[GRASS-SVN] r32700 - in grass/trunk/raster: r.cross r.slope.aspect
Mon Aug 11 23:36:56 EDT 2008
Author: hamish
Date: 2008-08-11 23:36:56 -0400 (Mon, 11 Aug 2008)
New Revision: 32700
   grass/trunk/raster/r.cross/description.html
   grass/trunk/raster/r.slope.aspect/description.html
html fixes (merge from devbr6)
Modified: grass/trunk/raster/r.cross/description.html
--- grass/trunk/raster/r.cross/description.html	2008-08-12 03:34:28 UTC (rev 32699)
+++ grass/trunk/raster/r.cross/description.html	2008-08-12 03:36:56 UTC (rev 32700)
@@ -2,7 +2,7 @@
 <em>r.cross</em> creates an <em>output</em> raster map layer representing
 all unique combinations of category values in the raster input layers
-(input=</b><em>name,name,name</em>, ...).  At least two, but not more than
+(<b>input=</b><em>name,name,name</em>, ...).  At least two, but not more than
 ten, <em>input</em> map layers must be specified.  The user must also
 specify a name to be assigned to the <em>output</em> raster map layer
 created by <em>r.cross</em>.
@@ -39,7 +39,7 @@
 For example, suppose that, using two raster map layers,
 the following combinations occur:
-<pre>
+<div class="code"><pre>
           map1   map2
           ___________
            0      1
@@ -47,12 +47,12 @@
            1      1
            1      2
            2      4
-</pre>
+</pre></div>
 <em>r.cross</em> would produce a new raster map layer with 5 categories:
-<pre>
           map1   map2   output
           ____________________
            0      1       1
@@ -60,7 +60,7 @@
            1      1       3
            1      2       4
            2      4       5
-</pre>
+</pre></div>
 Note: The actual category value assigned to a particular combination
 in the <em>result</em> map layer is
@@ -76,7 +76,7 @@
 each category.
 In the above example, the category labels would be:
-<pre>
           category   category
           value      label
           ______________________________
@@ -85,7 +85,7 @@
              3       layer1(1) layer2(1)
              4       layer1(1) layer2(2)
              5       layer1(2) layer2(4)
-</pre>
+</pre></div>
 A random color table is also generated for the <em>output</em> map layer.
@@ -105,4 +105,5 @@
 Michael Shapiro, U.S. Army Construction Engineering Research Laboratory
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.slope.aspect/description.html
--- grass/trunk/raster/r.slope.aspect/description.html	2008-08-12 03:34:28 UTC (rev 32699)
+++ grass/trunk/raster/r.slope.aspect/description.html	2008-08-12 03:36:56 UTC (rev 32700)
@@ -30,12 +30,13 @@
 steepest slope and in the direction of the contour tangent respectively. The
 curvatures are expressed as 1/metres, e.g. a curvature of 0.05 corresponds to a
 radius of curvature of 20m.
 <p>
 <table width="100%" border="0">
  <tr valign="baseline">
   <td>
   <div align="center">
-    <img src="dem.png" border="1"></a>
+    <img src="dem.png" border="1">
     <P>
     Example DEM
     <BR><BR>
@@ -48,7 +49,7 @@
   <td>
-    <img src="slope.png" border="1"></a>
+    <img src="slope.png" border="1">
     <P>
     Slope (degree) from example DEM
     <BR><BR>
@@ -56,7 +57,7 @@
   </td>
   <td>
-    <img src="aspect.png" border="1"></a>
+    <img src="aspect.png" border="1">
     <P>
     Aspect (degree) from example DEM
     <BR><BR>
@@ -67,7 +68,7 @@
   <td>
-    <img src="tcurv.png" border="1"></a>
+    <img src="tcurv.png" border="1">
     <P>
     Tangential curvature (m<sup>-1</sup>) from example DEM
     <BR><BR>
@@ -75,7 +76,7 @@
   </td>
   <td>
-    <img src="pcurv.png" border="1"></a>
+    <img src="pcurv.png" border="1">
     <P>
     Profile curvature (m<sup>-1</sup>) from example DEM
     <BR><BR>
@@ -91,30 +92,30 @@
 of slope that groups slope values into ranges of slope. This can be done using
 <i><a href="r.reclass.html">r.reclass</a></i>. An example of a useful
 reclassification is given below:
-<pre>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; category&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; range&nbsp;&nbsp; category labels
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; (in degrees)&nbsp;&nbsp;&nbsp; (in percent)
+<div class="code"><pre>          category      range   category labels
+                     (in degrees)    (in percent)
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0-&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0-&nbsp; 2%
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 2-&nbsp; 3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 3-&nbsp; 5%
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 4-&nbsp; 5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 6- 10%
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 6-&nbsp; 8&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 11- 15%
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 9- 11&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 16- 20%
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 12- 14&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 21- 25%
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 7&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 15- 90&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 26% and higher
+             1         0-  1             0-  2%
+             2         2-  3             3-  5%
+             3         4-  5             6- 10%
+             4         6-  8            11- 15%
+             5         9- 11            16- 20%
+             6        12- 14            21- 25%
+             7        15- 90            26% and higher
-&nbsp;&nbsp;&nbsp;&nbsp; The following color table works well with the above
-&nbsp;&nbsp;&nbsp;&nbsp; reclassification.
+     The following color table works well with the above
+     reclassification.
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; category&nbsp;&nbsp; red&nbsp;&nbsp; green&nbsp;&nbsp; blue
+          category   red   green   blue
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 179&nbsp;&nbsp;&nbsp; 179&nbsp;&nbsp;&nbsp;&nbsp; 179
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; 102&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; 153&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 128&nbsp;&nbsp;&nbsp; 153&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 204&nbsp;&nbsp;&nbsp; 179&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 128&nbsp;&nbsp;&nbsp;&nbsp; 51&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 51
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 255&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0
-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 7&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0</pre>
+             0       179    179     179
+             1         0    102       0
+             2         0    153       0
+             3       128    153       0
+             4       204    179       0
+             5       128     51      51
+             6       255      0       0
+             7         0      0       0</pre></div>
 <h2>NOTES</h2>
@@ -126,22 +127,27 @@
 cells in the elevation map. If the user really wants the elevation map
 resampled to the current region resolution, the -a flag should be specified.
-<p>The current mask is ignored.
+<p>
+The current mask is ignored.
-<p>The algorithm used to determine slope and aspect uses a 3x3 neighborhood
+<p>
+The algorithm used to determine slope and aspect uses a 3x3 neighborhood
 around each cell in the elevation file. Thus, it is not possible to determine
 slope and aspect for the cells adjacent to the edges in the elevation map
 layer. These cells are assigned a "zero slope" value (category 0) in both
 the slope and aspect raster map layers.
-<p>Horn's formula is used to find the derivatives in x and y directions.
+<p>
+Horn's formula is used to find the derivatives in x and y directions.
-<p>Only when using integer elevation models, the aspect is biased in 0,
+<p>
+Only when using integer elevation models, the aspect is biased in 0,
 45, 90, 180, 225, 270, 315, and 360 directions; i.e., the distribution
 of aspect categories is very uneven, with peaks at 0, 45,..., 360 categories.
 When working with floating point elevation models, no such aspect bias occurs.
-<p>Because most cells with a very small slope end up having category 0,
+<p>
+Because most cells with a very small slope end up having category 0,
 45, ..., 360, it is sometimes possible to reduce the bias in these directions
 by filtering out the aspect in areas where the terrain is almost flat. A new
 option <i>min_slp_allowed</i> was added to specify the minimum slope for which
@@ -150,6 +156,7 @@
 <h2>REFERENCE</h2>
 Horn, B. K. P. (1981). Hill Shading and the Reflectance Map, Proceedings
 of the IEEE, 69(1):14-47.
@@ -160,7 +167,8 @@
 <em><a href="r.rescale.html">r.rescale</a></em>
 <h2>AUTHORS</h2>
-Michael Shapiro, U.S.Army Construction Engineering Research Laboratory
-<p>Olga Waupotitsch, U.S.Army Construction Engineering Research Laboratory
+Michael Shapiro, U.S.Army Construction Engineering Research Laboratory<BR>
+Olga Waupotitsch, U.S.Army Construction Engineering Research Laboratory
+<p>
