Number of points that have been entered: %d\n"),
- n_points);
- print_transform_error(status);
- continue;
- print_transform_resids(n_points);
- ok = yes_no_quest
- ("\n\n\nIf satisfied with the residuals, enter 'y', else 'n' and <Return>: ");
- } /* while (!ok) */
- return (0);
-} /* create_transform_conversion() */
-int yes_no_quest(char *s)
- char buff[200];
- while (1) {
- G_message("%s", s);
- if (NULL == fgets(buff, 200, stdin))
- exit(-1);
- switch (*buff) {
- case 'Y':
- case 'y':
- return (1);
- case 'N':
- case 'n':
- return (0);
- default:
- G_message(_("Please answer yes or no"));
int create_transform_from_file(struct file_info *Coord, int quiet)
int status;
Modified: grass/trunk/vector/v.transform/local_proto.h
--- grass/trunk/vector/v.transform/local_proto.h 2008-08-06 17:01:08 UTC (rev 32576)
+++ grass/trunk/vector/v.transform/local_proto.h 2008-08-06 17:06:40 UTC (rev 32577)
@@ -1,13 +1,8 @@
-/* ask_trans.c */
-int ask_transform_coor(int);
/* command.c */
int set_default_options(struct file_info *, struct file_info *,
struct file_info *, struct command_flags *);
/* creat_trans.c */
-int create_transform_conversion(struct file_info *, int);
-int create_transform_from_user(void);
-int yes_no_quest(char *);
int create_transform_from_file(struct file_info *, int);
/* get_coor.c */
