[GRASS-SVN] r32720 - grass-addons/gipe/i.eb.h_SEBAL01
svn_grass at osgeo.org
Tue Aug 12 07:31:15 EDT 2008
Author: ychemin
Date: 2008-08-12 07:31:14 -0400 (Tue, 12 Aug 2008)
New Revision: 32720
grass-addons/gipe/i.eb.h_SEBAL01/main.c
added auto search for wet/dry pixels
Modified: grass-addons/gipe/i.eb.h_SEBAL01/main.c
--- grass-addons/gipe/i.eb.h_SEBAL01/main.c 2008-08-12 10:12:02 UTC (rev 32719)
+++ grass-addons/gipe/i.eb.h_SEBAL01/main.c 2008-08-12 11:31:14 UTC (rev 32720)
@@ -72,7 +72,7 @@
struct Option *input_ea, *output;
struct Option *input_row_wet, *input_col_wet;
struct Option *input_row_dry, *input_col_dry;
- struct Flag *flag3;
+ struct Flag *flag2, *flag3;
RASTER_MAP_TYPE data_type_Rn;
RASTER_MAP_TYPE data_type_g0;
@@ -165,6 +165,10 @@
output->description= _("Name of output sensible heat flux layer [W/m2]");
/* Define the different flags */
+ flag2 = G_define_flag() ;
+ flag2->key = 'a' ;
+ flag2->description = _("Automatic wet/dry pixel (careful!)") ;
flag3 = G_define_flag() ;
flag3->key = 'c' ;
flag3->description = _("Dry/Wet pixels coordinates are in image projection, not row/col");
@@ -279,6 +283,110 @@
DCELL d_g0_dry;
DCELL d_t0dem_dry;
DCELL d_t0dem_wet;
+ if(flag2->answer){
+ /* THREAD 3 */
+ /* Process tempk min / max pixels */
+ /* Internal use only */
+ DCELL d_Rn_wet;
+ DCELL d_g0_wet;
+ DCELL d_Rn;
+ DCELL d_g0;
+ DCELL d_h0;
+ DCELL t0dem_min;
+ DCELL t0dem_max;
+ for (row = 0; row < nrows; row++){
+ DCELL d_t0dem;
+ G_percent(row,nrows,2);
+ if(G_get_raster_row(infd_t0dem,inrast_t0dem,row,data_type_t0dem)<0)
+ G_fatal_error(_("Could not read from <%s>"),t0dem);
+ if(G_get_raster_row(infd_Rn, inrast_Rn, row,data_type_Rn) < 0)
+ G_fatal_error(_("Could not read from <%s>"),Rn);
+ if(G_get_raster_row(infd_g0, inrast_g0, row,data_type_g0) < 0)
+ G_fatal_error(_("Could not read from <%s>"),g0);
+ /*process the data */
+ for (col=0; col < ncols; col++)
+ switch(data_type_t0dem){
+ case CELL_TYPE:
+ d_t0dem = (double) ((CELL *) inrast_t0dem)[col];
+ break;
+ case FCELL_TYPE:
+ d_t0dem = (double) ((FCELL *) inrast_t0dem)[col];
+ break;
+ case DCELL_TYPE:
+ d_t0dem = (double) ((DCELL *) inrast_t0dem)[col];
+ break;
+ switch(data_type_Rn){
+ case CELL_TYPE:
+ d_Rn = (double) ((CELL *) inrast_Rn)[col];
+ break;
+ case FCELL_TYPE:
+ d_Rn = (double) ((FCELL *) inrast_Rn)[col];
+ break;
+ case DCELL_TYPE:
+ d_Rn = (double) ((DCELL *) inrast_Rn)[col];
+ break;
+ switch(data_type_g0){
+ case CELL_TYPE:
+ d_g0 = (double) ((CELL *) inrast_g0)[col];
+ break;
+ case FCELL_TYPE:
+ d_g0 = (double) ((FCELL *) inrast_g0)[col];
+ break;
+ case DCELL_TYPE:
+ d_g0 = (double) ((DCELL *) inrast_g0)[col];
+ break;
+ if(G_is_d_null_value(&d_t0dem)||
+ G_is_d_null_value(&d_Rn)||
+ G_is_d_null_value(&d_g0)){
+ /* do nothing */
+ }else{
+ if(d_t0dem<=250.0){
+ /* do nothing */
+ } else {
+ d_h0=d_Rn-d_g0;
+ if(d_t0dem<t0dem_min&&
+ d_Rn>0.0&&d_g0>0.0&&d_h0>0.0&&
+ d_h0<100.0){
+ t0dem_min=d_t0dem;
+ d_t0dem_wet=d_t0dem;
+ d_Rn_wet=d_Rn;
+ d_g0_wet=d_g0;
+ m_col_wet=col;
+ m_row_wet=row;
+ if(d_t0dem>t0dem_max&&
+ d_Rn>0.0&&d_g0>0.0&&d_h0>100.0&&
+ d_h0<500.0){
+ t0dem_max=d_t0dem;
+ d_t0dem_dry=d_t0dem;
+ d_Rn_dry=d_Rn;
+ d_g0_dry=d_g0;
+ m_col_dry=col;
+ m_row_dry=row;
+ G_message("row_wet=%d\tcol_wet=%d\n",row_wet,col_wet);
+ G_message("row_dry=%d\tcol_dry=%d\n",row_dry,col_dry);
+ G_message("g0_wet=%f\n",d_g0_wet);
+ G_message("Rn_wet=%f\n",d_Rn_wet);
+ G_message("LE_wet=%f\n",d_Rn_wet-d_g0_wet);
+ G_message("t0dem_dry=%f\n",d_t0dem_dry);
+ G_message("rnet_dry=%f\n",d_Rn_dry);
+ G_message("g0_dry=%f\n",d_g0_dry);
+ G_message("h0_dry=%f\n",d_Rn_dry-d_g0_dry);
+ } /* END OF FLAG2 */
+ /* MANUAL T0DEM WET/DRY PIXELS */
/*DRY PIXEL*/
if(flag3->answer){
/*Calculate coordinates of row/col from projected ones*/
