[GRASS-SVN] r32585 - in grass/trunk/lib: arraystats driver g3d gis gmath gpde gpde/test imagery ogsf proj rst/interp_float symbol vector/Vlib vector/diglib vector/vedit
Wed Aug 6 18:00:01 EDT 2008
Author: neteler
Date: 2008-08-06 18:00:00 -0400 (Wed, 06 Aug 2008)
New Revision: 32585
   grass/trunk/lib/arraystats/class.c
   grass/trunk/lib/driver/parse_ftcap.c
   grass/trunk/lib/g3d/g3dopen.c
   grass/trunk/lib/g3d/g3dparam.c
   grass/trunk/lib/gis/adj_cellhd.c
   grass/trunk/lib/gis/closecell.c
   grass/trunk/lib/gis/get_ellipse.c
   grass/trunk/lib/gis/get_row.c
   grass/trunk/lib/gis/gisinit.c
   grass/trunk/lib/gis/history.c
   grass/trunk/lib/gis/legal_name.c
   grass/trunk/lib/gis/opencell.c
   grass/trunk/lib/gis/parser.c
   grass/trunk/lib/gis/put_row.c
   grass/trunk/lib/gis/reclass.c
   grass/trunk/lib/gis/set_window.c
   grass/trunk/lib/gis/spawn.c
   grass/trunk/lib/gis/view.c
   grass/trunk/lib/gmath/la.c
   grass/trunk/lib/gpde/N_solvers.c
   grass/trunk/lib/gpde/N_solvers_krylov.c
   grass/trunk/lib/gpde/test/test_gwflow.c
   grass/trunk/lib/gpde/test/test_heat.c
   grass/trunk/lib/gpde/test/test_solute_transport.c
   grass/trunk/lib/imagery/fopen.c
   grass/trunk/lib/ogsf/GK2.c
   grass/trunk/lib/ogsf/GS2.c
   grass/trunk/lib/ogsf/Gp3.c
   grass/trunk/lib/ogsf/Gs3.c
   grass/trunk/lib/ogsf/Gv3.c
   grass/trunk/lib/ogsf/gsd_img_mpeg.c
   grass/trunk/lib/proj/convert.c
   grass/trunk/lib/proj/get_proj.c
   grass/trunk/lib/rst/interp_float/segmen2d.c
   grass/trunk/lib/rst/interp_float/vinput2d.c
   grass/trunk/lib/symbol/read.c
   grass/trunk/lib/vector/Vlib/array.c
   grass/trunk/lib/vector/Vlib/build_ogr.c
   grass/trunk/lib/vector/Vlib/cats.c
   grass/trunk/lib/vector/Vlib/cindex.c
   grass/trunk/lib/vector/Vlib/field.c
   grass/trunk/lib/vector/Vlib/intersect.c
   grass/trunk/lib/vector/Vlib/legal_vname.c
   grass/trunk/lib/vector/Vlib/map.c
   grass/trunk/lib/vector/Vlib/net.c
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/lib/vector/Vlib/open_nat.c
   grass/trunk/lib/vector/Vlib/open_ogr.c
   grass/trunk/lib/vector/Vlib/overlay.c
   grass/trunk/lib/vector/Vlib/read.c
   grass/trunk/lib/vector/Vlib/read_ogr.c
   grass/trunk/lib/vector/Vlib/sindex.c
   grass/trunk/lib/vector/Vlib/write_nat.c
   grass/trunk/lib/vector/diglib/plus_area.c
   grass/trunk/lib/vector/diglib/plus_node.c
   grass/trunk/lib/vector/vedit/cats.c
fixed unlucky formatted messages (thanks to Glynn)
Modified: grass/trunk/lib/arraystats/class.c
--- grass/trunk/lib/arraystats/class.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/arraystats/class.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -217,8 +217,7 @@
     if (j < (*nbreaks)) {
-	G_warning(_
-		  ("There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."),
+	G_warning(_("There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."),
 		  j + 1, *nbreaks + 1);
 	G_realloc(classbreaks, j * sizeof(double));
 	for (i = 0; i < j; i++)
Modified: grass/trunk/lib/driver/parse_ftcap.c
--- grass/trunk/lib/driver/parse_ftcap.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/driver/parse_ftcap.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -29,8 +29,7 @@
     fp = NULL;
     if ((capfile = getenv("GRASS_FONT_CAP"))) {
 	if ((fp = fopen(capfile, "r")) == NULL)
-	    G_warning(_
-		      ("%s: Unable to read font definition file; use the default"),
+	    G_warning(_("%s: Unable to read font definition file; use the default"),
 		      capfile);
     if (fp == NULL) {
Modified: grass/trunk/lib/g3d/g3dopen.c
--- grass/trunk/lib/g3d/g3dopen.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/g3d/g3dopen.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -121,8 +121,7 @@
 	window = G3d_windowPtr();
     if (proj != window->proj) {
-	G3d_error(_
-		  ("G3d_openCellOld: projection does not match window projection"));
+	G3d_error(_("G3d_openCellOld: projection does not match window projection"));
 	return (void *)NULL;
     if (zone != window->zone) {
@@ -144,8 +143,7 @@
 	/* if our long is to short to store offsets we can't read the file */
 	if (map->indexNbytesUsed > sizeof(long))
-	    G3d_fatalError(_
-			   ("G3d_openCellOld: index does not fit into long"));
+	    G3d_fatalError(_("G3d_openCellOld: index does not fit into long"));
 	ltmp = G3d_malloc(map->indexLongNbytes);
 	if (ltmp == NULL) {
Modified: grass/trunk/lib/g3d/g3dparam.c
--- grass/trunk/lib/g3d/g3dparam.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/g3d/g3dparam.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -146,8 +146,7 @@
     if (strcmp(param->dimension->answer, "default") != 0) {
 	if (sscanf(param->dimension->answer, "%dx%dx%d",
 		   tileX, tileY, tileZ) != 3) {
-	    G3d_error(_
-		      ("G3d_getStandard3dParams: tile dimension value invalid"));
+	    G3d_error(_("G3d_getStandard3dParams: tile dimension value invalid"));
 	    return 0;
Modified: grass/trunk/lib/gis/adj_cellhd.c
--- grass/trunk/lib/gis/adj_cellhd.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/adj_cellhd.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -76,8 +76,7 @@
 	if (cellhd->north > 90.0) {
 	    if (((cellhd->north - 90.0) < epsilon_ns) &&
 		((cellhd->north - 90.0) > GRASS_EPSILON)) {
-		G_warning(_
-			  ("Fixing subtle input data rounding error of north boundary (%g>%g)"),
+		G_warning(_("Fixing subtle input data rounding error of north boundary (%g>%g)"),
 			  cellhd->north - 90.0, epsilon_ns);
 		cellhd->north = 90.0;
@@ -88,8 +87,7 @@
 	if (cellhd->south < -90.0) {
 	    if (((cellhd->south + 90.0) < epsilon_ns) &&
 		((cellhd->south + 90.0) < GRASS_EPSILON)) {
-		G_warning(_
-			  ("Fixing subtle input data rounding error of south boundary (%g>%g)"),
+		G_warning(_("Fixing subtle input data rounding error of south boundary (%g>%g)"),
 			  cellhd->south + 90.0, epsilon_ns);
 		cellhd->south = -90.0;
@@ -106,8 +104,7 @@
 	if ((cellhd->west < -180.0) && ((cellhd->west + 180.0) < epsilon_ew)
 	    && ((cellhd->west + 180.0) < GRASS_EPSILON)) {
-	    G_warning(_
-		      ("Fixing subtle input data rounding error of west boundary (%g>%g)"),
+	    G_warning(_("Fixing subtle input data rounding error of west boundary (%g>%g)"),
 		      cellhd->west + 180.0, epsilon_ew);
 	    cellhd->west = -180.0;
@@ -118,8 +115,7 @@
 	if ((cellhd->east > 180.0) && ((cellhd->east - 180.0) > epsilon_ew)
 	    && ((cellhd->east - 180.0) > GRASS_EPSILON)) {
-	    G_warning(_
-		      ("Fixing subtle input data rounding error of east boundary (%g>%g)"),
+	    G_warning(_("Fixing subtle input data rounding error of east boundary (%g>%g)"),
 		      cellhd->east - 180.0, epsilon_ew);
 	    cellhd->east = 180.0;
@@ -248,8 +244,7 @@
-		G_warning(_
@@ -260,8 +255,7 @@
-		G_warning(_
@@ -278,8 +272,7 @@
-	    G_warning(_
@@ -290,8 +283,7 @@
-	    G_warning(_
Modified: grass/trunk/lib/gis/closecell.c
--- grass/trunk/lib/gis/closecell.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/closecell.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -244,8 +244,7 @@
 	    int cell_fd;
 	    if (G__write_fp_format(fd) != 0) {
-		G_warning(_
-			  ("Error writing floating point format file for map %s"),
+		G_warning(_("Error writing floating point format file for map %s"),
 			  fcb->name);
 		stat = -1;
Modified: grass/trunk/lib/gis/get_ellipse.c
--- grass/trunk/lib/gis/get_ellipse.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/get_ellipse.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -354,8 +354,7 @@
 	    str = G_find_key_value("a", proj_keys);
 	    if (str != NULL) {
 		if (sscanf(str, "%lf", a) != 1) {
-		    G_fatal_error(_
-				  ("Invalid a: field '%s' in file %s in <%s>"),
+		    G_fatal_error(_("Invalid a: field '%s' in file %s in <%s>"),
 				  str, PROJECTION_FILE, PERMANENT);
Modified: grass/trunk/lib/gis/get_row.c
--- grass/trunk/lib/gis/get_row.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/get_row.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -43,8 +43,7 @@
     /* check for row in window */
     if (row < 0 || row >= G__.window.rows) {
-	G_warning(_
-		  ("Reading raster map <%s@%s> request for row %d is outside region"),
+	G_warning(_("Reading raster map <%s@%s> request for row %d is outside region"),
 		  fcb->name, fcb->mapset, row);
 	return -1;
@@ -299,8 +298,7 @@
 	while (cmapold++ != cmap[i])	/* skip */
 	    if (!xdr_float(xdrs, &c[i]))
-		G_fatal_error(_
-			      ("cell_values_float: xdr_float failed for index %d"),
+		G_fatal_error(_("cell_values_float: xdr_float failed for index %d"),
 			      i);
 	cmapold--;
@@ -341,8 +339,7 @@
 	    if (!xdr_double(xdrs, &c[i]))
-		G_fatal_error(_
-			      ("cell_values_double: xdr_double failed for index %d"),
+		G_fatal_error(_("cell_values_double: xdr_double failed for index %d"),
 			      i);
 	cmapold--;
@@ -489,8 +486,7 @@
 	    if (!fcb->io_error) {
 		if (fcb->cellhd.compressed)
-		    G_warning(_
-			      ("Error reading compressed map <%s@%s>, row %d"),
+		    G_warning(_("Error reading compressed map <%s@%s>, row %d"),
 			      fcb->name, fcb->mapset, r);
 		else
 		    G_warning(_("Error reading map <%s@%s>, row %d"),
@@ -918,8 +914,7 @@
     int i, j, null_fd;
     if (row > G__.window.rows || row < 0) {
-	G_warning(_
Modified: grass/trunk/lib/gis/gisinit.c
--- grass/trunk/lib/gis/gisinit.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/gisinit.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -105,8 +105,7 @@
     if (initialized)
 	return 1;
-    G_warning(_
-	      ("System not initialized. Programmer forgot to call G_gisinit()."));
+    G_warning(_("System not initialized. Programmer forgot to call G_gisinit()."));
     G_sleep(3);
     exit(EXIT_FAILURE);
Modified: grass/trunk/lib/gis/history.c
--- grass/trunk/lib/gis/history.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/history.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -260,8 +260,7 @@
     cmdlen = strlen(cmdlin);
     if (hist->edlinecnt > MAXEDLINES - 2) {
-	G_warning(_
-		  ("Not enough room in history file to record command line."));
+	G_warning(_("Not enough room in history file to record command line."));
 	return 1;
@@ -283,8 +282,7 @@
 	    j += 68;
 	    hist->edlinecnt++;
-		G_warning(_
-			  ("Not enough room in history file for command line (truncated)."));
+		G_warning(_("Not enough room in history file for command line (truncated)."));
 		return 2;
Modified: grass/trunk/lib/gis/legal_name.c
--- grass/trunk/lib/gis/legal_name.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/legal_name.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -74,8 +74,7 @@
 	return 0;		/* don't die on undefined parameters */
     if (G_legal_filename(output) == -1) {
 	if (error == GR_FATAL_EXIT) {
-	    G_fatal_error(_
-			  ("Output raster map name <%s> is not valid map name"),
+	    G_fatal_error(_("Output raster map name <%s> is not valid map name"),
 			  output);
 	else if (error == GR_FATAL_PRINT) {
Modified: grass/trunk/lib/gis/opencell.c
--- grass/trunk/lib/gis/opencell.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/opencell.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -258,8 +258,7 @@
 	r_name = reclass.name;
 	r_mapset = reclass.mapset;
 	if (G_find_cell2(r_name, r_mapset) == NULL) {
-	    G_warning(_
-		      ("unable to open [%s] in [%s] since it is a reclass of [%s] in [%s] which does not exist"),
+	    G_warning(_("unable to open [%s] in [%s] since it is a reclass of [%s] in [%s] which does not exist"),
 		      name, mapset, r_name, r_mapset);
 	    return -1;
@@ -282,23 +281,20 @@
 	CELL_nbytes = cellhd.format + 1;
 	if (CELL_nbytes < 1) {
-	    G_warning(_
-		      ("[%s] in mapset [%s]-format field in header file invalid"),
+	    G_warning(_("[%s] in mapset [%s]-format field in header file invalid"),
 		      r_name, r_mapset);
 	    return -1;
     if (cellhd.proj != G__.window.proj) {
-	G_warning(_
-		  ("[%s] in mapset [%s] - in different projection than current region:\n found map [%s] in: <%s>, should be <%s> "),
+	G_warning(_("[%s] in mapset [%s] - in different projection than current region:\n found map [%s] in: <%s>, should be <%s> "),
 		  name, mapset, name, G__projection_name(cellhd.proj),
 		  G__projection_name(G__.window.proj));
 	return -1;
     if (cellhd.zone != G__.window.zone) {
-	G_warning(_
-		  ("[%s] in mapset [%s] - in different zone [%d] than current region [%d]"),
+	G_warning(_("[%s] in mapset [%s] - in different zone [%d] than current region [%d]"),
 		  name, mapset, cellhd.zone, G__.window.zone);
 	return -1;
@@ -689,8 +685,7 @@
 	if (open_mode == OPEN_NEW_RANDOM) {
-	    G_warning(_
-		      ("Can't write embedded null values for map open for random access"));
+	    G_warning(_("Can't write embedded null values for map open for random access"));
 	    if (fcb->map_type == CELL_TYPE)
 		G_write_zeros(fd,
 			      (long)WRITE_NBYTES * fcb->cellhd.cols *
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/parser.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -770,8 +770,7 @@
 			j++;
 		    if (!found) {
-			G_warning(_
-				  ("BUG in descriptions, option %s in %s does not exist"),
+			G_warning(_("BUG in descriptions, option %s in %s does not exist"),
 				  tokens[i], opt->key);
 		    else {
@@ -866,8 +865,7 @@
 		sprintf(buff, "GRASS_VERBOSE=%d", G_verbose_max());
 		putenv(G_store(buff));
 		if (quiet == 1) {
-		    G_warning(_
-			      ("Use either --quiet or --verbose flag, not both. Assuming --verbose."));
+		    G_warning(_("Use either --quiet or --verbose flag, not both. Assuming --verbose."));
 		quiet = -1;
@@ -881,8 +879,7 @@
 		sprintf(buff, "GRASS_VERBOSE=%d", G_verbose_min());
 		if (quiet == -1) {
-		    G_warning(_
-			      ("Use either --quiet or --verbose flag, not both. Assuming --quiet."));
+		    G_warning(_("Use either --quiet or --verbose flag, not both. Assuming --quiet."));
 		quiet = 1;	/* for passing to gui init */
Modified: grass/trunk/lib/gis/put_row.c
--- grass/trunk/lib/gis/put_row.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/put_row.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -212,8 +212,7 @@
     struct fileinfo *fcb = &G__.fileinfo[fd];
     if (fcb->map_type != CELL_TYPE) {
-	G_fatal_error(_
-		      ("G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"),
+	G_fatal_error(_("G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"),
 		      fcb->name);
 	return -1;
@@ -257,16 +256,14 @@
 	if (!random)
 	    return 1;
-	G_warning(_
-		  ("%s: map [%s] not open for random write - request ignored"),
+	G_warning(_("%s: map [%s] not open for random write - request ignored"),
 		  me, fcb->name);
 	break;
     case OPEN_NEW_RANDOM:
 	if (random)
 	    return 1;
-	G_warning(_
-		  ("%s: map [%s] not open for sequential write - request ignored"),
+	G_warning(_("%s: map [%s] not open for sequential write - request ignored"),
 		  me, fcb->name);
 	break;
     default:
Modified: grass/trunk/lib/gis/reclass.c
--- grass/trunk/lib/gis/reclass.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/reclass.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -143,8 +143,7 @@
 	    G_warning(_("Too many reclass categories for [%s in %s]"),
 		      name, mapset);
 	else
-	    G_warning(_
-		      ("Illegal reclass format in header file for [%s in %s]"),
+	    G_warning(_("Illegal reclass format in header file for [%s in %s]"),
 		      name, mapset);
 	stat = -1;
Modified: grass/trunk/lib/gis/set_window.c
--- grass/trunk/lib/gis/set_window.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/set_window.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -73,8 +73,7 @@
 		G__.fileinfo[i].cellhd.proj == window->proj)
 		continue;
 	    if (i != maskfd) {
-		G_warning(_
-			  ("G_set_window(): projection/zone differs from that of "
+		G_warning(_("G_set_window(): projection/zone differs from that of "
 			   "currently open raster maps"));
 		return -1;
Modified: grass/trunk/lib/gis/spawn.c
--- grass/trunk/lib/gis/spawn.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/spawn.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -355,8 +355,7 @@
 	    if (dup2(r->src_fd, r->dst_fd) < 0) {
-		G_warning(_
-			  ("G_spawn: unable to duplicate descriptor %d to %d"),
+		G_warning(_("G_spawn: unable to duplicate descriptor %d to %d"),
 			  r->src_fd, r->dst_fd);
 		_exit(127);
@@ -365,8 +364,7 @@
 	else if (r->src_fd >= 0) {
-		G_warning(_
 		_exit(127);
Modified: grass/trunk/lib/gis/view.c
--- grass/trunk/lib/gis/view.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gis/view.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -543,13 +543,11 @@
     switch (vis) {
     case 0:
-	G_warning(_
-		  (" Window saved in \"%s\" is completely outside of current GRASS window."),
+	G_warning(_(" Window saved in \"%s\" is completely outside of current GRASS window."),
 		  viewname);
 	break;
     default:
-	G_warning(_
-		  (" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."),
+	G_warning(_(" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."),
 		  vis, viewname);
 	break;
Modified: grass/trunk/lib/gmath/la.c
--- grass/trunk/lib/gmath/la.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gmath/la.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -527,8 +527,7 @@
 	    G_matrix_free(mtx);
 	    if (res_info > 0) {
-		G_warning(_
-			  ("Matrix (or submatrix is singular). Solution undetermined"));
+		G_warning(_("Matrix (or submatrix is singular). Solution undetermined"));
 		return 1;
 	    else if (res_info < 0) {
@@ -539,8 +538,7 @@
     default:
-	    G_warning(_
-		      ("Procedure not yet available for selected matrix type"));
+	    G_warning(_("Procedure not yet available for selected matrix type"));
 	    return -1;
     }				/* end switch */
Modified: grass/trunk/lib/gpde/N_solvers.c
--- grass/trunk/lib/gpde/N_solvers.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gpde/N_solvers.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -47,8 +47,7 @@
     if (les->type != N_NORMAL_LES) {
-	G_warning(_
-		  ("The gauss elimination solver does not work with sparse matrices"));
+	G_warning(_("The gauss elimination solver does not work with sparse matrices"));
 	return 0;
@@ -153,8 +152,7 @@
 int N_solver_cholesky(N_les * les)
-	G_warning(_
-		  ("The cholesky solver does not work with sparse matrices"));
+	G_warning(_("The cholesky solver does not work with sparse matrices"));
 	return 0;
Modified: grass/trunk/lib/gpde/N_solvers_krylov.c
--- grass/trunk/lib/gpde/N_solvers_krylov.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gpde/N_solvers_krylov.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -187,8 +187,7 @@
 		else {
-		    G_warning(_
-			      ("Unable to solve the linear equation system"));
+		    G_warning(_("Unable to solve the linear equation system"));
 		    error_break = 1;
@@ -355,8 +354,7 @@
 		else {
-		    G_warning(_
 		    error_break = 1;
@@ -480,8 +478,7 @@
 		else {
-		    G_warning(_
 		    error_break = 1;
Modified: grass/trunk/lib/gpde/test/test_gwflow.c
--- grass/trunk/lib/gpde/test/test_gwflow.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gpde/test/test_gwflow.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -51,8 +51,7 @@
     if (sum > 0)
 	G_warning(_("\n-- gwflow integration tests failure --"));
     else
-	G_message(_
-		  ("\n-- gwflow integration tests finished successfully --"));
+	G_message(_("\n-- gwflow integration tests finished successfully --"));
     return sum;
Modified: grass/trunk/lib/gpde/test/test_heat.c
--- grass/trunk/lib/gpde/test/test_heat.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gpde/test/test_heat.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -39,8 +39,7 @@
     if (sum > 0)
 	G_warning(_("\n-- heat flow integration tests failure --"));
     else
-	G_message(_
-		  ("\n-- heat flow integration tests finished successfully --"));
+	G_message(_("\n-- heat flow integration tests finished successfully --"));
     return sum;
Modified: grass/trunk/lib/gpde/test/test_solute_transport.c
--- grass/trunk/lib/gpde/test/test_solute_transport.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/gpde/test/test_solute_transport.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -51,8 +51,7 @@
     if (sum > 0)
 	G_warning(_("\n-- solute_transport integration tests failure --"));
     else
-	G_message(_
-		  ("\n-- solute_transport integration tests finished successfully --"));
+	G_message(_("\n-- solute_transport integration tests finished successfully --"));
     return sum;
Modified: grass/trunk/lib/imagery/fopen.c
--- grass/trunk/lib/imagery/fopen.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/imagery/fopen.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -76,8 +76,7 @@
     fd = G_fopen_new_misc("group", element, group);
     if (!fd)
-	G_warning(_
-		  ("Unable to create file [%s] for subgroup [%s] of group [%s in %s]"),
+	G_warning(_("Unable to create file [%s] for subgroup [%s] of group [%s in %s]"),
 		  file, subgroup, group, G_mapset());
     return fd;
@@ -99,8 +98,7 @@
     fd = G_fopen_append_misc("group", element, group);
     if (!fd)
-	G_warning(_
-		  ("Unable to open file [%s] for subgroup [%s] of group [%s in %s]"),
+	G_warning(_("Unable to open file [%s] for subgroup [%s] of group [%s in %s]"),
     return fd;
@@ -115,8 +113,7 @@
     /* find file first */
     if (!I_find_subgroup_file(group, subgroup, file)) {
-	G_warning(_
-		  ("Unable to find file [%s] for subgroup [%s] of group [%s in %s]"),
+	G_warning(_("Unable to find file [%s] for subgroup [%s] of group [%s in %s]"),
 	return ((FILE *) NULL);
@@ -127,8 +124,7 @@
     fd = G_fopen_old_misc("group", element, group, G_mapset());
     if (!fd)
-	G_warning(_
     return fd;
Modified: grass/trunk/lib/ogsf/GK2.c
--- grass/trunk/lib/ogsf/GK2.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/ogsf/GK2.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -272,8 +272,7 @@
 	Views = gk_make_linear_framesfromkeys(Keys, Numkeys, Viewsteps, loop);
 	if (!Views) {
-	    G_warning(_
-		      ("Check no. of frames requested and keyframes marked"));
+	    G_warning(_("Check no. of frames requested and keyframes marked"));
     else if (Numkeys > 2) {
@@ -286,8 +285,7 @@
 	    (Keys, Numkeys, Viewsteps, loop, 1.0 - Tension);
 	if (!Views) {
-	    G_warning(_
Modified: grass/trunk/lib/ogsf/GS2.c
--- grass/trunk/lib/ogsf/GS2.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/ogsf/GS2.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -1633,8 +1633,7 @@
     if (rast_head.north <= wind.south ||
 	rast_head.south >= wind.north ||
 	rast_head.east <= wind.west || rast_head.west >= wind.east) {
-	G_fatal_error(_
-		      ("Raster map <%s> is outside of current region. Load failed."),
+	G_fatal_error(_("Raster map <%s> is outside of current region. Load failed."),
 		      filename);
@@ -1715,15 +1714,13 @@
 	if (0 > gs_malloc_att_buff(gs, att, ATTY_NULL)) {
-	    G_fatal_error(_
-			  ("GS_load_att_map(): Out of memory. Unable to load map"));
+	    G_fatal_error(_("GS_load_att_map(): Out of memory. Unable to load map"));
 	switch (atty) {
 	case ATTY_MASK:
 	    if (0 > gs_malloc_att_buff(gs, att, ATTY_MASK)) {
-		G_fatal_error(_
 	    ret = Gs_loadmap_as_bitmap(&wind, filename, tbuff->bm);
@@ -1732,8 +1729,7 @@
 	    break;
 	case ATTY_CHAR:
 	    if (0 > gs_malloc_att_buff(gs, att, ATTY_CHAR)) {
-		G_fatal_error(_
 	    ret = Gs_loadmap_as_char(&wind, filename, tbuff->cb,
@@ -1743,8 +1739,7 @@
 	    break;
 	case ATTY_SHORT:
 	    if (0 > gs_malloc_att_buff(gs, att, ATTY_SHORT)) {
-		G_fatal_error(_
 	    ret = Gs_loadmap_as_short(&wind, filename, tbuff->sb,
@@ -1754,8 +1749,7 @@
 	    break;
 	case ATTY_FLOAT:
 	    if (0 > gs_malloc_att_buff(gs, att, ATTY_FLOAT)) {
-		G_fatal_error(_
 	    ret = Gs_loadmap_as_float(&wind, filename, tbuff->fb,
@@ -1766,8 +1760,7 @@
 	case ATTY_INT:
 	default:
 	    if (0 > gs_malloc_att_buff(gs, att, ATTY_INT)) {
-		G_fatal_error(_
 	    ret = Gs_loadmap_as_int(&wind, filename, tbuff->ib,
@@ -1820,8 +1813,7 @@
 	else if (ATTY_FLOAT == atty) {
 	    if (!reuse) {
-		    G_fatal_error(_
 		Gs_pack_colors_float(filename, tbuff->fb, tbuff->ib,
Modified: grass/trunk/lib/ogsf/Gp3.c
--- grass/trunk/lib/ogsf/Gp3.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/ogsf/Gp3.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -201,8 +201,7 @@
     Vect_close(&map);
     if (!np) {
-	G_warning(_
-		  ("No points from vector map <%s> fall within current region"),
+	G_warning(_("No points from vector map <%s> fall within current region"),
 		  G_fully_qualified_name(grassname, mapset));
 	return (NULL);
Modified: grass/trunk/lib/ogsf/Gs3.c
--- grass/trunk/lib/ogsf/Gs3.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/ogsf/Gs3.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -640,8 +640,7 @@
     G_get_color_range(&min, &max, &colrules);
     if (min < 0 || max > 255) {
-	G_warning(_
-		  ("Color table range doesn't match data (mincol=%d, maxcol=%d"),
+	G_warning(_("Color table range doesn't match data (mincol=%d, maxcol=%d"),
 		  min, max);
 	min = min < 0 ? 0 : min;
Modified: grass/trunk/lib/ogsf/Gv3.c
--- grass/trunk/lib/ogsf/Gv3.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/ogsf/Gv3.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -246,8 +246,7 @@
     Vect_close(&map);
     if (!nl) {
-	G_warning(_
-		  ("No features from vector map <%s> fall within current region"),
+	G_warning(_("No features from vector map <%s> fall within current region"),
 	return (NULL);
Modified: grass/trunk/lib/ogsf/gsd_img_mpeg.c
--- grass/trunk/lib/ogsf/gsd_img_mpeg.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/ogsf/gsd_img_mpeg.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -303,8 +303,7 @@
     /* auto detect the output format from the name. default is mpeg. */
     fmt = guess_format(NULL, filename, NULL);
     if (!fmt) {
-	G_warning(_
-		  ("Unable to deduce output format from file extension: using MPEG"));
+	G_warning(_("Unable to deduce output format from file extension: using MPEG"));
 	fmt = guess_format("mpeg", NULL, NULL);
     if (!fmt) {
Modified: grass/trunk/lib/proj/convert.c
--- grass/trunk/lib/proj/convert.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/proj/convert.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -381,8 +381,7 @@
 	G_set_key_value("proj", pszProj, *projinfo);
     else
-	G_warning(_
-		  ("No projection name! Projection parameters likely to be meaningless."));
+	G_warning(_("No projection name! Projection parameters likely to be meaningless."));
@@ -418,8 +417,7 @@
 	    if (datum == NULL) {
 		if (paramspresent < 2)
 		    /* Only give warning if no parameters present */
-		    G_warning(_
-			      ("Datum <%s> not recognised by GRASS and no parameters found"),
+		    G_warning(_("Datum <%s> not recognised by GRASS and no parameters found"),
 			      pszDatumName);
 	    else {
@@ -435,13 +433,11 @@
 			GPJ_get_default_datum_params_by_name(datum, &params);
 		    if (paramsets < 0)
-			G_warning(_
-				  ("Datum <%s> apparently recognised by GRASS but no parameters found. "
+			G_warning(_("Datum <%s> apparently recognised by GRASS but no parameters found. "
 				   "You may want to look into this."), datum);
 		    else if (datumtrans > paramsets) {
-			G_warning(_
-				  ("Invalid tranformation number %d; valid range is 1 to %d. "
+			G_warning(_("Invalid tranformation number %d; valid range is 1 to %d. "
 				   "Leaving datum transform parameters unspecified."),
 				  datumtrans, paramsets);
 			datumtrans = 0;
Modified: grass/trunk/lib/proj/get_proj.c
--- grass/trunk/lib/proj/get_proj.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/proj/get_proj.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -294,8 +294,7 @@
 		if (nsize = strlen(s), nsize) {
 		    if (nopt >= MAX_PARGS) {
 			fprintf(stderr, "nopt = %d, s=%s\n", nopt, str);
-			G_fatal_error(_
-				      ("Option input overflowed option table"));
+			G_fatal_error(_("Option input overflowed option table"));
 		    if (strncmp("zone=", s, 5) == 0) {
Modified: grass/trunk/lib/rst/interp_float/segmen2d.c
--- grass/trunk/lib/rst/interp_float/segmen2d.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/rst/interp_float/segmen2d.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -110,8 +110,7 @@
 	while ((npt < MINPTS) || (npt > params->KMAX2)) {
 	    if (i >= 70) {
 		fprintf(stderr, "\n");
-		G_warning(_
-			  ("taking too long to find points for interpolation--"
+		G_warning(_("taking too long to find points for interpolation--"
 			   "please change the region to area where your points are. "
 			   "Continuing calculations..."));
 		break;
Modified: grass/trunk/lib/rst/interp_float/vinput2d.c
--- grass/trunk/lib/rst/interp_float/vinput2d.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/rst/interp_float/vinput2d.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -89,12 +89,10 @@
 	zctype = db_column_Ctype(driver, Fi->table, zcol);
 	G_debug(3, " zcol C type = %d", zctype);
 	if (zctype == -1)
-	    G_fatal_error(_
-			  ("Cannot find z column <%s> (please verify name, e.g. with v.info)"),
+	    G_fatal_error(_("Cannot find z column <%s> (please verify name, e.g. with v.info)"),
 			  zcol);
 	if (zctype != DB_C_TYPE_INT && zctype != DB_C_TYPE_DOUBLE)
-	    G_fatal_error(_
-			  ("Column type of z column is not supported (must be integer or double)"));
+	    G_fatal_error(_("Column type of z column is not supported (must be integer or double)"));
 	db_CatValArray_init(&zarray);
 	G_debug(3, "RST SQL WHERE: %s", params->wheresql);
@@ -107,11 +105,9 @@
 	    if (sctype == -1)
 		G_fatal_error(_("Cannot read column type of smooth column"));
 	    if (sctype == DB_C_TYPE_DATETIME)
-		G_fatal_error(_
-			      ("Column type of smooth column (datetime) is not supported"));
+		G_fatal_error(_("Column type of smooth column (datetime) is not supported"));
 	    if (sctype != DB_C_TYPE_INT && sctype != DB_C_TYPE_DOUBLE)
-		G_fatal_error(_
-			      ("Column type of s column is not supported (must be integer or double)"));
+		G_fatal_error(_("Column type of s column is not supported (must be integer or double)"));
 	    db_CatValArray_init(&sarray);
 	    db_select_CatValArray(driver, Fi->table, Fi->key, scol,
@@ -332,16 +328,14 @@
     if (OUTRANGE > 0)
-	G_warning(_
-		  ("there are points outside specified 2D/3D region--ignored %d points"),
+	G_warning(_("there are points outside specified 2D/3D region--ignored %d points"),
 		  OUTRANGE);
     if (npoint > 0)
 	G_warning(_("ignoring %d points -- too dense"), npoint);
     npoint = k - npoint - OUTRANGE;
     if (npoint < params->kmin) {
 	if (npoint != 0) {
-	    G_warning(_
-		      ("%d points given for interpolation (after thinning) is less than given NPMIN=%d"),
+	    G_warning(_("%d points given for interpolation (after thinning) is less than given NPMIN=%d"),
 		      npoint, params->kmin);
 	    params->kmin = npoint;
Modified: grass/trunk/lib/symbol/read.c
--- grass/trunk/lib/symbol/read.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/symbol/read.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -251,8 +251,7 @@
     strcpy(group, sname);
     c = strchr(group, '/');
     if (c == NULL) {
-	G_warning(_
-		  ("Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"),
+	G_warning(_("Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"),
 		  sname);
 	return NULL;
@@ -376,8 +375,7 @@
 	    else if (sscanf(data, "%d %d %d", &r, &g, &b) == 3) {
 		if (r < 0 || r > 255 || g < 0 || g > 255 || b < 0 || b > 255)
-		    G_warning(_
-			      ("Incorrect symbol color: '%s', using default."),
+		    G_warning(_("Incorrect symbol color: '%s', using default."),
 			      buf);
 		else {
 		    fr = r / 255.0;
@@ -405,8 +403,7 @@
-		    G_warning(_
 			      buf);
 		else {
 		    fr = r / 255.0;
Modified: grass/trunk/lib/vector/Vlib/array.c
--- grass/trunk/lib/vector/Vlib/array.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/array.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -289,8 +289,7 @@
     db_close_database_shutdown_driver(driver);
     if (ncats == -1) {
-	G_warning(_
-		  ("Unable to select record from table <%s> (key %s, where %s)"),
+	G_warning(_("Unable to select record from table <%s> (key %s, where %s)"),
 		  Fi->table, Fi->key, where);
 	return -1;
Modified: grass/trunk/lib/vector/Vlib/build_ogr.c
--- grass/trunk/lib/vector/Vlib/build_ogr.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/build_ogr.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -345,8 +345,7 @@
     /* test layer capabilities */
     if (!OGR_L_TestCapability(Map->fInfo.ogr.layer, OLCRandomRead)) {
-	G_warning(_
-		  ("Random read is not supported by OGR for this layer, cannot build support"));
+	G_warning(_("Random read is not supported by OGR for this layer, cannot build support"));
 	return 0;
Modified: grass/trunk/lib/vector/Vlib/cats.c
--- grass/trunk/lib/vector/Vlib/cats.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/cats.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -126,8 +126,7 @@
     /* field was not found so we shall append new cat */
     /* test if space exist */
     if (n >= GV_NCATS_MAX) {
-	G_fatal_error(_
-		      ("Too many categories (%d), unable to set cat %d (layer %d)"),
+	G_fatal_error(_("Too many categories (%d), unable to set cat %d (layer %d)"),
 		      Cats->n_cats, cat, field);
@@ -374,8 +373,7 @@
 	    max = min;
 	else {			/* error */
-	    G_warning(_
-		      ("Unable to convert category string '%s' (from '%s') to category range"),
+	    G_warning(_("Unable to convert category string '%s' (from '%s') to category range"),
 		      buf, str);
 	    err++;
 	    continue;
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/cindex.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -104,8 +104,7 @@
     check_status(Map);
     if (index < 0 || index >= Map->plus.n_cidx)
-	G_fatal_error(_
-		      ("Invalid layer index (index < 0 or index >= number of layers)"));
+	G_fatal_error(_("Invalid layer index (index < 0 or index >= number of layers)"));
     return (Map->plus.cidx[index].n_ucats);
@@ -509,8 +508,7 @@
     fp.file = G_fopen_old(buf, GV_CIDX_ELEMENT, Map->mapset);
     if (fp.file == NULL) {	/* category index file is not available */
-	G_warning(_
-		  ("Unable to open category index file for vector map <%s@%s>"),
+	G_warning(_("Unable to open category index file for vector map <%s@%s>"),
 		  Map->name, Map->mapset);
 	return -1;
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/field.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -91,8 +91,7 @@
     if (Map->mode != GV_MODE_WRITE && Map->mode != GV_MODE_RW) {
-	G_warning(_
-		  ("Unable to add database link, map is not opened in WRITE mode"));
+	G_warning(_("Unable to add database link, map is not opened in WRITE mode"));
 	return -1;
@@ -544,8 +543,7 @@
 		    if (db_open_select_cursor
 			(driver, &sql, &cursor, DB_SEQUENTIAL) != DB_OK) {
 			/* neither FID nor ogc_fid nor ogr_fid nor gid available */
-			G_warning(_
-				  ("All FID tests failed. Neither 'FID' nor 'ogc_fid' "
+			G_warning(_("All FID tests failed. Neither 'FID' nor 'ogc_fid' "
 				   "nor 'ogr_fid' nor 'gid' available in OGR DB table"));
 			return 0;
@@ -773,8 +771,7 @@
 void Vect_set_db_updated(struct Map_info *Map)
     if (strcmp(Map->mapset, G_mapset()) != 0) {
-	G_fatal_error(_
-		      ("Bug: attempt to update map which is not in current mapset"));
+	G_fatal_error(_("Bug: attempt to update map which is not in current mapset"));
     Vect_write_dblinks(Map);
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/intersect.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -319,8 +319,7 @@
 	/* should not be reached */
-	G_warning(_
-		  ("Vect_segment_intersection() ERROR (collinear vertical segments)"));
+	G_warning(_("Vect_segment_intersection() ERROR (collinear vertical segments)"));
 	G_warning("%.15g %.15g", ax1, ay1);
 	G_warning("%.15g %.15g", ax2, ay2);
 	G_warning("x");
@@ -446,8 +445,7 @@
-    G_warning(_
-	      ("Vect_segment_intersection() ERROR (collinear non vertical segments)"));
+    G_warning(_("Vect_segment_intersection() ERROR (collinear non vertical segments)"));
     G_warning("x");
Modified: grass/trunk/lib/vector/Vlib/legal_vname.c
--- grass/trunk/lib/vector/Vlib/legal_vname.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/legal_vname.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -45,16 +45,14 @@
     sprintf(buf, "%s", s);
     if (*s == '.' || *s == 0) {
-	G_warning(_
-		  ("Illegal vector map name <%s>. May not contain '.' or 'NULL'."),
+	G_warning(_("Illegal vector map name <%s>. May not contain '.' or 'NULL'."),
 		  buf);
 	return -1;
     /* file name must start with letter */
     if (!((*s >= 'A' && *s <= 'Z') || (*s >= 'a' && *s <= 'z'))) {
-	G_warning(_
-		  ("Illegal vector map name <%s>. Must start with a letter."),
+	G_warning(_("Illegal vector map name <%s>. Must start with a letter."),
 		  buf);
 	return -1;
@@ -62,16 +60,14 @@
     for (s++; *s; s++)
 	if (!((*s >= 'A' && *s <= 'Z') || (*s >= 'a' && *s <= 'z') ||
 	      (*s >= '0' && *s <= '9') || *s == '_' || *s == '@')) {
-	    G_warning(_
-		      ("Illegal vector map name <%s>. Character '%c' not allowed."),
+	    G_warning(_("Illegal vector map name <%s>. Character '%c' not allowed."),
 		      buf, *s);
 	    return -1;
     for (i = 0; keywords[i]; i++)
 	if (G_strcasecmp(buf, keywords[i]) == 0) {
-	    G_warning(_
-		      ("Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."),
+	    G_warning(_("Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."),
 		      buf);
 	    return -1;
@@ -102,8 +98,7 @@
     if (Vect_legal_filename(output) == -1) {
 	if (error == GV_FATAL_EXIT) {
-	    G_fatal_error(_
-			  ("Output vector map name <%s> is not valid map name"),
+	    G_fatal_error(_("Output vector map name <%s> is not valid map name"),
 			  output);
 	else if (error == GV_FATAL_PRINT) {
Modified: grass/trunk/lib/vector/Vlib/map.c
--- grass/trunk/lib/vector/Vlib/map.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/map.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -263,8 +263,7 @@
 	else {
 	    if (db_create_index2(driver, Fin->table, Fi->key) != DB_OK)
-		G_warning(_
-			  ("Unable to create index for table <%s>, key <%s>"),
+		G_warning(_("Unable to create index for table <%s>, key <%s>"),
 			  Fi->table, Fi->key);
@@ -399,8 +398,7 @@
 	else {
 	    if (db_create_index2(driver, Fout->table, Fin->key) != DB_OK)
-		G_warning(_
 			  Fout->table, Fout->key);
@@ -460,8 +458,7 @@
 	    for (i = 0; i < n; i++) {
 		Fi = Vect_get_dblink(&Map, i);
 		if (Fi == NULL) {
-		    G_warning(_
-			      ("Database connection not defined for layer %d"),
+		    G_warning(_("Database connection not defined for layer %d"),
 			      Map.dblnk->field[i].number);
 		    Vect_close(&Map);
 		    return -1;
@@ -471,8 +468,7 @@
 		ret = db_table_exists(Fi->driver, Fi->database, Fi->table);
 		if (ret == -1) {
-		    G_warning(_
-			      ("Unable to find table <%s> linked to vector map <%s>"),
+		    G_warning(_("Unable to find table <%s> linked to vector map <%s>"),
 			      Fi->table, map);
 		    Vect_close(&Map);
 		    return -1;
@@ -488,8 +484,7 @@
 		else {
-		    G_warning(_
-			      ("Table <%s> linked to vector map <%s> does not exist"),
+		    G_warning(_("Table <%s> linked to vector map <%s> does not exist"),
 			      Fi->table, map);
@@ -615,8 +610,7 @@
 	else {
-		G_warning(_
 			  Fin->table, Fin->key);
Modified: grass/trunk/lib/vector/Vlib/net.c
--- grass/trunk/lib/vector/Vlib/net.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/net.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -193,8 +193,7 @@
 	fctype = db_sqltype_to_Ctype(db_get_column_sqltype(Column));
 	if (fctype != DB_C_TYPE_INT && fctype != DB_C_TYPE_DOUBLE)
-	    G_fatal_error(_
-			  ("Data type of column <%s> not supported (must be numeric)"),
+	    G_fatal_error(_("Data type of column <%s> not supported (must be numeric)"),
 			  afcol);
 	db_CatValArray_init(&fvarr);
@@ -211,8 +210,7 @@
 	    bctype = db_sqltype_to_Ctype(db_get_column_sqltype(Column));
 	    if (bctype != DB_C_TYPE_INT && bctype != DB_C_TYPE_DOUBLE)
-		G_fatal_error(_
 			      abcol);
 	    db_CatValArray_init(&bvarr);
@@ -365,8 +363,7 @@
-	    G_fatal_error(_
 			  ncol);
@@ -402,8 +399,7 @@
 							    &dcost);
 		    if (ret != DB_OK) {
-			G_warning(_
-				  ("Database record for node %d (cat = %d) not found "
+			G_warning(_("Database record for node %d (cat = %d) not found "
 				   "(cost set to 0)"), i, cat);
 		    cfound = 1;
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/open.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -176,8 +176,7 @@
     Map->gisdbase = G_store(G_gisdbase());
     if (update && (0 != strcmp(Map->mapset, G_mapset()))) {
-	G_warning(_
-		  ("Vector map which is not in the current mapset cannot be opened for update"));
+	G_warning(_("Vector map which is not in the current mapset cannot be opened for update"));
 	return -1;
@@ -233,8 +232,7 @@
 	    level = 1;
 	else if (ret == -1) {
-	    G_fatal_error(_
-			  ("Unable to open topology file for vector map <%s>"),
+	    G_fatal_error(_("Unable to open topology file for vector map <%s>"),
 			  Vect_get_full_name(Map));
 	/* open spatial index, not needed for head_only */
@@ -260,8 +258,7 @@
 		level = 1;
 	    else if (ret == -1) {	/* file exists, but cannot be opened */
-		G_fatal_error(_
-			      ("Unable to open category index file for vector map <%s>"),
+		G_fatal_error(_("Unable to open category index file for vector map <%s>"),
@@ -728,8 +725,7 @@
     /* do checks */
     err = 0;
     if (CInfo.size != Plus->coor_size) {
-	G_warning(_
-		  ("Size of 'coor' file differs from value saved in topology file"));
+	G_warning(_("Size of 'coor' file differs from value saved in topology file"));
 	err = 1;
     /* Do not check mtime because mtime is changed by copy */
Modified: grass/trunk/lib/vector/Vlib/open_nat.c
--- grass/trunk/lib/vector/Vlib/open_nat.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/open_nat.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -142,13 +142,11 @@
 	    Map->head.size, CInfo.size);
     if (dif > 0) {
-	G_warning(_
-		  ("Coor files of vector map <%s@%s> is larger than it should be "
+	G_warning(_("Coor files of vector map <%s@%s> is larger than it should be "
 		   "(%ld bytes excess)"), Map->name, Map->mapset, dif);
     else if (dif < 0) {
-	G_warning(_
-		  ("Coor files of vector <%s@%s> is shorter than it should be "
+	G_warning(_("Coor files of vector <%s@%s> is shorter than it should be "
 		   "(%ld bytes missing)."), Map->name, Map->mapset, -dif);
     return 1;
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -144,14 +144,12 @@
     /* check version numbers */
     if (Version_Major > 5 || Version_Minor > 0) {
 	if (Back_Major > 5 || Back_Minor > 0) {
-	    G_fatal_error(_
-			  ("Feature index format version %d.%d is not supported by this release."
+	    G_fatal_error(_("Feature index format version %d.%d is not supported by this release."
 			   " Try to rebuild topology or upgrade GRASS."),
 			  Version_Major, Version_Minor);
 	    return (-1);
-	G_warning(_
-		  ("Your GRASS version does not fully support feature index format %d.%d of the vector."
+	G_warning(_("Your GRASS version does not fully support feature index format %d.%d of the vector."
 		   " Consider to rebuild topology or upgrade GRASS."),
Modified: grass/trunk/lib/vector/Vlib/overlay.c
--- grass/trunk/lib/vector/Vlib/overlay.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/overlay.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -120,12 +120,10 @@
     /* TODO: support all types; at present only point x point, area x point and point x area supported  */
     if ((atype & GV_LINES) || (btype & GV_LINES))
-	G_warning(_
-		  ("Overlay: line/boundary types not supported by AND operator"));
+	G_warning(_("Overlay: line/boundary types not supported by AND operator"));
     if ((atype & GV_AREA) && (btype & GV_AREA))
-	G_warning(_
-		  ("Overlay: area x area types not supported by AND operator"));
+	G_warning(_("Overlay: area x area types not supported by AND operator"));
     /* TODO: more points in one node in one map */
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/read.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -103,8 +103,7 @@
 	G_fatal_error("Vect_read_line(): %s", _("vector map is not opened"));
     if (line < 1 || line > Map->plus.n_lines)
-	G_fatal_error(_
-		      ("Vect_read_line(): line %d is not reasonable (max line in vector map: %d)"),
+	G_fatal_error(_("Vect_read_line(): line %d is not reasonable (max line in vector map: %d)"),
 		      line, Map->plus.n_lines);
     return (*V2_read_line_array[Map->format]) (Map, line_p, line_c, line);
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -375,8 +375,7 @@
 		Map->fInfo.ogr.feature_cache =
 		    OGR_L_GetFeature(Map->fInfo.ogr.layer, FID);
 		if (Map->fInfo.ogr.feature_cache == NULL) {
-		    G_fatal_error(_
-				  ("Unable to get feature geometry, FID %ld"),
+		    G_fatal_error(_("Unable to get feature geometry, FID %ld"),
 				  FID);
 		Map->fInfo.ogr.feature_cache_id = FID;
Modified: grass/trunk/lib/vector/Vlib/sindex.c
--- grass/trunk/lib/vector/Vlib/sindex.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/sindex.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -166,8 +166,7 @@
 	Node = plus->Node[i];
 	if (!Node)
-	    G_fatal_error(_
-			  ("BUG (Vect_build_sidx_from_topo): node does not exist"));
+	    G_fatal_error(_("BUG (Vect_build_sidx_from_topo): node does not exist"));
 	dig_spidx_add_node(plus, i, Node->x, Node->y, Node->z);
@@ -179,8 +178,7 @@
 	Line = plus->Line[i];
 	if (!Line)
-	    G_fatal_error(_
-			  ("BUG (Vect_build_sidx_from_topo): line does not exist"));
+	    G_fatal_error(_("BUG (Vect_build_sidx_from_topo): line does not exist"));
 	box.N = Line->N;
 	box.S = Line->S;
@@ -199,8 +197,7 @@
 	Area = plus->Area[i];
 	if (!Area)
-	    G_fatal_error(_
-			  ("BUG (Vect_build_sidx_from_topo): area does not exist"));
+	    G_fatal_error(_("BUG (Vect_build_sidx_from_topo): area does not exist"));
 	box.N = Area->N;
 	box.S = Area->S;
@@ -219,8 +216,7 @@
 	Isle = plus->Isle[i];
 	if (!Isle)
-	    G_fatal_error(_
-			  ("BUG (Vect_build_sidx_from_topo): isle does not exist"));
+	    G_fatal_error(_("BUG (Vect_build_sidx_from_topo): isle does not exist"));
 	box.N = Isle->N;
 	box.S = Isle->S;
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/Vlib/write_nat.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -36,8 +36,7 @@
     Area = Map->plus.Area[area];
     if (!Area)
-	G_fatal_error(_
-		      ("BUG (delete_area_cats_from_cidx): Area %d does not exist"),
+	G_fatal_error(_("BUG (delete_area_cats_from_cidx): Area %d does not exist"),
 		      area);
     if (Area->centroid == 0)
@@ -64,8 +63,7 @@
     if (!Area)
-	G_fatal_error(_
-		      ("BUG (add_area_cats_to_cidx): Area %d does not exist"),
+	G_fatal_error(_("BUG (add_area_cats_to_cidx): Area %d does not exist"),
 		      area);
Modified: grass/trunk/lib/vector/diglib/plus_area.c
--- grass/trunk/lib/vector/diglib/plus_area.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/diglib/plus_area.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -301,8 +301,7 @@
 	Area->n_isles--;
     else {
-	G_fatal_error(_
-		      ("Attempt to delete not registered isle %d from area %d"),
+	G_fatal_error(_("Attempt to delete not registered isle %d from area %d"),
 		      isle, area);
@@ -380,8 +379,7 @@
     if (line > 0) {
 	Line = plus->Line[line];
 	if (!Line) {
-	    G_warning(_
-		      ("Dead centroid %d registered for area (bug in the vector library)"),
+	    G_warning(_("Dead centroid %d registered for area (bug in the vector library)"),
 		      line);
 	else {
@@ -405,8 +403,7 @@
     for (i = 0; i < Area->n_isles; i++) {
 	Isle = plus->Isle[Area->isles[i]];
 	if (Isle == NULL) {
-	    G_fatal_error(_
-			  ("Attempt to delete area %d info from dead isle %d"),
+	    G_fatal_error(_("Attempt to delete area %d info from dead isle %d"),
 			  area, Area->isles[i]);
 	else {
@@ -749,8 +746,7 @@
     G_debug(3, "  area outside isle = %d", Isle->area);
     if (Isle->area > 0) {
 	if (plus->Area[Isle->area] == NULL) {
-	    G_fatal_error(_
-			  ("Attempt to delete isle %d info from dead area %d"),
+	    G_fatal_error(_("Attempt to delete isle %d info from dead area %d"),
 			  isle, Isle->area);
 	else {
Modified: grass/trunk/lib/vector/diglib/plus_node.c
--- grass/trunk/lib/vector/diglib/plus_node.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/diglib/plus_node.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -214,8 +214,7 @@
 	    return (node->angles[i]);
-    G_fatal_error(_
-		  ("Attempt to read line angle for the line which is not connected to the node: "
+    G_fatal_error(_("Attempt to read line angle for the line which is not connected to the node: "
 		   "node %d, line %d"), nodeid, lineid);
     return 0.0;			/* not reached */
Modified: grass/trunk/lib/vector/vedit/cats.c
--- grass/trunk/lib/vector/vedit/cats.c	2008-08-06 21:50:17 UTC (rev 32584)
+++ grass/trunk/lib/vector/vedit/cats.c	2008-08-06 22:00:00 UTC (rev 32585)
@@ -71,8 +71,7 @@
 		else {		/* delete old category */
 		    if (Vect_field_cat_del(Cats, layer, cat) == 0) {
-			G_warning(_
-				  ("Unable to delete layer/category %d/%d line %d"),
+			G_warning(_("Unable to delete layer/category %d/%d line %d"),
 				  layer, cat, line);
 		    else {
