[GRASS-SVN] r32683 - in grass/branches/develbranch_6/vector:
v.distance v.to.db
svn_grass at osgeo.org
Mon Aug 11 07:49:18 EDT 2008
Author: neteler
Date: 2008-08-11 07:49:18 -0400 (Mon, 11 Aug 2008)
New Revision: 32683
grass/branches/develbranch_6/vector/v.distance/main.c
grass/branches/develbranch_6/vector/v.to.db/report.c
conditionalize output to not confuse the user with useless messages (merge from trunk, r32682)
Modified: grass/branches/develbranch_6/vector/v.distance/main.c
--- grass/branches/develbranch_6/vector/v.distance/main.c 2008-08-11 11:48:57 UTC (rev 32682)
+++ grass/branches/develbranch_6/vector/v.distance/main.c 2008-08-11 11:49:18 UTC (rev 32683)
@@ -1095,9 +1095,12 @@
db_commit_transaction(driver);
/* print stats */
- G_message(_("%d categories with more than 1 feature in vector map <%s>"),
- update_dupl, from_opt->answer);
- G_message(_("%d categories - no nearest feature found"), update_notfound);
+ if (update_dupl > 0)
+ G_message(_("%d categories with more than 1 feature in vector map <%s>"),
+ update_dupl, from_opt->answer);
+ if (update_notfound > 0)
+ G_message(_("%d categories - no nearest feature found"),
+ update_notfound);
if (!print_flag->answer) {
db_close_database_shutdown_driver(driver);
@@ -1107,17 +1110,23 @@
if (all && table_opt->answer) {
G_message(_("%d distances calculated"), count);
G_message(_("%d records inserted"), update_ok);
- G_message(_("%d insert errors"), update_err);
+ if (update_err > 0)
+ G_message(_("%d insert errors"), update_err);
else if (!all) {
- G_message(_("%d categories read from the map"), nfcats);
- G_message(_("%d categories exist in the table"), ncatexist);
- G_message(_("%d categories read from the map exist in the table"),
- update_exist);
- G_message(_("%d categories read from the map don't exist in the table"),
- update_notexist);
+ if (nfcats > 0)
+ G_message(_("%d categories read from the map"), nfcats);
+ if (ncatexist > 0)
+ G_message(_("%d categories exist in the table"), ncatexist);
+ if (update_exist > 0)
+ G_message(_("%d categories read from the map exist in the table"),
+ update_exist);
+ if (update_notexist > 0)
+ G_message(_("%d categories read from the map don't exist in the table"),
+ update_notexist);
G_message(_("%d records updated"), update_ok);
- G_message(_("%d update errors"), update_err);
+ G_message(_("%d update errors"), update_err);
G_free(catexist);
Modified: grass/branches/develbranch_6/vector/v.to.db/report.c
--- grass/branches/develbranch_6/vector/v.to.db/report.c 2008-08-11 11:48:57 UTC (rev 32682)
+++ grass/branches/develbranch_6/vector/v.to.db/report.c 2008-08-11 11:49:18 UTC (rev 32683)
@@ -171,14 +171,19 @@
int print_stat(void)
- G_message(_("%d categories read from map"), vstat.rcat);
- G_message(_("%d records selected from table"), vstat.select);
- G_message(_("%d categories read from map exist in selection from table"),
- vstat.exist);
- G_message(_("%d categories read from map don't exist in selection from table"),
- vstat.notexist);
+ if (vstat.rcat > 0)
+ G_message(_("%d categories read from map"), vstat.rcat);
+ if (vstat.select > 0)
+ G_message(_("%d records selected from table"), vstat.select);
+ if (vstat.exist > 0)
+ G_message(_("%d categories read from map exist in selection from table"),
+ vstat.exist);
+ if (vstat.notexist > 0)
+ G_message(_("%d categories read from map don't exist in selection from table"),
+ vstat.notexist);
G_message(_("%d records updated/inserted"), vstat.update);
- G_message(_("%d update/insert errors"), vstat.error);
+ if (vstat.error > 0)
+ G_message(_("%d update/insert errors"), vstat.error);
if (vstat.dupl > 0)
G_message(_("%d categories with more points (coordinates not loaded)"),
vstat.dupl);
