[GRASS-SVN] r32675 - in grass/trunk: db/drivers/dbf
db/drivers/mysql db/drivers/odbc db/drivers/ogr
db/drivers/postgres display/d.colors display/d.histogram
display/d.measure display/d.profile display/d.rast
display/d.rast.arrow display/d.rast.num display/d.title
display/d.what.vect display/d.zoom general/g.mapsets
general/g.mkfontcap general/g.proj general/manage
general/manage/cmd general/manage/lib imagery/i.cca
imagery/i.class imagery/i.fft imagery/i.ifft
imagery/i.ortho.photo/photo.camera imagery/i.ortho.photo/photo.elev
imagery/i.ortho.photo/photo.init imagery/i.zc include
lib/db/sqlp lib/dspf lib/proj ps/ps.map raster/r.cost
raster/r.digit raster/r.drain raster/r.fill.dir raster/r.flow
raster/r.in.gridatb raster/r.le/r.le.patch raster/r.los
raster/r.mfilter raster/r.out.gridatb raster/r.out.vtk
raster/r.param.scale raster/r.random.cells
raster/r.random.surface raster/r.recode raster/r.resamp.rst
raster/r.statistics raster/r.sunmask raster/r.surf.contour
raster/r.surf.fractal raster/r.surf.idw raster/r.to.vect
raster/r.topidx raster/r.topmodel raster/r.univar2
raster/r.walk raster/r.water.outlet raster/r.watershed/ram
raster/r.watershed/seg raster/wildfire/r.spreadpath
raster3d/r3.mkdspf raster3d/r3.out.vtk raster3d/r3.showdspf
vector/v.build.polylines vector/v.digit vector/v.in.dwg
vector/v.in.dxf vector/v.in.ogr vector/v.out.dxf
vector/v.out.vtk vector/v.to.db vector/v.transform
vector/v.vol.rst vector/v.voronoi visualization/nviz/src
visualization/xganim
svn_grass at osgeo.org
Mon Aug 11 05:29:52 EDT 2008
Author: glynn
Date: 2008-08-11 05:29:51 -0400 (Mon, 11 Aug 2008)
New Revision: 32675
Added:
grass/trunk/lib/dspf/cell_table.c
Removed:
grass/trunk/lib/dspf/cell_table.h
grass/trunk/raster3d/r3.showdspf/cell_table.h
grass/trunk/db/drivers/dbf/globals.h
grass/trunk/db/drivers/dbf/main.c
grass/trunk/db/drivers/dbf/main_debug.c
grass/trunk/db/drivers/mysql/globals.h
grass/trunk/db/drivers/mysql/main.c
grass/trunk/db/drivers/odbc/globals.h
grass/trunk/db/drivers/odbc/main.c
grass/trunk/db/drivers/ogr/globals.h
grass/trunk/db/drivers/ogr/main.c
grass/trunk/db/drivers/postgres/globals.h
grass/trunk/db/drivers/postgres/main.c
grass/trunk/display/d.colors/externs.h
grass/trunk/display/d.colors/set_sigs.c
grass/trunk/display/d.histogram/dhist.h
grass/trunk/display/d.histogram/main.c
grass/trunk/display/d.histogram/options.h
grass/trunk/display/d.measure/main.c
grass/trunk/display/d.profile/main.c
grass/trunk/display/d.profile/profile.h
grass/trunk/display/d.rast.arrow/arrow.c
grass/trunk/display/d.rast.num/number.c
grass/trunk/display/d.rast/main.c
grass/trunk/display/d.rast/mask.h
grass/trunk/display/d.title/main.c
grass/trunk/display/d.title/options.h
grass/trunk/display/d.what.vect/main.c
grass/trunk/display/d.what.vect/what.h
grass/trunk/display/d.zoom/local_proto.h
grass/trunk/display/d.zoom/main.c
grass/trunk/general/g.mapsets/externs.h
grass/trunk/general/g.mapsets/main_cmd.c
grass/trunk/general/g.mapsets/main_inter.c
grass/trunk/general/g.mkfontcap/local_proto.h
grass/trunk/general/g.mkfontcap/main.c
grass/trunk/general/g.proj/local_proto.h
grass/trunk/general/g.proj/main.c
grass/trunk/general/manage/cmd/copy.c
grass/trunk/general/manage/cmd/list.c
grass/trunk/general/manage/cmd/remove.c
grass/trunk/general/manage/cmd/rename.c
grass/trunk/general/manage/lib/read_list.c
grass/trunk/general/manage/list.h
grass/trunk/imagery/i.cca/main.c
grass/trunk/imagery/i.class/globals.h
grass/trunk/imagery/i.class/main.c
grass/trunk/imagery/i.fft/fftmain.c
grass/trunk/imagery/i.fft/globals.h
grass/trunk/imagery/i.ifft/globals.h
grass/trunk/imagery/i.ifft/ifftmain.c
grass/trunk/imagery/i.ortho.photo/photo.camera/globals.h
grass/trunk/imagery/i.ortho.photo/photo.camera/main.c
grass/trunk/imagery/i.ortho.photo/photo.elev/main.c
grass/trunk/imagery/i.ortho.photo/photo.init/globals.h
grass/trunk/imagery/i.ortho.photo/photo.init/main.c
grass/trunk/imagery/i.zc/main.c
grass/trunk/include/sqlp.h
grass/trunk/lib/db/sqlp/sql.c
grass/trunk/lib/dspf/viz.h
grass/trunk/lib/proj/get_proj.c
grass/trunk/ps/ps.map/border.h
grass/trunk/ps/ps.map/colortable.h
grass/trunk/ps/ps.map/comment.h
grass/trunk/ps/ps.map/decorate.h
grass/trunk/ps/ps.map/group.h
grass/trunk/ps/ps.map/header.h
grass/trunk/ps/ps.map/labels.h
grass/trunk/ps/ps.map/main.c
grass/trunk/ps/ps.map/map_info.h
grass/trunk/ps/ps.map/ps_info.h
grass/trunk/ps/ps.map/vector.h
grass/trunk/raster/r.cost/main.c
grass/trunk/raster/r.cost/stash.h
grass/trunk/raster/r.digit/main.c
grass/trunk/raster/r.drain/tinf.c
grass/trunk/raster/r.drain/tinf.h
grass/trunk/raster/r.fill.dir/tinf.c
grass/trunk/raster/r.fill.dir/tinf.h
grass/trunk/raster/r.flow/calc.c
grass/trunk/raster/r.flow/mem.h
grass/trunk/raster/r.flow/r.flow.h
grass/trunk/raster/r.in.gridatb/file_io.c
grass/trunk/raster/r.in.gridatb/local_proto.h
grass/trunk/raster/r.in.gridatb/main.c
grass/trunk/raster/r.le/r.le.patch/main.c
grass/trunk/raster/r.le/r.le.patch/patch.h
grass/trunk/raster/r.los/cmd_line.h
grass/trunk/raster/r.los/main.c
grass/trunk/raster/r.mfilter/glob.h
grass/trunk/raster/r.mfilter/main.c
grass/trunk/raster/r.out.gridatb/local_proto.h
grass/trunk/raster/r.out.gridatb/main.c
grass/trunk/raster/r.out.vtk/globaldefs.h
grass/trunk/raster/r.out.vtk/main.c
grass/trunk/raster/r.out.vtk/parameters.h
grass/trunk/raster/r.param.scale/main.c
grass/trunk/raster/r.param.scale/param.h
grass/trunk/raster/r.random.cells/gasdev.c
grass/trunk/raster/r.random.cells/indep.c
grass/trunk/raster/r.random.cells/init.c
grass/trunk/raster/r.random.cells/main.c
grass/trunk/raster/r.random.cells/random.c
grass/trunk/raster/r.random.cells/ransurf.h
grass/trunk/raster/r.random.surface/calcsd.c
grass/trunk/raster/r.random.surface/calcsurf.c
grass/trunk/raster/r.random.surface/cpfilter.c
grass/trunk/raster/r.random.surface/dd.c
grass/trunk/raster/r.random.surface/decay.c
grass/trunk/raster/r.random.surface/digits.c
grass/trunk/raster/r.random.surface/gasdev.c
grass/trunk/raster/r.random.surface/gennorm.c
grass/trunk/raster/r.random.surface/init.c
grass/trunk/raster/r.random.surface/main.c
grass/trunk/raster/r.random.surface/makebigf.c
grass/trunk/raster/r.random.surface/makepp.c
grass/trunk/raster/r.random.surface/random.c
grass/trunk/raster/r.random.surface/ransurf.h
grass/trunk/raster/r.random.surface/save.c
grass/trunk/raster/r.random.surface/zero.c
grass/trunk/raster/r.recode/global.h
grass/trunk/raster/r.recode/main.c
grass/trunk/raster/r.resamp.rst/main.c
grass/trunk/raster/r.statistics/main.c
grass/trunk/raster/r.statistics/method.h
grass/trunk/raster/r.sunmask/global.h
grass/trunk/raster/r.sunmask/main.c
grass/trunk/raster/r.surf.contour/contour.h
grass/trunk/raster/r.surf.contour/main.c
grass/trunk/raster/r.surf.fractal/frac.h
grass/trunk/raster/r.surf.fractal/main.c
grass/trunk/raster/r.surf.idw/main.c
grass/trunk/raster/r.surf.idw/main.h
grass/trunk/raster/r.to.vect/global.h
grass/trunk/raster/r.to.vect/main.c
grass/trunk/raster/r.topidx/global.h
grass/trunk/raster/r.topidx/main.c
grass/trunk/raster/r.topmodel/file_io.c
grass/trunk/raster/r.topmodel/global.h
grass/trunk/raster/r.topmodel/main.c
grass/trunk/raster/r.topmodel/misc.c
grass/trunk/raster/r.univar2/globals.h
grass/trunk/raster/r.univar2/r.univar_main.c
grass/trunk/raster/r.univar2/r3.univar_main.c
grass/trunk/raster/r.walk/main.c
grass/trunk/raster/r.walk/stash.h
grass/trunk/raster/r.water.outlet/basin.h
grass/trunk/raster/r.water.outlet/main.c
grass/trunk/raster/r.watershed/ram/Gwater.h
grass/trunk/raster/r.watershed/ram/main.c
grass/trunk/raster/r.watershed/seg/Gwater.h
grass/trunk/raster/r.watershed/seg/main.c
grass/trunk/raster/wildfire/r.spreadpath/main.c
grass/trunk/raster/wildfire/r.spreadpath/stash.h
grass/trunk/raster3d/r3.mkdspf/iso_surface.c
grass/trunk/raster3d/r3.mkdspf/main.c
grass/trunk/raster3d/r3.mkdspf/vizual.h
grass/trunk/raster3d/r3.out.vtk/globalDefs.h
grass/trunk/raster3d/r3.out.vtk/main.c
grass/trunk/raster3d/r3.out.vtk/parameters.h
grass/trunk/raster3d/r3.showdspf/kns_globals.h
grass/trunk/raster3d/r3.showdspf/main_ogl.c
grass/trunk/raster3d/r3.showdspf/togif.c
grass/trunk/raster3d/r3.showdspf/vizual.h
grass/trunk/raster3d/r3.showdspf/vizual2.h
grass/trunk/vector/v.build.polylines/global.h
grass/trunk/vector/v.build.polylines/main.c
grass/trunk/vector/v.digit/global.h
grass/trunk/vector/v.digit/main.c
grass/trunk/vector/v.in.dwg/global.h
grass/trunk/vector/v.in.dwg/main.c
grass/trunk/vector/v.in.dxf/global.h
grass/trunk/vector/v.in.dxf/main.c
grass/trunk/vector/v.in.ogr/global.h
grass/trunk/vector/v.in.ogr/main.c
grass/trunk/vector/v.out.dxf/global.h
grass/trunk/vector/v.out.dxf/main.c
grass/trunk/vector/v.out.vtk/local_proto.h
grass/trunk/vector/v.out.vtk/main.c
grass/trunk/vector/v.to.db/global.h
grass/trunk/vector/v.to.db/main.c
grass/trunk/vector/v.transform/main.c
grass/trunk/vector/v.transform/trans.h
grass/trunk/vector/v.vol.rst/main.c
grass/trunk/vector/v.vol.rst/userglobs.h
grass/trunk/vector/v.voronoi/defs.h
grass/trunk/vector/v.voronoi/dt_main.c
grass/trunk/vector/v.voronoi/sw_defs.h
grass/trunk/vector/v.voronoi/sw_main.c
grass/trunk/vector/v.voronoi/vo_main.c
grass/trunk/visualization/nviz/src/draw.c
grass/trunk/visualization/nviz/src/interface.h
grass/trunk/visualization/nviz/src/mkdspf_main.c
grass/trunk/visualization/nviz/src/viz.h
grass/trunk/visualization/xganim/local_proto.h
grass/trunk/visualization/xganim/main.c
Eliminate preprocessor abuse
Modified: grass/trunk/db/drivers/dbf/globals.h
--- grass/trunk/db/drivers/dbf/globals.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/db/drivers/dbf/globals.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -78,10 +78,5 @@
int *order; /* array of row indexes (sorted by ORDER BY) */
} cursor;
-#ifdef MAIN
-DATABASE db;
-dbString *errMsg = NULL;
-#else
extern DATABASE db;
extern dbString *errMsg;
-#endif
Modified: grass/trunk/db/drivers/dbf/main.c
--- grass/trunk/db/drivers/dbf/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/db/drivers/dbf/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -15,7 +15,6 @@
-#define MAIN
#include <stdlib.h>
#include <string.h>
#include <grass/dbmi.h>
@@ -23,6 +22,9 @@
#include "proto.h"
#include "dbdriver.h"
+DATABASE db;
+dbString *errMsg = NULL;
int main(int argc, char *argv[])
char *name;
Modified: grass/trunk/db/drivers/dbf/main_debug.c
--- grass/trunk/db/drivers/dbf/main_debug.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/db/drivers/dbf/main_debug.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
* just a test for debugging purpose, imitating dbf driver -a.sh.
-#define MAIN
#include <stdlib.h>
#include <grass/gis.h>
Modified: grass/trunk/db/drivers/mysql/globals.h
--- grass/trunk/db/drivers/mysql/globals.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/db/drivers/mysql/globals.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -18,10 +18,5 @@
unsigned int port;
} CONNPAR;
-#ifdef MAIN
-MYSQL *connection; /* Database connection */
-dbString *errMsg = NULL; /* error message */
-#else
extern MYSQL *connection;
-#endif
Modified: grass/trunk/db/drivers/mysql/main.c
--- grass/trunk/db/drivers/mysql/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/db/drivers/mysql/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -15,9 +15,11 @@
-#define MAIN
#include "globals.h"
+MYSQL *connection; /* Database connection */
+dbString *errMsg = NULL; /* error message */
init_dbdriver();
Modified: grass/trunk/db/drivers/odbc/globals.h
--- grass/trunk/db/drivers/odbc/globals.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/db/drivers/odbc/globals.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -11,10 +11,5 @@
int nrows; /* number of rows selected by SELECT statement */
} cursor;
-#ifdef MAIN
-SQLHENV ODenvi; /* Handle ODBC environment */
-SQLHDBC ODconn; /* Handle connection */
-#else
extern SQLHENV ODenvi; /* Handle ODBC environment */
extern SQLHDBC ODconn; /* Handle connection */
-#endif
Modified: grass/trunk/db/drivers/odbc/main.c
--- grass/trunk/db/drivers/odbc/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/db/drivers/odbc/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,10 +1,11 @@
-#define MAIN
#include <stdlib.h>
#include "odbc.h"
+SQLHENV ODenvi; /* Handle ODBC environment */
+SQLHDBC ODconn; /* Handle connection */
int main(int argc, char **argv)
Modified: grass/trunk/db/drivers/ogr/globals.h
--- grass/trunk/db/drivers/ogr/globals.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/db/drivers/ogr/globals.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -26,10 +26,5 @@
int ncols; /* num columns */
} cursor;
-#ifdef MAIN
-OGRDataSourceH hDs;
-#else
extern OGRDataSourceH hDs;
-#endif
Modified: grass/trunk/db/drivers/ogr/main.c
--- grass/trunk/db/drivers/ogr/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/db/drivers/ogr/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -14,13 +14,16 @@
* for details.
-#define MAIN
#include <stdlib.h>
#include "ogr_api.h"
+OGRDataSourceH hDs;
init_dbdriver();
Modified: grass/trunk/db/drivers/postgres/globals.h
--- grass/trunk/db/drivers/postgres/globals.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/db/drivers/postgres/globals.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -52,14 +52,7 @@
} PG_TYPES;
-#ifdef MAIN
-PGconn *pg_conn; /* Database connection */
-int (*pg_types)[2] = NULL; /* array of types, first is internal code, second PG_TYPE_* */
-int pg_ntypes = 0;
-#else
extern PGconn *pg_conn;
extern int (*pg_types)[2];
extern int pg_ntypes;
-#endif
Modified: grass/trunk/db/drivers/postgres/main.c
--- grass/trunk/db/drivers/postgres/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/db/drivers/postgres/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,9 +1,13 @@
-#define MAIN
#include <stdlib.h>
+PGconn *pg_conn; /* Database connection */
+int (*pg_types)[2] = NULL; /* array of types, first is internal code, second PG_TYPE_* */
+int pg_ntypes = 0;
init_dbdriver();
Modified: grass/trunk/display/d.colors/externs.h
--- grass/trunk/display/d.colors/externs.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.colors/externs.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,8 +3,4 @@
int interrupt;
-#ifdef SIG_MAIN
-struct signalflag signalflag;
-#else
extern struct signalflag signalflag;
-#endif
Modified: grass/trunk/display/d.colors/set_sigs.c
--- grass/trunk/display/d.colors/set_sigs.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.colors/set_sigs.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,9 +1,12 @@
-#define SIG_MAIN
#include "externs.h"
#include <signal.h>
+#include <grass/config.h>
-void sigint();
+struct signalflag signalflag;
+extern RETSIGTYPE sigint(int);
int set_signals(void)
Modified: grass/trunk/display/d.histogram/dhist.h
--- grass/trunk/display/d.histogram/dhist.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.histogram/dhist.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -26,19 +26,9 @@
long int every; /* tic_mark number interval */
-#ifdef MAIN
-struct stat_list dist_stats;
-struct Categories cats;
-struct FPRange fp_range;
-int is_fp;
-#else
extern struct Categories cats;
extern struct FPRange fp_range;
-#endif
/* bar.c */
int bar(struct stat_list *, struct Colors *);
float rem(long int, long int);
Modified: grass/trunk/display/d.histogram/main.c
--- grass/trunk/display/d.histogram/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.histogram/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -37,10 +37,25 @@
#include <grass/display.h>
#include <grass/raster.h>
#include <grass/glocale.h>
-#define MAIN
#include "options.h"
#include "dhist.h"
+struct stat_list dist_stats;
+struct Categories cats;
+struct FPRange fp_range;
+int is_fp;
+char *map_name;
+int color;
+float size;
+int style;
+int type;
+int is_fp;
+int nodata;
+int nsteps;
+int cat_ranges;
int text_height;
Modified: grass/trunk/display/d.histogram/options.h
--- grass/trunk/display/d.histogram/options.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.histogram/options.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,18 +1,13 @@
-#ifdef MAIN
-#define GLOBAL
-#else
-#define GLOBAL extern
-#endif
-GLOBAL char *map_name;
-GLOBAL int color;
-GLOBAL float size;
-GLOBAL int style;
-GLOBAL int type;
-GLOBAL int is_fp;
-GLOBAL int nodata;
-GLOBAL int nsteps;
-GLOBAL int cat_ranges;
+extern char *map_name;
+extern int color;
+extern float size;
+extern int style;
+extern int type;
+extern int is_fp;
+extern int nodata;
+extern int nsteps;
+extern int cat_ranges;
#define PIE 1
#define BAR 2
Modified: grass/trunk/display/d.measure/main.c
--- grass/trunk/display/d.measure/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.measure/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -25,7 +25,6 @@
-#define MAIN
#include "local_proto.h"
Modified: grass/trunk/display/d.profile/main.c
--- grass/trunk/display/d.profile/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.profile/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -20,7 +20,6 @@
#define DEBUG
-#define MAIN
#define USE_OLD_CODE /* Frame set-up still needs old code ATM. */
#include <stdio.h>
#include <stdlib.h>
@@ -31,6 +30,20 @@
#include "profile.h"
+struct windows windows[] = {
+ {"mou", 85, 100, 0, 50},
+ {"sta", 85, 100, 50, 100},
+ {"map", 0, 85, 0, 50},
+ {"orig", 0, 100, 0, 1009}
+struct windows profiles[] = {
+ {"pro1", 64, 85, 50, 100},
+ {"pro2", 43, 64, 50, 100},
+ {"pro3", 22, 43, 50, 100},
+ {"pro4", 0, 22, 50, 100}
struct Profile profile;
void myDcell(char *name, char *mapset, int overlay);
Modified: grass/trunk/display/d.profile/profile.h
--- grass/trunk/display/d.profile/profile.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.profile/profile.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -48,24 +48,8 @@
UCAT MinCat, MaxCat;
-#ifdef MAIN
-struct windows windows[] = {
- {"mou", 85, 100, 0, 50},
- {"sta", 85, 100, 50, 100},
- {"map", 0, 85, 0, 50},
- {"orig", 0, 100, 0, 1009}
-struct windows profiles[] = {
- {"pro1", 64, 85, 50, 100},
- {"pro2", 43, 64, 50, 100},
- {"pro3", 22, 43, 50, 100},
- {"pro4", 0, 22, 50, 100}
-#else
extern struct windows windows[];
extern struct windows profiles[];
-#endif
#define MOU windows[0]
#define STA windows[1]
Modified: grass/trunk/display/d.rast/main.c
--- grass/trunk/display/d.rast/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.rast/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -21,7 +21,7 @@
#include <stdlib.h>
-#define MAIN
#include "mask.h"
@@ -29,6 +29,9 @@
static int parse_catlist(char **, Mask *);
static int parse_vallist(char **, d_Mask *);
+d_Mask d_mask;
+Mask mask;
char *mapset;
Modified: grass/trunk/display/d.rast/mask.h
--- grass/trunk/display/d.rast/mask.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.rast/mask.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -22,10 +22,5 @@
d_Interval *list;
} d_Mask;
-#ifdef MAIN
-d_Mask d_mask;
-Mask mask;
-#else
extern d_Mask d_mask;
extern Mask mask;
-#endif
Modified: grass/trunk/display/d.rast.arrow/arrow.c
--- grass/trunk/display/d.rast.arrow/arrow.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.rast.arrow/arrow.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -46,7 +46,6 @@
# define RpD ((2 * M_PI) / 360.) /* radians/degree */
# define D2R(d) (double)(d * RpD) /* degrees->radians */
-#define MAIN
static void arrow_mag(double, double);
static void arrow_360(double);
static void arrow_se(void);
Modified: grass/trunk/display/d.rast.num/number.c
--- grass/trunk/display/d.rast.num/number.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.rast.num/number.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -42,7 +42,6 @@
#include <grass/colors.h>
-#define MAIN
int draw_number(double, int, RASTER_MAP_TYPE);
int D_x, D_y;
Modified: grass/trunk/display/d.title/main.c
--- grass/trunk/display/d.title/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.title/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -22,10 +22,15 @@
-#define MAIN
+char map_name[GNAME_MAX];
+char color[128];
+float size;
+int type;
char *mapset;
Modified: grass/trunk/display/d.title/options.h
--- grass/trunk/display/d.title/options.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.title/options.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,14 +1,8 @@
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
+extern char map_name[GNAME_MAX];
+extern char color[128];
+extern float size;
+extern int type;
-GLOBAL char map_name[GNAME_MAX];
-GLOBAL char color[128];
-GLOBAL float size;
-GLOBAL int type;
#define NORMAL 1
#define FANCY 2
Modified: grass/trunk/display/d.what.vect/main.c
--- grass/trunk/display/d.what.vect/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.what.vect/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -24,7 +24,6 @@
-#define MAIN
#include <stdlib.h>
#include <string.h>
@@ -36,6 +35,10 @@
+char **vect;
+int nvects;
+struct Map_info *Map;
/* Vector map grabbing taken from d.zoom */
Modified: grass/trunk/display/d.what.vect/what.h
--- grass/trunk/display/d.what.vect/what.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.what.vect/what.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -12,12 +12,6 @@
/* attr.c */
int disp_attr(char *, char *, char *, char *, int);
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
-GLOBAL char **vect;
-GLOBAL int nvects;
-GLOBAL struct Map_info *Map;
+extern char **vect;
+extern int nvects;
+extern struct Map_info *Map;
Modified: grass/trunk/display/d.zoom/local_proto.h
--- grass/trunk/display/d.zoom/local_proto.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.zoom/local_proto.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -40,13 +40,7 @@
/* quit.c */
int quit(struct Cell_head *, struct Cell_head *);
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
-GLOBAL char *cmd;
-GLOBAL char **rast, **vect, **list;
-GLOBAL int nrasts, nvects, nlists;
-GLOBAL double U_east, U_west, U_south, U_north;
+extern char *cmd;
+extern char **rast, **vect, **list;
+extern int nrasts, nvects, nlists;
+extern double U_east, U_west, U_south, U_north;
Modified: grass/trunk/display/d.zoom/main.c
--- grass/trunk/display/d.zoom/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/display/d.zoom/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -26,10 +26,15 @@
#include <grass/Vect.h>
-#define MAIN
+char *cmd;
+char **rast, **vect, **list;
+int nrasts, nvects, nlists;
+double U_east, U_west, U_south, U_north;
int stat;
Modified: grass/trunk/general/g.mapsets/externs.h
--- grass/trunk/general/g.mapsets/externs.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/g.mapsets/externs.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,18 +1,10 @@
-#ifdef MAIN
-char *mapset_name[GMAPSET_MAX];
-int nmapsets;
-int choice[GMAPSET_MAX];
-int nchoices;
-int curr_mapset[GMAPSET_MAX];
-int ncurr_mapsets;
-#else
extern char *mapset_name[];
extern int nmapsets;
extern int choice[];
extern int nchoices;
extern int curr_mapset[];
extern int ncurr_mapsets;
-#endif
#define REPLACE 0
#define ADD 1
Modified: grass/trunk/general/g.mapsets/main_cmd.c
--- grass/trunk/general/g.mapsets/main_cmd.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/g.mapsets/main_cmd.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -17,7 +17,6 @@
-#define MAIN
#include <string.h>
#include <stdlib.h>
#include <unistd.h>
@@ -27,6 +26,13 @@
+char *mapset_name[GMAPSET_MAX];
+int nmapsets;
+int choice[GMAPSET_MAX];
+int nchoices;
+int curr_mapset[GMAPSET_MAX];
+int ncurr_mapsets;
static char Path[GPATH_MAX];
Modified: grass/trunk/general/g.mapsets/main_inter.c
--- grass/trunk/general/g.mapsets/main_inter.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/g.mapsets/main_inter.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -15,7 +15,6 @@
-#define MAIN
Modified: grass/trunk/general/g.mkfontcap/local_proto.h
--- grass/trunk/general/g.mkfontcap/local_proto.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/g.mkfontcap/local_proto.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,16 +1,10 @@
-#ifdef G_MKFONTCAP_MAIN
-# define G_MKFONTCAP_GLOBAL
-#else
-# define G_MKFONTCAP_GLOBAL extern
-#endif
+extern char **searchdirs;
+extern int numsearchdirs;
-G_MKFONTCAP_GLOBAL char **searchdirs;
-G_MKFONTCAP_GLOBAL int numsearchdirs;
+extern struct GFONT_CAP *fontcap;
+extern int totalfonts;
+extern int maxfonts;
-G_MKFONTCAP_GLOBAL struct GFONT_CAP *fontcap;
-G_MKFONTCAP_GLOBAL int totalfonts;
-G_MKFONTCAP_GLOBAL int maxfonts;
/* freetype_fonts.c */
void find_freetype_fonts(void);
Modified: grass/trunk/general/g.mkfontcap/main.c
--- grass/trunk/general/g.mkfontcap/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/g.mkfontcap/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -14,8 +14,6 @@
-#define G_MKFONTCAP_MAIN 1
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
@@ -29,6 +27,13 @@
+char **searchdirs;
+int numsearchdirs;
+struct GFONT_CAP *fontcap;
+int totalfonts;
+int maxfonts;
static const char *standarddirs[] = {
/* These are the directories that are searched for Freetype-compatible
* font files by default. They may contain an environment variable
Modified: grass/trunk/general/g.proj/local_proto.h
--- grass/trunk/general/g.proj/local_proto.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/g.proj/local_proto.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,12 +1,6 @@
-#ifdef G_PROJ_MAIN
-# define G_PROJ_GLOBAL
-#else
-# define G_PROJ_GLOBAL extern
-#endif
+extern struct Key_Value *projinfo, *projunits;
+extern struct Cell_head cellhd;
-G_PROJ_GLOBAL struct Key_Value *projinfo, *projunits;
-G_PROJ_GLOBAL struct Cell_head cellhd;
/* input.c */
void input_currloc(void);
int input_wkt(char *);
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/g.proj/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -19,9 +19,11 @@
-#define G_PROJ_MAIN
+struct Key_Value *projinfo, *projunits;
+struct Cell_head cellhd;
struct Flag *printinfo, /* Print contents of PROJ_INFO & PROJ_UNITS */
Modified: grass/trunk/general/manage/cmd/copy.c
--- grass/trunk/general/manage/cmd/copy.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/manage/cmd/copy.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -17,7 +17,7 @@
* for details.
-#define MAIN
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/general/manage/cmd/list.c
--- grass/trunk/general/manage/cmd/list.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/manage/cmd/list.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -17,7 +17,6 @@
-#define MAIN
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
Modified: grass/trunk/general/manage/cmd/remove.c
--- grass/trunk/general/manage/cmd/remove.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/manage/cmd/remove.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -21,7 +21,7 @@
#include <stdlib.h>
#include <string.h>
-#define MAIN
#include "list.h"
Modified: grass/trunk/general/manage/cmd/rename.c
--- grass/trunk/general/manage/cmd/rename.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/manage/cmd/rename.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -16,7 +16,7 @@
* for details.
-#define MAIN
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/general/manage/lib/read_list.c
--- grass/trunk/general/manage/lib/read_list.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/manage/lib/read_list.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -17,6 +17,9 @@
+int nlist;
+struct list *list;
static int format_error(char *, int, char *);
int read_list(int check_if_empty)
Modified: grass/trunk/general/manage/list.h
--- grass/trunk/general/manage/list.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/general/manage/list.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -13,11 +13,6 @@
char *maindesc; /* main element description */
-#ifdef MAIN
-int nlist;
-struct list *list;
-#endif
extern int nlist;
extern struct list *list;
Modified: grass/trunk/imagery/i.cca/main.c
--- grass/trunk/imagery/i.cca/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.cca/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -38,7 +38,6 @@
#include <string.h>
#include <math.h>
-#define MAIN
#include <grass/imagery.h>
#include <grass/gmath.h>
Modified: grass/trunk/imagery/i.class/globals.h
--- grass/trunk/imagery/i.class/globals.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.class/globals.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,31 +3,24 @@
#include "defs.h"
-#ifndef GLOBAL
-# define GLOBAL extern
-# define INIT(x)
-#else
-# define INIT(x) = x
-#endif
+extern Window *PROMPT_WINDOW;
-GLOBAL Window *PROMPT_WINDOW;
+extern int SCREEN_TOP;
+extern int SCREEN_BOTTOM;
+extern int SCREEN_LEFT;
+extern int SCREEN_RIGHT;
-GLOBAL int SCREEN_TOP;
-GLOBAL int SCREEN_BOTTOM;
-GLOBAL int SCREEN_LEFT;
-GLOBAL int SCREEN_RIGHT;
+extern View *VIEW_MAP1;
+extern View *VIEW_TITLE1;
+extern View *VIEW_MAP1_ZOOM;
+extern View *VIEW_TITLE1_ZOOM;
-GLOBAL View *VIEW_MAP1;
-GLOBAL View *VIEW_TITLE1;
-GLOBAL View *VIEW_MAP1_ZOOM;
-GLOBAL View *VIEW_TITLE1_ZOOM;
+extern View *VIEW_MASK1;
+extern View *VIEW_MENU;
+extern View *VIEW_HISTO;
-GLOBAL View *VIEW_MASK1;
-GLOBAL View *VIEW_MENU;
-GLOBAL View *VIEW_HISTO;
+extern int THE_COLORS[10];
-GLOBAL int THE_COLORS[10];
#define BLACK THE_COLORS[0]
#define BLUE THE_COLORS[1]
#define BROWN THE_COLORS[2]
@@ -49,6 +42,7 @@
#define NUM_RED 7
#define NUM_WHITE 8
#define NUM_YELLOW 9
#define NAME_BLACK "Black"
#define NAME_BLUE "Blue"
#define NAME_BROWN "Brown"
@@ -59,35 +53,25 @@
#define NAME_RED "Red"
#define NAME_WHITE "White"
#define NAME_YELLOW "Yellow"
-#define MY_COLORS {{0,0,0}, /*black*/ \
- {50,50,255}, /*blue*/ \
- {170,200,70}, /*brown*/ \
- {0,255,0}, /*green*/ \
- {150,150,150}, /*grey*/ \
- {220,170,0}, /*orange*/\
- {200,0,200}, /*purple*/\
- {255,0,0}, /*red*/ \
- {255,255,255}, /*white*/ \
- {255,255,0}} /*yellow */
-GLOBAL struct
+struct Color_table
int red, grn, blue;
-} Color_table[10] INIT(MY_COLORS);
-GLOBAL struct Ref Refer;
-GLOBAL FILE *outsig_fd;
-GLOBAL struct Signature Sigs;
-GLOBAL struct Cell_head Band_cellhd;
+extern struct Color_table Color_table[10];
-double row_to_northing();
-double col_to_easting();
+extern struct Ref Refer;
+extern FILE *outsig_fd;
+extern struct Signature Sigs;
+extern struct Cell_head Band_cellhd;
-GLOBAL int *Bandfd;
-GLOBAL struct region Region;
-GLOBAL struct signalflag signalflag;
-GLOBAL CELL **Bandbuf;
+extern int *Bandfd;
+extern struct region Region;
+extern struct signalflag signalflag;
+extern CELL **Bandbuf;
+extern double row_to_northing(struct Cell_head *, int, double);
+extern double col_to_easting(struct Cell_head *, int, double);
-#undef INIT
#endif /* __GLOBALS_H__ */
Modified: grass/trunk/imagery/i.class/main.c
--- grass/trunk/imagery/i.class/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.class/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -18,8 +18,6 @@
* for details.
-#define MAIN
-#define GLOBAL
#include <stdlib.h>
#include <string.h>
@@ -29,7 +27,47 @@
+Window *PROMPT_WINDOW;
+int SCREEN_TOP;
+int SCREEN_BOTTOM;
+int SCREEN_LEFT;
+int SCREEN_RIGHT;
+View *VIEW_MAP1;
+View *VIEW_TITLE1;
+View *VIEW_MAP1_ZOOM;
+View *VIEW_TITLE1_ZOOM;
+View *VIEW_MASK1;
+View *VIEW_MENU;
+View *VIEW_HISTO;
+int THE_COLORS[10];
+struct Color_table Color_table[10] = {
+ {0,0,0}, /*black*/
+ {50,50,255}, /*blue*/
+ {170,200,70}, /*brown*/
+ {0,255,0}, /*green*/
+ {150,150,150}, /*grey*/
+ {220,170,0}, /*orange*/
+ {200,0,200}, /*purple*/
+ {255,0,0}, /*red*/
+ {255,255,255}, /*white*/
+ {255,255,0} /*yellow */
+struct Ref Refer;
+FILE *outsig_fd;
+struct Signature Sigs;
+struct Cell_head Band_cellhd;
+int *Bandfd;
+struct region Region;
+CELL **Bandbuf;
/* function prototypes */
static int check_files(char *, char *, char *, char *);
Modified: grass/trunk/imagery/i.fft/fftmain.c
--- grass/trunk/imagery/i.fft/fftmain.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.fft/fftmain.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -33,8 +33,6 @@
-#define MAIN
#include <string.h>
#include <stdlib.h>
#include <math.h>
@@ -44,12 +42,13 @@
+char Cellmap_real[GNAME_MAX], Cellmap_imag[GNAME_MAX];
/* Global variable & function declarations */
int Range;
- char Cellmap_orig[50];
+ char Cellmap_orig[GNAME_MAX];
int inputfd, realfd, imagfd; /* the input and output file descriptors */
char *inmapset; /* the input mapset name */
struct Cell_head window;
Modified: grass/trunk/imagery/i.fft/globals.h
--- grass/trunk/imagery/i.fft/globals.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.fft/globals.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,12 +1,6 @@
#ifndef __L_GLOBALS_H__
#define __L_GLOBALS_H__
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
+extern char Cellmap_real[], Cellmap_imag[];
-GLOBAL char Cellmap_real[50], Cellmap_imag[50];
#endif /* __L_GLOBALS_H__ */
Modified: grass/trunk/imagery/i.ifft/globals.h
--- grass/trunk/imagery/i.ifft/globals.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.ifft/globals.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,12 +1,6 @@
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
Modified: grass/trunk/imagery/i.ifft/ifftmain.c
--- grass/trunk/imagery/i.ifft/ifftmain.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.ifft/ifftmain.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -12,8 +12,6 @@
-#define MAIN
#include <string.h>
#include <stdlib.h>
#include <math.h>
@@ -23,11 +21,12 @@
FILE *realfp, *imagfp; /* the input and output file descriptors */
int outputfd, maskfd; /* the input and output file descriptors */
char *realmapset, *imagmapset; /* the input mapset names */
Modified: grass/trunk/imagery/i.ortho.photo/photo.camera/globals.h
--- grass/trunk/imagery/i.ortho.photo/photo.camera/globals.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.ortho.photo/photo.camera/globals.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,22 +1,17 @@
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
/* State flags Most are Toggles */
-GLOBAL char Data_Loaded; /* is there data in memory */
+extern char Data_Loaded; /* is there data in memory */
/* used for abnormal exit logic */
-GLOBAL char Files_Open; /* is there data in memory */
+extern char Files_Open; /* is there data in memory */
-GLOBAL struct Ortho_Camera_File_Ref cam_info;
+extern struct Ortho_Camera_File_Ref cam_info;
-GLOBAL char *camera;
+extern char *camera;
/* hold the names of files etc. mostly used by main.c */
-GLOBAL char *N_path;
-GLOBAL char *N_name;
-GLOBAL char *N_camera;
+extern char *N_path;
+extern char *N_name;
+extern char *N_camera;
/* mod_cam_info.c */
int mod_cam_info(int, struct Ortho_Camera_File_Ref *);
Modified: grass/trunk/imagery/i.ortho.photo/photo.camera/main.c
--- grass/trunk/imagery/i.ortho.photo/photo.camera/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.ortho.photo/photo.camera/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -18,11 +18,24 @@
/* select_camera */
/* select a camera reference file for a given imagery group */
-#define MAIN 1
#include <stdlib.h>
#include "orthophoto.h"
+char Data_Loaded; /* is there data in memory */
+ /* used for abnormal exit logic */
+char Files_Open; /* is there data in memory */
+struct Ortho_Camera_File_Ref cam_info;
+char *camera;
+/* hold the names of files etc. mostly used by main.c */
+char *N_path;
+char *N_name;
+char *N_camera;
static int have_old;
Modified: grass/trunk/imagery/i.ortho.photo/photo.elev/main.c
--- grass/trunk/imagery/i.ortho.photo/photo.elev/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.ortho.photo/photo.elev/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -18,7 +18,7 @@
/* main.c */
/* read the target for the block and cast it into the alternate GRASS env */
-#define MAIN
#include <stdlib.h>
#include <stdio.h>
#include <unistd.h>
Modified: grass/trunk/imagery/i.ortho.photo/photo.init/globals.h
--- grass/trunk/imagery/i.ortho.photo/photo.init/globals.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.ortho.photo/photo.init/globals.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,23 +1,17 @@
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
-GLOBAL struct Ortho_Image_Group group;
+extern struct Ortho_Image_Group group;
#define DEG_TO_RADS 0.01745329
#define RAD_TO_DEGS 57.29578
Modified: grass/trunk/imagery/i.ortho.photo/photo.init/main.c
--- grass/trunk/imagery/i.ortho.photo/photo.init/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.ortho.photo/photo.init/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -17,12 +17,22 @@
-#define MAIN 1
#include <stdlib.h>
#include <string.h>
+struct Ortho_Image_Group group;
+char *N_path;
+char *N_name;
+char *N_camera;
int have_old;
Modified: grass/trunk/imagery/i.zc/main.c
--- grass/trunk/imagery/i.zc/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/imagery/i.zc/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -19,8 +19,6 @@
-#define MAIN
#include <stdlib.h>
#include <math.h>
@@ -45,7 +43,6 @@
int size; /* the length of one side */
long totsize; /* the Total number of data points */
double *data[2]; /* Data structure containing real & complex values of FFT */
- int save_args(); /* function to stash the command line arguments */
struct GModule *module;
struct Option *input_map, *output_map, *width, *threshold, *orientations;
const char *me;
@@ -67,7 +64,6 @@
input_map->multiple = NO;
input_map->gisprompt = "old,cell,raster";
input_map->description = _("Name of input raster map");
-#define INPUT_MAP input_map->answer
output_map = G_define_option();
output_map->key = "output";
@@ -76,7 +72,6 @@
output_map->multiple = NO;
output_map->gisprompt = "new,cell,raster";
output_map->description = _("Zero crossing raster map");
-#define OUTPUT_MAP output_map->answer
width = G_define_option();
width->key = "width";
@@ -107,16 +102,16 @@
exit(EXIT_FAILURE);
/* open input cell map */
- if ((inmapset = G_find_cell(INPUT_MAP, "")) == NULL)
- G_fatal_error(_("Raster map <%s> not found"), INPUT_MAP);
+ if ((inmapset = G_find_cell(input_map->answer, "")) == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), input_map->answer);
- inputfd = G_open_cell_old(INPUT_MAP, inmapset);
+ inputfd = G_open_cell_old(input_map->answer, inmapset);
if (inputfd < 0)
exit(EXIT_FAILURE);
/* check command line args for validity */
- if (G_legal_filename(OUTPUT_MAP) < 0)
- G_fatal_error(_("<%s> is an illegal file name"), OUTPUT_MAP);
+ if (G_legal_filename(output_map->answer) < 0)
+ G_fatal_error(_("<%s> is an illegal file name"), output_map->answer);
sscanf(threshold->answer, "%1lf", &Thresh);
if (Thresh <= 0.0)
@@ -188,7 +183,7 @@
/* open the output cell maps and allocate cell row buffers */
G_message(_("Writing transformed data to file..."));
- if ((zcfd = G_open_cell_new(OUTPUT_MAP)) < 0)
+ if ((zcfd = G_open_cell_new(output_map->answer)) < 0)
exit(EXIT_FAILURE);
cell_row = G_allocate_cell_buf();
Modified: grass/trunk/include/sqlp.h
--- grass/trunk/include/sqlp.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/include/sqlp.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -141,8 +141,4 @@
void sqpFreeNode(SQLPNODE *);
-#ifdef SQLP_MAIN
-SQLPSTMT *sqlpStmt;
-#else
extern SQLPSTMT *sqlpStmt;
-#endif
Modified: grass/trunk/lib/db/sqlp/sql.c
--- grass/trunk/lib/db/sqlp/sql.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/lib/db/sqlp/sql.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -28,8 +28,6 @@
-#define SQLP_MAIN
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
@@ -37,6 +35,8 @@
#include <assert.h>
#include <grass/sqlp.h>
+SQLPSTMT *sqlpStmt;
/* save string to value */
int sqpSaveStr(SQLPVALUE * val, char *c)
Copied: grass/trunk/lib/dspf/cell_table.c (from rev 32672, grass/trunk/lib/dspf/cell_table.h)
--- grass/trunk/lib/dspf/cell_table.c (rev 0)
+++ grass/trunk/lib/dspf/cell_table.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -0,0 +1,2309 @@
+#include "viz.h"
+CELL_ENTRY cell_table[256] = {
+ {0, {0, 0, 0, 0, 0, 0, 0, 0}
+ 0, {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
+ 0, {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ 0, 0, 0, 0, 0, 0, 0}
+ {1, {1, 0, 0, 0, 0, 0, 0, 0}
+ 3, {1, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0}
+ 1, {1, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {1, {2, 0, 0, 0, 0, 0, 0, 0}
+ 3, {1, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0}
+ 1, {1, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {1, 2, 0, 0, 0, 0, 0, 0}
+ 4, {2, 4, 9, 10, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {2, 9, 10, 2, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {1, {3, 0, 0, 0, 0, 0, 0, 0}
+ 3, {3, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0}
+ 1, {3, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {1, 3, 0, 0, 0, 0, 0, 0}
+ 6, {1, 2, 3, 4, 9, 12, 0, 0, 0, 0, 0, 0}
+ 2, {1, 4, 9, 3, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {3, 2, 0, 0, 0, 0, 0, 0}
+ 4, {10, 12, 3, 1, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {10, 3, 1, 10, 12, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ 0, 0, 0, 0, 0, 0, 0, 0}
+ {3, {3, 2, 1, 0, 0, 0, 0, 0}
+ 5, {10, 12, 4, 9, 3, 0, 0, 0, 0, 0, 0, 0}
+ 3, {12, 9, 10, 3, 9, 12, 3, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {1, {4, 0, 0, 0, 0, 0, 0, 0}
+ 3, {3, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0}
+ 1, {3, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {1, 4, 0, 0, 0, 0, 0, 0}
+ 4, {11, 9, 1, 3, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {11, 1, 3, 11, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {2, 4, 0, 0, 0, 0, 0, 0}
+ 6, {2, 3, 4, 1, 10, 11, 0, 0, 0, 0, 0, 0}
+ 2, {2, 1, 10, 4, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {2, 1, 4, 0, 0, 0, 0, 0}
+ 5, {9, 10, 3, 11, 2, 0, 0, 0, 0, 0, 0, 0}
+ 3, {10, 11, 9, 2, 11, 10, 2, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ 0, 0, 0, 0, 0, 0, 0, 0, 0}
+ {2, {4, 3, 0, 0, 0, 0, 0, 0}
+ 4, {12, 11, 4, 2, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {12, 4, 2, 12, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {1, 4, 3, 0, 0, 0, 0, 0}
+ 5, {11, 9, 2, 12, 1, 0, 0, 0, 0, 0, 0, 0}
+ 3, {9, 12, 11, 1, 12, 9, 1, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {4, 3, 2, 0, 0, 0, 0, 0}
+ 5, {12, 11, 1, 10, 4, 0, 0, 0, 0, 0, 0, 0}
+ 3, {11, 10, 12, 4, 10, 11, 4, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {4, 3, 1, 2, 0, 0, 0, 0}
+ 4, {12, 11, 10, 9, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {11, 9, 10, 11, 10, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {1, {5, 0, 0, 0, 0, 0, 0, 0}
+ 3, {5, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0}
+ 1, {5, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {5, 1, 0, 0, 0, 0, 0, 0}
+ 4, {4, 8, 5, 1, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {4, 5, 1, 4, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {5, 2, 0, 0, 0, 0, 0, 0}
+ 6, {5, 10, 1, 9, 8, 2, 0, 0, 0, 0, 0, 0}
+ 2, {5, 9, 8, 1, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {5, 1, 2, 0, 0, 0, 0, 0}
+ 5, {4, 8, 10, 2, 5, 0, 0, 0, 0, 0, 0, 0}
+ 3, {8, 2, 4, 5, 2, 8, 5, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {5, 3, 0, 0, 0, 0, 0, 0}
+ 6, {5, 9, 12, 3, 8, 2, 0, 0, 0, 0, 0, 0}
+ 2, {5, 9, 8, 12, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {5, 1, 3, 0, 0, 0, 0, 0}
+ 7, {4, 8, 2, 12, 5, 1, 3, 0, 0, 0, 0, 0}
+ 3, {2, 12, 3, 4, 8, 5, 4, 5, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {3, 2, 5, 0, 0, 0, 0, 0}
+ 7, {10, 12, 9, 8, 3, 1, 5, 0, 0, 0, 0, 0}
+ 3, {9, 8, 5, 10, 12, 3, 10, 3, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {3, 1, 2, 5, 0, 0, 0, 0}
+ 6, {3, 12, 10, 5, 4, 8, 0, 0, 0, 0, 0, 0}
+ 4, {3, 10, 12, 3, 8, 10, 3, 4, 8, 10, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {5, 4, 0, 0, 0, 0, 0, 0}
+ 6, {9, 4, 11, 8, 5, 3, 0, 0, 0, 0, 0, 0}
+ 2, {9, 8, 5, 11, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {4, 1, 5, 0, 0, 0, 0, 0}
+ 5, {1, 3, 8, 5, 11, 0, 0, 0, 0, 0, 0, 0}
+ 3, {3, 5, 1, 11, 5, 3, 11, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {5, 4, 2, 0, 0, 0, 0, 0}
+ 9, {8, 9, 4, 11, 10, 2, 5, 3, 1, 0, 0, 0}
+ 3, {10, 2, 1, 4, 3, 11, 9, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {4, 1, 2, 5, 0, 0, 0, 0}
+ 6, {3, 11, 10, 5, 2, 8, 0, 0, 0, 0, 0, 0}
+ 4, {10, 2, 3, 5, 10, 3, 11, 5, 3, 8, 5, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {3, 4, 5, 0, 0, 0, 0, 0}
+ 7, {4, 2, 8, 5, 12, 11, 9, 0, 0, 0, 0, 0}
+ 3, {8, 5, 9, 4, 2, 12, 4, 12, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {3, 4, 1, 5, 0, 0, 0, 0}
+ 6, {2, 12, 8, 11, 1, 5, 0, 0, 0, 0, 0, 0}
+ 4, {12, 11, 2, 11, 5, 2, 5, 1, 2, 8, 5, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {4, 5, 2, 3, 0, 0, 0, 0}
+ 8, {4, 11, 8, 9, 12, 10, 1, 5, 0, 0, 0, 0}
+ 4, {11, 10, 12, 11, 1, 10, 4, 1, 11, 8, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {3, 2, 5, 4, 1, 0, 0, 0}
+ 5, {12, 10, 8, 11, 5, 0, 0, 0, 0, 0, 0, 0}
+ 3, {11, 10, 12, 11, 5, 10, 8, 5, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {1, {6, 0, 0, 0, 0, 0, 0, 0}
+ 3, {5, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0}
+ 1, {5, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {6, 1, 0, 0, 0, 0, 0, 0}
+ 6, {10, 1, 9, 5, 6, 4, 0, 0, 0, 0, 0, 0}
+ 2, {10, 5, 6, 9, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {2, 6, 0, 0, 0, 0, 0, 0}
+ 4, {6, 2, 1, 5, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {6, 1, 5, 6, 2, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {1, 2, 6, 0, 0, 0, 0, 0}
+ 5, {2, 4, 5, 6, 9, 0, 0, 0, 0, 0, 0, 0}
+ 3, {4, 6, 2, 9, 6, 4, 9, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {3, 6, 0, 0, 0, 0, 0, 0}
+ 6, {2, 10, 6, 12, 3, 5, 0, 0, 0, 0, 0, 0}
+ 2, {2, 12, 3, 6, 10, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {6, 1, 3, 0, 0, 0, 0, 0}
+ 9, {5, 10, 1, 9, 12, 3, 6, 4, 2, 0, 0, 0}
+ 3, {12, 3, 2, 1, 4, 9, 10, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {6, 2, 3, 0, 0, 0, 0, 0}
+ 5, {1, 5, 12, 3, 6, 0, 0, 0, 0, 0, 0, 0}
+ 3, {5, 3, 1, 6, 3, 5, 6, 12, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {1, 2, 3, 6, 0, 0, 0, 0}
+ 6, {4, 9, 12, 6, 3, 5, 0, 0, 0, 0, 0, 0}
+ 4, {12, 3, 4, 6, 12, 4, 9, 6, 4, 5, 6, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {4, 6, 0, 0, 0, 0, 0, 0}
+ 6, {3, 11, 10, 5, 4, 6, 0, 0, 0, 0, 0, 0}
+ 2, {3, 11, 4, 10, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {4, 1, 6, 0, 0, 0, 0, 0}
+ 7, {1, 3, 5, 6, 11, 9, 10, 0, 0, 0, 0, 0}
+ 3, {5, 6, 10, 1, 3, 11, 1, 11, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {6, 2, 4, 0, 0, 0, 0, 0}
+ 7, {1, 5, 3, 11, 6, 2, 4, 0, 0, 0, 0, 0}
+ 3, {3, 11, 4, 1, 5, 6, 1, 6, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {4, 1, 2, 6, 0, 0, 0, 0}
+ 6, {3, 11, 5, 9, 2, 6, 0, 0, 0, 0, 0, 0}
+ 4, {11, 9, 3, 9, 6, 3, 6, 2, 3, 5, 6, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {4, 3, 6, 0, 0, 0, 0, 0}
+ 7, {12, 11, 10, 5, 4, 2, 6, 0, 0, 0, 0, 0}
+ 3, {10, 5, 6, 12, 11, 4, 12, 4, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {1, 6, 3, 4, 0, 0, 0, 0}
+ 8, {1, 9, 5, 10, 11, 12, 2, 6, 0, 0, 0, 0}
+ 4, {9, 12, 11, 9, 2, 12, 1, 2, 9, 5, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {4, 2, 3, 6, 0, 0, 0, 0}
+ 6, {4, 11, 12, 6, 1, 5, 0, 0, 0, 0, 0, 0}
+ 4, {4, 12, 11, 4, 5, 12, 4, 1, 5, 12, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {4, 3, 6, 1, 2, 0, 0, 0}
+ 5, {11, 12, 5, 9, 6, 0, 0, 0, 0, 0, 0, 0}
+ 3, {9, 12, 11, 9, 6, 12, 5, 6, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {5, 6, 0, 0, 0, 0, 0, 0}
+ 4, {10, 9, 8, 6, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {10, 8, 6, 10, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {6, 5, 1, 0, 0, 0, 0, 0}
+ 5, {8, 6, 1, 4, 10, 0, 0, 0, 0, 0, 0, 0}
+ 3, {6, 4, 8, 10, 4, 6, 10, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {2, 6, 5, 0, 0, 0, 0, 0}
+ 5, {6, 2, 9, 8, 1, 0, 0, 0, 0, 0, 0, 0}
+ 3, {2, 8, 6, 1, 8, 2, 1, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {1, 2, 5, 6, 0, 0, 0, 0}
+ 4, {2, 4, 6, 8, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {4, 8, 6, 4, 6, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {5, 6, 3, 0, 0, 0, 0, 0}
+ 7, {10, 9, 12, 3, 8, 6, 2, 0, 0, 0, 0, 0}
+ 3, {12, 3, 2, 10, 9, 8, 10, 8, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {6, 3, 1, 5, 0, 0, 0, 0}
+ 8, {10, 6, 12, 2, 8, 4, 1, 3, 0, 0, 0, 0}
+ 4, {6, 4, 8, 6, 1, 4, 10, 1, 6, 12, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {5, 6, 2, 3, 0, 0, 0, 0}
+ 6, {9, 8, 12, 6, 1, 3, 0, 0, 0, 0, 0, 0}
+ 4, {8, 6, 9, 6, 3, 9, 3, 1, 9, 12, 3, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {5, 1, 3, 6, 2, 0, 0, 0}
+ 5, {8, 4, 12, 6, 3, 0, 0, 0, 0, 0, 0, 0}
+ 3, {6, 4, 8, 6, 3, 4, 12, 3, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {6, 5, 4, 0, 0, 0, 0, 0}
+ 7, {8, 6, 4, 3, 10, 9, 11, 0, 0, 0, 0, 0}
+ 3, {4, 3, 11, 8, 6, 10, 8, 10, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {6, 1, 5, 4, 0, 0, 0, 0}
+ 6, {10, 6, 8, 11, 1, 3, 0, 0, 0, 0, 0, 0}
+ 4, {10, 8, 6, 10, 3, 8, 10, 1, 3, 8, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {2, 4, 5, 6, 0, 0, 0, 0}
+ 8, {1, 2, 3, 4, 6, 8, 9, 11, 0, 0, 0, 0}
+ 4, {2, 8, 6, 2, 9, 8, 1, 9, 2, 3, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {6, 5, 4, 2, 1, 0, 0, 0}
+ 5, {6, 8, 3, 2, 11, 0, 0, 0, 0, 0, 0, 0}
+ 3, {2, 8, 6, 2, 11, 8, 3, 11, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {3, 4, 6, 5, 0, 0, 0, 0}
+ 8, {12, 11, 10, 9, 2, 6, 4, 8, 0, 0, 0, 0}
+ 4, {12, 11, 2, 11, 4, 2, 10, 8, 6, 10, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {6, 5, 4, 3, 1, 0, 0, 0}
+ 7, {6, 8, 2, 1, 11, 12, 10, 0, 0, 0, 0, 0}
+ 5, {1, 2, 10, 8, 6, 11, 11, 6, 12, 12, 6, 2, 2, 6, 10, 0, 0, 0, 0, 0, 0,
+ {5, {4, 3, 6, 5, 2, 0, 0, 0}
+ 7, {11, 12, 9, 1, 6, 8, 4, 0, 0, 0, 0, 0}
+ 5, {1, 9, 4, 12, 11, 6, 6, 11, 8, 8, 11, 9, 9, 11, 4, 0, 0, 0, 0, 0, 0,
+ {6, {6, 5, 4, 3, 2, 1, 0, 0}
+ 4, {6, 8, 11, 12, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {11, 6, 12, 8, 6, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {1, {7, 0, 0, 0, 0, 0, 0, 0}
+ 3, {7, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0}
+ 1, {7, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {1, 7, 0, 0, 0, 0, 0, 0}
+ 6, {1, 4, 6, 7, 9, 12, 0, 0, 0, 0, 0, 0}
+ 2, {1, 4, 9, 6, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {2, 7, 0, 0, 0, 0, 0, 0}
+ 6, {10, 6, 12, 2, 1, 7, 0, 0, 0, 0, 0, 0}
+ 2, {10, 2, 1, 12, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {1, 2, 7, 0, 0, 0, 0, 0}
+ 7, {2, 4, 6, 7, 9, 10, 12, 0, 0, 0, 0, 0}
+ 3, {6, 7, 12, 2, 4, 9, 2, 9, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {7, 3, 0, 0, 0, 0, 0, 0}
+ 4, {2, 6, 7, 3, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {2, 7, 3, 2, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {7, 3, 1, 0, 0, 0, 0, 0}
+ 7, {2, 6, 4, 9, 7, 3, 1, 0, 0, 0, 0, 0}
+ 3, {4, 9, 1, 2, 6, 7, 2, 7, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {2, 3, 7, 0, 0, 0, 0, 0}
+ 5, {3, 1, 6, 7, 10, 0, 0, 0, 0, 0, 0, 0}
+ 3, {1, 7, 3, 10, 7, 1, 10, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {1, 2, 3, 7, 0, 0, 0, 0}
+ 6, {4, 9, 6, 10, 3, 7, 0, 0, 0, 0, 0, 0}
+ 4, {9, 10, 4, 10, 7, 4, 7, 3, 4, 6, 7, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {4, 7, 0, 0, 0, 0, 0, 0}
+ 6, {3, 12, 7, 11, 4, 6, 0, 0, 0, 0, 0, 0}
+ 2, {3, 11, 4, 7, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {1, 4, 7, 0, 0, 0, 0, 0}
+ 7, {11, 9, 12, 6, 1, 3, 7, 0, 0, 0, 0, 0}
+ 3, {12, 6, 7, 11, 9, 1, 11, 1, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {2, 4, 7, 0, 0, 0, 0, 0}
+ 9, {1, 2, 3, 4, 6, 7, 10, 11, 12, 0, 0, 0}
+ 3, {6, 7, 12, 3, 11, 4, 2, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {2, 7, 4, 1, 0, 0, 0, 0}
+ 8, {2, 10, 6, 12, 9, 11, 3, 7, 0, 0, 0, 0}
+ 4, {10, 11, 9, 10, 3, 11, 2, 3, 10, 6, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {7, 3, 4, 0, 0, 0, 0, 0}
+ 5, {2, 6, 11, 4, 7, 0, 0, 0, 0, 0, 0, 0}
+ 3, {6, 4, 2, 7, 4, 6, 7, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {7, 4, 3, 1, 0, 0, 0, 0}
+ 6, {7, 6, 2, 1, 11, 9, 0, 0, 0, 0, 0, 0}
+ 4, {7, 2, 6, 7, 9, 2, 7, 11, 9, 2, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {4, 3, 7, 2, 0, 0, 0, 0}
+ 6, {11, 4, 6, 10, 7, 1, 0, 0, 0, 0, 0, 0}
+ 4, {6, 7, 11, 10, 6, 11, 4, 10, 11, 1, 10, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {1, 4, 7, 2, 3, 0, 0, 0}
+ 5, {9, 11, 6, 10, 7, 0, 0, 0, 0, 0, 0, 0}
+ 3, {10, 11, 9, 10, 7, 11, 6, 7, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {7, 5, 0, 0, 0, 0, 0, 0}
+ 6, {6, 5, 8, 7, 12, 9, 0, 0, 0, 0, 0, 0}
+ 2, {6, 7, 12, 8, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {1, 5, 7, 0, 0, 0, 0, 0}
+ 7, {5, 1, 7, 12, 4, 8, 6, 0, 0, 0, 0, 0}
+ 3, {7, 12, 6, 5, 1, 4, 5, 4, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {7, 5, 2, 0, 0, 0, 0, 0}
+ 9, {7, 6, 5, 8, 2, 1, 12, 9, 10, 0, 0, 0}
+ 3, {2, 1, 10, 5, 9, 8, 6, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {5, 7, 2, 1, 0, 0, 0, 0}
+ 8, {5, 8, 7, 6, 4, 2, 10, 12, 0, 0, 0, 0}
+ 4, {8, 2, 4, 8, 10, 2, 5, 10, 8, 7, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {3, 7, 5, 0, 0, 0, 0, 0}
+ 7, {7, 3, 5, 9, 2, 6, 8, 0, 0, 0, 0, 0}
+ 3, {5, 9, 8, 7, 3, 2, 7, 2, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {5, 1, 7, 3, 0, 0, 0, 0}
+ 8, {5, 1, 7, 3, 8, 6, 4, 2, 0, 0, 0, 0}
+ 4, {5, 1, 8, 1, 4, 8, 7, 2, 6, 7, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {2, 5, 7, 3, 0, 0, 0, 0}
+ 8, {10, 1, 9, 5, 3, 7, 6, 8, 0, 0, 0, 0}
+ 4, {1, 7, 3, 1, 6, 7, 10, 6, 1, 9, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {5, 1, 3, 7, 2, 0, 0, 0}
+ 7, {8, 4, 6, 10, 3, 7, 5, 0, 0, 0, 0, 0}
+ 5, {10, 6, 5, 4, 8, 3, 3, 8, 7, 7, 8, 6, 6, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {4, 5, 7, 0, 0, 0, 0, 0}
+ 9, {4, 11, 8, 9, 12, 6, 3, 5, 7, 0, 0, 0}
+ 3, {12, 6, 7, 8, 5, 9, 11, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {4, 7, 5, 1, 0, 0, 0, 0}
+ 8, {11, 3, 12, 7, 1, 5, 8, 6, 0, 0, 0, 0}
+ 4, {3, 5, 1, 3, 8, 5, 11, 8, 3, 12, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {4, 7, 2, 5, 0, 0, 0, 0}
+ 12, {3, 12, 7, 11, 1, 10, 5, 9, 4, 2, 8, 6}
+ 4, {3, 11, 4, 12, 6, 7, 1, 10, 2, 5, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {4, 7, 1, 2, 5, 0, 0, 0}
+ 9, {3, 12, 7, 11, 10, 5, 2, 8, 6, 0, 0, 0}
+ 10, {5, 10, 6, 8, 7, 11, 3, 12, 2, 12, 3, 11, 12, 11, 7, 7, 8, 5, 7, 5,
+ 6, 12, 10, 2, 12, 6, 10, 12, 7, 6}
+ {4, {7, 5, 4, 3, 0, 0, 0, 0}
+ 8, {7, 6, 5, 8, 2, 4, 11, 9, 0, 0, 0, 0}
+ 4, {6, 4, 2, 6, 11, 4, 7, 11, 6, 5, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {7, 3, 1, 5, 4, 0, 0, 0}
+ 7, {6, 2, 8, 11, 1, 5, 7, 0, 0, 0, 0, 0}
+ 5, {11, 8, 7, 2, 6, 1, 1, 6, 5, 5, 6, 8, 8, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {4, 5, 3, 7, 2, 0, 0, 0}
+ 9, {11, 8, 9, 4, 6, 10, 7, 1, 5, 0, 0, 0}
+ 10, {10, 6, 5, 1, 9, 4, 11, 8, 7, 8, 11, 4, 8, 4, 9, 9, 1, 10, 9, 10, 5,
+ 8, 6, 7, 8, 5, 6, 8, 9, 5}
+ {6, {7, 5, 4, 3, 2, 1, 0, 0}
+ 6, {7, 6, 5, 8, 11, 10, 0, 0, 0, 0, 0, 0}
+ 4, {8, 7, 11, 6, 5, 10, 6, 7, 8, 6, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {6, 7, 0, 0, 0, 0, 0, 0}
+ 4, {12, 10, 5, 7, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {12, 5, 7, 12, 10, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {7, 6, 1, 0, 0, 0, 0, 0}
+ 7, {5, 7, 1, 4, 12, 10, 9, 0, 0, 0, 0, 0}
+ 3, {1, 4, 9, 5, 7, 12, 5, 12, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {7, 6, 2, 0, 0, 0, 0, 0}
+ 5, {5, 7, 2, 1, 12, 0, 0, 0, 0, 0, 0, 0}
+ 3, {7, 1, 5, 12, 1, 7, 12, 2, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {1, 6, 2, 7, 0, 0, 0, 0}
+ 6, {9, 4, 2, 12, 5, 7, 0, 0, 0, 0, 0, 0}
+ 4, {9, 2, 4, 9, 7, 2, 9, 5, 7, 2, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {3, 7, 6, 0, 0, 0, 0, 0}
+ 5, {7, 3, 10, 5, 2, 0, 0, 0, 0, 0, 0, 0}
+ 3, {3, 5, 7, 2, 5, 3, 2, 10, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {3, 1, 6, 7, 0, 0, 0, 0}
+ 8, {2, 3, 4, 1, 7, 5, 10, 9, 0, 0, 0, 0}
+ 4, {3, 5, 7, 3, 10, 5, 2, 10, 3, 4, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {2, 3, 6, 7, 0, 0, 0, 0}
+ 4, {3, 1, 7, 5, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {1, 5, 7, 1, 7, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {7, 6, 1, 3, 2, 0, 0, 0}
+ 5, {7, 5, 4, 3, 9, 0, 0, 0, 0, 0, 0, 0}
+ 3, {3, 5, 7, 3, 9, 5, 4, 9, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {6, 7, 4, 0, 0, 0, 0, 0}
+ 7, {12, 10, 11, 4, 5, 7, 3, 0, 0, 0, 0, 0}
+ 3, {11, 4, 3, 12, 10, 5, 12, 5, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {1, 4, 6, 7, 0, 0, 0, 0}
+ 8, {1, 3, 5, 7, 9, 10, 11, 12, 0, 0, 0, 0}
+ 4, {1, 3, 9, 3, 11, 9, 5, 12, 10, 5, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {7, 4, 2, 6, 0, 0, 0, 0}
+ 8, {12, 7, 11, 3, 5, 1, 2, 4, 0, 0, 0, 0}
+ 4, {7, 1, 5, 7, 2, 1, 12, 2, 7, 11, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {7, 6, 1, 4, 2, 0, 0, 0}
+ 7, {7, 5, 3, 2, 9, 11, 12, 0, 0, 0, 0, 0}
+ 5, {2, 3, 12, 5, 7, 9, 9, 7, 11, 11, 7, 3, 3, 7, 12, 0, 0, 0, 0, 0, 0, 0,
+ {4, {4, 3, 7, 6, 0, 0, 0, 0}
+ 6, {11, 4, 10, 2, 7, 5, 0, 0, 0, 0, 0, 0}
+ 4, {4, 2, 11, 2, 5, 11, 5, 7, 11, 10, 5, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {1, 4, 7, 6, 3, 0, 0, 0}
+ 7, {9, 11, 10, 2, 7, 5, 1, 0, 0, 0, 0, 0}
+ 5, {2, 10, 1, 11, 9, 7, 7, 9, 5, 5, 9, 10, 10, 9, 1, 0, 0, 0, 0, 0, 0, 0,
+ {5, {6, 2, 4, 7, 3, 0, 0, 0}
+ 5, {5, 1, 11, 7, 4, 0, 0, 0, 0, 0, 0, 0}
+ 3, {7, 1, 5, 7, 4, 1, 11, 4, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {1, 4, 7, 6, 2, 3, 0, 0}
+ 4, {9, 11, 7, 5, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {7, 9, 5, 11, 9, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {5, 6, 7, 0, 0, 0, 0, 0}
+ 5, {10, 9, 7, 12, 8, 0, 0, 0, 0, 0, 0, 0}
+ 3, {9, 12, 10, 8, 12, 9, 8, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {1, 5, 6, 7, 0, 0, 0, 0}
+ 6, {1, 4, 7, 8, 10, 12, 0, 0, 0, 0, 0, 0}
+ 4, {4, 8, 1, 8, 12, 1, 12, 10, 1, 7, 12, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {5, 6, 2, 7, 0, 0, 0, 0}
+ 6, {9, 8, 2, 12, 1, 7, 0, 0, 0, 0, 0, 0}
+ 4, {2, 1, 9, 12, 2, 9, 8, 12, 9, 7, 12, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {1, 2, 7, 5, 6, 0, 0, 0}
+ 5, {4, 2, 7, 8, 12, 0, 0, 0, 0, 0, 0, 0}
+ 3, {8, 2, 4, 8, 12, 2, 7, 12, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {5, 7, 6, 3, 0, 0, 0, 0}
+ 6, {8, 9, 10, 2, 7, 3, 0, 0, 0, 0, 0, 0}
+ 4, {8, 10, 9, 8, 3, 10, 8, 7, 3, 10, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {3, 7, 5, 1, 6, 0, 0, 0}
+ 7, {3, 7, 1, 10, 8, 4, 2, 0, 0, 0, 0, 0}
+ 5, {10, 1, 2, 7, 3, 8, 8, 3, 4, 4, 3, 1, 1, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {3, 7, 5, 2, 6, 0, 0, 0}
+ 5, {3, 7, 9, 1, 8, 0, 0, 0, 0, 0, 0, 0}
+ 3, {1, 7, 3, 1, 8, 7, 9, 8, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {5, 1, 3, 7, 6, 2, 0, 0}
+ 4, {8, 4, 3, 7, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {3, 8, 7, 4, 8, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {5, 4, 7, 6, 0, 0, 0, 0}
+ 8, {8, 9, 4, 11, 10, 12, 7, 3, 0, 0, 0, 0}
+ 4, {9, 12, 10, 9, 7, 12, 8, 7, 9, 4, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {4, 1, 6, 7, 5, 0, 0, 0}
+ 7, {3, 1, 7, 8, 10, 12, 11, 0, 0, 0, 0, 0}
+ 5, {8, 7, 11, 1, 3, 10, 10, 3, 12, 12, 3, 7, 7, 3, 11, 0, 0, 0, 0, 0, 0,
+ {5, {5, 4, 6, 2, 7, 0, 0, 0}
+ 9, {9, 4, 11, 8, 2, 12, 1, 7, 3, 0, 0, 0}
+ 10, {12, 2, 3, 7, 11, 8, 9, 4, 1, 4, 9, 8, 4, 8, 11, 11, 7, 12, 11, 12,
+ 3, 4, 2, 1, 4, 3, 2, 4, 11, 3}
+ {6, {7, 4, 2, 6, 5, 1, 0, 0}
+ 6, {12, 7, 11, 3, 2, 8, 0, 0, 0, 0, 0, 0}
+ 4, {3, 12, 2, 7, 11, 8, 7, 12, 3, 7, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {5, 6, 3, 4, 7, 0, 0, 0}
+ 7, {9, 10, 11, 7, 2, 4, 8, 0, 0, 0, 0, 0}
+ 5, {7, 11, 8, 10, 9, 2, 2, 9, 4, 4, 9, 11, 11, 9, 8, 0, 0, 0, 0, 0, 0, 0,
+ {6, {7, 6, 5, 4, 3, 1, 0, 0}
+ 6, {7, 8, 2, 1, 11, 10, 0, 0, 0, 0, 0, 0}
+ 2, {8, 7, 11, 1, 2, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {4, 5, 2, 3, 7, 6, 0, 0}
+ 6, {4, 11, 8, 9, 1, 7, 0, 0, 0, 0, 0, 0}
+ 4, {9, 4, 1, 11, 8, 7, 11, 4, 9, 11, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {7, {7, 6, 5, 4, 3, 2, 1, 0}
+ 3, {7, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0}
+ 1, {8, 7, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {1, {8, 0, 0, 0, 0, 0, 0, 0}
+ 1, {7, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {1, 8, 0, 0, 0, 0, 0, 0}
+ 2, {4, 9, 1, 8, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {8, 2, 0, 0, 0, 0, 0, 0}
+ 2, {7, 8, 11, 2, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {2, 1, 8, 0, 0, 0, 0, 0}
+ 3, {11, 7, 8, 9, 10, 2, 9, 2, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {3, 8, 0, 0, 0, 0, 0, 0}
+ 2, {12, 3, 2, 11, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {1, 8, 3, 0, 0, 0, 0, 0}
+ 3, {2, 12, 3, 11, 7, 8, 4, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {2, 3, 8, 0, 0, 0, 0, 0}
+ 3, {7, 8, 11, 3, 1, 10, 3, 10, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {3, 8, 1, 2, 0, 0, 0, 0}
+ 8, {3, 12, 7, 11, 10, 9, 4, 8, 0, 0, 0, 0}
+ 4, {12, 9, 10, 12, 4, 9, 3, 4, 12, 7, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {4, 8, 0, 0, 0, 0, 0, 0}
+ 2, {8, 3, 7, 8, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {8, 4, 1, 0, 0, 0, 0, 0}
+ 3, {7, 1, 3, 8, 1, 7, 8, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {8, 4, 2, 0, 0, 0, 0, 0}
+ 3, {1, 10, 2, 3, 7, 8, 3, 8, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {2, 4, 1, 8, 0, 0, 0, 0}
+ 6, {2, 10, 9, 8, 3, 7, 0, 0, 0, 0, 0, 0}
+ 4, {2, 9, 10, 2, 7, 9, 2, 3, 7, 9, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {3, 4, 8, 0, 0, 0, 0, 0}
+ 3, {2, 8, 4, 12, 8, 2, 12, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {8, 4, 3, 1, 0, 0, 0, 0}
+ 6, {7, 8, 2, 1, 12, 9, 0, 0, 0, 0, 0, 0}
+ 4, {2, 12, 7, 1, 2, 7, 8, 1, 7, 9, 1, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {8, 4, 3, 2, 0, 0, 0, 0}
+ 6, {7, 8, 1, 4, 12, 10, 0, 0, 0, 0, 0, 0}
+ 4, {8, 4, 7, 4, 10, 7, 10, 12, 7, 1, 10, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {2, 1, 8, 3, 4, 0, 0, 0}
+ 3, {12, 9, 10, 12, 8, 9, 7, 8, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {8, 5, 0, 0, 0, 0, 0, 0}
+ 2, {9, 7, 5, 9, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {1, 5, 8, 0, 0, 0, 0, 0}
+ 3, {1, 7, 5, 4, 7, 1, 4, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {8, 5, 2, 0, 0, 0, 0, 0}
+ 3, {10, 2, 1, 9, 11, 7, 9, 7, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {2, 1, 5, 8, 0, 0, 0, 0}
+ 6, {10, 2, 11, 4, 5, 7, 0, 0, 0, 0, 0, 0}
+ 4, {2, 4, 10, 4, 7, 10, 7, 5, 10, 11, 7, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {5, 8, 3, 0, 0, 0, 0, 0}
+ 3, {3, 2, 12, 7, 5, 9, 7, 9, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {1, 3, 8, 5, 0, 0, 0, 0}
+ 8, {4, 1, 2, 3, 5, 7, 11, 12, 0, 0, 0, 0}
+ 4, {1, 7, 5, 1, 11, 7, 4, 11, 1, 2, 12, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {8, 5, 3, 2, 0, 0, 0, 0}
+ 8, {7, 5, 3, 1, 11, 12, 9, 10, 0, 0, 0, 0}
+ 4, {7, 5, 11, 5, 9, 11, 3, 10, 12, 3, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {3, 2, 5, 8, 1, 0, 0, 0}
+ 5, {4, 11, 3, 10, 12, 5, 5, 12, 7, 7, 12, 11, 11, 12, 3, 0, 0, 0, 0, 0,
+ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
+ {3, {5, 8, 4, 0, 0, 0, 0, 0}
+ 3, {5, 3, 7, 9, 3, 5, 9, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {5, 8, 1, 4, 0, 0, 0, 0}
+ 4, {7, 5, 3, 1, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {5, 1, 3, 5, 3, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {5, 2, 4, 8, 0, 0, 0, 0}
+ 8, {9, 5, 10, 1, 7, 3, 4, 2, 0, 0, 0, 0}
+ 4, {5, 3, 7, 5, 4, 3, 9, 4, 5, 10, 2, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {8, 4, 2, 5, 1, 0, 0, 0}
+ 3, {5, 3, 7, 5, 2, 3, 10, 2, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {3, 8, 4, 5, 0, 0, 0, 0}
+ 6, {12, 2, 4, 9, 7, 5, 0, 0, 0, 0, 0, 0}
+ 4, {12, 4, 2, 12, 5, 4, 12, 7, 5, 4, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {5, 8, 3, 1, 4, 0, 0, 0}
+ 3, {1, 7, 5, 1, 12, 7, 2, 12, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {5, 8, 3, 2, 4, 0, 0, 0}
+ 5, {4, 1, 9, 7, 5, 12, 12, 5, 10, 10, 5, 1, 1, 5, 9, 0, 0, 0, 0, 0, 0, 0,
+ {6, {3, 2, 5, 8, 4, 1, 0, 0}
+ 2, {5, 12, 7, 10, 12, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {8, 6, 0, 0, 0, 0, 0, 0}
+ 2, {7, 8, 11, 5, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {8, 1, 6, 0, 0, 0, 0, 0}
+ 3, {6, 10, 5, 9, 1, 4, 8, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {2, 6, 8, 0, 0, 0, 0, 0}
+ 3, {8, 11, 7, 6, 2, 1, 6, 1, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {1, 8, 6, 2, 0, 0, 0, 0}
+ 8, {9, 4, 11, 8, 2, 6, 5, 7, 0, 0, 0, 0}
+ 4, {4, 6, 2, 4, 5, 6, 9, 5, 4, 11, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {3, 8, 6, 0, 0, 0, 0, 0}
+ 3, {10, 5, 6, 7, 8, 11, 12, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {1, 3, 6, 8, 0, 0, 0, 0}
+ 12, {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12}
+ 4, {1, 4, 9, 2, 12, 3, 5, 6, 10, 7, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {6, 8, 3, 2, 0, 0, 0, 0}
+ 8, {6, 5, 8, 7, 1, 3, 12, 11, 0, 0, 0, 0}
+ 4, {5, 3, 1, 5, 12, 3, 6, 12, 5, 8, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {1, 8, 2, 3, 6, 0, 0, 0}
+ 10, {6, 12, 7, 5, 8, 9, 4, 11, 3, 11, 4, 9, 11, 9, 8, 8, 5, 6, 8, 6, 7,
+ 11, 12, 3, 11, 7, 12, 11, 8, 7}
+ {3, {4, 8, 6, 0, 0, 0, 0, 0}
+ 3, {6, 10, 5, 8, 4, 3, 8, 3, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {8, 6, 1, 4, 0, 0, 0, 0}
+ 8, {8, 7, 6, 5, 3, 1, 9, 10, 0, 0, 0, 0}
+ 4, {7, 1, 3, 7, 9, 1, 8, 9, 7, 6, 10, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {4, 8, 2, 6, 0, 0, 0, 0}
+ 8, {3, 7, 1, 5, 4, 2, 8, 6, 0, 0, 0, 0}
+ 4, {3, 7, 4, 7, 8, 4, 1, 6, 2, 1, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {8, 4, 2, 6, 1, 0, 0, 0}
+ 5, {9, 5, 8, 3, 7, 2, 2, 7, 6, 6, 7, 5, 5, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {3, 6, 8, 4, 0, 0, 0, 0}
+ 8, {12, 2, 10, 6, 4, 8, 7, 5, 0, 0, 0, 0}
+ 4, {2, 8, 4, 2, 7, 8, 12, 7, 2, 10, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {8, 6, 4, 3, 1, 0, 0, 0}
+ 10, {1, 2, 10, 9, 5, 8, 7, 6, 12, 6, 7, 8, 6, 8, 5, 5, 9, 1, 5, 1, 10, 6,
+ 2, 12, 6, 10, 2, 6, 5, 10}
+ {5, {6, 2, 4, 8, 3, 0, 0, 0}
+ 5, {12, 7, 6, 1, 5, 4, 4, 5, 8, 8, 5, 7, 7, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {6, 8, 3, 2, 1, 4, 0, 0}
+ 4, {7, 6, 12, 5, 8, 9, 5, 6, 7, 5, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {8, 5, 6, 0, 0, 0, 0, 0}
+ 3, {11, 10, 9, 7, 10, 11, 7, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {1, 5, 6, 8, 0, 0, 0, 0}
+ 6, {1, 4, 6, 7, 10, 11, 0, 0, 0, 0, 0, 0}
+ 4, {6, 10, 1, 7, 6, 1, 4, 7, 1, 11, 7, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {2, 5, 6, 8, 0, 0, 0, 0}
+ 6, {1, 2, 6, 7, 9, 11, 0, 0, 0, 0, 0, 0}
+ 4, {1, 6, 2, 1, 11, 6, 1, 9, 11, 6, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {2, 6, 8, 1, 5, 0, 0, 0}
+ 3, {4, 6, 2, 4, 7, 6, 11, 7, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {8, 3, 6, 5, 0, 0, 0, 0}
+ 8, {7, 11, 3, 12, 9, 10, 6, 2, 0, 0, 0, 0}
+ 4, {11, 10, 9, 11, 6, 10, 7, 6, 11, 3, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {1, 3, 5, 6, 8, 0, 0, 0}
+ 10, {7, 6, 12, 11, 3, 4, 1, 2, 10, 2, 1, 4, 2, 4, 3, 3, 11, 7, 3, 7, 12,
+ 2, 6, 10, 2, 12, 6, 2, 3, 12}
+ {5, {8, 5, 2, 3, 6, 0, 0, 0}
+ 5, {6, 12, 7, 9, 11, 1, 1, 11, 3, 3, 11, 12, 12, 11, 7, 0, 0, 0, 0, 0, 0,
+ {6, {3, 8, 1, 2, 6, 5, 0, 0}
+ 4, {11, 3, 4, 12, 7, 6, 12, 3, 11, 12, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {6, 5, 8, 4, 0, 0, 0, 0}
+ 6, {6, 10, 4, 9, 7, 3, 0, 0, 0, 0, 0, 0}
+ 4, {10, 9, 6, 9, 3, 6, 3, 7, 6, 4, 3, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {4, 1, 6, 8, 5, 0, 0, 0}
+ 3, {7, 1, 3, 7, 10, 1, 6, 10, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {2, 6, 8, 4, 5, 0, 0, 0}
+ 5, {9, 4, 1, 6, 2, 7, 7, 2, 3, 3, 2, 4, 4, 2, 1, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {2, 6, 8, 4, 1, 5, 0, 0}
+ 2, {7, 2, 3, 6, 2, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {3, 4, 5, 6, 8, 0, 0, 0}
+ 5, {7, 6, 12, 4, 2, 9, 9, 2, 10, 10, 2, 6, 6, 2, 12, 0, 0, 0, 0, 0, 0, 0,
+ {6, {6, 3, 1, 5, 8, 4, 0, 0}
+ 4, {2, 10, 1, 6, 12, 7, 6, 10, 2, 6, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {2, 3, 4, 5, 6, 8, 0, 0}
+ 2, {4, 1, 9, 7, 6, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {7, {8, 4, 3, 6, 5, 1, 2, 0}
+ 1, {12, 7, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {2, {8, 7, 0, 0, 0, 0, 0, 0}
+ 2, {6, 11, 12, 6, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {7, 8, 1, 0, 0, 0, 0, 0}
+ 3, {9, 1, 4, 11, 12, 6, 11, 6, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {8, 7, 2, 0, 0, 0, 0, 0}
+ 3, {2, 1, 10, 6, 8, 11, 6, 11, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {2, 1, 7, 8, 0, 0, 0, 0}
+ 8, {2, 4, 6, 8, 10, 12, 9, 11, 0, 0, 0, 0}
+ 4, {2, 4, 10, 4, 9, 10, 6, 11, 12, 6, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {8, 7, 3, 0, 0, 0, 0, 0}
+ 3, {8, 2, 6, 11, 2, 8, 11, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {8, 1, 3, 7, 0, 0, 0, 0}
+ 8, {11, 8, 9, 4, 6, 2, 3, 1, 0, 0, 0, 0}
+ 4, {8, 2, 6, 8, 3, 2, 11, 3, 8, 9, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {8, 3, 7, 2, 0, 0, 0, 0}
+ 6, {11, 8, 6, 10, 3, 1, 0, 0, 0, 0, 0, 0}
+ 4, {11, 6, 8, 11, 1, 6, 11, 3, 1, 6, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {8, 7, 2, 1, 3, 0, 0, 0}
+ 5, {3, 4, 11, 6, 8, 10, 10, 8, 9, 9, 8, 4, 4, 8, 11, 0, 0, 0, 0, 0, 0, 0,
+ {3, {4, 8, 7, 0, 0, 0, 0, 0}
+ 3, {4, 6, 8, 3, 6, 4, 3, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {7, 8, 4, 1, 0, 0, 0, 0}
+ 6, {12, 6, 9, 8, 3, 1, 0, 0, 0, 0, 0, 0}
+ 4, {6, 8, 12, 8, 1, 12, 1, 3, 12, 9, 1, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {4, 2, 7, 8, 0, 0, 0, 0}
+ 8, {3, 4, 1, 2, 8, 6, 12, 10, 0, 0, 0, 0}
+ 4, {4, 6, 8, 4, 12, 6, 3, 12, 4, 1, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {2, 1, 8, 7, 4, 0, 0, 0}
+ 5, {3, 12, 2, 9, 10, 8, 8, 10, 6, 6, 10, 12, 12, 10, 2, 0, 0, 0, 0, 0, 0,
+ {4, {8, 7, 4, 3, 0, 0, 0, 0}
+ 4, {6, 8, 2, 4, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {8, 4, 2, 8, 2, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {7, 3, 1, 8, 4, 0, 0, 0}
+ 3, {8, 2, 6, 8, 1, 2, 9, 1, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {8, 7, 2, 4, 3, 0, 0, 0}
+ 3, {4, 6, 8, 4, 10, 6, 1, 10, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {2, 1, 8, 7, 3, 4, 0, 0}
+ 2, {8, 10, 6, 9, 10, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {7, 8, 5, 0, 0, 0, 0, 0}
+ 3, {12, 9, 11, 6, 9, 12, 6, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {7, 5, 8, 1, 0, 0, 0, 0}
+ 6, {6, 12, 11, 4, 5, 1, 0, 0, 0, 0, 0, 0}
+ 4, {6, 11, 12, 6, 1, 11, 6, 5, 1, 11, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {7, 2, 5, 8, 0, 0, 0, 0}
+ 8, {6, 12, 2, 10, 11, 9, 5, 1, 0, 0, 0, 0}
+ 4, {12, 9, 11, 12, 5, 9, 6, 5, 12, 2, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {7, 8, 1, 2, 5, 0, 0, 0}
+ 5, {5, 10, 6, 11, 12, 4, 4, 12, 2, 2, 12, 10, 10, 12, 6, 0, 0, 0, 0, 0,
+ {4, {5, 8, 7, 3, 0, 0, 0, 0}
+ 6, {5, 9, 3, 11, 6, 2, 0, 0, 0, 0, 0, 0}
+ 4, {9, 11, 5, 11, 2, 5, 2, 6, 5, 3, 2, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {1, 5, 7, 3, 8, 0, 0, 0}
+ 5, {11, 3, 4, 5, 1, 6, 6, 1, 2, 2, 1, 3, 3, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {2, 3, 8, 5, 7, 0, 0, 0}
+ 5, {6, 5, 10, 3, 1, 11, 11, 1, 9, 9, 1, 5, 5, 1, 10, 0, 0, 0, 0, 0, 0, 0,
+ {6, {3, 7, 8, 1, 2, 5, 0, 0}
+ 2, {11, 3, 4, 5, 10, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {5, 8, 7, 4, 0, 0, 0, 0}
+ 6, {5, 9, 12, 3, 6, 4, 0, 0, 0, 0, 0, 0}
+ 4, {12, 6, 5, 3, 12, 5, 9, 3, 5, 4, 3, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {1, 5, 7, 4, 8, 0, 0, 0}
+ 3, {3, 5, 1, 3, 6, 5, 12, 6, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {5, 2, 8, 7, 4, 0, 0, 0}
+ 10, {3, 12, 2, 4, 1, 9, 5, 10, 6, 10, 5, 9, 10, 9, 1, 1, 4, 3, 1, 3, 2,
+ 10, 12, 6, 10, 2, 12, 10, 1, 2}
+ {6, {2, 7, 4, 1, 5, 8, 0, 0}
+ 4, {12, 2, 3, 10, 6, 5, 10, 2, 12, 10, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {3, 4, 5, 7, 8, 0, 0, 0}
+ 3, {6, 4, 2, 6, 9, 4, 5, 9, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {7, 3, 1, 5, 8, 4, 0, 0}
+ 2, {1, 6, 5, 2, 6, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {2, 5, 7, 3, 4, 8, 0, 0}
+ 4, {5, 10, 6, 1, 9, 4, 1, 10, 5, 1, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {7, {5, 8, 7, 2, 1, 4, 3, 0}
+ 1, {6, 5, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {3, {6, 7, 8, 0, 0, 0, 0, 0}
+ 3, {10, 11, 12, 5, 11, 10, 5, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {6, 1, 8, 7, 0, 0, 0, 0}
+ 8, {5, 10, 1, 9, 12, 11, 8, 4, 0, 0, 0, 0}
+ 4, {10, 11, 12, 10, 8, 11, 5, 8, 10, 1, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {8, 7, 6, 2, 0, 0, 0, 0}
+ 6, {8, 11, 2, 12, 5, 1, 0, 0, 0, 0, 0, 0}
+ 4, {11, 12, 8, 12, 1, 8, 1, 5, 8, 2, 1, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {1, 2, 7, 8, 6, 0, 0, 0}
+ 5, {5, 8, 9, 2, 4, 12, 12, 4, 11, 11, 4, 8, 8, 4, 9, 0, 0, 0, 0, 0, 0, 0,
+ {4, {8, 7, 6, 3, 0, 0, 0, 0}
+ 6, {8, 11, 10, 2, 5, 3, 0, 0, 0, 0, 0, 0}
+ 4, {10, 5, 8, 2, 10, 8, 11, 2, 8, 3, 2, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {8, 1, 7, 6, 3, 0, 0, 0}
+ 10, {2, 10, 1, 3, 4, 11, 8, 9, 5, 9, 8, 11, 9, 11, 4, 4, 3, 2, 4, 2, 1,
+ 9, 10, 5, 9, 1, 10, 9, 4, 1}
+ {5, {2, 3, 8, 6, 7, 0, 0, 0}
+ 3, {5, 3, 1, 5, 11, 3, 8, 11, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {1, 8, 6, 2, 3, 7, 0, 0}
+ 4, {8, 9, 5, 4, 11, 3, 4, 9, 8, 4, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {6, 8, 7, 4, 0, 0, 0, 0}
+ 6, {5, 10, 12, 3, 8, 4, 0, 0, 0, 0, 0, 0}
+ 4, {5, 12, 10, 5, 4, 12, 5, 8, 4, 12, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {6, 7, 4, 1, 8, 0, 0, 0}
+ 5, {8, 9, 5, 12, 10, 3, 3, 10, 1, 1, 10, 9, 9, 10, 5, 0, 0, 0, 0, 0, 0,
+ {5, {4, 8, 6, 2, 7, 0, 0, 0}
+ 5, {12, 2, 3, 8, 4, 5, 5, 4, 1, 1, 4, 2, 2, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {6, 2, 1, 8, 7, 4, 0, 0}
+ 2, {9, 5, 8, 3, 12, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {4, 8, 6, 3, 7, 0, 0, 0}
+ 3, {2, 8, 4, 2, 5, 8, 10, 5, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {6, 1, 8, 7, 3, 4, 0, 0}
+ 4, {9, 5, 8, 10, 1, 2, 10, 5, 9, 10, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {4, 8, 6, 2, 3, 7, 0, 0}
+ 2, {5, 4, 1, 8, 4, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {7, {6, 2, 1, 8, 7, 3, 4, 0}
+ 1, {9, 5, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {4, {5, 6, 8, 7, 0, 0, 0, 0}
+ 4, {10, 9, 12, 11, 0, 0, 0, 0, 0, 0, 0, 0}
+ 2, {9, 11, 12, 9, 12, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {7, 8, 1, 6, 5, 0, 0, 0}
+ 3, {10, 11, 12, 10, 4, 11, 1, 4, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {8, 5, 2, 7, 6, 0, 0, 0}
+ 3, {12, 9, 11, 12, 1, 9, 2, 1, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {7, 8, 1, 2, 6, 5, 0, 0}
+ 2, {4, 12, 2, 11, 12, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {5, 6, 3, 8, 7, 0, 0, 0}
+ 3, {11, 10, 9, 11, 2, 10, 3, 2, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {3, 1, 6, 7, 8, 5, 0, 0}
+ 4, {1, 2, 10, 3, 4, 11, 3, 2, 1, 3, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {8, 5, 2, 3, 7, 6, 0, 0}
+ 2, {1, 11, 3, 9, 11, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {7, {3, 7, 8, 1, 2, 6, 5, 0}
+ 1, {11, 3, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {5, {6, 7, 4, 5, 8, 0, 0, 0}
+ 3, {9, 12, 10, 9, 3, 12, 4, 3, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {6, 7, 4, 1, 5, 8, 0, 0}
+ 2, {3, 10, 1, 12, 10, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {2, 4, 5, 6, 7, 8, 0, 0}
+ 4, {4, 1, 9, 2, 3, 12, 2, 1, 4, 2, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {7, {4, 1, 2, 7, 8, 5, 6, 0}
+ 1, {2, 3, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {6, {3, 4, 5, 6, 7, 8, 0, 0}
+ 2, {9, 2, 10, 4, 2, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {7, {1, 5, 6, 3, 4, 8, 7, 0}
+ 1, {10, 1, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ {7, {2, 3, 4, 5, 6, 7, 8, 0}
+ 1, {4, 1, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
Deleted: grass/trunk/lib/dspf/cell_table.h
--- grass/trunk/lib/dspf/cell_table.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/lib/dspf/cell_table.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,2310 +0,0 @@
-#ifdef MAIN
-CELL_ENTRY cell_table[256] = {
- {0, {0, 0, 0, 0, 0, 0, 0, 0}
- 0, {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
- 0, {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 0, 0, 0, 0, 0, 0, 0}
- {1, {1, 0, 0, 0, 0, 0, 0, 0}
- 3, {1, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0}
- 1, {1, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, {2, 0, 0, 0, 0, 0, 0, 0}
- 3, {1, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0}
- 1, {1, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {1, 2, 0, 0, 0, 0, 0, 0}
- 4, {2, 4, 9, 10, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {2, 9, 10, 2, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, {3, 0, 0, 0, 0, 0, 0, 0}
- 3, {3, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0}
- 1, {3, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {1, 3, 0, 0, 0, 0, 0, 0}
- 6, {1, 2, 3, 4, 9, 12, 0, 0, 0, 0, 0, 0}
- 2, {1, 4, 9, 3, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {3, 2, 0, 0, 0, 0, 0, 0}
- 4, {10, 12, 3, 1, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {10, 3, 1, 10, 12, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 0, 0, 0, 0, 0, 0, 0, 0}
- {3, {3, 2, 1, 0, 0, 0, 0, 0}
- 5, {10, 12, 4, 9, 3, 0, 0, 0, 0, 0, 0, 0}
- 3, {12, 9, 10, 3, 9, 12, 3, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, {4, 0, 0, 0, 0, 0, 0, 0}
- 3, {3, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0}
- 1, {3, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {1, 4, 0, 0, 0, 0, 0, 0}
- 4, {11, 9, 1, 3, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {11, 1, 3, 11, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {2, 4, 0, 0, 0, 0, 0, 0}
- 6, {2, 3, 4, 1, 10, 11, 0, 0, 0, 0, 0, 0}
- 2, {2, 1, 10, 4, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {2, 1, 4, 0, 0, 0, 0, 0}
- 5, {9, 10, 3, 11, 2, 0, 0, 0, 0, 0, 0, 0}
- 3, {10, 11, 9, 2, 11, 10, 2, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 0, 0, 0, 0, 0, 0, 0, 0, 0}
- {2, {4, 3, 0, 0, 0, 0, 0, 0}
- 4, {12, 11, 4, 2, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {12, 4, 2, 12, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {1, 4, 3, 0, 0, 0, 0, 0}
- 5, {11, 9, 2, 12, 1, 0, 0, 0, 0, 0, 0, 0}
- 3, {9, 12, 11, 1, 12, 9, 1, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {4, 3, 2, 0, 0, 0, 0, 0}
- 5, {12, 11, 1, 10, 4, 0, 0, 0, 0, 0, 0, 0}
- 3, {11, 10, 12, 4, 10, 11, 4, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {4, 3, 1, 2, 0, 0, 0, 0}
- 4, {12, 11, 10, 9, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {11, 9, 10, 11, 10, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, {5, 0, 0, 0, 0, 0, 0, 0}
- 3, {5, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0}
- 1, {5, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {5, 1, 0, 0, 0, 0, 0, 0}
- 4, {4, 8, 5, 1, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {4, 5, 1, 4, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {5, 2, 0, 0, 0, 0, 0, 0}
- 6, {5, 10, 1, 9, 8, 2, 0, 0, 0, 0, 0, 0}
- 2, {5, 9, 8, 1, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {5, 1, 2, 0, 0, 0, 0, 0}
- 5, {4, 8, 10, 2, 5, 0, 0, 0, 0, 0, 0, 0}
- 3, {8, 2, 4, 5, 2, 8, 5, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {5, 3, 0, 0, 0, 0, 0, 0}
- 6, {5, 9, 12, 3, 8, 2, 0, 0, 0, 0, 0, 0}
- 2, {5, 9, 8, 12, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {5, 1, 3, 0, 0, 0, 0, 0}
- 7, {4, 8, 2, 12, 5, 1, 3, 0, 0, 0, 0, 0}
- 3, {2, 12, 3, 4, 8, 5, 4, 5, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {3, 2, 5, 0, 0, 0, 0, 0}
- 7, {10, 12, 9, 8, 3, 1, 5, 0, 0, 0, 0, 0}
- 3, {9, 8, 5, 10, 12, 3, 10, 3, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {3, 1, 2, 5, 0, 0, 0, 0}
- 6, {3, 12, 10, 5, 4, 8, 0, 0, 0, 0, 0, 0}
- 4, {3, 10, 12, 3, 8, 10, 3, 4, 8, 10, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {5, 4, 0, 0, 0, 0, 0, 0}
- 6, {9, 4, 11, 8, 5, 3, 0, 0, 0, 0, 0, 0}
- 2, {9, 8, 5, 11, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {4, 1, 5, 0, 0, 0, 0, 0}
- 5, {1, 3, 8, 5, 11, 0, 0, 0, 0, 0, 0, 0}
- 3, {3, 5, 1, 11, 5, 3, 11, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {5, 4, 2, 0, 0, 0, 0, 0}
- 9, {8, 9, 4, 11, 10, 2, 5, 3, 1, 0, 0, 0}
- 3, {10, 2, 1, 4, 3, 11, 9, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {4, 1, 2, 5, 0, 0, 0, 0}
- 6, {3, 11, 10, 5, 2, 8, 0, 0, 0, 0, 0, 0}
- 4, {10, 2, 3, 5, 10, 3, 11, 5, 3, 8, 5, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {3, 4, 5, 0, 0, 0, 0, 0}
- 7, {4, 2, 8, 5, 12, 11, 9, 0, 0, 0, 0, 0}
- 3, {8, 5, 9, 4, 2, 12, 4, 12, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {3, 4, 1, 5, 0, 0, 0, 0}
- 6, {2, 12, 8, 11, 1, 5, 0, 0, 0, 0, 0, 0}
- 4, {12, 11, 2, 11, 5, 2, 5, 1, 2, 8, 5, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {4, 5, 2, 3, 0, 0, 0, 0}
- 8, {4, 11, 8, 9, 12, 10, 1, 5, 0, 0, 0, 0}
- 4, {11, 10, 12, 11, 1, 10, 4, 1, 11, 8, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {3, 2, 5, 4, 1, 0, 0, 0}
- 5, {12, 10, 8, 11, 5, 0, 0, 0, 0, 0, 0, 0}
- 3, {11, 10, 12, 11, 5, 10, 8, 5, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, {6, 0, 0, 0, 0, 0, 0, 0}
- 3, {5, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0}
- 1, {5, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {6, 1, 0, 0, 0, 0, 0, 0}
- 6, {10, 1, 9, 5, 6, 4, 0, 0, 0, 0, 0, 0}
- 2, {10, 5, 6, 9, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {2, 6, 0, 0, 0, 0, 0, 0}
- 4, {6, 2, 1, 5, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {6, 1, 5, 6, 2, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {1, 2, 6, 0, 0, 0, 0, 0}
- 5, {2, 4, 5, 6, 9, 0, 0, 0, 0, 0, 0, 0}
- 3, {4, 6, 2, 9, 6, 4, 9, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {3, 6, 0, 0, 0, 0, 0, 0}
- 6, {2, 10, 6, 12, 3, 5, 0, 0, 0, 0, 0, 0}
- 2, {2, 12, 3, 6, 10, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {6, 1, 3, 0, 0, 0, 0, 0}
- 9, {5, 10, 1, 9, 12, 3, 6, 4, 2, 0, 0, 0}
- 3, {12, 3, 2, 1, 4, 9, 10, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {6, 2, 3, 0, 0, 0, 0, 0}
- 5, {1, 5, 12, 3, 6, 0, 0, 0, 0, 0, 0, 0}
- 3, {5, 3, 1, 6, 3, 5, 6, 12, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {1, 2, 3, 6, 0, 0, 0, 0}
- 6, {4, 9, 12, 6, 3, 5, 0, 0, 0, 0, 0, 0}
- 4, {12, 3, 4, 6, 12, 4, 9, 6, 4, 5, 6, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {4, 6, 0, 0, 0, 0, 0, 0}
- 6, {3, 11, 10, 5, 4, 6, 0, 0, 0, 0, 0, 0}
- 2, {3, 11, 4, 10, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {4, 1, 6, 0, 0, 0, 0, 0}
- 7, {1, 3, 5, 6, 11, 9, 10, 0, 0, 0, 0, 0}
- 3, {5, 6, 10, 1, 3, 11, 1, 11, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {6, 2, 4, 0, 0, 0, 0, 0}
- 7, {1, 5, 3, 11, 6, 2, 4, 0, 0, 0, 0, 0}
- 3, {3, 11, 4, 1, 5, 6, 1, 6, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {4, 1, 2, 6, 0, 0, 0, 0}
- 6, {3, 11, 5, 9, 2, 6, 0, 0, 0, 0, 0, 0}
- 4, {11, 9, 3, 9, 6, 3, 6, 2, 3, 5, 6, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {4, 3, 6, 0, 0, 0, 0, 0}
- 7, {12, 11, 10, 5, 4, 2, 6, 0, 0, 0, 0, 0}
- 3, {10, 5, 6, 12, 11, 4, 12, 4, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {1, 6, 3, 4, 0, 0, 0, 0}
- 8, {1, 9, 5, 10, 11, 12, 2, 6, 0, 0, 0, 0}
- 4, {9, 12, 11, 9, 2, 12, 1, 2, 9, 5, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {4, 2, 3, 6, 0, 0, 0, 0}
- 6, {4, 11, 12, 6, 1, 5, 0, 0, 0, 0, 0, 0}
- 4, {4, 12, 11, 4, 5, 12, 4, 1, 5, 12, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {4, 3, 6, 1, 2, 0, 0, 0}
- 5, {11, 12, 5, 9, 6, 0, 0, 0, 0, 0, 0, 0}
- 3, {9, 12, 11, 9, 6, 12, 5, 6, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {5, 6, 0, 0, 0, 0, 0, 0}
- 4, {10, 9, 8, 6, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {10, 8, 6, 10, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {6, 5, 1, 0, 0, 0, 0, 0}
- 5, {8, 6, 1, 4, 10, 0, 0, 0, 0, 0, 0, 0}
- 3, {6, 4, 8, 10, 4, 6, 10, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {2, 6, 5, 0, 0, 0, 0, 0}
- 5, {6, 2, 9, 8, 1, 0, 0, 0, 0, 0, 0, 0}
- 3, {2, 8, 6, 1, 8, 2, 1, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {1, 2, 5, 6, 0, 0, 0, 0}
- 4, {2, 4, 6, 8, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {4, 8, 6, 4, 6, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {5, 6, 3, 0, 0, 0, 0, 0}
- 7, {10, 9, 12, 3, 8, 6, 2, 0, 0, 0, 0, 0}
- 3, {12, 3, 2, 10, 9, 8, 10, 8, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {6, 3, 1, 5, 0, 0, 0, 0}
- 8, {10, 6, 12, 2, 8, 4, 1, 3, 0, 0, 0, 0}
- 4, {6, 4, 8, 6, 1, 4, 10, 1, 6, 12, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {5, 6, 2, 3, 0, 0, 0, 0}
- 6, {9, 8, 12, 6, 1, 3, 0, 0, 0, 0, 0, 0}
- 4, {8, 6, 9, 6, 3, 9, 3, 1, 9, 12, 3, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {5, 1, 3, 6, 2, 0, 0, 0}
- 5, {8, 4, 12, 6, 3, 0, 0, 0, 0, 0, 0, 0}
- 3, {6, 4, 8, 6, 3, 4, 12, 3, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {6, 5, 4, 0, 0, 0, 0, 0}
- 7, {8, 6, 4, 3, 10, 9, 11, 0, 0, 0, 0, 0}
- 3, {4, 3, 11, 8, 6, 10, 8, 10, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {6, 1, 5, 4, 0, 0, 0, 0}
- 6, {10, 6, 8, 11, 1, 3, 0, 0, 0, 0, 0, 0}
- 4, {10, 8, 6, 10, 3, 8, 10, 1, 3, 8, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {2, 4, 5, 6, 0, 0, 0, 0}
- 8, {1, 2, 3, 4, 6, 8, 9, 11, 0, 0, 0, 0}
- 4, {2, 8, 6, 2, 9, 8, 1, 9, 2, 3, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {6, 5, 4, 2, 1, 0, 0, 0}
- 5, {6, 8, 3, 2, 11, 0, 0, 0, 0, 0, 0, 0}
- 3, {2, 8, 6, 2, 11, 8, 3, 11, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {3, 4, 6, 5, 0, 0, 0, 0}
- 8, {12, 11, 10, 9, 2, 6, 4, 8, 0, 0, 0, 0}
- 4, {12, 11, 2, 11, 4, 2, 10, 8, 6, 10, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {6, 5, 4, 3, 1, 0, 0, 0}
- 7, {6, 8, 2, 1, 11, 12, 10, 0, 0, 0, 0, 0}
- 5, {1, 2, 10, 8, 6, 11, 11, 6, 12, 12, 6, 2, 2, 6, 10, 0, 0, 0, 0, 0, 0,
- {5, {4, 3, 6, 5, 2, 0, 0, 0}
- 7, {11, 12, 9, 1, 6, 8, 4, 0, 0, 0, 0, 0}
- 5, {1, 9, 4, 12, 11, 6, 6, 11, 8, 8, 11, 9, 9, 11, 4, 0, 0, 0, 0, 0, 0,
- {6, {6, 5, 4, 3, 2, 1, 0, 0}
- 4, {6, 8, 11, 12, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {11, 6, 12, 8, 6, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, {7, 0, 0, 0, 0, 0, 0, 0}
- 3, {7, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0}
- 1, {7, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {1, 7, 0, 0, 0, 0, 0, 0}
- 6, {1, 4, 6, 7, 9, 12, 0, 0, 0, 0, 0, 0}
- 2, {1, 4, 9, 6, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {2, 7, 0, 0, 0, 0, 0, 0}
- 6, {10, 6, 12, 2, 1, 7, 0, 0, 0, 0, 0, 0}
- 2, {10, 2, 1, 12, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {1, 2, 7, 0, 0, 0, 0, 0}
- 7, {2, 4, 6, 7, 9, 10, 12, 0, 0, 0, 0, 0}
- 3, {6, 7, 12, 2, 4, 9, 2, 9, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {7, 3, 0, 0, 0, 0, 0, 0}
- 4, {2, 6, 7, 3, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {2, 7, 3, 2, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {7, 3, 1, 0, 0, 0, 0, 0}
- 7, {2, 6, 4, 9, 7, 3, 1, 0, 0, 0, 0, 0}
- 3, {4, 9, 1, 2, 6, 7, 2, 7, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {2, 3, 7, 0, 0, 0, 0, 0}
- 5, {3, 1, 6, 7, 10, 0, 0, 0, 0, 0, 0, 0}
- 3, {1, 7, 3, 10, 7, 1, 10, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {1, 2, 3, 7, 0, 0, 0, 0}
- 6, {4, 9, 6, 10, 3, 7, 0, 0, 0, 0, 0, 0}
- 4, {9, 10, 4, 10, 7, 4, 7, 3, 4, 6, 7, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {4, 7, 0, 0, 0, 0, 0, 0}
- 6, {3, 12, 7, 11, 4, 6, 0, 0, 0, 0, 0, 0}
- 2, {3, 11, 4, 7, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {1, 4, 7, 0, 0, 0, 0, 0}
- 7, {11, 9, 12, 6, 1, 3, 7, 0, 0, 0, 0, 0}
- 3, {12, 6, 7, 11, 9, 1, 11, 1, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {2, 4, 7, 0, 0, 0, 0, 0}
- 9, {1, 2, 3, 4, 6, 7, 10, 11, 12, 0, 0, 0}
- 3, {6, 7, 12, 3, 11, 4, 2, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {2, 7, 4, 1, 0, 0, 0, 0}
- 8, {2, 10, 6, 12, 9, 11, 3, 7, 0, 0, 0, 0}
- 4, {10, 11, 9, 10, 3, 11, 2, 3, 10, 6, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {7, 3, 4, 0, 0, 0, 0, 0}
- 5, {2, 6, 11, 4, 7, 0, 0, 0, 0, 0, 0, 0}
- 3, {6, 4, 2, 7, 4, 6, 7, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {7, 4, 3, 1, 0, 0, 0, 0}
- 6, {7, 6, 2, 1, 11, 9, 0, 0, 0, 0, 0, 0}
- 4, {7, 2, 6, 7, 9, 2, 7, 11, 9, 2, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {4, 3, 7, 2, 0, 0, 0, 0}
- 6, {11, 4, 6, 10, 7, 1, 0, 0, 0, 0, 0, 0}
- 4, {6, 7, 11, 10, 6, 11, 4, 10, 11, 1, 10, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {1, 4, 7, 2, 3, 0, 0, 0}
- 5, {9, 11, 6, 10, 7, 0, 0, 0, 0, 0, 0, 0}
- 3, {10, 11, 9, 10, 7, 11, 6, 7, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {7, 5, 0, 0, 0, 0, 0, 0}
- 6, {6, 5, 8, 7, 12, 9, 0, 0, 0, 0, 0, 0}
- 2, {6, 7, 12, 8, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {1, 5, 7, 0, 0, 0, 0, 0}
- 7, {5, 1, 7, 12, 4, 8, 6, 0, 0, 0, 0, 0}
- 3, {7, 12, 6, 5, 1, 4, 5, 4, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {7, 5, 2, 0, 0, 0, 0, 0}
- 9, {7, 6, 5, 8, 2, 1, 12, 9, 10, 0, 0, 0}
- 3, {2, 1, 10, 5, 9, 8, 6, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {5, 7, 2, 1, 0, 0, 0, 0}
- 8, {5, 8, 7, 6, 4, 2, 10, 12, 0, 0, 0, 0}
- 4, {8, 2, 4, 8, 10, 2, 5, 10, 8, 7, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {3, 7, 5, 0, 0, 0, 0, 0}
- 7, {7, 3, 5, 9, 2, 6, 8, 0, 0, 0, 0, 0}
- 3, {5, 9, 8, 7, 3, 2, 7, 2, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {5, 1, 7, 3, 0, 0, 0, 0}
- 8, {5, 1, 7, 3, 8, 6, 4, 2, 0, 0, 0, 0}
- 4, {5, 1, 8, 1, 4, 8, 7, 2, 6, 7, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {2, 5, 7, 3, 0, 0, 0, 0}
- 8, {10, 1, 9, 5, 3, 7, 6, 8, 0, 0, 0, 0}
- 4, {1, 7, 3, 1, 6, 7, 10, 6, 1, 9, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {5, 1, 3, 7, 2, 0, 0, 0}
- 7, {8, 4, 6, 10, 3, 7, 5, 0, 0, 0, 0, 0}
- 5, {10, 6, 5, 4, 8, 3, 3, 8, 7, 7, 8, 6, 6, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {4, 5, 7, 0, 0, 0, 0, 0}
- 9, {4, 11, 8, 9, 12, 6, 3, 5, 7, 0, 0, 0}
- 3, {12, 6, 7, 8, 5, 9, 11, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {4, 7, 5, 1, 0, 0, 0, 0}
- 8, {11, 3, 12, 7, 1, 5, 8, 6, 0, 0, 0, 0}
- 4, {3, 5, 1, 3, 8, 5, 11, 8, 3, 12, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {4, 7, 2, 5, 0, 0, 0, 0}
- 12, {3, 12, 7, 11, 1, 10, 5, 9, 4, 2, 8, 6}
- 4, {3, 11, 4, 12, 6, 7, 1, 10, 2, 5, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {4, 7, 1, 2, 5, 0, 0, 0}
- 9, {3, 12, 7, 11, 10, 5, 2, 8, 6, 0, 0, 0}
- 10, {5, 10, 6, 8, 7, 11, 3, 12, 2, 12, 3, 11, 12, 11, 7, 7, 8, 5, 7, 5,
- 6, 12, 10, 2, 12, 6, 10, 12, 7, 6}
- {4, {7, 5, 4, 3, 0, 0, 0, 0}
- 8, {7, 6, 5, 8, 2, 4, 11, 9, 0, 0, 0, 0}
- 4, {6, 4, 2, 6, 11, 4, 7, 11, 6, 5, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {7, 3, 1, 5, 4, 0, 0, 0}
- 7, {6, 2, 8, 11, 1, 5, 7, 0, 0, 0, 0, 0}
- 5, {11, 8, 7, 2, 6, 1, 1, 6, 5, 5, 6, 8, 8, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {4, 5, 3, 7, 2, 0, 0, 0}
- 9, {11, 8, 9, 4, 6, 10, 7, 1, 5, 0, 0, 0}
- 10, {10, 6, 5, 1, 9, 4, 11, 8, 7, 8, 11, 4, 8, 4, 9, 9, 1, 10, 9, 10, 5,
- 8, 6, 7, 8, 5, 6, 8, 9, 5}
- {6, {7, 5, 4, 3, 2, 1, 0, 0}
- 6, {7, 6, 5, 8, 11, 10, 0, 0, 0, 0, 0, 0}
- 4, {8, 7, 11, 6, 5, 10, 6, 7, 8, 6, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {6, 7, 0, 0, 0, 0, 0, 0}
- 4, {12, 10, 5, 7, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {12, 5, 7, 12, 10, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {7, 6, 1, 0, 0, 0, 0, 0}
- 7, {5, 7, 1, 4, 12, 10, 9, 0, 0, 0, 0, 0}
- 3, {1, 4, 9, 5, 7, 12, 5, 12, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {7, 6, 2, 0, 0, 0, 0, 0}
- 5, {5, 7, 2, 1, 12, 0, 0, 0, 0, 0, 0, 0}
- 3, {7, 1, 5, 12, 1, 7, 12, 2, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {1, 6, 2, 7, 0, 0, 0, 0}
- 6, {9, 4, 2, 12, 5, 7, 0, 0, 0, 0, 0, 0}
- 4, {9, 2, 4, 9, 7, 2, 9, 5, 7, 2, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {3, 7, 6, 0, 0, 0, 0, 0}
- 5, {7, 3, 10, 5, 2, 0, 0, 0, 0, 0, 0, 0}
- 3, {3, 5, 7, 2, 5, 3, 2, 10, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {3, 1, 6, 7, 0, 0, 0, 0}
- 8, {2, 3, 4, 1, 7, 5, 10, 9, 0, 0, 0, 0}
- 4, {3, 5, 7, 3, 10, 5, 2, 10, 3, 4, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {2, 3, 6, 7, 0, 0, 0, 0}
- 4, {3, 1, 7, 5, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {1, 5, 7, 1, 7, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {7, 6, 1, 3, 2, 0, 0, 0}
- 5, {7, 5, 4, 3, 9, 0, 0, 0, 0, 0, 0, 0}
- 3, {3, 5, 7, 3, 9, 5, 4, 9, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {6, 7, 4, 0, 0, 0, 0, 0}
- 7, {12, 10, 11, 4, 5, 7, 3, 0, 0, 0, 0, 0}
- 3, {11, 4, 3, 12, 10, 5, 12, 5, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {1, 4, 6, 7, 0, 0, 0, 0}
- 8, {1, 3, 5, 7, 9, 10, 11, 12, 0, 0, 0, 0}
- 4, {1, 3, 9, 3, 11, 9, 5, 12, 10, 5, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {7, 4, 2, 6, 0, 0, 0, 0}
- 8, {12, 7, 11, 3, 5, 1, 2, 4, 0, 0, 0, 0}
- 4, {7, 1, 5, 7, 2, 1, 12, 2, 7, 11, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {7, 6, 1, 4, 2, 0, 0, 0}
- 7, {7, 5, 3, 2, 9, 11, 12, 0, 0, 0, 0, 0}
- 5, {2, 3, 12, 5, 7, 9, 9, 7, 11, 11, 7, 3, 3, 7, 12, 0, 0, 0, 0, 0, 0, 0,
- {4, {4, 3, 7, 6, 0, 0, 0, 0}
- 6, {11, 4, 10, 2, 7, 5, 0, 0, 0, 0, 0, 0}
- 4, {4, 2, 11, 2, 5, 11, 5, 7, 11, 10, 5, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {1, 4, 7, 6, 3, 0, 0, 0}
- 7, {9, 11, 10, 2, 7, 5, 1, 0, 0, 0, 0, 0}
- 5, {2, 10, 1, 11, 9, 7, 7, 9, 5, 5, 9, 10, 10, 9, 1, 0, 0, 0, 0, 0, 0, 0,
- {5, {6, 2, 4, 7, 3, 0, 0, 0}
- 5, {5, 1, 11, 7, 4, 0, 0, 0, 0, 0, 0, 0}
- 3, {7, 1, 5, 7, 4, 1, 11, 4, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {1, 4, 7, 6, 2, 3, 0, 0}
- 4, {9, 11, 7, 5, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {7, 9, 5, 11, 9, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {5, 6, 7, 0, 0, 0, 0, 0}
- 5, {10, 9, 7, 12, 8, 0, 0, 0, 0, 0, 0, 0}
- 3, {9, 12, 10, 8, 12, 9, 8, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {1, 5, 6, 7, 0, 0, 0, 0}
- 6, {1, 4, 7, 8, 10, 12, 0, 0, 0, 0, 0, 0}
- 4, {4, 8, 1, 8, 12, 1, 12, 10, 1, 7, 12, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {5, 6, 2, 7, 0, 0, 0, 0}
- 6, {9, 8, 2, 12, 1, 7, 0, 0, 0, 0, 0, 0}
- 4, {2, 1, 9, 12, 2, 9, 8, 12, 9, 7, 12, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {1, 2, 7, 5, 6, 0, 0, 0}
- 5, {4, 2, 7, 8, 12, 0, 0, 0, 0, 0, 0, 0}
- 3, {8, 2, 4, 8, 12, 2, 7, 12, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {5, 7, 6, 3, 0, 0, 0, 0}
- 6, {8, 9, 10, 2, 7, 3, 0, 0, 0, 0, 0, 0}
- 4, {8, 10, 9, 8, 3, 10, 8, 7, 3, 10, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {3, 7, 5, 1, 6, 0, 0, 0}
- 7, {3, 7, 1, 10, 8, 4, 2, 0, 0, 0, 0, 0}
- 5, {10, 1, 2, 7, 3, 8, 8, 3, 4, 4, 3, 1, 1, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {3, 7, 5, 2, 6, 0, 0, 0}
- 5, {3, 7, 9, 1, 8, 0, 0, 0, 0, 0, 0, 0}
- 3, {1, 7, 3, 1, 8, 7, 9, 8, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {5, 1, 3, 7, 6, 2, 0, 0}
- 4, {8, 4, 3, 7, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {3, 8, 7, 4, 8, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {5, 4, 7, 6, 0, 0, 0, 0}
- 8, {8, 9, 4, 11, 10, 12, 7, 3, 0, 0, 0, 0}
- 4, {9, 12, 10, 9, 7, 12, 8, 7, 9, 4, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {4, 1, 6, 7, 5, 0, 0, 0}
- 7, {3, 1, 7, 8, 10, 12, 11, 0, 0, 0, 0, 0}
- 5, {8, 7, 11, 1, 3, 10, 10, 3, 12, 12, 3, 7, 7, 3, 11, 0, 0, 0, 0, 0, 0,
- {5, {5, 4, 6, 2, 7, 0, 0, 0}
- 9, {9, 4, 11, 8, 2, 12, 1, 7, 3, 0, 0, 0}
- 10, {12, 2, 3, 7, 11, 8, 9, 4, 1, 4, 9, 8, 4, 8, 11, 11, 7, 12, 11, 12,
- 3, 4, 2, 1, 4, 3, 2, 4, 11, 3}
- {6, {7, 4, 2, 6, 5, 1, 0, 0}
- 6, {12, 7, 11, 3, 2, 8, 0, 0, 0, 0, 0, 0}
- 4, {3, 12, 2, 7, 11, 8, 7, 12, 3, 7, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {5, 6, 3, 4, 7, 0, 0, 0}
- 7, {9, 10, 11, 7, 2, 4, 8, 0, 0, 0, 0, 0}
- 5, {7, 11, 8, 10, 9, 2, 2, 9, 4, 4, 9, 11, 11, 9, 8, 0, 0, 0, 0, 0, 0, 0,
- {6, {7, 6, 5, 4, 3, 1, 0, 0}
- 6, {7, 8, 2, 1, 11, 10, 0, 0, 0, 0, 0, 0}
- 2, {8, 7, 11, 1, 2, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {4, 5, 2, 3, 7, 6, 0, 0}
- 6, {4, 11, 8, 9, 1, 7, 0, 0, 0, 0, 0, 0}
- 4, {9, 4, 1, 11, 8, 7, 11, 4, 9, 11, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, {7, 6, 5, 4, 3, 2, 1, 0}
- 3, {7, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0}
- 1, {8, 7, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, {8, 0, 0, 0, 0, 0, 0, 0}
- 1, {7, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {1, 8, 0, 0, 0, 0, 0, 0}
- 2, {4, 9, 1, 8, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {8, 2, 0, 0, 0, 0, 0, 0}
- 2, {7, 8, 11, 2, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {2, 1, 8, 0, 0, 0, 0, 0}
- 3, {11, 7, 8, 9, 10, 2, 9, 2, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {3, 8, 0, 0, 0, 0, 0, 0}
- 2, {12, 3, 2, 11, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {1, 8, 3, 0, 0, 0, 0, 0}
- 3, {2, 12, 3, 11, 7, 8, 4, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {2, 3, 8, 0, 0, 0, 0, 0}
- 3, {7, 8, 11, 3, 1, 10, 3, 10, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {3, 8, 1, 2, 0, 0, 0, 0}
- 8, {3, 12, 7, 11, 10, 9, 4, 8, 0, 0, 0, 0}
- 4, {12, 9, 10, 12, 4, 9, 3, 4, 12, 7, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {4, 8, 0, 0, 0, 0, 0, 0}
- 2, {8, 3, 7, 8, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {8, 4, 1, 0, 0, 0, 0, 0}
- 3, {7, 1, 3, 8, 1, 7, 8, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {8, 4, 2, 0, 0, 0, 0, 0}
- 3, {1, 10, 2, 3, 7, 8, 3, 8, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {2, 4, 1, 8, 0, 0, 0, 0}
- 6, {2, 10, 9, 8, 3, 7, 0, 0, 0, 0, 0, 0}
- 4, {2, 9, 10, 2, 7, 9, 2, 3, 7, 9, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {3, 4, 8, 0, 0, 0, 0, 0}
- 3, {2, 8, 4, 12, 8, 2, 12, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {8, 4, 3, 1, 0, 0, 0, 0}
- 6, {7, 8, 2, 1, 12, 9, 0, 0, 0, 0, 0, 0}
- 4, {2, 12, 7, 1, 2, 7, 8, 1, 7, 9, 1, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {8, 4, 3, 2, 0, 0, 0, 0}
- 6, {7, 8, 1, 4, 12, 10, 0, 0, 0, 0, 0, 0}
- 4, {8, 4, 7, 4, 10, 7, 10, 12, 7, 1, 10, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {2, 1, 8, 3, 4, 0, 0, 0}
- 3, {12, 9, 10, 12, 8, 9, 7, 8, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {8, 5, 0, 0, 0, 0, 0, 0}
- 2, {9, 7, 5, 9, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {1, 5, 8, 0, 0, 0, 0, 0}
- 3, {1, 7, 5, 4, 7, 1, 4, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {8, 5, 2, 0, 0, 0, 0, 0}
- 3, {10, 2, 1, 9, 11, 7, 9, 7, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {2, 1, 5, 8, 0, 0, 0, 0}
- 6, {10, 2, 11, 4, 5, 7, 0, 0, 0, 0, 0, 0}
- 4, {2, 4, 10, 4, 7, 10, 7, 5, 10, 11, 7, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {5, 8, 3, 0, 0, 0, 0, 0}
- 3, {3, 2, 12, 7, 5, 9, 7, 9, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {1, 3, 8, 5, 0, 0, 0, 0}
- 8, {4, 1, 2, 3, 5, 7, 11, 12, 0, 0, 0, 0}
- 4, {1, 7, 5, 1, 11, 7, 4, 11, 1, 2, 12, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {8, 5, 3, 2, 0, 0, 0, 0}
- 8, {7, 5, 3, 1, 11, 12, 9, 10, 0, 0, 0, 0}
- 4, {7, 5, 11, 5, 9, 11, 3, 10, 12, 3, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {3, 2, 5, 8, 1, 0, 0, 0}
- 5, {4, 11, 3, 10, 12, 5, 5, 12, 7, 7, 12, 11, 11, 12, 3, 0, 0, 0, 0, 0,
- 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
- {3, {5, 8, 4, 0, 0, 0, 0, 0}
- 3, {5, 3, 7, 9, 3, 5, 9, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {5, 8, 1, 4, 0, 0, 0, 0}
- 4, {7, 5, 3, 1, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {5, 1, 3, 5, 3, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {5, 2, 4, 8, 0, 0, 0, 0}
- 8, {9, 5, 10, 1, 7, 3, 4, 2, 0, 0, 0, 0}
- 4, {5, 3, 7, 5, 4, 3, 9, 4, 5, 10, 2, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {8, 4, 2, 5, 1, 0, 0, 0}
- 3, {5, 3, 7, 5, 2, 3, 10, 2, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {3, 8, 4, 5, 0, 0, 0, 0}
- 6, {12, 2, 4, 9, 7, 5, 0, 0, 0, 0, 0, 0}
- 4, {12, 4, 2, 12, 5, 4, 12, 7, 5, 4, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {5, 8, 3, 1, 4, 0, 0, 0}
- 3, {1, 7, 5, 1, 12, 7, 2, 12, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {5, 8, 3, 2, 4, 0, 0, 0}
- 5, {4, 1, 9, 7, 5, 12, 12, 5, 10, 10, 5, 1, 1, 5, 9, 0, 0, 0, 0, 0, 0, 0,
- {6, {3, 2, 5, 8, 4, 1, 0, 0}
- 2, {5, 12, 7, 10, 12, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {8, 6, 0, 0, 0, 0, 0, 0}
- 2, {7, 8, 11, 5, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {8, 1, 6, 0, 0, 0, 0, 0}
- 3, {6, 10, 5, 9, 1, 4, 8, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {2, 6, 8, 0, 0, 0, 0, 0}
- 3, {8, 11, 7, 6, 2, 1, 6, 1, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {1, 8, 6, 2, 0, 0, 0, 0}
- 8, {9, 4, 11, 8, 2, 6, 5, 7, 0, 0, 0, 0}
- 4, {4, 6, 2, 4, 5, 6, 9, 5, 4, 11, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {3, 8, 6, 0, 0, 0, 0, 0}
- 3, {10, 5, 6, 7, 8, 11, 12, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {1, 3, 6, 8, 0, 0, 0, 0}
- 12, {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12}
- 4, {1, 4, 9, 2, 12, 3, 5, 6, 10, 7, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {6, 8, 3, 2, 0, 0, 0, 0}
- 8, {6, 5, 8, 7, 1, 3, 12, 11, 0, 0, 0, 0}
- 4, {5, 3, 1, 5, 12, 3, 6, 12, 5, 8, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {1, 8, 2, 3, 6, 0, 0, 0}
- 10, {6, 12, 7, 5, 8, 9, 4, 11, 3, 11, 4, 9, 11, 9, 8, 8, 5, 6, 8, 6, 7,
- 11, 12, 3, 11, 7, 12, 11, 8, 7}
- {3, {4, 8, 6, 0, 0, 0, 0, 0}
- 3, {6, 10, 5, 8, 4, 3, 8, 3, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {8, 6, 1, 4, 0, 0, 0, 0}
- 8, {8, 7, 6, 5, 3, 1, 9, 10, 0, 0, 0, 0}
- 4, {7, 1, 3, 7, 9, 1, 8, 9, 7, 6, 10, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {4, 8, 2, 6, 0, 0, 0, 0}
- 8, {3, 7, 1, 5, 4, 2, 8, 6, 0, 0, 0, 0}
- 4, {3, 7, 4, 7, 8, 4, 1, 6, 2, 1, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {8, 4, 2, 6, 1, 0, 0, 0}
- 5, {9, 5, 8, 3, 7, 2, 2, 7, 6, 6, 7, 5, 5, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {3, 6, 8, 4, 0, 0, 0, 0}
- 8, {12, 2, 10, 6, 4, 8, 7, 5, 0, 0, 0, 0}
- 4, {2, 8, 4, 2, 7, 8, 12, 7, 2, 10, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {8, 6, 4, 3, 1, 0, 0, 0}
- 10, {1, 2, 10, 9, 5, 8, 7, 6, 12, 6, 7, 8, 6, 8, 5, 5, 9, 1, 5, 1, 10, 6,
- 2, 12, 6, 10, 2, 6, 5, 10}
- {5, {6, 2, 4, 8, 3, 0, 0, 0}
- 5, {12, 7, 6, 1, 5, 4, 4, 5, 8, 8, 5, 7, 7, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {6, 8, 3, 2, 1, 4, 0, 0}
- 4, {7, 6, 12, 5, 8, 9, 5, 6, 7, 5, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {8, 5, 6, 0, 0, 0, 0, 0}
- 3, {11, 10, 9, 7, 10, 11, 7, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {1, 5, 6, 8, 0, 0, 0, 0}
- 6, {1, 4, 6, 7, 10, 11, 0, 0, 0, 0, 0, 0}
- 4, {6, 10, 1, 7, 6, 1, 4, 7, 1, 11, 7, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {2, 5, 6, 8, 0, 0, 0, 0}
- 6, {1, 2, 6, 7, 9, 11, 0, 0, 0, 0, 0, 0}
- 4, {1, 6, 2, 1, 11, 6, 1, 9, 11, 6, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {2, 6, 8, 1, 5, 0, 0, 0}
- 3, {4, 6, 2, 4, 7, 6, 11, 7, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {8, 3, 6, 5, 0, 0, 0, 0}
- 8, {7, 11, 3, 12, 9, 10, 6, 2, 0, 0, 0, 0}
- 4, {11, 10, 9, 11, 6, 10, 7, 6, 11, 3, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {1, 3, 5, 6, 8, 0, 0, 0}
- 10, {7, 6, 12, 11, 3, 4, 1, 2, 10, 2, 1, 4, 2, 4, 3, 3, 11, 7, 3, 7, 12,
- 2, 6, 10, 2, 12, 6, 2, 3, 12}
- {5, {8, 5, 2, 3, 6, 0, 0, 0}
- 5, {6, 12, 7, 9, 11, 1, 1, 11, 3, 3, 11, 12, 12, 11, 7, 0, 0, 0, 0, 0, 0,
- {6, {3, 8, 1, 2, 6, 5, 0, 0}
- 4, {11, 3, 4, 12, 7, 6, 12, 3, 11, 12, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {6, 5, 8, 4, 0, 0, 0, 0}
- 6, {6, 10, 4, 9, 7, 3, 0, 0, 0, 0, 0, 0}
- 4, {10, 9, 6, 9, 3, 6, 3, 7, 6, 4, 3, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {4, 1, 6, 8, 5, 0, 0, 0}
- 3, {7, 1, 3, 7, 10, 1, 6, 10, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {2, 6, 8, 4, 5, 0, 0, 0}
- 5, {9, 4, 1, 6, 2, 7, 7, 2, 3, 3, 2, 4, 4, 2, 1, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {2, 6, 8, 4, 1, 5, 0, 0}
- 2, {7, 2, 3, 6, 2, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {3, 4, 5, 6, 8, 0, 0, 0}
- 5, {7, 6, 12, 4, 2, 9, 9, 2, 10, 10, 2, 6, 6, 2, 12, 0, 0, 0, 0, 0, 0, 0,
- {6, {6, 3, 1, 5, 8, 4, 0, 0}
- 4, {2, 10, 1, 6, 12, 7, 6, 10, 2, 6, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {2, 3, 4, 5, 6, 8, 0, 0}
- 2, {4, 1, 9, 7, 6, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, {8, 4, 3, 6, 5, 1, 2, 0}
- 1, {12, 7, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, {8, 7, 0, 0, 0, 0, 0, 0}
- 2, {6, 11, 12, 6, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {7, 8, 1, 0, 0, 0, 0, 0}
- 3, {9, 1, 4, 11, 12, 6, 11, 6, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {8, 7, 2, 0, 0, 0, 0, 0}
- 3, {2, 1, 10, 6, 8, 11, 6, 11, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {2, 1, 7, 8, 0, 0, 0, 0}
- 8, {2, 4, 6, 8, 10, 12, 9, 11, 0, 0, 0, 0}
- 4, {2, 4, 10, 4, 9, 10, 6, 11, 12, 6, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {8, 7, 3, 0, 0, 0, 0, 0}
- 3, {8, 2, 6, 11, 2, 8, 11, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {8, 1, 3, 7, 0, 0, 0, 0}
- 8, {11, 8, 9, 4, 6, 2, 3, 1, 0, 0, 0, 0}
- 4, {8, 2, 6, 8, 3, 2, 11, 3, 8, 9, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {8, 3, 7, 2, 0, 0, 0, 0}
- 6, {11, 8, 6, 10, 3, 1, 0, 0, 0, 0, 0, 0}
- 4, {11, 6, 8, 11, 1, 6, 11, 3, 1, 6, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {8, 7, 2, 1, 3, 0, 0, 0}
- 5, {3, 4, 11, 6, 8, 10, 10, 8, 9, 9, 8, 4, 4, 8, 11, 0, 0, 0, 0, 0, 0, 0,
- {3, {4, 8, 7, 0, 0, 0, 0, 0}
- 3, {4, 6, 8, 3, 6, 4, 3, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {7, 8, 4, 1, 0, 0, 0, 0}
- 6, {12, 6, 9, 8, 3, 1, 0, 0, 0, 0, 0, 0}
- 4, {6, 8, 12, 8, 1, 12, 1, 3, 12, 9, 1, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {4, 2, 7, 8, 0, 0, 0, 0}
- 8, {3, 4, 1, 2, 8, 6, 12, 10, 0, 0, 0, 0}
- 4, {4, 6, 8, 4, 12, 6, 3, 12, 4, 1, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {2, 1, 8, 7, 4, 0, 0, 0}
- 5, {3, 12, 2, 9, 10, 8, 8, 10, 6, 6, 10, 12, 12, 10, 2, 0, 0, 0, 0, 0, 0,
- {4, {8, 7, 4, 3, 0, 0, 0, 0}
- 4, {6, 8, 2, 4, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {8, 4, 2, 8, 2, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {7, 3, 1, 8, 4, 0, 0, 0}
- 3, {8, 2, 6, 8, 1, 2, 9, 1, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {8, 7, 2, 4, 3, 0, 0, 0}
- 3, {4, 6, 8, 4, 10, 6, 1, 10, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {2, 1, 8, 7, 3, 4, 0, 0}
- 2, {8, 10, 6, 9, 10, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {7, 8, 5, 0, 0, 0, 0, 0}
- 3, {12, 9, 11, 6, 9, 12, 6, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {7, 5, 8, 1, 0, 0, 0, 0}
- 6, {6, 12, 11, 4, 5, 1, 0, 0, 0, 0, 0, 0}
- 4, {6, 11, 12, 6, 1, 11, 6, 5, 1, 11, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {7, 2, 5, 8, 0, 0, 0, 0}
- 8, {6, 12, 2, 10, 11, 9, 5, 1, 0, 0, 0, 0}
- 4, {12, 9, 11, 12, 5, 9, 6, 5, 12, 2, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {7, 8, 1, 2, 5, 0, 0, 0}
- 5, {5, 10, 6, 11, 12, 4, 4, 12, 2, 2, 12, 10, 10, 12, 6, 0, 0, 0, 0, 0,
- {4, {5, 8, 7, 3, 0, 0, 0, 0}
- 6, {5, 9, 3, 11, 6, 2, 0, 0, 0, 0, 0, 0}
- 4, {9, 11, 5, 11, 2, 5, 2, 6, 5, 3, 2, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {1, 5, 7, 3, 8, 0, 0, 0}
- 5, {11, 3, 4, 5, 1, 6, 6, 1, 2, 2, 1, 3, 3, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {2, 3, 8, 5, 7, 0, 0, 0}
- 5, {6, 5, 10, 3, 1, 11, 11, 1, 9, 9, 1, 5, 5, 1, 10, 0, 0, 0, 0, 0, 0, 0,
- {6, {3, 7, 8, 1, 2, 5, 0, 0}
- 2, {11, 3, 4, 5, 10, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {5, 8, 7, 4, 0, 0, 0, 0}
- 6, {5, 9, 12, 3, 6, 4, 0, 0, 0, 0, 0, 0}
- 4, {12, 6, 5, 3, 12, 5, 9, 3, 5, 4, 3, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {1, 5, 7, 4, 8, 0, 0, 0}
- 3, {3, 5, 1, 3, 6, 5, 12, 6, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {5, 2, 8, 7, 4, 0, 0, 0}
- 10, {3, 12, 2, 4, 1, 9, 5, 10, 6, 10, 5, 9, 10, 9, 1, 1, 4, 3, 1, 3, 2,
- 10, 12, 6, 10, 2, 12, 10, 1, 2}
- {6, {2, 7, 4, 1, 5, 8, 0, 0}
- 4, {12, 2, 3, 10, 6, 5, 10, 2, 12, 10, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {3, 4, 5, 7, 8, 0, 0, 0}
- 3, {6, 4, 2, 6, 9, 4, 5, 9, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {7, 3, 1, 5, 8, 4, 0, 0}
- 2, {1, 6, 5, 2, 6, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {2, 5, 7, 3, 4, 8, 0, 0}
- 4, {5, 10, 6, 1, 9, 4, 1, 10, 5, 1, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, {5, 8, 7, 2, 1, 4, 3, 0}
- 1, {6, 5, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, {6, 7, 8, 0, 0, 0, 0, 0}
- 3, {10, 11, 12, 5, 11, 10, 5, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {6, 1, 8, 7, 0, 0, 0, 0}
- 8, {5, 10, 1, 9, 12, 11, 8, 4, 0, 0, 0, 0}
- 4, {10, 11, 12, 10, 8, 11, 5, 8, 10, 1, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {8, 7, 6, 2, 0, 0, 0, 0}
- 6, {8, 11, 2, 12, 5, 1, 0, 0, 0, 0, 0, 0}
- 4, {11, 12, 8, 12, 1, 8, 1, 5, 8, 2, 1, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {1, 2, 7, 8, 6, 0, 0, 0}
- 5, {5, 8, 9, 2, 4, 12, 12, 4, 11, 11, 4, 8, 8, 4, 9, 0, 0, 0, 0, 0, 0, 0,
- {4, {8, 7, 6, 3, 0, 0, 0, 0}
- 6, {8, 11, 10, 2, 5, 3, 0, 0, 0, 0, 0, 0}
- 4, {10, 5, 8, 2, 10, 8, 11, 2, 8, 3, 2, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {8, 1, 7, 6, 3, 0, 0, 0}
- 10, {2, 10, 1, 3, 4, 11, 8, 9, 5, 9, 8, 11, 9, 11, 4, 4, 3, 2, 4, 2, 1,
- 9, 10, 5, 9, 1, 10, 9, 4, 1}
- {5, {2, 3, 8, 6, 7, 0, 0, 0}
- 3, {5, 3, 1, 5, 11, 3, 8, 11, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {1, 8, 6, 2, 3, 7, 0, 0}
- 4, {8, 9, 5, 4, 11, 3, 4, 9, 8, 4, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {6, 8, 7, 4, 0, 0, 0, 0}
- 6, {5, 10, 12, 3, 8, 4, 0, 0, 0, 0, 0, 0}
- 4, {5, 12, 10, 5, 4, 12, 5, 8, 4, 12, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {6, 7, 4, 1, 8, 0, 0, 0}
- 5, {8, 9, 5, 12, 10, 3, 3, 10, 1, 1, 10, 9, 9, 10, 5, 0, 0, 0, 0, 0, 0,
- {5, {4, 8, 6, 2, 7, 0, 0, 0}
- 5, {12, 2, 3, 8, 4, 5, 5, 4, 1, 1, 4, 2, 2, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {6, 2, 1, 8, 7, 4, 0, 0}
- 2, {9, 5, 8, 3, 12, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {4, 8, 6, 3, 7, 0, 0, 0}
- 3, {2, 8, 4, 2, 5, 8, 10, 5, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {6, 1, 8, 7, 3, 4, 0, 0}
- 4, {9, 5, 8, 10, 1, 2, 10, 5, 9, 10, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {4, 8, 6, 2, 3, 7, 0, 0}
- 2, {5, 4, 1, 8, 4, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, {6, 2, 1, 8, 7, 3, 4, 0}
- 1, {9, 5, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, {5, 6, 8, 7, 0, 0, 0, 0}
- 4, {10, 9, 12, 11, 0, 0, 0, 0, 0, 0, 0, 0}
- 2, {9, 11, 12, 9, 12, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {7, 8, 1, 6, 5, 0, 0, 0}
- 3, {10, 11, 12, 10, 4, 11, 1, 4, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {8, 5, 2, 7, 6, 0, 0, 0}
- 3, {12, 9, 11, 12, 1, 9, 2, 1, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {7, 8, 1, 2, 6, 5, 0, 0}
- 2, {4, 12, 2, 11, 12, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {5, 6, 3, 8, 7, 0, 0, 0}
- 3, {11, 10, 9, 11, 2, 10, 3, 2, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {3, 1, 6, 7, 8, 5, 0, 0}
- 4, {1, 2, 10, 3, 4, 11, 3, 2, 1, 3, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {8, 5, 2, 3, 7, 6, 0, 0}
- 2, {1, 11, 3, 9, 11, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, {3, 7, 8, 1, 2, 6, 5, 0}
- 1, {11, 3, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, {6, 7, 4, 5, 8, 0, 0, 0}
- 3, {9, 12, 10, 9, 3, 12, 4, 3, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {6, 7, 4, 1, 5, 8, 0, 0}
- 2, {3, 10, 1, 12, 10, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {2, 4, 5, 6, 7, 8, 0, 0}
- 4, {4, 1, 9, 2, 3, 12, 2, 1, 4, 2, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, {4, 1, 2, 7, 8, 5, 6, 0}
- 1, {2, 3, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, {3, 4, 5, 6, 7, 8, 0, 0}
- 2, {9, 2, 10, 4, 2, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, {1, 5, 6, 3, 4, 8, 7, 0}
- 1, {10, 1, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, {2, 3, 4, 5, 6, 7, 8, 0}
- 1, {4, 1, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
-#else
-extern CELL_ENTRY cell_table[256];
-#endif
Modified: grass/trunk/lib/dspf/viz.h
--- grass/trunk/lib/dspf/viz.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/lib/dspf/viz.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -98,10 +98,4 @@
/* struct_copy.c */
int struct_copy(char *, char *, int);
-#ifdef MAIN
-#define GLOBAL
-#else
-#define GLOBAL extern
-#endif
-#include "cell_table.h"
+extern CELL_ENTRY cell_table[];
Modified: grass/trunk/lib/proj/get_proj.c
--- grass/trunk/lib/proj/get_proj.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/lib/proj/get_proj.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -23,8 +23,6 @@
#include <grass/gprojects.h>
#include <grass/glocale.h>
-#define MAIN
/* Finder function for datum conversion lookup tables */
#define FINDERFUNC set_proj_lib
#define PERMANENT "PERMANENT"
Modified: grass/trunk/ps/ps.map/border.h
--- grass/trunk/ps/ps.map/border.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/ps/ps.map/border.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -14,8 +14,4 @@
double width;
-#ifdef MAIN
-struct border brd;
-#else
extern struct border brd;
-#endif
Modified: grass/trunk/ps/ps.map/colortable.h
--- grass/trunk/ps/ps.map/colortable.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/ps/ps.map/colortable.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -21,8 +21,4 @@
int range_override;
-#ifdef MAIN
-struct colortable ct;
-#else
extern struct colortable ct;
-#endif
Modified: grass/trunk/ps/ps.map/comment.h
--- grass/trunk/ps/ps.map/comment.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/ps/ps.map/comment.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -13,8 +13,4 @@
int color;
-#ifdef MAIN
-struct comment cmt;
-#else
extern struct comment cmt;
-#endif
Modified: grass/trunk/ps/ps.map/decorate.h
--- grass/trunk/ps/ps.map/decorate.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/ps/ps.map/decorate.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -17,8 +17,5 @@
int color, bgcolor;
-#ifdef MAIN
-struct scalebar sb;
-#else
extern struct scalebar sb;
-#endif
Modified: grass/trunk/ps/ps.map/group.h
--- grass/trunk/ps/ps.map/group.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/ps/ps.map/group.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -11,8 +11,4 @@
int do_group;
-#ifdef MAIN
-struct PS_group grp;
-#else
extern struct PS_group grp;
-#endif
Modified: grass/trunk/ps/ps.map/header.h
--- grass/trunk/ps/ps.map/header.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/ps/ps.map/header.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -14,8 +14,4 @@
FILE *fp;
-#ifdef MAIN
-struct header hdr;
-#else
extern struct header hdr;
-#endif
Modified: grass/trunk/ps/ps.map/labels.h
--- grass/trunk/ps/ps.map/labels.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/ps/ps.map/labels.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -9,8 +9,4 @@
char *other;
-#ifdef MAIN
-struct labels labels;
-#else
extern struct labels labels;
-#endif
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/ps/ps.map/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -18,7 +18,6 @@
-#define MAIN
#include <string.h>
#include <unistd.h>
#include <stdlib.h>
@@ -39,6 +38,22 @@
#include "group.h"
#include "local_proto.h"
+struct border brd;
+struct map_info m_info;
+struct labels labels;
+struct colortable ct;
+struct PS_data PS;
+int WHITE = 0;
+int BLACK = 1;
+int GREY = 9;
+int sec_draw;
+struct vector vector;
+struct header hdr;
+struct scalebar sb;
+struct comment cmt;
+struct PS_group grp;
#define KEY(x) (strcmp(key,x)==0)
FILE *tracefd;
Modified: grass/trunk/ps/ps.map/map_info.h
--- grass/trunk/ps/ps.map/map_info.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/ps/ps.map/map_info.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -11,8 +11,4 @@
int color, bgcolor, border;
-#ifdef MAIN
-struct map_info m_info;
-#else
extern struct map_info m_info;
-#endif
Modified: grass/trunk/ps/ps.map/ps_info.h
--- grass/trunk/ps/ps.map/ps_info.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/ps/ps.map/ps_info.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -80,13 +80,6 @@
#ifdef GREY
#undef GREY
#endif
-#ifdef MAIN
-struct PS_data PS;
-int WHITE = 0;
-int BLACK = 1;
-int GREY = 9;
-int sec_draw;
-#else
extern struct PS_data PS;
extern int WHITE, BLACK, GREY, sec_draw;
-#endif
Modified: grass/trunk/ps/ps.map/vector.h
--- grass/trunk/ps/ps.map/vector.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/ps/ps.map/vector.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -99,8 +99,4 @@
LAYER *layer;
-#ifdef MAIN
-struct vector vector;
-#else
extern struct vector vector;
-#endif
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.cost/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -48,8 +48,6 @@
* if "output" doesn't exist, but is expected (this is bad design).
-#define MAIN
#define SEGCOLSIZE 256
#include <stdlib.h>
@@ -69,7 +67,22 @@
struct Cell_head window;
+struct variables
+ char *alias;
+ int position;
+} variables[] = {
+ {"output", CUM_COST_LAYER},
+ {"input", COST_LAYER},
+ {"coor", START_PT}
+char cum_cost_layer[64];
+char cost_layer[64];
+struct start_pt *head_start_pt = NULL;
+struct start_pt *head_end_pt = NULL;
int main(int argc, char *argv[])
void *cell, *cell2;
Modified: grass/trunk/raster/r.cost/stash.h
--- grass/trunk/raster/r.cost/stash.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.cost/stash.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -37,35 +37,11 @@
struct start_pt *next;
-#ifdef MAIN
-struct variables
- char *alias;
- int position;
-variables[] = {
- "output", CUM_COST_LAYER}, {
- "input", COST_LAYER}, {
- "coor", START_PT}
-char cum_cost_layer[64];
-char cost_layer[64];
-struct start_pt *head_start_pt = NULL;
-struct start_pt *head_end_pt = NULL;
-#else
extern char cum_cost_layer[];
extern char cost_layer[];
extern struct start_pt *head_start_pt;
extern struct start_pt *head_end_pt;
-#endif
int process_answers(char **, struct start_pt **, struct start_pt **);
int time_to_stop(int, int);
Modified: grass/trunk/raster/r.digit/main.c
--- grass/trunk/raster/r.digit/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.digit/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -17,7 +17,6 @@
-#define MAIN
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
Modified: grass/trunk/raster/r.drain/tinf.c
--- grass/trunk/raster/r.drain/tinf.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.drain/tinf.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -2,9 +2,24 @@
#include <float.h>
#include <math.h>
#include <grass/gis.h>
-#define TINF_MAIN
#include "tinf.h"
+int (*is_null) (void *);
+void (*set_null_value) (void *, int);
+int (*bpe) ();
+void *(*get_max) (void *, void *);
+void *(*get_min) (void *, void *);
+int (*get_row) (int, void *, int);
+void *(*get_buf) ();
+int (*put_row) (int, void *);
+double (*slope) (void *, void *, double);
+void (*set_min) (void *);
+void (*set_max) (void *);
+void (*diff) (void *, void *);
+void (*sum) (void *, void *);
+void (*quot) (void *, void *);
+void (*prod) (void *, void *);
/* To add a new multitype function, use the function below to initialize
* the function pointer to each of the three typed functions. The function
* pointers and the function prototypes are defined in a header file.
Modified: grass/trunk/raster/r.drain/tinf.h
--- grass/trunk/raster/r.drain/tinf.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.drain/tinf.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -68,23 +68,7 @@
/* to add a new multitype function, add a pointer for the function and
* its argument list to the list below */
-#ifdef TINF_MAIN
-int (*is_null) (void *);
-void (*set_null_value) (void *, int);
-int (*bpe) ();
-void *(*get_max) (void *, void *);
-void *(*get_min) (void *, void *);
-int (*get_row) (int, void *, int);
-void *(*get_buf) ();
-int (*put_row) (int, void *);
-double (*slope) (void *, void *, double);
-void (*set_min) (void *);
-void (*set_max) (void *);
-void (*diff) (void *, void *);
-void (*sum) (void *, void *);
-void (*quot) (void *, void *);
-void (*prod) (void *, void *);
-#else
extern int (*is_null) (void *);
extern void (*set_null_value) (void *, int);
extern int (*bpe) ();
@@ -100,7 +84,7 @@
extern void (*sum) (void *, void *);
extern void (*quot) (void *, void *);
extern void (*prod) (void *, void *);
-#endif
/* probably not something of general interest */
double slope_c(void *, void *, double);
Modified: grass/trunk/raster/r.fill.dir/tinf.c
--- grass/trunk/raster/r.fill.dir/tinf.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.fill.dir/tinf.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -2,7 +2,6 @@
#include <float.h>
#include <math.h>
-#define TINF_MAIN
#include "tinf.h"
@@ -10,6 +9,21 @@
* The actual functions follow. */
+int (*bpe) ();
void set_func_pointers(int in_type)
switch (in_type) {
Modified: grass/trunk/raster/r.fill.dir/tinf.h
--- grass/trunk/raster/r.fill.dir/tinf.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.fill.dir/tinf.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -65,22 +65,6 @@
-#ifdef TINF_MAIN
-int (*bpe) ();
-#else
extern void *(*get_max) (void *, void *);
@@ -95,7 +79,6 @@
-#endif
Modified: grass/trunk/raster/r.flow/calc.c
--- grass/trunk/raster/r.flow/calc.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.flow/calc.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -26,8 +26,6 @@
** Update MN: commented line 387
-#define MAIN
#include <stdlib.h> /* for the random number generation */
#include <time.h>
@@ -47,7 +45,21 @@
#define ROW 1 /* | */
#define COL 0 /* / */
+CELL v; /* address for segment retrieval macros */
+/* heap memory */
+struct Cell_head region; /* resolution and boundaries */
+struct Map_info fl; /* output vector file header */
+struct BM *bitbar; /* space-efficient barrier matrix */
+int lgfd; /* output length file descriptor */
+char string[1024]; /* space for strings */
+layer el, as, ds; /* elevation, aspect, density */
+double *ew_dist; /* east-west distances for rows */
+double *epsilon[2]; /* quantization errors for rows */
+/* command-line parameters */
+params parm;
typedef struct
int row, col; /* current matrix address */
Modified: grass/trunk/raster/r.flow/mem.h
--- grass/trunk/raster/r.flow/mem.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.flow/mem.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -8,11 +8,7 @@
#define SEGCOLS ((int) (region.cols/3) + 1)
#define SEGROWS ((int)(MB/region.cols/3) <= 1 ? 1 : (int)(MB/region.cols/3))
-#ifdef MAIN
-CELL v; /* address for segment retrieval macros */
-#else
extern CELL v;
-#endif
Modified: grass/trunk/raster/r.flow/r.flow.h
--- grass/trunk/raster/r.flow/r.flow.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.flow/r.flow.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -80,23 +80,7 @@
layer;
/******************************* GLOBALS ********************************/
-#ifdef MAIN
-/* heap memory */
-struct Cell_head region; /* resolution and boundaries */
-struct Map_info fl; /* output vector file header */
-struct BM *bitbar; /* space-efficient barrier matrix */
-int lgfd; /* output length file descriptor */
-char string[1024]; /* space for strings */
-layer el, as, ds; /* elevation, aspect, density */
-double *ew_dist; /* east-west distances for rows */
-double *epsilon[2]; /* quantization errors for rows */
-/* command-line parameters */
-params parm;
-#else
extern struct Cell_head region;
extern struct Map_info fl;
extern struct BM *bitbar;
@@ -108,4 +92,3 @@
extern params parm;
-#endif
Modified: grass/trunk/raster/r.in.gridatb/file_io.c
--- grass/trunk/raster/r.in.gridatb/file_io.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.in.gridatb/file_io.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -4,8 +4,9 @@
-void rdwr_gridatb()
+void rdwr_gridatb(void)
+ char buf[1024];
FILE *fp;
int fd, i, j, retval;
float idx;
Modified: grass/trunk/raster/r.in.gridatb/local_proto.h
--- grass/trunk/raster/r.in.gridatb/local_proto.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.in.gridatb/local_proto.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -6,14 +6,7 @@
void rdwr_gridatb(void);
-#ifdef MAIN
-# define GLOBAL
-#else
-# define GLOBAL extern
-#endif
-GLOBAL struct Cell_head cellhd;
-GLOBAL FCELL *cell;
-GLOBAL char *file;
-GLOBAL char *mapset, *oname;
-GLOBAL char buf[1024];
+extern struct Cell_head cellhd;
+extern FCELL *cell;
+extern char *file;
+extern char *mapset, *oname;
Modified: grass/trunk/raster/r.in.gridatb/main.c
--- grass/trunk/raster/r.in.gridatb/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.in.gridatb/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -16,13 +16,16 @@
#include <stdlib.h>
#include <stdio.h>
-#define MAIN
-#undef MAIN
+struct Cell_head cellhd;
+FCELL *cell;
+char *file;
+char *mapset, *oname;
int main(int argc, char **argv)
struct
Modified: grass/trunk/raster/r.le/r.le.patch/main.c
--- grass/trunk/raster/r.le/r.le.patch/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.le/r.le.patch/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -26,9 +26,10 @@
#include <grass/config.h>
-#define MAIN
#include "patch.h"
+jmp_buf jmp;
struct CHOICE *choice;
Modified: grass/trunk/raster/r.le/r.le.patch/patch.h
--- grass/trunk/raster/r.le/r.le.patch/patch.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.le/r.le.patch/patch.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -39,11 +39,7 @@
#define BIG 1000000000.0
#define PI M_PI
-#ifdef MAIN
-jmp_buf jmp;
-#else
extern jmp_buf jmp;
-#endif
typedef struct __dirdesc
Modified: grass/trunk/raster/r.los/cmd_line.h
--- grass/trunk/raster/r.los/cmd_line.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.los/cmd_line.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -8,16 +8,10 @@
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
-GLOBAL double east;
-GLOBAL double north;
-GLOBAL double obs_elev;
-GLOBAL double max_dist;
-GLOBAL char *elev_layer;
-GLOBAL char *patt_layer;
-GLOBAL char *out_layer;
+extern double east;
+extern double north;
+extern double obs_elev;
+extern double max_dist;
+extern char *elev_layer;
+extern char *patt_layer;
+extern char *out_layer;
Modified: grass/trunk/raster/r.los/main.c
--- grass/trunk/raster/r.los/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.los/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -34,7 +34,7 @@
#include <math.h>
#include <fcntl.h>
-#define MAIN
#include <grass/segment.h>
@@ -50,6 +50,14 @@
struct Cell_head window; /* database window */
+double east;
+double north;
+double obs_elev;
+double max_dist;
+char *elev_layer;
+char *patt_layer;
+char *out_layer;
int row_viewpt, col_viewpt, nrows, ncols, a, b, row, patt_flag;
Modified: grass/trunk/raster/r.mfilter/glob.h
--- grass/trunk/raster/r.mfilter/glob.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.mfilter/glob.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,11 +1,5 @@
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
-GLOBAL int nrows, ncols;
-GLOBAL int buflen;
-GLOBAL int direction;
-GLOBAL int zero_only;
-GLOBAL int preserve_edges;
+extern int nrows, ncols;
+extern int buflen;
+extern int direction;
+extern int zero_only;
+extern int preserve_edges;
Modified: grass/trunk/raster/r.mfilter/main.c
--- grass/trunk/raster/r.mfilter/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.mfilter/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -14,7 +14,7 @@
* for details.
-#define MAIN
#include <stdlib.h>
#include <string.h>
#include <stdio.h>
@@ -23,6 +23,12 @@
#include "filter.h"
#include "glob.h"
+int nrows, ncols;
+int buflen;
+int direction;
+int zero_only;
+int preserve_edges;
FILTER *filter;
Modified: grass/trunk/raster/r.out.gridatb/local_proto.h
--- grass/trunk/raster/r.out.gridatb/local_proto.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.out.gridatb/local_proto.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -6,14 +6,8 @@
-#ifdef MAIN
-# define GLOBAL
-#else
-#endif
-GLOBAL char *file;
-GLOBAL char *mapset, *iname;
-GLOBAL char overwr;
+extern char *file;
+extern char *mapset, *iname;
+extern char overwr;
Modified: grass/trunk/raster/r.out.gridatb/main.c
--- grass/trunk/raster/r.out.gridatb/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.out.gridatb/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -16,13 +16,17 @@
#include <stdlib.h>
#include <stdio.h>
-#define MAIN
-#include "local_proto.h"
-#undef MAIN
+#include "local_proto.h"
+FCELL *cell;
+char *file;
+char *mapset, *iname;
+char overwr;
struct
Modified: grass/trunk/raster/r.out.vtk/globaldefs.h
--- grass/trunk/raster/r.out.vtk/globaldefs.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.out.vtk/globaldefs.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -21,12 +21,7 @@
#define TRIANGLE_STRIPS 1
#define VERTICES 2
-#ifdef MAIN
-double x_extent;
-double y_extent;
-#else
extern double x_extent;
extern double y_extent;
-#endif
#endif
Modified: grass/trunk/raster/r.out.vtk/main.c
--- grass/trunk/raster/r.out.vtk/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.out.vtk/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -23,10 +23,14 @@
#include "writeascii.h"
-#define MAIN
#include "parameters.h"
#include "globaldefs.h"
+paramType param; /*Parameters */
+double x_extent;
+double y_extent;
/*local protos */
static void check_input_maps(void);
Modified: grass/trunk/raster/r.out.vtk/parameters.h
--- grass/trunk/raster/r.out.vtk/parameters.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.out.vtk/parameters.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -28,13 +28,11 @@
} paramType;
/*global structs */
-#ifdef MAIN
-paramType param; /*Parameters */
-#else
extern paramType param; /*Parameters */
-#endif
/*prototype */
-void set_params();
+void set_params(void);
#endif
Modified: grass/trunk/raster/r.param.scale/main.c
--- grass/trunk/raster/r.param.scale/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.param.scale/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -12,53 +12,45 @@
-#define MAIN
#include "param.h"
-int main(int argc, char **argv)
+char
+ *rast_in_name, /* Name of the raster file to process. */
+ *rast_out_name, /* Name of the raster output file. */
+ *mapset_in, /* If no problems, these will be names */
+ *mapset_out, /* of mapsets containing the files to */
+ /* be processed. Otherwise, error code. */
+ constrained; /* Flag that forces quadtratic through */
- /* INITIALISE */
+ /* the central cell of the window. */
+int
+ fd_in, /* File descriptor for input and */
+ fd_out, /* output raster files. */
+ wsize, /* Size of local processing window. */
+ mparam; /* Morphometric parameter to calculate. */
+double
+ resoln, /* Planimetric resolution. */
+ exponent, /* Distance weighting exponent. */
+ zscale, /* Vertical scaling factor. */
+ slope_tol, /* Vertical tolerences for surface */
+ curve_tol; /* feature identification. */
- /* GET INPUT FROM USER */
+int main(int argc, char **argv)
interface(argc, argv);
- /* OPEN INPUT AND OUTPUT RASTER FILES */
/* Make sure that the current projection is not lat/long */
if ((G_projection() == PROJECTION_LL))
G_fatal_error(_("Lat/Long location is not supported"));
open_files();
- /* PROCESS SURFACE FOR FEATURE DETECTION */
process();
- /* CLOSE ALL OPENED FILES AND FREE MEMORY */
close_down();
if (mparam == FEATURE) {
Modified: grass/trunk/raster/r.param.scale/param.h
--- grass/trunk/raster/r.param.scale/param.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.param.scale/param.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -81,10 +81,8 @@
/* ------ Global variables ------ */
-#ifndef MAIN
-extern /* Externally defined if not main() */
-#endif
- char *rast_in_name, /* Name of the raster file to process. */
+extern char
@@ -93,19 +91,15 @@
-#ifndef MAIN
-#endif
- int fd_in, /* File descriptor for input and */
+extern int
-#ifndef MAIN
-#endif
- double resoln, /* Planimetric resolution. */
+extern double
Modified: grass/trunk/raster/r.random.cells/gasdev.c
--- grass/trunk/raster/r.random.cells/gasdev.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.cells/gasdev.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
#include <math.h>
#include "ransurf.h"
Modified: grass/trunk/raster/r.random.cells/indep.c
--- grass/trunk/raster/r.random.cells/indep.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.cells/indep.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
Modified: grass/trunk/raster/r.random.cells/init.c
--- grass/trunk/raster/r.random.cells/init.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.cells/init.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
#include <stdlib.h>
#include <unistd.h>
#include <sys/types.h>
Modified: grass/trunk/raster/r.random.cells/main.c
--- grass/trunk/raster/r.random.cells/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.cells/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -19,14 +19,23 @@
#undef TRACE
#undef DEBUG
-#define MAIN
#include <stdlib.h>
-#undef MAIN
+double NS, EW;
+int CellCount, Rs, Cs;
+double MaxDist, MaxDistSq;
+FLAG *Cells;
+CELLSORTER *DoNext;
+CELL **Out, *CellBuffer;
+int Seed, OutFD;
+struct Flag *Verbose;
+struct Option *Distance;
+struct Option *Output;
struct GModule *module;
Modified: grass/trunk/raster/r.random.cells/random.c
--- grass/trunk/raster/r.random.cells/random.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.cells/random.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
Modified: grass/trunk/raster/r.random.cells/ransurf.h
--- grass/trunk/raster/r.random.cells/ransurf.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.cells/ransurf.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -11,28 +11,22 @@
#define SEED_MIN 0
#define PI M_PI
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
#define CELLSORTER struct cell_sorter_
CELLSORTER {
int R, C;
double Value;
-GLOBAL double NS, EW;
-GLOBAL int CellCount, Rs, Cs;
-GLOBAL double MaxDist, MaxDistSq;
-GLOBAL FLAG *Cells;
-GLOBAL CELLSORTER *DoNext;
-GLOBAL CELL **Out, *CellBuffer;
-GLOBAL int Seed, OutFD;
-GLOBAL struct Flag *Verbose;
-GLOBAL struct Option *Distance;
-GLOBAL struct Option *Output;
+extern double NS, EW;
+extern int CellCount, Rs, Cs;
+extern double MaxDist, MaxDistSq;
+extern FLAG *Cells;
+extern CELLSORTER *DoNext;
+extern CELL **Out, *CellBuffer;
+extern int Seed, OutFD;
+extern struct Flag *Verbose;
+extern struct Option *Distance;
+extern struct Option *Output;
#ifdef DEBUG
#define INDX(a,b) (printf("(a)[%d]:%lf ",(b),(a)[(b)]))
Modified: grass/trunk/raster/r.random.surface/calcsd.c
--- grass/trunk/raster/r.random.surface/calcsd.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/calcsd.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
Modified: grass/trunk/raster/r.random.surface/calcsurf.c
--- grass/trunk/raster/r.random.surface/calcsurf.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/calcsurf.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
#include <stdlib.h>
@@ -99,7 +98,6 @@
for (Col = Cs - 1; Col >= 0; Col--) {
Surface[Row][Col] =
MakePP(Row, Col, OutRows, OutCols, Randoms, BigF);
- if (!Verbose->answer)
G_percent(++Count, MapCount, 1);
@@ -107,7 +105,6 @@
for (Col = 0; Col < Cs; Col++) {
Surface[Row][Col] =
@@ -123,8 +120,6 @@
else {
Surface[Row][Col] =
@@ -136,8 +131,6 @@
else {
Surface[Row][Col] =
Modified: grass/trunk/raster/r.random.surface/cpfilter.c
--- grass/trunk/raster/r.random.surface/cpfilter.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/cpfilter.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
Modified: grass/trunk/raster/r.random.surface/dd.c
--- grass/trunk/raster/r.random.surface/dd.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/dd.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
#include <math.h>
Modified: grass/trunk/raster/r.random.surface/decay.c
--- grass/trunk/raster/r.random.surface/decay.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/decay.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
void DistDecay(double *Effect, int R, int C)
Modified: grass/trunk/raster/r.random.surface/digits.c
--- grass/trunk/raster/r.random.surface/digits.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/digits.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
#include <math.h>
Modified: grass/trunk/raster/r.random.surface/gasdev.c
--- grass/trunk/raster/r.random.surface/gasdev.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/gasdev.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
#include <math.h>
Modified: grass/trunk/raster/r.random.surface/gennorm.c
--- grass/trunk/raster/r.random.surface/gennorm.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/gennorm.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
#include <math.h>
Modified: grass/trunk/raster/r.random.surface/init.c
--- grass/trunk/raster/r.random.surface/init.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/init.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -11,7 +11,6 @@
-#undef MAIN
Modified: grass/trunk/raster/r.random.surface/main.c
--- grass/trunk/raster/r.random.surface/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -29,12 +29,22 @@
#undef TRACE
#undef DEBUG
-#define MAIN
-#undef MAIN
+BIGF BigF;
+double **Surface, NS, EW, FilterSD, AllMaxDist, *Norm;
+int MapCount, FDM, Rs, Cs, Theory;
+CELL *CellBuffer;
+FILTER *AllFilters, Filter;
+CATINFO CatInfo;
+int *Seeds, Seed, NumSeeds, Low, High, NumMaps, NumFilters, OutFD;
+char Buf[240], **OutNames, *TheoryName, *Mapset;
+struct Flag *Uniform;
+ /* please, remove before GRASS 7 released */
+struct Option *Distance, *Exponent, *Weight;
Modified: grass/trunk/raster/r.random.surface/makebigf.c
--- grass/trunk/raster/r.random.surface/makebigf.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/makebigf.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
Modified: grass/trunk/raster/r.random.surface/makepp.c
--- grass/trunk/raster/r.random.surface/makepp.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/makepp.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
Modified: grass/trunk/raster/r.random.surface/random.c
--- grass/trunk/raster/r.random.surface/random.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/random.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
Modified: grass/trunk/raster/r.random.surface/ransurf.h
--- grass/trunk/raster/r.random.surface/ransurf.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/ransurf.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -20,12 +20,6 @@
#define SIZE_OF_DISTRIBUTION 20000
#define PI M_PI
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
#define BIGF struct _big_f_filter_
BIGF {
int RowPlus, ColPlus, NumR, NumC, *LowBF, *HihBF;
@@ -43,19 +37,19 @@
double *Average, *Max, *Min;
-GLOBAL BIGF BigF;
-GLOBAL double **Surface, NS, EW, FilterSD, AllMaxDist, *Norm;
-GLOBAL int MapCount, FDM, Rs, Cs, Theory;
-GLOBAL CELL *CellBuffer;
-GLOBAL FILTER *AllFilters, Filter;
-GLOBAL CATINFO CatInfo;
-GLOBAL int *Seeds, Seed, NumSeeds, Low, High, NumMaps, NumFilters, OutFD;
-GLOBAL char Buf[240], **OutNames, *TheoryName, *Mapset;
-GLOBAL struct Flag *Uniform;
+extern BIGF BigF;
+extern double **Surface, NS, EW, FilterSD, AllMaxDist, *Norm;
+extern int MapCount, FDM, Rs, Cs, Theory;
+extern CELL *CellBuffer;
+extern FILTER *AllFilters, Filter;
+extern CATINFO CatInfo;
+extern int *Seeds, Seed, NumSeeds, Low, High, NumMaps, NumFilters, OutFD;
+extern char Buf[240], **OutNames, *TheoryName, *Mapset;
+extern struct Flag *Uniform;
-GLOBAL struct Option *Distance, *Exponent, *Weight;
+extern struct Option *Distance, *Exponent, *Weight;
#ifdef DEBUG
Modified: grass/trunk/raster/r.random.surface/save.c
--- grass/trunk/raster/r.random.surface/save.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/save.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
#include <string.h>
@@ -175,8 +174,7 @@
CellBuffer[Col] = (CELL) Surface[Row][Col];
G_put_raster_row(OutFD, CellBuffer, CELL_TYPE);
- G_percent(Row + 1, Rs, 1);
+ G_percent(Row + 1, Rs, 1);
G_close_cell(OutFD);
Modified: grass/trunk/raster/r.random.surface/zero.c
--- grass/trunk/raster/r.random.surface/zero.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.random.surface/zero.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -3,7 +3,6 @@
#undef TRACE
#undef DEBUG
-#undef MAIN
Modified: grass/trunk/raster/r.recode/global.h
--- grass/trunk/raster/r.recode/global.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.recode/global.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,15 +1,6 @@
#include <stdio.h>
-#ifdef MAIN
-RASTER_MAP_TYPE in_type;
-RASTER_MAP_TYPE out_type;
-struct FPReclass rcl_struct;
-CELL old_min, old_max;
-DCELL old_dmin, old_dmax;
-int in_fd, out_fd, no_mask, align_wind, make_dcell, nrules, rule_size;
-char *name, *mapset, *result, *title;
-char **rules;
-#else
extern RASTER_MAP_TYPE in_type;
extern RASTER_MAP_TYPE out_type;
extern struct FPReclass rcl_struct;
@@ -18,7 +9,7 @@
extern int in_fd, out_fd, no_mask, align_wind, make_dcell, nrules, rule_size;
extern char *name, *mapset, *result, *title;
extern char **rules;
-#endif
/* read_rules.c */
int report_range(void);
int read_rules(FILE *);
Modified: grass/trunk/raster/r.recode/main.c
--- grass/trunk/raster/r.recode/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.recode/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -13,7 +13,7 @@
* for details.
-#define MAIN
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
@@ -22,6 +22,15 @@
#include "global.h"
+RASTER_MAP_TYPE in_type;
+RASTER_MAP_TYPE out_type;
+struct FPReclass rcl_struct;
+CELL old_min, old_max;
+DCELL old_dmin, old_dmax;
+int in_fd, out_fd, no_mask, align_wind, make_dcell, nrules, rule_size;
+char *name, *mapset, *result, *title;
+char **rules;
char *title;
Modified: grass/trunk/raster/r.resamp.rst/main.c
--- grass/trunk/raster/r.resamp.rst/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.resamp.rst/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -35,8 +35,6 @@
#include <stdlib.h>
#include <unistd.h>
-#define MAIN
#include <grass/dbmi.h>
#include <grass/linkm.h>
Modified: grass/trunk/raster/r.statistics/main.c
--- grass/trunk/raster/r.statistics/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.statistics/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -20,9 +20,27 @@
-#define MAIN
#include "method.h"
+/* modify this table to add new methods */
+struct menu menu[] = {
+ {"diversity", DIV, "diversity of values in specified objects in %%"},
+ {"distribution", DISTRIB,
+ "distribution of values in specified objects in %%"},
+ {"average", AVERAGE, "average of values in specified objects"},
+ {"mode", MODE, "mode of values in specified objects"},
+ {"median", MEDIAN, "median of values in specified objects"},
+ {"avedev", ADEV, "Average deviation of values in specified objects"},
+ {"stddev", SDEV, "Standard deviation of values in specified objects"},
+ {"variance", VARIANC, "Variance of values in specified objects"},
+ {"skewness", SKEWNES, "Skewnes of values in specified objects"},
+ {"kurtosis", KURTOSI, "Kurtosis of values in specified objects"},
+ {"min", MIN, "Minimum of values in specified objects"},
+ {"max", MAX, "Maximum of values in specified objects"},
+ {"sum", SUM, "Sum of values in specified objects"},
+ {0, 0, 0}
/* function prototypes */
static int is_ok(char *, char *);
Modified: grass/trunk/raster/r.statistics/method.h
--- grass/trunk/raster/r.statistics/method.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.statistics/method.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -27,34 +27,8 @@
char *text; /* menu display - full description */
-#ifdef MAIN
-/* modify this table to add new methods */
-struct menu menu[] = {
- {"diversity", DIV, "diversity of values in specified objects in %%"},
- {"distribution", DISTRIB,
- "distribution of values in specified objects in %%"},
- {"average", AVERAGE, "average of values in specified objects"},
- {"mode", MODE, "mode of values in specified objects"},
- {"median", MEDIAN, "median of values in specified objects"},
- {"avedev", ADEV, "Average deviation of values in specified objects"},
- {"stddev", SDEV, "Standard deviation of values in specified objects"},
- {"variance", VARIANC, "Variance of values in specified objects"},
- {"skewness", SKEWNES, "Skewnes of values in specified objects"},
- {"kurtosis", KURTOSI, "Kurtosis of values in specified objects"},
- {"min", MIN, "Minimum of values in specified objects"},
- {"max", MAX, "Maximum of values in specified objects"},
- {"sum", SUM, "Sum of values in specified objects"},
- {0, 0, 0}
-#else
extern struct menu menu[];
-#endif
/* o_adev.c */
int o_adev(char *, char *, char *, int, struct Categories *);
Modified: grass/trunk/raster/r.sunmask/global.h
--- grass/trunk/raster/r.sunmask/global.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.sunmask/global.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,12 +1,6 @@
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
+extern float asol, phi0, sun_zenith, sun_azimuth; /* from nadir, from north */
+extern int sunset;
-GLOBAL float asol, phi0, sun_zenith, sun_azimuth; /* from nadir, from north */
-GLOBAL int sunset;
/* proto */
long G_calc_solar_position(double, double, double, int, int, int, int, int,
int);
Modified: grass/trunk/raster/r.sunmask/main.c
--- grass/trunk/raster/r.sunmask/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.sunmask/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -39,8 +39,6 @@
* but it's somewhat slow with non-CELL maps
-#define MAIN
#include "global.h"
#include <stdio.h>
#include <stdlib.h>
@@ -50,6 +48,9 @@
#include "solpos00.h"
+float asol, phi0, sun_zenith, sun_azimuth; /* from nadir, from north */
+int sunset;
/* to be displayed in r.sunmask */
static char *SOLPOSVERSION = "11 April 2001";
Modified: grass/trunk/raster/r.surf.contour/contour.h
--- grass/trunk/raster/r.surf.contour/contour.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.surf.contour/contour.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -17,26 +17,20 @@
double d;
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
+extern int nrows;
+extern int ncols;
+extern int minc;
+extern int minr;
+extern int maxc;
+extern int maxr;
+extern int array_size;
+extern double i_val_l_f;
+extern CSEG con;
+extern FLAG *seen, *mask;
+extern BSEG bseen, bmask;
+extern NODE *zero;
+extern CELL on, off;
-GLOBAL int nrows;
-GLOBAL int ncols;
-GLOBAL int minc;
-GLOBAL int minr;
-GLOBAL int maxc;
-GLOBAL int maxr;
-GLOBAL int array_size;
-GLOBAL double i_val_l_f;
-GLOBAL CSEG con;
-GLOBAL FLAG *seen, *mask;
-GLOBAL BSEG bseen, bmask;
-GLOBAL NODE *zero;
-GLOBAL CELL on, off;
/* add_in.c */
NODE *add_in_slow(int, int, int, int, NODE *, int *);
NODE *add_in(int, int, int, int, NODE *, int *);
Modified: grass/trunk/raster/r.surf.contour/main.c
--- grass/trunk/raster/r.surf.contour/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.surf.contour/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -22,13 +22,25 @@
#include <stdlib.h>
#include <stdio.h>
-#define MAIN
#include "contour.h"
#include <unistd.h>
-#undef MAIN
+int nrows;
+int ncols;
+int minc;
+int minr;
+int maxc;
+int maxr;
+int array_size;
+double i_val_l_f;
+CSEG con;
+FLAG *seen, *mask;
+BSEG bseen, bmask;
+NODE *zero;
+CELL on, off;
int r, c;
Modified: grass/trunk/raster/r.surf.fractal/frac.h
--- grass/trunk/raster/r.surf.fractal/frac.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.surf.fractal/frac.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -23,22 +23,15 @@
-#ifndef MAIN
-#endif
- char *rast_out_name, /* Name of the raster output file. */
+extern char
*mapset_out;
-#ifndef MAIN
-extern
-#endif
- int fd_out, /* File descriptor of output raster */
+extern int
+ fd_out, /* File descriptor of output raster */
Steps; /* Number of intermediate images. */
-#ifndef MAIN
-extern
-#endif
-double H; /* Hausdorff-Besickovitch dimension. */
+extern double H; /* Hausdorff-Besickovitch dimension. */
/* interface.c */
int interface(int, char *[]);
Modified: grass/trunk/raster/r.surf.fractal/main.c
--- grass/trunk/raster/r.surf.fractal/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.surf.fractal/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -12,26 +12,22 @@
-#define MAIN
#include "frac.h"
-int main(int argc, char *argv[])
+char
+ *mapset_out;
+int
+ Steps; /* Number of intermediate images. */
+double H; /* Hausdorff-Besickovitch dimension. */
- interface(argc, argv);
+int main(int argc, char *argv[])
- /* PROCESS RASTER FILES */
+ interface(argc, argv);
process();
return EXIT_SUCCESS;
Modified: grass/trunk/raster/r.surf.idw/main.c
--- grass/trunk/raster/r.surf.idw/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.surf.idw/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -35,10 +35,45 @@
#include <stdlib.h>
#include <math.h>
-#define MAIN
-#include "main.h"
+#include "main.h"
+struct Cell_head window;
+CELL *cell, *mask;
+double *rowlook, *collook, *lat_diff, /* distances between latitudes */
+ ew2;
+short ll; /* TRUE if latitude-longitude projection */
+/* function pointers for LL function substitutes */
+int first_west(EW *, SHORT);
+int first_west_LL(EW *, SHORT);
+int (*init_row_search) (EW *, SHORT); /* function pointer */
+int completed_row(EW *);
+int completed_row_LL(EW *);
+ /* function pointer */
+int (*comp_row_search) (EW *);
+int find_neighbors(EW *, NEIGHBOR *, SHORT, SHORT, int, SHORT *);
+int find_neighbors_LL(EW *, NEIGHBOR *, SHORT, SHORT, int, SHORT *);
+int (*locate_neighbors) (EW *, NEIGHBOR *, SHORT, SHORT, int, SHORT *);
+int exhaust_search(EW *, NEIGHBOR *, SHORT, SHORT);
+int exhaust_search_LL(EW *, NEIGHBOR *, SHORT, SHORT);
+/* function pointer */
+int (*exhaust_row) (EW *, NEIGHBOR *, SHORT, SHORT);
+double offset_distance(SHORT);
+double offset_distance_LL(SHORT);
+double (*check_offset) (SHORT); /* function pointer */
static int error_flag = 0;
static char *input;
static char *output;
Modified: grass/trunk/raster/r.surf.idw/main.h
--- grass/trunk/raster/r.surf.idw/main.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.surf.idw/main.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -32,45 +32,6 @@
EW *next;
-#ifdef MAIN
-struct Cell_head window;
-CELL *cell, *mask;
-double *rowlook, *collook, *lat_diff, /* distances between latitudes */
- ew2;
-short ll; /* TRUE if latitude-longitude projection */
-/* function pointers for LL function substitutes */
-int first_west(EW *, SHORT);
-int first_west_LL(EW *, SHORT);
-int (*init_row_search) (EW *, SHORT); /* function pointer */
-int completed_row(EW *);
-int completed_row_LL(EW *);
- /* function pointer */
-int (*comp_row_search) (EW *);
-int find_neighbors(EW *, NEIGHBOR *, SHORT, SHORT, int, SHORT *);
-int find_neighbors_LL(EW *, NEIGHBOR *, SHORT, SHORT, int, SHORT *);
-int (*locate_neighbors) (EW *, NEIGHBOR *, SHORT, SHORT, int, SHORT *);
-int exhaust_search(EW *, NEIGHBOR *, SHORT, SHORT);
-int exhaust_search_LL(EW *, NEIGHBOR *, SHORT, SHORT);
-/* function pointer */
-int (*exhaust_row) (EW *, NEIGHBOR *, SHORT, SHORT);
-double offset_distance(SHORT);
-double offset_distance_LL(SHORT);
-double (*check_offset) (SHORT); /* function pointer */
-#endif
/* dist.c */
int G_begin_geodesic_distance_l(short, double, double);
double LL_set_geodesic_distance_lat(double);
Modified: grass/trunk/raster/r.to.vect/global.h
--- grass/trunk/raster/r.to.vect/global.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.to.vect/global.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -20,12 +20,6 @@
/* write_boundary write a line out to the digit files */
/* write_area make table of area mappings and write dlg label file */
-#ifdef MAIN
-#define Global
-#else
-#define Global extern
-#endif
#define BACKWARD 1
#define FORWARD 2
#define OPEN 1
@@ -38,27 +32,27 @@
#define CATNUM 0
#define CATLABEL 1
-Global int data_type;
-Global int data_size;
-Global struct Map_info Map;
-Global int input_fd; /* input_fd input raster map descriptor */
-Global struct line_cats *Cats;
-Global struct Cell_head cell_head;
+extern int data_type;
+extern int data_size;
+extern struct Map_info Map;
+extern int input_fd; /* input_fd input raster map descriptor */
+extern struct line_cats *Cats;
+extern struct Cell_head cell_head;
-Global int direction;
-Global int first_read, last_read;
-Global int row_length, row_count, n_rows;
-Global int total_areas;
+extern int first_read, last_read;
+extern int row_length, row_count, n_rows;
+extern int total_areas;
-Global int smooth_flag; /* this is 0 for no smoothing, 1 for smoothing of lines */
-Global int value_flag; /* use raster values as categories */
+extern int smooth_flag; /* this is 0 for no smoothing, 1 for smoothing of lines */
+extern int value_flag; /* use raster values as categories */
-Global struct Categories RastCats;
-Global int has_cats; /* Category labels available */
-Global struct field_info *Fi;
-Global dbDriver *driver;
-Global dbString sql, label;
+extern struct Categories RastCats;
+extern int has_cats; /* Category labels available */
+extern struct field_info *Fi;
+extern dbDriver *driver;
+extern dbString sql, label;
struct COOR
Modified: grass/trunk/raster/r.to.vect/main.c
--- grass/trunk/raster/r.to.vect/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.to.vect/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -16,8 +16,6 @@
-#define MAIN
#include <stdio.h>
#include <stdlib.h>
@@ -35,6 +33,28 @@
* 2007/2: attributes for lines supported
+int data_type;
+int data_size;
+struct Map_info Map;
+int input_fd; /* input_fd input raster map descriptor */
+struct line_cats *Cats;
+struct Cell_head cell_head;
+int direction;
+int first_read, last_read;
+int input_fd;
+int row_length, row_count, n_rows;
+int total_areas;
+int smooth_flag; /* this is 0 for no smoothing, 1 for smoothing of lines */
+int value_flag; /* use raster values as categories */
+struct Categories RastCats;
+int has_cats; /* Category labels available */
+struct field_info *Fi;
+dbDriver *driver;
+dbString sql, label;
Modified: grass/trunk/raster/r.topidx/global.h
--- grass/trunk/raster/r.topidx/global.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.topidx/global.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -18,13 +18,7 @@
void initialize(void);
void atanb(void);
-#ifdef MAIN
-# define GLOBAL
-#else
-#endif
-GLOBAL char *mapset, *iname, *oname;
-GLOBAL struct Cell_head window;
-GLOBAL DCELL **cell;
-GLOBAL DCELL **atb, **a;
+extern char *mapset, *iname, *oname;
+extern struct Cell_head window;
+extern DCELL **cell;
+extern DCELL **atb, **a;
Modified: grass/trunk/raster/r.topidx/main.c
--- grass/trunk/raster/r.topidx/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.topidx/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -18,10 +18,14 @@
-#define MAIN
#include "global.h"
+char *mapset, *iname, *oname;
+DCELL **cell;
+DCELL **atb, **a;
Modified: grass/trunk/raster/r.topmodel/file_io.c
--- grass/trunk/raster/r.topmodel/file_io.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.topmodel/file_io.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -21,6 +21,7 @@
void read_inputs(void)
+ char buf[1024];
FILE *fp;
int i, j;
double x;
Modified: grass/trunk/raster/r.topmodel/global.h
--- grass/trunk/raster/r.topmodel/global.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.topmodel/global.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -51,22 +51,15 @@
double get_f(double t, double R);
-#ifdef MAIN
-# define GLOBAL
-#else
-#endif
/* Topographic index statistics file */
-GLOBAL struct
+struct idxstats
/* misc.nidxclass's */
double *atb, *Aatb_r;
-} idxstats;
/* Parameters file */
-GLOBAL struct
+struct params
char *name;
double A, qs0, lnTe, m, Sr0, Srmax, td, vch, vr;
@@ -78,28 +71,28 @@
} params;
/* Input file */
-GLOBAL struct
+struct input
int ntimestep;
double dt;
/* input.ntimestep's */
double *R, *Ep;
-} input;
/* Map names */
-GLOBAL struct
+struct map
char *basin, *elev, *belev, *fill, *dir, *topidx;
-} map;
/* File names */
-GLOBAL struct
+struct file
char *idxstats, *params, *input, *output, *Qobs;
-} file;
/* Miscellaneous TOPMODEL variables */
-GLOBAL struct
+struct misc
/* Number of non-null cells */
int ncell;
@@ -133,10 +126,9 @@
double **ex;
/* Miscellaneous variables */
int timestep, idxclass;
-} misc;
-GLOBAL struct
+struct flg
/* Input flag */
char input;
@@ -144,9 +136,16 @@
char overwr;
/* Overwrite list */
int overwrlist;
-} flg;
+extern struct idxstats idxstats;
+extern struct params params;
+extern struct input input;
+extern struct map map;
+extern struct file file;
+extern struct misc misc;
+extern struct flg flg;
-GLOBAL char *gisbase, *mapset;
-GLOBAL char buf[BUFSIZE];
+extern char *gisbase, *mapset;
+extern char buf[BUFSIZE];
Modified: grass/trunk/raster/r.topmodel/main.c
--- grass/trunk/raster/r.topmodel/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.topmodel/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -14,12 +14,19 @@
-#define MAIN
#include <stdio.h>
#include <stdlib.h>
#include "global.h"
+struct idxstats idxstats;
+struct params params;
+struct input input;
+struct map map;
+struct file file;
+struct misc misc;
+struct flg flg;
+char *gisbase, *mapset;
Modified: grass/trunk/raster/r.topmodel/misc.c
--- grass/trunk/raster/r.topmodel/misc.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.topmodel/misc.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -22,6 +22,7 @@
void gregion(void)
+ char buf[GPATH_MAX];
char *hdmap;
@@ -48,6 +49,7 @@
void depressionless(void)
sprintf(buf, "%s/bin/r.fill.dir "
"input=%s elev=%s dir=%s type=grass > /dev/null",
gisbase, map.elev, map.fill, map.dir);
@@ -66,6 +68,7 @@
void basin_elevation(void)
sprintf(buf, "%s/bin/r.mapcalc "
"'%s = if(%s == 0 || isnull(%s), null(), %s)' > /dev/null",
gisbase, map.belev, map.basin, map.basin, map.elev);
@@ -82,6 +85,7 @@
void top_index(void)
if (map.belev) {
sprintf(buf, "%s/bin/r.topidx "
"input=%s output=%s > /dev/null",
Modified: grass/trunk/raster/r.univar2/globals.h
--- grass/trunk/raster/r.univar2/globals.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.univar2/globals.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -47,11 +47,7 @@
struct Flag *shell_style, *extended;
} param_type;
-#ifdef MAIN
-param_type param;
-#else
extern param_type param;
-#endif
/* fn prototypes */
void heapsort_double(double *data, int n);
Modified: grass/trunk/raster/r.univar2/r.univar_main.c
--- grass/trunk/raster/r.univar2/r.univar_main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.univar2/r.univar_main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -16,16 +16,14 @@
#include <assert.h>
#include <string.h>
-#define MAIN
#include "globals.h"
-/* local proto */
-void set_params();
+param_type param;
/* Set up the arguments we are expecting ********************************** */
-void set_params()
param.inputfile = G_define_standard_option(G_OPT_R_MAPS);
Modified: grass/trunk/raster/r.univar2/r3.univar_main.c
--- grass/trunk/raster/r.univar2/r3.univar_main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.univar2/r3.univar_main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -15,16 +15,14 @@
-#define MAIN
-/* local proto */
-void set_params();
+param_type param;
-void set_params()
param.inputfile = G_define_standard_option(G_OPT_R3_INPUT);
Modified: grass/trunk/raster/r.walk/main.c
--- grass/trunk/raster/r.walk/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.walk/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -90,8 +90,6 @@
* Markus Neteler CEA
-#define MAIN
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
@@ -107,6 +105,21 @@
+struct variables
+ char *alias;
+ int position;
+} variables[] = {
+char cost_layer[64], dtm_layer[64];
Modified: grass/trunk/raster/r.walk/stash.h
--- grass/trunk/raster/r.walk/stash.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.walk/stash.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -25,36 +25,11 @@
-#ifdef MAIN
-struct variables
- char *alias;
- int position;
-variables[] = {
- "coor", START_PT}
-char cost_layer[64], dtm_layer[64];
-#else
extern char cost_layer[], dtm_layer[];
-#endif
Modified: grass/trunk/raster/r.water.outlet/basin.h
--- grass/trunk/raster/r.water.outlet/basin.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.water.outlet/basin.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -26,37 +26,23 @@
int row, col;
-#ifdef MAIN
-#define GLOBAL
-#define DRAINVAR = {{ 7,6,5 },{ 8,-17,4 },{ 1,2,3 }}
-#define UPDRAINVAR = {{ 3,2,1 },{ 4,-17,8 },{ 5,6,7 }}
-#define DRVAR ={0,1,1,1,0,-1,-1,-1,0}
-#define DCVAR ={0,1,0,-1,-1,-1,0,1,1}
-#else
-#define DRAINVAR
-#define UPDRAINVAR
-#define DRVAR
-#define DCVAR
-#endif
-GLOBAL SHORT drain[3][3] DRAINVAR;
-GLOBAL SHORT updrain[3][3] UPDRAINVAR;
-GLOBAL char dr_mod[9] DRVAR;
-GLOBAL char dc_mod[9] DCVAR;
-GLOBAL char basin_name[GNAME_MAX], swale_name[GNAME_MAX],
+extern SHORT drain[3][3];
+extern SHORT updrain[3][3];
+extern char dr_mod[9];
+extern char dc_mod[9];
+extern char basin_name[GNAME_MAX], swale_name[GNAME_MAX],
half_name[GNAME_MAX], elev_name[GNAME_MAX], armsed_name[GNAME_MAX];
-GLOBAL int nrows, ncols, done, total;
-GLOBAL int array_size, high_index, do_index;
-GLOBAL char *drain_ptrs, ha_f, el_f, ar_f;
-GLOBAL RAMSEG ba_seg, pt_seg, sl_seg;
-GLOBAL int ncols_less_one, nrows_less_one;
-GLOBAL NODE *to_do;
-GLOBAL FILE *arm_fd, *fp;
-GLOBAL FLAG *doner, *swale, *left;
-GLOBAL CELL *bas;
-GLOBAL double half_res, diag, max_length, dep_slope;
+extern int nrows, ncols, done, total;
+extern int array_size, high_index, do_index;
+extern char *drain_ptrs, ha_f, el_f, ar_f;
+extern RAMSEG ba_seg, pt_seg, sl_seg;
+extern int ncols_less_one, nrows_less_one;
+extern NODE *to_do;
+extern FILE *arm_fd, *fp;
+extern FLAG *doner, *swale, *left;
+extern CELL *bas;
+extern double half_res, diag, max_length, dep_slope;
GLOBAL CELL *dis, *alt, *wat, *asp, *bas, *haf, *r_h, *dep, *ril_buf;
Modified: grass/trunk/raster/r.water.outlet/main.c
--- grass/trunk/raster/r.water.outlet/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.water.outlet/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -24,13 +24,30 @@
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
-#define MAIN
-#include "basin.h"
-#include "outletP.h"
-#undef MAIN
+#include "basin.h"
+#include "outletP.h"
+SHORT drain[3][3] = {{ 7,6,5 },{ 8,-17,4 },{ 1,2,3 }};
+SHORT updrain[3][3] = {{ 3,2,1 },{ 4,-17,8 },{ 5,6,7 }};
+char dr_mod[9] = {0,1,1,1,0,-1,-1,-1,0};
+char dc_mod[9] = {0,1,0,-1,-1,-1,0,1,1};
+char basin_name[GNAME_MAX], swale_name[GNAME_MAX],
+ half_name[GNAME_MAX], elev_name[GNAME_MAX], armsed_name[GNAME_MAX];
+int nrows, ncols, done, total;
+int array_size, high_index, do_index;
+char *drain_ptrs, ha_f, el_f, ar_f;
+RAMSEG ba_seg, pt_seg, sl_seg;
+int ncols_less_one, nrows_less_one;
+NODE *to_do;
+FILE *arm_fd, *fp;
+FLAG *doner, *swale, *left;
+CELL *bas;
+double half_res, diag, max_length, dep_slope;
double N, E;
Modified: grass/trunk/raster/r.watershed/ram/Gwater.h
--- grass/trunk/raster/r.watershed/ram/Gwater.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.watershed/ram/Gwater.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -38,60 +38,41 @@
int nxt;
-#ifdef MAIN
-#define GLOBAL
-#define DRAINVAR = {{ 7,6,5 },{ 8,0,4 },{ 1,2,3 }}
-#define UPDRAINVAR = {{ 3,2,1 },{ 4,0,8 },{ 5,6,7 }}
-#define NEXTDRVAR = { 1,-1,0,0,-1,1,1,-1 }
-#define NEXTDCVAR = { 0,0,-1,1,1,-1,1,-1 }
-#else
-#define DRAINVAR
-#define UPDRAINVAR
-#define NEXTDRVAR
-#define NEXTDCVAR
-#endif
+extern int first_astar, first_cum, nxt_avail_pt, total_cells, do_points;
+extern SHORT nrows, ncols;
+extern int bas_thres, tot_parts;
+extern FLAG *worked, *in_list, *s_b, *swale;
+extern RAMSEG dis_seg, alt_seg, wat_seg, asp_seg, bas_seg, haf_seg;
+extern RAMSEG r_h_seg, dep_seg;
+extern RAMSEG slp_seg, s_l_seg, s_g_seg, l_s_seg;
+extern POINT *astar_pts;
+extern CELL *dis, *alt, *wat, *asp, *bas, *haf, *r_h, *dep;
+extern CELL *ril_buf;
+extern int ril_fd;
+extern double *s_l, *s_g, *l_s;
+extern CELL one, zero;
+extern double ril_value, dzero;
+extern SHORT sides;
+extern SHORT nextdr[8];
+extern SHORT nextdc[8];
+extern char ele_name[GNAME_MAX], *ele_mapset, pit_name[GNAME_MAX], *pit_mapset;
+extern char run_name[GNAME_MAX], *run_mapset, ob_name[GNAME_MAX], *ob_mapset;
+extern char ril_name[GNAME_MAX], *ril_mapset, dep_name[GNAME_MAX], *dep_mapset;
+extern char *this_mapset;
+extern char seg_name[GNAME_MAX], bas_name[GNAME_MAX], haf_name[GNAME_MAX], thr_name[8];
+extern char ls_name[GNAME_MAX], st_name[GNAME_MAX], sl_name[GNAME_MAX], sg_name[GNAME_MAX];
+extern char wat_name[GNAME_MAX], asp_name[GNAME_MAX], arm_name[GNAME_MAX], dis_name[GNAME_MAX];
+extern char ele_flag, pit_flag, run_flag, dis_flag, ob_flag;
+extern char wat_flag, asp_flag, arm_flag, ril_flag, dep_flag;
+extern char bas_flag, seg_flag, haf_flag, er_flag;
+extern char st_flag, sb_flag, sg_flag, sl_flag, ls_flag;
+extern FILE *fp;
-GLOBAL int first_astar, first_cum, nxt_avail_pt, total_cells, do_points;
-GLOBAL SHORT nrows, ncols;
-GLOBAL int bas_thres, tot_parts;
-GLOBAL FLAG *worked, *in_list, *s_b, *swale;
-GLOBAL RAMSEG dis_seg, alt_seg, wat_seg, asp_seg, bas_seg, haf_seg;
-GLOBAL RAMSEG r_h_seg, dep_seg;
-GLOBAL RAMSEG slp_seg, s_l_seg, s_g_seg, l_s_seg;
-GLOBAL POINT *astar_pts;
-GLOBAL CELL *dis, *alt, *wat, *asp, *bas, *haf, *r_h, *dep;
-GLOBAL CELL *ril_buf;
-GLOBAL int ril_fd;
-GLOBAL double *s_l, *s_g, *l_s;
-GLOBAL CELL one, zero;
-GLOBAL double ril_value, dzero;
-GLOBAL SHORT sides;
-GLOBAL SHORT nextdr[8] NEXTDRVAR;
-GLOBAL SHORT nextdc[8] NEXTDCVAR;
-GLOBAL char ele_name[GNAME_MAX], *ele_mapset, pit_name[GNAME_MAX],
- *pit_mapset;
-GLOBAL char run_name[GNAME_MAX], *run_mapset, ob_name[GNAME_MAX], *ob_mapset;
-GLOBAL char ril_name[GNAME_MAX], *ril_mapset, dep_name[GNAME_MAX],
- *dep_mapset;
-GLOBAL char *this_mapset;
-GLOBAL char seg_name[GNAME_MAX], bas_name[GNAME_MAX], haf_name[GNAME_MAX],
- thr_name[8];
-GLOBAL char ls_name[GNAME_MAX], st_name[GNAME_MAX], sl_name[GNAME_MAX],
- sg_name[GNAME_MAX];
-GLOBAL char wat_name[GNAME_MAX], asp_name[GNAME_MAX], arm_name[GNAME_MAX],
- dis_name[GNAME_MAX];
-GLOBAL char ele_flag, pit_flag, run_flag, dis_flag, ob_flag;
-GLOBAL char wat_flag, asp_flag, arm_flag, ril_flag, dep_flag;
-GLOBAL char bas_flag, seg_flag, haf_flag, er_flag;
-GLOBAL char st_flag, sb_flag, sg_flag, sl_flag, ls_flag;
-GLOBAL FILE *fp;
/* close_maps.c */
int close_maps(void);
Modified: grass/trunk/raster/r.watershed/ram/main.c
--- grass/trunk/raster/r.watershed/ram/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.watershed/ram/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -13,15 +13,48 @@
* for details.
-#define MAIN
#include <stdlib.h>
#include <unistd.h>
#include "Gwater.h"
-#undef MAIN
+int first_astar, first_cum, nxt_avail_pt, total_cells, do_points;
+SHORT nrows, ncols;
+int bas_thres, tot_parts;
+FLAG *worked, *in_list, *s_b, *swale;
+RAMSEG dis_seg, alt_seg, wat_seg, asp_seg, bas_seg, haf_seg;
+RAMSEG r_h_seg, dep_seg;
+RAMSEG slp_seg, s_l_seg, s_g_seg, l_s_seg;
+POINT *astar_pts;
+CELL *dis, *alt, *wat, *asp, *bas, *haf, *r_h, *dep;
+CELL *ril_buf;
+int ril_fd;
+double *s_l, *s_g, *l_s;
+CELL one, zero;
+double ril_value, dzero;
+SHORT sides;
+SHORT drain[3][3] = {{ 7,6,5 },{ 8,0,4 },{ 1,2,3 }};
+SHORT updrain[3][3] = {{ 3,2,1 },{ 4,0,8 },{ 5,6,7 }};
+SHORT nextdr[8] = { 1,-1,0,0,-1,1,1,-1 };
+SHORT nextdc[8] = { 0,0,-1,1,1,-1,1,-1 };
+char ele_name[GNAME_MAX], *ele_mapset, pit_name[GNAME_MAX], *pit_mapset;
+char run_name[GNAME_MAX], *run_mapset, ob_name[GNAME_MAX], *ob_mapset;
+char ril_name[GNAME_MAX], *ril_mapset, dep_name[GNAME_MAX], *dep_mapset;
+char *this_mapset;
+char seg_name[GNAME_MAX], bas_name[GNAME_MAX], haf_name[GNAME_MAX], thr_name[8];
+char ls_name[GNAME_MAX], st_name[GNAME_MAX], sl_name[GNAME_MAX], sg_name[GNAME_MAX];
+char wat_name[GNAME_MAX], asp_name[GNAME_MAX], arm_name[GNAME_MAX], dis_name[GNAME_MAX];
+char ele_flag, pit_flag, run_flag, dis_flag, ob_flag;
+char wat_flag, asp_flag, arm_flag, ril_flag, dep_flag;
+char bas_flag, seg_flag, haf_flag, er_flag;
+char st_flag, sb_flag, sg_flag, sl_flag, ls_flag;
+FILE *fp;
init_vars(argc, argv);
Modified: grass/trunk/raster/r.watershed/seg/Gwater.h
--- grass/trunk/raster/r.watershed/seg/Gwater.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.watershed/seg/Gwater.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -35,56 +35,37 @@
int nxt;
-#ifdef MAIN
-#define GLOBAL
-#else
-#define DRAINVAR
-#define UPDRAINVAR
-#define NEXTDRVAR
-#define NEXTDCVAR
-#endif
+extern SSEG astar_pts;
+extern BSEG worked, in_list, s_b, swale;
+extern CSEG dis, alt, wat, asp, bas, haf, r_h, dep;
+extern DSEG slp, s_l, s_g, l_s, ril;
-GLOBAL SSEG astar_pts;
-GLOBAL BSEG worked, in_list, s_b, swale;
-GLOBAL CSEG dis, alt, wat, asp, bas, haf, r_h, dep;
-GLOBAL DSEG slp, s_l, s_g, l_s, ril;
- *pit_mapset;
- *dep_mapset;
+extern FILE *fp;
- thr_name[8];
-GLOBAL FILE *fp;
/* close_maps.c */
Modified: grass/trunk/raster/r.watershed/seg/main.c
--- grass/trunk/raster/r.watershed/seg/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/r.watershed/seg/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -15,19 +15,53 @@
* for details.
-#define MAIN
#include <stdlib.h>
#include <unistd.h>
#include "Gwater.h"
-#undef MAIN
+SSEG astar_pts;
+BSEG worked, in_list, s_b, swale;
+CSEG dis, alt, wat, asp, bas, haf, r_h, dep;
+DSEG slp, s_l, s_g, l_s, ril;
+CELL one, zero;
+SHORT sides;
+ *pit_mapset;
+ *dep_mapset;
+char *this_mapset;
+ thr_name[8];
+ sg_name[GNAME_MAX];
+ dis_name[GNAME_MAX];
+FILE *fp;
- extern FILE *fopen();
one = 1;
zero = 0;
dzero = 0.0;
Modified: grass/trunk/raster/wildfire/r.spreadpath/main.c
--- grass/trunk/raster/wildfire/r.spreadpath/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/wildfire/r.spreadpath/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -33,12 +33,28 @@
#include <fcntl.h>
-#define MAIN
#include "stash.h"
+struct variables
+ char *alias;
+ int position;
+} variables[] = {
+ {"x_input", BACKCOL_LAYER},
+ {"y_input", BACKROW_LAYER},
+ {"coor", START_PT},
+ {"output", PATH_LAYER}
+char path_layer[64];
+char backrow_layer[64];
+char backcol_layer[64];
+struct point *head_start_pt = NULL;
char *value;
int nrows, ncols;
SEGMENT in_row_seg, in_col_seg, out_seg;
Modified: grass/trunk/raster/wildfire/r.spreadpath/stash.h
--- grass/trunk/raster/wildfire/r.spreadpath/stash.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster/wildfire/r.spreadpath/stash.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -17,34 +17,10 @@
#define PATH_LAYER 4
#include "point.h"
-#ifdef MAIN
-struct variables
- char *alias;
- int position;
-variables[] = {
- "x_input", BACKCOL_LAYER}, {
- "y_input", BACKROW_LAYER}, {
- "coor", START_PT}, {
- "output", PATH_LAYER}
-char path_layer[64];
-char backrow_layer[64];
-char backcol_layer[64];
-struct point *head_start_pt = NULL;
-#else
extern char path_layer[];
extern char backrow_layer[];
extern char backcol_layer[];
extern struct point *head_start_pt;
-#endif
/****************END OF "GDRAIN_CMD_LINE.H"**********************/
Modified: grass/trunk/raster3d/r3.mkdspf/iso_surface.c
--- grass/trunk/raster3d/r3.mkdspf/iso_surface.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster3d/r3.mkdspf/iso_surface.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,7 +1,6 @@
#include <stdlib.h>
#include <math.h>
#include "vizual.h"
-#include "cell_table.h"
#include <grass/G3d.h>
Modified: grass/trunk/raster3d/r3.mkdspf/main.c
--- grass/trunk/raster3d/r3.mkdspf/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster3d/r3.mkdspf/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -40,7 +40,6 @@
* to use new GRASS 3dgrid data files & API
-#define MAIN
#include <stdlib.h>
#include <math.h>
#include "vizual.h"
@@ -49,6 +48,10 @@
#include <grass/glocale.h>
+file_info Headfax; /* contains info about command line */
+Cube_data CUBE; /* and the data for a single cube */
+int NTHRESH;
char *dspout, element[160];
Modified: grass/trunk/raster3d/r3.mkdspf/vizual.h
--- grass/trunk/raster3d/r3.mkdspf/vizual.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster3d/r3.mkdspf/vizual.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,5 +1,5 @@
#include "viz.h"
-GLOBAL file_info Headfax; /* contains info about command line */
-GLOBAL Cube_data CUBE; /* and the data for a single cube */
-GLOBAL int NTHRESH;
+extern file_info Headfax; /* contains info about command line */
+extern Cube_data CUBE; /* and the data for a single cube */
+extern int NTHRESH;
Modified: grass/trunk/raster3d/r3.out.vtk/globalDefs.h
--- grass/trunk/raster3d/r3.out.vtk/globalDefs.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster3d/r3.out.vtk/globalDefs.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -41,12 +41,7 @@
} input_maps;
-#ifdef MAIN
-double x_extent;
-double y_extent;
-#else
-#endif
#endif
Modified: grass/trunk/raster3d/r3.out.vtk/main.c
--- grass/trunk/raster3d/r3.out.vtk/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster3d/r3.out.vtk/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -22,7 +22,6 @@
-#define MAIN
#include "globalDefs.h"
@@ -31,6 +30,11 @@
#include "writeVTKHead.h"
#include "errorHandling.h"
+double x_extent;
+double y_extent;
/** prototypes ***************************************************************/
/*Open the rgb voxel maps and write the data to the output */
Modified: grass/trunk/raster3d/r3.out.vtk/parameters.h
--- grass/trunk/raster3d/r3.out.vtk/parameters.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster3d/r3.out.vtk/parameters.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -29,13 +29,9 @@
/*global structs */
-#ifdef MAIN
-#else
-#endif
/*prototype */
-void set_params();
#endif
Deleted: grass/trunk/raster3d/r3.showdspf/cell_table.h
--- grass/trunk/raster3d/r3.showdspf/cell_table.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster3d/r3.showdspf/cell_table.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,1542 +0,0 @@
-#ifdef MAIN
-CELL_ENTRY cell_table[256] = {
- {0, 0, 0, 0, 0, 0, 0, 0, 0,
- 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, 1, 0, 0, 0, 0, 0, 0, 0,
- 3, 1, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 1, 1, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, 2, 0, 0, 0, 0, 0, 0, 0,
- 3, 1, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 1, 1, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 1, 2, 0, 0, 0, 0, 0, 0,
- 4, 2, 4, 9, 10, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 2, 9, 10, 2, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, 3, 0, 0, 0, 0, 0, 0, 0,
- 3, 3, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 1, 3, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 1, 3, 0, 0, 0, 0, 0, 0,
- 6, 1, 2, 3, 4, 9, 12, 0, 0, 0, 0, 0, 0,
- 2, 1, 4, 9, 3, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 3, 2, 0, 0, 0, 0, 0, 0,
- 4, 10, 12, 3, 1, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 10, 3, 1, 10, 12, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 3, 2, 1, 0, 0, 0, 0, 0,
- 5, 10, 12, 4, 9, 3, 0, 0, 0, 0, 0, 0, 0,
- 3, 12, 9, 10, 3, 9, 12, 3, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, 4, 0, 0, 0, 0, 0, 0, 0,
- 3, 3, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 1, 3, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 1, 4, 0, 0, 0, 0, 0, 0,
- 4, 11, 9, 1, 3, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 11, 1, 3, 11, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 2, 4, 0, 0, 0, 0, 0, 0,
- 6, 2, 3, 4, 1, 10, 11, 0, 0, 0, 0, 0, 0,
- 2, 2, 1, 10, 4, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 2, 1, 4, 0, 0, 0, 0, 0,
- 5, 9, 10, 3, 11, 2, 0, 0, 0, 0, 0, 0, 0,
- 3, 10, 11, 9, 2, 11, 10, 2, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 4, 3, 0, 0, 0, 0, 0, 0,
- 4, 12, 11, 4, 2, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 12, 4, 2, 12, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 1, 4, 3, 0, 0, 0, 0, 0,
- 5, 11, 9, 2, 12, 1, 0, 0, 0, 0, 0, 0, 0,
- 3, 9, 12, 11, 1, 12, 9, 1, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 4, 3, 2, 0, 0, 0, 0, 0,
- 5, 12, 11, 1, 10, 4, 0, 0, 0, 0, 0, 0, 0,
- 3, 11, 10, 12, 4, 10, 11, 4, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 4, 3, 1, 2, 0, 0, 0, 0,
- 4, 12, 11, 10, 9, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 11, 9, 10, 11, 10, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, 5, 0, 0, 0, 0, 0, 0, 0,
- 3, 5, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 1, 5, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 5, 1, 0, 0, 0, 0, 0, 0,
- 4, 4, 8, 5, 1, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 4, 5, 1, 4, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 5, 2, 0, 0, 0, 0, 0, 0,
- 6, 5, 10, 1, 9, 8, 2, 0, 0, 0, 0, 0, 0,
- 2, 5, 9, 8, 1, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 5, 1, 2, 0, 0, 0, 0, 0,
- 5, 4, 8, 10, 2, 5, 0, 0, 0, 0, 0, 0, 0,
- 3, 8, 2, 4, 5, 2, 8, 5, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 5, 3, 0, 0, 0, 0, 0, 0,
- 6, 5, 9, 12, 3, 8, 2, 0, 0, 0, 0, 0, 0,
- 2, 5, 9, 8, 12, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 5, 1, 3, 0, 0, 0, 0, 0,
- 7, 4, 8, 2, 12, 5, 1, 3, 0, 0, 0, 0, 0,
- 3, 2, 12, 3, 4, 8, 5, 4, 5, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 3, 2, 5, 0, 0, 0, 0, 0,
- 7, 10, 12, 9, 8, 3, 1, 5, 0, 0, 0, 0, 0,
- 3, 9, 8, 5, 10, 12, 3, 10, 3, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 3, 1, 2, 5, 0, 0, 0, 0,
- 6, 3, 12, 10, 5, 4, 8, 0, 0, 0, 0, 0, 0,
- 4, 3, 10, 12, 3, 8, 10, 3, 4, 8, 10, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 5, 4, 0, 0, 0, 0, 0, 0,
- 6, 9, 4, 11, 8, 5, 3, 0, 0, 0, 0, 0, 0,
- 2, 9, 8, 5, 11, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 4, 1, 5, 0, 0, 0, 0, 0,
- 5, 1, 3, 8, 5, 11, 0, 0, 0, 0, 0, 0, 0,
- 3, 3, 5, 1, 11, 5, 3, 11, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 5, 4, 2, 0, 0, 0, 0, 0,
- 9, 8, 9, 4, 11, 10, 2, 5, 3, 1, 0, 0, 0,
- 3, 10, 2, 1, 4, 3, 11, 9, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 4, 1, 2, 5, 0, 0, 0, 0,
- 6, 3, 11, 10, 5, 2, 8, 0, 0, 0, 0, 0, 0,
- 4, 10, 2, 3, 5, 10, 3, 11, 5, 3, 8, 5, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 3, 4, 5, 0, 0, 0, 0, 0,
- 7, 4, 2, 8, 5, 12, 11, 9, 0, 0, 0, 0, 0,
- 3, 8, 5, 9, 4, 2, 12, 4, 12, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 3, 4, 1, 5, 0, 0, 0, 0,
- 6, 2, 12, 8, 11, 1, 5, 0, 0, 0, 0, 0, 0,
- 4, 12, 11, 2, 11, 5, 2, 5, 1, 2, 8, 5, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 4, 5, 2, 3, 0, 0, 0, 0,
- 8, 4, 11, 8, 9, 12, 10, 1, 5, 0, 0, 0, 0,
- 4, 11, 10, 12, 11, 1, 10, 4, 1, 11, 8, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 3, 2, 5, 4, 1, 0, 0, 0,
- 5, 12, 10, 8, 11, 5, 0, 0, 0, 0, 0, 0, 0,
- 3, 11, 10, 12, 11, 5, 10, 8, 5, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, 6, 0, 0, 0, 0, 0, 0, 0,
- 3, 5, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 1, 5, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 6, 1, 0, 0, 0, 0, 0, 0,
- 6, 10, 1, 9, 5, 6, 4, 0, 0, 0, 0, 0, 0,
- 2, 10, 5, 6, 9, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 2, 6, 0, 0, 0, 0, 0, 0,
- 4, 6, 2, 1, 5, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 6, 1, 5, 6, 2, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 1, 2, 6, 0, 0, 0, 0, 0,
- 5, 2, 4, 5, 6, 9, 0, 0, 0, 0, 0, 0, 0,
- 3, 4, 6, 2, 9, 6, 4, 9, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 3, 6, 0, 0, 0, 0, 0, 0,
- 6, 2, 10, 6, 12, 3, 5, 0, 0, 0, 0, 0, 0,
- 2, 2, 12, 3, 6, 10, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 6, 1, 3, 0, 0, 0, 0, 0,
- 9, 5, 10, 1, 9, 12, 3, 6, 4, 2, 0, 0, 0,
- 3, 12, 3, 2, 1, 4, 9, 10, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 6, 2, 3, 0, 0, 0, 0, 0,
- 5, 1, 5, 12, 3, 6, 0, 0, 0, 0, 0, 0, 0,
- 3, 5, 3, 1, 6, 3, 5, 6, 12, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 1, 2, 3, 6, 0, 0, 0, 0,
- 6, 4, 9, 12, 6, 3, 5, 0, 0, 0, 0, 0, 0,
- 4, 12, 3, 4, 6, 12, 4, 9, 6, 4, 5, 6, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 4, 6, 0, 0, 0, 0, 0, 0,
- 6, 3, 11, 10, 5, 4, 6, 0, 0, 0, 0, 0, 0,
- 2, 3, 11, 4, 10, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 4, 1, 6, 0, 0, 0, 0, 0,
- 7, 1, 3, 5, 6, 11, 9, 10, 0, 0, 0, 0, 0,
- 3, 5, 6, 10, 1, 3, 11, 1, 11, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 6, 2, 4, 0, 0, 0, 0, 0,
- 7, 1, 5, 3, 11, 6, 2, 4, 0, 0, 0, 0, 0,
- 3, 3, 11, 4, 1, 5, 6, 1, 6, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 4, 1, 2, 6, 0, 0, 0, 0,
- 6, 3, 11, 5, 9, 2, 6, 0, 0, 0, 0, 0, 0,
- 4, 11, 9, 3, 9, 6, 3, 6, 2, 3, 5, 6, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 4, 3, 6, 0, 0, 0, 0, 0,
- 7, 12, 11, 10, 5, 4, 2, 6, 0, 0, 0, 0, 0,
- 3, 10, 5, 6, 12, 11, 4, 12, 4, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 1, 6, 3, 4, 0, 0, 0, 0,
- 8, 1, 9, 5, 10, 11, 12, 2, 6, 0, 0, 0, 0,
- 4, 9, 12, 11, 9, 2, 12, 1, 2, 9, 5, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 4, 2, 3, 6, 0, 0, 0, 0,
- 6, 4, 11, 12, 6, 1, 5, 0, 0, 0, 0, 0, 0,
- 4, 4, 12, 11, 4, 5, 12, 4, 1, 5, 12, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 4, 3, 6, 1, 2, 0, 0, 0,
- 5, 11, 12, 5, 9, 6, 0, 0, 0, 0, 0, 0, 0,
- 3, 9, 12, 11, 9, 6, 12, 5, 6, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 5, 6, 0, 0, 0, 0, 0, 0,
- 4, 10, 9, 8, 6, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 10, 8, 6, 10, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 6, 5, 1, 0, 0, 0, 0, 0,
- 5, 8, 6, 1, 4, 10, 0, 0, 0, 0, 0, 0, 0,
- 3, 6, 4, 8, 10, 4, 6, 10, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 2, 6, 5, 0, 0, 0, 0, 0,
- 5, 6, 2, 9, 8, 1, 0, 0, 0, 0, 0, 0, 0,
- 3, 2, 8, 6, 1, 8, 2, 1, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 1, 2, 5, 6, 0, 0, 0, 0,
- 4, 2, 4, 6, 8, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 4, 8, 6, 4, 6, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 5, 6, 3, 0, 0, 0, 0, 0,
- 7, 10, 9, 12, 3, 8, 6, 2, 0, 0, 0, 0, 0,
- 3, 12, 3, 2, 10, 9, 8, 10, 8, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 6, 3, 1, 5, 0, 0, 0, 0,
- 8, 10, 6, 12, 2, 8, 4, 1, 3, 0, 0, 0, 0,
- 4, 6, 4, 8, 6, 1, 4, 10, 1, 6, 12, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 5, 6, 2, 3, 0, 0, 0, 0,
- 6, 9, 8, 12, 6, 1, 3, 0, 0, 0, 0, 0, 0,
- 4, 8, 6, 9, 6, 3, 9, 3, 1, 9, 12, 3, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 5, 1, 3, 6, 2, 0, 0, 0,
- 5, 8, 4, 12, 6, 3, 0, 0, 0, 0, 0, 0, 0,
- 3, 6, 4, 8, 6, 3, 4, 12, 3, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 6, 5, 4, 0, 0, 0, 0, 0,
- 7, 8, 6, 4, 3, 10, 9, 11, 0, 0, 0, 0, 0,
- 3, 4, 3, 11, 8, 6, 10, 8, 10, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 6, 1, 5, 4, 0, 0, 0, 0,
- 6, 10, 6, 8, 11, 1, 3, 0, 0, 0, 0, 0, 0,
- 4, 10, 8, 6, 10, 3, 8, 10, 1, 3, 8, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 2, 4, 5, 6, 0, 0, 0, 0,
- 8, 1, 2, 3, 4, 6, 8, 9, 11, 0, 0, 0, 0,
- 4, 2, 8, 6, 2, 9, 8, 1, 9, 2, 3, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 6, 5, 4, 2, 1, 0, 0, 0,
- 5, 6, 8, 3, 2, 11, 0, 0, 0, 0, 0, 0, 0,
- 3, 2, 8, 6, 2, 11, 8, 3, 11, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 3, 4, 6, 5, 0, 0, 0, 0,
- 8, 12, 11, 10, 9, 2, 6, 4, 8, 0, 0, 0, 0,
- 4, 12, 11, 2, 11, 4, 2, 10, 8, 6, 10, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 6, 5, 4, 3, 1, 0, 0, 0,
- 7, 6, 8, 2, 1, 11, 12, 10, 0, 0, 0, 0, 0,
- 5, 1, 2, 10, 8, 6, 11, 11, 6, 12, 12, 6, 2, 2, 6, 10, 0, 0, 0, 0, 0, 0,
- {5, 4, 3, 6, 5, 2, 0, 0, 0,
- 7, 11, 12, 9, 1, 6, 8, 4, 0, 0, 0, 0, 0,
- 5, 1, 9, 4, 12, 11, 6, 6, 11, 8, 8, 11, 9, 9, 11, 4, 0, 0, 0, 0, 0, 0, 0,
- {6, 6, 5, 4, 3, 2, 1, 0, 0,
- 4, 6, 8, 11, 12, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 11, 6, 12, 8, 6, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, 7, 0, 0, 0, 0, 0, 0, 0,
- 3, 7, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 1, 7, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 1, 7, 0, 0, 0, 0, 0, 0,
- 6, 1, 4, 6, 7, 9, 12, 0, 0, 0, 0, 0, 0,
- 2, 1, 4, 9, 6, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 2, 7, 0, 0, 0, 0, 0, 0,
- 6, 10, 6, 12, 2, 1, 7, 0, 0, 0, 0, 0, 0,
- 2, 10, 2, 1, 12, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 1, 2, 7, 0, 0, 0, 0, 0,
- 7, 2, 4, 6, 7, 9, 10, 12, 0, 0, 0, 0, 0,
- 3, 6, 7, 12, 2, 4, 9, 2, 9, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 7, 3, 0, 0, 0, 0, 0, 0,
- 4, 2, 6, 7, 3, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 2, 7, 3, 2, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 7, 3, 1, 0, 0, 0, 0, 0,
- 7, 2, 6, 4, 9, 7, 3, 1, 0, 0, 0, 0, 0,
- 3, 4, 9, 1, 2, 6, 7, 2, 7, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 2, 3, 7, 0, 0, 0, 0, 0,
- 5, 3, 1, 6, 7, 10, 0, 0, 0, 0, 0, 0, 0,
- 3, 1, 7, 3, 10, 7, 1, 10, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 1, 2, 3, 7, 0, 0, 0, 0,
- 6, 4, 9, 6, 10, 3, 7, 0, 0, 0, 0, 0, 0,
- 4, 9, 10, 4, 10, 7, 4, 7, 3, 4, 6, 7, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 4, 7, 0, 0, 0, 0, 0, 0,
- 6, 3, 12, 7, 11, 4, 6, 0, 0, 0, 0, 0, 0,
- 2, 3, 11, 4, 7, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 1, 4, 7, 0, 0, 0, 0, 0,
- 7, 11, 9, 12, 6, 1, 3, 7, 0, 0, 0, 0, 0,
- 3, 12, 6, 7, 11, 9, 1, 11, 1, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 2, 4, 7, 0, 0, 0, 0, 0,
- 9, 1, 2, 3, 4, 6, 7, 10, 11, 12, 0, 0, 0,
- 3, 6, 7, 12, 3, 11, 4, 2, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 2, 7, 4, 1, 0, 0, 0, 0,
- 8, 2, 10, 6, 12, 9, 11, 3, 7, 0, 0, 0, 0,
- 4, 10, 11, 9, 10, 3, 11, 2, 3, 10, 6, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 7, 3, 4, 0, 0, 0, 0, 0,
- 5, 2, 6, 11, 4, 7, 0, 0, 0, 0, 0, 0, 0,
- 3, 6, 4, 2, 7, 4, 6, 7, 11, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 7, 4, 3, 1, 0, 0, 0, 0,
- 6, 7, 6, 2, 1, 11, 9, 0, 0, 0, 0, 0, 0,
- 4, 7, 2, 6, 7, 9, 2, 7, 11, 9, 2, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 4, 3, 7, 2, 0, 0, 0, 0,
- 6, 11, 4, 6, 10, 7, 1, 0, 0, 0, 0, 0, 0,
- 4, 6, 7, 11, 10, 6, 11, 4, 10, 11, 1, 10, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 1, 4, 7, 2, 3, 0, 0, 0,
- 5, 9, 11, 6, 10, 7, 0, 0, 0, 0, 0, 0, 0,
- 3, 10, 11, 9, 10, 7, 11, 6, 7, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 7, 5, 0, 0, 0, 0, 0, 0,
- 6, 6, 5, 8, 7, 12, 9, 0, 0, 0, 0, 0, 0,
- 2, 6, 7, 12, 8, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 1, 5, 7, 0, 0, 0, 0, 0,
- 7, 5, 1, 7, 12, 4, 8, 6, 0, 0, 0, 0, 0,
- 3, 7, 12, 6, 5, 1, 4, 5, 4, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 7, 5, 2, 0, 0, 0, 0, 0,
- 9, 7, 6, 5, 8, 2, 1, 12, 9, 10, 0, 0, 0,
- 3, 2, 1, 10, 5, 9, 8, 6, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 5, 7, 2, 1, 0, 0, 0, 0,
- 8, 5, 8, 7, 6, 4, 2, 10, 12, 0, 0, 0, 0,
- 4, 8, 2, 4, 8, 10, 2, 5, 10, 8, 7, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 3, 7, 5, 0, 0, 0, 0, 0,
- 7, 7, 3, 5, 9, 2, 6, 8, 0, 0, 0, 0, 0,
- 3, 5, 9, 8, 7, 3, 2, 7, 2, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 5, 1, 7, 3, 0, 0, 0, 0,
- 8, 5, 1, 7, 3, 8, 6, 4, 2, 0, 0, 0, 0,
- 4, 5, 1, 8, 1, 4, 8, 7, 2, 6, 7, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 2, 5, 7, 3, 0, 0, 0, 0,
- 8, 10, 1, 9, 5, 3, 7, 6, 8, 0, 0, 0, 0,
- 4, 1, 7, 3, 1, 6, 7, 10, 6, 1, 9, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 5, 1, 3, 7, 2, 0, 0, 0,
- 7, 8, 4, 6, 10, 3, 7, 5, 0, 0, 0, 0, 0,
- 5, 10, 6, 5, 4, 8, 3, 3, 8, 7, 7, 8, 6, 6, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 4, 5, 7, 0, 0, 0, 0, 0,
- 9, 4, 11, 8, 9, 12, 6, 3, 5, 7, 0, 0, 0,
- 3, 12, 6, 7, 8, 5, 9, 11, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 4, 7, 5, 1, 0, 0, 0, 0,
- 8, 11, 3, 12, 7, 1, 5, 8, 6, 0, 0, 0, 0,
- 4, 3, 5, 1, 3, 8, 5, 11, 8, 3, 12, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 4, 7, 2, 5, 0, 0, 0, 0,
- 12, 3, 12, 7, 11, 1, 10, 5, 9, 4, 2, 8, 6,
- 4, 3, 11, 4, 12, 6, 7, 1, 10, 2, 5, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 4, 7, 1, 2, 5, 0, 0, 0,
- 9, 3, 12, 7, 11, 10, 5, 2, 8, 6, 0, 0, 0,
- 10, 5, 10, 6, 8, 7, 11, 3, 12, 2, 12, 3, 11, 12, 11, 7, 7, 8, 5, 7, 5, 6,
- 12, 10, 2, 12, 6, 10, 12, 7, 6,
- {4, 7, 5, 4, 3, 0, 0, 0, 0,
- 8, 7, 6, 5, 8, 2, 4, 11, 9, 0, 0, 0, 0,
- 4, 6, 4, 2, 6, 11, 4, 7, 11, 6, 5, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 7, 3, 1, 5, 4, 0, 0, 0,
- 7, 6, 2, 8, 11, 1, 5, 7, 0, 0, 0, 0, 0,
- 5, 11, 8, 7, 2, 6, 1, 1, 6, 5, 5, 6, 8, 8, 6, 7, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 4, 5, 3, 7, 2, 0, 0, 0,
- 9, 11, 8, 9, 4, 6, 10, 7, 1, 5, 0, 0, 0,
- 10, 10, 6, 5, 1, 9, 4, 11, 8, 7, 8, 11, 4, 8, 4, 9, 9, 1, 10, 9, 10, 5,
- 8, 6, 7, 8, 5, 6, 8, 9, 5,
- {6, 7, 5, 4, 3, 2, 1, 0, 0,
- 6, 7, 6, 5, 8, 11, 10, 0, 0, 0, 0, 0, 0,
- 4, 8, 7, 11, 6, 5, 10, 6, 7, 8, 6, 8, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 6, 7, 0, 0, 0, 0, 0, 0,
- 4, 12, 10, 5, 7, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 12, 5, 7, 12, 10, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 7, 6, 1, 0, 0, 0, 0, 0,
- 7, 5, 7, 1, 4, 12, 10, 9, 0, 0, 0, 0, 0,
- 3, 1, 4, 9, 5, 7, 12, 5, 12, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 7, 6, 2, 0, 0, 0, 0, 0,
- 5, 5, 7, 2, 1, 12, 0, 0, 0, 0, 0, 0, 0,
- 3, 7, 1, 5, 12, 1, 7, 12, 2, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 1, 6, 2, 7, 0, 0, 0, 0,
- 6, 9, 4, 2, 12, 5, 7, 0, 0, 0, 0, 0, 0,
- 4, 9, 2, 4, 9, 7, 2, 9, 5, 7, 2, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 3, 7, 6, 0, 0, 0, 0, 0,
- 5, 7, 3, 10, 5, 2, 0, 0, 0, 0, 0, 0, 0,
- 3, 3, 5, 7, 2, 5, 3, 2, 10, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 3, 1, 6, 7, 0, 0, 0, 0,
- 8, 2, 3, 4, 1, 7, 5, 10, 9, 0, 0, 0, 0,
- 4, 3, 5, 7, 3, 10, 5, 2, 10, 3, 4, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 2, 3, 6, 7, 0, 0, 0, 0,
- 4, 3, 1, 7, 5, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 1, 5, 7, 1, 7, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 7, 6, 1, 3, 2, 0, 0, 0,
- 5, 7, 5, 4, 3, 9, 0, 0, 0, 0, 0, 0, 0,
- 3, 3, 5, 7, 3, 9, 5, 4, 9, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 6, 7, 4, 0, 0, 0, 0, 0,
- 7, 12, 10, 11, 4, 5, 7, 3, 0, 0, 0, 0, 0,
- 3, 11, 4, 3, 12, 10, 5, 12, 5, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 1, 4, 6, 7, 0, 0, 0, 0,
- 8, 1, 3, 5, 7, 9, 10, 11, 12, 0, 0, 0, 0,
- 4, 1, 3, 9, 3, 11, 9, 5, 12, 10, 5, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 7, 4, 2, 6, 0, 0, 0, 0,
- 8, 12, 7, 11, 3, 5, 1, 2, 4, 0, 0, 0, 0,
- 4, 7, 1, 5, 7, 2, 1, 12, 2, 7, 11, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 7, 6, 1, 4, 2, 0, 0, 0,
- 7, 7, 5, 3, 2, 9, 11, 12, 0, 0, 0, 0, 0,
- 5, 2, 3, 12, 5, 7, 9, 9, 7, 11, 11, 7, 3, 3, 7, 12, 0, 0, 0, 0, 0, 0, 0,
- {4, 4, 3, 7, 6, 0, 0, 0, 0,
- 6, 11, 4, 10, 2, 7, 5, 0, 0, 0, 0, 0, 0,
- 4, 4, 2, 11, 2, 5, 11, 5, 7, 11, 10, 5, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 1, 4, 7, 6, 3, 0, 0, 0,
- 7, 9, 11, 10, 2, 7, 5, 1, 0, 0, 0, 0, 0,
- 5, 2, 10, 1, 11, 9, 7, 7, 9, 5, 5, 9, 10, 10, 9, 1, 0, 0, 0, 0, 0, 0, 0,
- {5, 6, 2, 4, 7, 3, 0, 0, 0,
- 5, 5, 1, 11, 7, 4, 0, 0, 0, 0, 0, 0, 0,
- 3, 7, 1, 5, 7, 4, 1, 11, 4, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 1, 4, 7, 6, 2, 3, 0, 0,
- 4, 9, 11, 7, 5, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 7, 9, 5, 11, 9, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 5, 6, 7, 0, 0, 0, 0, 0,
- 5, 10, 9, 7, 12, 8, 0, 0, 0, 0, 0, 0, 0,
- 3, 9, 12, 10, 8, 12, 9, 8, 7, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 1, 5, 6, 7, 0, 0, 0, 0,
- 6, 1, 4, 7, 8, 10, 12, 0, 0, 0, 0, 0, 0,
- 4, 4, 8, 1, 8, 12, 1, 12, 10, 1, 7, 12, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 5, 6, 2, 7, 0, 0, 0, 0,
- 6, 9, 8, 2, 12, 1, 7, 0, 0, 0, 0, 0, 0,
- 4, 2, 1, 9, 12, 2, 9, 8, 12, 9, 7, 12, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 1, 2, 7, 5, 6, 0, 0, 0,
- 5, 4, 2, 7, 8, 12, 0, 0, 0, 0, 0, 0, 0,
- 3, 8, 2, 4, 8, 12, 2, 7, 12, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 5, 7, 6, 3, 0, 0, 0, 0,
- 6, 8, 9, 10, 2, 7, 3, 0, 0, 0, 0, 0, 0,
- 4, 8, 10, 9, 8, 3, 10, 8, 7, 3, 10, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 3, 7, 5, 1, 6, 0, 0, 0,
- 7, 3, 7, 1, 10, 8, 4, 2, 0, 0, 0, 0, 0,
- 5, 10, 1, 2, 7, 3, 8, 8, 3, 4, 4, 3, 1, 1, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 3, 7, 5, 2, 6, 0, 0, 0,
- 5, 3, 7, 9, 1, 8, 0, 0, 0, 0, 0, 0, 0,
- 3, 1, 7, 3, 1, 8, 7, 9, 8, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 5, 1, 3, 7, 6, 2, 0, 0,
- 4, 8, 4, 3, 7, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 3, 8, 7, 4, 8, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 5, 4, 7, 6, 0, 0, 0, 0,
- 8, 8, 9, 4, 11, 10, 12, 7, 3, 0, 0, 0, 0,
- 4, 9, 12, 10, 9, 7, 12, 8, 7, 9, 4, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 4, 1, 6, 7, 5, 0, 0, 0,
- 7, 3, 1, 7, 8, 10, 12, 11, 0, 0, 0, 0, 0,
- 5, 8, 7, 11, 1, 3, 10, 10, 3, 12, 12, 3, 7, 7, 3, 11, 0, 0, 0, 0, 0, 0,
- {5, 5, 4, 6, 2, 7, 0, 0, 0,
- 9, 9, 4, 11, 8, 2, 12, 1, 7, 3, 0, 0, 0,
- 10, 12, 2, 3, 7, 11, 8, 9, 4, 1, 4, 9, 8, 4, 8, 11, 11, 7, 12, 11, 12, 3,
- 4, 2, 1, 4, 3, 2, 4, 11, 3,
- {6, 7, 4, 2, 6, 5, 1, 0, 0,
- 6, 12, 7, 11, 3, 2, 8, 0, 0, 0, 0, 0, 0,
- 4, 3, 12, 2, 7, 11, 8, 7, 12, 3, 7, 3, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 5, 6, 3, 4, 7, 0, 0, 0,
- 7, 9, 10, 11, 7, 2, 4, 8, 0, 0, 0, 0, 0,
- 5, 7, 11, 8, 10, 9, 2, 2, 9, 4, 4, 9, 11, 11, 9, 8, 0, 0, 0, 0, 0, 0, 0,
- {6, 7, 6, 5, 4, 3, 1, 0, 0,
- 6, 7, 8, 2, 1, 11, 10, 0, 0, 0, 0, 0, 0,
- 2, 8, 7, 11, 1, 2, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 4, 5, 2, 3, 7, 6, 0, 0,
- 6, 4, 11, 8, 9, 1, 7, 0, 0, 0, 0, 0, 0,
- 4, 9, 4, 1, 11, 8, 7, 11, 4, 9, 11, 9, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, 7, 6, 5, 4, 3, 2, 1, 0,
- 3, 7, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 1, 8, 7, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {1, 8, 0, 0, 0, 0, 0, 0, 0,
- 1, 7, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 1, 8, 0, 0, 0, 0, 0, 0,
- 2, 4, 9, 1, 8, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 8, 2, 0, 0, 0, 0, 0, 0,
- 2, 7, 8, 11, 2, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 2, 1, 8, 0, 0, 0, 0, 0,
- 3, 11, 7, 8, 9, 10, 2, 9, 2, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 3, 8, 0, 0, 0, 0, 0, 0,
- 2, 12, 3, 2, 11, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 1, 8, 3, 0, 0, 0, 0, 0,
- 3, 2, 12, 3, 11, 7, 8, 4, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 2, 3, 8, 0, 0, 0, 0, 0,
- 3, 7, 8, 11, 3, 1, 10, 3, 10, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 3, 8, 1, 2, 0, 0, 0, 0,
- 8, 3, 12, 7, 11, 10, 9, 4, 8, 0, 0, 0, 0,
- 4, 12, 9, 10, 12, 4, 9, 3, 4, 12, 7, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 4, 8, 0, 0, 0, 0, 0, 0,
- 2, 8, 3, 7, 8, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 8, 4, 1, 0, 0, 0, 0, 0,
- 3, 7, 1, 3, 8, 1, 7, 8, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 8, 4, 2, 0, 0, 0, 0, 0,
- 3, 1, 10, 2, 3, 7, 8, 3, 8, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 2, 4, 1, 8, 0, 0, 0, 0,
- 6, 2, 10, 9, 8, 3, 7, 0, 0, 0, 0, 0, 0,
- 4, 2, 9, 10, 2, 7, 9, 2, 3, 7, 9, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 3, 4, 8, 0, 0, 0, 0, 0,
- 3, 2, 8, 4, 12, 8, 2, 12, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 8, 4, 3, 1, 0, 0, 0, 0,
- 6, 7, 8, 2, 1, 12, 9, 0, 0, 0, 0, 0, 0,
- 4, 2, 12, 7, 1, 2, 7, 8, 1, 7, 9, 1, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 8, 4, 3, 2, 0, 0, 0, 0,
- 6, 7, 8, 1, 4, 12, 10, 0, 0, 0, 0, 0, 0,
- 4, 8, 4, 7, 4, 10, 7, 10, 12, 7, 1, 10, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 2, 1, 8, 3, 4, 0, 0, 0,
- 3, 12, 9, 10, 12, 8, 9, 7, 8, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 8, 5, 0, 0, 0, 0, 0, 0,
- 2, 9, 7, 5, 9, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 1, 5, 8, 0, 0, 0, 0, 0,
- 3, 1, 7, 5, 4, 7, 1, 4, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 8, 5, 2, 0, 0, 0, 0, 0,
- 3, 10, 2, 1, 9, 11, 7, 9, 7, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 2, 1, 5, 8, 0, 0, 0, 0,
- 6, 10, 2, 11, 4, 5, 7, 0, 0, 0, 0, 0, 0,
- 4, 2, 4, 10, 4, 7, 10, 7, 5, 10, 11, 7, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 5, 8, 3, 0, 0, 0, 0, 0,
- 3, 3, 2, 12, 7, 5, 9, 7, 9, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 1, 3, 8, 5, 0, 0, 0, 0,
- 8, 4, 1, 2, 3, 5, 7, 11, 12, 0, 0, 0, 0,
- 4, 1, 7, 5, 1, 11, 7, 4, 11, 1, 2, 12, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 8, 5, 3, 2, 0, 0, 0, 0,
- 8, 7, 5, 3, 1, 11, 12, 9, 10, 0, 0, 0, 0,
- 4, 7, 5, 11, 5, 9, 11, 3, 10, 12, 3, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 3, 2, 5, 8, 1, 0, 0, 0,
- 5, 4, 11, 3, 10, 12, 5, 5, 12, 7, 7, 12, 11, 11, 12, 3, 0, 0, 0, 0, 0, 0,
- {3, 5, 8, 4, 0, 0, 0, 0, 0,
- 3, 5, 3, 7, 9, 3, 5, 9, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 5, 8, 1, 4, 0, 0, 0, 0,
- 4, 7, 5, 3, 1, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 5, 1, 3, 5, 3, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 5, 2, 4, 8, 0, 0, 0, 0,
- 8, 9, 5, 10, 1, 7, 3, 4, 2, 0, 0, 0, 0,
- 4, 5, 3, 7, 5, 4, 3, 9, 4, 5, 10, 2, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 8, 4, 2, 5, 1, 0, 0, 0,
- 3, 5, 3, 7, 5, 2, 3, 10, 2, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 3, 8, 4, 5, 0, 0, 0, 0,
- 6, 12, 2, 4, 9, 7, 5, 0, 0, 0, 0, 0, 0,
- 4, 12, 4, 2, 12, 5, 4, 12, 7, 5, 4, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 5, 8, 3, 1, 4, 0, 0, 0,
- 3, 1, 7, 5, 1, 12, 7, 2, 12, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 5, 8, 3, 2, 4, 0, 0, 0,
- 5, 4, 1, 9, 7, 5, 12, 12, 5, 10, 10, 5, 1, 1, 5, 9, 0, 0, 0, 0, 0, 0, 0,
- {6, 3, 2, 5, 8, 4, 1, 0, 0,
- 2, 5, 12, 7, 10, 12, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 8, 6, 0, 0, 0, 0, 0, 0,
- 2, 7, 8, 11, 5, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 8, 1, 6, 0, 0, 0, 0, 0,
- 3, 6, 10, 5, 9, 1, 4, 8, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 2, 6, 8, 0, 0, 0, 0, 0,
- 3, 8, 11, 7, 6, 2, 1, 6, 1, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 1, 8, 6, 2, 0, 0, 0, 0,
- 8, 9, 4, 11, 8, 2, 6, 5, 7, 0, 0, 0, 0,
- 4, 4, 6, 2, 4, 5, 6, 9, 5, 4, 11, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 3, 8, 6, 0, 0, 0, 0, 0,
- 3, 10, 5, 6, 7, 8, 11, 12, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 1, 3, 6, 8, 0, 0, 0, 0,
- 12, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12,
- 4, 1, 4, 9, 2, 12, 3, 5, 6, 10, 7, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 6, 8, 3, 2, 0, 0, 0, 0,
- 8, 6, 5, 8, 7, 1, 3, 12, 11, 0, 0, 0, 0,
- 4, 5, 3, 1, 5, 12, 3, 6, 12, 5, 8, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 1, 8, 2, 3, 6, 0, 0, 0,
- 10, 6, 12, 7, 5, 8, 9, 4, 11, 3, 11, 4, 9, 11, 9, 8, 8, 5, 6, 8, 6, 7,
- 11, 12, 3, 11, 7, 12, 11, 8, 7,
- {3, 4, 8, 6, 0, 0, 0, 0, 0,
- 3, 6, 10, 5, 8, 4, 3, 8, 3, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 8, 6, 1, 4, 0, 0, 0, 0,
- 8, 8, 7, 6, 5, 3, 1, 9, 10, 0, 0, 0, 0,
- 4, 7, 1, 3, 7, 9, 1, 8, 9, 7, 6, 10, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 4, 8, 2, 6, 0, 0, 0, 0,
- 8, 3, 7, 1, 5, 4, 2, 8, 6, 0, 0, 0, 0,
- 4, 3, 7, 4, 7, 8, 4, 1, 6, 2, 1, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 8, 4, 2, 6, 1, 0, 0, 0,
- 5, 9, 5, 8, 3, 7, 2, 2, 7, 6, 6, 7, 5, 5, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 3, 6, 8, 4, 0, 0, 0, 0,
- 8, 12, 2, 10, 6, 4, 8, 7, 5, 0, 0, 0, 0,
- 4, 2, 8, 4, 2, 7, 8, 12, 7, 2, 10, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 8, 6, 4, 3, 1, 0, 0, 0,
- 10, 1, 2, 10, 9, 5, 8, 7, 6, 12, 6, 7, 8, 6, 8, 5, 5, 9, 1, 5, 1, 10, 6,
- 2, 12, 6, 10, 2, 6, 5, 10,
- {5, 6, 2, 4, 8, 3, 0, 0, 0,
- 5, 12, 7, 6, 1, 5, 4, 4, 5, 8, 8, 5, 7, 7, 5, 6, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 6, 8, 3, 2, 1, 4, 0, 0,
- 4, 7, 6, 12, 5, 8, 9, 5, 6, 7, 5, 7, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 8, 5, 6, 0, 0, 0, 0, 0,
- 3, 11, 10, 9, 7, 10, 11, 7, 6, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 1, 5, 6, 8, 0, 0, 0, 0,
- 6, 1, 4, 6, 7, 10, 11, 0, 0, 0, 0, 0, 0,
- 4, 6, 10, 1, 7, 6, 1, 4, 7, 1, 11, 7, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 2, 5, 6, 8, 0, 0, 0, 0,
- 6, 1, 2, 6, 7, 9, 11, 0, 0, 0, 0, 0, 0,
- 4, 1, 6, 2, 1, 11, 6, 1, 9, 11, 6, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 2, 6, 8, 1, 5, 0, 0, 0,
- 3, 4, 6, 2, 4, 7, 6, 11, 7, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 8, 3, 6, 5, 0, 0, 0, 0,
- 8, 7, 11, 3, 12, 9, 10, 6, 2, 0, 0, 0, 0,
- 4, 11, 10, 9, 11, 6, 10, 7, 6, 11, 3, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 1, 3, 5, 6, 8, 0, 0, 0,
- 10, 7, 6, 12, 11, 3, 4, 1, 2, 10, 2, 1, 4, 2, 4, 3, 3, 11, 7, 3, 7, 12,
- 2, 6, 10, 2, 12, 6, 2, 3, 12,
- {5, 8, 5, 2, 3, 6, 0, 0, 0,
- 5, 6, 12, 7, 9, 11, 1, 1, 11, 3, 3, 11, 12, 12, 11, 7, 0, 0, 0, 0, 0, 0,
- {6, 3, 8, 1, 2, 6, 5, 0, 0,
- 4, 11, 3, 4, 12, 7, 6, 12, 3, 11, 12, 11, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 6, 5, 8, 4, 0, 0, 0, 0,
- 6, 6, 10, 4, 9, 7, 3, 0, 0, 0, 0, 0, 0,
- 4, 10, 9, 6, 9, 3, 6, 3, 7, 6, 4, 3, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 4, 1, 6, 8, 5, 0, 0, 0,
- 3, 7, 1, 3, 7, 10, 1, 6, 10, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 2, 6, 8, 4, 5, 0, 0, 0,
- 5, 9, 4, 1, 6, 2, 7, 7, 2, 3, 3, 2, 4, 4, 2, 1, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 2, 6, 8, 4, 1, 5, 0, 0,
- 2, 7, 2, 3, 6, 2, 7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 3, 4, 5, 6, 8, 0, 0, 0,
- 5, 7, 6, 12, 4, 2, 9, 9, 2, 10, 10, 2, 6, 6, 2, 12, 0, 0, 0, 0, 0, 0, 0,
- {6, 6, 3, 1, 5, 8, 4, 0, 0,
- 4, 2, 10, 1, 6, 12, 7, 6, 10, 2, 6, 2, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 2, 3, 4, 5, 6, 8, 0, 0,
- 2, 4, 1, 9, 7, 6, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, 8, 4, 3, 6, 5, 1, 2, 0,
- 1, 12, 7, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {2, 8, 7, 0, 0, 0, 0, 0, 0,
- 2, 6, 11, 12, 6, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 7, 8, 1, 0, 0, 0, 0, 0,
- 3, 9, 1, 4, 11, 12, 6, 11, 6, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 8, 7, 2, 0, 0, 0, 0, 0,
- 3, 2, 1, 10, 6, 8, 11, 6, 11, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 2, 1, 7, 8, 0, 0, 0, 0,
- 8, 2, 4, 6, 8, 10, 12, 9, 11, 0, 0, 0, 0,
- 4, 2, 4, 10, 4, 9, 10, 6, 11, 12, 6, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 8, 7, 3, 0, 0, 0, 0, 0,
- 3, 8, 2, 6, 11, 2, 8, 11, 3, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 8, 1, 3, 7, 0, 0, 0, 0,
- 8, 11, 8, 9, 4, 6, 2, 3, 1, 0, 0, 0, 0,
- 4, 8, 2, 6, 8, 3, 2, 11, 3, 8, 9, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 8, 3, 7, 2, 0, 0, 0, 0,
- 6, 11, 8, 6, 10, 3, 1, 0, 0, 0, 0, 0, 0,
- 4, 11, 6, 8, 11, 1, 6, 11, 3, 1, 6, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 8, 7, 2, 1, 3, 0, 0, 0,
- 5, 3, 4, 11, 6, 8, 10, 10, 8, 9, 9, 8, 4, 4, 8, 11, 0, 0, 0, 0, 0, 0, 0,
- {3, 4, 8, 7, 0, 0, 0, 0, 0,
- 3, 4, 6, 8, 3, 6, 4, 3, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 7, 8, 4, 1, 0, 0, 0, 0,
- 6, 12, 6, 9, 8, 3, 1, 0, 0, 0, 0, 0, 0,
- 4, 6, 8, 12, 8, 1, 12, 1, 3, 12, 9, 1, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 4, 2, 7, 8, 0, 0, 0, 0,
- 8, 3, 4, 1, 2, 8, 6, 12, 10, 0, 0, 0, 0,
- 4, 4, 6, 8, 4, 12, 6, 3, 12, 4, 1, 10, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 2, 1, 8, 7, 4, 0, 0, 0,
- 5, 3, 12, 2, 9, 10, 8, 8, 10, 6, 6, 10, 12, 12, 10, 2, 0, 0, 0, 0, 0, 0,
- {4, 8, 7, 4, 3, 0, 0, 0, 0,
- 4, 6, 8, 2, 4, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 8, 4, 2, 8, 2, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 7, 3, 1, 8, 4, 0, 0, 0,
- 3, 8, 2, 6, 8, 1, 2, 9, 1, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 8, 7, 2, 4, 3, 0, 0, 0,
- 3, 4, 6, 8, 4, 10, 6, 1, 10, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 2, 1, 8, 7, 3, 4, 0, 0,
- 2, 8, 10, 6, 9, 10, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 7, 8, 5, 0, 0, 0, 0, 0,
- 3, 12, 9, 11, 6, 9, 12, 6, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 7, 5, 8, 1, 0, 0, 0, 0,
- 6, 6, 12, 11, 4, 5, 1, 0, 0, 0, 0, 0, 0,
- 4, 6, 11, 12, 6, 1, 11, 6, 5, 1, 11, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 7, 2, 5, 8, 0, 0, 0, 0,
- 8, 6, 12, 2, 10, 11, 9, 5, 1, 0, 0, 0, 0,
- 4, 12, 9, 11, 12, 5, 9, 6, 5, 12, 2, 1, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 7, 8, 1, 2, 5, 0, 0, 0,
- 5, 5, 10, 6, 11, 12, 4, 4, 12, 2, 2, 12, 10, 10, 12, 6, 0, 0, 0, 0, 0, 0,
- {4, 5, 8, 7, 3, 0, 0, 0, 0,
- 6, 5, 9, 3, 11, 6, 2, 0, 0, 0, 0, 0, 0,
- 4, 9, 11, 5, 11, 2, 5, 2, 6, 5, 3, 2, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 1, 5, 7, 3, 8, 0, 0, 0,
- 5, 11, 3, 4, 5, 1, 6, 6, 1, 2, 2, 1, 3, 3, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 2, 3, 8, 5, 7, 0, 0, 0,
- 5, 6, 5, 10, 3, 1, 11, 11, 1, 9, 9, 1, 5, 5, 1, 10, 0, 0, 0, 0, 0, 0, 0,
- {6, 3, 7, 8, 1, 2, 5, 0, 0,
- 2, 11, 3, 4, 5, 10, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 5, 8, 7, 4, 0, 0, 0, 0,
- 6, 5, 9, 12, 3, 6, 4, 0, 0, 0, 0, 0, 0,
- 4, 12, 6, 5, 3, 12, 5, 9, 3, 5, 4, 3, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 1, 5, 7, 4, 8, 0, 0, 0,
- 3, 3, 5, 1, 3, 6, 5, 12, 6, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 5, 2, 8, 7, 4, 0, 0, 0,
- 10, 3, 12, 2, 4, 1, 9, 5, 10, 6, 10, 5, 9, 10, 9, 1, 1, 4, 3, 1, 3, 2,
- 10, 12, 6, 10, 2, 12, 10, 1, 2,
- {6, 2, 7, 4, 1, 5, 8, 0, 0,
- 4, 12, 2, 3, 10, 6, 5, 10, 2, 12, 10, 12, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 3, 4, 5, 7, 8, 0, 0, 0,
- 3, 6, 4, 2, 6, 9, 4, 5, 9, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 7, 3, 1, 5, 8, 4, 0, 0,
- 2, 1, 6, 5, 2, 6, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 2, 5, 7, 3, 4, 8, 0, 0,
- 4, 5, 10, 6, 1, 9, 4, 1, 10, 5, 1, 5, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, 5, 8, 7, 2, 1, 4, 3, 0,
- 1, 6, 5, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {3, 6, 7, 8, 0, 0, 0, 0, 0,
- 3, 10, 11, 12, 5, 11, 10, 5, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 6, 1, 8, 7, 0, 0, 0, 0,
- 8, 5, 10, 1, 9, 12, 11, 8, 4, 0, 0, 0, 0,
- 4, 10, 11, 12, 10, 8, 11, 5, 8, 10, 1, 4, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 8, 7, 6, 2, 0, 0, 0, 0,
- 6, 8, 11, 2, 12, 5, 1, 0, 0, 0, 0, 0, 0,
- 4, 11, 12, 8, 12, 1, 8, 1, 5, 8, 2, 1, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 1, 2, 7, 8, 6, 0, 0, 0,
- 5, 5, 8, 9, 2, 4, 12, 12, 4, 11, 11, 4, 8, 8, 4, 9, 0, 0, 0, 0, 0, 0, 0,
- {4, 8, 7, 6, 3, 0, 0, 0, 0,
- 6, 8, 11, 10, 2, 5, 3, 0, 0, 0, 0, 0, 0,
- 4, 10, 5, 8, 2, 10, 8, 11, 2, 8, 3, 2, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 8, 1, 7, 6, 3, 0, 0, 0,
- 10, 2, 10, 1, 3, 4, 11, 8, 9, 5, 9, 8, 11, 9, 11, 4, 4, 3, 2, 4, 2, 1, 9,
- 10, 5, 9, 1, 10, 9, 4, 1,
- {5, 2, 3, 8, 6, 7, 0, 0, 0,
- 3, 5, 3, 1, 5, 11, 3, 8, 11, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 1, 8, 6, 2, 3, 7, 0, 0,
- 4, 8, 9, 5, 4, 11, 3, 4, 9, 8, 4, 8, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 6, 8, 7, 4, 0, 0, 0, 0,
- 6, 5, 10, 12, 3, 8, 4, 0, 0, 0, 0, 0, 0,
- 4, 5, 12, 10, 5, 4, 12, 5, 8, 4, 12, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 6, 7, 4, 1, 8, 0, 0, 0,
- 5, 8, 9, 5, 12, 10, 3, 3, 10, 1, 1, 10, 9, 9, 10, 5, 0, 0, 0, 0, 0, 0, 0,
- {5, 4, 8, 6, 2, 7, 0, 0, 0,
- 5, 12, 2, 3, 8, 4, 5, 5, 4, 1, 1, 4, 2, 2, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 6, 2, 1, 8, 7, 4, 0, 0,
- 2, 9, 5, 8, 3, 12, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 4, 8, 6, 3, 7, 0, 0, 0,
- 3, 2, 8, 4, 2, 5, 8, 10, 5, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 6, 1, 8, 7, 3, 4, 0, 0,
- 4, 9, 5, 8, 10, 1, 2, 10, 5, 9, 10, 9, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 4, 8, 6, 2, 3, 7, 0, 0,
- 2, 5, 4, 1, 8, 4, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, 6, 2, 1, 8, 7, 3, 4, 0,
- 1, 9, 5, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {4, 5, 6, 8, 7, 0, 0, 0, 0,
- 4, 10, 9, 12, 11, 0, 0, 0, 0, 0, 0, 0, 0,
- 2, 9, 11, 12, 9, 12, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 7, 8, 1, 6, 5, 0, 0, 0,
- 3, 10, 11, 12, 10, 4, 11, 1, 4, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 8, 5, 2, 7, 6, 0, 0, 0,
- 3, 12, 9, 11, 12, 1, 9, 2, 1, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 7, 8, 1, 2, 6, 5, 0, 0,
- 2, 4, 12, 2, 11, 12, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 5, 6, 3, 8, 7, 0, 0, 0,
- 3, 11, 10, 9, 11, 2, 10, 3, 2, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 3, 1, 6, 7, 8, 5, 0, 0,
- 4, 1, 2, 10, 3, 4, 11, 3, 2, 1, 3, 1, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 8, 5, 2, 3, 7, 6, 0, 0,
- 2, 1, 11, 3, 9, 11, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, 3, 7, 8, 1, 2, 6, 5, 0,
- 1, 11, 3, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {5, 6, 7, 4, 5, 8, 0, 0, 0,
- 3, 9, 12, 10, 9, 3, 12, 4, 3, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 6, 7, 4, 1, 5, 8, 0, 0,
- 2, 3, 10, 1, 12, 10, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 2, 4, 5, 6, 7, 8, 0, 0,
- 4, 4, 1, 9, 2, 3, 12, 2, 1, 4, 2, 4, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, 4, 1, 2, 7, 8, 5, 6, 0,
- 1, 2, 3, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {6, 3, 4, 5, 6, 7, 8, 0, 0,
- 2, 9, 2, 10, 4, 2, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, 1, 5, 6, 3, 4, 8, 7, 0,
- 1, 10, 1, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- {7, 2, 3, 4, 5, 6, 7, 8, 0,
- 1, 4, 1, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
-#else
-extern CELL_ENTRY cell_table[256];
-#endif
Modified: grass/trunk/raster3d/r3.showdspf/kns_globals.h
--- grass/trunk/raster3d/r3.showdspf/kns_globals.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster3d/r3.showdspf/kns_globals.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,16 +1,10 @@
#ifndef KNS_GLOBALS_DEFINED
#define KNS_GLOBALS_DEFINED
-#ifdef MAIN
-#define DECLARATION
-#else
-#define DECLARATION extern
-#endif
+extern GLuint Material_1_Dlist;
+extern OGLMotifWindowData MainOGLWindow;
+extern OGLMotifWindowData ColormapWindow;
+extern GLuint MainDlist;
+extern XtAppContext App_context;
-DECLARATION GLuint Material_1_Dlist;
-DECLARATION OGLMotifWindowData MainOGLWindow;
-DECLARATION OGLMotifWindowData ColormapWindow;
-DECLARATION GLuint MainDlist;
-DECLARATION XtAppContext App_context;
#endif
Modified: grass/trunk/raster3d/r3.showdspf/main_ogl.c
--- grass/trunk/raster3d/r3.showdspf/main_ogl.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster3d/r3.showdspf/main_ogl.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -21,7 +21,6 @@
#define TOGGLE(x) ((x) = (x) ? 0 : 1)
-#define MAIN
#include <Xm/Xm.h>
#include <Xm/Form.h>
@@ -54,6 +53,18 @@
#define WAIT_ANY ((pid_t) -1)
#endif
+GLuint Material_1_Dlist;
+OGLMotifWindowData MainOGLWindow;
+OGLMotifWindowData ColormapWindow;
+GLuint MainDlist;
+XtAppContext App_context;
+file_info Headfax; /* contains info about data itself */
+file_info G3header; /* contains info about data itself */
+int G_sign;
+int X_sign;
+long D_offset; /*offset to data in grid3 file */
void set_threshold_button(int i);
char *check_get_any_dspname();
void do__bbox(struct dspec *D_spec);
Modified: grass/trunk/raster3d/r3.showdspf/togif.c
--- grass/trunk/raster3d/r3.showdspf/togif.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster3d/r3.showdspf/togif.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -15,8 +15,9 @@
#include <stdio.h>
#include <string.h>
#include <math.h>
+#include <stdlib.h>
+#include <grass/gis.h>
#include "togif.h"
-#include <stdlib.h>
#define GIFGAMMA (1.5) /* smaller makes output image darker */
#define MAXCOLORS 256
#define CBITS 12
Modified: grass/trunk/raster3d/r3.showdspf/vizual.h
--- grass/trunk/raster3d/r3.showdspf/vizual.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster3d/r3.showdspf/vizual.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -8,14 +8,14 @@
#define INSIDE 0
#define OUTSIDE 1
-GLOBAL file_info Headfax; /* contains info about data itself */
+extern file_info Headfax; /* contains info about data itself */
-GLOBAL file_info G3header; /* contains info about data itself */
+extern file_info G3header; /* contains info about data itself */
-GLOBAL int G_sign;
-GLOBAL int X_sign;
+extern int G_sign;
+extern int X_sign;
-GLOBAL long D_offset; /*offset to data in grid3 file */
+extern long D_offset; /*offset to data in grid3 file */
struct poly_info
Modified: grass/trunk/raster3d/r3.showdspf/vizual2.h
--- grass/trunk/raster3d/r3.showdspf/vizual2.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/raster3d/r3.showdspf/vizual2.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -80,10 +80,5 @@
} CELL_ENTRY; /* for writing out in condensed format */
-#ifdef MAIN
-#define GLOBAL
-#else
-#define GLOBAL extern
-#endif
+extern CELL_ENTRY cell_table[256];
Modified: grass/trunk/vector/v.build.polylines/global.h
--- grass/trunk/vector/v.build.polylines/global.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.build.polylines/global.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,13 +1,8 @@
#ifndef GLOBAL_VARSH
#define GLOBAL_VARSH
-#ifndef MAIN
-#define WORLD extern
-#else
-#define WORLD
-#endif
+extern int gCopy_atts;
+extern int gAsciiout;
+extern char gAscii_type;
-WORLD int gCopy_atts;
-WORLD int gAsciiout;
-WORLD char gAscii_type;
#endif
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.build.polylines/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -68,7 +68,6 @@
1) Portable
-#define MAIN
#include <stdlib.h>
#include <stdio.h>
@@ -78,6 +77,10 @@
#include "walk.h"
+int gCopy_atts;
+int gAsciiout;
+char gAscii_type;
int main(int argc, char **argv)
int line;
Modified: grass/trunk/vector/v.digit/global.h
--- grass/trunk/vector/v.digit/global.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.digit/global.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -2,12 +2,6 @@
#include <tk.h>
#include <grass/Vect.h>
-#ifdef MAIN
-#define Global
-#else
-#define Global extern
-#endif
/* tool in c: name in Tk */
typedef enum
@@ -117,59 +111,38 @@
#define VAR_LINEWIDTH 11
#define VARN_LINEWIDTH "linewidth" /* Width for lines and boundaries */
-#ifdef MAIN
-VAR Variable[] = {
- {VAR_CAT, VARN_CAT, VART_INT, 0, 0, NULL},
- {VAR_FIELD, VARN_FIELD, VART_INT, 0, 0, NULL},
- {VAR_CAT_MODE, VARN_CAT_MODE, VART_INT, 0, 0, NULL},
- {VAR_INSERT, VARN_INSERT, VART_INT, 0, 0, NULL},
- {VAR_MESSAGE, VARN_MESSAGE, VART_CHAR, 0, 0, NULL},
- {VAR_SNAP, VARN_SNAP, VART_INT, 0, 0, NULL},
- {VAR_SNAP_MODE, VARN_SNAP_MODE, VART_INT, 0, 0, NULL},
- {VAR_SNAP_SCREEN, VARN_SNAP_SCREEN, VART_INT, 0, 0, NULL},
- {VAR_SNAP_MAP, VARN_SNAP_MAP, VART_DOUBLE, 0, 0, NULL},
- {VAR_ZOOM_REGION, VARN_ZOOM_REGION, VART_CHAR, 0, 0, NULL},
- {VAR_ANSWER, VARN_ANSWER, VART_INT, 0, 0, NULL},
- {VAR_LINEWIDTH, VARN_LINEWIDTH, VART_INT, 2, 0, NULL},
- {0, NULL, 0, 0, 0, NULL}
-#else
extern VAR Variable[];
-#endif
/* Category and field set for current line to be written */
#define CAT_MODE_NO 0 /* No category */
#define CAT_MODE_MAN 1 /* Manual imput */
#define CAT_MODE_NEXT 2 /* Next not yet used category of given field */
#define CAT_MODE_COUNT 3 /* Count of modes */
-#ifdef MAIN
-char *CatModeLab[] = { "No category", "Manual entry", "Next not used" };
-#else
extern char *CatModeLab[];
-#endif
/* Maximum value for field */
-Global int (*MaxFieldCat)[2];
-Global int nMaxFieldCat, aMaxFieldCat;
+extern int (*MaxFieldCat)[2];
+extern int nMaxFieldCat, aMaxFieldCat;
-Global SYMB Symb[SYMB_COUNT];
+extern SYMB Symb[SYMB_COUNT];
-Global struct Map_info Map;
-Global struct Cell_head GRegion; /* Current region (synchronized with GRASS WIND) */
-Global Tcl_Interp *Toolbox;
-Global int Tool_next; /* Next tool to be run */
-Global double Xscale, Yscale; /* Scale factors = size_in_map / size_on_screen */
+extern struct Map_info Map;
+extern struct Cell_head GRegion; /* Current region (synchronized with GRASS WIND) */
+extern Tcl_Interp *Toolbox;
+extern int Tool_next; /* Next tool to be run */
+extern double Xscale, Yscale; /* Scale factors = size_in_map / size_on_screen */
-Global struct Cell_head window;
+extern struct Cell_head window;
-Global double Scale; /* Map / xdriver */
+extern double Scale; /* Map / xdriver */
/* Display symbology for lines and nodes */
-Global int *LineSymb; /* array of line symbology codes, starts from index 1 */
-Global int aLineSymb; /* number of lines / allocated space (array size + 1) */
-Global int *NodeSymb; /* array of nodes' symbology codes, start from index 1 */
-Global int aNodeSymb; /* number of nodes / allocated space (array size + 1) */
+extern int *LineSymb; /* array of line symbology codes, starts from index 1 */
+extern int aLineSymb; /* number of lines / allocated space (array size + 1) */
+extern int *NodeSymb; /* array of nodes' symbology codes, start from index 1 */
+extern int aNodeSymb; /* number of nodes / allocated space (array size + 1) */
/* Background commands */
typedef struct
@@ -178,15 +151,9 @@
int on; /* 1 display, 0 do not display */
} BGCMD;
-#ifdef MAIN
-BGCMD *Bgcmd = NULL;
-int nbgcmd = 0;
-int abgcmd = 0;
-#else
extern BGCMD *Bgcmd;
extern int nbgcmd;
extern int abgcmd;
-#endif
#define MOUSE_POINT 1
#define MOUSE_LINE 2
Modified: grass/trunk/vector/v.digit/main.c
--- grass/trunk/vector/v.digit/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.digit/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -9,7 +9,6 @@
* for details.
-#define MAIN
#include <stdio.h>
#include <stdlib.h>
#include <tcl.h>
@@ -22,6 +21,50 @@
#include "global.h"
#include "proto.h"
+VAR Variable[] = {
+ {VAR_CAT, VARN_CAT, VART_INT, 0, 0, NULL},
+ {VAR_FIELD, VARN_FIELD, VART_INT, 0, 0, NULL},
+ {VAR_CAT_MODE, VARN_CAT_MODE, VART_INT, 0, 0, NULL},
+ {VAR_INSERT, VARN_INSERT, VART_INT, 0, 0, NULL},
+ {VAR_MESSAGE, VARN_MESSAGE, VART_CHAR, 0, 0, NULL},
+ {VAR_SNAP, VARN_SNAP, VART_INT, 0, 0, NULL},
+ {VAR_SNAP_MODE, VARN_SNAP_MODE, VART_INT, 0, 0, NULL},
+ {VAR_SNAP_SCREEN, VARN_SNAP_SCREEN, VART_INT, 0, 0, NULL},
+ {VAR_SNAP_MAP, VARN_SNAP_MAP, VART_DOUBLE, 0, 0, NULL},
+ {VAR_ZOOM_REGION, VARN_ZOOM_REGION, VART_CHAR, 0, 0, NULL},
+ {VAR_ANSWER, VARN_ANSWER, VART_INT, 0, 0, NULL},
+ {VAR_LINEWIDTH, VARN_LINEWIDTH, VART_INT, 2, 0, NULL},
+ {0, NULL, 0, 0, 0, NULL}
+BGCMD *Bgcmd = NULL;
+int nbgcmd = 0;
+int abgcmd = 0;
+char *CatModeLab[] = { "No category", "Manual entry", "Next not used" };
+/* Maximum value for field */
+int (*MaxFieldCat)[2];
+int nMaxFieldCat, aMaxFieldCat;
+SYMB Symb[SYMB_COUNT];
+struct Map_info Map;
+struct Cell_head GRegion; /* Current region (synchronized with GRASS WIND) */
+Tcl_Interp *Toolbox;
+int Tool_next; /* Next tool to be run */
+double Xscale, Yscale; /* Scale factors = size_in_map / size_on_screen */
+struct Cell_head window;
+double Scale; /* Map / xdriver */
+/* Display symbology for lines and nodes */
+int *LineSymb; /* array of line symbology codes, starts from index 1 */
+int aLineSymb; /* number of lines / allocated space (array size + 1) */
+int *NodeSymb; /* array of nodes' symbology codes, start from index 1 */
+int aNodeSymb; /* number of nodes / allocated space (array size + 1) */
int Tcl_AppInit(Tcl_Interp * interp)
int ret;
Modified: grass/trunk/vector/v.in.dwg/global.h
--- grass/trunk/vector/v.in.dwg/global.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.in.dwg/global.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -25,11 +25,6 @@
* from your version.
-#ifdef MAIN
-#define Global
-#else
-#endif
/* transformation, first level is 0 ( called from main ) and transformation
* for this level is 0,0,0, 1,1,1, 0 so that no transformation is done on first level
@@ -41,24 +36,24 @@
double rotang;
} TRANS;
-Global int cat;
-Global int n_elements; /* number of processed elements (only low level elements) */
-Global int n_skipped; /* number of skipped low level elements (different layer name) */
-Global dbDriver *driver;
-Global dbString sql;
-Global dbString str;
-Global struct line_pnts *Points;
-Global struct line_cats *Cats;
-Global PAD_LAY Layer;
-Global char *Txt;
-Global char *Block;
-Global struct field_info *Fi;
-Global AD_DB_HANDLE dwghandle;
-Global TRANS *Trans; /* transformation */
-Global int atrans; /* number of allocated levels */
-Global struct Option *layers_opt;
-Global struct Flag *invert_flag;
+extern int cat;
+extern int n_elements; /* number of processed elements (only low level elements) */
+extern int n_skipped; /* number of skipped low level elements (different layer name) */
+extern dbDriver *driver;
+extern dbString sql;
+extern dbString str;
+extern struct line_pnts *Points;
+extern struct line_cats *Cats;
+extern PAD_LAY Layer;
+extern char *Txt;
+extern char *Block;
+extern struct field_info *Fi;
+extern AD_DB_HANDLE dwghandle;
+extern TRANS *Trans; /* transformation */
+extern int atrans; /* number of allocated levels */
+extern struct Option *layers_opt;
+extern struct Flag *invert_flag;
void wrentity(PAD_ENT_HDR adenhd, PAD_ENT aden, int level, AD_VMADDR entlist,
int circle_as_point);
Modified: grass/trunk/vector/v.in.dwg/main.c
--- grass/trunk/vector/v.in.dwg/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.in.dwg/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -28,8 +28,6 @@
#define AD_VM_PC
#define OD_GENERIC_READ
-#define MAIN
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
@@ -44,6 +42,25 @@
#include "io/odio.h"
#include "global.h"
+int cat;
+int n_elements; /* number of processed elements (only low level elements) */
+int n_skipped; /* number of skipped low level elements (different layer name) */
+dbDriver *driver;
+dbString sql;
+dbString str;
+struct line_pnts *Points;
+struct line_cats *Cats;
+PAD_LAY Layer;
+char *Txt;
+char *Block;
+struct field_info *Fi;
+AD_DB_HANDLE dwghandle;
+TRANS *Trans; /* transformation */
+int atrans; /* number of allocated levels */
+struct Option *layers_opt;
+struct Flag *invert_flag;
int main(int argc, char *argv[])
struct GModule *module;
Modified: grass/trunk/vector/v.in.dxf/global.h
--- grass/trunk/vector/v.in.dxf/global.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.in.dxf/global.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -19,20 +19,14 @@
#define ARR_INCR 256
#define DXF_BUF_SIZE 256
-#ifdef _MAIN_C_
-#define GLOBAL
-#else
-#endif
-GLOBAL int flag_list, flag_extent, flag_table, flag_topo, flag_invert,
+extern int flag_list, flag_extent, flag_table, flag_topo, flag_invert,
flag_one_layer, flag_frame;
-GLOBAL int num_layers, found_layers;
-GLOBAL char **layers;
-GLOBAL char dxf_buf[DXF_BUF_SIZE], entity[DXF_BUF_SIZE];
-GLOBAL int ARR_MAX;
-GLOBAL double *xpnts, *ypnts, *zpnts;
-GLOBAL struct line_pnts *Points;
+extern int num_layers, found_layers;
+extern char **layers;
+extern char dxf_buf[DXF_BUF_SIZE], entity[DXF_BUF_SIZE];
+extern int ARR_MAX;
+extern double *xpnts, *ypnts, *zpnts;
/* dxf_to_vect.c */
int dxf_to_vect(struct dxf_file *, struct Map_info *);
Modified: grass/trunk/vector/v.in.dxf/main.c
--- grass/trunk/vector/v.in.dxf/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.in.dxf/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -24,12 +24,20 @@
* for details.
-#define _MAIN_C_
#include <stdlib.h>
#include "global.h"
+int flag_list, flag_extent, flag_table, flag_topo, flag_invert,
+ flag_one_layer, flag_frame;
+int num_layers, found_layers;
+char **layers;
+char dxf_buf[DXF_BUF_SIZE], entity[DXF_BUF_SIZE];
+int ARR_MAX;
+double *xpnts, *ypnts, *zpnts;
struct dxf_file *dxf;
Modified: grass/trunk/vector/v.in.ogr/global.h
--- grass/trunk/vector/v.in.ogr/global.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.in.ogr/global.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -24,13 +24,8 @@
#define __GLOBAL_H__
-#ifdef MAIN
-int n_polygons = 0;
-#else
extern int n_polygons;
-#endif
/* centroid structure */
typedef struct
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.in.ogr/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -19,7 +19,7 @@
* TODO: - make fixed field length of OFTIntegerList dynamic
* - several other TODOs below
-#define MAIN
#include <grass/config.h>
#include <stdlib.h>
#include <string.h>
@@ -37,6 +37,8 @@
# define MAX(a,b) ((a>b) ? a : b)
#endif
+int n_polygons;
int geom(OGRGeometryH hGeom, struct Map_info *Map, int field, int cat,
double min_area, int type, int mk_centr);
int centroid(OGRGeometryH hGeom, CENTR * Centr, SPATIAL_INDEX * Sindex,
Modified: grass/trunk/vector/v.out.dxf/global.h
--- grass/trunk/vector/v.out.dxf/global.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.out.dxf/global.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -4,15 +4,9 @@
#include <stdio.h>
-#ifdef _MAIN_C_
-#define GLOBAL
-#else
-#endif
+extern FILE *dxf_fp;
+extern int overwrite;
-GLOBAL FILE *dxf_fp;
-GLOBAL int overwrite;
/* write_dxf.c */
int dxf_open(char *);
int dxf_header(void);
Modified: grass/trunk/vector/v.out.dxf/main.c
--- grass/trunk/vector/v.out.dxf/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.out.dxf/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -14,7 +14,6 @@
* for details.
-#define _MAIN_C_
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
@@ -24,6 +23,9 @@
#include "global.h"
+FILE *dxf_fp;
+int overwrite;
/* size of text compared to screen=1 */
#define TEXT_SIZE .003
#define CENTERED 4
Modified: grass/trunk/vector/v.out.vtk/local_proto.h
--- grass/trunk/vector/v.out.vtk/local_proto.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.out.vtk/local_proto.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -18,13 +18,8 @@
#define __V_OUT_VTK_LOCAL_PROTO__
/*global structs */
-#ifdef MAIN
-double x_extent;
-double y_extent;
-#else
extern double x_extent;
extern double y_extent;
-#endif
/*Write the vtk output */
int write_vtk(FILE * ascii, struct Map_info *, int layer, int *types,
Modified: grass/trunk/vector/v.out.vtk/main.c
--- grass/trunk/vector/v.out.vtk/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.out.vtk/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -23,9 +23,11 @@
#include <string.h>
-#define MAIN
#include "local_proto.h"
+double x_extent;
+double y_extent;
FILE *ascii;
Modified: grass/trunk/vector/v.to.db/global.h
--- grass/trunk/vector/v.to.db/global.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.to.db/global.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,13 +1,7 @@
-#ifndef MAIN
-# define EXT extern
-#else
-# define EXT
-#endif
-typedef struct
+struct value
int cat; /* category */
int count1, count2; /* Count of found values; i1: count, coor, sides; i2: sides */
@@ -20,12 +14,11 @@
int nqcats; /* number of query cats */
int aqcats; /* number of allocated query cats */
char null; /* no records selected by query */
-} VALUE;
-EXT VALUE *Values;
+extern struct value *Values;
-#define OPTIONS struct _options_
-EXT OPTIONS
+struct options
char *name;
char *mapset;
@@ -39,10 +32,11 @@
int total; /* print totals */
int units;
int qfield; /* query field */
-} options;
-#define VSTAT struct _vstat_
-EXT VSTAT
+extern struct options options;
+struct vstat
int rcat; /* number of categories read from map */
int select; /* number of categories selected from DB */
@@ -52,8 +46,10 @@
int update; /* number of updated rows */
int error; /* number of errors */
int qtype; /* C type of query column */
-} vstat;
+extern struct vstat vstat;
#define O_CAT 1
#define O_AREA 2
#define O_LENGTH 3
Modified: grass/trunk/vector/v.to.db/main.c
--- grass/trunk/vector/v.to.db/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.to.db/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -15,10 +15,13 @@
-#define MAIN
#include "global.h"
+struct value *Values;
+struct options options;
+struct vstat vstat;
int n;
@@ -59,7 +62,7 @@
n = 0;
G_debug(2, "%d unique cats", n);
- Values = (VALUE *) G_calloc(n + 1, sizeof(VALUE));
+ Values = (struct value *) G_calloc(n + 1, sizeof(struct value));
vstat.rcat = 0;
/* Read values from map */
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.transform/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -29,7 +29,6 @@
*- Modified by Radim Blazek to work on binary files 2002
*- Interactive functionality disabled, 2007
-#define MAIN
#include <stdio.h>
#include <stdlib.h>
@@ -41,7 +40,19 @@
#include "trans.h"
+double ax[MAX_COOR]; /* current map */
+double ay[MAX_COOR];
+double bx[MAX_COOR]; /* map we are going to */
+double by[MAX_COOR];
+int use[MAX_COOR]; /* where the coordinate came from */
+double residuals[MAX_COOR];
+double rms;
+/* this may be used in the future */
+int reg_cnt; /* count of registered points */
struct file_info Current, Trans, Coord;
Modified: grass/trunk/vector/v.transform/trans.h
--- grass/trunk/vector/v.transform/trans.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.transform/trans.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -49,24 +49,18 @@
* Yah, I made them global. So shoot me.
-#ifdef MAIN
-#define GLOBAL
-#else
-#endif
+extern double ax[MAX_COOR]; /* current map */
+extern double ay[MAX_COOR];
-GLOBAL double ax[MAX_COOR]; /* current map */
-GLOBAL double ay[MAX_COOR];
+extern double bx[MAX_COOR]; /* map we are going to */
+extern double by[MAX_COOR];
-GLOBAL double bx[MAX_COOR]; /* map we are going to */
-GLOBAL double by[MAX_COOR];
+extern int use[MAX_COOR]; /* where the coordinate came from */
+extern double residuals[MAX_COOR];
+extern double rms;
-GLOBAL int use[MAX_COOR]; /* where the coordinate came from */
-GLOBAL double residuals[MAX_COOR];
-GLOBAL double rms;
-GLOBAL int reg_cnt; /* count of registered points */
+extern int reg_cnt; /* count of registered points */
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.vol.rst/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -32,8 +32,6 @@
#include <string.h>
#include <unistd.h>
-#define USERMAIN
#include <grass/site.h>
@@ -50,6 +48,45 @@
#include <grass/dbmi.h>
+double /* pargr */ xmin, xmax, ymin, ymax, zmin, zmax, wmin, wmax;
+double /* norm */ xmin0, xmax0, ymin0, ymax0, zmin0, zmax0, wmin0, wmax0,
+ delt, dnorm;
+double /* MAT */ *A;
+double /* PRISP */ fi, rsm, fstar2, alphat, betat;
+double /* out */ *b, *w;
+double /* orig */ x0utm, y0utm, z0utm;
+double /* gcmax */ gmin, gmax, c1min, c1max, c2min, c2max, c3min, c3max;
+double /* gcmax */ a1min, a1max, a2min, a2max;
+float *zero_array1, *zero_array2, *zero_array3, *zero_array4, *zero_array5,
+ *zero_array6, *zero_array7;
+int out_cond1, out_cond2;
+double xmn, xmx, ymn, ymx, zmn, zmx;
+double z_orig_in, tb_res_in;
+int cursegm;
+int totsegm;
+int iw2;
+int n_rows_in; /* fix by JH 04/24/02 */
+int cv;
+int sig1;
+char msg[80];
+dbString sql;
+dbDriver *driver;
+dbHandle handle;
+struct field_info *f;
+struct line_pnts *Pnts;
+char buf[1024];
+int count;
+FILE *dev, *cvdevf;
+FCELL *zero_array_cell;
+G3D_Region current_region;
/* pargr */
double ns_res, ew_res, tb_res;
double dmin, ertre;
Modified: grass/trunk/vector/v.vol.rst/userglobs.h
--- grass/trunk/vector/v.vol.rst/userglobs.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.vol.rst/userglobs.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -5,46 +5,6 @@
-#ifdef USERMAIN
-double /* pargr */ xmin, xmax, ymin, ymax, zmin, zmax, wmin, wmax;
-double /* norm */ xmin0, xmax0, ymin0, ymax0, zmin0, zmax0, wmin0, wmax0,
- delt, dnorm;
-double /* MAT */ *A;
-double /* PRISP */ fi, rsm, fstar2, alphat, betat;
-double /* out */ *b, *w;
-double /* orig */ x0utm, y0utm, z0utm;
-double /* gcmax */ gmin, gmax, c1min, c1max, c2min, c2max, c3min, c3max;
-double /* gcmax */ a1min, a1max, a2min, a2max;
-float *zero_array1, *zero_array2, *zero_array3, *zero_array4, *zero_array5,
- *zero_array6, *zero_array7;
-int out_cond1, out_cond2;
-double xmn, xmx, ymn, ymx, zmn, zmx;
-double z_orig_in, tb_res_in;
-int cursegm;
-int totsegm;
-int iw2;
-int n_rows_in; /* fix by JH 04/24/02 */
-int cv;
-int sig1;
-char msg[80];
-struct Map_info Map;
-dbString sql;
-dbDriver *driver;
-dbHandle handle;
-struct field_info *f;
-struct line_pnts *Pnts;
-struct line_cats *Cats;
-char buf[1024];
-int count;
-FILE *dev, *cvdevf;
-FCELL *zero_array_cell;
-G3D_Region current_region;
-#else
extern double /* pargr */ xmin, xmax, ymin, ymax, zmin, zmax, wmin, wmax;
extern double /* norm */ xmin0, xmax0, ymin0, ymax0, zmin0, zmax0, wmin0,
wmax0, delt, dnorm;
@@ -84,6 +44,5 @@
extern FILE *dev, *cvdevf;
extern FCELL *zero_array_cell;
extern G3D_Region current_region;
-#endif
#endif
Modified: grass/trunk/vector/v.voronoi/defs.h
--- grass/trunk/vector/v.voronoi/defs.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.voronoi/defs.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,13 +1,6 @@
-#ifdef MAIN
-struct Cell_head Window;
-BOUND_BOX Box;
-struct Map_info In, Out;
-int Type;
-int All;
-#else
extern struct Cell_head Window;
extern BOUND_BOX Box;
extern struct Map_info In, Out;
extern int Type;
extern int All;
-#endif
Modified: grass/trunk/vector/v.voronoi/dt_main.c
--- grass/trunk/vector/v.voronoi/dt_main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.voronoi/dt_main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -18,7 +18,6 @@
** 4 2008: Benjamin Ducke - 3D support + better memory management
-#define MAIN
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
Modified: grass/trunk/vector/v.voronoi/sw_defs.h
--- grass/trunk/vector/v.voronoi/sw_defs.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.voronoi/sw_defs.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -46,27 +46,6 @@
struct Halfedge *PQnext;
-#ifdef MAIN
-int triangulate, sorted, plot, debug, mode3d;
-struct Site *sites;
-int nsites;
-int siteidx;
-int sqrt_nsites;
-int nvertices;
-struct Freelist sfl;
-struct Site *bottomsite;
-int nedges;
-struct Freelist efl;
-double xmin, xmax, ymin, ymax, deltax, deltay;
-struct Freelist hfl;
-struct Halfedge *ELleftend, *ELrightend;
-int ELhashsize;
-struct Halfedge **ELhash;
-int PQhashsize;
-struct Halfedge *PQhash;
-int PQcount;
-int PQmin;
-#else
extern int triangulate, sorted, plot, debug, mode3d;
extern struct Site *sites;
extern int nsites;
@@ -86,7 +65,6 @@
extern struct Halfedge *PQhash;
extern int PQcount;
extern int PQmin;
-#endif
/* sw_edgelist.c */
int ELinitialize(void);
Modified: grass/trunk/vector/v.voronoi/sw_main.c
--- grass/trunk/vector/v.voronoi/sw_main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.voronoi/sw_main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -6,6 +6,32 @@
#include "sw_defs.h"
#include "defs.h"
+int triangulate, sorted, plot, debug, mode3d;
+struct Site *sites;
+int nsites;
+int siteidx;
+int sqrt_nsites;
+int nvertices;
+struct Freelist sfl;
+struct Site *bottomsite;
+int nedges;
+struct Freelist efl;
+double xmin, xmax, ymin, ymax, deltax, deltay;
+struct Freelist hfl;
+struct Halfedge *ELleftend, *ELrightend;
+int ELhashsize;
+struct Halfedge **ELhash;
+int PQhashsize;
+struct Halfedge *PQhash;
+int PQcount;
+int PQmin;
+struct Cell_head Window;
+BOUND_BOX Box;
+struct Map_info In, Out;
+int Type;
+int All;
/* sort sites on y, then x, coord */
int scomp(const void *v1, const void *v2)
Modified: grass/trunk/vector/v.voronoi/vo_main.c
--- grass/trunk/vector/v.voronoi/vo_main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/vector/v.voronoi/vo_main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -34,7 +34,6 @@
** this together from stuff he found on netlib (see the manpage).
-#define MAIN
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
Modified: grass/trunk/visualization/nviz/src/draw.c
--- grass/trunk/visualization/nviz/src/draw.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/visualization/nviz/src/draw.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -2,7 +2,6 @@
#include "togl.h"
-#define FontBase_MAIN
#include "interface.h"
#define BG_COLOR 0xFF000000
@@ -23,6 +22,8 @@
Tcl_Interp *cancel_interp;
static GLuint legend_list = 0;
+GLuint FontBase;
int auto_draw(Nv_data *, Tcl_Interp *);
/* this function is used as a hook to
Modified: grass/trunk/visualization/nviz/src/interface.h
--- grass/trunk/visualization/nviz/src/interface.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/visualization/nviz/src/interface.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -62,11 +62,7 @@
#define SV_ATT_MAP -6
#define SV_ATT_FLAT -7
-#ifdef FontBase_MAIN
-GLuint FontBase;
-#else
extern GLuint FontBase;
-#endif
- this is the data type declaration section -
Modified: grass/trunk/visualization/nviz/src/mkdspf_main.c
--- grass/trunk/visualization/nviz/src/mkdspf_main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/visualization/nviz/src/mkdspf_main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -51,9 +51,12 @@
-#define MAIN
#include "viz.h"
+Cube_data CUBE; /* and the data for a single cube */
+int NTHRESH;
/* Nvision includes */
Modified: grass/trunk/visualization/nviz/src/viz.h
--- grass/trunk/visualization/nviz/src/viz.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/visualization/nviz/src/viz.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,5 +1,5 @@
#include "Viz.h"
-GLOBAL Cube_data CUBE; /* and the data for a single cube */
-GLOBAL int NTHRESH;
+extern Cube_data CUBE; /* and the data for a single cube */
+extern int NTHRESH;
Modified: grass/trunk/visualization/xganim/local_proto.h
--- grass/trunk/visualization/xganim/local_proto.h 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/visualization/xganim/local_proto.h 2008-08-11 09:29:51 UTC (rev 32675)
@@ -1,5 +1 @@
-#ifdef MAIN
-Visual *use_visual;
-#else
extern Visual *use_visual;
-#endif
Modified: grass/trunk/visualization/xganim/main.c
--- grass/trunk/visualization/xganim/main.c 2008-08-11 09:18:29 UTC (rev 32674)
+++ grass/trunk/visualization/xganim/main.c 2008-08-11 09:29:51 UTC (rev 32675)
@@ -26,7 +26,6 @@
#include <grass/glocale.h>
#include "gui.h"
-#define MAIN
#define COLOR_OFFSET 0
@@ -65,6 +64,7 @@
unsigned int depth;
+Visual *use_visual;
