[GRASS-SVN] r32651 - in grass/branches/develbranch_6: lib/ogsf visualization/nviz2/cmd
Sat Aug 9 05:37:38 EDT 2008
Author: martinl
Date: 2008-08-09 05:37:38 -0400 (Sat, 09 Aug 2008)
New Revision: 32651
   grass/branches/develbranch_6/lib/ogsf/GVL2.c
   grass/branches/develbranch_6/lib/ogsf/gvl.c
   grass/branches/develbranch_6/lib/ogsf/gvl_calc.c
   grass/branches/develbranch_6/visualization/nviz2/cmd/args.c
   grass/branches/develbranch_6/visualization/nviz2/cmd/local_proto.h
   grass/branches/develbranch_6/visualization/nviz2/cmd/main.c
   grass/branches/develbranch_6/visualization/nviz2/cmd/vector.c
   grass/branches/develbranch_6/visualization/nviz2/cmd/volume.c
nviz2/cli: volume support in progress (fundamental attributes: topo, color)
some doxygen/debug messages in ogsflib
Modified: grass/branches/develbranch_6/lib/ogsf/GVL2.c
--- grass/branches/develbranch_6/lib/ogsf/GVL2.c	2008-08-09 07:05:29 UTC (rev 32650)
+++ grass/branches/develbranch_6/lib/ogsf/GVL2.c	2008-08-09 09:37:38 UTC (rev 32651)
@@ -620,7 +620,7 @@
     geovol *gvl;
     geovol_isosurf *isosurf;
-    G_debug(3, "GVL_isosurf_add");
+    G_debug(3, "GVL_isosurf_add() id=%d", id);
     gvl = gvl_get_vol(id);
@@ -630,8 +630,8 @@
     if (gvl->n_isosurfs == MAX_ISOSURFS)
 	return (-1);
-    if (NULL ==
-	(isosurf = (geovol_isosurf *) G_malloc(sizeof(geovol_isosurf)))) {
+    isosurf = (geovol_isosurf *) G_malloc(sizeof(geovol_isosurf));
+    if (!isosurf) {
 	return (-1);
@@ -821,19 +821,29 @@
    \brief Set constant isosurface attribute
+   Attributes:
+    - ATT_NORM
+    - ATT_TOPO topography (level) constant
+    - ATT_COLOR color map/constant
+    - ATT_MASK mask map
+    - ATT_TRANSP transparency map/constant
+    - ATT_SHINE shininess map/constant
+    - ATT_EMIT emission map/constant
    \param id volume set id
-   \param isosurf_id isosurface id
-   \param att attribute id
+   \param isosurf_id isosurface id (0 - MAX_ISOSURFS)
+   \param att attribute descriptor
    \param constant constant value
-   \return ?
+   \return 1 on success
    \return -1 on error
 int GVL_isosurf_set_att_const(int id, int isosurf_id, int att, float constant)
-    G_debug(3, "GVL_isosurf_set_att_const");
+    G_debug(3, "GVL_isosurf_set_att_const() id=%d isosurf_id=%d "
+	    "att=%d const=%f", id, isosurf_id, att, constant);
     isosurf = gvl_isosurf_get_isosurf(id, isosurf_id);
@@ -847,12 +857,21 @@
    \brief Set isosurface map attribute
+   Attributes:
+    - ATT_NORM
    \param filename map name
-   \return ?
    \return -1 on error
 int GVL_isosurf_set_att_map(int id, int isosurf_id, int att,
@@ -860,7 +879,8 @@
-    G_debug(3, "GVL_isosurf_set_att_map");
+    G_debug(3, "GVL_isosurf_set_att_map(): id=%d, isosurf_id=%d "
+	    "att=%d map=%s", id, isosurf_id, att, filename);
Modified: grass/branches/develbranch_6/lib/ogsf/gvl.c
--- grass/branches/develbranch_6/lib/ogsf/gvl.c	2008-08-09 07:05:29 UTC (rev 32650)
+++ grass/branches/develbranch_6/lib/ogsf/gvl.c	2008-08-09 09:37:38 UTC (rev 32651)
@@ -527,6 +527,9 @@
 	isosurf->att[i].att_src = NOTSET_ATT;
 	isosurf->att[i].constant = 0.;
 	isosurf->att[i].hfile = -1;
+	isosurf->att[i].user_func = NULL;
+	isosurf->att[i].att_data = NULL;
+	isosurf->att[i].changed = 0;
     isosurf->data = NULL;
@@ -563,10 +566,10 @@
-   \brief Get geovol_isosurf struct of given volume set
+   \brief Get isosurface of given volume set
    \return pointer to geovol_isosurf struct
    \return NULL on failure
@@ -575,6 +578,9 @@
     geovol *gvl;
+    G_debug(5, "gvl_isosurf_get_isosurf(): id=%d isosurf=%d",
+	    id, isosurf_id);
     if (gvl) {
@@ -645,10 +651,10 @@
-   \brief Set attribute constant
+   \brief Set isosurface attribute constant
    \param isosurf pointer to geovol_isosurf struct
-   \param desc attribute id
+   \param desc attribute descriptor
    \param constant attribute value
    \return -1 on failure
@@ -657,7 +663,8 @@
 int gvl_isosurf_set_att_const(geovol_isosurf * isosurf, int desc,
 			      float constant)
-    G_debug(5, "gvl_isosurf_set_att_const");
+    G_debug(5, "gvl_isosurf_set_att_const(): att=%d, const=%f",
+	    desc, constant);
     if (isosurf) {
 	isosurf->att[desc].constant = constant;
@@ -685,7 +692,7 @@
     int hfile;
-    G_debug(5, "gvl_isosurf_set_att_map(): att_map: %s", filename);
+    G_debug(5, "gvl_isosurf_set_att_map(): att=%d map=%s", desc, filename);
     if (isosurf) {
 	if (0 > (hfile = gvl_file_newh(filename, VOL_FTYPE_G3D)))
Modified: grass/branches/develbranch_6/lib/ogsf/gvl_calc.c
--- grass/branches/develbranch_6/lib/ogsf/gvl_calc.c	2008-08-09 07:05:29 UTC (rev 32650)
+++ grass/branches/develbranch_6/lib/ogsf/gvl_calc.c	2008-08-09 09:37:38 UTC (rev 32651)
@@ -751,10 +751,14 @@
    \param pos position index
    \param data data buffer
-   \param char
+   \return char on success
+   \return NULL on failure
 unsigned char gvl_read_char(int pos, const unsigned char *data)
+    if (!data)
+	return NULL;
     return data[pos];
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/args.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/args.c	2008-08-09 07:05:29 UTC (rev 32650)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/args.c	2008-08-09 09:37:38 UTC (rev 32651)
@@ -289,7 +289,7 @@
     params->vlines->required = NO;
     params->vlines->description = _("Name of line vector overlay map(s)");
     params->vlines->guisection = _("Vector lines");
-    params->vlines->key = "vlines";
+    params->vlines->key = "vline";
     /* line width */
     params->vline_width = G_define_option();
@@ -346,7 +346,7 @@
     params->vpoints->required = NO;
     params->vpoints->description = _("Name of point vector overlay map(s)");
     params->vpoints->guisection = _("Vector points");
-    params->vpoints->key = "vpoints";
+    params->vpoints->key = "vpoint";
     /* point width */
     params->vpoint_size = G_define_option();
@@ -462,8 +462,64 @@
     params->volume = G_define_standard_option(G_OPT_R3_MAPS);
     params->volume->required = NO;
     params->volume->guisection = _("Volume");
-    params->volume->key = "rast3d";
+    params->volume->key = "volume";
+    /* mode */
+    params->volume_mode = G_define_option();
+    params->volume_mode->key = "volume_mode";
+    params->volume_mode->key_desc = "string";
+    params->volume_mode->type = TYPE_STRING;
+    params->volume_mode->required = YES;
+    params->volume_mode->multiple = YES;
+    params->volume_mode->description = _("Volume draw mode");
+    params->volume_mode->options = "isosurface,slice";
+    params->volume_mode->answer = "isosurface";
+    params->volume_mode->guisection = _("Draw");
+    /* shading */
+    params->volume_shade = G_define_option();
+    params->volume_shade->key = "volume_shading";
+    params->volume_shade->key_desc = "string";
+    params->volume_shade->type = TYPE_STRING;
+    params->volume_shade->required = YES;
+    params->volume_shade->multiple = YES;
+    params->volume_shade->description = _("Volume shading");
+    params->volume_shade->options = "flat,gouraud";
+    params->volume_shade->answer = "gouraud";
+    params->volume_shade->guisection = _("Draw");
+    /* position */
+    params->volume_pos = G_define_option();
+    params->volume_pos->key = "volume_position";
+    params->volume_pos->key_desc = "x,y,z";
+    params->volume_pos->type = TYPE_INTEGER;
+    params->volume_pos->required = YES;
+    params->volume_pos->multiple = YES;
+    params->volume_pos->description = _("Volume position");
+    params->volume_pos->guisection = _("Volume");
+    params->volume_pos->answer = "0,0,0";
+    /* resolution  */
+    params->volume_res = G_define_option();
+    params->volume_res->key = "volume_resolution";
+    params->volume_res->key_desc = "value";
+    params->volume_res->type = TYPE_INTEGER;
+    params->volume_res->required = YES;
+    params->volume_res->multiple = YES;
+    params->volume_res->description = _("Volume resolution");
+    params->volume_res->answer = "3";
+    params->volume_res->guisection = _("Volume");
+    /* isosurface level */
+    params->isosurf_level = G_define_option();
+    params->isosurf_level->key = "isosurf_level";
+    params->isosurf_level->key_desc = "volume:value";
+    params->isosurf_level->type = TYPE_STRING;
+    params->isosurf_level->required = NO;
+    params->isosurf_level->multiple = YES;
+    params->isosurf_level->description = _("Isosurface level");
+    params->isosurf_level->guisection = _("Volume");
     return;
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/local_proto.h
--- grass/branches/develbranch_6/visualization/nviz2/cmd/local_proto.h	2008-08-09 07:05:29 UTC (rev 32650)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/local_proto.h	2008-08-09 09:37:38 UTC (rev 32651)
@@ -20,7 +20,7 @@
     /* vector points */
       *vpoints, *vpoint_size, *vpoint_marker, *vpoint_color, *vpoint_width,
     /* volumes */
-      *volume,
+      *volume, *volume_mode, *volume_shade, *volume_pos, *volume_res, *isosurf_level,
     /* misc */
       *exag, *bgcolor,
     /* viewpoint */
@@ -40,13 +40,14 @@
 void surface_set_draw_mode(const struct GParams *);
 /* vector.c */
-int load_vector_lines(const struct GParams *, nv_data *);
-int load_vector_points(const struct GParams *, nv_data *);
+int load_vlines(const struct GParams *, nv_data *);
+int load_vpoints(const struct GParams *, nv_data *);
 int vlines_set_attrb(const struct GParams *);
 int vpoints_set_attrb(const struct GParams *);
 /* volume.c */
-int load_volume(const struct GParams *, nv_data *);
+int load_rasters3d(const struct GParams *, nv_data *);
+int add_isosurfs(const struct GParams *, nv_data *);
 /* write_img.c */
 int write_img(const char *, int);
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/main.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/main.c	2008-08-09 07:05:29 UTC (rev 32650)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/main.c	2008-08-09 09:37:38 UTC (rev 32651)
@@ -43,7 +43,7 @@
     G_gisinit(argv[0]);
     module = G_define_module();
-    module->keywords = _("visualization, raster, vector");
+    module->keywords = _("visualization, raster, vector, raster3d");
     module->description = _("Experimental NVIZ CLI prototype.");
     params = (struct GParams *)G_malloc(sizeof(struct GParams));
@@ -99,23 +99,28 @@
     /* load line vector maps */
     if (params->vlines->answer) {
-	load_vector_lines(params, &data);
+	load_vlines(params, &data);
 	/* set attributes of 2d lines */
 	vlines_set_attrb(params);
     /* load point vector maps */
     if (params->vpoints->answer) {
-	load_vector_points(params, &data);
+	load_vpoints(params, &data);
 	/* set attributes for 2d lines */
 	vpoints_set_attrb(params);
     /* load volumes */
     if (params->volume->answer) {
-	load_volume(params, &data);
+	load_rasters3d(params, &data);
+    /* define isosurfaces for displaying volumes */
+    if (params->isosurf_level->answer) {
+	add_isosurfs(params, &data);
     /* focus on loaded data */
     Nviz_set_focus_map(MAP_OBJ_UNDEFINED, -1);
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/vector.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/vector.c	2008-08-09 07:05:29 UTC (rev 32650)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/vector.c	2008-08-09 09:37:38 UTC (rev 32651)
@@ -32,7 +32,7 @@
    \return number of loaded vectors
-int load_vector_lines(const struct GParams *params, nv_data * data)
+int load_vlines(const struct GParams *params, nv_data * data)
     return load_vectors(params->elev_map, params->elev_const,
 			params->vlines, MAP_OBJ_VECT, data);
@@ -46,7 +46,7 @@
-int load_vector_points(const struct GParams *params, nv_data * data)
+int load_vpoints(const struct GParams *params, nv_data * data)
 			params->vpoints, MAP_OBJ_SITE, data);
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/volume.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/volume.c	2008-08-09 07:05:29 UTC (rev 32650)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/volume.c	2008-08-09 09:37:38 UTC (rev 32651)
@@ -14,6 +14,8 @@
    \date 2008
+#include <stdlib.h>
 #include <grass/G3d.h>
 #include <grass/glocale.h>
@@ -27,9 +29,9 @@
    \return number of loaded volumes
-int load_volume(const struct GParams *params, nv_data *data)
+int load_rasters3d(const struct GParams *params, nv_data *data)
-    int i, nvol;
+  int i, nvol, id;
     char *mapset;
     nvol = opt_get_num_answers(params->volume);
@@ -41,11 +43,65 @@
 			  params->volume->answers[i]);
-	Nviz_new_map_obj(MAP_OBJ_VOL,
-			 G_fully_qualified_name(params->volume->answers[i],
-						mapset),
-			 0.0, data);
+	id = Nviz_new_map_obj(MAP_OBJ_VOL,
+			      G_fully_qualified_name(params->volume->answers[i],
+						     mapset),
+			      0.0, data);
     return 1;
+  \brief Add isosurfaces and set their attributes
+  \param params module parameters
+  \param data nviz data
+  \return number of defined isosurfaces
+int add_isosurfs(const struct GParams *params, nv_data *data)
+    int i;
+    int num, level, nvols, *vol_list, id, nisosurfs;
+    char **tokens;
+    vol_list = GVL_get_vol_list(&nvols);
+    for (i = 0; params->isosurf_level->answers[i]; i++) {
+	tokens = G_tokenize(params->isosurf_level->answers[i], ":");
+	if (G_number_of_tokens(tokens) != 2)
+	    G_fatal_error(_("Error tokenize '%s'"),
+			  params->isosurf_level->answers[i]);
+	num = atoi(tokens[0]);
+	level = atoi(tokens[1]);
+	G_free_tokens(tokens);
+	if (num > nvols) {
+	    G_fatal_error(_("Volume set number %d is not available"),
+			  num);
+	id = vol_list[num-1];
+	if (GVL_isosurf_add(id) < 0) {
+	    G_fatal_error(_("Unable to add isosurface (volume set %d)"),
+			  id);
+	nisosurfs = GVL_isosurf_num_isosurfs(id);
+	/* topography (level) */
+	if (GVL_isosurf_set_att_const(id, nisosurfs-1, ATT_TOPO, level) < 0) {
+	    G_fatal_error(_("Unable to set isosurface (%d) attribute (%d) of volume %d"),
+			  nisosurfs-1, ATT_TOPO, id);
+	/* color */
+	if (GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_COLOR, params->volume->answers[0]) < 0) {
+			  nisosurfs-1, ATT_COLOR, id);
+    return 1;
