[GRASS-SVN] r32627 - grass/trunk/raster/r.support
svn_grass at osgeo.org
Thu Aug 7 17:27:37 EDT 2008
Author: glynn
Date: 2008-08-07 17:27:37 -0400 (Thu, 07 Aug 2008)
New Revision: 32627
Added:
grass/trunk/raster/r.support/Makefile
grass/trunk/raster/r.support/check.c
grass/trunk/raster/r.support/description.html
grass/trunk/raster/r.support/front.c
grass/trunk/raster/r.support/histo.c
grass/trunk/raster/r.support/local_proto.h
Removed:
grass/trunk/raster/r.support/front/
grass/trunk/raster/r.support/modcats/
grass/trunk/raster/r.support/modcolr/
grass/trunk/raster/r.support/modhead/
grass/trunk/raster/r.support/modhist/
Remove terminal-interactive sub-modules
Replace yes/no questions with flags
Deleted: grass/trunk/raster/r.support/Makefile
--- grass/trunk/raster/r.support/Makefile 2008-08-07 21:26:18 UTC (rev 32626)
+++ grass/trunk/raster/r.support/Makefile 2008-08-07 21:27:37 UTC (rev 32627)
@@ -1,14 +0,0 @@
-MODULE_TOPDIR = ../..
-SUBDIRS = \
- modcats \
- modcolr \
- modhist \
- modhead \
- front
-include $(MODULE_TOPDIR)/include/Make/Dir.make
-default: parsubdirs
-clean: cleansubdirs
Copied: grass/trunk/raster/r.support/Makefile (from rev 32621, grass/trunk/raster/r.support/front/Makefile)
--- grass/trunk/raster/r.support/Makefile (rev 0)
@@ -0,0 +1,12 @@
+MODULE_TOPDIR = ../..
+PGM = r.support
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Copied: grass/trunk/raster/r.support/check.c (from rev 32621, grass/trunk/raster/r.support/front/check.c)
--- grass/trunk/raster/r.support/check.c (rev 0)
+++ grass/trunk/raster/r.support/check.c 2008-08-07 21:27:37 UTC (rev 32627)
@@ -0,0 +1,76 @@
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+ * check_stats() - Check and update statistics
+ * RETURN: EXIT_SUCCESS / EXIT_FAILURE
+int check_stats(const char *name, const char *mapset)
+ RASTER_MAP_TYPE data_type;
+ struct Histogram histogram;
+ struct Categories cats;
+ struct Range range;
+ struct FPRange fprange;
+ int i;
+ int cats_ok;
+ int max;
+ data_type = G_raster_map_type(name, mapset);
+ G_message(_("\n Updating statistics for [%s]"), name);
+ if (!do_histogram(name, mapset))
+ return EXIT_SUCCESS;
+ if (G_read_histogram(name, mapset, &histogram) <= 0)
+ /* Init histogram range */
+ if (data_type == CELL_TYPE)
+ G_init_range(&range);
+ else
+ G_init_fp_range(&fprange);
+ /* Update histogram range */
+ i = G_get_histogram_num(&histogram);
+ while (i >= 0) {
+ G_update_range(G_get_histogram_cat(i--, &histogram), &range);
+ else
+ G_update_fp_range((DCELL) G_get_histogram_cat(i--, &histogram),
+ &fprange);
+ /* Write histogram range */
+ G_write_range(name, &range);
+ else
+ G_write_fp_range(name, &fprange);
+ /* Get category status and max */
+ cats_ok = (G_read_cats(name, mapset, &cats) >= 0);
+ max = (data_type == CELL_TYPE ? range.max : fprange.max);
+ /* Further category checks */
+ if (!cats_ok)
+ G_init_cats(max, "", &cats);
+ else if (cats.num != max) {
+ cats.num = max;
+ cats_ok = 0;
+ /* Update categories if needed */
+ if (!cats_ok) {
+ G_message(_(" Updating the number of categories for "
+ "[%s]\n\n"), name);
+ G_write_cats(name, &cats);
+ G_free_histogram(&histogram);
+ G_free_cats(&cats);
Copied: grass/trunk/raster/r.support/description.html (from rev 32621, grass/trunk/raster/r.support/front/description.html)
--- grass/trunk/raster/r.support/description.html (rev 0)
+++ grass/trunk/raster/r.support/description.html 2008-08-07 21:27:37 UTC (rev 32627)
@@ -0,0 +1,42 @@
+<h2>DESCRIPTION</h2>
+<b>r.support</b> allows the user to create and/or edit raster map support
+information. Editing of raster map color tables, category labels, header,
+history, and title is supported. Category labels can also be copied from
+another raster map.
+<h2>NOTES</h2>
+If metadata options such as <b>title</b> or <b>history</b> are given the
+module will run non-interactively. If only the map name is given
+<em>r.support</em> will run interactively within a terminal shell and the
+user with be prompted for input.
+<p>
+Freeform metadata information is stored in a "<tt>hist</tt>" file which may be
+appended to by using the <b>history</b> option. Currently this is limited to
+50 lines of text with a maximum line length of 78 characters. Any input
+larger than this will be wrapped to the next line.
+All other metadata strings available as standard options are limited to
+79 characters.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.category.html">r.category</a>,
+<a href="r.describe.html">r.describe</a>,
+<a href="r.info.html">r.info</a>,
+<a href="r.null.html">r.null</a>,
+<a href="r.region.html">r.region</a>,
+<a href="r.report.html">r.report</a>,
+<a href="r.timestamp.html">r.timestamp</a>
+</em>
+<h2>AUTHORS</h2>
+Micharl Shapiro, CERL: Original author<br>
+<a href="MAILTO:rez at touchofmadness.com">Brad Douglas</a>: GRASS 6 Port<br>
+M. Hamish Bowman: command line enhancements<br>
+Markus Neteler: category copy from other map
+<p>
+<i>Last changed: $Date$</i>
+</p>
Copied: grass/trunk/raster/r.support/front.c (from rev 32621, grass/trunk/raster/r.support/front/front.c)
--- grass/trunk/raster/r.support/front.c (rev 0)
+++ grass/trunk/raster/r.support/front.c 2008-08-07 21:27:37 UTC (rev 32627)
@@ -0,0 +1,314 @@
+ * MODULE: r.support (GRASS core)
+ * AUTHOR(S): Original by Michael Shapiro - CERL
+ * Preliminary parser support by Markus Neteler, rast parameter
+ * Port to 6.x by Brad Douglas
+ * PURPOSE: Build support files for raster map
+ * - Edit header
+ * - Update status (histogram, range)
+ * COPYRIGHT: (C) 2000-2007 by the GRASS Development Team
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that comes
+ * with GRASS for details.
+#include <unistd.h>
+#include <string.h>
+/* two less than lib/gis/put_title.c G_put_cell_title()
+ if only one less a newline gets appended in the cats file. bug? */
+#define MAX_TITLE_LEN 1022
+int main(int argc, char *argv[])
+ char rname[GNAME_MAX]; /* Reclassed map name */
+ char rmapset[GMAPSET_MAX]; /* Reclassed mapset */
+ char *mapset; /* Raster mapset */
+ struct Cell_head cellhd;
+ struct GModule *module;
+ struct Option *raster, *title_opt, *history_opt;
+ struct Option *datasrc1_opt, *datasrc2_opt, *datadesc_opt;
+ struct Option *map_opt, *units_opt, *vdatum_opt;
+ struct Flag *stats_flag, *null_flag, *del_flag;
+ int cellhd_ok; /* Is cell header OK? */
+ int is_reclass; /* Is raster reclass? */
+ char *infile, *cmapset;
+ char title[MAX_TITLE_LEN + 1], datasrc[RECORD_LEN + 1];
+ struct History hist;
+ /* Initialize GIS engine */
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->keywords = _("raster, metadata");
+ module->description = _("Allows creation and/or modification of "
+ "raster map layer support files.");
+ raster = G_define_standard_option(G_OPT_R_MAP);
+ title_opt = G_define_option();
+ title_opt->key = "title";
+ title_opt->key_desc = "\"phrase\"";
+ title_opt->type = TYPE_STRING;
+ title_opt->required = NO;
+ title_opt->description = _("Text to use for map title");
+ history_opt = G_define_option();
+ history_opt->key = "history";
+ history_opt->key_desc = "\"phrase\"";
+ history_opt->type = TYPE_STRING;
+ history_opt->required = NO;
+ history_opt->description =
+ _("Text to append to the next line of the map's metadata file");
+ units_opt = G_define_option();
+ units_opt->key = "units";
+ units_opt->type = TYPE_STRING;
+ units_opt->required = NO;
+ units_opt->description = _("Text to use for map data units");
+ vdatum_opt = G_define_option();
+ vdatum_opt->key = "vdatum";
+ vdatum_opt->type = TYPE_STRING;
+ vdatum_opt->required = NO;
+ vdatum_opt->description = _("Text to use for map vertical datum");
+ datasrc1_opt = G_define_option();
+ datasrc1_opt->key = "source1";
+ datasrc1_opt->key_desc = "\"phrase\"";
+ datasrc1_opt->type = TYPE_STRING;
+ datasrc1_opt->required = NO;
+ datasrc1_opt->description = _("Text to use for data source, line 1");
+ datasrc2_opt = G_define_option();
+ datasrc2_opt->key = "source2";
+ datasrc2_opt->key_desc = "\"phrase\"";
+ datasrc2_opt->type = TYPE_STRING;
+ datasrc2_opt->required = NO;
+ datasrc2_opt->description = _("Text to use for data source, line 2");
+ datadesc_opt = G_define_option();
+ datadesc_opt->key = "description";
+ datadesc_opt->key_desc = "\"phrase\"";
+ datadesc_opt->type = TYPE_STRING;
+ datadesc_opt->required = NO;
+ datadesc_opt->description =
+ _("Text to use for data description or keyword(s)");
+ map_opt = G_define_option();
+ map_opt->key = "raster";
+ map_opt->type = TYPE_STRING;
+ map_opt->required = NO;
+ map_opt->gisprompt = "old,cell,raster";
+ map_opt->description = _("Raster map from which to copy category table");
+ stats_flag = G_define_flag();
+ stats_flag->key = 's';
+ stats_flag->description = _("Update statistics (histogram, range)");
+ null_flag = G_define_flag();
+ null_flag->key = 'n';
+ null_flag->description = _("Create/reset the null file");
+ del_flag = G_define_flag();
+ del_flag->key = 'd';
+ del_flag->description = _("Delete the null file");
+ /* Parse command-line options */
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ /* Make sure raster exists and set mapset */
+ infile = raster->answer;
+ mapset = G_find_cell2(infile, G_mapset()); /* current mapset only for editing */
+ if (mapset == NULL)
+ G_fatal_error(_("Raster map <%s> not found in current mapset"),
+ infile);
+ cellhd_ok = (G_get_cellhd(raster->answer, mapset, &cellhd) >= 0);
+ is_reclass = (G_is_reclass(raster->answer, mapset, rname, rmapset) > 0);
+ if (title_opt->answer) {
+ strncpy(title, title_opt->answer, MAX_TITLE_LEN);
+ title[MAX_TITLE_LEN] = '\0'; /* strncpy doesn't null terminate oversized input */
+ G_strip(title);
+ G_debug(3, "map title= [%s] (%d chars)", title, strlen(title));
+ G_put_cell_title(raster->answer, title);
+ if (history_opt->answer) {
+ G_read_history(raster->answer, mapset, &hist);
+ if (hist.edlinecnt >= MAXEDLINES)
+ G_fatal_error(_("Not enough room in history file"));
+ /* two less than defined as if only one less a newline gets appended in the hist file. bug? */
+ /* Should be RECORD_LEN, but r.info truncates at > 71 chars */
+ if (strlen(history_opt->answer) > 71) {
+ int i;
+ for (i = 0; i < strlen(history_opt->answer); i += 71) {
+ char *tmp = &history_opt->answer[i];
+ strncpy(hist.edhist[hist.edlinecnt], tmp, 71);
+ /* strncpy doesn't null terminate oversized input */
+ hist.edhist[hist.edlinecnt][RECORD_LEN - 2] = '\0';
+ hist.edlinecnt++;
+ G_debug(3, "new history line= [%s] (%d chars)",
+ hist.edhist[hist.edlinecnt],
+ strlen(hist.edhist[hist.edlinecnt]));
+ else {
+ strncpy(hist.edhist[hist.edlinecnt], history_opt->answer,
+ RECORD_LEN - 2);
+ hist.edlinecnt++;
+ G_write_history(raster->answer, &hist);
+ if (units_opt->answer)
+ G_write_raster_units(raster->answer, units_opt->answer);
+ if (vdatum_opt->answer)
+ G_write_raster_vdatum(raster->answer, vdatum_opt->answer);
+ if (datasrc1_opt->answer || datasrc2_opt->answer || datadesc_opt->answer) {
+ if (datasrc1_opt->answer) {
+ strncpy(datasrc, datasrc1_opt->answer, RECORD_LEN);
+ datasrc[RECORD_LEN] = '\0'; /* strncpy doesn't null terminate oversized input */
+ G_strip(datasrc);
+ G_debug(3, "map datasrc1= [%s] (%d chars)", datasrc,
+ strlen(datasrc));
+ strncpy(hist.datsrc_1, datasrc, RECORD_LEN);
+ if (datasrc2_opt->answer) {
+ strncpy(datasrc, datasrc2_opt->answer, RECORD_LEN);
+ G_strip(datasrc);
+ G_debug(3, "map datasrc2= [%s] (%d chars)", datasrc,
+ strlen(datasrc));
+ strncpy(hist.datsrc_2, datasrc, RECORD_LEN);
+ if (datadesc_opt->answer) {
+ strncpy(datasrc, datadesc_opt->answer, RECORD_LEN);
+ G_strip(datasrc);
+ G_debug(3, "map datadesc= [%s] (%d chars)", datasrc,
+ strlen(datasrc));
+ strncpy(hist.keywrd, datasrc, RECORD_LEN);
+ if (map_opt->answer) { /* use cats from another map */
+ int fd;
+ cmapset = G_find_cell2(map_opt->answer, "");
+ if (cmapset == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), map_opt->answer);
+ if ((fd = G_open_cell_old(infile, mapset)) < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), infile);
+ G_init_cats((CELL) 0, "", &cats);
+ if (0 > G_read_cats(map_opt->answer, cmapset, &cats))
+ G_fatal_error(_("Unable to read category file of raster map <%s@%s>"),
+ map_opt->answer, cmapset);
+ if (G_write_cats(infile, &cats) >= 0)
+ G_message(_("cats table for [%s] set to %s"), infile,
+ map_opt->answer);
+ G_close_cell(fd);
+ if (title_opt->answer || history_opt->answer || units_opt->answer
+ || vdatum_opt->answer || datasrc1_opt->answer || datasrc2_opt->answer
+ || datadesc_opt->answer || map_opt->answer)
+ exit(EXIT_SUCCESS);
+ /* Check the histogram and range */
+ if (stats_flag->answer)
+ check_stats(raster->answer, mapset);
+ /* null file */
+ if (null_flag->answer) {
+ unsigned char *null_bits;
+ int row, col;
+ int null_fd;
+ if (is_reclass)
+ G_fatal_error(_("[%s] is a reclass of another map. Exiting."),
+ raster->answer);
+ /* Create a file of no-nulls */
+ null_bits = G__allocate_null_bits(cellhd.cols);
+ for (col = 0; col < G__null_bitstream_size(cellhd.cols); col++)
+ null_bits[col] = 0;
+ /* Open null file for writing */
+ null_fd = G_open_new_misc("cell_misc", "null", raster->answer);
+ G_message(_("Writing new null file for [%s]... "), raster->answer);
+ for (row = 0; row < cellhd.rows; row++) {
+ G_percent(row, cellhd.rows, 1);
+ if (G__write_null_bits(null_fd, null_bits, row, cellhd.cols, 0) <
+ 0)
+ G_fatal_error(_("Error writing null row [%d]."), row);
+ /* Cleanup */
+ close(null_fd);
+ G_free(null_bits);
+ if (del_flag->answer) {
+ int null_fd;
+ char path[GPATH_MAX];
+ if (is_reclass)
+ raster->answer);
+ /* Write a file of no-nulls */
+ G_message(_("Removing null file for [%s]...\n"), raster->answer);
+ G__file_name_misc(path, "cell_misc", "null", raster->answer, mapset);
+ unlink(path);
+ close(null_fd);
+ G_done_msg(_("Done."));
Copied: grass/trunk/raster/r.support/histo.c (from rev 32621, grass/trunk/raster/r.support/front/histo.c)
--- grass/trunk/raster/r.support/histo.c (rev 0)
+++ grass/trunk/raster/r.support/histo.c 2008-08-07 21:27:37 UTC (rev 32627)
@@ -0,0 +1,49 @@
+ * do_histogram() - Creates histogram for CELL
+int do_histogram(const char *name, const char *mapset)
+ CELL *cell;
+ struct Cell_stats statf;
+ int nrows, ncols;
+ int row;
+ int fd;
+ if (G_get_cellhd(name, mapset, &cellhd) < 0)
+ return EXIT_FAILURE;
+ G_set_window(&cellhd);
+ if ((fd = G_open_cell_old(name, mapset)) < 0)
+ nrows = G_window_rows();
+ ncols = G_window_cols();
+ cell = G_allocate_cell_buf();
+ G_init_cell_stats(&statf);
+ for (row = 0; row < nrows; row++) {
+ if (G_get_map_row_nomask(fd, cell, row) < 0)
+ break;
+ G_update_cell_stats(cell, ncols, &statf);
+ if (row == nrows)
+ G_write_histogram_cs(name, &statf);
+ G_free_cell_stats(&statf);
+ G_close_cell(fd);
+ G_free(cell);
+ if (row == nrows)
Copied: grass/trunk/raster/r.support/local_proto.h (from rev 32621, grass/trunk/raster/r.support/front/local_proto.h)
--- grass/trunk/raster/r.support/local_proto.h (rev 0)
+++ grass/trunk/raster/r.support/local_proto.h 2008-08-07 21:27:37 UTC (rev 32627)
@@ -0,0 +1,5 @@
+/* check.c */
+int check_stats(const char *, const char *);
+/* histo.c */
+int do_histogram(const char *, const char *);
