[GRASS-SVN] r32580 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Aug 6 13:55:58 EDT 2008
Author: martinl
Date: 2008-08-06 13:55:58 -0400 (Wed, 06 Aug 2008)
New Revision: 32580
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
wxGUI/vdigit: error message cosmetics, define default units (for XY location)
merge from devbr6, r32579
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-08-06 17:51:37 UTC (rev 32579)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-08-06 17:55:58 UTC (rev 32580)
@@ -100,14 +100,14 @@
"""Exception raised during digitization session"""
def __init__(self, message, parent=None):
GException.__init__(self, message,
- title=_("Error in digitization tool"),
+ title=_("Vector digitizer error"),
parent=parent)
class DBMError(GException):
"""Attribute Table Manager exception class"""
- title=_("Error in Attribute Table Manager"),
+ title=_("Attribute table manager error"),
parent=parent)
class NvizError(GException):
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-08-06 17:51:37 UTC (rev 32579)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-08-06 17:55:58 UTC (rev 32580)
@@ -691,6 +691,7 @@
projinfo[key] = val
elif "XY location (unprojected)" in line:
projinfo['proj'] = "xy"
+ projinfo['units'] = ''
return projinfo
else:
return None
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-08-06 17:51:37 UTC (rev 32579)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-08-06 17:55:58 UTC (rev 32580)
@@ -21,6 +21,7 @@
- VDigitCategoryDialog
- VDigitZBulkDialog
- VDigitDuplicatesDialog
+ - VDigitVBuildDialog
(C) 2007-2008 by the GRASS Development Team
@@ -146,14 +147,18 @@
if map and ret == -1:
raise gcmd.DigitError(parent=self.mapWindow.parent,
- message=_('Unable to open vector map <%s> for editing. '
+ message=_('Unable to open vector map <%s> for editing.\n\n'
'Data are probably corrupted, '
- 'try to run v.build for rebuilding the topology.') % map)
+ 'try to run v.build to rebuild '
+ 'the topology (Vector->Develop vector map->'
+ 'Create/rebuild topology).') % map)
if not map and ret != 0:
if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') != 'v.edit':
try:
