[GRASS-SVN] r32717 - in grass/trunk/lib: gis vector/Vlib
svn_grass at osgeo.org
Tue Aug 12 06:06:33 EDT 2008
Author: glynn
Date: 2008-08-12 06:06:33 -0400 (Tue, 12 Aug 2008)
New Revision: 32717
grass/trunk/lib/gis/opencell.c
grass/trunk/lib/vector/Vlib/map.c
Fix handling of qualified map names
Modified: grass/trunk/lib/gis/opencell.c
--- grass/trunk/lib/gis/opencell.c 2008-08-12 10:05:05 UTC (rev 32716)
+++ grass/trunk/lib/gis/opencell.c 2008-08-12 10:06:33 UTC (rev 32717)
@@ -158,10 +158,18 @@
int MAP_NBYTES;
RASTER_MAP_TYPE MAP_TYPE;
struct Reclass reclass;
+ const char *xmapset;
/* make sure window is set */
G__init_window();
+ xmapset = G_find_cell2(name, mapset);
+ if (!xmapset) {
+ G_warning(_("Unable to find <%s@%s>"), name, mapset);
+ return -1;
+ mapset = xmapset;
/* Check for reclassification */
reclass_flag = G_get_reclass(name, mapset, &reclass);
@@ -943,15 +951,17 @@
int G_raster_map_is_fp(const char *name, const char *mapset)
char path[GPATH_MAX];
- if (G_find_cell2(name, mapset) == NULL) {
- G_warning(_("Unable to find <%s@%s>"), name, mapset);
+ if (!xmapset) {
+ G_warning(_("Unable to find '%s' in '%s'"), name, mapset);
return -1;
- G__file_name(path, "fcell", name, mapset);
+ G__file_name(path, "fcell", name, xmapset);
if (access(path, 0) == 0)
return 1;
- G__file_name(path, "g3dcell", name, mapset);
+ G__file_name(path, "g3dcell", name, xmapset);
return 1;
@@ -964,8 +974,6 @@
Determines if the raster map is floating point or integer. Returns
DCELL_TYPE for double maps, FCELL_TYPE for float maps, CELL_TYPE for
integer maps, -1 if error has occured
- This function just calls G_raster_map_type()!
\param name map name
\param mapset mapset where map <i>name</i> lives
@@ -974,38 +982,23 @@
RASTER_MAP_TYPE G_raster_map_type(const char *name, const char *mapset)
- return G_raster_map_type2(name, mapset);
- \brief Determine raster type (look but don't touch)
- See G_raster_map_type().
- \param name map name
- \param mapset mapset where map <i>name</i> lives
- \return raster data type
-RASTER_MAP_TYPE G_raster_map_type2(const char *name, const char *mapset)
- if (mapset) {
+ if (!xmapset) {
+ if (mapset && *mapset)
G_warning(_("Raster map <%s> not found in mapset <%s>"), name, mapset);
- else {
+ else
G_warning(_("Raster map <%s> not found"), name);
return -1;
- return G__check_fp_type(name, mapset);
+ return G__check_fp_type(name, xmapset);
return DCELL_TYPE;
@@ -1046,8 +1039,14 @@
int in_stat;
char *str, *str1;
RASTER_MAP_TYPE map_type;
- G__file_name_misc(path, "cell_misc", FORMAT_FILE, name, mapset);
+ if (!xmapset) {
+ return -1;
+ G__file_name_misc(path, "cell_misc", FORMAT_FILE, name, xmapset);
if (access(path, 0) != 0) {
G_warning(_("Unable to find '%s'"), path);
Modified: grass/trunk/lib/vector/Vlib/map.c
--- grass/trunk/lib/vector/Vlib/map.c 2008-08-12 10:05:05 UTC (rev 32716)
+++ grass/trunk/lib/vector/Vlib/map.c 2008-08-12 10:06:33 UTC (rev 32717)
@@ -166,6 +166,7 @@
GV_TOPO_ELEMENT, GV_SIDX_ELEMENT, GV_CIDX_ELEMENT,
NULL
dbDriver *driver;
@@ -174,13 +175,20 @@
if (Vect_legal_filename(out) < 0)
G_fatal_error(_("Vector map name is not SQL compliant"));
+ xmapset = G_find_vector2(in, mapset);
+ if (!xmapset) {
+ G_warning(_("Unable to find vector map <%s> in <%s>"), in, mapset);
+ return -1;
+ mapset = xmapset;
/* Delete old vector if it exists */
if (G_find_vector2(out, G_mapset())) {
G_warning(_("Vector map <%s> already exists and will be overwritten"),
out);
ret = Vect_delete(out);
if (ret != 0) {
- G_warning(_("Unable to delete vector map <%s>"), in);
+ G_warning(_("Unable to delete vector map <%s>"), out);
return -1;
