[GRASS-SVN] r32653 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules nviz scripts
svn_grass at osgeo.org
Sat Aug 9 09:05:45 EDT 2008
Author: martinl
Date: 2008-08-09 09:05:45 -0400 (Sat, 09 Aug 2008)
New Revision: 32653
grass/branches/develbranch_6/gui/wxpython/Makefile
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
grass/branches/develbranch_6/gui/wxpython/nviz/load.cpp
grass/branches/develbranch_6/gui/wxpython/nviz/nviz.h
grass/branches/develbranch_6/gui/wxpython/scripts/d.rast3d
wxGUI/nviz: volume support in progress, cosmetics in preferences dialog
Modified: grass/branches/develbranch_6/gui/wxpython/Makefile
--- grass/branches/develbranch_6/gui/wxpython/Makefile 2008-08-09 09:57:35 UTC (rev 32652)
+++ grass/branches/develbranch_6/gui/wxpython/Makefile 2008-08-09 13:05:45 UTC (rev 32653)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-SUBDIRS = docs
+SUBDIRS = docs scripts
include $(MODULE_TOPDIR)/include/Make/Platform.make
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-08-09 09:57:35 UTC (rev 32652)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-08-09 13:05:45 UTC (rev 32653)
@@ -2643,6 +2643,11 @@
self.toolbars['map'].Enable2D(False)
+ # update layer tree (-> enable 3d-rasters)
+ self.tree.EnableItemType(type='3d-raster', enable=True)
# update status bar
self.toggleStatus.Enable(False)
@@ -2727,7 +2732,12 @@
CloseButton(False).DestroyOnClose(True).
Layer(0))
self.MapWindow = self.MapWindow2D
+ # update layer tree (-> disable 3d-rasters)
+ self.tree.EnableItemType(type='3d-raster', enable=False)
self.toolbars['map'].combo.SetValue ("Tools")
self.toolbars['map'].Enable2D(True)
self.toggleStatus.Enable(True)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py 2008-08-09 09:57:35 UTC (rev 32652)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py 2008-08-09 13:05:45 UTC (rev 32653)
@@ -86,7 +86,7 @@
# list of loaded map layers
self.layers = {}
- for type in ('raster', 'vlines', 'vpoints'):
+ for type in ('raster', 'vlines', 'vpoints', '3d-raster'):
self.layers[type] = {}
self.layers[type]['name'] = []
self.layers[type]['id'] = []
@@ -122,7 +122,7 @@
self.Bind(wx.EVT_LEFT_UP, self.OnLeftUp)
self.Bind(wx.EVT_MOTION, self.OnMouseAction)
self.Bind(wx.EVT_MOUSE_EVENTS, self.OnMouseAction)
def OnEraseBackground(self, event):
pass # do nothing, to avoid flashing on MSW
@@ -331,7 +331,7 @@
while item and item.IsOk():
type = self.tree.GetPyData(item)[0]['type']
if not item.IsChecked() or \
- type not in ('raster', 'vector'):
+ type not in ('raster', 'vector', '3d-raster'):
item = self.tree.GetNextSibling(item)
continue
@@ -348,6 +348,8 @@
try:
if type == 'raster':
self.LoadRaster(item)
+ elif type == '3d-raster':
+ self.LoadRaster3d(item)
except gcmd.NvizError, e:
print >> sys.stderr, "Nviz:" + e.message
@@ -400,6 +402,12 @@
# reset to default properties (lines/points)
self.SetVectorDefaultProp(data['vector'])
+ data[nvizType] = {}
+ # reset to default properties
+ self.SetVolumeDefaultProp(data[nvizType])
else:
# check data
@@ -428,73 +436,131 @@
return data
def LoadRaster(self, item):
- """Load raster map and set surface attributes
+ """Load 2d raster map and set surface attributes
@param layer item
+ return self._loadRaster(item)
+ def LoadRaster3d(self, item):
+ """Load 3d raster map and set surface attributes
+ @param layer item
+ def _loadRaster(self, item):
+ """Load 2d/3d raster map and set its attributes
+ @param layer item
layer = self.tree.GetPyData(item)[0]['maplayer']
- if layer.type != 'raster':
+ if layer.type not in ('raster', '3d-raster'):
return
- id = self.nvizClass.LoadSurface(str(layer.name), None, None)
+ if layer.type == 'raster':
+ id = self.nvizClass.LoadSurface(str(layer.name), None, None)
+ nvizType = 'surface'
+ errorMsg = _("Loading raster map")
+ elif layer.type == '3d-raster':
+ id = self.nvizClass.LoadVolume(str(layer.name), None, None)
+ nvizType = 'volume'
+ errorMsg = _("Loading 3d raster map")
+ else:
+ id = -1
if id < 0:
- print >> sys.stderr, "Nviz:" + _("Loading raster map <%s> failed") % layer.name
+ if layer.type in ('raster', '3d-raster'):
+ print >> sys.stderr, "Nviz:" + "%s <%s> %s" % (errorMsg, layer.name, _("failed"))
+ else:
+ print >> sys.stderr, "Nviz:" + _("Unsupported layer type '%s'") % layer.type
- self.layers['raster']['name'].append(layer.name)
- self.layers['raster']['id'].append(id)
+ self.layers[layer.type]['name'].append(layer.name)
+ self.layers[layer.type]['id'].append(id)
# set default/workspace layer properties
- data = self.SetLayerData(item, id, 'surface')
+ data = self.SetLayerData(item, id, nvizType)
# update properties
self.UpdateLayerProperties(item)
# update tools window
if hasattr(self.parent, "nvizToolWin") and \
- item == self.GetSelectedLayer(type='item'):
+ item == self.GetSelectedLayer(type='item') and \
+ layer.type == 'raster':
toolWin = self.parent.nvizToolWin
win = toolWin.FindWindowById( \
toolWin.win['vector']['lines']['surface'])
- win.SetItems(self.layers['raster']['name'])
+ win.SetItems(self.layers[layer.type]['name'])
- toolWin.UpdatePage('surface')
- toolWin.SetPage('surface')
+ toolWin.UpdatePage(nvizType)
+ toolWin.SetPage(nvizType)
return id
def UnloadRaster(self, item):
- """Unload raster map
+ """Unload 2d raster map
+ @param layer item
+ return self._unloadRaster(item)
+ def UnloadRaster3d(self, item):
+ """Unload 3d raster map
+ @param layer item
+ def _unloadRaster(self, item):
+ """Unload 2d/3d raster map
@param item layer item
+ return
data = self.tree.GetPyData(item)[0]['nviz']
- id = data['surface']['object']['id']
+ unloadFn = self.nvizClass.UnloadSurface
+ errorMsg = _("Unable to unload raster map")
+ successMsg = _("Raster map")
+ else:
+ unloadFn = self.nvizClass.UnloadVolume
+ errorMsg = _("Unable to unload 3d raster map")
+ successMsg = _("3d raster map")
- if self.nvizClass.UnloadSurface(id) == 0:
- print >> sys.stderr, "Nviz:" + _("Unable to unload raster map <%s>") % layer.name
+ id = data[nvizType]['object']['id']
+ if unloadFn(id) == 0:
+ print >> sys.stderr, "Nviz:" + "%s <%s>" % (errorMsg, layer.name)
else:
- print "Nviz:" + _("Raster map <%s> unloaded successfully") % layer.name
+ print "Nviz:" + "%s <%s> %s" % (successMsg, layer.name, _("unloaded successfully"))
- data['surface'].pop('object')
+ data[nvizType].pop('object')
- idx = self.layers['raster']['id'].index(id)
- del self.layers['raster']['name'][idx]
- del self.layers['raster']['id'][idx]
+ idx = self.layers[layer.type]['id'].index(id)
+ del self.layers[layer.type]['name'][idx]
+ del self.layers[layer.type]['id'][idx]
- if hasattr(self.parent, "nvizToolWin"):
+ if hasattr(self.parent, "nvizToolWin") and \
# remove surface page
- if toolWin.notebook.GetSelection() == toolWin.page['surface']['id']:
- toolWin.notebook.RemovePage(toolWin.page['surface']['id'])
- toolWin.page['surface']['id'] = -1
+ if toolWin.notebook.GetSelection() == toolWin.page[nvizType]['id']:
+ toolWin.notebook.RemovePage(toolWin.page[nvizType]['id'])
+ toolWin.page[nvizType]['id'] = -1
toolWin.page['settings']['id'] = 1
def GetSurfaceMode(self, mode, style, shade, string=False):
@@ -785,6 +851,10 @@
self.update.append('vector:points:color')
self.update.append('vector:points:surface')
self.update.append('vector:points:height')
+ def SetVolumeDefaultProp(self, data):
+ """Set default volume properties"""
+ pass
def Reset(self):
"""Reset (unload data)"""
@@ -1066,6 +1136,8 @@
size = (size[0] + 25, size[0] + 20)
# vector page
self.__createVectorPage()
+ # volume page
+ self.__createVolumePage()
# settings page
self.__createSettingsPage()
self.page['settings'] = { 'id' : 1 }
@@ -1713,6 +1785,103 @@
return panel.GetBestSize()
+ def __createVolumePage(self):
+ """Create view settings page"""
+ panel = wx.Panel(parent=self.notebook, id=wx.ID_ANY)
+ self.page['volume'] = {}
+ self.page['volume']['id'] = -1
+ self.page['volume']['panel'] = panel.GetId()
+ pageSizer = wx.BoxSizer(wx.VERTICAL)
+ self.win['volume'] = {}
+ # volume attributes
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
+ label=" %s " % (_("Volume attributes")))
+ boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ gridSizer = wx.GridBagSizer(vgap=3, hgap=3)
+ self.win['volume']['attr'] = {}
+ row = 0
+ for code, attrb in (('topo', _("Topography level")),
+ ('color', _("Color")),
+ ('mask', _("Mask")),
+ ('transp', _("Transparency")),
+ ('shine', _("Shininess")),
+ ('emit', _("Emission"))):
+ self.win['volume'][code] = {}
+ gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label=attrb + ':'),
+ pos=(row, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+ use = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
+ choices = [_("map")])
+ if code not in ('topo', 'color', 'shine'):
+ use.Insert(item=_("unset"), pos=0)
+ self.win['volume'][code]['required'] = False
+ else:
+ self.win['surface'][code]['required'] = True
+ if code != 'mask':
+ use.Append(item=_('constant'))
+ self.win['surface'][code]['use'] = use.GetId()
+ use.Bind(wx.EVT_CHOICE, self.OnSurfaceUse)
+ gridSizer.Add(item=use, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(row, 1))
+ map = gselect.Select(parent=panel, id=wx.ID_ANY,
+ # size=globalvar.DIALOG_GSELECT_SIZE,
+ size=(200, -1),
+ type="raster")
+ self.win['volume'][code]['map'] = map.GetId() - 1 # FIXME
+ map.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
+ # changing map topography not allowed
+ if code == 'topo':
+ map.Enable(False)
+ gridSizer.Add(item=map, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(row, 2))
+ if code == 'color':
+ value = csel.ColourSelect(panel, id=wx.ID_ANY,
+ colour=UserSettings.Get(group='nviz', key='volume',
+ subkey=['color', 'value']))
+ value.Bind(csel.EVT_COLOURSELECT, self.OnSurfaceMap)
+ elif code == 'mask':
+ value = None
+ else:
+ value = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=0)
+ value.SetRange(minVal=-1e9, maxVal=1e9)
+ elif code in ('shine', 'transp', 'emit'):
+ value.SetRange(minVal=0, maxVal=255)
+ else:
+ value.SetRange(minVal=0, maxVal=100)
+ value.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
+ if value:
+ self.win['volume'][code]['const'] = value.GetId()
+ value.Enable(False)
+ gridSizer.Add(item=value, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(row, 3))
+ else:
+ self.win['volume'][code]['const'] = None
+ ### self.SetSurfaceUseMap(code) # -> enable map / disable constant
+ row += 1
+ boxSizer.Add(item=gridSizer, proportion=1,
+ flag=wx.ALL | wx.EXPAND, border=3)
+ pageSizer.Add(item=boxSizer, proportion=0,
+ flag=wx.EXPAND | wx.ALL,
+ border=5)
+ panel.SetSizer(pageSizer)
+ return panel.GetBestSize()
def __createSettingsPage(self):
"""Create settings page"""
@@ -1835,7 +2004,7 @@
hstep = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
initial=hvals['step'],
min=1,
- max=hvals['max']-1)
+ max=1e6)
self.win['settings']['view']['height']['step'] = hstep.GetId()
gridSizer.Add(item=hstep, pos=(2, 2),
@@ -2761,26 +2930,43 @@
page=panel,
text=" %s " % _("Layer properties"),
select=True)
self.UpdateSurfacePage(layer, data['surface'])
elif pageId == 'vector':
if self.notebook.GetSelection() != self.page['vector']['id']:
if self.page['surface']['id'] > -1:
self.notebook.RemovePage(self.page['surface']['id'])
self.page['surface']['id'] = -1
self.page['vector']['id'] = 1
self.page['settings']['id'] = 2
panel = wx.FindWindowById(self.page['vector']['panel'])
self.notebook.InsertPage(n=self.page['vector']['id'],
page=panel,
select=True)
+ self.UpdateVectorPage(layer, data['vector'])
+ elif pageId == 'volume':
+ if self.notebook.GetSelection() != self.page['volume']['id']:
+ if self.page['volume']['id'] > -1:
+ self.notebook.RemovePage(self.page['volume']['id'])
+ self.page['volume']['id'] = 1
+ self.page['settings']['id'] = 2
- self.UpdateVectorPage(layer, data['vector'])
+ panel = wx.FindWindowById(self.page['volume']['panel'])
+ self.notebook.InsertPage(n=self.page['volume']['id'],
+ page=panel,
+ text=" %s " % _("Layer properties"),
+ select=True)
+ self.UpdateVolumePage(layer, data['volume'])
self.pageChanging = False
def UpdateSurfacePage(self, layer, data):
@@ -2962,6 +3148,10 @@
win = self.FindWindowById(self.win['vector']['points']['height'][type])
win.SetValue(data['points']['height'])
+ def UpdateVolumePage(self, layer, data):
+ """Update volume layer properties page"""
+ pass
def SetPage(self, name):
"""Get named page"""
self.notebook.SetSelection(self.page[name]['id'])
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2008-08-09 09:57:35 UTC (rev 32652)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2008-08-09 13:05:45 UTC (rev 32653)
@@ -445,6 +445,12 @@
'height' : 0,
+ 'volume' : {
+ 'color' : {
+ 'map' : True,
+ 'value' : (0, 0, 0, 255), # constant: black
'settings': {
'general' : {
'bgcolor' : (255, 255, 255, 255), # white
@@ -1132,10 +1138,14 @@
box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Vector settings"))
sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- gridSizer = wx.FlexGridSizer (cols=6, hgap=3, vgap=3)
+ gridSizer = wx.FlexGridSizer (cols=7, hgap=3, vgap=3)
+ label=_("Display:")),
+ flag=wx.ALIGN_CENTER_VERTICAL)
for type in ('point', 'line', 'centroid', 'boundary',
- 'area', 'face'):
+ 'area', 'face'):
chkbox = wx.CheckBox(parent=panel, label=type)
checked = self.settings.Get(group='cmd', key='showType',
subkey=[type, 'enabled'])
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2008-08-09 09:57:35 UTC (rev 32652)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2008-08-09 13:05:45 UTC (rev 32653)
@@ -95,6 +95,10 @@
if len(self.cmdlist) == 0:
return None
+ # ignore in 2D
+ if self.type == '3d-raster':
+ return None
Debug.msg (3, "Layer.Render(): type=%s, name=%s" % \
(self.type, self.name))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-09 09:57:35 UTC (rev 32652)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-09 13:05:45 UTC (rev 32653)
@@ -1,23 +1,23 @@
-MODULE: wxgui_utils.py
+ at package wxgui_utils.py
-CLASSES:
- * AbstractLayer
- * Layer
- * LayerTree
+ at brief Utility classes for GRASS wxPython GUI. Main functions include
+tree control for GIS map layer management, command console, and
+command parsing.
-PURPOSE: Utility classes for GRASS wxPython GUI. Main functions include tree control
- for GIS map layer management, command console, and command parsing.
+Classes:
+ - AbstractLayer
+ - Layer
+ - LayerTree
-AUTHORS: The GRASS Development Team
- Michael Barton (Arizona State University)
- Jachym Cepicky (Mendel University of Agriculture)
- Martin Landa <landa.martin gmail.com>
-COPYRIGHT: (C) 2007-2008 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
+(C) 2007-2008 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Michael Barton (Arizona State University)
+ at author Jachym Cepicky (Mendel University of Agriculture)
+ at author Martin Landa <landa.martin gmail.com>
import os
@@ -663,7 +663,11 @@
# run properties dialog if no properties given
if len(cmd) == 0:
self.PropertiesDialog(layer, show=True)
+ if ltype == '3d-raster' and \
+ not self.mapdisplay.toolbars['nviz']:
+ self.EnableItem(layer, False)
else: # group
self.SetPyData(layer, ({'cmd': None,
'type' : ltype,
@@ -682,7 +686,7 @@
self.SetItemText(layer, name)
else:
ctrl.SetValue(lname)
# updated progress bar range (mapwindow statusbar)
if checked is True:
self.mapdisplay.onRenderGauge.SetRange(len(self.Map.GetListOfLayers(l_active=True)))
@@ -869,6 +873,8 @@
if checked: # enable
if mapLayer.type == 'raster':
self.mapdisplay.MapWindow.LoadRaster(item)
+ elif mapLayer.type == '3d-raster':
+ self.mapdisplay.MapWindow.LoadRaster3d(item)
elif mapLayer.type == 'vector':
self.mapdisplay.MapWindow.LoadVector(item)
@@ -877,6 +883,8 @@
self.mapdisplay.MapWindow.UnloadRaster(item)
+ self.mapdisplay.MapWindow.UnloadRaster3d(item)
self.mapdisplay.MapWindow.UnloadVector(item)
@@ -952,8 +960,11 @@
elif type == 'vector':
self.mapdisplay.nvizToolWin.UpdatePage('vector')
self.mapdisplay.nvizToolWin.SetPage('vector')
+ self.mapdisplay.nvizToolWin.UpdatePage('volume')
+ self.mapdisplay.nvizToolWin.SetPage('volume')
else:
- for page in ('surface', 'vector'):
+ for page in ('surface', 'vector', 'volume'):
pageId = self.mapdisplay.nvizToolWin.page[page]['id']
if pageId > -1:
self.mapdisplay.nvizToolWin.notebook.RemovePage(pageId)
@@ -1148,6 +1159,13 @@
mapWin.UnloadRaster(layer)
mapWin.LoadRaster(layer)
+ if mapWin.IsLoaded(layer):
+ mapWin.UnloadRaster3d(layer)
+ mapWin.LoadRaster3d(layer)
mapWin.UnloadVector(layer)
@@ -1239,6 +1257,15 @@
item = self.GetFirstChild(self.root)[0]
return self.__FindSubItemByData(item, key, value)
+ def EnableItemType(self, type, enable=True):
+ """Enable/disable items in layer tree"""
+ item = self.GetFirstChild(self.root)[0]
+ while item and item.IsOk():
+ ltype = self.GetPyData(item)[0]['maplayer'].type
+ if type == ltype:
+ self.EnableItem(item, enable)
+ item = self.GetNextSibling(item)
def __FindSubItemByData(self, item, key, value):
"""Support method for FindItemByValue"""
Modified: grass/branches/develbranch_6/gui/wxpython/nviz/load.cpp
--- grass/branches/develbranch_6/gui/wxpython/nviz/load.cpp 2008-08-09 09:57:35 UTC (rev 32652)
+++ grass/branches/develbranch_6/gui/wxpython/nviz/load.cpp 2008-08-09 13:05:45 UTC (rev 32653)
@@ -19,6 +19,7 @@
#include "nviz.h"
extern "C" {
+#include <grass/G3d.h>
#include <grass/glocale.h>
@@ -185,3 +186,85 @@
return 1;
+ \brief Load 3d raster map (volume)
+ \param name 3d raster map name
+ \param color_name 3d raster map for color (NULL for color_value)
+ \param color_value color string (named color or RGB triptet)
+ \return object id
+ \return -1 on failure
+int Nviz::LoadVolume(const char* name, const char *color_name, const char *color_value)
+ char *mapset;
+ int id;
+ mapset = G_find_grid3(name, "");
+ if (mapset == NULL) {
+ G_warning(_("3d raster map <%s> not found"),
+ name);
+ return -1;
+ /* topography */
+ id = Nviz_new_map_obj(MAP_OBJ_VOL,
+ G_fully_qualified_name(name, mapset), 0.0,
+ data);
+ if (color_name) { /* check for color map */
+ mapset = G_find_grid3(color_name, "");
+ color_name);
+ GVL_delete_vol(id);
+ return -1;
+ Nviz_set_attr(id, MAP_OBJ_VOL, ATT_COLOR, MAP_ATT,
+ G_fully_qualified_name(color_name, mapset), -1.0,
+ data);
+ else if (color_value) { /* check for color value */
+ Nviz_set_attr(id, MAP_OBJ_VOL, ATT_COLOR, CONST_ATT,
+ NULL, Nviz_color_from_str(color_value),
+ data);
+ else { /* use by default elevation map for coloring */
+ G_fully_qualified_name(name, mapset), -1.0,
+ data);
+ /* focus on loaded data */
+ Nviz_set_focus_map(MAP_OBJ_UNDEFINED, -1);
+ G_debug(1, "Nviz::LoadVolume(): name=%s -> id=%d", name, id);
+ return id;
+ \brief Unload volume
+ \param id volume id
+ \return 1 on success
+ \return 0 on failure
+int Nviz::UnloadVolume(int id)
+ if (!GVL_vol_exists(id)) {
+ return 0;
+ G_debug(1, "Nviz::UnloadVolume(): id=%d", id);
+ if (GVL_delete_vol(id) < 0)
+ return 0;
+ return 1;
Modified: grass/branches/develbranch_6/gui/wxpython/nviz/nviz.h
--- grass/branches/develbranch_6/gui/wxpython/nviz/nviz.h 2008-08-09 09:57:35 UTC (rev 32652)
+++ grass/branches/develbranch_6/gui/wxpython/nviz/nviz.h 2008-08-09 13:05:45 UTC (rev 32653)
@@ -64,6 +64,8 @@
int UnloadSurface(int);
int LoadVector(const char *, bool);
int UnloadVector(int, bool);
+ int LoadVolume(const char*, const char *, const char *);
+ int UnloadVolume(int);
/* draw.cpp */
void Draw(bool, bool, bool);
Modified: grass/branches/develbranch_6/gui/wxpython/scripts/d.rast3d
--- grass/branches/develbranch_6/gui/wxpython/scripts/d.rast3d 2008-08-09 09:57:35 UTC (rev 32652)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/d.rast3d 2008-08-09 13:05:45 UTC (rev 32653)
@@ -18,10 +18,10 @@
#%Module
#% description: Displays 3d raster data in the active frame on the graphics monitor.
-#% keywords: display, raster3d, voxel
+#% keywords: display, raster3d
#%End
#%option
-#% key: input
+#% key: map
#% type: string
#% gisprompt: old,grid3,3d-raster
#% description: 3D raster map to be displayed
