[GRASS-SVN] r32587 - in grass/trunk/vector: lidar/v.lidar.correction lidar/v.lidar.edgedetection lidar/v.lidar.growing lidar/v.outlier lidar/v.surf.bspline v.buffer v.build v.category v.class v.clean v.convert v.db.connect v.digit v.distance v.drape v.edit v.generalize v.hull v.in.ascii v.in.db v.in.dxf v.in.ogr v.in.sites v.info v.kcv v.kernel v.label v.label.sa v.lrs/v.lrs.create v.lrs/v.lrs.segment v.mapcalc v.net v.net.alloc v.net.iso v.out.ascii v.out.ogr v.out.vtk v.overlay v.patch v.perturb v.proj v.random v.reclass v.sample v.segment v.surf.idw v.surf.rst v.to.db v.to.rast v.transform v.univar v.vol.rst v.what.rast
Wed Aug 6 18:06:13 EDT 2008
Author: neteler
Date: 2008-08-06 18:06:12 -0400 (Wed, 06 Aug 2008)
New Revision: 32587
   grass/trunk/vector/lidar/v.lidar.correction/correction.c
   grass/trunk/vector/lidar/v.lidar.correction/main.c
   grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
   grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
   grass/trunk/vector/lidar/v.lidar.growing/main.c
   grass/trunk/vector/lidar/v.outlier/main.c
   grass/trunk/vector/lidar/v.outlier/outlier.c
   grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
   grass/trunk/vector/lidar/v.surf.bspline/main.c
   grass/trunk/vector/v.buffer/main.c
   grass/trunk/vector/v.build/main.c
   grass/trunk/vector/v.category/main.c
   grass/trunk/vector/v.class/main.c
   grass/trunk/vector/v.clean/main.c
   grass/trunk/vector/v.clean/prune.c
   grass/trunk/vector/v.convert/att.c
   grass/trunk/vector/v.convert/old2new.c
   grass/trunk/vector/v.db.connect/main.c
   grass/trunk/vector/v.digit/main.c
   grass/trunk/vector/v.distance/main.c
   grass/trunk/vector/v.drape/main.c
   grass/trunk/vector/v.edit/a2b.c
   grass/trunk/vector/v.edit/main.c
   grass/trunk/vector/v.generalize/main.c
   grass/trunk/vector/v.hull/main.c
   grass/trunk/vector/v.in.ascii/a2b.c
   grass/trunk/vector/v.in.ascii/in.c
   grass/trunk/vector/v.in.ascii/points.c
   grass/trunk/vector/v.in.db/main.c
   grass/trunk/vector/v.in.dxf/add_polyline.c
   grass/trunk/vector/v.in.dxf/main.c
   grass/trunk/vector/v.in.ogr/geom.c
   grass/trunk/vector/v.in.ogr/main.c
   grass/trunk/vector/v.in.sites/main.c
   grass/trunk/vector/v.info/main.c
   grass/trunk/vector/v.kcv/main.c
   grass/trunk/vector/v.kernel/main.c
   grass/trunk/vector/v.label.sa/font.c
   grass/trunk/vector/v.label/main.c
   grass/trunk/vector/v.lrs/v.lrs.create/main.c
   grass/trunk/vector/v.lrs/v.lrs.segment/main.c
   grass/trunk/vector/v.mapcalc/number.c
   grass/trunk/vector/v.net.alloc/main.c
   grass/trunk/vector/v.net.iso/main.c
   grass/trunk/vector/v.net/main.c
   grass/trunk/vector/v.net/report.c
   grass/trunk/vector/v.out.ascii/out.c
   grass/trunk/vector/v.out.ogr/main.c
   grass/trunk/vector/v.out.vtk/main.c
   grass/trunk/vector/v.out.vtk/writeVTK.c
   grass/trunk/vector/v.overlay/main.c
   grass/trunk/vector/v.patch/main.c
   grass/trunk/vector/v.perturb/main.c
   grass/trunk/vector/v.proj/main.c
   grass/trunk/vector/v.random/main.c
   grass/trunk/vector/v.reclass/main.c
   grass/trunk/vector/v.sample/main.c
   grass/trunk/vector/v.segment/main.c
   grass/trunk/vector/v.surf.idw/main.c
   grass/trunk/vector/v.surf.rst/main.c
   grass/trunk/vector/v.to.db/main.c
   grass/trunk/vector/v.to.db/parse.c
   grass/trunk/vector/v.to.db/query.c
   grass/trunk/vector/v.to.db/report.c
   grass/trunk/vector/v.to.db/update.c
   grass/trunk/vector/v.to.rast/do_lines.c
   grass/trunk/vector/v.to.rast/main.c
   grass/trunk/vector/v.to.rast/support.c
   grass/trunk/vector/v.to.rast/vect2rast.c
   grass/trunk/vector/v.transform/main.c
   grass/trunk/vector/v.transform/trans_digit.c
   grass/trunk/vector/v.univar/main.c
   grass/trunk/vector/v.vol.rst/main.c
   grass/trunk/vector/v.vol.rst/user1.c
   grass/trunk/vector/v.what.rast/main.c
fixed unlucky formatted messages (thanks to Glynn)
Modified: grass/trunk/vector/lidar/v.lidar.correction/correction.c
--- grass/trunk/vector/lidar/v.lidar.correction/correction.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/lidar/v.lidar.correction/correction.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -81,13 +81,11 @@
 			if (Select_Correction
 			    (&interpolation, line_num[i], driver) != DB_OK)
-			    G_fatal_error(_
-					  ("Impossible to read the database"));
+			    G_fatal_error(_("Impossible to read the database"));
 			if (UpDate_Correction
 			    (interpolation, line_num[i], driver) != DB_OK)
-			    G_fatal_error(_
-					  ("Impossible to update the database"));
+			    G_fatal_error(_("Impossible to update the database"));
 		    else if ((*points->y < Overlap.S)) {	/*(1) */
@@ -98,8 +96,7 @@
 			if (Insert_Correction
 			    (interpolation * weight, line_num[i],
 			     driver) != DB_OK)
-			    G_fatal_error(_
-					  ("Impossible to write in the database"));
+			    G_fatal_error(_("Impossible to write in the database"));
 		    else {	/*(1) */
@@ -108,8 +105,7 @@
 			     driver) != DB_OK)
-			    G_fatal_error(_
 		else if ((*points->x < Overlap.W)) {
@@ -121,8 +117,7 @@
 			interpolation *= weight;
-			    G_fatal_error(_
 			Vect_cat_get(cats, F_CLASSIFICATION, &class);
 			class =
@@ -144,13 +139,11 @@
-			    G_fatal_error(_
-			    G_fatal_error(_
 		    else {	/*(2) */
 			weight = (Overlap.W - *points->x) / overlap;
@@ -158,8 +151,7 @@
-			    G_fatal_error(_
 			class =
@@ -182,8 +174,7 @@
-			    G_fatal_error(_
 			class =
@@ -203,8 +194,7 @@
 			     driver) != DB_OK)
-			    G_fatal_error(_
Modified: grass/trunk/vector/lidar/v.lidar.correction/main.c
--- grass/trunk/vector/lidar/v.lidar.correction/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/lidar/v.lidar.correction/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -174,8 +174,7 @@
     /* Start driver and open db */
     driver = db_start_driver_open_database(dvr, db);
     if (driver == NULL)
-	G_fatal_error(_
-		      ("No database connection for driver <%s> is defined. Run db.connect."),
+	G_fatal_error(_("No database connection for driver <%s> is defined. Run db.connect."),
 		      dvr);
     /* Setting regions and boxes */
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -237,14 +237,12 @@
 			if (Select
 			    (&gradient[0], &gradient[1], &interpolation,
-			    G_fatal_error(_
 			if (UpDate
 			    (gradient[0], gradient[1], interpolation,
-			    G_fatal_error(_
 		    else if ((*point->y < Overlap.S) && (*point->y != General.S)) {	/*(1) */
@@ -256,8 +254,7 @@
 			    (gradient[0] * weight, gradient[1] * weight,
 			     driver) != DB_OK)
-			    G_fatal_error(_
 		    else if ((*point->y <= Overlap.N) && (*point->y >= Overlap.S)) {	/*(1) */
@@ -267,8 +264,7 @@
 			     driver) != DB_OK)
-			    G_fatal_error(_
@@ -286,8 +282,7 @@
 			if (Select
-			    G_fatal_error(_
 			residual = *point->z - interpolation;
 			edge =
@@ -318,14 +313,12 @@
 			if (Select
-			    G_fatal_error(_
 			if (UpDate
-			    G_fatal_error(_
 		    else if ((*point->y <= Overlap.N) && (*point->y >= Overlap.S)) {	/*(2) */
@@ -338,8 +331,7 @@
 			if (Select
-			    G_fatal_error(_
 			edge =
@@ -370,8 +362,7 @@
 			if (Select
-			    G_fatal_error(_
 			edge =
@@ -396,8 +387,7 @@
 			     interpolation * weight, line_num[i], driver)
 			    != DB_OK)
-			    G_fatal_error(_
 		    }		/*else (1) */
 		}		/*else */
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -187,13 +187,11 @@
     if (driver == NULL)
-	G_fatal_error(_
 		      dvr);
     if (Create_Interpolation_Table(out_opt->answer, driver) != DB_OK)
-	G_fatal_error(_
-		      ("It was impossible to create <%s> interpolation table in database."),
+	G_fatal_error(_("It was impossible to create <%s> interpolation table in database."),
 		      out_opt->answer);
Modified: grass/trunk/vector/lidar/v.lidar.growing/main.c
--- grass/trunk/vector/lidar/v.lidar.growing/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/lidar/v.lidar.growing/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -148,8 +148,7 @@
     driver = db_start_driver_open_database(field->driver, field->database);
     if (driver == NULL)
-	G_fatal_error(_
 		      field->driver);
Modified: grass/trunk/vector/lidar/v.outlier/main.c
--- grass/trunk/vector/lidar/v.outlier/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/lidar/v.outlier/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -164,8 +164,7 @@
     Vect_set_open_level(1);
     /* Open input vector */
     if (1 > Vect_open_old(&In, in_opt->answer, mapset))
-	G_fatal_error(_
-		      ("Unable to open vector map <%s> at the topological level"),
+	G_fatal_error(_("Unable to open vector map <%s> at the topological level"),
 		      in_opt->answer);
     /* Copy vector Head File */
@@ -186,8 +185,7 @@
     if (driver == NULL)
-	G_fatal_error(_
 		      dvr);
@@ -317,8 +315,7 @@
 			    "Creating auxiliar table for archiving overlaping zones");
 		    if ((flag_auxiliar =
 			 P_Create_Aux_Table(driver, table_name)) == FALSE)
-			G_fatal_error(_
-				      ("It was impossible to create <Auxiliar_outlier_table>."));
+			G_fatal_error(_("It was impossible to create <Auxiliar_outlier_table>."));
 		if (qgis_opt->answer)
Modified: grass/trunk/vector/lidar/v.outlier/outlier.c
--- grass/trunk/vector/lidar/v.outlier/outlier.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/lidar/v.outlier/outlier.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -70,13 +70,11 @@
 			if (Select_Outlier(&gradient[0], line_num[i], driver)
 			    != DB_OK)
-			    G_fatal_error(_
 			if (UpDate_Outlier(gradient[0], line_num[i], driver)
 			    != DB_OK)
-			    G_fatal_error(_
@@ -87,8 +85,7 @@
 			if (Insert_Outlier
 			     driver) != DB_OK)
-			    G_fatal_error(_
@@ -97,8 +94,7 @@
 			if (Insert_Outlier
 			     driver) != DB_OK)
-			    G_fatal_error(_
@@ -115,8 +111,7 @@
 			    != DB_OK)
-			    G_fatal_error(_
@@ -143,13 +138,11 @@
 			    != DB_OK)
-			    G_fatal_error(_
 			    != DB_OK)
-			    G_fatal_error(_
@@ -161,8 +154,7 @@
 			    != DB_OK)
-			    G_fatal_error(_
@@ -189,8 +181,7 @@
 			    != DB_OK)
-			    G_fatal_error(_
@@ -212,8 +203,7 @@
 			if (Insert_Outlier
 			    (interpolation * weight, line_num[i], driver)
 			    != DB_OK)
-			    G_fatal_error(_
 		    }		/*else (1) */
 		}		/*else */
Modified: grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
--- grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -117,8 +117,7 @@
 		    Fi->database);
 	    if (driver_cats == NULL)
-		G_fatal_error(_
-			      ("CrossCorrelation: Cannot open database %s by driver %s"),
+		G_fatal_error(_("CrossCorrelation: Cannot open database %s by driver %s"),
 			      Fi->database, Fi->driver);
 	    nrec =
@@ -128,12 +127,10 @@
 	    ctype = cvarr.ctype;
 	    if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE)
-		G_fatal_error(_
-			      ("CrossCorrelation: Column type not supported"));
+		G_fatal_error(_("CrossCorrelation: Column type not supported"));
 	    if (nrec < 0)
-		G_fatal_error(_
-			      ("CrossCorrelation: Cannot select data from table"));
+		G_fatal_error(_("CrossCorrelation: Cannot select data from table"));
 	    G_message(_("CrossCorrelation: %d records selected from table"),
 		      nrec);
@@ -216,8 +213,7 @@
 			    obs_mean[i] = dval;
 			if (ret != DB_OK) {
-			    G_warning(_
-				      ("CrossCorrelation: No record for point (cat = %d)"),
+			    G_warning(_("CrossCorrelation: No record for point (cat = %d)"),
 				      cat);
 			    continue;
@@ -333,8 +329,7 @@
 	G_free_vector(rms);
     }				/* ENDIF (ndata > 0) */
     else
-	G_warning(_
-		  ("CrossCorrelation: No point lies into the current region"));
+	G_warning(_("CrossCorrelation: No point lies into the current region"));
     G_free(observ);
     return TRUE;
Modified: grass/trunk/vector/lidar/v.surf.bspline/main.c
--- grass/trunk/vector/lidar/v.surf.bspline/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/lidar/v.surf.bspline/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -201,8 +201,7 @@
 	if (driver == NULL)
-	    G_fatal_error(_
-			  ("No database connection for driver <%s> is defined. "
+	    G_fatal_error(_("No database connection for driver <%s> is defined. "
 			   "Run db.connect."), dvr);
 	db_init_string(&sql);
@@ -229,8 +228,7 @@
     Vect_set_open_level(1);	/* WITHOUT TOPOLOGY */
-	G_fatal_error(_
 		      in_opt->answer);
     /* Open input ext vector */
@@ -250,8 +248,7 @@
 	if (1 > Vect_open_old(&In_ext, in_ext_opt->answer, mapset))
-	    G_fatal_error(_
 			  in_opt->answer);
@@ -259,8 +256,7 @@
     /* vector output */
     if (vector && !map) {
 	if (strcmp(dvr, "dbf") == 0)
-	    G_fatal_error(_
-			  ("Sorry, <%s> driver is not allowed for vector output in this module. "
+	    G_fatal_error(_("Sorry, <%s> driver is not allowed for vector output in this module. "
 			   "Try with a raster output or other driver."), dvr);
 	Vect_check_input_output_name(in_opt->answer, out_opt->answer,
@@ -382,8 +378,7 @@
 	nrows_ncols = (double)nrows *ncols;
 	if ((nrows_ncols) > 30000000)	/* about 5500x5500 cells */
-	    G_fatal_error(_
-			  ("Interpolation: The region resolution is too high: %d cells. "
+	    G_fatal_error(_("Interpolation: The region resolution is too high: %d cells. "
 			   "Consider to change it."), nrows_ncols);
 	/*raster_matrix = G_alloc_fmatrix (nrows, ncols);  Is it neccesary a double precision?? */
@@ -545,8 +540,7 @@
 			    obs_mean[i] = dval;
 			if (ret != DB_OK) {
-			    G_warning(_
-				      ("Interpolation: (%d,%d): No record for point (cat = %d)"),
+			    G_warning(_("Interpolation: (%d,%d): No record for point (cat = %d)"),
 				      subregion_row, subregion_col, cat);
 			    continue;
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.buffer/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -452,8 +452,7 @@
 			db_CatValArray_get_value_int(&cvarr, cat,
 						     &size_val_int);
 		    if (ret != DB_OK) {
-			G_warning(_
-				  ("No record for category %d in table <%s>"),
+			G_warning(_("No record for category %d in table <%s>"),
 				  cat, Fi->table);
 			continue;
@@ -465,16 +464,14 @@
 			db_CatValArray_get_value_double(&cvarr, cat,
 							&size_val);
 		    if (ret != DB_OK) {
-			G_warning(_
 				  cat, Fi->table);
 			continue;
 		if (size_val < 0.0) {
-		    G_warning(_
-			      ("Attribute is of invalid size (%.3f) for category %d"),
+		    G_warning(_("Attribute is of invalid size (%.3f) for category %d"),
 			      size_val, cat);
 		    continue;
@@ -493,8 +490,7 @@
 		G_debug(2, "Minimum tolerance = %f", dtmp);
 		if (tolerance > dtmp) {
 		    tolerance = dtmp;
-		    G_warning(_
-			      ("The tolerance was reset to %g (map units). [category %d]"),
+		    G_warning(_("The tolerance was reset to %g (map units). [category %d]"),
 			      tolerance, cat);
@@ -533,8 +529,7 @@
 						     &size_val_int);
 		    if (ret != DB_OK) {
-			G_warning(_
 				  cat, Fi->table);
 			continue;
@@ -546,16 +541,14 @@
 							&size_val);
 		    if (ret != DB_OK) {
-			G_warning(_
 				  cat, Fi->table);
 			continue;
-		    G_warning(_
 			      size_val, cat);
 		    continue;
@@ -574,8 +567,7 @@
 		    tolerance = dtmp;
-		    G_warning(_
 			      tolerance, cat);
Modified: grass/trunk/vector/v.build/main.c
--- grass/trunk/vector/v.build/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.build/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -82,8 +82,7 @@
     if (build) {
 	/* open input vector */
 	if (G_find_vector2(map_opt->answer, G_mapset()) == NULL)
-	    G_fatal_error(_
-			  ("Vector map <%s> not found in the current mapset"),
+	    G_fatal_error(_("Vector map <%s> not found in the current mapset"),
 			  map_opt->answer);
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.category/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -130,8 +130,7 @@
 	break;
     case ('c'):
 	option = O_CHFIELD;
-	G_warning(_
-		  ("Database connection and attribute tables for concerned layers are not changed"));
+	G_warning(_("Database connection and attribute tables for concerned layers are not changed"));
 	break;
     case ('s'):
 	option = O_SUM;
Modified: grass/trunk/vector/v.class/main.c
--- grass/trunk/vector/v.class/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.class/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -163,8 +163,7 @@
     if (G_strcasecmp(algo_opt->answer, "dis") == 0 && finfo < 3.84148)
-	G_warning(_
-		  ("The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."));
+	G_warning(_("The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."));
     /*output to be piped to other modules ? */
     if (shell_flag->answer) {
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.clean/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -368,8 +368,7 @@
 	    G_message(_("%d modifications done"), count);
 	    break;
 	case TOOL_RMLINE:
-	    G_message(_
-		      ("Tool: Remove all lines and boundaries of zero length"));
+	    G_message(_("Tool: Remove all lines and boundaries of zero length"));
 	    count = remove_zero_line(&Out, otype, pErr);
 	    G_message(_("%d lines / boundaries removed"), count);
 	    break;
@@ -379,8 +378,7 @@
     if (!no_build_flag->answer) {
-	G_important_message(_
-			    ("Rebuilding topology for output vector map..."));
+	G_important_message(_("Rebuilding topology for output vector map..."));
 	Vect_build_partial(&Out, GV_BUILD_NONE, NULL);
 	Vect_build(&Out, output);
Modified: grass/trunk/vector/v.clean/prune.c
--- grass/trunk/vector/v.clean/prune.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.clean/prune.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -217,13 +217,11 @@
 	fflush(stderr);
-			("\n%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"),
+    G_important_message(_("\n%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"),
 			nremoved, nvertices, 100.0 * nremoved / nvertices);
     if (not_pruned_lines > 0)
-	G_message(_
-		  ("%d boundaries not pruned because pruning would damage topology"),
+	G_message(_("%d boundaries not pruned because pruning would damage topology"),
 		  not_pruned_lines);
     Vect_destroy_line_struct(Points);
Modified: grass/trunk/vector/v.convert/att.c
--- grass/trunk/vector/v.convert/att.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.convert/att.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -33,8 +33,7 @@
     /* Find dig_cats if exists */
     if (NULL == G_find_file("dig_cats", in, mapset)) {
-	G_message(_
-		  ("No category labels (dig_cats) found, no table created.\n"));
+	G_message(_("No category labels (dig_cats) found, no table created.\n"));
 	return 0;
Modified: grass/trunk/vector/v.convert/old2new.c
--- grass/trunk/vector/v.convert/old2new.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.convert/old2new.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -86,14 +86,12 @@
 	    if (sline == -1) {
-		G_warning(_
-			  ("Failed to attach an attribute (category %d) to a line."),
+		G_warning(_("Failed to attach an attribute (category %d) to a line."),
 			  cats[i].cat);
 	    else {
 		if (lines[sline].cat > -1) {
-		    G_warning(_
-			      ("Line %d label: %d matched another label: %d."),
+		    G_warning(_("Line %d label: %d matched another label: %d."),
 			      sline, lines[sline].cat, cats[i].cat);
 		lines[sline].cat = cats[i].cat;
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.db.connect/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -132,16 +132,14 @@
 	Vect_open_old(&Map, inopt->answer, mapset);
     else {
 	if (Vect_open_update_head(&Map, inopt->answer, G_mapset()) < 1)
-	    G_fatal_error(_
-			  ("Unable to modify vector map stored in other mapset"));
+	    G_fatal_error(_("Unable to modify vector map stored in other mapset"));
 	Vect_hist_command(&Map);
     if (print->answer || shell_print->answer || columns->answer) {
 	num_dblinks = Vect_get_num_dblinks(&Map);
 	if (num_dblinks <= 0)
-	    G_fatal_error(_
-			  ("Database connection for map <%s> is not defined in DB file"),
+	    G_fatal_error(_("Database connection for map <%s> is not defined in DB file"),
 			  G_fully_qualified_name(input, mapset));
 	else {			/* num_dblinks > 0 */
@@ -178,8 +176,7 @@
 	    else {		/* columns */
 		if ((fi = Vect_get_field(&Map, field)) == NULL)
-		    G_fatal_error(_
-				  ("Database connection not defined for layer %d"),
+		    G_fatal_error(_("Database connection not defined for layer %d"),
 				  field);
 		driver = db_start_driver(fi->driver);
 		if (driver == NULL)
@@ -189,8 +186,7 @@
 		db_init_handle(&handle);
 		db_set_handle(&handle, fi->database, NULL);
 		if (db_open_database(driver, &handle) != DB_OK)
-		    G_fatal_error(_
-				  ("Unable to open database <%s> by driver <%s>"),
+		    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 				  fi->database, fi->driver);
 		db_init_string(&table_name);
 		db_set_string(&table_name, fi->table);
@@ -241,8 +237,7 @@
 			if (db_table_exists
 			    (dbdriver->answer, dbdatabase->answer,
 			     dbtable->answer) < 1)
-			    G_fatal_error(_
-					  ("Table <%s> does not exist in database <%s>"),
+			    G_fatal_error(_("Table <%s> does not exist in database <%s>"),
 					  dbtable->answer,
 					  dbdatabase->answer);
@@ -257,23 +252,20 @@
 			db_get_column(driver, dbtable->answer, dbkey->answer,
 				      &column);
 			if (!column)
-			    G_fatal_error(_
-					  ("Missing column <%s> in table <%s>"),
+			    G_fatal_error(_("Missing column <%s> in table <%s>"),
 					  dbkey->answer, dbtable->answer);
 			if (db_column_Ctype
 			     dbkey->answer) != DB_C_TYPE_INT)
-			    G_fatal_error(_
-					  ("Data type of key column must be integer"));
+			    G_fatal_error(_("Data type of key column must be integer"));
 			ret = Vect_map_del_dblink(&Map, field);
 			if (Vect_map_add_dblink(&Map, field,
 						fi->name, fi->table, fi->key,
 						fi->database,
 						fi->driver) == 0) {
-						("The table <%s> is now part of vector map <%s> "
+			    G_important_message(_("The table <%s> is now part of vector map <%s> "
 						 "and may be deleted "
 						 "or overwritten by GRASS modules"),
 						dbtable->answer, input);
@@ -285,15 +277,13 @@
 		    if (db_table_exists
-			G_warning(_
+			G_warning(_("Table <%s> does not exist in database <%s>"),
 				  dbtable->answer, dbdatabase->answer);
 					    fi->database, fi->driver) == 0) {
@@ -304,8 +294,7 @@
 								&Map));
 			if (!driver)
-			    G_fatal_error(_
 			if (db_create_index2(driver, fi->table, fi->key) !=
@@ -315,12 +304,10 @@
 			if (db_grant_on_table
 			    (driver, fi->table, DB_PRIV_SELECT,
 			     DB_GROUP | DB_PUBLIC) != DB_OK)
-			    G_warning(_
-				      ("Cannot grant privileges on table %s"),
+			    G_warning(_("Cannot grant privileges on table %s"),
 				      fi->table);
-					    ("Select privileges were granted on the table"));
+			G_important_message(_("Select privileges were granted on the table"));
 			db_close_database_shutdown_driver(driver);
Modified: grass/trunk/vector/v.digit/main.c
--- grass/trunk/vector/v.digit/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.digit/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -155,8 +155,7 @@
 	    Vect_open_update(&Map, map_opt->answer, G_mapset());
 	else {
-	    G_fatal_error(_
-			  ("Map <%s> does not exist in current mapset. Add flag -n to create a new map."),
+	    G_fatal_error(_("Map <%s> does not exist in current mapset. Add flag -n to create a new map."),
 			  map_opt->answer);
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.distance/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -294,8 +294,7 @@
 	G_fatal_error(_("Vector map <%s> not found"), from_opt->answer);
     if (!print_flag->answer && strcmp(mapset, G_mapset()) != 0)
-	G_fatal_error(_
-		      ("Vector map <%s> is not in user mapset and cannot be updated"),
+	G_fatal_error(_("Vector map <%s> is not in user mapset and cannot be updated"),
 		      from_opt->answer);
     Vect_set_open_level(2);
@@ -348,14 +347,12 @@
 	if (!all) {
 	    Fi = Vect_get_field(&From, from_field);
 	    if (Fi == NULL)
-		G_fatal_error(_
 			      from_field);
 	    driver = db_start_driver_open_database(Fi->driver, Fi->database);
 	    if (driver == NULL)
-		G_fatal_error(_
 	    /* check if column exists */
@@ -709,8 +706,7 @@
 		for (j = 0; j < TCats->n_cats; j++) {
 		    if (TCats->field[j] == to_field) {
 			if (tmp_tcat >= 0)
-			    G_warning(_
-				      ("More cats found in to_layer (area=%d)"),
+			    G_warning(_("More cats found in to_layer (area=%d)"),
 				      area);
 			tmp_tcat = TCats->cat[j];
@@ -851,8 +847,7 @@
 	G_debug(3, "selected values = %d", nrec);
 	if (cvarr.ctype == DB_C_TYPE_DATETIME) {
-	    G_warning(_
-		      ("DATETIME type not yet supported, no attributes will be uploaded"));
+	    G_warning(_("DATETIME type not yet supported, no attributes will be uploaded"));
 	db_close_database_shutdown_driver(to_driver);
@@ -1119,8 +1114,7 @@
 	    G_message(_("%d categories exist in the table"), ncatexist);
 	    G_message(_("%d categories read from the map exist in the table"),
 		      update_exist);
-	    G_message(_
-		      ("%d categories read from the map don't exist in the table"),
+	    G_message(_("%d categories read from the map don't exist in the table"),
 		      update_notexist);
 	    G_message(_("%d records updated"), update_ok);
 	    G_message(_("%d update errors"), update_err);
Modified: grass/trunk/vector/v.drape/main.c
--- grass/trunk/vector/v.drape/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.drape/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -153,15 +153,13 @@
     if (in_bbox.W < region_bbox.W ||
 	in_bbox.E > region_bbox.E ||
 	in_bbox.S < region_bbox.S || in_bbox.N > region_bbox.N) {
-	G_warning(_
-		  ("Current region does not include the entire input vector map <%s>"),
+	G_warning(_("Current region does not include the entire input vector map <%s>"),
 		  in_opt->answer);
     if (in_bbox.W < rast_bbox.W ||
 	in_bbox.E > rast_bbox.E ||
 	in_bbox.S < rast_bbox.S || in_bbox.N > rast_bbox.N) {
-	G_warning(_
-		  ("Elevation raster map <%s> does not cover the entire area "
+	G_warning(_("Elevation raster map <%s> does not cover the entire area "
 		   "of the input vector map <%s>. "), rast_opt->answer,
 		  in_opt->answer);
Modified: grass/trunk/vector/v.edit/a2b.c
--- grass/trunk/vector/v.edit/a2b.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.edit/a2b.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -133,8 +133,7 @@
 	/* Collect the points */
 	for (i = 0; i < n_coors; i++) {
 	    if (G_getl2(buff, BUFFSIZE - 1, ascii) == 0) {
-		G_warning(_
-			  ("End of ASCII file reached before end of coordinates"));
+		G_warning(_("End of ASCII file reached before end of coordinates"));
 		return -1;
 	    if (buff[0] == '\0') {
@@ -176,8 +175,7 @@
 	/* Collect the cats */
 	for (i = 0; i < n_cats; i++) {
-		G_warning(_
-			  ("End of ascii file reached before end of categories"));
+		G_warning(_("End of ascii file reached before end of categories"));
 		return -1;
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.edit/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -111,8 +111,7 @@
     else {			/* open selected vector file */
 	mapset = G_find_vector2(params.map->answer, G_mapset());
 	if (mapset == NULL) {
-	    G_fatal_error(_
 			  params.map->answer);
 	else if (action_mode == MODE_ADD) {	/* write */
@@ -123,8 +122,7 @@
 	if (ret < 2)
-	    G_fatal_error(_
-			  ("Unable to open vector map <%s> at topological level %d"),
+	    G_fatal_error(_("Unable to open vector map <%s> at topological level %d"),
 			  params.map->answer, 2);
@@ -147,8 +145,7 @@
 		 ((const char *)params.map->answer, (const char *)G_mapset()),
 		 G_fully_qualified_name((const char *)bmap,
 					(const char *)mapset)) == 0) {
-		G_fatal_error(_
-			      ("Unable to open vector map <%s> as the backround map. "
+		G_fatal_error(_("Unable to open vector map <%s> as the backround map. "
 			       "It is given as vector map to be edited."),
 			      bmap);
@@ -222,8 +219,7 @@
 	    /* reopen the map for updating */
 	    if (action_mode == MODE_ZBULK && !Vect_is_3d(&Map)) {
 		Vect_close(&Map);
-		G_fatal_error(_
-			      ("Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. "
+		G_fatal_error(_("Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. "
 			       "Please convert the vector map "
 			       "to 3D using e.g. %s."), params.map->answer,
 			      params.tool->answer, "v.extrude");
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.generalize/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -321,8 +321,7 @@
 	if (layer < 1)
 	    G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", "where");
 	if (cat_opt->answer)
-	    G_warning(_
-		      ("'where' and 'cats' parameters were supplied, cat will be ignored"));
+	    G_warning(_("'where' and 'cats' parameters were supplied, cat will be ignored"));
 	chcat = 1;
 	varray = Vect_new_varray(Vect_get_num_lines(&In));
 	if (Vect_set_varray_from_db
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.hull/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -329,8 +329,7 @@
 	G_fatal_error(_("Error loading vector points map <%s>"), sitefile);
     if (numSitePoints < 3)
-	G_fatal_error(_
-		      ("Convex hull calculation requires at least three points"));
+	G_fatal_error(_("Convex hull calculation requires at least three points"));
     /* create a 2D or a 3D hull? */
Modified: grass/trunk/vector/v.in.ascii/a2b.c
--- grass/trunk/vector/v.in.ascii/a2b.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.in.ascii/a2b.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -99,8 +99,7 @@
-		G_fatal_error(_
+		G_fatal_error(_("End of ASCII file reached before end of coordinates"));
 		G_debug(3, "a2b: skipping blank line while reading vertices");
@@ -141,8 +140,7 @@
-		G_fatal_error(_
-			      ("End of ASCII file reached before end of categories"));
+		G_fatal_error(_("End of ASCII file reached before end of categories"));
 		G_debug(3,
Modified: grass/trunk/vector/v.in.ascii/in.c
--- grass/trunk/vector/v.in.ascii/in.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.in.ascii/in.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -259,13 +259,11 @@
 	/* check column numbers */
 	if (xcol >= minncols) {
 	    Vect_delete(new->answer);
-	    G_fatal_error(_
-			  ("x column number > minimum last column number\n(incorrect field separator?)"));
+	    G_fatal_error(_("x column number > minimum last column number\n(incorrect field separator?)"));
 	if (ycol >= minncols) {
-	    G_fatal_error(_
-			  ("y column number > minimum last column number\n(incorrect field separator?)"));
+	    G_fatal_error(_("y column number > minimum last column number\n(incorrect field separator?)"));
 	if (zcol >= minncols) {
@@ -315,8 +313,7 @@
 							     &Map));
 	    if (driver == NULL) {
-		G_fatal_error(_
 			      Vect_subst_var(Fi->database, &Map), Fi->driver);
 	    db_begin_transaction(driver);
@@ -335,8 +332,7 @@
 		if (catcol == i && coltype[i] != DB_C_TYPE_INT) {
-		    G_fatal_error(_
-				  ("Category column is not of integer type"));
+		    G_fatal_error(_("Category column is not of integer type"));
 		switch (coltype[i]) {
@@ -417,8 +413,7 @@
 		if ((catcol >= 0 && nc != ncols) ||
 		    (catcol < 0 && (nc - 1) != ncols)) {
-		    G_fatal_error(_
-				  ("Number of columns defined (%d) does not match number "
+		    G_fatal_error(_("Number of columns defined (%d) does not match number "
 				   "of columns (%d) in input"),
 				  catcol < 0 ? nc - 1 : nc, ncols);
@@ -446,14 +441,12 @@
 		    case DB_C_TYPE_INT:
 			if (ctype == DB_C_TYPE_DOUBLE) {
-			    G_warning(_
-				      ("Column number %d <%s> defined as double "
+			    G_warning(_("Column number %d <%s> defined as double "
 				       "has only integer values"), i + 1,
 				      db_get_column_name(column));
 			else if (ctype == DB_C_TYPE_STRING) {
-			    G_warning(_
-				      ("Column number %d <%s> defined as string "
+			    G_warning(_("Column number %d <%s> defined as string "
@@ -461,14 +454,12 @@
 		    case DB_C_TYPE_DOUBLE:
 			if (ctype == DB_C_TYPE_INT) {
-			    G_fatal_error(_
-					  ("Column number %d <%s> defined as integer "
+			    G_fatal_error(_("Column number %d <%s> defined as integer "
 					   "has double values"), i + 1,
-			    G_warning(_
@@ -476,22 +467,19 @@
 		    case DB_C_TYPE_STRING:
-			    G_fatal_error(_
 					   "has string values"), i + 1,
 			else if (ctype == DB_C_TYPE_DOUBLE) {
-			    G_fatal_error(_
+			    G_fatal_error(_("Column number %d <%s> defined as double "
 			if (length < collen[i]) {
-			    G_fatal_error(_
-					  ("Length of column %d <%s> (%d) is less than "
+			    G_fatal_error(_("Length of column %d <%s> (%d) is less than "
 					   "maximum value " "length (%d)"),
 					  i + 1, db_get_column_name(column),
 					  length, collen[i]);
@@ -513,8 +501,7 @@
 	    if (db_create_index2(driver, Fi->table, key) != DB_OK)
-		G_warning(_
-			  ("Unable to create index for table <%s>, key <%s>"),
+		G_warning(_("Unable to create index for table <%s>, key <%s>"),
 			  Fi->table, key);
 	    Vect_map_del_dblink(&Map, 1);
Modified: grass/trunk/vector/v.in.ascii/points.c
--- grass/trunk/vector/v.in.ascii/points.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.in.ascii/points.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -162,8 +162,7 @@
 			else {
 			    fprintf(stderr, "Current row: '%s'\n", buf_raw);
-			    G_fatal_error(_
-					  ("Unparsable longitude value in column <%d>: %s"),
+			    G_fatal_error(_("Unparsable longitude value in column <%d>: %s"),
 					  i, tokens[i]);
@@ -182,8 +181,7 @@
 			else {
-			    G_fatal_error(_
-					  ("Unparsable latitude value in column <%d>: %s"),
+			    G_fatal_error(_("Unparsable latitude value in column <%d>: %s"),
 					  i, tokens[i]);
@@ -260,8 +258,7 @@
     G_free(tmp_token);
     if (region_flag)
-	G_message(_
-		  ("Skipping %d of %d rows falling outside of current region"),
+	G_message(_("Skipping %d of %d rows falling outside of current region"),
 		  skipped, row - 1);
     return 0;
Modified: grass/trunk/vector/v.in.db/main.c
--- grass/trunk/vector/v.in.db/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.in.db/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -127,8 +127,7 @@
     if (db_table_exists(db_get_default_driver_name(),
 			db_get_default_database_name(), outvect->answer) == 1)
-	G_fatal_error(_
-		      ("Output vector map, table <%s> (driver: <%s>, database: <%s>) "
+	G_fatal_error(_("Output vector map, table <%s> (driver: <%s>, database: <%s>) "
 		       "already exists"), outvect->answer,
 		      db_get_default_database_name());
Modified: grass/trunk/vector/v.in.dxf/add_polyline.c
--- grass/trunk/vector/v.in.dxf/add_polyline.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.in.dxf/add_polyline.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -75,8 +75,7 @@
 		|| polyline_flag & 32)
 		if (warn_flag70) {
 		    if (!flag_list)
-			G_warning(_
-				  ("3-d data in dxf file. Polyline_flag: %d"),
+			G_warning(_("3-d data in dxf file. Polyline_flag: %d"),
 				  polyline_flag);
 		    warn_flag70 = 0;
Modified: grass/trunk/vector/v.in.dxf/main.c
--- grass/trunk/vector/v.in.dxf/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.in.dxf/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -121,8 +121,7 @@
 	num_layers = 0;
 	layers = NULL;
 	Map = NULL;
-	G_verbose_message(_
-			  ("Layer number: layer name / GRASS compliant name"));
+	G_verbose_message(_("Layer number: layer name / GRASS compliant name"));
     else {
 	/* make vector map name SQL compliant */
Modified: grass/trunk/vector/v.in.ogr/geom.c
--- grass/trunk/vector/v.in.ogr/geom.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.in.ogr/geom.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -317,8 +317,7 @@
 		Vect_write_line(Map, otype, Points, Cats);
 	    else {		/* 0 points */
-		G_warning(_
-			  ("No centroid written for polygon with 0 vertices"));
+		G_warning(_("No centroid written for polygon with 0 vertices"));
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.in.ogr/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -332,8 +332,7 @@
     if (!outloc_opt->answer) {	/* Check if the map exists */
 	if (G_find_vector2(out_opt->answer, G_mapset())) {
 	    if (overwrite)
-		G_warning(_
-			  ("Vector map <%s> already exists and will be overwritten"),
+		G_warning(_("Vector map <%s> already exists and will be overwritten"),
 			  out_opt->answer);
 	    else
 		G_fatal_error(_("Vector map <%s> already exists"),
@@ -377,8 +376,7 @@
     if (region_flag->answer) {
 	if (spat_opt->answer)
-	    G_fatal_error(_
-			  ("Select either the current region flag or the spatial option, not both"));
+	    G_fatal_error(_("Select either the current region flag or the spatial option, not both"));
 	G_get_window(&cur_wind);
 	xmin = cur_wind.west;
@@ -485,8 +483,7 @@
 	/* Projection only required for checking so convert non-interactively */
 	if (GPJ_osr_to_grass(&cellhd, &proj_info,
 			     &proj_units, Ogr_projection, 0) < 0)
-	    G_warning(_
-		      ("Unable to convert input map projection information to "
+	    G_warning(_("Unable to convert input map projection information to "
 		       "GRASS format for checking"));
 	/* Does the projection of the current location match the dataset? */
@@ -709,8 +706,7 @@
 		    /* hack: treat as string */
 		    sprintf(buf, ", %s varchar ( %d )", Ogr_fieldname,
 			    OFTIntegerListlength);
-		    G_warning(_
-			      ("Writing column <%s> with fixed length %d chars (may be truncated)"),
+		    G_warning(_("Writing column <%s> with fixed length %d chars (may be truncated)"),
 			      Ogr_fieldname, OFTIntegerListlength);
 		else if (Ogr_ftype == OFTReal) {
@@ -733,8 +729,7 @@
 		    fwidth = OGR_Fld_GetWidth(Ogr_field);
 		    /* TODO: read all records first and find the longest string length */
 		    if (fwidth == 0) {
-			G_warning(_
-				  ("Width for column %s set to 255 (was not specified by OGR), "
+			G_warning(_("Width for column %s set to 255 (was not specified by OGR), "
 				   "some strings may be truncated!"),
 				  Ogr_fieldname);
 			fwidth = 255;
@@ -746,8 +741,7 @@
-		    G_warning(_
-			      ("Writing column %s with fixed length %d chars (may be truncated)"),
+		    G_warning(_("Writing column %s with fixed length %d chars (may be truncated)"),
 		else {
@@ -1077,8 +1071,7 @@
 	G_message("%s", separator);
 	if (n_overlaps > 0) {
-	    G_warning(_
-		      ("%d areas represent more (overlapping) features, because polygons overlap "
+	    G_warning(_("%d areas represent more (overlapping) features, because polygons overlap "
 		       "in input layer(s). Such areas are linked to more than 1 row in attribute table. "
 		       "The number of features for those areas is stored as category in layer %d"),
 		      n_overlaps, nlayers + 1);
@@ -1133,8 +1126,7 @@
     if (with_z && !z_flag->answer)
-	G_warning(_
-		  ("Input data contains 3D features. Created vector is 2D only, "
+	G_warning(_("Input data contains 3D features. Created vector is 2D only, "
 		   "use -z flag to import 3D vector"));
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.in.sites/main.c
--- grass/trunk/vector/v.in.sites/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.in.sites/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -95,12 +95,10 @@
 		      dims, strs, dbls);
     if (map_type == FCELL_TYPE || map_type == DCELL_TYPE) {
-	G_message(_
-		  ("Floating point category values, using sequential integer for category"));
+	G_message(_("Floating point category values, using sequential integer for category"));
     else if (map_type != CELL_TYPE) {
-	G_message(_
-		  ("No category values, using sequential integer for category"));
+	G_message(_("No category values, using sequential integer for category"));
     clen = (int *)G_calloc(strs, sizeof(int));
Modified: grass/trunk/vector/v.info/main.c
--- grass/trunk/vector/v.info/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.info/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -185,15 +185,13 @@
 	if (columns->answer) {
 	    if (num_dblinks <= 0) {
-		G_fatal_error(_
 			      in_opt->answer);
 		field = atoi(fieldopt->answer);
-		G_message(_
-			  ("Displaying column types/names for database connection of layer %d:"),
+		G_message(_("Displaying column types/names for database connection of layer %d:"),
 			  field);
 		    G_fatal_error("Database connection not defined");
Modified: grass/trunk/vector/v.kcv/main.c
--- grass/trunk/vector/v.kcv/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.kcv/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -134,8 +134,7 @@
     if (Vect_open_old(&In, in_opt->answer, mapset) < 2) {
-	G_fatal_error(_
 		      in_opt->answer, 2);
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.kernel/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -69,8 +69,7 @@
     /* resL = (1./(pow(n,2.)*pow(smooth,dimension))) * (resL + n*( gaussianFunction(0.,2.,dimension) - 2. * gaussianKernel(0.,term)) ) + (2./(n*pow(smooth,dimension)))*gaussianKernel(0.,term);   */
     G_debug(3, "smooth = %e resL = %e", smooth, resL);
-    G_message(_
-	      ("\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"),
+    G_message(_("\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"),
 	      resL, smooth);
     return (resL);
@@ -273,8 +272,7 @@
     /* valutazione distanza ottimale */
     if (flag_o->answer) {
 	/* Note: sigmaOptimal calculates using ALL points (also those outside the region) */
-	G_message(_
-		  ("Automatic choose of smoothing parameter (standard deviation), maximum possible "
+	G_message(_("Automatic choose of smoothing parameter (standard deviation), maximum possible "
 		   "value of standard deviation is was set to %f"), sigma);
 	/* maximum distance 4*sigma (3.9*sigma ~ 1.0000), keep it small, otherwise it takes
Modified: grass/trunk/vector/v.label/main.c
--- grass/trunk/vector/v.label/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.label/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -249,8 +249,7 @@
     if (Along_flag->answer && !fontsize &&
 	(size / space >= 2 || size / space <= 0.5))
-	G_warning(_
-		  ("size and space options vary significantly which may lead to crummy output"));
+	G_warning(_("size and space options vary significantly which may lead to crummy output"));
     /* parse reference answers */
Modified: grass/trunk/vector/v.label.sa/font.c
--- grass/trunk/vector/v.label.sa/font.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.label.sa/font.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -51,8 +51,7 @@
     fp = NULL;
     if ((capfile = getenv("GRASS_FONT_CAP"))) {
 	if ((fp = fopen(capfile, "r")) == NULL)
-	    G_warning(_
-		      ("%s: Unable to read font definition file; use the default"),
+	    G_warning(_("%s: Unable to read font definition file; use the default"),
 		      capfile);
     if (fp == NULL) {
Modified: grass/trunk/vector/v.lrs/v.lrs.create/main.c
--- grass/trunk/vector/v.lrs/v.lrs.create/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.lrs/v.lrs.create/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -474,8 +474,7 @@
 	    if (floor(mp_tmp) != mp_tmp) {
 		mp_tmp2 = floor(mp_tmp);
 		off_tmp2 = off_tmp + multip * (mp_tmp - mp_tmp2);
-		G_warning(_
-			  ("Milepost (start) %f+%f used as %f+%f (change MP to integer)"),
+		G_warning(_("Milepost (start) %f+%f used as %f+%f (change MP to integer)"),
 			  mp_tmp, off_tmp, mp_tmp2, off_tmp2);
 	    else {
@@ -497,8 +496,7 @@
-		G_warning(_
-			  ("Milepost (end) %f+%f used as %f+%f (change MP to integer)"),
+		G_warning(_("Milepost (end) %f+%f used as %f+%f (change MP to integer)"),
 	    else {
@@ -571,8 +569,7 @@
 		else {
 		    mposts[mpost].line_idx = PORT_INT_MAX;
 		    mposts[mpost].err = ERR_THRESHOLD;
-		    G_warning(_
-			      ("Point [%d] cat [%d] is out of threshold (distance = %f)"),
+		    G_warning(_("Point [%d] cat [%d] is out of threshold (distance = %f)"),
 			      point, cat, distance_to);
@@ -721,8 +718,7 @@
 						 mposts[k + 1].end_mp,
 						 mposts[k + 1].end_off);
 			    if (ret > -1) {	/* start >= end */
-				G_warning(_
-					  ("Start of 1. MP >= end of 2. MP for points' "
+				G_warning(_("Start of 1. MP >= end of 2. MP for points' "
 					   "cats %[d], [%d]"), mposts[k].cat,
 					  mposts[k + 1].cat);
 				mposts[k].err = ERR_END_GT_START;
@@ -739,8 +735,7 @@
 						 mposts[k + 1].start_mp,
 						 mposts[k + 1].start_off);
 			    if (ret > -1) {	/* start > end */
-				G_warning(_
-					  ("Start of 1. MP >= start of 2. MP for points' "
+				G_warning(_("Start of 1. MP >= start of 2. MP for points' "
 					   "cats [%d], [%d]"), mposts[k].cat,
 					  mposts[k + 1].cat);
@@ -750,8 +745,7 @@
 			/* 4) For 2 MPs must be distance along line different (duplicate points) */
 			if (mposts[k].dist_along == mposts[k + 1].dist_along) {
-			    G_warning(_
-				      ("Distance along line identical for points' "
+			    G_warning(_("Distance along line identical for points' "
 				      mposts[k + 1].cat);
 			    mposts[k].err = ERR_IDENT;
@@ -765,19 +759,16 @@
 	    /* Write errors if any ( and continue ) */
 	    if (!order) {	/* something is wrong */
 		if (rlines[j].nmposts < 2) {	/* Impossible to get reference/direction */
-		    G_warning(_
-			      ("Not enough points (%d) attached to the line (cat %d), "
+		    G_warning(_("Not enough points (%d) attached to the line (cat %d), "
 			       "line skip."), rlines[j].nmposts,
 			      rlines[j].cat);
 		else if (rlines[j].direction == DIR_UNKNOWN) {	/* Unknown direction */
-		    G_warning(_
-			      ("Unable to guess direction for the line (cat %d), "
+		    G_warning(_("Unable to guess direction for the line (cat %d), "
 			       "line skip."), rlines[j].cat);
 		else {
-		    G_warning(_
-			      ("Incorrect order of points along line cat [%d]"),
+		    G_warning(_("Incorrect order of points along line cat [%d]"),
 			      rlines[j].cat);
 		    rlines[j].err = ERR_LINE_ORDER;
Modified: grass/trunk/vector/v.lrs/v.lrs.segment/main.c
--- grass/trunk/vector/v.lrs/v.lrs.segment/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.lrs/v.lrs.segment/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -279,8 +279,7 @@
 	    /* Check if both points are at the same line */
 	    if (lcat1 != lcat2) {
-		G_warning(_
-			  ("Segment over 2 (or more) segments, not yet supported"));
+		G_warning(_("Segment over 2 (or more) segments, not yet supported"));
 		break;
 	    G_debug(2, "segment: lcat = %d : %f -  %f", lcat1, map_offset1,
Modified: grass/trunk/vector/v.mapcalc/number.c
--- grass/trunk/vector/v.mapcalc/number.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.mapcalc/number.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -210,8 +210,7 @@
     func = getsym(buf);
     if (!func) {
 	if (opd1->itype == st_num)
-	    G_warning(_
-		      ("No function defined to perform ``number %c number''"),
+	    G_warning(_("No function defined to perform ``number %c number''"),
 		      op);
 	else if (opd1->itype == st_pnt)
 	    G_warning(_("No function defined to perform ``point %c point''"),
Modified: grass/trunk/vector/v.net/main.c
--- grass/trunk/vector/v.net/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.net/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -170,8 +170,7 @@
 	Vect_set_fatal_error(GV_FATAL_PRINT);
 	if (1 > Vect_open_new(&Out, output->answer, is3d)) {
 	    Vect_close(&In);
-	    G_fatal_error(_
-			  ("Unable to open vector map <%s> at topology level %d"),
+	    G_fatal_error(_("Unable to open vector map <%s> at topology level %d"),
 			  output->answer, 2);
Modified: grass/trunk/vector/v.net/report.c
--- grass/trunk/vector/v.net/report.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.net/report.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -64,12 +64,10 @@
 		    nnodes++;
 		if (nnodes == 0)
-		    G_warning(_
-			      ("Point not found: %.3lf %.3lf %.3lf line category: %d"),
+		    G_warning(_("Point not found: %.3lf %.3lf %.3lf line category: %d"),
 			      x, y, z, cat_line);
 		else if (nnodes > 1)
-		    G_warning(_
-			      ("%d points found: %.3lf %.3lf %.3lf line category: %d"),
+		    G_warning(_("%d points found: %.3lf %.3lf %.3lf line category: %d"),
 			      nnodes, x, y, z, cat_line);
 	    fprintf(stdout, "%d %d %d\n", cat_line, cat_node[0], cat_node[1]);
Modified: grass/trunk/vector/v.net.alloc/main.c
--- grass/trunk/vector/v.net.alloc/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.net.alloc/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -337,8 +337,7 @@
 		    /* First segment */
 		    ret = Vect_line_segment(Points, 0, l1, SPoints);
 		    if (ret == 0) {
-			G_warning(_
-				  ("Cannot get line segment, segment out of line"));
+			G_warning(_("Cannot get line segment, segment out of line"));
 		    else {
 			cat = Centers[centre1].cat;
@@ -349,8 +348,7 @@
 		    /* Second segment */
 		    ret = Vect_line_segment(Points, l1, l, SPoints);
 		    if (ret == 0) {
-			G_warning(_
 		    else {
 			Vect_reset_cats(Cats);
Modified: grass/trunk/vector/v.net.iso/main.c
--- grass/trunk/vector/v.net.iso/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.net.iso/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -175,8 +175,7 @@
     /* Should not happen: */
     if (niso < 2)
-	G_warning(_
-		  ("Not enough costs, everything reachable falls to first band"));
+	G_warning(_("Not enough costs, everything reachable falls to first band"));
     if (geo_f->answer)
 	geo = 1;
@@ -210,8 +209,7 @@
 	    if (Vect_cat_in_cat_list(cat, catlist)) {
 		Vect_net_get_node_cost(&Map, node, &n1cost);
 		if (n1cost == -1) {	/* closed */
-		    G_warning(_
-			      ("Centre at closed node (costs = -1) ignored"));
+		    G_warning(_("Centre at closed node (costs = -1) ignored"));
 		else {
 		    if (acentres == ncentres) {
@@ -233,8 +231,7 @@
     G_message(_("Number of centres: [%d] (nlayer: [%d])"), ncentres, nfield);
     if (ncentres == 0)
-	G_warning(_
-		  ("Not enough centres for selected nlayer. Nothing will be allocated."));
+	G_warning(_("Not enough centres for selected nlayer. Nothing will be allocated."));
     /* alloc and reset space for all nodes */
     Nodes = (NODE *) G_calloc((nnodes + 1), sizeof(NODE));
@@ -513,8 +510,7 @@
 		    Vect_line_segment(Points, pnts1[i - 1].distance,
 				      pnts1[i].distance, SPoints);
 		if (ret == 0) {
-		    G_warning(_
 		else {
Modified: grass/trunk/vector/v.out.ascii/out.c
--- grass/trunk/vector/v.out.ascii/out.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.out.ascii/out.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -122,8 +122,7 @@
     /*The precision of the output */
     if (dp_opt->answer) {
 	if (sscanf(dp_opt->answer, "%d", &dp) != 1)
-	    G_fatal_error(_
-			  ("Failed to interprete 'dp' parameter as an integer"));
+	    G_fatal_error(_("Failed to interprete 'dp' parameter as an integer"));
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.out.ogr/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -309,8 +309,7 @@
 	doatt = 1;		/* do attributes */
 	Fi = Vect_get_field(&In, field);
 	if (Fi == NULL) {
-	    G_warning(_
-		      ("No attribute table found -> using only category numbers as attributes"));
+	    G_warning(_("No attribute table found -> using only category numbers as attributes"));
 	    Ogr_field = OGR_Fld_Create("cat", OFTInteger);
 	    OGR_L_CreateField(Ogr_layer, Ogr_field, 0);
@@ -325,8 +324,7 @@
 	    db_set_handle(&handle, Fi->database, NULL);
 	    if (db_open_database(Driver, &handle) != DB_OK)
-		G_fatal_error(_
 	    db_set_string(&dbstring, Fi->table);
@@ -396,15 +394,13 @@
     if (Vect_get_num_primitives(&In, GV_BOUNDARY) > 0 &&
 	!(otype & GV_BOUNDARY) && !(otype & GV_AREA))
-	G_warning(_
-		  ("%d boundary(ies) found, but not requested to be exported. "
+	G_warning(_("%d boundary(ies) found, but not requested to be exported. "
 		   "Verify 'type' parameter."), Vect_get_num_primitives(&In,
 									GV_BOUNDARY));
     if (Vect_get_num_primitives(&In, GV_CENTROID) > 0 &&
 	!(otype & GV_CENTROID) && !(otype & GV_AREA))
-	G_warning(_
-		  ("%d centroid(s) found, but not requested to be exported. "
+	G_warning(_("%d centroid(s) found, but not requested to be exported. "
 									GV_CENTROID));
Modified: grass/trunk/vector/v.out.vtk/main.c
--- grass/trunk/vector/v.out.vtk/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.out.vtk/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -171,8 +171,7 @@
-	    G_fatal_error(_
 	if (dp > 8 || dp < 0)
 	    G_fatal_error(_("dp has to be from 0 to 8"));
@@ -183,8 +182,7 @@
     /*The Layer */
     if (layer_opt->answer) {
 	if (sscanf(layer_opt->answer, "%d", &layer) != 1)
-	    G_fatal_error(_
-			  ("Failed to interprete 'layer' parameter as an integer"));
+	    G_fatal_error(_("Failed to interprete 'layer' parameter as an integer"));
     else {
 	layer = 1;
Modified: grass/trunk/vector/v.out.vtk/writeVTK.c
--- grass/trunk/vector/v.out.vtk/writeVTK.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.out.vtk/writeVTK.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -184,8 +184,7 @@
     /*break if nothing to generate */
     if (info->maxnumpoints == 0)
-	G_fatal_error(_
-		      ("No coordinates to generate the output! Maybe an empty vector type chosen?"));
+	G_fatal_error(_("No coordinates to generate the output! Maybe an empty vector type chosen?"));
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.overlay/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -279,8 +279,7 @@
 	    in_driver =
 		db_start_driver_open_database(inFi->driver, inFi->database);
 	    if (in_driver == NULL) {
-		G_fatal_error(_
 			      inFi->database, inFi->driver);
Modified: grass/trunk/vector/v.patch/main.c
--- grass/trunk/vector/v.patch/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.patch/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -130,8 +130,7 @@
 		    db_start_driver_open_database(fi_out->driver,
 						  fi_out->database);
 		if (!driver_out) {
-		    G_fatal_error(_
 				  fi_out->database, fi_out->driver);
@@ -161,8 +160,7 @@
 		    db_start_driver_open_database(fi_in->driver,
 						  fi_in->database);
 		if (!driver_in) {
-		    G_fatal_error(_
 				  fi_in->database, fi_in->driver);
@@ -274,8 +272,7 @@
 					      fi_out->database);
 	    if (!driver_out) {
-		G_fatal_error(_
 	    db_begin_transaction(driver_out);
@@ -333,8 +330,7 @@
 						  fi_in->database);
 		if (!driver_in) {
-		    G_fatal_error(_
Modified: grass/trunk/vector/v.perturb/main.c
--- grass/trunk/vector/v.perturb/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.perturb/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -137,16 +137,14 @@
 	    G_fatal_error(_("Error scanning arguments"));
 	else if (p1 <= 0)
-	    G_fatal_error(_
-			  ("Maximum of uniform distribution must be >= zero"));
+	    G_fatal_error(_("Maximum of uniform distribution must be >= zero"));
     else {
 	if ((i = sscanf(parm.pars->answer, "%lf,%lf", &p1, &p2)) != 2) {
 	if (p2 <= 0)
-	    G_fatal_error(_
-			  ("Standard deviation of normal distribution must be >= zero"));
+	    G_fatal_error(_("Standard deviation of normal distribution must be >= zero"));
     G_get_window(&window);
Modified: grass/trunk/vector/v.proj/main.c
--- grass/trunk/vector/v.proj/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.proj/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -167,8 +167,7 @@
 	/* Make sure map is available */
 	mapset = G_find_vector2(map_name, iset_name);
 	if (mapset == NULL)
-	    G_fatal_error(_
-			  ("Vector map <%s> in location <%s> mapset <%s> not found"),
+	    G_fatal_error(_("Vector map <%s> in location <%s> mapset <%s> not found"),
 			  map_name, iloc_name, iset_name);
 	 /*** Get projection info for input mapset ***/
@@ -192,8 +191,7 @@
     {				/* allow 0 (i.e. denied permission) */
 	/* need to be able to read from others */
 	if (stat == 0)
-	    G_fatal_error(_
-			  ("Mapset <%s> in input location <%s> - permission denied"),
+	    G_fatal_error(_("Mapset <%s> in input location <%s> - permission denied"),
 			  iset_name, iloc_name);
 	else
 	    G_fatal_error(_("Mapset <%s> in input location <%s> not found"),
Modified: grass/trunk/vector/v.random/main.c
--- grass/trunk/vector/v.random/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.random/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -134,8 +134,7 @@
 	exit(EXIT_FAILURE);
     if (flag.z->answer && parm.zcol->answer) {
-	G_fatal_error(_
-		      ("v.random can't create 3D vector and attribute table at same time"));
+	G_fatal_error(_("v.random can't create 3D vector and attribute table at same time"));
     output = parm.output->answer;
@@ -218,8 +217,7 @@
 	    db_close_database(driver);
 	    db_shutdown_driver(driver);
 	    Vect_delete(parm.output->answer);
-	    G_fatal_error(_
-			  ("You have created unsupported column type. This module supports only INTEGER"
+	    G_fatal_error(_("You have created unsupported column type. This module supports only INTEGER"
 			   " and DOUBLE PRECISION column types."));
Modified: grass/trunk/vector/v.reclass/main.c
--- grass/trunk/vector/v.reclass/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.reclass/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -358,8 +358,7 @@
 		if (over > 0)
-		    G_warning(_
-			      ("%d previously set categories overwritten by new category %d"),
+		    G_warning(_("%d previously set categories overwritten by new category %d"),
 			      over, cat);
 		for (i = 0; i < ncats; i++) {
Modified: grass/trunk/vector/v.sample/main.c
--- grass/trunk/vector/v.sample/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.sample/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -134,8 +134,7 @@
 	if (flag.B->answer)
 	    method = BILINEAR;
 	if (flag.B->answer && flag.C->answer)
-	    G_fatal_error(_
-			  ("Flags -b & -c are mutually exclusive. Choose only one."));
+	    G_fatal_error(_("Flags -b & -c are mutually exclusive. Choose only one."));
     else {
 	method = NEAREST;
@@ -174,8 +173,7 @@
-	G_fatal_error(_
-		      ("Column type <%s> not supported (must be integer or double precision)"),
+	G_fatal_error(_("Column type <%s> not supported (must be integer or double precision)"),
 		      db_sqltype_name(ctype));
     if (nrecords < 0)
Modified: grass/trunk/vector/v.segment/main.c
--- grass/trunk/vector/v.segment/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.segment/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -154,8 +154,7 @@
 				   NULL);
 	    if (ret == 0) {
 		len = Vect_line_length(LPoints);
-		G_warning(_
-			  ("Unable to get point on line: cat = %d offset = %f "
+		G_warning(_("Unable to get point on line: cat = %d offset = %f "
 			   "(line length = %.15g)\n%s"), lcat, offset1, len,
 			  buf);
 		break;
Modified: grass/trunk/vector/v.surf.idw/main.c
--- grass/trunk/vector/v.surf.idw/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.surf.idw/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -249,8 +249,7 @@
 	G_fatal_error(_("Unable to create raster map <%s>"),
-			("Interpolating raster map <%s> (%d rows, %d cols)... "),
+    G_important_message(_("Interpolating raster map <%s> (%d rows, %d cols)... "),
 			parm.output->answer, window.rows, window.cols);
     north = window.north + window.ns_res / 2.0;
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.surf.rst/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -417,12 +417,10 @@
     cv = flag.cv->answer;
     if ((cv && cvdev == NULL) || (!(cv) && cvdev != NULL))
-	G_fatal_error(_
-		      ("Both cross-validation options (-c flag and cvdev vector output) must be specified"));
+	G_fatal_error(_("Both cross-validation options (-c flag and cvdev vector output) must be specified"));
     if ((elev != NULL || cond1 || cond2 || devi != NULL) && cv)
-	G_fatal_error(_
-		      ("The cross-validation cannot be computed simultaneously with output raster or devi file"));
+	G_fatal_error(_("The cross-validation cannot be computed simultaneously with output raster or devi file"));
     ertre = 0.1;
     sscanf(parm.dmax->answer, "%lf", &dmax);
@@ -440,8 +438,7 @@
     if (parm.scalex->answer) {
 	sscanf(parm.scalex->answer, "%lf", &scalex);
 	if (!parm.theta->answer)
-	    G_fatal_error(_
-			  ("Using anisotropy - both theta and scalex have to be specified"));
+	    G_fatal_error(_("Using anisotropy - both theta and scalex have to be specified"));
     if (parm.rsm->answer) {
@@ -449,8 +446,7 @@
 	if (rsm < 0.0)
 	    G_fatal_error("Smoothing must be a positive value");
 	if (scol != NULL)
-	    G_warning(_
-		      ("Both smatt and smooth options specified - using constant"));
+	    G_warning(_("Both smatt and smooth options specified - using constant"));
     else {
 	sscanf(SMOOTH, "%lf", &rsm);
@@ -460,8 +456,7 @@
     if (npmin > MAXPOINTS - 50) {
-	G_warning(_
-		  ("The computation will last too long - lower npmin is suggested"));
+	G_warning(_("The computation will last too long - lower npmin is suggested"));
 	KMAX2 = 2 * npmin;	/* was: KMAX2 = npmin + 50; */
     else
@@ -608,8 +603,7 @@
 			  Tmp_file_z);
 	for (i = 0; i < n_rows; i++) {
 	    if (!(fwrite(zero_array_cell, sizeof(FCELL), n_cols, Tmp_fd_z)))
-		G_fatal_error(_
-			      ("Not enough disk space -- cannot write files"));
+		G_fatal_error(_("Not enough disk space -- cannot write files"));
     if (Tmp_file_dx != NULL) {
@@ -618,8 +612,7 @@
 			  Tmp_file_dx);
 	    if (!(fwrite(zero_array_cell, sizeof(FCELL), n_cols, Tmp_fd_dx)))
-		G_fatal_error(_
     if (Tmp_file_dy != NULL) {
@@ -628,8 +621,7 @@
 			  Tmp_file_dy);
 	    if (!(fwrite(zero_array_cell, sizeof(FCELL), n_cols, Tmp_fd_dy)))
-		G_fatal_error(_
@@ -639,8 +631,7 @@
 			  Tmp_file_xx);
 	    if (!(fwrite(zero_array_cell, sizeof(FCELL), n_cols, Tmp_fd_xx)))
-		G_fatal_error(_
     if (Tmp_file_yy != NULL) {
@@ -649,8 +640,7 @@
 			  Tmp_file_yy);
 	    if (!(fwrite(zero_array_cell, sizeof(FCELL), n_cols, Tmp_fd_yy)))
-		G_fatal_error(_
     if (Tmp_file_xy != NULL) {
@@ -659,8 +649,7 @@
 			  Tmp_file_xy);
 	    if (!(fwrite(zero_array_cell, sizeof(FCELL), n_cols, Tmp_fd_xy)))
-		G_fatal_error(_
Modified: grass/trunk/vector/v.to.db/main.c
--- grass/trunk/vector/v.to.db/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.to.db/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -44,8 +44,7 @@
     Fi = Vect_get_field(&Map, options.field);
     if (!options.print && Fi == NULL) {
-	G_fatal_error(_
-		      ("Database connection not defined for layer %d. Use v.db.connect first."),
+	G_fatal_error(_("Database connection not defined for layer %d. Use v.db.connect first."),
 		      options.field);
Modified: grass/trunk/vector/v.to.db/parse.c
--- grass/trunk/vector/v.to.db/parse.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.to.db/parse.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -155,14 +155,12 @@
     if (options.option == O_QUERY && !parms.qcol->answers)
-	G_fatal_error(_
-		      ("Parameter 'qcolumn' must be specified for 'option=query'"));
+	G_fatal_error(_("Parameter 'qcolumn' must be specified for 'option=query'"));
     options.qcol = parms.qcol->answer;
     if (options.option == O_SIDES && !(options.type | GV_BOUNDARY))
-	G_fatal_error(_
-		      ("The 'sides' option makes sense only for boundaries"));
+	G_fatal_error(_("The 'sides' option makes sense only for boundaries"));
     if (options.option == O_SINUOUS && !(options.type | GV_LINES))
 	G_fatal_error(_("The 'sinuous' option makes sense only for lines"));
Modified: grass/trunk/vector/v.to.db/query.c
--- grass/trunk/vector/v.to.db/query.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.to.db/query.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -79,8 +79,7 @@
     db_init_string(&value_string);
     if ((Fi = Vect_get_field(Map, options.qfield)) == NULL)
-	G_fatal_error(_
 		      options.qfield);
     /* Open driver */
@@ -105,8 +104,7 @@
 	/* Skip if cat is zero and large number of query categories (many features without category).
 	 * It would cause problems on server side and take long time. Postgres limit is 10000 */
 	if (Values[i].cat == 0 && Values[i].nqcats > 1000) {
-	    G_warning(_
-		      ("Query for category '0' (no category) was not executed because of too many "
+	    G_warning(_("Query for category '0' (no category) was not executed because of too many "
 		       "(%d) query categories. All later reported values for cat 0 are not valid."),
 		      Values[i].nqcats);
 	    continue;
@@ -143,8 +141,7 @@
 	    if (nrows != 1) {
 		if (nrows > 1) {
-		    G_warning(_
-			      ("Multiple query results, output value set to NULL (category [%d])"),
+		    G_warning(_("Multiple query results, output value set to NULL (category [%d])"),
 			      Values[i].cat);
 		Values[i].null = 1;
Modified: grass/trunk/vector/v.to.db/report.c
--- grass/trunk/vector/v.to.db/report.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.to.db/report.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -175,14 +175,12 @@
     G_message(_("%d records selected from table"), vstat.select);
     G_message(_("%d categories read from map exist in selection from table"),
 	      vstat.exist);
-    G_message(_
-	      ("%d categories read from map don't exist in selection from table"),
+    G_message(_("%d categories read from map don't exist in selection from table"),
 	      vstat.notexist);
     G_message(_("%d records updated/inserted"), vstat.update);
     G_message(_("%d update/insert errors"), vstat.error);
     if (vstat.dupl > 0)
-	G_message(_
-		  ("%d categories with more points (coordinates not loaded)"),
+	G_message(_("%d categories with more points (coordinates not loaded)"),
 		  vstat.dupl);
     return 0;
Modified: grass/trunk/vector/v.to.db/update.c
--- grass/trunk/vector/v.to.db/update.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.to.db/update.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -23,8 +23,7 @@
     db_init_string(&stmt);
     if ((Fi = Vect_get_field(Map, options.field)) == NULL)
-	G_fatal_error(_
 		      options.field);
     /* Open driver */
@@ -96,8 +95,7 @@
 	case O_START:
 	case O_END:
 	    if (Values[i].count1 > 1) {
-		G_warning(_
-			  ("More elements of category [%d], nothing loaded to DB"),
+		G_warning(_("More elements of category [%d], nothing loaded to DB"),
 			  Values[i].cat);
 		vstat.dupl++;
 		continue;
Modified: grass/trunk/vector/v.to.rast/do_lines.c
--- grass/trunk/vector/v.to.rast/do_lines.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.to.rast/do_lines.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -119,8 +119,7 @@
     if (no_contour > 0)
-	G_warning(_
-		  ("%d lines with varying height were not written to raster"),
+	G_warning(_("%d lines with varying height were not written to raster"),
 		  no_contour);
     Vect_destroy_cats_struct(Cats);
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.to.rast/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -107,26 +107,22 @@
     case 'a':
 	use = USE_ATTR;
 	if (!col->answer)
-	    G_fatal_error(_
-			  ("Column parameter missing (or use value parameter)"));
+	    G_fatal_error(_("Column parameter missing (or use value parameter)"));
 	break;
     case 'c':
 	use = USE_CAT;
 	if (col->answer)
-	    G_fatal_error(_
-			  ("Column parameter cannot be combined with use of category values option"));
+	    G_fatal_error(_("Column parameter cannot be combined with use of category values option"));
 	break;
     case 'v':
 	use = USE_VAL;
 	if (col->answer || label_opt->answer || rgbcol_opt->answer)
-	    G_fatal_error(_
-			  ("Column parameter cannot be combined with use of value option"));
+	    G_fatal_error(_("Column parameter cannot be combined with use of value option"));
 	break;
     case 'z':
 	use = USE_Z;
-	    G_fatal_error(_
-			  ("Column parameter cannot be combined with use of z coordinate"));
+	    G_fatal_error(_("Column parameter cannot be combined with use of z coordinate"));
 	break;
     case 'd':
 	use = USE_D;
Modified: grass/trunk/vector/v.to.rast/support.c
--- grass/trunk/vector/v.to.rast/support.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.to.rast/support.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -274,15 +274,13 @@
 	    db_CatValArray_init(&cvarr);
 	    if (!(Fi = Vect_get_field(&Map, field)))
-		G_fatal_error(_
 			      field);
 	    if (!
 		(Driver =
 		 db_start_driver_open_database(Fi->driver, Fi->database)))
-		G_fatal_error(_
 	    /* get number of records in label_column */
@@ -304,8 +302,7 @@
 	    /* get column type */
 	    if (!label_column) {
-		G_warning(_
-			  ("Label column was not specified, no labels will be written"));
+		G_warning(_("Label column was not specified, no labels will be written"));
 		break;
 	    else {
Modified: grass/trunk/vector/v.to.rast/vect2rast.c
--- grass/trunk/vector/v.to.rast/vect2rast.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.to.rast/vect2rast.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -66,8 +66,7 @@
-	    G_fatal_error(_
-			  ("Column type (%s) not supported (did you mean 'labelcolumn'?)"),
+	    G_fatal_error(_("Column type (%s) not supported (did you mean 'labelcolumn'?)"),
 	if (nrec < 0)
@@ -162,8 +161,7 @@
 	    if (do_areas
 		(&Map, Points, &cvarr, ctype, field, use, value,
 		 value_type) < 0) {
-		G_warning(_
-			  ("Problem processing areas from vector map <%s>, continuing..."),
+		G_warning(_("Problem processing areas from vector map <%s>, continuing..."),
 			  vector_map);
 		stat = -1;
 		break;
@@ -174,8 +172,7 @@
 	    if ((nlines =
 		 do_lines(&Map, Points, &cvarr, ctype, field, use, value,
 			  value_type, ftype, &nplines_all)) < 0) {
-		G_warning(_
-			  ("Problem processing lines from vector map <%s>, continuing..."),
+		G_warning(_("Problem processing lines from vector map <%s>, continuing..."),
 			  vector_map);
 		stat = -1;
 		break;
@@ -209,8 +206,7 @@
     /* colors */
     if (rgbcolumn) {
 	if (use != USE_ATTR) {
-	    G_warning(_
-		      ("Color can be updated from database only if use=attr"));
+	    G_warning(_("Color can be updated from database only if use=attr"));
 	    update_colors(raster_map);
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.transform/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -198,27 +198,23 @@
     /* please remove in GRASS7 */
     if (shift_flag->answer)
-	G_warning(_
-		  ("The '%c' flag is deprecated and will be removed in future. "
+	G_warning(_("The '%c' flag is deprecated and will be removed in future. "
 		   "Transformation parameters are used automatically when no pointsfile is given."),
 		  shift_flag->key);
     if (quiet_flag->answer) {
-	G_warning(_
 		   "Please use '--quiet' instead."), quiet_flag->key);
 	G_putenv("GRASS_VERBOSE", "0");
     if (!table->answer && columns->answer) {
-	G_fatal_error(_
-		      ("Table name is not defined. Please use '%s' parameter."),
+	G_fatal_error(_("Table name is not defined. Please use '%s' parameter."),
 		      table->key);
     if (table->answer && strcmp(vnew->answer, table->answer) == 0) {
-	G_fatal_error(_
-		      ("Name of table and name for output vector map must be different. "
+	G_fatal_error(_("Name of table and name for output vector map must be different. "
 		       "Otherwise the table is overwritten."));
Modified: grass/trunk/vector/v.transform/trans_digit.c
--- grass/trunk/vector/v.transform/trans_digit.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.transform/trans_digit.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -101,8 +101,7 @@
 			|| db_test_value_isnull(&val)) {
 			trans_params[j] = trans_params_def[j];
-			G_warning(_
-				  ("Unable to select value for category %d from table <%s>, column <%s>. "
+			G_warning(_("Unable to select value for category %d from table <%s>, column <%s>. "
 				   "For category %d using default transformation parameter %.3f."),
 				  cat, table, columns[j], cat,
 				  trans_params[j]);
@@ -113,8 +112,7 @@
 	    else {
-		G_warning(_
-			  ("No category number defined. Using default transformation parameters."));
+		G_warning(_("No category number defined. Using default transformation parameters."));
 		for (j = 0; j <= IDX_ZROT; j++) {
Modified: grass/trunk/vector/v.univar/main.c
--- grass/trunk/vector/v.univar/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.univar/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -125,14 +125,12 @@
 	compatible = 0;
     if (!compatible) {
-	G_warning(_
-		  ("Incompatible vector type(s) specified, only number of features, minimum, maximum and range "
+	G_warning(_("Incompatible vector type(s) specified, only number of features, minimum, maximum and range "
 		   "can be calculated"));
     if (extended->answer && !(otype & GV_POINTS)) {
-	G_warning(_
-		  ("Extended statistics is currently supported only for points/centroids"));
+	G_warning(_("Extended statistics is currently supported only for points/centroids"));
     /* Read attributes */
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.vol.rst/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -463,11 +463,9 @@
 	rsm = -1;		/* used in InterpLib to indicate variable smoothing */
     if (cv != (cvdev != NULL))
-	G_fatal_error(_
-		      ("Both crossvalidation options (-c, cvdev) must be specified"));
+	G_fatal_error(_("Both crossvalidation options (-c, cvdev) must be specified"));
     if (cv && devi != NULL)
-	G_fatal_error(_
-		      ("Both crossvalidation and deviations file specified"));
+	G_fatal_error(_("Both crossvalidation and deviations file specified"));
     if (cellinp == NULL && outz == NULL && cellout == NULL && gradient == NULL
 	&& aspect1 == NULL && aspect2 == NULL && ncurv == NULL &&
 	gcurv == NULL && mcurv == NULL) {
Modified: grass/trunk/vector/v.vol.rst/user1.c
--- grass/trunk/vector/v.vol.rst/user1.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.vol.rst/user1.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -104,8 +104,7 @@
     G_debug(3, "nrec = %d", nrec);
-	G_fatal_error(_
-		      ("Column type of wcolumn is not supported (must be integer or double)"));
+	G_fatal_error(_("Column type of wcolumn is not supported (must be integer or double)"));
     if (nrec < 0)
 	G_fatal_error("Unable to select data from table");
@@ -124,8 +123,7 @@
 	    G_fatal_error
 		("Column type of smooth column (datetime) is not supported");
 	if (sctype != DB_C_TYPE_INT && sctype != DB_C_TYPE_DOUBLE)
-	    G_fatal_error(_
-			  ("Column type of smooth column is not supported (must be integer or double)"));
+	    G_fatal_error(_("Column type of smooth column is not supported (must be integer or double)"));
     Points = Vect_new_line_struct();
Modified: grass/trunk/vector/v.what.rast/main.c
--- grass/trunk/vector/v.what.rast/main.c	2008-08-06 22:02:30 UTC (rev 32586)
+++ grass/trunk/vector/v.what.rast/main.c	2008-08-06 22:06:12 UTC (rev 32587)
@@ -163,8 +163,7 @@
 	G_warning(_("Raster type is integer and column type is float"));
     if (out_type != CELL_TYPE && col_type == DB_C_TYPE_INT)
-	G_warning(_
-		  ("Raster type is float and column type is integer, some data lost!!"));
+	G_warning(_("Raster type is float and column type is integer, some data lost!!"));
     /* Read vector points to cache */
     Cache_size = Vect_get_num_primitives(&Map, GV_POINT);
@@ -302,8 +301,7 @@
     for (point = 0; point < point_cnt; point++) {
 	if (cache[point].count > 1) {
-	    G_warning(_
-		      ("More points (%d) of category %d, value set to 'NULL'"),
+	    G_warning(_("More points (%d) of category %d, value set to 'NULL'"),
 		      cache[point].count, cache[point].cat);
 	    dupl_cnt++;
