[GRASS-SVN] r32589 - in grass/trunk/imagery: i.cca i.class
i.cluster i.fft i.gensig i.group i.ifft i.maxlik
i.ortho.photo/photo.rectify i.pca i.rectify i.smap/bouman
i.smap/shapiro i.zc
svn_grass at osgeo.org
Wed Aug 6 18:07:55 EDT 2008
Author: neteler
Date: 2008-08-06 18:07:54 -0400 (Wed, 06 Aug 2008)
New Revision: 32589
grass/trunk/imagery/i.cca/main.c
grass/trunk/imagery/i.class/add_point.c
grass/trunk/imagery/i.class/complete_reg.c
grass/trunk/imagery/i.class/readbands.c
grass/trunk/imagery/i.class/signature.c
grass/trunk/imagery/i.cluster/checkpt.c
grass/trunk/imagery/i.cluster/main.c
grass/trunk/imagery/i.fft/fftmain.c
grass/trunk/imagery/i.gensig/get_train.c
grass/trunk/imagery/i.gensig/openfiles.c
grass/trunk/imagery/i.group/main.c
grass/trunk/imagery/i.ifft/ifftmain.c
grass/trunk/imagery/i.ifft/orig_wind.c
grass/trunk/imagery/i.maxlik/invert.c
grass/trunk/imagery/i.maxlik/open.c
grass/trunk/imagery/i.ortho.photo/photo.rectify/write.c
grass/trunk/imagery/i.pca/main.c
grass/trunk/imagery/i.rectify/main.c
grass/trunk/imagery/i.smap/bouman/model.c
grass/trunk/imagery/i.smap/shapiro/openfiles.c
grass/trunk/imagery/i.smap/shapiro/read_sig.c
grass/trunk/imagery/i.zc/main.c
fixed unlucky formatted messages (thanks to Glynn)
Modified: grass/trunk/imagery/i.cca/main.c
--- grass/trunk/imagery/i.cca/main.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.cca/main.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -142,8 +142,7 @@
/* check the number of input bands */
bands = refs.nfiles;
if (bands > MX - 1)
- G_fatal_error(_
- ("Subgroup too large. Maximum number of bands is %d\n."),
+ G_fatal_error(_("Subgroup too large. Maximum number of bands is %d\n."),
MX - 1);
Modified: grass/trunk/imagery/i.class/add_point.c
--- grass/trunk/imagery/i.class/add_point.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.class/add_point.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -19,8 +19,7 @@
return (1);
if (Region.npoints >= MAX_VERTEX) {
- G_warning(_
- ("Can't mark another point. Only %d points allowed. Sorry."),
+ G_warning(_("Can't mark another point. Only %d points allowed. Sorry."),
MAX_VERTEX);
return (0);
Modified: grass/trunk/imagery/i.class/complete_reg.c
--- grass/trunk/imagery/i.class/complete_reg.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.class/complete_reg.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -9,8 +9,7 @@
int complete_region(void)
if (Region.npoints < 3)
- G_warning(_
- ("Too few points for region. Must have at least 3 points."));
+ G_warning(_("Too few points for region. Must have at least 3 points."));
else if (Region.area.completed)
G_warning(_("Area already completed."));
else {
Modified: grass/trunk/imagery/i.class/readbands.c
--- grass/trunk/imagery/i.class/readbands.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.class/readbands.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -9,8 +9,7 @@
for (i = 0; i < nbands; i++)
if (G_get_map_row_nomask(Bandfd[i], Bandbuf[i], cur) < 0)
- G_fatal_error(_
- ("Error reading raster map in function readbands."));
+ G_fatal_error(_("Error reading raster map in function readbands."));
return 0;
Modified: grass/trunk/imagery/i.class/signature.c
--- grass/trunk/imagery/i.class/signature.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.class/signature.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -47,14 +47,12 @@
(Band_sum = (float *)G_calloc(nbands, sizeof(float))) == NULL ||
(Band_product = (float **)G_calloc(nbands, sizeof(float *))) == NULL
|| (Band_histo = (int **)G_calloc(nbands, sizeof(int *))) == NULL)
- G_fatal_error(_
- ("Unable to allocate space for signature statistics."));
+ G_fatal_error(_("Unable to allocate space for signature statistics."));
for (i = 0; i < nbands; i++) {
if ((Band_product[i] =
(Band_histo[i] = (int *)G_calloc(MAX_CATS, sizeof(int))) == NULL)
- G_fatal_error(_
return 0;
@@ -112,8 +110,7 @@
y = P[i].y;
if (y != P[i - 1].y) {
- G_warning(_
- ("prepare_signature: scan line %d has odd number of points."),
+ G_warning(_("prepare_signature: scan line %d has odd number of points."),
(i + 1) / 2);
return (0);
@@ -278,8 +275,7 @@
if ((fd = G_open_cell_new(MASK)) < 0)
G_fatal_error(_("Unable to open the cell map MASK."));
if ((buffer = G_allocate_cell_buf()) == NULL)
- G_fatal_error(_
- ("Unable to allocate the cell buffer in display_signature()."));
+ G_fatal_error(_("Unable to allocate the cell buffer in display_signature()."));
nrows = G_window_rows();
ncols = G_window_cols();
Modified: grass/trunk/imagery/i.cluster/checkpt.c
--- grass/trunk/imagery/i.cluster/checkpt.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.cluster/checkpt.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -37,8 +37,7 @@
if (verbose) {
cur_time = time(NULL);
elapsed_time = cur_time - start_time;
- G_message(_
- ("Iteration %d: %% Convergence: %.2f (%s elapsed, %s left)"),
+ G_message(_("Iteration %d: %% Convergence: %.2f (%s elapsed, %s left)"),
X->iteration, (double)X->percent_stable,
print_time(elapsed_time),
print_time(iters * elapsed_time / (X->iteration + 1) -
Modified: grass/trunk/imagery/i.cluster/main.c
--- grass/trunk/imagery/i.cluster/main.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.cluster/main.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -310,8 +310,7 @@
for (n = 0; n < ref.nfiles; n++)
x[n] = cell[n][col];
if (I_cluster_point(&C, x) < 0)
- G_fatal_error(_
- ("Out of Memory. Please run again and choose a smaller sample size"));
+ G_fatal_error(_("Out of Memory. Please run again and choose a smaller sample size"));
if (verbose)
Modified: grass/trunk/imagery/i.fft/fftmain.c
--- grass/trunk/imagery/i.fft/fftmain.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.fft/fftmain.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -160,8 +160,7 @@
data[0] = (double *)G_malloc((rows * cols) * sizeof(double));
data[1] = (double *)G_malloc((rows * cols) * sizeof(double));
if (data[0] == NULL || data[1] == NULL)
- G_fatal_error(_
- ("Insufficent memory for allocation of data structure"));
+ G_fatal_error(_("Insufficent memory for allocation of data structure"));
/* Initialize real & complex components to zero */
G_message(_("Initializing data...\n"));
Modified: grass/trunk/imagery/i.gensig/get_train.c
--- grass/trunk/imagery/i.gensig/get_train.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.gensig/get_train.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -50,8 +50,7 @@
n++;
else
- G_warning(_
- ("Training class [%d] only has one cell - this class will be ignored."),
+ G_warning(_("Training class [%d] only has one cell - this class will be ignored."),
cat);
Modified: grass/trunk/imagery/i.gensig/openfiles.c
--- grass/trunk/imagery/i.gensig/openfiles.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.gensig/openfiles.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -13,8 +13,7 @@
if (!I_get_subgroup_ref(parms->group, parms->subgroup, &Ref))
- G_fatal_error(_
- ("Unable to read REF file for subgroup [%s] in group [%s]."),
+ G_fatal_error(_("Unable to read REF file for subgroup [%s] in group [%s]."),
parms->subgroup, parms->group);
if (Ref.nfiles <= 0)
Modified: grass/trunk/imagery/i.group/main.c
--- grass/trunk/imagery/i.group/main.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.group/main.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -121,8 +121,7 @@
/* Remove files from Group */
if (I_find_group(group) == 0) {
- G_fatal_error(_
- ("Specified group does not exist in current mapset"));
+ G_fatal_error(_("Specified group does not exist in current mapset"));
if (sgrp->answer) {
@@ -143,8 +142,7 @@
struct Ref ref;
- G_fatal_error(_
if (sgrp->answer) {
@@ -167,8 +165,7 @@
else {
/* Create or update Group REF */
- G_verbose_message(_
- ("Group <%s> does not yet exist. Creating..."),
+ G_verbose_message(_("Group <%s> does not yet exist. Creating..."),
group);
if (sgrp->answer) {
@@ -253,8 +250,7 @@
/* Go through existing files to check for duplicates */
for (n = 0; n < ref.nfiles; n++) {
if (strcmp(rasters[m], ref.file[n].name) == 0) {
- G_message(_
- ("Raster map <%s> exists in subgroup. Skipping..."),
+ G_message(_("Raster map <%s> exists in subgroup. Skipping..."),
G_fully_qualified_name(rasters[m], mapset));
skip = 1;
continue;
Modified: grass/trunk/imagery/i.ifft/ifftmain.c
--- grass/trunk/imagery/i.ifft/ifftmain.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.ifft/ifftmain.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -94,8 +94,7 @@
if ((realfp =
G_fopen_old_misc("cell_misc", "fftreal", Cellmap_real,
realmapset)) == NULL)
- G_fatal_error(_
- ("Unable to open real-image in the cell_misc directory.\nInput map probably wasn't created by i.fft"));
+ G_fatal_error(_("Unable to open real-image in the cell_misc directory.\nInput map probably wasn't created by i.fft"));
if ((imagmapset = G_find_cell(Cellmap_imag, "")) == NULL)
G_fatal_error(_("%s: %s - Unable to find the imaginary-image."),
@@ -104,8 +103,7 @@
if ((imagfp =
G_fopen_old_misc("cell_misc", "fftimag", Cellmap_imag,
imagmapset)) == NULL)
- G_fatal_error(_
- ("Unable to open imaginary-image in the cell_misc directory.\nInput map probably wasn't created by i.fft"));
+ G_fatal_error(_("Unable to open imaginary-image in the cell_misc directory.\nInput map probably wasn't created by i.fft"));
/* check command line args for validity */
if (G_legal_filename(Cellmap_orig) < 0)
@@ -135,8 +133,7 @@
- G_fatal_error(_
G_message(_("Reading the raster maps..."));
Modified: grass/trunk/imagery/i.ifft/orig_wind.c
--- grass/trunk/imagery/i.ifft/orig_wind.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.ifft/orig_wind.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -24,8 +24,7 @@
hd->east != tmphd.east ||
hd->west != tmphd.west ||
hd->ew_res != tmphd.ew_res || hd->ns_res != tmphd.ns_res)
- G_fatal_error(_
- ("The real and imaginary original windows did not match."));
+ G_fatal_error(_("The real and imaginary original windows did not match."));
return 0;
Modified: grass/trunk/imagery/i.maxlik/invert.c
--- grass/trunk/imagery/i.maxlik/invert.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.maxlik/invert.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -25,12 +25,10 @@
stat = invert(s = &S.sig[c], S.nbands, ik, jk, &det);
if (stat != 1) {
if (stat)
- G_warning(_
- ("signature %d is not valid (ill-conditioned) - ignored."),
+ G_warning(_("signature %d is not valid (ill-conditioned) - ignored."),
c + 1);
else
- G_warning(_
- ("signature %d is not valid (singular) - ignored."),
+ G_warning(_("signature %d is not valid (singular) - ignored."),
c + 1);
bad = 1;
Modified: grass/trunk/imagery/i.maxlik/open.c
--- grass/trunk/imagery/i.maxlik/open.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.maxlik/open.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -23,8 +23,7 @@
if (Ref.nfiles <= 1) {
- G_fatal_error(_
- ("Subgroup [%s] of group [%s] doesn't have any files.\n"
+ G_fatal_error(_("Subgroup [%s] of group [%s] doesn't have any files.\n"
"The subgroup must have at least 2 files."));
else
G_fatal_error(_("Subgroup [%s] of group [%s] only has 1 file.\n"
Modified: grass/trunk/imagery/i.ortho.photo/photo.rectify/write.c
--- grass/trunk/imagery/i.ortho.photo/photo.rectify/write.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.ortho.photo/photo.rectify/write.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -63,8 +63,7 @@
G_fatal_error(_("Unable to write row %d"), row);
if (G_put_raster_row(fd, rast, map_type) < 0) {
- G_fatal_error(_
- ("Unable to write raster map. You might want to check available disk space and write permissions."));
+ G_fatal_error(_("Unable to write raster map. You might want to check available disk space and write permissions."));
unlink(temp_name);
Modified: grass/trunk/imagery/i.pca/main.c
--- grass/trunk/imagery/i.pca/main.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.pca/main.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -203,8 +203,7 @@
if (*scale_min == 0)
*scale = 0;
else {
- G_warning(_
- ("Scale range length should be > 0. Using default values: 0,255"));
+ G_warning(_("Scale range length should be > 0. Using default values: 0,255"));
*scale_min = 0;
*scale_max = 255;
@@ -422,8 +421,7 @@
if (rowbuf)
G_free(rowbuf);
if (!(rowbuf = G_allocate_raster_buf(maptype)))
- G_fatal_error(_
- ("Cannot allocate memory for row buffer"));
+ G_fatal_error(_("Cannot allocate memory for row buffer"));
if (G_get_raster_row(inp_fd[j], rowbuf, row, maptype) < 0)
G_fatal_error(_("Cannot read raster row [%d]"), row);
Modified: grass/trunk/imagery/i.rectify/main.c
--- grass/trunk/imagery/i.rectify/main.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.rectify/main.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -116,8 +116,7 @@
G_fatal_error(_("Group <%s> does not exist"), grp->answer);
if (ref.nfiles <= 0) {
- G_important_message(_
- ("Group <%s> contains no raster maps; run i.group"),
+ G_important_message(_("Group <%s> contains no raster maps; run i.group"),
grp->answer);
exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.smap/bouman/model.c
--- grass/trunk/imagery/i.smap/bouman/model.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.smap/bouman/model.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -35,8 +35,7 @@
for (b1 = 0; b1 < nbands; b1++)
for (b2 = 0; b2 < nbands; b2++) {
if (SubS->R[b1][b2] != SubS->R[b2][b1])
- G_warning(_
- ("\nNonsymetric covariance for class [%d] subclass [%d]."),
+ G_warning(_("\nNonsymetric covariance for class [%d] subclass [%d]."),
m + 1, i + 1);
SubS->Rinv[b1][b2] = SubS->R[b1][b2];
@@ -46,8 +45,7 @@
eigen(SubS->Rinv, lambda, nbands);
for (b1 = 0; b1 < nbands; b1++) {
if (lambda[b1] <= 0.0)
- G_warning(_
- ("Nonpositive eigenvalues for class [%d] subclass [%d]."),
+ G_warning(_("Nonpositive eigenvalues for class [%d] subclass [%d]."),
m + 1, i + 1);
Modified: grass/trunk/imagery/i.smap/shapiro/openfiles.c
--- grass/trunk/imagery/i.smap/shapiro/openfiles.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.smap/shapiro/openfiles.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -12,8 +12,7 @@
- G_fatal_error(_
Modified: grass/trunk/imagery/i.smap/shapiro/read_sig.c
--- grass/trunk/imagery/i.smap/shapiro/read_sig.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.smap/shapiro/read_sig.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -10,8 +10,7 @@
struct Ref Ref;
- G_fatal_error(_
Modified: grass/trunk/imagery/i.zc/main.c
--- grass/trunk/imagery/i.zc/main.c 2008-08-06 22:06:47 UTC (rev 32588)
+++ grass/trunk/imagery/i.zc/main.c 2008-08-06 22:07:54 UTC (rev 32589)
@@ -153,8 +153,7 @@
data[0] = (double *)G_malloc(totsize * sizeof(double));
data[1] = (double *)G_malloc(totsize * sizeof(double));
- G_fatal_error(_
G_message(_("Initializing data..."));
