[GRASS-SVN] r32667 - in grass-addons/vector/voronoi: . demo
Sun Aug 10 10:00:11 EDT 2008
Author: pkelly
Date: 2008-08-10 10:00:11 -0400 (Sun, 10 Aug 2008)
New Revision: 32667
Added:
   grass-addons/vector/voronoi/demo/
   grass-addons/vector/voronoi/demo/Makefile
   grass-addons/vector/voronoi/demo/README
   grass-addons/vector/voronoi/demo/data_types.h
   grass-addons/vector/voronoi/demo/edge.c
   grass-addons/vector/voronoi/demo/edge.h
   grass-addons/vector/voronoi/demo/error.c
   grass-addons/vector/voronoi/demo/error.h
   grass-addons/vector/voronoi/demo/geom_primitives.h
   grass-addons/vector/voronoi/demo/geometry.c
   grass-addons/vector/voronoi/demo/geometry.h
   grass-addons/vector/voronoi/demo/in_out.c
   grass-addons/vector/voronoi/demo/in_out.h
   grass-addons/vector/voronoi/demo/main.c
   grass-addons/vector/voronoi/demo/memory.c
   grass-addons/vector/voronoi/demo/memory.h
Interim demo code (not yet a GRASS module and still with
bugs to be fixed and optimisations to be made) from Martin
Pavlovsky
Added: grass-addons/vector/voronoi/demo/Makefile
--- grass-addons/vector/voronoi/demo/Makefile	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/Makefile	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,37 @@
+CC	= gcc
+CFLAGS	= -O0 -g3 $$(pkg-config --cflags --libs cairo)
+LDFLAGS	= -lm
+INCS 	=\
+	data_types.h\
+	edge.h\
+	error.h\
+	geometry.h\
+	geom_primitives.h\
+	in_out.h\
+	memory.h\
+SRC 	=\
+	edge.c\
+	error.c\
+	in_out.c\
+	main.c\
+	memory.c\
+	geometry.c
+OBJS 	=\
+	edge.o\
+	error.o\
+	in_out.o\
+	main.o\
+	memory.o\
+	geometry.o
+TEXT	= Makefile README $(INCS) $(SRC)
+guibas-stolfi	: $(OBJS)
+	$(CC) -o $@ $(CFLAGS) $(OBJS) $(LDFLAGS)
+clean:
+	rm -f guibas-stolfi $(OBJS)
Added: grass-addons/vector/voronoi/demo/README
--- grass-addons/vector/voronoi/demo/README	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/README	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,39 @@
+                  Delaunay Triangulation Demonstration Code
+          (Guibas-Stolfi algorithm with winged edge data structure)
+Source code from Martin Pavlovsky, July 2008 as part of interim evaluation
+in the Google Summer of Code project "Reimplementation of v.voronoi and
+v.delaunay modules in the Vector library of GRASS GIS using more efficient
+algorithms".
+Description from the author:
+Date: Sun, 13 Jul 2008 18:57:46 +0200
+From: "Martin Pavlovsky" <mpavlovsky at gmail.com>
+To: "Paul Kelly" <paul-grass at stjohnspoint.co.uk>
+Subject: UPDATE: SVGAlib replaced with cairo, freezes are no longer present
+Source code in the attachement is just the implementation of the
+guibas-stolfi algorithm with winged-edge data structure, not an actual GRASS
+module. I will start working on the module itself as soon as I feel that the
+algorithm is robust and stable enough.
+Since I understand that it is almost impossible for a human to check if a
+triangulation of lets say 1000 or more sites is correct by just reading text
+output of the edges of the triangulation (e.g. pairs of the form:
+{edge_origin edge_destination}) I decided to use graphic library Cairo
+to visualize the triangulation.
+You can compile the sources using makefile included in the directory. Then
+you run the executable guibas-stolfi.
+The program generates the Delaunay-triangulation of N randomly generated
+sites(this is just for testing and presentation purposes). After starting
+the program, you are prompted to enter number of sites. After you run the
+program, you can find the visual output in file "dt.png".
+You may notice that triangulation for a higher number of sites (>500) are
+sometimes not correct(merging of two halves is not complete occasionaly). I
+am working on correcting this bug.
Added: grass-addons/vector/voronoi/demo/data_types.h
--- grass-addons/vector/voronoi/demo/data_types.h	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/data_types.h	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,27 @@
+#include <stdlib.h>
+#ifndef NULL
+#define NULL   0
+#endif
+#define TRUE   1
+#define FALSE  0
+typedef enum {left, right} side;
+typedef unsigned char boolean;
+struct vertex {
+    double x,y;
+    struct edge *entry_pt;
+struct edge {
+    struct vertex *org;
+    struct vertex *dest;
+    struct edge *onext;
+    struct edge *oprev;
+    struct edge *dnext;
+    struct edge *dprev;
+extern struct vertex *sites;
Added: grass-addons/vector/voronoi/demo/edge.c
--- grass-addons/vector/voronoi/demo/edge.c	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/edge.c	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,117 @@
+#include  "data_types.h"
+#include  "memory.h"
+#include  "edge.h"
+ *  Construct an edge from vertices v1, v2 and add it to rings of edges e1, e2
+struct edge *join(struct edge *e1, struct vertex *v1,
+                  struct edge *e2, struct vertex *v2, side s){
+    struct edge *new_edge;
+  /* v1, v2 - vertices to be joined.
+    e1, e2 - edges to which v1, v2 belong to */
+    new_edge = create_edge(v1, v2);
+    if (s == left) {
+        if (ORG(e1) == v1)
+            splice(OPREV(e1), new_edge, v1);
+        else
+            splice(DPREV(e1), new_edge, v1);
+        splice(e2, new_edge, v2);
+    } else {
+        splice(e1, new_edge, v1);
+        if (ORG(e2) == v2)
+            splice(OPREV(e2), new_edge, v2);
+        else
+            splice(DPREV(e2), new_edge, v2);
+    return new_edge;
+ *  Remove an edge.
+void delete_edge(struct edge *e){
+    struct vertex *u, *v;
+    /* Save destination and origin. */
+    u = ORG(e);
+    v = DEST(e);
+    /* Set entry points. */
+    if (u->entry_pt == e)
+        u->entry_pt = ONEXT(e);
+    if (v->entry_pt == e)
+        v->entry_pt = DNEXT(e);
+    /* Four edge references need adjustment */
+    if (ORG(ONEXT(e)) == u)
+        OPREV(ONEXT(e)) = OPREV(e);
+    else
+        DPREV(ONEXT(e)) = OPREV(e);
+    if (ORG(OPREV(e)) == u)
+        ONEXT(OPREV(e)) = ONEXT(e);
+    else
+        DNEXT(OPREV(e)) = ONEXT(e);
+    if (ORG(DNEXT(e)) == v)
+        OPREV(DNEXT(e)) = DPREV(e);
+    else
+        DPREV(DNEXT(e)) = DPREV(e);
+    if (ORG(DPREV(e)) == v)
+        ONEXT(DPREV(e)) = DNEXT(e);
+    else
+        DNEXT(DPREV(e)) = DNEXT(e);
+    free_edge(e);
+ /*  Add an edge to a ring of edges. */
+void splice(struct edge *a, struct edge *b, struct vertex *v){
+    struct edge *next;
+  /* b must be the unnattached edge and a must be the previous
+    ccw edge to b. */
+    if (ORG(a) == v) {
+        next = ONEXT(a);
+        ONEXT(a) = b;
+    } else {
+        next = DNEXT(a);
+        DNEXT(a) = b;
+    if (ORG(next) == v)
+        OPREV(next) = b;
+    else
+        DPREV(next) = b;
+    if (ORG(b) == v) {
+        ONEXT(b) = next;
+        OPREV(b) = a;
+    } else {
+        DNEXT(b) = next;
+        DPREV(b) = a;
+ //  Create a new edge and initialize it
+ struct edge *create_edge(struct vertex *v1, struct vertex *v2){
+    new_edge = get_edge();
+    DNEXT(new_edge) = DPREV(new_edge) = ONEXT(new_edge) = OPREV(new_edge) = new_edge;
+    ORG(new_edge) = v1;
+    DEST(new_edge) = v2;
+    if (v1->entry_pt == NULL)
+        v1->entry_pt = new_edge;
+    if (v2->entry_pt == NULL)
+        v2->entry_pt = new_edge;
+    return new_edge;
Added: grass-addons/vector/voronoi/demo/edge.h
--- grass-addons/vector/voronoi/demo/edge.h	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/edge.h	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,19 @@
+#define ORG(e)   ((e)->org)
+#define DEST(e)  ((e)->dest)
+#define ONEXT(e) ((e)->onext)
+#define OPREV(e) ((e)->oprev)
+#define DNEXT(e) ((e)->dnext)
+#define DPREV(e) ((e)->dprev)
+#define OTHER_VERTEX(e,p) (ORG(e) == p ? DEST(e) : ORG(e))
+#define NEXT(e,p)         (ORG(e) == p ? ONEXT(e) : DNEXT(e))
+#define PREV(e,p)         (ORG(e) == p ? OPREV(e) : DPREV(e))
+#define SAME_EDGE(e1,e2) (e1 == e2)
+                  struct edge *e2, struct vertex *v2, side s);
+void delete_edge(struct edge *e);
+void splice(struct edge *a, struct edge *b, struct vertex *v);
+struct edge *create_edge(struct vertex *v1, struct vertex *v2);
Added: grass-addons/vector/voronoi/demo/error.c
--- grass-addons/vector/voronoi/demo/error.c	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/error.c	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,7 @@
+#include <stdio.h>
+void problem(char *message){
+    fprintf(stderr, message);
+    exit(EXIT_FAILURE);
Added: grass-addons/vector/voronoi/demo/error.h
--- grass-addons/vector/voronoi/demo/error.h	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/error.h	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,2 @@
+void problem(char *message);
\ No newline at end of file
Added: grass-addons/vector/voronoi/demo/geom_primitives.h
--- grass-addons/vector/voronoi/demo/geom_primitives.h	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/geom_primitives.h	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,15 @@
+#define CREATE_VECTOR(p1, p2, dx, dy) (dx = p2->x - p1->x, dy = p2->y - p1->y)
+#define DOT_PRODUCT_2V(a1, a2, b1, b2) (a1 * b1 + a2 * b2)
+#define CROSS_PRODUCT_2V(a1, a2, b1, b2) (a1 * b2 - a2 * b1)
+cross-product around p2
+((p2->x - p1->x) * (p3->y - p2->y) - (p2->y - p1->y) * (p3->x - p2->x))
+around p1
+#define CROSS_PRODUCT_3P(p1, p2, p3) ((p2->x - p1->x) * (p3->y - p1->y) - (p2->y - p1->y) * (p3->x - p1->x))
Added: grass-addons/vector/voronoi/demo/geometry.c
--- grass-addons/vector/voronoi/demo/geometry.c	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/geometry.c	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,255 @@
+#include "geometry.h"
+#include "geom_primitives.h"
+#include "edge.h"
+#include <stddef.h>
+static void find_lowest_cross_edge(struct edge *r_cw_l, struct vertex *s,
+                                   struct edge *l_ccw_r, struct vertex *u,
+                                   struct edge **l_lower, struct vertex **org_l_lower,
+                                   struct edge **r_lower, struct vertex **org_r_lower);
+static void merge(struct edge *r_cw_l, struct vertex *s,
+                  struct edge **l_tangent);
+void divide(struct vertex *sites_sorted[], unsigned int l, unsigned int r,
+            struct edge **l_ccw, struct edge **r_cw) {
+    unsigned int n;
+    unsigned int split;
+    struct edge *l_ccw_l, *r_cw_l, *l_ccw_r, *r_cw_r, *l_tangent;
+    struct edge *a, *b, *c;
+    double c_p;
+    n = r - l + 1;
+    if (n == 2) {
+        /* Base case #1 - 2 sites in region. Construct an edge from
+           two sites in the region       */
+        *l_ccw = *r_cw = create_edge(sites_sorted[l], sites_sorted[r]);
+    } else if (n == 3) {
+        /* Base case #2 - 3 sites. Construct a triangle or two edges */
+        a = create_edge(sites_sorted[l], sites_sorted[l+1]);
+        b = create_edge(sites_sorted[l+1], sites_sorted[r]);
+        splice(a, b, sites_sorted[l+1]);
+        c_p = CROSS_PRODUCT_3P(sites_sorted[l], sites_sorted[l+1], sites_sorted[r]);
+        if (c_p > 0.0) {
+            /* Create a triangle */
+            c = join(a, sites_sorted[l], b, sites_sorted[r], right);
+            *l_ccw = a;
+            *r_cw = b;
+        } else if (c_p < 0.0) {
+            c = join(a, sites_sorted[l], b, sites_sorted[r], left);
+            *l_ccw = c;
+            *r_cw = c;
+        } else {
+            /* Cross product is zero. Sites are located on a line.
+            Triangle cannot be created */
+            *l_ccw = a;
+            *r_cw = b;
+    } else if (n > 3) {
+        /* Recursive case. Continue splitting */
+        /* Splitting point */
+        split = (l + r) / 2;
+        /* Divide into two halves */
+        divide(sites_sorted, l, split, &l_ccw_l, &r_cw_l);
+        divide(sites_sorted, split+1, r, &l_ccw_r, &r_cw_r);
+        /* Merge the two triangulations */
+        merge(r_cw_l, sites_sorted[split], l_ccw_r, sites_sorted[split+1], &l_tangent);
+        /* The lower tangent added by merge may have invalidated
+        l_ccw_l or r_cw_r. Update them if necessary. */
+        if (ORG(l_tangent) == sites_sorted[l])
+            l_ccw_l = l_tangent;
+        if (DEST(l_tangent) == sites_sorted[r])
+            r_cw_r = l_tangent;
+        /* Update edge references to be returned */
+        *l_ccw = l_ccw_l;
+        *r_cw = r_cw_r;
+ *  Find the lowest cross edge of the two triangulations
+    struct edge *l, *r;
+    struct vertex *o_l, *o_r, *d_l, *d_r;
+    boolean ready;
+    l = r_cw_l;
+    r = l_ccw_r;
+    o_l = s;
+    d_l = OTHER_VERTEX(l, s);
+    o_r = u;
+    d_r = OTHER_VERTEX(r, u);
+    ready = FALSE;
+    while (!ready)
+        if (CROSS_PRODUCT_3P(o_l, d_l, o_r) > 0.0) {
+            l = PREV(l, d_l);
+            o_l = d_l;
+            d_l = OTHER_VERTEX(l, o_l);
+        } else if (CROSS_PRODUCT_3P(o_r, d_r, o_l) < 0.0) {
+            r = NEXT(r, d_r);
+            o_r = d_r;
+            d_r = OTHER_VERTEX(r, o_r);
+        } else
+            ready = TRUE;
+    *l_lower = l;
+    *r_lower = r;
+    *org_l_lower = o_l;
+    *org_r_lower = o_r;
+ *  The most time-expensive function, most of the work gets done here.
+    struct edge *base, *l_cand, *r_cand;
+    struct vertex *org_base, *dest_base;
+    double u_l_c_o_b, v_l_c_o_b, u_l_c_d_b, v_l_c_d_b;
+    double u_r_c_o_b, v_r_c_o_b, u_r_c_d_b, v_r_c_d_b;
+    /* cross product */
+    double c_p_l_cand, c_p_r_cand;
+    /* dot product */
+    double d_p_l_cand, d_p_r_cand;
+    boolean above_l_cand, above_r_cand, above_next, above_prev;
+    struct vertex *dest_l_cand, *dest_r_cand;
+    double cot_l_cand, cot_r_cand;
+    struct edge *l_lower, *r_lower;
+    struct vertex *org_r_lower, *org_l_lower;
+    /* Create first cross edge by joining lower common tangent */
+    find_lowest_cross_edge(r_cw_l, s, l_ccw_r, u, &l_lower, &org_l_lower, &r_lower, &org_r_lower);
+    base = join(l_lower, org_l_lower, r_lower, org_r_lower, right);
+    org_base = org_l_lower;
+    dest_base = org_r_lower;
+    /* Need to return lower tangent. */
+    *l_tangent = base;
+    /* The merge loop */
+    while (TRUE) {
+        /* Initialise l_cand and r_cand */
+        l_cand = NEXT(base, org_base);
+        r_cand = PREV(base, dest_base);
+        dest_l_cand = OTHER_VERTEX(l_cand, org_base);
+        dest_r_cand = OTHER_VERTEX(r_cand, dest_base);
+        /* Vectors for above and "in_circle" tests.
+        u/v left/right candidate origin/destination */
+        CREATE_VECTOR(dest_l_cand, org_base, u_l_c_o_b, v_l_c_o_b);
+        CREATE_VECTOR(dest_l_cand, dest_base, u_l_c_d_b, v_l_c_d_b);
+        CREATE_VECTOR(dest_r_cand, org_base, u_r_c_o_b, v_r_c_o_b);
+        CREATE_VECTOR(dest_r_cand, dest_base, u_r_c_d_b, v_r_c_d_b);
+        /* Above tests. */
+        c_p_l_cand = CROSS_PRODUCT_2V(u_l_c_o_b, v_l_c_o_b, u_l_c_d_b, v_l_c_d_b);
+        c_p_r_cand = CROSS_PRODUCT_2V(u_r_c_o_b, v_r_c_o_b, u_r_c_d_b, v_r_c_d_b);
+        above_l_cand = c_p_l_cand > 0.0;
+        above_r_cand = c_p_r_cand > 0.0;
+        if (!above_l_cand && !above_r_cand)
+            break;        /* Terminate loop */
+        /* Advance l_cand ccw,  delete the old l_cand edge, until the
+        in_circle test gets invalid. */
+        if (above_l_cand) {
+            double u_n_o_b, v_n_o_b, u_n_d_b, v_n_d_b;
+            double c_p_next, d_p_next, cot_next;
+            struct vertex *dest_next;
+            d_p_l_cand = DOT_PRODUCT_2V(u_l_c_o_b, v_l_c_o_b, u_l_c_d_b, v_l_c_d_b);
+            cot_l_cand = d_p_l_cand / c_p_l_cand;
+            while (TRUE) {
+                next = NEXT(l_cand, org_base);
+                dest_next = OTHER_VERTEX(next, org_base);
+                CREATE_VECTOR(dest_next, org_base, u_n_o_b, v_n_o_b);
+                CREATE_VECTOR(dest_next, dest_base, u_n_d_b, v_n_d_b);
+                c_p_next = CROSS_PRODUCT_2V(u_n_o_b, v_n_o_b, u_n_d_b, v_n_d_b);
+                above_next = c_p_next > 0.0;
+                if (!above_next)
+                    break;    /* Terminate loop. */
+                d_p_next = DOT_PRODUCT_2V(u_n_o_b, v_n_o_b, u_n_d_b, v_n_d_b);
+                cot_next = d_p_next / c_p_next;
+                if (cot_next > cot_l_cand)
+                delete_edge(l_cand);
+                l_cand = next;
+                cot_l_cand = cot_next;
+        /* Do the same for r_cand symmetrically. */
+        if (above_r_cand) {
+            double u_p_o_b, v_p_o_b, u_p_d_b, v_p_d_b;
+            double c_p_prev, d_p_prev, cot_prev;
+            struct edge *prev;
+            struct vertex *dest_prev;
+            d_p_r_cand = DOT_PRODUCT_2V(u_r_c_o_b, v_r_c_o_b, u_r_c_d_b, v_r_c_d_b);
+            cot_r_cand = d_p_r_cand / c_p_r_cand;
+            while (TRUE) {
+                prev = PREV(r_cand, dest_base);
+                dest_prev = OTHER_VERTEX(prev, dest_base);
+                CREATE_VECTOR(dest_prev, org_base, u_p_o_b, v_p_o_b);
+                CREATE_VECTOR(dest_prev, dest_base, u_p_d_b, v_p_d_b);
+                c_p_prev = CROSS_PRODUCT_2V(u_p_o_b, v_p_o_b, u_p_d_b, v_p_d_b);
+                above_prev = c_p_prev > 0.0;
+                if (!above_prev)
+                    break;    /* Terminate. */
+                d_p_prev = DOT_PRODUCT_2V(u_p_o_b, v_p_o_b, u_p_d_b, v_p_d_b);
+                cot_prev = d_p_prev / c_p_prev;
+                if (cot_prev > cot_r_cand)
+                delete_edge(r_cand);
+                r_cand = prev;
+                cot_r_cand = cot_prev;
+        *  Now add a cross edge from base to either l_cand or r_cand.
+        *  If both are valid choose on the basis of the in_circle test .
+        *  Advance base and whichever candidate was chosen.
+        if (!above_l_cand || (above_l_cand && above_r_cand && cot_r_cand < cot_l_cand))        {
+            /* Connect to the right */
+            base = join(base, org_base, r_cand, dest_r_cand, right);
+            dest_base = dest_r_cand;
+        } else {
+            /* Connect to the left */
+            base = join(l_cand, dest_l_cand, base, dest_base, right);
+            org_base = dest_l_cand;
Added: grass-addons/vector/voronoi/demo/geometry.h
--- grass-addons/vector/voronoi/demo/geometry.h	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/geometry.h	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,3 @@
+            struct edge **l_ccw, struct edge **r_cw);
Added: grass-addons/vector/voronoi/demo/in_out.c
--- grass-addons/vector/voronoi/demo/in_out.c	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/in_out.c	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,137 @@
+#include "edge.h"
+#include <stdio.h>
+#include <cairo.h>
+#include <math.h>
+cairo_surface_t *surface;
+cairo_t *cr;
+static void print_edges(unsigned int n);
+static void print_triangles(unsigned int n);
+void read_points(unsigned int n){
+    int i;
+    for (i = 0; i < n; i++)
+        if (scanf("%f %f", &sites[i].x, &sites[i].y) != 2)
+            problem("Error reading sites.");
+void print_results(unsigned int n, char option){
+    /* Print either triangles or edges */
+    if (option == 't')
+        print_triangles(n);
+    else
+        print_edges(n);
+ *  Print the ring of edges about each vertex.
+static void print_edges(unsigned int n){
+    struct edge *e_start, *e;
+    unsigned int i;
+    for (i = 0; i < n; i++) {
+        u = &sites[i];
+        e_start = e = u->entry_pt;
+        do{
+            v = OTHER_VERTEX(e, u);
+            if (u < v)
+                if (printf("%d %d\n", u - sites, v - sites) == EOF)
+                    problem("Error printing results\n");
+            e = NEXT(e, u);
+        } while (!SAME_EDGE(e, e_start));
+/* draw triangulation */
+void draw_sites(int n){
+    int i;
+    surface = cairo_image_surface_create(CAIRO_FORMAT_ARGB32, 1280, 800);
+    cr = cairo_create(surface);
+/*    for (i = 0; i < n; i++) {
+        cairo_arc(cr, sites[i].x, sites[i].y, 1, 0, 2 * M_PI);
+        cairo_stroke (cr);
+void draw(unsigned int n){
+    unsigned int i;
+    draw_sites(n);
+    cairo_set_line_width (cr, 1);
+    int x1, y1, x2, y2;
+        u = &sites[i];
+        do{
+            if (u < v) {
+                x1 = (int) sites[u - sites].x;
+                y1 = (int) sites[u - sites].y;
+                x2 = (int) sites[v - sites].x;
+                y2 = (int) sites[v - sites].y;
+                cairo_move_to (cr, x1, y1);
+                cairo_line_to (cr, x2, y2);
+          /*      printf("e1=%d e2=%d\n", u - sites, v - sites);
+                printf("%3d %3d %3d %3d \n", x1, y1, x2, y2);
+            e = NEXT(e, u);
+    cairo_destroy (cr);
+    cairo_surface_write_to_png (surface, "dt.png");
+    cairo_surface_destroy (surface);
+ *  Print the ring of triangles about each vertex.
+    struct edge *e_start, *e, *next;
+    struct vertex *u, *v, *w;
+    unsigned int i;
+    struct vertex *temp;
+        u = &sites[i];
+        do {
+            if (u < v) {
+                next = NEXT(e, u);
+                w = OTHER_VERTEX(next, u);
+                if (u < w)
+                    if (SAME_EDGE(NEXT(next, w), PREV(e, v))) {
+                        /* Triangle. */
+                        if (v > w) {
+                            temp = v;
+                            v = w;
+                            w = temp;
+                        if (printf("%d %d %d\n", u - sites, v - sites, w - sites) == EOF)
+            /* Next edge around u. */
+            e = NEXT(e, u);
Added: grass-addons/vector/voronoi/demo/in_out.h
--- grass-addons/vector/voronoi/demo/in_out.h	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/in_out.h	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,3 @@
+void read_points(unsigned int n);
+void print_results(unsigned int n, char option);
+void draw(unsigned int n);
Added: grass-addons/vector/voronoi/demo/main.c
--- grass-addons/vector/voronoi/demo/main.c	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/main.c	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,64 @@
+#include "edge.h"
+#include <stdio.h>
+#include <time.h>
+int compare(const struct vertex **p1, const struct vertex **p2);
+int main(int argc, char *argv[]){
+    unsigned int i;
+    unsigned int n;
+    struct edge *l_cw, *r_ccw;
+    struct vertex **sites_sorted;
+    printf("Enter number of sites: ");
+    if (scanf("%d", &n) != 1)
+        problem("Number of sites could not be read.");
+    if (n <= 0)
+        problem("Number of sites has to be positive integer.");
+    alloc_memory(n);
+    //read_points(n);
+    srand((unsigned int)time(0));
+    for (i = 0; i < n; i++){
+        sites[i].x = rand() % 1260 + 10;
+        sites[i].y = rand() % 780 + 10;
+    /* Initialise entry edge vertices. */
+        sites[i].entry_pt = NULL;
+    /* Sort. */
+    sites_sorted = (struct vertex **) malloc((unsigned)n*sizeof(struct vertex *));
+    if (sites_sorted == NULL)
+        problem("Not enough memory\n");
+        sites_sorted[i] = sites + i;
+    qsort(sites_sorted, n, sizeof(struct vertex *), (void *)compare);
+//     for (i = 0; i < n; i++)
+//         printf("(%3d)  x=%3.0f y=%3.f\n", i, sites[i].x, sites[i].y);
+    /* Triangulate. */
+    divide(sites_sorted, 0, n-1, &l_cw, &r_ccw);
+    free((char *)sites_sorted);
+    draw(n);
+    free_memory();
+    exit(EXIT_SUCCESS);
+    return 0;	/* To keep lint quiet. */
+/* compare first according to x-coordinate, if equal then y-coordinate */
+int compare(const struct vertex **p1, const struct vertex **p2){
+    if ((*p1)->x == (*p2)->x) return ((*p1)->y < (*p2)->y);
+    return ((*p1)->x < (*p2)->x);
Added: grass-addons/vector/voronoi/demo/memory.c
--- grass-addons/vector/voronoi/demo/memory.c	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/memory.c	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,45 @@
+struct vertex *sites;
+static struct edge *edges;
+static struct edge **free_list_e;
+static unsigned int n_free_e;
+void alloc_memory(unsigned int n){
+    struct edge *e;
+    int i;
+    /* Point storage. */
+    sites = (struct vertex *) calloc(n, sizeof(struct vertex));
+    if (sites == NULL)
+    /* Edges. */
+    /* Euler's formula - at most 3n edges on a set of n sites */
+    n_free_e = 3 * n;
+    edges = e = (struct edge *) calloc(n_free_e, sizeof(struct edge));
+    if (edges == NULL)
+    free_list_e = (struct edge **) calloc(n_free_e, sizeof(struct edge *));
+    if (free_list_e == NULL)
+    for (i = 0; i < n_free_e; i++, e++)
+        free_list_e[i] = e;
+void free_memory(){
+    free(sites);
+    free(edges);
+    free(free_list_e);
+struct edge *get_edge(){
+    if (n_free_e < 1) problem("All allocated edges have been used\n");
+    return (free_list_e[--n_free_e]);
+void free_edge(struct edge *e){
+    free_list_e[n_free_e++] = e;
Added: grass-addons/vector/voronoi/demo/memory.h
--- grass-addons/vector/voronoi/demo/memory.h	                        (rev 0)
+++ grass-addons/vector/voronoi/demo/memory.h	2008-08-10 14:00:11 UTC (rev 32667)
@@ -0,0 +1,5 @@
+void alloc_memory(unsigned int n);
+void free_memory();
+struct edge *get_edge();
+void free_edge(struct edge *e);
