[GRASS-SVN] r32637 - in grass/trunk/lib/db: . dbmi_client dbmi_driver
Fri Aug 8 05:18:01 EDT 2008
Author: martinl
Date: 2008-08-08 05:18:01 -0400 (Fri, 08 Aug 2008)
New Revision: 32637
   grass/trunk/lib/db/dbmi_client/c_drop_col.c
   grass/trunk/lib/db/dbmi_client/c_execute.c
   grass/trunk/lib/db/dbmi_client/c_list_tabs.c
   grass/trunk/lib/db/dbmi_client/c_openupdate.c
   grass/trunk/lib/db/dbmi_client/c_priv.c
   grass/trunk/lib/db/dbmi_driver/d_add_col.c
   grass/trunk/lib/db/dbmi_driver/d_begin_work.x
   grass/trunk/lib/db/dbmi_driver/d_bindupdate.c
   grass/trunk/lib/db/dbmi_driver/d_close_cur.c
   grass/trunk/lib/db/dbmi_driver/d_closedb.c
   grass/trunk/lib/db/dbmi_driver/d_create_idx.c
   grass/trunk/lib/db/dbmi_driver/d_create_tab.c
   grass/trunk/lib/db/dbmi_driver/d_createdb.c
   grass/trunk/lib/db/dbmi_driver/d_delete.c
   grass/trunk/lib/db/dbmi_driver/d_deletedb.c
   grass/trunk/lib/db/dbmi_driver/d_desc_table.c
   grass/trunk/lib/db/dbmi_driver/d_drop_col.c
   grass/trunk/lib/db/dbmi_driver/d_drop_index.c
   grass/trunk/lib/db/dbmi_driver/d_drop_tab.c
   grass/trunk/lib/db/dbmi_driver/d_execute.c
   grass/trunk/lib/db/dbmi_driver/d_fetch.c
   grass/trunk/lib/db/dbmi_driver/d_finddb.c
   grass/trunk/lib/db/dbmi_driver/d_insert.c
   grass/trunk/lib/db/dbmi_driver/d_list_idx.c
   grass/trunk/lib/db/dbmi_driver/d_list_tabs.c
   grass/trunk/lib/db/dbmi_driver/d_listdb.c
   grass/trunk/lib/db/dbmi_driver/d_mkdir.c
   grass/trunk/lib/db/dbmi_driver/d_opendb.c
   grass/trunk/lib/db/dbmi_driver/d_openinsert.c
   grass/trunk/lib/db/dbmi_driver/d_openselect.c
   grass/trunk/lib/db/dbmi_driver/d_openupdate.c
   grass/trunk/lib/db/dbmi_driver/d_priv.c
   grass/trunk/lib/db/dbmi_driver/d_rows.c
   grass/trunk/lib/db/dbmi_driver/d_update.c
   grass/trunk/lib/db/dbmi_driver/d_version.c
   grass/trunk/lib/db/dbmi_driver/driver.c
   grass/trunk/lib/db/dbmi_driver/driver_state.c
   grass/trunk/lib/db/dbmilib.dox
dbmilib: initial doxygenization of dbmi_driver (merge from devbr6, r32636)
Modified: grass/trunk/lib/db/dbmi_client/c_drop_col.c
--- grass/trunk/lib/db/dbmi_client/c_drop_col.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_client/c_drop_col.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -16,7 +16,7 @@
 #include "macros.h"
-  \brief driver db driver
+  \brief Drop column
   \param driver db driver
   \param tableName table name
Modified: grass/trunk/lib/db/dbmi_client/c_execute.c
--- grass/trunk/lib/db/dbmi_client/c_execute.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_client/c_execute.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -48,7 +48,7 @@
   \brief Begin transaction
-  \return driver db driver
+  \param driver db driver
   \return DB_OK on success
   \return DB_FAILED on failure
Modified: grass/trunk/lib/db/dbmi_client/c_list_tabs.c
--- grass/trunk/lib/db/dbmi_client/c_list_tabs.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_client/c_list_tabs.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -36,8 +36,7 @@
-int
-db_list_tables(dbDriver * driver, dbString ** names, int *count, int system)
+int db_list_tables(dbDriver * driver, dbString ** names, int *count, int system)
     int ret_code;
Modified: grass/trunk/lib/db/dbmi_client/c_openupdate.c
--- grass/trunk/lib/db/dbmi_client/c_openupdate.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_client/c_openupdate.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -27,7 +27,6 @@
 int db_open_update_cursor(dbDriver * driver, dbString * table_name,
 			  dbString * select, dbCursor * cursor, int mode)
Modified: grass/trunk/lib/db/dbmi_client/c_priv.c
--- grass/trunk/lib/db/dbmi_client/c_priv.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_client/c_priv.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -16,7 +16,7 @@
 #include "macros.h"
-  \brief Grant privileges
+  \brief Grant privileges on table
Modified: grass/trunk/lib/db/dbmi_driver/d_add_col.c
--- grass/trunk/lib/db/dbmi_driver/d_add_col.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_add_col.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_add_col.c
+ * \brief DBMI Library (driver) - add column to table
+ * (C) 1999-2008 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+ * \author Joel Jones (CERL/UIUC), Radim Blazek
 #include <stdlib.h>
 #include <grass/dbmi.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
 #include "dbstubs.h"
-   \fn
-   \brief
-   \return
-   \param
-int db_d_add_column()
+   \brief Add column to table
+   \return DB_OK on success
+   \return DB_FAILED on failure
+int db_d_add_column(void)
     dbColumn column;
     dbString name;
Modified: grass/trunk/lib/db/dbmi_driver/d_begin_work.x
--- grass/trunk/lib/db/dbmi_driver/d_begin_work.x	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_begin_work.x	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,8 +1,27 @@
+ * \file db/dbmi_driver/d_begin_work.c
+ * \brief DBMI Library (driver) - ?
+ * for details.
 #include "dbmi.h"
 #include "macros.h"
-int
-db_d_begin_work()
+   \brief ?
+int db_d_begin_work(void)
     int stat;
     int result;
Modified: grass/trunk/lib/db/dbmi_driver/d_bindupdate.c
--- grass/trunk/lib/db/dbmi_driver/d_bindupdate.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_bindupdate.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_bindupdate.c
+ * \brief DBMI Library (driver) - bind update
+ * for details.
 #include "macros.h"
@@ -3,8 +17,8 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief ADD
 int db_d_bind_update()
Modified: grass/trunk/lib/db/dbmi_driver/d_close_cur.c
--- grass/trunk/lib/db/dbmi_driver/d_close_cur.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_close_cur.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_close_cur.c
+ * \brief DBMI Library (driver) - close cursor
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
-int db_d_close_cursor()
+  \brief Close cursor
+int db_d_close_cursor(void)
     dbCursor *cursor;
     dbToken token;
Modified: grass/trunk/lib/db/dbmi_driver/d_closedb.c
--- grass/trunk/lib/db/dbmi_driver/d_closedb.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_closedb.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_closedb.c
+ * \brief DBMI Library (driver) - close database connection
+ * for details.
 #include "macros.h"
@@ -3,10 +17,10 @@
-   \fn
-   \brief
-   \return
-   \param
-int db_d_close_database()
+  \brief Close database connection
+int db_d_close_database(void)
     int stat;
Modified: grass/trunk/lib/db/dbmi_driver/d_create_idx.c
--- grass/trunk/lib/db/dbmi_driver/d_create_idx.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_create_idx.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_create_idx.c
+ * \brief DBMI Library (driver) - create index
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
-int db_d_create_index()
+  \brief Create index
+int db_d_create_index(void)
     dbIndex index;
     int stat;
Modified: grass/trunk/lib/db/dbmi_driver/d_create_tab.c
--- grass/trunk/lib/db/dbmi_driver/d_create_tab.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_create_tab.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_create_tab.c
+ * \brief DBMI Library (driver) - create table
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Create table
-int db_d_create_table()
+int db_d_create_table(void)
     dbTable *table;
     int stat;
Modified: grass/trunk/lib/db/dbmi_driver/d_createdb.c
--- grass/trunk/lib/db/dbmi_driver/d_createdb.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_createdb.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_createdb.c
+ * \brief DBMI Library (driver) - create database
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Create database
-int db_d_create_database()
+int db_d_create_database(void)
     dbHandle handle;
     int stat;
Modified: grass/trunk/lib/db/dbmi_driver/d_delete.c
--- grass/trunk/lib/db/dbmi_driver/d_delete.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_delete.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_delete.c
+ * \brief DBMI Library (driver) - delete record
+ * for details.
 #include "macros.h"
@@ -3,10 +17,10 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Delete record (?)
-int db_d_delete()
+int db_d_delete(void)
     dbToken token;
Modified: grass/trunk/lib/db/dbmi_driver/d_deletedb.c
--- grass/trunk/lib/db/dbmi_driver/d_deletedb.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_deletedb.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_deletedb.c
+ * \brief DBMI Library (driver) - delete database
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Delete database
-int db_d_delete_database()
+int db_d_delete_database(void)
     dbHandle handle;
     int stat;
Modified: grass/trunk/lib/db/dbmi_driver/d_desc_table.c
--- grass/trunk/lib/db/dbmi_driver/d_desc_table.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_desc_table.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_desc_table.c
+ * \brief DBMI Library (driver) - describe table
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Describe table
-int db_d_describe_table()
+int db_d_describe_table(void)
     dbTable *table;
     dbString name;
Modified: grass/trunk/lib/db/dbmi_driver/d_drop_col.c
--- grass/trunk/lib/db/dbmi_driver/d_drop_col.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_drop_col.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_drop_col.c
+ * \brief DBMI Library (driver) - drop column
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
-int db_d_drop_column()
+int db_d_drop_column(void)
     dbString tableName;
     dbString columnName;
Modified: grass/trunk/lib/db/dbmi_driver/d_drop_index.c
--- grass/trunk/lib/db/dbmi_driver/d_drop_index.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_drop_index.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_drop_index.c
+ * \brief DBMI Library (driver) - drop index
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,11 +18,11 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Drop index
 int db_d_drop_index(void)
     dbString name;
Modified: grass/trunk/lib/db/dbmi_driver/d_drop_tab.c
--- grass/trunk/lib/db/dbmi_driver/d_drop_tab.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_drop_tab.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_drop_tab.c
+ * \brief DBMI Library (driver) - drop table
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,10 +18,10 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Drop table
 int db_d_drop_table(void)
Modified: grass/trunk/lib/db/dbmi_driver/d_execute.c
--- grass/trunk/lib/db/dbmi_driver/d_execute.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_execute.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_execute.c
+ * \brief DBMI Library (driver) - execute SQL statements
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Execute SQL statements
-int db_d_execute_immediate()
+int db_d_execute_immediate(void)
     int stat;
     dbString SQLstatement;
@@ -34,12 +48,12 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Begin transaction
-int db_d_begin_transaction()
+int db_d_begin_transaction(void)
     int stat;
@@ -58,10 +72,12 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Commit transaction
 int db_d_commit_transaction()
Modified: grass/trunk/lib/db/dbmi_driver/d_fetch.c
--- grass/trunk/lib/db/dbmi_driver/d_fetch.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_fetch.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_fetch.c
+ * \brief DBMI Library (driver) - fetch data
+ * for details.
 #include "macros.h"
@@ -5,12 +19,11 @@
 static int valid_cursor(dbCursor * cursor, int position);
+  \brief Fetch data
-   \fn
-   \brief
-   \return
-   \param
 int db_d_fetch(void)
Modified: grass/trunk/lib/db/dbmi_driver/d_finddb.c
--- grass/trunk/lib/db/dbmi_driver/d_finddb.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_finddb.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_finddb.c
+ * \brief DBMI Library (driver) - find database
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Find database
-int db_d_find_database()
+int db_d_find_database(void)
     dbHandle handle;
     int found;
Modified: grass/trunk/lib/db/dbmi_driver/d_insert.c
--- grass/trunk/lib/db/dbmi_driver/d_insert.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_insert.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_insert.c
+ * \brief DBMI Library (driver) - insert new record
+ * for details.
 #include "macros.h"
@@ -3,10 +17,10 @@
-   \fn
-   \brief
-   \return
-   \param
-int db_d_insert()
+  \brief Insert new record into table
+int db_d_insert(void)
     dbToken token;
Modified: grass/trunk/lib/db/dbmi_driver/d_list_idx.c
--- grass/trunk/lib/db/dbmi_driver/d_list_idx.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_list_idx.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_list_idx.c
+ * \brief DBMI Library (driver) - list indexes
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief List indexes
-int db_d_list_indexes()
+int db_d_list_indexes(void)
     dbIndex *list;
     dbString table_name;
Modified: grass/trunk/lib/db/dbmi_driver/d_list_tabs.c
--- grass/trunk/lib/db/dbmi_driver/d_list_tabs.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_list_tabs.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_list_tabs.c
+ * \brief DBMI Library (driver) - list tables
+ * for details.
 #include "macros.h"
@@ -3,10 +17,10 @@
-   \fn
-   \brief
-   \return
-   \param
+   \brief List available tables for given connection
-int db_d_list_tables()
+int db_d_list_tables(void)
     dbString *names;
Modified: grass/trunk/lib/db/dbmi_driver/d_listdb.c
--- grass/trunk/lib/db/dbmi_driver/d_listdb.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_listdb.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_listdb.c
+ * \brief DBMI Library (driver) - list databases
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,11 +18,11 @@
-   \fn int db_d_list_databases(void)
-   \brief
-   \return
-   \param
+  \brief List databases
     dbHandle *handles;
Modified: grass/trunk/lib/db/dbmi_driver/d_mkdir.c
--- grass/trunk/lib/db/dbmi_driver/d_mkdir.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_mkdir.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_mkdir.c
+ * \brief DBMI Library (driver) - creare directories
+ * for details.
 #include <string.h>
 #include <unistd.h>
 #include <sys/stat.h>
@@ -12,11 +26,15 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Create db directory
+  \param path full path
+  \param mode mode
+  \param parentdirs parent directories
 int db_driver_mkdir(const char *path, int mode, int parentdirs)
     if (parentdirs) {
Modified: grass/trunk/lib/db/dbmi_driver/d_opendb.c
--- grass/trunk/lib/db/dbmi_driver/d_opendb.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_opendb.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_opendb.c
+ * \brief DBMI Library (driver) - open database connection
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Open database connection
-int db_d_open_database()
+int db_d_open_database(void)
     dbHandle handle;
     int stat;
Modified: grass/trunk/lib/db/dbmi_driver/d_openinsert.c
--- grass/trunk/lib/db/dbmi_driver/d_openinsert.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_openinsert.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_openinsert.c
+ * \brief DBMI Library (driver) - open insert cursor
+ * for details.
 #include "macros.h"
@@ -3,10 +17,10 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Open insert cursor
-int db_d_open_insert_cursor()
+int db_d_open_insert_cursor(void)
     dbCursor *cursor;
Modified: grass/trunk/lib/db/dbmi_driver/d_openselect.c
--- grass/trunk/lib/db/dbmi_driver/d_openselect.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_openselect.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_openselect.c
+ * \brief DBMI Library (driver) - open select cursor
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Open select cursor
-int db_d_open_select_cursor()
+int db_d_open_select_cursor(void)
     dbCursor *cursor;
     int stat;
Modified: grass/trunk/lib/db/dbmi_driver/d_openupdate.c
--- grass/trunk/lib/db/dbmi_driver/d_openupdate.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_openupdate.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_openupdate.c
+ * \brief DBMI Library (driver) - open update cursor
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,12 +18,12 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Open update cursor
-int db_d_open_update_cursor()
+int db_d_open_update_cursor(void)
     dbCursor *cursor;
     int stat;
Modified: grass/trunk/lib/db/dbmi_driver/d_priv.c
--- grass/trunk/lib/db/dbmi_driver/d_priv.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_priv.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_priv.c
+ * \brief DBMI Library (driver) - privileges management
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -4,11 +18,12 @@
-   \brief Grant privileges on table
-   \return
-   \param
-int db_d_grant_on_table()
+int db_d_grant_on_table(void)
     dbString tableName;
     int priv, to;
Modified: grass/trunk/lib/db/dbmi_driver/d_rows.c
--- grass/trunk/lib/db/dbmi_driver/d_rows.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_rows.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_rows.c
+ * \brief DBMI Library (driver) - get number of records
+ * for details.
 #include "macros.h"
@@ -3,10 +17,10 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Get number of selected rows
-int db_d_get_num_rows()
+int db_d_get_num_rows(void)
     dbToken token;
Modified: grass/trunk/lib/db/dbmi_driver/d_update.c
--- grass/trunk/lib/db/dbmi_driver/d_update.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_update.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_update.c
+ * \brief DBMI Library (driver) - update statemets
+ * for details.
 #include "macros.h"
@@ -3,10 +17,10 @@
-   \fn
-   \brief
-   \return
-   \param
-int db_d_update()
+  \brief ?
+int db_d_update(void)
     dbToken token;
Modified: grass/trunk/lib/db/dbmi_driver/d_version.c
--- grass/trunk/lib/db/dbmi_driver/d_version.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/d_version.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/d_version.c
+ * \brief DBMI Library (driver) - version info
+ * for details.
 #include "macros.h"
@@ -2,8 +16,8 @@
-   \fn
-   \brief
-   \return
-   \param
-int db_d_version()
+  \brief Get version info
+int db_d_version(void)
Modified: grass/trunk/lib/db/dbmi_driver/driver.c
--- grass/trunk/lib/db/dbmi_driver/driver.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/driver.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,22 +1,19 @@
+ * \file db/dbmi_driver/driver.c
+ * \brief DBMI Library (driver) - drivers
- * MODULE:       DBMI library - drivers
- * AUTHOR(S):    Joel Jones (CERL/UIUC) <jjones zorro.cecer.army.mil>
- *               (overall original contributor of db libraries)
- *               This file (and driver directory) originates with GRASS 5.0:
- *               Radim Blazek <radim.blazek gmail.com> (original contributor)
- *               Glynn Clements <glynn gclements.plus.com>,
- *               Markus Neteler <neteler itc.it>,
- *               Huidae Cho <grass4u gmail.com>,
- * PURPOSE:      database management driver functions
- * COPYRIGHT:    (C) 2003-2006 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
+ * for details.
+ * \author Modified by Glynn Clements <glynn gclements.plus.com>,
+ * Markus Neteler <neteler itc.it>,
+ * Huidae Cho <grass4u gmail.com>
 #include <sys/types.h>
@@ -31,11 +28,12 @@
 extern char *getenv();
-   \fn int db_driver (int argc,
-   char *argv[])
-   \brief
-   \return
-   \param
+  \brief Get driver (?)
+  \param argc, argv arguments
+  \return 0 on success
+  \return 1 on failure
 int db_driver(int argc, char *argv[])
Modified: grass/trunk/lib/db/dbmi_driver/driver_state.c
--- grass/trunk/lib/db/dbmi_driver/driver_state.c	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmi_driver/driver_state.c	2008-08-08 09:18:01 UTC (rev 32637)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_driver/driver_state.c
+ * \brief DBMI Library (driver) - drivers state
+ * for details.
 #include <stdlib.h>
@@ -5,25 +19,41 @@
 static dbDriverState state;
+  \brief Initialize driver state
 void db__init_driver_state(void)
     db_zero((void *)&state, sizeof(state));
+  \brief Get driver state
+  \return pointer to dbDriverState
 dbDriverState *db__get_driver_state(void)
     return &state;
+  \brief Test database connection
+  \return 1 opened
+  \return 0 closed
 int db__test_database_open(void)
     return state.open ? 1 : 0;
+  \brief Mark database as opened
+  \param dbname database name
+  \param dbschema database schema name
 void db__mark_database_open(const char *dbname, const char *dbschema)
     state.dbname = db_store(dbname);
@@ -31,7 +61,9 @@
     state.open = 1;
+  \brief Mark database as closed
 void db__mark_database_closed(void)
     free(state.dbname);
@@ -39,7 +71,11 @@
     state.open = 0;
+  \brief Add cursor do driver state
+  \param cursor db cursor to be added
 void db__add_cursor_to_driver_state(dbCursor * cursor)
     dbCursor **list;
@@ -66,7 +102,11 @@
     list[i] = cursor;
+  \brief Drop cursor from driver state
+  \param cursor db cursor to be dropped
 void db__drop_cursor_from_driver_state(dbCursor * cursor)
     int i;
@@ -76,7 +116,9 @@
 	    state.cursor_list[i] = NULL;
+  \brief Close all cursors
 void db__close_all_cursors(void)
     int i;
Modified: grass/trunk/lib/db/dbmilib.dox
--- grass/trunk/lib/db/dbmilib.dox	2008-08-08 09:11:14 UTC (rev 32636)
+++ grass/trunk/lib/db/dbmilib.dox	2008-08-08 09:18:01 UTC (rev 32637)
@@ -176,10 +176,89 @@
  - db_update()
  - db__copy_table()
 \section dbmi_driver DBMI DRIVER functions
-[ to be moved here from below list ]
+ - db_driver()
+ - db_driver_mkdir()
+ - db_d_add_column()
+ - db_d_begin_transaction()
+ - db_d_bind_update()
+ - db_d_close_cursor()
+ - db_d_close_database()
+ - db_d_commit_transaction()
+ - db_d_create_database()
+ - db_d_create_index()
+ - db_d_create_table()
+ - db_d_delete()
+ - db_d_delete_database()
+ - db_d_describe_table()
+ - db_d_drop_column()
+ - db_d_drop_index()
+ - db_d_drop_table()
+ - db_d_execute_immediate()
+ - db_d_fetch()
+ - db_d_find_database()
+ - db_d_get_num_rows()
+ - db_d_grant_on_table()
+ - db_d_insert()
+ - db_d_list_databases()
+ - db_d_list_indexes()
+ - db_d_list_tables()
+ - db_d_open_database()
+ - db_d_open_insert_cursor()
+ - db_d_open_select_cursor()
+ - db_d_open_update_cursor()
+ - db_d_update()
+ - db_d_update()
+ - db__add_cursor_to_driver_state()
+ - db__close_all_cursors()
+ - db__drop_cursor_from_driver_state()
+ - db__init_driver_state()
+ - db__mark_database_closed()
+ - db__mark_database_open()
+ - db__test_database_open()
 \section dbmi_functions DBMI functions list (incomplete)
 \subsection DB_alloc_routines DB alloc routines
