[GRASS-SVN] r32634 - in grass/trunk: db/base display/d.rast.arrow display/d.thematic.area display/d.vect general/g.parser general/manage general/manage/cmd general/manage/lib gui/wxpython/vdigit imagery/i.gensig imagery/i.pca include lib/display lib/gis lib/ogsf lib/proj lib/sites ps/ps.map raster/r.in.ascii raster/r.le/r.le.patch raster/r.le/r.le.pixel raster/r.le/r.le.trace raster/r.out.bin raster/r.surf.fractal raster/r.watershed/shed sites/s.in.ascii sites/s.out.ascii vector/v.in.ogr vector/v.label.sa vector/v.out.svg vector/v.transform
Fri Aug 8 01:31:22 EDT 2008
Author: glynn
Date: 2008-08-08 01:31:22 -0400 (Fri, 08 Aug 2008)
New Revision: 32634
Removed:
   grass/trunk/general/manage/lib/ask.c
   grass/trunk/lib/gis/squeeze.c
   grass/trunk/lib/gis/store.c
   grass/trunk/lib/gis/unix_socks.c
   grass/trunk/db/base/execute.c
   grass/trunk/display/d.rast.arrow/arrow.c
   grass/trunk/display/d.thematic.area/main.c
   grass/trunk/display/d.vect/main.c
   grass/trunk/general/g.parser/main.c
   grass/trunk/general/manage/cmd/list.c
   grass/trunk/general/manage/lib/read_list.c
   grass/trunk/general/manage/list.h
   grass/trunk/gui/wxpython/vdigit/line.cpp
   grass/trunk/imagery/i.gensig/get_train.c
   grass/trunk/imagery/i.pca/support.c
   grass/trunk/include/gisdefs.h
   grass/trunk/lib/display/tran_colr.c
   grass/trunk/lib/gis/area.c
   grass/trunk/lib/gis/bres_line.c
   grass/trunk/lib/gis/cats.c
   grass/trunk/lib/gis/cell_stats.c
   grass/trunk/lib/gis/color_look.c
   grass/trunk/lib/gis/color_str.c
   grass/trunk/lib/gis/geodesic.c
   grass/trunk/lib/gis/get_ellipse.c
   grass/trunk/lib/gis/init_map.c
   grass/trunk/lib/gis/plot.c
   grass/trunk/lib/gis/strings.c
   grass/trunk/lib/ogsf/GVL2.c
   grass/trunk/lib/proj/convert.c
   grass/trunk/lib/proj/ellipse.c
   grass/trunk/lib/sites/sites.c
   grass/trunk/ps/ps.map/main.c
   grass/trunk/ps/ps.map/r_text.c
   grass/trunk/ps/ps.map/r_vlines.c
   grass/trunk/ps/ps.map/r_vpoints.c
   grass/trunk/ps/ps.map/scale.c
   grass/trunk/raster/r.in.ascii/gethead.c
   grass/trunk/raster/r.le/r.le.patch/driver.c
   grass/trunk/raster/r.le/r.le.patch/input.c
   grass/trunk/raster/r.le/r.le.pixel/driver.c
   grass/trunk/raster/r.le/r.le.pixel/input.c
   grass/trunk/raster/r.le/r.le.trace/user_input.c
   grass/trunk/raster/r.out.bin/main.c
   grass/trunk/raster/r.surf.fractal/write_rast.c
   grass/trunk/raster/r.watershed/shed/com_line.c
   grass/trunk/sites/s.in.ascii/
   grass/trunk/sites/s.in.ascii/get_site.c
   grass/trunk/sites/s.in.ascii/main.c
   grass/trunk/sites/s.out.ascii/
   grass/trunk/vector/v.in.ogr/main.c
   grass/trunk/vector/v.label.sa/labels.c
   grass/trunk/vector/v.out.svg/main.c
   grass/trunk/vector/v.transform/main.c
Remove socket code
Remove redundant string functions
Move G_squeeze, G_store to lib/gis/strings.c
Remove G_strdup(); use G_store() instead
Remove "register" qualifier
Remove ask_* functions from libgrass_manage
Modified: grass/trunk/db/base/execute.c
--- grass/trunk/db/base/execute.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/db/base/execute.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -145,7 +145,7 @@
 	G_chop(buf2);
 	len = strlen(buf2);
-	G_strncpy(buf3, buf2, 6);
+	strncpy(buf3, buf2, 6);
 	if (G_strcasecmp(buf3, "select") == 0)
 	    G_fatal_error(_("Use db.select for SELECT SQL statements"));
Modified: grass/trunk/display/d.rast.arrow/arrow.c
--- grass/trunk/display/d.rast.arrow/arrow.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/display/d.rast.arrow/arrow.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -186,7 +186,7 @@
 	exit(-1);
-    G_strncpy(layer_name, opt1->answer, sizeof(layer_name) - 1);
+    strncpy(layer_name, opt1->answer, sizeof(layer_name) - 1);
     if ((mapset = G_find_cell2(layer_name, "")) == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), layer_name);
Modified: grass/trunk/display/d.thematic.area/main.c
--- grass/trunk/display/d.thematic.area/main.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/display/d.thematic.area/main.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -210,7 +210,7 @@
     /* Read map options */
-    G_strcpy(map_name, map_opt->answer);
+    strcpy(map_name, map_opt->answer);
     /* Make sure map is available */
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/display/d.vect/main.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -420,7 +420,7 @@
     default_width = atoi(width_opt->answer);
     if (default_width < 0)
Modified: grass/trunk/general/g.parser/main.c
--- grass/trunk/general/g.parser/main.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/general/g.parser/main.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -382,7 +382,7 @@
 		option->answer ? option->answer : "");
 	putenv(G_store(buff));
-	G_strcpy(upper, option->key);
+	strcpy(upper, option->key);
 	G_str_to_upper(upper);
 	sprintf(buff, "GIS_OPT_%s=%s", upper,
Modified: grass/trunk/general/manage/cmd/list.c
--- grass/trunk/general/manage/cmd/list.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/general/manage/cmd/list.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -56,11 +56,11 @@
     for (n = 0; n < nlist; n++) {
 	if (n) {
-	    G_strcat(str, ",");
-	    G_strcat(str, list[n].alias);
+	    strcat(str, ",");
+	    strcat(str, list[n].alias);
 	else
-	    G_strcpy(str, list[n].alias);
+	    strcpy(str, list[n].alias);
     element->options = str;
Deleted: grass/trunk/general/manage/lib/ask.c
--- grass/trunk/general/manage/lib/ask.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/general/manage/lib/ask.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -1,16 +0,0 @@
-#include "list.h"
-char *ask_old(int n, char *prompt, char *name)
-    return G_ask_old(prompt, name, list[n].element[0], list[n].desc[0]);
-char *ask_new(int n, char *prompt, char *name)
-    return G_ask_new(prompt, name, list[n].element[0], list[n].desc[0]);
-char *ask_in_mapset(int n, char *prompt, char *name)
-    return G_ask_in_mapset(prompt, name, list[n].element[0], list[n].desc[0]);
Modified: grass/trunk/general/manage/lib/read_list.c
--- grass/trunk/general/manage/lib/read_list.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/general/manage/lib/read_list.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -37,7 +37,7 @@
     any = 0;
     if ((env = G__getenv("ELEMENT_LIST")))
-	G_strcpy(element_list, env);
+	strcpy(element_list, env);
     else
 	sprintf(element_list, "%s/etc/element_list", G_gisbase());
     fd = fopen(element_list, "r");
Modified: grass/trunk/general/manage/list.h
--- grass/trunk/general/manage/list.h	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/general/manage/list.h	2008-08-08 05:31:22 UTC (rev 32634)
@@ -26,16 +26,10 @@
 #define COPY   3
 #define LIST   4
-char *ask_in_mapset();
 /* add_elem.c */
 int add_element(char *, char *);
-/* ask.c */
-char *ask_old(int, char *, char *);
-char *ask_new(int, char *, char *);
-char *ask_in_mapset(int, char *, char *);
 /* copyfile.c */
 int copyfile(char *, char *, char *, char *);
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp	2008-08-08 05:31:22 UTC (rev 32634)
@@ -835,7 +835,7 @@
     BgMap = NULL;
     if (!G__name_is_fully_qualified(bgmap, name, mapset)) {
-	G_strncpy(name, bgmap, GNAME_MAX);
+	strncpy(name, bgmap, GNAME_MAX);
 	mapset[0] = '\0';
     if (strcmp(G_fully_qualified_name((const char*) display->mapInfo->name, (const char*) G_mapset()),
Modified: grass/trunk/imagery/i.gensig/get_train.c
--- grass/trunk/imagery/i.gensig/get_train.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/imagery/i.gensig/get_train.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -1,4 +1,5 @@
 #include <stdlib.h>
+#include <string.h>
 #include <grass/imagery.h>
 #include <grass/glocale.h>
 #include "signature.h"
@@ -43,7 +44,7 @@
 	    I_new_signature(S);
 	    S->sig[n].status = 1;
 	    S->sig[n].npoints = count;
-	    G_strncpy(S->sig[n].desc,
+	    strncpy(S->sig[n].desc,
 		      G_get_cat(cat, &files->training_labels),
 		      sizeof(S->sig[n].desc)
Modified: grass/trunk/imagery/i.pca/support.c
--- grass/trunk/imagery/i.pca/support.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/imagery/i.pca/support.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -48,9 +48,9 @@
 	sprintf(tmpeigen, "( ");
 	for (j = 0; j < bands; j++) {
 	    sprintf(tmpa, "%.2f ", eigmat[i][j]);
-	    G_strcat(tmpeigen, tmpa);
+	    strcat(tmpeigen, tmpa);
-	G_strcat(tmpeigen, ")");
+	strcat(tmpeigen, ")");
 	sprintf(hist.edhist[i + 1], tmpeigen);
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/include/gisdefs.h	2008-08-08 05:31:22 UTC (rev 32634)
@@ -1086,29 +1086,17 @@
 int G_snprintf(char *, size_t, const char *, ...)
     __attribute__ ((format(printf, 3, 4)));
-/* squeeze.c */
-char *G_squeeze(char *);
-/* store.c */
-char *G_store(const char *);
 /* strings.c */
-char *G_strcpy(char *, const char *);
-char *G_chrcpy(char *, const char *, int);
-char *G_strncpy(char *, const char *, int);
-char *G_strcat(char *, const char *);
-char *G_chrcat(char *, const char *, int);
-char *G_strmov(char *, const char *);
-char *G_chrmov(char *, const char *, int);
 int G_strcasecmp(const char *, const char *);
-char *G_strstr(const char *, const char *);
-char *G_strdup(const char *);
+char *G_store(const char *);
 char *G_strchg(char *, char, char);
 char *G_str_replace(char *, const char *, const char *);
+int G_strip(char *);
+char *G_chop(char *);
 void G_str_to_upper(char *);
 void G_str_to_lower(char *);
 int G_str_to_sql(char *);
-int G_strip(char *);
+char *G_squeeze(char *);
 /* svd.c */
 int G_svdcmp(double **, int, int, double *, double **);
@@ -1154,14 +1142,6 @@
 /* unctrl.c */
 char *G_unctrl(int);
-/* unix_socks.c */
-char *G_sock_get_fname(const char *);
-int G_sock_exists(const char *);
-int G_sock_bind(const char *);
-int G_sock_listen(int, unsigned int);
-int G_sock_accept(int);
-int G_sock_connect(const char *);
 /* verbose.c */
 int G_verbose(void);
 int G_verbose_min(void);
Modified: grass/trunk/lib/display/tran_colr.c
--- grass/trunk/lib/display/tran_colr.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/display/tran_colr.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -63,7 +63,7 @@
     char lowerstr[MAX_COLOR_LEN];
     /* Make the color string lowercase for display colors */
-    G_strcpy(lowerstr, str);
+    strcpy(lowerstr, str);
     G_chop(lowerstr);
     G_tolcase(lowerstr);
Modified: grass/trunk/lib/gis/area.c
--- grass/trunk/lib/gis/area.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/area.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -90,8 +90,8 @@
 double G_area_of_cell_at_row(int row)
-    register double south_value;
-    register double cell_area;
+    double south_value;
+    double cell_area;
     if (projection != PROJECTION_LL)
 	return square_meters;
Modified: grass/trunk/lib/gis/bres_line.c
--- grass/trunk/lib/gis/bres_line.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/bres_line.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -40,7 +40,7 @@
     int dx, dy;
     int xinc, yinc;
-    register int res1;
+    int res1;
     int res2;
     xinc = 1;
Modified: grass/trunk/lib/gis/cats.c
--- grass/trunk/lib/gis/cats.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/cats.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -728,7 +728,7 @@
 int G_unmark_raster_cats(struct Categories *pcats)
 {				/* structure to hold category info */
-    register int i;
+    int i;
     for (i = 0; i < pcats->ncats; i++)
 	pcats->marks[i] = 0;
Modified: grass/trunk/lib/gis/cell_stats.c
--- grass/trunk/lib/gis/cell_stats.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/cell_stats.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -67,11 +67,11 @@
 int G_update_cell_stats(const CELL * cell, int n, struct Cell_stats *s)
     CELL cat;
-    register int p, q;
+    int p, q;
     int idx, offset;
     int N;
-    register NODE *node, *pnode;
-    register NODE *new_node;
+    NODE *node, *pnode;
+    NODE *new_node;
     if (n <= 0)
 	return 1;
@@ -163,8 +163,8 @@
 static int init_node(NODE * node, int idx, int offset)
-    register long *count;
-    register int i;
+    long *count;
+    int i;
     count = node->count = (long *)G_calloc(i = NCATS, sizeof(long));
     while (i--)
@@ -203,8 +203,8 @@
 int G_find_cell_stat(CELL cat, long *count, const struct Cell_stats *s)
-    register int q;
-    register int idx;
+    int q;
+    int idx;
     int offset;
     *count = 0;
Modified: grass/trunk/lib/gis/color_look.c
--- grass/trunk/lib/gis/color_look.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/color_look.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -237,7 +237,7 @@
     struct _Color_Rule_ *rule;
     DCELL dmin, dmax, val, dmod = 0L, shift;
     CELL cat, min, max;
-    register const void *ptr, *last_ptr = NULL;
+    const void *ptr, *last_ptr = NULL;
     int invert;
     int found, r, g, b;
     int cell_type;
Modified: grass/trunk/lib/gis/color_str.c
--- grass/trunk/lib/gis/color_str.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/color_str.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -115,7 +115,7 @@
     int num_names = G_num_standard_color_names();
     int i;
-    G_strcpy(buf, str);
+    strcpy(buf, str);
     G_chop(buf);
     G_debug(3, "G_str_to_color(): str = '%s'", buf);
Modified: grass/trunk/lib/gis/geodesic.c
--- grass/trunk/lib/gis/geodesic.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/geodesic.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -28,8 +28,6 @@
-#define SWAP(a,b) temp=a;a=b;b=temp
 static int adjust_lat(double *);
 static int adjust_lon(double *);
@@ -46,10 +44,9 @@
     adjust_lat(&lat1);
     adjust_lat(&lat2);
     if (lon1 > lon2) {
-	register double temp;
-	SWAP(lon1, lon2);
-	SWAP(lat1, lat2);
+	double temp;
+	temp = lon1; lon1 = lon2; lon2 = temp;
+	temp = lat1; lat1 = lat2; lat2 = temp;
     if (lon1 == lon2) {
 	A = B = 0.0;
Modified: grass/trunk/lib/gis/get_ellipse.c
--- grass/trunk/lib/gis/get_ellipse.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/get_ellipse.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -297,8 +297,8 @@
 	    err++;
 	    sprintf(buf, " %d", line);
 	    if (*badlines)
-		G_strcat(badlines, ",");
-	    G_strcat(badlines, buf);
+		strcat(badlines, ",");
+	    strcat(badlines, buf);
 	    continue;
@@ -317,8 +317,8 @@
 	    err++;
 	    if (*badlines)
 	    continue;
Modified: grass/trunk/lib/gis/init_map.c
--- grass/trunk/lib/gis/init_map.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/init_map.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -16,7 +16,7 @@
     struct fileinfo *fcb = &G__.fileinfo[fd];
     int row, col;
     double zeroVal, *zeroValP;
-    register XDR *xdrs;
+    XDR *xdrs;
     xdrs = &fcb->xdrstream;	/* xdr stream is initialized to write into */
     xdr_setpos(xdrs, 0);	/* G__.work_buf in 'opencell.c' */
@@ -56,7 +56,7 @@
     int row, col;
     float zeroVal, *zeroValP;
+    XDR *xdrs;
Modified: grass/trunk/lib/gis/plot.c
--- grass/trunk/lib/gis/plot.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/plot.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -660,7 +660,7 @@
 static int edge(double x0, double y0, double x1, double y1)
-    register double m;
+    double m;
     double dy, x;
     int ystart, ystop;
Deleted: grass/trunk/lib/gis/squeeze.c
--- grass/trunk/lib/gis/squeeze.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/squeeze.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -1,66 +0,0 @@
- * \file squeeze.c
- * \brief GIS Library - String white space removal functions.
- * (C) 2001-2008 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author GRASS GIS Development Team
- * \date 1998-2008
-#include <ctype.h>
-#include <string.h>
-#include <grass/gis.h>
- * last modification: 12 aug 81, j w hamilton
- * 1998-04-04  WBH
- *     Also squeezes out newlines -- easier to use with fgets()
- * 1999-19-12 Werner Droege
- *     changed line 37, line 48ff. -- return (strip_NL(line))
- * \brief Remove superfluous white space.
- * Leading and trailing white space is removed from the string
- * <b>line</b> and internal white space which is more than one character
- * is reduced to a single space character. White space here means
- * spaces, tabs, linefeeds, newlines, and formfeeds.
- * \param[in,out] line
- * \return Pointer to <b>line</b>
-char *G_squeeze(char *line)
-    register char *f = line, *t = line;
-    int l;
-    /* skip over space at the beginning of the line. */
-    while (isspace(*f))
-	f++;
-    while (*f)
-	if (!isspace(*f))
-	    *t++ = *f++;
-	else if (*++f)
-	    if (!isspace(*f))
-		*t++ = ' ';
-    *t = '\0';
-    l = strlen(line) - 1;
-    if (*(line + l) == '\n')
-	*(line + l) = '\0';
-    return line;
Deleted: grass/trunk/lib/gis/store.c
--- grass/trunk/lib/gis/store.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/store.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -1,40 +0,0 @@
- * \file store.c
- * \brief GIS Library - String storage functions.
- * \date 1999-2008
- * \brief Copy string to allocated memory.
- * This routine allocates enough memory to hold the string <b>s</b>,
- * copies <b>s</b> to the allocated memory, and returns a pointer
- * to the allocated memory.
- *  \param[in] s string
- *  \return pointer to newly allocated string
-char *G_store(const char *s)
-    char *buf;
-    buf = G_malloc(strlen(s) + 1);
-    strcpy(buf, s);
-    return buf;
Modified: grass/trunk/lib/gis/strings.c
--- grass/trunk/lib/gis/strings.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/strings.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -26,158 +26,7 @@
 #define NULL		0
 #endif
-static char *G_strend(const char *S)
-    while (*S)
-	S++;
-    return (char *)S;
- * \brief Copies characters from the string F into the string T.
- * This function has undefined results if the strings overlap.
- * \param[out] T target string
- * \param[in] F source string
- * \return pointer to T
-char *G_strcpy(char *T, const char *F)
-    char *d = T;
-    while ((*d++ = *F++)) ;
-    return (T);
- * Copies just the first n characters from the string F. At the end
- * the null terminator is written into the string T.
- * \param[in] n number of characters to copy
- * \return T value
-char *G_chrcpy(char *T, const char *F, int n)
-    char *d = T;
-    while (n--)
-	*d++ = *F++;
-    *d = '\0';
-    return (T);
- * \brief This function is similar to G_chrcpy() but always copies at least
- * n characters into the string T.
- * If the length of F is more than n, then copies just the first n
- * characters. At the end the null terminator is written into the
- * string T.
- * \return T value
-char *G_strncpy(char *T, const char *F, int n)
-    char *d = T;
-    while (n-- && *F)
-	*d++ = *F++;
-    *d = '\0';
-    return (T);
- * \brief Copies characters from the string F (not including the
- * terminating null character) into the string T.
- * \return T value
-char *G_strmov(char *T, const char *F)
-    char *d = T;
-    while (*F)
-	*d++ = *F++;
-    return (T);
- * \brief This copies characters from the string F (exactly n
- * characters) into the string T.
- * The terminating null character is not explicitly written into the
- * string T.
- * \return T value
-char *G_chrmov(char *T, const char *F, int n)
-    char *d = T;
-    while (n--)
-	*d++ = *F++;
-    return (T);
- * \brief This copies characters from the string F into the string T.
- * This function is similar to G_strcpy(), except that the
- * characters from F are concatenated or appended to the end of
- * T, instead of overwriting it.  That is, the first character from
- * F overwrites the null character marking the end of T.
- * \return T value
-char *G_strcat(char *T, const char *F)
-    G_strcpy(G_strend(T), F);
-    return (T);
- * \brief This function is like G_strcat() except that not more than n
- * characters from F are appended to the end of T.
- * \param[in] n number of character to copy
- * \return T value
-char *G_chrcat(char *T, const char *F, int n)
-    G_chrcpy(G_strend(T), F, n);
-    return (T);
  * \brief String compare ignoring case (upper or lower)
  * Returning a value that has the same sign as the difference between
@@ -216,63 +65,25 @@
     return 0;
- * \brief Finds the first occurrence of the character C in the
- * null-terminated string beginning at mainString
+ * \brief Copy string to allocated memory.
- * \param[in] mainString string where to find sub-string
- * \param[in] subString sub-string
- * \return a pointer to the first occurrence of subString in
- * mainString
- * \return NULL if no occurrences are found
+ * This routine allocates enough memory to hold the string <b>s</b>,
+ * copies <b>s</b> to the allocated memory, and returns a pointer
+ * to the allocated memory.
+ *  \param[in] s string
+ *  \return pointer to newly allocated string
-char *G_strstr(const char *mainString, const char *subString)
-    const char *p;
-    const char *q;
-    int length;
-    p = subString;
-    q = mainString;
-    length = strlen(subString);
-    do {
-	while (*q != '\0' && *q != *p) {	/* match 1st subString char */
-	    q++;
-    } while (*q != '\0' && strncmp(p, q, length) != 0 && q++);
-    /* Short-circuit evaluation is your friend */
-    if (*q == '\0') {		/* ran off end of mainString */
-	return NULL;
-    else {
-	return (char *)q;
- * \brief Copies the null-terminated string into a newly
- * allocated string. The string is allocated using G_malloc().
- * \param[in] string the string to duplicate
- * \return pointer to a string that is a duplicate of the string
- *  given to G_strdup().
- * \return NULL if unable to allocate the required space
-char *G_strdup(const char *string)
+char *G_store(const char *s)
-    char *p;
+    char *buf;
-    p = G_malloc(strlen(string) + 1);
+    buf = G_malloc(strlen(s) + 1);
+    strcpy(buf, s);
-    if (p != NULL) {
-	strcpy(p, string);
-    return p;
+    return buf;
@@ -323,7 +134,7 @@
     /* Make sure old_str and new_str are not NULL */
     if (old_str == NULL || new_str == NULL)
-	return G_strdup(buffer);
+	return G_store(buffer);
     /* Make sure buffer is not NULL */
     if (buffer == NULL)
 	return NULL;
@@ -332,7 +143,7 @@
     B = strstr(buffer, old_str);
     if (B == NULL)
 	/* return NULL; */
     if (strlen(new_str) > strlen(old_str)) {
 	/* Count occurences of old_str */
@@ -340,7 +151,7 @@
 	len = strlen(old_str);
 	B = buffer;
 	while (B != NULL && *B != '\0') {
-	    B = G_strstr(B, old_str);
+	    B = strstr(B, old_str);
 	    if (B != NULL) {
 		B += len;
 		count++;
@@ -388,7 +199,7 @@
 int G_strip(char *buf)
-    register char *a, *b;
+    char *a, *b;
     /* remove leading white space */
     for (a = b = buf; *a == ' ' || *a == '\t'; a++) ;
@@ -417,7 +228,7 @@
 char *G_chop(char *line)
+    char *f = line, *t = line;
     while (isspace(*f))		/* go to first non white-space char */
 	f++;
@@ -513,3 +324,38 @@
     return count;
+ * \brief Remove superfluous white space.
+ * Leading and trailing white space is removed from the string
+ * <b>line</b> and internal white space which is more than one character
+ * is reduced to a single space character. White space here means
+ * spaces, tabs, linefeeds, newlines, and formfeeds.
+ * \param[in,out] line
+ * \return Pointer to <b>line</b>
+char *G_squeeze(char *line)
+    int l;
+    /* skip over space at the beginning of the line. */
+    while (isspace(*f))
+	f++;
+    while (*f)
+	if (!isspace(*f))
+	    *t++ = *f++;
+	else if (*++f)
+	    if (!isspace(*f))
+		*t++ = ' ';
+    *t = '\0';
+    l = strlen(line) - 1;
+    if (*(line + l) == '\n')
+	*(line + l) = '\0';
+    return line;
Deleted: grass/trunk/lib/gis/unix_socks.c
--- grass/trunk/lib/gis/unix_socks.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/gis/unix_socks.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -1,394 +0,0 @@
- * \file unix_sockets.c
- * \brief GIS Library - Unix sockets support functions.
- * Routines related to using UNIX domain sockets for IPC mechanisms
- * (such as XDRIVER).<br>
- * Historically GRASS has used FIFO for interprocess communications for
- * display functions. Unfortunately, FIFO's are not available on all
- * target platforms. An attempt has been made to use IPC message
- * passing, but the semantics are variable and it also isn't available
- * on all target platforms. UNIX sockets, or local or domain sockets,
- * are much more widely available and consistent.<br>
- * <b>Note:</b> This implementation of UNIX sockets provides zero
- * security checking so should not be used from untrusted clients.<br>
- * \author Eric G. Miller
- * \date 1999-2008
-#include <grass/config.h>
-#ifdef HAVE_SOCKET
-#include <stdio.h>
-#include <stddef.h>
-#include <stdlib.h>
-#include <errno.h>
-#include <unistd.h>
-#include <sys/types.h>
-#include <sys/stat.h>
-#ifdef __MINGW32__
-#define USE_TCP
-#include <winsock2.h>
-#include <ws2tcpip.h>
-#define EADDRINUSE WSAEADDRINUSE
-#else
-#include <sys/socket.h>
-#include <sys/un.h>
-#include <netinet/in.h>
-#define INVALID_SOCKET (-1)
-#endif
-#include <grass/version.h>
-#include <grass/glocale.h>
-/** For systems where the *_LOCAL (POSIX 1g) is not defined
- ** There's not really any difference between PF and AF in practice.
-static char *_get_make_sock_path(void);
-static void init_sockets(void)
-#ifdef __MINGW32__
-    static int ready;
-    WSADATA wsadata;
-    if (ready)
-	return;
-    ready = 1;
-    WSAStartup(0x0001, &wsadata);
-#endif
- * _get_make_sock_path(), builds and tests the path for the socket
- * directory.  Returns NULL on any failure, otherwise it returns the
- * directory path. The path will be like
- * "/tmp/grass7-$USER-$GIS_LOCK".
- * ($GIS_LOCK is set in lib/init/init.sh to PID)
-    char *path, *user, *lock;
-    const char *prefix = "/tmp/grass7";
-    int len, status;
-    struct stat theStat;
-    user = G_whoami();		/* Don't G_free () return value ever! */
-    if (user == NULL)
-	return NULL;
-    else if (user[0] == '?') {	/* why's it do that? */
-	return NULL;
-    if ((lock = getenv("GIS_LOCK")) == NULL)
-	G_fatal_error(_("Unable to get GIS_LOCK enviroment variable value"));
-    len = strlen(prefix) + strlen(user) + strlen(lock) + 3;
-    path = G_malloc(len);
-    sprintf(path, "%s-%s-%s", prefix, user, lock);
-    if ((status = G_lstat(path, &theStat)) != 0) {
-	status = G_mkdir(path);
-    else {
-	if (!S_ISDIR(theStat.st_mode)) {
-	    status = -1;	/* not a directory ?? */
-	else {
-	    status = chmod(path, S_IRWXU);	/* fails if we don't own it */
-    if (status) {		/* something's wrong if non-zero */
-	G_free(path);
-	path = NULL;
-    return path;
-#ifdef USE_TCP
-#define PROTO PF_INET
-typedef struct sockaddr_in sockaddr_t;
-static int set_port(const char *name, int port)
-    FILE *fp = fopen(name, "w");
-    if (!fp)
-	return -1;
-    fprintf(fp, "%d\n", port);
-    fclose(fp);
-    return 0;
-static int get_port(const char *name)
-    FILE *fp = fopen(name, "r");
-    int port;
-    if (!fp)
-	return -1;
-    if (fscanf(fp, "%d", &port) != 1)
-	port = -1;
-    fclose(fp);
-    return port;
-static int save_port(int sockfd, const char *name)
-    sockaddr_t addr;
-    socklen_t size = sizeof(addr);
-    if (getsockname(sockfd, (struct sockaddr *)&addr, &size) != 0)
-	return -1;
-    if (set_port(name, ntohs(addr.sin_port)) < 0)
-	return -1;
-    return 0;
-static int make_address(sockaddr_t * addr, const char *name, int exists)
-    int port = exists ? get_port(name) : 0;
-    if (port < 0)
-	return -1;
-    addr->sin_family = AF_INET;
-    addr->sin_addr.s_addr = htonl(INADDR_LOOPBACK);
-    addr->sin_port = htons((unsigned short)port);
-    return 0;
-#else
-#define PROTO PF_UNIX
-typedef struct sockaddr_un sockaddr_t;
-    addr->sun_family = AF_UNIX;
-    /* The path to the unix socket must fit in sun_path[] */
-    if (sizeof(addr->sun_path) < strlen(name) + 1)
-	return -1;
-    strncpy(addr->sun_path, name, sizeof(addr->sun_path) - 1);
-    return 0;
-#endif
- * \brief Builds full path for a UNIX socket.
- * Caller should <i>G_free()</i> the return value when it is no longer
- * needed.
- * \param[in] name
- * \return NULL on error
- * \return Pointer to string socket path on success
-char *G_sock_get_fname(const char *name)
-    char *path, *dirpath;
-    int len;
-    if (name == NULL)
-	return NULL;
-    dirpath = _get_make_sock_path();
-    if (dirpath == NULL)
-	return NULL;
-    len = strlen(dirpath) + strlen(name) + 2;
-    sprintf(path, "%s/%s", dirpath, name);
-    G_free(dirpath);
-    return path;
- * \brief Checks socket existence.
- * \param[in] name
- * \return 1 if <b>name</b> exists
- * \return 0 if <b>name</b> does not exist
-int G_sock_exists(const char *name)
-    if (name == NULL || stat(name, &theStat) != 0)
-	return 0;
-#ifdef USE_TCP
-    if (S_ISREG(theStat.st_mode))
-#else
-    if (S_ISSOCK(theStat.st_mode))
-#endif
-	return 1;
-    else
-	return 0;
- * \brief Binds socket to file descriptor.
- * Takes the full pathname for a UNIX socket and returns the file
- * descriptor to the socket after a successful call to <i>bind()</i>.
- * \param[in] name
- * \return -1 and "errno" is set on error
- * \return file descriptor on success
-int G_sock_bind(const char *name)
-    int sockfd;
-    sockaddr_t addr;
-    socklen_t size;
-    if (name == NULL)
-	return -1;
-    init_sockets();
-    /* Bind requires that the file does not exist. Force the caller
-     * to make sure the socket is not in use.  The only way to test,
-     * is a call to connect().
-    if (G_sock_exists(name)) {
-	errno = EADDRINUSE;
-	return -1;
-    /* must always zero socket structure */
-    memset(&addr, 0, sizeof(addr));
-    size = sizeof(addr);
-    if (make_address(&addr, name, 0) < 0)
-	return -1;
-    sockfd = socket(PROTO, SOCK_STREAM, 0);
-    if (sockfd == INVALID_SOCKET)
-	return -1;
-    if (bind(sockfd, (const struct sockaddr *)&addr, size) != 0)
-	return -1;
-#ifdef USE_TCP
-    if (save_port(sockfd, name) < 0)
-	return -1;
-#endif
-    return sockfd;
- * \brief Wrapper function to <i>listen()</i>.
- * \param[in] sockfd
- * \param[in] queue_len
- * \return 0 on success
- * \return -1 and "errno" set on error
-int G_sock_listen(int sockfd, unsigned int queue_len)
-    return listen(sockfd, queue_len);
- * \brief Wrapper around <i>accept()</i>.
- * <b>Note:</b> This call will usually block until a connection arrives.
- * <i>select()</i> can be used for a time out on the call.
-int G_sock_accept(int sockfd)
-    sockaddr_t addr;
-    socklen_t len = sizeof(addr);
-    return accept(sockfd, (struct sockaddr *)&addr, &len);
- * \brief Tries to connect to the UNIX socket specified by <b>name</b>.
- * \param[in] name
-int G_sock_connect(const char *name)
-    int sockfd;
-    sockaddr_t addr;
-    init_sockets();
-    if (!G_sock_exists(name))
-	return -1;
-    if (make_address(&addr, name, 1) < 0)
-	return -1;
-	return -1;
-    if (connect(sockfd, (struct sockaddr *)&addr, sizeof(addr)) != 0)
-	return -1;
-    else
-	return sockfd;
-#endif
Modified: grass/trunk/lib/ogsf/GVL2.c
--- grass/trunk/lib/ogsf/GVL2.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/ogsf/GVL2.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -16,6 +16,7 @@
    Tomas Paudits (February 2004)
 #include <grass/G3d.h>
 #include <grass/gstypes.h>
@@ -276,7 +277,7 @@
 	return (-1);
-    G_strcpy(filename, gvl_file_get_name(gvl->hfile));
+    strcpy(filename, gvl_file_get_name(gvl->hfile));
     return (1);
@@ -781,7 +782,7 @@
 		*constant = isosurf->att[att].constant;
 	    else if (src == MAP_ATT) {
-		G_strcpy(mapname, gvl_file_get_name(isosurf->att[att].hfile));
+		strcpy(mapname, gvl_file_get_name(isosurf->att[att].hfile));
 	    return (1);
Modified: grass/trunk/lib/proj/convert.c
--- grass/trunk/lib/proj/convert.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/proj/convert.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -156,8 +156,8 @@
     else
 	ellpslong = G_store(ellps);
-    startmod = G_strstr(wkt, "GEOGCS");
-    lastpart = G_strstr(wkt, "PRIMEM");
+    startmod = strstr(wkt, "GEOGCS");
+    lastpart = strstr(wkt, "PRIMEM");
     len = strlen(wkt) - strlen(startmod);
     wkt[len] = '\0';
     if (haveparams == 2) {
@@ -199,7 +199,7 @@
 	    G_asprintf(&buff, ",UNIT[\"%s\",", osrunit);
-	    startmod = G_strstr(lastpart, buff);
+	    startmod = strstr(lastpart, buff);
 	    len = strlen(lastpart) - strlen(startmod);
 	    lastpart[len] = '\0';
Modified: grass/trunk/lib/proj/ellipse.c
--- grass/trunk/lib/proj/ellipse.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/proj/ellipse.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -232,8 +232,8 @@
 	    err++;
 	    if (*badlines)
 	    continue;
@@ -256,8 +256,8 @@
 	    err++;
 	    if (*badlines)
 	    continue;
Modified: grass/trunk/lib/sites/sites.c
--- grass/trunk/lib/sites/sites.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/lib/sites/sites.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -96,13 +96,13 @@
 		for (i = 0; i < Map->n_site_dbl; i++)
 		    s->dbl_att[i] = 0;
 		for (i = 0; i < Map->n_site_str; i++)
-		    G_strncpy(s->str_att[i], "", MAX_SITE_STRING);
+		    strncpy(s->str_att[i], "", MAX_SITE_STRING);
 	    else {
 		    s->dbl_att[i] = sa->dbl[i];
-		    G_strncpy(s->str_att[i], sa->str[i], MAX_SITE_STRING);
+		    strncpy(s->str_att[i], sa->str[i], MAX_SITE_STRING);
@@ -713,7 +713,7 @@
 	    /* allow both prefixed and unprefixed strings */
 	    if (c < s->str_alloc) {
 		if ((tmp = cleanse_string(buf)) > 0) {
-		    G_strncpy(s->str_att[c++], buf, tmp);
+		    strncpy(s->str_att[c++], buf, tmp);
 		    buf += tmp;
 		else
@@ -818,9 +818,9 @@
 	switch (*buf) {
 	case '#':		/* category field */
 	    sscanf(buf, "#%s ", ebuf);
-	    if (G_strstr(ebuf, ".") == NULL && sscanf(ebuf, "%d", &itmp) == 1)
+	    if (strstr(ebuf, ".") == NULL && sscanf(ebuf, "%d", &itmp) == 1)
 		*cat = CELL_TYPE;
-	    else if (G_strstr(ebuf, ".") != NULL &&
+	    else if (strstr(ebuf, ".") != NULL &&
 		     sscanf(ebuf, "%f", &ftmp) == 1)
 		*cat = FCELL_TYPE;
 	    else
@@ -1065,7 +1065,7 @@
     for (i = 0; i < s->dim_alloc; ++i) {
 	format_double(s->dim[i], nbuf);
 	sprintf(xbuf, "%s%s", nfs, nbuf);
-	G_strcat(buf, xbuf);
+	strcat(buf, xbuf);
     nfs = (fs == NULL) ? " " : fs;
@@ -1073,19 +1073,19 @@
     switch (s->cattype) {
     case CELL_TYPE:
 	sprintf(xbuf, "%s%s%d ", nfs, ((id == 0) ? "" : "#"), (int)s->ccat);
 	break;
     case FCELL_TYPE:
     case DCELL_TYPE:
 	sprintf(xbuf, "%s%s%g ", nfs, ((id == 0) ? "" : "#"), (float)s->fcat);
 	break;
     for (i = 0; i < s->dbl_alloc; ++i) {
 	format_double(s->dbl_att[i], nbuf);
 	sprintf(xbuf, "%s%s%s", nfs, ((id == 0) ? "" : "%"), nbuf);
     for (i = 0; i < s->str_alloc; ++i) {
@@ -1114,9 +1114,9 @@
 	     else
-	    G_strcpy(xbuf, s->str_att[i]);
+	    strcpy(xbuf, s->str_att[i]);
-	    G_strcpy(s->str_att[i], xbuf);
+	    strcpy(s->str_att[i], xbuf);
 	    if (G_index(s->str_att[i], SPACE) != (char *)NULL)
 		sprintf(xbuf, "%s%s\"%s\"", nfs, ((id == 0) ? "" : "@"),
@@ -1124,7 +1124,7 @@
 	    else
 		sprintf(xbuf, "%s%s%s", nfs, ((id == 0) ? "" : "@"),
 			s->str_att[i]);
     return buf;
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/ps/ps.map/main.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -162,11 +162,11 @@
     /* set default paper */
     set_paper("a4");
-    G_strcpy(buf, "black");
+    strcpy(buf, "black");
     BLACK = get_color_number(buf);
-    G_strcpy(buf, "white");
+    strcpy(buf, "white");
     WHITE = get_color_number(buf);
-    G_strcpy(buf, "grey");
+    strcpy(buf, "grey");
     GREY = get_color_number(buf);
     /* initialize */
@@ -244,7 +244,7 @@
 		  "scale", "scale", "scale");
 	can_reset_scale = isatty(0);
 	if (check_scale(map_scale->answer))
-	    G_strcpy(PS.scaletext, map_scale->answer);
+	    strcpy(PS.scaletext, map_scale->answer);
 	else
 	    error(map_scale->answer, "", "illegal scale request");
@@ -447,7 +447,7 @@
 	    PS.do_scalebar = 1;
 	    if (sscanf(data, "%s", sb.type) != 1)
-		G_strcpy(sb.type, "f");	/* default to fancy scalebar */
+		strcpy(sb.type, "f");	/* default to fancy scalebar */
 	    read_scalebar();
 	    if (sb.length <= 0.) {
 		error(key, data, "Bad scalebar length");
Modified: grass/trunk/ps/ps.map/r_text.c
--- grass/trunk/ps/ps.map/r_text.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/ps/ps.map/r_text.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -74,7 +74,7 @@
     rotate = 0.0;
     xref = CENTER;
     yref = CENTER;
-    G_strcpy(fontname, "Helvetica");
+    strcpy(fontname, "Helvetica");
     while (*text == ' ' || *text == '\t')
 	text++;
Modified: grass/trunk/ps/ps.map/r_vlines.c
--- grass/trunk/ps/ps.map/r_vlines.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/ps/ps.map/r_vlines.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -102,10 +102,10 @@
 	    G_strip(data);
 	    vector.layer[vec].ltype = 0;
-	    if (G_strstr(data, "line"))
+	    if (strstr(data, "line"))
 		vector.layer[vec].ltype |= GV_LINE;
-	    if (G_strstr(data, "boundary"))
+	    if (strstr(data, "boundary"))
 		vector.layer[vec].ltype |= GV_BOUNDARY;
 	    continue;
Modified: grass/trunk/ps/ps.map/r_vpoints.c
--- grass/trunk/ps/ps.map/r_vpoints.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/ps/ps.map/r_vpoints.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -106,10 +106,10 @@
 	    G_strip(data);
-	    if (G_strstr(data, "point"))
+	    if (strstr(data, "point"))
 		vector.layer[vec].ltype |= GV_POINT;
-	    if (G_strstr(data, "centroid"))
+	    if (strstr(data, "centroid"))
 		vector.layer[vec].ltype |= GV_CENTROID;
 	    continue;
Modified: grass/trunk/ps/ps.map/scale.c
--- grass/trunk/ps/ps.map/scale.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/ps/ps.map/scale.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -102,22 +102,22 @@
 	/* unit2: meters, miles, kilometers */
 	if (strncmp(unit2, "mile", 4) == 0) {
 	    u2 = MILES_TO_INCHES;
-	    G_strcpy(unit2, "mile");
+	    strcpy(unit2, "mile");
 	else if (strncmp(unit2, "meter", 5) == 0) {
 	    u2 = METERS_TO_INCHES;
-	    G_strcpy(unit2, "meter");
+	    strcpy(unit2, "meter");
 	else if (strncmp(unit2, "kilometer", 9) == 0) {
 	    u2 = METERS_TO_INCHES * 1000;
-	    G_strcpy(unit2, "kilometer");
+	    strcpy(unit2, "kilometer");
 	else
 	    OOPS();
 	u2 *= n2;
-	G_strcpy(unit1, "inch");
-	G_strcpy(equals, "equal");
+	strcpy(unit1, "inch");
+	strcpy(equals, "equal");
 	if (n1 == 1)
 	    strcat(equals, "s");
 	else
Modified: grass/trunk/raster/r.in.ascii/gethead.c
--- grass/trunk/raster/r.in.ascii/gethead.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/raster/r.in.ascii/gethead.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -110,7 +110,7 @@
 	len = strlen(buf);
 	*label = *value = '\0';
-	if (NULL == G_strstr(buf, ":"))
+	if (NULL == strstr(buf, ":"))
 	    break;
 	if (sscanf(buf, "%[^:]:%s", label, value) != 2)
 	    break;
Modified: grass/trunk/raster/r.le/r.le.patch/driver.c
--- grass/trunk/raster/r.le/r.le.patch/driver.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/raster/r.le/r.le.patch/driver.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -2644,35 +2644,35 @@
 	    if (i == 0)
-		G_strcpy(istr, "1");
+		strcpy(istr, "1");
 	    else if (i == 1)
-		G_strcpy(istr, "2");
+		strcpy(istr, "2");
 	    else if (i == 2)
-		G_strcpy(istr, "3");
+		strcpy(istr, "3");
 	    else if (i == 3)
-		G_strcpy(istr, "4");
+		strcpy(istr, "4");
 	    else if (i == 4)
-		G_strcpy(istr, "5");
+		strcpy(istr, "5");
 	    else if (i == 5)
-		G_strcpy(istr, "6");
+		strcpy(istr, "6");
 	    else if (i == 6)
-		G_strcpy(istr, "7");
+		strcpy(istr, "7");
 	    else if (i == 7)
-		G_strcpy(istr, "8");
+		strcpy(istr, "8");
 	    else if (i == 8)
-		G_strcpy(istr, "9");
+		strcpy(istr, "9");
 	    else if (i == 9)
-		G_strcpy(istr, "10");
+		strcpy(istr, "10");
 	    else if (i == 10)
-		G_strcpy(istr, "11");
+		strcpy(istr, "11");
 	    else if (i == 11)
-		G_strcpy(istr, "12");
+		strcpy(istr, "12");
 	    else if (i == 12)
-		G_strcpy(istr, "13");
+		strcpy(istr, "13");
 	    else if (i == 13)
-		G_strcpy(istr, "14");
+		strcpy(istr, "14");
 	    else if (i == 14)
-		G_strcpy(istr, "15");
+		strcpy(istr, "15");
 	    else if (i > 14) {
 		fprintf(stderr, "\n");
 		fprintf(stderr,
@@ -2700,8 +2700,8 @@
 	/* if a map of the sampling units
 	   was requested */
 	if (choice->units) {
-	    G_strcpy(unitname, "units_");
-	    G_strcat(unitname, istr);
+	    strcpy(unitname, "units_");
+	    strcat(unitname, istr);
 	    fd = G_open_raster_new(unitname, CELL_TYPE);
 	    unit_buf = G_allocate_raster_buf(CELL_TYPE);
 	    for (k = 1; k < wind.rows + 1; k++) {
Modified: grass/trunk/raster/r.le/r.le.patch/input.c
--- grass/trunk/raster/r.le/r.le.patch/input.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/raster/r.le/r.le.patch/input.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -205,12 +205,12 @@
     /* record the user inputs for map,
        sam and out parameters */
-    G_strcpy(choice->fn, name->answer);
+    strcpy(choice->fn, name->answer);
     choice->wrum = sampling_method->answer[0];
     if (out->answer && choice->wrum != 'm')
-	G_strcpy(choice->out, out->answer);
+	strcpy(choice->out, out->answer);
     else if (out->answer && choice->wrum == 'm') {
 	fprintf(stderr,
@@ -222,7 +222,7 @@
 	exit(EXIT_FAILURE);
     else
-	G_strcpy(choice->out, "");
+	strcpy(choice->out, "");
     /* check for unacceptable values for
        input parameters for sam */
@@ -405,7 +405,7 @@
     if (!strcmp(sampling_method->answer, "r")) {
 	if (region->answer)
-	    G_strcpy(choice->reg, region->answer);
+	    strcpy(choice->reg, region->answer);
 	else {
 	    fprintf(stderr,
Modified: grass/trunk/raster/r.le/r.le.pixel/driver.c
--- grass/trunk/raster/r.le/r.le.pixel/driver.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/raster/r.le/r.le.pixel/driver.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -1464,35 +1464,35 @@
 	    if (i == 0)
 	    else if (i == 1)
 	    else if (i == 2)
 	    else if (i == 3)
 	    else if (i == 4)
 	    else if (i == 5)
 	    else if (i == 6)
 	    else if (i == 7)
 	    else if (i == 8)
 	    else if (i == 9)
 	    else if (i == 10)
 	    else if (i == 11)
 	    else if (i == 12)
 	    else if (i == 13)
 	    else if (i == 14)
 	    else if (i > 14) {
 		fprintf(stdout, "\n");
 		fprintf(stdout,
@@ -1522,8 +1522,8 @@
 	   was requested */
Modified: grass/trunk/raster/r.le/r.le.pixel/input.c
--- grass/trunk/raster/r.le/r.le.pixel/input.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/raster/r.le/r.le.pixel/input.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -151,7 +151,7 @@
        sam, run, and out parameters */
@@ -217,7 +217,7 @@
 	if (region->answer)
 	else {
 	    fprintf(stdout,
Modified: grass/trunk/raster/r.le/r.le.trace/user_input.c
--- grass/trunk/raster/r.le/r.le.trace/user_input.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/raster/r.le/r.le.trace/user_input.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -54,12 +54,12 @@
 	exit(EXIT_FAILURE);
     if (out->answer)
     else
     /* if the 4 neighbor tracing flag -t
        is specified, then set the
Modified: grass/trunk/raster/r.out.bin/main.c
--- grass/trunk/raster/r.out.bin/main.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/raster/r.out.bin/main.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -112,9 +112,9 @@
     name = parm.input->answer;
     if (parm.output->answer)
-	G_strncpy(outfile, parm.output->answer, sizeof(outfile) - 1);
+	strncpy(outfile, parm.output->answer, sizeof(outfile) - 1);
     else {
-	G_strncpy(outfile, name, sizeof(outfile) - 1 - 4);
+	strncpy(outfile, name, sizeof(outfile) - 1 - 4);
 	strcat(outfile, ".bin");
Modified: grass/trunk/raster/r.surf.fractal/write_rast.c
--- grass/trunk/raster/r.surf.fractal/write_rast.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/raster/r.surf.fractal/write_rast.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -52,7 +52,7 @@
     if (Steps != step)
 	sprintf(file_name, "%s.%d", rast_out_name, step);
     else
-	G_strcpy(file_name, rast_out_name);
+	strcpy(file_name, rast_out_name);
     if ((fd_out = G_open_raster_new(file_name, DCELL_TYPE)) < 0) {
 	G_fatal_error(_("ERROR: Problem opening output file."));
Modified: grass/trunk/raster/r.watershed/shed/com_line.c
--- grass/trunk/raster/r.watershed/shed/com_line.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/raster/r.watershed/shed/com_line.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -417,14 +417,14 @@
 int com_line_add(char **com_line, char *prompt, char *map_layer, char *mapset)
-    G_strcat(*com_line, prompt);
-    G_strcat(*com_line, "\"");
-    G_strcat(*com_line, map_layer);
+    strcat(*com_line, prompt);
+    strcat(*com_line, "\"");
+    strcat(*com_line, map_layer);
     if (mapset) {
-	G_strcat(*com_line, "@");
-	G_strcat(*com_line, mapset);
+	strcat(*com_line, "@");
+	strcat(*com_line, mapset);
     return 0;
@@ -439,7 +439,7 @@
     if (i < 1)
 	i = 1;
     sprintf(buf, " t=%d", i);
-    G_strcat(*com_line, buf);
+    strcat(*com_line, buf);
     return 0;
@@ -448,9 +448,9 @@
     char buf[20];
     sprintf(buf, "%d", ril_value);
     return 0;
Property changes on: grass/trunk/sites/s.in.ascii
___________________________________________________________________
   + *.tmp.html
*OBJ*
Modified: grass/trunk/sites/s.in.ascii/get_site.c
--- grass/trunk/sites/s.in.ascii/get_site.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/sites/s.in.ascii/get_site.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -124,13 +124,13 @@
 	    if (n == 0) {
 		    sscanf(ebuf, "%d", &itmp) == 1) {
 		    site->cattype = CELL_TYPE;
 		    site->ccat = itmp;
 		    n++;
 			 sscanf(ebuf, "%f", &ftmp) == 1) {
 		    site->cattype = FCELL_TYPE;
 		    site->fcat = ftmp;
@@ -180,7 +180,7 @@
 		if ((err = cleanse_string(buf)) > 0) {
-		    G_strncpy(site->str_att[c++], buf, err);
+		    strncpy(site->str_att[c++], buf, err);
 		    buf += err;
 		else
@@ -209,7 +209,7 @@
 	       if ((err = cleanse_string (buf)) > 0) {
-	       G_strncpy (site->str_att[c++], buf, err);
+	       strncpy (site->str_att[c++], buf, err);
 	       buf += err;
 	       else *buf = '\0';
@@ -258,7 +258,7 @@
 		    buf += err;
 		else
Modified: grass/trunk/sites/s.in.ascii/main.c
--- grass/trunk/sites/s.in.ascii/main.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/sites/s.in.ascii/main.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -183,22 +183,22 @@
 	sprintf(xbuf, "%s|", nbuf);
     if (has_cat) {
 	case CELL_TYPE:
 	    sprintf(xbuf, "#%d ", s->ccat);
 	    break;
 	case FCELL_TYPE:
 	    sprintf(xbuf, "#%g ", s->fcat);
 	    break;
 	case DCELL_TYPE:
 	    sprintf(xbuf, "#%g ", s->dcat);
 	    break;
@@ -207,14 +207,14 @@
 	/* we create a #cat entry in site_list from the current site number 11/99 */
 	sprintf(xbuf, "#%d ", loop);
 	loop++;
     /* now import attributes */
 	sprintf(xbuf, "%%%s ", nbuf);
@@ -238,16 +238,16 @@
 		xbuf[k] = (char)NULL;
 	    else
 		sprintf(xbuf, "@\"%s\" ", s->str_att[i]);
 	    else
 		sprintf(xbuf, "@%s ", s->str_att[i]);
     fprintf(fptr, "%s\n", buf);
Property changes on: grass/trunk/sites/s.out.ascii
   + *.tmp.html
*OBJ*
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/vector/v.in.ogr/main.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -650,7 +650,7 @@
 		else {
 		    /* Change column names to [A-Za-z][A-Za-z0-9_]* */
-		    Ogr_fieldname = G_strdup(OGR_Fld_GetNameRef(Ogr_field));
+		    Ogr_fieldname = G_store(OGR_Fld_GetNameRef(Ogr_field));
 		    G_debug(3, "Ogr_fieldname: '%s'", Ogr_fieldname);
 		    G_str_to_sql(Ogr_fieldname);
Modified: grass/trunk/vector/v.label.sa/labels.c
--- grass/trunk/vector/v.label.sa/labels.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/vector/v.label.sa/labels.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -188,7 +188,7 @@
 	if (strlen(db_get_string(&value)) == 0)
 	    continue;
-	labels[i].text = G_strdup(db_get_string(&value));
+	labels[i].text = G_store(db_get_string(&value));
 	labels[i].cat = cat;
 	labels[i].type = type;
 	labels[i].shape = Points;
Modified: grass/trunk/vector/v.out.svg/main.c
--- grass/trunk/vector/v.out.svg/main.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/vector/v.out.svg/main.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -378,7 +378,7 @@
 	    Column = db_get_table_column(Table, attr_cols[i]);
 	    Value = db_get_column_value(Column);
 	    db_convert_column_value_to_string(Column, &dbstring);
-	    G_strcpy(buf, db_get_column_name(Column));
+	    strcpy(buf, db_get_column_name(Column));
 	    fprintf(fpsvg, "gg:%s=\"", G_tolcase(buf));
 	    print_escaped_for_xml(db_get_string(&dbstring));
 	    fprintf(fpsvg, "\" ");
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c	2008-08-08 04:35:12 UTC (rev 32633)
+++ grass/trunk/vector/v.transform/main.c	2008-08-08 05:31:22 UTC (rev 32634)
@@ -191,8 +191,8 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    G_strcpy(Current.name, vold->answer);
-    G_strcpy(Trans.name, vnew->answer);
+    strcpy(Current.name, vold->answer);
+    strcpy(Trans.name, vnew->answer);
     Vect_check_input_output_name(vold->answer, vnew->answer, GV_FATAL_EXIT);
@@ -219,7 +219,7 @@
     if (pointsfile->answer != NULL && !shift_flag->answer) {
-	G_strcpy(Coord.name, pointsfile->answer);
+	strcpy(Coord.name, pointsfile->answer);
     else {
 	Coord.name[0] = '\0';
