[GRASS-SVN] r32582 - grass/trunk/lib/external/shapelib
svn_grass at osgeo.org
Wed Aug 6 15:37:35 EDT 2008
Author: neteler
Date: 2008-08-06 15:37:34 -0400 (Wed, 06 Aug 2008)
New Revision: 32582
grass/trunk/lib/external/shapelib/dbfopen.c
grass/trunk/lib/external/shapelib/safileio.c
grass/trunk/lib/external/shapelib/shapefil.h
grass/trunk/lib/external/shapelib/shpopen.c
reverted indentation of external library
Modified: grass/trunk/lib/external/shapelib/dbfopen.c
--- grass/trunk/lib/external/shapelib/dbfopen.c 2008-08-06 19:30:45 UTC (rev 32581)
+++ grass/trunk/lib/external/shapelib/dbfopen.c 2008-08-06 19:37:34 UTC (rev 32582)
@@ -1,4 +1,3 @@
* $Id$
@@ -113,24 +112,26 @@
#include <string.h>
SHP_CVSID("$Id$")
#ifndef FALSE
# define FALSE 0
# define TRUE 1
#endif
- /* SfRealloc() */
- /* A realloc cover function that will access a NULL pointer as */
- /* a valid input. */
+/* SfRealloc() */
+/* A realloc cover function that will access a NULL pointer as */
+/* a valid input. */
- static void *SfRealloc(void *pMem, int nNewSize)
+static void * SfRealloc( void * pMem, int nNewSize )
- if (pMem == NULL)
- return ((void *)malloc(nNewSize));
+ if( pMem == NULL )
+ return( (void *) malloc(nNewSize) );
else
- return ((void *)realloc(pMem, nNewSize));
+ return( (void *) realloc(pMem,nNewSize) );
@@ -140,57 +141,58 @@
/* descriptions before writing any actual data records. This */
/* also computes all the DBFDataSet field offset/size/decimals */
/* and so forth values. */
static void DBFWriteHeader(DBFHandle psDBF)
- unsigned char abyHeader[XBASE_FLDHDR_SZ];
- int i;
+ unsigned char abyHeader[XBASE_FLDHDR_SZ];
+ int i;
- if (!psDBF->bNoHeader)
- return;
+ if( !psDBF->bNoHeader )
+ return;
psDBF->bNoHeader = FALSE;
- /* Initialize the file header information. */
- for (i = 0; i < XBASE_FLDHDR_SZ; i++)
- abyHeader[i] = 0;
+/* Initialize the file header information. */
+ for( i = 0; i < XBASE_FLDHDR_SZ; i++ )
+ abyHeader[i] = 0;
- abyHeader[0] = 0x03; /* memo field? - just copying */
+ abyHeader[0] = 0x03; /* memo field? - just copying */
/* write out a dummy date */
- abyHeader[1] = 95; /* YY */
- abyHeader[2] = 7; /* MM */
- abyHeader[3] = 26; /* DD */
+ abyHeader[1] = 95; /* YY */
+ abyHeader[2] = 7; /* MM */
+ abyHeader[3] = 26; /* DD */
/* record count preset at zero */
- abyHeader[8] = (unsigned char)(psDBF->nHeaderLength % 256);
- abyHeader[9] = (unsigned char)(psDBF->nHeaderLength / 256);
+ abyHeader[8] = (unsigned char) (psDBF->nHeaderLength % 256);
+ abyHeader[9] = (unsigned char) (psDBF->nHeaderLength / 256);
+ abyHeader[10] = (unsigned char) (psDBF->nRecordLength % 256);
+ abyHeader[11] = (unsigned char) (psDBF->nRecordLength / 256);
- abyHeader[10] = (unsigned char)(psDBF->nRecordLength % 256);
- abyHeader[11] = (unsigned char)(psDBF->nRecordLength / 256);
+/* Write the initial 32 byte file header, and all the field */
+/* descriptions. */
+ psDBF->sHooks.FSeek( psDBF->fp, 0, 0 );
+ psDBF->sHooks.FWrite( abyHeader, XBASE_FLDHDR_SZ, 1, psDBF->fp );
+ psDBF->sHooks.FWrite( psDBF->pszHeader, XBASE_FLDHDR_SZ, psDBF->nFields,
+ psDBF->fp );
- /* Write the initial 32 byte file header, and all the field */
- /* descriptions. */
- psDBF->sHooks.FSeek(psDBF->fp, 0, 0);
- psDBF->sHooks.FWrite(abyHeader, XBASE_FLDHDR_SZ, 1, psDBF->fp);
- psDBF->sHooks.FWrite(psDBF->pszHeader, XBASE_FLDHDR_SZ, psDBF->nFields,
- psDBF->fp);
+/* Write out the newline character if there is room for it. */
+ if( psDBF->nHeaderLength > 32*psDBF->nFields + 32 )
+ char cNewline;
- /* Write out the newline character if there is room for it. */
- if (psDBF->nHeaderLength > 32 * psDBF->nFields + 32) {
- char cNewline;
- cNewline = 0x0d;
- psDBF->sHooks.FWrite(&cNewline, 1, 1, psDBF->fp);
+ cNewline = 0x0d;
+ psDBF->sHooks.FWrite( &cNewline, 1, 1, psDBF->fp );
@@ -198,33 +200,36 @@
/* DBFFlushRecord() */
/* Write out the current record if there is one. */
-static int DBFFlushRecord(DBFHandle psDBF)
+static int DBFFlushRecord( DBFHandle psDBF )
- SAOffset nRecordOffset;
+ SAOffset nRecordOffset;
- if (psDBF->bCurrentRecordModified && psDBF->nCurrentRecord > -1) {
+ if( psDBF->bCurrentRecordModified && psDBF->nCurrentRecord > -1 )
psDBF->bCurrentRecordModified = FALSE;
- nRecordOffset =
- psDBF->nRecordLength * (SAOffset) psDBF->nCurrentRecord
- + psDBF->nHeaderLength;
+ nRecordOffset =
+ psDBF->nRecordLength * (SAOffset) psDBF->nCurrentRecord
+ + psDBF->nHeaderLength;
- if (psDBF->sHooks.FSeek(psDBF->fp, nRecordOffset, 0) != 0
- || psDBF->sHooks.FWrite(psDBF->pszCurrentRecord,
- psDBF->nRecordLength,
- 1, psDBF->fp) != 1) {
+ if( psDBF->sHooks.FSeek( psDBF->fp, nRecordOffset, 0 ) != 0
+ || psDBF->sHooks.FWrite( psDBF->pszCurrentRecord,
+ psDBF->nRecordLength,
+ 1, psDBF->fp ) != 1 )
#ifdef USE_CPL
- CPLError(CE_Failure, CPLE_FileIO,
- "Failure writing DBF record %d.", psDBF->nCurrentRecord);
-#else
- fprintf(stderr, "Failure writing DBF record %d.",
- psDBF->nCurrentRecord);
+ CPLError( CE_Failure, CPLE_FileIO,
+ "Failure writing DBF record %d.",
+ psDBF->nCurrentRecord );
+#else
+ fprintf( stderr, "Failure writing DBF record %d.",
#endif
- return FALSE;
+ return FALSE;
return TRUE;
@@ -232,42 +237,47 @@
/* DBFLoadRecord() */
-static int DBFLoadRecord(DBFHandle psDBF, int iRecord)
+static int DBFLoadRecord( DBFHandle psDBF, int iRecord )
- if (psDBF->nCurrentRecord != iRecord) {
+ if( psDBF->nCurrentRecord != iRecord )
- if (!DBFFlushRecord(psDBF))
- return FALSE;
+ if( !DBFFlushRecord( psDBF ) )
+ return FALSE;
- nRecordOffset =
- psDBF->nRecordLength * (SAOffset) iRecord + psDBF->nHeaderLength;
+ nRecordOffset =
+ psDBF->nRecordLength * (SAOffset) iRecord + psDBF->nHeaderLength;
- if (psDBF->sHooks.FSeek(psDBF->fp, nRecordOffset, SEEK_SET) != 0) {
+ if( psDBF->sHooks.FSeek( psDBF->fp, nRecordOffset, SEEK_SET ) != 0 )
#ifdef USE_CPL
- "fseek(%ld) failed on DBF file.\n", (long)nRecordOffset);
+ "fseek(%ld) failed on DBF file.\n",
+ (long) nRecordOffset );
#else
- fprintf(stderr, "fseek(%ld) failed on DBF file.\n",
- (long)nRecordOffset);
+ fprintf( stderr, "fseek(%ld) failed on DBF file.\n",
#endif
- return FALSE;
+ return FALSE;
- if (psDBF->sHooks.FRead(psDBF->pszCurrentRecord,
- psDBF->nRecordLength, 1, psDBF->fp) != 1) {
+ if( psDBF->sHooks.FRead( psDBF->pszCurrentRecord,
+ psDBF->nRecordLength, 1, psDBF->fp ) != 1 )
#ifdef USE_CPL
- "fread(%d) failed on DBF file.\n", psDBF->nRecordLength);
+ "fread(%d) failed on DBF file.\n",
+ psDBF->nRecordLength );
#else
- fprintf(stderr, "fread(%d) failed on DBF file.\n",
- psDBF->nRecordLength);
+ fprintf( stderr, "fread(%d) failed on DBF file.\n",
#endif
- return FALSE;
+ return FALSE;
psDBF->nCurrentRecord = iRecord;
@@ -277,314 +287,323 @@
/* DBFUpdateHeader() */
-void SHPAPI_CALL DBFUpdateHeader(DBFHandle psDBF)
+void SHPAPI_CALL
+DBFUpdateHeader( DBFHandle psDBF )
- unsigned char abyFileHeader[32];
+ unsigned char abyFileHeader[32];
- if (psDBF->bNoHeader)
- DBFWriteHeader(psDBF);
+ if( psDBF->bNoHeader )
+ DBFWriteHeader( psDBF );
- DBFFlushRecord(psDBF);
+ DBFFlushRecord( psDBF );
- psDBF->sHooks.FRead(abyFileHeader, 32, 1, psDBF->fp);
+ psDBF->sHooks.FRead( abyFileHeader, 32, 1, psDBF->fp );
+ abyFileHeader[4] = (unsigned char) (psDBF->nRecords % 256);
+ abyFileHeader[5] = (unsigned char) ((psDBF->nRecords/256) % 256);
+ abyFileHeader[6] = (unsigned char) ((psDBF->nRecords/(256*256)) % 256);
+ abyFileHeader[7] = (unsigned char) ((psDBF->nRecords/(256*256*256)) % 256);
+ psDBF->sHooks.FWrite( abyFileHeader, 32, 1, psDBF->fp );
- abyFileHeader[4] = (unsigned char)(psDBF->nRecords % 256);
- abyFileHeader[5] = (unsigned char)((psDBF->nRecords / 256) % 256);
- abyFileHeader[6] = (unsigned char)((psDBF->nRecords / (256 * 256)) % 256);
- abyFileHeader[7] =
- (unsigned char)((psDBF->nRecords / (256 * 256 * 256)) % 256);
- psDBF->sHooks.FWrite(abyFileHeader, 32, 1, psDBF->fp);
- psDBF->sHooks.FFlush(psDBF->fp);
+ psDBF->sHooks.FFlush( psDBF->fp );
/* DBFOpen() */
/* Open a .dbf file. */
+DBFHandle SHPAPI_CALL
+DBFOpen( const char * pszFilename, const char * pszAccess )
-DBFHandle SHPAPI_CALL DBFOpen(const char *pszFilename, const char *pszAccess)
SAHooks sHooks;
- SASetupDefaultHooks(&sHooks);
+ SASetupDefaultHooks( &sHooks );
- return DBFOpenLL(pszFilename, pszAccess, &sHooks);
+ return DBFOpenLL( pszFilename, pszAccess, &sHooks );
/* DBFOpen() */
+DBFOpenLL( const char * pszFilename, const char * pszAccess, SAHooks *psHooks )
-DBFOpenLL(const char *pszFilename, const char *pszAccess, SAHooks * psHooks)
- DBFHandle psDBF;
- unsigned char *pabyBuf;
- int nFields, nHeadLen, iField, i;
- char *pszBasename, *pszFullname;
+ DBFHandle psDBF;
+ unsigned char *pabyBuf;
+ int nFields, nHeadLen, iField, i;
+ char *pszBasename, *pszFullname;
- /* We only allow the access strings "rb" and "r+". */
- if (strcmp(pszAccess, "r") != 0 && strcmp(pszAccess, "r+") != 0
- && strcmp(pszAccess, "rb") != 0 && strcmp(pszAccess, "rb+") != 0
- && strcmp(pszAccess, "r+b") != 0)
- return (NULL);
+/* We only allow the access strings "rb" and "r+". */
+ if( strcmp(pszAccess,"r") != 0 && strcmp(pszAccess,"r+") != 0
+ && strcmp(pszAccess,"rb") != 0 && strcmp(pszAccess,"rb+") != 0
+ && strcmp(pszAccess,"r+b") != 0 )
+ return( NULL );
- if (strcmp(pszAccess, "r") == 0)
- pszAccess = "rb";
+ if( strcmp(pszAccess,"r") == 0 )
+ pszAccess = "rb";
+ if( strcmp(pszAccess,"r+") == 0 )
+ pszAccess = "rb+";
- if (strcmp(pszAccess, "r+") == 0)
- pszAccess = "rb+";
- /* Compute the base (layer) name. If there is any extension */
- /* on the passed in filename we will strip it off. */
- pszBasename = (char *)malloc(strlen(pszFilename) + 5);
- strcpy(pszBasename, pszFilename);
- for (i = strlen(pszBasename) - 1;
+/* Compute the base (layer) name. If there is any extension */
+/* on the passed in filename we will strip it off. */
+ pszBasename = (char *) malloc(strlen(pszFilename)+5);
+ strcpy( pszBasename, pszFilename );
+ for( i = strlen(pszBasename)-1;
i > 0 && pszBasename[i] != '.' && pszBasename[i] != '/'
- && pszBasename[i] != '\\'; i--) {
+ && pszBasename[i] != '\\';
+ i-- ) {}
- if (pszBasename[i] == '.')
- pszBasename[i] = '\0';
+ if( pszBasename[i] == '.' )
+ pszBasename[i] = '\0';
- pszFullname = (char *)malloc(strlen(pszBasename) + 5);
- sprintf(pszFullname, "%s.dbf", pszBasename);
+ pszFullname = (char *) malloc(strlen(pszBasename) + 5);
+ sprintf( pszFullname, "%s.dbf", pszBasename );
+ psDBF = (DBFHandle) calloc( 1, sizeof(DBFInfo) );
+ psDBF->fp = psHooks->FOpen( pszFullname, pszAccess );
+ memcpy( &(psDBF->sHooks), psHooks, sizeof(SAHooks) );
- psDBF = (DBFHandle) calloc(1, sizeof(DBFInfo));
- psDBF->fp = psHooks->FOpen(pszFullname, pszAccess);
- memcpy(&(psDBF->sHooks), psHooks, sizeof(SAHooks));
- if (psDBF->fp == NULL) {
- sprintf(pszFullname, "%s.DBF", pszBasename);
- psDBF->fp = psDBF->sHooks.FOpen(pszFullname, pszAccess);
+ if( psDBF->fp == NULL )
+ sprintf( pszFullname, "%s.DBF", pszBasename );
+ psDBF->fp = psDBF->sHooks.FOpen(pszFullname, pszAccess );
- free(pszBasename);
- free(pszFullname);
- free(psDBF);
- return (NULL);
+ free( pszBasename );
+ free( pszFullname );
+ free( psDBF );
+ return( NULL );
psDBF->nCurrentRecord = -1;
- /* Read Table Header info */
- pabyBuf = (unsigned char *)malloc(500);
- if (psDBF->sHooks.FRead(pabyBuf, 32, 1, psDBF->fp) != 1) {
- psDBF->sHooks.FClose(psDBF->fp);
- free(pabyBuf);
- free(psDBF);
- return NULL;
+/* Read Table Header info */
+ pabyBuf = (unsigned char *) malloc(500);
+ if( psDBF->sHooks.FRead( pabyBuf, 32, 1, psDBF->fp ) != 1 )
+ psDBF->sHooks.FClose( psDBF->fp );
+ free( pabyBuf );
+ free( psDBF );
+ return NULL;
- psDBF->nRecords =
- pabyBuf[4] + pabyBuf[5] * 256 + pabyBuf[6] * 256 * 256 +
- pabyBuf[7] * 256 * 256 * 256;
+ psDBF->nRecords =
+ pabyBuf[4] + pabyBuf[5]*256 + pabyBuf[6]*256*256 + pabyBuf[7]*256*256*256;
- psDBF->nHeaderLength = nHeadLen = pabyBuf[8] + pabyBuf[9] * 256;
- psDBF->nRecordLength = pabyBuf[10] + pabyBuf[11] * 256;
+ psDBF->nHeaderLength = nHeadLen = pabyBuf[8] + pabyBuf[9]*256;
+ psDBF->nRecordLength = pabyBuf[10] + pabyBuf[11]*256;
psDBF->nFields = nFields = (nHeadLen - 32) / 32;
- psDBF->pszCurrentRecord = (char *)malloc(psDBF->nRecordLength);
+ psDBF->pszCurrentRecord = (char *) malloc(psDBF->nRecordLength);
- /* Read in Field Definitions */
+/* Read in Field Definitions */
+ pabyBuf = (unsigned char *) SfRealloc(pabyBuf,nHeadLen);
+ psDBF->pszHeader = (char *) pabyBuf;
- pabyBuf = (unsigned char *)SfRealloc(pabyBuf, nHeadLen);
- psDBF->pszHeader = (char *)pabyBuf;
- psDBF->sHooks.FSeek(psDBF->fp, 32, 0);
- if (psDBF->sHooks.FRead(pabyBuf, nHeadLen - 32, 1, psDBF->fp) != 1) {
- free(pabyBuf);
- free(psDBF->pszCurrentRecord);
- free(psDBF);
- return NULL;
+ psDBF->sHooks.FSeek( psDBF->fp, 32, 0 );
+ if( psDBF->sHooks.FRead( pabyBuf, nHeadLen-32, 1, psDBF->fp ) != 1 )
+ free( pabyBuf );
+ free( psDBF->pszCurrentRecord );
+ free( psDBF );
+ return NULL;
- psDBF->panFieldOffset = (int *)malloc(sizeof(int) * nFields);
- psDBF->panFieldSize = (int *)malloc(sizeof(int) * nFields);
- psDBF->panFieldDecimals = (int *)malloc(sizeof(int) * nFields);
- psDBF->pachFieldType = (char *)malloc(sizeof(char) * nFields);
+ psDBF->panFieldOffset = (int *) malloc(sizeof(int) * nFields);
+ psDBF->panFieldSize = (int *) malloc(sizeof(int) * nFields);
+ psDBF->panFieldDecimals = (int *) malloc(sizeof(int) * nFields);
+ psDBF->pachFieldType = (char *) malloc(sizeof(char) * nFields);
- for (iField = 0; iField < nFields; iField++) {
- unsigned char *pabyFInfo;
+ for( iField = 0; iField < nFields; iField++ )
+ unsigned char *pabyFInfo;
- pabyFInfo = pabyBuf + iField * 32;
+ pabyFInfo = pabyBuf+iField*32;
- if (pabyFInfo[11] == 'N' || pabyFInfo[11] == 'F') {
+ if( pabyFInfo[11] == 'N' || pabyFInfo[11] == 'F' )
psDBF->panFieldSize[iField] = pabyFInfo[16];
psDBF->panFieldDecimals[iField] = pabyFInfo[17];
- else {
+ else
psDBF->panFieldDecimals[iField] = 0;
- ** The following seemed to be used sometimes to handle files with long
- ** string fields, but in other cases (such as bug 1202) the decimals field
- ** just seems to indicate some sort of preferred formatting, not very
- ** wide fields. So I have disabled this code. FrankW.
- psDBF->panFieldSize[iField] = pabyFInfo[16] + pabyFInfo[17]*256;
- psDBF->panFieldDecimals[iField] = 0;
+** The following seemed to be used sometimes to handle files with long
+** string fields, but in other cases (such as bug 1202) the decimals field
+** just seems to indicate some sort of preferred formatting, not very
+** wide fields. So I have disabled this code. FrankW.
+ psDBF->panFieldSize[iField] = pabyFInfo[16] + pabyFInfo[17]*256;
+ psDBF->panFieldDecimals[iField] = 0;
- psDBF->pachFieldType[iField] = (char)pabyFInfo[11];
- if (iField == 0)
+ psDBF->pachFieldType[iField] = (char) pabyFInfo[11];
+ if( iField == 0 )
psDBF->panFieldOffset[iField] = 1;
else
- psDBF->panFieldOffset[iField] =
- psDBF->panFieldOffset[iField - 1] +
- psDBF->panFieldSize[iField - 1];
+ psDBF->panFieldOffset[iField] =
+ psDBF->panFieldOffset[iField-1] + psDBF->panFieldSize[iField-1];
- return (psDBF);
+ return( psDBF );
/* DBFClose() */
-void SHPAPI_CALL DBFClose(DBFHandle psDBF)
+void SHPAPI_CALL
+DBFClose(DBFHandle psDBF)
- /* Write out header if not already written. */
+/* Write out header if not already written. */
- /* Update last access date, and number of records if we have */
- /* write access. */
- if (psDBF->bUpdated)
- DBFUpdateHeader(psDBF);
+/* Update last access date, and number of records if we have */
+/* write access. */
+ if( psDBF->bUpdated )
+ DBFUpdateHeader( psDBF );
- /* Close, and free resources. */
+/* Close, and free resources. */
- if (psDBF->panFieldOffset != NULL) {
- free(psDBF->panFieldOffset);
- free(psDBF->panFieldSize);
- free(psDBF->panFieldDecimals);
- free(psDBF->pachFieldType);
+ if( psDBF->panFieldOffset != NULL )
+ free( psDBF->panFieldOffset );
+ free( psDBF->panFieldSize );
+ free( psDBF->panFieldDecimals );
+ free( psDBF->pachFieldType );
- if (psDBF->pszWorkField != NULL)
- free(psDBF->pszWorkField);
+ if( psDBF->pszWorkField != NULL )
+ free( psDBF->pszWorkField );
- free(psDBF->pszHeader);
+ free( psDBF->pszHeader );
- free(psDBF);
+ free( psDBF );
/* DBFCreate() */
/* Create a new .dbf file. */
-DBFHandle SHPAPI_CALL DBFCreate(const char *pszFilename)
+DBFCreate( const char * pszFilename )
SAHooks sHooks;
- return DBFCreateLL(pszFilename, &sHooks);
+ return DBFCreateLL( pszFilename, &sHooks );
/* DBFCreate() */
-DBFHandle SHPAPI_CALL DBFCreateLL(const char *pszFilename, SAHooks * psHooks)
+DBFCreateLL( const char * pszFilename, SAHooks *psHooks )
- DBFHandle psDBF;
- SAFile fp;
- char *pszFullname, *pszBasename;
- int i;
+ DBFHandle psDBF;
+ SAFile fp;
+ char *pszFullname, *pszBasename;
+ int i;
char chZero = '\0';
+ i-- ) {}
- /* Create the file. */
- fp = psHooks->FOpen(pszFullname, "wb");
- if (fp == NULL)
- return (NULL);
+/* Create the file. */
+ fp = psHooks->FOpen( pszFullname, "wb" );
+ if( fp == NULL )
+ return( NULL );
+ psHooks->FWrite( &chZero, 1, 1, fp );
+ psHooks->FClose( fp );
- psHooks->FWrite(&chZero, 1, 1, fp);
- psHooks->FClose(fp);
+ fp = psHooks->FOpen( pszFullname, "rb+" );
+ if( fp == NULL )
+ return( NULL );
- fp = psHooks->FOpen(pszFullname, "rb+");
- if (fp == NULL)
- return (NULL);
+/* Create the info structure. */
+ psDBF = (DBFHandle) calloc(1,sizeof(DBFInfo));
- /* Create the info structure. */
psDBF->fp = fp;
psDBF->nRecords = 0;
psDBF->nFields = 0;
psDBF->nRecordLength = 1;
psDBF->nHeaderLength = 33;
psDBF->panFieldOffset = NULL;
psDBF->panFieldSize = NULL;
psDBF->panFieldDecimals = NULL;
@@ -597,7 +616,7 @@
psDBF->bNoHeader = TRUE;
- return (psDBF);
+ return( psDBF );
@@ -605,24 +624,24 @@
/* Add a field to a newly created .dbf file before any records */
/* are written. */
int SHPAPI_CALL
-DBFAddField(DBFHandle psDBF, const char *pszFieldName,
- DBFFieldType eType, int nWidth, int nDecimals)
+DBFAddField(DBFHandle psDBF, const char * pszFieldName,
+ DBFFieldType eType, int nWidth, int nDecimals )
char chNativeType = 'C';
- if (eType == FTLogical)
- chNativeType = 'L';
- else if (eType == FTString)
- chNativeType = 'C';
+ if( eType == FTLogical )
+ chNativeType = 'L';
+ else if( eType == FTString )
+ chNativeType = 'C';
else
- chNativeType = 'N';
+ chNativeType = 'N';
- return DBFAddNativeFieldType(psDBF, pszFieldName, chNativeType,
- nWidth, nDecimals);
+ return DBFAddNativeFieldType( psDBF, pszFieldName, chNativeType,
+ nWidth, nDecimals );
@@ -630,245 +649,249 @@
/* are written. */
int SHPAPI_CALL
-DBFAddNativeFieldType(DBFHandle psDBF, const char *pszFieldName,
- char chType, int nWidth, int nDecimals)
+DBFAddNativeFieldType(DBFHandle psDBF, const char * pszFieldName,
+ char chType, int nWidth, int nDecimals )
- char *pszFInfo;
- int i;
+ char *pszFInfo;
+ int i;
- /* Do some checking to ensure we can add records to this file. */
- if (psDBF->nRecords > 0)
- return (-1);
+/* Do some checking to ensure we can add records to this file. */
+ if( psDBF->nRecords > 0 )
+ return( -1 );
- return (-1);
+ return( -1 );
- if (nWidth < 1)
- return -1;
+ if( nWidth < 1 )
+ return -1;
- if (nWidth > 255)
- nWidth = 255;
+ if( nWidth > 255 )
+ nWidth = 255;
- /* SfRealloc all the arrays larger to hold the additional field */
- /* information. */
+/* SfRealloc all the arrays larger to hold the additional field */
+/* information. */
psDBF->nFields++;
- SfRealloc(psDBF->panFieldOffset, sizeof(int) * psDBF->nFields);
+ SfRealloc( psDBF->panFieldOffset, sizeof(int) * psDBF->nFields );
- SfRealloc(psDBF->panFieldSize, sizeof(int) * psDBF->nFields);
+ SfRealloc( psDBF->panFieldSize, sizeof(int) * psDBF->nFields );
- SfRealloc(psDBF->panFieldDecimals, sizeof(int) * psDBF->nFields);
+ SfRealloc( psDBF->panFieldDecimals, sizeof(int) * psDBF->nFields );
- SfRealloc(psDBF->pachFieldType, sizeof(char) * psDBF->nFields);
+ SfRealloc( psDBF->pachFieldType, sizeof(char) * psDBF->nFields );
- /* Assign the new field information fields. */
- psDBF->panFieldOffset[psDBF->nFields - 1] = psDBF->nRecordLength;
+/* Assign the new field information fields. */
+ psDBF->panFieldOffset[psDBF->nFields-1] = psDBF->nRecordLength;
psDBF->nRecordLength += nWidth;
- psDBF->panFieldSize[psDBF->nFields - 1] = nWidth;
- psDBF->panFieldDecimals[psDBF->nFields - 1] = nDecimals;
- psDBF->pachFieldType[psDBF->nFields - 1] = chType;
+ psDBF->panFieldSize[psDBF->nFields-1] = nWidth;
+ psDBF->panFieldDecimals[psDBF->nFields-1] = nDecimals;
+ psDBF->pachFieldType[psDBF->nFields-1] = chType;
- /* Extend the required header information. */
+/* Extend the required header information. */
psDBF->nHeaderLength += 32;
psDBF->bUpdated = FALSE;
- (char *)SfRealloc(psDBF->pszHeader, psDBF->nFields * 32);
+ psDBF->pszHeader = (char *) SfRealloc(psDBF->pszHeader,psDBF->nFields*32);
- pszFInfo = psDBF->pszHeader + 32 * (psDBF->nFields - 1);
+ pszFInfo = psDBF->pszHeader + 32 * (psDBF->nFields-1);
- for (i = 0; i < 32; i++)
- pszFInfo[i] = '\0';
+ for( i = 0; i < 32; i++ )
+ pszFInfo[i] = '\0';
- if ((int)strlen(pszFieldName) < 10)
- strncpy(pszFInfo, pszFieldName, strlen(pszFieldName));
+ if( (int) strlen(pszFieldName) < 10 )
+ strncpy( pszFInfo, pszFieldName, strlen(pszFieldName));
else
- strncpy(pszFInfo, pszFieldName, 10);
+ strncpy( pszFInfo, pszFieldName, 10);
- pszFInfo[11] = psDBF->pachFieldType[psDBF->nFields - 1];
+ pszFInfo[11] = psDBF->pachFieldType[psDBF->nFields-1];
- if (chType == 'C') {
- pszFInfo[16] = (unsigned char)(nWidth % 256);
- pszFInfo[17] = (unsigned char)(nWidth / 256);
+ if( chType == 'C' )
+ pszFInfo[16] = (unsigned char) (nWidth % 256);
+ pszFInfo[17] = (unsigned char) (nWidth / 256);
- else {
- pszFInfo[16] = (unsigned char)nWidth;
- pszFInfo[17] = (unsigned char)nDecimals;
+ else
+ pszFInfo[16] = (unsigned char) nWidth;
+ pszFInfo[17] = (unsigned char) nDecimals;
+/* Make the current record buffer appropriately larger. */
+ psDBF->pszCurrentRecord = (char *) SfRealloc(psDBF->pszCurrentRecord,
+ psDBF->nRecordLength);
- /* Make the current record buffer appropriately larger. */
- psDBF->pszCurrentRecord = (char *)SfRealloc(psDBF->pszCurrentRecord,
- return (psDBF->nFields - 1);
+ return( psDBF->nFields-1 );
/* DBFReadAttribute() */
/* Read one of the attribute fields of a record. */
static void *DBFReadAttribute(DBFHandle psDBF, int hEntity, int iField,
- char chReqType)
+ char chReqType )
- unsigned char *pabyRec;
- void *pReturnField = NULL;
+ unsigned char *pabyRec;
+ void *pReturnField = NULL;
- /* Verify selection. */
- if (hEntity < 0 || hEntity >= psDBF->nRecords)
- return (NULL);
+/* Verify selection. */
+ if( hEntity < 0 || hEntity >= psDBF->nRecords )
+ return( NULL );
- if (iField < 0 || iField >= psDBF->nFields)
- return (NULL);
+ if( iField < 0 || iField >= psDBF->nFields )
+ return( NULL );
- /* Have we read the record? */
- if (!DBFLoadRecord(psDBF, hEntity))
- return NULL;
+/* Have we read the record? */
+ if( !DBFLoadRecord( psDBF, hEntity ) )
+ return NULL;
- pabyRec = (unsigned char *)psDBF->pszCurrentRecord;
+ pabyRec = (unsigned char *) psDBF->pszCurrentRecord;
- /* Ensure we have room to extract the target field. */
- if (psDBF->panFieldSize[iField] >= psDBF->nWorkFieldLength) {
- psDBF->nWorkFieldLength = psDBF->panFieldSize[iField] + 100;
- if (psDBF->pszWorkField == NULL)
- psDBF->pszWorkField = (char *)malloc(psDBF->nWorkFieldLength);
- else
- psDBF->pszWorkField = (char *)realloc(psDBF->pszWorkField,
- psDBF->nWorkFieldLength);
+/* Ensure we have room to extract the target field. */
+ if( psDBF->panFieldSize[iField] >= psDBF->nWorkFieldLength )
+ psDBF->nWorkFieldLength = psDBF->panFieldSize[iField] + 100;
+ if( psDBF->pszWorkField == NULL )
+ psDBF->pszWorkField = (char *) malloc(psDBF->nWorkFieldLength);
+ else
+ psDBF->pszWorkField = (char *) realloc(psDBF->pszWorkField,
+ psDBF->nWorkFieldLength);
- /* Extract the requested field. */
- strncpy(psDBF->pszWorkField,
- ((const char *)pabyRec) + psDBF->panFieldOffset[iField],
- psDBF->panFieldSize[iField]);
+/* Extract the requested field. */
+ strncpy( psDBF->pszWorkField,
+ ((const char *) pabyRec) + psDBF->panFieldOffset[iField],
+ psDBF->panFieldSize[iField] );
psDBF->pszWorkField[psDBF->panFieldSize[iField]] = '\0';
pReturnField = psDBF->pszWorkField;
- /* Decode the field. */
- if (chReqType == 'N') {
- psDBF->dfDoubleField = atof(psDBF->pszWorkField);
+/* Decode the field. */
+ if( chReqType == 'N' )
+ psDBF->dfDoubleField = atof(psDBF->pszWorkField);
pReturnField = &(psDBF->dfDoubleField);
- /* Should we trim white space off the string attribute value? */
+/* Should we trim white space off the string attribute value? */
#ifdef TRIM_DBF_WHITESPACE
- else {
- char *pchSrc, *pchDst;
+ else
+ char *pchSrc, *pchDst;
- pchDst = pchSrc = psDBF->pszWorkField;
- while (*pchSrc == ' ')
- pchSrc++;
+ pchDst = pchSrc = psDBF->pszWorkField;
+ while( *pchSrc == ' ' )
+ pchSrc++;
- while (*pchSrc != '\0')
- *(pchDst++) = *(pchSrc++);
- *pchDst = '\0';
+ while( *pchSrc != '\0' )
+ *(pchDst++) = *(pchSrc++);
+ *pchDst = '\0';
- while (pchDst != psDBF->pszWorkField && *(--pchDst) == ' ')
- *pchDst = '\0';
+ while( pchDst != psDBF->pszWorkField && *(--pchDst) == ' ' )
+ *pchDst = '\0';
#endif
- return (pReturnField);
+ return( pReturnField );
/* DBFReadIntAttribute() */
/* Read an integer attribute. */
int SHPAPI_CALL
-DBFReadIntegerAttribute(DBFHandle psDBF, int iRecord, int iField)
+DBFReadIntegerAttribute( DBFHandle psDBF, int iRecord, int iField )
- double *pdValue;
+ double *pdValue;
- pdValue = (double *)DBFReadAttribute(psDBF, iRecord, iField, 'N');
+ pdValue = (double *) DBFReadAttribute( psDBF, iRecord, iField, 'N' );
- if (pdValue == NULL)
- return 0;
+ if( pdValue == NULL )
+ return 0;
else
- return ((int)*pdValue);
+ return( (int) *pdValue );
/* DBFReadDoubleAttribute() */
/* Read a double attribute. */
double SHPAPI_CALL
-DBFReadDoubleAttribute(DBFHandle psDBF, int iRecord, int iField)
+DBFReadDoubleAttribute( DBFHandle psDBF, int iRecord, int iField )
- double *pdValue;
+ double *pdValue;
- return 0.0;
+ return 0.0;
else
- return (*pdValue);
+ return( *pdValue );
/* DBFReadStringAttribute() */
/* Read a string attribute. */
const char SHPAPI_CALL1(*)
-DBFReadStringAttribute(DBFHandle psDBF, int iRecord, int iField)
+DBFReadStringAttribute( DBFHandle psDBF, int iRecord, int iField )
- return ((const char *)DBFReadAttribute(psDBF, iRecord, iField, 'C'));
+ return( (const char *) DBFReadAttribute( psDBF, iRecord, iField, 'C' ) );
/* DBFReadLogicalAttribute() */
/* Read a logical attribute. */
-DBFReadLogicalAttribute(DBFHandle psDBF, int iRecord, int iField)
+DBFReadLogicalAttribute( DBFHandle psDBF, int iRecord, int iField )
- return ((const char *)DBFReadAttribute(psDBF, iRecord, iField, 'L'));
+ return( (const char *) DBFReadAttribute( psDBF, iRecord, iField, 'L' ) );
@@ -877,47 +900,50 @@
/* Return TRUE if value for field is NULL. */
/* Contributed by Jim Matthews. */
-int SHPAPI_CALL DBFIsAttributeNULL(DBFHandle psDBF, int iRecord, int iField)
+int SHPAPI_CALL
+DBFIsAttributeNULL( DBFHandle psDBF, int iRecord, int iField )
- const char *pszValue;
+ const char *pszValue;
int i;
- pszValue = DBFReadStringAttribute(psDBF, iRecord, iField);
+ pszValue = DBFReadStringAttribute( psDBF, iRecord, iField );
- if (pszValue == NULL)
- return TRUE;
+ if( pszValue == NULL )
+ return TRUE;
- switch (psDBF->pachFieldType[iField]) {
- case 'N':
- case 'F':
- ** We accept all asterisks or all blanks as NULL
- ** though according to the spec I think it should be all
- ** asterisks.
- if (pszValue[0] == '*')
- return TRUE;
+ switch(psDBF->pachFieldType[iField])
+ case 'N':
+ case 'F':
+ ** We accept all asterisks or all blanks as NULL
+ ** though according to the spec I think it should be all
+ ** asterisks.
+ if( pszValue[0] == '*' )
+ return TRUE;
- for (i = 0; pszValue[i] != '\0'; i++) {
- if (pszValue[i] != ' ')
- return FALSE;
- return TRUE;
+ for( i = 0; pszValue[i] != '\0'; i++ )
+ if( pszValue[i] != ' ' )
+ return FALSE;
+ return TRUE;
- case 'D':
- /* NULL date fields have value "00000000" */
- return strncmp(pszValue, "00000000", 8) == 0;
+ case 'D':
+ /* NULL date fields have value "00000000" */
+ return strncmp(pszValue,"00000000",8) == 0;
- case 'L':
- /* NULL boolean fields have value "?" */
- return pszValue[0] == '?';
+ case 'L':
+ /* NULL boolean fields have value "?" */
+ return pszValue[0] == '?';
- default:
- /* empty string fields are considered NULL */
- return strlen(pszValue) == 0;
+ default:
+ /* empty string fields are considered NULL */
+ return strlen(pszValue) == 0;
@@ -925,219 +951,234 @@
/* DBFGetFieldCount() */
/* Return the number of fields in this table. */
-int SHPAPI_CALL DBFGetFieldCount(DBFHandle psDBF)
+int SHPAPI_CALL
+DBFGetFieldCount( DBFHandle psDBF )
- return (psDBF->nFields);
+ return( psDBF->nFields );
/* DBFGetRecordCount() */
/* Return the number of records in this table. */
-int SHPAPI_CALL DBFGetRecordCount(DBFHandle psDBF)
+int SHPAPI_CALL
+DBFGetRecordCount( DBFHandle psDBF )
- return (psDBF->nRecords);
+ return( psDBF->nRecords );
/* DBFGetFieldInfo() */
/* Return any requested information about the field. */
DBFFieldType SHPAPI_CALL
-DBFGetFieldInfo(DBFHandle psDBF, int iField, char *pszFieldName,
- int *pnWidth, int *pnDecimals)
+DBFGetFieldInfo( DBFHandle psDBF, int iField, char * pszFieldName,
+ int * pnWidth, int * pnDecimals )
- return (FTInvalid);
+ return( FTInvalid );
- if (pnWidth != NULL)
- *pnWidth = psDBF->panFieldSize[iField];
+ if( pnWidth != NULL )
+ *pnWidth = psDBF->panFieldSize[iField];
- if (pnDecimals != NULL)
- *pnDecimals = psDBF->panFieldDecimals[iField];
+ if( pnDecimals != NULL )
+ *pnDecimals = psDBF->panFieldDecimals[iField];
- if (pszFieldName != NULL) {
- int i;
+ if( pszFieldName != NULL )
+ int i;
- strncpy(pszFieldName, (char *)psDBF->pszHeader + iField * 32, 11);
+ strncpy( pszFieldName, (char *) psDBF->pszHeader+iField*32, 11 );
pszFieldName[11] = '\0';
- for (i = 10; i > 0 && pszFieldName[i] == ' '; i--)
+ for( i = 10; i > 0 && pszFieldName[i] == ' '; i-- )
pszFieldName[i] = '\0';
- if (psDBF->pachFieldType[iField] == 'L')
- return (FTLogical);
+ if ( psDBF->pachFieldType[iField] == 'L' )
+ return( FTLogical);
- else if (psDBF->pachFieldType[iField] == 'N'
- || psDBF->pachFieldType[iField] == 'F') {
- if (psDBF->panFieldDecimals[iField] > 0)
- /* || psDBF->panFieldSize[iField] > 10 ) *//* GDAL bug #809 */
- return (FTDouble);
+ else if( psDBF->pachFieldType[iField] == 'N'
+ || psDBF->pachFieldType[iField] == 'F' )
+ if( psDBF->panFieldDecimals[iField] > 0 )
+/* || psDBF->panFieldSize[iField] > 10 ) */ /* GDAL bug #809 */
+ return( FTDouble );
else
- return (FTInteger);
+ return( FTInteger );
- else {
- return (FTString);
+ else
+ return( FTString );
/* DBFWriteAttribute() */
-/* Write an attribute record to the file. */
+/* Write an attribute record to the file. */
static int DBFWriteAttribute(DBFHandle psDBF, int hEntity, int iField,
- void *pValue)
+ void * pValue )
- int i, j, nRetResult = TRUE;
- char szSField[400], szFormat[20];
+ int i, j, nRetResult = TRUE;
+ char szSField[400], szFormat[20];
- /* Is this a valid record? */
- if (hEntity < 0 || hEntity > psDBF->nRecords)
- return (FALSE);
+/* Is this a valid record? */
+ if( hEntity < 0 || hEntity > psDBF->nRecords )
+ return( FALSE );
+ DBFWriteHeader(psDBF);
- /* Is this a brand new record? */
- if (hEntity == psDBF->nRecords) {
- return FALSE;
+/* Is this a brand new record? */
+ if( hEntity == psDBF->nRecords )
+ return FALSE;
psDBF->nRecords++;
- for (i = 0; i < psDBF->nRecordLength; i++)
+ for( i = 0; i < psDBF->nRecordLength; i++ )
psDBF->pszCurrentRecord[i] = ' ';
psDBF->nCurrentRecord = hEntity;
- /* Is this an existing record, but different than the last one */
- /* we accessed? */
- return FALSE;
+/* Is this an existing record, but different than the last one */
+/* we accessed? */
+ return FALSE;
psDBF->bCurrentRecordModified = TRUE;
psDBF->bUpdated = TRUE;
- /* Translate NULL value to valid DBF file representation. */
- /* Contributed by Jim Matthews. */
- if (pValue == NULL) {
- case 'N':
- case 'F':
+/* Translate NULL value to valid DBF file representation. */
+/* Contributed by Jim Matthews. */
+ if( pValue == NULL )
+ case 'N':
+ case 'F':
/* NULL numeric fields have value "****************" */
- memset((char *)(pabyRec + psDBF->panFieldOffset[iField]), '*',
- break;
+ memset( (char *) (pabyRec+psDBF->panFieldOffset[iField]), '*',
+ break;
- case 'D':
+ case 'D':
- memset((char *)(pabyRec + psDBF->panFieldOffset[iField]), '0',
- break;
+ memset( (char *) (pabyRec+psDBF->panFieldOffset[iField]), '0',
+ break;
- case 'L':
- memset((char *)(pabyRec + psDBF->panFieldOffset[iField]), '?',
- break;
+ case 'L':
+ memset( (char *) (pabyRec+psDBF->panFieldOffset[iField]), '?',
+ break;
- default:
- memset((char *)(pabyRec + psDBF->panFieldOffset[iField]), ' ',
- break;
- return TRUE;
+ default:
+ memset( (char *) (pabyRec+psDBF->panFieldOffset[iField]), ' ',
+ break;
+ return TRUE;
- /* Assign all the record fields. */
- case 'D':
- case 'N':
- case 'F':
- if (psDBF->panFieldDecimals[iField] == 0) {
- int nWidth = psDBF->panFieldSize[iField];
+/* Assign all the record fields. */
+ switch( psDBF->pachFieldType[iField] )
+ case 'D':
+ case 'N':
+ case 'F':
+ if( psDBF->panFieldDecimals[iField] == 0 )
+ int nWidth = psDBF->panFieldSize[iField];
- if ((int)sizeof(szSField) - 2 < nWidth)
- nWidth = sizeof(szSField) - 2;
+ if( (int) sizeof(szSField)-2 < nWidth )
+ nWidth = sizeof(szSField)-2;
- sprintf(szFormat, "%%%dd", nWidth);
- sprintf(szSField, szFormat, (int)*((double *)pValue));
- if ((int)strlen(szSField) > psDBF->panFieldSize[iField]) {
- szSField[psDBF->panFieldSize[iField]] = '\0';
- nRetResult = FALSE;
+ sprintf( szFormat, "%%%dd", nWidth );
+ sprintf(szSField, szFormat, (int) *((double *) pValue) );
+ if( (int)strlen(szSField) > psDBF->panFieldSize[iField] )
+ szSField[psDBF->panFieldSize[iField]] = '\0';
+ nRetResult = FALSE;
- strncpy((char *)(pabyRec + psDBF->panFieldOffset[iField]),
- szSField, strlen(szSField));
+ strncpy((char *) (pabyRec+psDBF->panFieldOffset[iField]),
+ szSField, strlen(szSField) );
- else {
+ else
- sprintf(szFormat, "%%%d.%df",
- nWidth, psDBF->panFieldDecimals[iField]);
- sprintf(szSField, szFormat, *((double *)pValue));
+ sprintf( szFormat, "%%%d.%df",
+ nWidth, psDBF->panFieldDecimals[iField] );
+ sprintf(szSField, szFormat, *((double *) pValue) );
+ if( (int) strlen(szSField) > psDBF->panFieldSize[iField] )
break;
- case 'L':
- if (psDBF->panFieldSize[iField] >= 1 &&
- (*(char *)pValue == 'F' || *(char *)pValue == 'T'))
- *(pabyRec + psDBF->panFieldOffset[iField]) = *(char *)pValue;
- break;
+ case 'L':
+ if (psDBF->panFieldSize[iField] >= 1 &&
+ (*(char*)pValue == 'F' || *(char*)pValue == 'T'))
+ *(pabyRec+psDBF->panFieldOffset[iField]) = *(char*)pValue;
+ break;
- default:
- if ((int)strlen((char *)pValue) > psDBF->panFieldSize[iField]) {
+ default:
+ if( (int) strlen((char *) pValue) > psDBF->panFieldSize[iField] )
j = psDBF->panFieldSize[iField];
- else {
- memset(pabyRec + psDBF->panFieldOffset[iField], ' ',
- j = strlen((char *)pValue);
+ else
+ memset( pabyRec+psDBF->panFieldOffset[iField], ' ',
+ j = strlen((char *) pValue);
- (char *)pValue, j);
+ (char *) pValue, j );
break;
- return (nRetResult);
+ return( nRetResult );
@@ -1146,188 +1187,193 @@
/* Write an attribute record to the file, but without any */
/* reformatting based on type. The provided buffer is written */
/* as is to the field position in the record. */
int SHPAPI_CALL
DBFWriteAttributeDirectly(DBFHandle psDBF, int hEntity, int iField,
- void *pValue)
+ void * pValue )
- int i, j;
+ int i, j;
- return (FALSE);
+ return( FALSE );
- return FALSE;
+ return FALSE;
psDBF->nRecords++;
- return FALSE;
+/* we accessed? */
+ return FALSE;
- j = psDBF->panFieldSize[iField];
- else {
+ if( (int)strlen((char *) pValue) > psDBF->panFieldSize[iField] )
+ j = psDBF->panFieldSize[iField];
+ else
- return (TRUE);
+ return( TRUE );
/* DBFWriteDoubleAttribute() */
/* Write a double attribute. */
int SHPAPI_CALL
-DBFWriteDoubleAttribute(DBFHandle psDBF, int iRecord, int iField,
- double dValue)
+DBFWriteDoubleAttribute( DBFHandle psDBF, int iRecord, int iField,
+ double dValue )
- return (DBFWriteAttribute(psDBF, iRecord, iField, (void *)&dValue));
+ return( DBFWriteAttribute( psDBF, iRecord, iField, (void *) &dValue ) );
/* DBFWriteIntegerAttribute() */
/* Write a integer attribute. */
int SHPAPI_CALL
-DBFWriteIntegerAttribute(DBFHandle psDBF, int iRecord, int iField, int nValue)
+DBFWriteIntegerAttribute( DBFHandle psDBF, int iRecord, int iField,
+ int nValue )
- double dValue = nValue;
+ double dValue = nValue;
/* DBFWriteStringAttribute() */
/* Write a string attribute. */
int SHPAPI_CALL
-DBFWriteStringAttribute(DBFHandle psDBF, int iRecord, int iField,
- const char *pszValue)
+DBFWriteStringAttribute( DBFHandle psDBF, int iRecord, int iField,
+ const char * pszValue )
- return (DBFWriteAttribute(psDBF, iRecord, iField, (void *)pszValue));
+ return( DBFWriteAttribute( psDBF, iRecord, iField, (void *) pszValue ) );
/* DBFWriteNULLAttribute() */
int SHPAPI_CALL
-DBFWriteNULLAttribute(DBFHandle psDBF, int iRecord, int iField)
+DBFWriteNULLAttribute( DBFHandle psDBF, int iRecord, int iField )
- return (DBFWriteAttribute(psDBF, iRecord, iField, NULL));
+ return( DBFWriteAttribute( psDBF, iRecord, iField, NULL ) );
/* DBFWriteLogicalAttribute() */
/* Write a logical attribute. */
int SHPAPI_CALL
-DBFWriteLogicalAttribute(DBFHandle psDBF, int iRecord, int iField,
- const char lValue)
+DBFWriteLogicalAttribute( DBFHandle psDBF, int iRecord, int iField,
+ const char lValue)
- return (DBFWriteAttribute(psDBF, iRecord, iField, (void *)(&lValue)));
+ return( DBFWriteAttribute( psDBF, iRecord, iField, (void *) (&lValue) ) );
/* DBFWriteTuple() */
-int SHPAPI_CALL DBFWriteTuple(DBFHandle psDBF, int hEntity, void *pRawTuple)
+int SHPAPI_CALL
+DBFWriteTuple(DBFHandle psDBF, int hEntity, void * pRawTuple )
- int i;
+ int i;
- return (FALSE);
+ return( FALSE );
- return FALSE;
+ return FALSE;
psDBF->nRecords++;
- return FALSE;
+/* we accessed? */
+ return FALSE;
- memcpy(pabyRec, pRawTuple, psDBF->nRecordLength);
+ memcpy ( pabyRec, pRawTuple, psDBF->nRecordLength );
- return (TRUE);
+ return( TRUE );
@@ -1335,64 +1381,60 @@
/* Read a complete record. Note that the result is only valid */
/* till the next record read for any reason. */
-const char SHPAPI_CALL1(*) DBFReadTuple(DBFHandle psDBF, int hEntity)
+const char SHPAPI_CALL1(*)
+DBFReadTuple(DBFHandle psDBF, int hEntity )
- return (NULL);
+ return( NULL );
- return NULL;
+ return NULL;
- return (const char *)psDBF->pszCurrentRecord;
+ return (const char *) psDBF->pszCurrentRecord;
/* DBFCloneEmpty() */
-DBFHandle SHPAPI_CALL DBFCloneEmpty(DBFHandle psDBF, const char *pszFilename)
+DBFCloneEmpty(DBFHandle psDBF, const char * pszFilename )
- DBFHandle newDBF;
+ DBFHandle newDBF;
- newDBF = DBFCreate(pszFilename);
- if (newDBF == NULL)
- return (NULL);
+ newDBF = DBFCreate ( pszFilename );
+ if ( newDBF == NULL ) return ( NULL );
+ newDBF->nFields = psDBF->nFields;
+ newDBF->nRecordLength = psDBF->nRecordLength;
+ newDBF->nHeaderLength = psDBF->nHeaderLength;
+ newDBF->pszHeader = (char *) malloc ( newDBF->nHeaderLength );
+ memcpy ( newDBF->pszHeader, psDBF->pszHeader, newDBF->nHeaderLength );
+ newDBF->panFieldOffset = (int *) malloc ( sizeof(int) * psDBF->nFields );
+ memcpy ( newDBF->panFieldOffset, psDBF->panFieldOffset, sizeof(int) * psDBF->nFields );
+ newDBF->panFieldSize = (int *) malloc ( sizeof(int) * psDBF->nFields );
+ memcpy ( newDBF->panFieldSize, psDBF->panFieldSize, sizeof(int) * psDBF->nFields );
+ newDBF->panFieldDecimals = (int *) malloc ( sizeof(int) * psDBF->nFields );
+ memcpy ( newDBF->panFieldDecimals, psDBF->panFieldDecimals, sizeof(int) * psDBF->nFields );
+ newDBF->pachFieldType = (char *) malloc ( sizeof(char) * psDBF->nFields );
+ memcpy ( newDBF->pachFieldType, psDBF->pachFieldType, sizeof(char)*psDBF->nFields );
- newDBF->nFields = psDBF->nFields;
- newDBF->nRecordLength = psDBF->nRecordLength;
- newDBF->nHeaderLength = psDBF->nHeaderLength;
+ newDBF->bNoHeader = TRUE;
+ newDBF->bUpdated = TRUE;
+ DBFWriteHeader ( newDBF );
+ DBFClose ( newDBF );
+ newDBF = DBFOpen ( pszFilename, "rb+" );
- newDBF->pszHeader = (char *)malloc(newDBF->nHeaderLength);
- memcpy(newDBF->pszHeader, psDBF->pszHeader, newDBF->nHeaderLength);
- newDBF->panFieldOffset = (int *)malloc(sizeof(int) * psDBF->nFields);
- memcpy(newDBF->panFieldOffset, psDBF->panFieldOffset,
- sizeof(int) * psDBF->nFields);
- newDBF->panFieldSize = (int *)malloc(sizeof(int) * psDBF->nFields);
- memcpy(newDBF->panFieldSize, psDBF->panFieldSize,
- newDBF->panFieldDecimals = (int *)malloc(sizeof(int) * psDBF->nFields);
- memcpy(newDBF->panFieldDecimals, psDBF->panFieldDecimals,
- newDBF->pachFieldType = (char *)malloc(sizeof(char) * psDBF->nFields);
- memcpy(newDBF->pachFieldType, psDBF->pachFieldType,
- sizeof(char) * psDBF->nFields);
- newDBF->bNoHeader = TRUE;
- newDBF->bUpdated = TRUE;
- DBFWriteHeader(newDBF);
- DBFClose(newDBF);
- newDBF = DBFOpen(pszFilename, "rb+");
- return (newDBF);
+ return ( newDBF );
@@ -1404,32 +1446,32 @@
/* 'N' (Numeric, with or without decimal), */
/* 'L' (Logical), */
/* 'M' (Memo: 10 digits .DBT block ptr) */
-char SHPAPI_CALL DBFGetNativeFieldType(DBFHandle psDBF, int iField)
+char SHPAPI_CALL
+DBFGetNativeFieldType( DBFHandle psDBF, int iField )
- if (iField >= 0 && iField < psDBF->nFields)
- return psDBF->pachFieldType[iField];
+ if( iField >=0 && iField < psDBF->nFields )
+ return psDBF->pachFieldType[iField];
- return ' ';
+ return ' ';
/* str_to_upper() */
-static void str_to_upper(char *string)
+static void str_to_upper (char *string)
int len;
short i = -1;
- len = strlen(string);
+ len = strlen (string);
while (++i < len)
- if (isalpha(string[i]) && islower(string[i]))
- string[i] = (char)toupper((int)string[i]);
+ if (isalpha(string[i]) && islower(string[i]))
+ string[i] = (char) toupper ((int)string[i]);
@@ -1438,27 +1480,29 @@
/* Get the index number for a field in a .dbf file. */
-int SHPAPI_CALL DBFGetFieldIndex(DBFHandle psDBF, const char *pszFieldName)
+int SHPAPI_CALL
+DBFGetFieldIndex(DBFHandle psDBF, const char *pszFieldName)
- char name[12], name1[12], name2[12];
- int i;
+ char name[12], name1[12], name2[12];
+ int i;
- strncpy(name1, pszFieldName, 11);
+ strncpy(name1, pszFieldName,11);
name1[11] = '\0';
str_to_upper(name1);
- for (i = 0; i < DBFGetFieldCount(psDBF); i++) {
- DBFGetFieldInfo(psDBF, i, name, NULL, NULL);
- strncpy(name2, name, 11);
- str_to_upper(name2);
+ for( i = 0; i < DBFGetFieldCount(psDBF); i++ )
+ DBFGetFieldInfo( psDBF, i, name, NULL, NULL );
+ strncpy(name2,name,11);
+ str_to_upper(name2);
- if (!strncmp(name1, name2, 10))
- return (i);
+ if(!strncmp(name1,name2,10))
+ return(i);
- return (-1);
+ return(-1);
@@ -1466,64 +1510,65 @@
/* Returns TRUE if the indicated record is deleted, otherwise */
/* it returns FALSE. */
-int SHPAPI_CALL DBFIsRecordDeleted(DBFHandle psDBF, int iShape)
+int SHPAPI_CALL DBFIsRecordDeleted( DBFHandle psDBF, int iShape )
- if (iShape < 0 || iShape >= psDBF->nRecords)
- return TRUE;
+ if( iShape < 0 || iShape >= psDBF->nRecords )
+ return TRUE;
- if (!DBFLoadRecord(psDBF, iShape))
- return FALSE;
+ if( !DBFLoadRecord( psDBF, iShape ) )
+ return FALSE;
- /* '*' means deleted. */
+/* '*' means deleted. */
return psDBF->pszCurrentRecord[0] == '*';
/* DBFMarkRecordDeleted() */
-int SHPAPI_CALL DBFMarkRecordDeleted(DBFHandle psDBF, int iShape,
- int bIsDeleted)
+int SHPAPI_CALL DBFMarkRecordDeleted( DBFHandle psDBF, int iShape,
+ int bIsDeleted )
char chNewFlag;
- return FALSE;
+ return FALSE;
- return FALSE;
+/* we accessed? */
+ return FALSE;
- /* Assign value, marking record as dirty if it changes. */
- if (bIsDeleted)
- chNewFlag = '*';
- else
- chNewFlag = ' ';
+/* Assign value, marking record as dirty if it changes. */
+ if( bIsDeleted )
+ chNewFlag = '*';
+ else
+ chNewFlag = ' ';
- if (psDBF->pszCurrentRecord[0] != chNewFlag) {
- psDBF->bCurrentRecordModified = TRUE;
- psDBF->bUpdated = TRUE;
- psDBF->pszCurrentRecord[0] = chNewFlag;
+ if( psDBF->pszCurrentRecord[0] != chNewFlag )
+ psDBF->bCurrentRecordModified = TRUE;
+ psDBF->bUpdated = TRUE;
+ psDBF->pszCurrentRecord[0] = chNewFlag;
return TRUE;
Modified: grass/trunk/lib/external/shapelib/safileio.c
--- grass/trunk/lib/external/shapelib/safileio.c 2008-08-06 19:30:45 UTC (rev 32581)
+++ grass/trunk/lib/external/shapelib/safileio.c 2008-08-06 19:37:34 UTC (rev 32582)
@@ -1,4 +1,3 @@
* $Id: safileio.c,v 1.4 2008/01/16 20:05:14 bram Exp $
@@ -79,110 +78,112 @@
/* SADFOpen() */
-SAFile SADFOpen(const char *pszFilename, const char *pszAccess)
+SAFile SADFOpen( const char *pszFilename, const char *pszAccess )
- return (SAFile) fopen(pszFilename, pszAccess);
+ return (SAFile) fopen( pszFilename, pszAccess );
/* SADFRead() */
-SAOffset SADFRead(void *p, SAOffset size, SAOffset nmemb, SAFile file)
+SAOffset SADFRead( void *p, SAOffset size, SAOffset nmemb, SAFile file )
- return (SAOffset) fread(p, (size_t) size, (size_t) nmemb, (FILE *) file);
+ return (SAOffset) fread( p, (size_t) size, (size_t) nmemb,
+ (FILE *) file );
/* SADFWrite() */
-SAOffset SADFWrite(void *p, SAOffset size, SAOffset nmemb, SAFile file)
+SAOffset SADFWrite( void *p, SAOffset size, SAOffset nmemb, SAFile file )
- return (SAOffset) fwrite(p, (size_t) size, (size_t) nmemb, (FILE *) file);
+ return (SAOffset) fwrite( p, (size_t) size, (size_t) nmemb,
+ (FILE *) file );
/* SADFSeek() */
-SAOffset SADFSeek(SAFile file, SAOffset offset, int whence)
+SAOffset SADFSeek( SAFile file, SAOffset offset, int whence )
- return (SAOffset) fseek((FILE *) file, (long)offset, whence);
+ return (SAOffset) fseek( (FILE *) file, (long) offset, whence );
/* SADFTell() */
-SAOffset SADFTell(SAFile file)
+SAOffset SADFTell( SAFile file )
- return (SAOffset) ftell((FILE *) file);
+ return (SAOffset) ftell( (FILE *) file );
/* SADFFlush() */
-int SADFFlush(SAFile file)
+int SADFFlush( SAFile file )
- return fflush((FILE *) file);
+ return fflush( (FILE *) file );
/* SADFClose() */
-int SADFClose(SAFile file)
+int SADFClose( SAFile file )
- return fclose((FILE *) file);
+ return fclose( (FILE *) file );
/* SADFClose() */
-int SADRemove(const char *filename)
+int SADRemove( const char *filename )
- return remove(filename);
+ return remove( filename );
/* SADError() */
-void SADError(const char *message)
+void SADError( const char *message )
- fprintf(stderr, "%s\n", message);
+ fprintf( stderr, "%s\n", message );
/* SASetupDefaultHooks() */
-void SASetupDefaultHooks(SAHooks * psHooks)
+void SASetupDefaultHooks( SAHooks *psHooks )
- psHooks->FOpen = SADFOpen;
- psHooks->FRead = SADFRead;
- psHooks->FWrite = SADFWrite;
- psHooks->FSeek = SADFSeek;
- psHooks->FTell = SADFTell;
- psHooks->FFlush = SADFFlush;
- psHooks->FClose = SADFClose;
+ psHooks->FOpen = SADFOpen;
+ psHooks->FRead = SADFRead;
+ psHooks->FWrite = SADFWrite;
+ psHooks->FSeek = SADFSeek;
+ psHooks->FTell = SADFTell;
+ psHooks->FFlush = SADFFlush;
+ psHooks->FClose = SADFClose;
- psHooks->Error = SADError;
+ psHooks->Error = SADError;
@@ -192,65 +193,64 @@
/* Utf8ToWideChar */
-const wchar_t *Utf8ToWideChar(const char *pszFilename)
+const wchar_t* Utf8ToWideChar( const char *pszFilename )
int nMulti, nWide;
wchar_t *pwszFileName;
nMulti = strlen(pszFilename) + 1;
- nWide = MultiByteToWideChar(CP_UTF8, 0, pszFilename, nMulti, 0, 0);
- if (nWide == 0) {
- return NULL;
+ nWide = MultiByteToWideChar( CP_UTF8, 0, pszFilename, nMulti, 0, 0);
+ if( nWide == 0 )
+ return NULL;
- pwszFileName = (wchar_t *) malloc(nWide * sizeof(wchar_t));
- if (pwszFileName == NULL) {
- return NULL;
+ pwszFileName = (wchar_t*) malloc(nWide * sizeof(wchar_t));
+ if ( pwszFileName == NULL )
+ return NULL;
- if (MultiByteToWideChar
- (CP_UTF8, 0, pszFilename, nMulti, pwszFileName, nWide) == 0) {
- free(pwszFileName);
- return NULL;
+ if( MultiByteToWideChar( CP_UTF8, 0, pszFilename, nMulti, pwszFileName, nWide ) == 0 )
+ free( pwszFileName );
+ return NULL;
return pwszFileName;
/* SAUtf8WFOpen */
-SAFile SAUtf8WFOpen(const char *pszFilename, const char *pszAccess)
+SAFile SAUtf8WFOpen( const char *pszFilename, const char *pszAccess )
SAFile file = NULL;
const wchar_t *pwszFileName, *pwszAccess;
- pwszFileName = Utf8ToWideChar(pszFilename);
- pwszAccess = Utf8ToWideChar(pszAccess);
- if (pwszFileName != NULL && pwszFileName != NULL) {
- file = (SAFile) _wfopen(pwszFileName, pwszAccess);
+ pwszFileName = Utf8ToWideChar( pszFilename );
+ pwszAccess = Utf8ToWideChar( pszAccess );
+ if( pwszFileName != NULL && pwszFileName != NULL)
+ file = (SAFile) _wfopen( pwszFileName, pwszAccess );
- free((wchar_t *) pwszFileName);
- free((wchar_t *) pwszAccess);
+ free ((wchar_t*) pwszFileName);
+ free ((wchar_t*) pwszAccess);
return file;
/* SAUtf8WRemove() */
-int SAUtf8WRemove(const char *pszFilename)
+int SAUtf8WRemove( const char *pszFilename )
- const wchar_t *pwszFileName = Utf8ToWideChar(pszFilename);
- int rc = -1;
- if (pwszFileName != NULL) {
- rc = _wremove(pwszFileName);
+ const wchar_t *pwszFileName = Utf8ToWideChar( pszFilename );
+ int rc = -1;
+ if( pwszFileName != NULL )
+ rc = _wremove( pwszFileName );
return rc;
@@ -260,26 +260,25 @@
/* SASetupUtf8Hooks() */
-void SASetupUtf8Hooks(SAHooks * psHooks)
+void SASetupUtf8Hooks( SAHooks *psHooks )
-#ifdef SHPAPI_WINDOWS
- psHooks->FOpen = SAUtf8WFOpen;
- psHooks->Remove = SAUtf8WRemove;
+#ifdef SHPAPI_WINDOWS
+ psHooks->FOpen = SAUtf8WFOpen;
+ psHooks->Remove = SAUtf8WRemove;
#else
# error "no implementations of UTF-8 hooks available for this platform"
#endif
- psHooks->Atof = atof;
+ psHooks->Atof = atof;
#endif
Modified: grass/trunk/lib/external/shapelib/shapefil.h
--- grass/trunk/lib/external/shapelib/shapefil.h 2008-08-06 19:30:45 UTC (rev 32581)
+++ grass/trunk/lib/external/shapelib/shapefil.h 2008-08-06 19:37:34 UTC (rev 32582)
@@ -108,57 +108,55 @@
#endif
#ifdef __cplusplus
-extern "C"
+extern "C" {
#endif
- /* Configuration options. */
+/* Configuration options. */
- /* Should the DBFReadStringAttribute() strip leading and */
- /* trailing white space? */
+/* Should the DBFReadStringAttribute() strip leading and */
+/* trailing white space? */
#define TRIM_DBF_WHITESPACE
- /* Should we write measure values to the Multipatch object? */
- /* Reportedly ArcView crashes if we do write it, so for now it */
- /* is disabled. */
+/* Should we write measure values to the Multipatch object? */
+/* Reportedly ArcView crashes if we do write it, so for now it */
+/* is disabled. */
#define DISABLE_MULTIPATCH_MEASURE
+/* SHPAPI_CALL */
+/* The following two macros are present to allow forcing */
+/* various calling conventions on the Shapelib API. */
+/* To force __stdcall conventions (needed to call Shapelib */
+/* from Visual Basic and/or Dephi I believe) the makefile could */
+/* be modified to define: */
+/* /DSHPAPI_CALL=__stdcall */
+/* If it is desired to force export of the Shapelib API without */
+/* using the shapelib.def file, use the following definition. */
+/* /DSHAPELIB_DLLEXPORT */
+/* To get both at once it will be necessary to hack this */
+/* include file to define: */
+/* #define SHPAPI_CALL __declspec(dllexport) __stdcall */
+/* #define SHPAPI_CALL1 __declspec(dllexport) * __stdcall */
+/* The complexity of the situtation is partly caused by the */
+/* peculiar requirement of Visual C++ that __stdcall appear */
+/* after any "*"'s in the return value of a function while the */
+/* __declspec(dllexport) must appear before them. */
- /* SHPAPI_CALL */
- /* The following two macros are present to allow forcing */
- /* various calling conventions on the Shapelib API. */
- /* To force __stdcall conventions (needed to call Shapelib */
- /* from Visual Basic and/or Dephi I believe) the makefile could */
- /* be modified to define: */
- /* /DSHPAPI_CALL=__stdcall */
- /* If it is desired to force export of the Shapelib API without */
- /* using the shapelib.def file, use the following definition. */
- /* /DSHAPELIB_DLLEXPORT */
- /* To get both at once it will be necessary to hack this */
- /* include file to define: */
- /* #define SHPAPI_CALL __declspec(dllexport) __stdcall */
- /* #define SHPAPI_CALL1 __declspec(dllexport) * __stdcall */
- /* The complexity of the situtation is partly caused by the */
- /* peculiar requirement of Visual C++ that __stdcall appear */
- /* after any "*"'s in the return value of a function while the */
- /* __declspec(dllexport) must appear before them. */
#ifdef SHAPELIB_DLLEXPORT
# define SHPAPI_CALL __declspec(dllexport)
# define SHPAPI_CALL1(x) __declspec(dllexport) x
@@ -176,78 +174,74 @@
#ifndef SHPAPI_CALL1
# define SHPAPI_CALL1(x) x SHPAPI_CALL
#endif
- /* Macros for controlling CVSID and ensuring they don't appear */
- /* as unreferenced variables resulting in lots of warnings. */
+/* Macros for controlling CVSID and ensuring they don't appear */
+/* as unreferenced variables resulting in lots of warnings. */
#ifndef DISABLE_CVSID
# define SHP_CVSID(string) static char cpl_cvsid[] = string; \
static char *cvsid_aw() { return( cvsid_aw() ? ((char *) NULL) : cpl_cvsid ); }
#else
#endif
+/* IO/Error hook functions. */
+typedef int *SAFile;
- /* IO/Error hook functions. */
- typedef int *SAFile;
#ifndef SAOffset
- typedef unsigned long SAOffset;
+typedef unsigned long SAOffset;
#endif
- typedef struct
- SAFile(*FOpen) (const char *filename, const char *path);
- SAOffset(*FRead) (void *p, SAOffset size, SAOffset nmemb,
- SAFile file);
- SAOffset(*FWrite) (void *p, SAOffset size, SAOffset nmemb,
- SAFile file);
- SAOffset(*FSeek) (SAFile file, SAOffset offset, int whence);
- SAOffset(*FTell) (SAFile file);
- int (*FFlush) (SAFile file);
- int (*FClose) (SAFile file);
+typedef struct {
+ SAFile (*FOpen) ( const char *filename, const char *path);
+ SAOffset (*FRead) ( void *p, SAOffset size, SAOffset nmemb, SAFile file);
+ SAOffset (*FWrite)( void *p, SAOffset size, SAOffset nmemb, SAFile file);
+ SAOffset (*FSeek) ( SAFile file, SAOffset offset, int whence );
+ SAOffset (*FTell) ( SAFile file );
+ int (*FFlush)( SAFile file );
+ int (*FClose)( SAFile file );
- void (*Error) (const char *message);
- } SAHooks;
+ void (*Error) ( const char *message );
+} SAHooks;
- void SHPAPI_CALL SASetupDefaultHooks(SAHooks * psHooks);
+void SHPAPI_CALL SASetupDefaultHooks( SAHooks *psHooks );
- /* SHP Support. */
+/* SHP Support. */
- typedef struct
- SAHooks sHooks;
+typedef struct
+ SAHooks sHooks;
- SAFile fpSHP;
- SAFile fpSHX;
+ SAFile fpSHP;
+ SAFile fpSHX;
- int nShapeType; /* SHPT_* */
+ int nShapeType; /* SHPT_* */
+ int nFileSize; /* SHP file */
- int nFileSize; /* SHP file */
+ int nRecords;
+ int nMaxRecords;
+ int *panRecOffset;
+ int *panRecSize;
- int nRecords;
- int nMaxRecords;
- int *panRecOffset;
- int *panRecSize;
+ double adBoundsMin[4];
+ double adBoundsMax[4];
- double adBoundsMin[4];
- double adBoundsMax[4];
+ int bUpdated;
- int bUpdated;
+ int nBufSize;
+} SHPInfo;
- int nBufSize;
- } SHPInfo;
+typedef SHPInfo * SHPHandle;
- typedef SHPInfo *SHPHandle;
- /* Shape types (nSHPType) */
+/* Shape types (nSHPType) */
#define SHPT_NULL 0
#define SHPT_POINT 1
#define SHPT_ARC 3
@@ -264,10 +258,10 @@
#define SHPT_MULTIPATCH 31
- /* Part types - everything but SHPT_MULTIPATCH just uses */
- /* SHPP_RING. */
+/* Part types - everything but SHPT_MULTIPATCH just uses */
+/* SHPP_RING. */
#define SHPP_TRISTRIP 0
#define SHPP_TRIFAN 1
@@ -276,277 +270,289 @@
#define SHPP_FIRSTRING 4
#define SHPP_RING 5
- /* SHPObject - represents on shape (without attributes) read */
- /* from the .shp file. */
- typedef struct
- int nSHPType;
+/* SHPObject - represents on shape (without attributes) read */
+/* from the .shp file. */
+typedef struct
+ int nSHPType;
- int nShapeId; /* -1 is unknown/unassigned */
+ int nShapeId; /* -1 is unknown/unassigned */
- int nParts;
- int *panPartStart;
- int *panPartType;
+ int nParts;
+ int *panPartStart;
+ int *panPartType;
+ int nVertices;
+ double *padfX;
+ double *padfY;
+ double *padfZ;
+ double *padfM;
- int nVertices;
- double *padfX;
- double *padfY;
- double *padfZ;
- double *padfM;
+ double dfXMin;
+ double dfYMin;
+ double dfZMin;
+ double dfMMin;
- double dfXMin;
- double dfYMin;
- double dfZMin;
- double dfMMin;
+ double dfXMax;
+ double dfYMax;
+ double dfZMax;
+ double dfMMax;
- double dfXMax;
- double dfYMax;
- double dfZMax;
- double dfMMax;
+ int bMeasureIsUsed;
+} SHPObject;
- int bMeasureIsUsed;
- } SHPObject;
+/* SHP API Prototypes */
- /* SHP API Prototypes */
+/* If pszAccess is read-only, the fpSHX field of the returned structure */
+/* will be NULL as it is not necessary to keep the SHX file open */
+SHPHandle SHPAPI_CALL
+ SHPOpen( const char * pszShapeFile, const char * pszAccess );
+ SHPOpenLL( const char *pszShapeFile, const char *pszAccess,
+ SAHooks *psHooks );
+ SHPCreate( const char * pszShapeFile, int nShapeType );
+ SHPCreateLL( const char * pszShapeFile, int nShapeType,
+void SHPAPI_CALL
+ SHPGetInfo( SHPHandle hSHP, int * pnEntities, int * pnShapeType,
+ double * padfMinBound, double * padfMaxBound );
- /* If pszAccess is read-only, the fpSHX field of the returned structure */
- /* will be NULL as it is not necessary to keep the SHX file open */
- SHPHandle SHPAPI_CALL
- SHPOpen(const char *pszShapeFile, const char *pszAccess);
- SHPOpenLL(const char *pszShapeFile, const char *pszAccess,
- SAHooks * psHooks);
- SHPHandle SHPAPI_CALL SHPCreate(const char *pszShapeFile, int nShapeType);
- SHPCreateLL(const char *pszShapeFile, int nShapeType,
- void SHPAPI_CALL
- SHPGetInfo(SHPHandle hSHP, int *pnEntities, int *pnShapeType,
- double *padfMinBound, double *padfMaxBound);
+SHPObject SHPAPI_CALL1(*)
+ SHPReadObject( SHPHandle hSHP, int iShape );
+int SHPAPI_CALL
+ SHPWriteObject( SHPHandle hSHP, int iShape, SHPObject * psObject );
- SHPObject SHPAPI_CALL1(*)
- SHPReadObject(SHPHandle hSHP, int iShape);
- int SHPAPI_CALL
- SHPWriteObject(SHPHandle hSHP, int iShape, SHPObject * psObject);
+void SHPAPI_CALL
+ SHPDestroyObject( SHPObject * psObject );
+void SHPAPI_CALL
+ SHPComputeExtents( SHPObject * psObject );
+ SHPCreateObject( int nSHPType, int nShapeId, int nParts,
+ const int * panPartStart, const int * panPartType,
+ int nVertices,
+ const double * padfX, const double * padfY,
+ const double * padfZ, const double * padfM );
+ SHPCreateSimpleObject( int nSHPType, int nVertices,
+ const double * padfY,
+ const double * padfZ );
- void SHPAPI_CALL SHPDestroyObject(SHPObject * psObject);
- void SHPAPI_CALL SHPComputeExtents(SHPObject * psObject);
- SHPCreateObject(int nSHPType, int nShapeId, int nParts,
- const int *panPartStart, const int *panPartType,
- int nVertices,
- const double *padfX, const double *padfY,
- const double *padfZ, const double *padfM);
- SHPCreateSimpleObject(int nSHPType, int nVertices,
- const double *padfY, const double *padfZ);
+int SHPAPI_CALL
+ SHPRewindObject( SHPHandle hSHP, SHPObject * psObject );
- int SHPAPI_CALL SHPRewindObject(SHPHandle hSHP, SHPObject * psObject);
+void SHPAPI_CALL SHPClose( SHPHandle hSHP );
+void SHPAPI_CALL SHPWriteHeader( SHPHandle hSHP );
- void SHPAPI_CALL SHPClose(SHPHandle hSHP);
- void SHPAPI_CALL SHPWriteHeader(SHPHandle hSHP);
+ SHPTypeName( int nSHPType );
+ SHPPartTypeName( int nPartType );
- const char SHPAPI_CALL1(*)
- SHPTypeName(int nSHPType);
- SHPPartTypeName(int nPartType);
+/* Shape quadtree indexing API. */
- /* Shape quadtree indexing API. */
- /* this can be two or four for binary or quad tree */
+/* this can be two or four for binary or quad tree */
#define MAX_SUBNODE 4
- /* upper limit of tree levels for automatic estimation */
+/* upper limit of tree levels for automatic estimation */
#define MAX_DEFAULT_TREE_DEPTH 12
- typedef struct shape_tree_node
- /* region covered by this node */
- double adfBoundsMin[4];
- double adfBoundsMax[4];
+typedef struct shape_tree_node
+ /* region covered by this node */
+ double adfBoundsMin[4];
+ double adfBoundsMax[4];
- /* list of shapes stored at this node. The papsShapeObj pointers
- or the whole list can be NULL */
- int nShapeCount;
- int *panShapeIds;
- SHPObject **papsShapeObj;
+ /* list of shapes stored at this node. The papsShapeObj pointers
+ or the whole list can be NULL */
+ int nShapeCount;
+ int *panShapeIds;
+ SHPObject **papsShapeObj;
- int nSubNodes;
- struct shape_tree_node *apsSubNode[MAX_SUBNODE];
+ int nSubNodes;
+ struct shape_tree_node *apsSubNode[MAX_SUBNODE];
+} SHPTreeNode;
- } SHPTreeNode;
+typedef struct
+ SHPHandle hSHP;
+ int nMaxDepth;
+ int nDimension;
+ int nTotalCount;
+ SHPTreeNode *psRoot;
+} SHPTree;
- typedef struct
- SHPHandle hSHP;
+SHPTree SHPAPI_CALL1(*)
+ SHPCreateTree( SHPHandle hSHP, int nDimension, int nMaxDepth,
+ double *padfBoundsMin, double *padfBoundsMax );
+void SHPAPI_CALL
+ SHPDestroyTree( SHPTree * hTree );
- int nMaxDepth;
- int nDimension;
- int nTotalCount;
+int SHPAPI_CALL
+ SHPWriteTree( SHPTree *hTree, const char * pszFilename );
+ SHPReadTree( const char * pszFilename );
- SHPTreeNode *psRoot;
- } SHPTree;
+int SHPAPI_CALL
+ SHPTreeAddObject( SHPTree * hTree, SHPObject * psObject );
+int SHPAPI_CALL
+ SHPTreeAddShapeId( SHPTree * hTree, SHPObject * psObject );
+int SHPAPI_CALL
+ SHPTreeRemoveShapeId( SHPTree * hTree, int nShapeId );
- SHPTree SHPAPI_CALL1(*)
- SHPCreateTree(SHPHandle hSHP, int nDimension, int nMaxDepth,
- double *padfBoundsMin, double *padfBoundsMax);
- void SHPAPI_CALL SHPDestroyTree(SHPTree * hTree);
+void SHPAPI_CALL
+ SHPTreeTrimExtraNodes( SHPTree * hTree );
- int SHPAPI_CALL SHPWriteTree(SHPTree * hTree, const char *pszFilename);
- SHPTree SHPAPI_CALL SHPReadTree(const char *pszFilename);
+int SHPAPI_CALL1(*)
+ SHPTreeFindLikelyShapes( SHPTree * hTree,
+ double * padfBoundsMin,
+ double * padfBoundsMax,
+ int * );
+int SHPAPI_CALL
+ SHPCheckBoundsOverlap( double *, double *, double *, double *, int );
- int SHPAPI_CALL SHPTreeAddObject(SHPTree * hTree, SHPObject * psObject);
- int SHPAPI_CALL SHPTreeAddShapeId(SHPTree * hTree, SHPObject * psObject);
- int SHPAPI_CALL SHPTreeRemoveShapeId(SHPTree * hTree, int nShapeId);
+SHPSearchDiskTree( FILE *fp,
+ double *padfBoundsMin, double *padfBoundsMax,
+ int *pnShapeCount );
- void SHPAPI_CALL SHPTreeTrimExtraNodes(SHPTree * hTree);
- int SHPAPI_CALL1(*)
- SHPTreeFindLikelyShapes(SHPTree * hTree,
- double *padfBoundsMax, int *);
- int SHPAPI_CALL
- SHPCheckBoundsOverlap(double *, double *, double *, double *, int);
- SHPSearchDiskTree(FILE * fp,
- double *padfBoundsMin, double *padfBoundsMax,
- int *pnShapeCount);
- /* DBF Support. */
+/* DBF Support. */
- typedef struct
- SAHooks sHooks;
+typedef struct
+ SAHooks sHooks;
- SAFile fp;
+ SAFile fp;
- int nRecords;
+ int nRecords;
- int nRecordLength;
- int nHeaderLength;
- int nFields;
- int *panFieldOffset;
- int *panFieldSize;
- int *panFieldDecimals;
- char *pachFieldType;
+ int nRecordLength;
+ int nHeaderLength;
+ int nFields;
+ int *panFieldOffset;
+ int *panFieldSize;
+ int *panFieldDecimals;
+ char *pachFieldType;
- char *pszHeader;
+ char *pszHeader;
- int nCurrentRecord;
- int bCurrentRecordModified;
- char *pszCurrentRecord;
+ int nCurrentRecord;
+ int bCurrentRecordModified;
+ char *pszCurrentRecord;
- int nWorkFieldLength;
- char *pszWorkField;
+ int nWorkFieldLength;
+ char *pszWorkField;
+ int bNoHeader;
+ int bUpdated;
- int bNoHeader;
- int bUpdated;
+ double dfDoubleField;
+} DBFInfo;
- double dfDoubleField;
- } DBFInfo;
+typedef DBFInfo * DBFHandle;
- typedef DBFInfo *DBFHandle;
+typedef enum {
+ FTString,
+ FTInteger,
+ FTDouble,
+ FTLogical,
+ FTInvalid
+} DBFFieldType;
- typedef enum
- FTString,
- FTInteger,
- FTDouble,
- FTLogical,
- FTInvalid
- } DBFFieldType;
#define XBASE_FLDHDR_SZ 32
- DBFHandle SHPAPI_CALL
- DBFOpen(const char *pszDBFFile, const char *pszAccess);
- DBFOpenLL(const char *pszDBFFile, const char *pszAccess,
- DBFHandle SHPAPI_CALL DBFCreate(const char *pszDBFFile);
- DBFCreateLL(const char *pszDBFFile, SAHooks * psHooks);
+ DBFOpen( const char * pszDBFFile, const char * pszAccess );
+ DBFOpenLL( const char * pszDBFFile, const char * pszAccess,
+ DBFCreate( const char * pszDBFFile );
+ DBFCreateLL( const char * pszDBFFile, SAHooks *psHooks );
- int SHPAPI_CALL DBFGetFieldCount(DBFHandle psDBF);
- int SHPAPI_CALL DBFGetRecordCount(DBFHandle psDBF);
- int SHPAPI_CALL
- DBFAddField(DBFHandle hDBF, const char *pszFieldName,
- DBFFieldType eType, int nWidth, int nDecimals);
+int SHPAPI_CALL
+ DBFGetFieldCount( DBFHandle psDBF );
+int SHPAPI_CALL
+ DBFGetRecordCount( DBFHandle psDBF );
+int SHPAPI_CALL
+ DBFAddField( DBFHandle hDBF, const char * pszFieldName,
+ DBFFieldType eType, int nWidth, int nDecimals );
- int SHPAPI_CALL
- DBFAddNativeFieldType(DBFHandle hDBF, const char *pszFieldName,
- char chType, int nWidth, int nDecimals);
+int SHPAPI_CALL
+ DBFAddNativeFieldType( DBFHandle hDBF, const char * pszFieldName,
+ char chType, int nWidth, int nDecimals );
- DBFFieldType SHPAPI_CALL
- DBFGetFieldInfo(DBFHandle psDBF, int iField,
- char *pszFieldName, int *pnWidth, int *pnDecimals);
+DBFFieldType SHPAPI_CALL
+ DBFGetFieldInfo( DBFHandle psDBF, int iField,
+ char * pszFieldName, int * pnWidth, int * pnDecimals );
- int SHPAPI_CALL
- DBFGetFieldIndex(DBFHandle psDBF, const char *pszFieldName);
+int SHPAPI_CALL
+ DBFGetFieldIndex(DBFHandle psDBF, const char *pszFieldName);
- int SHPAPI_CALL
- DBFReadIntegerAttribute(DBFHandle hDBF, int iShape, int iField);
- double SHPAPI_CALL
- DBFReadDoubleAttribute(DBFHandle hDBF, int iShape, int iField);
- DBFReadStringAttribute(DBFHandle hDBF, int iShape, int iField);
- DBFReadLogicalAttribute(DBFHandle hDBF, int iShape, int iField);
- int SHPAPI_CALL
- DBFIsAttributeNULL(DBFHandle hDBF, int iShape, int iField);
+int SHPAPI_CALL
+ DBFReadIntegerAttribute( DBFHandle hDBF, int iShape, int iField );
+double SHPAPI_CALL
+ DBFReadDoubleAttribute( DBFHandle hDBF, int iShape, int iField );
+ DBFReadStringAttribute( DBFHandle hDBF, int iShape, int iField );
+ DBFReadLogicalAttribute( DBFHandle hDBF, int iShape, int iField );
+int SHPAPI_CALL
+ DBFIsAttributeNULL( DBFHandle hDBF, int iShape, int iField );
- int SHPAPI_CALL
- DBFWriteIntegerAttribute(DBFHandle hDBF, int iShape, int iField,
- int nFieldValue);
- int SHPAPI_CALL
- DBFWriteDoubleAttribute(DBFHandle hDBF, int iShape, int iField,
- double dFieldValue);
- int SHPAPI_CALL
- DBFWriteStringAttribute(DBFHandle hDBF, int iShape, int iField,
- const char *pszFieldValue);
- int SHPAPI_CALL
- DBFWriteNULLAttribute(DBFHandle hDBF, int iShape, int iField);
+int SHPAPI_CALL
+ DBFWriteIntegerAttribute( DBFHandle hDBF, int iShape, int iField,
+ int nFieldValue );
+int SHPAPI_CALL
+ DBFWriteDoubleAttribute( DBFHandle hDBF, int iShape, int iField,
+ double dFieldValue );
+int SHPAPI_CALL
+ DBFWriteStringAttribute( DBFHandle hDBF, int iShape, int iField,
+ const char * pszFieldValue );
+int SHPAPI_CALL
+ DBFWriteNULLAttribute( DBFHandle hDBF, int iShape, int iField );
- int SHPAPI_CALL
- DBFWriteLogicalAttribute(DBFHandle hDBF, int iShape, int iField,
- const char lFieldValue);
- int SHPAPI_CALL
- DBFWriteAttributeDirectly(DBFHandle psDBF, int hEntity, int iField,
- void *pValue);
- DBFReadTuple(DBFHandle psDBF, int hEntity);
- int SHPAPI_CALL
- DBFWriteTuple(DBFHandle psDBF, int hEntity, void *pRawTuple);
+int SHPAPI_CALL
+ DBFWriteLogicalAttribute( DBFHandle hDBF, int iShape, int iField,
+ const char lFieldValue);
+int SHPAPI_CALL
+ DBFWriteAttributeDirectly(DBFHandle psDBF, int hEntity, int iField,
+ void * pValue );
+ DBFReadTuple(DBFHandle psDBF, int hEntity );
+int SHPAPI_CALL
+ DBFWriteTuple(DBFHandle psDBF, int hEntity, void * pRawTuple );
- int SHPAPI_CALL DBFIsRecordDeleted(DBFHandle psDBF, int iShape);
- int SHPAPI_CALL DBFMarkRecordDeleted(DBFHandle psDBF, int iShape,
- int bIsDeleted);
+int SHPAPI_CALL DBFIsRecordDeleted( DBFHandle psDBF, int iShape );
+ int bIsDeleted );
- DBFCloneEmpty(DBFHandle psDBF, const char *pszFilename);
+DBFHandle SHPAPI_CALL
+ DBFCloneEmpty(DBFHandle psDBF, const char * pszFilename );
+void SHPAPI_CALL
+ DBFClose( DBFHandle hDBF );
+void SHPAPI_CALL
+ DBFUpdateHeader( DBFHandle hDBF );
+char SHPAPI_CALL
+ DBFGetNativeFieldType( DBFHandle hDBF, int iField );
- void SHPAPI_CALL DBFClose(DBFHandle hDBF);
- void SHPAPI_CALL DBFUpdateHeader(DBFHandle hDBF);
- char SHPAPI_CALL DBFGetNativeFieldType(DBFHandle hDBF, int iField);
#ifdef __cplusplus
#endif
-#endif /* ndef _SHAPEFILE_H_INCLUDED */
+#endif /* ndef _SHAPEFILE_H_INCLUDED */
Modified: grass/trunk/lib/external/shapelib/shpopen.c
--- grass/trunk/lib/external/shapelib/shpopen.c 2008-08-06 19:30:45 UTC (rev 32581)
+++ grass/trunk/lib/external/shapelib/shpopen.c 2008-08-06 19:37:34 UTC (rev 32582)
@@ -1,4 +1,3 @@
* $Id$
@@ -234,12 +233,12 @@
SHP_CVSID("$Id$")
- typedef unsigned char uchar;
+typedef unsigned char uchar;
#if UINT_MAX == 65535
- typedef long int32;
+typedef long int32;
#else
- typedef int int32;
+typedef int int32;
#endif
#ifndef FALSE
@@ -253,25 +252,26 @@
# define MAX(a,b) ((a>b) ? a : b)
#endif
- static int bBigEndian;
+static int bBigEndian;
/* SwapWord() */
/* Swap a 2, 4 or 8 byte word. */
- static void SwapWord(int length, void *wordP)
+static void SwapWord( int length, void * wordP )
- int i;
- uchar temp;
+ int i;
+ uchar temp;
- for (i = 0; i < length / 2; i++) {
+ for( i=0; i < length/2; i++ )
temp = ((uchar *) wordP)[i];
- ((uchar *) wordP)[i] = ((uchar *) wordP)[length - i - 1];
- ((uchar *) wordP)[length - i - 1] = temp;
+ ((uchar *)wordP)[i] = ((uchar *) wordP)[length-i-1];
+ ((uchar *) wordP)[length-i-1] = temp;
@@ -280,166 +280,157 @@
/* A realloc cover function that will access a NULL pointer as */
/* a valid input. */
-static void *SfRealloc(void *pMem, int nNewSize)
+static void * SfRealloc( void * pMem, int nNewSize )
- if (pMem == NULL)
- return ((void *)malloc(nNewSize));
+ if( pMem == NULL )
+ return( (void *) malloc(nNewSize) );
else
- return ((void *)realloc(pMem, nNewSize));
+ return( (void *) realloc(pMem,nNewSize) );
/* SHPWriteHeader() */
-/* Write out a header for the .shp and .shx files as well as the */
-/* contents of the index (.shx) file. */
+/* Write out a header for the .shp and .shx files as well as the */
+/* contents of the index (.shx) file. */
-void SHPWriteHeader(SHPHandle psSHP)
- uchar abyHeader[100];
- int i;
- int32 i32;
- double dValue;
- int32 *panSHX;
+void SHPWriteHeader( SHPHandle psSHP )
- if (psSHP->fpSHX == NULL) {
- psSHP->sHooks.Error("SHPWriteHeader failed : SHX file is closed");
- return;
+ uchar abyHeader[100];
+ int i;
+ int32 i32;
+ double dValue;
+ int32 *panSHX;
+ if (psSHP->fpSHX == NULL)
+ psSHP->sHooks.Error( "SHPWriteHeader failed : SHX file is closed");
+ return;
- /* Prepare header block for .shp file. */
- for (i = 0; i < 100; i++)
- abyHeader[i] = 0;
+/* Prepare header block for .shp file. */
+ for( i = 0; i < 100; i++ )
+ abyHeader[i] = 0;
- abyHeader[2] = 0x27; /* magic cookie */
+ abyHeader[2] = 0x27; /* magic cookie */
abyHeader[3] = 0x0a;
- i32 = psSHP->nFileSize / 2; /* file size */
- ByteCopy(&i32, abyHeader + 24, 4);
- if (!bBigEndian)
- SwapWord(4, abyHeader + 24);
+ i32 = psSHP->nFileSize/2; /* file size */
+ ByteCopy( &i32, abyHeader+24, 4 );
+ if( !bBigEndian ) SwapWord( 4, abyHeader+24 );
+ i32 = 1000; /* version */
+ ByteCopy( &i32, abyHeader+28, 4 );
+ if( bBigEndian ) SwapWord( 4, abyHeader+28 );
+ i32 = psSHP->nShapeType; /* shape type */
+ ByteCopy( &i32, abyHeader+32, 4 );
+ if( bBigEndian ) SwapWord( 4, abyHeader+32 );
- i32 = 1000; /* version */
- ByteCopy(&i32, abyHeader + 28, 4);
- if (bBigEndian)
- SwapWord(4, abyHeader + 28);
+ dValue = psSHP->adBoundsMin[0]; /* set bounds */
+ ByteCopy( &dValue, abyHeader+36, 8 );
+ if( bBigEndian ) SwapWord( 8, abyHeader+36 );
- i32 = psSHP->nShapeType; /* shape type */
- ByteCopy(&i32, abyHeader + 32, 4);
- if (bBigEndian)
- SwapWord(4, abyHeader + 32);
- dValue = psSHP->adBoundsMin[0]; /* set bounds */
- ByteCopy(&dValue, abyHeader + 36, 8);
- if (bBigEndian)
- SwapWord(8, abyHeader + 36);
dValue = psSHP->adBoundsMin[1];
- ByteCopy(&dValue, abyHeader + 44, 8);
- if (bBigEndian)
- SwapWord(8, abyHeader + 44);
+ ByteCopy( &dValue, abyHeader+44, 8 );
+ if( bBigEndian ) SwapWord( 8, abyHeader+44 );
dValue = psSHP->adBoundsMax[0];
- ByteCopy(&dValue, abyHeader + 52, 8);
- if (bBigEndian)
- SwapWord(8, abyHeader + 52);
+ ByteCopy( &dValue, abyHeader+52, 8 );
+ if( bBigEndian ) SwapWord( 8, abyHeader+52 );
dValue = psSHP->adBoundsMax[1];
- ByteCopy(&dValue, abyHeader + 60, 8);
- if (bBigEndian)
- SwapWord(8, abyHeader + 60);
+ ByteCopy( &dValue, abyHeader+60, 8 );
+ if( bBigEndian ) SwapWord( 8, abyHeader+60 );
- dValue = psSHP->adBoundsMin[2]; /* z */
- ByteCopy(&dValue, abyHeader + 68, 8);
- if (bBigEndian)
- SwapWord(8, abyHeader + 68);
+ dValue = psSHP->adBoundsMin[2]; /* z */
+ ByteCopy( &dValue, abyHeader+68, 8 );
+ if( bBigEndian ) SwapWord( 8, abyHeader+68 );
dValue = psSHP->adBoundsMax[2];
- ByteCopy(&dValue, abyHeader + 76, 8);
- if (bBigEndian)
- SwapWord(8, abyHeader + 76);
+ ByteCopy( &dValue, abyHeader+76, 8 );
+ if( bBigEndian ) SwapWord( 8, abyHeader+76 );
- dValue = psSHP->adBoundsMin[3]; /* m */
- ByteCopy(&dValue, abyHeader + 84, 8);
- if (bBigEndian)
- SwapWord(8, abyHeader + 84);
+ dValue = psSHP->adBoundsMin[3]; /* m */
+ ByteCopy( &dValue, abyHeader+84, 8 );
+ if( bBigEndian ) SwapWord( 8, abyHeader+84 );
dValue = psSHP->adBoundsMax[3];
- ByteCopy(&dValue, abyHeader + 92, 8);
- if (bBigEndian)
- SwapWord(8, abyHeader + 92);
+ ByteCopy( &dValue, abyHeader+92, 8 );
+ if( bBigEndian ) SwapWord( 8, abyHeader+92 );
- /* Write .shp file header. */
- if (psSHP->sHooks.FSeek(psSHP->fpSHP, 0, 0) != 0
- || psSHP->sHooks.FWrite(abyHeader, 100, 1, psSHP->fpSHP) != 1) {
- psSHP->sHooks.Error("Failure writing .shp header");
- return;
+/* Write .shp file header. */
+ if( psSHP->sHooks.FSeek( psSHP->fpSHP, 0, 0 ) != 0
+ || psSHP->sHooks.FWrite( abyHeader, 100, 1, psSHP->fpSHP ) != 1 )
+ psSHP->sHooks.Error( "Failure writing .shp header" );
+ return;
- /* Prepare, and write .shx file header. */
- i32 = (psSHP->nRecords * 2 * sizeof(int32) + 100) / 2; /* file size */
- if (!bBigEndian)
- if (psSHP->sHooks.FSeek(psSHP->fpSHX, 0, 0) != 0
- || psSHP->sHooks.FWrite(abyHeader, 100, 1, psSHP->fpSHX) != 1) {
- psSHP->sHooks.Error("Failure writing .shx header");
- return;
+/* Prepare, and write .shx file header. */
+ i32 = (psSHP->nRecords * 2 * sizeof(int32) + 100)/2; /* file size */
+ if( psSHP->sHooks.FSeek( psSHP->fpSHX, 0, 0 ) != 0
+ || psSHP->sHooks.FWrite( abyHeader, 100, 1, psSHP->fpSHX ) != 1 )
+ psSHP->sHooks.Error( "Failure writing .shx header" );
+ return;
- /* Write out the .shx contents. */
+/* Write out the .shx contents. */
panSHX = (int32 *) malloc(sizeof(int32) * 2 * psSHP->nRecords);
- for (i = 0; i < psSHP->nRecords; i++) {
- panSHX[i * 2] = psSHP->panRecOffset[i] / 2;
- panSHX[i * 2 + 1] = psSHP->panRecSize[i] / 2;
- if (!bBigEndian)
- SwapWord(4, panSHX + i * 2);
- if (!bBigEndian)
- SwapWord(4, panSHX + i * 2 + 1);
+ for( i = 0; i < psSHP->nRecords; i++ )
+ panSHX[i*2 ] = psSHP->panRecOffset[i]/2;
+ panSHX[i*2+1] = psSHP->panRecSize[i]/2;
+ if( !bBigEndian ) SwapWord( 4, panSHX+i*2 );
+ if( !bBigEndian ) SwapWord( 4, panSHX+i*2+1 );
- if ((int)psSHP->sHooks.
- FWrite(panSHX, sizeof(int32) * 2, psSHP->nRecords, psSHP->fpSHX)
- != psSHP->nRecords) {
- psSHP->sHooks.Error("Failure writing .shx contents");
+ if( (int)psSHP->sHooks.FWrite( panSHX, sizeof(int32)*2, psSHP->nRecords, psSHP->fpSHX )
+ != psSHP->nRecords )
+ psSHP->sHooks.Error( "Failure writing .shx contents" );
- free(panSHX);
+ free( panSHX );
- /* Flush to disk. */
- psSHP->sHooks.FFlush(psSHP->fpSHP);
- psSHP->sHooks.FFlush(psSHP->fpSHX);
+/* Flush to disk. */
+ psSHP->sHooks.FFlush( psSHP->fpSHP );
+ psSHP->sHooks.FFlush( psSHP->fpSHX );
/* SHPOpen() */
-SHPHandle SHPAPI_CALL SHPOpen(const char *pszLayer, const char *pszAccess)
+SHPOpen( const char * pszLayer, const char * pszAccess )
SAHooks sHooks;
- SASetupDefaultHooks(&sHooks);
+ SASetupDefaultHooks( &sHooks );
- return SHPOpenLL(pszLayer, pszAccess, &sHooks);
+ return SHPOpenLL( pszLayer, pszAccess, &sHooks );
@@ -447,339 +438,343 @@
/* Open the .shp and .shx files based on the basename of the */
/* files or either file name. */
-SHPOpenLL(const char *pszLayer, const char *pszAccess, SAHooks * psHooks)
- SHPHandle psSHP;
+SHPOpenLL( const char * pszLayer, const char * pszAccess, SAHooks *psHooks )
- uchar *pabyBuf;
- int i;
- double dValue;
- /* Ensure the access string is one of the legal ones. We */
- /* ensure the result string indicates binary to avoid common */
- /* problems on Windows. */
- if (strcmp(pszAccess, "rb+") == 0 || strcmp(pszAccess, "r+b") == 0
- || strcmp(pszAccess, "r+") == 0)
- pszAccess = "r+b";
+ char *pszFullname, *pszBasename;
+ SHPHandle psSHP;
+ uchar *pabyBuf;
+ int i;
+ double dValue;
+/* Ensure the access string is one of the legal ones. We */
+/* ensure the result string indicates binary to avoid common */
+/* problems on Windows. */
+ if( strcmp(pszAccess,"rb+") == 0 || strcmp(pszAccess,"r+b") == 0
+ || strcmp(pszAccess,"r+") == 0 )
+ pszAccess = "r+b";
else
- pszAccess = "rb";
- /* Establish the byte order on this machine. */
+ pszAccess = "rb";
+/* Establish the byte order on this machine. */
i = 1;
- if (*((uchar *) & i) == 1)
- bBigEndian = FALSE;
+ if( *((uchar *) &i) == 1 )
+ bBigEndian = FALSE;
else
- bBigEndian = TRUE;
+ bBigEndian = TRUE;
- /* Initialize the info structure. */
- psSHP = (SHPHandle) calloc(sizeof(SHPInfo), 1);
+/* Initialize the info structure. */
+ psSHP = (SHPHandle) calloc(sizeof(SHPInfo),1);
psSHP->bUpdated = FALSE;
- memcpy(&(psSHP->sHooks), psHooks, sizeof(SAHooks));
+ memcpy( &(psSHP->sHooks), psHooks, sizeof(SAHooks) );
- /* Compute the base (layer) name. If there is any extension */
- /* on the passed in filename we will strip it off. */
- pszBasename = (char *)malloc(strlen(pszLayer) + 5);
- strcpy(pszBasename, pszLayer);
- for (i = strlen(pszBasename) - 1;
+/* Compute the base (layer) name. If there is any extension */
+/* on the passed in filename we will strip it off. */
+ pszBasename = (char *) malloc(strlen(pszLayer)+5);
+ strcpy( pszBasename, pszLayer );
+ for( i = strlen(pszBasename)-1;
i > 0 && pszBasename[i] != '.' && pszBasename[i] != '/'
- && pszBasename[i] != '\\'; i--) {
+ && pszBasename[i] != '\\';
+ i-- ) {}
- if (pszBasename[i] == '.')
- pszBasename[i] = '\0';
+ if( pszBasename[i] == '.' )
+ pszBasename[i] = '\0';
- /* Open the .shp and .shx files. Note that files pulled from */
- /* a PC to Unix with upper case filenames won't work! */
- pszFullname = (char *)malloc(strlen(pszBasename) + 5);
- sprintf(pszFullname, "%s.shp", pszBasename);
- psSHP->fpSHP = psSHP->sHooks.FOpen(pszFullname, pszAccess);
- if (psSHP->fpSHP == NULL) {
- sprintf(pszFullname, "%s.SHP", pszBasename);
+/* Open the .shp and .shx files. Note that files pulled from */
+/* a PC to Unix with upper case filenames won't work! */
+ pszFullname = (char *) malloc(strlen(pszBasename) + 5);
+ sprintf( pszFullname, "%s.shp", pszBasename ) ;
+ psSHP->fpSHP = psSHP->sHooks.FOpen(pszFullname, pszAccess );
+ if( psSHP->fpSHP == NULL )
+ sprintf( pszFullname, "%s.SHP", pszBasename );
#ifdef USE_CPL
- CPLError(CE_Failure, CPLE_OpenFailed,
- "Unable to open %s.shp or %s.SHP.",
- pszBasename, pszBasename);
+ CPLError( CE_Failure, CPLE_OpenFailed,
+ "Unable to open %s.shp or %s.SHP.",
+ pszBasename, pszBasename );
#endif
- free(psSHP);
- free(pszBasename);
- free(pszFullname);
- return (NULL);
+ free( psSHP );
+ free( pszBasename );
+ free( pszFullname );
+ return( NULL );
- sprintf(pszFullname, "%s.shx", pszBasename);
- psSHP->fpSHX = psSHP->sHooks.FOpen(pszFullname, pszAccess);
- sprintf(pszFullname, "%s.SHX", pszBasename);
+ sprintf( pszFullname, "%s.shx", pszBasename );
+ psSHP->fpSHX = psSHP->sHooks.FOpen(pszFullname, pszAccess );
+ if( psSHP->fpSHX == NULL )
+ sprintf( pszFullname, "%s.SHX", pszBasename );
#ifdef USE_CPL
- "Unable to open %s.shx or %s.SHX.",
+ "Unable to open %s.shx or %s.SHX.",
#endif
- psSHP->sHooks.FClose(psSHP->fpSHP);
- free(psSHP);
- return (NULL);
+ psSHP->sHooks.FClose( psSHP->fpSHP );
+ free( psSHP );
+ return( NULL );
- /* Read the file size from the SHP file. */
+/* Read the file size from the SHP file. */
pabyBuf = (uchar *) malloc(100);
- psSHP->sHooks.FRead(pabyBuf, 100, 1, psSHP->fpSHP);
+ psSHP->sHooks.FRead( pabyBuf, 100, 1, psSHP->fpSHP );
psSHP->nFileSize = (pabyBuf[24] * 256 * 256 * 256
+ pabyBuf[25] * 256 * 256
- + pabyBuf[26] * 256 + pabyBuf[27]) * 2;
+ + pabyBuf[26] * 256
+ + pabyBuf[27]) * 2;
- /* Read SHX file Header info */
- if (psSHP->sHooks.FRead(pabyBuf, 100, 1, psSHP->fpSHX) != 1
- || pabyBuf[0] != 0
- || pabyBuf[1] != 0
- || pabyBuf[2] != 0x27 || (pabyBuf[3] != 0x0a && pabyBuf[3] != 0x0d)) {
- psSHP->sHooks.Error(".shx file is unreadable, or corrupt.");
- psSHP->sHooks.FClose(psSHP->fpSHX);
- free(psSHP);
+/* Read SHX file Header info */
+ if( psSHP->sHooks.FRead( pabyBuf, 100, 1, psSHP->fpSHX ) != 1
+ || pabyBuf[0] != 0
+ || pabyBuf[1] != 0
+ || pabyBuf[2] != 0x27
+ || (pabyBuf[3] != 0x0a && pabyBuf[3] != 0x0d) )
+ psSHP->sHooks.Error( ".shx file is unreadable, or corrupt." );
+ psSHP->sHooks.FClose( psSHP->fpSHX );
+ free( psSHP );
- return (NULL);
+ return( NULL );
psSHP->nRecords = pabyBuf[27] + pabyBuf[26] * 256
- + pabyBuf[25] * 256 * 256 + pabyBuf[24] * 256 * 256 * 256;
- psSHP->nRecords = (psSHP->nRecords * 2 - 100) / 8;
+ + pabyBuf[25] * 256 * 256 + pabyBuf[24] * 256 * 256 * 256;
+ psSHP->nRecords = (psSHP->nRecords*2 - 100) / 8;
psSHP->nShapeType = pabyBuf[32];
- if (psSHP->nRecords < 0 || psSHP->nRecords > 256000000) {
- char szError[200];
+ if( psSHP->nRecords < 0 || psSHP->nRecords > 256000000 )
+ char szError[200];
+ sprintf( szError,
+ "Record count in .shp header is %d, which seems\n"
+ "unreasonable. Assuming header is corrupt.",
+ psSHP->nRecords );
+ psSHP->sHooks.Error( szError );
+ free( psSHP );
+ free(pabyBuf);
- sprintf(szError,
- "Record count in .shp header is %d, which seems\n"
- "unreasonable. Assuming header is corrupt.",
- psSHP->nRecords);
- psSHP->sHooks.Error(szError);
- free(psSHP);
- free(pabyBuf);
- return (NULL);
+ return( NULL );
- /* Read the bounds. */
- if (bBigEndian)
- SwapWord(8, pabyBuf + 36);
- memcpy(&dValue, pabyBuf + 36, 8);
+/* Read the bounds. */
+ if( bBigEndian ) SwapWord( 8, pabyBuf+36 );
+ memcpy( &dValue, pabyBuf+36, 8 );
psSHP->adBoundsMin[0] = dValue;
- if (bBigEndian)
- SwapWord(8, pabyBuf + 44);
- memcpy(&dValue, pabyBuf + 44, 8);
+ if( bBigEndian ) SwapWord( 8, pabyBuf+44 );
+ memcpy( &dValue, pabyBuf+44, 8 );
psSHP->adBoundsMin[1] = dValue;
- if (bBigEndian)
- SwapWord(8, pabyBuf + 52);
- memcpy(&dValue, pabyBuf + 52, 8);
+ if( bBigEndian ) SwapWord( 8, pabyBuf+52 );
+ memcpy( &dValue, pabyBuf+52, 8 );
psSHP->adBoundsMax[0] = dValue;
- if (bBigEndian)
- SwapWord(8, pabyBuf + 60);
- memcpy(&dValue, pabyBuf + 60, 8);
+ if( bBigEndian ) SwapWord( 8, pabyBuf+60 );
+ memcpy( &dValue, pabyBuf+60, 8 );
psSHP->adBoundsMax[1] = dValue;
- if (bBigEndian)
- SwapWord(8, pabyBuf + 68); /* z */
- memcpy(&dValue, pabyBuf + 68, 8);
+ if( bBigEndian ) SwapWord( 8, pabyBuf+68 ); /* z */
+ memcpy( &dValue, pabyBuf+68, 8 );
psSHP->adBoundsMin[2] = dValue;
- if (bBigEndian)
- SwapWord(8, pabyBuf + 76);
- memcpy(&dValue, pabyBuf + 76, 8);
+ if( bBigEndian ) SwapWord( 8, pabyBuf+76 );
+ memcpy( &dValue, pabyBuf+76, 8 );
psSHP->adBoundsMax[2] = dValue;
- if (bBigEndian)
- SwapWord(8, pabyBuf + 84); /* z */
- memcpy(&dValue, pabyBuf + 84, 8);
+ if( bBigEndian ) SwapWord( 8, pabyBuf+84 ); /* z */
+ memcpy( &dValue, pabyBuf+84, 8 );
psSHP->adBoundsMin[3] = dValue;
- if (bBigEndian)
- SwapWord(8, pabyBuf + 92);
- memcpy(&dValue, pabyBuf + 92, 8);
+ if( bBigEndian ) SwapWord( 8, pabyBuf+92 );
+ memcpy( &dValue, pabyBuf+92, 8 );
psSHP->adBoundsMax[3] = dValue;
- free(pabyBuf);
+ free( pabyBuf );
- /* Read the .shx file to get the offsets to each record in */
- /* the .shp file. */
+/* Read the .shx file to get the offsets to each record in */
+/* the .shp file. */
psSHP->nMaxRecords = psSHP->nRecords;
psSHP->panRecOffset =
- (int *)malloc(sizeof(int) * MAX(1, psSHP->nMaxRecords));
+ (int *) malloc(sizeof(int) * MAX(1,psSHP->nMaxRecords) );
psSHP->panRecSize =
- pabyBuf = (uchar *) malloc(8 * MAX(1, psSHP->nRecords));
+ pabyBuf = (uchar *) malloc(8 * MAX(1,psSHP->nRecords) );
if (psSHP->panRecOffset == NULL ||
- psSHP->panRecSize == NULL || pabyBuf == NULL) {
+ psSHP->panRecSize == NULL ||
+ pabyBuf == NULL)
- sprintf(szError,
- "Not enough memory to allocate requested memory (nRecords=%d).\n"
- "Probably broken SHP file", psSHP->nRecords);
- if (psSHP->panRecOffset)
- free(psSHP->panRecOffset);
- if (psSHP->panRecSize)
- free(psSHP->panRecSize);
- if (pabyBuf)
- free(pabyBuf);
- free(psSHP);
- return (NULL);
+ sprintf(szError,
+ "Not enough memory to allocate requested memory (nRecords=%d).\n"
+ "Probably broken SHP file",
+ if (psSHP->panRecOffset) free( psSHP->panRecOffset );
+ if (psSHP->panRecSize) free( psSHP->panRecSize );
+ if (pabyBuf) free( pabyBuf );
+ free( psSHP );
+ return( NULL );
- if ((int)psSHP->sHooks.FRead(pabyBuf, 8, psSHP->nRecords, psSHP->fpSHX)
+ if( (int) psSHP->sHooks.FRead( pabyBuf, 8, psSHP->nRecords, psSHP->fpSHX )
- sprintf(szError,
- "Failed to read all values for %d records in .shx file.",
- psSHP->nRecords);
+ sprintf( szError,
+ "Failed to read all values for %d records in .shx file.",
- /* SHX is short or unreadable for some reason. */
- free(pabyBuf);
- free(psSHP);
+ /* SHX is short or unreadable for some reason. */
+ free( psSHP->panRecOffset );
+ free( psSHP->panRecSize );
+ free( pabyBuf );
+ free( psSHP );
- return (NULL);
+ return( NULL );
/* In read-only mode, we can close the SHX now */
- if (strcmp(pszAccess, "rb") == 0) {
- psSHP->fpSHX = NULL;
+ if (strcmp(pszAccess, "rb") == 0)
+ psSHP->fpSHX = NULL;
- int32 nOffset, nLength;
+ int32 nOffset, nLength;
- memcpy(&nOffset, pabyBuf + i * 8, 4);
- if (!bBigEndian)
- SwapWord(4, &nOffset);
+ memcpy( &nOffset, pabyBuf + i * 8, 4 );
+ if( !bBigEndian ) SwapWord( 4, &nOffset );
- memcpy(&nLength, pabyBuf + i * 8 + 4, 4);
- if (!bBigEndian)
- SwapWord(4, &nLength);
+ memcpy( &nLength, pabyBuf + i * 8 + 4, 4 );
+ if( !bBigEndian ) SwapWord( 4, &nLength );
- psSHP->panRecOffset[i] = nOffset * 2;
- psSHP->panRecSize[i] = nLength * 2;
+ psSHP->panRecOffset[i] = nOffset*2;
+ psSHP->panRecSize[i] = nLength*2;
- free(pabyBuf);
+ free( pabyBuf );
- return (psSHP);
+ return( psSHP );
/* SHPClose() */
-/* Close the .shp and .shx files. */
+/* Close the .shp and .shx files. */
-void SHPAPI_CALL SHPClose(SHPHandle psSHP)
+void SHPAPI_CALL
+SHPClose(SHPHandle psSHP )
- if (psSHP == NULL)
- return;
+ if( psSHP == NULL )
+ return;
- /* Update the header if we have modified anything. */
- if (psSHP->bUpdated)
- SHPWriteHeader(psSHP);
+/* Update the header if we have modified anything. */
+ if( psSHP->bUpdated )
+ SHPWriteHeader( psSHP );
- /* Free all resources, and close files. */
+/* Free all resources, and close files. */
- if (psSHP->fpSHX != NULL)
+ if ( psSHP->fpSHX != NULL)
- if (psSHP->pabyRec != NULL) {
- free(psSHP->pabyRec);
+ if( psSHP->pabyRec != NULL )
+ free( psSHP->pabyRec );
- free(psSHP);
+ free( psSHP );
/* SHPGetInfo() */
/* Fetch general information about the shape file. */
void SHPAPI_CALL
-SHPGetInfo(SHPHandle psSHP, int *pnEntities, int *pnShapeType,
+SHPGetInfo(SHPHandle psSHP, int * pnEntities, int * pnShapeType,
- int i;
+ int i;
- return;
+ return;
+ if( pnEntities != NULL )
+ *pnEntities = psSHP->nRecords;
- if (pnEntities != NULL)
- *pnEntities = psSHP->nRecords;
+ if( pnShapeType != NULL )
+ *pnShapeType = psSHP->nShapeType;
- if (pnShapeType != NULL)
- *pnShapeType = psSHP->nShapeType;
- for (i = 0; i < 4; i++) {
- if (padfMinBound != NULL)
- padfMinBound[i] = psSHP->adBoundsMin[i];
- if (padfMaxBound != NULL)
- padfMaxBound[i] = psSHP->adBoundsMax[i];
+ for( i = 0; i < 4; i++ )
+ if( padfMinBound != NULL )
+ padfMinBound[i] = psSHP->adBoundsMin[i];
+ if( padfMaxBound != NULL )
+ padfMaxBound[i] = psSHP->adBoundsMax[i];
@@ -788,16 +783,17 @@
/* Create a new shape file and return a handle to the open */
/* shape file with read/write access. */
-SHPHandle SHPAPI_CALL SHPCreate(const char *pszLayer, int nShapeType)
+SHPCreate( const char * pszLayer, int nShapeType )
SAHooks sHooks;
- return SHPCreateLL(pszLayer, nShapeType, &sHooks);
+ return SHPCreateLL( pszLayer, nShapeType, &sHooks );
@@ -805,121 +801,121 @@
-SHPCreateLL(const char *pszLayer, int nShapeType, SAHooks * psHooks)
- char *pszBasename, *pszFullname;
- int i;
- SAFile fpSHP, fpSHX;
- int32 i32;
- double dValue;
+SHPCreateLL( const char * pszLayer, int nShapeType, SAHooks *psHooks )
- /* Establish the byte order on this system. */
+ char *pszBasename, *pszFullname;
+ int i;
+ SAFile fpSHP, fpSHX;
+ int32 i32;
+ double dValue;
+/* Establish the byte order on this system. */
i = 1;
else
+ i-- ) {}
- /* Open the two files so we can write their headers. */
- fpSHP = psHooks->FOpen(pszFullname, "wb");
- if (fpSHP == NULL) {
- psHooks->Error("Failed to create file .shp file.");
- return (NULL);
+/* Open the two files so we can write their headers. */
+ sprintf( pszFullname, "%s.shp", pszBasename );
+ fpSHP = psHooks->FOpen(pszFullname, "wb" );
+ if( fpSHP == NULL )
+ psHooks->Error( "Failed to create file .shp file." );
+ return( NULL );
- fpSHX = psHooks->FOpen(pszFullname, "wb");
- if (fpSHX == NULL) {
- psHooks->Error("Failed to create file .shx file.");
- return (NULL);
+ fpSHX = psHooks->FOpen(pszFullname, "wb" );
+ if( fpSHX == NULL )
+ psHooks->Error( "Failed to create file .shx file." );
+ return( NULL );
- abyHeader[i] = 0;
+ abyHeader[i] = 0;
- i32 = 50; /* file size */
- if (!bBigEndian)
+ i32 = 50; /* file size */
+ i32 = nShapeType; /* shape type */
- if (bBigEndian)
+ dValue = 0.0; /* set bounds */
- i32 = nShapeType; /* shape type */
- if (bBigEndian)
- dValue = 0.0; /* set bounds */
- if (psHooks->FWrite(abyHeader, 100, 1, fpSHP) != 1) {
- psHooks->Error("Failed to write .shp header.");
- return NULL;
+ if( psHooks->FWrite( abyHeader, 100, 1, fpSHP ) != 1 )
+ psHooks->Error( "Failed to write .shp header." );
+ return NULL;
- if (!bBigEndian)
- if (psHooks->FWrite(abyHeader, 100, 1, fpSHX) != 1) {
- psHooks->Error("Failed to write .shx header.");
- return NULL;
+ if( psHooks->FWrite( abyHeader, 100, 1, fpSHX ) != 1 )
+ psHooks->Error( "Failed to write .shx header." );
+ return NULL;
- /* Close the files, and then open them as regular existing files. */
- psHooks->FClose(fpSHP);
- psHooks->FClose(fpSHX);
+/* Close the files, and then open them as regular existing files. */
+ psHooks->FClose( fpSHP );
+ psHooks->FClose( fpSHX );
- return (SHPOpenLL(pszLayer, "r+b", psHooks));
+ return( SHPOpenLL( pszLayer, "r+b", psHooks ) );
@@ -927,21 +923,22 @@
/* Compute a bounds rectangle for a shape, and set it into the */
/* indicated location in the record. */
-static void _SHPSetBounds(uchar * pabyRec, SHPObject * psShape)
+static void _SHPSetBounds( uchar * pabyRec, SHPObject * psShape )
- ByteCopy(&(psShape->dfXMin), pabyRec + 0, 8);
- ByteCopy(&(psShape->dfYMin), pabyRec + 8, 8);
- ByteCopy(&(psShape->dfXMax), pabyRec + 16, 8);
- ByteCopy(&(psShape->dfYMax), pabyRec + 24, 8);
+ ByteCopy( &(psShape->dfXMin), pabyRec + 0, 8 );
+ ByteCopy( &(psShape->dfYMin), pabyRec + 8, 8 );
+ ByteCopy( &(psShape->dfXMax), pabyRec + 16, 8 );
+ ByteCopy( &(psShape->dfYMax), pabyRec + 24, 8 );
- if (bBigEndian) {
- SwapWord(8, pabyRec + 0);
- SwapWord(8, pabyRec + 8);
- SwapWord(8, pabyRec + 16);
- SwapWord(8, pabyRec + 24);
+ if( bBigEndian )
+ SwapWord( 8, pabyRec + 0 );
+ SwapWord( 8, pabyRec + 8 );
+ SwapWord( 8, pabyRec + 16 );
+ SwapWord( 8, pabyRec + 24 );
@@ -950,33 +947,36 @@
/* Recompute the extents of a shape. Automatically done by */
/* SHPCreateObject(). */
-void SHPAPI_CALL SHPComputeExtents(SHPObject * psObject)
- int i;
+void SHPAPI_CALL
+SHPComputeExtents( SHPObject * psObject )
- /* Build extents for this object. */
- if (psObject->nVertices > 0) {
- psObject->dfXMin = psObject->dfXMax = psObject->padfX[0];
- psObject->dfYMin = psObject->dfYMax = psObject->padfY[0];
- psObject->dfZMin = psObject->dfZMax = psObject->padfZ[0];
- psObject->dfMMin = psObject->dfMMax = psObject->padfM[0];
+ int i;
+/* Build extents for this object. */
+ if( psObject->nVertices > 0 )
+ psObject->dfXMin = psObject->dfXMax = psObject->padfX[0];
+ psObject->dfYMin = psObject->dfYMax = psObject->padfY[0];
+ psObject->dfZMin = psObject->dfZMax = psObject->padfZ[0];
+ psObject->dfMMin = psObject->dfMMax = psObject->padfM[0];
+ for( i = 0; i < psObject->nVertices; i++ )
+ psObject->dfXMin = MIN(psObject->dfXMin, psObject->padfX[i]);
+ psObject->dfYMin = MIN(psObject->dfYMin, psObject->padfY[i]);
+ psObject->dfZMin = MIN(psObject->dfZMin, psObject->padfZ[i]);
+ psObject->dfMMin = MIN(psObject->dfMMin, psObject->padfM[i]);
- for (i = 0; i < psObject->nVertices; i++) {
- psObject->dfXMin = MIN(psObject->dfXMin, psObject->padfX[i]);
- psObject->dfYMin = MIN(psObject->dfYMin, psObject->padfY[i]);
- psObject->dfZMin = MIN(psObject->dfZMin, psObject->padfZ[i]);
- psObject->dfMMin = MIN(psObject->dfMMin, psObject->padfM[i]);
- psObject->dfXMax = MAX(psObject->dfXMax, psObject->padfX[i]);
- psObject->dfYMax = MAX(psObject->dfYMax, psObject->padfY[i]);
- psObject->dfZMax = MAX(psObject->dfZMax, psObject->padfZ[i]);
- psObject->dfMMax = MAX(psObject->dfMMax, psObject->padfM[i]);
+ psObject->dfXMax = MAX(psObject->dfXMax, psObject->padfX[i]);
+ psObject->dfYMax = MAX(psObject->dfYMax, psObject->padfY[i]);
+ psObject->dfZMax = MAX(psObject->dfZMax, psObject->padfZ[i]);
+ psObject->dfMMax = MAX(psObject->dfMMax, psObject->padfM[i]);
@@ -985,107 +985,116 @@
/* Create a shape object. It should be freed with */
/* SHPDestroyObject(). */
-SHPCreateObject(int nSHPType, int nShapeId, int nParts,
- int nVertices, const double *padfX, const double *padfY,
+SHPCreateObject( int nSHPType, int nShapeId, int nParts,
+ int nVertices, const double *padfX, const double *padfY,
- SHPObject *psObject;
- int i, bHasM, bHasZ;
+ SHPObject *psObject;
+ int i, bHasM, bHasZ;
- psObject = (SHPObject *) calloc(1, sizeof(SHPObject));
+ psObject = (SHPObject *) calloc(1,sizeof(SHPObject));
psObject->nSHPType = nSHPType;
psObject->nShapeId = nShapeId;
psObject->bMeasureIsUsed = FALSE;
- /* Establish whether this shape type has M, and Z values. */
- if (nSHPType == SHPT_ARCM
- || nSHPType == SHPT_POINTM
- || nSHPType == SHPT_POLYGONM || nSHPType == SHPT_MULTIPOINTM) {
- bHasM = TRUE;
- bHasZ = FALSE;
+/* Establish whether this shape type has M, and Z values. */
+ if( nSHPType == SHPT_ARCM
+ || nSHPType == SHPT_POINTM
+ || nSHPType == SHPT_POLYGONM
+ || nSHPType == SHPT_MULTIPOINTM )
+ bHasM = TRUE;
+ bHasZ = FALSE;
- else if (nSHPType == SHPT_ARCZ
- || nSHPType == SHPT_POINTZ
- || nSHPType == SHPT_POLYGONZ
- || nSHPType == SHPT_MULTIPOINTZ || nSHPType == SHPT_MULTIPATCH) {
- bHasM = TRUE;
- bHasZ = TRUE;
+ else if( nSHPType == SHPT_ARCZ
+ || nSHPType == SHPT_POINTZ
+ || nSHPType == SHPT_POLYGONZ
+ || nSHPType == SHPT_MULTIPOINTZ
+ || nSHPType == SHPT_MULTIPATCH )
+ bHasM = TRUE;
+ bHasZ = TRUE;
- else {
- bHasM = FALSE;
- bHasZ = FALSE;
+ else
+ bHasM = FALSE;
+ bHasZ = FALSE;
- /* Capture parts. Note that part type is optional, and */
- /* defaults to ring. */
- if (nSHPType == SHPT_ARC || nSHPType == SHPT_POLYGON
- || nSHPType == SHPT_ARCM || nSHPType == SHPT_POLYGONM
- || nSHPType == SHPT_ARCZ || nSHPType == SHPT_POLYGONZ
- || nSHPType == SHPT_MULTIPATCH) {
- psObject->nParts = MAX(1, nParts);
+/* Capture parts. Note that part type is optional, and */
+/* defaults to ring. */
+ if( nSHPType == SHPT_ARC || nSHPType == SHPT_POLYGON
+ || nSHPType == SHPT_ARCM || nSHPType == SHPT_POLYGONM
+ || nSHPType == SHPT_ARCZ || nSHPType == SHPT_POLYGONZ
+ psObject->nParts = MAX(1,nParts);
- psObject->panPartStart = (int *)
- malloc(sizeof(int) * psObject->nParts);
- psObject->panPartType = (int *)
+ psObject->panPartStart = (int *)
+ malloc(sizeof(int) * psObject->nParts);
+ psObject->panPartType = (int *)
- psObject->panPartStart[0] = 0;
- psObject->panPartType[0] = SHPP_RING;
+ psObject->panPartStart[0] = 0;
+ psObject->panPartType[0] = SHPP_RING;
+ for( i = 0; i < nParts; i++ )
+ psObject->panPartStart[i] = panPartStart[i];
- for (i = 0; i < nParts; i++) {
- psObject->panPartStart[i] = panPartStart[i];
+ if( panPartType != NULL )
+ psObject->panPartType[i] = panPartType[i];
+ else
+ psObject->panPartType[i] = SHPP_RING;
- if (panPartType != NULL)
- psObject->panPartType[i] = panPartType[i];
- else
- psObject->panPartType[i] = SHPP_RING;
- if (psObject->panPartStart[0] != 0)
+ if( psObject->panPartStart[0] != 0 )
- /* Capture vertices. Note that Z and M are optional, but X and */
- /* Y are not. */
- if (nVertices > 0) {
- psObject->padfX = (double *)calloc(sizeof(double), nVertices);
- psObject->padfY = (double *)calloc(sizeof(double), nVertices);
- psObject->padfZ = (double *)calloc(sizeof(double), nVertices);
- psObject->padfM = (double *)calloc(sizeof(double), nVertices);
+/* Capture vertices. Note that Z and M are optional, but X and */
+/* Y are not. */
+ if( nVertices > 0 )
+ psObject->padfX = (double *) calloc(sizeof(double),nVertices);
+ psObject->padfY = (double *) calloc(sizeof(double),nVertices);
+ psObject->padfZ = (double *) calloc(sizeof(double),nVertices);
+ psObject->padfM = (double *) calloc(sizeof(double),nVertices);
- assert(padfX != NULL);
- assert(padfY != NULL);
- for (i = 0; i < nVertices; i++) {
- psObject->padfX[i] = padfX[i];
- psObject->padfY[i] = padfY[i];
- if (padfZ != NULL && bHasZ)
- psObject->padfZ[i] = padfZ[i];
- if (padfM != NULL && bHasM)
- psObject->padfM[i] = padfM[i];
- psObject->bMeasureIsUsed = TRUE;
+ assert( padfX != NULL );
+ assert( padfY != NULL );
+ for( i = 0; i < nVertices; i++ )
+ psObject->padfX[i] = padfX[i];
+ psObject->padfY[i] = padfY[i];
+ if( padfZ != NULL && bHasZ )
+ psObject->padfZ[i] = padfZ[i];
+ if( padfM != NULL && bHasM )
+ psObject->padfM[i] = padfM[i];
+ psObject->bMeasureIsUsed = TRUE;
- /* Compute the extents. */
+/* Compute the extents. */
psObject->nVertices = nVertices;
- SHPComputeExtents(psObject);
+ SHPComputeExtents( psObject );
- return (psObject);
+ return( psObject );
@@ -1093,1028 +1102,1014 @@
/* Create a simple (common) shape object. Destroy with */
-SHPCreateSimpleObject(int nSHPType, int nVertices,
- const double *padfZ)
+SHPCreateSimpleObject( int nSHPType, int nVertices,
- return (SHPCreateObject(nSHPType, -1, 0, NULL, NULL,
- nVertices, padfX, padfY, padfZ, NULL));
+ return( SHPCreateObject( nSHPType, -1, 0, NULL, NULL,
+ nVertices, padfX, padfY, padfZ, NULL ) );
/* SHPWriteObject() */
/* Write out the vertices of a new structure. Note that it is */
/* only possible to write vertices at the end of the file. */
int SHPAPI_CALL
-SHPWriteObject(SHPHandle psSHP, int nShapeId, SHPObject * psObject)
+SHPWriteObject(SHPHandle psSHP, int nShapeId, SHPObject * psObject )
- int nRecordOffset, i, nRecordSize = 0;
- uchar *pabyRec;
- int32 i32;
+ int nRecordOffset, i, nRecordSize=0;
+ uchar *pabyRec;
+ int32 i32;
psSHP->bUpdated = TRUE;
- /* Ensure that shape object matches the type of the file it is */
- /* being written to. */
- assert(psObject->nSHPType == psSHP->nShapeType
- || psObject->nSHPType == SHPT_NULL);
+/* Ensure that shape object matches the type of the file it is */
+/* being written to. */
+ assert( psObject->nSHPType == psSHP->nShapeType
+ || psObject->nSHPType == SHPT_NULL );
- /* Ensure that -1 is used for appends. Either blow an */
- /* assertion, or if they are disabled, set the shapeid to -1 */
- /* for appends. */
- assert(nShapeId == -1 || (nShapeId >= 0 && nShapeId < psSHP->nRecords));
+/* Ensure that -1 is used for appends. Either blow an */
+/* assertion, or if they are disabled, set the shapeid to -1 */
+/* for appends. */
+ assert( nShapeId == -1
+ || (nShapeId >= 0 && nShapeId < psSHP->nRecords) );
- if (nShapeId != -1 && nShapeId >= psSHP->nRecords)
- nShapeId = -1;
+ if( nShapeId != -1 && nShapeId >= psSHP->nRecords )
+ nShapeId = -1;
- /* Add the new entity to the in memory index. */
- if (nShapeId == -1 && psSHP->nRecords + 1 > psSHP->nMaxRecords) {
- psSHP->nMaxRecords = (int)(psSHP->nMaxRecords * 1.3 + 100);
+/* Add the new entity to the in memory index. */
+ if( nShapeId == -1 && psSHP->nRecords+1 > psSHP->nMaxRecords )
+ psSHP->nMaxRecords =(int) ( psSHP->nMaxRecords * 1.3 + 100);
- psSHP->panRecOffset = (int *)
- SfRealloc(psSHP->panRecOffset, sizeof(int) * psSHP->nMaxRecords);
- psSHP->panRecSize = (int *)
- SfRealloc(psSHP->panRecSize, sizeof(int) * psSHP->nMaxRecords);
+ psSHP->panRecOffset = (int *)
+ SfRealloc(psSHP->panRecOffset,sizeof(int) * psSHP->nMaxRecords );
+ psSHP->panRecSize = (int *)
+ SfRealloc(psSHP->panRecSize,sizeof(int) * psSHP->nMaxRecords );
- /* Initialize record. */
- pabyRec = (uchar *) malloc(psObject->nVertices * 4 * sizeof(double)
+/* Initialize record. */
+ pabyRec = (uchar *) malloc(psObject->nVertices * 4 * sizeof(double)
+ psObject->nParts * 8 + 128);
+/* Extract vertices for a Polygon or Arc. */
+ if( psObject->nSHPType == SHPT_POLYGON
+ || psObject->nSHPType == SHPT_POLYGONZ
+ || psObject->nSHPType == SHPT_POLYGONM
+ || psObject->nSHPType == SHPT_ARC
+ || psObject->nSHPType == SHPT_ARCZ
+ || psObject->nSHPType == SHPT_ARCM
+ || psObject->nSHPType == SHPT_MULTIPATCH )
+ int32 nPoints, nParts;
+ int i;
- /* Extract vertices for a Polygon or Arc. */
- if (psObject->nSHPType == SHPT_POLYGON
- || psObject->nSHPType == SHPT_POLYGONZ
- || psObject->nSHPType == SHPT_POLYGONM
- || psObject->nSHPType == SHPT_ARC
- || psObject->nSHPType == SHPT_ARCZ
- || psObject->nSHPType == SHPT_ARCM
- || psObject->nSHPType == SHPT_MULTIPATCH) {
- int32 nPoints, nParts;
- int i;
nPoints = psObject->nVertices;
nParts = psObject->nParts;
- _SHPSetBounds(pabyRec + 12, psObject);
+ _SHPSetBounds( pabyRec + 12, psObject );
- if (bBigEndian)
- SwapWord(4, &nPoints);
- if (bBigEndian)
- SwapWord(4, &nParts);
+ if( bBigEndian ) SwapWord( 4, &nPoints );
+ if( bBigEndian ) SwapWord( 4, &nParts );
- ByteCopy(&nPoints, pabyRec + 40 + 8, 4);
- ByteCopy(&nParts, pabyRec + 36 + 8, 4);
+ ByteCopy( &nPoints, pabyRec + 40 + 8, 4 );
+ ByteCopy( &nParts, pabyRec + 36 + 8, 4 );
- nRecordSize = 52;
+ nRecordSize = 52;
- * Write part start positions.
- ByteCopy(psObject->panPartStart, pabyRec + 44 + 8,
- 4 * psObject->nParts);
- for (i = 0; i < psObject->nParts; i++) {
- if (bBigEndian)
- SwapWord(4, pabyRec + 44 + 8 + 4 * i);
- nRecordSize += 4;
+ * Write part start positions.
+ ByteCopy( psObject->panPartStart, pabyRec + 44 + 8,
+ 4 * psObject->nParts );
+ for( i = 0; i < psObject->nParts; i++ )
+ if( bBigEndian ) SwapWord( 4, pabyRec + 44 + 8 + 4*i );
+ nRecordSize += 4;
- * Write multipatch part types if needed.
- if (psObject->nSHPType == SHPT_MULTIPATCH) {
- memcpy(pabyRec + nRecordSize, psObject->panPartType,
- if (bBigEndian)
- SwapWord(4, pabyRec + nRecordSize);
- nRecordSize += 4;
+ * Write multipatch part types if needed.
+ if( psObject->nSHPType == SHPT_MULTIPATCH )
+ memcpy( pabyRec + nRecordSize, psObject->panPartType,
+ 4*psObject->nParts );
+ if( bBigEndian ) SwapWord( 4, pabyRec + nRecordSize );
+ nRecordSize += 4;
- * Write the (x,y) vertex values.
- ByteCopy(psObject->padfX + i, pabyRec + nRecordSize, 8);
- ByteCopy(psObject->padfY + i, pabyRec + nRecordSize + 8, 8);
+ * Write the (x,y) vertex values.
+ ByteCopy( psObject->padfX + i, pabyRec + nRecordSize, 8 );
+ ByteCopy( psObject->padfY + i, pabyRec + nRecordSize + 8, 8 );
- if (bBigEndian)
- SwapWord(8, pabyRec + nRecordSize);
+ if( bBigEndian )
+ SwapWord( 8, pabyRec + nRecordSize );
+ if( bBigEndian )
+ SwapWord( 8, pabyRec + nRecordSize + 8 );
- if (bBigEndian)
- SwapWord(8, pabyRec + nRecordSize + 8);
- nRecordSize += 2 * 8;
+ nRecordSize += 2 * 8;
- * Write the Z coordinates (if any).
- if (psObject->nSHPType == SHPT_POLYGONZ
- ByteCopy(&(psObject->dfZMin), pabyRec + nRecordSize, 8);
- if (bBigEndian)
- nRecordSize += 8;
+ * Write the Z coordinates (if any).
+ if( psObject->nSHPType == SHPT_POLYGONZ
+ ByteCopy( &(psObject->dfZMin), pabyRec + nRecordSize, 8 );
+ if( bBigEndian ) SwapWord( 8, pabyRec + nRecordSize );
+ nRecordSize += 8;
+ ByteCopy( &(psObject->dfZMax), pabyRec + nRecordSize, 8 );
+ nRecordSize += 8;
- ByteCopy(&(psObject->dfZMax), pabyRec + nRecordSize, 8);
- if (bBigEndian)
- nRecordSize += 8;
+ ByteCopy( psObject->padfZ + i, pabyRec + nRecordSize, 8 );
+ nRecordSize += 8;
- ByteCopy(psObject->padfZ + i, pabyRec + nRecordSize, 8);
- if (bBigEndian)
- nRecordSize += 8;
+ * Write the M values, if any.
+ if( psObject->bMeasureIsUsed
+ && (psObject->nSHPType == SHPT_POLYGONM
+#ifndef DISABLE_MULTIPATCH_MEASURE
+#endif
+ || psObject->nSHPType == SHPT_ARCZ) )
+ ByteCopy( &(psObject->dfMMin), pabyRec + nRecordSize, 8 );
+ nRecordSize += 8;
+ ByteCopy( &(psObject->dfMMax), pabyRec + nRecordSize, 8 );
+ nRecordSize += 8;
- * Write the M values, if any.
- if (psObject->bMeasureIsUsed
- && (psObject->nSHPType == SHPT_POLYGONM
-#ifndef DISABLE_MULTIPATCH_MEASURE
-#endif
- || psObject->nSHPType == SHPT_ARCZ)) {
- ByteCopy(&(psObject->dfMMin), pabyRec + nRecordSize, 8);
- if (bBigEndian)
- nRecordSize += 8;
- ByteCopy(&(psObject->dfMMax), pabyRec + nRecordSize, 8);
- if (bBigEndian)
- nRecordSize += 8;
- ByteCopy(psObject->padfM + i, pabyRec + nRecordSize, 8);
- if (bBigEndian)
- nRecordSize += 8;
+ ByteCopy( psObject->padfM + i, pabyRec + nRecordSize, 8 );
+ nRecordSize += 8;
- /* Extract vertices for a MultiPoint. */
- else if (psObject->nSHPType == SHPT_MULTIPOINT
- || psObject->nSHPType == SHPT_MULTIPOINTZ
- || psObject->nSHPType == SHPT_MULTIPOINTM) {
- int32 nPoints;
- int i;
+/* Extract vertices for a MultiPoint. */
+ else if( psObject->nSHPType == SHPT_MULTIPOINT
+ || psObject->nSHPType == SHPT_MULTIPOINTZ
+ || psObject->nSHPType == SHPT_MULTIPOINTM )
+ int32 nPoints;
+ int i;
- if (bBigEndian)
- ByteCopy(&nPoints, pabyRec + 44, 4);
+ ByteCopy( &nPoints, pabyRec + 44, 4 );
+ ByteCopy( psObject->padfX + i, pabyRec + 48 + i*16, 8 );
+ ByteCopy( psObject->padfY + i, pabyRec + 48 + i*16 + 8, 8 );
- ByteCopy(psObject->padfX + i, pabyRec + 48 + i * 16, 8);
- ByteCopy(psObject->padfY + i, pabyRec + 48 + i * 16 + 8, 8);
- if (bBigEndian)
- SwapWord(8, pabyRec + 48 + i * 16);
- if (bBigEndian)
- SwapWord(8, pabyRec + 48 + i * 16 + 8);
+ if( bBigEndian ) SwapWord( 8, pabyRec + 48 + i*16 );
+ if( bBigEndian ) SwapWord( 8, pabyRec + 48 + i*16 + 8 );
nRecordSize = 48 + 16 * psObject->nVertices;
- if (psObject->nSHPType == SHPT_MULTIPOINTZ) {
- if (bBigEndian)
- nRecordSize += 8;
+ if( psObject->nSHPType == SHPT_MULTIPOINTZ )
+ nRecordSize += 8;
- if (bBigEndian)
- nRecordSize += 8;
+ nRecordSize += 8;
+ nRecordSize += 8;
- if (bBigEndian)
- nRecordSize += 8;
+ && (psObject->nSHPType == SHPT_MULTIPOINTZ
+ || psObject->nSHPType == SHPT_MULTIPOINTM) )
+ nRecordSize += 8;
- && (psObject->nSHPType == SHPT_MULTIPOINTZ
- || psObject->nSHPType == SHPT_MULTIPOINTM)) {
- if (bBigEndian)
- nRecordSize += 8;
- if (bBigEndian)
- nRecordSize += 8;
- if (bBigEndian)
- nRecordSize += 8;
+ nRecordSize += 8;
+ nRecordSize += 8;
- /* Write point. */
- else if (psObject->nSHPType == SHPT_POINT
- || psObject->nSHPType == SHPT_POINTZ
- || psObject->nSHPType == SHPT_POINTM) {
- ByteCopy(psObject->padfX, pabyRec + 12, 8);
- ByteCopy(psObject->padfY, pabyRec + 20, 8);
+/* Write point. */
+ else if( psObject->nSHPType == SHPT_POINT
+ || psObject->nSHPType == SHPT_POINTZ
+ || psObject->nSHPType == SHPT_POINTM )
+ ByteCopy( psObject->padfX, pabyRec + 12, 8 );
+ ByteCopy( psObject->padfY, pabyRec + 20, 8 );
- if (bBigEndian)
- SwapWord(8, pabyRec + 12);
- if (bBigEndian)
- SwapWord(8, pabyRec + 20);
+ if( bBigEndian ) SwapWord( 8, pabyRec + 12 );
+ if( bBigEndian ) SwapWord( 8, pabyRec + 20 );
- nRecordSize = 28;
- if (psObject->nSHPType == SHPT_POINTZ) {
- ByteCopy(psObject->padfZ, pabyRec + nRecordSize, 8);
- if (bBigEndian)
- nRecordSize += 8;
- && (psObject->nSHPType == SHPT_POINTZ
- || psObject->nSHPType == SHPT_POINTM)) {
- ByteCopy(psObject->padfM, pabyRec + nRecordSize, 8);
- if (bBigEndian)
- nRecordSize += 8;
+ nRecordSize = 28;
+ if( psObject->nSHPType == SHPT_POINTZ )
+ ByteCopy( psObject->padfZ, pabyRec + nRecordSize, 8 );
+ nRecordSize += 8;
+ && (psObject->nSHPType == SHPT_POINTZ
+ || psObject->nSHPType == SHPT_POINTM) )
+ ByteCopy( psObject->padfM, pabyRec + nRecordSize, 8 );
+ nRecordSize += 8;
- /* Not much to do for null geometries. */
- else if (psObject->nSHPType == SHPT_NULL) {
- nRecordSize = 12;
+/* Not much to do for null geometries. */
+ else if( psObject->nSHPType == SHPT_NULL )
+ nRecordSize = 12;
- else {
- /* unknown type */
- assert(FALSE);
+ else
+ /* unknown type */
+ assert( FALSE );
- /* Establish where we are going to put this record. If we are */
- /* rewriting and existing record, and it will fit, then put it */
- /* back where the original came from. Otherwise write at the end. */
- if (nShapeId == -1 || psSHP->panRecSize[nShapeId] < nRecordSize - 8) {
- if (nShapeId == -1)
- nShapeId = psSHP->nRecords++;
+/* Establish where we are going to put this record. If we are */
+/* rewriting and existing record, and it will fit, then put it */
+/* back where the original came from. Otherwise write at the end. */
+ if( nShapeId == -1 || psSHP->panRecSize[nShapeId] < nRecordSize-8 )
+ if( nShapeId == -1 )
+ nShapeId = psSHP->nRecords++;
- psSHP->panRecOffset[nShapeId] = nRecordOffset = psSHP->nFileSize;
- psSHP->panRecSize[nShapeId] = nRecordSize - 8;
- psSHP->nFileSize += nRecordSize;
+ psSHP->panRecOffset[nShapeId] = nRecordOffset = psSHP->nFileSize;
+ psSHP->panRecSize[nShapeId] = nRecordSize-8;
+ psSHP->nFileSize += nRecordSize;
- else {
- nRecordOffset = psSHP->panRecOffset[nShapeId];
+ else
+ nRecordOffset = psSHP->panRecOffset[nShapeId];
+/* Set the shape type, record number, and record size. */
+ i32 = nShapeId+1; /* record # */
+ if( !bBigEndian ) SwapWord( 4, &i32 );
+ ByteCopy( &i32, pabyRec, 4 );
- /* Set the shape type, record number, and record size. */
- i32 = nShapeId + 1; /* record # */
- if (!bBigEndian)
- SwapWord(4, &i32);
- ByteCopy(&i32, pabyRec, 4);
+ i32 = (nRecordSize-8)/2; /* record size */
+ ByteCopy( &i32, pabyRec + 4, 4 );
- i32 = (nRecordSize - 8) / 2; /* record size */
- if (!bBigEndian)
- ByteCopy(&i32, pabyRec + 4, 4);
+ i32 = psObject->nSHPType; /* shape type */
+ if( bBigEndian ) SwapWord( 4, &i32 );
+ ByteCopy( &i32, pabyRec + 8, 4 );
- i32 = psObject->nSHPType; /* shape type */
- if (bBigEndian)
- ByteCopy(&i32, pabyRec + 8, 4);
- /* Write out record. */
- if (psSHP->sHooks.FSeek(psSHP->fpSHP, nRecordOffset, 0) != 0
- || psSHP->sHooks.FWrite(pabyRec, nRecordSize, 1, psSHP->fpSHP) < 1) {
- psSHP->sHooks.
- Error
- ("Error in psSHP->sHooks.FSeek() or fwrite() writing object to .shp file.");
- free(pabyRec);
- return -1;
+/* Write out record. */
+ if( psSHP->sHooks.FSeek( psSHP->fpSHP, nRecordOffset, 0 ) != 0
+ || psSHP->sHooks.FWrite( pabyRec, nRecordSize, 1, psSHP->fpSHP ) < 1 )
+ psSHP->sHooks.Error( "Error in psSHP->sHooks.FSeek() or fwrite() writing object to .shp file." );
+ free( pabyRec );
+ return -1;
+ free( pabyRec );
- free(pabyRec);
- /* Expand file wide bounds based on this shape. */
- if (psSHP->adBoundsMin[0] == 0.0
- && psSHP->adBoundsMax[0] == 0.0
- && psSHP->adBoundsMin[1] == 0.0 && psSHP->adBoundsMax[1] == 0.0) {
- if (psObject->nSHPType == SHPT_NULL || psObject->nVertices == 0) {
- psSHP->adBoundsMin[0] = psSHP->adBoundsMax[0] = 0.0;
- psSHP->adBoundsMin[1] = psSHP->adBoundsMax[1] = 0.0;
- psSHP->adBoundsMin[2] = psSHP->adBoundsMax[2] = 0.0;
- psSHP->adBoundsMin[3] = psSHP->adBoundsMax[3] = 0.0;
- else {
- psObject->padfX[0];
- psObject->padfY[0];
- psObject->padfZ[0];
- psObject->padfM[0];
+/* Expand file wide bounds based on this shape. */
+ if( psSHP->adBoundsMin[0] == 0.0
+ && psSHP->adBoundsMax[0] == 0.0
+ && psSHP->adBoundsMin[1] == 0.0
+ && psSHP->adBoundsMax[1] == 0.0 )
+ if( psObject->nSHPType == SHPT_NULL || psObject->nVertices == 0 )
+ psSHP->adBoundsMin[0] = psSHP->adBoundsMax[0] = 0.0;
+ psSHP->adBoundsMin[1] = psSHP->adBoundsMax[1] = 0.0;
+ psSHP->adBoundsMin[2] = psSHP->adBoundsMax[2] = 0.0;
+ psSHP->adBoundsMin[3] = psSHP->adBoundsMax[3] = 0.0;
+ else
+ psSHP->adBoundsMin[0] = psSHP->adBoundsMax[0] = psObject->padfX[0];
+ psSHP->adBoundsMin[1] = psSHP->adBoundsMax[1] = psObject->padfY[0];
+ psSHP->adBoundsMin[2] = psSHP->adBoundsMax[2] = psObject->padfZ[0];
+ psSHP->adBoundsMin[3] = psSHP->adBoundsMax[3] = psObject->padfM[0];
- MIN(psSHP->adBoundsMin[0], psObject->padfX[i]);
- MIN(psSHP->adBoundsMin[1], psObject->padfY[i]);
- MIN(psSHP->adBoundsMin[2], psObject->padfZ[i]);
- MIN(psSHP->adBoundsMin[3], psObject->padfM[i]);
- psSHP->adBoundsMax[0] =
- MAX(psSHP->adBoundsMax[0], psObject->padfX[i]);
- psSHP->adBoundsMax[1] =
- MAX(psSHP->adBoundsMax[1], psObject->padfY[i]);
- psSHP->adBoundsMax[2] =
- MAX(psSHP->adBoundsMax[2], psObject->padfZ[i]);
- psSHP->adBoundsMax[3] =
- MAX(psSHP->adBoundsMax[3], psObject->padfM[i]);
+ psSHP->adBoundsMin[0] = MIN(psSHP->adBoundsMin[0],psObject->padfX[i]);
+ psSHP->adBoundsMin[1] = MIN(psSHP->adBoundsMin[1],psObject->padfY[i]);
+ psSHP->adBoundsMin[2] = MIN(psSHP->adBoundsMin[2],psObject->padfZ[i]);
+ psSHP->adBoundsMin[3] = MIN(psSHP->adBoundsMin[3],psObject->padfM[i]);
+ psSHP->adBoundsMax[0] = MAX(psSHP->adBoundsMax[0],psObject->padfX[i]);
+ psSHP->adBoundsMax[1] = MAX(psSHP->adBoundsMax[1],psObject->padfY[i]);
+ psSHP->adBoundsMax[2] = MAX(psSHP->adBoundsMax[2],psObject->padfZ[i]);
+ psSHP->adBoundsMax[3] = MAX(psSHP->adBoundsMax[3],psObject->padfM[i]);
- return (nShapeId);
+ return( nShapeId );
/* SHPReadObject() */
-/* Read the vertices, parts, and other non-attribute information */
-/* for one shape. */
+/* Read the vertices, parts, and other non-attribute information */
+/* for one shape. */
-SHPObject SHPAPI_CALL1(*) SHPReadObject(SHPHandle psSHP, int hEntity)
+SHPReadObject( SHPHandle psSHP, int hEntity )
- int nEntitySize, nRequiredSize;
- SHPObject *psShape;
- char pszErrorMsg[128];
+ int nEntitySize, nRequiredSize;
+ SHPObject *psShape;
+ char pszErrorMsg[128];
- /* Validate the record/entity number. */
- if (hEntity < 0 || hEntity >= psSHP->nRecords)
- return (NULL);
+/* Validate the record/entity number. */
+ if( hEntity < 0 || hEntity >= psSHP->nRecords )
+ return( NULL );
- /* Ensure our record buffer is large enough. */
- nEntitySize = psSHP->panRecSize[hEntity] + 8;
- if (nEntitySize > psSHP->nBufSize) {
- psSHP->pabyRec = (uchar *) SfRealloc(psSHP->pabyRec, nEntitySize);
- if (psSHP->pabyRec == NULL) {
+/* Ensure our record buffer is large enough. */
+ nEntitySize = psSHP->panRecSize[hEntity]+8;
+ if( nEntitySize > psSHP->nBufSize )
+ psSHP->pabyRec = (uchar *) SfRealloc(psSHP->pabyRec,nEntitySize);
+ if (psSHP->pabyRec == NULL)
- /* Reallocate previous successfull size for following features */
- psSHP->pabyRec = malloc(psSHP->nBufSize);
+ /* Reallocate previous successfull size for following features */
+ psSHP->pabyRec = malloc(psSHP->nBufSize);
- sprintf(szError,
- "Not enough memory to allocate requested memory (nBufSize=%d). "
- "Probably broken SHP file", psSHP->nBufSize);
- return NULL;
+ sprintf( szError,
+ "Not enough memory to allocate requested memory (nBufSize=%d). "
+ "Probably broken SHP file", psSHP->nBufSize );
+ return NULL;
- /* Only set new buffer size after successfull alloc */
+ /* Only set new buffer size after successfull alloc */
psSHP->nBufSize = nEntitySize;
/* In case we were not able to reallocate the buffer on a previous step */
- return NULL;
+ return NULL;
- /* Read the record. */
- if (psSHP->sHooks.FSeek(psSHP->fpSHP, psSHP->panRecOffset[hEntity], 0) !=
- 0 ||
- psSHP->sHooks.FRead(psSHP->pabyRec, nEntitySize, 1,
- psSHP->fpSHP) != 1) {
- * TODO - mloskot: Consider detailed diagnostics of shape file,
- * for example to detect if file is truncated.
+/* Read the record. */
+ if( psSHP->sHooks.FSeek( psSHP->fpSHP, psSHP->panRecOffset[hEntity], 0 ) != 0
+ || psSHP->sHooks.FRead( psSHP->pabyRec, nEntitySize, 1,
+ psSHP->fpSHP ) != 1 )
+ * TODO - mloskot: Consider detailed diagnostics of shape file,
+ * for example to detect if file is truncated.
- psSHP->sHooks.
- Error
- ("Error in fseek() or fread() reading object from .shp file.");
- return NULL;
+ psSHP->sHooks.Error( "Error in fseek() or fread() reading object from .shp file." );
+ return NULL;
- /* Allocate and minimally initialize the object. */
- psShape = (SHPObject *) calloc(1, sizeof(SHPObject));
+/* Allocate and minimally initialize the object. */
+ psShape = (SHPObject *) calloc(1,sizeof(SHPObject));
psShape->nShapeId = hEntity;
psShape->bMeasureIsUsed = FALSE;
- if (8 + 4 > nEntitySize) {
- snprintf(pszErrorMsg, 128,
- "Corrupted .shp file : shape %d : nEntitySize = %d", hEntity,
- nEntitySize);
- psSHP->sHooks.Error(pszErrorMsg);
- SHPDestroyObject(psShape);
- return NULL;
+ if ( 8 + 4 > nEntitySize )
+ snprintf(pszErrorMsg, 128, "Corrupted .shp file : shape %d : nEntitySize = %d",
+ hEntity, nEntitySize);
+ psSHP->sHooks.Error( pszErrorMsg );
+ SHPDestroyObject(psShape);
+ return NULL;
- memcpy(&psShape->nSHPType, psSHP->pabyRec + 8, 4);
+ memcpy( &psShape->nSHPType, psSHP->pabyRec + 8, 4 );
- if (bBigEndian)
- SwapWord(4, &(psShape->nSHPType));
+ if( bBigEndian ) SwapWord( 4, &(psShape->nSHPType) );
- if (psShape->nSHPType == SHPT_POLYGON || psShape->nSHPType == SHPT_ARC
- || psShape->nSHPType == SHPT_POLYGONZ
- || psShape->nSHPType == SHPT_POLYGONM
- || psShape->nSHPType == SHPT_ARCZ
- || psShape->nSHPType == SHPT_ARCM
- || psShape->nSHPType == SHPT_MULTIPATCH) {
- int i, nOffset;
+ if( psShape->nSHPType == SHPT_POLYGON || psShape->nSHPType == SHPT_ARC
+ || psShape->nSHPType == SHPT_POLYGONZ
+ || psShape->nSHPType == SHPT_POLYGONM
+ || psShape->nSHPType == SHPT_ARCZ
+ || psShape->nSHPType == SHPT_ARCM
+ || psShape->nSHPType == SHPT_MULTIPATCH )
+ int i, nOffset;
- if (40 + 8 + 4 > nEntitySize) {
- hEntity, nEntitySize);
- return NULL;
- /* Get the X/Y bounds. */
- memcpy(&(psShape->dfXMin), psSHP->pabyRec + 8 + 4, 8);
- memcpy(&(psShape->dfYMin), psSHP->pabyRec + 8 + 12, 8);
- memcpy(&(psShape->dfXMax), psSHP->pabyRec + 8 + 20, 8);
- memcpy(&(psShape->dfYMax), psSHP->pabyRec + 8 + 28, 8);
+ if ( 40 + 8 + 4 > nEntitySize )
+ return NULL;
+/* Get the X/Y bounds. */
+ memcpy( &(psShape->dfXMin), psSHP->pabyRec + 8 + 4, 8 );
+ memcpy( &(psShape->dfYMin), psSHP->pabyRec + 8 + 12, 8 );
+ memcpy( &(psShape->dfXMax), psSHP->pabyRec + 8 + 20, 8 );
+ memcpy( &(psShape->dfYMax), psSHP->pabyRec + 8 + 28, 8 );
- if (bBigEndian)
- SwapWord(8, &(psShape->dfXMin));
- if (bBigEndian)
- SwapWord(8, &(psShape->dfYMin));
- if (bBigEndian)
- SwapWord(8, &(psShape->dfXMax));
- if (bBigEndian)
- SwapWord(8, &(psShape->dfYMax));
+ if( bBigEndian ) SwapWord( 8, &(psShape->dfXMin) );
+ if( bBigEndian ) SwapWord( 8, &(psShape->dfYMin) );
+ if( bBigEndian ) SwapWord( 8, &(psShape->dfXMax) );
+ if( bBigEndian ) SwapWord( 8, &(psShape->dfYMax) );
- /* Extract part/point count, and build vertex and part arrays */
- /* to proper size. */
- memcpy(&nPoints, psSHP->pabyRec + 40 + 8, 4);
- memcpy(&nParts, psSHP->pabyRec + 36 + 8, 4);
+/* Extract part/point count, and build vertex and part arrays */
+/* to proper size. */
+ memcpy( &nPoints, psSHP->pabyRec + 40 + 8, 4 );
+ memcpy( &nParts, psSHP->pabyRec + 36 + 8, 4 );
- if (bBigEndian)
- if (bBigEndian)
- if (nPoints < 0 || nParts < 0 ||
- nPoints > 50 * 1000 * 1000 || nParts > 10 * 1000 * 1000) {
- "Corrupted .shp file : shape %d, nPoints=%d, nParts=%d.",
- hEntity, nPoints, nParts);
- return NULL;
+ if (nPoints < 0 || nParts < 0 ||
+ nPoints > 50 * 1000 * 1000 || nParts > 10 * 1000 * 1000)
+ snprintf(pszErrorMsg, 128, "Corrupted .shp file : shape %d, nPoints=%d, nParts=%d.",
+ hEntity, nPoints, nParts);
+ return NULL;
+ /* With the previous checks on nPoints and nParts, */
+ /* we should not overflow here and after */
+ /* since 50 M * (16 + 8 + 8) = 1 600 MB */
+ nRequiredSize = 44 + 8 + 4 * nParts + 16 * nPoints;
+ if ( psShape->nSHPType == SHPT_POLYGONZ
+ nRequiredSize += 16 + 8 * nPoints;
+ if( psShape->nSHPType == SHPT_MULTIPATCH )
+ nRequiredSize += 4 * nParts;
+ if (nRequiredSize > nEntitySize)
+ snprintf(pszErrorMsg, 128, "Corrupted .shp file : shape %d, nPoints=%d, nParts=%d, nEntitySize=%d.",
+ hEntity, nPoints, nParts, nEntitySize);
+ return NULL;
- /* With the previous checks on nPoints and nParts, */
- /* we should not overflow here and after */
- /* since 50 M * (16 + 8 + 8) = 1 600 MB */
- nRequiredSize = 44 + 8 + 4 * nParts + 16 * nPoints;
- if (psShape->nSHPType == SHPT_POLYGONZ
- nRequiredSize += 16 + 8 * nPoints;
- if (psShape->nSHPType == SHPT_MULTIPATCH) {
- nRequiredSize += 4 * nParts;
- if (nRequiredSize > nEntitySize) {
- "Corrupted .shp file : shape %d, nPoints=%d, nParts=%d, nEntitySize=%d.",
- hEntity, nPoints, nParts, nEntitySize);
- return NULL;
psShape->nVertices = nPoints;
- psShape->padfX = (double *)calloc(nPoints, sizeof(double));
- psShape->padfY = (double *)calloc(nPoints, sizeof(double));
- psShape->padfZ = (double *)calloc(nPoints, sizeof(double));
- psShape->padfM = (double *)calloc(nPoints, sizeof(double));
+ psShape->padfX = (double *) calloc(nPoints,sizeof(double));
+ psShape->padfY = (double *) calloc(nPoints,sizeof(double));
+ psShape->padfZ = (double *) calloc(nPoints,sizeof(double));
+ psShape->padfM = (double *) calloc(nPoints,sizeof(double));
psShape->nParts = nParts;
- psShape->panPartStart = (int *)calloc(nParts, sizeof(int));
- psShape->panPartType = (int *)calloc(nParts, sizeof(int));
+ psShape->panPartStart = (int *) calloc(nParts,sizeof(int));
+ psShape->panPartType = (int *) calloc(nParts,sizeof(int));
+ if (psShape->padfX == NULL ||
+ psShape->padfY == NULL ||
+ psShape->padfZ == NULL ||
+ psShape->padfM == NULL ||
+ psShape->panPartStart == NULL ||
+ psShape->panPartType == NULL)
+ "Not enough memory to allocate requested memory (nPoints=%d, nParts=%d) for shape %d. "
+ "Probably broken SHP file", hEntity, nPoints, nParts );
+ return NULL;
- if (psShape->padfX == NULL ||
- psShape->padfY == NULL ||
- psShape->padfZ == NULL ||
- psShape->padfM == NULL ||
- psShape->panPartStart == NULL || psShape->panPartType == NULL) {
- "Not enough memory to allocate requested memory (nPoints=%d, nParts=%d) for shape %d. "
- "Probably broken SHP file", hEntity, nPoints, nParts);
- return NULL;
+ psShape->panPartType[i] = SHPP_RING;
- psShape->panPartType[i] = SHPP_RING;
+/* Copy out the part array from the record. */
+ memcpy( psShape->panPartStart, psSHP->pabyRec + 44 + 8, 4 * nParts );
+ if( bBigEndian ) SwapWord( 4, psShape->panPartStart+i );
- /* Copy out the part array from the record. */
- memcpy(psShape->panPartStart, psSHP->pabyRec + 44 + 8, 4 * nParts);
- if (bBigEndian)
- SwapWord(4, psShape->panPartStart + i);
- /* We check that the offset is inside the vertex array */
- if (psShape->panPartStart[i] < 0 ||
- psShape->panPartStart[i] >= psShape->nVertices) {
- "Corrupted .shp file : shape %d : panPartStart[%d] = %d, nVertices = %d",
- hEntity, i, psShape->panPartStart[i],
- psShape->nVertices);
- return NULL;
- if (i > 0 &&
- psShape->panPartStart[i] <= psShape->panPartStart[i - 1]) {
- "Corrupted .shp file : shape %d : panPartStart[%d] = %d, panPartStart[%d] = %d",
- hEntity, i, psShape->panPartStart[i], i - 1,
- psShape->panPartStart[i - 1]);
- return NULL;
+ /* We check that the offset is inside the vertex array */
+ if (psShape->panPartStart[i] < 0 ||
+ psShape->panPartStart[i] >= psShape->nVertices)
+ snprintf(pszErrorMsg, 128, "Corrupted .shp file : shape %d : panPartStart[%d] = %d, nVertices = %d",
+ hEntity, i, psShape->panPartStart[i], psShape->nVertices);
+ return NULL;
+ if (i > 0 && psShape->panPartStart[i] <= psShape->panPartStart[i-1])
+ snprintf(pszErrorMsg, 128, "Corrupted .shp file : shape %d : panPartStart[%d] = %d, panPartStart[%d] = %d",
+ hEntity, i, psShape->panPartStart[i], i - 1, psShape->panPartStart[i - 1]);
+ return NULL;
- nOffset = 44 + 8 + 4 * nParts;
+ nOffset = 44 + 8 + 4*nParts;
- /* If this is a multipatch, we will also have parts types. */
- memcpy(psShape->panPartType, psSHP->pabyRec + nOffset,
- 4 * nParts);
- if (bBigEndian)
- SwapWord(4, psShape->panPartType + i);
+/* If this is a multipatch, we will also have parts types. */
+ memcpy( psShape->panPartType, psSHP->pabyRec + nOffset, 4*nParts );
+ if( bBigEndian ) SwapWord( 4, psShape->panPartType+i );
- nOffset += 4 * nParts;
+ nOffset += 4*nParts;
+/* Copy out the vertices from the record. */
+ for( i = 0; i < nPoints; i++ )
+ memcpy(psShape->padfX + i,
+ psSHP->pabyRec + nOffset + i * 16,
+ 8 );
- /* Copy out the vertices from the record. */
- for (i = 0; i < nPoints; i++) {
- memcpy(psShape->padfX + i, psSHP->pabyRec + nOffset + i * 16, 8);
memcpy(psShape->padfY + i,
- psSHP->pabyRec + nOffset + i * 16 + 8, 8);
+ psSHP->pabyRec + nOffset + i * 16 + 8,
+ 8 );
- if (bBigEndian)
- SwapWord(8, psShape->padfX + i);
- if (bBigEndian)
- SwapWord(8, psShape->padfY + i);
+ if( bBigEndian ) SwapWord( 8, psShape->padfX + i );
+ if( bBigEndian ) SwapWord( 8, psShape->padfY + i );
- nOffset += 16 * nPoints;
+ nOffset += 16*nPoints;
+/* If we have a Z coordinate, collect that now. */
+ if( psShape->nSHPType == SHPT_POLYGONZ
+ memcpy( &(psShape->dfZMin), psSHP->pabyRec + nOffset, 8 );
+ memcpy( &(psShape->dfZMax), psSHP->pabyRec + nOffset + 8, 8 );
+ if( bBigEndian ) SwapWord( 8, &(psShape->dfZMin) );
+ if( bBigEndian ) SwapWord( 8, &(psShape->dfZMax) );
+ memcpy( psShape->padfZ + i,
+ psSHP->pabyRec + nOffset + 16 + i*8, 8 );
+ if( bBigEndian ) SwapWord( 8, psShape->padfZ + i );
- /* If we have a Z coordinate, collect that now. */
- memcpy(&(psShape->dfZMin), psSHP->pabyRec + nOffset, 8);
- memcpy(&(psShape->dfZMax), psSHP->pabyRec + nOffset + 8, 8);
+ nOffset += 16 + 8*nPoints;
- if (bBigEndian)
- SwapWord(8, &(psShape->dfZMin));
- if (bBigEndian)
- SwapWord(8, &(psShape->dfZMax));
- memcpy(psShape->padfZ + i,
- psSHP->pabyRec + nOffset + 16 + i * 8, 8);
- if (bBigEndian)
- SwapWord(8, psShape->padfZ + i);
- nOffset += 16 + 8 * nPoints;
- /* If we have a M measure value, then read it now. We assume */
- /* that the measure can be present for any shape if the size is */
- /* big enough, but really it will only occur for the Z shapes */
- /* (options), and the M shapes. */
- if (nEntitySize >= nOffset + 16 + 8 * nPoints) {
- memcpy(&(psShape->dfMMin), psSHP->pabyRec + nOffset, 8);
- memcpy(&(psShape->dfMMax), psSHP->pabyRec + nOffset + 8, 8);
- if (bBigEndian)
- SwapWord(8, &(psShape->dfMMin));
- if (bBigEndian)
- SwapWord(8, &(psShape->dfMMax));
- memcpy(psShape->padfM + i,
- if (bBigEndian)
- SwapWord(8, psShape->padfM + i);
- psShape->bMeasureIsUsed = TRUE;
+/* If we have a M measure value, then read it now. We assume */
+/* that the measure can be present for any shape if the size is */
+/* big enough, but really it will only occur for the Z shapes */
+/* (options), and the M shapes. */
+ if( nEntitySize >= nOffset + 16 + 8*nPoints )
+ memcpy( &(psShape->dfMMin), psSHP->pabyRec + nOffset, 8 );
+ memcpy( &(psShape->dfMMax), psSHP->pabyRec + nOffset + 8, 8 );
+ if( bBigEndian ) SwapWord( 8, &(psShape->dfMMin) );
+ if( bBigEndian ) SwapWord( 8, &(psShape->dfMMax) );
+ memcpy( psShape->padfM + i,
+ if( bBigEndian ) SwapWord( 8, psShape->padfM + i );
+ psShape->bMeasureIsUsed = TRUE;
- else if (psShape->nSHPType == SHPT_MULTIPOINT
- || psShape->nSHPType == SHPT_MULTIPOINTM
- || psShape->nSHPType == SHPT_MULTIPOINTZ) {
- int32 nPoints;
- int i, nOffset;
+ else if( psShape->nSHPType == SHPT_MULTIPOINT
+ || psShape->nSHPType == SHPT_MULTIPOINTM
+ || psShape->nSHPType == SHPT_MULTIPOINTZ )
+ int32 nPoints;
+ int i, nOffset;
- if (44 + 4 > nEntitySize) {
- return NULL;
- memcpy(&nPoints, psSHP->pabyRec + 44, 4);
+ if ( 44 + 4 > nEntitySize )
+ return NULL;
+ memcpy( &nPoints, psSHP->pabyRec + 44, 4 );
- if (bBigEndian)
- if (nPoints < 0 || nPoints > 50 * 1000 * 1000) {
- "Corrupted .shp file : shape %d : nPoints = %d", hEntity,
- nPoints);
- return NULL;
+ if (nPoints < 0 || nPoints > 50 * 1000 * 1000)
+ snprintf(pszErrorMsg, 128, "Corrupted .shp file : shape %d : nPoints = %d",
+ hEntity, nPoints);
+ return NULL;
- nRequiredSize = 48 + nPoints * 16;
- if (psShape->nSHPType == SHPT_MULTIPOINTZ) {
- nRequiredSize += 16 + nPoints * 8;
- "Corrupted .shp file : shape %d : nPoints = %d, nEntitySize = %d",
- hEntity, nPoints, nEntitySize);
- return NULL;
+ nRequiredSize = 48 + nPoints * 16;
+ if( psShape->nSHPType == SHPT_MULTIPOINTZ )
+ nRequiredSize += 16 + nPoints * 8;
+ snprintf(pszErrorMsg, 128, "Corrupted .shp file : shape %d : nPoints = %d, nEntitySize = %d",
+ hEntity, nPoints, nEntitySize);
+ return NULL;
- psShape->padfZ == NULL || psShape->padfM == NULL) {
- "Not enough memory to allocate requested memory (nPoints=%d) for shape %d. "
- "Probably broken SHP file", hEntity, nPoints);
- return NULL;
+ psShape->padfM == NULL)
+ "Not enough memory to allocate requested memory (nPoints=%d) for shape %d. "
+ "Probably broken SHP file", hEntity, nPoints );
+ return NULL;
- memcpy(psShape->padfX + i, psSHP->pabyRec + 48 + 16 * i, 8);
- memcpy(psShape->padfY + i, psSHP->pabyRec + 48 + 16 * i + 8, 8);
+ memcpy(psShape->padfX+i, psSHP->pabyRec + 48 + 16 * i, 8 );
+ memcpy(psShape->padfY+i, psSHP->pabyRec + 48 + 16 * i + 8, 8 );
- if (bBigEndian)
- if (bBigEndian)
- nOffset = 48 + 16 * nPoints;
+ nOffset = 48 + 16*nPoints;
- if (bBigEndian)
- if (bBigEndian)
- if (bBigEndian)
- if (bBigEndian)
- if (bBigEndian)
- if (bBigEndian)
- if (bBigEndian)
- if (bBigEndian)
- if (bBigEndian)
- if (bBigEndian)
- /* Extract vertices for a point. */
- else if (psShape->nSHPType == SHPT_POINT
- || psShape->nSHPType == SHPT_POINTM
- || psShape->nSHPType == SHPT_POINTZ) {
- int nOffset;
+/* Extract vertices for a point. */
+ else if( psShape->nSHPType == SHPT_POINT
+ || psShape->nSHPType == SHPT_POINTM
+ || psShape->nSHPType == SHPT_POINTZ )
+ int nOffset;
psShape->nVertices = 1;
- psShape->padfX = (double *)calloc(1, sizeof(double));
- psShape->padfY = (double *)calloc(1, sizeof(double));
- psShape->padfZ = (double *)calloc(1, sizeof(double));
- psShape->padfM = (double *)calloc(1, sizeof(double));
+ psShape->padfX = (double *) calloc(1,sizeof(double));
+ psShape->padfY = (double *) calloc(1,sizeof(double));
+ psShape->padfZ = (double *) calloc(1,sizeof(double));
+ psShape->padfM = (double *) calloc(1,sizeof(double));
- if (20 + 8 + ((psShape->nSHPType == SHPT_POINTZ) ? 8 : 0) >
- nEntitySize) {
- return NULL;
- memcpy(psShape->padfX, psSHP->pabyRec + 12, 8);
- memcpy(psShape->padfY, psSHP->pabyRec + 20, 8);
+ if (20 + 8 + (( psShape->nSHPType == SHPT_POINTZ ) ? 8 : 0)> nEntitySize)
+ return NULL;
+ memcpy( psShape->padfX, psSHP->pabyRec + 12, 8 );
+ memcpy( psShape->padfY, psSHP->pabyRec + 20, 8 );
- if (bBigEndian)
- SwapWord(8, psShape->padfX);
- if (bBigEndian)
- SwapWord(8, psShape->padfY);
+ if( bBigEndian ) SwapWord( 8, psShape->padfX );
+ if( bBigEndian ) SwapWord( 8, psShape->padfY );
- nOffset = 20 + 8;
+ nOffset = 20 + 8;
+ if( psShape->nSHPType == SHPT_POINTZ )
+ memcpy( psShape->padfZ, psSHP->pabyRec + nOffset, 8 );
+ if( bBigEndian ) SwapWord( 8, psShape->padfZ );
+ nOffset += 8;
- if (psShape->nSHPType == SHPT_POINTZ) {
- memcpy(psShape->padfZ, psSHP->pabyRec + nOffset, 8);
+ if( nEntitySize >= nOffset + 8 )
+ memcpy( psShape->padfM, psSHP->pabyRec + nOffset, 8 );
+ if( bBigEndian ) SwapWord( 8, psShape->padfM );
- if (bBigEndian)
- SwapWord(8, psShape->padfZ);
- nOffset += 8;
- if (nEntitySize >= nOffset + 8) {
- memcpy(psShape->padfM, psSHP->pabyRec + nOffset, 8);
- if (bBigEndian)
- SwapWord(8, psShape->padfM);
- /* Since no extents are supplied in the record, we will apply */
- /* them from the single vertex. */
- psShape->dfXMin = psShape->dfXMax = psShape->padfX[0];
- psShape->dfYMin = psShape->dfYMax = psShape->padfY[0];
- psShape->dfZMin = psShape->dfZMax = psShape->padfZ[0];
- psShape->dfMMin = psShape->dfMMax = psShape->padfM[0];
+/* Since no extents are supplied in the record, we will apply */
+/* them from the single vertex. */
+ psShape->dfXMin = psShape->dfXMax = psShape->padfX[0];
+ psShape->dfYMin = psShape->dfYMax = psShape->padfY[0];
+ psShape->dfZMin = psShape->dfZMax = psShape->padfZ[0];
+ psShape->dfMMin = psShape->dfMMax = psShape->padfM[0];
- return (psShape);
+ return( psShape );
/* SHPTypeName() */
-const char SHPAPI_CALL1(*) SHPTypeName(int nSHPType)
+const char SHPAPI_CALL1(*)
+SHPTypeName( int nSHPType )
- switch (nSHPType) {
- case SHPT_NULL:
- return "NullShape";
+ switch( nSHPType )
+ case SHPT_NULL:
+ return "NullShape";
- case SHPT_POINT:
- return "Point";
+ case SHPT_POINT:
+ return "Point";
- case SHPT_ARC:
- return "Arc";
+ case SHPT_ARC:
+ return "Arc";
- case SHPT_POLYGON:
- return "Polygon";
+ case SHPT_POLYGON:
+ return "Polygon";
- case SHPT_MULTIPOINT:
- return "MultiPoint";
+ case SHPT_MULTIPOINT:
+ return "MultiPoint";
+ case SHPT_POINTZ:
+ return "PointZ";
- case SHPT_POINTZ:
- return "PointZ";
+ case SHPT_ARCZ:
+ return "ArcZ";
- case SHPT_ARCZ:
- return "ArcZ";
+ case SHPT_POLYGONZ:
+ return "PolygonZ";
- case SHPT_POLYGONZ:
- return "PolygonZ";
+ case SHPT_MULTIPOINTZ:
+ return "MultiPointZ";
+ case SHPT_POINTM:
+ return "PointM";
- case SHPT_MULTIPOINTZ:
- return "MultiPointZ";
+ case SHPT_ARCM:
+ return "ArcM";
- case SHPT_POINTM:
- return "PointM";
+ case SHPT_POLYGONM:
+ return "PolygonM";
- case SHPT_ARCM:
- return "ArcM";
+ case SHPT_MULTIPOINTM:
+ return "MultiPointM";
- case SHPT_POLYGONM:
- return "PolygonM";
+ case SHPT_MULTIPATCH:
+ return "MultiPatch";
- case SHPT_MULTIPOINTM:
- return "MultiPointM";
- case SHPT_MULTIPATCH:
- return "MultiPatch";
- default:
- return "UnknownShapeType";
+ default:
+ return "UnknownShapeType";
/* SHPPartTypeName() */
-const char SHPAPI_CALL1(*) SHPPartTypeName(int nPartType)
+SHPPartTypeName( int nPartType )
- switch (nPartType) {
- case SHPP_TRISTRIP:
- return "TriangleStrip";
+ switch( nPartType )
+ case SHPP_TRISTRIP:
+ return "TriangleStrip";
+ case SHPP_TRIFAN:
+ return "TriangleFan";
- case SHPP_TRIFAN:
- return "TriangleFan";
+ case SHPP_OUTERRING:
+ return "OuterRing";
- case SHPP_OUTERRING:
- return "OuterRing";
+ case SHPP_INNERRING:
+ return "InnerRing";
- case SHPP_INNERRING:
- return "InnerRing";
+ case SHPP_FIRSTRING:
+ return "FirstRing";
- case SHPP_FIRSTRING:
- return "FirstRing";
+ case SHPP_RING:
+ return "Ring";
- case SHPP_RING:
- return "Ring";
- default:
- return "UnknownPartType";
+ default:
+ return "UnknownPartType";
/* SHPDestroyObject() */
-void SHPAPI_CALL SHPDestroyObject(SHPObject * psShape)
+void SHPAPI_CALL
+SHPDestroyObject( SHPObject * psShape )
- if (psShape == NULL)
- return;
+ if( psShape == NULL )
+ return;
+ if( psShape->padfX != NULL )
+ free( psShape->padfX );
+ if( psShape->padfY != NULL )
+ free( psShape->padfY );
+ if( psShape->padfZ != NULL )
+ free( psShape->padfZ );
+ if( psShape->padfM != NULL )
+ free( psShape->padfM );
- if (psShape->padfX != NULL)
- free(psShape->padfX);
- if (psShape->padfY != NULL)
- free(psShape->padfY);
- if (psShape->padfZ != NULL)
- free(psShape->padfZ);
- if (psShape->padfM != NULL)
- free(psShape->padfM);
+ if( psShape->panPartStart != NULL )
+ free( psShape->panPartStart );
+ if( psShape->panPartType != NULL )
+ free( psShape->panPartType );
- if (psShape->panPartStart != NULL)
- free(psShape->panPartStart);
- if (psShape->panPartType != NULL)
- free(psShape->panPartType);
- free(psShape);
+ free( psShape );
@@ -2122,163 +2117,167 @@
/* Reset the winding of polygon objects to adhere to the */
/* specification. */
-int SHPAPI_CALL SHPRewindObject(SHPHandle hSHP, SHPObject * psObject)
+int SHPAPI_CALL
+SHPRewindObject( SHPHandle hSHP, SHPObject * psObject )
- int iOpRing, bAltered = 0;
+ int iOpRing, bAltered = 0;
- /* Do nothing if this is not a polygon object. */
- if (psObject->nSHPType != SHPT_POLYGON
- && psObject->nSHPType != SHPT_POLYGONZ
- && psObject->nSHPType != SHPT_POLYGONM)
- return 0;
+/* Do nothing if this is not a polygon object. */
+ if( psObject->nSHPType != SHPT_POLYGON
+ && psObject->nSHPType != SHPT_POLYGONZ
+ && psObject->nSHPType != SHPT_POLYGONM )
+ return 0;
- if (psObject->nVertices == 0 || psObject->nParts == 0)
- return 0;
+ if( psObject->nVertices == 0 || psObject->nParts == 0 )
+ return 0;
- /* Process each of the rings. */
- for (iOpRing = 0; iOpRing < psObject->nParts; iOpRing++) {
- int bInner, iVert, nVertCount, nVertStart, iCheckRing;
- double dfSum, dfTestX, dfTestY;
+/* Process each of the rings. */
+ for( iOpRing = 0; iOpRing < psObject->nParts; iOpRing++ )
+ int bInner, iVert, nVertCount, nVertStart, iCheckRing;
+ double dfSum, dfTestX, dfTestY;
- /* Determine if this ring is an inner ring or an outer ring */
- /* relative to all the other rings. For now we assume the */
- /* first ring is outer and all others are inner, but eventually */
- /* we need to fix this to handle multiple island polygons and */
- /* unordered sets of rings. */
+/* Determine if this ring is an inner ring or an outer ring */
+/* relative to all the other rings. For now we assume the */
+/* first ring is outer and all others are inner, but eventually */
+/* we need to fix this to handle multiple island polygons and */
+/* unordered sets of rings. */
- /* Use point in the middle of segment to avoid testing
- * common points of rings.
- dfTestX = (psObject->padfX[psObject->panPartStart[iOpRing]]
- + psObject->padfX[psObject->panPartStart[iOpRing] +
- 1]) / 2;
- dfTestY = (psObject->padfY[psObject->panPartStart[iOpRing]]
- + psObject->padfY[psObject->panPartStart[iOpRing] +
- 1]) / 2;
+ /* Use point in the middle of segment to avoid testing
+ * common points of rings.
+ dfTestX = ( psObject->padfX[psObject->panPartStart[iOpRing]]
+ + psObject->padfX[psObject->panPartStart[iOpRing] + 1] ) / 2;
+ dfTestY = ( psObject->padfY[psObject->panPartStart[iOpRing]]
+ + psObject->padfY[psObject->panPartStart[iOpRing] + 1] ) / 2;
- bInner = FALSE;
- for (iCheckRing = 0; iCheckRing < psObject->nParts; iCheckRing++) {
- int iEdge;
+ bInner = FALSE;
+ for( iCheckRing = 0; iCheckRing < psObject->nParts; iCheckRing++ )
+ int iEdge;
- if (iCheckRing == iOpRing)
- continue;
+ if( iCheckRing == iOpRing )
+ continue;
+ nVertStart = psObject->panPartStart[iCheckRing];
- nVertStart = psObject->panPartStart[iCheckRing];
+ if( iCheckRing == psObject->nParts-1 )
+ nVertCount = psObject->nVertices
+ - psObject->panPartStart[iCheckRing];
+ else
+ nVertCount = psObject->panPartStart[iCheckRing+1]
- if (iCheckRing == psObject->nParts - 1)
- nVertCount = psObject->nVertices
- - psObject->panPartStart[iCheckRing];
- else
- nVertCount = psObject->panPartStart[iCheckRing + 1]
+ for( iEdge = 0; iEdge < nVertCount; iEdge++ )
+ int iNext;
- for (iEdge = 0; iEdge < nVertCount; iEdge++) {
- int iNext;
+ if( iEdge < nVertCount-1 )
+ iNext = iEdge+1;
+ else
+ iNext = 0;
- if (iEdge < nVertCount - 1)
- iNext = iEdge + 1;
- else
- iNext = 0;
+ /* Rule #1:
+ * Test whether the edge 'straddles' the horizontal ray from the test point (dfTestY,dfTestY)
+ * The rule #1 also excludes edges collinear with the ray.
+ if ( ( psObject->padfY[iEdge+nVertStart] < dfTestY
+ && dfTestY <= psObject->padfY[iNext+nVertStart] )
+ || ( psObject->padfY[iNext+nVertStart] < dfTestY
+ && dfTestY <= psObject->padfY[iEdge+nVertStart] ) )
+ /* Rule #2:
+ * Test if edge-ray intersection is on the right from the test point (dfTestY,dfTestY)
+ double const intersect =
+ ( psObject->padfX[iEdge+nVertStart]
+ + ( dfTestY - psObject->padfY[iEdge+nVertStart] )
+ / ( psObject->padfY[iNext+nVertStart] - psObject->padfY[iEdge+nVertStart] )
+ * ( psObject->padfX[iNext+nVertStart] - psObject->padfX[iEdge+nVertStart] ) );
- /* Rule #1:
- * Test whether the edge 'straddles' the horizontal ray from the test point (dfTestY,dfTestY)
- * The rule #1 also excludes edges collinear with the ray.
- if ((psObject->padfY[iEdge + nVertStart] < dfTestY
- && dfTestY <= psObject->padfY[iNext + nVertStart])
- || (psObject->padfY[iNext + nVertStart] < dfTestY
- && dfTestY <= psObject->padfY[iEdge + nVertStart])) {
- /* Rule #2:
- * Test if edge-ray intersection is on the right from the test point (dfTestY,dfTestY)
- double const intersect =
- (psObject->padfX[iEdge + nVertStart]
- + (dfTestY - psObject->padfY[iEdge + nVertStart])
- / (psObject->padfY[iNext + nVertStart] -
- * (psObject->padfX[iNext + nVertStart] -
- psObject->padfX[iEdge + nVertStart]));
+ if (intersect < dfTestX)
+ bInner = !bInner;
+ } /* for iCheckRing */
- if (intersect < dfTestX) {
- bInner = !bInner;
- } /* for iCheckRing */
+/* Determine the current order of this ring so we will know if */
+/* it has to be reversed. */
+ nVertStart = psObject->panPartStart[iOpRing];
- /* Determine the current order of this ring so we will know if */
- /* it has to be reversed. */
- nVertStart = psObject->panPartStart[iOpRing];
+ if( iOpRing == psObject->nParts-1 )
+ nVertCount = psObject->nVertices - psObject->panPartStart[iOpRing];
+ else
+ nVertCount = psObject->panPartStart[iOpRing+1]
+ - psObject->panPartStart[iOpRing];
- if (iOpRing == psObject->nParts - 1)
- nVertCount =
- psObject->nVertices - psObject->panPartStart[iOpRing];
- else
- nVertCount = psObject->panPartStart[iOpRing + 1]
- - psObject->panPartStart[iOpRing];
+ dfSum = 0.0;
+ for( iVert = nVertStart; iVert < nVertStart+nVertCount-1; iVert++ )
+ dfSum += psObject->padfX[iVert] * psObject->padfY[iVert+1]
+ - psObject->padfY[iVert] * psObject->padfX[iVert+1];
- dfSum = 0.0;
- for (iVert = nVertStart; iVert < nVertStart + nVertCount - 1; iVert++) {
- dfSum += psObject->padfX[iVert] * psObject->padfY[iVert + 1]
- - psObject->padfY[iVert] * psObject->padfX[iVert + 1];
+ dfSum += psObject->padfX[iVert] * psObject->padfY[nVertStart]
+ - psObject->padfY[iVert] * psObject->padfX[nVertStart];
- dfSum += psObject->padfX[iVert] * psObject->padfY[nVertStart]
- - psObject->padfY[iVert] * psObject->padfX[nVertStart];
+/* Reverse if necessary. */
+ if( (dfSum < 0.0 && bInner) || (dfSum > 0.0 && !bInner) )
+ int i;
- /* Reverse if necessary. */
- if ((dfSum < 0.0 && bInner) || (dfSum > 0.0 && !bInner)) {
- int i;
+ bAltered++;
+ for( i = 0; i < nVertCount/2; i++ )
+ double dfSaved;
- bAltered++;
- for (i = 0; i < nVertCount / 2; i++) {
- double dfSaved;
+ /* Swap X */
+ dfSaved = psObject->padfX[nVertStart+i];
+ psObject->padfX[nVertStart+i] =
+ psObject->padfX[nVertStart+nVertCount-i-1];
+ psObject->padfX[nVertStart+nVertCount-i-1] = dfSaved;
- /* Swap X */
- dfSaved = psObject->padfX[nVertStart + i];
- psObject->padfX[nVertStart + i] =
- psObject->padfX[nVertStart + nVertCount - i - 1];
- psObject->padfX[nVertStart + nVertCount - i - 1] = dfSaved;
+ /* Swap Y */
+ dfSaved = psObject->padfY[nVertStart+i];
+ psObject->padfY[nVertStart+i] =
+ psObject->padfY[nVertStart+nVertCount-i-1];
+ psObject->padfY[nVertStart+nVertCount-i-1] = dfSaved;
- /* Swap Y */
- dfSaved = psObject->padfY[nVertStart + i];
- psObject->padfY[nVertStart + i] =
- psObject->padfY[nVertStart + nVertCount - i - 1];
- psObject->padfY[nVertStart + nVertCount - i - 1] = dfSaved;
+ /* Swap Z */
+ if( psObject->padfZ )
+ dfSaved = psObject->padfZ[nVertStart+i];
+ psObject->padfZ[nVertStart+i] =
+ psObject->padfZ[nVertStart+nVertCount-i-1];
+ psObject->padfZ[nVertStart+nVertCount-i-1] = dfSaved;
- /* Swap Z */
- if (psObject->padfZ) {
- dfSaved = psObject->padfZ[nVertStart + i];
- psObject->padfZ[nVertStart + i] =
- psObject->padfZ[nVertStart + nVertCount - i - 1];
- psObject->padfZ[nVertStart + nVertCount - i - 1] =
- dfSaved;
- /* Swap M */
- if (psObject->padfM) {
- dfSaved = psObject->padfM[nVertStart + i];
- psObject->padfM[nVertStart + i] =
- psObject->padfM[nVertStart + nVertCount - i - 1];
- psObject->padfM[nVertStart + nVertCount - i - 1] =
- dfSaved;
+ /* Swap M */
+ if( psObject->padfM )
+ dfSaved = psObject->padfM[nVertStart+i];
+ psObject->padfM[nVertStart+i] =
+ psObject->padfM[nVertStart+nVertCount-i-1];
+ psObject->padfM[nVertStart+nVertCount-i-1] = dfSaved;
return bAltered;
